[GRASS-SVN] r54507 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Wed Jan 2 10:57:25 PST 2013
Author: martinl
Date: 2013-01-02 10:57:25 -0800 (Wed, 02 Jan 2013)
New Revision: 54507
grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI: attempt to fix LayerSelect (check v.category instead of v.db.connect)
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2013-01-02 18:42:32 UTC (rev 54506)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2013-01-02 18:57:25 UTC (rev 54507)
@@ -729,25 +729,24 @@
layers.append('-1')
if vector:
- # TODO: use Vect_get_field2() in C modules where possible
- # currently the following is identical to
- # layers = utils.GetVectorNumberOfLayers(self, vector)
- ret = RunCommand('v.db.connect',
+ ret = RunCommand('v.category',
read = True,
quiet = True,
- sep = '|',
+ option = 'report',
flags = 'g',
- map = vector)
+ input = vector)
if ret:
for line in ret.splitlines():
- layerinfo = line.split('|')
- layername = layerinfo[0].split('/')
+ if 'all' not in line:
+ continue
+ try:
+ layer = line.split(' ')[0]
+ except IndexError:
+ continue
# use this to get layer names
# but only when all modules use Vect_get_field2()
# which is not the case right now
- ### layers.append(layername[len(layername) - 1])
- layers.append(layername[0])
+ layers.append(layer)
elif dsn:
ret = RunCommand('v.in.ogr',
