[GRASS-SVN] r54914 - grass/trunk/lib/python/pygrass/raster
svn_grass at osgeo.org
Tue Feb 5 00:19:46 PST 2013
Author: zarch
Date: 2013-02-05 00:19:46 -0800 (Tue, 05 Feb 2013)
New Revision: 54914
grass/trunk/lib/python/pygrass/raster/history.py
grass/trunk/lib/python/pygrass/raster/rowio.py
grass/trunk/lib/python/pygrass/raster/segment.py
Change the C struct attribute name to be consistent with the other classes
Modified: grass/trunk/lib/python/pygrass/raster/history.py
--- grass/trunk/lib/python/pygrass/raster/history.py 2013-02-05 08:19:35 UTC (rev 54913)
+++ grass/trunk/lib/python/pygrass/raster/history.py 2013-02-05 08:19:46 UTC (rev 54914)
@@ -14,33 +14,34 @@
*Examples*
- >>> import grass.pygrass as pygrass
- >>> hist = pygrass.raster.History()
- >>> hist.read('aspect')
+ >>> import grass.lib.gis as libgis
+ >>> libgis.G_gisinit('')
+ >>> hist = History('elevation')
>>> hist.creator
'helena'
>>> hist.src1
- 'raster elevation file elev_ned10m'
>>> hist.src2
>>> hist.keyword
- 'generated by r.slope.aspect'
+ 'generated by r.proj'
>>> hist.date
- datetime.datetime(2006, 11, 7, 1, 11, 23)
+ datetime.datetime(2006, 11, 7, 1, 9, 51)
>>> hist.mapset
'PERMANENT'
>>> hist.maptype
'raster'
>>> hist.title
- 'asp_ned10m'
+ 'elev_ned10m'
- def __init__(self):
- self.hist = libraster.History()
+ def __init__(self, name=''):
+ self.c_hist = ctypes.pointer(libraster.History())
# 'Tue Nov 7 01:11:23 2006'
self.date_fmt = '%a %b %d %H:%M:%S %Y'
+ if name:
+ self.read(name)
def __del__(self):
"""Rast_free_history"""
@@ -49,11 +50,11 @@
#libraster.HIST_CREATOR
def _get_creator(self):
- return libraster.Rast_get_history(ctypes.byref(self.hist),
+ return libraster.Rast_get_history(self.c_hist,
libraster.HIST_CREATOR)
def _set_creator(self, creator):
- return libraster.Rast_set_history(ctypes.byref(self.hist),
+ return libraster.Rast_set_history(self.c_hist,
libraster.HIST_CREATOR,
ctypes.c_char_p(creator))
@@ -62,11 +63,11 @@
#libraster.HIST_DATSRC_1
def _get_src1(self):
libraster.HIST_DATSRC_1)
def _set_src1(self, src1):
libraster.HIST_DATSRC_1,
ctypes.c_char_p(src1))
@@ -75,11 +76,11 @@
#libraster.HIST_DATSRC_2
def _get_src2(self):
libraster.HIST_DATSRC_2)
def _set_src2(self, src2):
libraster.HIST_DATSRC_2,
ctypes.c_char_p(src2))
@@ -88,11 +89,11 @@
#libraster.HIST_KEYWORD
def _get_keyword(self):
libraster.HIST_KEYWRD)
def _set_keyword(self, keyword):
libraster.HIST_KEYWRD,
ctypes.c_char_p(keyword))
@@ -101,13 +102,13 @@
#libraster.HIST_MAPID
def _get_date(self):
- date_str = libraster.Rast_get_history(ctypes.byref(self.hist),
+ date_str = libraster.Rast_get_history(self.c_hist,
libraster.HIST_MAPID)
return datetime.datetime.strptime(date_str, self.date_fmt)
def _set_date(self, datetimeobj):
date_str = datetimeobj.strftime(self.date_fmt)
libraster.HIST_MAPID,
ctypes.c_char_p(date_str))
@@ -116,11 +117,11 @@
#libraster.HIST_MAPSET
def _get_mapset(self):
libraster.HIST_MAPSET)
def _set_mapset(self, mapset):
libraster.HIST_MAPSET,
ctypes.c_char_p(mapset))
@@ -129,11 +130,11 @@
#libraster.HIST_MAPTYPE
def _get_maptype(self):
libraster.HIST_MAPTYPE)
def _set_maptype(self, maptype):
libraster.HIST_MAPTYPE,
ctypes.c_char_p(maptype))
@@ -145,11 +146,11 @@
# Never used in any raster modules
# def _get_num_fields(self):
- # return libraster.Rast_get_history(ctypes.byref(self.hist),
+ # return libraster.Rast_get_history(self.c_hist,
# libraster.HIST_NUM_FIELDS)
# def _set_num_fields(self, num_fields):
- # return libraster.Rast_set_history(ctypes.byref(self.hist),
+ # return libraster.Rast_set_history(self.c_hist,
# libraster.HIST_NUM_FIELDS,
# ctypes.c_char_p(num_fields))
@@ -157,11 +158,11 @@
#libraster.HIST_TITLE
def _get_title(self):
libraster.HIST_TITLE)
def _set_title(self, title):
libraster.HIST_TITLE,
ctypes.c_char_p(title))
@@ -169,37 +170,37 @@
def append(self, obj):
"""Rast_append_history"""
- libraster.Rast_append_history(ctypes.byref(self.hist),
+ libraster.Rast_append_history(self.c_hist,
ctypes.c_char_p(str(obj)))
def appent_fmt(self, fmt, *args):
"""Rast_append_format_history"""
- libraster.Rast_append_format_history(ctypes.byref(self.hist),
+ libraster.Rast_append_format_history(self.c_hist,
ctypes.c_char_p(fmt),
*args)
def clear(self):
"""Rast_clear_history"""
- libraster.Rast_clear_history(ctypes.byref(self.hist))
+ libraster.Rast_clear_history(self.c_hist)
def command(self):
"""Rast_command_history"""
- libraster.Rast_command_history(ctypes.byref(self.hist))
+ libraster.Rast_command_history(self.c_hist)
def format(self, field, fmt, *args):
"""Rast_format_history"""
- libraster.Rast_format_history(ctypes.byref(self.hist),
+ libraster.Rast_format_history(self.c_hist,
ctypes.c_int(field),
*args)
def length(self):
"""Rast_history_length"""
- libraster.Rast_history_length(ctypes.byref(self.hist))
+ libraster.Rast_history_length(self.c_hist)
def line(self, line):
"""Rast_history_line"""
- libraster.Rast_history_line(ctypes.byref(self.hist),
+ libraster.Rast_history_line(self.c_hist,
ctypes.c_int(line))
def read(self, name):
@@ -210,27 +211,27 @@
>>> import ctypes
>>> import grass.lib.raster as libraster
- >>> libraster.Rast_read_history(ctypes.c_char_p('aspect'),
+ >>> libraster.Rast_read_history(ctypes.c_char_p('elevation'),
... ctypes.c_char_p(''),
... ctypes.byref(hist))
0
>>> libraster.Rast_get_history(ctypes.byref(hist),
... libraster.HIST_MAPID)
- 'Tue Nov 7 01:11:23 2006'
+ 'Tue Nov 7 01:09:51 2006'
libraster.Rast_read_history(ctypes.c_char_p(name),
- ctypes.byref(self.hist))
+ self.c_hist)
def write(self, name):
"""Rast_write_history"""
libraster.Rast_write_history(ctypes.c_char_p(name),
+ self.c_hist)
def short(self, name, maptype,):
"""Rast_short_history"""
libraster.Rast_short_history(ctypes.c_char_p(name),
ctypes.c_char_p(maptype),
+ self.c_hist)
Modified: grass/trunk/lib/python/pygrass/raster/rowio.py
--- grass/trunk/lib/python/pygrass/raster/rowio.py 2013-02-05 08:19:35 UTC (rev 54913)
+++ grass/trunk/lib/python/pygrass/raster/rowio.py 2013-02-05 08:19:46 UTC (rev 54914)
@@ -45,7 +45,7 @@
class RowIO(object):
def __init__(self):
- self.crowio = librowio.ROWIO()
+ self.c_rowio = librowio.ROWIO()
self.fd = None
self.rows = None
self.cols = None
@@ -58,7 +58,7 @@
self.cols = cols
self.mtype = mtype
self.row_size = ctypes.sizeof(RTYPE[mtype]['grass def'] * cols)
- if (librowio.Rowio_setup(ctypes.byref(self.crowio), self.fd,
+ if (librowio.Rowio_setup(ctypes.byref(self.c_rowio), self.fd,
self.rows,
self.row_size,
get_row[self.mtype],
@@ -66,13 +66,13 @@
raise GrassError('Fatal error, Rowio not setup correctly.')
def release(self):
- librowio.Rowio_release(ctypes.byref(self.crowio))
+ librowio.Rowio_release(ctypes.byref(self.c_rowio))
self.fd = None
self.rows = None
self.cols = None
self.mtype = None
def get(self, row_index, buf):
- rowio_buf = librowio.Rowio_get(ctypes.byref(self.crowio), row_index)
+ rowio_buf = librowio.Rowio_get(ctypes.byref(self.c_rowio), row_index)
ctypes.memmove(buf.p, rowio_buf, self.row_size)
return buf
Modified: grass/trunk/lib/python/pygrass/raster/segment.py
--- grass/trunk/lib/python/pygrass/raster/segment.py 2013-02-05 08:19:35 UTC (rev 54913)
+++ grass/trunk/lib/python/pygrass/raster/segment.py 2013-02-05 08:19:46 UTC (rev 54914)
@@ -16,7 +16,7 @@
self.srows = srows
self.scols = scols
self.maxmem = maxmem
- self.cseg = libseg.SEGMENT()
+ self.c_seg = ctypes.pointer(libseg.SEGMENT())
def rows(self):
return libraster.Rast_window_rows()
@@ -48,7 +48,7 @@
size = ctypes.sizeof(RTYPE[mapobj.mtype]['ctypes'])
file_name = libgis.G_tempfile()
#import pdb; pdb.set_trace()
- libseg.segment_open(ctypes.byref(self.cseg), file_name,
+ libseg.segment_open(self.c_seg, file_name,
self.rows(), self.cols(),
self.srows, self.scols,
size,
@@ -78,29 +78,29 @@
if file_name == '':
file_name = mapobj.temp_file.name
mapobj.temp_file = open(file_name, 'w')
- libseg.segment_init(ctypes.byref(self.cseg), mapobj.temp_file.fileno(),
+ libseg.segment_init(self.c_seg, mapobj.temp_file.fileno(),
self.segments_in_mem)
def get_row(self, row_index, buf):
"""Return the row using, the `segment` method"""
- libseg.segment_get_row(ctypes.byref(self.cseg), buf.p, row_index)
+ libseg.segment_get_row(self.c_seg, buf.p, row_index)
return buf
def put_row(self, row_index, buf):
"""Write the row using the `segment` method"""
- libseg.segment_put_row(ctypes.byref(self.cseg), buf.p, row_index)
+ libseg.segment_put_row(self.c_seg, buf.p, row_index)
def get(self, row_index, col_index):
"""Return the value of the map
- libseg.segment_get(ctypes.byref(self.cseg),
+ libseg.segment_get(self.c_seg,
ctypes.byref(self.val), row_index, col_index)
return self.val.value
def put(self, row_index, col_index):
"""Write the value to the map
- libseg.segment_put(ctypes.byref(self.cseg),
+ libseg.segment_put(self.c_seg,
def get_seg_number(self, row_index, col_index):
@@ -115,15 +115,15 @@
the segment file seg. Must be called after the final segment_put()
to force all pending updates to disk. Must also be called before the
first call to segment_get_row."""
- libseg.segment_flush(ctypes.byref(self.cseg))
+ libseg.segment_flush(self.c_seg)
def close(self):
"""Free memory allocated to segment and delete temp file. """
- libseg.segment_close(ctypes.byref(self.cseg))
+ libseg.segment_close(self.c_seg)
def release(self):
"""Free memory allocated to segment.
Releases the allocated memory associated with the segment file seg.
Note: Does not close the file. Does not flush the data which may be
pending from previous segment_put() calls."""
- libseg.segment_release(ctypes.byref(self.cseg))
+ libseg.segment_release(self.c_seg)
