[GRASS-SVN] r54849 - in grass-addons/grass7/raster/r.agent: libagent tests
Sat Feb 2 12:20:43 PST 2013
Author: mic
Date: 2013-02-02 12:20:42 -0800 (Sat, 02 Feb 2013)
New Revision: 54849
   grass-addons/grass7/raster/r.agent/libagent/playground.py
   grass-addons/grass7/raster/r.agent/libagent/world.py
   grass-addons/grass7/raster/r.agent/tests/test_playground.py
fix getregion and clean error msgs
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py	2013-02-02 19:48:09 UTC (rev 54848)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py	2013-02-02 20:20:42 UTC (rev 54849)
@@ -20,6 +20,7 @@
     def __init__(self):
         """Create a Playground"""
         self.layers = dict()
+        self.region = dict()
         self.setregion(1,1)
     def setregion(self, rows, cols):
@@ -29,8 +30,19 @@
         @param numeric number of rows
         @param numeric number of columns
-        self.region = dict(s=0,n=rows,w=0,e=cols,rows=rows,cols=cols)
+        self.region["s"] = 0
+        self.region["n"] = rows
+        self.region["w"] = 0
+        self.region["e"] = cols
+        self.region["rows"] = rows
+        self.region["cols"] = cols
+        for layer in self.layers:
+            if not ( len(layer) is rows and len(layer[0]) is cols):
+                raise error.Error(
+                        "r.agent::libagent.playground.Playground.setregion()",
+                        "new region is incompatible with some layer(s).")
     def getregion(self):
         Return the region information
@@ -55,8 +67,9 @@
         @param boolean optional, whether to overwrite values if key exists
         if not force and self.layers.has_key(layername):
-            raise error.Error("r.agent::libagent.playground.Playground()",
-                                    "May not overwrite existing layer.")
+                    "r.agent::libagent.playground.Playground.setlayer()",
+                    "May not overwrite existing layer.")
         self.layers[layername] = layer
     def createlayer(self, layername, filename=False, force=False):
Modified: grass-addons/grass7/raster/r.agent/libagent/world.py
--- grass-addons/grass7/raster/r.agent/libagent/world.py	2013-02-02 19:48:09 UTC (rev 54848)
+++ grass-addons/grass7/raster/r.agent/libagent/world.py	2013-02-02 20:20:42 UTC (rev 54849)
@@ -81,7 +81,8 @@
         position = self.findposition(position)
         if not position:
-            raise error.DataError("world.bear", "invalid position")
+            raise error.DataError("r.agent::libagent.world.World.bear()",
+                                  "invalid position")
         agent = self.agenttype(timetolive, self, position)
         self.agents.append(agent)
         return agent
@@ -94,7 +95,8 @@
         if not position:
+            raise error.DataError("r.agent::libagent.world.World.move()",
         agent.setposition(position)
     def getneighbourpositions(self, position, freedom=None):
Modified: grass-addons/grass7/raster/r.agent/tests/test_playground.py
--- grass-addons/grass7/raster/r.agent/tests/test_playground.py	2013-02-02 19:48:09 UTC (rev 54848)
+++ grass-addons/grass7/raster/r.agent/tests/test_playground.py	2013-02-02 20:20:42 UTC (rev 54849)
@@ -9,8 +9,11 @@
         self.pg = playground.Playground()
     def test_setregion(self):
-        # is actually already tested by playground.Playground.__init__()
-        pass
+        self.assertTrue(self.pg.region["rows"] == 1)
+        self.pg.setregion(2,1)
+        self.pg.createlayer("bar")
+        self.assertTrue(self.pg.region["rows"] == 2)
+        self.assertRaises(error.Error, self.pg.setregion, *[2,1])
     def test_getregion(self):
         self.assertIsNotNone(self.pg.getregion())
