[GRASS-SVN] r55139 - grass/trunk/vector/v.category
svn_grass at osgeo.org
Thu Feb 21 02:12:02 PST 2013
Author: mmetz
Date: 2013-02-21 02:12:02 -0800 (Thu, 21 Feb 2013)
New Revision: 55139
grass/trunk/vector/v.category/main.c
v.category: add option=layers
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2013-02-21 09:42:00 UTC (rev 55138)
+++ grass/trunk/vector/v.category/main.c 2013-02-21 10:12:02 UTC (rev 55139)
@@ -29,6 +29,7 @@
#define O_CHFIELD 6
#define O_TYPE_REP 7 /* report number of features for each type */
#define O_TRANS 8
+#define O_LYR 9
#define FRTYPES 9 /* number of field report types */
@@ -97,7 +98,7 @@
option_opt->type = TYPE_STRING;
option_opt->required = YES;
option_opt->multiple = NO;
- option_opt->options = "add,del,chlayer,sum,report,print,transfer";
+ option_opt->options = "add,del,chlayer,sum,report,print,layers,transfer";
option_opt->description = _("Action to be done");
desc = NULL;
G_asprintf(&desc,
@@ -107,14 +108,16 @@
"sum;%s;"
"transfer;%s;"
"report;%s;"
- "print;%s",
+ "print;%s;"
+ "layers;%s",
_("add a new category"),
_("delete category (-1 to delete all categories of given layer)"),
_("change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"),
_("add the value specified by cat option to the current category value"),
_("copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"),
_("print report (statistics), in shell style: layer type count min max"),
- _("print category values, more cats in the same layer are separated by '/'"));
+ _("print category values, more cats in the same layer are separated by '/'"),
+ _("print only layer numbers"));
option_opt->descriptions = desc;
cat_opt = G_define_standard_option(G_OPT_V_CAT);
@@ -163,8 +166,35 @@
case ('p'):
option = O_PRN;
break;
+ case ('l'):
+ option = O_LYR;
+ break;
+ if (option == O_LYR) {
+ /* print vector layer numbers */
+ /* open vector on level 2 head only, this is why this option
+ * is processed here, all other options need (?) to fully open
+ * the input vector */
+ Vect_set_open_level(2);
+ if (Vect_open_old_head2(&In, in_opt->answer, "", field_opt->answer) < 2) {
+ G_fatal_error(_("Can not open vector <%s> on level %d"),
+ Vect_get_full_name(&In), 2);
+ if (In.format == GV_FORMAT_NATIVE) {
+ nfields = Vect_cidx_get_num_fields(&In);
+ for (i = 0; i < nfields; i++) {
+ if ((field = Vect_cidx_get_field_number(&In, i)) > 0)
+ fprintf(stdout, "%d\n", field);
+ else
+ fprintf(stdout, "%s\n", field_opt->answer);
+ Vect_close(&In);
+ exit(EXIT_SUCCESS);
cat = atoi(cat_opt->answer);
step = atoi(step_opt->answer);
otype = Vect_option_to_types(type_opt);
@@ -186,7 +216,7 @@
Clist = NULL;
- if ((option != O_REP) && (option != O_PRN)) {
+ if ((option != O_REP) && (option != O_PRN) && (option != O_LYR)) {
if (out_opt->answer == NULL)
G_fatal_error(_("Output vector wasn't entered"));
@@ -200,7 +230,8 @@
/* do we need topology ? */
if ((option == O_ADD && (otype & GV_AREA)) ||
(option == O_REP && (otype & GV_AREA)) ||
- (option == O_TRANS)) /* topo for cidx check */
+ (option == O_TRANS) || /* topo for cidx check */
+ (option == O_LYR)) /* topo for cidx check */
open_level = 2;
else
open_level = 1;
