[GRASS-SVN] r55199 - grass/branches/develbranch_6/scripts/g.mremove
svn_grass at osgeo.org
Mon Feb 25 12:38:58 PST 2013
Author: hamish
Date: 2013-02-25 12:38:57 -0800 (Mon, 25 Feb 2013)
New Revision: 55199
grass/branches/develbranch_6/scripts/g.mremove/g.mremove
better handle spaces in GISDBASE (#1683)
Modified: grass/branches/develbranch_6/scripts/g.mremove/g.mremove
--- grass/branches/develbranch_6/scripts/g.mremove/g.mremove 2013-02-25 20:02:28 UTC (rev 55198)
+++ grass/branches/develbranch_6/scripts/g.mremove/g.mremove 2013-02-25 20:38:57 UTC (rev 55199)
@@ -93,15 +93,12 @@
fi
if test "$GISBASE" = ""; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
fi
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
-PROG=`basename "$0"`
+MAPSET=`g.gisenv get=MAPSET`
g.message "Collecting map names for current mapset <$MAPSET>..."
@@ -127,81 +124,82 @@
d="$GIS_OPT_DVIEW"
if [ -n "$r" ] ; then
- rast=`g.mlist $regex type=rast sep=, mapset=$MAPSET pattern="$r"`
+ rast=`g.mlist $regex type=rast sep=, mapset="$MAPSET" pattern="$r"`
fi
if [ -n "$r3" ] ; then
- rast3d=`g.mlist $regex type=rast3d sep=, mapset=$MAPSET pattern="$r3"`
+ rast3d=`g.mlist $regex type=rast3d sep=, mapset="$MAPSET" pattern="$r3"`
fi
if [ -n "$v" ] ; then
- vect=`g.mlist $regex type=vect sep=, mapset=$MAPSET pattern="$v"`
+ vect=`g.mlist $regex type=vect sep=, mapset="$MAPSET" pattern="$v"`
fi
if [ -n "$i" ] ; then
- icon=`g.mlist $regex type=icon sep=, mapset=$MAPSET pattern="$i"`
+ icon=`g.mlist $regex type=icon sep=, mapset="$MAPSET" pattern="$i"`
fi
if [ -n "$l" ] ; then
- labels=`g.mlist $regex type=labels sep=, mapset=$MAPSET pattern="$l"`
+ labels=`g.mlist $regex type=labels sep=, mapset="$MAPSET" pattern="$l"`
fi
if [ -n "$rg" ] ; then
- region=`g.mlist $regex type=region sep=, mapset=$MAPSET pattern="$rg"`
+ region=`g.mlist $regex type=region sep=, mapset="$MAPSET" pattern="$rg"`
fi
if [ -n "$g" ] ; then
- group=`g.mlist $regex type=group sep=, mapset=$MAPSET pattern="$g"`
+ group=`g.mlist $regex type=group sep=, mapset="$MAPSET" pattern="$g"`
fi
if [ -n "$d" ] ; then
- dview=`g.mlist $regex type=3dview sep=, mapset=$MAPSET pattern="$d"`
+ dview=`g.mlist $regex type=3dview sep=, mapset="$MAPSET" pattern="$d"`
fi
-found=
+found=""
if [ "$rast" ] ; then
- found=1
- rast="rast=$rast"
+ found=1
+ rast="rast=$rast"
fi
if [ "$rast3d" ] ; then
- found=1
- rast3d="rast3d=$rast3d"
+ found=1
+ rast3d="rast3d=$rast3d"
fi
if [ "$vect" ] ; then
- found=1
- vect="vect=$vect"
+ found=1
+ vect="vect=$vect"
fi
if [ "$icon" ] ; then
- found=1
- icon="icon=$icon"
+ found=1
+ icon="icon=$icon"
fi
if [ "$labels" ] ; then
- found=1
- labels="labels=$labels"
+ found=1
+ labels="labels=$labels"
fi
if [ "$region" ] ; then
- found=1
- region="region=$region"
+ found=1
+ region="region=$region"
fi
if [ "$group" ] ; then
- found=1
- group="group=$group"
+ found=1
+ group="group=$group"
fi
if [ "$dview" ] ; then
- found=1
- dview="3dview=$dview"
+ found=1
+ dview="3dview=$dview"
fi
if [ ! "$found" ] ; then
- g.message -e "No data found."
- exit 1
+ g.message -e "No data found."
+ exit 1
fi
if [ $force -eq 0 ] ; then
