[GRASS-SVN] r54848 - grass/trunk/gui/wxpython/rlisetup
svn_grass at osgeo.org
Sat Feb 2 11:48:10 PST 2013
Author: lucadelu
Date: 2013-02-02 11:48:09 -0800 (Sat, 02 Feb 2013)
New Revision: 54848
grass/trunk/gui/wxpython/rlisetup/frame.py
grass/trunk/gui/wxpython/rlisetup/functions.py
grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
grass/trunk/gui/wxpython/rlisetup/wizard.py
fix r.li.setup on windows, some cleaning of code
Modified: grass/trunk/gui/wxpython/rlisetup/frame.py
--- grass/trunk/gui/wxpython/rlisetup/frame.py 2013-02-02 19:17:20 UTC (rev 54847)
+++ grass/trunk/gui/wxpython/rlisetup/frame.py 2013-02-02 19:48:09 UTC (rev 54848)
@@ -17,7 +17,7 @@
class RLiSetupFrame(wx.Frame):
def __init__(self, parent, giface = None, id=wx.ID_ANY, title=_("GRASS" \
- " GIS Setup for r.li modules"),
+ " GIS Setup for r.li modules"),
style=wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER, **kwargs):
###VARIABLES
self.parent = parent
Modified: grass/trunk/gui/wxpython/rlisetup/functions.py
--- grass/trunk/gui/wxpython/rlisetup/functions.py 2013-02-02 19:17:20 UTC (rev 54847)
+++ grass/trunk/gui/wxpython/rlisetup/functions.py 2013-02-02 19:48:09 UTC (rev 54848)
@@ -6,7 +6,7 @@
import wx
import os
-from grass.script import core as grass
+import sys
def checkValue(value):
@@ -17,11 +17,19 @@
def retRLiPath():
- major_version = int(grass.version()['version'].split('.', 1)[0])
- rlipath = os.path.join(os.environ['HOME'], '.grass%d' % major_version,
- 'r.li')
+ # configuration directory
+ if sys.platform == 'win32':
+ grass_config_dirname = "GRASS7"
+ grass_config_dir = os.path.join(os.getenv('APPDATA'),
+ grass_config_dirname)
+ else:
+ grass_config_dirname = ".grass7"
+ grass_config_dir = os.path.join(os.getenv('HOME'),
+ rlipath = os.path.join(grass_config_dir, 'r.li')
if os.path.exists(rlipath):
return rlipath
else:
os.mkdir(rlipath)
- return rlipath
\ No newline at end of file
+ return rlipath
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py 2013-02-02 19:17:20 UTC (rev 54847)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py 2013-02-02 19:48:09 UTC (rev 54848)
@@ -38,17 +38,17 @@
from core.giface import StandaloneGrassInterface
from rlisetup.frame import RLiSetupFrame
def main():
- import gettext
- gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'),
+ unicode = True)
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
frame = RLiSetupFrame(parent = None, giface = StandaloneGrassInterface())
frame.Show()
app.MainLoop()
if __name__ == "__main__":
options, flags = grass.parser()
main()
Modified: grass/trunk/gui/wxpython/rlisetup/wizard.py
--- grass/trunk/gui/wxpython/rlisetup/wizard.py 2013-02-02 19:17:20 UTC (rev 54847)
+++ grass/trunk/gui/wxpython/rlisetup/wizard.py 2013-02-02 19:48:09 UTC (rev 54848)
@@ -140,7 +140,7 @@
self.per_x = float(self.SF_X) / float(self.rasterinfo['cols'])
self.per_y = float(self.SF_Y) / float(self.rasterinfo['rows'])
self.per_rl = float(self.SF_RL) / float(self.rasterinfo['rows'])
- self.per_cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
+ self.per_cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
elif self.startpage.region == 'key':
self._temp_region()
self.SF_X = float(self.keyboardpage.col_up)
