[GRASS-SVN] r58554 - grass/trunk/raster/r.sun
svn_grass at osgeo.org
Sun Dec 29 16:38:49 PST 2013
Author: neteler
Date: 2013-12-29 16:38:49 -0800 (Sun, 29 Dec 2013)
New Revision: 58554
grass/trunk/raster/r.sun/TODO
grass/trunk/raster/r.sun/r.sun.html
r.sun manual: update to NC dataset; TODO file updated
Modified: grass/trunk/raster/r.sun/TODO
--- grass/trunk/raster/r.sun/TODO 2013-12-30 00:10:47 UTC (rev 58553)
+++ grass/trunk/raster/r.sun/TODO 2013-12-30 00:38:49 UTC (rev 58554)
@@ -1,7 +1,5 @@
TODO
-11/2008: Integrate latest GRASS 7 API changes
Probably the sun position calculation shouldbe replaced
with
@@ -12,3 +10,25 @@
solpos.c from NREL and very precise.
MN 4/2001
+Update
+ http://grasswiki.osgeo.org/wiki/R.sun
+Fix http://trac.osgeo.org/grass/ticket/498
+pseudo-data test-case
+http://trac.osgeo.org/grass/ticket/498#comment:22
+#spearfish (further north than NC so more defined shadows)
+g.region -d
+r.mapcalc "undulates = (2 + sin( row() * 2 ) + cos( col() * 2 )) * 500"
+r.colors undulates color=bcyr
+nviz undulates
+DAY=355
+time r.sun elevin=undulates day=$DAY step=0.05 \
+ beam_rad=rad_test.und.355.beam \
+ diff_rad=rad_test.und.355.diff \
+ refl_rad=rad_test.und.355.refl
Modified: grass/trunk/raster/r.sun/r.sun.html
--- grass/trunk/raster/r.sun/r.sun.html 2013-12-30 00:10:47 UTC (rev 58553)
+++ grass/trunk/raster/r.sun/r.sun.html 2013-12-30 00:38:49 UTC (rev 58554)
@@ -253,19 +253,19 @@
<h2>EXAMPLES</h2>
-Spearfish example (considering also cast shadows):
+North Carolina example (considering also cast shadows):
<div class="code"><pre>
-g.region rast=elevation.dem -p
+g.region rast=elevation -p
-# calculate horizons
-# (we put a bufferzone of 10% of maxdistance around the study area)
-r.horizon elev_in=elevation.dem horizon_step=30 bufferzone=200 horizon=horangle distance_step=0.7 maxdistance=2000
+# calculate horizon angles (to speed up the subsequent r.sun calculation)
+r.horizon elev_in=elevation horizon_step=30 bufferzone=200 horizon=horangle \
+ maxdistance=5000
# slope + aspect
-r.slope.aspect elevation=elevation.dem aspect=aspect.dem slope=slope.dem
+r.slope.aspect elevation=elevation aspect=aspect.dem slope=slope.dem
-# calculate global radiation for day 180 at 14:00hrs
-r.sun elevation.dem horizon=horangle horizon_step=30 asp_in=aspect.dem \
+# calculate global radiation for day 180 at 14:00hrs, using r.horizon output
+r.sun elev_in=elevation horizon=horangle horizon_step=30 asp_in=aspect.dem \
slope_in=slope.dem glob_rad=global_rad day=180 time=14
</pre></div>
@@ -279,11 +279,11 @@
g.region rast=elev_ned_30m -p
# considering cast shadows
-r.sun elev_ned_30m lin=2.5 alb=0.2 day=172 \
+r.sun elev_in=elev_ned_30m lin=2.5 alb=0.2 day=172 \
beam_rad=b172 diff_rad=d172 \
refl_rad=r172 insol_time=it172
-d.mon x0
+d.mon wx0
# show irradiation raster map [Wh.m-2.day-1]
d.rast.leg b172
# show insolation time raster map [h]
@@ -340,7 +340,7 @@
<a href="http://www.grassbook.org/">r.sun script download</a>)
<li>
Page, J. ed. (1986). Prediction of solar radiation on inclined surfaces. Solar
-energy R&D in the European Community, series F – Solar radiation data,
+energy R&D in the European Community, series F - Solar radiation data,
Dordrecht (D. Reidel), 3, 71, 81-83.
<li>
Page, J., Albuisson, M., Wald, L. (2001). The European solar radiation atlas:
@@ -351,7 +351,7 @@
Solar energy, 68, 33-48.
<li>
Scharmer, K., Greif, J., eds., (2000). The European solar radiation atlas,
-Vol. 2: Database and exploitation software. Paris (Les Presses de l’ École
+Vol. 2: Database and exploitation software. Paris (Les Presses de l'École
des Mines).
<li>
Joint Research Centre: <a href="http://re.jrc.ec.europa.eu/pvgis/">GIS solar radiation database for Europe</a> and
