[GRASS-SVN] r54510 - in grass/branches/develbranch_6: . mswindows/osgeo4w
svn_grass at osgeo.org
Thu Jan 3 02:47:39 PST 2013
Author: martinl
Date: 2013-01-03 02:47:38 -0800 (Thu, 03 Jan 2013)
New Revision: 54510
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
grass/branches/develbranch_6/mswindows/osgeo4w/geos-config
fix configure & geos-config for osgeo4w
geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2013-01-03 10:43:43 UTC (rev 54509)
+++ grass/branches/develbranch_6/configure 2013-01-03 10:47:38 UTC (rev 54510)
@@ -8057,73 +8057,23 @@
CPPFLAGS=$ac_save_cppflags
- if test "$MINGW32" = yes ; then
+### geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
+# if test "$MINGW32" = yes ; then
+# LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# else
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$GEOS_LIBS $LDFLAGS"
-echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:8068: checking for initGEOS in -lgeos_c_i" >&5
-ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-lgeos_c_i $LIBS"
-cat > conftest.$ac_ext <<EOF
-#line 8074 "configure"
-#include "confdefs.h"
-/* Override any gcc2 internal prototype to avoid an error. */
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char initGEOS();
-int main() {
-initGEOS()
-; return 0; }
-EOF
-if { (eval echo configure:8085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=yes"
-else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
- echo "$ac_t""yes" 1>&6
- GEOS_LIBS="$GEOS_LIBS -lgeos_c_i "
-else
- echo "$ac_t""no" 1>&6
-LDFLAGS=${ac_save_ldflags}
- { echo "configure: error: *** Unable to locate GEOS library." 1>&2; exit 1; }
-fi
- else
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$GEOS_LIBS $LDFLAGS"
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8121: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8071: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 8127 "configure"
+#line 8077 "configure"
@@ -8134,7 +8084,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8163,7 +8113,7 @@
- fi
+# fi
cat >> confdefs.h <<\EOF
#define HAVE_GEOS 1
EOF
@@ -8178,7 +8128,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8182: checking whether to use TIFF" >&5
+echo "configure:8132: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8198,7 +8148,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8202: checking for location of TIFF includes" >&5
+echo "configure:8152: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8224,15 +8174,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8228: checking for $ac_hdr" >&5
+echo "configure:8178: checking for $ac_hdr" >&5
-#line 8231 "configure"
+#line 8181 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8266,7 +8216,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8270: checking for location of TIFF library" >&5
+echo "configure:8220: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8297,13 +8247,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8301: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8251: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8307 "configure"
+#line 8257 "configure"
@@ -8314,7 +8264,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8333,13 +8283,13 @@
-echo "configure:8337: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8287: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8343 "configure"
+#line 8293 "configure"
@@ -8350,7 +8300,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8369,13 +8319,13 @@
-echo "configure:8373: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8323: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8379 "configure"
+#line 8329 "configure"
@@ -8386,7 +8336,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8405,13 +8355,13 @@
-echo "configure:8409: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8359: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8415 "configure"
+#line 8365 "configure"
@@ -8422,7 +8372,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8441,13 +8391,13 @@
-echo "configure:8445: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8395: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 8451 "configure"
+#line 8401 "configure"
@@ -8458,7 +8408,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8477,13 +8427,13 @@
-echo "configure:8481: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8431: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 8487 "configure"
+#line 8437 "configure"
@@ -8494,7 +8444,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8513,13 +8463,13 @@
-echo "configure:8517: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8467: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 8523 "configure"
+#line 8473 "configure"
@@ -8530,7 +8480,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8549,13 +8499,13 @@
-echo "configure:8553: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8503: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 8559 "configure"
+#line 8509 "configure"
@@ -8566,7 +8516,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8664,7 +8614,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8668: checking whether to use PNG" >&5
+echo "configure:8618: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8683,7 +8633,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8687: checking for location of PNG includes" >&5
+echo "configure:8637: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8709,15 +8659,15 @@
do
-echo "configure:8713: checking for $ac_hdr" >&5
+echo "configure:8663: checking for $ac_hdr" >&5
-#line 8716 "configure"
+#line 8666 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8751,7 +8701,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8755: checking for location of PNG library" >&5
+echo "configure:8705: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8776,13 +8726,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8780: checking for png_read_image in -lpng" >&5
+echo "configure:8730: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8786 "configure"
+#line 8736 "configure"
@@ -8793,7 +8743,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8835,7 +8785,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8839: checking whether to use PostgreSQL" >&5
+echo "configure:8789: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8862,7 +8812,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8866: checking for location of PostgreSQL includes" >&5
+echo "configure:8816: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8888,15 +8838,15 @@
do
-echo "configure:8892: checking for $ac_hdr" >&5
+echo "configure:8842: checking for $ac_hdr" >&5
-#line 8895 "configure"
+#line 8845 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8850: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8934,7 +8884,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8938: checking for location of PostgreSQL library" >&5
+echo "configure:8888: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8963,13 +8913,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8967: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8917: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8973 "configure"
+#line 8923 "configure"
@@ -8980,7 +8930,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8999,13 +8949,13 @@
-echo "configure:9003: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8953: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9009 "configure"
+#line 8959 "configure"
@@ -9016,7 +8966,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9035,13 +8985,13 @@
-echo "configure:9039: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8989: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9045 "configure"
+#line 8995 "configure"
@@ -9052,7 +9002,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9071,13 +9021,13 @@
-echo "configure:9075: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9025: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9081 "configure"
+#line 9031 "configure"
@@ -9088,7 +9038,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9145,13 +9095,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9149: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9099: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9155 "configure"
+#line 9105 "configure"
@@ -9162,7 +9112,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9184,13 +9134,13 @@
-echo "configure:9188: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9138: checking for PQcmdTuples in -lpq" >&5
-#line 9194 "configure"
+#line 9144 "configure"
@@ -9201,7 +9151,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9244,7 +9194,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9248: checking whether to use MySQL" >&5
+echo "configure:9198: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9264,7 +9214,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9268: checking for location of MySQL includes" >&5
+echo "configure:9218: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9290,15 +9240,15 @@
do
-echo "configure:9294: checking for $ac_hdr" >&5
+echo "configure:9244: checking for $ac_hdr" >&5
-#line 9297 "configure"
+#line 9247 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9335,7 +9285,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9339: checking for location of MySQL library" >&5
+echo "configure:9289: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9366,13 +9316,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9370: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9320: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9376 "configure"
+#line 9326 "configure"
@@ -9383,7 +9333,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9402,13 +9352,13 @@
-echo "configure:9406: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9356: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9412 "configure"
+#line 9362 "configure"
@@ -9419,7 +9369,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9438,13 +9388,13 @@
-echo "configure:9442: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9392: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9448 "configure"
+#line 9398 "configure"
@@ -9455,7 +9405,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9474,13 +9424,13 @@
-echo "configure:9478: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9428: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9484 "configure"
+#line 9434 "configure"
@@ -9491,7 +9441,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9510,13 +9460,13 @@
-echo "configure:9514: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9464: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9520 "configure"
+#line 9470 "configure"
@@ -9527,7 +9477,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9546,13 +9496,13 @@
-echo "configure:9550: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9500: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9556 "configure"
+#line 9506 "configure"
@@ -9563,7 +9513,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9582,13 +9532,13 @@
-echo "configure:9586: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9536: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9592 "configure"
+#line 9542 "configure"
@@ -9599,7 +9549,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9618,13 +9568,13 @@
-echo "configure:9622: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9572: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9628 "configure"
+#line 9578 "configure"
@@ -9635,7 +9585,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9725,7 +9675,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:9729: checking for $ac_word" >&5
+echo "configure:9679: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9766,10 +9716,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9770: checking for mysql_server_init" >&5
+echo "configure:9720: checking for mysql_server_init" >&5
-#line 9773 "configure"
+#line 9723 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9792,7 +9742,7 @@
; return 0; }
EOF
-if { (eval echo configure:9796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9830,7 +9780,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9834: checking whether to use SQLite" >&5
+echo "configure:9784: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9850,7 +9800,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9854: checking for location of SQLite includes" >&5
+echo "configure:9804: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9876,15 +9826,15 @@
do
-echo "configure:9880: checking for $ac_hdr" >&5
+echo "configure:9830: checking for $ac_hdr" >&5
-#line 9883 "configure"
+#line 9833 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9927,7 +9877,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9931: checking for location of SQLite library" >&5
+echo "configure:9881: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9956,13 +9906,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9960: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9910: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 9966 "configure"
+#line 9916 "configure"
@@ -9973,7 +9923,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9992,13 +9942,13 @@
-echo "configure:9996: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9946: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 10002 "configure"
+#line 9952 "configure"
@@ -10009,7 +9959,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10028,13 +9978,13 @@
-echo "configure:10032: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9982: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10038 "configure"
+#line 9988 "configure"
@@ -10045,7 +9995,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10064,13 +10014,13 @@
-echo "configure:10068: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10018: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10074 "configure"
+#line 10024 "configure"
@@ -10081,7 +10031,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10150,7 +10100,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10154: checking whether to use FFMPEG" >&5
+echo "configure:10104: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10170,7 +10120,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10174: checking for location of FFMPEG includes" >&5
+echo "configure:10124: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10196,15 +10146,15 @@
do
-echo "configure:10200: checking for $ac_hdr" >&5
+echo "configure:10150: checking for $ac_hdr" >&5
-#line 10203 "configure"
+#line 10153 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10208: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10240,15 +10190,15 @@
do
-echo "configure:10244: checking for $ac_hdr" >&5
+echo "configure:10194: checking for $ac_hdr" >&5
-#line 10247 "configure"
+#line 10197 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10202: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10284,15 +10234,15 @@
do
-echo "configure:10288: checking for $ac_hdr" >&5
+echo "configure:10238: checking for $ac_hdr" >&5
-#line 10291 "configure"
+#line 10241 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10335,7 +10285,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10339: checking for location of FFMPEG library" >&5
+echo "configure:10289: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10362,13 +10312,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10366: checking for av_free in -lavutil" >&5
+echo "configure:10316: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10372 "configure"
+#line 10322 "configure"
@@ -10379,7 +10329,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10398,13 +10348,13 @@
-echo "configure:10402: checking for av_free in -lavutil" >&5
+echo "configure:10352: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10408 "configure"
+#line 10358 "configure"
@@ -10415,7 +10365,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10460,13 +10410,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:10464: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10414: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10470 "configure"
+#line 10420 "configure"
@@ -10477,7 +10427,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:10481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10496,13 +10446,13 @@
-echo "configure:10500: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10450: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10506 "configure"
+#line 10456 "configure"
@@ -10513,7 +10463,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:10517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10558,13 +10508,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:10562: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10512: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10568 "configure"
+#line 10518 "configure"
@@ -10575,7 +10525,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:10579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10594,13 +10544,13 @@
-echo "configure:10598: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10548: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10604 "configure"
+#line 10554 "configure"
@@ -10611,7 +10561,7 @@
; return 0; }
EOF
-if { (eval echo configure:10615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10670,7 +10620,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10674: checking whether to use OpenGL" >&5
+echo "configure:10624: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10704,7 +10654,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10708: checking for location of OpenGL includes" >&5
+echo "configure:10658: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10730,15 +10680,15 @@
do
-echo "configure:10734: checking for $ac_hdr" >&5
+echo "configure:10684: checking for $ac_hdr" >&5
-#line 10737 "configure"
+#line 10687 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10742: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10692: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10775,15 +10725,15 @@
do
-echo "configure:10779: checking for $ac_hdr" >&5
+echo "configure:10729: checking for $ac_hdr" >&5
-#line 10782 "configure"
+#line 10732 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10787: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10737: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10817,7 +10767,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10821: checking for location of OpenGL library" >&5
+echo "configure:10771: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10838,7 +10788,7 @@
echo $ac_n "checking for location of Xmu library""... $ac_c" 1>&6
-echo "configure:10842: checking for location of Xmu library" >&5
+echo "configure:10792: checking for location of Xmu library" >&5
case "$with_Xmu_libs" in
{ echo "configure: error: *** You must supply a directory to --with-Xmu-libs." 1>&2; exit 1; }
@@ -10867,13 +10817,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10871: checking for glBegin in -lGL" >&5
+echo "configure:10821: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10877 "configure"
+#line 10827 "configure"
@@ -10884,7 +10834,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10903,13 +10853,13 @@
-echo "configure:10907: checking for glBegin in -lGL" >&5
+echo "configure:10857: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10913 "configure"
+#line 10863 "configure"
@@ -10920,7 +10870,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10939,13 +10889,13 @@
-echo "configure:10943: checking for glBegin in -lGL" >&5
+echo "configure:10893: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10949 "configure"
+#line 10899 "configure"
@@ -10956,7 +10906,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10975,13 +10925,13 @@
-echo "configure:10979: checking for glBegin in -lGL" >&5
+echo "configure:10929: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10985 "configure"
+#line 10935 "configure"
@@ -10992,7 +10942,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11054,13 +11004,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11058: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11008: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11064 "configure"
+#line 11014 "configure"
@@ -11071,7 +11021,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11090,13 +11040,13 @@
-echo "configure:11094: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11044: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11100 "configure"
+#line 11050 "configure"
@@ -11107,7 +11057,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11151,10 +11101,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11155: checking for glXCreatePbuffer" >&5
+echo "configure:11105: checking for glXCreatePbuffer" >&5
-#line 11158 "configure"
+#line 11108 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11177,7 +11127,7 @@
; return 0; }
EOF
-if { (eval echo configure:11181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11199,10 +11149,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11203: checking for glXCreateGLXPixmap" >&5
+echo "configure:11153: checking for glXCreateGLXPixmap" >&5
-#line 11206 "configure"
+#line 11156 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11225,7 +11175,7 @@
; return 0; }
EOF
-if { (eval echo configure:11229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11264,7 +11214,7 @@
-echo "configure:11268: checking for location of OpenGL includes" >&5
+echo "configure:11218: checking for location of OpenGL includes" >&5
@@ -11290,15 +11240,15 @@
do
-echo "configure:11294: checking for $ac_hdr" >&5
+echo "configure:11244: checking for $ac_hdr" >&5
-#line 11297 "configure"
+#line 11247 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11333,10 +11283,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11337: checking for glBegin" >&5
+echo "configure:11287: checking for glBegin" >&5
-#line 11340 "configure"
+#line 11290 "configure"
which can conflict with char glBegin(); below. */
@@ -11359,7 +11309,7 @@
; return 0; }
EOF
-if { (eval echo configure:11363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11374,10 +11324,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11378: checking for gluBeginCurve" >&5
+echo "configure:11328: checking for gluBeginCurve" >&5
-#line 11381 "configure"
+#line 11331 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11400,7 +11350,7 @@
; return 0; }
EOF
-if { (eval echo configure:11404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11444,7 +11394,7 @@
-echo "configure:11448: checking for location of OpenGL includes" >&5
+echo "configure:11398: checking for location of OpenGL includes" >&5
@@ -11470,15 +11420,15 @@
do
-echo "configure:11474: checking for $ac_hdr" >&5
+echo "configure:11424: checking for $ac_hdr" >&5
-#line 11477 "configure"
+#line 11427 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11482: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11512,7 +11462,7 @@
-echo "configure:11516: checking for location of OpenGL library" >&5
+echo "configure:11466: checking for location of OpenGL library" >&5
@@ -11537,18 +11487,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11541: checking for OpenGL library" >&5
+echo "configure:11491: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11545 "configure"
+#line 11495 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11572,18 +11522,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11576: checking for GLU library" >&5
+echo "configure:11526: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11580 "configure"
+#line 11530 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11632,7 +11582,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11636: checking whether to use Tcl/Tk" >&5
+echo "configure:11586: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11652,7 +11602,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11656: checking for location of Tcl/Tk includes" >&5
+echo "configure:11606: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11678,15 +11628,15 @@
do
-echo "configure:11682: checking for $ac_hdr" >&5
+echo "configure:11632: checking for $ac_hdr" >&5
-#line 11685 "configure"
+#line 11635 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11690: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11640: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11723,15 +11673,15 @@
do
-echo "configure:11727: checking for $ac_hdr" >&5
+echo "configure:11677: checking for $ac_hdr" >&5
-#line 11730 "configure"
+#line 11680 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11764,7 +11714,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11768: checking Tcl version" >&5
+echo "configure:11718: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11772,7 +11722,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 11776 "configure"
+#line 11726 "configure"
#include <stdio.h>
@@ -11784,7 +11734,7 @@
EOF
-if { (eval echo configure:11788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11802,7 +11752,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11806: checking Tk version" >&5
+echo "configure:11756: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11810,7 +11760,7 @@
else
-#line 11814 "configure"
+#line 11764 "configure"
#include <stdio.h>
@@ -11822,7 +11772,7 @@
EOF
-if { (eval echo configure:11826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11853,7 +11803,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11857: checking for location of Tcl/Tk library" >&5
+echo "configure:11807: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11893,13 +11843,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11897: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11847: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11903 "configure"
+#line 11853 "configure"
@@ -11910,7 +11860,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11929,13 +11879,13 @@
-echo "configure:11933: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11883: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11939 "configure"
+#line 11889 "configure"
@@ -11946,7 +11896,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11973,13 +11923,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11977: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11927: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11983 "configure"
+#line 11933 "configure"
@@ -11990,7 +11940,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12009,13 +11959,13 @@
-echo "configure:12013: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11963: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12019 "configure"
+#line 11969 "configure"
@@ -12026,7 +11976,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12053,13 +12003,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12057: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12007: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12063 "configure"
+#line 12013 "configure"
@@ -12070,7 +12020,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12089,13 +12039,13 @@
-echo "configure:12093: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12043: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12099 "configure"
+#line 12049 "configure"
@@ -12106,7 +12056,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12184,13 +12134,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12188: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12138: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12194 "configure"
+#line 12144 "configure"
@@ -12201,7 +12151,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12220,13 +12170,13 @@
-echo "configure:12224: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12174: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12230 "configure"
+#line 12180 "configure"
@@ -12237,7 +12187,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12264,13 +12214,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12268: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12218: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12274 "configure"
+#line 12224 "configure"
@@ -12281,7 +12231,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12300,13 +12250,13 @@
-echo "configure:12304: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12254: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12310 "configure"
+#line 12260 "configure"
@@ -12317,7 +12267,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12344,13 +12294,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12348: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12298: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12354 "configure"
+#line 12304 "configure"
@@ -12361,7 +12311,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12380,13 +12330,13 @@
-echo "configure:12384: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12334: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12390 "configure"
+#line 12340 "configure"
@@ -12397,7 +12347,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12487,13 +12437,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12491: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12441: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12497 "configure"
+#line 12447 "configure"
@@ -12504,7 +12454,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12553,7 +12503,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12557: checking whether to use ODBC" >&5
+echo "configure:12507: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12572,7 +12522,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12576: checking for location of ODBC includes" >&5
+echo "configure:12526: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12598,15 +12548,15 @@
do
-echo "configure:12602: checking for $ac_hdr" >&5
+echo "configure:12552: checking for $ac_hdr" >&5
-#line 12605 "configure"
+#line 12555 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12610: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12640,7 +12590,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12644: checking for location of ODBC library" >&5
+echo "configure:12594: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12665,13 +12615,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12669: checking for SQLConnect in -lodbc" >&5
+echo "configure:12619: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12675 "configure"
+#line 12625 "configure"
@@ -12682,7 +12632,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12707,13 +12657,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12711: checking for SQLConnect in -liodbc" >&5
+echo "configure:12661: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12717 "configure"
+#line 12667 "configure"
@@ -12724,7 +12674,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12749,11 +12699,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12753: checking for ODBC library" >&5
+echo "configure:12703: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12757 "configure"
+#line 12707 "configure"
#include <windows.h>
#include <sql.h>
@@ -12761,7 +12711,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12810,7 +12760,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12814: checking whether to use FFTW" >&5
+echo "configure:12764: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12829,7 +12779,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12833: checking for location of FFTW includes" >&5
+echo "configure:12783: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12855,15 +12805,15 @@
do
-echo "configure:12859: checking for $ac_hdr" >&5
+echo "configure:12809: checking for $ac_hdr" >&5
-#line 12862 "configure"
+#line 12812 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12867: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12891,15 +12841,15 @@
do
-echo "configure:12895: checking for $ac_hdr" >&5
+echo "configure:12845: checking for $ac_hdr" >&5
-#line 12898 "configure"
+#line 12848 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12927,15 +12877,15 @@
do
-echo "configure:12931: checking for $ac_hdr" >&5
+echo "configure:12881: checking for $ac_hdr" >&5
-#line 12934 "configure"
+#line 12884 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12939: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12981,7 +12931,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12985: checking for location of FFTW library" >&5
+echo "configure:12935: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13006,13 +12956,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13010: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12960: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13016 "configure"
+#line 12966 "configure"
@@ -13023,7 +12973,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:13027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13048,13 +12998,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13052: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13002: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 13058 "configure"
+#line 13008 "configure"
@@ -13065,7 +13015,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13090,13 +13040,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13094: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13044: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldfftw $MATHLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 13100 "configure"
+#line 13050 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13107,7 +13057,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13164,7 +13114,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13168: checking whether to use BLAS" >&5
+echo "configure:13118: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13185,7 +13135,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13189: checking for location of BLAS includes" >&5
+echo "configure:13139: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13205,7 +13155,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13209: checking for location of BLAS library" >&5
+echo "configure:13159: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13231,15 +13181,15 @@
do
-echo "configure:13235: checking for $ac_hdr" >&5
+echo "configure:13185: checking for $ac_hdr" >&5
-#line 13238 "configure"
+#line 13188 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13274,13 +13224,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13278: checking for dnrm2_ in -lblas" >&5
+echo "configure:13228: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 13284 "configure"
+#line 13234 "configure"
@@ -13291,7 +13241,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13310,13 +13260,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13314: checking for dnrm2_ in -lblas" >&5
+echo "configure:13264: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13320 "configure"
+#line 13270 "configure"
@@ -13327,7 +13277,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13371,13 +13321,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13375: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13325: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13381 "configure"
+#line 13331 "configure"
@@ -13388,7 +13338,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13403,13 +13353,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13407: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13357: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13413 "configure"
+#line 13363 "configure"
@@ -13420,7 +13370,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13435,13 +13385,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13439: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13389: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13445 "configure"
+#line 13395 "configure"
@@ -13452,7 +13402,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13498,16 +13448,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13502: checking for sgemm in $vlib_flags" >&5
+echo "configure:13452: checking for sgemm in $vlib_flags" >&5
-#line 13504 "configure"
+#line 13454 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13525,13 +13475,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13529: checking for sgemm_ in -lblas" >&5
+echo "configure:13479: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13535 "configure"
+#line 13485 "configure"
@@ -13542,7 +13492,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13557,13 +13507,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13561: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13511: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13567 "configure"
+#line 13517 "configure"
@@ -13574,7 +13524,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13589,13 +13539,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13593: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13543: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13599 "configure"
+#line 13549 "configure"
@@ -13606,7 +13556,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13640,13 +13590,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13644: checking for acosp in -lsunmath" >&5
+echo "configure:13594: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13650 "configure"
+#line 13600 "configure"
@@ -13657,7 +13607,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13661: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13672,13 +13622,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13676: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13626: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13682 "configure"
+#line 13632 "configure"
@@ -13689,7 +13639,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13719,13 +13669,13 @@
# Generic BLAS library
-echo "configure:13723: checking for sgemm_ in -lblas" >&5
+echo "configure:13673: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13729 "configure"
+#line 13679 "configure"
@@ -13736,7 +13686,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13775,7 +13725,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13779: checking whether to use LAPACK" >&5
+echo "configure:13729: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13800,7 +13750,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13804: checking for location of LAPACK includes" >&5
+echo "configure:13754: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13820,7 +13770,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13824: checking for location of LAPACK library" >&5
+echo "configure:13774: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13846,15 +13796,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13850: checking for $ac_hdr" >&5
+echo "configure:13800: checking for $ac_hdr" >&5
-#line 13853 "configure"
+#line 13803 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13858: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13886,10 +13836,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13890: checking for dsegv_" >&5
+echo "configure:13840: checking for dsegv_" >&5
-#line 13893 "configure"
+#line 13843 "configure"
which can conflict with char dsegv_(); below. */
@@ -13912,7 +13862,7 @@
; return 0; }
EOF
-if { (eval echo configure:13916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13939,13 +13889,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13943: checking for desgv_ in -llapack" >&5
+echo "configure:13893: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13949 "configure"
+#line 13899 "configure"
@@ -13956,7 +13906,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13988,13 +13938,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13992: checking for dgesv_ in -llapack" >&5
+echo "configure:13942: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13998 "configure"
+#line 13948 "configure"
@@ -14005,7 +13955,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14024,13 +13974,13 @@
-echo "configure:14028: checking for dgesv_ in -llapack" >&5
+echo "configure:13978: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14034 "configure"
+#line 13984 "configure"
@@ -14041,7 +13991,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14097,7 +14047,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14101: checking whether to use Motif" >&5
+echo "configure:14051: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14116,7 +14066,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14120: checking for location of Motif includes" >&5
+echo "configure:14070: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14142,15 +14092,15 @@
do
-echo "configure:14146: checking for $ac_hdr" >&5
+echo "configure:14096: checking for $ac_hdr" >&5
-#line 14149 "configure"
+#line 14099 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14154: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14184,7 +14134,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14188: checking for location of Motif library" >&5
+echo "configure:14138: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14209,13 +14159,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14213: checking for XmStringCreate in -lXm" >&5
+echo "configure:14163: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14219 "configure"
+#line 14169 "configure"
@@ -14226,7 +14176,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14267,7 +14217,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14271: checking whether to use Cairo" >&5
+echo "configure:14221: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14299,7 +14249,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14303: checking for location of cairo includes" >&5
+echo "configure:14253: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14325,15 +14275,15 @@
do
-echo "configure:14329: checking for $ac_hdr" >&5
+echo "configure:14279: checking for $ac_hdr" >&5
-#line 14332 "configure"
+#line 14282 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14337: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14369,7 +14319,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14373: checking for location of cairo library" >&5
+echo "configure:14323: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14389,7 +14339,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14393: checking for cairo linking flags" >&5
+echo "configure:14343: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14405,10 +14355,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14409: checking for cairo_create" >&5
+echo "configure:14359: checking for cairo_create" >&5
-#line 14412 "configure"
+#line 14362 "configure"
which can conflict with char cairo_create(); below. */
@@ -14431,7 +14381,7 @@
; return 0; }
EOF
-if { (eval echo configure:14435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14465,10 +14415,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14469: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14419: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14472 "configure"
+#line 14422 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14491,7 +14441,7 @@
; return 0; }
EOF
-if { (eval echo configure:14495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14524,10 +14474,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14528: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14478: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14531 "configure"
+#line 14481 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -14550,7 +14500,7 @@
; return 0; }
EOF
-if { (eval echo configure:14554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -14592,7 +14542,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14596: checking whether to use GLw" >&5
+echo "configure:14546: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14611,7 +14561,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14615: checking for location of GLw includes" >&5
+echo "configure:14565: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14637,15 +14587,15 @@
do
-echo "configure:14641: checking for $ac_hdr" >&5
+echo "configure:14591: checking for $ac_hdr" >&5
-#line 14644 "configure"
+#line 14594 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14673,15 +14623,15 @@
do
-echo "configure:14677: checking for $ac_hdr" >&5
+echo "configure:14627: checking for $ac_hdr" >&5
-#line 14680 "configure"
+#line 14630 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14721,7 +14671,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14725: checking for location of GLw library" >&5
+echo "configure:14675: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14746,13 +14696,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14750: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14700: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14756 "configure"
+#line 14706 "configure"
@@ -14763,7 +14713,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14788,13 +14738,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14792: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14742: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14798 "configure"
+#line 14748 "configure"
@@ -14805,7 +14755,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14830,13 +14780,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14834: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14784: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14840 "configure"
+#line 14790 "configure"
@@ -14847,7 +14797,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14872,13 +14822,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14876: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14826: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14882 "configure"
+#line 14832 "configure"
@@ -14889,7 +14839,7 @@
; return 0; }
EOF
-if { (eval echo configure:14893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14914,13 +14864,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14918: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14868: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14924 "configure"
+#line 14874 "configure"
@@ -14931,7 +14881,7 @@
; return 0; }
EOF
-if { (eval echo configure:14935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14956,13 +14906,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14960: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14910: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14966 "configure"
+#line 14916 "configure"
@@ -14973,7 +14923,7 @@
; return 0; }
EOF
-if { (eval echo configure:14977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15000,13 +14950,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:15004: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14954: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15010 "configure"
+#line 14960 "configure"
@@ -15017,7 +14967,7 @@
; return 0; }
EOF
-if { (eval echo configure:15021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15036,13 +14986,13 @@
-echo "configure:15040: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14990: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15046 "configure"
+#line 14996 "configure"
@@ -15053,7 +15003,7 @@
; return 0; }
EOF
-if { (eval echo configure:15057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15080,13 +15030,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15084: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15034: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15090 "configure"
+#line 15040 "configure"
@@ -15097,7 +15047,7 @@
; return 0; }
EOF
-if { (eval echo configure:15101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15116,13 +15066,13 @@
-echo "configure:15120: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15070: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15126 "configure"
+#line 15076 "configure"
@@ -15133,7 +15083,7 @@
; return 0; }
EOF
-if { (eval echo configure:15137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15246,7 +15196,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15250: checking whether to use FreeType" >&5
+echo "configure:15200: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15265,7 +15215,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15269: checking for location of FreeType includes" >&5
+echo "configure:15219: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15291,15 +15241,15 @@
do
-echo "configure:15295: checking for $ac_hdr" >&5
+echo "configure:15245: checking for $ac_hdr" >&5
-#line 15298 "configure"
+#line 15248 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15303: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15333,7 +15283,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15337: checking for location of FreeType library" >&5
+echo "configure:15287: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15358,13 +15308,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15362: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15312: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15368 "configure"
+#line 15318 "configure"
@@ -15375,7 +15325,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15416,7 +15366,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15420: checking whether to use NLS" >&5
+echo "configure:15370: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15436,10 +15386,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15440: checking for gettext" >&5
+echo "configure:15390: checking for gettext" >&5
-#line 15443 "configure"
+#line 15393 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below. */
@@ -15462,7 +15412,7 @@
; return 0; }
EOF
-if { (eval echo configure:15466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15480,13 +15430,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15484: checking for gettext in -lintl" >&5
+echo "configure:15434: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15490 "configure"
+#line 15440 "configure"
@@ -15497,7 +15447,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15532,7 +15482,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15536: checking whether to use C++" >&5
+echo "configure:15486: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15548,7 +15498,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15552: checking for $ac_word" >&5
+echo "configure:15502: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15577,7 +15527,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15581: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15531: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15588,12 +15538,12 @@
cat > conftest.$ac_ext << EOF
-#line 15592 "configure"
+#line 15542 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15619,19 +15569,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15623: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15573: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15628: checking whether we are using GNU C++" >&5
+echo "configure:15578: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15585: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15649,7 +15599,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15653: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15603: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15677,58 +15627,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 15691 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15699: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 15709 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15716: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -15741,7 +15640,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15745: checking whether to use openDWG" >&5
+echo "configure:15644: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15761,7 +15660,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15765: checking for location of openDGW includes" >&5
+echo "configure:15664: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15787,15 +15686,15 @@
do
-echo "configure:15791: checking for $ac_hdr" >&5
+echo "configure:15690: checking for $ac_hdr" >&5
-#line 15794 "configure"
+#line 15693 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15799: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15698: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15829,7 +15728,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15833: checking for location of openDWG library" >&5
+echo "configure:15732: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15876,7 +15775,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15880: checking for special C compiler options needed for large files" >&5
+echo "configure:15779: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15884,7 +15783,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15888 "configure"
+#line 15787 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15900,7 +15799,7 @@
; return 0; }
EOF
-if { (eval echo configure:15904: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -15909,7 +15808,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15913 "configure"
+#line 15812 "configure"
@@ -15925,7 +15824,7 @@
; return 0; }
EOF
-if { (eval echo configure:15929: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15945,11 +15844,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15949: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15848: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15953 "configure"
+#line 15852 "configure"
@@ -15965,14 +15864,14 @@
; return 0; }
EOF
-if { (eval echo configure:15969: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15868: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15976 "configure"
+#line 15875 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15990,7 +15889,7 @@
; return 0; }
EOF
-if { (eval echo configure:15994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15893: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -16009,11 +15908,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:16013: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15912: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 16017 "configure"
+#line 15916 "configure"
@@ -16029,14 +15928,14 @@
; return 0; }
EOF
-if { (eval echo configure:16033: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15932: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16040 "configure"
+#line 15939 "configure"
#define _LARGE_FILES 1
@@ -16054,7 +15953,7 @@
; return 0; }
EOF
-if { (eval echo configure:16058: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15957: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -16073,25 +15972,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16077: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15976: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 16081 "configure"
+#line 15980 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16088: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16095 "configure"
+#line 15994 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -16100,7 +15999,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16104: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16003: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16121,10 +16020,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16125: checking if system supports Large Files at all" >&5
+echo "configure:16024: checking if system supports Large Files at all" >&5
-#line 16128 "configure"
+#line 16027 "configure"
#include <stdio.h>
@@ -16156,7 +16055,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16160: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16185,7 +16084,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16189: checking whether to use Python" >&5
+echo "configure:16088: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16205,7 +16104,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16209: checking for $ac_word" >&5
+echo "configure:16108: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16247,15 +16146,15 @@
do
-echo "configure:16251: checking for $ac_hdr" >&5
+echo "configure:16150: checking for $ac_hdr" >&5
-#line 16254 "configure"
+#line 16153 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16259: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16325,7 +16224,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16329: checking whether to use wxWidgets" >&5
+echo "configure:16228: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16346,7 +16245,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16350: checking for $ac_word" >&5
+echo "configure:16249: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16394,7 +16293,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16398: checking wxWidgets version" >&5
+echo "configure:16297: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16417,15 +16316,15 @@
do
-echo "configure:16421: checking for $ac_hdr" >&5
+echo "configure:16320: checking for $ac_hdr" >&5
-#line 16424 "configure"
+#line 16323 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2013-01-03 10:43:43 UTC (rev 54509)
+++ grass/branches/develbranch_6/configure.in 2013-01-03 10:47:38 UTC (rev 54510)
@@ -852,11 +852,12 @@
fi
LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
- if test "$MINGW32" = yes ; then
- LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
- else
- LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
- fi
+### geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
+# if test "$MINGW32" = yes ; then
+# LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# else
+ LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# fi
AC_DEFINE(HAVE_GEOS)
fi
Modified: grass/branches/develbranch_6/mswindows/osgeo4w/geos-config
--- grass/branches/develbranch_6/mswindows/osgeo4w/geos-config 2013-01-03 10:43:43 UTC (rev 54509)
+++ grass/branches/develbranch_6/mswindows/osgeo4w/geos-config 2013-01-03 10:47:38 UTC (rev 54510)
@@ -34,7 +34,7 @@
echo -I$OSGEO4W_ROOT_MSYS/include
--libs)
- echo $OSGEO4W_ROOT_MSYS/lib/geos_c_i.lib
+ echo $OSGEO4W_ROOT_MSYS/lib/geos_c.lib
--ldflags)
echo
