[GRASS-SVN] r54508 - grass/branches/releasebranch_6_4
svn_grass at osgeo.org
Thu Jan 3 02:42:27 PST 2013
Author: martinl
Date: 2013-01-03 02:42:27 -0800 (Thu, 03 Jan 2013)
New Revision: 54508
grass/branches/releasebranch_6_4/configure
grass/branches/releasebranch_6_4/configure.in
fix configure for osgeo4w
geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure 2013-01-02 18:57:25 UTC (rev 54507)
+++ grass/branches/releasebranch_6_4/configure 2013-01-03 10:42:27 UTC (rev 54508)
@@ -8057,73 +8057,23 @@
CPPFLAGS=$ac_save_cppflags
- if test "$MINGW32" = yes ; then
+### geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
+# if test "$MINGW32" = yes ; then
+# LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# else
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$GEOS_LIBS $LDFLAGS"
-echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:8068: checking for initGEOS in -lgeos_c_i" >&5
-ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-lgeos_c_i $LIBS"
-cat > conftest.$ac_ext <<EOF
-#line 8074 "configure"
-#include "confdefs.h"
-/* Override any gcc2 internal prototype to avoid an error. */
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char initGEOS();
-int main() {
-initGEOS()
-; return 0; }
-EOF
-if { (eval echo configure:8085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=yes"
-else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
- echo "$ac_t""yes" 1>&6
- GEOS_LIBS="$GEOS_LIBS -lgeos_c_i "
-else
- echo "$ac_t""no" 1>&6
-LDFLAGS=${ac_save_ldflags}
- { echo "configure: error: *** Unable to locate GEOS library." 1>&2; exit 1; }
-fi
- else
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$GEOS_LIBS $LDFLAGS"
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8121: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8071: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 8127 "configure"
+#line 8077 "configure"
@@ -8134,7 +8084,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8163,7 +8113,7 @@
- fi
+# fi
cat >> confdefs.h <<\EOF
#define HAVE_GEOS 1
@@ -8179,7 +8129,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8183: checking whether to use TIFF" >&5
+echo "configure:8133: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8199,7 +8149,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8203: checking for location of TIFF includes" >&5
+echo "configure:8153: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8225,15 +8175,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8229: checking for $ac_hdr" >&5
+echo "configure:8179: checking for $ac_hdr" >&5
-#line 8232 "configure"
+#line 8182 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8237: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8267,7 +8217,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8271: checking for location of TIFF library" >&5
+echo "configure:8221: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8298,13 +8248,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8302: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8252: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8308 "configure"
+#line 8258 "configure"
@@ -8315,7 +8265,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8334,13 +8284,13 @@
-echo "configure:8338: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8288: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8344 "configure"
+#line 8294 "configure"
@@ -8351,7 +8301,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8370,13 +8320,13 @@
-echo "configure:8374: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8324: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8380 "configure"
+#line 8330 "configure"
@@ -8387,7 +8337,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8406,13 +8356,13 @@
-echo "configure:8410: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8360: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8416 "configure"
+#line 8366 "configure"
@@ -8423,7 +8373,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8442,13 +8392,13 @@
-echo "configure:8446: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8396: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 8452 "configure"
+#line 8402 "configure"
@@ -8459,7 +8409,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8478,13 +8428,13 @@
-echo "configure:8482: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8432: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 8488 "configure"
+#line 8438 "configure"
@@ -8495,7 +8445,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8514,13 +8464,13 @@
-echo "configure:8518: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8468: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 8524 "configure"
+#line 8474 "configure"
@@ -8531,7 +8481,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8550,13 +8500,13 @@
-echo "configure:8554: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8504: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 8560 "configure"
+#line 8510 "configure"
@@ -8567,7 +8517,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8665,7 +8615,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8669: checking whether to use PNG" >&5
+echo "configure:8619: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8684,7 +8634,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8688: checking for location of PNG includes" >&5
+echo "configure:8638: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8710,15 +8660,15 @@
do
-echo "configure:8714: checking for $ac_hdr" >&5
+echo "configure:8664: checking for $ac_hdr" >&5
-#line 8717 "configure"
+#line 8667 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8752,7 +8702,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8756: checking for location of PNG library" >&5
+echo "configure:8706: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8777,13 +8727,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8781: checking for png_read_image in -lpng" >&5
+echo "configure:8731: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8787 "configure"
+#line 8737 "configure"
@@ -8794,7 +8744,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8836,7 +8786,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8840: checking whether to use PostgreSQL" >&5
+echo "configure:8790: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8863,7 +8813,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8867: checking for location of PostgreSQL includes" >&5
+echo "configure:8817: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8889,15 +8839,15 @@
do
-echo "configure:8893: checking for $ac_hdr" >&5
+echo "configure:8843: checking for $ac_hdr" >&5
-#line 8896 "configure"
+#line 8846 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8901: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8935,7 +8885,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8939: checking for location of PostgreSQL library" >&5
+echo "configure:8889: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8964,13 +8914,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8968: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8918: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8974 "configure"
+#line 8924 "configure"
@@ -8981,7 +8931,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9000,13 +8950,13 @@
-echo "configure:9004: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8954: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9010 "configure"
+#line 8960 "configure"
@@ -9017,7 +8967,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9036,13 +8986,13 @@
-echo "configure:9040: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8990: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9046 "configure"
+#line 8996 "configure"
@@ -9053,7 +9003,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9072,13 +9022,13 @@
-echo "configure:9076: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9026: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9082 "configure"
+#line 9032 "configure"
@@ -9089,7 +9039,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9146,13 +9096,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9150: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9100: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9156 "configure"
+#line 9106 "configure"
@@ -9163,7 +9113,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9185,13 +9135,13 @@
-echo "configure:9189: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9139: checking for PQcmdTuples in -lpq" >&5
-#line 9195 "configure"
+#line 9145 "configure"
@@ -9202,7 +9152,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9245,7 +9195,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9249: checking whether to use MySQL" >&5
+echo "configure:9199: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9265,7 +9215,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9269: checking for location of MySQL includes" >&5
+echo "configure:9219: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9291,15 +9241,15 @@
do
-echo "configure:9295: checking for $ac_hdr" >&5
+echo "configure:9245: checking for $ac_hdr" >&5
-#line 9298 "configure"
+#line 9248 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9303: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9336,7 +9286,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9340: checking for location of MySQL library" >&5
+echo "configure:9290: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9367,13 +9317,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9371: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9321: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9377 "configure"
+#line 9327 "configure"
@@ -9384,7 +9334,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9403,13 +9353,13 @@
-echo "configure:9407: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9357: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9413 "configure"
+#line 9363 "configure"
@@ -9420,7 +9370,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9439,13 +9389,13 @@
-echo "configure:9443: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9393: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9449 "configure"
+#line 9399 "configure"
@@ -9456,7 +9406,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9475,13 +9425,13 @@
-echo "configure:9479: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9429: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9485 "configure"
+#line 9435 "configure"
@@ -9492,7 +9442,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9511,13 +9461,13 @@
-echo "configure:9515: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9465: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9521 "configure"
+#line 9471 "configure"
@@ -9528,7 +9478,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9547,13 +9497,13 @@
-echo "configure:9551: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9501: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9557 "configure"
+#line 9507 "configure"
@@ -9564,7 +9514,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9583,13 +9533,13 @@
-echo "configure:9587: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9537: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9593 "configure"
+#line 9543 "configure"
@@ -9600,7 +9550,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9619,13 +9569,13 @@
-echo "configure:9623: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9573: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9629 "configure"
+#line 9579 "configure"
@@ -9636,7 +9586,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9726,7 +9676,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:9730: checking for $ac_word" >&5
+echo "configure:9680: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9767,10 +9717,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9771: checking for mysql_server_init" >&5
+echo "configure:9721: checking for mysql_server_init" >&5
-#line 9774 "configure"
+#line 9724 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9793,7 +9743,7 @@
; return 0; }
EOF
-if { (eval echo configure:9797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9831,7 +9781,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9835: checking whether to use SQLite" >&5
+echo "configure:9785: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9851,7 +9801,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9855: checking for location of SQLite includes" >&5
+echo "configure:9805: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9877,15 +9827,15 @@
do
-echo "configure:9881: checking for $ac_hdr" >&5
+echo "configure:9831: checking for $ac_hdr" >&5
-#line 9884 "configure"
+#line 9834 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9839: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9928,7 +9878,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9932: checking for location of SQLite library" >&5
+echo "configure:9882: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9957,13 +9907,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9961: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9911: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 9967 "configure"
+#line 9917 "configure"
@@ -9974,7 +9924,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9993,13 +9943,13 @@
-echo "configure:9997: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9947: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 10003 "configure"
+#line 9953 "configure"
@@ -10010,7 +9960,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10029,13 +9979,13 @@
-echo "configure:10033: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9983: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10039 "configure"
+#line 9989 "configure"
@@ -10046,7 +9996,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10065,13 +10015,13 @@
-echo "configure:10069: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10019: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10075 "configure"
+#line 10025 "configure"
@@ -10082,7 +10032,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10151,7 +10101,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10155: checking whether to use FFMPEG" >&5
+echo "configure:10105: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10171,7 +10121,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10175: checking for location of FFMPEG includes" >&5
+echo "configure:10125: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10197,15 +10147,15 @@
do
-echo "configure:10201: checking for $ac_hdr" >&5
+echo "configure:10151: checking for $ac_hdr" >&5
-#line 10204 "configure"
+#line 10154 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10241,15 +10191,15 @@
do
-echo "configure:10245: checking for $ac_hdr" >&5
+echo "configure:10195: checking for $ac_hdr" >&5
-#line 10248 "configure"
+#line 10198 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10203: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10285,15 +10235,15 @@
do
-echo "configure:10289: checking for $ac_hdr" >&5
+echo "configure:10239: checking for $ac_hdr" >&5
-#line 10292 "configure"
+#line 10242 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10247: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10336,7 +10286,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10340: checking for location of FFMPEG library" >&5
+echo "configure:10290: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10363,13 +10313,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10367: checking for av_free in -lavutil" >&5
+echo "configure:10317: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10373 "configure"
+#line 10323 "configure"
@@ -10380,7 +10330,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10399,13 +10349,13 @@
-echo "configure:10403: checking for av_free in -lavutil" >&5
+echo "configure:10353: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10409 "configure"
+#line 10359 "configure"
@@ -10416,7 +10366,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10461,13 +10411,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:10465: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10415: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10471 "configure"
+#line 10421 "configure"
@@ -10478,7 +10428,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:10482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10497,13 +10447,13 @@
-echo "configure:10501: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10451: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10507 "configure"
+#line 10457 "configure"
@@ -10514,7 +10464,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:10518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10559,13 +10509,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:10563: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10513: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10569 "configure"
+#line 10519 "configure"
@@ -10576,7 +10526,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:10580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10595,13 +10545,13 @@
-echo "configure:10599: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10549: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10605 "configure"
+#line 10555 "configure"
@@ -10612,7 +10562,7 @@
; return 0; }
EOF
-if { (eval echo configure:10616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10671,7 +10621,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10675: checking whether to use OpenGL" >&5
+echo "configure:10625: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10705,7 +10655,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10709: checking for location of OpenGL includes" >&5
+echo "configure:10659: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10731,15 +10681,15 @@
do
-echo "configure:10735: checking for $ac_hdr" >&5
+echo "configure:10685: checking for $ac_hdr" >&5
-#line 10738 "configure"
+#line 10688 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10693: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10773,7 +10723,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10777: checking for location of OpenGL library" >&5
+echo "configure:10727: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10802,13 +10752,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10806: checking for glBegin in -lGL" >&5
+echo "configure:10756: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10812 "configure"
+#line 10762 "configure"
@@ -10819,7 +10769,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10838,13 +10788,13 @@
-echo "configure:10842: checking for glBegin in -lGL" >&5
+echo "configure:10792: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10848 "configure"
+#line 10798 "configure"
@@ -10855,7 +10805,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10874,13 +10824,13 @@
-echo "configure:10878: checking for glBegin in -lGL" >&5
+echo "configure:10828: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10884 "configure"
+#line 10834 "configure"
@@ -10891,7 +10841,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10910,13 +10860,13 @@
-echo "configure:10914: checking for glBegin in -lGL" >&5
+echo "configure:10864: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10920 "configure"
+#line 10870 "configure"
@@ -10927,7 +10877,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10989,13 +10939,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10993: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10943: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10999 "configure"
+#line 10949 "configure"
@@ -11006,7 +10956,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11025,13 +10975,13 @@
-echo "configure:11029: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10979: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11035 "configure"
+#line 10985 "configure"
@@ -11042,7 +10992,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11086,10 +11036,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11090: checking for glXCreatePbuffer" >&5
+echo "configure:11040: checking for glXCreatePbuffer" >&5
-#line 11093 "configure"
+#line 11043 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11112,7 +11062,7 @@
; return 0; }
EOF
-if { (eval echo configure:11116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11134,10 +11084,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11138: checking for glXCreateGLXPixmap" >&5
+echo "configure:11088: checking for glXCreateGLXPixmap" >&5
-#line 11141 "configure"
+#line 11091 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11160,7 +11110,7 @@
; return 0; }
EOF
-if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11199,7 +11149,7 @@
-echo "configure:11203: checking for location of OpenGL includes" >&5
+echo "configure:11153: checking for location of OpenGL includes" >&5
@@ -11225,15 +11175,15 @@
do
-echo "configure:11229: checking for $ac_hdr" >&5
+echo "configure:11179: checking for $ac_hdr" >&5
-#line 11232 "configure"
+#line 11182 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11237: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11268,10 +11218,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11272: checking for glBegin" >&5
+echo "configure:11222: checking for glBegin" >&5
-#line 11275 "configure"
+#line 11225 "configure"
which can conflict with char glBegin(); below. */
@@ -11294,7 +11244,7 @@
; return 0; }
EOF
-if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11309,10 +11259,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11313: checking for gluBeginCurve" >&5
+echo "configure:11263: checking for gluBeginCurve" >&5
-#line 11316 "configure"
+#line 11266 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11335,7 +11285,7 @@
; return 0; }
EOF
-if { (eval echo configure:11339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11379,7 +11329,7 @@
-echo "configure:11383: checking for location of OpenGL includes" >&5
+echo "configure:11333: checking for location of OpenGL includes" >&5
@@ -11405,15 +11355,15 @@
do
-echo "configure:11409: checking for $ac_hdr" >&5
+echo "configure:11359: checking for $ac_hdr" >&5
-#line 11412 "configure"
+#line 11362 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11367: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11447,7 +11397,7 @@
-echo "configure:11451: checking for location of OpenGL library" >&5
+echo "configure:11401: checking for location of OpenGL library" >&5
@@ -11472,18 +11422,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11476: checking for OpenGL library" >&5
+echo "configure:11426: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11480 "configure"
+#line 11430 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11507,18 +11457,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11511: checking for GLU library" >&5
+echo "configure:11461: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11515 "configure"
+#line 11465 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11567,7 +11517,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11571: checking whether to use Tcl/Tk" >&5
+echo "configure:11521: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11587,7 +11537,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11591: checking for location of Tcl/Tk includes" >&5
+echo "configure:11541: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11613,15 +11563,15 @@
do
-echo "configure:11617: checking for $ac_hdr" >&5
+echo "configure:11567: checking for $ac_hdr" >&5
-#line 11620 "configure"
+#line 11570 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11575: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11658,15 +11608,15 @@
do
-echo "configure:11662: checking for $ac_hdr" >&5
+echo "configure:11612: checking for $ac_hdr" >&5
-#line 11665 "configure"
+#line 11615 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11699,7 +11649,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11703: checking Tcl version" >&5
+echo "configure:11653: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11707,7 +11657,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 11711 "configure"
+#line 11661 "configure"
#include <stdio.h>
@@ -11719,7 +11669,7 @@
EOF
-if { (eval echo configure:11723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11737,7 +11687,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11741: checking Tk version" >&5
+echo "configure:11691: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11745,7 +11695,7 @@
else
-#line 11749 "configure"
+#line 11699 "configure"
#include <stdio.h>
@@ -11757,7 +11707,7 @@
EOF
-if { (eval echo configure:11761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11788,7 +11738,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11792: checking for location of Tcl/Tk library" >&5
+echo "configure:11742: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11828,13 +11778,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11832: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11782: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11838 "configure"
+#line 11788 "configure"
@@ -11845,7 +11795,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11864,13 +11814,13 @@
-echo "configure:11868: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11818: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11874 "configure"
+#line 11824 "configure"
@@ -11881,7 +11831,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11908,13 +11858,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11912: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11862: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11918 "configure"
+#line 11868 "configure"
@@ -11925,7 +11875,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11944,13 +11894,13 @@
-echo "configure:11948: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11898: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11954 "configure"
+#line 11904 "configure"
@@ -11961,7 +11911,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11988,13 +11938,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11992: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11942: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11998 "configure"
+#line 11948 "configure"
@@ -12005,7 +11955,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12024,13 +11974,13 @@
-echo "configure:12028: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11978: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12034 "configure"
+#line 11984 "configure"
@@ -12041,7 +11991,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12119,13 +12069,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12123: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12073: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12129 "configure"
+#line 12079 "configure"
@@ -12136,7 +12086,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12155,13 +12105,13 @@
-echo "configure:12159: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12109: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12165 "configure"
+#line 12115 "configure"
@@ -12172,7 +12122,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12199,13 +12149,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12203: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12153: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12209 "configure"
+#line 12159 "configure"
@@ -12216,7 +12166,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12235,13 +12185,13 @@
-echo "configure:12239: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12189: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12245 "configure"
+#line 12195 "configure"
@@ -12252,7 +12202,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12279,13 +12229,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12283: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12233: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12289 "configure"
+#line 12239 "configure"
@@ -12296,7 +12246,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12315,13 +12265,13 @@
-echo "configure:12319: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12269: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12325 "configure"
+#line 12275 "configure"
@@ -12332,7 +12282,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12422,13 +12372,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12426: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12376: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12432 "configure"
+#line 12382 "configure"
@@ -12439,7 +12389,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12488,7 +12438,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12492: checking whether to use ODBC" >&5
+echo "configure:12442: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12507,7 +12457,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12511: checking for location of ODBC includes" >&5
+echo "configure:12461: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12533,15 +12483,15 @@
do
-echo "configure:12537: checking for $ac_hdr" >&5
+echo "configure:12487: checking for $ac_hdr" >&5
-#line 12540 "configure"
+#line 12490 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12495: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12575,7 +12525,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12579: checking for location of ODBC library" >&5
+echo "configure:12529: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12600,13 +12550,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12604: checking for SQLConnect in -lodbc" >&5
+echo "configure:12554: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12610 "configure"
+#line 12560 "configure"
@@ -12617,7 +12567,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12642,13 +12592,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12646: checking for SQLConnect in -liodbc" >&5
+echo "configure:12596: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12652 "configure"
+#line 12602 "configure"
@@ -12659,7 +12609,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12684,11 +12634,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12688: checking for ODBC library" >&5
+echo "configure:12638: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12692 "configure"
+#line 12642 "configure"
#include <windows.h>
#include <sql.h>
@@ -12696,7 +12646,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12745,7 +12695,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12749: checking whether to use FFTW" >&5
+echo "configure:12699: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12764,7 +12714,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12768: checking for location of FFTW includes" >&5
+echo "configure:12718: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12790,15 +12740,15 @@
do
-echo "configure:12794: checking for $ac_hdr" >&5
+echo "configure:12744: checking for $ac_hdr" >&5
-#line 12797 "configure"
+#line 12747 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12802: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12752: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12826,15 +12776,15 @@
do
-echo "configure:12830: checking for $ac_hdr" >&5
+echo "configure:12780: checking for $ac_hdr" >&5
-#line 12833 "configure"
+#line 12783 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12788: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12862,15 +12812,15 @@
do
-echo "configure:12866: checking for $ac_hdr" >&5
+echo "configure:12816: checking for $ac_hdr" >&5
-#line 12869 "configure"
+#line 12819 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12916,7 +12866,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12920: checking for location of FFTW library" >&5
+echo "configure:12870: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12941,13 +12891,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12945: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12895: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12951 "configure"
+#line 12901 "configure"
@@ -12958,7 +12908,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12983,13 +12933,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12987: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12937: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12993 "configure"
+#line 12943 "configure"
@@ -13000,7 +12950,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13025,13 +12975,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13029: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12979: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13035 "configure"
+#line 12985 "configure"
@@ -13042,7 +12992,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13099,7 +13049,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13103: checking whether to use BLAS" >&5
+echo "configure:13053: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13120,7 +13070,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13124: checking for location of BLAS includes" >&5
+echo "configure:13074: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13140,7 +13090,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13144: checking for location of BLAS library" >&5
+echo "configure:13094: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13166,15 +13116,15 @@
do
-echo "configure:13170: checking for $ac_hdr" >&5
+echo "configure:13120: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 13173 "configure"
+#line 13123 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13128: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13209,13 +13159,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13213: checking for dnrm2_ in -lblas" >&5
+echo "configure:13163: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $MATHLIB $LIBS"
-#line 13219 "configure"
+#line 13169 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13226,7 +13176,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13245,13 +13195,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13249: checking for dnrm2_ in -lblas" >&5
+echo "configure:13199: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13255 "configure"
+#line 13205 "configure"
@@ -13262,7 +13212,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13306,13 +13256,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13310: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13260: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13316 "configure"
+#line 13266 "configure"
@@ -13323,7 +13273,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13338,13 +13288,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13342: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13292: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13348 "configure"
+#line 13298 "configure"
@@ -13355,7 +13305,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13370,13 +13320,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13374: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13324: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13380 "configure"
+#line 13330 "configure"
@@ -13387,7 +13337,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13433,16 +13383,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13437: checking for sgemm in $vlib_flags" >&5
+echo "configure:13387: checking for sgemm in $vlib_flags" >&5
-#line 13439 "configure"
+#line 13389 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13460,13 +13410,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13464: checking for sgemm_ in -lblas" >&5
+echo "configure:13414: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13470 "configure"
+#line 13420 "configure"
@@ -13477,7 +13427,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13492,13 +13442,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13496: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13446: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13502 "configure"
+#line 13452 "configure"
@@ -13509,7 +13459,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13524,13 +13474,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13528: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13478: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13534 "configure"
+#line 13484 "configure"
@@ -13541,7 +13491,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13575,13 +13525,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13579: checking for acosp in -lsunmath" >&5
+echo "configure:13529: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13585 "configure"
+#line 13535 "configure"
@@ -13592,7 +13542,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13607,13 +13557,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13611: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13561: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13617 "configure"
+#line 13567 "configure"
@@ -13624,7 +13574,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13654,13 +13604,13 @@
# Generic BLAS library
-echo "configure:13658: checking for sgemm_ in -lblas" >&5
+echo "configure:13608: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13664 "configure"
+#line 13614 "configure"
@@ -13671,7 +13621,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13710,7 +13660,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13714: checking whether to use LAPACK" >&5
+echo "configure:13664: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13735,7 +13685,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13739: checking for location of LAPACK includes" >&5
+echo "configure:13689: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13755,7 +13705,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13759: checking for location of LAPACK library" >&5
+echo "configure:13709: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13781,15 +13731,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13785: checking for $ac_hdr" >&5
+echo "configure:13735: checking for $ac_hdr" >&5
-#line 13788 "configure"
+#line 13738 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13793: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13821,10 +13771,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13825: checking for dsegv_" >&5
+echo "configure:13775: checking for dsegv_" >&5
-#line 13828 "configure"
+#line 13778 "configure"
which can conflict with char dsegv_(); below. */
@@ -13847,7 +13797,7 @@
; return 0; }
EOF
-if { (eval echo configure:13851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13874,13 +13824,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13878: checking for desgv_ in -llapack" >&5
+echo "configure:13828: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13884 "configure"
+#line 13834 "configure"
@@ -13891,7 +13841,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13923,13 +13873,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13927: checking for dgesv_ in -llapack" >&5
+echo "configure:13877: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13933 "configure"
+#line 13883 "configure"
@@ -13940,7 +13890,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13959,13 +13909,13 @@
-echo "configure:13963: checking for dgesv_ in -llapack" >&5
+echo "configure:13913: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13969 "configure"
+#line 13919 "configure"
@@ -13976,7 +13926,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14032,7 +13982,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14036: checking whether to use Motif" >&5
+echo "configure:13986: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14051,7 +14001,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14055: checking for location of Motif includes" >&5
+echo "configure:14005: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14077,15 +14027,15 @@
do
-echo "configure:14081: checking for $ac_hdr" >&5
+echo "configure:14031: checking for $ac_hdr" >&5
-#line 14084 "configure"
+#line 14034 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14089: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14119,7 +14069,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14123: checking for location of Motif library" >&5
+echo "configure:14073: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14144,13 +14094,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14148: checking for XmStringCreate in -lXm" >&5
+echo "configure:14098: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14154 "configure"
+#line 14104 "configure"
@@ -14161,7 +14111,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14202,7 +14152,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14206: checking whether to use Cairo" >&5
+echo "configure:14156: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14234,7 +14184,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14238: checking for location of cairo includes" >&5
+echo "configure:14188: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14260,15 +14210,15 @@
do
-echo "configure:14264: checking for $ac_hdr" >&5
+echo "configure:14214: checking for $ac_hdr" >&5
-#line 14267 "configure"
+#line 14217 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14304,7 +14254,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14308: checking for location of cairo library" >&5
+echo "configure:14258: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14324,7 +14274,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14328: checking for cairo linking flags" >&5
+echo "configure:14278: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14340,10 +14290,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14344: checking for cairo_create" >&5
+echo "configure:14294: checking for cairo_create" >&5
-#line 14347 "configure"
+#line 14297 "configure"
which can conflict with char cairo_create(); below. */
@@ -14366,7 +14316,7 @@
; return 0; }
EOF
-if { (eval echo configure:14370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14400,10 +14350,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14404: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14354: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14407 "configure"
+#line 14357 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14426,7 +14376,7 @@
; return 0; }
EOF
-if { (eval echo configure:14430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14380: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14459,10 +14409,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14463: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14413: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14466 "configure"
+#line 14416 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -14485,7 +14435,7 @@
; return 0; }
EOF
-if { (eval echo configure:14489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -14527,7 +14477,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14531: checking whether to use GLw" >&5
+echo "configure:14481: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14546,7 +14496,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14550: checking for location of GLw includes" >&5
+echo "configure:14500: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14572,15 +14522,15 @@
do
-echo "configure:14576: checking for $ac_hdr" >&5
+echo "configure:14526: checking for $ac_hdr" >&5
-#line 14579 "configure"
+#line 14529 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14584: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14608,15 +14558,15 @@
do
-echo "configure:14612: checking for $ac_hdr" >&5
+echo "configure:14562: checking for $ac_hdr" >&5
-#line 14615 "configure"
+#line 14565 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14656,7 +14606,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14660: checking for location of GLw library" >&5
+echo "configure:14610: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14681,13 +14631,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14685: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14635: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14691 "configure"
+#line 14641 "configure"
@@ -14698,7 +14648,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14723,13 +14673,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14727: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14677: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14733 "configure"
+#line 14683 "configure"
@@ -14740,7 +14690,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14765,13 +14715,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14769: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14719: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14775 "configure"
+#line 14725 "configure"
@@ -14782,7 +14732,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14807,13 +14757,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14811: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14761: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14817 "configure"
+#line 14767 "configure"
@@ -14824,7 +14774,7 @@
; return 0; }
EOF
-if { (eval echo configure:14828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14849,13 +14799,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14853: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14803: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14859 "configure"
+#line 14809 "configure"
@@ -14866,7 +14816,7 @@
; return 0; }
EOF
-if { (eval echo configure:14870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14891,13 +14841,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14895: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14845: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14901 "configure"
+#line 14851 "configure"
@@ -14908,7 +14858,7 @@
; return 0; }
EOF
-if { (eval echo configure:14912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14935,13 +14885,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14939: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14889: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14945 "configure"
+#line 14895 "configure"
@@ -14952,7 +14902,7 @@
; return 0; }
EOF
-if { (eval echo configure:14956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14971,13 +14921,13 @@
-echo "configure:14975: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14925: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14981 "configure"
+#line 14931 "configure"
@@ -14988,7 +14938,7 @@
; return 0; }
EOF
-if { (eval echo configure:14992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15015,13 +14965,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15019: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14969: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15025 "configure"
+#line 14975 "configure"
@@ -15032,7 +14982,7 @@
; return 0; }
EOF
-if { (eval echo configure:15036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15051,13 +15001,13 @@
-echo "configure:15055: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15005: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15061 "configure"
+#line 15011 "configure"
@@ -15068,7 +15018,7 @@
; return 0; }
EOF
-if { (eval echo configure:15072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15181,7 +15131,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15185: checking whether to use FreeType" >&5
+echo "configure:15135: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15200,7 +15150,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15204: checking for location of FreeType includes" >&5
+echo "configure:15154: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15226,15 +15176,15 @@
do
-echo "configure:15230: checking for $ac_hdr" >&5
+echo "configure:15180: checking for $ac_hdr" >&5
-#line 15233 "configure"
+#line 15183 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15238: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15188: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15268,7 +15218,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15272: checking for location of FreeType library" >&5
+echo "configure:15222: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15293,13 +15243,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15297: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15247: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15303 "configure"
+#line 15253 "configure"
@@ -15310,7 +15260,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15351,7 +15301,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15355: checking whether to use NLS" >&5
+echo "configure:15305: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15371,10 +15321,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15375: checking for gettext" >&5
+echo "configure:15325: checking for gettext" >&5
-#line 15378 "configure"
+#line 15328 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below. */
@@ -15397,7 +15347,7 @@
; return 0; }
EOF
-if { (eval echo configure:15401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15415,13 +15365,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15419: checking for gettext in -lintl" >&5
+echo "configure:15369: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15425 "configure"
+#line 15375 "configure"
@@ -15432,7 +15382,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15467,7 +15417,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15471: checking whether to use C++" >&5
+echo "configure:15421: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15483,7 +15433,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15487: checking for $ac_word" >&5
+echo "configure:15437: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15512,7 +15462,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15516: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15466: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15523,12 +15473,12 @@
cat > conftest.$ac_ext << EOF
-#line 15527 "configure"
+#line 15477 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15554,19 +15504,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15558: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15508: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15563: checking whether we are using GNU C++" >&5
+echo "configure:15513: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15520: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15584,7 +15534,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15588: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15538: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15612,58 +15562,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 15626 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15634: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 15644 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15651: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -15676,7 +15575,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15680: checking whether to use openDWG" >&5
+echo "configure:15579: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15696,7 +15595,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15700: checking for location of openDGW includes" >&5
+echo "configure:15599: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15722,15 +15621,15 @@
do
-echo "configure:15726: checking for $ac_hdr" >&5
+echo "configure:15625: checking for $ac_hdr" >&5
-#line 15729 "configure"
+#line 15628 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15633: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15764,7 +15663,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15768: checking for location of openDWG library" >&5
+echo "configure:15667: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15811,7 +15710,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15815: checking for special C compiler options needed for large files" >&5
+echo "configure:15714: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15819,7 +15718,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15823 "configure"
+#line 15722 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15835,7 +15734,7 @@
; return 0; }
EOF
-if { (eval echo configure:15839: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15738: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -15844,7 +15743,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15848 "configure"
+#line 15747 "configure"
@@ -15860,7 +15759,7 @@
; return 0; }
EOF
-if { (eval echo configure:15864: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15763: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15880,11 +15779,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15884: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15783: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15888 "configure"
+#line 15787 "configure"
@@ -15900,14 +15799,14 @@
; return 0; }
EOF
-if { (eval echo configure:15904: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15911 "configure"
+#line 15810 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15925,7 +15824,7 @@
; return 0; }
EOF
-if { (eval echo configure:15929: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15944,11 +15843,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15948: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15847: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15952 "configure"
+#line 15851 "configure"
@@ -15964,14 +15863,14 @@
; return 0; }
EOF
-if { (eval echo configure:15968: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15867: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15975 "configure"
+#line 15874 "configure"
#define _LARGE_FILES 1
@@ -15989,7 +15888,7 @@
; return 0; }
EOF
-if { (eval echo configure:15993: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15892: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -16008,25 +15907,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16012: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15911: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 16016 "configure"
+#line 15915 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16023: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15922: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16030 "configure"
+#line 15929 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -16035,7 +15934,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15938: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16056,10 +15955,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16060: checking if system supports Large Files at all" >&5
+echo "configure:15959: checking if system supports Large Files at all" >&5
-#line 16063 "configure"
+#line 15962 "configure"
#include <stdio.h>
@@ -16091,7 +15990,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16095: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16120,7 +16019,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16124: checking whether to use Python" >&5
+echo "configure:16023: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16140,7 +16039,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16144: checking for $ac_word" >&5
+echo "configure:16043: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16182,15 +16081,15 @@
do
-echo "configure:16186: checking for $ac_hdr" >&5
+echo "configure:16085: checking for $ac_hdr" >&5
-#line 16189 "configure"
+#line 16088 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16194: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16093: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16260,7 +16159,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16264: checking whether to use wxWidgets" >&5
+echo "configure:16163: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16281,7 +16180,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16285: checking for $ac_word" >&5
+echo "configure:16184: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16329,7 +16228,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16333: checking wxWidgets version" >&5
+echo "configure:16232: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16352,15 +16251,15 @@
do
-echo "configure:16356: checking for $ac_hdr" >&5
+echo "configure:16255: checking for $ac_hdr" >&5
-#line 16359 "configure"
+#line 16258 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16364: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16263: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in 2013-01-02 18:57:25 UTC (rev 54507)
+++ grass/branches/releasebranch_6_4/configure.in 2013-01-03 10:42:27 UTC (rev 54508)
@@ -852,11 +852,12 @@
fi
LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
- if test "$MINGW32" = yes ; then
- LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
- else
- LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
- fi
+### geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
+# if test "$MINGW32" = yes ; then
+# LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# else
+ LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# fi
AC_DEFINE(HAVE_GEOS)
fi
