[GRASS-SVN] r54916 - in grass/trunk/gui/wxpython: . animation gmodeler gui_core iclass mapdisp mapswipe modules nviz psmap rlisetup vdigit
Tue Feb 5 00:42:01 PST 2013
Author: annakrat
Date: 2013-02-05 00:42:01 -0800 (Tue, 05 Feb 2013)
New Revision: 54916
   grass/trunk/gui/wxpython/animation/g.gui.animation.py
   grass/trunk/gui/wxpython/gis_set.py
   grass/trunk/gui/wxpython/gmodeler/frame.py
   grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
   grass/trunk/gui/wxpython/gui_core/ghelp.py
   grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
   grass/trunk/gui/wxpython/mapdisp/main.py
   grass/trunk/gui/wxpython/mapdisp/mapwindow.py
   grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
   grass/trunk/gui/wxpython/modules/colorrules.py
   grass/trunk/gui/wxpython/modules/histogram.py
   grass/trunk/gui/wxpython/nviz/tools.py
   grass/trunk/gui/wxpython/psmap/frame.py
   grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
   grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
   grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: ensure compatibility with wxPython 2.9
Modified: grass/trunk/gui/wxpython/animation/g.gui.animation.py
--- grass/trunk/gui/wxpython/animation/g.gui.animation.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/animation/g.gui.animation.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -51,6 +51,7 @@
     sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
 from core.settings import UserSettings
+from core.globalvar import CheckWxVersion
 from core.giface import StandaloneGrassInterface
 from animation.frame import AnimationFrame, MAX_COUNT
@@ -76,7 +77,8 @@
         strds = None
     app = wx.PySimpleApp()
-    wx.InitAllImageHandlers()
+    if not CheckWxVersion([2, 9]):
+        wx.InitAllImageHandlers()
     frame = AnimationFrame(parent = None)
     frame.CentreOnScreen()
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/gis_set.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -956,7 +956,8 @@
     """!Start-up application"""
     def OnInit(self):
+        if not globalvar.CheckWxVersion([2, 9]):
         StartUp = GRASSStartup()
         StartUp.CenterOnScreen()
         self.SetTopWindow(StartUp)
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -1062,7 +1062,8 @@
         shape = self.GetShape()
         canvas = shape.GetCanvas()
         dc = wx.ClientDC(canvas)
-        canvas.PrepareDC(dc)
+        # probably does nothing, removed from wxPython 2.9
+        # canvas.PrepareDC(dc)
         if hasattr(self.frame, 'defineRelation'):
             drel = self.frame.defineRelation
Modified: grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
--- grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -45,6 +45,7 @@
 from gmodeler.frame import ModelFrame
 def main():
@@ -52,7 +53,8 @@
     gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
     frame = ModelFrame(parent = None, giface = StandaloneGrassInterface())
     if options['file']:
         frame.LoadModelFile(options['file'])
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -605,7 +605,8 @@
         in the Panel.
         self.parent = parent
         HtmlWindow.__init__(self, parent = parent, **kwargs)
         self.loaded = False
Modified: grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
--- grass/trunk/gui/wxpython/iclass/g.gui.iclass.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/iclass/g.gui.iclass.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -58,6 +58,7 @@
 from iclass.frame   import IClassMapFrame
@@ -85,7 +86,8 @@
     # launch application
     # show main frame
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -298,7 +298,8 @@
 class MapApp(wx.App):
     def OnInit(self):
         if __name__ == "__main__":
             self.cmdTimeStamp = os.path.getmtime(monFile['cmd'])
             self.Map = DMonMap(cmdfile = monFile['cmd'], mapfile = monFile['map'],
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -363,7 +363,8 @@
         dc.Clear()
         # use PrepareDC to set position correctly
-        self.PrepareDC(dc)
+        # self.PrepareDC(dc)
         # create a clipping rect from our position and size
         # and update region
@@ -523,7 +524,8 @@
         dc = wx.BufferedDC(None, ibuffer)
         dc.Clear()
         self.pdc.DrawToDC(dc)
         if self.pdcVector:
             self.pdcVector.DrawToDC(dc)
Modified: grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
--- grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -57,6 +57,7 @@
 from mapswipe.frame import SwipeMapFrame
@@ -83,7 +84,8 @@
                 grass.fatal(_("Raster map <%s> not found") % mapName)
     frame = SwipeMapFrame(parent = None, giface = StandaloneGrassInterface())
Modified: grass/trunk/gui/wxpython/modules/colorrules.py
--- grass/trunk/gui/wxpython/modules/colorrules.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/modules/colorrules.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -1810,7 +1810,8 @@
         dc = wx.BufferedPaintDC(self, self._Buffer)
         # we need to clear the dc BEFORE calling PrepareDC
         bg = wx.Brush(self.GetBackgroundColour())
Modified: grass/trunk/gui/wxpython/modules/histogram.py
--- grass/trunk/gui/wxpython/modules/histogram.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/modules/histogram.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -124,7 +124,8 @@
         dc = wx.BufferedPaintDC(self, self._buffer)
         dc.SetBackground(bg)
@@ -184,7 +185,8 @@
         self.Draw(self.pdc, img, drawid = 99)
         dc = wx.BufferedPaintDC(self, ibuffer)
         dc.Clear()
         ibuffer.SaveFile(FileName, FileType)
Modified: grass/trunk/gui/wxpython/nviz/tools.py
--- grass/trunk/gui/wxpython/nviz/tools.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/nviz/tools.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -5056,7 +5056,8 @@
         dc.SetBackground(wx.Brush("White"))
         dc.Clear()
     def UpdatePos(self, xcoord, ycoord):
Modified: grass/trunk/gui/wxpython/psmap/frame.py
--- grass/trunk/gui/wxpython/psmap/frame.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/psmap/frame.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -1241,7 +1241,8 @@
             return
         dc.SetBackground(wx.LIGHT_GREY_BRUSH)
         dc.Clear()
Modified: grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
--- grass/trunk/gui/wxpython/psmap/g.gui.psmap.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/psmap/g.gui.psmap.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -49,7 +49,8 @@
     frame = PsMapFrame(parent = None)
     frame.Show()
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -36,6 +36,7 @@
 from rlisetup.frame import RLiSetupFrame
@@ -43,7 +44,8 @@
                     unicode = True)
     frame = RLiSetupFrame(parent = None, giface = StandaloneGrassInterface())
     frame.Show()
Modified: grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
--- grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -41,6 +41,7 @@
 if __name__ == '__main__':
 from mapdisp.frame import MapFrame
@@ -79,7 +80,8 @@
         os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
     frame = VDigitMapFrame(options['map'])
     frame.Show()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2013-02-05 08:19:54 UTC (rev 54915)
+++ grass/trunk/gui/wxpython/wxgui.py	2013-02-05 08:42:01 UTC (rev 54916)
@@ -51,7 +51,8 @@
         @return True
         # create splash screen
         introImagePath = os.path.join(globalvar.ETCIMGDIR, "silesia_splash.png")
