[GRASS-SVN] r55099 - grass-addons/grass6/vector/v.out.kml
svn_grass at osgeo.org
Sun Feb 17 16:45:47 PST 2013
Author: hamish
Date: 2013-02-17 16:45:47 -0800 (Sun, 17 Feb 2013)
New Revision: 55099
grass-addons/grass6/vector/v.out.kml/v.out.kml
safety from bashisms
Modified: grass-addons/grass6/vector/v.out.kml/v.out.kml
--- grass-addons/grass6/vector/v.out.kml/v.out.kml 2013-02-18 00:41:24 UTC (rev 55098)
+++ grass-addons/grass6/vector/v.out.kml/v.out.kml 2013-02-18 00:45:47 UTC (rev 55099)
@@ -198,7 +198,7 @@
# purpose: Removes all temporary files which might have been created.
# usage: CLEANUP_TEMPFILES
-function CLEANUP_TEMPFILES ()
+CLEANUP_TEMPFILES()
rm $TMPDIR/.grassrc6_$TEMP_LOCATION
rm $THE_VECTOR.shp
@@ -219,7 +219,7 @@
# name: exitprocedure
# purpose: removes all temporary files
-exitprocedure ()
+exitprocedure()
message 0 "User break!"
#rm -f ${TMP}*
@@ -240,7 +240,7 @@
# name: error_routine
# purpose: If an error occurs, exit gracefully.
-error_routine () {
+error_routine() {
echo "ERROR: $1"
exit 1
@@ -271,7 +271,7 @@
# purpose: if the user provides a path to a specific version of OGR it will be used.
# usage: OGR_PATH_USER_OVERRIDE
-function OGR_PATH_USER_OVERRIDE ()
+OGR_PATH_USER_OVERRIDE()
if [ "${OPT_OGRPATH}" != "" ] ; then
@@ -298,7 +298,7 @@
# purpose: Verify that string $1 equals the name of column of the maps database.
# usage: ENSURE_COLUMN string-for-column-name
-function ENSURE_COLUMN () {
+ENSURE_COLUMN() {
#1: $COLUMN NAME to be verified
echo $DB_COLUMN_NAMES |grep -q "$1"
@@ -313,7 +313,7 @@
# purpose: create new string variables for R,G,B as 2byte hex numbers from a R:G:B string (can be hex, decimal or other).
# usage: SET_HEX_COLORS value-string-variable R-variable-name G-variable-name B-variable-name R-hex-default G-hex-default B-hex-default
-function SET_HEX_COLORS
+SET_HEX_COLORS()
if [ "$1" != "(null)" ] ; then
RED_D=`echo ${1} | cut -d: -f 1 `
@@ -347,7 +347,8 @@
# usage: SET_HEX_VALUE grass_parameter-variable new-variable-name default-value
-function SET_HEX_VALUE () {
+SET_HEX_VALUE()
#1: $OPT_LINE_SIZE 2:GMLSIZE 3:1
@@ -383,7 +384,7 @@
# Has a value for line color been provided by the user ?
# Otherwise use grass-green as the default.
-SET_HEX_COLORS ${OPT_LINE_COLOR} "GMLRED" "GMLGREEN" "GMLBLUE" "0" "ff" "0"
+SET_HEX_COLORS "${OPT_LINE_COLOR}" "GMLRED" "GMLGREEN" "GMLBLUE" "0" "ff" "0"
