[GRASS-SVN] r55100 - grass-addons/grass6/vector/v.out.kml
Sun Feb 17 18:28:30 PST 2013
Author: hamish
Date: 2013-02-17 18:28:30 -0800 (Sun, 17 Feb 2013)
New Revision: 55100
   grass-addons/grass6/vector/v.out.kml/v.out.kml
fix bashisms, gui sections, curly brackets don't work/replace with "quotes", always quote filenames
Modified: grass-addons/grass6/vector/v.out.kml/v.out.kml
--- grass-addons/grass6/vector/v.out.kml/v.out.kml	2013-02-18 00:45:47 UTC (rev 55099)
+++ grass-addons/grass6/vector/v.out.kml/v.out.kml	2013-02-18 02:28:30 UTC (rev 55100)
@@ -4,7 +4,7 @@
 # MODULE:       v.out.kml
 # AUTHOR(S):    Peter Loewe <peter.loewe AT grass-verein.de>
-# PURPOSE:      Export GRASS point/line/area-vectors into a KML file in
+# PURPOSE:      Export GRASS point/line/area-vectors into a KML file in
 #               geographic coordinates (lat lon).
 # COPYRIGHT:    (c) 2007 Peter Loewe and the GRASS DEVELOPMENT TEAM
@@ -20,7 +20,7 @@
 #%Module
-#%  description: Creates a KML-file from GRASS point/line/polygon vectors
+#%  description: Creates a KML-file from GRASS point/line/polygon vectors
 #%End
 #%flag
 #%  key: l
@@ -42,30 +42,31 @@
 #% key: map
 #% type: string
 #% gisprompt: old,vector,vector
-#% description: vector input map
+#% description: Vector input map
 #% required : yes
 #%end
 #%option
 #% key: output
 #% type: string
 #% gisprompt: new_file,file,file
-#% description: name/path of kml output
+#% description: Name/path of KML output
 #% required : no
 #%end
 #%option
 #% key: ogrpath
 #% type: string
 #% gisprompt: old_file,file,file
-#% description: optional path to ogr2ogr
+#% description: Optional path to ogr2ogr
 #% required : no
 #%end
 #%option
 #% key: color
 #% type: string
 #% gisprompt: color,grass,color
-#% description: hexcode triplet for line color (blue:green:red 00:00:00-255:255:255)
+#% description: hexcode triplet for line color (blue:green:red 00:00:00-255:255:255)
 #% answer : 00:200:00
 #% required : no
+#% guisection: Lines
 #%end
 #%option
 #% key: transparency
@@ -73,6 +74,7 @@
 #% description: integer for vector line transparency (0=invisible 255=opaque)
 #% answer : 255
 #% required : no
 #%end
 #%option
 #% key: fcolor
@@ -81,6 +83,7 @@
 #% description: hexcode triplet for polygon fill color (blue:green:red 00:00:00-255:255:255)
 #% answer : 00:100:00
 #% required : no
+#% guisection: Polygons
 #%end
 #%option
 #% key: ftransparency
@@ -88,6 +91,7 @@
 #% description: integer for polygon transparency (00=invisible 255=opaque)
 #% answer : 255
 #% required : no
 #%end
 #%option
 #% key: size
@@ -96,30 +100,34 @@
 #% options: 0.5,1,1.5,2,2.5,3,3.5,4,4.5,5,5.5,6,6.5,7,7.5,8,8.5,9,9.5,10
 #% answer : 1
 #% required : no
 #%end
 #%option
 #% key: iconcode
 #% type: string
-#% description: Select an icons number within its palette for point-vectors
+#% description: Select an icons number within its palette for point-vectors
 #% options: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45
 #% answer : 1
 #% required : no
+#% guisection: Icons
 #%end
 #%option
 #% key: iconpalette
 #% type: string
-#% description: Select a KML palette of icons for point-vectors
+#% description: Select a KML palette of icons for point-vectors
 #% answer : 1
 #% required :no
 #%end
 #%option
 #% key: iconcolor
 #% type: string
-#% description: hexcode color triplet for point-vectors (blue:green:red 00:00:00-255:255:255)
+#% description: hexcode color triplet for point-vectors (blue:green:red 00:00:00-255:255:255)
 #% required : no
 #%end
 #%option
 #% key: icontransparency
@@ -127,37 +135,42 @@
 #% description: integer for point-vector transparency (0=invisible 255=opaque 0-255)
 #% answer : 255
 #% required : no
 #%end
 #%option
 #% key: iconurl
 #% type: string
-#% description: Provide a URL pointing to a symbol for point-vectors
+#% description: Provide a URL pointing to a symbol for point-vectors
 #% required : no
 #%end
 #%option
 #% key: linecolumn
 #% type: string
 #% description: column name string for line color ([xxx]:xxx:xxx:xxx). Transparency should be provided as first value, unless 3-Flag is set.
 #% required : no
 #%end
 #%option
 #% key: fillcolumn
 #% type: string
 #% description: column name string for area fill color ([xxx]:xxx:xxx:xxx). Transparency should be provided as first value, unless 3-Flag is set.
 #% required : no
 #%end
 #%option
 #% key: linetranscolumn
 #% type: string
 #% description: column name string for line transparency (xxx). This option is overridden by the 'transparency'-option.
 #% required : no
 #%end
 #%option
 #% key: filltranscolumn
 #% type: string
 #% description: column name string for fill transparency (xxx). This option is overridden by the 'transparency'-option.
 #% required : no
 #%end
@@ -165,29 +178,29 @@
 ### This is good practice if we have to change terms in the GUI/frontend.
-FLAG_FORCE_LINE_EXPORT=${GIS_FLAG_L}
-FLAG_FORCE_POLYGON_EXPORT=${GIS_FLAG_Y}
-FLAG_POINT_EXPORT=${GIS_FLAG_P}
-FLAG_RANDOM_COLORS=${GIS_FLAG_R}
+FLAG_FORCE_LINE_EXPORT="$GIS_FLAG_L"
+FLAG_FORCE_POLYGON_EXPORT="$GIS_FLAG_Y"
+FLAG_POINT_EXPORT="$GIS_FLAG_P"
+FLAG_RANDOM_COLORS="$GIS_FLAG_R"
-OPT_MAP=${GIS_OPT_MAP}
-OPT_OUTPUT=${GIS_OPT_OUTPUT}
-OPT_OGRPATH=${GIS_OPT_OGRPATH}
-OPT_LINE_COLOR=${GIS_OPT_COLOR}
-OPT_LINE_TRANS=${GIS_OPT_TRANSPARENCY}
-OPT_FILL_COLOR=${GIS_OPT_FCOLOR}
-OPT_FILL_TRANS=${GIS_OPT_FTRANSPARENCY}
-OPT_LINE_SIZE=${GIS_OPT_SIZE}
-OPT_ICON_CODE=${GIS_OPT_ICONCODE}
-OPT_ICON_PALETTE=${GIS_OPT_ICONPALETTE}
-OPT_ICON_COLOR=${GIS_OPT_ICONCOLOR}
-OPT_ICON_TRANS=${GIS_OPT_ICONTRANSPARENCY}
-OPT_ICON_URL=${GIS_OPT_ICONURL}
-OPT_COLUMN_LINE_COLOR=${GIS_OPT_LINECOLUMN}
-OPT_COLUMN_LINE_TRANS=${GIS_OPT_LINETRANSCOLUMN}
-OPT_COLUMN_FILL_COLOR=${GIS_OPT_FILLCOLUMN}
-OPT_COLUMN_FILL_TRANS=${GIS_OPT_FILLTRANSCOLUMN}
+OPT_MAP="$GIS_OPT_MAP"
+OPT_OUTPUT="$GIS_OPT_OUTPUT"
+OPT_OGRPATH="$GIS_OPT_OGRPATH"
+OPT_LINE_COLOR="$GIS_OPT_COLOR"
+OPT_LINE_TRANS="$GIS_OPT_TRANSPARENCY"
+OPT_FILL_COLOR="$GIS_OPT_FCOLOR"
+OPT_FILL_TRANS="$GIS_OPT_FTRANSPARENCY"
+OPT_LINE_SIZE="$GIS_OPT_SIZE"
+OPT_ICON_CODE="$GIS_OPT_ICONCODE"
+OPT_ICON_PALETTE="$GIS_OPT_ICONPALETTE"
+OPT_ICON_COLOR="$GIS_OPT_ICONCOLOR"
+OPT_ICON_TRANS="$GIS_OPT_ICONTRANSPARENCY"
+OPT_ICON_URL="$GIS_OPT_ICONURL"
+OPT_COLUMN_LINE_COLOR="$GIS_OPT_LINECOLUMN"
+OPT_COLUMN_LINE_TRANS="$GIS_OPT_LINETRANSCOLUMN"
+OPT_COLUMN_FILL_COLOR="$GIS_OPT_FILLCOLUMN"
+OPT_COLUMN_FILL_TRANS="$GIS_OPT_FILLTRANSCOLUMN"
 TMPDIR=`g.gisenv get="GISDBASE"`
@@ -198,20 +211,20 @@
 # purpose:  Removes all temporary files which might have been created.
 # usage: CLEANUP_TEMPFILES
-CLEANUP_TEMPFILES()
+CLEANUP_TEMPFILES()
- rm $TMPDIR/.grassrc6_$TEMP_LOCATION
- rm $THE_VECTOR.shp
- rm  $THE_VECTOR.shx
- rm  $THE_VECTOR.prj
- rm  $THE_VECTOR.dbf
- rm  $VECTOR_KML.raw
- rm  $VECTOR_KML.cat_poly
- rm  $VECTOR_KML.cat_point
- rm  $VECTOR_KML.prepoint
- rm -rf $GISDBASE/$TEMP_LOCATION/PERMANENT
- rmdir $GISDBASE/$TEMP_LOCATION
- rm -rf $VECTOR_KML.raw2
+ rm "$TMPDIR/.grassrc6_$TEMP_LOCATION"
+ rm "$THE_VECTOR.shp"
+ rm "$THE_VECTOR.shx"
+ rm "$THE_VECTOR.prj"
+ rm "$THE_VECTOR.dbf"
+ rm "$VECTOR_KML.raw"
+ rm "$VECTOR_KML.cat_poly"
+ rm "$VECTOR_KML.cat_point"
+ rm "$VECTOR_KML.prepoint"
+ rm -rf "$GISDBASE/$TEMP_LOCATION/PERMANENT"
+ rmdir "$GISDBASE/$TEMP_LOCATION"
+ rm -rf "$VECTOR_KML.raw2"
@@ -221,12 +234,12 @@
 exitprocedure()
-        message 0 "User break!"
-        #rm -f ${TMP}*
-        #rm $TMPDIR/.grassrc6_$TEMP_LOCATION
-        #rm -rf $GISDBASE/$TEMP_LOCATION
-        CLEANUP_TEMPFILES
-        exit 1
+    message 0 "User break!"
+    #rm -f "$TMP"*
+    #rm "$TMPDIR/.grassrc6_$TEMP_LOCATION"
+    #rm -rf "$GISDBASE/$TEMP_LOCATION"
+    CLEANUP_TEMPFILES
+    exit 1
 trap "exitprocedure" 2 3 15
@@ -268,29 +281,29 @@
 # name: OGR_PATH_USER_OVERRIDE
-# purpose: if the user provides a path to a specific version of OGR it will be used.
+# purpose: if the user provides a path to a specific version of OGR it will be used.
 # usage: OGR_PATH_USER_OVERRIDE
 OGR_PATH_USER_OVERRIDE()
- if [ "${OPT_OGRPATH}" != "" ] ; then
+ if [ -n "$OPT_OGRPATH" ] ; then
    #ensure that the path-string properly ends with the file name
-   OGR_ENDING=`echo ${OPT_OGRPATH} | grep "/ogr2ogr$" `
+   OGR_ENDING=`echo "$OPT_OGRPATH" | grep "/ogr2ogr$" `
-   if [ "$OGR_ENDING" == "" ] ; then
-      OPT_OGRPATH="${OPT_OGRPATH}/ogr2ogr"
+   if [ -z "$OGR_ENDING" ] ; then
+      OPT_OGRPATH="$OPT_OGRPATH/ogr2ogr"
    fi
-   if [ -f ${OPT_OGRPATH} ]; then
-    #store this path as a GRASS variable for further use
-    THE_OGR_PATH=$OPT_OGRPATH
-    `g.gisenv set="GML_OGR_PATH"=${OPT_OGRPATH}`
+   if [ -f "$OPT_OGRPATH" ] ; then
+      #store this path as a GRASS variable for further use
+      THE_OGR_PATH=$OPT_OGRPATH
+      `g.gisenv set="GML_OGR_PATH=$OPT_OGRPATH"`
     else
-     error_routine "Invalid path to OGR: ${THE_OGR_PATH}"
-   fi
+       error_routine "Invalid path to OGR: <$THE_OGR_PATH>"
+   fi
  fi
@@ -301,23 +314,23 @@
 ENSURE_COLUMN() {
 #1: $COLUMN NAME to be verified
-   echo $DB_COLUMN_NAMES |grep -q "$1"
-   if [ $? != 0 ] ; then
+   echo $DB_COLUMN_NAMES | grep -q "$1"
+   if [ $? -ne 0 ] ; then
      error_routine "$1 is not a database column."
    fi
 # name:     SET__HEX_COLORS
-# purpose:  create new string variables for R,G,B as 2byte hex numbers from a R:G:B string (can be hex, decimal or other).
+# purpose:  create new string variables for R,G,B as 2byte hex numbers from a R:G:B string (can be hex, decimal or other).
 # usage: SET_HEX_COLORS value-string-variable R-variable-name G-variable-name B-variable-name R-hex-default G-hex-default B-hex-default
 SET_HEX_COLORS()
 if [ "$1" != "(null)" ] ; then
   RED_D=`echo ${1} | cut -d: -f 1 `
-  eval "$2"=`printf "%02x" $RED_D`
+  eval "$2"=`printf "%02x" $RED_D`
   GREEN_D=`echo ${1} | cut -d: -f 2 `
   eval "$3"=`printf "%02x" $GREEN_D`
@@ -328,15 +341,15 @@
   eval "$3=$5"
   eval "$3=$6"
   eval "$4=$7"
-fi
+fi
 if [ "${GIS_FLAG_r}" = 1 ] ; then
      # the flag for random colors is set
-     RCOLOR=`expr ${RANDOM} % 255`
+     RCOLOR=`expr $RANDOM % 255`
      eval "$2"=`printf "%02x" $RCOLOR`
      eval "$4"=`printf "%02x" $RCOLOR`
      eval "$3"=`printf "%02x" $RCOLOR`
 fi
@@ -365,43 +378,42 @@
 ### Verify correct column names
 ### if they are provided, they are needed further below
- if [ "${OPT_COLUMN_LINE_TRANS}" != "" ] ; then
-      ENSURE_COLUMN "${OPT_COLUMN_LINE_TRANS}"
+ if [ -n "$OPT_COLUMN_LINE_TRANS" ] ; then
+      ENSURE_COLUMN "$OPT_COLUMN_LINE_TRANS"
  fi
- if [ "${OPT_COLUMN_FILL_TRANS}" != "" ] ; then
-      ENSURE_COLUMN "${OPT_COLUMN_FILL_TRANS}"
+ if [ -n "$OPT_COLUMN_FILL_TRANS" ] ; then
+      ENSURE_COLUMN "$OPT_COLUMN_FILL_TRANS"
  fi
  fi
+       ENSURE_COLUMN "$OPT_COLUMN_FILL_TRANS"    #dupe?
  fi
-# Has a value for line color been provided by the user ?
+# Has a value for line color been provided by the user ?
 # Otherwise use grass-green as the default.
-SET_HEX_COLORS "${OPT_LINE_COLOR}" "GMLRED" "GMLGREEN" "GMLBLUE" "0" "ff" "0"
+SET_HEX_COLORS "$OPT_LINE_COLOR" "GMLRED" "GMLGREEN" "GMLBLUE" "0" "ff" "0"
 ### Has a value for a polygon fill color been provided by the user ?
-SET_HEX_COLORS "${OPT_FILL_COLOR}" "GMLFILLRED" "GMLFILLGREEN" "GMLFILLBLUE" "0" "ff" "0"
+SET_HEX_COLORS "$OPT_FILL_COLOR" "GMLFILLRED" "GMLFILLGREEN" "GMLFILLBLUE" "0" "ff" "0"
 ### Has a value for a icon color been provided by the user ?
-SET_HEX_COLORS "${OPT_ICON_COLOR}" "GMLICONRED" "GMLICONGREEN" "GMLICONBLUE" "0" "ff" "0"
+SET_HEX_COLORS "$OPT_ICON_COLOR" "GMLICONRED" "GMLICONGREEN" "GMLICONBLUE" "0" "ff" "0"
 ### Has a transparency value  been provided by the user ?
 # Otherwise use full opacity as the default.
-SET_HEX_VALUE "${OPT_LINE_TRANS}" "GMLTRANSPARENCY"  "ff"
+SET_HEX_VALUE "$OPT_LINE_TRANS" "GMLTRANSPARENCY"  "ff"
@@ -409,13 +421,13 @@
 ### Otherwise use full opacity as the default.
-SET_HEX_VALUE "${OPT_FILL_TRANS}" "GMLFILLTRANSPARENCY"  "ff"
+SET_HEX_VALUE "$OPT_FILL_TRANS" "GMLFILLTRANSPARENCY"  "ff"
 ## Has a icon-transparency value  been provided by the user ?
-SET_HEX_VALUE "${OPT_ICON_TRANS}" "GMLICONTRANSPARENCY"  "ff"
+SET_HEX_VALUE "$OPT_ICON_TRANS" "GMLICONTRANSPARENCY"  "ff"
 ## Has a line-size value  been provided by the user ?
@@ -426,16 +438,16 @@
 # Ensure that the output file has the proper .kml-extension
 # if no output file has been named, fall back to the name of the map.
-if [ -z "${OPT_OUTPUT}" ] ; then
-  VECTOR_KML=${OPT_MAP}.kml
+if [ -z "$OPT_OUTPUT" ] ; then
+  VECTOR_KML="$OPT_MAP.kml"
  else
-  VECTOR_KML=${OPT_OUTPUT}
+  VECTOR_KML="$OPT_OUTPUT"
 fi
-KML_ENDING=`echo $VECTOR_KML | grep ".kml$" `
+KML_ENDING=`echo "$VECTOR_KML" | grep ".kml$" `
 if [ -z "$KML_ENDING" ] ; then
- VECTOR_KML=$VECTOR_KML.kml
+ VECTOR_KML="$VECTOR_KML.kml"
 fi
@@ -447,15 +459,15 @@
      s/::/:.:/g
      s/:$/:./
      s/:/ /g'`
-     do
-            if [ -f $i/ogr2ogr ] ; then
-		OGR_AVAILABLE=1
-                THE_OGR_PATH="$i/ogr2ogr"
-		break
-	    fi
-     done
+do
+    if [ -f $i/ogr2ogr ] ; then
+     	OGR_AVAILABLE=1
+     	THE_OGR_PATH="$i/ogr2ogr"
+     	break
+    fi
+done
-# has a custom  ogr2ogr path already been provided on this machine (like in previous GRASS sessions) ?
+# has a custom  ogr2ogr path already been provided on this machine (like in previous GRASS sessions) ?
 # in any case, if the user explicitly provides a ogr2ogr path from the command line,
 # this one will override any defaults or previous settings
@@ -463,16 +475,16 @@
 if [ "${PREVIOUS_SESSION_OGR}" ] ; then
    # if a ogr setting has been stored from former sessions then use it.
-   THE_OGR_PATH=${PREVIOUS_SESSION_OGR}
+   THE_OGR_PATH="$PREVIOUS_SESSION_OGR"
    #Even if we have a path to OGR provided by the system, the user can override it.
 else
-  # this might be the first session ever, so lets stick to the user-provided path
+  # this might be the first session ever, so lets stick to the user-provided path
-  if [ "${THE_OGR_PATH}" == "" ]; then
+  if [ -z "$THE_OGR_PATH" ] ; then
    error_routine "  ogr2ogr is not found in your default search-path. Is it installed ? You might provide a path to ogr2ogr as a second argument to this program."
   fi
@@ -480,11 +492,11 @@
  #So we have ogr2ogr, but can it deal with KML ?
   echo "$THE_OGR_PATH --formats"
-  OGR_KML=`$THE_OGR_PATH --formats |grep "KML"`
+  OGR_KML=`"$THE_OGR_PATH" --formats |grep "KML"`
   if [ -z "$OGR_KML" ]; then
-     error_routine "  $THE_OGR_PATH is lacking KML support."
+     error_routine "  $THE_OGR_PATH lacks support for KML."
   fi
 fi
@@ -493,19 +505,19 @@
 # Setting the Line/Poly flags
 # Only one of both flags can be set:
-if [ "${FLAG_FORCE_LINE_EXPORT}" = 1 ] && [ "${FLAG_FORCE_POLYGON_EXPORT}" = 1 ] ; then
-   error_routine "Conflicting flag settings: -l and -y can not be used together."
+if [ "$FLAG_FORCE_LINE_EXPORT" = 1 ] && [ "$FLAG_FORCE_POLYGON_EXPORT" = 1 ] ; then
+   error_routine "Conflicting flag settings: -l and -y can not be used together."
 fi
 # Get the name of the vector layer to be converted
-THE_VECTOR=${OPT_MAP}
+THE_VECTOR="$OPT_MAP"
 # create a name fpr the temporary location
 TEMP_LOCATION=latlon_location_$$
 # Create a new temporary latlon location
-g.proj -c proj4='+init=epsg:4326' location=$TEMP_LOCATION
+g.proj -c proj4='+init=epsg:4326' location="$TEMP_LOCATION"
 #Set variables
 GISDBASE=`g.gisenv get=GISDBASE`
@@ -513,57 +525,57 @@
 OUTER_MAPSET=`g.gisenv get=MAPSET`
 #Keep the path to the settings file for the original location
-export OUTER_GISRC=$GISRC
+export OUTER_GISRC="$GISRC"
 ##generate GRASS_settings-file for lat lon location:
-echo "GISDBASE: $GISDBASE " > $TMPDIR/.grassrc6_$TEMP_LOCATION
-echo "LOCATION_NAME: $TEMP_LOCATION " >> $TMPDIR/.grassrc6_$TEMP_LOCATION
-echo "MAPSET: PERMANENT " >>  $TMPDIR/.grassrc6_$TEMP_LOCATION
-echo "GRASS_GUI: text " >>  $TMPDIR/.grassrc6_$TEMP_LOCATION
+echo "GISDBASE: $GISDBASE " > "$TMPDIR/.grassrc6_$TEMP_LOCATION"
+echo "LOCATION_NAME: $TEMP_LOCATION " >> "$TMPDIR/.grassrc6_$TEMP_LOCATION"
+echo "MAPSET: PERMANENT " >> "$TMPDIR/.grassrc6_$TEMP_LOCATION"
+echo "GRASS_GUI: text " >> "$TMPDIR/.grassrc6_$TEMP_LOCATION"
 ##switch over to lat lon location
-export GISRC=$TMPDIR/.grassrc6_$TEMP_LOCATION
+export GISRC="$TMPDIR/.grassrc6_$TEMP_LOCATION"
 #use process ID (PID) as lock file number:
 export GIS_LOCK=$$
 # Import the vector data into the lat lon location
-v.proj input=$THE_VECTOR location=$OUTER_LOCATION mapset=$OUTER_MAPSET
+v.proj input="$THE_VECTOR" location="$OUTER_LOCATION" mapset="$OUTER_MAPSET"
 ## VECTOR FEATURE EXPORT OR POLYGON FEATURE EXPORT
-if [ "${FLAG_FORCE_LINE_EXPORT}" == 1 ] ; then
-    GEOMETRY="kernel,line,boundary"
+if [ "$FLAG_FORCE_LINE_EXPORT" = 1 ] ; then
+    GEOMETRY="kernel,line,boundary"
 fi
-if [ "${FLAG_FORCE_POLYGON_EXPORT}" == 1 ] ; then
-    GEOMETRY="area"
+if [ "$FLAG_FORCE_POLYGON_EXPORT" = 1 ] ; then
+    GEOMETRY="area"
 fi
-if [ "${FLAG_POINT_EXPORT}" == 1 ] ; then
- if [ "$GEOMETRY" != "" ] ; then
-   GEOMETRY="$GEOMETRY,point"
- else
-   GEOMETRY="point"
- fi
+if [ "$FLAG_POINT_EXPORT" = 1 ] ; then
+  if [ -n "$GEOMETRY" ] ; then
+    GEOMETRY="$GEOMETRY,point"
+  else
+    GEOMETRY="point"
+  fi
 fi
-v.out.ogr input=$THE_VECTOR type=$GEOMETRY dsn=. olayer=$THE_VECTOR
+v.out.ogr input="$THE_VECTOR" type="$GEOMETRY" dsn=. olayer="$THE_VECTOR"
 #Switch back to the original location
-export GISRC=$OUTER_GISRC
-GISRC=$OUTER_GISRC
+export GISRC="$OUTER_GISRC"
+GISRC="$OUTER_GISRC"
@@ -571,8 +583,8 @@
-echo "$OGR_PATH -f KML $VECTOR_KML.raw $THE_VECTOR.sh"
-`$THE_OGR_PATH -f KML $VECTOR_KML.raw $THE_VECTOR.shp` || error_routine "$OGR_PATH aborted."
+echo "$OGR_PATH -f KML $VECTOR_KML.raw $THE_VECTOR.sh"
+`"$THE_OGR_PATH" -f KML "$VECTOR_KML.raw" "$THE_VECTOR.shp"` || error_routine "$OGR_PATH aborted."
@@ -580,8 +592,8 @@
 # create indicators for points and lines
-cat $VECTOR_KML.raw | grep PolyStyle > $VECTOR_KML.cat_poly
-cat $VECTOR_KML.raw | grep Point > $VECTOR_KML.cat_point
+cat "$VECTOR_KML.raw" | grep PolyStyle > "$VECTOR_KML.cat_poly"
+cat "$VECTOR_KML.raw" | grep Point > "$VECTOR_KML.cat_point"
@@ -589,7 +601,7 @@
 if [ -s "$VECTOR_KML.cat_poly" ]; then
-  sed "s/<color>........<\/color>/<size>${GMLSIZE}<\/size><color>${GMLTRANSPARENCY}${GMLBLUE}${GMLGREEN}${GMLRED}<\/color>/g" $VECTOR_KML.raw > $VECTOR_KML.raw2
+  sed "s/<color>........<\/color>/<size>${GMLSIZE}<\/size><color>${GMLTRANSPARENCY}${GMLBLUE}${GMLGREEN}${GMLRED}<\/color>/g" $VECTOR_KML.raw > $VECTOR_KML.raw2
   sed "s/<fill>0<\/fill>/<color>${GMLFILLTRANSPARENCY}${GMLFILLBLUE}${GMLFILLGREEN}${GMLFILLRED}<\/color>/g" $VECTOR_KML.raw2 > $VECTOR_KML.prepoint
  else
@@ -601,53 +613,53 @@
 ##  Add color, transparency and icon for points
-if [ -s "$VECTOR_KML.cat_point" ] &&  [ "${GIS_FLAG_P}" = 1 ] ; then
+if [ -s "$VECTOR_KML.cat_point" ] &&  [ "$GIS_FLAG_P" = 1 ] ; then
 # There are point-vectors in the file AND we want to deal with them
   POINT_BEGIN="<Style><IconStyle><color>${GMLICONTRANSPARENCY}${GMLICONBLUE}${GMLICONGREEN}${GMLICONRED}<\/color><Icon><href>"
   POINT_END="<\/href><\/Icon><\/IconStyle><\/Style>"
-    if [ "${OPT_ICON_URL}" ] ; then
+    if [ "${OPT_ICON_URL}" ] ; then
       # an URL has been provided by the user
-      ICONURL=` echo ${OPT_ICON_URL} | sed "s|\/|\\\\\/|g"`
+      ICONURL=` echo "$OPT_ICON_URL" | sed "s|\/|\\\\\/|g"`
       POINT_STYLE="${POINT_BEGIN}${ICONURL}${POINT_END}"
       sed "s/<\/Point>/<\/Point>${POINT_STYLE}/g" $VECTOR_KML.prepoint > $VECTOR_KML
     else
-          if [ -z "${OPT_ICON_CODE}" ] || [ -z "${OPT_ICON_PALETTE}" ] ; then
-              error_routine "GML ICON PROBLEM: ICON=${OPT_ICON_CODE} PALETTE=${OPT_ICON_PALETTE}."
+          if [ -z "$OPT_ICON_CODE" ] || [ -z "$OPT_ICON_PALETTE" ] ; then
+              error_routine "GML ICON PROBLEM: ICON=$OPT_ICON_CODE PALETTE=$OPT_ICON_PALETTE."
           fi
-          if [ "${OPT_ICON_CODE}" -a "${OPT_ICON_PALETTE}" ] ; then
+          if [ "$OPT_ICON_CODE" -a "$OPT_ICON_PALETTE" ] ; then
               ICONURL="http:\/\/maps.google.com\/mapfiles\/kml\/pal${OPT_ICON_PALETTE}\/icon${OPT_ICON_CODE}.png"
-              sed "s/<\/Point>/<\/Point>${POINT_STYLE}/g" $VECTOR_KML.prepoint > $VECTOR_KML
+              sed "s/<\/Point>/<\/Point>${POINT_STYLE}/g" $VECTOR_KML.prepoint > "$VECTOR_KML"
           else
-              cp  $VECTOR_KML.prepoint $VECTOR_KML
-              # let handle googleearth the icon rendering
+              cp "$VECTOR_KML.prepoint" "$VECTOR_KML"
+              # let handle googleearth the icon rendering
           fi
     fi
 else
  #no points around so the results from the line/polygon-conversion are to be used
 fi  # cat_points && gis_flag_p  ende
-## The files for the transparenices have to be defined prior to pumping the awk-content
+## The files for the transparenices have to be defined prior to pumping the awk-content
 ## into the strings -> the transparency values are integrated into the awk-strings
-# ENSURE_COLUMN "${OPT_COLUMN_LINE_TRANS}"
-   AWK_LINE_TRANS_QUERY="/^.*${OPT_COLUMN_LINE_TRANS}.*$/ { parse_event=1; print \$0; split(\$2,a1,\">\"); split(a1[2],a2,\"<\"); LINETRANS=a2[1];} "
+ if [ -n "${OPT_COLUMN_LINE_TRANS}" ] ; then
+# ENSURE_COLUMN "${OPT_COLUMN_LINE_TRANS}"
+   AWK_LINE_TRANS_QUERY="/^.*$OPT_COLUMN_LINE_TRANS.*$/ { parse_event=1; print \$0; split(\$2,a1,\">\"); split(a1[2],a2,\"<\"); LINETRANS=a2[1];} "
  else
    AWK_LINE_TRANS_QUERY=""
  fi
  # a database column for line-transparency has explicitly been set
  #  ENSURE_COLUMN "${OPT_COLUMN_FILL_TRANS}"
-   AWK_FILL_TRANS_QUERY="/^.*${OPT_COLUMN_FILL_TRANS}.*$/ { parse_event=1; print \$0; split(\$2,a1,\">\"); split(a1[2],a2,\"<\"); FILLTRANS=a2[1];} "
+   AWK_FILL_TRANS_QUERY="/^.*$OPT_COLUMN_FILL_TRANS.*$/ { parse_event=1; print \$0; split(\$2,a1,\">\"); split(a1[2],a2,\"<\"); FILLTRANS=a2[1];} "
  else
   AWK_FILL_TRANS_QUERY=""
@@ -666,40 +678,40 @@
 /^.*$OPT_COLUMN_LINE_COLOR.*$/ {
                         print \$0;
-                        parse_event=1;
+                        parse_event=1;
                         rgb_provided=1;
                         split(\$2,array1,">");
                         split(array1[2],array2,"<");
-                        grassrgb=array2[1];
+                        grassrgb=array2[1];
                         split(grassrgb,colors,":");
-                        hex_rgb=sprintf("%2.2x%2.2x%2.2x",colors[1],colors[2],colors[3]);
+                        hex_rgb=sprintf("%2.2x%2.2x%2.2x",colors[1],colors[2],colors[3]);
 $AWK_LINE_TRANS_QUERY
 /^.*<Style>.*$/         {
                         if (rgb_provided == 1)
                             the_rgb=hex_rgb;
                             rgb_provided=0;
-                         else
+                         else
-                            the_rgb=hex_fallback;
+                            the_rgb=hex_fallback;
                         # LINETRANS can either be inserted from the GRASS_DB by a $AWK_LINE_TRANS_QUERY or when the script is called up.
                         parse_event=1;
-                        the_line=\$0;
+                        the_line=\$0;
                         gsub(/\<color\>........\<\/color\>\<\/LineStyle\>/,"<color>"hex_line_trans the_rgb"</color></LineStyle>", the_line);
                         print the_line;
-                        {if (parse_event == 0) {print \$0;}
-			  else { parse_event=0; }
+                        {if (parse_event == 0) {print \$0;}
+			  else { parse_event=0; }
 END
@@ -707,22 +719,22 @@
 ##################### AWK-Code for FILL:###################################
-awktemp_fill=/tmp/awk.prog.fill.$$
-cat > $awktemp_fill <<END
+awktemp_fill="/tmp/awk.prog.fill.$$"
+cat > "$awktemp_fill" << END
 BEGIN                   {
-                         hex_fallback=sprintf("%2.2x%2.2x%2.2x",32,32,32);
-                         hex_fill_trans=FILLTRANS;
+                         hex_fallback=sprintf("%2.2x%2.2x%2.2x",32,32,32);
+                         hex_fill_trans=FILLTRANS;
 /^.*$OPT_COLUMN_FILL_COLOR.*$/ {
-                        parse_event=1;
+                        parse_event=1;
                         rgb_provided=1;
 $AWK_FILL_TRANS_QUERY
@@ -734,19 +746,18 @@
                             the_rgb=hex_rgb;
                             rgb_provided=0;
-                         else
+                         else
-                        gsub(/\<color\>........\<\/color\>\<\/PolyStyle\>/,"<color>"hex_fill_trans the_rgb"</color></PolyStyle>",the_line);
+                        gsub(/\<color\>........\<\/color\>\<\/PolyStyle\>/,"<color>"hex_fill_trans the_rgb"</color></PolyStyle>",the_line);
                         print the_line;
 END
@@ -754,23 +765,23 @@
 #apply AWK-Codes if necessary (aka database columns have been provided):
-   if [ "${OPT_COLUMN_LINE_COLOR}" != "" ] ; then
-     AWK_LINE_RGB=${OPT_COLUMN_LINE_COLOR}
-     awk -f $awktemp_line -v LINETRANS=$GMLTRANSPARENCY  $VECTOR_KML > $VECTOR_KML.awk
+   if [ -n "$OPT_COLUMN_LINE_COLOR" ] ; then
+     AWK_LINE_RGB="$OPT_COLUMN_LINE_COLOR"
+     awk -f $awktemp_line -v LINETRANS=$GMLTRANSPARENCY  $VECTOR_KML > "$VECTOR_KML.awk"
      echo "awk -f $awktemp_line -v LINETRANS=$GMLTRANSPARENCY  $VECTOR_KML > $VECTOR_KML.awk"
-     mv $VECTOR_KML  $VECTOR_KML.preline
-     mv $VECTOR_KML.awk $VECTOR_KML
+     mv "$VECTOR_KML" "$VECTOR_KML.preline"
+     mv "$VECTOR_KML.awk" "$VECTOR_KML"
    fi
-   if [ "${OPT_COLUMN_FILL_COLOR}" != "" ] ; then
+   if [ -n "$OPT_COLUMN_FILL_COLOR" ] ; then
       # a column for fill colors has been explicitly set
-     AWK_FILL_RGB=${OPT_COLUMN_FILL_COLOR}
+     AWK_FILL_RGB="$OPT_COLUMN_FILL_COLOR"
      echo "awk -f $awktemp_fill -v FILLTRANS=$GMLFILLTRANSPARENCY  $VECTOR_KML > $VECTOR_KML.awk"
-     awk -f $awktemp_fill -v FILLTRANS=$GMLFILLTRANSPARENCY  $VECTOR_KML > $VECTOR_KML.awk
-     mv $VECTOR_KML  $VECTOR_KML.prefill
+     awk -f $awktemp_fill -v FILLTRANS="$GMLFILLTRANSPARENCY"  "$VECTOR_KML" > "$VECTOR_KML.awk"
+     mv "$VECTOR_KML"  "$VECTOR_KML.prefill"
    fi
