[GRASS-SVN] r54511 - in grass/trunk: . mswindows/osgeo4w
svn_grass at osgeo.org
Thu Jan 3 02:50:10 PST 2013
Author: martinl
Date: 2013-01-03 02:50:09 -0800 (Thu, 03 Jan 2013)
New Revision: 54511
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/mswindows/osgeo4w/geos-config
fix configure & geos-config for osgeo4w
geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-01-03 10:47:38 UTC (rev 54510)
+++ grass/trunk/configure 2013-01-03 10:50:09 UTC (rev 54511)
@@ -6423,73 +6423,23 @@
CPPFLAGS=$ac_save_cppflags
- if test "$MINGW32" = yes ; then
+### geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
+# if test "$MINGW32" = yes ; then
+# LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# else
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$GEOS_LIBS $LDFLAGS"
-echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6434: checking for initGEOS in -lgeos_c_i" >&5
-ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-lgeos_c_i $LIBS"
-cat > conftest.$ac_ext <<EOF
-#line 6440 "configure"
-#include "confdefs.h"
-/* Override any gcc2 internal prototype to avoid an error. */
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char initGEOS();
-int main() {
-initGEOS()
-; return 0; }
-EOF
-if { (eval echo configure:6451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=yes"
-else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
- echo "$ac_t""yes" 1>&6
- GEOS_LIBS="$GEOS_LIBS -lgeos_c_i "
-else
- echo "$ac_t""no" 1>&6
-LDFLAGS=${ac_save_ldflags}
- { echo "configure: error: *** Unable to locate GEOS library." 1>&2; exit 1; }
-fi
- else
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$GEOS_LIBS $LDFLAGS"
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6487: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6437: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6493 "configure"
+#line 6443 "configure"
@@ -6500,7 +6450,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6529,7 +6479,7 @@
- fi
+# fi
cat >> confdefs.h <<\EOF
#define HAVE_GEOS 1
EOF
@@ -6544,7 +6494,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6548: checking whether to use TIFF" >&5
+echo "configure:6498: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6564,7 +6514,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6568: checking for location of TIFF includes" >&5
+echo "configure:6518: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6590,15 +6540,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:6594: checking for $ac_hdr" >&5
+echo "configure:6544: checking for $ac_hdr" >&5
-#line 6597 "configure"
+#line 6547 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:6602: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6552: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -6632,7 +6582,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6636: checking for location of TIFF library" >&5
+echo "configure:6586: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6663,13 +6613,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6667: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6617: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6673 "configure"
+#line 6623 "configure"
@@ -6680,7 +6630,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6699,13 +6649,13 @@
-echo "configure:6703: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6653: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6709 "configure"
+#line 6659 "configure"
@@ -6716,7 +6666,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6735,13 +6685,13 @@
-echo "configure:6739: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6689: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6745 "configure"
+#line 6695 "configure"
@@ -6752,7 +6702,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6771,13 +6721,13 @@
-echo "configure:6775: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6725: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6781 "configure"
+#line 6731 "configure"
@@ -6788,7 +6738,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6807,13 +6757,13 @@
-echo "configure:6811: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6761: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6817 "configure"
+#line 6767 "configure"
@@ -6824,7 +6774,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6843,13 +6793,13 @@
-echo "configure:6847: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6797: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6853 "configure"
+#line 6803 "configure"
@@ -6860,7 +6810,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6879,13 +6829,13 @@
-echo "configure:6883: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6833: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6889 "configure"
+#line 6839 "configure"
@@ -6896,7 +6846,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6915,13 +6865,13 @@
-echo "configure:6919: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6869: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6925 "configure"
+#line 6875 "configure"
@@ -6932,7 +6882,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7030,7 +6980,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7034: checking whether to use PNG" >&5
+echo "configure:6984: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7049,7 +6999,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7053: checking for location of PNG includes" >&5
+echo "configure:7003: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7075,15 +7025,15 @@
do
-echo "configure:7079: checking for $ac_hdr" >&5
+echo "configure:7029: checking for $ac_hdr" >&5
-#line 7082 "configure"
+#line 7032 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7087: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7037: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7117,7 +7067,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7121: checking for location of PNG library" >&5
+echo "configure:7071: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7142,13 +7092,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7146: checking for png_read_image in -lpng" >&5
+echo "configure:7096: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7152 "configure"
+#line 7102 "configure"
@@ -7159,7 +7109,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7201,7 +7151,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7205: checking whether to use PostgreSQL" >&5
+echo "configure:7155: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7228,7 +7178,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7232: checking for location of PostgreSQL includes" >&5
+echo "configure:7182: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7254,15 +7204,15 @@
do
-echo "configure:7258: checking for $ac_hdr" >&5
+echo "configure:7208: checking for $ac_hdr" >&5
-#line 7261 "configure"
+#line 7211 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7266: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7300,7 +7250,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7304: checking for location of PostgreSQL library" >&5
+echo "configure:7254: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7329,13 +7279,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7333: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7283: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7339 "configure"
+#line 7289 "configure"
@@ -7346,7 +7296,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7365,13 +7315,13 @@
-echo "configure:7369: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7319: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7375 "configure"
+#line 7325 "configure"
@@ -7382,7 +7332,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7401,13 +7351,13 @@
-echo "configure:7405: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7355: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7411 "configure"
+#line 7361 "configure"
@@ -7418,7 +7368,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7437,13 +7387,13 @@
-echo "configure:7441: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7391: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7447 "configure"
+#line 7397 "configure"
@@ -7454,7 +7404,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7511,13 +7461,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7515: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7465: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7521 "configure"
+#line 7471 "configure"
@@ -7528,7 +7478,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7550,13 +7500,13 @@
-echo "configure:7554: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7504: checking for PQcmdTuples in -lpq" >&5
-#line 7560 "configure"
+#line 7510 "configure"
@@ -7567,7 +7517,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7610,7 +7560,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7614: checking whether to use MySQL" >&5
+echo "configure:7564: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7630,7 +7580,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7634: checking for location of MySQL includes" >&5
+echo "configure:7584: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7656,15 +7606,15 @@
do
-echo "configure:7660: checking for $ac_hdr" >&5
+echo "configure:7610: checking for $ac_hdr" >&5
-#line 7663 "configure"
+#line 7613 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7701,7 +7651,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7705: checking for location of MySQL library" >&5
+echo "configure:7655: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7732,13 +7682,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7736: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7686: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7742 "configure"
+#line 7692 "configure"
@@ -7749,7 +7699,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7768,13 +7718,13 @@
-echo "configure:7772: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7722: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7778 "configure"
+#line 7728 "configure"
@@ -7785,7 +7735,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7804,13 +7754,13 @@
-echo "configure:7808: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7758: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7814 "configure"
+#line 7764 "configure"
@@ -7821,7 +7771,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7840,13 +7790,13 @@
-echo "configure:7844: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7794: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7850 "configure"
+#line 7800 "configure"
@@ -7857,7 +7807,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7876,13 +7826,13 @@
-echo "configure:7880: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7830: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7886 "configure"
+#line 7836 "configure"
@@ -7893,7 +7843,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7912,13 +7862,13 @@
-echo "configure:7916: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7866: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7922 "configure"
+#line 7872 "configure"
@@ -7929,7 +7879,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7948,13 +7898,13 @@
-echo "configure:7952: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7902: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7958 "configure"
+#line 7908 "configure"
@@ -7965,7 +7915,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7984,13 +7934,13 @@
-echo "configure:7988: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7938: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 7994 "configure"
+#line 7944 "configure"
@@ -8001,7 +7951,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8091,7 +8041,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8095: checking for $ac_word" >&5
+echo "configure:8045: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8140,10 +8090,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8144: checking for mysql_server_init" >&5
+echo "configure:8094: checking for mysql_server_init" >&5
-#line 8147 "configure"
+#line 8097 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -8169,7 +8119,7 @@
; return 0; }
EOF
-if { (eval echo configure:8173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8221,7 +8171,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8225: checking whether to use SQLite" >&5
+echo "configure:8175: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8241,7 +8191,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8245: checking for location of SQLite includes" >&5
+echo "configure:8195: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8267,15 +8217,15 @@
do
-echo "configure:8271: checking for $ac_hdr" >&5
+echo "configure:8221: checking for $ac_hdr" >&5
-#line 8274 "configure"
+#line 8224 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8279: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8318,7 +8268,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8322: checking for location of SQLite library" >&5
+echo "configure:8272: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8347,13 +8297,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8351: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8301: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8357 "configure"
+#line 8307 "configure"
@@ -8364,7 +8314,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8383,13 +8333,13 @@
-echo "configure:8387: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8337: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8393 "configure"
+#line 8343 "configure"
@@ -8400,7 +8350,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8419,13 +8369,13 @@
-echo "configure:8423: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8373: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8429 "configure"
+#line 8379 "configure"
@@ -8436,7 +8386,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8455,13 +8405,13 @@
-echo "configure:8459: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8409: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8465 "configure"
+#line 8415 "configure"
@@ -8472,7 +8422,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8541,7 +8491,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8545: checking whether to use FFMPEG" >&5
+echo "configure:8495: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8561,7 +8511,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8565: checking for location of FFMPEG includes" >&5
+echo "configure:8515: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8587,15 +8537,15 @@
do
-echo "configure:8591: checking for $ac_hdr" >&5
+echo "configure:8541: checking for $ac_hdr" >&5
-#line 8594 "configure"
+#line 8544 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8631,15 +8581,15 @@
do
-echo "configure:8635: checking for $ac_hdr" >&5
+echo "configure:8585: checking for $ac_hdr" >&5
-#line 8638 "configure"
+#line 8588 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8643: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8675,15 +8625,15 @@
do
-echo "configure:8679: checking for $ac_hdr" >&5
+echo "configure:8629: checking for $ac_hdr" >&5
-#line 8682 "configure"
+#line 8632 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8726,7 +8676,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8730: checking for location of FFMPEG library" >&5
+echo "configure:8680: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8753,13 +8703,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8757: checking for av_free in -lavutil" >&5
+echo "configure:8707: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8763 "configure"
+#line 8713 "configure"
@@ -8770,7 +8720,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8789,13 +8739,13 @@
-echo "configure:8793: checking for av_free in -lavutil" >&5
+echo "configure:8743: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8799 "configure"
+#line 8749 "configure"
@@ -8806,7 +8756,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8851,13 +8801,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8855: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8805: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8861 "configure"
+#line 8811 "configure"
@@ -8868,7 +8818,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8887,13 +8837,13 @@
-echo "configure:8891: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8841: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8897 "configure"
+#line 8847 "configure"
@@ -8904,7 +8854,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8949,13 +8899,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:8953: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8903: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 8959 "configure"
+#line 8909 "configure"
@@ -8966,7 +8916,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:8970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8985,13 +8935,13 @@
-echo "configure:8989: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8939: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 8995 "configure"
+#line 8945 "configure"
@@ -9002,7 +8952,7 @@
; return 0; }
EOF
-if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9061,7 +9011,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9065: checking whether to use OpenGL" >&5
+echo "configure:9015: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9095,7 +9045,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9099: checking for location of OpenGL includes" >&5
+echo "configure:9049: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9121,15 +9071,15 @@
do
-echo "configure:9125: checking for $ac_hdr" >&5
+echo "configure:9075: checking for $ac_hdr" >&5
-#line 9128 "configure"
+#line 9078 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9133: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9163,7 +9113,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9167: checking for location of OpenGL library" >&5
+echo "configure:9117: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9192,13 +9142,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9196: checking for glBegin in -lGL" >&5
+echo "configure:9146: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9202 "configure"
+#line 9152 "configure"
@@ -9209,7 +9159,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9228,13 +9178,13 @@
-echo "configure:9232: checking for glBegin in -lGL" >&5
+echo "configure:9182: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9238 "configure"
+#line 9188 "configure"
@@ -9245,7 +9195,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9264,13 +9214,13 @@
-echo "configure:9268: checking for glBegin in -lGL" >&5
+echo "configure:9218: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9274 "configure"
+#line 9224 "configure"
@@ -9281,7 +9231,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9300,13 +9250,13 @@
-echo "configure:9304: checking for glBegin in -lGL" >&5
+echo "configure:9254: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9310 "configure"
+#line 9260 "configure"
@@ -9317,7 +9267,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9379,13 +9329,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9383: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9333: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9389 "configure"
+#line 9339 "configure"
@@ -9396,7 +9346,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9415,13 +9365,13 @@
-echo "configure:9419: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9369: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9425 "configure"
+#line 9375 "configure"
@@ -9432,7 +9382,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9479,10 +9429,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9483: checking for glXCreatePbuffer" >&5
+echo "configure:9433: checking for glXCreatePbuffer" >&5
-#line 9486 "configure"
+#line 9436 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -9505,7 +9455,7 @@
; return 0; }
EOF
-if { (eval echo configure:9509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9542,10 +9492,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9546: checking for glXCreateGLXPixmap" >&5
+echo "configure:9496: checking for glXCreateGLXPixmap" >&5
-#line 9549 "configure"
+#line 9499 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9568,7 +9518,7 @@
; return 0; }
EOF
-if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9611,7 +9561,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9615: checking for location of OpenGL framework" >&5
+echo "configure:9565: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9635,15 +9585,15 @@
do
-echo "configure:9639: checking for $ac_hdr" >&5
+echo "configure:9589: checking for $ac_hdr" >&5
-#line 9642 "configure"
+#line 9592 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9647: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9597: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9679,10 +9629,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9683: checking for glBegin" >&5
+echo "configure:9633: checking for glBegin" >&5
-#line 9686 "configure"
+#line 9636 "configure"
which can conflict with char glBegin(); below. */
@@ -9705,7 +9655,7 @@
; return 0; }
EOF
-if { (eval echo configure:9709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9742,10 +9692,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9746: checking for gluBeginCurve" >&5
+echo "configure:9696: checking for gluBeginCurve" >&5
-#line 9749 "configure"
+#line 9699 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9768,7 +9718,7 @@
; return 0; }
EOF
-if { (eval echo configure:9772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9816,7 +9766,7 @@
-echo "configure:9820: checking for location of OpenGL includes" >&5
+echo "configure:9770: checking for location of OpenGL includes" >&5
@@ -9842,15 +9792,15 @@
do
-echo "configure:9846: checking for $ac_hdr" >&5
+echo "configure:9796: checking for $ac_hdr" >&5
-#line 9849 "configure"
+#line 9799 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9854: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9804: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9884,7 +9834,7 @@
-echo "configure:9888: checking for location of OpenGL library" >&5
+echo "configure:9838: checking for location of OpenGL library" >&5
@@ -9909,18 +9859,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9913: checking for OpenGL library" >&5
+echo "configure:9863: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9917 "configure"
+#line 9867 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9944,18 +9894,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9948: checking for GLU library" >&5
+echo "configure:9898: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 9952 "configure"
+#line 9902 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:9959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10004,7 +9954,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10008: checking whether to use ODBC" >&5
+echo "configure:9958: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10023,7 +9973,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10027: checking for location of ODBC includes" >&5
+echo "configure:9977: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10049,15 +9999,15 @@
do
-echo "configure:10053: checking for $ac_hdr" >&5
+echo "configure:10003: checking for $ac_hdr" >&5
-#line 10056 "configure"
+#line 10006 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10091,7 +10041,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10095: checking for location of ODBC library" >&5
+echo "configure:10045: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10116,13 +10066,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10120: checking for SQLConnect in -lodbc" >&5
+echo "configure:10070: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10126 "configure"
+#line 10076 "configure"
@@ -10133,7 +10083,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10158,13 +10108,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10162: checking for SQLConnect in -liodbc" >&5
+echo "configure:10112: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10168 "configure"
+#line 10118 "configure"
@@ -10175,7 +10125,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10200,11 +10150,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10204: checking for ODBC library" >&5
+echo "configure:10154: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10208 "configure"
+#line 10158 "configure"
#include <windows.h>
#include <sql.h>
@@ -10212,7 +10162,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10261,7 +10211,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10265: checking whether to use FFTW" >&5
+echo "configure:10215: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10280,7 +10230,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10284: checking for location of FFTW includes" >&5
+echo "configure:10234: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10306,15 +10256,15 @@
do
-echo "configure:10310: checking for $ac_hdr" >&5
+echo "configure:10260: checking for $ac_hdr" >&5
-#line 10313 "configure"
+#line 10263 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10318: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10268: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10342,15 +10292,15 @@
do
-echo "configure:10346: checking for $ac_hdr" >&5
+echo "configure:10296: checking for $ac_hdr" >&5
-#line 10349 "configure"
+#line 10299 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10354: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10304: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10378,15 +10328,15 @@
do
-echo "configure:10382: checking for $ac_hdr" >&5
+echo "configure:10332: checking for $ac_hdr" >&5
-#line 10385 "configure"
+#line 10335 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10390: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10432,7 +10382,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10436: checking for location of FFTW library" >&5
+echo "configure:10386: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10457,13 +10407,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10461: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10411: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10467 "configure"
+#line 10417 "configure"
@@ -10474,7 +10424,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10499,13 +10449,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10503: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10453: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10509 "configure"
+#line 10459 "configure"
@@ -10516,7 +10466,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10541,13 +10491,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10545: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10495: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10551 "configure"
+#line 10501 "configure"
@@ -10558,7 +10508,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10615,7 +10565,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10619: checking whether to use BLAS" >&5
+echo "configure:10569: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10636,7 +10586,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10640: checking for location of BLAS includes" >&5
+echo "configure:10590: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10656,7 +10606,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10660: checking for location of BLAS library" >&5
+echo "configure:10610: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10682,15 +10632,15 @@
do
-echo "configure:10686: checking for $ac_hdr" >&5
+echo "configure:10636: checking for $ac_hdr" >&5
-#line 10689 "configure"
+#line 10639 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10644: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10725,13 +10675,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10729: checking for dnrm2_ in -lblas" >&5
+echo "configure:10679: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10735 "configure"
+#line 10685 "configure"
@@ -10742,7 +10692,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10761,13 +10711,13 @@
-echo "configure:10765: checking for dnrm2_ in -lblas" >&5
+echo "configure:10715: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10771 "configure"
+#line 10721 "configure"
@@ -10778,7 +10728,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10822,13 +10772,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10826: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10776: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10832 "configure"
+#line 10782 "configure"
@@ -10839,7 +10789,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10854,13 +10804,13 @@
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10858: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10808: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10864 "configure"
+#line 10814 "configure"
@@ -10871,7 +10821,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10886,13 +10836,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10890: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10840: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10896 "configure"
+#line 10846 "configure"
@@ -10903,7 +10853,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10949,16 +10899,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10953: checking for sgemm in $vlib_flags" >&5
+echo "configure:10903: checking for sgemm in $vlib_flags" >&5
-#line 10955 "configure"
+#line 10905 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:10962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -10976,13 +10926,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10980: checking for sgemm_ in -lblas" >&5
+echo "configure:10930: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 10986 "configure"
+#line 10936 "configure"
@@ -10993,7 +10943,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11008,13 +10958,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11012: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10962: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11018 "configure"
+#line 10968 "configure"
@@ -11025,7 +10975,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11040,13 +10990,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11044: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10994: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11050 "configure"
+#line 11000 "configure"
@@ -11057,7 +11007,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11091,13 +11041,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11095: checking for acosp in -lsunmath" >&5
+echo "configure:11045: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11101 "configure"
+#line 11051 "configure"
@@ -11108,7 +11058,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11123,13 +11073,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11127: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11077: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11133 "configure"
+#line 11083 "configure"
@@ -11140,7 +11090,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11170,13 +11120,13 @@
# Generic BLAS library
-echo "configure:11174: checking for sgemm_ in -lblas" >&5
+echo "configure:11124: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11180 "configure"
+#line 11130 "configure"
@@ -11187,7 +11137,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11226,7 +11176,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11230: checking whether to use LAPACK" >&5
+echo "configure:11180: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11251,7 +11201,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11255: checking for location of LAPACK includes" >&5
+echo "configure:11205: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11271,7 +11221,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11275: checking for location of LAPACK library" >&5
+echo "configure:11225: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11297,15 +11247,15 @@
do
-echo "configure:11301: checking for $ac_hdr" >&5
+echo "configure:11251: checking for $ac_hdr" >&5
-#line 11304 "configure"
+#line 11254 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11259: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11337,10 +11287,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11341: checking for dsegv_" >&5
+echo "configure:11291: checking for dsegv_" >&5
-#line 11344 "configure"
+#line 11294 "configure"
which can conflict with char dsegv_(); below. */
@@ -11363,7 +11313,7 @@
; return 0; }
EOF
-if { (eval echo configure:11367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11390,13 +11340,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11394: checking for desgv_ in -llapack" >&5
+echo "configure:11344: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-llapack $FLIBS $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 11400 "configure"
+#line 11350 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -11407,7 +11357,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -11439,13 +11389,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11443: checking for dgesv_ in -llapack" >&5
+echo "configure:11393: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11449 "configure"
+#line 11399 "configure"
@@ -11456,7 +11406,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11475,13 +11425,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:11479: checking for dgesv_ in -llapack" >&5
+echo "configure:11429: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11485 "configure"
+#line 11435 "configure"
@@ -11492,7 +11442,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11548,7 +11498,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11552: checking whether to use Cairo" >&5
+echo "configure:11502: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11580,7 +11530,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11584: checking for location of cairo includes" >&5
+echo "configure:11534: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11606,15 +11556,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11610: checking for $ac_hdr" >&5
+echo "configure:11560: checking for $ac_hdr" >&5
-#line 11613 "configure"
+#line 11563 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11568: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -11650,7 +11600,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11654: checking for location of cairo library" >&5
+echo "configure:11604: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11670,7 +11620,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11674: checking for cairo linking flags" >&5
+echo "configure:11624: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11686,10 +11636,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11690: checking for cairo_create" >&5
+echo "configure:11640: checking for cairo_create" >&5
-#line 11693 "configure"
+#line 11643 "configure"
which can conflict with char cairo_create(); below. */
@@ -11712,7 +11662,7 @@
; return 0; }
EOF
-if { (eval echo configure:11716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11746,10 +11696,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11750: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11700: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11753 "configure"
+#line 11703 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11772,7 +11722,7 @@
; return 0; }
EOF
-if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11805,10 +11755,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11809: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11759: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11812 "configure"
+#line 11762 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11831,7 +11781,7 @@
; return 0; }
EOF
-if { (eval echo configure:11835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11873,7 +11823,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11877: checking whether to use FreeType" >&5
+echo "configure:11827: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11892,7 +11842,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11896: checking for location of FreeType includes" >&5
+echo "configure:11846: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11918,15 +11868,15 @@
do
-echo "configure:11922: checking for $ac_hdr" >&5
+echo "configure:11872: checking for $ac_hdr" >&5
-#line 11925 "configure"
+#line 11875 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11880: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11960,7 +11910,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11964: checking for location of FreeType library" >&5
+echo "configure:11914: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11985,13 +11935,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11989: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11939: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 11995 "configure"
+#line 11945 "configure"
@@ -12002,7 +11952,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12043,7 +11993,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12047: checking whether to use NLS" >&5
+echo "configure:11997: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12063,10 +12013,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12067: checking for gettext" >&5
+echo "configure:12017: checking for gettext" >&5
-#line 12070 "configure"
+#line 12020 "configure"
which can conflict with char gettext(); below. */
@@ -12089,7 +12039,7 @@
; return 0; }
EOF
-if { (eval echo configure:12093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12107,13 +12057,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12111: checking for gettext in -lintl" >&5
+echo "configure:12061: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12117 "configure"
+#line 12067 "configure"
@@ -12124,7 +12074,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12159,7 +12109,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12163: checking whether to use C++" >&5
+echo "configure:12113: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12175,7 +12125,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12179: checking for $ac_word" >&5
+echo "configure:12129: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12204,7 +12154,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12208: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12158: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12215,12 +12165,12 @@
cat > conftest.$ac_ext << EOF
-#line 12219 "configure"
+#line 12169 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12246,19 +12196,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12250: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12200: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12255: checking whether we are using GNU C++" >&5
+echo "configure:12205: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12276,7 +12226,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12280: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12230: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12304,58 +12254,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 12318 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12326: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 12336 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12343: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -12368,7 +12267,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12372: checking whether to use openDWG" >&5
+echo "configure:12271: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12388,7 +12287,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12392: checking for location of openDGW includes" >&5
+echo "configure:12291: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12414,15 +12313,15 @@
do
-echo "configure:12418: checking for $ac_hdr" >&5
+echo "configure:12317: checking for $ac_hdr" >&5
-#line 12421 "configure"
+#line 12320 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12456,7 +12355,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12460: checking for location of openDWG library" >&5
+echo "configure:12359: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12497,7 +12396,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12501: checking whether to use POSIX threads" >&5
+echo "configure:12400: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12517,7 +12416,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12521: checking for location of POSIX threads includes" >&5
+echo "configure:12420: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12543,15 +12442,15 @@
do
-echo "configure:12547: checking for $ac_hdr" >&5
+echo "configure:12446: checking for $ac_hdr" >&5
-#line 12550 "configure"
+#line 12449 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12555: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12454: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12585,7 +12484,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12589: checking for location of POSIX threads library" >&5
+echo "configure:12488: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12610,10 +12509,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12614: checking for pthread_create" >&5
+echo "configure:12513: checking for pthread_create" >&5
-#line 12617 "configure"
+#line 12516 "configure"
which can conflict with char pthread_create(); below. */
@@ -12636,7 +12535,7 @@
; return 0; }
EOF
-if { (eval echo configure:12640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12663,13 +12562,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12667: checking for pthread_create in -lpthread" >&5
+echo "configure:12566: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 12673 "configure"
+#line 12572 "configure"
@@ -12680,7 +12579,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12730,7 +12629,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12734: checking whether to use OpenMP" >&5
+echo "configure:12633: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12751,7 +12650,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12755: checking for location of OpenMP includes" >&5
+echo "configure:12654: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12777,15 +12676,15 @@
do
-echo "configure:12781: checking for $ac_hdr" >&5
+echo "configure:12680: checking for $ac_hdr" >&5
-#line 12784 "configure"
+#line 12683 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12789: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12823,7 +12722,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12827: checking for location of OpenMP library" >&5
+echo "configure:12726: checking for location of OpenMP library" >&5
case "$with_gomp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -12848,10 +12747,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12852: checking for GOMP_parallel_start" >&5
+echo "configure:12751: checking for GOMP_parallel_start" >&5
-#line 12855 "configure"
+#line 12754 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12874,7 +12773,7 @@
; return 0; }
EOF
-if { (eval echo configure:12878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12901,13 +12800,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12905: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12804: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12911 "configure"
+#line 12810 "configure"
@@ -12918,7 +12817,7 @@
; return 0; }
EOF
-if { (eval echo configure:12922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12997,7 +12896,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13001: checking for special C compiler options needed for large files" >&5
+echo "configure:12900: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13005,7 +12904,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13009 "configure"
+#line 12908 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13021,7 +12920,7 @@
; return 0; }
EOF
-if { (eval echo configure:13025: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12924: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13030,7 +12929,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13034 "configure"
+#line 12933 "configure"
@@ -13046,7 +12945,7 @@
; return 0; }
EOF
-if { (eval echo configure:13050: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12949: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13066,11 +12965,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13070: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:12969: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13074 "configure"
+#line 12973 "configure"
@@ -13086,14 +12985,14 @@
; return 0; }
EOF
-if { (eval echo configure:13090: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13097 "configure"
+#line 12996 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13111,7 +13010,7 @@
; return 0; }
EOF
-if { (eval echo configure:13115: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13014: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13130,11 +13029,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13134: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13033: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13138 "configure"
+#line 13037 "configure"
@@ -13150,14 +13049,14 @@
; return 0; }
EOF
-if { (eval echo configure:13154: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13161 "configure"
+#line 13060 "configure"
#define _LARGE_FILES 1
@@ -13175,7 +13074,7 @@
; return 0; }
EOF
-if { (eval echo configure:13179: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13078: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13194,25 +13093,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13198: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13097: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13202 "configure"
+#line 13101 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13209: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13108: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13216 "configure"
+#line 13115 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13221,7 +13120,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13225: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13242,25 +13141,25 @@
fi
-echo "configure:13246: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13145: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13250 "configure"
+#line 13149 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13257: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13264 "configure"
+#line 13163 "configure"
#include <stdio.h>
@@ -13269,7 +13168,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13273: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13292,18 +13191,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13296: checking for fseeko" >&5
+echo "configure:13195: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13300 "configure"
+#line 13199 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13320,10 +13219,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13324: checking if system supports Large Files at all" >&5
+echo "configure:13223: checking if system supports Large Files at all" >&5
-#line 13327 "configure"
+#line 13226 "configure"
#include <stdio.h>
@@ -13355,7 +13254,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13359: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13258: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13384,7 +13283,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13388: checking whether to use wxWidgets" >&5
+echo "configure:13287: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13405,7 +13304,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13409: checking for $ac_word" >&5
+echo "configure:13308: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13453,7 +13352,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13457: checking wxWidgets version" >&5
+echo "configure:13356: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13476,15 +13375,15 @@
do
-echo "configure:13480: checking for $ac_hdr" >&5
+echo "configure:13379: checking for $ac_hdr" >&5
-#line 13483 "configure"
+#line 13382 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2013-01-03 10:47:38 UTC (rev 54510)
+++ grass/trunk/configure.in 2013-01-03 10:50:09 UTC (rev 54511)
@@ -897,11 +897,12 @@
fi
LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
- if test "$MINGW32" = yes ; then
- LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
- else
- LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
- fi
+### geos 3.3.6 installs geos_c.lib, see http://osgeo-org.1560.n6.nabble.com/osgeo4w-329-update-geos-to-3-3-6-td5024605.html
+# if test "$MINGW32" = yes ; then
+# LOC_CHECK_LIBS(geos_c_i,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# else
+ LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
+# fi
AC_DEFINE(HAVE_GEOS)
fi
Modified: grass/trunk/mswindows/osgeo4w/geos-config
--- grass/trunk/mswindows/osgeo4w/geos-config 2013-01-03 10:47:38 UTC (rev 54510)
+++ grass/trunk/mswindows/osgeo4w/geos-config 2013-01-03 10:50:09 UTC (rev 54511)
@@ -34,7 +34,7 @@
echo -I$OSGEO4W_ROOT_MSYS/include
--libs)
- echo $OSGEO4W_ROOT_MSYS/lib/geos_c_i.lib
+ echo $OSGEO4W_ROOT_MSYS/lib/geos_c.lib
--ldflags)
echo
