[GRASS-SVN] r58555 - grass/trunk/include
svn_grass at osgeo.org
Sun Dec 29 17:07:06 PST 2013
Author: huhabla
Date: 2013-12-29 17:07:06 -0800 (Sun, 29 Dec 2013)
New Revision: 58555
grass/trunk/include/temporal.h
C-Interface design approach of the temporal framework
Modified: grass/trunk/include/temporal.h
--- grass/trunk/include/temporal.h 2013-12-30 00:38:49 UTC (rev 58554)
+++ grass/trunk/include/temporal.h 2013-12-30 01:07:06 UTC (rev 58555)
@@ -1,11 +1,15 @@
#ifndef GRASS_TEMPORAL_H
#define GRASS_TEMPORAL_H
+#include <grass/datetime.h>
+#include <grass/gis.h>
#include <grass/dbmi.h>
#define TGISDB_DEFAULT_DRIVER "sqlite"
#define TGISDB_DEFAULT_SQLITE_PATH "PERMANENT/tgis/sqlite.db"
int tgis_set_connection(dbConnection * connection);
int tgis_get_connection(dbConnection * connection);
const char *tgis_get_default_driver_name(void);
@@ -14,4 +18,223 @@
char *tgis_get_database_name(void);
int tgis_set_default_connection(void);
+/* ALL CODE BELOW THIS COMMENT
+ * IS A PROTOTYPICAL DEFINITION OF THE
+ * FUTURE TEMPORAL GIS C-LIBRARY INTERFACE
+ * AND NOT YET IMPLEMENTED
+#define TGIS_TYPE_MAP 0
+#define TGIS_TYPE_STDS 1
+#define TGIS_RASTER_MAP 1
+#define TGIS_RASTER3D_MAP 2
+#define TGIS_VECTOR_MAP 3
+#define TGIS_STRDS 4
+#define TGIS STR3DS 5
+#define TGIS_STVDS 6
+#define TGIS_ABSOLUTE_TIME 0
+#define TGIS_RELATIVE_TIME 1
+/*! A simple structure to organize time stamped maps*/
+typedef struct _tgisMap {
+ char *name;
+ char *mapset;
+ struct TimeStamp ts;
+} tgisMap;
+ \brief List of tgisMap struct's
+ This structure is used to store lists of time stamped maps
+ using the tgisMap structure internally.
+typedef struct _tgisMapList
+ \brief Array of tgisMap struct's
+ tgisMap **a;
+ \brief Number of tgisMap struct's in the list
+ int n_values;
+ \brief Allocated space for tgisMap struct's
+ int alloc_values;
+} tgisMapList;
+/* map_list.c */
+void tgis_init_map_list(tgisMapList *list);
+void tgis_free_map_list(tgisMapList *list);
+tgisMapList * tgis_new_map_list();
+/*! Insert a new map to the map list */
+void tgis_map_list_insert(tgisMapList *list, char *name, char*mapset, struct TimeStamp *ts);
+/*! Add a new map to the map list */
+void tgis_map_list_add(tgisMap *map);
+/*!Spatio temporal extent as double values
+ The spatio temporal extent contains only double values.
+ The unit of start and end time is seconds in case the time is absolute.
+ Reference is Jan. 1. 1900 00:00:00 +00:00 UTC
+ If no end time is present, because its a time instance, then has_end must be 0.
+typedef struct _tgisExtent
+ double start; /*Start time as double value*/
+ double end; /*End time as double value*/
+ char has_end; /*Set to 1 if the end time exists, 0 otherwise*/
+ double north;
+ double south;
+ double east;
+ double west;
+ double top;
+ double bottom;
+} tgisExtent;
+/* Forward declaration */
+struct _tgisDataset;
+ \brief List of tgisDatasets struct's
+ This structure is used to store lists of dataset (space time datasets or time stamped maps)
+ using the tgisDataset structure internally.
+typedef struct _tgisDatasetList
+ \brief Array of tgisDataset structs
+ struct _tgisDataset **a;
+ \brief Number of tgisDataset structs in the list
+ int n_values;
+ \brief Allocated space for tgisDataset structs
+ int alloc_values;
+} tgisDatasetList;
+/*! A dataset structure to organize time stamped maps and space time datasets
+ and their spatio-temporal topological relations.
+typedef struct _tgisDataset {
+ char *name; /* The name of this dataset */
+ char *mapset; /* The mapset of this dataset */
+ char *creator; /* The creator of this dataset */
+ DateTime creation_time; /* The creation time of this dataset */
+ char temporal_type; /* The temporal type of this dataset: TGIS_ABSOLUTE_TIME,
+ TGIS_RELATIVE_TIME */
+ struct TimeStamp ts; /* The timestamp of this dataset */
+ tgisExtent extent; /* This is the spatio-temporal extent represented as double values */
+ void *metadata; /* A pointer to the dataset specific metadata (not used yet) */
+ char dataset_type; /* The type of the dataset: TGIS_RASTER_MAP, TGIS_RASTER3D_MAP,
+ TGIS_VECTOR_MAP, TGIS_STRDS, TGIS_STR3DS, TGIS_STVDS */
+ char is_stds; /* Represent this struct a space time dataset? 1 True, 0 False */
+ struct _tgisDataset *next;
+ struct _tgisDataset *prev;
+ /* Temporal topology relations */
+ tgisDatasetList equal;
+ tgisDatasetList follows;
+ tgisDatasetList precedes;
+ tgisDatasetList overlaps;
+ tgisDatasetList overlapped;
+ tgisDatasetList during;
+ tgisDatasetList contains;
+ tgisDatasetList starts;
+ tgisDatasetList started;
+ tgisDatasetList finishes;
+ tgisDatasetList finished;
+ /* Spatial topology relations */
+ tgisDatasetList equivalent;
+ tgisDatasetList cover;
+ tgisDatasetList covered;
+ tgisDatasetList overlap;
+ tgisDatasetList in;
+ tgisDatasetList contain;
+ tgisDatasetList meet;
+} tgisDataset;
+/* dataset_list.c */
+void tgis_init_dataset_list(tgisDatasetList *list);
+void tgis_free_dataset_list(tgisDatasetList *list);
+tgisDatasetList * tgis_new_dataset_list();
+/*! Insert a new dataset to the dataset list */
+void tgis_dataset_list_insert(tgisDatasetList *list, char *name, char *mapset, char *creator,
+ DateTime *creation_time, char temporal_type,
+ struct TimeStamp *ts, tgisExtent *extent, void *metadata,
+ char dataset_type, char is_stds);
+/*! Add a new dataset to the dataset list */
+void tgis_dataset_list_add(tgisDataset *dataset);
+/* topology.c */
+/*! Build the temporal or spatio-temporal topology of the provided dataset list */
+int tgis_build_topology(tgisDatasetList *A, char spatial);
+/*! Build the temporal or spatio-temporal topology between the two dataset list */
+int tgis_build_topology2(tgisDatasetList *A, tgisDatasetList *B, char spatial);
+ * INTERFACE TO THE TEMPORAL PYTHON FRAMEWORK
+/* create.c */
+/*! Create the new space time dataset */
+int tgis_create_stds(char *stds_name, char stds_type, char temporal_type, char *title,
+ char *description, char *semantic_type, char *aggregation_type);
+/*! Modify the metadata of an existing space time dataset */
+int tgis_modify_stds(char *stds_name, char stds_type, char *title,
+/* remove.c */
+/*! Remove a space time dataset and optionally all of its maps */
+int tgis_remove_stds(char *stds_name, char stds_type, char remove_maps);
+/* update.c */
+int tgis_update_stds(char *stds_name, char stds_type);
+/* register.c */
+/*! Register a map in the temporal database and optionally in a space time dataset */
+int tgis_register_map(tgisMap *map, char map_type, char *stds_name);
+/*! Unregister a map from the temporal database or optionally from a space time dataset */
+int tgis_unregister_map(tgisMap *map, char map_type, char *stds_name);
+/*! Register maps in the temporal database and optionally in a space time dataset */
+int tgis_register_maps(tgisMapList *list, char map_type, char *stds_name);
+/*! Unregister maps from the temporal database or optionally from a space time dataset */
+int tgis_unregister_maps(tgisMapList *list, char map_type, char *stds_name);
+/*! Get all maps that are registered in a space time dataset */
+tgisDatasetList *tgis_get_registered_maps(char *stds_name, char *mapset,
+ char stds_type, char *order,
+ char *where);
+/* stds.c */
+/*! Get all stds from the temporal database */
+tgisDatasetList *tgis_get_registered_stds(char *stds_name, char *mapset,
+ char stds_type, char temporal_type,
+ char *order, char *where);
+/*! Get the information about a specific space time dataset from the temporal database */
+tgisDataset *tgis_get_stds_info(char *stds_name, char *mapset, char stds_type);
#endif
