[GRASS-SVN] r54915 - grass/trunk/lib/python/pygrass/raster
svn_grass at osgeo.org
Tue Feb 5 00:19:55 PST 2013
Author: zarch
Date: 2013-02-05 00:19:54 -0800 (Tue, 05 Feb 2013)
New Revision: 54915
grass/trunk/lib/python/pygrass/raster/__init__.py
grass/trunk/lib/python/pygrass/raster/abstract.py
Read the cats and the history when opening an existing maps
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py 2013-02-05 08:19:46 UTC (rev 54914)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py 2013-02-05 08:19:54 UTC (rev 54915)
@@ -167,6 +167,8 @@
self._fd = libraster.Rast_open_old(self.name, self.mapset)
self._gtype = libraster.Rast_get_map_type(self._fd)
self.mtype = RTYPE_STR[self._gtype]
+ self.cats.read(self)
+ self.hist.read(self.name)
elif self.overwrite:
if self._gtype is None:
raise OpenError(_("Raster type not defined"))
@@ -401,6 +403,8 @@
self.segment.open(self)
self.map2segment()
self.segment.flush()
if self.mode == "rw":
warning(_(WARN_OVERWRITE.format(self)))
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py 2013-02-05 08:19:46 UTC (rev 54914)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py 2013-02-05 08:19:54 UTC (rev 54915)
@@ -32,6 +32,7 @@
from raster_type import TYPE as RTYPE
from category import Category
+from history import History
## Define global variables to not exceed the 80 columns
@@ -67,9 +68,6 @@
self.mapset = mapset
- #self.region = Region()
- self.cats = Category()
self._name = name
## Private attribute `_fd` that return the file descriptor of the map
self._fd = None
@@ -81,7 +79,11 @@
# in active window, When the class is instanced is empty and it is set
# when you open the file, using Rast_window_cols()
self._cols = None
+ #self.region = Region()
+ self.cats = Category()
+ self.hist = History()
def _get_mtype(self):
return self._mtype
