[GRASS-SVN] r54842 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Feb 2 09:58:59 PST 2013
Author: mmetz
Date: 2013-02-02 09:58:59 -0800 (Sat, 02 Feb 2013)
New Revision: 54842
grass/trunk/lib/vector/Vlib/intersect.c
Vlib: speed up Vect_break_lines()
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2013-02-02 17:32:39 UTC (rev 54841)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2013-02-02 17:58:59 UTC (rev 54842)
@@ -614,6 +614,7 @@
int seg1, seg2, vert1, vert2;
static struct RTree_Rect rect;
static int rect_init = 0;
+ struct bound_box box, abbox;
if (debug_level == -1) {
const char *dstr = G__getenv("DEBUG");
@@ -691,6 +692,35 @@
* is build first for the second line and segments from the first line are broken by segments
* in bound box */
+ dig_line_box(APoints, &box);
+ dig_line_box(BPoints, &abbox);
+ if (!Vect_box_overlap(&box, &abbox)) {
+ *nalines = 0;
+ *nblines = 0;
+ return 0;
+ if (abbox.N > box.N)
+ abbox.N = box.N;
+ if (abbox.S < box.S)
+ abbox.S = box.S;
+ if (abbox.E > box.E)
+ abbox.E = box.E;
+ if (abbox.W < box.W)
+ abbox.W = box.W;
+ if (abbox.T > box.T)
+ abbox.T = box.T;
+ if (abbox.B < box.B)
+ abbox.B = box.B;
+ abbox.N += rethresh;
+ abbox.S -= rethresh;
+ abbox.E += rethresh;
+ abbox.W -= rethresh;
+ abbox.T += rethresh;
+ abbox.B -= rethresh;
/* Create rtree for B line */
MyRTree = RTreeCreateTree(-1, 0, 2);
RTreeSetOverflow(MyRTree, 0);
@@ -698,31 +728,57 @@
if (BPoints->x[i] <= BPoints->x[i + 1]) {
rect.boundary[0] = BPoints->x[i];
rect.boundary[3] = BPoints->x[i + 1];
+ box.W = BPoints->x[i];
+ box.E = BPoints->x[i + 1];
else {
rect.boundary[0] = BPoints->x[i + 1];
rect.boundary[3] = BPoints->x[i];
+ box.W = BPoints->x[i + 1];
+ box.E = BPoints->x[i];
if (BPoints->y[i] <= BPoints->y[i + 1]) {
rect.boundary[1] = BPoints->y[i];
rect.boundary[4] = BPoints->y[i + 1];
+ box.S = BPoints->y[i];
+ box.N = BPoints->y[i + 1];
else {
rect.boundary[1] = BPoints->y[i + 1];
rect.boundary[4] = BPoints->y[i];
+ box.S = BPoints->y[i + 1];
+ box.N = BPoints->y[i];
if (BPoints->z[i] <= BPoints->z[i + 1]) {
rect.boundary[2] = BPoints->z[i];
rect.boundary[5] = BPoints->z[i + 1];
+ box.B = BPoints->z[i];
+ box.T = BPoints->z[i + 1];
else {
rect.boundary[2] = BPoints->z[i + 1];
rect.boundary[5] = BPoints->z[i];
+ box.B = BPoints->z[i + 1];
+ box.T = BPoints->z[i];
+ box.N += rethresh;
+ box.S -= rethresh;
+ box.E += rethresh;
+ box.W -= rethresh;
+ box.T += rethresh;
+ box.B -= rethresh;
- RTreeInsertRect(&rect, i + 1, MyRTree); /* B line segment numbers in rtree start from 1 */
+ if (Vect_box_overlap(&abbox, &box)) {
+ RTreeInsertRect(&rect, i + 1, MyRTree); /* B line segment numbers in rtree start from 1 */
/* Break segments in A by segments in B */
