[GRASS-SVN] r54850 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Sat Feb 2 13:06:11 PST 2013
Author: mic
Date: 2013-02-02 13:06:11 -0800 (Sat, 02 Feb 2013)
New Revision: 54850
grass-addons/grass7/raster/r.agent/libagent/agent.py
grass-addons/grass7/raster/r.agent/tests/test_agent.py
basic agent implemented
Modified: grass-addons/grass7/raster/r.agent/libagent/agent.py
--- grass-addons/grass7/raster/r.agent/libagent/agent.py 2013-02-02 20:20:42 UTC (rev 54849)
+++ grass-addons/grass7/raster/r.agent/libagent/agent.py 2013-02-02 21:06:11 UTC (rev 54850)
@@ -30,7 +30,7 @@
def setposition(self, position):
- Move the agent to a certain position
+ Tell the agent to stand still at a certain position
@param list coordinate of the current position
if position and position != []:
@@ -44,14 +44,15 @@
return self.position
- def move(self, nrofsteps, direction):
- Let the agent move
- @param int the number of steps to walk
- @param char the direction to go
- @return list coordinate of the current position
- return self.position
+# def move(self, nrofsteps, direction):
+# not implemented yet
+# Let the agent move
+# @param int the number of steps to walk
+# @param char the direction to go
+# @return list coordinate of the current position
+# return self.position
def age(self):
Modified: grass-addons/grass7/raster/r.agent/tests/test_agent.py
--- grass-addons/grass7/raster/r.agent/tests/test_agent.py 2013-02-02 20:20:42 UTC (rev 54849)
+++ grass-addons/grass7/raster/r.agent/tests/test_agent.py 2013-02-02 21:06:11 UTC (rev 54850)
@@ -2,27 +2,40 @@
import unittest2 as unittest
#import unittest
-from libagent import agent
+from libagent import playground, world, agent
class TestAgent(unittest.TestCase):
def setUp(self):
- pass
-# self.agent = agent.Agent()
+ self.pg = playground.Playground()
+ self.pg.setregion(3,3)
+ self.world = world.World(None, self.pg)
+ self.world.bear(1, [1,1], agent.Agent)
+ self.agent = self.world.agents[0]
def test_setposition(self):
- pass
+ self.assertTrue(self.agent.getposition() == [1,1])
+ self.agent.setposition([3,3])
+ self.assertTrue(self.agent.getposition() == [3,3])
def test_getposition(self):
- pass
- def test_move(self):
- pass
+# def test_move(self):
+# pass
def test_age(self):
- pass
+ self.agent.ttl = 1
+ age = self.agent.ttl
+ self.agent.age()
+ self.assertTrue(self.agent.ttl < age)
+ self.agent.age()
+ self.assertTrue(len(self.world.agents) == 0)
def test_snuffit(self):
- pass
+ self.assertTrue(len(self.world.agents) == 1)
+ self.agent.snuffit()
# def tearDown(self):
