[GRASS-SVN] r55266 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Feb 28 10:51:54 PST 2013
Author: mmetz
Date: 2013-02-28 10:51:53 -0800 (Thu, 28 Feb 2013)
New Revision: 55266
grass/trunk/lib/vector/Vlib/break_lines.c
Vlib: update Vect_break_lines()
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2013-02-28 18:51:16 UTC (rev 55265)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2013-02-28 18:51:53 UTC (rev 55266)
@@ -120,7 +120,7 @@
int ai = *(int *)a;
int bi = *(int *)b;
- return (ai < bi ? -1 : ai > bi);
+ return (ai - bi);
static void sort_ilist(struct ilist *List, int (*cmp_ilist)(const void *, const void *))
@@ -146,10 +146,11 @@
struct line_pnts *APoints, *BPoints, *Points;
struct line_pnts **AXLines, **BXLines;
struct line_cats *ACats, *BCats, *Cats;
- int j, k, l, ret, atype, btype, aline, bline, found, iline, nlines;
+ int j, k, l, ret, atype, btype, aline, bline, found, iline;
+ int nlines, nlines_org;
int naxlines, nbxlines, nx;
double *xx = NULL, *yx = NULL, *zx = NULL;
- struct bound_box ABox, BBox;
+ struct bound_box ABox, *BBox;
struct boxlist *List;
int nbreaks;
int touch1_n = 0, touch1_s = 0, touch1_e = 0, touch1_w = 0; /* other vertices except node1 touching box */
@@ -170,14 +171,26 @@
if (List_break) {
nlines = List_break->n_values;
+ nlines_org = 0;
+ for (i = 0; i < List_break->n_values; i++) {
+ if (nlines_org < List_break->value[i])
+ nlines_org = List_break->value[i];
else {
nlines = Vect_get_num_lines(Map);
+ nlines_org = nlines;
G_debug(3, "nlines = %d", nlines);
- /* TODO: It seems that lines/boundaries are not broken at intersections
- * with points/centroids. Check if true, if yes, skip GV_POINTS
+ /* TODO:
+ * 1. It seems that lines/boundaries are not broken at intersections
+ * with points/centroids. Check if true, if yes, skip GV_POINTS
+ * 2. list of lines to break and list of reference lines
+ * aline: line to break, if List_break == NULL, break all
+ * bline: reference line, if List_ref == NULL, use all
+ * break bline only if it is in the list of lines to break
/* To find intersection of two lines (Vect_line_intersection) is quite slow.
@@ -253,17 +266,15 @@
G_debug(3, " %d lines selected by box", List->n_values);
for (j = 0; j < List->n_values; j++) {
bline = List->id[j];
- if (List_break && !Vect_val_in_list(List_break, bline)) {
- continue;
/* check intersection of aline with bline only once */
if (bline > aline) {
if (!List_ref)
continue;
else if (bsearch(&bline, List_ref->value, List_ref->n_values,
- sizeof(int), cmp))
+ sizeof(int), cmp))
continue;
@@ -271,11 +282,12 @@
btype = Vect_read_line(Map, BPoints, BCats, bline);
+ BBox = &List->box[j];
/* Check if touch by end node only */
if (!is3d) {
Vect_get_line_nodes(Map, aline, &anode1, &anode2);
Vect_get_line_nodes(Map, bline, &bnode1, &bnode2);
- BBox = List->box[j];
node = 0;
if (anode1 == bnode1 || anode1 == bnode2)
@@ -286,21 +298,21 @@
if (node) {
Vect_get_node_coor(Map, node, &nodex, &nodey, NULL);
if ((node == anode1 && nodey == ABox.N &&
- !touch1_n && nodey == BBox.S) ||
+ !touch1_n && nodey == BBox->S) ||
(node == anode2 && nodey == ABox.N &&
- !touch2_n && nodey == BBox.S) ||
+ !touch2_n && nodey == BBox->S) ||
(node == anode1 && nodey == ABox.S &&
- !touch1_s && nodey == BBox.N) ||
+ !touch1_s && nodey == BBox->N) ||
(node == anode2 && nodey == ABox.S &&
- !touch2_s && nodey == BBox.N) ||
+ !touch2_s && nodey == BBox->N) ||
(node == anode1 && nodex == ABox.E &&
- !touch1_e && nodex == BBox.W) ||
+ !touch1_e && nodex == BBox->W) ||
(node == anode2 && nodex == ABox.E &&
- !touch2_e && nodex == BBox.W) ||
+ !touch2_e && nodex == BBox->W) ||
(node == anode1 && nodex == ABox.W &&
- !touch1_w && nodex == BBox.E) ||
+ !touch1_w && nodex == BBox->E) ||
(node == anode2 && nodex == ABox.W &&
- !touch2_w && nodex == BBox.E)) {
+ !touch2_w && nodex == BBox->E)) {
G_debug(3,
"lines %d and %d touching by end nodes only -> no intersection",
@@ -312,7 +324,8 @@
AXLines = NULL;
BXLines = NULL;
- Vect_line_intersection(APoints, BPoints, &AXLines, &BXLines,
+ Vect_line_intersection(APoints, BPoints, &ABox, BBox,
+ &AXLines, &BXLines,
&naxlines, &nbxlines, 0);
G_debug(3, " naxlines = %d nbxlines = %d", naxlines, nbxlines);
@@ -398,7 +411,15 @@
G_free(AXLines);
if (nbxlines > 0) {
- if (aline != bline) { /* Self intersection, do not write twice, TODO: is it OK? */
+ int break_bline = 1;
+ if (List_break && !Vect_val_in_list(List_break, bline)) {
+ break_bline = 0;
+ if (aline == bline) { /* Self intersection, do not write twice, TODO: is it OK? */
+ break_bline = 0;
+ if (break_bline) {
if (!check)
Vect_delete_line(Map, bline);
for (k = 0; k < nbxlines; k++) {
