[GRASS-SVN] r54841 - grass/trunk/gui/wxpython/dbmgr
Sat Feb 2 09:32:40 PST 2013
Author: martinl
Date: 2013-02-02 09:32:39 -0800 (Sat, 02 Feb 2013)
New Revision: 54841
   grass/trunk/gui/wxpython/dbmgr/base.py
   grass/trunk/gui/wxpython/dbmgr/dialogs.py
   grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
   grass/trunk/gui/wxpython/dbmgr/vinfo.py
wxGUI/dbmgr: fix updating existing attributes (encoding and casting issues)
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py	2013-02-02 17:06:19 UTC (rev 54840)
+++ grass/trunk/gui/wxpython/dbmgr/base.py	2013-02-02 17:32:39 UTC (rev 54841)
@@ -45,7 +45,7 @@
 from core.gcmd        import RunCommand, GException, GError, GMessage, GWarning
 from core.utils       import ListOfCatsToRange
 from gui_core.dialogs import CreateNewVector
-from dbmgr.vinfo      import VectorDBInfo, unicodeValue, createDbInfoDesc
+from dbmgr.vinfo      import VectorDBInfo, GetUnicodeValue, CreateDbInfoDesc
 from core.debug       import Debug
 from dbmgr.dialogs    import ModifyTableRecord, AddColumnDialog
 from core.settings    import UserSettings
@@ -289,7 +289,7 @@
             else:
                 # encode string values
                 try:
-                    self.itemDataMap[i].append(unicodeValue(value))
+                    self.itemDataMap[i].append(GetUnicodeValue(value))
                 except UnicodeDecodeError:
                     self.itemDataMap[i].append(_("Unable to decode value. "
                                                  "Set encoding in GUI preferences ('Attributes')."))
@@ -1298,10 +1298,6 @@
                                 idx = i
                             if column['ctype'] != types.StringType:
-                                if column['ctype'] == types.IntegerType:
-                                    value = float(values[i])
-                                else:
-                                    value = values[i]
                                 tlist.itemDataMap[item][idx] = column['ctype'] (value)
                             else: # -> string
                                 tlist.itemDataMap[item][idx] = values[i]
@@ -1949,7 +1945,7 @@
         dbBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
                                       label = " %s " % _("Database connection"))
         dbSizer = wx.StaticBoxSizer(dbBox, wx.VERTICAL)
-        dbSizer.Add(item = createDbInfoDesc(panel, self.dbMgrData['mapDBInfo'], layer),
+        dbSizer.Add(item = CreateDbInfoDesc(panel, self.dbMgrData['mapDBInfo'], layer),
                     proportion = 1,
                     flag = wx.EXPAND | wx.ALL,
                     border = 3)
Modified: grass/trunk/gui/wxpython/dbmgr/dialogs.py
--- grass/trunk/gui/wxpython/dbmgr/dialogs.py	2013-02-02 17:06:19 UTC (rev 54840)
+++ grass/trunk/gui/wxpython/dbmgr/dialogs.py	2013-02-02 17:32:39 UTC (rev 54841)
@@ -8,7 +8,7 @@
  - dialogs::ModifyTableRecord
  - dialogs::AddColumnDialog
-(C) 2007-2012 by the GRASS Development Team
+(C) 2007-2013 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -27,7 +27,7 @@
 from core.gcmd        import RunCommand, GError
 from gui_core.widgets import IntegerValidator, FloatValidator
 class DisplayAttributesDialog(wx.Dialog):
@@ -692,17 +692,17 @@
         If columns is given (list), return only values of given columns.
-        valueList = []
+        valueList = list()
         for labelId, ctypeId, valueId in self.widgets:
-            column = self.FindWindowById(labelId).GetLabel().replace(':', '')
+            column = self.FindWindowById(labelId).GetLabel()
             if columns is None or column in columns:
-                value = str(self.FindWindowById(valueId).GetValue())
+                value = GetUnicodeValue(self.FindWindowById(valueId).GetValue())
                 valueList.append(value)
         # add key value
         if self.usebox:
-            valueList.insert(self.keyId, str(self.cat))
+            valueList.insert(self.keyId, GetUnicodeValue(str(self.cat)))
         return valueList
 class AddColumnDialog(wx.Dialog):
Modified: grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
--- grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py	2013-02-02 17:06:19 UTC (rev 54840)
+++ grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py	2013-02-02 17:32:39 UTC (rev 54841)
@@ -33,7 +33,7 @@
 import wx
 from core.gcmd   import RunCommand, GError, GMessage
-from dbmgr.vinfo import createDbInfoDesc, VectorDBInfo
+from dbmgr.vinfo import CreateDbInfoDesc, VectorDBInfo
 import grass.script as grass
@@ -81,7 +81,7 @@
         databasebox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
         databaseboxsizer = wx.StaticBoxSizer(databasebox, wx.VERTICAL)
-        databaseboxsizer.Add(item=createDbInfoDesc(self.panel, self.dbInfo, layer = self.layer),
+        databaseboxsizer.Add(item = CreateDbInfoDesc(self.panel, self.dbInfo, layer = self.layer),
                              proportion=1,
                              flag=wx.EXPAND | wx.ALL,
                              border=3)
Modified: grass/trunk/gui/wxpython/dbmgr/vinfo.py
--- grass/trunk/gui/wxpython/dbmgr/vinfo.py	2013-02-02 17:06:19 UTC (rev 54840)
+++ grass/trunk/gui/wxpython/dbmgr/vinfo.py	2013-02-02 17:32:39 UTC (rev 54841)
@@ -22,11 +22,15 @@
 from gui_core.gselect import VectorDBInfo as VectorDBInfoBase
-def unicodeValue(value):
-    """!Encode value"""
+def GetUnicodeValue(value):
+    """!Get unicode value
+    @param value value to be recoded
+    @return unicode value
     if type(value) == types.UnicodeType:
         return value
@@ -37,8 +41,8 @@
         enc = 'utf-8' # assuming UTF-8
     return unicode(value, enc, errors = 'replace')
-def createDbInfoDesc(panel, mapDBInfo, layer):
+def CreateDbInfoDesc(panel, mapDBInfo, layer):
     """!Create database connection information content"""
     infoFlexSizer = wx.FlexGridSizer (cols = 2, hgap = 1, vgap = 1)
     infoFlexSizer.AddGrowableCol(1)
@@ -111,7 +115,7 @@
                     if self.tables[table][key]['ctype'] != types.StringType:
                         value = self.tables[table][key]['ctype'] (value)
                     else:
-                        value = unicodeValue(value)
+                        value = GetUnicodeValue(value)
                 self.tables[table][key]['values'].append(value)
             for key, value in record.iteritems():
@@ -159,7 +163,7 @@
                     if self.tables[table][name]['ctype'] != type(''):
                         value = self.tables[table][name]['ctype'] (value)
                     else:
                 else:
                     value = None
                 self.tables[table][name]['values'].append(value)
