[GRASS-SVN] r55200 - grass/branches/develbranch_6/scripts/db.dropcol
svn_grass at osgeo.org
Mon Feb 25 12:49:49 PST 2013
Author: hamish
Date: 2013-02-25 12:49:49 -0800 (Mon, 25 Feb 2013)
New Revision: 55200
grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
remove some unused code, minor robustness tweaks
Modified: grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
--- grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol 2013-02-25 20:38:57 UTC (rev 55199)
+++ grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol 2013-02-25 20:49:49 UTC (rev 55200)
@@ -53,14 +53,7 @@
exec g.parser "$0" "$@"
fi
-PROG=`basename "$0"`
-#### check if we have awk
-if [ ! -x "`which awk`" ] ; then
- g.message -e "awk required, please install awk or gawk first"
- exit 1
-fi
# setting environment, so that awk works properly in all languages
unset LC_ALL
LC_NUMERIC=C
@@ -89,9 +82,6 @@
trap "exitprocedure" 2 3 15
### setup enviro vars ###
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
table="$GIS_OPT_TABLE"
# check if DB parameters are set, and if not set them.
@@ -102,8 +92,8 @@
# schema needed for PG?
col="$GIS_OPT_COLUMN"
-force=$GIS_FLAG_F
-if [ $force -eq 1 ] ; then
+force="$GIS_FLAG_F"
+if [ "$force" -eq 1 ] ; then
g.message "Forcing ..."
fi
@@ -115,14 +105,15 @@
#exit 1
fi
-db.describe -c $GIS_OPT_TABLE | grep '^Column ' | cut -d':' -f2 | grep "^ ${col}" 2>&1 >/dev/null
+db.describe -c "$GIS_OPT_TABLE" | grep '^Column ' | \
+ cut -d':' -f2 | grep "^ ${col}" 2>&1 >/dev/null
if [ $? -ne 0 ] ; then
g.message -e "Column <$col> not found in table"
cleanup
exit 1
fi
-if [ $force -eq 0 ] ; then
+if [ "$force" -eq 0 ] ; then
g.message "The <$col> column would be deleted."
g.message message=""
g.message "You must use the force flag to actually remove it. Exiting."
@@ -138,7 +129,8 @@
cat "$TEMPFILE.coldesc" | cut -d':' -f1 > "$TEMPFILE.colnames"
COLDEF=`paste -d' ' "$TEMPFILE.colnames" "$TEMPFILE.coltypes" | tr '\n' ',' | sed 's+,$++g'`
COLNAMES=`cat "$TEMPFILE.colnames" | tr '\n' ',' | sed 's+,$++g'`
-echo "BEGIN TRANSACTION;
+ echo "BEGIN TRANSACTION;
CREATE TEMPORARY TABLE ${table}_backup(${COLDEF});
INSERT INTO ${table}_backup SELECT ${COLNAMES} FROM ${table};
DROP TABLE ${table};
@@ -146,15 +138,17 @@
INSERT INTO ${table} SELECT ${COLNAMES} FROM ${table}_backup;
DROP TABLE ${table}_backup;
COMMIT;" > "$TEMPFILE"
db.execute input="$TEMPFILE"
- if [ $? -eq 1 ] ; then
+ if [ $? -ne 0 ] ; then
g.message -e "Cannot continue (problem deleting column)."
cleanup
exit 1
fi
else
- echo "ALTER TABLE $table DROP COLUMN $col" | db.execute database="${database}" driver=${driver}
+ echo "ALTER TABLE $table DROP COLUMN $col" | \
+ db.execute database="$database" driver="$driver"
cleanup
exit 1
@@ -165,4 +159,3 @@
cleanup
exit 0
