[GRASS-SVN] r55140 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Thu Feb 21 02:13:02 PST 2013
Author: mmetz
Date: 2013-02-21 02:13:02 -0800 (Thu, 21 Feb 2013)
New Revision: 55140
grass/trunk/gui/wxpython/core/utils.py
wxGUI: GetVectorNumberOfLayers use v.category op=layers
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2013-02-21 10:12:02 UTC (rev 55139)
+++ grass/trunk/gui/wxpython/core/utils.py 2013-02-21 10:13:02 UTC (rev 55140)
@@ -304,11 +304,11 @@
Debug.msg(5, "utils.GetVectorNumberOfLayers(): vector map '%s' not found" % vector)
return layers
- ret, out, msg = RunCommand('v.db.connect',
+ ret, out, msg = RunCommand('v.category',
getErrorMsg = True,
read = True,
- flags = 'g',
- map = fullname,
+ input = fullname,
+ option = 'layers',
sep = ';')
if ret != 0:
sys.stderr.write(_("Vector map <%(map)s>: %(msg)s\n") % { 'map' : fullname, 'msg' : msg })
@@ -316,14 +316,8 @@
else:
Debug.msg(1, "GetVectorNumberOfLayers(): ret %s" % ret)
- for line in out.splitlines():
- try:
- layer = line.split(';')[0]
- if '/' in layer:
- layer = layer.split('/')[0]
- layers.append(layer)
- except IndexError:
- pass
+ for layer in out.splitlines():
+ layers.append(layer)
Debug.msg(3, "utils.GetVectorNumberOfLayers(): vector=%s -> %s" % \
(fullname, ','.join(layers)))
