[GRASS-SVN] r58543 - in grass/trunk/gui/wxpython: animation core lmgr
svn_grass at osgeo.org
Sat Dec 28 20:35:32 PST 2013
Author: annakrat
Date: 2013-12-28 20:35:32 -0800 (Sat, 28 Dec 2013)
New Revision: 58543
grass/trunk/gui/wxpython/animation/controller.py
grass/trunk/gui/wxpython/animation/data.py
grass/trunk/gui/wxpython/animation/dialogs.py
grass/trunk/gui/wxpython/animation/nviztask.py
grass/trunk/gui/wxpython/animation/provider.py
grass/trunk/gui/wxpython/core/layerlist.py
grass/trunk/gui/wxpython/core/workspace.py
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI/animation: enable volume animation; volumes now saved also in workspace file
Modified: grass/trunk/gui/wxpython/animation/controller.py
--- grass/trunk/gui/wxpython/animation/controller.py 2013-12-28 16:33:57 UTC (rev 58542)
+++ grass/trunk/gui/wxpython/animation/controller.py 2013-12-29 04:35:32 UTC (rev 58543)
@@ -397,7 +397,7 @@
for anim in animationData:
for layer in anim.layerList:
if layer.active and hasattr(layer, 'maps'):
- if layer.mapType in ('strds', 'stvds'):
+ if layer.mapType in ('strds', 'stvds', 'str3ds'):
stds += 1
else:
maps += 1
Modified: grass/trunk/gui/wxpython/animation/data.py
--- grass/trunk/gui/wxpython/animation/data.py 2013-12-28 16:33:57 UTC (rev 58542)
+++ grass/trunk/gui/wxpython/animation/data.py 2013-12-29 04:35:32 UTC (rev 58543)
@@ -76,7 +76,7 @@
timeseriesList = []
for layer in layerList:
timeseriesList.append((layer.name, layer.mapType))
self._firstStdsNameType = layer.name, layer.mapType
else:
@@ -189,7 +189,7 @@
or series of maps."""
def __init__(self):
Layer.__init__(self)
- self._mapTypes.extend(['strds', 'stvds'])
+ self._mapTypes.extend(['strds', 'stvds', 'str3ds'])
self._maps = []
tgis.init()
@@ -197,14 +197,14 @@
if not self.hidden:
if self._mapType is None:
raise ValueError("To set layer name, the type of layer must be specified.")
- if self._mapType in ('strds', 'stvds'):
+ if self._mapType in ('strds', 'stvds', 'str3ds'):
try:
name = validateTimeseriesName(name, self._mapType)
self._maps = getRegisteredMaps(name, self._mapType)
except (GException, gcore.ScriptError), e:
raise ValueError(str(e))
else:
- self._maps = validateMapNames(name.split(','), self._internalTypes[self._mapType])
+ self._maps = validateMapNames(name.split(','), self._mapType)
self._name = name
self.label = name
Modified: grass/trunk/gui/wxpython/animation/dialogs.py
--- grass/trunk/gui/wxpython/animation/dialogs.py 2013-12-28 16:33:57 UTC (rev 58542)
+++ grass/trunk/gui/wxpython/animation/dialogs.py 2013-12-29 04:35:32 UTC (rev 58543)
@@ -434,10 +434,6 @@
else:
cmd = ['d.legend', 'at=5,50,2,5']
- mapName = self._getLegendMapHint()
- if mapName:
- cmd.append("map=%s" % mapName)
GUI(parent=self, modal=True).ParseCommand(cmd=cmd,
completed=(self.GetOptData, '', ''))
@@ -1102,6 +1098,7 @@
SIMPLE_LMGR_TB_TOP | SIMPLE_LMGR_STDS,
toolbarCls=AnimSimpleLmgrToolbar, modal=True):
SimpleLayerManager.__init__(self, parent, layerList, lmgrStyle, toolbarCls, modal)
+ self._3dActivated = False
def OnAddStds(self, event):
"""!Opens dialog for specifying temporal dataset.
@@ -1113,7 +1110,7 @@
event.Skip()
def SetStdsProperties(self, layer):
- dlg = AddTemporalLayerDialog(parent=self, layer=layer)
+ dlg = AddTemporalLayerDialog(parent=self, layer=layer, volume=self._3dActivated)
# first get hidden property, it's altered afterwards
hidden = layer.hidden
dlg.CenterOnParent()
@@ -1144,11 +1141,13 @@
"""!Activates/deactivates certain tool depending on 2D/3D view."""
self._toolbar.EnableTools(['addRaster', 'addVector',
'opacity', 'up', 'down'], not activate)
+ self._3dActivated = activate
class AddTemporalLayerDialog(wx.Dialog):
"""!Dialog for adding space-time dataset/ map series."""
- def __init__(self, parent, layer, title=_("Add space-time dataset layer")):
+ def __init__(self, parent, layer, volume=False,
+ title=_("Add space-time dataset layer")):
wx.Dialog.__init__(self, parent=parent, title=title)
self.layer = layer
@@ -1168,8 +1167,13 @@
types = [('rast', _("Multiple raster maps")),
('vect', _("Multiple vector maps")),
+ ('rast3d', _("Multiple 3D raster maps")),
('strds', _("Space time raster dataset")),
- ('stvds', _("Space time vector dataset"))]
+ ('stvds', _("Space time vector dataset")),
+ ('str3ds', _("Space time 3D raster dataset"))]
+ if not volume:
+ del types[5]
+ del types[2]
self._types = dict(types)
self.tchoice = wx.Choice(parent=self)
@@ -1237,7 +1241,7 @@
if typeName:
self.tchoice.SetStringSelection(self._types[typeName])
self.tselect.SetType(typeName)
- if typeName in ('strds', 'stvds'):
+ if typeName in ('strds', 'stvds', 'str3ds'):
self.tselect.SetType(typeName, multiple=False)
self.addManyMapsButton.Disable()
else:
@@ -1247,7 +1251,7 @@
self.tselect.SetValue('')
else:
typeName = self.tchoice.GetClientData(self.tchoice.GetSelection())
else:
@@ -1264,8 +1268,10 @@
cmd.append('d.rast')
elif self._mapType in ('vect', 'stvds'):
cmd.append('d.vect')
+ elif self._mapType in ('rast3d', 'str3ds'):
+ cmd.append('d.rast3d')
if self._name:
- if self._mapType in ('rast', 'vect'):
+ if self._mapType in ('rast', 'vect', 'rast3d'):
cmd.append('map={}'.format(self._name.split(',')[0]))
else:
try:
@@ -1281,7 +1287,13 @@
dlg = MapLayersDialog(self, title=_("Select raster/vector maps."))
dlg.applyAddingMapLayers.connect(lambda mapLayers:
self.tselect.SetValue(','.join(mapLayers)))
- index = 0 if self._mapType == 'rast' else 1
+ if self._mapType == 'rast':
+ index = 0
+ elif self._mapType == 'vect':
+ index = 2
+ else: # rast3d
+ index = 1
dlg.layerType.SetSelection(index)
dlg.LoadMapLayers(dlg.GetLayerType(cmd=True),
dlg.mapset.GetStringSelection())
Modified: grass/trunk/gui/wxpython/animation/nviztask.py
--- grass/trunk/gui/wxpython/animation/nviztask.py 2013-12-28 16:33:57 UTC (rev 58542)
+++ grass/trunk/gui/wxpython/animation/nviztask.py 2013-12-29 04:35:32 UTC (rev 58543)
@@ -61,7 +61,9 @@
for display in root.displays:
if display['viewMode'] == '3d':
self.region['w'], self.region['s'],\
- self.region['e'], self.region['n'] = display['extent']
+ self.region['e'], self.region['n'],\
+ self.region['b'], self.region['t'] = display['extent']
+ self.region['tbres'] = display['tbres']
def _processLayers(self, layers):
for layer in layers:
@@ -77,6 +79,8 @@
if 'surface' in layer['nviz']:
self._processSurface(layer['nviz']['surface'], mapName=layerName)
+ if 'volume' in layer['nviz']:
+ self._processVolume(layer['nviz']['volume'], mapName=layerName)
def _processSurface(self, surface, mapName):
self._setMultiTaskParam('elevation_map', mapName)
@@ -124,6 +128,68 @@
value = ','.join(pos)
self._setMultiTaskParam('surface_position', value)
+ def _processVolume(self, volume, mapName):
+ self._setMultiTaskParam('volume', mapName)
+ if volume['draw']['box']['enabled']:
+ self.task.set_flag('b', True)
+ # isosurfaces
+ isosurfaces = volume['isosurface']
+ if isosurfaces:
+ res_value = volume['draw']['resolution']['isosurface']['value']
+ self._setMultiTaskParam('volume_resolution', res_value)
+ for isosurface in isosurfaces:
+ attributes = ('topo', 'color', 'shine', 'transp')
+ parameters = ((None, 'isosurf_level'),
+ ('isosurf_color_map', 'isosurf_color_value'),
+ ('isosurf_shininess_map', 'isosurf_shininess_value'),
+ ('isosurf_transparency_map', 'isosurf_transparency_value'))
+ for attr, params in zip(attributes, parameters):
+ mapname = None
+ const = None
+ if attr in isosurface:
+ if isosurface[attr]['map']:
+ mapname = isosurface[attr]['value']
+ else:
+ const = float(isosurface[attr]['value'])
+ else:
+ if attr == 'transp':
+ const = 0
+ elif attr == 'color':
+ mapname = mapName
+ if mapname:
+ self._setMultiTaskParam(params[0], mapname)
+ else:
+ if attr == 'topo':
+ # TODO: we just assume it's the first volume, what to do else?
+ self._setMultiTaskParam(params[1], '1:' + str(const))
+ else:
+ self._setMultiTaskParam(params[1], const)
+ if isosurface['inout']['value']:
+ self.task.set_flag('n', True)
+ # slices
+ slices = volume['slice']
+ if slices:
+ res_value = volume['draw']['resolution']['slice']['value']
+ for slice_ in slices:
+ self._setMultiTaskParam('slice_transparency', slice_['transp']['value'])
+ axis = slice_['position']['axis']
+ self._setMultiTaskParam('slice', '1:' + 'xyz'[axis])
+ pos = slice_['position']
+ coords = pos['x1'], pos['x2'], pos['y1'], pos['y2'], pos['z1'], pos['z2']
+ self._setMultiTaskParam('slice_position', ','.join([str(c) for c in coords]))
+ # position
+ pos = []
+ for coor in ('x', 'y', 'z'):
+ pos.append(str(volume['position'][coor]))
+ value = ','.join(pos)
+ self._setMultiTaskParam('volume_position', value)
def _processState(self, state):
color = state['view']['background']['color']
self.task.set_param('bgcolor', self._join(color, delim=':'))
@@ -163,7 +229,7 @@
# params = self.task.get_list_params()
# parameter with 'map' name
# params = filter(lambda x: 'map' in x, params)
- return ('elevation_map', 'color_map', 'vline', 'vpoint')
+ return ('elevation_map', 'color_map', 'vline', 'vpoint', 'volume')
def GetCommandSeries(self, layerList, paramName):
commands = []
Modified: grass/trunk/gui/wxpython/animation/provider.py
--- grass/trunk/gui/wxpython/animation/provider.py 2013-12-28 16:33:57 UTC (rev 58542)
+++ grass/trunk/gui/wxpython/animation/provider.py 2013-12-29 04:35:32 UTC (rev 58543)
@@ -202,7 +202,7 @@
self.compositionFinished.emit()
if self._cmds3D:
for cmd in self._cmds3D:
- self._bitmapPool[HashCmd(cmd)] = \
+ self._bitmapPool[HashCmds([cmd])] = \
wx.Bitmap(GetFileFromCmd(self._tempDir, cmd))
self.mapsLoaded.emit()
@@ -311,7 +311,9 @@
q = Queue()
# The separate render process
if cmd[0] == 'm.nviz.image':
- p = Process(target=self.RenderProcess3D, args=(cmd, regionFor3D, bgcolor, q))
+ p = Process(target=RenderProcess3D,
+ args=(self.imageWidth, self.imageHeight, self._tempDir,
+ cmd, regionFor3D, bgcolor, q))
else:
p = Process(target=RenderProcess2D,
args=(self.imageWidth, self.imageHeight, self._tempDir, cmd, bgcolor, q))
@@ -489,9 +491,9 @@
filename = GetFileFromCmd(tempDir, cmd)
- os.environ['GRASS_REGION'] = gcore.region_env(**region)
+ os.environ['GRASS_REGION'] = gcore.region_env(region3d=True, **region)
+ Debug.msg(1, "Render image to file " + str(filename))
- Debug.msg(1, "Render image to file " + str(filename))
cmdTuple = CmdToTuple(cmd)
cmdTuple[1]['output'] = os.path.splitext(filename)[0]
# set size
Modified: grass/trunk/gui/wxpython/core/layerlist.py
--- grass/trunk/gui/wxpython/core/layerlist.py 2013-12-28 16:33:57 UTC (rev 58542)
+++ grass/trunk/gui/wxpython/core/layerlist.py 2013-12-29 04:35:32 UTC (rev 58543)
@@ -191,7 +191,7 @@
self._mapTypes = ['rast', 'vect', 'rast3d']
self._internalTypes = {'rast': 'cell',
- 'vect': 'vect',
+ 'vect': 'vector',
'rast3d': 'grid3'}
def GetName(self):
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py 2013-12-28 16:33:57 UTC (rev 58542)
+++ grass/trunk/gui/wxpython/core/workspace.py 2013-12-29 04:35:32 UTC (rev 58543)
@@ -25,6 +25,9 @@
from core.gcmd import EncodeString, GetDefaultEncoding
from nviz.main import NvizSettings
+from grass.script import core as gcore
class ProcessWorkspaceFile:
def __init__(self, tree):
"""!A ElementTree handler for the GXW XML file, as defined in
@@ -149,6 +152,7 @@
"pos" : pos,
"size" : size,
"extent" : extent,
+ "tbres" : display.get('tbres', '0'),
"alignExtent" : bool(int(display.get('alignExtent', "0"))),
"constrainRes" : bool(int(display.get('constrainRes', "0"))),
"projection" : projection,
@@ -275,175 +279,295 @@
# init nviz layer properties
nviz = {}
- if node_nviz.find('surface') is not None: # -> raster
+ if node_nviz.find('surface') is not None: # -> raster
nviz['surface'] = {}
for sec in ('attribute', 'draw', 'position'):
nviz['surface'][sec] = {}
+ self.__processLayerNvizSurface(nviz, node_nviz.find('surface'))
+ elif node_nviz.find('volume') is not None: # -> raster
+ nviz['volume'] = {}
+ for sec in ('attribute', 'draw', 'position'):
+ nviz['volume'][sec] = {}
+ self.__processLayerNvizVolume(nviz, node_nviz.find('volume'))
elif node_nviz.find('vlines') is not None or \
- node_nviz.find('vpoints') is not None: # -> vector
+ node_nviz.find('vpoints') is not None: # -> vector
nviz['vector'] = {}
for sec in ('lines', 'points'):
nviz['vector'][sec] = {}
- if 'surface' in nviz:
- node_surface = node_nviz.find('surface')
- # attributes
- for attrb in node_surface.findall('attribute'):
- tagName = str(attrb.tag)
- attrbName = attrb.get('name', '')
- dc = nviz['surface'][tagName][attrbName] = {}
- if attrb.get('map', '0') == '0':
- dc['map'] = False
- else:
- dc['map'] = True
- value = self.__getNodeText(attrb, 'value')
+ if node_nviz.find('vlines'):
+ self.__processLayerNvizVectorLines(nviz, node_nviz.find('vlines'))
+ if node_nviz.find('vpoints'):
+ self.__processLayerNvizVectorPoints(nviz, node_nviz.find('vpoints'))
+ return nviz
+ def __processLayerNvizSurface(self, nvizData, nodeSurface):
+ """!Process 3D layer settings - surface
+ @param nodeData nviz data dict
+ @param nodeSurface nviz surface node
+ # attributes
+ for attrb in nodeSurface.findall('attribute'):
+ tagName = str(attrb.tag)
+ attrbName = attrb.get('name', '')
+ dc = nvizData['surface'][tagName][attrbName] = {}
+ if attrb.get('map', '0') == '0':
+ dc['map'] = False
+ else:
+ dc['map'] = True
+ value = self.__getNodeText(attrb, 'value')
+ try:
+ dc['value'] = int(value)
+ except ValueError:
try:
- dc['value'] = int(value)
+ dc['value'] = float(value)
except ValueError:
- try:
- dc['value'] = float(value)
- except ValueError:
- dc['value'] = str(value)
+ dc['value'] = str(value)
+ # draw
+ node_draw = nodeSurface.find('draw')
+ if node_draw is not None:
+ tagName = str(node_draw.tag)
+ nvizData['surface'][tagName]['all'] = False
+ nvizData['surface'][tagName]['mode'] = {}
+ nvizData['surface'][tagName]['mode']['value'] = -1 # to be calculated
+ nvizData['surface'][tagName]['mode']['desc'] = {}
+ nvizData['surface'][tagName]['mode']['desc']['shading'] = \
+ str(node_draw.get('shading', ''))
+ nvizData['surface'][tagName]['mode']['desc']['style'] = \
+ str(node_draw.get('style', ''))
+ nvizData['surface'][tagName]['mode']['desc']['mode'] = \
+ str(node_draw.get('mode', ''))
+ # resolution
+ for node_res in node_draw.findall('resolution'):
+ resType = str(node_res.get('type', ''))
+ if 'resolution' not in nvizData['surface']['draw']:
+ nvizData['surface']['draw']['resolution'] = {}
+ value = int(self.__getNodeText(node_res, 'value'))
+ nvizData['surface']['draw']['resolution'][resType] = value
+ # wire-color
+ node_wire_color = node_draw.find('wire_color')
+ if node_wire_color is not None:
+ nvizData['surface']['draw']['wire-color'] = {}
+ value = str(self.__getNodeText(node_wire_color, 'value'))
+ nvizData['surface']['draw']['wire-color']['value'] = value
+ # position
+ node_pos = nodeSurface.find('position')
+ if node_pos is not None:
+ dc = nvizData['surface']['position']
+ for coor in ['x', 'y', 'z']:
+ node = node_pos.find(coor)
+ if node is None:
+ continue
+ value = int(self.__getNodeText(node_pos, coor))
+ dc[coor] = value
+ def __processLayerNvizVolume(self, nvizData, nodeVolume):
+ """!Process 3D layer settings - volume
+ @param nodeVolume nviz volume node
+ # attributes
+ for attrb in nodeVolume.findall('attribute'):
+ dc = nvizData['volume'][tagName][attrbName] = {}
+ if attrb.get('map') == '0':
+ dc['map'] = False
+ elif attrb.get('map') == '1':
+ dc['map'] = True
+ else:
+ dc['map'] = None
+ try:
+ try:
+ # draw
+ node_draw = nodeVolume.find('draw')
+ node_box = node_draw.find('box')
+ if node_box is not None:
+ nvizData['volume']['draw']['box'] = {}
+ enabled = bool(int(self.__getNodeText(node_box, 'enabled')))
+ nvizData['volume']['draw']['box']['enabled'] = enabled
+ node_mode = node_draw.find('mode')
+ if node_mode is not None:
+ nvizData['volume']['draw']['mode'] = {}
+ desc = self.__getNodeText(node_mode, 'desc')
+ value = int(self.__getNodeText(node_mode, 'value'))
+ nvizData['volume']['draw']['mode']['desc'] = desc
+ nvizData['volume']['draw']['mode']['value'] = value
+ node_res = node_draw.find('resolution')
+ if node_res is not None:
+ nvizData['volume']['draw']['resolution'] = {}
+ for vol_type in ('isosurface', 'slice'):
+ nd = node_res.find(vol_type)
+ value = int(self.__getNodeText(nd, 'value'))
+ nvizData['volume']['draw']['resolution'][vol_type] = {'value': value}
+ node_shading = node_draw.find('shading')
+ if node_shading is not None:
+ nvizData['volume']['draw']['shading'] = {}
+ nd = node_shading.find(vol_type)
+ desc = self.__getNodeText(nd, 'desc')
+ nvizData['volume']['draw']['shading'][vol_type] = {'value': value, 'desc': desc}
+ nvizData['volume']['isosurface'] = []
+ for isosurfaceNode in nodeVolume.findall('isosurface'):
+ isoDict = {}
+ for att in ('topo', 'transp', 'shine', 'color'):
+ attNode = isosurfaceNode.find(att)
+ if attNode is not None:
+ isMap = attNode.find('map').text
+ value = attNode.find('value').text
+ if not isMap:
+ isoDict[att] = {'map': None}
+ isoDict[att]['value'] = float(value)
+ elif isMap == '1':
+ isoDict[att] = {'map': True}
+ isoDict[att]['value'] = value
+ else:
+ isoDict[att] = {'map': False}
+ inout = isosurfaceNode.find('inout')
+ if inout is not None:
+ isoDict['inout'] = {'value': int(float(inout.find('value').text))}
+ nvizData['volume']['isosurface'].append(isoDict)
- # draw
- node_draw = node_surface.find('draw')
- if node_draw is not None:
- tagName = str(node_draw.tag)
- nviz['surface'][tagName]['all'] = False
- nviz['surface'][tagName]['mode'] = {}
- nviz['surface'][tagName]['mode']['value'] = -1 # to be calculated
- nviz['surface'][tagName]['mode']['desc'] = {}
- nviz['surface'][tagName]['mode']['desc']['shading'] = \
- str(node_draw.get('shading', ''))
- nviz['surface'][tagName]['mode']['desc']['style'] = \
- str(node_draw.get('style', ''))
- nviz['surface'][tagName]['mode']['desc']['mode'] = \
- str(node_draw.get('mode', ''))
- # resolution
- for node_res in node_draw.findall('resolution'):
- resType = str(node_res.get('type', ''))
- if 'resolution' not in nviz['surface']['draw']:
- nviz['surface']['draw']['resolution'] = {}
- value = int(self.__getNodeText(node_res, 'value'))
- nviz['surface']['draw']['resolution'][resType] = value
- # wire-color
- node_wire_color = node_draw.find('wire_color')
- if node_wire_color is not None:
- nviz['surface']['draw']['wire-color'] = {}
- value = str(self.__getNodeText(node_wire_color, 'value'))
- nviz['surface']['draw']['wire-color']['value'] = value
- # position
- node_pos = node_surface.find('position')
- if node_pos is not None:
- dc = nviz['surface']['position'] = {}
- for coor in ['x', 'y', 'z']:
- node = node_pos.find(coor)
- if node is None:
- continue
- value = int(self.__getNodeText(node_pos, coor))
- dc[coor] = value
- elif 'vector' in nviz:
- # vpoints
- node_vpoints = node_nviz.find('vpoints')
- if node_vpoints is not None:
- marker = str(node_vpoints.get('marker', ''))
- markerId = list(UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'marker'], internal=True)).index(marker)
- nviz['vector']['points']['marker'] = { 'value' : markerId }
- node_mode = node_vpoints.find('mode')
- if node_mode is not None:
- nviz['vector']['points']['mode'] = {}
- nviz['vector']['points']['mode']['type'] = str(node_mode.get('type', 'surface'))
- nviz['vector']['points']['mode']['surface'] = {}
- nviz['vector']['points']['mode']['surface']['value'] = []
- nviz['vector']['points']['mode']['surface']['show'] = []
- # map
- for node_map in node_mode.findall('map'):
- nviz['vector']['points']['mode']['surface']['value'].append(
- self.__processLayerNvizNode(node_map, 'name', str))
- nviz['vector']['points']['mode']['surface']['show'].append(bool(
- self.__processLayerNvizNode(node_map, 'checked', int)))
- # color
- self.__processLayerNvizNode(node_vpoints, 'color', str,
- nviz['vector']['points'])
- # width
- self.__processLayerNvizNode(node_vpoints, 'width', int,
- # height
- self.__processLayerNvizNode(node_vpoints, 'height', float,
- # height
- self.__processLayerNvizNode(node_vpoints, 'size', float,
- # thematic
- node_thematic = node_vpoints.find('thematic')
- thematic = nviz['vector']['points']['thematic'] = {}
- thematic['rgbcolumn'] = self.__processLayerNvizNode(node_thematic, 'rgbcolumn', str)
- thematic['sizecolumn'] = self.__processLayerNvizNode(node_thematic, 'sizecolumn', str)
- for col in ('rgbcolumn', 'sizecolumn'):
- if thematic[col] == 'None':
- thematic[col] = None
- thematic['layer'] = self.__processLayerNvizNode(node_thematic, 'layer', int)
- for use in ('usecolor', 'usesize', 'usewidth'):
- if node_thematic.get(use, ''):
- thematic[use] = int(node_thematic.get(use, '0'))
- # vlines
- node_vlines = node_nviz.find('vlines')
- if node_vlines is not None:
- node_mode = node_vlines.find('mode')
- nviz['vector']['lines']['mode'] = {}
- nviz['vector']['lines']['mode']['type'] = str(node_mode.get('type', ''))
- nviz['vector']['lines']['mode']['surface'] = {}
- nviz['vector']['lines']['mode']['surface']['value'] = []
- nviz['vector']['lines']['mode']['surface']['show'] = []
- # map
- nviz['vector']['lines']['mode']['surface']['value'].append(
- nviz['vector']['lines']['mode']['surface']['show'].append(bool(
- # color
- self.__processLayerNvizNode(node_vlines, 'color', str,
- nviz['vector']['lines'])
- # width
- self.__processLayerNvizNode(node_vlines, 'width', int,
- # height
- self.__processLayerNvizNode(node_vlines, 'height', int,
- # thematic
- node_thematic = node_vlines.find('thematic')
- thematic = nviz['vector']['lines']['thematic'] = {}
- return nviz
+ nvizData['volume']['slice'] = []
+ for sliceNode in nodeVolume.findall('slice'):
+ sliceDict = {}
+ sliceDict['transp'] = {'value': int(sliceNode.find('transp').find('value').text)}
+ sliceDict['position'] = {}
+ for child in sliceNode.find('position'):
+ if child.tag == 'axis':
+ sliceDict['position'][child.tag] = int(child.text)
+ else:
+ sliceDict['position'][child.tag] = float(child.text)
+ nvizData['volume']['slice'].append(sliceDict)
+ # position
+ node_pos = nodeVolume.find('position')
+ dc = nvizData['volume']['position']
+ if node is None:
+ continue
+ dc[coor] = value
+ def __processLayerNvizVectorPoints(self, nvizData, nodePoints):
+ """!Process 3D layer settings - vector points
+ @param nodeVector nviz vector points node
+ marker = str(nodePoints.get('marker', ''))
+ markerId = list(UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'marker'], internal=True)).index(marker)
+ nvizData['vector']['points']['marker'] = {'value': markerId}
+ node_mode = nodePoints.find('mode')
+ nvizData['vector']['points']['mode'] = {}
+ nvizData['vector']['points']['mode']['type'] = str(node_mode.get('type', 'surface'))
+ nvizData['vector']['points']['mode']['surface'] = {}
+ nvizData['vector']['points']['mode']['surface']['value'] = []
+ nvizData['vector']['points']['mode']['surface']['show'] = []
+ # map
+ for node_map in node_mode.findall('map'):
+ nvizData['vector']['points']['mode']['surface']['value'].append(
+ self.__processLayerNvizNode(node_map, 'name', str))
+ nvizData['vector']['points']['mode']['surface']['show'].append(bool(
+ self.__processLayerNvizNode(node_map, 'checked', int)))
+ # color
+ self.__processLayerNvizNode(nodePoints, 'color', str,
+ nvizData['vector']['points'])
+ # width
+ self.__processLayerNvizNode(nodePoints, 'width', int,
+ # height
+ self.__processLayerNvizNode(nodePoints, 'height', float,
+ # height
+ self.__processLayerNvizNode(nodePoints, 'size', float,
+ # thematic
+ node_thematic = nodePoints.find('thematic')
+ thematic = nvizData['vector']['points']['thematic'] = {}
+ thematic['rgbcolumn'] = self.__processLayerNvizNode(node_thematic, 'rgbcolumn', str)
+ thematic['sizecolumn'] = self.__processLayerNvizNode(node_thematic, 'sizecolumn', str)
+ for col in ('rgbcolumn', 'sizecolumn'):
+ if thematic[col] == 'None':
+ thematic[col] = None
+ thematic['layer'] = self.__processLayerNvizNode(node_thematic, 'layer', int)
+ for use in ('usecolor', 'usesize', 'usewidth'):
+ if node_thematic.get(use, ''):
+ thematic[use] = int(node_thematic.get(use, '0'))
+ def __processLayerNvizVectorLines(self, nvizData, nodeLines):
+ """!Process 3D layer settings - vector lines
+ @param nodeVector nviz vector lines node
+ node_mode = nodeLines.find('mode')
+ nvizData['vector']['lines']['mode'] = {}
+ nvizData['vector']['lines']['mode']['type'] = str(node_mode.get('type', ''))
+ nvizData['vector']['lines']['mode']['surface'] = {}
+ nvizData['vector']['lines']['mode']['surface']['value'] = []
+ nvizData['vector']['lines']['mode']['surface']['show'] = []
+ # map
+ nvizData['vector']['lines']['mode']['surface']['value'].append(
+ nvizData['vector']['lines']['mode']['surface']['show'].append(bool(
+ # color
+ self.__processLayerNvizNode(nodeLines, 'color', str,
+ nvizData['vector']['lines'])
+ # width
+ self.__processLayerNvizNode(nodeLines, 'width', int,
+ # height
+ self.__processLayerNvizNode(nodeLines, 'height', int,
+ # thematic
+ node_thematic = nodeLines.find('thematic')
+ thematic = nvizData['vector']['lines']['thematic'] = {}
def __processLayerNvizNode(self, node, tag, cast, dc = None):
"""!Process given tag nviz/vector"""
node_tag = node.find(tag)
@@ -598,6 +722,7 @@
dispName = self.lmgr.GetLayerNotebook().GetPageText(page)
mapTree = self.lmgr.GetLayerNotebook().GetPage(page).maptree
region = mapTree.GetMap().GetCurrentRegion()
+ compRegion = gcore.region(region3d=True)
mapdisp = mapTree.GetMapDisplay()
displayPos = mapdisp.GetPosition()
@@ -613,7 +738,8 @@
'alignExtent="%d" '
'constrainRes="%d" '
'dim="%d,%d,%d,%d" '
- 'extent="%f,%f,%f,%f" '
+ 'extent="%f,%f,%f,%f,%f,%f" '
+ 'tbres="%f" ' # needed only for animation tool
'viewMode="%s" >\n' % (' ' * self.indent,
dispName.encode('utf8'),
int(mapdisp.mapWindowProperties.autoRender),
@@ -629,6 +755,9 @@
region['s'],
region['e'],
region['n'],
+ compRegion['b'],
+ compRegion['t'],
+ compRegion['tbres'],
viewmode
# projection statusbar info
@@ -749,6 +878,8 @@
self.file.write('%s<nviz>\n' % (' ' * self.indent))
if maplayer.type == 'raster':
self.__writeNvizSurface(nviz['surface'])
+ if maplayer.type == '3d-raster':
+ self.__writeNvizVolume(nviz['volume'])
elif maplayer.type == 'vector':
self.__writeNvizVector(nviz['vector'])
self.file.write('%s</nviz>\n' % (' ' * self.indent))
@@ -830,6 +961,134 @@
self.file.write('%s</surface>\n' % (' ' * self.indent))
self.indent -= 4
+ def __writeNvizVolume(self, data):
+ """!Save Nviz volume layer properties to workspace
+ @param data Nviz layer properties
+ if 'object' not in data: # skip disabled
+ return
+ self.indent += 4
+ self.file.write('%s<volume>\n' % (' ' * self.indent))
+ self.indent += 4
+ for attrb in data.iterkeys():
+ if len(data[attrb]) < 1: # skip empty attributes
+ continue
+ if attrb == 'object':
+ continue
+ if attrb == 'attribute':
+ for name in data[attrb].iterkeys():
+ # surface attribute
+ if data[attrb][name]['map'] is None:
+ continue
+ self.file.write('%s<%s name="%s" map="%d">\n' %
+ (' ' * self.indent, attrb, name, data[attrb][name]['map']))
+ self.indent += 4
+ self.file.write('%s<value>%s</value>\n' % (' ' * self.indent, data[attrb][name]['value']))
+ self.indent -= 4
+ # end tag
+ self.file.write('%s</%s>\n' % (' ' * self.indent, attrb))
+ # draw mode
+ if attrb == 'draw':
+ self.file.write('%s<%s>\n' % (' ' * self.indent, attrb))
+ self.indent += 4
+ for att in ('resolution', 'shading'):
+ if att in data[attrb]:
+ self.file.write('%s<%s>\n' % (' ' * self.indent, att))
+ for type in ('isosurface', 'slice'):
+ self.indent += 4
+ self.file.write('%s<%s>\n' % (' ' * self.indent, type))
+ self.indent += 4
+ self.file.write('%s<value>%d</value>\n' % (' ' * self.indent,
+ data[attrb][att][type]['value']))
+ if att == 'shading':
+ self.file.write('%s<desc>%s</desc>\n' % (' ' * self.indent,
+ data[attrb][att][type]['desc']))
+ self.indent -= 4
+ self.file.write('%s</%s>\n' % (' ' * self.indent, type))
+ self.indent -= 4
+ self.file.write('%s</%s>\n' % (' ' * self.indent, att))
+ if 'box' in data[attrb]:
+ self.file.write('%s<box>\n' % (' ' * self.indent))
+ self.indent += 4
+ self.file.write('%s<enabled>%d</enabled>\n' % (' ' * self.indent, data[attrb]['box']['enabled']))
+ self.indent -= 4
+ self.file.write('%s</box>\n' % (' ' * self.indent))
+ if 'mode' in data[attrb]:
+ self.file.write('%s<mode>\n' % (' ' * self.indent))
+ self.indent += 4
+ self.file.write('%s<desc>%s</desc>\n' % (' ' * self.indent, data[attrb]['mode']['desc']))
+ self.file.write('%s<value>%d</value>\n' % (' ' * self.indent, data[attrb]['mode']['value']))
+ self.indent -= 4
+ self.file.write('%s</mode>\n' % (' ' * self.indent))
+ self.indent -= 4
+ # position
+ elif attrb == 'position':
+ for tag in ('x', 'y', 'z'):
+ self.indent += 4
+ self.file.write('%s<%s>%d</%s>\n' % (' ' * self.indent, tag,
+ data[attrb].get(tag, 0), tag))
+ self.indent -= 4
+ if attrb == 'isosurface':
+ for isosurface in data[attrb]:
+ for name in isosurface.iterkeys():
+ self.indent += 4
+ self.file.write('%s<%s>\n' % (' ' * self.indent, name))
+ for att in isosurface[name].iterkeys():
+ if isosurface[name][att] is True:
+ val = '1'
+ elif isosurface[name][att] is False:
+ val = '0'
+ else:
+ try:
+ val = '%f' % float(isosurface[name][att])
+ val = '%s' % isosurface[name][att]
+ except TypeError: # None
+ val = ''
+ self.indent += 4
+ self.file.write(('%s<%s>' % (' ' * self.indent, att)) + val)
+ self.file.write('</%s>\n' % att)
+ self.indent -= 4
+ # end tag
+ self.file.write('%s</%s>\n' % (' ' * self.indent, name))
+ self.indent -= 4
+ if attrb == 'slice':
+ for slice_ in data[attrb]:
+ for name in slice_.iterkeys():
+ self.indent += 4
+ for att in slice_[name].iterkeys():
+ if att in ('map', 'update'):
+ continue
+ val = slice_[name][att]
+ self.indent += 4
+ self.file.write(('%s<%s>' % (' ' * self.indent, att)) + str(val))
+ self.indent -= 4
+ # end tag
+ self.indent -= 4
+ if attrb not in ('attribute', 'isosurface', 'slice'):
+ # end tag
+ self.indent -= 4
+ self.file.write('%s</volume>\n' % (' ' * self.indent))
+ self.indent -= 4
def __writeNvizVector(self, data):
"""!Save Nviz vector layer properties (lines/points) to workspace
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2013-12-28 16:33:57 UTC (rev 58542)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2013-12-29 04:35:32 UTC (rev 58543)
@@ -1158,7 +1158,7 @@
# set extent if defined
if display['extent']:
- w, s, e, n = display['extent']
+ w, s, e, n, b, t = display['extent']
region = maptree.Map.region = maptree.Map.GetRegion(w = w, s = s, e = e, n = n)
mapdisp.GetWindow().ResetZoomHistory()
mapdisp.GetWindow().ZoomHistory(region['n'],
