[GRASS-SVN] r55267 - grass/trunk/lib/vector/vedit
svn_grass at osgeo.org
Thu Feb 28 10:52:24 PST 2013
Author: mmetz
Date: 2013-02-28 10:52:24 -0800 (Thu, 28 Feb 2013)
New Revision: 55267
grass/trunk/lib/vector/vedit/zbulk.c
vedit lib update
Modified: grass/trunk/lib/vector/vedit/zbulk.c
--- grass/trunk/lib/vector/vedit/zbulk.c 2013-02-28 18:51:53 UTC (rev 55266)
+++ grass/trunk/lib/vector/vedit/zbulk.c 2013-02-28 18:52:24 UTC (rev 55267)
@@ -40,6 +40,7 @@
struct line_cats *Cats;
struct line_pnts *Points, *Points_se; /* start - end */
+ struct bound_box box, box_se;
/* for intersection */
struct line_pnts **Points_a, **Points_b;
@@ -68,6 +69,8 @@
if (temp_line < 0) {
return -1;
+ Vect_line_box(Points_se, &box_se);
/* determine order of lines */
cv_i = 0;
@@ -82,8 +85,9 @@
if (!(type & GV_LINE))
continue;
+ Vect_line_box(Points, &box);
if (Vect_line_check_intersection(Points_se, Points, WITH_Z)) {
- Vect_line_intersection(Points_se, Points,
+ Vect_line_intersection(Points_se, Points, &box_se, &box,
&Points_a, &Points_b, &nlines_a, &nlines_b,
WITHOUT_Z);
@@ -108,7 +112,7 @@
/* z bulk-labeling */
for (cv_i = 0; cv_i < cv.n_values; cv_i++) {
line = cv.value[cv_i].cat;
- Vect_read_line(Map, Points, Cats, line);
+ type = Vect_read_line(Map, Points, Cats, line);
for (p_i = 0; p_i < Points->n_points; p_i++) {
Points->z[p_i] = value;
