[GRASS-SVN] r54531 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Sat Jan 5 04:25:30 PST 2013
Author: martinl
Date: 2013-01-05 04:25:29 -0800 (Sat, 05 Jan 2013)
New Revision: 54531
grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
grass/branches/releasebranch_6_4/locale/po/grasstcl_fr.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po
update French translation (by Sylvain Maillard)
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po 2013-01-05 09:25:09 UTC (rev 54530)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po 2013-01-05 12:25:29 UTC (rev 54531)
@@ -11,8 +11,8 @@
"Project-Id-Version: grasslibs_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-11-05 10:54+0100\n"
-"PO-Revision-Date: 2012-02-07 10:49+0100\n"
-"Last-Translator: Vincent Bain <bain at toraval.fr>\n"
+"PO-Revision-Date: 2013-01-04 00:54+0100\n"
+"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: French <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
"MIME-Version: 1.0\n"
@@ -29,12 +29,11 @@
#: ../lib/nviz/render.c:114
#, fuzzy
msgid "Unable to create rendering context"
-msgstr "Impossible de créer un nouveau processus"
+msgstr "Impossible de créer un contexte de rendu"
#: ../lib/nviz/position.c:56
-#, fuzzy
msgid "Unable to set focus"
-msgstr "Impossible d'ouvrir %s"
+msgstr ""
#: ../lib/nviz/map_obj.c:59
msgid "Maximum surfaces loaded!"
@@ -44,7 +43,8 @@
msgid "Maximum vector line maps loaded!"
msgstr "Maximum de cartes vecteur linéaires chargées !"
-#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
+#: ../lib/nviz/map_obj.c:97
+#: ../lib/nviz/map_obj.c:128
#, c-format
msgid "Error loading vector map <%s>"
msgstr "Erreur au chargement de la carte vecteur <%s>"
@@ -82,18 +82,17 @@
#: ../lib/symbol/read.c:259
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nom du symbole incorrect : '%s' (devrait être group/nom ou groupe/"
-"nom at jeudedonnées)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Nom du symbole incorrect : '%s' (devrait être group/nom ou groupe/nom at jeudedonnées)"
#: ../lib/symbol/read.c:283
#, c-format
msgid "Cannot find/open symbol: '%s'"
msgstr "Impossible de trouver/ouvrir le symbole : '%s'"
-#: ../lib/symbol/read.c:388 ../lib/symbol/read.c:406 ../lib/symbol/read.c:416
+#: ../lib/symbol/read.c:388
+#: ../lib/symbol/read.c:406
+#: ../lib/symbol/read.c:416
#: ../lib/symbol/read.c:434
#, c-format
msgid "Incorrect symbol color: '%s', using default."
@@ -120,28 +119,36 @@
msgid "Memory error in allocating timestamp"
msgstr "Erreur de mémoire dans l'attribution d'horodatage"
-#: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
+#: ../lib/sites/sites.c:348
+#: ../lib/sites/sites.c:478
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
msgstr ""
-#: ../lib/sites/sites.c:372 ../lib/vector/neta/utils.c:116
-#: ../lib/vector/neta/timetables.c:133 ../lib/vector/Vlib/map.c:271
-#: ../lib/vector/Vlib/map.c:405 ../lib/vector/Vlib/map.c:621
-#: ../lib/vector/Vlib/net.c:185 ../lib/vector/Vlib/net.c:355
-#: ../lib/vector/Vlib/array.c:284 ../lib/rst/interp_float/vinput2d.c:88
-#: ../lib/db/dbmi_client/delete_tab.c:49 ../lib/db/dbmi_client/db.c:46
-#: ../lib/db/dbmi_client/copy_tab.c:105 ../lib/db/dbmi_client/copy_tab.c:126
+#: ../lib/sites/sites.c:372
+#: ../lib/vector/neta/utils.c:116
+#: ../lib/vector/neta/timetables.c:133
+#: ../lib/vector/Vlib/map.c:271
+#: ../lib/vector/Vlib/map.c:405
+#: ../lib/vector/Vlib/map.c:621
+#: ../lib/vector/Vlib/net.c:185
+#: ../lib/vector/Vlib/net.c:355
+#: ../lib/vector/Vlib/array.c:284
+#: ../lib/rst/interp_float/vinput2d.c:88
+#: ../lib/db/dbmi_client/delete_tab.c:49
+#: ../lib/db/dbmi_client/db.c:46
+#: ../lib/db/dbmi_client/copy_tab.c:105
+#: ../lib/db/dbmi_client/copy_tab.c:126
#, c-format
msgid "Unable to open database <%s> by driver <%s>"
msgstr "Impossible d'ouvrir la base de données <%s> avec le driver <%s>"
-#: ../lib/sites/sites.c:381 ../lib/db/dbmi_client/copy_tab.c:199
-#: ../lib/db/dbmi_client/copy_tab.c:276 ../lib/db/dbmi_client/table.c:110
-#, fuzzy, c-format
+#: ../lib/sites/sites.c:381
+#: ../lib/db/dbmi_client/copy_tab.c:199
+#: ../lib/db/dbmi_client/copy_tab.c:276
+#: ../lib/db/dbmi_client/table.c:110
+#, c-format
msgid "Unable to open select cursor: '%s'"
-msgstr "Impossible d'ouvrir le répertoire '%s'"
+msgstr "Impossible d'ouvrir le curseur de sélection : '%s'"
#: ../lib/sites/sites.c:397
msgid "Cannot fetch row"
@@ -185,11 +192,14 @@
#: ../lib/ogsf/GS2.c:1651
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"La carte raster <%s> est en dehors de la région courante. Chargement échoué."
+msgstr "La carte raster <%s> est en dehors de la région courante. Chargement échoué."
-#: ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1735 ../lib/ogsf/GS2.c:1743
-#: ../lib/ogsf/GS2.c:1752 ../lib/ogsf/GS2.c:1760 ../lib/ogsf/GS2.c:1770
+#: ../lib/ogsf/GS2.c:1729
+#: ../lib/ogsf/GS2.c:1735
+#: ../lib/ogsf/GS2.c:1743
+#: ../lib/ogsf/GS2.c:1752
+#: ../lib/ogsf/GS2.c:1760
+#: ../lib/ogsf/GS2.c:1770
#: ../lib/ogsf/GS2.c:1818
msgid "GS_load_att_map(): Out of memory. Unable to load map"
msgstr "GS_load_att_map() : Mémoire saturée. Impossible de charger la carte"
@@ -199,11 +209,11 @@
msgstr "Échec du chargement"
#: ../lib/ogsf/GS2.c:1850
-#, fuzzy
msgid "Error finding range"
-msgstr "Erreur à l'ouverture de la couche matricielle %s"
+msgstr ""
-#: ../lib/ogsf/Gvl3.c:39 ../lib/ogsf/gvl_file.c:428
+#: ../lib/ogsf/Gvl3.c:39
+#: ../lib/ogsf/gvl_file.c:428
#: ../lib/gpde/N_arrays_io.c:296
#, c-format
msgid "3D raster map <%s> not found"
@@ -213,14 +223,19 @@
msgid "Bitmap mismatch"
msgstr ""
-#: ../lib/ogsf/Gv3.c:57 ../lib/ogsf/Gp3.c:109
-#: ../lib/vector/Vlib/legal_vname.c:118 ../lib/vector/Vlib/legal_vname.c:121
-#: ../lib/vector/Vlib/map.c:327 ../lib/vector/Vlib/open.c:168
+#: ../lib/ogsf/Gv3.c:57
+#: ../lib/ogsf/Gp3.c:109
+#: ../lib/vector/Vlib/legal_vname.c:118
+#: ../lib/vector/Vlib/legal_vname.c:121
+#: ../lib/vector/Vlib/map.c:327
+#: ../lib/vector/Vlib/open.c:168
#, c-format
msgid "Vector map <%s> not found"
msgstr "La couche vectorielle <%s> n'a pas été trouvée"
-#: ../lib/ogsf/Gv3.c:63 ../lib/ogsf/Gp3.c:115 ../lib/vector/Vlib/open.c:199
+#: ../lib/ogsf/Gv3.c:63
+#: ../lib/ogsf/Gp3.c:115
+#: ../lib/vector/Vlib/open.c:199
#, c-format
msgid "Unable to open vector map <%s>"
msgstr "Impossible d'ouvrir la couche vectorielle <%s>"
@@ -235,17 +250,28 @@
msgid "Vector map <%s> loaded (%d features)"
msgstr "Carte vecteur <%s> chargée (%d objets)"
-#: ../lib/ogsf/Gp3.c:54 ../lib/ogsf/gsd_legend.c:238 ../lib/ogsf/Gs3.c:126
-#: ../lib/ogsf/Gs3.c:201 ../lib/ogsf/Gs3.c:286 ../lib/ogsf/Gs3.c:359
-#: ../lib/ogsf/Gs3.c:475 ../lib/ogsf/Gs3.c:572 ../lib/ogsf/Gs3.c:639
-#: ../lib/ogsf/Gs3.c:696 ../lib/ogsf/Gs3.c:767 ../lib/ogsf/Gs3.c:837
-#: ../lib/gpde/N_arrays_io.c:56 ../lib/gis/legal_name.c:94
-#: ../lib/gis/legal_name.c:97 ../lib/gis/opencell.c:1011
+#: ../lib/ogsf/Gp3.c:54
+#: ../lib/ogsf/gsd_legend.c:238
+#: ../lib/ogsf/Gs3.c:126
+#: ../lib/ogsf/Gs3.c:201
+#: ../lib/ogsf/Gs3.c:286
+#: ../lib/ogsf/Gs3.c:359
+#: ../lib/ogsf/Gs3.c:475
+#: ../lib/ogsf/Gs3.c:572
+#: ../lib/ogsf/Gs3.c:639
+#: ../lib/ogsf/Gs3.c:696
+#: ../lib/ogsf/Gs3.c:767
+#: ../lib/ogsf/Gs3.c:837
+#: ../lib/gpde/N_arrays_io.c:56
+#: ../lib/gis/legal_name.c:94
+#: ../lib/gis/legal_name.c:97
+#: ../lib/gis/opencell.c:1011
#, c-format
msgid "Raster map <%s> not found"
msgstr "La carte vecteur <%s> n'a pas été trouvée"
-#: ../lib/ogsf/Gp3.c:145 ../lib/vector/Vlib/map.c:68
+#: ../lib/ogsf/Gp3.c:145
+#: ../lib/vector/Vlib/map.c:68
#: ../lib/vector/Vlib/map.c:84
#, c-format
msgid "Unable to read vector map <%s>"
@@ -268,15 +294,13 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot() : %c est une spécification d'axe non valide. Rotation ignorée. "
-"Merci d'avertir les développeurs GRASS de cette erreur"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot() : %c est une spécification d'axe non valide. Rotation ignorée. Merci d'avertir les développeurs GRASS de cette erreur"
-#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:219
-#: ../lib/ogsf/gsd_img_ppm.c:53 ../lib/ogsf/gsd_img_ppm.c:96
+#: ../lib/ogsf/gsd_img_tif.c:64
+#: ../lib/ogsf/GK2.c:219
+#: ../lib/ogsf/gsd_img_ppm.c:53
+#: ../lib/ogsf/gsd_img_ppm.c:96
#, c-format
msgid "Unable to open file <%s> for writing"
msgstr "Impossible d'ouvrir le fichier <%s> en écriture"
@@ -298,9 +322,8 @@
msgstr "Impossible de traiter la carte vecteur - mémoire saturée"
#: ../lib/ogsf/gsd_img_mpeg.c:63
-#, fuzzy
msgid "Unable to allocate stream"
-msgstr "Impossible d'allouer un flux"
+msgstr "Impossible d'allouer le flux"
#: ../lib/ogsf/gsd_img_mpeg.c:156
msgid "Video codec not found"
@@ -323,7 +346,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:252
#, fuzzy
msgid "Error while writing video frame"
-msgstr "Erreur lors de l'écriture du fichier topo."
+msgstr "Erreur lors de l'écriture du fichier vidéo"
#: ../lib/ogsf/gsd_img_mpeg.c:298
#, c-format
@@ -332,24 +355,32 @@
#: ../lib/ogsf/gsd_img_mpeg.c:306
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Impossible de déduire le format de sortie de l'extension du fichier : "
-"utilisation de MPEG"
+msgstr "Impossible de déduire le format de sortie de l'extension du fichier : utilisation de MPEG"
#: ../lib/ogsf/gsd_img_mpeg.c:310
msgid "Unable to find suitable output format"
msgstr "Impossible de trouver un format de sortie adapté"
-#: ../lib/ogsf/gsd_img_mpeg.c:317 ../lib/vector/neta/centrality.c:63
-#: ../lib/vector/neta/centrality.c:145 ../lib/vector/neta/path.c:134
-#: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
-#: ../lib/vector/neta/bridge.c:59 ../lib/vector/neta/flow.c:64
-#: ../lib/vector/neta/flow.c:178 ../lib/vector/neta/timetables.c:69
-#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
-#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
-#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
-#: ../lib/vector/neta/allpairs.c:50 ../lib/vector/neta/spanningtree.c:99
-#: ../lib/vector/neta/articulation_point.c:60 ../lib/vector/Vlib/line.c:62
+#: ../lib/ogsf/gsd_img_mpeg.c:317
+#: ../lib/vector/neta/centrality.c:63
+#: ../lib/vector/neta/centrality.c:145
+#: ../lib/vector/neta/path.c:134
+#: ../lib/vector/neta/components.c:46
+#: ../lib/vector/neta/components.c:113
+#: ../lib/vector/neta/bridge.c:59
+#: ../lib/vector/neta/flow.c:64
+#: ../lib/vector/neta/flow.c:178
+#: ../lib/vector/neta/timetables.c:69
+#: ../lib/vector/neta/timetables.c:168
+#: ../lib/vector/neta/timetables.c:178
+#: ../lib/vector/neta/timetables.c:191
+#: ../lib/vector/neta/timetables.c:278
+#: ../lib/vector/neta/timetables.c:413
+#: ../lib/vector/neta/timetables.c:425
+#: ../lib/vector/neta/allpairs.c:50
+#: ../lib/vector/neta/spanningtree.c:99
+#: ../lib/vector/neta/articulation_point.c:60
+#: ../lib/vector/Vlib/line.c:62
#: ../lib/rst/interp_float/segmen2d.c:175
#: ../lib/rst/interp_float/segmen2d.c:181
#: ../lib/rst/interp_float/segmen2d.c:187
@@ -383,28 +414,26 @@
msgstr "Impossible d'ouvrir le fichier de catégories de la carte raster <%s>"
#: ../lib/ogsf/gsd_legend.c:268
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read fp range of raster map <%s>"
msgstr "Impossible de lire la couche vectorielle <%s%s>"
#: ../lib/ogsf/gsd_legend.c:280
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read range of raster map <%s>"
-msgstr "Impossible de lire la couche vectorielle <%s%s>"
+msgstr ""
#: ../lib/ogsf/gsd_legend.c:294
msgid "Range request error for legend"
msgstr ""
#: ../lib/ogsf/gsd_legend.c:384
-#, fuzzy
msgid "Unable to show discrete FP range (use list"
+msgstr ""
#: ../lib/ogsf/gsd_legend.c:500
-#, fuzzy
msgid "Too many categories to show as discrete!"
-msgstr "Trop de catégories de reclassification pour [%s dans %s]"
+msgstr "Trop de catégories pour l'affichage en valeurs discrètes !"
#: ../lib/ogsf/gsd_legend.c:502
msgid "Try using smaller font!"
@@ -414,39 +443,51 @@
msgid "Maximum number of datafiles exceeded"
msgstr "Nombre maximal de fichiers de données dépassé"
-#: ../lib/ogsf/gvl_file.c:437 ../lib/gpde/N_arrays_io.c:304
+#: ../lib/ogsf/gvl_file.c:437
+#: ../lib/gpde/N_arrays_io.c:304
#, c-format
msgid "Unable to open 3D raster map <%s>"
msgstr "Impossible d'ouvrir la carte raster 3D <%s>"
#: ../lib/ogsf/gvl_file.c:443
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read range of 3D raster map <%s>"
+msgstr ""
#: ../lib/ogsf/gvl_file.c:471
#, c-format
msgid "Unable to close 3D raster map <%s>"
msgstr "Impossible de fermer la carte raster 3D <%s>"
-#: ../lib/ogsf/GK2.c:275 ../lib/ogsf/GK2.c:288
+#: ../lib/ogsf/GK2.c:275
+#: ../lib/ogsf/GK2.c:288
msgid "Check no. of frames requested and keyframes marked"
msgstr ""
-#: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:208 ../lib/ogsf/Gs3.c:366
-#: ../lib/ogsf/Gs3.c:482 ../lib/ogsf/Gs3.c:587
+#: ../lib/ogsf/Gs3.c:133
+#: ../lib/ogsf/Gs3.c:208
+#: ../lib/ogsf/Gs3.c:366
+#: ../lib/ogsf/Gs3.c:482
+#: ../lib/ogsf/Gs3.c:587
#, fuzzy
msgid "Unable to allocate memory for a null buffer"
-msgstr "Allocation mémoire impossible\n"
+msgstr "Impossible d'allouer la mémoire pour un tampon nul"
-#: ../lib/ogsf/Gs3.c:137 ../lib/ogsf/Gs3.c:212 ../lib/ogsf/Gs3.c:370
-#: ../lib/ogsf/Gs3.c:486 ../lib/ogsf/Gs3.c:577 ../lib/gpde/N_arrays_io.c:68
+#: ../lib/ogsf/Gs3.c:137
+#: ../lib/ogsf/Gs3.c:212
+#: ../lib/ogsf/Gs3.c:370
+#: ../lib/ogsf/Gs3.c:486
+#: ../lib/ogsf/Gs3.c:577
+#: ../lib/gpde/N_arrays_io.c:68
#, c-format
msgid "Unable to open raster map <%s>"
msgstr "Impossible d'ouvrir la carte raster <%s>"
-#: ../lib/ogsf/Gs3.c:140 ../lib/ogsf/Gs3.c:215 ../lib/ogsf/Gs3.c:378
-#: ../lib/ogsf/Gs3.c:494 ../lib/ogsf/Gs3.c:590
+#: ../lib/ogsf/Gs3.c:140
+#: ../lib/ogsf/Gs3.c:215
+#: ../lib/ogsf/Gs3.c:378
+#: ../lib/ogsf/Gs3.c:494
+#: ../lib/ogsf/Gs3.c:590
#, c-format
msgid "Loading raster map <%s>..."
msgstr "Chargement de la carte raster <%s>..."
@@ -454,9 +495,10 @@
#: ../lib/ogsf/Gs3.c:647
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
+msgstr "L'étendue de la table de couleur ne correspond pas aux données (mincol=%d, maxcol=%d"
-#: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
+#: ../lib/ogsf/Gs3.c:709
+#: ../lib/ogsf/Gs3.c:781
#, c-format
msgid "Translating colors from raster map <%s>..."
msgstr "Traduction des couleurs à partir de la carte raster <%s>..."
@@ -484,68 +526,56 @@
#: ../lib/proj/convert.c:127
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR ne peut pas analyser la chaîne de paramètre PROJ.4 : %s (Le code erreur "
-"OGR était %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR ne peut pas analyser la chaîne de paramètre PROJ.4 : %s (Le code erreur OGR était %d)"
#: ../lib/proj/convert.c:133
-#, fuzzy, c-format
+#, c-format
msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR ne peut pas obtenir les paramètres WKT\n"
-"(Le code erreur OGR était %d)"
+msgstr "OGR ne peut pas obtenir les paramètres WKT (code d'erreur OGR %d)"
#: ../lib/proj/convert.c:390
msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"Aucun nom de projection ! Projection de paramètres susceptibles d'être vide "
-"de sens."
+msgstr "Aucun nom de projection ! Projection de paramètres susceptibles d'être vide de sens."
#: ../lib/proj/convert.c:426
#, fuzzy, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr "La date <%s> n'est pas reconnue par GRASS et aucun paramètre trouvé."
+msgstr "Le datum <%s> n'est pas reconnu par GRASS et aucun paramètre trouvé"
#: ../lib/proj/convert.c:442
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"La date <% s> est apparemment reconnue par GRASS mais aucun paramètre "
-"trouvé. Vous devez examiner."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "La date <% s> est apparemment reconnue par GRASS mais aucun paramètre trouvé. Vous devez examiner."
#: ../lib/proj/convert.c:446
-#, fuzzy, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"La transformation du nombre %d est incorrecte ; la plage valide est de 1 à "
-"%d. Les paramètres de la transformation ne sont pas spécifiés."
+#, c-format
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Numéro de transformation %d invalide ; la plage valide est de 1 à %d. Paramètres datum de la transformation laissés non spécifiés."
#: ../lib/proj/datum.c:250
-#, fuzzy
msgid "Unable to open temporary file"
-msgstr "Impossible d'ouvrir le fichier %s"
+msgstr "Impossible d'ouvrir le fichier temporaire"
-#: ../lib/proj/datum.c:344 ../lib/gis/get_ell_name.c:45
-#: ../lib/gis/get_projname.c:52 ../lib/gis/get_datum_name.c:58
+#: ../lib/proj/datum.c:344
+#: ../lib/gis/get_ell_name.c:45
+#: ../lib/gis/get_projname.c:52
+#: ../lib/gis/get_datum_name.c:58
#, c-format
msgid "Hit RETURN to cancel request\n"
msgstr "Pressez RETOUR pour abandonner\n"
-#: ../lib/proj/datum.c:418 ../lib/proj/datum.c:498
-#, fuzzy, c-format
+#: ../lib/proj/datum.c:418
+#: ../lib/proj/datum.c:498
+#, c-format
msgid "Unable to open datum table file <%s>"
-msgstr "impossible d'ouvrir le fichier de datums : %s"
+msgstr "impossible d'ouvrir le fichier de datums <%s>"
-#: ../lib/proj/datum.c:431 ../lib/proj/datum.c:512
-#, fuzzy, c-format
+#: ../lib/proj/datum.c:431
+#: ../lib/proj/datum.c:512
+#, c-format
msgid "Error in datum table file <%s>, line %d"
-msgstr "erreur dans la table du fichier de datums, ligne %d"
+msgstr "Erreur dans la table du fichier de datums <%s>, ligne %d"
#: ../lib/proj/get_proj.c:150
#, c-format
@@ -586,45 +616,46 @@
msgid "Output Unit Factor"
msgstr "Facteur unité de sortie"
-#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
+#: ../lib/proj/do_proj.c:106
+#: ../lib/proj/do_proj.c:180
#, c-format
msgid "pj_transform() failed: %s"
-msgstr ""
+msgstr "pj_transform() a échoué : %s"
#: ../lib/proj/ellipse.c:75
-#, fuzzy, c-format
+#, c-format
msgid "Invalid ellipsoid <%s> in file"
-msgstr "l'ellipsoïde %s du fichier est invalide"
+msgstr "Ellipsoïde %s invalide dans le fichier"
#: ../lib/proj/ellipse.c:98
msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-"Pas de descripteur secondaire (rf, es or b) d'ellipsoïde dans le fichier"
+msgstr "Pas de descripteur secondaire (rf, es or b) d'ellipsoïde dans le fichier"
#: ../lib/proj/ellipse.c:102
-#, fuzzy
msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+msgstr "Descripteurs de l'ellipsoïde (a, rf, es ou b) invalides dans le fichier"
#: ../lib/proj/ellipse.c:115
msgid "No ellipsoid info given in file"
msgstr "Le fichier ne contient pas d'information sur l'ellipsoïde"
-#: ../lib/proj/ellipse.c:215 ../lib/gis/get_ellipse.c:283
-#, fuzzy, c-format
+#: ../lib/proj/ellipse.c:215
+#: ../lib/gis/get_ellipse.c:283
+#, c-format
msgid "Unable to open ellipsoid table file <%s>"
-msgstr "impossible d'ouvrir le fichier de l'ellipsoïde : %s"
+msgstr "impossible d'ouvrir la table d'ellipsoïde du fichier %s"
-#: ../lib/proj/ellipse.c:268 ../lib/gis/get_ellipse.c:338
+#: ../lib/proj/ellipse.c:268
+#: ../lib/gis/get_ellipse.c:338
#, c-format
msgid "Line%s of ellipsoid table file <%s> is invalid"
msgstr "La ligne%s du fichier <%s> de la table de l'ellipsoïde est invalide"
-#: ../lib/proj/ellipse.c:269 ../lib/gis/get_ellipse.c:336
+#: ../lib/proj/ellipse.c:269
+#: ../lib/gis/get_ellipse.c:336
#, c-format
msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr ""
-"Les lignes%s du fichier <%s> de la table de l'ellipsoïde sont invalides"
+msgstr "Les lignes%s du fichier <%s> de la table de l'ellipsoïde sont invalides"
#: ../lib/g3d/g3dparam.c:52
msgid "Data type used in the output file"
@@ -632,8 +663,7 @@
#: ../lib/g3d/g3dparam.c:61
msgid "Precision used in the output file (default, max, or 0 to 52)"
-msgstr ""
-"Précision utilisée dans le fichier de sortie (par défaut, max, ou 0 à 52)"
+msgstr "Précision utilisée dans le fichier de sortie (par défaut, max, ou 0 à 52)"
#: ../lib/g3d/g3dparam.c:71
msgid "The compression method used in the output file"
@@ -681,15 +711,14 @@
#: ../lib/g3d/g3dopen.c:124
msgid "G3d_openCellOld: projection does not match window projection"
-msgstr ""
-"G3d_openCellOld : la projection ne correspond pas à la projection de la "
-"fenêtre"
+msgstr "G3d_openCellOld : la projection ne correspond pas à la projection de la fenêtre"
#: ../lib/g3d/g3dopen.c:128
msgid "G3d_openCellOld: zone does not match window zone"
msgstr "G3d_openCellOld : la zone ne correspond pas à la zone de la fenêtre"
-#: ../lib/g3d/g3dopen.c:140 ../lib/g3d/g3dopen.c:157
+#: ../lib/g3d/g3dopen.c:140
+#: ../lib/g3d/g3dopen.c:157
msgid "G3d_openCellOld: can't read header"
msgstr "G3d_openCellOld : impossible de lire l'en-tête"
@@ -717,7 +746,8 @@
msgid "G3d_openCellNew: could not open file"
msgstr "G3d_openCellNew : impossible d'ouvrir le fichier"
-#: ../lib/g3d/g3dopen.c:290 ../lib/g3d/g3dopen.c:295
+#: ../lib/g3d/g3dopen.c:290
+#: ../lib/g3d/g3dopen.c:295
msgid "G3d_openCellNew: can't write header"
msgstr "G3d_openCellNew : impossible d'écrire l'en-tête"
@@ -725,7 +755,8 @@
msgid "G3d_openCellNew: error in G3d_fillHeader"
msgstr "G3d_openCellNew : erreur dans G3d_fillHeader"
-#: ../lib/g3d/g3dhistory.c:42 ../lib/gis/history.c:132
+#: ../lib/g3d/g3dhistory.c:42
+#: ../lib/gis/history.c:132
#, c-format
msgid "can't get history information for [%s] in mapset [%s]"
msgstr "impossible d'obtenir l'historique pour [%s] dans le mapset [%s]"
@@ -737,16 +768,12 @@
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-"Le verrouillage concurrent de jeux de cartes n'est pas pris en charge dans "
-"Windows"
+msgstr "Le verrouillage concurrent de jeux de cartes n'est pas pris en charge dans Windows"
#: ../lib/init/lock.c:60
#, c-format
msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr ""
-"Impossible d'écrire le fichier de verrouillage %s (disque plein ? "
-"permissions ?)"
+msgstr "Impossible d'écrire le fichier de verrouillage %s (disque plein ? permissions ?)"
#: ../lib/raster/io_sock.c:63
msgid "No graphics monitor has been selected for output."
@@ -835,31 +862,27 @@
msgstr "Le groupe <%s> référence les cartes raster suivantes\n"
#: ../lib/imagery/sigsetfile.c:41
-#, fuzzy, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"Impossible de créer le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
+#, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> du groupe <%s> - <%s> n'est pas le jeux de cartes courant"
#: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
+msgstr "Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> du groupe <%s>"
#: ../lib/imagery/sigsetfile.c:86
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
+msgstr "Impossible d'ouvrir le fichier de signatures <%s> pour le sous-groupe <%s>du groupe <%s@%s>"
#: ../lib/imagery/fopen.c:23
#, c-format
msgid "Unable to create file [%s] of group [%s in %s]"
msgstr "Impossible de créer le fichier [%s] du groupe [%s de %s]"
-#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
+#: ../lib/imagery/fopen.c:36
+#: ../lib/imagery/fopen.c:57
#, c-format
msgid "Unable to open file [%s] of group [%s in %s]"
msgstr "Impossible d'ouvrir le fichier [%s] du groupe [%s de %s]"
@@ -872,21 +895,18 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
+msgstr "Impossible de créer le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
-#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
+#: ../lib/imagery/fopen.c:101
+#: ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
+msgstr "Impossible d'ouvrir le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible de trouver le fichier [%s] pour le sous-groupe [%s] du groupe [%s "
-"de %s]"
+msgstr "Impossible de trouver le fichier [%s] pour le sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/list_subgp.c:36
#, c-format
@@ -896,30 +916,30 @@
#: ../lib/imagery/list_subgp.c:48
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"Le sous-groupe <%s> du groupe <%s>référence les cartes raster suivantes\n"
+msgstr "Le sous-groupe <%s> du groupe <%s>référence les cartes raster suivantes\n"
#: ../lib/imagery/target.c:38
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read target file for group [%s]"
-msgstr "Impossible de créer le fichier d'en-tête pour [%s]"
+msgstr "Impossible de lire le fichier de cible pour le groupe [%s]"
#: ../lib/imagery/points.c:124
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr "Impossible d'ouvrir le fichier [%s] du groupe [%s de %s]"
+msgstr "Impossible d'ouvrir le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/points.c:132
-#, fuzzy, c-format
+#, c-format
msgid "Bad format in control point file for group [%s in %s]"
+msgstr "Mauvais format dans le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/points.c:159
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create control point file for group [%s in %s]"
-msgstr "Impossible de créer le fichier [%s] du groupe [%s de %s]"
+msgstr "Impossible de créer le fichier de points de contrôle pour le groupe [%s dans %s]"
-#: ../lib/gmath/la.c:64 ../lib/gmath/la.c:120
+#: ../lib/gmath/la.c:64
+#: ../lib/gmath/la.c:120
msgid "Matrix dimensions out of range"
msgstr "Dimension de la matrice en dehors des limites"
@@ -935,11 +955,14 @@
msgid "First scalar multiplier must be non-zero"
msgstr "Le première scalaire multiplicateur ne doit pas être à zéro"
-#: ../lib/gmath/la.c:253 ../lib/gmath/la.c:261 ../lib/gmath/la.c:326
+#: ../lib/gmath/la.c:253
+#: ../lib/gmath/la.c:261
+#: ../lib/gmath/la.c:326
msgid "One or both input matrices uninitialised"
msgstr "Une ou deux matrices d'entrée non initialisées"
-#: ../lib/gmath/la.c:266 ../lib/gmath/la.c:331
+#: ../lib/gmath/la.c:266
+#: ../lib/gmath/la.c:331
msgid "Matrix order does not match"
msgstr "L'ordre des matrices ne correspond pas"
@@ -967,7 +990,8 @@
msgid "Could not allocate space for solution matrix"
msgstr "Impossible d'allouer de l'espace pour la matrice solution"
-#: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
+#: ../lib/gmath/la.c:470
+#: ../lib/gmath/la.c:478
msgid "Could not allocate space for working matrix"
msgstr "Impossible d'allouer de l'espace pour la matrice de travail"
@@ -1009,15 +1033,18 @@
#: ../lib/gmath/la.c:750
msgid "Specified matrix column index is outside range"
-msgstr ""
-"L'index de colonne de la matrice spécifié est en dehors de l'intervalle"
+msgstr "L'index de colonne de la matrice spécifié est en dehors de l'intervalle"
-#: ../lib/gmath/la.c:755 ../lib/gmath/la.c:796 ../lib/gmath/la.c:1109
-#: ../lib/gmath/la.c:1161 ../lib/gmath/la.c:1236
+#: ../lib/gmath/la.c:755
+#: ../lib/gmath/la.c:796
+#: ../lib/gmath/la.c:1109
+#: ../lib/gmath/la.c:1161
+#: ../lib/gmath/la.c:1236
msgid "Matrix is not initialised"
msgstr "La matrice n'est pas initialisée"
-#: ../lib/gmath/la.c:760 ../lib/gmath/la.c:801
+#: ../lib/gmath/la.c:760
+#: ../lib/gmath/la.c:801
msgid "Could not allocate space for vector structure"
msgstr "Impossible d'allouer de l'espace pour le vecteur structure"
@@ -1073,7 +1100,9 @@
msgid "Vector structure is not initialised"
msgstr "La structure du vecteur n'est pas initialisée"
-#: ../lib/gmath/la.c:1395 ../lib/gmath/la.c:1403 ../lib/gmath/la.c:1408
+#: ../lib/gmath/la.c:1395
+#: ../lib/gmath/la.c:1403
+#: ../lib/gmath/la.c:1408
msgid "Input format error"
msgstr "Erreur de format d'entrée"
@@ -1097,7 +1126,8 @@
msgid " taking inverse FFT..."
msgstr " prenant FFT inverse..."
-#: ../lib/display/tran_colr.c:129 ../lib/display/tran_colr.c:131
+#: ../lib/display/tran_colr.c:129
+#: ../lib/display/tran_colr.c:131
#, c-format
msgid "[%s]: No such color"
msgstr "[%s] : cette couleur n'existe pas"
@@ -1114,9 +1144,7 @@
#: ../lib/driver/parse_ftcap.c:32
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s : Impossible de lire le fichier de définition de police, utilisation de "
-"celle par défaut"
+msgstr "%s : Impossible de lire le fichier de définition de police, utilisation de celle par défaut"
#: ../lib/driver/parse_ftcap.c:38
#, c-format
@@ -1139,14 +1167,16 @@
#: ../lib/gpde/N_solvers.c:50
msgid "The gauss elimination solver does not work with sparse matrices"
-msgstr ""
-"La résolution par la méthode de Gauss ne fonctionne pas avec les matrices "
-"creuses"
+msgstr "La résolution par la méthode de Gauss ne fonctionne pas avec les matrices creuses"
-#: ../lib/gpde/N_solvers.c:55 ../lib/gpde/N_solvers.c:93
-#: ../lib/gpde/N_solvers.c:160 ../lib/gpde/N_solvers_classic_iter.c:57
-#: ../lib/gpde/N_solvers_classic_iter.c:94 ../lib/gpde/N_solvers_krylov.c:78
-#: ../lib/gpde/N_solvers_krylov.c:255 ../lib/gpde/N_solvers_krylov.c:423
+#: ../lib/gpde/N_solvers.c:55
+#: ../lib/gpde/N_solvers.c:93
+#: ../lib/gpde/N_solvers.c:160
+#: ../lib/gpde/N_solvers_classic_iter.c:57
+#: ../lib/gpde/N_solvers_classic_iter.c:94
+#: ../lib/gpde/N_solvers_krylov.c:78
+#: ../lib/gpde/N_solvers_krylov.c:255
+#: ../lib/gpde/N_solvers_krylov.c:423
#: ../lib/gpde/N_solvers_krylov.c:832
msgid "The linear equation system is not quadratic"
msgstr "Le système d'équations linéaires n'est pas quadratique"
@@ -1167,7 +1197,8 @@
msgid "The cholesky solver does not work with sparse matrices"
msgstr "Le solveur de Cholesky ne fonctionne pas avec les matrices creuses"
-#: ../lib/gpde/N_solvers.c:166 ../lib/gpde/N_solvers_krylov.c:84
+#: ../lib/gpde/N_solvers.c:166
+#: ../lib/gpde/N_solvers_krylov.c:84
#: ../lib/gpde/N_solvers_krylov.c:261
msgid "Matrix is not symmetric!"
msgstr "La matrice n'est pas symétrique!"
@@ -1176,44 +1207,32 @@
msgid "Starting cholesky decomposition solver"
msgstr "Commencer la décomposition par la méthode de Cholesky"
-#: ../lib/gpde/N_solvers.c:173 ../lib/gpde/N_solvers_krylov.c:190
-#: ../lib/gpde/N_solvers_krylov.c:357 ../lib/gpde/N_solvers_krylov.c:481
+#: ../lib/gpde/N_solvers.c:173
+#: ../lib/gpde/N_solvers_krylov.c:190
+#: ../lib/gpde/N_solvers_krylov.c:357
+#: ../lib/gpde/N_solvers_krylov.c:481
msgid "Unable to solve the linear equation system"
msgstr "Impossible de résoudre le système d'équations linéaires"
#: ../lib/gpde/N_parse_options.c:59
-msgid ""
-"The type of solver which should solve the symmetric linear equation system"
-msgstr ""
-"Le type de solveur qui devrait résoudre le système d'équations linéaires "
-"symétrique"
+msgid "The type of solver which should solve the symmetric linear equation system"
+msgstr "Le type de solveur qui devrait résoudre le système d'équations linéaires symétrique"
#: ../lib/gpde/N_parse_options.c:71
msgid "The type of solver which should solve the linear equation system"
-msgstr ""
-"Le type de solveur qui devrait permettre de résoudre le système d'équations "
-"linéaires"
+msgstr "Le type de solveur qui devrait permettre de résoudre le système d'équations linéaires"
#: ../lib/gpde/N_parse_options.c:80
msgid "Maximum number of iteration used to solver the linear equation system"
-msgstr ""
-"Nombre maximum d'itérations utilisées pour le solutionneur du système "
-"d'équations linéaires"
+msgstr "Nombre maximum d'itérations utilisées pour le solutionneur du système d'équations linéaires"
#: ../lib/gpde/N_parse_options.c:89
-msgid ""
-"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-msgstr ""
-"Erreur de critères pour le solveur par itération (Jacobi, sor, cg ou "
-"bicgstab)"
+msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr "Erreur de critères pour le solveur par itération (Jacobi, sor, cg ou bicgstab)"
#: ../lib/gpde/N_parse_options.c:98
-msgid ""
-"The relaxation parameter used by the jacobi and sor solver for speedup or "
-"stabilizing"
-msgstr ""
-"Les paramètres utilisés par le solveur pour les méthodes jacobi et sor pour "
-"accélérer ou stabiliser"
+msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+msgstr "Les paramètres utilisés par le solveur pour les méthodes jacobi et sor pour accélérer ou stabiliser"
#: ../lib/gpde/N_parse_options.c:106
msgid "The calculation time in seconds"
@@ -1602,7 +1621,8 @@
msgid "Could not get raster row"
msgstr "Impossible d'obtenir la ligne matricielle"
-#: ../lib/gpde/N_arrays_io.c:162 ../lib/gpde/N_arrays_io.c:244
+#: ../lib/gpde/N_arrays_io.c:162
+#: ../lib/gpde/N_arrays_io.c:244
msgid "Unable to close input map"
msgstr "Impossible de fermer la carte en entrée"
@@ -1611,27 +1631,29 @@
msgstr "Le tableau N_array_2d * est vide"
#: ../lib/gpde/N_arrays_io.c:203
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create raster map <%s>"
-msgstr "Impossible de créer la couche vectorielle <%s>"
+msgstr "Impossible de créer la couche raster <%s>"
#: ../lib/gpde/N_arrays_io.c:212
#, c-format
msgid "Write 2d array to raster map <%s>"
msgstr "Écriture du tableau 2d dans la couche matricielle <%s>"
-#: ../lib/gpde/N_arrays_io.c:228 ../lib/gpde/N_arrays_io.c:233
+#: ../lib/gpde/N_arrays_io.c:228
+#: ../lib/gpde/N_arrays_io.c:233
#: ../lib/gpde/N_arrays_io.c:238
-#, fuzzy, c-format
+#, c-format
msgid "Unable to write raster row %i"
-msgstr "Impossible d'écrire la ligne matricielle %i"
+msgstr "Impossible d'écrire la ligne raster %i"
#: ../lib/gpde/N_arrays_io.c:332
#, c-format
msgid "Read g3d map <%s> into the memory"
msgstr "Écriture de la couche g3d <%s> dans la mémoire"
-#: ../lib/gpde/N_arrays_io.c:387 ../lib/gpde/N_arrays_io.c:487
+#: ../lib/gpde/N_arrays_io.c:387
+#: ../lib/gpde/N_arrays_io.c:487
msgid "Error closing g3d file"
msgstr "Erreur à la fermeture du fichier g3d"
@@ -1657,44 +1679,44 @@
#: ../lib/arraystats/class.c:26
#, c-format
msgid "%s: Error in classification algorithm"
-msgstr ""
+msgstr "%s : Erreur dans l'algorithme de classification"
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
msgstr ""
-#: ../lib/vector/neta/utils.c:219 ../lib/vector/neta/utils.c:232
+#: ../lib/vector/neta/utils.c:219
+#: ../lib/vector/neta/utils.c:232
#, c-format
msgid "'%s' must be > 0 for '%s'"
-msgstr ""
+msgstr "'%s' doit être > 0 pour '%s'"
#: ../lib/vector/neta/utils.c:221
msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
msgstr "les paramètres 'where' et 'cats' ont été fournis, cat sera ignoré"
#: ../lib/vector/neta/utils.c:225
-#, fuzzy
msgid "Unable to load data from database"
-msgstr "Impossible d'ajouter un lien base de données."
+msgstr "Impossible de charger des données depuis la base de données"
#: ../lib/vector/neta/utils.c:236
-#, fuzzy
msgid "Problem loading category values"
-msgstr "Problème de lecture du fichier de cellules raster"
+msgstr "Problème de chargement des valeurs de catégories"
-#: ../lib/vector/neta/flow.c:309 ../lib/vector/Vlib/net.c:432
+#: ../lib/vector/neta/flow.c:309
+#: ../lib/vector/Vlib/net.c:432
#: ../lib/vector/Vlib/graph.c:110
msgid "GngFlatten error"
msgstr "Erreur GngFlatten"
-#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
-#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, fuzzy, c-format
+#: ../lib/vector/neta/timetables.c:46
+#: ../lib/vector/neta/timetables.c:203
+#: ../lib/vector/neta/timetables.c:244
+#: ../lib/vector/neta/timetables.c:286
+#, c-format
msgid "Unable to open select cursor: %s"
+msgstr "Impossible d'ouvrir le curseur de sélection : %s"
#: ../lib/vector/neta/allpairs.c:53
msgid "Computing all pairs shortest paths..."
@@ -1706,204 +1728,184 @@
#: ../lib/vector/diglib/plus_node.c:217
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Tentative de lire l'angle d'une ligne qui n'est pas connectée au noeud : noeud %d, ligne %d"
#: ../lib/vector/diglib/file.c:157
msgid "Writing to file loaded to memory not supported"
msgstr "L'écriture dans un fichier chargé en mémoire n'est pas prise en charge"
#: ../lib/vector/diglib/file.c:200
-#, fuzzy
msgid "Unable to load file to memory, file not open"
+msgstr "Impossible de charger le fichier en mémoire, fichier non ouvert"
#: ../lib/vector/diglib/file.c:215
msgid "Vector memory mode not supported, using 'AUTO'"
msgstr ""
#: ../lib/vector/diglib/plus.c:288
-#, fuzzy
msgid "Unable read topology for nodes"
-msgstr "Impossible de lire la topologie pour les noeuds"
+msgstr "Impossible de lire la topologie des noeuds"
#: ../lib/vector/diglib/plus.c:293
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read topology for node %d"
-msgstr "Impossible de lire la topologie pour le noeud [%d]"
+msgstr "Impossible de lire la topologie du noeud %d"
#: ../lib/vector/diglib/plus.c:298
-#, fuzzy
msgid "Unable read topology for lines"
-msgstr "Impossible d'écrire la topologie pour les lignes"
+msgstr "Impossible de lire la topologie des lignes"
#: ../lib/vector/diglib/plus.c:303
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read topology for line %d"
-msgstr "Impossible de lire la topologie pour la ligne [%d]"
+msgstr "Impossible de lire la topologie de la ligne %d"
#: ../lib/vector/diglib/plus.c:308
-#, fuzzy
msgid "Unable to read topo for areas"
-msgstr "Impossible de lire la topologie pour les surfaces"
+msgstr "Impossible de lire la topologie des surfaces"
#: ../lib/vector/diglib/plus.c:313
-#, fuzzy, c-format
+#, c-format
msgid "Unable read topology for area %d"
-msgstr "Impossible de lire la topologie pour la surface [%d]"
+msgstr "Impossible de lire la topologie de la surface %d"
#: ../lib/vector/diglib/plus.c:318
-#, fuzzy
msgid "Unable to read topology for isles"
-msgstr "Impossible de lire la topologie pour les îles"
+msgstr "Impossible de lire la topologie des îles"
#: ../lib/vector/diglib/plus.c:323
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read topology for isle %d"
-msgstr "Impossible de lire la topologie pour l'île [%d]"
+msgstr "Impossible de lire la topologie de l'île %d"
-#: ../lib/vector/diglib/plus.c:345 ../lib/vector/diglib/plus.c:371
-#, fuzzy
+#: ../lib/vector/diglib/plus.c:345
+#: ../lib/vector/diglib/plus.c:371
msgid "Unable to write head to plus file"
-msgstr "Impossible de lire le fichier d'en-tête"
+msgstr "Impossible d'écrire l'en-tête du fichier plus"
#: ../lib/vector/diglib/plus.c:350
-#, fuzzy
msgid "Unable to write nodes to plus file"
-msgstr "pas en mesure d'écrire le fichier!"
+msgstr "Impossible d'écrire le noeud dans le fichier plus"
#: ../lib/vector/diglib/plus.c:355
-#, fuzzy
msgid "Unable to write lines to plus file"
+msgstr "Impossible d'écrire les lignes dans le fichier plus"
#: ../lib/vector/diglib/plus.c:360
-#, fuzzy
msgid "Unable to write areas to plus file"
+msgstr "Impossible d'écrire les surfaces dans le fichier plus"
#: ../lib/vector/diglib/plus.c:365
-#, fuzzy
msgid "Unable to write isles to plus file"
+msgstr "Impossible d'écrire les îles dans le fichier plus"
#: ../lib/vector/diglib/spindex.c:248
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete node %d from spatial index"
-msgstr "Impossible de supprimer le fichier <%s>"
+msgstr "Impossible de supprimer le noeud %d de l'index spatial"
#: ../lib/vector/diglib/spindex.c:288
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete line %d from spatial index"
+msgstr "Impossible de supprimer la ligne %d de l'index spatial"
#: ../lib/vector/diglib/spindex.c:314
-#, fuzzy
msgid "Attempt to delete sidx for dead area"
-msgstr "Tentative de supprimer une île d'une surface morte"
+msgstr "Tentative de supprimer sidx pour une surface morte"
#: ../lib/vector/diglib/spindex.c:327
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete area %d from spatial index"
-msgstr "Tentative de suppression de la surface [%d] info de l'île morte [%d]"
+msgstr "Impossible de supprimer la surface %d de l'index spatial"
#: ../lib/vector/diglib/spindex.c:362
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete isle %d from spatial index"
+msgstr "Impossible de supprimer l'île %d de l'index spatial"
-#: ../lib/vector/diglib/plus_area.c:207 ../lib/vector/diglib/plus_area.c:675
+#: ../lib/vector/diglib/plus_area.c:207
+#: ../lib/vector/diglib/plus_area.c:675
#: ../lib/vector/diglib/plus_area.c:683
-#, fuzzy, c-format
+#, c-format
msgid "Line %d already has area/isle %d to left"
-msgstr "La ligne [%d] a déjà une surface/île [%d] à gauche."
+msgstr "La ligne %d a déjà une surface/île %d à gauche"
#: ../lib/vector/diglib/plus_area.c:217
-#, fuzzy, c-format
+#, c-format
msgid "Line %d already has area/isle %d to right"
-msgstr "La ligne [%d] a déjà une surface/île [%d] à droite."
+msgstr "La ligne %d a déjà une surface/île %d à droite"
#: ../lib/vector/diglib/plus_area.c:299
msgid "Attempt to delete isle from dead area"
#: ../lib/vector/diglib/plus_area.c:316
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to delete not registered isle %d from area %d"
-msgstr "Tentative de supprimer l'île [%d] non enregistrée de la zone [%d]"
+msgstr "Tentative de supprimer l'île %d non enregistrée de la zone %d"
#: ../lib/vector/diglib/plus_area.c:354
msgid "Attempt to delete dead area"
msgstr "Tentative de supprimer une surface morte"
#: ../lib/vector/diglib/plus_area.c:394
-#, fuzzy, c-format
+#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Le centroïde mort [%d] enregistré pour une surface (bug dans la librairie)."
+msgstr "Centroïde mort %d enregistré pour une surface (bug dans la librairie vecteur)"
#: ../lib/vector/diglib/plus_area.c:418
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to delete area %d info from dead isle %d"
+msgstr "Tentative de suppression des information de la surface %d de l'île morte %d"
#: ../lib/vector/diglib/plus_area.c:773
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to delete isle %d info from dead area %d"
-msgstr "Tentative de suppression de l'île [%d] info de la surface morte [%d]"
+msgstr "Tentative de suppression des informations de l'île % de la surface morte %d"
-#: ../lib/vector/Vlib/write_nat.c:50 ../lib/vector/Vlib/write_nat.c:83
+#: ../lib/vector/Vlib/write_nat.c:50
+#: ../lib/vector/Vlib/write_nat.c:83
#, c-format
msgid "%s: Area %d does not exist"
msgstr "%s: la surface %d n'existe pas"
#: ../lib/vector/Vlib/write_nat.c:640
-#, fuzzy
msgid "Attempt to delete dead feature"
-msgstr "Tentative de supprimer une surface morte"
+msgstr "Tentative de suppression d'un objet mort"
#: ../lib/vector/Vlib/write_nat.c:885
-#, fuzzy
msgid "Attempt to restore alive feature"
+msgstr "Tentative de restauration d'un objet mort"
#: ../lib/vector/Vlib/legal_vname.c:48
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Ne doit contenir ni '.', ni 'NULL'."
+msgstr "Nom de couche vectorielle illégale <%s>. Ne doit contenir ni '.', ni 'NULL'."
#: ../lib/vector/Vlib/legal_vname.c:55
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Doit commencer par une lettre."
+msgstr "Nom de couche vectorielle illégale <%s>. Doit commencer par une lettre."
#: ../lib/vector/Vlib/legal_vname.c:63
#, c-format
msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Le caractère '%c' n'est pas "
-"autorisé."
+msgstr "Nom de couche vectorielle illégale <%s>. Le caractère '%c' n'est pas autorisé."
#: ../lib/vector/Vlib/legal_vname.c:70
-#, fuzzy, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"autorisé."
+#, c-format
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Nom de couche vectorielle illégale <%s>. Les mot-clefs SQL ne peut pas être utilisés comme nom de carte vectorielle."
-#: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
+#: ../lib/vector/Vlib/legal_vname.c:101
+#: ../lib/vector/Vlib/legal_vname.c:105
#, c-format
msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-"Le nom de sortie de la couche vectorielle <%s> n'est pas un nom de couche "
-"vectorielle valide"
+msgstr "Le nom de sortie de la couche vectorielle <%s> n'est pas un nom de couche vectorielle valide"
-#: ../lib/vector/Vlib/legal_vname.c:142 ../lib/vector/Vlib/legal_vname.c:146
+#: ../lib/vector/Vlib/legal_vname.c:142
+#: ../lib/vector/Vlib/legal_vname.c:146
#, c-format
msgid "Output vector map <%s> is used as input"
msgstr "La couche vectorielle de sortie <%s> est utilisée en entrée"
@@ -1918,22 +1920,24 @@
msgid "%d new boundaries"
msgstr "%d nouveaux contours"
-#: ../lib/vector/Vlib/build.c:31 ../lib/vector/Vlib/close.c:38
-#: ../lib/vector/Vlib/rewind.c:35 ../lib/vector/Vlib/read.c:30
-#: ../lib/vector/Vlib/open.c:40 ../lib/vector/Vlib/write.c:53
+#: ../lib/vector/Vlib/build.c:31
+#: ../lib/vector/Vlib/close.c:38
+#: ../lib/vector/Vlib/rewind.c:35
+#: ../lib/vector/Vlib/read.c:30
+#: ../lib/vector/Vlib/open.c:40
+#: ../lib/vector/Vlib/write.c:53
#: ../lib/vector/Vlib/write.c:59
msgid "Requested format is not compiled in this version"
msgstr "Le format demandé n'est pas compatible avec cette version"
#: ../lib/vector/Vlib/build.c:123
-#, fuzzy, c-format
+#, c-format
msgid "Building topology for vector map <%s>..."
-msgstr "Veuillez reconstruire la topologie pour la couche vectorielle <%s@%s>"
+msgstr "Construction de la topologie pour la crate vectorielle <%s>..."
#: ../lib/vector/Vlib/build.c:141
-#, fuzzy
msgid "Topology was built"
-msgstr "La topologie a bien été construite.\n"
+msgstr "La topologie a bien été construite"
#: ../lib/vector/Vlib/build.c:153
#, c-format
@@ -2051,10 +2055,11 @@
msgid "Map structure has been closed"
msgstr "La structure de carte a été fermée"
-#: ../lib/vector/Vlib/line.c:201 ../lib/vector/Vlib/line.c:233
+#: ../lib/vector/Vlib/line.c:201
+#: ../lib/vector/Vlib/line.c:233
#, fuzzy
msgid "Index out of range in"
-msgstr "Index de couche en dehors des limites"
+msgstr "Index hors des limites"
#: ../lib/vector/Vlib/line.c:529
msgid "Segment outside line, no segment created"
@@ -2065,17 +2070,18 @@
msgid "Unable to close vector <%s>"
msgstr "Impossible de fermer la carte vecteur <%s>"
-#: ../lib/vector/Vlib/read_nat.c:136 ../lib/vector/Vlib/geos.c:66
+#: ../lib/vector/Vlib/read_nat.c:136
+#: ../lib/vector/Vlib/geos.c:66
#: ../lib/vector/Vlib/geos.c:256
-#, fuzzy
msgid "Attempt to read dead line"
-msgstr "Tentative de lire la ligne d'arrivée [%d]"
+msgstr "Tentative de lecture d'une ligne morte"
#: ../lib/vector/Vlib/map.c:55
msgid "input vector map is not open"
msgstr "La carte vecteur en entrée n'est pas ouverte"
-#: ../lib/vector/Vlib/map.c:178 ../lib/vector/Vlib/map.c:314
+#: ../lib/vector/Vlib/map.c:178
+#: ../lib/vector/Vlib/map.c:314
#: ../lib/vector/Vlib/open.c:540
#, c-format
msgid "Vector map name is not SQL compliant"
@@ -2086,44 +2092,55 @@
msgid "Unable to find vector map <%s> in <%s>"
msgstr "Impossible de trouver la carte vecteur <%s> dans <%s>"
-#: ../lib/vector/Vlib/map.c:189 ../lib/vector/Vlib/map.c:318
+#: ../lib/vector/Vlib/map.c:189
+#: ../lib/vector/Vlib/map.c:318
#: ../lib/vector/Vlib/open.c:547
#, c-format
msgid "Vector map <%s> already exists and will be overwritten"
msgstr "La couche vectorielle <%s> existe déjà et va être écrasé"
-#: ../lib/vector/Vlib/map.c:193 ../lib/vector/Vlib/open.c:552
+#: ../lib/vector/Vlib/map.c:193
+#: ../lib/vector/Vlib/open.c:552
#, c-format
msgid "Unable to delete vector map <%s>"
msgstr "Impossible de supprimer la couche vectorielle <%s>"
-#: ../lib/vector/Vlib/map.c:213 ../lib/vector/Vlib/map.c:331
+#: ../lib/vector/Vlib/map.c:213
+#: ../lib/vector/Vlib/map.c:331
#, c-format
msgid "Unable to copy vector map <%s> to <%s>"
msgstr "Impossible de copier la couche vectorielle <%s> vers <%s>"
-#: ../lib/vector/Vlib/map.c:243 ../lib/vector/Vlib/map.c:364
-#: ../lib/vector/Vlib/map.c:470 ../lib/vector/Vlib/map.c:588
-#: ../lib/vector/Vlib/map.c:686 ../lib/vector/Vlib/net.c:179
-#: ../lib/vector/Vlib/net.c:350 ../lib/vector/Vlib/array.c:278
+#: ../lib/vector/Vlib/map.c:243
+#: ../lib/vector/Vlib/map.c:364
+#: ../lib/vector/Vlib/map.c:470
+#: ../lib/vector/Vlib/map.c:588
+#: ../lib/vector/Vlib/map.c:686
+#: ../lib/vector/Vlib/net.c:179
+#: ../lib/vector/Vlib/net.c:350
+#: ../lib/vector/Vlib/array.c:278
#: ../lib/rst/interp_float/vinput2d.c:79
#, c-format
msgid "Database connection not defined for layer %d"
msgstr "Connexion à la base de données indéfinie pour la couche %d"
-#: ../lib/vector/Vlib/map.c:260 ../lib/vector/Vlib/map.c:381
-#: ../lib/vector/Vlib/map.c:613 ../lib/vector/Vlib/map.c:720
+#: ../lib/vector/Vlib/map.c:260
+#: ../lib/vector/Vlib/map.c:381
+#: ../lib/vector/Vlib/map.c:613
+#: ../lib/vector/Vlib/map.c:720
#, c-format
msgid "Unable to copy table <%s>"
msgstr "Impossible de copier la table <%s>"
-#: ../lib/vector/Vlib/map.c:276 ../lib/vector/Vlib/map.c:410
+#: ../lib/vector/Vlib/map.c:276
+#: ../lib/vector/Vlib/map.c:410
#: ../lib/vector/Vlib/map.c:626
#, c-format
msgid "Unable to create index for table <%s>, key <%s>"
msgstr "Impossible de créer l'index de la table <%s>, clef <%s>"
-#: ../lib/vector/Vlib/map.c:395 ../lib/vector/Vlib/map.c:490
+#: ../lib/vector/Vlib/map.c:395
+#: ../lib/vector/Vlib/map.c:490
#, c-format
msgid "Unable to delete table <%s>"
msgstr "Impossible de supprimer la table <%s>"
@@ -2168,7 +2185,8 @@
msgid "Unable to remove directory '%s'"
msgstr "Impossible de supprimer le répertoire '%s'"
-#: ../lib/vector/Vlib/map.c:604 ../lib/vector/Vlib/map.c:705
+#: ../lib/vector/Vlib/map.c:604
+#: ../lib/vector/Vlib/map.c:705
#, c-format
msgid "Unable to add database link for vector map <%s>"
msgstr "Impossible de lier la base de données à la carte vectorielle <%s>"
@@ -2181,18 +2199,15 @@
msgid "conditions failed"
msgstr "Échec des conditions."
-#: ../lib/vector/Vlib/geos.c:53 ../lib/vector/Vlib/read.c:99
+#: ../lib/vector/Vlib/geos.c:53
+#: ../lib/vector/Vlib/read.c:99
msgid "vector map is not opened"
msgstr "La carte vecteur n'est pas ouverte"
#: ../lib/vector/Vlib/geos.c:56
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): l'id d'objet %d n'est pas raisonnable (nombre maxi "
-"d'objets dans la carte vecteur <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): l'id d'objet %d n'est pas raisonnable (nombre maxi d'objets dans la carte vecteur <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:61
msgid "only native format supported"
@@ -2206,48 +2221,40 @@
#: ../lib/vector/Vlib/geos.c:105
#, c-format
msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
+msgstr "Vect_read_area_geos() : impossible de lire l'île d'id %d de la surface d'id %d"
#: ../lib/vector/Vlib/geos.c:203
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read line offset %ld"
+msgstr "Impossible de lire le décalage de ligne %ld"
#: ../lib/vector/Vlib/geos.c:410
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to read points of nonexistent area id %d"
+msgstr "Tentative de lecture des points de la surface non existante d'id %d"
#: ../lib/vector/Vlib/geos.c:470
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read feature id %d"
+msgstr "Impossible de lire l'objet d'id %d"
#: ../lib/vector/Vlib/read.c:102
#, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): l'id d'objet %d n'est pas raisonnable (nombre maxi "
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): l'id d'objet %d n'est pas raisonnable (nombre maxi d'objets dans la carte vecteur <%s>: %d)"
#: ../lib/vector/Vlib/sindex.c:97
msgid "not implemented"
-msgstr ""
+msgstr "non implémenté"
#: ../lib/vector/Vlib/sindex.c:109
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete item %d from spatial index"
+msgstr "Impossible de supprimer l'élément d'id %d de l'index spatial"
#: ../lib/vector/Vlib/sindex.c:127
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topo level 2"
-msgstr ""
-"Impossible de construire l'index spatial à partir de la topologie, la carte "
-"vecteur n'est pas ouverte au niveau topo 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+msgstr "Impossible de construire l'index spatial à partir de la topologie, la carte vecteur n'est pas ouverte au niveau topo 2"
#: ../lib/vector/Vlib/sindex.c:168
msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
@@ -2266,29 +2273,28 @@
msgstr "BUG (Vect_build_sidx_from_topo) : l'île n'existe pas"
#: ../lib/vector/Vlib/build_ogr.c:272
-#, fuzzy, c-format
+#, c-format
msgid "Unable to calculate centroid for area %d"
-msgstr "Impossible de calculer le centroïde de l'entité surfacique %d"
+msgstr "Impossible de calculer le centroïde pour la surface %d"
-#: ../lib/vector/Vlib/build_ogr.c:309 ../lib/vector/Vlib/read_ogr.c:120
+#: ../lib/vector/Vlib/build_ogr.c:309
+#: ../lib/vector/Vlib/read_ogr.c:120
#: ../lib/vector/Vlib/read_ogr.c:306
-#, fuzzy, c-format
+#, c-format
msgid "OGR feature type %d not supported"
-msgstr "Le type d'objet OGR %d n'est pas géré"
+msgstr "Objet OGR de type %d non pris en charge"
#: ../lib/vector/Vlib/build_ogr.c:333
msgid "Partial build for OGR is not supported"
msgstr "La construction partielle pour OGR n'est pas prise en charge"
#: ../lib/vector/Vlib/build_ogr.c:342
-msgid ""
-"Random read is not supported by OGR for this layer, cannot build support"
+msgid "Random read is not supported by OGR for this layer, cannot build support"
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:349
-#, fuzzy
msgid "Feature: "
-msgstr "Type(s) d'entité(s)"
+msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:361
#, c-format
@@ -2296,17 +2302,14 @@
msgstr "L'objet %d sans géométrie a été ignoré"
#: ../lib/vector/Vlib/build_ogr.c:368
-#, fuzzy
msgid "OGR feature without ID ignored"
-msgstr "L'objet OGR sans ID a été ignoré"
+msgstr "Objet OGR sans ID ignoré"
#: ../lib/vector/Vlib/net.c:121
-#, fuzzy
msgid "Building graph..."
msgstr "Construction du graphique ..."
#: ../lib/vector/Vlib/net.c:163
-#, fuzzy
msgid "Unable to build network graph"
msgstr "Impossible de construire le graphe de réseau"
@@ -2318,58 +2321,46 @@
msgid "Arc field < 1"
msgstr "Arc < 1"
-#: ../lib/vector/Vlib/net.c:190 ../lib/vector/Vlib/net.c:207
+#: ../lib/vector/Vlib/net.c:190
+#: ../lib/vector/Vlib/net.c:207
#: ../lib/vector/Vlib/net.c:360
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s> not found in table <%s>"
-msgstr "Impossible de décrire la table <%s>"
+msgstr "Colonne <%s> non trouvée dans la table <%s>"
-#: ../lib/vector/Vlib/net.c:196 ../lib/vector/Vlib/net.c:213
+#: ../lib/vector/Vlib/net.c:196
+#: ../lib/vector/Vlib/net.c:213
#: ../lib/vector/Vlib/net.c:366
-#, fuzzy, c-format
+#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"Le type de colonne de la colonne z n'est pas supporté (doit être un entier "
-"ou un double)"
+msgstr "Type de données de la colonne <%s> non pris en charge (doit être numeric)"
#: ../lib/vector/Vlib/net.c:226
-#, fuzzy
msgid "Registering arcs..."
msgstr "Enregistrement des arcs ... "
#: ../lib/vector/Vlib/net.c:254
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"L'enregistrement de la base de données de la ligne %d (cat = %d, avant/"
-"toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, avant/toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
#: ../lib/vector/Vlib/net.c:273
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
-msgstr ""
-"L'enregistrement de la base de données de la ligne %d (cat = %d, direction "
-"arrière) introuvable (direction de la ligne sautée)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, direction arrière) introuvable (direction de la ligne sautée)"
#: ../lib/vector/Vlib/net.c:322
msgid "Cannot add network arc"
msgstr "Impossible d'ajouter un arc de réseau"
#: ../lib/vector/Vlib/net.c:346
-#, fuzzy
msgid "Setting node costs..."
-msgstr "Réglage des coûts du noeud..."
+msgstr "Réglage des coûts du noeud ..."
#: ../lib/vector/Vlib/net.c:402
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas "
-"été trouvé (coût fixé à 0)"
+msgstr "L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas été trouvé (coût fixé à 0)"
#: ../lib/vector/Vlib/net.c:429
#, fuzzy
@@ -2380,24 +2371,23 @@
msgid "Graph was built"
msgstr "Le graphique a été construit"
-#: ../lib/vector/Vlib/net.c:521 ../lib/vector/Vlib/graph.c:231
+#: ../lib/vector/Vlib/net.c:521
+#: ../lib/vector/Vlib/graph.c:231
#, c-format
msgid "dglShortestPath error: %s"
-msgstr ""
+msgstr "erreur de dglShortestPath : %s"
#: ../lib/vector/Vlib/net.c:602
msgid "Wrong line direction in Vect_net_get_line_cost()"
msgstr "Mauvaise ligne de direction dans Vect_net_get_line_cost()"
#: ../lib/vector/Vlib/build_nat.c:93
-#, fuzzy
msgid "Unable to add area (map closed, topo saved)"
-msgstr "Impossible d'ajouter la surface (couche fermée, topo sauvegardée)"
+msgstr "Impossible d'ajouter la surface (carte fermée, topologie sauvegardée)"
#: ../lib/vector/Vlib/build_nat.c:102
-#, fuzzy
msgid "Unable to add isle (map closed, topo saved)"
-msgstr "Impossible d'ajouter l'île (couche fermée; topo sauvegardée)"
+msgstr "Impossible d'ajouter l'île (carte fermée, topologie sauvegardée)"
#: ../lib/vector/Vlib/build_nat.c:112
msgid "Area of size = 0.0 ignored"
@@ -2408,109 +2398,93 @@
msgstr ""
#: ../lib/vector/Vlib/build_nat.c:516
-#, fuzzy
msgid "Registering primitives..."
-msgstr "Enregistrement des arcs ... "
+msgstr "Enregistrement des primitives ... "
#: ../lib/vector/Vlib/build_nat.c:525
-#, fuzzy
msgid "Unable to read vector map"
+msgstr "Impossible de lire la carte vectorielle"
#: ../lib/vector/Vlib/build_nat.c:569
-#, fuzzy, c-format
+#, c-format
msgid "%d primitives registered"
-msgstr "\r%d primitives enregistrées \n"
+msgstr "%d primitives enregistrées"
#: ../lib/vector/Vlib/build_nat.c:570
#, fuzzy, c-format
msgid "%d vertices registered"
+msgstr "%d sommets enregistrées"
#: ../lib/vector/Vlib/build_nat.c:581
-#, fuzzy
msgid "Building areas..."
-msgstr "Construction du graphique ..."
+msgstr "Construction des surfaces ..."
#: ../lib/vector/Vlib/build_nat.c:604
-#, fuzzy, c-format
+#, c-format
msgid "%d areas built"
-msgstr "Le graphique a été construit"
+msgstr "%d surfaces construites"
#: ../lib/vector/Vlib/build_nat.c:605
-#, fuzzy, c-format
+#, c-format
msgid "%d isles built"
+msgstr "%d îles construites"
#: ../lib/vector/Vlib/build_nat.c:614
-#, fuzzy
msgid "Attaching islands..."
-msgstr "Rattachement des îles : "
+msgstr "Attachement des îles ..."
#: ../lib/vector/Vlib/build_nat.c:629
-#, fuzzy
msgid "Attaching centroids..."
-msgstr "Rattachement des centroïdes : "
+msgstr "Attachement des centroïdes ..."
-#: ../lib/vector/Vlib/level_two.c:234 ../lib/vector/Vlib/level_two.c:259
-#: ../lib/vector/Vlib/level_two.c:283 ../lib/vector/Vlib/level_two.c:302
-#: ../lib/vector/Vlib/level_two.c:320 ../lib/vector/Vlib/level_two.c:339
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/level_two.c:234
+#: ../lib/vector/Vlib/level_two.c:259
+#: ../lib/vector/Vlib/level_two.c:283
+#: ../lib/vector/Vlib/level_two.c:302
+#: ../lib/vector/Vlib/level_two.c:320
+#: ../lib/vector/Vlib/level_two.c:339
+#, c-format
msgid "Vector map <%s> is not open on level >= 2"
-msgstr "La couche vectorielle <%s> n'a pas été trouvée"
+msgstr "La carte vectorielle <%s> n'ets pas ouverte au niveau >= 2"
#: ../lib/vector/Vlib/open_ogr.c:53
msgid "OGR format cannot be updated"
msgstr "Le format OGR ne peut pas être mis à jour"
#: ../lib/vector/Vlib/open_ogr.c:65
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open OGR data source '%s'"
+msgstr "Impossible d'ouvrir la source de données OGR '%s'"
#: ../lib/vector/Vlib/open_ogr.c:85
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open layer <%s>"
+msgstr "Impossible d'ouvrir la couche <%s>"
#: ../lib/vector/Vlib/open_ogr.c:129
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open fidx file for vector map <%s@%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier d'index de catégorie pour la couche "
-"vectorielle <%s@%s>"
+msgstr "Impossible d'ouvrir le fichier fidx pour la couche vectorielle <%s@%s>"
#: ../lib/vector/Vlib/open_ogr.c:147
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Le format d'index %d.%d n'est pas supporté par cette version. Essayez de reconstruire la topologie ou de mettre à jour GRASS."
#: ../lib/vector/Vlib/open_ogr.c:152
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Votre version de GRASS ne supporte pas complétement le format d'index %d.%d pour le vecteur. Reconstruisez la topologie ou faites une mise à jour de GRASS."
#: ../lib/vector/Vlib/open_nat.c:145
#, c-format
-msgid ""
-"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-"Le fichier de coordonnées de la carte vecteur <%s@%s> est plus long qu'il ne "
-"devrait être (excès de %ld bytes)"
+msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr "Le fichier de coordonnées de la carte vecteur <%s@%s> est plus long qu'il ne devrait être (excès de %ld bytes)"
#: ../lib/vector/Vlib/open_nat.c:149
#, c-format
-msgid ""
-"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
-msgstr ""
-"Le fichier de coordonnées de la carte vecteur <%s@%s> est plus court qu'il "
-"ne devrait être (excès de %ld bytes)"
+msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "Le fichier de coordonnées de la carte vecteur <%s@%s> est plus court qu'il ne devrait être (excès de %ld bytes)"
#: ../lib/vector/Vlib/open.c:100
#, c-format
@@ -2518,20 +2492,15 @@
msgstr "Le programmeur a demandé un open level inconnu %d"
#: ../lib/vector/Vlib/open.c:179
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Une couche vectorielle qui n'est pas dans le jeu de données courant ne peut "
-"pas être ouverte pour une mise à jour"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Une couche vectorielle qui n'est pas dans le jeu de données courant ne peut pas être ouverte pour une mise à jour"
-#: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
+#: ../lib/vector/Vlib/open.c:211
+#: ../lib/vector/Vlib/open.c:279
#: ../lib/vector/Vlib/open.c:299
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Impossible d'ouvrir la couche vectorielle <%s> au niveau topologique %d"
+#, c-format
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Impossible d'ouvrir la carte vectorielle <%s> au niveau %d. Essayez de reconstruire la topologie avec v.build."
#: ../lib/vector/Vlib/open.c:214
msgid "Unable to read head file"
@@ -2540,26 +2509,23 @@
#: ../lib/vector/Vlib/open.c:236
#, c-format
msgid "Unable to open topology file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open.c:262
#, c-format
msgid "Unable to open category index file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier des catégories d'index pour la couche "
-"vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier des catégories d'index pour la couche vectorielle <%s>"
-#: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/open.c:576
+#: ../lib/vector/Vlib/open.c:353
+#: ../lib/vector/Vlib/open.c:576
#, c-format
msgid "Unable to open history file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open.c:531
-#, fuzzy, c-format
+#, c-format
msgid "%s is not in the current mapset (%s)"
-msgstr "pas de fichier %s disponible dans le jeu de données actuel\n"
+msgstr "%s n'est pas dans le jeux de carte courant (%s)"
#: ../lib/vector/Vlib/open.c:566
#, c-format
@@ -2573,9 +2539,7 @@
#: ../lib/vector/Vlib/open.c:731
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"La taille du fichier 'coord' est différente de la valeur sauvegardée dans le "
-"fichier de topologie"
+msgstr "La taille du fichier 'coord' est différente de la valeur sauvegardée dans le fichier de topologie"
#: ../lib/vector/Vlib/open.c:742
#, c-format
@@ -2583,25 +2547,26 @@
#: ../lib/vector/Vlib/area.c:53
-#, fuzzy
msgid "Attempt to read points of nonexistent area"
+msgstr "Tentative de lire les points d'une surface non existante"
#: ../lib/vector/Vlib/area.c:125
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read line %d"
+msgstr "Impossible de lire la ligne %d"
-#: ../lib/vector/Vlib/area.c:164 ../lib/vector/Vlib/area.c:193
-#: ../lib/vector/Vlib/area.c:257 ../lib/vector/Vlib/area.c:286
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/area.c:164
+#: ../lib/vector/Vlib/area.c:193
+#: ../lib/vector/Vlib/area.c:257
+#: ../lib/vector/Vlib/area.c:286
+#, c-format
msgid "Attempt to read topo for dead area (%d)"
+msgstr "Tentative de lire la topologie d'une surface morte (%d)"
#: ../lib/vector/Vlib/area.c:313
-#, fuzzy, c-format
+#, c-format
msgid "Attempt to read topo for dead isle (%d)"
+msgstr "Tentative de lire la topologie d'une île morte (%d)"
#: ../lib/vector/Vlib/cats.c:47
msgid "Vect_new_cats_struct(): Out of memory"
@@ -2610,18 +2575,14 @@
#: ../lib/vector/Vlib/cats.c:131
#, c-format
msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-"Trop de catégories (%d), dans l'impossibilité de mettre en cat %d (couche %d)"
+msgstr "Trop de catégories (%d), dans l'impossibilité de mettre en cat %d (couche %d)"
#: ../lib/vector/Vlib/cats.c:410
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Impossible de convertir les catégories de caractères '%s' (de '%s') en "
-"intervalle de catégorie"
+msgstr "Impossible de convertir les catégories de caractères '%s' (de '%s') en intervalle de catégorie"
#: ../lib/vector/Vlib/graph.c:143
-#, fuzzy
msgid "Unable to add network arc"
@@ -2635,22 +2596,24 @@
#: ../lib/vector/Vlib/intersect.c:448
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Vect_segment_intersection() ERREUR (segments verticaux non colinéaires)"
+msgstr "Vect_segment_intersection() ERREUR (segments verticaux non colinéaires)"
-#: ../lib/vector/Vlib/intersect.c:1099 ../lib/vector/Vlib/intersect.c:1105
-#: ../lib/vector/Vlib/intersect.c:1107 ../lib/vector/Vlib/intersect.c:1155
-#: ../lib/vector/Vlib/intersect.c:1164 ../lib/vector/Vlib/intersect.c:1185
+#: ../lib/vector/Vlib/intersect.c:1099
+#: ../lib/vector/Vlib/intersect.c:1105
+#: ../lib/vector/Vlib/intersect.c:1107
+#: ../lib/vector/Vlib/intersect.c:1155
+#: ../lib/vector/Vlib/intersect.c:1164
+#: ../lib/vector/Vlib/intersect.c:1185
#: ../lib/vector/Vlib/intersect.c:1202
msgid "Error while adding point to array. Out of memory"
msgstr "Erreur lors de l'ajout du point au tableau. Dépassement de mémoire"
#: ../lib/vector/Vlib/buffer2.c:364
-#, fuzzy
msgid "Line is not looped"
-msgstr "Matrices non autorisées"
+msgstr "La ligne ne boucle pas"
-#: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
+#: ../lib/vector/Vlib/buffer2.c:598
+#: ../lib/vector/Vlib/buffer2.c:609
msgid "Next edge was visited but it is not the first one !!! breaking loop"
msgstr ""
@@ -2658,117 +2621,110 @@
msgid "side != 0 feature not implemented"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:899 ../lib/vector/Vlib/buffer2.c:946
+#: ../lib/vector/Vlib/buffer2.c:899
+#: ../lib/vector/Vlib/buffer2.c:946
msgid "zero area size"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:905 ../lib/vector/Vlib/buffer2.c:952
-#, fuzzy
+#: ../lib/vector/Vlib/buffer2.c:905
+#: ../lib/vector/Vlib/buffer2.c:952
msgid "Line was not closed"
+msgstr "La ligne n'était pas fermée"
-#: ../lib/vector/Vlib/buffer2.c:918 ../lib/vector/Vlib/buffer2.c:969
+#: ../lib/vector/Vlib/buffer2.c:918
+#: ../lib/vector/Vlib/buffer2.c:969
msgid "Vect_get_point_in_poly() failed"
-msgstr ""
+msgstr "Vect_get_point_in_poly() a échoué"
#: ../lib/vector/Vlib/array.c:99
#, c-format
msgid "%d errors in category string."
msgstr ""
-#: ../lib/vector/Vlib/array.c:145 ../lib/vector/Vlib/array.c:269
+#: ../lib/vector/Vlib/array.c:145
+#: ../lib/vector/Vlib/array.c:269
msgid "Mixed area and other type requested for vector array"
msgstr ""
-#: ../lib/vector/Vlib/array.c:155 ../lib/vector/Vlib/array.c:178
-#: ../lib/vector/Vlib/array.c:306 ../lib/vector/Vlib/array.c:339
+#: ../lib/vector/Vlib/array.c:155
+#: ../lib/vector/Vlib/array.c:178
+#: ../lib/vector/Vlib/array.c:306
+#: ../lib/vector/Vlib/array.c:339
msgid "Not enough space in vector array"
msgstr "Espace insuffisant dans le tableau vecteur"
#: ../lib/vector/Vlib/array.c:294
-#, fuzzy, c-format
+#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr "Impossible de créer l'index de la table <%s>, clef <%s>"
+msgstr "Impossible de sélectionner un enregistrement depuis la table <%s> (clef %s, où %s)"
-#: ../lib/vector/Vlib/write.c:27 ../lib/vector/Vlib/write.c:33
-#: ../lib/vector/Vlib/write.c:39 ../lib/vector/Vlib/write.c:46
-#, fuzzy
+#: ../lib/vector/Vlib/write.c:27
+#: ../lib/vector/Vlib/write.c:33
+#: ../lib/vector/Vlib/write.c:39
+#: ../lib/vector/Vlib/write.c:46
msgid "for this format/level not supported"
-msgstr "Vect_write_line() n'est pas supportée pour ce format/niveau"
+msgstr "non pris en charge pour ce format/niveau"
#: ../lib/vector/Vlib/write.c:135
-#, fuzzy
msgid "Unable to write feature, vector map is not opened"
msgstr "Impossible d'écrire la ligne, la couche n'est pas ouverte"
#: ../lib/vector/Vlib/write.c:148
-#, fuzzy
msgid "Unable to write feature (negative offset)"
msgstr "Impossible d'écrire la ligne (décalage négatif)"
#: ../lib/vector/Vlib/write.c:181
-#, fuzzy
msgid "Unable to rewrite feature, vector map is not opened"
-msgstr "Impossible de réécrire la ligne, la couche n'est pas ouverte"
+msgstr "Impossible de ré-écrire la ligne, la couche n'est pas ouverte"
#: ../lib/vector/Vlib/write.c:194
-#, fuzzy, c-format
+#, c-format
msgid "Unable to rewrite feature %d"
+msgstr "Impossible de ré-écrire la ligne %d"
#: ../lib/vector/Vlib/write.c:219
-#, fuzzy, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
+#, c-format
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossible de supprimer la ligne %d, la carte vectorielle <%s> n'est pas ouverte au niveau topologique"
#: ../lib/vector/Vlib/write.c:225
-#, fuzzy, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en mode "
-"'écriture'"
+#, c-format
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossible de supprimer la ligne %s, la carte vecotirelle <%s> n'est pas ouverte en mode « écriture »"
#: ../lib/vector/Vlib/write.c:239
-#, fuzzy, c-format
+#, c-format
msgid "Unable to delete feature %d from vector map <%s>"
-msgstr ""
+msgstr "Impossible de supprimer la ligne %d de la couche vectorielle <%s>"
#: ../lib/vector/Vlib/write.c:265
-#, fuzzy, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
+#, c-format
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossible de restaurer la ligne %d, la carte vectorielle <%s> n'est pas ouverte au niveau topologique"
#: ../lib/vector/Vlib/write.c:271
-#, fuzzy, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"'écriture'"
+#, c-format
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossible de restaurer la ligne %d, la carte vectorielle <%s> n'est pas ouverte en mode « écriture »"
#: ../lib/vector/Vlib/write.c:285
-#, fuzzy, c-format
+#, c-format
msgid "Unable to restore feature %d from vector map <%s>"
-msgstr ""
+msgstr "Impossible de restaurer la ligne %d de la couche vectorielle <%s>"
#: ../lib/vector/Vlib/break_lines.c:374
-#, fuzzy, c-format
+#, c-format
msgid "Intersections: %5d"
-msgstr "Autre projection"
+msgstr "Intersections : %5d"
#: ../lib/vector/Vlib/cindex.c:31
msgid "Category index is not up to date"
msgstr "L'indice de catégorie n'est pas à jour"
-#: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:125
-#: ../lib/vector/Vlib/cindex.c:143 ../lib/vector/Vlib/cindex.c:166
+#: ../lib/vector/Vlib/cindex.c:61
+#: ../lib/vector/Vlib/cindex.c:125
+#: ../lib/vector/Vlib/cindex.c:143
+#: ../lib/vector/Vlib/cindex.c:166
msgid "Invalid layer index (index >= number of layers)"
msgstr "Indice de couche invalide (indice >= nombre de couches)"
@@ -2797,47 +2753,40 @@
#: ../lib/vector/Vlib/cindex.c:511
#, c-format
msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr ""
+msgstr "Impossible d'ouvrir le fichier d'index de catégorie pour la couche vectorielle <%s@%s>"
#: ../lib/vector/Vlib/field.c:93
-#, fuzzy
msgid "Layer number must be 1 or greater"
-msgstr "Le champ doit être supérieur ou égal à 1."
+msgstr "Le numéro de couche doit être supérieur ou égal à 1"
#: ../lib/vector/Vlib/field.c:98
-#, fuzzy
msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr ""
-"Impossible d'ajouter un lien base de données, la couche n'est pas ouverte en "
-"ECRITURE."
+msgstr "Impossible d'ajouter un lien base de données, la carte n'est pas ouverte en mode ÉCRITURE"
#: ../lib/vector/Vlib/field.c:104
-#, fuzzy
msgid "Unable to add database link"
+msgstr "Impossible d'ajouter un lien base de données"
-#: ../lib/vector/Vlib/field.c:110 ../lib/vector/Vlib/field.c:155
-#, fuzzy
+#: ../lib/vector/Vlib/field.c:110
+#: ../lib/vector/Vlib/field.c:155
msgid "Unable to write database links"
-msgstr "Impossible d'ajouter des liens base de données."
+msgstr "Impossible d'écrire des liens base de données"
#: ../lib/vector/Vlib/field.c:223
-#, fuzzy, c-format
+#, c-format
msgid "Layer number %d or name <%s> already exists"
-msgstr "Le numéro de champ <%d> ou nom <%s> existe déjà"
+msgstr "La couche numéro %d ou de nom <%s> existe déjà"
#: ../lib/vector/Vlib/field.c:302
-#, fuzzy, c-format
+#, c-format
msgid ""
"Default driver / database set to:\n"
"driver: %s\n"
"database: %s"
msgstr ""
-"Pilote par défaut / base de données :\n"
-"Pilote : dbf\n"
-"base de données: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
+"Pilote / base de données par défaut définis à :\n"
+"pilote : %s\n"
+"base de données: %s"
#: ../lib/vector/Vlib/field.c:309
msgid "Default driver is not set"
@@ -2853,15 +2802,12 @@
msgstr "dblink demandé %d, nombre maximum du lien %d"
#: ../lib/vector/Vlib/field.c:512
-#, fuzzy
msgid "Unable to open OGR DBMI driver"
-msgstr "Impossible d'ouvrir le pilote (driver) OGR DBMI."
+msgstr "Impossible d'ouvrir le pilote OGR DBMI"
#: ../lib/vector/Vlib/field.c:551
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Tous les tests FID ont échoués. Ni 'FID' ni 'ogc_fid' ni 'ogr_fid' ni 'gid' ne sont disponibles dans la table OGR DB"
#: ../lib/vector/Vlib/field.c:606
#, c-format
@@ -2876,82 +2822,70 @@
#: ../lib/vector/Vlib/field.c:709
#, fuzzy, c-format
msgid "Unable to open vector database definition file '%s'"
-msgstr "impossible d'ouvrir le fichier de datums : %s"
+msgstr "impossible d'ouvrir le fichier de définition de base de données du vecteur '%s'"
#: ../lib/vector/Vlib/field.c:804
-#, fuzzy
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug : tentative de mise à jour d'une couche qui n'est pas dans le jeu de "
-"données (mapset) courant."
+msgstr "Bug : tentative de mise à jour d'une couche qui n'est pas dans le jeu de cartes courant"
#: ../lib/vector/Vlib/remove_areas.c:96
msgid "Area is composed of dead boundary"
msgstr "La surface comporte des contours morts"
#: ../lib/vector/Vlib/read_ogr.c:178
-#, fuzzy
msgid "OGR feature without ID"
-msgstr "L'objet OGR sans ID."
+msgstr "Objet OGR sans ID"
-#: ../lib/vector/Vlib/read_ogr.c:378 ../lib/vector/Vlib/read_ogr.c:386
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/read_ogr.c:378
+#: ../lib/vector/Vlib/read_ogr.c:386
+#, c-format
msgid "Unable to get feature geometry, FID %ld"
-msgstr "Impossible d'obtenir la géométrie caractéristique, FID [%Id]"
+msgstr "Impossible d'obtenir la géométrie de l'objet, FID %Id"
-#: ../lib/vector/Vlib/header.c:95 ../lib/vector/Vlib/header.c:143
+#: ../lib/vector/Vlib/header.c:95
+#: ../lib/vector/Vlib/header.c:143
#, fuzzy, c-format
msgid "Unable to open header file of vector <%s>"
-msgstr ""
#: ../lib/vector/Vlib/header.c:151
#, c-format
msgid "Corrupted row in head: %s"
-msgstr ""
+msgstr "Ligne corrompue dans l'en-tête : %s"
#: ../lib/vector/Vlib/header.c:189
-#, fuzzy, c-format
+#, c-format
msgid "Unknown keyword %s in vector head"
-msgstr "Type vectoriel inconnu."
+msgstr "Mot-clef %s inconnu dans l'en-tête du vecteur"
-#: ../lib/vector/Vlib/header.c:512 ../lib/gis/proj3.c:64
+#: ../lib/vector/Vlib/header.c:512
+#: ../lib/gis/proj3.c:64
msgid "Unknown projection"
msgstr "Projection inconnue"
#: ../lib/vector/vedit/cats.c:63
#, fuzzy, c-format
msgid "Unable to set category %d for (feature id %d)"
-msgstr ""
-"vectorielle <%s>"
#: ../lib/vector/vedit/select.c:232
-#, fuzzy
msgid "Unknown query tool"
-msgstr "Erreur inconnue"
+msgstr "Outil de recherche inconnu"
#: ../lib/rst/interp_float/segmen2d.c:111
#, fuzzy
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"la recherche de points pour l'interpolation prend trop de temps -- veuillez "
-"changer la régionpour la zone où se trouvent vos points. Les calculs se "
-"poursuivent..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "la recherche de points pour l'interpolation prend trop de temps -- veuillez changer la régionpour la zone où se trouvent vos points. Les calculs se poursuivent..."
#: ../lib/rst/interp_float/interp2d.c:212
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
msgstr ""
#: ../lib/rst/interp_float/input2d.c:47
-#, fuzzy, c-format
+#, c-format
msgid "Mask raster map <%s> not found"
-msgstr "la couche matricielle demandée <%s> n'a pas été trouvée"
+msgstr "Masque de carte raster <%s> non trouvé"
#: ../lib/rst/interp_float/input2d.c:69
msgid "Bitmap mask created"
@@ -2960,30 +2894,29 @@
#: ../lib/rst/interp_float/output2d.c:125
#, c-format
msgid "First change your cols number to nsizc %d %d"
-msgstr ""
+msgstr "Commencez par changer le nombre de colonnes vers nsizc %d %d"
#: ../lib/rst/interp_float/vinput2d.c:73
-#, fuzzy, c-format
+#, c-format
msgid "Vector map <%s> is not 3D"
+msgstr "La carte vectorielle <%s> n'est pas 3D"
#: ../lib/rst/interp_float/vinput2d.c:76
msgid "Loading data from attribute table ..."
msgstr "Chargement des données de la table attributaire..."
#: ../lib/rst/interp_float/vinput2d.c:94
-#: ../lib/rst/interp_float/vinput2d.c:108 ../lib/db/dbmi_client/copy_tab.c:248
-#, fuzzy, c-format
+#: ../lib/rst/interp_float/vinput2d.c:108
+#: ../lib/db/dbmi_client/copy_tab.c:248
+#, c-format
msgid "Column <%s> not found"
+msgstr "Colonne <%s> non trouvée"
#: ../lib/rst/interp_float/vinput2d.c:97
#: ../lib/rst/interp_float/vinput2d.c:110
-#, fuzzy, c-format
+#, c-format
msgid "Data type of column <%s> must be numeric"
-msgstr ""
-"ou un double)"
+msgstr "Le type des données de la colonne <%s> doit être numeric"
#: ../lib/rst/interp_float/vinput2d.c:121
#, fuzzy
@@ -2998,13 +2931,13 @@
#: ../lib/rst/interp_float/vinput2d.c:171
#: ../lib/rst/interp_float/vinput2d.c:288
+#, fuzzy
msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr ""
+msgstr "Valeur négative détectée pour le smoothing : sm doit être >= 0"
#: ../lib/rst/interp_float/vinput2d.c:233
-#, fuzzy
msgid "Reading nodes from vector map ..."
-msgstr "Lignes de lecture de la carte vectorielle..."
+msgstr "Lecture des noeuds depuis la carte vectorielle ..."
#: ../lib/rst/interp_float/vinput2d.c:314
#, fuzzy
@@ -3014,73 +2947,59 @@
#: ../lib/rst/interp_float/vinput2d.c:328
#, fuzzy, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"il y a des points en-dehors de la région 2D/3D spécifiée -- %d points ignorés"
+msgstr "il y a des points en-dehors de la région 2D/3D spécifiée -- %d points ignorés"
#: ../lib/rst/interp_float/vinput2d.c:331
-#, fuzzy, c-format
+#, c-format
msgid "Ignoring %d points (too dense)"
-msgstr "%d points ignorés -- trop dense"
+msgstr "%d points ignorés (trop dense)"
#: ../lib/rst/interp_float/vinput2d.c:335
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"%d points donnés pour l'interpolation (après squelettisation) est moins que "
-"le NPMIN=% donnéd"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d points donnés pour l'interpolation (après squelettisation) est moins que le NPMIN=% donnéd"
#: ../lib/rst/interp_float/vinput2d.c:340
msgid "Zero points in the given region"
msgstr "Zéro point dans la région donnée"
#: ../lib/rst/interp_float/vinput2d.c:345
-#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
+#, fuzzy, c-format
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Paramètres de segmentation invalides : npmin= %d, segmax= %d pour une bonne connexion des segmetns, npmin > segmax (voir le manuel)"
#: ../lib/rst/interp_float/vinput2d.c:351
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Il y a moins de %d poitns pour l'interpolation. Aucune segmentation n'est "
-"nécessaire, pour faire tourner le programme plus vite, paramétrez segmax=%d "
-"(voir manuel)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Il y a moins de %d poitns pour l'interpolation. Aucune segmentation n'est nécessaire, pour faire tourner le programme plus vite, paramétrez segmax=%d (voir manuel)"
#: ../lib/rst/interp_float/vinput2d.c:355
-#, fuzzy, c-format
+#, c-format
msgid "Number of points from vector map %d"
-msgstr "Nom de la couche vectorielle en entrée"
+msgstr "Nombre de points de la carte vecteur %d"
#: ../lib/rst/interp_float/vinput2d.c:356
-#, fuzzy, c-format
+#, c-format
msgid "Number of points outside of 2D/3D region %d"
-msgstr "Nombre de contours en dehors de la surface : %d\n"
+msgstr "Nombre de points en dehors de la surface 2D/3D %d"
#: ../lib/rst/interp_float/vinput2d.c:358
-#, fuzzy, c-format
+#, c-format
msgid "Number of points being used %d"
-msgstr "Nombre de points : %d\n"
+msgstr "Nombre de points utilisés %d"
#: ../lib/rst/interp_float/vinput2d.c:391
-#, fuzzy
msgid "Some points outside of region (ignored)"
-msgstr "certains points sont en dehors de la région -- ignorés..."
+msgstr "Certains points sont en dehors de la région (ignorés)"
#: ../lib/rst/interp_float/vinput2d.c:397
-#, fuzzy
msgid "Unable to allocate memory"
-msgstr "Allocation mémoire impossible\n"
+msgstr "Allocation mémoire impossible"
#: ../lib/rst/interp_float/vinput2d.c:405
-#, fuzzy, c-format
+#, c-format
msgid "Unable to insert %f,%f,%f a = %d"
+msgstr "Impossible d'insérer %f,%f,%f a = %d"
#: ../lib/gis/range.c:192
#, c-format
@@ -3092,7 +3011,8 @@
msgid "can't read range file for [%s in %s]"
msgstr "impossible de lire le fichier de limites pour [%s dans %s]"
-#: ../lib/gis/range.c:359 ../lib/gis/range.c:412
+#: ../lib/gis/range.c:359
+#: ../lib/gis/range.c:412
#, c-format
msgid "can't write range file for [%s in %s]"
msgstr "impossible d'écrire le fichier de limites pour [%s dans %s]"
@@ -3235,7 +3155,8 @@
msgid "Unable to open file %s in <%s>"
msgstr "Impossible d'ouvrir le fichier %s dans %s"
-#: ../lib/gis/get_ellipse.c:358 ../lib/gis/get_ellipse.c:384
+#: ../lib/gis/get_ellipse.c:358
+#: ../lib/gis/get_ellipse.c:384
#, fuzzy, c-format
msgid "Invalid a: field '%s' in file %s in <%s>"
msgstr "a invalide : champ %s dans le fichier %s de %s"
@@ -3262,15 +3183,11 @@
#: ../lib/gis/history.c:263
msgid "Not enough room in history file to record command line."
-msgstr ""
-"Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne "
-"de commande"
+msgstr "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne de commande"
#: ../lib/gis/history.c:285
msgid "Not enough room in history file for command line (truncated)."
-msgstr ""
-"de commande (tronquée)"
+msgstr "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne de commande (tronquée)"
#: ../lib/gis/put_title.c:29
#, c-format
@@ -3295,8 +3212,7 @@
#: ../lib/gis/put_title.c:72
#, c-format
msgid "can't write category information for [%s] in [%s]"
-msgstr ""
-"impossible d'écrire les informations de la catégorie pour [%s] dans [%s]"
+msgstr "impossible d'écrire les informations de la catégorie pour [%s] dans [%s]"
#: ../lib/gis/legal_name.c:39
#, c-format
@@ -3308,17 +3224,17 @@
msgid "Illegal filename. Character <%c> not allowed.\n"
msgstr "Nom de fichier illégal. Caractère <%c> interdit.\n"
-#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#: ../lib/gis/legal_name.c:77
+#: ../lib/gis/legal_name.c:81
#, fuzzy, c-format
msgid "Output raster map name <%s> is not valid map name"
-msgstr ""
-#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
-#, fuzzy, c-format
+#: ../lib/gis/legal_name.c:118
+#: ../lib/gis/legal_name.c:122
+#, c-format
msgid "Output raster map <%s> is used as input"
-msgstr "La couche vectorielle de sortie <%s> est utilisée en entrée"
+msgstr "La carte raster de sortie <%s> est utilisée en entrée"
#: ../lib/gis/system.c:85
msgid "Can not create a new process!"
@@ -3334,27 +3250,28 @@
msgstr "GISRC - variable sans valeur"
#: ../lib/gis/env.c:274
-#, fuzzy, c-format
+#, c-format
msgid "G_getenv(): Variable %s not set"
-msgstr "GISRC - variable sans valeur"
+msgstr "G_getenv() : variable %s non définie"
#: ../lib/gis/env.c:300
#, c-format
msgid "%s not set"
msgstr "%s n'a pas de valeur"
-#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
+#: ../lib/gis/gisinit.c:54
+#: ../lib/gis/gisinit.c:90
+#, fuzzy
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Version de librairie incompatible pour le module. Vous devez reconstruire GRASS ou gérer les versions multiples."
#: ../lib/gis/gisinit.c:63
#, c-format
msgid "MAPSET %s - permission denied"
msgstr "Jeu de données (MAPSET) %s - permission refusée"
-#: ../lib/gis/gisinit.c:66 ../lib/gis/mapset.c:57
+#: ../lib/gis/gisinit.c:66
+#: ../lib/gis/mapset.c:57
#, c-format
msgid "MAPSET %s not found"
msgstr "Jeu de données (MAPSET) %s n'a pas été trouvé"
@@ -3362,17 +3279,15 @@
#: ../lib/gis/gisinit.c:110
#, fuzzy
msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"\aERREUR : Le système n'est pas initialisé. Le développeur a oublié "
-"d'appeler G_gisinit()\n"
+msgstr "\aERREUR : Le système n'est pas initialisé. Le développeur a oublié d'appeler G_gisinit()\n"
#: ../lib/gis/color_read.c:116
#, c-format
msgid "color support for [%s] in mapset [%s] %s"
-msgstr ""
-"support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
+msgstr "support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
-#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
+#: ../lib/gis/seek.c:52
+#: ../lib/gis/seek.c:58
#, fuzzy
msgid "Unable to seek"
msgstr "Impossible d'ouvrir %s"
@@ -3387,80 +3302,85 @@
msgstr "Impossible d'ouvrir le masque (MASK) automatique du fichier"
#: ../lib/gis/gdal.c:66
-#, fuzzy, c-format
+#, c-format
msgid "Unable to locate symbol <%s>"
-msgstr "Impossible de supprimer la table <%s>"
+msgstr "Impossible de localiser le symbole <%s>"
#: ../lib/gis/gdal.c:114
-#, fuzzy
msgid "Unable to load GDAL library"
+msgstr "Impossible de charger la librairie GDAL"
-#: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:199
+#: ../lib/gis/adj_cellhd.c:47
+#: ../lib/gis/adj_cellhd.c:199
msgid "Illegal n-s resolution value"
msgstr "Valeur de résolution n-s illégale"
-#: ../lib/gis/adj_cellhd.c:51 ../lib/gis/adj_cellhd.c:205
+#: ../lib/gis/adj_cellhd.c:51
+#: ../lib/gis/adj_cellhd.c:205
msgid "Illegal row value"
msgstr "Valeur de ligne illégale"
-#: ../lib/gis/adj_cellhd.c:55 ../lib/gis/adj_cellhd.c:211
+#: ../lib/gis/adj_cellhd.c:55
+#: ../lib/gis/adj_cellhd.c:211
msgid "Illegal e-w resolution value"
msgstr "Valeur de résolution e-o illégale"
-#: ../lib/gis/adj_cellhd.c:59 ../lib/gis/adj_cellhd.c:217
+#: ../lib/gis/adj_cellhd.c:59
+#: ../lib/gis/adj_cellhd.c:217
msgid "Illegal col value"
msgstr "Valeur de colonne illégale"
-#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
+#: ../lib/gis/adj_cellhd.c:79
+#: ../lib/gis/adj_cellhd.c:247
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-"Ajustement d'une légère erreur d'arrondi sur la valeur de la limite Nord (%g>"
-"%g)"
+msgstr "Ajustement d'une légère erreur d'arrondi sur la valeur de la limite Nord (%g>%g)"
-#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
+#: ../lib/gis/adj_cellhd.c:84
+#: ../lib/gis/adj_cellhd.c:252
msgid "Illegal latitude for North"
msgstr "Latitude illégale pour Nord"
-#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
+#: ../lib/gis/adj_cellhd.c:90
+#: ../lib/gis/adj_cellhd.c:258
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"justement d'une légère erreur d'arrondi sur la valeur de la limite Sud (%g>"
-"%g)"
+msgstr "justement d'une légère erreur d'arrondi sur la valeur de la limite Sud (%g>%g)"
-#: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
+#: ../lib/gis/adj_cellhd.c:95
+#: ../lib/gis/adj_cellhd.c:263
msgid "Illegal latitude for South"
msgstr "Latitude illégale pour Sud"
-#: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
+#: ../lib/gis/adj_cellhd.c:107
+#: ../lib/gis/adj_cellhd.c:275
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-"Erreur dans les méthodes de fixation des données d'entrée à la frontière "
-"Ouest (%g>%g)"
+msgstr "Erreur dans les méthodes de fixation des données d'entrée à la frontière Ouest (%g>%g)"
-#: ../lib/gis/adj_cellhd.c:118 ../lib/gis/adj_cellhd.c:286
+#: ../lib/gis/adj_cellhd.c:118
+#: ../lib/gis/adj_cellhd.c:286
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-"Erreur dans les méthodes de fixation des données d'entrée à la frontière Est "
-"(%g>%g)"
+msgstr "Erreur dans les méthodes de fixation des données d'entrée à la frontière Est (%g>%g)"
-#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
+#: ../lib/gis/adj_cellhd.c:131
+#: ../lib/gis/adj_cellhd.c:299
msgid "North must be north of South"
msgstr "Le Nord doit être au nord du Sud"
-#: ../lib/gis/adj_cellhd.c:133 ../lib/gis/adj_cellhd.c:301
+#: ../lib/gis/adj_cellhd.c:133
+#: ../lib/gis/adj_cellhd.c:301
msgid "North must be larger than South"
msgstr "Le Nord doit être plus grand que le Sud"
-#: ../lib/gis/adj_cellhd.c:136 ../lib/gis/adj_cellhd.c:304
+#: ../lib/gis/adj_cellhd.c:136
+#: ../lib/gis/adj_cellhd.c:304
msgid "East must be larger than West"
msgstr "L'Est doit être plus grand que l'Ouest"
-#: ../lib/gis/adj_cellhd.c:155 ../lib/gis/adj_cellhd.c:348
+#: ../lib/gis/adj_cellhd.c:155
+#: ../lib/gis/adj_cellhd.c:348
msgid "Invalid coordinates"
msgstr "Coordonnées invalides"
@@ -3517,14 +3437,14 @@
#: ../lib/gis/color_rules.c:151
-#, fuzzy, c-format
+#, c-format
msgid "bad rule (%s): [%s]"
-msgstr "mauvais état (%s) : %s"
+msgstr "mauvaise règle (%s) : [%s]"
#: ../lib/gis/color_rules.c:265
-#, fuzzy, c-format
+#, c-format
msgid "Unable to load color rules <%s>"
-msgstr "Impossible d'ouvrir la couche vectorielle <%s>"
+msgstr "Impossible de charger les règles de couleurs <%s>"
#: ../lib/gis/error.c:257
msgid "WARNING: "
@@ -3544,7 +3464,8 @@
msgid "Unable to access mapset element %s (%s): %s"
msgstr "ne peut pas fabriquer l'élément %s (%s) du jeu de données (mapset)"
-#: ../lib/gis/get_ell_name.c:31 ../lib/gis/get_projname.c:38
+#: ../lib/gis/get_ell_name.c:31
+#: ../lib/gis/get_projname.c:38
#: ../lib/gis/get_datum_name.c:69
msgid "Cannot open temp file"
msgstr "Impossible d'ouvrir le fichier temporaire"
@@ -3605,15 +3526,16 @@
msgstr "Nom du groupe d'image en entrée"
#: ../lib/gis/parser.c:404
-#, fuzzy
msgid "Name of input imagery subgroup"
-#: ../lib/gis/parser.c:414 ../lib/gis/parser.c:439
+#: ../lib/gis/parser.c:414
+#: ../lib/gis/parser.c:439
msgid "Name of input raster map"
msgstr "Nom de la couche matricielle d'entrée"
-#: ../lib/gis/parser.c:423 ../lib/gis/parser.c:448
+#: ../lib/gis/parser.c:423
+#: ../lib/gis/parser.c:448
msgid "Name of input raster map(s)"
msgstr "Nom de(s) couche(s) matricielle(s) en entrée"
@@ -3637,11 +3559,13 @@
msgid "Name of elevation raster map(s)"
msgstr "Nom de(s) couche(s) matricielle(s) d'élévation"
-#: ../lib/gis/parser.c:491 ../lib/gis/parser.c:516
+#: ../lib/gis/parser.c:491
+#: ../lib/gis/parser.c:516
msgid "Name of input raster3d map"
msgstr "Nom de la couche matricielle 3D en entrée"
-#: ../lib/gis/parser.c:500 ../lib/gis/parser.c:525
+#: ../lib/gis/parser.c:500
+#: ../lib/gis/parser.c:525
msgid "Name of input raster3d map(s)"
msgstr "Nom de(s) couche(s) matricielle(s) 3D en sortie"
@@ -3649,11 +3573,13 @@
msgid "Name for output raster3d map"
msgstr "Nom de la couche matricielle 3D en sortie"
-#: ../lib/gis/parser.c:535 ../lib/gis/parser.c:560
+#: ../lib/gis/parser.c:535
+#: ../lib/gis/parser.c:560
msgid "Name of input vector map"
-#: ../lib/gis/parser.c:544 ../lib/gis/parser.c:569
+#: ../lib/gis/parser.c:544
+#: ../lib/gis/parser.c:569
msgid "Name of input vector map(s)"
msgstr "Nom de(s) couche(s) vectorielle(s) en entrée"
@@ -3661,7 +3587,8 @@
msgid "Name for output vector map"
msgstr "Nom de la couche vectorielle en sortie"
-#: ../lib/gis/parser.c:578 ../lib/gis/parser.c:587
+#: ../lib/gis/parser.c:578
+#: ../lib/gis/parser.c:587
#, fuzzy
msgid "Feature type"
@@ -3671,12 +3598,8 @@
msgstr "Numéro de la couche"
#: ../lib/gis/parser.c:596
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"Une seule carte vectorielle peut être connectée à plusieurs tables de base "
-"de données. Ce nombre détermine la table à utiliser."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Une seule carte vectorielle peut être connectée à plusieurs tables de base de données. Ce nombre détermine la table à utiliser."
#: ../lib/gis/parser.c:605
msgid "Category value"
@@ -3686,7 +3609,8 @@
msgid "Category values"
msgstr "Valeurs de catégorie"
-#: ../lib/gis/parser.c:613 ../lib/gis/parser.c:627
+#: ../lib/gis/parser.c:613
+#: ../lib/gis/parser.c:627
msgid "Example: 1,3,7-9,13"
msgstr "Exemple : 1,3,7-9,13"
@@ -3701,12 +3625,10 @@
#: ../lib/gis/parser.c:637
-#, fuzzy
msgid "Name of input file"
msgstr "Nom du fichier en entrée"
#: ../lib/gis/parser.c:645
-#, fuzzy
msgid "Name for output file"
msgstr "Nom du fichier en sortie"
@@ -3716,7 +3638,7 @@
#: ../lib/gis/parser.c:654
msgid "Special characters: newline, space, comma, tab"
-msgstr ""
+msgstr "Caractères spéciaux : nouvelle ligne, espace, virgule, tabulation"
#: ../lib/gis/parser.c:665
msgid "Color"
@@ -3741,15 +3663,11 @@
#: ../lib/gis/parser.c:926
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --verbose "
-"supposé."
+msgstr "Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --verbose supposé."
#: ../lib/gis/parser.c:940
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --quiet "
-"supposé."
+msgstr "Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --quiet supposé."
#: ../lib/gis/parser.c:971
#, c-format
@@ -3794,16 +3712,22 @@
"\n"
"Drapeaux :\n"
-#: ../lib/gis/parser.c:1177 ../lib/gis/parser.c:1501 ../lib/gis/parser.c:1661
+#: ../lib/gis/parser.c:1177
+#: ../lib/gis/parser.c:1501
+#: ../lib/gis/parser.c:1661
#: ../lib/gis/parser.c:1949
msgid "Allow output files to overwrite existing files"
msgstr "Autoriser les fichiers de sortie à écraser les fichiers existants"
-#: ../lib/gis/parser.c:1179 ../lib/gis/parser.c:1509 ../lib/gis/parser.c:1665
+#: ../lib/gis/parser.c:1179
+#: ../lib/gis/parser.c:1509
+#: ../lib/gis/parser.c:1665
msgid "Verbose module output"
msgstr "Module de sortie en mode bavard"
-#: ../lib/gis/parser.c:1180 ../lib/gis/parser.c:1516 ../lib/gis/parser.c:1668
+#: ../lib/gis/parser.c:1180
+#: ../lib/gis/parser.c:1516
+#: ../lib/gis/parser.c:1668
msgid "Quiet module output"
msgstr "Moduel de sortie en mode silence"
@@ -3862,21 +3786,20 @@
msgstr "Exécuter en silence"
#: ../lib/gis/parser.c:1994
-#, fuzzy
msgid "Unable to spawn the 'wish' program"
-msgstr "Impossible d'ouvrir %s"
+msgstr ""
#: ../lib/gis/parser.c:2013
-#, fuzzy
msgid "Unable to determine program name"
-msgstr "impossible d'obtenir le répertoire de l'utilisateur"
+msgstr "impossible de déterminer le nom du programme"
#: ../lib/gis/parser.c:2070
#, c-format
msgid " %*s options: "
msgstr " %*s options : "
-#: ../lib/gis/parser.c:2115 ../lib/gis/parser.c:2130
+#: ../lib/gis/parser.c:2115
+#: ../lib/gis/parser.c:2130
#, c-format
msgid "Sorry, <%c> is not a valid flag\n"
msgstr "Désolé, <%c> n'est pas un drapeau valide\n"
@@ -3934,14 +3857,13 @@
"ERREUR : Valeur manquante pour le paramètre <%s>\n"
#: ../lib/gis/parser.c:2445
-#, fuzzy, c-format
+#, c-format
msgid ""
"ERROR: Required parameter <%s> not set:\n"
"\t(%s)\n"
msgstr ""
-"\n"
-"ERREUR : Le paramètre obligatoire <%s> n'a pas de valeur :\n"
-" (%s).\n"
+"ERREUR : Le paramètre obligatoire <%s> n'est pas définit :\n"
+"\t(%s)\n"
#: ../lib/gis/parser.c:2540
#, c-format
@@ -4015,7 +3937,8 @@
msgid "enter option > "
msgstr "entrez une option > "
-#: ../lib/gis/parser.c:2707 ../lib/gis/parser.c:2717
+#: ../lib/gis/parser.c:2707
+#: ../lib/gis/parser.c:2717
msgid " Try again? "
msgstr " Essayer à nouveau? "
@@ -4079,12 +4002,8 @@
"projection invalide\n"
#: ../lib/gis/set_window.c:76
-msgid ""
-"G_set_window(): projection/zone differs from that of currently open raster "
-"maps"
-msgstr ""
-"G_set_window() : projection/zone diffèrent de ceux présents dans le fichier "
-"matriciel actuellement ouvert"
+msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window() : projection/zone diffèrent de ceux présents dans le fichier matriciel actuellement ouvert"
#: ../lib/gis/home.c:39
msgid "unable to determine user's home directory"
@@ -4127,30 +4046,22 @@
#: ../lib/gis/timestamp.c:282
#, c-format
msgid "Can't create timestamp file for %s map %s in mapset %s"
-msgstr ""
-"Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la "
-"couche %s %s dans le jeu de données (mapset) %s"
+msgstr "Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/gis/timestamp.c:291
#, c-format
msgid "Invalid timestamp specified for %s map %s in mapset %s"
-msgstr ""
-"L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est "
-"invalide dans le jeu de données (mapset) %s"
+msgstr "L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est invalide dans le jeu de données (mapset) %s"
#: ../lib/gis/timestamp.c:313
#, c-format
msgid "Can't open timestamp file for %s map %s in mapset %s"
-msgstr ""
-"Impossible d'ouvrir le fichier d'étiquettes date&heure (timestamp) pour la "
+msgstr "Impossible d'ouvrir le fichier d'étiquettes date&heure (timestamp) pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/gis/timestamp.c:322
#, c-format
msgid "Invalid timestamp file for %s map %s in mapset %s"
-msgstr ""
-"Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s "
-"dans le jeu de données (mapset) %s"
+msgstr "Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/gis/reclass.c:145
#, c-format
@@ -4160,9 +4071,7 @@
#: ../lib/gis/reclass.c:148
#, c-format
msgid "Illegal reclass format in header file for [%s in %s]"
-msgstr ""
-"Format de reclassification illégal dans l'en-tête de fichier pour [%s dans "
-"%s]"
+msgstr "Format de reclassification illégal dans l'en-tête de fichier pour [%s dans %s]"
#: ../lib/gis/reclass.c:238
msgid "Illegal reclass request"
@@ -4182,12 +4091,11 @@
msgid "Unable to create dependency file in [%s in %s]"
msgstr "Impossible de créer le fichier de dépendances dans [%s dans %s]"
-#: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
+#: ../lib/gis/get_row.c:46
+#: ../lib/gis/get_row.c:1049
#, fuzzy, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"[%s de %s] - la demande de lecture pour la ligne %d est en dehors de la "
-"région"
+msgstr "[%s de %s] - la demande de lecture pour la ligne %d est en dehors de la région"
#: ../lib/gis/get_row.c:324
#, c-format
@@ -4195,26 +4103,25 @@
msgstr "cell_values_float : xdr_float échec de l'indice %d"
#: ../lib/gis/get_row.c:365
-#, fuzzy, c-format
+#, c-format
msgid "cell_values_double: xdr_double failed for index %d"
-msgstr "cell_values_double : échec de xdr_double pour l'index %d"
+msgstr "cell_values_double : xdr_double a échoué pour l'index %d"
#: ../lib/gis/get_row.c:621
-#, fuzzy, c-format
+#, c-format
msgid "Error reading compressed map <%s@%s>, row %d"
-msgstr ""
-"erreur en lisant la couche compressée [%s] dans le jeu de données [%s], "
-"ligne %d"
+msgstr "Erreur de lecture de la carte compressée <%s@%s>, ligne %d"
#: ../lib/gis/get_row.c:624
-#, fuzzy, c-format
+#, c-format
msgid "Error reading map <%s@%s>, row %d"
-msgstr "erreur en lisant la couche [%s] dans le jeu de données [%s], ligne %d"
+msgstr "Erreur de lecture de la carte <%s@%s>, ligne %d"
-#: ../lib/gis/get_row.c:1031 ../lib/gis/get_row.c:1036
-#, fuzzy, c-format
+#: ../lib/gis/get_row.c:1031
+#: ../lib/gis/get_row.c:1036
+#, c-format
msgid "Error reading null row %d"
-msgstr "erreur en lisant la ligne nulle %d"
+msgstr "Erreur de lecture de la ligne nulle %d"
#: ../lib/gis/get_row.c:1115
#, fuzzy
@@ -4234,12 +4141,12 @@
#: ../lib/gis/open.c:62
#, c-format
msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
+msgstr "G__open(read): mapset <%s> ne correspond pas à xmapset <%s>"
#: ../lib/gis/open.c:84
#, c-format
msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
+msgstr "G__open(write): xmapset <%s> != G_mapset() <%s>"
#: ../lib/gis/null_val.c:91
msgid "EmbedGivenNulls: wrong data type!"
@@ -4263,28 +4170,31 @@
#: ../lib/gis/unix_socks.c:102
msgid "Unable to get GIS_LOCK environment variable value"
-msgstr ""
+msgstr "Impossible d'obtenir la variable d'environnement GIS_LOCK"
#: ../lib/gis/spawn.c:385
#, c-format
msgid "CreateProcess() failed: error = %d"
-msgstr ""
+msgstr "CreateProcess() a échoué : erreur = %d"
#: ../lib/gis/spawn.c:416
#, fuzzy, c-format
msgid "G_spawn: unable to redirect descriptor %d"
msgstr "G_spawn : impossible de dupliquer le descripteur %d vers %d"
-#: ../lib/gis/spawn.c:424 ../lib/gis/spawn.c:609
+#: ../lib/gis/spawn.c:424
+#: ../lib/gis/spawn.c:609
#, c-format
msgid "G_spawn: unable to open file %s"
msgstr "G_spawn : impossible d'ouvrir le fichier %s"
-#: ../lib/gis/spawn.c:493 ../lib/gis/spawn.c:679
+#: ../lib/gis/spawn.c:493
+#: ../lib/gis/spawn.c:679
msgid "Unable to execute command"
msgstr "Impossible d'exécuter la commande"
-#: ../lib/gis/spawn.c:518 ../lib/gis/spawn.c:526
+#: ../lib/gis/spawn.c:518
+#: ../lib/gis/spawn.c:526
#, c-format
msgid "G_spawn: unable to restore signal %d"
msgstr "G_spawn : impossible de restaurer le signal %d"
@@ -4309,7 +4219,8 @@
msgid "G_spawn: unable to unblock signal %d"
msgstr "G_spawn : impossible de débloquer le signal %d"
-#: ../lib/gis/spawn.c:614 ../lib/gis/spawn.c:623
+#: ../lib/gis/spawn.c:614
+#: ../lib/gis/spawn.c:623
#, c-format
msgid "G_spawn: unable to duplicate descriptor %d to %d"
@@ -4326,8 +4237,7 @@
#: ../lib/gis/put_row.c:215
#, c-format
msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-msgstr ""
-"G_put_map_row : %s n'est pas un entier! Utiliser G_put_[f/d]_raster_row() !"
+msgstr "G_put_map_row : %s n'est pas un entier! Utiliser G_put_[f/d]_raster_row() !"
#: ../lib/gis/put_row.c:251
#, c-format
@@ -4342,8 +4252,7 @@
#: ../lib/gis/put_row.c:266
#, c-format
msgid "%s: map [%s] not open for sequential write - request ignored"
-msgstr ""
-"%s : couche [%s] non ouverte en écriture séquentielle - demande ignorée"
+msgstr "%s : couche [%s] non ouverte en écriture séquentielle - demande ignorée"
#: ../lib/gis/put_row.c:270
#, c-format
@@ -4370,7 +4279,8 @@
msgid "unable to find a temporary null file %s"
msgstr "impossible de trouver un fichier temporaire null %s"
-#: ../lib/gis/put_row.c:776 ../lib/gis/put_row.c:781
+#: ../lib/gis/put_row.c:776
+#: ../lib/gis/put_row.c:781
#, c-format
msgid "error writing null row %d"
msgstr "erreur lors de l'écriture d'une ligne nulle %d"
@@ -4378,8 +4288,7 @@
#: ../lib/gis/quant_rw.c:206
#, c-format
msgid "Cannot write quant rules: map %s is integer"
-msgstr ""
-"Impossible d'écrire les règles de quantité : la couche %s est un entier"
+msgstr "Impossible d'écrire les règles de quantité : la couche %s est un entier"
#: ../lib/gis/quant_rw.c:215
#, c-format
@@ -4394,9 +4303,7 @@
#: ../lib/gis/cats.c:417
#, c-format
msgid "category support for vector map [%s] in mapset [%s] %s"
-msgstr ""
-"support de la catégorie pour le fichier vecteur [%s] dans le jeu de données "
-"(mapset) [%s] %s"
+msgstr "support de la catégorie pour le fichier vecteur [%s] dans le jeu de données (mapset) [%s] %s"
#: ../lib/gis/ask.c:341
msgid "to cancel request"
@@ -4442,7 +4349,9 @@
msgid "Hit RETURN %s\n"
msgstr "Pressez RETOUR %s\n"
-#: ../lib/gis/ask.c:452 ../lib/gis/ask.c:557 ../lib/gis/ask.c:577
+#: ../lib/gis/ask.c:452
+#: ../lib/gis/ask.c:557
+#: ../lib/gis/ask.c:577
#, c-format
msgid ""
"\n"
@@ -4451,7 +4360,8 @@
"\n"
"** %s - introuvable **\n"
-#: ../lib/gis/ask.c:459 ../lib/gis/ask.c:544
+#: ../lib/gis/ask.c:459
+#: ../lib/gis/ask.c:544
#, c-format
msgid ""
"\n"
@@ -4508,8 +4418,7 @@
#: ../lib/gis/get_datum_name.c:57
#, c-format
msgid "or 'custom' if you wish to enter custom parameters\n"
-msgstr ""
-"ou 'personnalisé' si vous souhaitez entrer des paramètres personnalisés\n"
+msgstr "ou 'personnalisé' si vous souhaitez entrer des paramètres personnalisés\n"
#: ../lib/gis/get_datum_name.c:97
#, c-format
@@ -4521,128 +4430,109 @@
"datum invalide\n"
#: ../lib/gis/opencell.c:105
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open raster map <%s@%s>"
-msgstr "impossible d'ouvrir la couche raster |%s dans %s]"
+msgstr "Impossible d'ouvrir la carte raster <%s@%s>"
#: ../lib/gis/opencell.c:171
-#, fuzzy, c-format
+#, c-format
msgid "Unable to find <%s@%s>"
-msgstr "[%s] introuvable"
+msgstr "Impossible de trouver <%s@%s>"
#: ../lib/gis/opencell.c:188
-#, fuzzy, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"impossible d'ouvrir [%s] dans [%s] puisqu'il s'agit d'une reclassification "
-"de [%s] dans [%s] qui n'existe pas"
+#, c-format
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Impossible d'ouvrir la carte raster <%s@%s> car il s'agit d'une reclassification de la carte raster <%s@%s> qui n'existe pas"
#: ../lib/gis/opencell.c:212
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
-"[%s] dans le jeu de données (mapset) [%s]-le champ de format dans le fichier "
-"d'en-tête est invalide"
+msgstr "Carte raster <%s@%s> : format de champ invalide dans le fichier d'en-tête"
#: ../lib/gis/opencell.c:219
-#, fuzzy, c-format
-msgid ""
-"Raster map <%s@%s> is in different projection than current region. Found "
-"raster map <%s@%s>, should be <%s>."
-msgstr ""
-"[%s] dans le jeu de données (mapset) [%s] - est dans une projection "
-"différente par rapport à la région courante :\n"
-" la couche [%s] dans: <%s>, devrait être <%s> "
+#, c-format
+msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+msgstr "Carte raster <%s@%s> dans une projection différente de la région courante. La carte raster <%s@%s>, devrait être <%s>."
#: ../lib/gis/opencell.c:226
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"[%s] dans le jeu de données (mapset) [%s] - est dans une zone différente "
-"[%d] de celle de la région courante [%d]"
+msgstr "Carte raster <%s@%s> est dans une zone différentes (%d) de la région courante (%d)"
#: ../lib/gis/opencell.c:233
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
-msgstr "[%s] dans [%s] - octets par cellule (%d) trop grand"
+msgstr "Carte raster <%s@%s> : octets par cellule (%d) trop grands"
#: ../lib/gis/opencell.c:262
#, c-format
msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
+msgstr "la carte <%s@%s> est un lien GDAL mais GRASS est compilé sans le support GDAL"
#: ../lib/gis/opencell.c:642
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr ""
+msgstr "La carte raster <%s> n'est pas dans le jeux de carte courant (%s)"
#: ../lib/gis/opencell.c:649
-#, fuzzy, c-format
+#, c-format
msgid "<%s> is an illegal file name"
-msgstr "opensell : %s - nom de fichier illégal"
+msgstr "<%s> est un nom de fichier illégal"
#: ../lib/gis/opencell.c:655
-#, fuzzy, c-format
+#, c-format
msgid "<%s>: bad mapset"
-msgstr "<%s> dans le jeu de données (mapset) <%s>"
+msgstr "<%s> : mauvais jeu de données"
-#: ../lib/gis/opencell.c:666 ../lib/gis/opencell.c:767
+#: ../lib/gis/opencell.c:666
+#: ../lib/gis/opencell.c:767
msgid "G__open_raster_new(): no temp files available"
-msgstr ""
+msgstr "G__open_raster_new() : pas de fichiers temporaires disponibles"
#: ../lib/gis/opencell.c:736
-#, fuzzy
-msgid ""
-"Unable to write embedded null values for raster map open for random access"
-msgstr ""
-"Impossible d'écrire les valeurs nulles intégrées pour une couche ouverte en "
-"accès aléatoire"
+msgid "Unable to write embedded null values for raster map open for random access"
+msgstr "Impossible d'écrire les valeurs nulles intégrées pour une carte raster ouverte en accès aléatoire"
#: ../lib/gis/opencell.c:941
msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
+msgstr "G_set_fp_type() : ne peut être appellé que pour des FCELL_TYPE ou des DCELL_TYPE"
-#: ../lib/gis/opencell.c:976 ../lib/gis/opencell.c:1064
-#, fuzzy, c-format
+#: ../lib/gis/opencell.c:976
+#: ../lib/gis/opencell.c:1064
+#, c-format
msgid "Unable to find '%s' in '%s'"
-msgstr "impossible de trouver [%s] dans [%s]"
+msgstr "Ompossible de trouver '%s' dans '%s'"
#: ../lib/gis/opencell.c:1009
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> not found in mapset <%s>"
+msgstr "Carte raster <%s> non trouvée dans le jeux de données <%s>"
#: ../lib/gis/opencell.c:1070
-#, fuzzy, c-format
+#, c-format
msgid "Unable to find '%s'"
+msgstr "Impossible de trouve '%s'"
#: ../lib/gis/opencell.c:1075
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open '%s'"
+msgstr "Impossible d'ouvrir '%s'"
#: ../lib/gis/opencell.c:1085
-#, fuzzy, c-format
+#, c-format
msgid "Invalid type: field '%s' in file '%s'"
-msgstr "type invalide : champ %s dans le fichier %s"
+msgstr "type invalide : champ '%s' dans le fichier '%s'"
#: ../lib/gis/opencell.c:1099
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> is not xdr: byte_order: %s"
-msgstr "Le vecteur d'entrée '%s' n'a pas été trouvé"
+msgstr "La carte raster <%s> n'est pas xdr : byte_order : %s"
#: ../lib/gis/opencell.c:1179
-msgid ""
-"G_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
+msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr "G_set_quant_rules() ne peut être appellé que pour des cartes raster ouvertes en lecture"
#: ../lib/gis/sample.c:71
-#, fuzzy
msgid "Unknown interpolation type"
msgstr "Type d'interpolation inconnu"
@@ -4651,9 +4541,8 @@
msgstr "étiquette \"no data\" trouvée, réglé à zéro"
#: ../lib/gis/sample.c:299
-#, fuzzy
msgid "Problem reading raster map"
-msgstr "Problème de lecture du fichier de cellules raster"
+msgstr "Problème de lecture de la carte raster"
#: ../lib/gis/location.c:44
#, c-format
@@ -4705,35 +4594,37 @@
msgid "Unable to create header file for [%s]"
msgstr "Impossible de créer le fichier d'en-tête pour [%s]"
-#: ../lib/gis/alloc.c:42 ../lib/gis/alloc.c:82 ../lib/gis/alloc.c:125
-#, fuzzy, c-format
+#: ../lib/gis/alloc.c:42
+#: ../lib/gis/alloc.c:82
+#: ../lib/gis/alloc.c:125
+#, c-format
msgid "Current region rows: %d, cols: %d"
-msgstr "Ligne vide courante en mémoire %d"
+msgstr "Région actuelle %d lignes, %d colonnes"
#: ../lib/gis/alloc.c:45
#, c-format
msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
+msgstr "G_malloc : impossible d'allouer %lu octets de mémoire à %s:%d"
#: ../lib/gis/alloc.c:85
#, c-format
msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
-msgstr ""
+msgstr "G_calloc : impossible d'allouer %lu octets de mémoire à %s:%d"
#: ../lib/gis/alloc.c:128
#, c-format
msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
+msgstr "G_realloc : impossible d'allouer %lu octets de mémoire à %s:%d"
#: ../lib/gis/open_misc.c:45
#, c-format
msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
+msgstr "G__open_misc(read) : mapset <%s> ne correspond pas à xmapset <%s>"
#: ../lib/gis/open_misc.c:67
#, c-format
msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
+msgstr "G__open_misc(write) : xmapset <%s> != G_mapset() <%s>"
#: ../lib/gis/quant_io.c:89
#, c-format
@@ -4750,7 +4641,8 @@
msgid "quantization file [%s] in mapset [%s] %s"
msgstr "fichier de quantification [%s] dans le jeu de données (mapset) [%s] %s"
-#: ../lib/gis/get_window.c:67 ../lib/gis/get_window.c:85
+#: ../lib/gis/get_window.c:67
+#: ../lib/gis/get_window.c:85
#, c-format
msgid ""
"region for current mapset %s\n"
@@ -4777,12 +4669,14 @@
"est invalide\n"
"%s"
-#: ../lib/gis/get_projinfo.c:33 ../lib/gis/get_projinfo.c:60
+#: ../lib/gis/get_projinfo.c:33
+#: ../lib/gis/get_projinfo.c:60
#, c-format
msgid "<%s> file not found for location <%s>"
msgstr "fichier <%s> introuvable pour le secteur <%s>"
-#: ../lib/gis/get_projinfo.c:39 ../lib/gis/get_projinfo.c:66
+#: ../lib/gis/get_projinfo.c:39
+#: ../lib/gis/get_projinfo.c:66
#, c-format
msgid "ERROR in reading <%s> file for location <%s>"
msgstr "ERREUR en lisant le fichier <%s> du secteur <%s>"
@@ -4801,8 +4695,7 @@
msgstr ""
"\n"
"\n"
-"La table des couleurs est nécessaire pour le fichier |%s] dans le jeu de "
-"données (mapset) [%s].\n"
+"La table des couleurs est nécessaire pour le fichier |%s] dans le jeu de données (mapset) [%s].\n"
#: ../lib/gis/make_colr.c:52
#, c-format
@@ -4872,50 +4765,49 @@
msgid "%s complete. %s"
msgstr "%s terminé. %s"
-#: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
-#, fuzzy, c-format
+#: ../lib/gis/get_cellhd.c:71
+#: ../lib/gis/get_cellhd.c:100
+#, c-format
msgid "Unable to read header file for raster map <%s@%s>."
-msgstr "Impossible de créer l'en-tête de fichier pour [%s dans %s]"
+msgstr "Impossible de lire le fichier d'en-tête de la carte raster <%s@%s>."
#: ../lib/gis/get_cellhd.c:74
-#, fuzzy, c-format
+#, c-format
msgid " It is a reclass of raster map <%s@%s> "
-msgstr "C'est une reclassification de [%s dans %s]"
+msgstr " C'est une reclassification de la carte raster <%s@%s> "
#: ../lib/gis/get_cellhd.c:78
-#, fuzzy, c-format
+#, c-format
msgid "which is missing."
-msgstr "qui est manquant"
+msgstr "qui est manquant."
#: ../lib/gis/get_cellhd.c:80
-#, fuzzy, c-format
+#, c-format
msgid "whose header file can't be opened."
-msgstr "dont le fichier d'en-tête ne peut être ouvert"
+msgstr "dont le fichier d'en-tête ne peut être ouvert."
#: ../lib/gis/get_cellhd.c:88
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open header file for raster map <%s@%s>"
-msgstr ""
+msgstr "Impossible d'ouvrir le fichier d'en-tête de la carte raster <%s@%s>"
#: ../lib/gis/get_cellhd.c:105
-#, fuzzy, c-format
+#, c-format
msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr ""
-"C'est une reclassification de [%s dans %s] dont l'en-tête est invalide\n"
+msgstr " C'est une reclassification de la carte raster <%s@%s> dont l'en-tête est invalide."
#: ../lib/gis/get_cellhd.c:109
-#, fuzzy, c-format
+#, c-format
msgid " Invalid format."
-msgstr "Format invalide\n"
+msgstr "Format invalide."
#: ../lib/gis/view.c:177
#, c-format
msgid "Unable to open %s for writing"
msgstr "Impossible d'ouvrir %s en écriture"
-#: ../lib/gis/view.c:263 ../lib/gis/view.c:480
+#: ../lib/gis/view.c:263
+#: ../lib/gis/view.c:480
#, c-format
msgid "Unable to open %s for reading"
msgstr "Impossible d'ouvrir %s en lecture"
@@ -4928,19 +4820,16 @@
#: ../lib/gis/view.c:546
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-"La fenêtre sauvegardée dans \"%s\" est complètement en dehors de la fenêtre "
-"GRASS courante."
+msgstr "La fenêtre sauvegardée dans \"%s\" est complètement en dehors de la fenêtre GRASS courante."
#: ../lib/gis/view.c:550
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la "
-"fenêtre GRASS courante."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la fenêtre GRASS courante."
-#: ../lib/gis/ask_cell.c:54 ../lib/gis/ask_cell.c:72 ../lib/gis/ask_cell.c:91
+#: ../lib/gis/ask_cell.c:54
+#: ../lib/gis/ask_cell.c:72
+#: ../lib/gis/ask_cell.c:91
#: ../lib/gis/ask_cell.c:96
msgid "with titles"
msgstr "avec les titres"
@@ -4959,7 +4848,8 @@
msgid "Can't read histogram for [%s in %s]"
msgstr "Impossible de lire l'histogramme pour [%s dans %s]"
-#: ../lib/gis/histogram.c:74 ../lib/gis/histogram.c:84
+#: ../lib/gis/histogram.c:74
+#: ../lib/gis/histogram.c:84
#, c-format
msgid "Invalid histogram file for [%s in %s]"
msgstr "fichier d'histogramme invalide pour [%s dans %s]"
@@ -4981,9 +4871,7 @@
#: ../lib/gis/closecell.c:250
#, c-format
msgid "Error writing floating point format file for map %s"
-msgstr ""
-"Erreur lors de l'écriture en virgule flottante dans le fichier au format de "
-"la couche %s"
+msgstr "Erreur lors de l'écriture en virgule flottante dans le fichier au format de la couche %s"
#: ../lib/gis/closecell.c:300
#, c-format
@@ -5000,8 +4888,7 @@
#: ../lib/gis/closecell.c:406
msgid "unable to write f_format file for CELL maps"
-msgstr ""
-"pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
+msgstr "pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
#: ../lib/gis/mapset.c:39
msgid "MAPSET is not set"
@@ -5009,9 +4896,7 @@
#: ../lib/gis/distance.c:160
#, c-format
-msgid ""
-"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,"
-"%f)(%f,%f)"
+msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
msgstr ""
#: ../lib/gis/debug.c:74
@@ -5022,87 +4907,89 @@
#: ../lib/gis/find_file.c:74
#, c-format
msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
+msgstr "'%s/%s' trouvé dans plusieurs jeux de cartes (également trouvé dans <%s>)"
#: ../lib/gis/find_file.c:82
-#, fuzzy, c-format
+#, c-format
msgid "Using <%s@%s>"
+msgstr "Utilisation de <%s@%s>"
#: ../lib/db/dbmi_client/delete_tab.c:44
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open driver <%s>"
-msgstr "Impossible d'ouvrir le fichier %s"
+msgstr "Impossible d'ouvrir le pilote <%s>"
#: ../lib/db/dbmi_client/delete_tab.c:62
-#, fuzzy, c-format
+#, c-format
msgid "Unable to drop table: '%s'"
-msgstr "Impossible de copier la table <%s>"
+msgstr "Impossible de dupprimer la table : '%s'"
-#: ../lib/db/dbmi_client/db.c:41 ../lib/db/dbmi_client/copy_tab.c:100
+#: ../lib/db/dbmi_client/db.c:41
+#: ../lib/db/dbmi_client/copy_tab.c:100
#: ../lib/db/dbmi_client/copy_tab.c:120
-#, fuzzy, c-format
+#, c-format
msgid "Unable to start driver <%s>"
-msgstr "Impossible d'ouvrir le fichier statistique <%s>"
+msgstr "Impossible de démarrer le pilote <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:144
-#, fuzzy, c-format
+#, c-format
msgid "Unable to get list tables in database <%s>"
+msgstr "Impossible d'obtenir la liste des tables dans la base de données <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:157
-#, fuzzy, c-format
+#, c-format
msgid "Table <%s> already exists in database <%s>"
-msgstr "impossible d'ouvrir le fichier de l'ellipsoïde: %s"
+msgstr "La table <%s> existe déjà dans la base de données <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:231
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s> is not integer"
-msgstr "Impossible d'ouvrir la base de données %s"
+msgstr "La colonne <%s> n'est pas de type entier"
#: ../lib/db/dbmi_client/copy_tab.c:251
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create table <%s>"
+msgstr "Impossible de créer la table <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:295
-#, fuzzy, c-format
+#, c-format
msgid "Unable to fetch data from table <%s>"
+msgstr "Impossible de récupérer les données depuis la table <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:351
-#, fuzzy, c-format
+#, c-format
msgid "Unknown column type (column <%s>)"
-msgstr "Impossible de lire le type de colonne de la colonne de lissage"
+msgstr "Type de colonne inconnu (colonne <%s>)"
#: ../lib/db/dbmi_client/column.c:114
-#, fuzzy, c-format
+#, c-format
msgid "Unable to describe table <%s>"
+msgstr "Impossible de décrire la table <%s>"
#: ../lib/db/dbmi_client/table.c:46
-#, fuzzy, c-format
+#, c-format
msgid "Unable open database <%s> by driver <%s>"
msgstr "Impossible d'ouvrir la base de données <%s> avec le driver <%s>"
-#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
+#: ../lib/db/dbmi_client/select.c:119
+#: ../lib/db/dbmi_client/select.c:221
#: ../lib/db/dbmi_client/select.c:288
msgid "Missing column name"
msgstr "Nom de colonne manquant"
-#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
+#: ../lib/db/dbmi_client/select.c:216
+#: ../lib/db/dbmi_client/select.c:283
msgid "Missing key column name"
msgstr "Nom de colonne clé manquant"
#: ../lib/db/dbmi_client/select.c:317
-#, fuzzy, c-format
+#, c-format
msgid "Unable select records from table <%s>"
+msgstr "Impossible de sélectionner les enregistrements depuis la table <%s>"
#: ../lib/db/dbmi_client/select.c:333
-#, fuzzy
msgid "Key column type is not integer"
+msgstr "La colonne clef n'est pas de type entier"
#: ../lib/db/dbmi_base/login.c:98
msgid "Login file corrupted"
@@ -5121,451 +5008,9 @@
#: ../lib/db/dbmi_base/legal_dbname.c:43
#, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr ""
-"Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
+msgstr "Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
#: ../lib/db/dbmi_base/default_name.c:127
-#, fuzzy
msgid "Programmer error"
-msgstr "Probablement erreur de programmation."
+msgstr "Erreur de programmation"
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "La couche g3d demandée <%s> n'a pas été trouvée"
-#, fuzzy
-#~ msgid "Unable to feature %d from vector map <%s>"
-#~ msgstr "Impossible de créer la couche vectorielle <%s>"
-#~ msgid "Vector is not 3D"
-#~ msgstr "Le vecteur n'est pas 3D"
-#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr ""
-#~ "Impossible de trouver la colonne z <%s> (veuillez vérifier le nom, par "
-#~ "exemple avec v.info)"
-#~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Le type de colonne de la colonne z n'est pas supporté (doit être un "
-#~ "entier ou un double)"
-#~ msgid "Cannot read column type of smooth column"
-#~ msgstr "Impossible de lire le type de colonne de la colonne de lissage"
-#~ msgid "Column type of smooth column (datetime) is not supported"
-#~ msgstr ""
-#~ "Le type de colonne de la colonne de lissage (date temps) n'est pas géré"
-#~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Le type de la colonne s n'est pas supporté (doit être entier ou double)"
-#~ msgid "Unknown Location"
-#~ msgstr "Secteur (Location) inconnu"
-#~ msgid "Too many arguments"
-#~ msgstr "Trop d'arguments"
-#, fuzzy
-#~ msgid "Unable to delete layer/category %d/%d line %d"
-#~ msgstr "Impossible de supprimer la couche vectorielle <%s>"
-#~ msgid "Registering points"
-#~ msgstr "Enregistrement des points"
-#~ msgid "Registered points"
-#~ msgstr "Points enregistrés"
-#, fuzzy
-#~ msgid "Registered points (unique coordinates)"
-#, fuzzy
-#~ msgid "Duplicates"
-#~ msgstr "multiples occurrences du champ Est"
-#~ msgid "Type"
-#~ msgstr "Type"
-#~ msgid "G_malloc: out of memory"
-#~ msgstr "G_malloc : dépassement de mémoire"
-#~ msgid "G_calloc: out of memory"
-#~ msgstr "G_calloc : allocation mémoire impossible"
-#~ msgid "G_realloc: out of memory"
-#~ msgstr "G_realloc : dépassement de mémoire"
-#~ msgid "Cannot get layer info"
-#~ msgstr "Impossible de récupérer les infos de la couche"
-#~ msgid "Cannot open database %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Impossible de décrire la table <%s>"
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "Impossible de lire la topologie pour la ligne [%d]"
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr ""
-#~ "Le nom de sortie '%s' n'est pas un nom de couche matricielle valide."
-#~ msgid "Cannot find input map '%s'"
-#~ msgstr "Impossible de trouver la couche d'entrée '%s'"
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "La couche de sortie '%s' est utilisée en entrée"
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "impossible d'ouvrir la couche raster |%s dans %s]"
-#~ msgid "unable to find [%s] in [%s]"
-#~ msgstr "impossible de trouver [%s] dans [%s]"
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "Impossible de lire l'en-tête de fichier pour [%s dans %s]\n"
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "Impossible d'ouvrir le fichier d'en-tête pour [%s dans %s]"
-#~ msgid "Cannot get field info"
-#~ msgstr "Impossible d'obtenir les informations du champ"
-#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgid "Building topology ...\n"
-#~ msgstr "Construction de la topologie ...\n"
-#~ msgid ""
-#~ "\r%d areas built \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r%d surfaces construites \n"
-#~ "%d îles construites\n"
-#~ msgid "Cannot get column info"
-#~ msgstr "Impossible d'obtenir les informations de la colonne"
-#~ msgid "OGR feature type [%d] not supported"
-#~ msgstr "Le type d'objet OGR [%d] n'est pas supporté"
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "Vect_rewrite_line() n'est pas supportée pour ce format/niveau"
-#~ msgid "Vect_delete_line() for this format/level not supported"
-#~ msgstr "Vect_delete_line() n'est pas supportée pour ce format/niveau"
-#~ msgid "Cannot rewrite line"
-#~ msgstr "Impossible de réécrire la ligne"
-#~ msgid "Cannot delete line"
-#~ msgstr "Impossible de supprimer la ligne"
-#~ msgid "Output name '%s' is not valid vector name."
-#~ msgstr "Le nom de sortie '%s' n'est pas un nom de vecteur valide."
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "Impossible de copier le vecteur '%s' vers '%s'"
-#, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "Impossible de supprimer le vecteur %s"
-#, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "Impossible d'ouvrir le nouveau vecteur %s"
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
-#~ msgid "Could not stat file '%s'"
-#~ msgstr "Impossible d'obtenir des informations sur le fichier '%s'"
-#, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "Impossible d'ouvrir l'ancien vecteur %s"
-#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** nom illégal **"
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "Aucun moniteur graphique correspondant à <%s>.\n"
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr ""
-#~ "Veuillez lancer \"d.mon\" pour sélectionner un moniteur graphique "
-#~ "valide.\n"
-#~ msgid "Can't stat %s\n"
-#~ msgstr "Impossible d'obtenir des informations sur %s\n"
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "Erreur - Le moniteur <%s> est en cours d'utilisation.\n"
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr "Erreur - Le moniteur <%s> est utilisé par %s.\n"
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "Erreur - Impossible de bloquer le moniteur <%s>.\n"
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "Erreur - Impossible de créer un tube vers la sortie graphique.\n"
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "Erreur - Le moniteur graphique <%s> n'est pas lancé!\n"
-#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "Veuillez démarrer le moniteur graphique <%s>.\n"
-#~ msgid "Not connected...\n"
-#~ msgstr "Aucune connexion...\n"
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr ""
-#~ "Impossible de se connecter au moniteur. Nous allons essayer encore une "
-#~ "fois.\n"
-#~ msgid "G_dump: memory allocated to G__"
-#~ msgstr "G_dump: mémoire allouée à G__"
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr ""
-#~ "Taille de cellule dans les couches en nombres en virgule flottante = %d"
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr ""
-#~ "type d'écriture pour les couches en nombres en virgule flottante = %d"
-#~ msgid "current window = %p"
-#~ msgstr "fenêtre courante = %p"
-#~ msgid "Flag: window set? %d"
-#~ msgstr "Drapeau: fenêtre définie? %d"
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "Descripteur de fichier pour le masque automatique %d"
-#~ msgid "Flag denoting automatic masking %d"
-#~ msgstr "Drapeau signifiant un masquage automatique %d"
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "Tampon du masque de CELLULE %p"
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "tampon pour lire les lignes nulles %p"
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "Tampon pour les données compressées pre/post %p"
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "sizeof compressed_buf %d"
-#~ msgid "work data buffer %p"
-#~ msgstr "tampon des données de travail %p"
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "sizeof work_buf %d"
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "sizeof null_buf %d"
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "sizeof mask_buf %d"
-#~ msgid "Histogram request %d"
-#~ msgstr "Demande de construction d'un histogramme %d"
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump: fichier #%d"
-#~ msgid "open mode = %d"
-#~ msgstr "mode d'ouverture = %d"
-#~ msgid "Cell header %p"
-#~ msgstr "En-tête de cellule %p"
-#~ msgid "Table reclass %p"
-#~ msgstr "Tableau de reclassification %p"
-#~ msgid "Cell stats %p"
-#~ msgstr "Statistiques de cellule %p"
-#~ msgid "Range structure %p"
-#~ msgstr "Structure de l'intervalle %p"
-#~ msgid "float Range structure %p"
-#~ msgstr "structure de l'intervalle en nombres en virgule flottante %p"
-#~ msgid "want histogram? %d"
-#~ msgstr "un histogramme?..%d"
-#~ msgid "Automatic reclass flag %d"
-#~ msgstr "Drapeau de reclassification automatique %d"
-#~ msgid "File row addresses %p"
-#~ msgstr "Adresses de la ligne du fichier %p"
-#~ msgid "Data to window col mapping %p"
-#~ msgstr "Donnée du tracé de la colonne dans la fenêtre %p"
-#~ msgid "Data to window row constants %f,%f"
-#~ msgstr "Données des constantes de lignes dans la fenêtre %f,%f"
-#~ msgid "Current data row in memory %d"
-#~ msgstr "Lignes de données actuellement en mémoire %d"
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "Nombre d'octets par cellule pour la ligne courante %d"
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr "Tampon de données décompressées %s"
-#~ msgid "bytes per cell %d"
-#~ msgstr "octets par cellule %d"
-#~ msgid "type: int, float or double map %d"
-#~ msgstr ""
-#~ "type: entier(int), nombre en virgule flottante (float) ou double couche %d"
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "Nom temporaire pour les NOUVEAUX fichiers %s"
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "Nom temporaire pour les NOUVEAUX fichier %s NULS"
-#~ msgid "Mapset of open file %s"
-#~ msgstr "Mapset du fichier ouvert %s"
-#~ msgid "io error warning given %d"
-#~ msgstr "erreur d'entrée/sortie renvoyée %d"
-#~ msgid "xdr stream for reading fp %p"
-#~ msgstr "flux xdr pour lire fp %p"
-#~ msgid "NULL_ROWS array[%d] = %p"
-#~ msgstr "NULL_ROWS array[%d] = %p"
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "tampon de données pour lire les lignes nulles %p"
-#~ msgid "Minimum row null row number in memory %d"
-#~ msgstr "Nombre minimum d'une ligne d'une ligne nulle en mémoire %d"
-#~ msgid "Quant ptr = %p"
-#~ msgstr "Quant ptr = %p"
-#~ msgid "G_dump: end"
-#~ msgstr "G_dump: fin"
-#, fuzzy
-#~ msgid "Current window not settable"
-#, fuzzy
-#~ msgid "Color file for [%s] not available"
-#~ msgstr "aucun fichier %s disponible\n"
-#, fuzzy
-#~ msgid "Cannot use current window"
-#, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier %s dans %s"
-#~ msgid "Too many open raster maps"
-#~ msgstr "Trop de fichiers raster ouverts"
-#~ msgid "Too many open files"
-#~ msgstr "Trop de fichiers ouverts"
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "ERREUR: Géodatabase (GISBASE) sans valeur\n"
-#~ msgid "Error reading datum shift parameters for %s from table"
-#~ msgstr ""
-#~ "Erreur en lisant le paramètre de décalage du datum dans la table pour %s"
-#~ msgid "Error reading ellipsoid parameters for %s from table"
-#~ msgstr ""
-#~ "Erreur en lisant les paramètres de l'ellipsoïde depuis la table pour %s"
-#~ msgid "No ellipsoid field %s in file %s in %s"
-#~ msgstr "Pas de champ ellipsoïde %s dans le fichier %s de %s"
-#~ msgid "invalid value: field %s in file %s in %s"
-#~ msgstr "valeur invalide: champ %s dans le fichier %s de %s"
-#~ msgid "No n-dims in site_list"
-#~ msgstr "Pas de n-dims dans site_list"
-#~ msgid "No double attributes in site_list"
-#~ msgstr "Aucun attribut double dans site_list"
-#~ msgid "No string attributes in site_list"
-#~ msgstr "Pas d'attribut chaîne de caractère dans site_list"
-#~ msgid "String attribute index out of range"
-#~ msgstr "Index de l'attribut chaîne en dehors des limites"
-#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
-#~ msgstr "Attribut inconnu dans l'appel a G_readsites_xyz()!\n"
-#~ msgid "Failed to convert string attribute."
-#~ msgstr "Echec lors de la conversion de l'attribut."
-#~ msgid "Reading sites list ... "
-#~ msgstr "Lecture de la liste des sites... "
-#~ msgid "failed to guess format"
-#~ msgstr "impossible de deviner le format"
-#~ msgid "decimal field %i not present in sites file"
-#~ msgstr "le champ décimal %i n'est pas présent dans le fichier de sites"
-#~ msgid ""
-#~ "I'm finding records that do not have a floating point attributes (fields "
-#~ "prefixed with '%')."
-#~ msgstr ""
-#~ "J'ai trouvé des enregistrements sans attribut en virgule flottante "
-#~ "(champs préfixés par '%')"
-#~ msgid "WARNING: can not create a new process\n"
-#~ msgstr "ATTENTION: impossible de créer un nouveau processus\n"
-#~ msgid "Select type: point, line, boundary, centroid or area"
-#~ msgstr "Sélectionnez un type: point, ligne, intervalle, centroïde ou zone"
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "Le vecteur '%s' existe déjà."
-#~ msgid "Insufficent memory for allocation of gaussian"
-#~ msgstr "Mémoire insuffisante pour l'attribution gaussienne"
-#~ msgid "Registering lines: "
-#~ msgstr "Enregistrement des lignes : "
-#~ msgid "All vertices"
-#~ msgstr "Tous les sommets"
-#~ msgid "Snaps"
-#~ msgstr "Cassés"
-#~ msgid "Snapped vertices"
-#~ msgstr "Sommets cassés"
-#~ msgid "New vertices"
-#~ msgstr "Nouveaux sommets"
-#~ msgid "Cannot delete the line, map '%s' is not opened on level 2"
-#~ msgstr ""
-#~ "Impossible de supprimer la ligne, la couche '%s' n'est pas ouverte en "
-#~ "niveau 2"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2013-01-05 09:25:09 UTC (rev 54530)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2013-01-05 12:25:29 UTC (rev 54531)
@@ -13,8 +13,8 @@
"Project-Id-Version: grassmods_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-11-05 10:54+0100\n"
-"PO-Revision-Date: 2012-02-07 10:50+0100\n"
-"Last-Translator: Vincent Bain <bain at toraval.fr>\n"
+"PO-Revision-Date: 2012-12-24 17:49+0100\n"
+"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: Français <grass-translations at lists.osgeo.org>\n"
"Language: \n"
"MIME-Version: 1.0\n"
@@ -24,7 +24,8 @@
"X-Poedit-Country: FRANCE\n"
"X-Poedit-SourceCharset: iso-8859-1\n"
-#: ../visualization/nviz/src/nviz_init.c:53 ../misc/m.nviz.image/main.c:49
+#: ../visualization/nviz/src/nviz_init.c:53
+#: ../misc/m.nviz.image/main.c:49
msgid "visualization, raster, vector, raster3d"
msgstr "visualisation, raster, vecteur, raster 3D"
@@ -97,24 +98,22 @@
msgid "Load previously saved state file"
msgstr "Charger le fichier d'état enregistré précédemment"
-#: ../visualization/nviz/src/nviz_init.c:157 ../raster/r.cost/main.c:226
-#: ../raster/wildfire/r.spread/main.c:255 ../raster/wildfire/r.ros/main.c:314
-#: ../raster/r.out.tiff/r.out.tiff.c:144 ../raster/r.out.mat/main.c:90
-#: ../raster/r.in.mat/main.c:125 ../display/d.vect/main.c:367
+#: ../visualization/nviz/src/nviz_init.c:157
+#: ../raster/r.cost/main.c:226
+#: ../raster/wildfire/r.spread/main.c:255
+#: ../raster/wildfire/r.ros/main.c:314
+#: ../raster/r.out.tiff/r.out.tiff.c:144
+#: ../raster/r.out.mat/main.c:90
+#: ../raster/r.in.mat/main.c:125
+#: ../display/d.vect/main.c:367
#: ../display/d.mon/pgms/release.c:36
-msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
-msgstr ""
-"Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--"
-"verbose' à la place."
+msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+msgstr "Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--verbose' à la place."
#: ../visualization/nviz/src/nviz_init.c:287
#, fuzzy
msgid "Number of elevation files does not match number of colors files"
-msgstr ""
-"Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)"
-"de la source."
+msgstr "Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)de la source."
#: ../visualization/nviz/src/nviz_init.c:298
#, fuzzy
@@ -155,7 +154,8 @@
msgid "Unable to map image file"
msgstr "Impossible d'ouvrir le fichier de sortie"
-#: ../visualization/ximgview/main.c:270 ../display/d.mon/cmd/main.c:49
+#: ../visualization/ximgview/main.c:270
+#: ../display/d.mon/cmd/main.c:49
#: ../locale/scriptstrings/d.redraw_to_translate.c:2
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
#, fuzzy
@@ -175,7 +175,8 @@
msgid "Percentage of CPU time to use"
msgstr "Pourcentage du temps CPU à utiliser"
-#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
+#: ../visualization/ximgview/color.c:90
+#: ../visualization/ximgview/color.c:288
#: ../visualization/xganim/Clr_table.c:94
#: ../visualization/xganim/Clr_table.c:292
#: ../visualization/xganim/Clr_table.c:318
@@ -196,188 +197,338 @@
#: ../visualization/ximgview/color.c:269
#: ../visualization/xganim/Clr_table.c:273
msgid "Using private colormap for DirectColor visual."
-msgstr ""
-"Utilisation d'une table de couleur privée pour la visualisation DirectColor"
+msgstr "Utilisation d'une table de couleur privée pour la visualisation DirectColor"
#: ../visualization/xganim/main.c:362
#, fuzzy, c-format
msgid "Reading file [%s]..."
msgstr "Lecture du fichier [%s]..."
-#: ../visualization/xganim/main.c:366 ../doc/raster/r.example/main.c:111
-#: ../misc/m.nviz.image/surface.c:51 ../misc/m.nviz.image/surface.c:108
-#: ../raster/r.bilinear/main.c:81 ../raster/r.profile/main.c:142
-#: ../raster/r.sun2/main.c:811 ../raster/r.sun2/main.c:826
-#: ../raster/r.sun2/main.c:843 ../raster/r.sun2/main.c:857
-#: ../raster/r.sun2/main.c:869 ../raster/r.sun2/main.c:881
-#: ../raster/r.sun2/main.c:892 ../raster/r.sun2/main.c:904
-#: ../raster/r.sun2/main.c:916 ../raster/r.colors.out/main.c:88
-#: ../raster/r.drain/main.c:140 ../raster/r.param.scale/interface.c:172
+#: ../visualization/xganim/main.c:366
+#: ../doc/raster/r.example/main.c:111
+#: ../misc/m.nviz.image/surface.c:51
+#: ../misc/m.nviz.image/surface.c:108
+#: ../raster/r.bilinear/main.c:81
+#: ../raster/r.profile/main.c:142
+#: ../raster/r.sun2/main.c:811
+#: ../raster/r.sun2/main.c:826
+#: ../raster/r.sun2/main.c:843
+#: ../raster/r.sun2/main.c:857
+#: ../raster/r.sun2/main.c:869
+#: ../raster/r.sun2/main.c:881
+#: ../raster/r.sun2/main.c:892
+#: ../raster/r.sun2/main.c:904
+#: ../raster/r.sun2/main.c:916
+#: ../raster/r.colors.out/main.c:88
+#: ../raster/r.drain/main.c:140
+#: ../raster/r.param.scale/interface.c:172
#: ../raster/r.support/front/front.c:224
-#: ../raster/r.support/modcolr/modcolr.c:46 ../raster/r.cross/main.c:125
-#: ../raster/r.distance/parse.c:79 ../raster/r.distance/parse.c:86
-#: ../raster/r.out.mpeg/main.c:217 ../raster/r.patch/main.c:113
-#: ../raster/r.cost/main.c:322 ../raster/r.grow2/main.c:187
-#: ../raster/r.out.vtk/main.c:47 ../raster/r.out.vtk/main.c:60
-#: ../raster/r.recode/main.c:81 ../raster/r.statistics/main.c:79
-#: ../raster/r.statistics/main.c:85 ../raster/r.los/main.c:162
-#: ../raster/r.los/main.c:168 ../raster/r.his/main.c:127
-#: ../raster/r.his/main.c:164 ../raster/r.his/main.c:189
-#: ../raster/r.buffer/main.c:127 ../raster/r.resamp.stats/main.c:296
-#: ../raster/r.walk/main.c:523 ../raster/r.walk/main.c:526
-#: ../raster/r.contour/main.c:158 ../raster/r.series/main.c:212
-#: ../raster/r.composite/main.c:155 ../raster/r.topidx/check_ready.c:11
-#: ../raster/r.fill.dir/main.c:172 ../raster/r.mfilter/main.c:121
-#: ../raster/r.mfilter.fp/main.c:126 ../raster/r.out.arc/main.c:113
-#: ../raster/r.clump/main.c:87 ../raster/r.colors/main.c:306
-#: ../raster/r.colors/main.c:387 ../raster/r.kappa/main.c:161
-#: ../raster/r.kappa/stats.c:30 ../raster/r.kappa/stats.c:35
-#: ../raster/r.out.png/r.out.png.c:214 ../raster/r.resamp.rst/main.c:397
-#: ../raster/r.resamp.rst/main.c:423 ../raster/r.support.stats/main.c:49
-#: ../raster/r.random/main.c:119 ../raster/r.random/main.c:124
+#: ../raster/r.support/modcolr/modcolr.c:46
+#: ../raster/r.cross/main.c:125
+#: ../raster/r.distance/parse.c:79
+#: ../raster/r.distance/parse.c:86
+#: ../raster/r.out.mpeg/main.c:217
+#: ../raster/r.patch/main.c:113
+#: ../raster/r.cost/main.c:322
+#: ../raster/r.grow2/main.c:187
+#: ../raster/r.out.vtk/main.c:47
+#: ../raster/r.out.vtk/main.c:60
+#: ../raster/r.recode/main.c:81
+#: ../raster/r.statistics/main.c:79
+#: ../raster/r.statistics/main.c:85
+#: ../raster/r.los/main.c:162
+#: ../raster/r.los/main.c:168
+#: ../raster/r.his/main.c:127
+#: ../raster/r.his/main.c:164
+#: ../raster/r.his/main.c:189
+#: ../raster/r.buffer/main.c:127
+#: ../raster/r.resamp.stats/main.c:296
+#: ../raster/r.walk/main.c:523
+#: ../raster/r.walk/main.c:526
+#: ../raster/r.contour/main.c:158
+#: ../raster/r.series/main.c:212
+#: ../raster/r.composite/main.c:155
+#: ../raster/r.topidx/check_ready.c:11
+#: ../raster/r.fill.dir/main.c:172
+#: ../raster/r.mfilter/main.c:121
+#: ../raster/r.mfilter.fp/main.c:126
+#: ../raster/r.out.arc/main.c:113
+#: ../raster/r.clump/main.c:87
+#: ../raster/r.colors/main.c:306
+#: ../raster/r.colors/main.c:387
+#: ../raster/r.kappa/main.c:161
+#: ../raster/r.kappa/stats.c:30
+#: ../raster/r.kappa/stats.c:35
+#: ../raster/r.out.png/r.out.png.c:214
+#: ../raster/r.resamp.rst/main.c:397
+#: ../raster/r.resamp.rst/main.c:423
+#: ../raster/r.support.stats/main.c:49
+#: ../raster/r.random/main.c:119
+#: ../raster/r.random/main.c:124
#: ../raster/wildfire/r.spread/main.c:356
#: ../raster/wildfire/r.spread/main.c:359
#: ../raster/wildfire/r.spread/main.c:362
#: ../raster/wildfire/r.spread/main.c:365
#: ../raster/wildfire/r.spread/main.c:369
#: ../raster/wildfire/r.spread/main.c:372
-#: ../raster/wildfire/r.spread/main.c:375 ../raster/wildfire/r.ros/main.c:322
-#: ../raster/wildfire/r.ros/main.c:335 ../raster/wildfire/r.ros/main.c:340
-#: ../raster/wildfire/r.ros/main.c:345 ../raster/wildfire/r.ros/main.c:350
-#: ../raster/wildfire/r.ros/main.c:368 ../raster/wildfire/r.ros/main.c:372
-#: ../raster/wildfire/r.ros/main.c:391 ../raster/wildfire/r.ros/main.c:395
-#: ../raster/wildfire/r.ros/main.c:408 ../raster/r.univar2/r.univar_main.c:216
-#: ../raster/r.report/parse.c:243 ../raster/r.out.pov/main.c:174
-#: ../raster/r.water.outlet/legal.c:23 ../raster/r.carve/main.c:178
-#: ../raster/r.out.tiff/r.out.tiff.c:166 ../raster/r.null/null.c:119
-#: ../raster/r.basins.fill/main.c:82 ../raster/r.basins.fill/main.c:94
-#: ../raster/r.surf.idw2/read_cell.c:19 ../raster/r.stats/main.c:270
-#: ../raster/r.region/main.c:166 ../raster/r.region/main.c:225
-#: ../raster/r.region/main.c:348 ../raster/r.out.mat/main.c:103
-#: ../raster/r.regression.line/main.c:86 ../raster/r.regression.line/main.c:95
-#: ../raster/r.resample/main.c:97 ../raster/r.out.ppm/main.c:116
-#: ../raster/r.out.ascii/main.c:146 ../raster/r.cats/main.c:125
-#: ../raster/r.cats/main.c:146 ../raster/r.slope.aspect/main.c:360
-#: ../raster/r.bitpattern/main.c:101 ../raster/r.to.vect/main.c:114
-#: ../raster/r.out.ppm3/main.c:120 ../raster/r.sum/main.c:62
-#: ../raster/r.transect/main.c:119 ../raster/r.surf.idw/main.c:108
-#: ../raster/r.median/main.c:75 ../raster/r.surf.area/main.c:118
-#: ../raster/r.neighbors/main.c:193 ../raster/r.resamp.interp/main.c:103
-#: ../raster/r.info/main.c:118 ../raster/r.reclass/main.c:78
-#: ../raster/r.coin/main.c:127 ../raster/r.coin/main.c:130
-#: ../raster/r.coin/inter.c:40 ../raster/r.coin/inter.c:44
-#: ../raster/r.texture/main.c:228 ../raster/r.horizon/main.c:550
-#: ../raster/simwe/simlib/input.c:178 ../raster/simwe/simlib/input.c:184
-#: ../raster/simwe/simlib/input.c:189 ../raster/simwe/simlib/input.c:198
-#: ../raster/simwe/simlib/input.c:206 ../raster/simwe/simlib/input.c:212
-#: ../raster/simwe/simlib/input.c:218 ../raster/simwe/simlib/input.c:225
-#: ../raster/simwe/simlib/input.c:232 ../raster/simwe/simlib/input.c:239
-#: ../raster/simwe/simlib/input.c:246 ../raster/r.thin/io.c:96
-#: ../raster/r.covar/main.c:95 ../raster/r.lake/main.c:254
-#: ../raster/r.lake/main.c:265 ../raster/r.average/main.c:72
-#: ../raster/r.average/main.c:75 ../raster/r.out.gridatb/check_ready.c:12
-#: ../raster/r.to.rast3elev/main.c:114 ../raster/r.to.rast3elev/main.c:129
-#: ../raster/r.mapcalc/map.c:377 ../raster/r.flow/io.c:65
-#: ../imagery/i.zc/main.c:111 ../imagery/i.landsat.acca/main.c:58
+#: ../raster/wildfire/r.spread/main.c:375
+#: ../raster/wildfire/r.ros/main.c:322
+#: ../raster/wildfire/r.ros/main.c:335
+#: ../raster/wildfire/r.ros/main.c:340
+#: ../raster/wildfire/r.ros/main.c:345
+#: ../raster/wildfire/r.ros/main.c:350
+#: ../raster/wildfire/r.ros/main.c:368
+#: ../raster/wildfire/r.ros/main.c:372
+#: ../raster/wildfire/r.ros/main.c:391
+#: ../raster/wildfire/r.ros/main.c:395
+#: ../raster/wildfire/r.ros/main.c:408
+#: ../raster/r.univar2/r.univar_main.c:216
+#: ../raster/r.report/parse.c:243
+#: ../raster/r.out.pov/main.c:174
+#: ../raster/r.water.outlet/legal.c:23
+#: ../raster/r.carve/main.c:178
+#: ../raster/r.out.tiff/r.out.tiff.c:166
+#: ../raster/r.null/null.c:119
+#: ../raster/r.basins.fill/main.c:82
+#: ../raster/r.basins.fill/main.c:94
+#: ../raster/r.surf.idw2/read_cell.c:19
+#: ../raster/r.stats/main.c:270
+#: ../raster/r.region/main.c:166
+#: ../raster/r.region/main.c:225
+#: ../raster/r.region/main.c:348
+#: ../raster/r.out.mat/main.c:103
+#: ../raster/r.regression.line/main.c:86
+#: ../raster/r.regression.line/main.c:95
+#: ../raster/r.resample/main.c:97
+#: ../raster/r.out.ppm/main.c:116
+#: ../raster/r.out.ascii/main.c:146
+#: ../raster/r.cats/main.c:125
+#: ../raster/r.cats/main.c:146
+#: ../raster/r.slope.aspect/main.c:360
+#: ../raster/r.bitpattern/main.c:101
+#: ../raster/r.to.vect/main.c:114
+#: ../raster/r.out.ppm3/main.c:120
+#: ../raster/r.sum/main.c:62
+#: ../raster/r.transect/main.c:119
+#: ../raster/r.surf.idw/main.c:108
+#: ../raster/r.median/main.c:75
+#: ../raster/r.surf.area/main.c:118
+#: ../raster/r.neighbors/main.c:193
+#: ../raster/r.resamp.interp/main.c:103
+#: ../raster/r.info/main.c:118
+#: ../raster/r.reclass/main.c:78
+#: ../raster/r.coin/main.c:127
+#: ../raster/r.coin/main.c:130
+#: ../raster/r.coin/inter.c:40
+#: ../raster/r.coin/inter.c:44
+#: ../raster/r.texture/main.c:228
+#: ../raster/r.horizon/main.c:550
+#: ../raster/simwe/simlib/input.c:178
+#: ../raster/simwe/simlib/input.c:184
+#: ../raster/simwe/simlib/input.c:189
+#: ../raster/simwe/simlib/input.c:198
+#: ../raster/simwe/simlib/input.c:206
+#: ../raster/simwe/simlib/input.c:212
+#: ../raster/simwe/simlib/input.c:218
+#: ../raster/simwe/simlib/input.c:225
+#: ../raster/simwe/simlib/input.c:232
+#: ../raster/simwe/simlib/input.c:239
+#: ../raster/simwe/simlib/input.c:246
+#: ../raster/r.thin/io.c:96
+#: ../raster/r.covar/main.c:95
+#: ../raster/r.lake/main.c:254
+#: ../raster/r.lake/main.c:265
+#: ../raster/r.average/main.c:72
+#: ../raster/r.average/main.c:75
+#: ../raster/r.out.gridatb/check_ready.c:12
+#: ../raster/r.to.rast3elev/main.c:114
+#: ../raster/r.to.rast3elev/main.c:129
+#: ../raster/r.mapcalc/map.c:377
+#: ../raster/r.flow/io.c:65
+#: ../imagery/i.zc/main.c:111
+#: ../imagery/i.landsat.acca/main.c:58
#: ../imagery/i.landsat.acca/algorithm.c:387
-#: ../imagery/i.landsat.acca/tools.c:127 ../imagery/i.landsat.toar/main.c:327
-#: ../imagery/i.landsat.toar/main.c:460 ../imagery/i.class/main.c:127
-#: ../imagery/i.group/main.c:201 ../imagery/i.group/main.c:240
-#: ../imagery/i.gensig/parse.c:36 ../imagery/i.his.rgb/openfiles.c:31
-#: ../imagery/i.his.rgb/openfiles.c:36 ../imagery/i.his.rgb/openfiles.c:41
-#: ../imagery/i.topo.corr/main.c:34 ../imagery/i.ifft/ifftmain.c:95
-#: ../imagery/i.ifft/ifftmain.c:105 ../imagery/i.fft/fftmain.c:108
-#: ../imagery/i.modis.qc/main.c:217 ../imagery/i.gensigset/parse.c:42
-#: ../imagery/i.pca/main.c:138 ../imagery/i.rgb.his/openfiles.c:14
-#: ../imagery/i.rgb.his/openfiles.c:16 ../imagery/i.rgb.his/openfiles.c:18
+#: ../imagery/i.landsat.acca/tools.c:127
+#: ../imagery/i.landsat.toar/main.c:327
+#: ../imagery/i.landsat.toar/main.c:460
+#: ../imagery/i.class/main.c:127
+#: ../imagery/i.group/main.c:201
+#: ../imagery/i.group/main.c:240
+#: ../imagery/i.gensig/parse.c:36
+#: ../imagery/i.his.rgb/openfiles.c:31
+#: ../imagery/i.his.rgb/openfiles.c:36
+#: ../imagery/i.his.rgb/openfiles.c:41
+#: ../imagery/i.topo.corr/main.c:34
+#: ../imagery/i.ifft/ifftmain.c:95
+#: ../imagery/i.ifft/ifftmain.c:105
+#: ../imagery/i.fft/fftmain.c:108
+#: ../imagery/i.modis.qc/main.c:217
+#: ../imagery/i.gensigset/parse.c:42
+#: ../imagery/i.pca/main.c:138
+#: ../imagery/i.rgb.his/openfiles.c:14
+#: ../imagery/i.rgb.his/openfiles.c:16
+#: ../imagery/i.rgb.his/openfiles.c:18
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:197
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:227
-#: ../ps/ps.map/outl_io.c:68 ../display/d.histogram/main.c:162
-#: ../display/d.profile/main.c:94 ../display/d.what.rast/main.c:155
-#: ../display/d.what.rast/opencell.c:13 ../display/d.zoom/main.c:208
-#: ../display/d.rast.num/number.c:153 ../display/d.his/main.c:137
-#: ../display/d.his/main.c:174 ../display/d.his/main.c:199
-#: ../display/d.colortable/main.c:95 ../display/d.rast/main.c:111
-#: ../display/d.rgb/main.c:95 ../display/d.rast.arrow/arrow.c:195
-#: ../display/d.rast.arrow/arrow.c:237 ../display/d.rast.arrow/arrow.c:372
-#: ../display/d.legend/main.c:256 ../display/d.nviz/main.c:185
-#: ../display/d.extend/main.c:60 ../display/d.title/main.c:105
-#: ../general/g.mremove/do_remove.c:50 ../general/g.region/main.c:479
-#: ../general/g.region/main.c:822 ../general/g.region/main.c:830
-#: ../vector/v.sample/main.c:158 ../vector/v.what.rast/main.c:139
-#: ../vector/v.extrude/main.c:180 ../vector/v.vol.rst/main.c:606
+#: ../ps/ps.map/outl_io.c:68
+#: ../display/d.histogram/main.c:162
+#: ../display/d.profile/main.c:94
+#: ../display/d.what.rast/main.c:155
+#: ../display/d.what.rast/opencell.c:13
+#: ../display/d.zoom/main.c:208
+#: ../display/d.rast.num/number.c:153
+#: ../display/d.his/main.c:137
+#: ../display/d.his/main.c:174
+#: ../display/d.his/main.c:199
+#: ../display/d.colortable/main.c:95
+#: ../display/d.rast/main.c:111
+#: ../display/d.rgb/main.c:95
+#: ../display/d.rast.arrow/arrow.c:195
+#: ../display/d.rast.arrow/arrow.c:237
+#: ../display/d.rast.arrow/arrow.c:372
+#: ../display/d.legend/main.c:256
+#: ../display/d.nviz/main.c:185
+#: ../display/d.extend/main.c:60
+#: ../display/d.title/main.c:105
+#: ../general/g.mremove/do_remove.c:50
+#: ../general/g.region/main.c:479
+#: ../general/g.region/main.c:822
+#: ../general/g.region/main.c:830
+#: ../vector/v.sample/main.c:158
+#: ../vector/v.what.rast/main.c:139
+#: ../vector/v.extrude/main.c:180
+#: ../vector/v.vol.rst/main.c:606
#: ../vector/v.drape/main.c:245
#, c-format
msgid "Raster map <%s> not found"
msgstr "couche raster <%s> non trouvée"
# c-format
-#: ../visualization/xganim/main.c:370 ../doc/raster/r.example/main.c:122
-#: ../raster/r.bilinear/main.c:94 ../raster/r.profile/main.c:144
-#: ../raster/r.support/front/front.c:227 ../raster/r.cross/main.c:129
-#: ../raster/r.cost/main.c:340 ../raster/r.cost/main.c:608
-#: ../raster/r.grow2/main.c:203 ../raster/r.out.vtk/main.c:222
-#: ../raster/r.out.vtk/main.c:288 ../raster/r.out.vtk/main.c:317
-#: ../raster/r.out.vtk/main.c:364 ../raster/r.recode/recode.c:48
-#: ../raster/r.los/main.c:198 ../raster/r.los/main.c:209
-#: ../raster/r.his/main.c:131 ../raster/r.his/main.c:154
-#: ../raster/r.his/main.c:179 ../raster/r.buffer/read_map.c:42
-#: ../raster/r.buffer/write_map.c:45 ../raster/r.resamp.stats/main.c:329
-#: ../raster/r.walk/main.c:545 ../raster/r.walk/main.c:548
-#: ../raster/r.walk/main.c:854 ../raster/r.contour/main.c:162
-#: ../raster/r.random.surface/init.c:134 ../raster/r.random.surface/main.c:54
-#: ../raster/r.composite/main.c:159 ../raster/r.out.arc/main.c:117
-#: ../raster/r.clump/main.c:94 ../raster/r.colors/stats.c:33
-#: ../raster/r.to.rast3/main.c:366 ../raster/r.out.png/r.out.png.c:217
-#: ../raster/r.resamp.rst/main.c:402 ../raster/r.resamp.rst/main.c:434
-#: ../raster/r.quantile/main.c:311 ../raster/r.random/random.c:41
-#: ../raster/r.random/random.c:45 ../raster/r.random/count.c:24
-#: ../raster/r.random/count.c:30 ../raster/wildfire/r.spread/main.c:411
+#: ../visualization/xganim/main.c:370
+#: ../doc/raster/r.example/main.c:122
+#: ../raster/r.bilinear/main.c:94
+#: ../raster/r.profile/main.c:144
+#: ../raster/r.support/front/front.c:227
+#: ../raster/r.cross/main.c:129
+#: ../raster/r.cost/main.c:340
+#: ../raster/r.cost/main.c:608
+#: ../raster/r.grow2/main.c:203
+#: ../raster/r.out.vtk/main.c:222
+#: ../raster/r.out.vtk/main.c:288
+#: ../raster/r.out.vtk/main.c:317
+#: ../raster/r.out.vtk/main.c:364
+#: ../raster/r.recode/recode.c:48
+#: ../raster/r.los/main.c:198
+#: ../raster/r.los/main.c:209
+#: ../raster/r.his/main.c:131
+#: ../raster/r.his/main.c:154
+#: ../raster/r.his/main.c:179
+#: ../raster/r.buffer/read_map.c:42
+#: ../raster/r.buffer/write_map.c:45
+#: ../raster/r.resamp.stats/main.c:329
+#: ../raster/r.walk/main.c:545
+#: ../raster/r.walk/main.c:548
+#: ../raster/r.walk/main.c:854
+#: ../raster/r.contour/main.c:162
+#: ../raster/r.random.surface/init.c:134
+#: ../raster/r.random.surface/main.c:54
+#: ../raster/r.composite/main.c:159
+#: ../raster/r.out.arc/main.c:117
+#: ../raster/r.clump/main.c:94
+#: ../raster/r.colors/stats.c:33
+#: ../raster/r.to.rast3/main.c:366
+#: ../raster/r.out.png/r.out.png.c:217
+#: ../raster/r.resamp.rst/main.c:402
+#: ../raster/r.resamp.rst/main.c:434
+#: ../raster/r.quantile/main.c:311
+#: ../raster/r.random/random.c:41
+#: ../raster/r.random/random.c:45
+#: ../raster/r.random/count.c:24
+#: ../raster/r.random/count.c:30
+#: ../raster/wildfire/r.spread/main.c:411
#: ../raster/wildfire/r.spread/main.c:415
#: ../raster/wildfire/r.spread/main.c:419
#: ../raster/wildfire/r.spread/main.c:425
#: ../raster/wildfire/r.spread/main.c:430
#: ../raster/wildfire/r.spread/main.c:434
-#: ../raster/wildfire/r.spread/main.c:503 ../raster/wildfire/r.ros/main.c:475
-#: ../raster/wildfire/r.ros/main.c:483 ../raster/wildfire/r.ros/main.c:491
-#: ../raster/wildfire/r.ros/main.c:499 ../raster/wildfire/r.ros/main.c:507
-#: ../raster/wildfire/r.ros/main.c:515 ../raster/wildfire/r.ros/main.c:523
-#: ../raster/wildfire/r.ros/main.c:532 ../raster/wildfire/r.ros/main.c:540
-#: ../raster/wildfire/r.ros/main.c:549 ../raster/r.univar2/r.univar_main.c:221
-#: ../raster/r.grow.distance/main.c:209 ../raster/r.out.pov/main.c:178
-#: ../raster/r.carve/main.c:181 ../raster/r.out.tiff/r.out.tiff.c:188
-#: ../raster/r.null/null.c:324 ../raster/r.surf.idw2/read_cell.c:34
-#: ../raster/r.out.mat/main.c:108 ../raster/r.sunmask/main.c:448
-#: ../raster/r.regression.line/main.c:90 ../raster/r.regression.line/main.c:99
-#: ../raster/r.out.ppm/main.c:120 ../raster/r.random.cells/init.c:68
-#: ../raster/r.random.cells/indep.c:134 ../raster/r.out.ascii/main.c:151
-#: ../raster/r.cats/main.c:150 ../raster/r.bitpattern/main.c:108
-#: ../raster/r.to.vect/main.c:117 ../raster/r.out.ppm3/main.c:124
-#: ../raster/r.sum/main.c:65 ../raster/r.surf.idw/main.c:135
-#: ../raster/r.surf.area/main.c:121 ../raster/r.resamp.interp/main.c:138
-#: ../raster/r.texture/main.c:234 ../raster/r.thin/io.c:100
-#: ../raster/r.covar/main.c:98 ../raster/r.out.gdal/export_band.c:48
-#: ../raster/r.out.gdal/export_band.c:246 ../raster/r.lake/main.c:258
-#: ../raster/r.lake/main.c:269 ../raster/r.to.rast3elev/main.c:160
-#: ../raster/r.mapcalc/map3.c:510 ../imagery/i.smap/shapiro/opencell.c:16
+#: ../raster/wildfire/r.spread/main.c:503
+#: ../raster/wildfire/r.ros/main.c:475
+#: ../raster/wildfire/r.ros/main.c:483
+#: ../raster/wildfire/r.ros/main.c:491
+#: ../raster/wildfire/r.ros/main.c:499
+#: ../raster/wildfire/r.ros/main.c:507
+#: ../raster/wildfire/r.ros/main.c:515
+#: ../raster/wildfire/r.ros/main.c:523
+#: ../raster/wildfire/r.ros/main.c:532
+#: ../raster/wildfire/r.ros/main.c:540
+#: ../raster/wildfire/r.ros/main.c:549
+#: ../raster/r.univar2/r.univar_main.c:221
+#: ../raster/r.grow.distance/main.c:209
+#: ../raster/r.out.pov/main.c:178
+#: ../raster/r.carve/main.c:181
+#: ../raster/r.out.tiff/r.out.tiff.c:188
+#: ../raster/r.null/null.c:324
+#: ../raster/r.surf.idw2/read_cell.c:34
+#: ../raster/r.out.mat/main.c:108
+#: ../raster/r.sunmask/main.c:448
+#: ../raster/r.regression.line/main.c:90
+#: ../raster/r.regression.line/main.c:99
+#: ../raster/r.out.ppm/main.c:120
+#: ../raster/r.random.cells/init.c:68
+#: ../raster/r.random.cells/indep.c:134
+#: ../raster/r.out.ascii/main.c:151
+#: ../raster/r.cats/main.c:150
+#: ../raster/r.bitpattern/main.c:108
+#: ../raster/r.to.vect/main.c:117
+#: ../raster/r.out.ppm3/main.c:124
+#: ../raster/r.sum/main.c:65
+#: ../raster/r.surf.idw/main.c:135
+#: ../raster/r.surf.area/main.c:121
+#: ../raster/r.resamp.interp/main.c:138
+#: ../raster/r.texture/main.c:234
+#: ../raster/r.thin/io.c:100
+#: ../raster/r.covar/main.c:98
+#: ../raster/r.out.gdal/export_band.c:48
+#: ../raster/r.out.gdal/export_band.c:246
+#: ../raster/r.lake/main.c:258
+#: ../raster/r.lake/main.c:269
+#: ../raster/r.to.rast3elev/main.c:160
+#: ../raster/r.mapcalc/map3.c:510
+#: ../imagery/i.smap/shapiro/opencell.c:16
#: ../imagery/i.landsat.acca/main.c:61
#: ../imagery/i.landsat.acca/algorithm.c:389
-#: ../imagery/i.landsat.acca/tools.c:130 ../imagery/i.maxlik/open.c:41
-#: ../imagery/i.landsat.toar/main.c:331 ../imagery/i.landsat.toar/main.c:465
-#: ../imagery/i.gensig/opencell.c:12 ../imagery/i.his.rgb/openfiles.c:33
-#: ../imagery/i.his.rgb/openfiles.c:38 ../imagery/i.his.rgb/openfiles.c:43
-#: ../imagery/i.modis.qc/main.c:221 ../imagery/i.gensigset/opencell.c:13
-#: ../imagery/i.cluster/open_files.c:56 ../imagery/i.pca/main.c:141
-#: ../imagery/i.rgb.his/openfiles.c:21 ../imagery/i.rgb.his/openfiles.c:23
-#: ../imagery/i.rgb.his/openfiles.c:25 ../display/d.rast.edit/cell.c:92
-#: ../display/d.profile/ExtractProf.c:93 ../display/d.profile/What.c:23
-#: ../display/d.what.rast/opencell.c:24 ../display/d.rast.num/number.c:157
-#: ../display/d.his/main.c:141 ../display/d.his/main.c:164
-#: ../display/d.rast/display.c:79 ../display/d.rgb/main.c:99
-#: ../display/d.rast.arrow/arrow.c:380 ../display/d.nviz/main.c:187
-#: ../vector/v.sample/main.c:161 ../vector/v.what.rast/main.c:142
-#: ../vector/v.extrude/main.c:184 ../vector/v.vol.rst/main.c:609
-#: ../vector/v.drape/main.c:250 ../vector/v.to.rast/support.c:267
+#: ../imagery/i.landsat.acca/tools.c:130
+#: ../imagery/i.maxlik/open.c:41
+#: ../imagery/i.landsat.toar/main.c:331
+#: ../imagery/i.landsat.toar/main.c:465
+#: ../imagery/i.gensig/opencell.c:12
+#: ../imagery/i.his.rgb/openfiles.c:33
+#: ../imagery/i.his.rgb/openfiles.c:38
+#: ../imagery/i.his.rgb/openfiles.c:43
+#: ../imagery/i.modis.qc/main.c:221
+#: ../imagery/i.gensigset/opencell.c:13
+#: ../imagery/i.cluster/open_files.c:56
+#: ../imagery/i.pca/main.c:141
+#: ../imagery/i.rgb.his/openfiles.c:21
+#: ../imagery/i.rgb.his/openfiles.c:23
+#: ../imagery/i.rgb.his/openfiles.c:25
+#: ../display/d.rast.edit/cell.c:92
+#: ../display/d.profile/ExtractProf.c:93
+#: ../display/d.profile/What.c:23
+#: ../display/d.what.rast/opencell.c:24
+#: ../display/d.rast.num/number.c:157
+#: ../display/d.his/main.c:141
+#: ../display/d.his/main.c:164
+#: ../display/d.rast/display.c:79
+#: ../display/d.rgb/main.c:99
+#: ../display/d.rast.arrow/arrow.c:380
+#: ../display/d.nviz/main.c:187
+#: ../vector/v.sample/main.c:161
+#: ../vector/v.what.rast/main.c:142
+#: ../vector/v.extrude/main.c:184
+#: ../vector/v.vol.rst/main.c:609
+#: ../vector/v.drape/main.c:250
+#: ../vector/v.to.rast/support.c:267
#: ../vector/v.to.rast/support.c:513
#, c-format
msgid "Unable to open raster map <%s>"
@@ -398,16 +549,19 @@
msgid "Unable to read raster row"
msgstr "Impossible de lire la ligne raster."
-#: ../visualization/xganim/main.c:544 ../raster/r.out.mpeg/main.c:346
+#: ../visualization/xganim/main.c:544
+#: ../raster/r.out.mpeg/main.c:346
msgid "Error reading wildcard"
msgstr "Erreur de lecture de la wildcard"
-#: ../visualization/xganim/main.c:600 ../raster/r.out.mpeg/main.c:396
+#: ../visualization/xganim/main.c:600
+#: ../raster/r.out.mpeg/main.c:396
#, c-format
msgid "Raster file(s) for View%d"
msgstr "Fichier(s) raster pour la Vue%d"
-#: ../sites/s.out.ascii/main.c:47 ../sites/s.in.ascii/main.c:50
+#: ../sites/s.out.ascii/main.c:47
+#: ../sites/s.in.ascii/main.c:50
msgid "sites"
msgstr "sites"
@@ -420,41 +574,69 @@
msgid "My first raster module"
msgstr "Mon module raster de départ."
-#: ../doc/raster/r.example/main.c:96 ../raster/r.patch/main.c:72
-#: ../raster/r.grow2/main.c:167 ../raster/r.rescale.eq/main.c:98
-#: ../raster/r.mfilter/main.c:85 ../raster/r.mfilter.fp/main.c:91
-#: ../raster/r.kappa/main.c:102 ../raster/r.report/parse.c:95
-#: ../raster/r.resample/main.c:79 ../raster/r.slope.aspect/main.c:263
-#: ../raster/r.bitpattern/main.c:87 ../raster/r.texture/main.c:111
-#: ../imagery/i.cluster/main.c:163 ../vector/v.kcv/main.c:106
-#: ../vector/v.sample/main.c:129 ../vector/v.perturb/main.c:117
+#: ../doc/raster/r.example/main.c:96
+#: ../raster/r.patch/main.c:72
+#: ../raster/r.grow2/main.c:167
+#: ../raster/r.rescale.eq/main.c:98
+#: ../raster/r.mfilter/main.c:85
+#: ../raster/r.mfilter.fp/main.c:91
+#: ../raster/r.kappa/main.c:102
+#: ../raster/r.report/parse.c:95
+#: ../raster/r.resample/main.c:79
+#: ../raster/r.slope.aspect/main.c:263
+#: ../raster/r.bitpattern/main.c:87
+#: ../raster/r.texture/main.c:111
+#: ../imagery/i.cluster/main.c:163
+#: ../vector/v.kcv/main.c:106
+#: ../vector/v.sample/main.c:129
+#: ../vector/v.perturb/main.c:117
msgid "Quiet"
msgstr "Silencieux"
-#: ../doc/raster/r.example/main.c:114 ../raster/r.mode/main.c:94
+#: ../doc/raster/r.example/main.c:114
+#: ../raster/r.mode/main.c:94
#: ../raster/r.watershed/shed/com_line.c:231
-#: ../raster/r.watershed/shed/com_line.c:266 ../raster/r.cost/main.c:327
-#: ../raster/r.recode/main.c:84 ../raster/r.los/main.c:173
-#: ../raster/r.buffer/main.c:130 ../raster/r.walk/main.c:531
-#: ../raster/r.clump/main.c:90 ../raster/r.random/main.c:147
-#: ../raster/r.random/main.c:152 ../raster/wildfire/r.spread/main.c:380
+#: ../raster/r.watershed/shed/com_line.c:266
+#: ../raster/r.cost/main.c:327
+#: ../raster/r.recode/main.c:84
+#: ../raster/r.los/main.c:173
+#: ../raster/r.buffer/main.c:130
+#: ../raster/r.walk/main.c:531
+#: ../raster/r.clump/main.c:90
+#: ../raster/r.random/main.c:147
+#: ../raster/r.random/main.c:152
+#: ../raster/wildfire/r.spread/main.c:380
#: ../raster/wildfire/r.spread/main.c:389
-#: ../raster/wildfire/r.spread/main.c:399 ../raster/r.water.outlet/legal.c:10
-#: ../raster/r.surf.idw2/main.c:83 ../raster/r.in.mat/main.c:388
-#: ../raster/r.slope.aspect/opennew.c:11 ../raster/r.bitpattern/main.c:104
-#: ../raster/r.surf.idw/main.c:112 ../raster/r.median/main.c:77
-#: ../raster/r.neighbors/main.c:197 ../raster/r.reclass/main.c:81
-#: ../raster/r.texture/main.c:231 ../raster/r.in.gdal/main.c:225
-#: ../raster/r.surf.gauss/main.c:77 ../raster/r.in.ascii/main.c:203
-#: ../raster/r.surf.fractal/interface.c:79 ../raster/r.average/main.c:78
-#: ../raster/r.to.rast3elev/main.c:472 ../imagery/i.zc/main.c:119
-#: ../imagery/i.landsat.acca/main.c:189 ../imagery/i.landsat.toar/main.c:475
-#: ../imagery/i.ifft/ifftmain.c:116 ../imagery/i.fft/fftmain.c:121
+#: ../raster/wildfire/r.spread/main.c:399
+#: ../raster/r.water.outlet/legal.c:10
+#: ../raster/r.surf.idw2/main.c:83
+#: ../raster/r.in.mat/main.c:388
+#: ../raster/r.slope.aspect/opennew.c:11
+#: ../raster/r.bitpattern/main.c:104
+#: ../raster/r.surf.idw/main.c:112
+#: ../raster/r.median/main.c:77
+#: ../raster/r.neighbors/main.c:197
+#: ../raster/r.reclass/main.c:81
+#: ../raster/r.texture/main.c:231
+#: ../raster/r.in.gdal/main.c:225
+#: ../raster/r.surf.gauss/main.c:77
+#: ../raster/r.in.ascii/main.c:203
+#: ../raster/r.surf.fractal/interface.c:79
+#: ../raster/r.average/main.c:78
+#: ../raster/r.to.rast3elev/main.c:472
+#: ../imagery/i.zc/main.c:119
+#: ../imagery/i.landsat.acca/main.c:189
+#: ../imagery/i.landsat.toar/main.c:475
+#: ../imagery/i.ifft/ifftmain.c:116
+#: ../imagery/i.fft/fftmain.c:121
#: ../imagery/i.fft/fftmain.c:124
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:91
-#: ../general/manage/cmd/rename.c:84 ../general/manage/cmd/copy.c:88
-#: ../vector/v.kernel/main.c:323 ../vector/v.in.ogr/main.c:331
-#: ../vector/v.edit/main.c:87 ../vector/v.to.rast3/main.c:69
+#: ../general/manage/cmd/rename.c:84
+#: ../general/manage/cmd/copy.c:88
+#: ../vector/v.kernel/main.c:323
+#: ../vector/v.in.ogr/main.c:331
+#: ../vector/v.edit/main.c:87
+#: ../vector/v.to.rast3/main.c:69
#: ../vector/v.surf.idw/main.c:137
#, fuzzy, c-format
@@ -467,80 +649,135 @@
msgstr "Impossible de lire les informations de l'en-tête de fichier [%s]"
# c-format
-#: ../doc/raster/r.example/main.c:141 ../raster3d/r3.to.rast/main.c:183
-#: ../raster/r.bilinear/main.c:104 ../raster/r.sun2/main.c:1164
-#: ../raster/r.sun2/main.c:1171 ../raster/r.sun2/main.c:1178
-#: ../raster/r.sun2/main.c:1185 ../raster/r.sun2/main.c:1192
-#: ../raster/r.sun2/main.c:1199 ../raster/r.cross/main.c:145
-#: ../raster/r.patch/main.c:144 ../raster/r.grow2/main.c:209
-#: ../raster/r.los/main.c:203 ../raster/r.buffer/write_map.c:40
-#: ../raster/r.resamp.stats/main.c:341 ../raster/r.circle/dist.c:127
-#: ../raster/r.series/main.c:250 ../raster/r.random.surface/save.c:23
-#: ../raster/r.in.xyz/main.c:498 ../raster/r.composite/main.c:192
-#: ../raster/r.in.arc/main.c:154 ../raster/r.clump/main.c:98
-#: ../raster/r.random/random.c:55 ../raster/r.carve/main.c:189
-#: ../raster/r.null/null.c:329 ../raster/r.basins.fill/main.c:106
-#: ../raster/r.surf.idw2/main.c:111 ../raster/r.sunmask/main.c:450
-#: ../raster/r.surf.random/randsurf.c:28 ../raster/r.surf.random/randsurf.c:32
-#: ../raster/r.in.mat/main.c:430 ../raster/r.li/r.li.daemon/daemon.c:132
-#: ../raster/r.slope.aspect/opennew.c:19 ../raster/r.bitpattern/main.c:125
-#: ../raster/r.surf.idw/main.c:147 ../raster/r.resamp.interp/main.c:148
-#: ../raster/r.texture/main.c:309 ../raster/r.in.gdal/main.c:760
-#: ../raster/r.in.gdal/main.c:765 ../raster/r.in.gdal/main.c:779
-#: ../raster/r.thin/io.c:168 ../raster/r.lake/main.c:229
-#: ../raster/r.lake/main.c:318 ../raster/r.in.ascii/main.c:206
-#: ../raster/r.surf.fractal/write_rast.c:58 ../raster/r.mapcalc/map.c:507
-#: ../raster/r.mapcalc/map3.c:580 ../raster/r.flow/io.c:173
-#: ../raster/r.flow/io.c:208 ../imagery/i.smap/shapiro/opencell.c:30
+#: ../doc/raster/r.example/main.c:141
+#: ../raster3d/r3.to.rast/main.c:183
+#: ../raster/r.bilinear/main.c:104
+#: ../raster/r.sun2/main.c:1164
+#: ../raster/r.sun2/main.c:1171
+#: ../raster/r.sun2/main.c:1178
+#: ../raster/r.sun2/main.c:1185
+#: ../raster/r.sun2/main.c:1192
+#: ../raster/r.sun2/main.c:1199
+#: ../raster/r.cross/main.c:145
+#: ../raster/r.patch/main.c:144
+#: ../raster/r.grow2/main.c:209
+#: ../raster/r.los/main.c:203
+#: ../raster/r.buffer/write_map.c:40
+#: ../raster/r.resamp.stats/main.c:341
+#: ../raster/r.circle/dist.c:127
+#: ../raster/r.series/main.c:250
+#: ../raster/r.random.surface/save.c:23
+#: ../raster/r.in.xyz/main.c:498
+#: ../raster/r.composite/main.c:192
+#: ../raster/r.in.arc/main.c:154
+#: ../raster/r.clump/main.c:98
+#: ../raster/r.random/random.c:55
+#: ../raster/r.carve/main.c:189
+#: ../raster/r.null/null.c:329
+#: ../raster/r.basins.fill/main.c:106
+#: ../raster/r.surf.idw2/main.c:111
+#: ../raster/r.sunmask/main.c:450
+#: ../raster/r.surf.random/randsurf.c:28
+#: ../raster/r.surf.random/randsurf.c:32
+#: ../raster/r.in.mat/main.c:430
+#: ../raster/r.li/r.li.daemon/daemon.c:132
+#: ../raster/r.slope.aspect/opennew.c:19
+#: ../raster/r.bitpattern/main.c:125
+#: ../raster/r.surf.idw/main.c:147
+#: ../raster/r.resamp.interp/main.c:148
+#: ../raster/r.texture/main.c:309
+#: ../raster/r.in.gdal/main.c:760
+#: ../raster/r.in.gdal/main.c:765
+#: ../raster/r.in.gdal/main.c:779
+#: ../raster/r.thin/io.c:168
+#: ../raster/r.lake/main.c:229
+#: ../raster/r.lake/main.c:318
+#: ../raster/r.in.ascii/main.c:206
+#: ../raster/r.surf.fractal/write_rast.c:58
+#: ../raster/r.mapcalc/map.c:507
+#: ../raster/r.mapcalc/map3.c:580
+#: ../raster/r.flow/io.c:173
+#: ../raster/r.flow/io.c:208
+#: ../imagery/i.smap/shapiro/opencell.c:30
#: ../imagery/i.landsat.acca/algorithm.c:234
#: ../imagery/i.landsat.acca/algorithm.c:397
-#: ../imagery/i.landsat.acca/tools.c:140 ../imagery/i.maxlik/open.c:74
-#: ../imagery/i.landsat.toar/main.c:478 ../imagery/i.his.rgb/openfiles.c:15
-#: ../imagery/i.his.rgb/openfiles.c:17 ../imagery/i.his.rgb/openfiles.c:19
-#: ../imagery/i.topo.corr/main.c:58 ../imagery/i.ifft/ifftmain.c:219
-#: ../imagery/i.modis.qc/main.c:235 ../imagery/i.rgb.his/openfiles.c:29
-#: ../imagery/i.rgb.his/openfiles.c:31 ../imagery/i.rgb.his/openfiles.c:33
-#: ../vector/v.kernel/main.c:328 ../vector/lidar/v.surf.bspline/main.c:317
-#: ../vector/v.neighbors/main.c:96 ../vector/v.surf.idw/main.c:264
-#: ../vector/v.to.rast/vect2rast.c:125 ../vector/v.to.rast/vect2rast.c:129
+#: ../imagery/i.landsat.acca/tools.c:140
+#: ../imagery/i.maxlik/open.c:74
+#: ../imagery/i.landsat.toar/main.c:478
+#: ../imagery/i.his.rgb/openfiles.c:15
+#: ../imagery/i.his.rgb/openfiles.c:17
+#: ../imagery/i.his.rgb/openfiles.c:19
+#: ../imagery/i.topo.corr/main.c:58
+#: ../imagery/i.ifft/ifftmain.c:219
+#: ../imagery/i.modis.qc/main.c:235
+#: ../imagery/i.rgb.his/openfiles.c:29
+#: ../imagery/i.rgb.his/openfiles.c:31
+#: ../imagery/i.rgb.his/openfiles.c:33
+#: ../vector/v.kernel/main.c:328
+#: ../vector/lidar/v.surf.bspline/main.c:317
+#: ../vector/v.neighbors/main.c:96
+#: ../vector/v.surf.idw/main.c:264
+#: ../vector/v.to.rast/vect2rast.c:125
+#: ../vector/v.to.rast/vect2rast.c:129
#, c-format
msgid "Unable to create raster map <%s>"
msgstr "Impossible de créer la couche raster <%s>"
# c-format
-#: ../doc/raster/r.example/main.c:154 ../raster/r.profile/read_rast.c:45
-#: ../raster/r.profile/read_rast.c:73 ../raster/r.profile/read_rast.c:101
-#: ../raster/r.patch/main.c:156 ../raster/r.patch/main.c:163
-#: ../raster/r.cost/main.c:405 ../raster/r.cost/main.c:624
-#: ../raster/r.cost/main.c:939 ../raster/r.cost/main.c:972
-#: ../raster/r.cost/main.c:1005 ../raster/r.los/main.c:264
-#: ../raster/r.los/main.c:272 ../raster/r.buffer/read_map.c:63
-#: ../raster/r.buffer/write_map.c:61 ../raster/r.walk/main.c:697
-#: ../raster/r.walk/main.c:756 ../raster/r.walk/main.c:872
-#: ../raster/r.walk/main.c:1413 ../raster/r.walk/main.c:1448
-#: ../raster/r.walk/main.c:1483 ../raster/r.topidx/file_io.c:77
-#: ../raster/r.colors/stats.c:46 ../raster/r.colors/stats.c:113
-#: ../raster/r.null/null.c:340 ../raster/r.sunmask/main.c:481
-#: ../raster/r.out.ppm/main.c:188 ../raster/r.bitpattern/main.c:135
+#: ../doc/raster/r.example/main.c:154
+#: ../raster/r.profile/read_rast.c:45
+#: ../raster/r.profile/read_rast.c:73
+#: ../raster/r.profile/read_rast.c:101
+#: ../raster/r.patch/main.c:156
+#: ../raster/r.patch/main.c:163
+#: ../raster/r.cost/main.c:405
+#: ../raster/r.cost/main.c:624
+#: ../raster/r.cost/main.c:939
+#: ../raster/r.cost/main.c:972
+#: ../raster/r.cost/main.c:1005
+#: ../raster/r.los/main.c:264
+#: ../raster/r.los/main.c:272
+#: ../raster/r.buffer/read_map.c:63
+#: ../raster/r.buffer/write_map.c:61
+#: ../raster/r.walk/main.c:697
+#: ../raster/r.walk/main.c:756
+#: ../raster/r.walk/main.c:872
+#: ../raster/r.walk/main.c:1413
+#: ../raster/r.walk/main.c:1448
+#: ../raster/r.walk/main.c:1483
+#: ../raster/r.topidx/file_io.c:77
+#: ../raster/r.colors/stats.c:46
+#: ../raster/r.colors/stats.c:113
+#: ../raster/r.null/null.c:340
+#: ../raster/r.sunmask/main.c:481
+#: ../raster/r.out.ppm/main.c:188
+#: ../raster/r.bitpattern/main.c:135
#: ../raster/r.out.gdal/export_band.c:90
#: ../raster/r.out.gdal/export_band.c:121
#: ../raster/r.out.gdal/export_band.c:152
#: ../raster/r.out.gdal/export_band.c:397
#: ../raster/r.out.gdal/export_band.c:430
-#: ../raster/r.out.gdal/export_band.c:463 ../raster/r.lake/main.c:288
-#: ../raster/r.lake/main.c:293 ../imagery/i.landsat.acca/algorithm.c:252
+#: ../raster/r.out.gdal/export_band.c:463
+#: ../raster/r.lake/main.c:288
+#: ../raster/r.lake/main.c:293
+#: ../imagery/i.landsat.acca/algorithm.c:252
#: ../imagery/i.landsat.acca/algorithm.c:411
#: ../imagery/i.landsat.acca/algorithm.c:414
-#: ../imagery/i.landsat.acca/tools.c:155 ../imagery/i.landsat.acca/tools.c:159
-#: ../imagery/i.landsat.acca/tools.c:163 ../imagery/i.gensig/get_train.c:32
-#: ../imagery/i.gensigset/get_train.c:36 ../vector/v.what.rast/main.c:276
-#: ../vector/v.what.rast/main.c:281 ../vector/v.to.rast/support.c:525
+#: ../imagery/i.landsat.acca/tools.c:155
+#: ../imagery/i.landsat.acca/tools.c:159
+#: ../imagery/i.landsat.acca/tools.c:163
+#: ../imagery/i.gensig/get_train.c:32
+#: ../imagery/i.gensigset/get_train.c:36
+#: ../vector/v.what.rast/main.c:276
+#: ../vector/v.what.rast/main.c:281
+#: ../vector/v.to.rast/support.c:525
#, fuzzy, c-format
msgid "Unable to read raster map <%s> row %d"
# c-format
-#: ../doc/raster/r.example/main.c:181 ../raster/r.composite/main.c:258
+#: ../doc/raster/r.example/main.c:181
+#: ../raster/r.composite/main.c:258
#, fuzzy, c-format
msgid "Failed writing raster map <%s>"
msgstr "Couche raster %i créée \n"
@@ -554,51 +791,86 @@
msgid "My first vector module"
-#: ../doc/vector/v.example/main.c:73 ../misc/m.nviz.image/vector.c:81
-#: ../raster/r.drain/main.c:202 ../raster/r.cost/main.c:301
-#: ../raster/r.carve/main.c:172 ../raster/r.region/main.c:237
-#: ../display/d.vect/main.c:451 ../display/d.what.vect/main.c:148
-#: ../display/d.vect.chart/main.c:246 ../display/d.zoom/main.c:245
-#: ../display/d.thematic.area/main.c:212 ../display/d.path/main.c:193
-#: ../display/d.extract/main.c:98 ../display/d.extend/main.c:97
-#: ../general/g.mremove/do_remove.c:34 ../general/g.region/main.c:547
-#: ../vector/v.net.iso/main.c:181 ../vector/v.type/main.c:202
-#: ../vector/v.voronoi/vo_main.c:158 ../vector/v.voronoi/dt_main.c:77
-#: ../vector/v.net.steiner/main.c:428 ../vector/v.overlay/main.c:204
-#: ../vector/v.kernel/main.c:275 ../vector/v.net/main.c:143
-#: ../vector/v.net/main.c:158 ../vector/v.label/main.c:270
-#: ../vector/v.buffer2/main.c:311 ../vector/v.univar/main.c:161
+#: ../doc/vector/v.example/main.c:73
+#: ../misc/m.nviz.image/vector.c:81
+#: ../raster/r.drain/main.c:202
+#: ../raster/r.cost/main.c:301
+#: ../raster/r.carve/main.c:172
+#: ../raster/r.region/main.c:237
+#: ../display/d.vect/main.c:451
+#: ../display/d.what.vect/main.c:148
+#: ../display/d.vect.chart/main.c:246
+#: ../display/d.zoom/main.c:245
+#: ../display/d.thematic.area/main.c:212
+#: ../display/d.path/main.c:193
+#: ../display/d.extract/main.c:98
+#: ../display/d.extend/main.c:97
+#: ../general/g.mremove/do_remove.c:34
+#: ../general/g.region/main.c:547
+#: ../vector/v.net.iso/main.c:181
+#: ../vector/v.type/main.c:202
+#: ../vector/v.voronoi/vo_main.c:158
+#: ../vector/v.voronoi/dt_main.c:77
+#: ../vector/v.net.steiner/main.c:428
+#: ../vector/v.overlay/main.c:204
+#: ../vector/v.kernel/main.c:275
+#: ../vector/v.net/main.c:143
+#: ../vector/v.net/main.c:158
+#: ../vector/v.label/main.c:270
+#: ../vector/v.buffer2/main.c:311
+#: ../vector/v.univar/main.c:161
#: ../vector/v.lrs/v.lrs.segment/main.c:138
#: ../vector/v.lrs/v.lrs.where/main.c:127
#: ../vector/v.lrs/v.lrs.where/main.c:135
#: ../vector/v.lrs/v.lrs.create/main.c:250
#: ../vector/v.lrs/v.lrs.create/main.c:257
-#: ../vector/v.lrs/v.lrs.label/main.c:286 ../vector/v.edit/main.c:146
-#: ../vector/v.net.alloc/main.c:143 ../vector/v.kcv/main.c:132
-#: ../vector/v.extract/main.c:193 ../vector/v.db.connect/main.c:140
-#: ../vector/v.delaunay2/main.c:117 ../vector/v.sample/main.c:152
-#: ../vector/v.distance/main.c:303 ../vector/v.to.db/parse.c:128
-#: ../vector/v.build.polylines/main.c:145 ../vector/v.qcount/main.c:128
-#: ../vector/v.category/main.c:197 ../vector/v.buffer/main.c:365
-#: ../vector/v.surf.rst/main.c:565 ../vector/v.transform/main.c:307
+#: ../vector/v.lrs/v.lrs.label/main.c:286
+#: ../vector/v.edit/main.c:146
+#: ../vector/v.net.alloc/main.c:143
+#: ../vector/v.kcv/main.c:132
+#: ../vector/v.extract/main.c:193
+#: ../vector/v.db.connect/main.c:140
+#: ../vector/v.delaunay2/main.c:117
+#: ../vector/v.sample/main.c:152
+#: ../vector/v.distance/main.c:303
+#: ../vector/v.to.db/parse.c:128
+#: ../vector/v.build.polylines/main.c:145
+#: ../vector/v.qcount/main.c:128
+#: ../vector/v.category/main.c:197
+#: ../vector/v.buffer/main.c:365
+#: ../vector/v.surf.rst/main.c:565
+#: ../vector/v.transform/main.c:307
#: ../vector/lidar/v.outlier/main.c:156
#: ../vector/lidar/v.lidar.edgedetection/main.c:217
#: ../vector/lidar/v.lidar.correction/main.c:182
#: ../vector/lidar/v.surf.bspline/main.c:219
#: ../vector/lidar/v.surf.bspline/main.c:273
-#: ../vector/lidar/v.lidar.growing/main.c:129 ../vector/v.reclass/main.c:108
-#: ../vector/v.out.svg/main.c:127 ../vector/v.normal/main.c:128
-#: ../vector/v.out.ogr/main.c:196 ../vector/v.out.pov/main.c:94
-#: ../vector/v.select/main.c:103 ../vector/v.convert/att.c:30
-#: ../vector/v.convert/old2new.c:26 ../vector/v.clean/main.c:241
-#: ../vector/v.perturb/main.c:154 ../vector/v.class/main.c:95
-#: ../vector/v.info/main.c:103 ../vector/v.db.select/main.c:132
-#: ../vector/v.what.rast/main.c:120 ../vector/v.net.salesman/main.c:171
-#: ../vector/v.to.points/main.c:244 ../vector/v.extrude/main.c:144
-#: ../vector/v.segment/main.c:99 ../vector/v.what/main.c:151
-#: ../vector/v.generalize/main.c:290 ../vector/v.label.sa/labels.c:60
-#: ../vector/v.hull/main.c:300 ../vector/v.out.dxf/main.c:69
-#: ../vector/v.drape/main.c:261 ../vector/v.net.path/main.c:131
+#: ../vector/lidar/v.lidar.growing/main.c:129
+#: ../vector/v.reclass/main.c:108
+#: ../vector/v.out.svg/main.c:127
+#: ../vector/v.normal/main.c:128
+#: ../vector/v.out.ogr/main.c:196
+#: ../vector/v.out.pov/main.c:94
+#: ../vector/v.select/main.c:103
+#: ../vector/v.convert/att.c:30
+#: ../vector/v.convert/old2new.c:26
+#: ../vector/v.clean/main.c:241
+#: ../vector/v.perturb/main.c:154
+#: ../vector/v.class/main.c:95
+#: ../vector/v.info/main.c:103
+#: ../vector/v.db.select/main.c:132
+#: ../vector/v.what.rast/main.c:120
+#: ../vector/v.net.salesman/main.c:171
+#: ../vector/v.to.points/main.c:244
+#: ../vector/v.extrude/main.c:144
+#: ../vector/v.segment/main.c:99
+#: ../vector/v.what/main.c:151
+#: ../vector/v.generalize/main.c:290
+#: ../vector/v.label.sa/labels.c:60
+#: ../vector/v.hull/main.c:300
+#: ../vector/v.out.dxf/main.c:69
+#: ../vector/v.drape/main.c:261
+#: ../vector/v.net.path/main.c:131
#: ../vector/v.to.rast/vect2rast.c:37
#, fuzzy, c-format
msgid "Vector map <%s> not found"
@@ -610,138 +882,231 @@
msgstr "Impossible d'ouvrir la couche vectorielle de centroïdes"
# c-format
-#: ../doc/vector/v.example/main.c:85 ../display/d.what.vect/main.c:126
-#: ../vector/v.net.centrality/main.c:188 ../vector/v.net/main.c:164
-#: ../vector/v.buffer2/main.c:316 ../vector/v.net.distance/main.c:140
-#: ../vector/v.out.ascii/out.c:154 ../vector/v.support/main.c:135
-#: ../vector/v.edit/main.c:166 ../vector/v.net.bridge/main.c:80
-#: ../vector/v.net.flow/main.c:132 ../vector/v.surf.rst/main.c:569
-#: ../vector/v.surf.rst/main.c:724 ../vector/v.surf.rst/main.c:813
+#: ../doc/vector/v.example/main.c:85
+#: ../display/d.what.vect/main.c:126
+#: ../vector/v.net.centrality/main.c:188
+#: ../vector/v.net/main.c:164
+#: ../vector/v.buffer2/main.c:316
+#: ../vector/v.net.distance/main.c:140
+#: ../vector/v.out.ascii/out.c:154
+#: ../vector/v.support/main.c:135
+#: ../vector/v.edit/main.c:166
+#: ../vector/v.net.bridge/main.c:80
+#: ../vector/v.net.flow/main.c:132
+#: ../vector/v.surf.rst/main.c:569
+#: ../vector/v.surf.rst/main.c:724
+#: ../vector/v.surf.rst/main.c:813
#: ../vector/lidar/v.lidar.edgedetection/main.c:223
#: ../vector/lidar/v.lidar.correction/main.c:186
#: ../vector/lidar/v.lidar.growing/main.c:141
#: ../vector/lidar/v.lidar.growing/main.c:145
-#: ../vector/v.net.timetable/main.c:317 ../vector/v.net.spanningtree/main.c:81
-#: ../vector/v.net.allpairs/main.c:110 ../vector/v.info/main.c:113
-#: ../vector/v.net.components/main.c:108 ../vector/v.to.3d/main.c:72
-#: ../vector/v.generalize/main.c:295 ../vector/v.hull/main.c:307
+#: ../vector/v.net.timetable/main.c:317
+#: ../vector/v.net.spanningtree/main.c:81
+#: ../vector/v.net.allpairs/main.c:110
+#: ../vector/v.info/main.c:113
+#: ../vector/v.net.components/main.c:108
+#: ../vector/v.to.3d/main.c:72
+#: ../vector/v.generalize/main.c:295
+#: ../vector/v.hull/main.c:307
#: ../vector/v.net.connectivity/main.c:115
-#: ../vector/v.net.visibility/main.c:82 ../vector/v.net.visibility/main.c:94
+#: ../vector/v.net.visibility/main.c:82
+#: ../vector/v.net.visibility/main.c:94
#, fuzzy, c-format
msgid "Unable to open vector map <%s>"
msgstr "Impossible d'ouvrir la couche vecteur [%s]"
# c-format
-#: ../doc/vector/v.example/main.c:96 ../raster/r.flow/io.c:176
-#: ../vector/v.net.centrality/main.c:194 ../vector/v.voronoi/vo_main.c:165
-#: ../vector/v.voronoi/dt_main.c:92 ../vector/v.voronoi/dt_main.c:98
-#: ../vector/v.buffer2/main.c:320 ../vector/v.net.distance/main.c:146
-#: ../vector/v.edit/main.c:106 ../vector/v.delaunay2/main.c:126
-#: ../vector/v.mkgrid/main.c:223 ../vector/v.net.bridge/main.c:86
-#: ../vector/v.net.flow/main.c:138 ../vector/v.net.flow/main.c:144
-#: ../vector/lidar/v.outlier/main.c:205 ../vector/lidar/v.outlier/main.c:210
+#: ../doc/vector/v.example/main.c:96
+#: ../raster/r.flow/io.c:176
+#: ../vector/v.net.centrality/main.c:194
+#: ../vector/v.voronoi/vo_main.c:165
+#: ../vector/v.voronoi/dt_main.c:92
+#: ../vector/v.voronoi/dt_main.c:98
+#: ../vector/v.buffer2/main.c:320
+#: ../vector/v.net.distance/main.c:146
+#: ../vector/v.edit/main.c:106
+#: ../vector/v.delaunay2/main.c:126
+#: ../vector/v.mkgrid/main.c:223
+#: ../vector/v.net.bridge/main.c:86
+#: ../vector/v.net.flow/main.c:138
+#: ../vector/v.net.flow/main.c:144
+#: ../vector/lidar/v.outlier/main.c:205
+#: ../vector/lidar/v.outlier/main.c:210
#: ../vector/lidar/v.outlier/main.c:216
#: ../vector/lidar/v.lidar.edgedetection/main.c:245
#: ../vector/lidar/v.lidar.correction/main.c:209
#: ../vector/lidar/v.lidar.correction/main.c:215
#: ../vector/lidar/v.surf.bspline/main.c:293
-#: ../vector/v.net.timetable/main.c:323 ../vector/v.net.spanningtree/main.c:87
-#: ../vector/v.net.allpairs/main.c:116 ../vector/v.net.components/main.c:114
-#: ../vector/v.to.3d/main.c:88 ../vector/v.in.dxf/main.c:168
-#: ../vector/v.generalize/main.c:302 ../vector/v.hull/main.c:334
-#: ../vector/v.drape/main.c:339 ../vector/v.drape/main.c:380
-#: ../vector/v.net.path/main.c:139 ../vector/v.net.connectivity/main.c:121
+#: ../vector/v.net.timetable/main.c:323
+#: ../vector/v.net.spanningtree/main.c:87
+#: ../vector/v.net.allpairs/main.c:116
+#: ../vector/v.net.components/main.c:114
+#: ../vector/v.to.3d/main.c:88
+#: ../vector/v.in.dxf/main.c:168
+#: ../vector/v.generalize/main.c:302
+#: ../vector/v.hull/main.c:334
+#: ../vector/v.drape/main.c:339
+#: ../vector/v.drape/main.c:380
+#: ../vector/v.net.path/main.c:139
+#: ../vector/v.net.connectivity/main.c:121
#: ../vector/v.net.visibility/main.c:87
#, fuzzy, c-format
msgid "Unable to create vector map <%s>"
-#: ../doc/vector/v.example/main.c:103 ../display/d.vect/area.c:54
-#: ../display/d.vect/plot1.c:205 ../display/d.vect.chart/plot.c:38
-#: ../display/d.thematic.area/plot1.c:196 ../vector/v.overlay/main.c:287
-#: ../vector/v.buffer2/main.c:329 ../vector/v.univar/main.c:209
-#: ../vector/v.out.ascii/b2a.c:40 ../vector/v.edit/select.c:507
-#: ../vector/v.extract/main.c:278 ../vector/v.db.connect/main.c:208
-#: ../vector/v.sample/main.c:167 ../vector/v.distance/main.c:359
+#: ../doc/vector/v.example/main.c:103
+#: ../display/d.vect/area.c:54
+#: ../display/d.vect/plot1.c:205
+#: ../display/d.vect.chart/plot.c:38
+#: ../display/d.thematic.area/plot1.c:196
+#: ../vector/v.overlay/main.c:287
+#: ../vector/v.buffer2/main.c:329
+#: ../vector/v.univar/main.c:209
+#: ../vector/v.out.ascii/b2a.c:40
+#: ../vector/v.edit/select.c:507
+#: ../vector/v.extract/main.c:278
+#: ../vector/v.db.connect/main.c:208
+#: ../vector/v.sample/main.c:167
+#: ../vector/v.distance/main.c:359
#: ../vector/v.distance/main.c:395
#: ../vector/lidar/v.surf.bspline/crosscorr.c:119
-#: ../vector/v.reclass/main.c:122 ../vector/v.info/main.c:208
-#: ../vector/v.to.3d/trans3.c:47 ../vector/v.to.3d/trans2.c:45
-#: ../vector/v.db.select/main.c:149 ../vector/v.what.rast/main.c:127
-#: ../vector/v.extrude/main.c:163 ../vector/v.generalize/misc.c:163
-#: ../vector/v.surf.idw/read_sites.c:34 ../vector/v.drape/main.c:271
-#: ../vector/v.to.rast/support.c:126 ../vector/v.to.rast/support.c:287
-#: ../vector/v.to.rast/support.c:437 ../vector/v.to.rast/vect2rast.c:51
+#: ../vector/v.reclass/main.c:122
+#: ../vector/v.info/main.c:208
+#: ../vector/v.to.3d/trans3.c:47
+#: ../vector/v.to.3d/trans2.c:45
+#: ../vector/v.db.select/main.c:149
+#: ../vector/v.what.rast/main.c:127
+#: ../vector/v.extrude/main.c:163
+#: ../vector/v.generalize/misc.c:163
+#: ../vector/v.surf.idw/read_sites.c:34
+#: ../vector/v.drape/main.c:271
+#: ../vector/v.to.rast/support.c:126
+#: ../vector/v.to.rast/support.c:287
+#: ../vector/v.to.rast/support.c:437
+#: ../vector/v.to.rast/vect2rast.c:51
#, fuzzy, c-format
msgid "Database connection not defined for layer %d"
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>"
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>"
# c-format
-#: ../doc/vector/v.example/main.c:123 ../display/d.vect/main.c:470
-#: ../display/d.thematic.area/main.c:231 ../vector/v.out.ascii/b2a.c:46
-#: ../vector/v.edit/select.c:514 ../vector/v.extract/main.c:286
-#: ../vector/v.db.connect/main.c:212 ../vector/v.db.connect/main.c:278
-#: ../vector/v.out.svg/main.c:141 ../vector/v.out.ogr/main.c:629
-#: ../vector/v.in.sites/main.c:158 ../vector/v.drape/main.c:288
-#: ../vector/v.out.vtk/writeVTK.c:635 ../db/base/droptable.c:44
-#: ../db/base/createdb.c:43 ../db/base/tables.c:46 ../db/base/dropdb.c:43
-#: ../db/base/columns.c:45 ../db/base/execute.c:61 ../db/base/describe.c:52
-#: ../db/base/databases.c:52 ../db/base/select.c:67
+#: ../doc/vector/v.example/main.c:123
+#: ../display/d.vect/main.c:470
+#: ../display/d.thematic.area/main.c:231
+#: ../vector/v.out.ascii/b2a.c:46
+#: ../vector/v.edit/select.c:514
+#: ../vector/v.extract/main.c:286
+#: ../vector/v.db.connect/main.c:212
+#: ../vector/v.db.connect/main.c:278
+#: ../vector/v.out.svg/main.c:141
+#: ../vector/v.out.ogr/main.c:629
+#: ../vector/v.in.sites/main.c:158
+#: ../vector/v.drape/main.c:288
+#: ../vector/v.out.vtk/writeVTK.c:635
+#: ../db/base/droptable.c:44
+#: ../db/base/createdb.c:43
+#: ../db/base/tables.c:46
+#: ../db/base/dropdb.c:43
+#: ../db/base/columns.c:45
+#: ../db/base/execute.c:61
+#: ../db/base/describe.c:52
+#: ../db/base/databases.c:52
+#: ../db/base/select.c:67
#, fuzzy, c-format
msgid "Unable to start driver <%s>"
msgstr "Impossible de lancer le pilote '%s'."
-#: ../doc/vector/v.example/main.c:128 ../raster/r.contour/main.c:185
-#: ../raster/r.random/random.c:74 ../raster/r.to.vect/main.c:159
-#: ../ps/ps.map/catval.c:54 ../ps/ps.map/catval.c:116
-#: ../ps/ps.map/catval.c:182 ../display/d.vect/attr.c:45
-#: ../display/d.vect/area.c:60 ../display/d.vect/plot1.c:211
-#: ../display/d.vect.chart/plot.c:44 ../display/d.thematic.area/plot1.c:202
-#: ../vector/v.random/main.c:168 ../vector/v.net.centrality/main.c:220
-#: ../vector/v.overlay/main.c:186 ../vector/v.overlay/main.c:295
-#: ../vector/v.label/main.c:282 ../vector/v.buffer2/main.c:334
-#: ../vector/v.net.distance/main.c:196 ../vector/v.lrs/v.lrs.create/main.c:287
-#: ../vector/v.lrs/v.lrs.create/main.c:295 ../vector/v.out.ascii/b2a.c:52
-#: ../vector/v.edit/select.c:521 ../vector/v.in.dwg/main.c:194
-#: ../vector/v.kcv/main.c:181 ../vector/v.extract/main.c:291
-#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
-#: ../vector/v.in.ascii/in.c:317 ../vector/v.sample/main.c:207
-#: ../vector/v.distance/main.c:364 ../vector/v.distance/main.c:401
-#: ../vector/v.to.db/query.c:89 ../vector/v.to.db/update.c:46
-#: ../vector/v.mkgrid/main.c:237 ../vector/v.net.flow/main.c:157
-#: ../vector/v.buffer/main.c:387 ../vector/v.surf.rst/main.c:607
+#: ../doc/vector/v.example/main.c:128
+#: ../raster/r.contour/main.c:185
+#: ../raster/r.random/random.c:74
+#: ../raster/r.to.vect/main.c:159
+#: ../ps/ps.map/catval.c:54
+#: ../ps/ps.map/catval.c:116
+#: ../ps/ps.map/catval.c:182
+#: ../display/d.vect/attr.c:45
+#: ../display/d.vect/area.c:60
+#: ../display/d.vect/plot1.c:211
+#: ../display/d.vect.chart/plot.c:44
+#: ../display/d.thematic.area/plot1.c:202
+#: ../vector/v.random/main.c:168
+#: ../vector/v.net.centrality/main.c:220
+#: ../vector/v.overlay/main.c:186
+#: ../vector/v.overlay/main.c:295
+#: ../vector/v.label/main.c:282
+#: ../vector/v.buffer2/main.c:334
+#: ../vector/v.net.distance/main.c:196
+#: ../vector/v.lrs/v.lrs.create/main.c:287
+#: ../vector/v.lrs/v.lrs.create/main.c:295
+#: ../vector/v.out.ascii/b2a.c:52
+#: ../vector/v.edit/select.c:521
+#: ../vector/v.in.dwg/main.c:194
+#: ../vector/v.kcv/main.c:181
+#: ../vector/v.extract/main.c:291
+#: ../vector/v.db.connect/main.c:218
+#: ../vector/v.db.connect/main.c:326
+#: ../vector/v.in.ascii/in.c:317
+#: ../vector/v.sample/main.c:207
+#: ../vector/v.distance/main.c:364
+#: ../vector/v.distance/main.c:401
+#: ../vector/v.to.db/query.c:89
+#: ../vector/v.to.db/update.c:46
+#: ../vector/v.mkgrid/main.c:237
+#: ../vector/v.net.flow/main.c:157
+#: ../vector/v.buffer/main.c:387
+#: ../vector/v.surf.rst/main.c:607
#: ../vector/v.transform/trans_digit.c:64
#: ../vector/lidar/v.surf.bspline/main.c:335
#: ../vector/lidar/v.surf.bspline/crosscorr.c:128
-#: ../vector/v.reclass/main.c:127 ../vector/v.net.timetable/main.c:93
-#: ../vector/v.out.svg/main.c:148 ../vector/v.normal/main.c:141
-#: ../vector/v.out.ogr/main.c:634 ../vector/v.patch/main.c:132
-#: ../vector/v.patch/main.c:162 ../vector/v.patch/main.c:274
-#: ../vector/v.patch/main.c:332 ../vector/v.in.sites/main.c:163
-#: ../vector/v.net.allpairs/main.c:141 ../vector/v.info/main.c:217
-#: ../vector/v.net.components/main.c:137 ../vector/v.to.3d/trans3.c:54
-#: ../vector/v.to.3d/trans2.c:52 ../vector/v.db.select/main.c:155
-#: ../vector/v.db.select/main.c:286 ../vector/v.in.dxf/write_vect.c:198
-#: ../vector/v.what.rast/main.c:133 ../vector/v.to.points/main.c:285
-#: ../vector/v.extrude/main.c:168 ../vector/v.vol.rst/main.c:590
-#: ../vector/v.vol.rst/user1.c:97 ../vector/v.to.rast3/main.c:86
-#: ../vector/v.label.sa/labels.c:83 ../vector/v.in.db/main.c:119
-#: ../vector/v.surf.idw/read_sites.c:39 ../vector/v.drape/main.c:293
-#: ../vector/v.net.path/path.c:96 ../vector/v.to.rast/support.c:131
-#: ../vector/v.to.rast/support.c:295 ../vector/v.to.rast/support.c:445
-#: ../vector/v.to.rast/vect2rast.c:56 ../vector/v.out.vtk/writeVTK.c:640
+#: ../vector/v.reclass/main.c:127
+#: ../vector/v.net.timetable/main.c:93
+#: ../vector/v.out.svg/main.c:148
+#: ../vector/v.normal/main.c:141
+#: ../vector/v.out.ogr/main.c:634
+#: ../vector/v.patch/main.c:132
+#: ../vector/v.patch/main.c:162
+#: ../vector/v.patch/main.c:274
+#: ../vector/v.patch/main.c:332
+#: ../vector/v.in.sites/main.c:163
+#: ../vector/v.net.allpairs/main.c:141
+#: ../vector/v.info/main.c:217
+#: ../vector/v.net.components/main.c:137
+#: ../vector/v.to.3d/trans3.c:54
+#: ../vector/v.to.3d/trans2.c:52
+#: ../vector/v.db.select/main.c:155
+#: ../vector/v.db.select/main.c:286
+#: ../vector/v.in.dxf/write_vect.c:198
+#: ../vector/v.what.rast/main.c:133
+#: ../vector/v.to.points/main.c:285
+#: ../vector/v.extrude/main.c:168
+#: ../vector/v.vol.rst/main.c:590
+#: ../vector/v.vol.rst/user1.c:97
+#: ../vector/v.to.rast3/main.c:86
+#: ../vector/v.label.sa/labels.c:83
+#: ../vector/v.in.db/main.c:119
+#: ../vector/v.surf.idw/read_sites.c:39
+#: ../vector/v.drape/main.c:293
+#: ../vector/v.net.path/path.c:96
+#: ../vector/v.to.rast/support.c:131
+#: ../vector/v.to.rast/support.c:295
+#: ../vector/v.to.rast/support.c:445
+#: ../vector/v.to.rast/vect2rast.c:56
+#: ../vector/v.out.vtk/writeVTK.c:640
#, fuzzy, c-format
msgid "Unable to open database <%s> by driver <%s>"
msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
# c-format
-#: ../doc/vector/v.example/main.c:134 ../vector/v.random/main.c:214
-#: ../vector/v.db.connect/main.c:223 ../vector/v.in.ascii/in.c:408
-#: ../vector/v.reclass/main.c:174 ../vector/v.out.svg/main.c:154
-#: ../vector/v.out.ogr/main.c:639 ../vector/v.patch/main.c:139
-#: ../vector/v.patch/main.c:177 ../vector/v.info/main.c:222
-#: ../vector/v.drape/main.c:299 ../vector/v.out.vtk/writeVTK.c:644
+#: ../doc/vector/v.example/main.c:134
+#: ../vector/v.random/main.c:214
+#: ../vector/v.db.connect/main.c:223
+#: ../vector/v.in.ascii/in.c:408
+#: ../vector/v.reclass/main.c:174
+#: ../vector/v.out.svg/main.c:154
+#: ../vector/v.out.ogr/main.c:639
+#: ../vector/v.patch/main.c:139
+#: ../vector/v.patch/main.c:177
+#: ../vector/v.info/main.c:222
+#: ../vector/v.drape/main.c:299
+#: ../vector/v.out.vtk/writeVTK.c:644
#: ../db/base/describe.c:63
#, fuzzy, c-format
msgid "Unable to describe table <%s>"
@@ -765,30 +1130,33 @@
msgid "Unable to copy attribute table to vector map <%s>"
-#: ../raster3d/r3.in.v5d/main.c:191 ../raster3d/r3.in.ascii/main.c:240
+#: ../raster3d/r3.in.v5d/main.c:191
+#: ../raster3d/r3.in.ascii/main.c:240
#, fuzzy
msgid "raster3d, voxel, import"
msgstr "Niveau d'eau"
#: ../raster3d/r3.in.v5d/main.c:193
-msgid ""
-"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
-"time step)."
-msgstr ""
-"Importe des fichiers 3D Vis5D (c.-à-d. des fichiers V5D avec une variable et "
-"un pas de temps)."
+msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+msgstr "Importe des fichiers 3D Vis5D (c.-à-d. des fichiers V5D avec une variable et un pas de temps)."
# c-format
-#: ../raster3d/r3.in.v5d/main.c:213 ../raster3d/r3.in.ascii/main.c:268
+#: ../raster3d/r3.in.v5d/main.c:213
+#: ../raster3d/r3.in.ascii/main.c:268
#, fuzzy
msgid "Unable to open 3D raster map"
msgstr "Impossible d'ouvrir la couche raster <%s>"
-#: ../raster3d/r3.in.v5d/main.c:218 ../raster3d/r3.out.ascii/main.c:58
-#: ../raster3d/r3.out.ascii/main.c:300 ../raster3d/r3.out.v5d/main.c:54
-#: ../raster3d/r3.out.v5d/main.c:326 ../raster3d/r3.to.rast/main.c:55
-#: ../raster3d/r3.to.rast/main.c:390 ../raster3d/r3.cross.rast/main.c:55
-#: ../raster3d/r3.out.vtk/main.c:254 ../raster3d/r3.out.vtk/main.c:339
+#: ../raster3d/r3.in.v5d/main.c:218
+#: ../raster3d/r3.out.ascii/main.c:58
+#: ../raster3d/r3.out.ascii/main.c:300
+#: ../raster3d/r3.out.v5d/main.c:54
+#: ../raster3d/r3.out.v5d/main.c:326
+#: ../raster3d/r3.to.rast/main.c:55
+#: ../raster3d/r3.to.rast/main.c:390
+#: ../raster3d/r3.cross.rast/main.c:55
+#: ../raster3d/r3.out.vtk/main.c:254
+#: ../raster3d/r3.out.vtk/main.c:339
#: ../raster3d/r3.in.ascii/main.c:274
#, fuzzy
msgid "Unable to close 3D raster map"
@@ -828,9 +1196,7 @@
msgstr "Lecteur du fichier raster..."
#: ../raster3d/r3.gwflow/main.c:116
-msgid ""
-"The piezometric head result of the numerical calculation will be written to "
-"this map"
+msgid "The piezometric head result of the numerical calculation will be written to this map"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:123
@@ -840,35 +1206,39 @@
"Name is basename for the new 3D raster maps."
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:136 ../raster3d/r3.out.vtk/parameters.c:117
+#: ../raster3d/r3.gwflow/main.c:136
+#: ../raster3d/r3.out.vtk/parameters.c:117
#, fuzzy
msgid "Use 3D raster mask (if exists) with input maps"
msgstr "Utilisez le masque raster 3D (s'il existe) sur la couche en entrée"
#: ../raster3d/r3.gwflow/main.c:141
-msgid ""
-"Use a sparse linear equation system, only available with iterative solvers"
+msgid "Use a sparse linear equation system, only available with iterative solvers"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:169 ../raster3d/r3.mkdspf/main.c:75
-#: ../raster3d/base/r3.info.main.c:78 ../raster3d/base/r3.null.main.c:205
-#: ../raster3d/base/r3.timestamp.main.c:43 ../raster3d/base/r3.mask.main.c:153
-#: ../raster3d/r3.to.rast/main.c:215 ../raster3d/r3.cross.rast/main.c:270
+#: ../raster3d/r3.gwflow/main.c:169
+#: ../raster3d/r3.mkdspf/main.c:75
+#: ../raster3d/base/r3.info.main.c:78
+#: ../raster3d/base/r3.null.main.c:205
+#: ../raster3d/base/r3.timestamp.main.c:43
+#: ../raster3d/base/r3.mask.main.c:153
+#: ../raster3d/r3.to.rast/main.c:215
+#: ../raster3d/r3.cross.rast/main.c:270
#, fuzzy
msgid "raster3d, voxel"
#: ../raster3d/r3.gwflow/main.c:171
-msgid ""
-"Calculates numerically transient, confined groundwater flow in three "
-"dimensions."
+msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:189 ../raster/r.gwflow/main.c:240
+#: ../raster3d/r3.gwflow/main.c:189
+#: ../raster/r.gwflow/main.c:240
msgid "The direct LU solver do not work with sparse matrices"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:191 ../raster/r.gwflow/main.c:242
+#: ../raster3d/r3.gwflow/main.c:191
+#: ../raster/r.gwflow/main.c:242
msgid "The direct Gauss solver do not work with sparse matrices"
msgstr ""
@@ -877,7 +1247,8 @@
msgstr ""
# c-format
-#: ../raster3d/r3.gwflow/main.c:294 ../raster/r.gwflow/main.c:529
+#: ../raster3d/r3.gwflow/main.c:294
+#: ../raster/r.gwflow/main.c:529
#, fuzzy
msgid "Unable to create and solve the linear equation system"
msgstr "Impossible de créer la couche raster %s"
@@ -889,7 +1260,8 @@
# c-format
-#: ../raster3d/r3.gwflow/main.c:415 ../raster3d/base/r3.info.main.c:425
+#: ../raster3d/r3.gwflow/main.c:415
+#: ../raster3d/base/r3.info.main.c:425
#: ../raster3d/r3.cross.rast/main.c:404
#: ../raster3d/r3.out.vtk/errorHandling.c:67
#, fuzzy, c-format
@@ -897,12 +1269,8 @@
#: ../raster3d/r3.mkdspf/main.c:77
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Crée un affichage à partir d'une couche raster 3D existante à partir de "
-"seuils de valeur spécifiée"
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Crée un affichage à partir d'une couche raster 3D existante à partir de seuils de valeur spécifiée"
#: ../raster3d/r3.mkdspf/main.c:85
msgid "Name of an existing 3d raster map"
@@ -926,8 +1294,7 @@
#: ../raster3d/r3.mkdspf/main.c:116
msgid "Positive increment between isosurface levels"
-msgstr ""
-"Dénivelé (de valeur positive) entre les courbes de niveau des iso-surfaces"
+msgstr "Dénivelé (de valeur positive) entre les courbes de niveau des iso-surfaces"
#: ../raster3d/r3.mkdspf/main.c:123
msgid "Number of isosurface threshold levels"
@@ -984,23 +1351,28 @@
msgid "Number of decimal places for floats"
msgstr "Nombre de chiffres après la virgule"
-#: ../raster3d/r3.out.ascii/main.c:98 ../raster/r.what/main.c:117
+#: ../raster3d/r3.out.ascii/main.c:98
+#: ../raster/r.what/main.c:117
#: ../raster/r.transect/main.c:85
msgid "Char string to represent no data cell"
msgstr "Chaîne de caractère pour les cellules sans valeurs"
-#: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.out.arc/main.c:81
+#: ../raster3d/r3.out.ascii/main.c:103
+#: ../raster/r.out.arc/main.c:81
#: ../raster/r.out.ascii/main.c:104
msgid "Suppress printing of header information"
msgstr "Supprimer l'affichage des informations d'en-tête"
-#: ../raster3d/r3.out.ascii/main.c:107 ../raster3d/r3.to.rast/main.c:90
-#: ../raster3d/r3.cross.rast/main.c:110 ../raster/r.to.rast3elev/main.c:232
+#: ../raster3d/r3.out.ascii/main.c:107
+#: ../raster3d/r3.to.rast/main.c:90
+#: ../raster3d/r3.cross.rast/main.c:110
+#: ../raster/r.to.rast3elev/main.c:232
#, fuzzy
msgid "Use 3D raster mask (if exists) with input map"
-#: ../raster3d/r3.out.ascii/main.c:244 ../raster3d/r3.out.v5d/main.c:286
+#: ../raster3d/r3.out.ascii/main.c:244
+#: ../raster3d/r3.out.v5d/main.c:286
#: ../raster3d/r3.out.vtk/main.c:376
#, fuzzy
msgid "raster3d, voxel, export"
@@ -1011,23 +1383,34 @@
msgid "Converts a 3D raster map layer into an ASCII text file."
msgstr "Convertit une couche raster 3D en fichier texte ASCII."
-#: ../raster3d/r3.out.ascii/main.c:259 ../raster3d/base/r3.null.main.c:106
-#: ../raster3d/base/r3.mask.main.c:78 ../raster3d/r3.out.v5d/main.c:307
-#: ../raster3d/r3.to.rast/main.c:228 ../raster3d/r3.cross.rast/main.c:284
-#: ../raster3d/r3.out.vtk/main.c:143 ../raster3d/r3.out.vtk/main.c:153
-#: ../raster3d/r3.stats/main.c:611 ../raster/r.univar2/r3.univar_main.c:147
+#: ../raster3d/r3.out.ascii/main.c:259
+#: ../raster3d/base/r3.null.main.c:106
+#: ../raster3d/base/r3.mask.main.c:78
+#: ../raster3d/r3.out.v5d/main.c:307
+#: ../raster3d/r3.to.rast/main.c:228
+#: ../raster3d/r3.cross.rast/main.c:284
+#: ../raster3d/r3.out.vtk/main.c:143
+#: ../raster3d/r3.out.vtk/main.c:153
+#: ../raster3d/r3.stats/main.c:611
+#: ../raster/r.univar2/r3.univar_main.c:147
#: ../raster/r.univar2/r3.univar_main.c:186
-#: ../general/g.mremove/do_remove.c:55 ../general/g.region/main.c:507
+#: ../general/g.mremove/do_remove.c:55
+#: ../general/g.region/main.c:507
#, c-format
msgid "3D raster map <%s> not found"
msgstr "couche raster 3D <%s> non trouvée"
# c-format
-#: ../raster3d/r3.out.ascii/main.c:268 ../raster3d/base/r3.info.main.c:128
-#: ../raster3d/base/r3.null.main.c:113 ../raster3d/base/r3.mask.main.c:84
-#: ../raster3d/r3.out.v5d/main.c:312 ../raster3d/r3.cross.rast/main.c:318
-#: ../raster3d/r3.out.vtk/main.c:209 ../raster3d/r3.out.vtk/main.c:293
-#: ../raster3d/r3.out.vtk/main.c:517 ../raster3d/r3.stats/main.c:618
+#: ../raster3d/r3.out.ascii/main.c:268
+#: ../raster3d/base/r3.info.main.c:128
+#: ../raster3d/base/r3.null.main.c:113
+#: ../raster3d/base/r3.mask.main.c:84
+#: ../raster3d/r3.out.v5d/main.c:312
+#: ../raster3d/r3.cross.rast/main.c:318
+#: ../raster3d/r3.out.vtk/main.c:209
+#: ../raster3d/r3.out.vtk/main.c:293
+#: ../raster3d/r3.out.vtk/main.c:517
+#: ../raster3d/r3.stats/main.c:618
#: ../raster/r.univar2/r3.univar_main.c:154
#: ../raster/r.univar2/r3.univar_main.c:193
#, fuzzy, c-format
@@ -1045,7 +1428,8 @@
msgid "Adding rule: %lf - %lf"
msgstr "Ajout de la règle : %lf - %lf"
-#: ../raster3d/base/mask_functions.c:100 ../raster/r.null/null.c:266
+#: ../raster3d/base/mask_functions.c:100
+#: ../raster/r.null/null.c:266
#, fuzzy, c-format
msgid "%s: illegal value spec"
msgstr ""
@@ -1054,23 +1438,20 @@
#: ../raster3d/base/r3.info.main.c:80
msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-"Obtenir des informations générales à propos d'une couche raster 3D spécifiée "
-"par l'utilisateur."
+msgstr "Obtenir des informations générales à propos d'une couche raster 3D spécifiée par l'utilisateur."
#: ../raster3d/base/r3.info.main.c:87
msgid "Name of input 3D raster map"
msgstr "Nom de la couche raster 3D source"
-#: ../raster3d/base/r3.info.main.c:91 ../raster/r.info/main.c:77
+#: ../raster3d/base/r3.info.main.c:91
+#: ../raster/r.info/main.c:77
msgid "Print range only"
msgstr "Afficher uniquement l'intervalle"
#: ../raster3d/base/r3.info.main.c:96
msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr ""
-"Écrire uniquement la résolution de la couche raster 3D (NS-res, EW-res, Haut-"
-"Bas-res)"
+msgstr "Écrire uniquement la résolution de la couche raster 3D (NS-res, EW-res, Haut-Bas-res)"
#: ../raster3d/base/r3.info.main.c:100
msgid "Print 3D raster map type (float/double) only"
@@ -1087,34 +1468,43 @@
#: ../raster3d/base/r3.info.main.c:113
msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Afficher seulement l'étiquette date&heure du raster 3D (sous la forme jour."
-"mois.année heure:minute:secondes)"
+msgstr "Afficher seulement l'étiquette date&heure du raster 3D (sous la forme jour.mois.année heure:minute:secondes)"
#: ../raster3d/base/r3.info.main.c:121
#, fuzzy, c-format
msgid "3D Raster map <%s> not found"
-#: ../raster3d/base/r3.info.main.c:158 ../raster3d/base/r3.info.main.c:166
-#: ../raster3d/base/r3.info.main.c:172 ../raster3d/base/r3.info.main.c:177
-#: ../raster3d/base/r3.info.main.c:184 ../raster3d/base/r3.info.main.c:195
-#: ../raster3d/base/r3.info.main.c:201 ../raster3d/base/r3.info.main.c:217
-#: ../raster3d/base/r3.info.main.c:224 ../raster3d/base/r3.info.main.c:231
-#: ../raster3d/base/r3.info.main.c:236 ../raster3d/base/r3.info.main.c:241
-#: ../raster3d/base/r3.info.main.c:248 ../raster3d/base/r3.info.main.c:255
-#: ../raster3d/base/r3.info.main.c:265 ../raster3d/base/r3.info.main.c:275
-#: ../raster3d/base/r3.info.main.c:285 ../raster3d/base/r3.info.main.c:298
-#: ../raster3d/base/r3.info.main.c:308 ../raster3d/base/r3.info.main.c:313
-#: ../raster3d/base/r3.info.main.c:321 ../raster3d/base/r3.info.main.c:334
-#: ../raster/r.info/main.c:307 ../raster/r.info/main.c:433
+#: ../raster3d/base/r3.info.main.c:158
+#: ../raster3d/base/r3.info.main.c:166
+#: ../raster3d/base/r3.info.main.c:172
+#: ../raster3d/base/r3.info.main.c:177
+#: ../raster3d/base/r3.info.main.c:184
+#: ../raster3d/base/r3.info.main.c:195
+#: ../raster3d/base/r3.info.main.c:201
+#: ../raster3d/base/r3.info.main.c:217
+#: ../raster3d/base/r3.info.main.c:224
+#: ../raster3d/base/r3.info.main.c:231
+#: ../raster3d/base/r3.info.main.c:236
+#: ../raster3d/base/r3.info.main.c:241
+#: ../raster3d/base/r3.info.main.c:248
+#: ../raster3d/base/r3.info.main.c:255
+#: ../raster3d/base/r3.info.main.c:265
+#: ../raster3d/base/r3.info.main.c:275
+#: ../raster3d/base/r3.info.main.c:285
+#: ../raster3d/base/r3.info.main.c:298
+#: ../raster3d/base/r3.info.main.c:308
+#: ../raster3d/base/r3.info.main.c:313
+#: ../raster3d/base/r3.info.main.c:321
+#: ../raster3d/base/r3.info.main.c:334
+#: ../raster/r.info/main.c:307
+#: ../raster/r.info/main.c:433
msgid "Cannot allocate memory for string"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
# c-format
-#: ../raster3d/base/r3.info.main.c:287 ../raster3d/base/r3.info.main.c:349
+#: ../raster3d/base/r3.info.main.c:287
+#: ../raster3d/base/r3.info.main.c:349
#, fuzzy, c-format
msgid "Unable to read range of 3D raster map <%s>"
msgstr "Impossible d'écrire la couche raster lac <%s>!"
@@ -1128,11 +1518,13 @@
msgid "3d raster map for which to modify null values"
msgstr "Nom de la couche raster 3D où modifier les valeurs null"
-#: ../raster3d/base/r3.null.main.c:66 ../raster/r.null/null.c:70
+#: ../raster3d/base/r3.null.main.c:66
+#: ../raster/r.null/null.c:70
msgid "List of cell values to be set to NULL"
msgstr "Liste de valeurs de cellules auxquelles assigner la valeur NULL"
-#: ../raster3d/base/r3.null.main.c:73 ../raster/r.null/null.c:78
+#: ../raster3d/base/r3.null.main.c:73
+#: ../raster/r.null/null.c:78
msgid "The value to replace the null value by"
msgstr "Valeur à remplacer par la valeur null"
@@ -1143,9 +1535,7 @@
#: ../raster3d/base/r3.null.main.c:125
msgid "modifyNull: error opening tmp file"
-msgstr ""
-"modifyNull (modification des valeurs nulles) : erreur d'ouverture du fichier "
-"temporaire"
+msgstr "modifyNull (modification des valeurs nulles) : erreur d'ouverture du fichier temporaire"
#: ../raster3d/base/r3.null.main.c:174
msgid "modifyNull: error flushing tiles in cube"
@@ -1155,7 +1545,8 @@
msgid "modifyNull: error flushing all tiles"
msgstr "modifyNull : erreur dans le tuilage de la couche"
-#: ../raster3d/base/r3.null.main.c:188 ../raster/r.mapcalc/map.c:521
+#: ../raster3d/base/r3.null.main.c:188
+#: ../raster/r.mapcalc/map.c:521
#, fuzzy
msgid "Unable to close raster map"
msgstr "Impossible de fermer la couche de sortie"
@@ -1163,9 +1554,7 @@
#: ../raster3d/base/r3.null.main.c:190
#, fuzzy
msgid "modifyNull: Unable to close tmp file"
-msgstr ""
-"modifyNull (modification des valeurs nulles) : erreur dans la fermeture du "
-"fichier temporaire"
+msgstr "modifyNull (modification des valeurs nulles) : erreur dans la fermeture du fichier temporaire"
#: ../raster3d/base/r3.null.main.c:207
msgid "Explicitly create the 3D NULL-value bitmap file."
@@ -1174,9 +1563,7 @@
#: ../raster3d/base/r3.timestamp.main.c:45
#, fuzzy
msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr ""
-"Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une "
-"couche raster 3D"
+msgstr "Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une couche raster 3D"
#: ../raster3d/base/r3.timestamp.main.c:52
#, fuzzy
@@ -1289,20 +1676,19 @@
msgstr "Racine du nom des tranches rasters créées"
#: ../raster3d/r3.to.rast/main.c:95
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D outputmaps, "
-"independent of the current region settings"
-msgstr ""
-"Utiliser la même résolution que la carte raster 3D en entrée pour les cartes "
-"2D en sortie, indépendamment des réglages de la région courante"
+msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
+msgstr "Utiliser la même résolution que la carte raster 3D en entrée pour les cartes 2D en sortie, indépendamment des réglages de la région courante"
-#: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
-#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
+#: ../raster3d/r3.to.rast/main.c:152
+#: ../raster3d/r3.to.rast/main.c:159
+#: ../raster3d/r3.cross.rast/main.c:230
+#: ../raster3d/r3.cross.rast/main.c:237
#, fuzzy
msgid "Unable to write raster row"
-#: ../raster3d/r3.to.rast/main.c:194 ../raster3d/r3.cross.rast/main.c:77
+#: ../raster3d/r3.to.rast/main.c:194
+#: ../raster3d/r3.cross.rast/main.c:77
#: ../raster3d/r3.cross.rast/main.c:392
#, fuzzy
msgid "Unable to close output map"
@@ -1318,7 +1704,8 @@
msgid "Open 3D raster map <%s>"
msgstr "Ouvrir la couche g3d <%s>"
-#: ../raster3d/r3.to.rast/main.c:243 ../raster3d/r3.to.rast/main.c:284
+#: ../raster3d/r3.to.rast/main.c:243
+#: ../raster3d/r3.to.rast/main.c:284
#, fuzzy, c-format
msgid "Error opening 3D raster map <%s>"
msgstr ""
@@ -1327,28 +1714,39 @@
"#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
"Erreur à l'ouverture du fichier raster 3D <%s>"
-#: ../raster3d/r3.to.rast/main.c:267 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"Les réglages de région 2D et 3D sont différents. Utilisation des réglages de "
-"la fenêtre 2D pour ajuster la partie 2D de la région 3D."
+#: ../raster3d/r3.to.rast/main.c:267
+#: ../raster3d/r3.out.vtk/main.c:451
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de la fenêtre 2D pour ajuster la partie 2D de la région 3D."
-#: ../raster3d/r3.to.rast/main.c:299 ../raster/r.gwflow/main.c:350
-#: ../raster/r.to.rast3/main.c:236 ../raster/r.li/r.li.daemon/list.c:49
-#: ../imagery/i.smap/bouman/multialloc.c:115 ../imagery/i.ask/popup.c:174
-#: ../vector/v.net.centrality/main.c:265 ../vector/v.net.centrality/main.c:270
-#: ../vector/v.net.centrality/main.c:276 ../vector/v.net.centrality/main.c:282
-#: ../vector/v.net.centrality/main.c:288 ../vector/v.net.distance/main.c:168
-#: ../vector/v.edit/a2b.c:198 ../vector/v.mapcalc/list.c:54
-#: ../vector/v.mapcalc/list.c:501 ../vector/v.in.ascii/a2b.c:172
-#: ../vector/v.mkgrid/write_grid.c:131 ../vector/v.net.flow/main.c:214
-#: ../vector/v.surf.rst/main.c:887 ../vector/v.net.timetable/main.c:353
-#: ../vector/v.net.timetable/main.c:363 ../vector/v.net.allpairs/main.c:174
-#: ../vector/v.net.components/main.c:127 ../vector/v.generalize/point.c:121
-#: ../vector/v.generalize/matrix.c:145 ../vector/v.generalize/network.c:94
-#: ../vector/v.generalize/network.c:129 ../vector/v.generalize/smoothing.c:95
+#: ../raster3d/r3.to.rast/main.c:299
+#: ../raster/r.gwflow/main.c:350
+#: ../raster/r.to.rast3/main.c:236
+#: ../raster/r.li/r.li.daemon/list.c:49
+#: ../imagery/i.smap/bouman/multialloc.c:115
+#: ../imagery/i.ask/popup.c:174
+#: ../vector/v.net.centrality/main.c:265
+#: ../vector/v.net.centrality/main.c:270
+#: ../vector/v.net.centrality/main.c:276
+#: ../vector/v.net.centrality/main.c:282
+#: ../vector/v.net.centrality/main.c:288
+#: ../vector/v.net.distance/main.c:168
+#: ../vector/v.edit/a2b.c:198
+#: ../vector/v.mapcalc/list.c:54
+#: ../vector/v.mapcalc/list.c:501
+#: ../vector/v.in.ascii/a2b.c:172
+#: ../vector/v.mkgrid/write_grid.c:131
+#: ../vector/v.net.flow/main.c:214
+#: ../vector/v.surf.rst/main.c:887
+#: ../vector/v.net.timetable/main.c:353
+#: ../vector/v.net.timetable/main.c:363
+#: ../vector/v.net.allpairs/main.c:174
+#: ../vector/v.net.components/main.c:127
+#: ../vector/v.generalize/point.c:121
+#: ../vector/v.generalize/matrix.c:145
+#: ../vector/v.generalize/network.c:94
+#: ../vector/v.generalize/network.c:129
+#: ../vector/v.generalize/smoothing.c:95
#: ../vector/v.generalize/smoothing.c:152
#: ../vector/v.generalize/smoothing.c:253
#: ../vector/v.generalize/smoothing.c:377
@@ -1369,7 +1767,8 @@
msgid "Out of memory"
msgstr "Mémoire insuffisante"
-#: ../raster3d/r3.to.rast/main.c:302 ../raster3d/r3.cross.rast/main.c:349
+#: ../raster3d/r3.to.rast/main.c:302
+#: ../raster3d/r3.cross.rast/main.c:349
#: ../raster/r.to.rast3/main.c:239
msgid "Illegal output file name"
msgstr "Nom du fichier de sortie illégal"
@@ -1389,9 +1788,7 @@
#: ../raster3d/r3.to.rast/main.c:313
#, fuzzy, c-format
msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-msgstr ""
-"Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être "
-"écrasé!\n"
+msgstr "Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être écrasé!\n"
#: ../raster3d/r3.cross.rast/main.c:91
msgid "Input 3D raster map for cross section."
@@ -1412,20 +1809,12 @@
#: ../raster3d/r3.cross.rast/main.c:272
#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map."
-msgstr ""
-"Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir "
-"d'une couche de relief 2D"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
+msgstr "Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir d'une couche de relief 2D"
#: ../raster3d/r3.cross.rast/main.c:298
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"carte 3D pour ajuster la région 2D."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de carte 3D pour ajuster la région 2D."
# c-format
#: ../raster3d/r3.cross.rast/main.c:333
@@ -1444,7 +1833,8 @@
msgstr "La couche de sortie existe déjà. Ce fichier va être écrasé!\n"
# c-format
-#: ../raster3d/r3.cross.rast/main.c:358 ../raster3d/r3.cross.rast/main.c:364
+#: ../raster3d/r3.cross.rast/main.c:358
+#: ../raster3d/r3.cross.rast/main.c:364
#, fuzzy
msgid "Unable to create raster map"
@@ -1457,8 +1847,7 @@
#: ../raster3d/r3.cross.rast/main.c:399
#, fuzzy
msgid "Wrong 3D raster map datatype! Unable to create raster map."
-msgstr ""
-"Erreur sur le type de raster G3D! Impossible de créer la couche raster."
+msgstr "Erreur sur le type de raster G3D! Impossible de créer la couche raster."
#: ../raster3d/r3.out.vtk/errorHandling.c:52
#, fuzzy
@@ -1494,15 +1883,14 @@
#: ../raster3d/r3.out.vtk/writeVTKData.c:462
#, fuzzy
msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-msgstr ""
-"Valeurs de couches G3D erronées! Les valeurs doivent être comprises entre 0 "
-"et 255!\n"
+msgstr "Valeurs de couches G3D erronées! Les valeurs doivent être comprises entre 0 et 255!\n"
#: ../raster3d/r3.out.vtk/parameters.c:30
msgid "G3D map(s) to be converted to VTK-ASCII data format"
msgstr "Couche(s) G3D à convertir au format de données VTK-ASCII"
-#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:38
+#: ../raster3d/r3.out.vtk/parameters.c:34
+#: ../raster/r.out.vtk/parameters.c:38
msgid "Name for VTK-ASCII output file"
msgstr "Nom du fichier VTK-ASCII en sortie"
@@ -1512,9 +1900,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:47
msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-"Créer des données points VTK à la place de données cellules VTK (par défaut, "
-"cellules)"
+msgstr "Créer des données points VTK à la place de données cellules VTK (par défaut, cellules)"
#: ../raster3d/r3.out.vtk/parameters.c:56
msgid "top surface 2D raster map"
@@ -1525,36 +1911,30 @@
msgstr "couche raster de surface 2D (couche inférieure)"
#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"Crée une sortie 3D en relief à partir de surface de dessus et de fond, les "
-"deux couches rasters sont requises."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
+msgstr "Crée une sortie 3D en relief à partir de surface de dessus et de fond, les deux couches rasters sont requises."
#: ../raster3d/r3.out.vtk/parameters.c:82
#, fuzzy
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-"3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,"
-"greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr "3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,greenmap,bluemap]"
#: ../raster3d/r3.out.vtk/parameters.c:92
#, fuzzy
msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:99 ../raster/r.out.vtk/parameters.c:93
+#: ../raster3d/r3.out.vtk/parameters.c:99
+#: ../raster/r.out.vtk/parameters.c:93
#: ../vector/v.out.vtk/main.c:75
msgid "Scale factor for elevation"
msgstr "Facteur d'échelle pour l'altitude"
#: ../raster3d/r3.out.vtk/parameters.c:112
-#: ../raster/r.out.vtk/parameters.c:105 ../raster/r.out.ascii/main.c:85
-#: ../display/d.rast.num/number.c:120 ../vector/v.out.ascii/out.c:76
+#: ../raster/r.out.vtk/parameters.c:105
+#: ../raster/r.out.ascii/main.c:85
+#: ../display/d.rast.num/number.c:120
+#: ../vector/v.out.ascii/out.c:76
#: ../vector/v.out.vtk/main.c:69
msgid "Number of significant digits (floating point only)"
msgstr "Nombre de chiffres significatifs (virgule flottante uniquement)"
@@ -1564,7 +1944,8 @@
msgstr "Le facteur d'échelle affecte l'origine"
#: ../raster3d/r3.out.vtk/parameters.c:128
-#: ../raster/r.out.vtk/parameters.c:135 ../vector/v.out.vtk/main.c:88
+#: ../raster/r.out.vtk/parameters.c:135
+#: ../vector/v.out.vtk/main.c:88
msgid "Correct the coordinates to fit the VTK-OpenGL precision"
msgstr "Corriger les coordonnés pour correspondre à la précision VTK-OpenGL"
@@ -1606,18 +1987,13 @@
#: ../raster3d/r3.out.vtk/main.c:178
#, fuzzy
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided. Will only write the "
-"geometry"
-msgstr ""
-"Aucune données g3d, couches RGB ou vecteur xyz n'ont été indiquées! On "
-"écrira uniquement la géométrie."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
+msgstr "Aucune données g3d, couches RGB ou vecteur xyz n'ont été indiquées! On écrira uniquement la géométrie."
#: ../raster3d/r3.out.vtk/main.c:211
#, fuzzy
msgid "No RGB Data will be created"
-msgstr ""
-"Erreur d'ouverture du fichier G3D <%s>. Aucune données RGB ne sera créée."
+msgstr "Erreur d'ouverture du fichier G3D <%s>. Aucune données RGB ne sera créée."
#: ../raster3d/r3.out.vtk/main.c:295
#, fuzzy
@@ -1633,7 +2009,8 @@
msgid "failed to interpret dp as an integer"
msgstr "Echec pour interpréter dp comme valeur entière (integer)"
-#: ../raster3d/r3.out.vtk/main.c:391 ../raster/r.out.ascii/main.c:125
+#: ../raster3d/r3.out.vtk/main.c:391
+#: ../raster/r.out.ascii/main.c:125
msgid "dp has to be from 0 to 20"
msgstr "dp doit être compris entre 0 et 20"
@@ -1650,9 +2027,7 @@
#: ../raster3d/r3.out.vtk/main.c:546
#, fuzzy
msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"Erreur de fermeture de la couche de données G3D, le fichier VTK risque "
-"d'être incomplet."
+msgstr "Erreur de fermeture de la couche de données G3D, le fichier VTK risque d'être incomplet."
# c-format
#: ../raster3d/r3.out.vtk/main.c:561
@@ -1682,9 +2057,7 @@
#: ../raster3d/r3.in.ascii/main.c:90
msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Chaîne représentant les cellules de données NULL (utilisez 'none' si toutes "
-"les valeurs sont définies)"
+msgstr "Chaîne représentant les cellules de données NULL (utilisez 'none' si toutes les valeurs sont définies)"
#: ../raster3d/r3.in.ascii/main.c:174
#, c-format
@@ -1697,16 +2070,12 @@
#: ../raster3d/r3.in.ascii/main.c:209
#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
-"Des données subsistent dans le fichier en entrée après l'importation "
-"complète des données attendues. [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr "Des données subsistent dans le fichier en entrée après l'importation complète des données attendues. [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:242
#, fuzzy
-msgid ""
-"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
msgstr "Convertir un fichier raster ASCII en couche raster 3D (binaire)."
# c-format
@@ -1715,7 +2084,8 @@
msgid "Unable to close ASCII file"
msgstr "impossible d'ouvrir le fichier en entrée <%s>"
-#: ../raster3d/r3.stats/main.c:568 ../raster/r.univar2/r3.univar_main.c:100
+#: ../raster3d/r3.stats/main.c:568
+#: ../raster/r.univar2/r3.univar_main.c:100
#, fuzzy
msgid "raster3d, voxel, statistics"
msgstr "Statistiques de transition de classe."
@@ -1728,9 +2098,7 @@
#: ../raster3d/r3.stats/main.c:580
#, fuzzy
msgid "Number of subranges to collect stats from"
-msgstr ""
-"Nombres de chiffres après la virgule à prendre en compte pour constituer les "
-"statistiques"
+msgstr "Nombres de chiffres après la virgule à prendre en compte pour constituer les statistiques"
#: ../raster3d/r3.stats/main.c:586
msgid "Calculate statistics based on equal value groups"
@@ -1749,12 +2117,18 @@
msgid "Use draw mode for all loaded surfaces"
msgstr "Utiliser le mode dessin pour toutes les surfaces chargées"
-#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:130
-#: ../misc/m.nviz.image/args.c:139 ../misc/m.nviz.image/args.c:146
-#: ../misc/m.nviz.image/args.c:152 ../misc/m.nviz.image/args.c:160
-#: ../misc/m.nviz.image/args.c:169 ../misc/m.nviz.image/args.c:179
-#: ../misc/m.nviz.image/args.c:187 ../misc/m.nviz.image/args.c:197
-#: ../misc/m.nviz.image/args.c:205 ../misc/m.nviz.image/args.c:215
+#: ../misc/m.nviz.image/args.c:52
+#: ../misc/m.nviz.image/args.c:130
+#: ../misc/m.nviz.image/args.c:139
+#: ../misc/m.nviz.image/args.c:146
+#: ../misc/m.nviz.image/args.c:152
+#: ../misc/m.nviz.image/args.c:160
+#: ../misc/m.nviz.image/args.c:169
+#: ../misc/m.nviz.image/args.c:179
+#: ../misc/m.nviz.image/args.c:187
+#: ../misc/m.nviz.image/args.c:197
+#: ../misc/m.nviz.image/args.c:205
+#: ../misc/m.nviz.image/args.c:215
#, fuzzy
msgid "Surfaces"
msgstr "Variance de la somme"
@@ -1764,7 +2138,8 @@
msgid "Name for output image file (without extension)"
msgstr "Nom du fichier en sortie (ne PAS ajouter l'extension)"
-#: ../misc/m.nviz.image/args.c:90 ../misc/m.nviz.image/args.c:104
+#: ../misc/m.nviz.image/args.c:90
+#: ../misc/m.nviz.image/args.c:104
#: ../misc/m.nviz.image/args.c:114
#, fuzzy
msgid "Image"
@@ -1838,10 +2213,14 @@
msgid "Draw mode"
msgstr "Mode Pan"
-#: ../misc/m.nviz.image/args.c:231 ../misc/m.nviz.image/args.c:242
-#: ../misc/m.nviz.image/args.c:253 ../misc/m.nviz.image/args.c:265
-#: ../misc/m.nviz.image/args.c:277 ../misc/m.nviz.image/args.c:286
-#: ../misc/m.nviz.image/args.c:296 ../misc/m.nviz.image/args.c:526
+#: ../misc/m.nviz.image/args.c:231
+#: ../misc/m.nviz.image/args.c:242
+#: ../misc/m.nviz.image/args.c:253
+#: ../misc/m.nviz.image/args.c:265
+#: ../misc/m.nviz.image/args.c:277
+#: ../misc/m.nviz.image/args.c:286
+#: ../misc/m.nviz.image/args.c:296
+#: ../misc/m.nviz.image/args.c:526
#: ../misc/m.nviz.image/args.c:538
msgid "Draw"
msgstr "Dessiner"
@@ -1880,9 +2259,12 @@
msgid "Name of line vector overlay map(s)"
msgstr "Nom de la couche vecteur"
-#: ../misc/m.nviz.image/args.c:308 ../misc/m.nviz.image/args.c:319
-#: ../misc/m.nviz.image/args.c:330 ../misc/m.nviz.image/args.c:342
-#: ../misc/m.nviz.image/args.c:352 ../misc/m.nviz.image/args.c:364
+#: ../misc/m.nviz.image/args.c:308
+#: ../misc/m.nviz.image/args.c:319
+#: ../misc/m.nviz.image/args.c:330
+#: ../misc/m.nviz.image/args.c:342
+#: ../misc/m.nviz.image/args.c:352
+#: ../misc/m.nviz.image/args.c:364
#, fuzzy
msgid "Vector lines"
msgstr "Type de couche vecteur"
@@ -1916,9 +2298,12 @@
msgid "Name of point vector overlay map(s)"
msgstr "Nom de la couche vecteur 2D source"
-#: ../misc/m.nviz.image/args.c:376 ../misc/m.nviz.image/args.c:387
-#: ../misc/m.nviz.image/args.c:399 ../misc/m.nviz.image/args.c:410
-#: ../misc/m.nviz.image/args.c:423 ../misc/m.nviz.image/args.c:433
+#: ../misc/m.nviz.image/args.c:376
+#: ../misc/m.nviz.image/args.c:387
+#: ../misc/m.nviz.image/args.c:399
+#: ../misc/m.nviz.image/args.c:410
+#: ../misc/m.nviz.image/args.c:423
+#: ../misc/m.nviz.image/args.c:433
#, fuzzy
msgid "Vector points"
@@ -1952,8 +2337,10 @@
msgid "Viewpoint position (x,y model coordinates)"
msgstr "Coordonnées du point germe"
-#: ../misc/m.nviz.image/args.c:450 ../misc/m.nviz.image/args.c:461
-#: ../misc/m.nviz.image/args.c:471 ../misc/m.nviz.image/args.c:483
+#: ../misc/m.nviz.image/args.c:450
+#: ../misc/m.nviz.image/args.c:461
+#: ../misc/m.nviz.image/args.c:471
+#: ../misc/m.nviz.image/args.c:483
#: ../misc/m.nviz.image/args.c:504
msgid "Viewpoint"
msgstr "Point de vue"
@@ -1972,7 +2359,8 @@
msgid "Viewpoint twist angle (in degrees)"
msgstr "Angle d'anisotropie (en degrés)"
-#: ../misc/m.nviz.image/args.c:494 ../raster/r.out.vrml/main.c:70
+#: ../misc/m.nviz.image/args.c:494
+#: ../raster/r.out.vrml/main.c:70
#, fuzzy
msgid "Vertical exaggeration"
msgstr "Facteur d'échelle vertical"
@@ -1981,12 +2369,18 @@
msgid "Focus to point on surface (from SW corner in map units)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:513 ../misc/m.nviz.image/args.c:548
-#: ../misc/m.nviz.image/args.c:560 ../misc/m.nviz.image/args.c:570
-#: ../misc/m.nviz.image/args.c:578 ../misc/m.nviz.image/args.c:586
-#: ../misc/m.nviz.image/args.c:595 ../misc/m.nviz.image/args.c:605
-#: ../misc/m.nviz.image/args.c:613 ../misc/m.nviz.image/args.c:623
-#: ../misc/m.nviz.image/args.c:635 ../misc/m.nviz.image/args.c:645
+#: ../misc/m.nviz.image/args.c:513
+#: ../misc/m.nviz.image/args.c:548
+#: ../misc/m.nviz.image/args.c:560
+#: ../misc/m.nviz.image/args.c:570
+#: ../misc/m.nviz.image/args.c:578
+#: ../misc/m.nviz.image/args.c:586
+#: ../misc/m.nviz.image/args.c:595
+#: ../misc/m.nviz.image/args.c:605
+#: ../misc/m.nviz.image/args.c:613
+#: ../misc/m.nviz.image/args.c:623
+#: ../misc/m.nviz.image/args.c:635
+#: ../misc/m.nviz.image/args.c:645
#: ../misc/m.nviz.image/args.c:656
#, fuzzy
msgid "Volumes"
@@ -2062,8 +2456,10 @@
msgid "Cutting plane index (0-5)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:672 ../misc/m.nviz.image/args.c:681
-#: ../misc/m.nviz.image/args.c:690 ../misc/m.nviz.image/args.c:701
+#: ../misc/m.nviz.image/args.c:672
+#: ../misc/m.nviz.image/args.c:681
+#: ../misc/m.nviz.image/args.c:690
+#: ../misc/m.nviz.image/args.c:701
#: ../misc/m.nviz.image/args.c:712
#, fuzzy
msgid "Cutting planes"
@@ -2092,8 +2488,10 @@
msgid "Light position (x,y,z model coordinates)"
-#: ../misc/m.nviz.image/args.c:728 ../misc/m.nviz.image/args.c:734
-#: ../misc/m.nviz.image/args.c:743 ../misc/m.nviz.image/args.c:753
+#: ../misc/m.nviz.image/args.c:728
+#: ../misc/m.nviz.image/args.c:734
+#: ../misc/m.nviz.image/args.c:743
+#: ../misc/m.nviz.image/args.c:753
#, fuzzy
msgid "Lighting"
msgstr "Existant"
@@ -2112,18 +2510,16 @@
msgstr ""
#: ../misc/m.nviz.image/args.c:764
-msgid ""
-"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
-msgstr ""
-"no ; bordure Nord-Ouest ; ne ; bordure Nord-Est ; so ; bordure Sud-Ouest ; "
-"se ; bordure Sud-Est"
+msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr "no ; bordure Nord-Ouest ; ne ; bordure Nord-Est ; so ; bordure Sud-Ouest ; se ; bordure Sud-Est"
#: ../misc/m.nviz.image/args.c:768
#, fuzzy
msgid "Fringe edges"
msgstr "Écrire les sommets de lignes."
-#: ../misc/m.nviz.image/args.c:769 ../misc/m.nviz.image/args.c:775
+#: ../misc/m.nviz.image/args.c:769
+#: ../misc/m.nviz.image/args.c:775
#: ../misc/m.nviz.image/args.c:784
#, fuzzy
msgid "Fringe"
@@ -2140,12 +2536,11 @@
msgstr "Tracer le relief"
#: ../misc/m.nviz.image/args.c:796
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:798 ../misc/m.nviz.image/args.c:807
+#: ../misc/m.nviz.image/args.c:798
+#: ../misc/m.nviz.image/args.c:807
#: ../misc/m.nviz.image/args.c:814
#, fuzzy
msgid "Decoration"
@@ -2166,9 +2561,12 @@
msgid "At least one <%s> or <%s> required"
msgstr "Au moins <%s> ou <%s> requis"
-#: ../misc/m.nviz.image/args.c:876 ../misc/m.nviz.image/args.c:906
-#: ../misc/m.nviz.image/args.c:912 ../misc/m.nviz.image/args.c:918
-#: ../misc/m.nviz.image/args.c:924 ../misc/m.nviz.image/args.c:930
+#: ../misc/m.nviz.image/args.c:876
+#: ../misc/m.nviz.image/args.c:906
+#: ../misc/m.nviz.image/args.c:912
+#: ../misc/m.nviz.image/args.c:918
+#: ../misc/m.nviz.image/args.c:924
+#: ../misc/m.nviz.image/args.c:930
#: ../misc/m.nviz.image/args.c:936
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
@@ -2179,15 +2577,20 @@
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"
msgstr "Nombre d'attributs incohérent (<%s> %d: <%s> %d)"
-#: ../misc/m.nviz.image/args.c:952 ../misc/m.nviz.image/args.c:957
-#: ../misc/m.nviz.image/args.c:968 ../misc/m.nviz.image/args.c:975
-#: ../misc/m.nviz.image/args.c:982 ../misc/m.nviz.image/args.c:989
-#: ../misc/m.nviz.image/args.c:996 ../misc/m.nviz.image/args.c:1028
+#: ../misc/m.nviz.image/args.c:952
+#: ../misc/m.nviz.image/args.c:957
+#: ../misc/m.nviz.image/args.c:968
+#: ../misc/m.nviz.image/args.c:975
+#: ../misc/m.nviz.image/args.c:982
+#: ../misc/m.nviz.image/args.c:989
+#: ../misc/m.nviz.image/args.c:996
+#: ../misc/m.nviz.image/args.c:1028
#, c-format
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
-#: ../misc/m.nviz.image/args.c:1012 ../misc/m.nviz.image/args.c:1021
+#: ../misc/m.nviz.image/args.c:1012
+#: ../misc/m.nviz.image/args.c:1021
#, fuzzy, c-format
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d)"
msgstr "Nombre d'attributs incohérent (<%s/%s> %d: <%s> %d, <%s> %d"
@@ -2202,17 +2605,20 @@
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"
-#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:125
+#: ../misc/m.nviz.image/volume.c:42
+#: ../misc/m.nviz.image/volume.c:125
#, fuzzy, c-format
msgid "3d raster map <%s> not found"
-#: ../misc/m.nviz.image/volume.c:92 ../misc/m.nviz.image/volume.c:231
+#: ../misc/m.nviz.image/volume.c:92
+#: ../misc/m.nviz.image/volume.c:231
#, fuzzy, c-format
msgid "Error tokenize '%s'"
msgstr "Erreur à l'ouverture du canal %i"
-#: ../misc/m.nviz.image/volume.c:99 ../misc/m.nviz.image/volume.c:247
+#: ../misc/m.nviz.image/volume.c:99
+#: ../misc/m.nviz.image/volume.c:247
#, fuzzy, c-format
msgid "Volume set number %d is not available"
msgstr "Le fichier vecteur [%s] n'est pas disponible"
@@ -2222,15 +2628,19 @@
msgid "Unable to add isosurface (volume set %d)"
msgstr "Impossible de lire la ligne %i\n"
-#: ../misc/m.nviz.image/volume.c:113 ../misc/m.nviz.image/volume.c:131
-#: ../misc/m.nviz.image/volume.c:139 ../misc/m.nviz.image/volume.c:155
-#: ../misc/m.nviz.image/volume.c:162 ../misc/m.nviz.image/volume.c:173
+#: ../misc/m.nviz.image/volume.c:113
+#: ../misc/m.nviz.image/volume.c:131
+#: ../misc/m.nviz.image/volume.c:139
+#: ../misc/m.nviz.image/volume.c:155
+#: ../misc/m.nviz.image/volume.c:162
+#: ../misc/m.nviz.image/volume.c:173
#: ../misc/m.nviz.image/volume.c:180
#, fuzzy, c-format
msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
msgstr "Impossible de sélectionner des données dans la table attributaire"
-#: ../misc/m.nviz.image/volume.c:144 ../misc/m.nviz.image/surface.c:129
+#: ../misc/m.nviz.image/volume.c:144
+#: ../misc/m.nviz.image/surface.c:129
#, fuzzy, c-format
msgid "Color attribute not defined, using default <%s>"
msgstr "raster <%s> non trouvé"
@@ -2264,29 +2674,21 @@
#: ../misc/m.nviz.image/main.c:50
#, fuzzy
msgid "Creates a 3D rendering of GIS data."
-msgstr ""
-"Créer de nouveaux objets vecteurs (points) à partir de la table de la base "
-"de données contenant les coordonnées."
+msgstr "Créer de nouveaux objets vecteurs (points) à partir de la table de la base de données contenant les coordonnées."
#: ../misc/m.nviz.image/main.c:51
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-"Restitue en 3D des surfaces (données raster), des données vecteur 2D/3D, et "
-"des volumes (données raster 3D)."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "Restitue en 3D des surfaces (données raster), des données vecteur 2D/3D, et des volumes (données raster 3D)."
#: ../misc/m.nviz.image/main.c:134
#, c-format
msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-"Exagération verticale non fournie, utilisation de la valeur calculée %.0f"
+msgstr "Exagération verticale non fournie, utilisation de la valeur calculée %.0f"
#: ../misc/m.nviz.image/main.c:146
#, c-format
msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-"Hauteur de point de vue non fournie, utilisation de la valeur calculée %.0f"
+msgstr "Hauteur de point de vue non fournie, utilisation de la valeur calculée %.0f"
#: ../misc/m.nviz.image/main.c:229
#, fuzzy
@@ -2294,7 +2696,8 @@
msgstr "Lister les formats gérés en sor"
# c-format
-#: ../misc/m.nviz.image/main.c:231 ../imagery/i.cluster/main.c:346
+#: ../misc/m.nviz.image/main.c:231
+#: ../imagery/i.cluster/main.c:346
#, fuzzy, c-format
msgid "File <%s> created."
msgstr "Secteur %s créé!"
@@ -2316,7 +2719,8 @@
msgstr "La couche raster [%s] n'existe pas"
# c-format
-#: ../misc/m.nviz.image/surface.c:258 ../misc/m.nviz.image/surface.c:265
+#: ../misc/m.nviz.image/surface.c:258
+#: ../misc/m.nviz.image/surface.c:265
#, fuzzy, c-format
msgid "Unable to set draw mode for surface id %d"
msgstr "Impossible d'accéder à la ligne %d de la couche raster %s"
@@ -2332,12 +2736,8 @@
msgstr "Projection source"
#: ../misc/m.cogo/main.c:226
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Un utilitaire simple pour convertir des mesures de gisement et distance en "
-"coordonnées et vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Un utilitaire simple pour convertir des mesures de gisement et distance en coordonnées et vice versa."
#: ../misc/m.cogo/main.c:228
msgid "It assumes a cartesian coordinate system"
@@ -2372,7 +2772,8 @@
msgid "Couldn't open output file <%s>"
msgstr "impossible d'ouvrir le fichier vecteur <%s>"
-#: ../misc/m.cogo/main.c:305 ../misc/m.cogo/main.c:308
+#: ../misc/m.cogo/main.c:305
+#: ../misc/m.cogo/main.c:308
#, fuzzy
msgid "Converting starting coordinate pair"
msgstr "Utiliser les coordonnées du centre de la couche\n"
@@ -2387,45 +2788,47 @@
msgid "Supported Formats:\n"
-#: ../raster/r.external/main.c:83 ../raster/r.in.gdal/main.c:341
+#: ../raster/r.external/main.c:83
+#: ../raster/r.in.gdal/main.c:341
#, fuzzy
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-"Impossible de convertir l'information de projection de la couche de données "
-"au format GRASS pour vérification"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
+msgstr "Impossible de convertir l'information de projection de la couche de données au format GRASS pour vérification"
-#: ../raster/r.external/main.c:99 ../raster/r.in.gdal/main.c:357
+#: ../raster/r.external/main.c:99
+#: ../raster/r.in.gdal/main.c:357
#: ../vector/v.in.ogr/main.c:512
#, fuzzy
msgid "Over-riding projection check"
-#: ../raster/r.external/main.c:107 ../raster/r.in.gdal/main.c:367
+#: ../raster/r.external/main.c:107
+#: ../raster/r.in.gdal/main.c:367
#: ../vector/v.in.ogr/main.c:521
#, fuzzy
msgid ""
"Projection of dataset does not appear to match current location.\n"
"\n"
msgstr ""
-"La projection des données en entrée et le Secteur (location) courant "
-"semblent correspondre.\n"
+"La projection des données en entrée et le Secteur (location) courant semblent correspondre.\n"
"Poursuite de la procédure d'importation...\n"
# c-format
-#: ../raster/r.external/main.c:112 ../raster/r.in.gdal/main.c:372
+#: ../raster/r.external/main.c:112
+#: ../raster/r.in.gdal/main.c:372
#, fuzzy
msgid "Location PROJ_INFO is:\n"
msgstr "Secteur : %s\n"
-#: ../raster/r.external/main.c:123 ../raster/r.in.gdal/main.c:383
+#: ../raster/r.external/main.c:123
+#: ../raster/r.in.gdal/main.c:383
msgid "Dataset PROJ_INFO is:\n"
msgstr "Le PROJ_INFO du jeu de données est : \n"
# c-format
-#: ../raster/r.external/main.c:150 ../raster/r.in.gdal/main.c:410
-#: ../vector/v.in.ogr/main.c:537 ../vector/v.in.ogr/main.c:544
+#: ../raster/r.external/main.c:150
+#: ../raster/r.in.gdal/main.c:410
+#: ../vector/v.in.ogr/main.c:537
+#: ../vector/v.in.ogr/main.c:544
#, fuzzy
msgid "Import dataset PROJ_INFO is:\n"
@@ -2434,40 +2837,33 @@
#, fuzzy
msgid ""
"\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
"Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
-#: ../raster/r.external/main.c:175 ../raster/r.in.gdal/main.c:435
+#: ../raster/r.external/main.c:175
+#: ../raster/r.in.gdal/main.c:435
#, fuzzy
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
-"des données en entrée.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' des données en entrée.\n"
-#: ../raster/r.external/main.c:180 ../raster/r.in.gdal/main.c:440
+#: ../raster/r.external/main.c:180
+#: ../raster/r.in.gdal/main.c:440
#: ../vector/v.in.ogr/main.c:595
#, fuzzy
msgid "Projection of input dataset and current location appear to match"
msgstr ""
#: ../raster/r.external/main.c:202
#, fuzzy
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"La carte raster en entrée est pivotée - importation impossible. Vous pouvez "
-"utiliser 'gdalwarp' pour transformer la carte en \"North up\""
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "La carte raster en entrée est pivotée - importation impossible. Vous pouvez utiliser 'gdalwarp' pour transformer la carte en \"North up\""
-#: ../raster/r.external/main.c:264 ../raster/r.in.gdal/main.c:624
+#: ../raster/r.external/main.c:264
+#: ../raster/r.in.gdal/main.c:624
#: ../vector/v.in.ogr/main.c:1207
#, fuzzy
msgid "Default region for this location updated"
@@ -2476,7 +2872,8 @@
"Information de projection mise à jour!\n"
"\n"
-#: ../raster/r.external/main.c:267 ../raster/r.in.gdal/main.c:627
+#: ../raster/r.external/main.c:267
+#: ../raster/r.in.gdal/main.c:627
#: ../vector/v.in.ogr/main.c:1210
#, fuzzy
msgid "Region for the current mapset updated"
@@ -2548,9 +2945,12 @@
msgid "Link to raster map <%s> created"
msgstr "couche raster <%s> non trouvée"
-#: ../raster/r.external/main.c:520 ../raster/r.in.gridatb/main.c:41
-#: ../raster/r.in.arc/main.c:59 ../raster/r.in.bin/main.c:234
-#: ../raster/r.in.mat/main.c:92 ../raster/r.in.gdal/main.c:79
+#: ../raster/r.external/main.c:520
+#: ../raster/r.in.gridatb/main.c:41
+#: ../raster/r.in.arc/main.c:59
+#: ../raster/r.in.bin/main.c:234
+#: ../raster/r.in.mat/main.c:92
+#: ../raster/r.in.gdal/main.c:79
#: ../raster/r.in.poly/main.c:29
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
#, fuzzy
@@ -2567,12 +2967,18 @@
msgid "Raster file to be linked"
msgstr "Fichier raster à importer"
-#: ../raster/r.external/main.c:527 ../raster/r.external/main.c:537
-#: ../raster/r.recode/main.c:54 ../raster/r.colors/main.c:181
-#: ../raster/r.in.gdal/main.c:90 ../raster/r.in.gdal/main.c:94
-#: ../raster/r.out.gdal/main.c:148 ../raster/r.out.gdal/main.c:184
-#: ../display/d.rast.num/number.c:91 ../vector/v.in.ogr/main.c:116
-#: ../vector/v.in.ogr/main.c:120 ../vector/v.in.ascii/in.c:57
+#: ../raster/r.external/main.c:527
+#: ../raster/r.external/main.c:537
+#: ../raster/r.recode/main.c:54
+#: ../raster/r.colors/main.c:181
+#: ../raster/r.in.gdal/main.c:90
+#: ../raster/r.in.gdal/main.c:94
+#: ../raster/r.out.gdal/main.c:148
+#: ../raster/r.out.gdal/main.c:184
+#: ../display/d.rast.num/number.c:91
+#: ../vector/v.in.ogr/main.c:116
+#: ../vector/v.in.ogr/main.c:120
+#: ../vector/v.in.ascii/in.c:57
#: ../vector/v.select/args.c:50
#, fuzzy
msgid "Required"
@@ -2588,30 +2994,40 @@
msgid "Band to select (default: all)"
msgstr "Bande à sélectionner (par défaut : tout sélectionner)"
-#: ../raster/r.external/main.c:550 ../raster/r.in.arc/main.c:87
-#: ../raster/r.in.bin/main.c:277 ../raster/r.in.gdal/main.c:121
-#: ../raster/r.in.poly/main.c:44 ../raster/r.in.ascii/main.c:85
+#: ../raster/r.external/main.c:550
+#: ../raster/r.in.arc/main.c:87
+#: ../raster/r.in.bin/main.c:277
+#: ../raster/r.in.gdal/main.c:121
+#: ../raster/r.in.poly/main.c:44
+#: ../raster/r.in.ascii/main.c:85
msgid "Title for resultant raster map"
msgstr "Titre de la couche raster créée"
-#: ../raster/r.external/main.c:551 ../raster/r.in.gdal/main.c:122
-#: ../imagery/i.landsat.toar/main.c:86 ../imagery/i.landsat.toar/main.c:104
-#: ../imagery/i.landsat.toar/main.c:114 ../imagery/i.landsat.toar/main.c:123
-#: ../imagery/i.landsat.toar/main.c:131 ../imagery/i.landsat.toar/main.c:140
+#: ../raster/r.external/main.c:551
+#: ../raster/r.in.gdal/main.c:122
+#: ../imagery/i.landsat.toar/main.c:86
+#: ../imagery/i.landsat.toar/main.c:104
+#: ../imagery/i.landsat.toar/main.c:114
+#: ../imagery/i.landsat.toar/main.c:123
+#: ../imagery/i.landsat.toar/main.c:131
+#: ../imagery/i.landsat.toar/main.c:140
msgid "Metadata"
msgstr "Métadonnées"
-#: ../raster/r.external/main.c:556 ../raster/r.in.gdal/main.c:134
+#: ../raster/r.external/main.c:556
+#: ../raster/r.in.gdal/main.c:134
msgid "Override projection (use location's projection)"
msgstr "Ne pas tenir compte de la projection (utiliser celle du Secteur)"
-#: ../raster/r.external/main.c:560 ../raster/r.in.gdal/main.c:138
+#: ../raster/r.external/main.c:560
+#: ../raster/r.in.gdal/main.c:138
#: ../vector/v.in.ogr/main.c:231
#, fuzzy
msgid "Extend region extents based on new dataset"
msgstr "Étendre le Secteur actuel en fonction des données importés"
-#: ../raster/r.external/main.c:562 ../raster/r.in.gdal/main.c:140
+#: ../raster/r.external/main.c:562
+#: ../raster/r.in.gdal/main.c:140
#: ../vector/v.in.ogr/main.c:233
msgid "Also updates the default region if in the PERMANENT mapset"
msgstr ""
@@ -2620,38 +3036,65 @@
msgid "Require exact range"
msgstr ""
-#: ../raster/r.external/main.c:570 ../raster/r.in.gdal/main.c:144
+#: ../raster/r.external/main.c:570
+#: ../raster/r.in.gdal/main.c:144
#: ../vector/v.in.ogr/main.c:202
#, fuzzy
msgid "List supported formats and exit"
msgstr "Lister les formats gérés et quitter"
-#: ../raster/r.external/main.c:571 ../raster/r.stats/main.c:147
-#: ../raster/r.stats/main.c:152 ../raster/r.stats/main.c:157
-#: ../raster/r.stats/main.c:163 ../raster/r.stats/main.c:168
-#: ../raster/r.stats/main.c:173 ../raster/r.stats/main.c:178
-#: ../raster/r.stats/main.c:183 ../raster/r.sunmask/main.c:232
-#: ../raster/r.sunmask/main.c:238 ../raster/r.in.gdal/main.c:145
-#: ../raster/r.out.gdal/main.c:133 ../imagery/i.group/main.c:77
-#: ../imagery/i.group/main.c:83 ../general/g.proj/main.c:77
-#: ../general/g.proj/main.c:83 ../general/g.proj/main.c:89
-#: ../general/g.proj/main.c:95 ../general/g.proj/main.c:101
-#: ../general/g.proj/main.c:112 ../general/g.proj/main.c:117
-#: ../general/g.mapset/main.c:87 ../general/g.mlist/main.c:140
-#: ../general/g.mlist/main.c:145 ../general/g.mlist/main.c:150
-#: ../general/g.mlist/main.c:155 ../general/g.region/main.c:91
-#: ../general/g.region/main.c:97 ../general/g.region/main.c:102
-#: ../general/g.region/main.c:108 ../general/g.region/main.c:114
-#: ../general/g.region/main.c:120 ../general/g.region/main.c:126
-#: ../general/g.region/main.c:134 ../general/g.region/main.c:139
-#: ../general/g.region/main.c:145 ../general/g.region/main.c:150
-#: ../general/g.mapsets/main.c:98 ../general/g.mapsets/main.c:103
-#: ../vector/v.db.connect/main.c:81 ../vector/v.db.connect/main.c:86
-#: ../vector/v.db.connect/main.c:94 ../vector/v.db.connect/main.c:110
-#: ../vector/v.to.db/parse.c:104 ../vector/v.to.db/parse.c:109
-#: ../vector/v.to.db/parse.c:115 ../vector/v.info/main.c:75
-#: ../vector/v.info/main.c:81 ../vector/v.info/main.c:86
-#: ../vector/v.info/main.c:91 ../vector/v.info/main.c:96
+#: ../raster/r.external/main.c:571
+#: ../raster/r.stats/main.c:147
+#: ../raster/r.stats/main.c:152
+#: ../raster/r.stats/main.c:157
+#: ../raster/r.stats/main.c:163
+#: ../raster/r.stats/main.c:168
+#: ../raster/r.stats/main.c:173
+#: ../raster/r.stats/main.c:178
+#: ../raster/r.stats/main.c:183
+#: ../raster/r.sunmask/main.c:232
+#: ../raster/r.sunmask/main.c:238
+#: ../raster/r.in.gdal/main.c:145
+#: ../raster/r.out.gdal/main.c:133
+#: ../imagery/i.group/main.c:77
+#: ../imagery/i.group/main.c:83
+#: ../general/g.proj/main.c:77
+#: ../general/g.proj/main.c:83
+#: ../general/g.proj/main.c:89
+#: ../general/g.proj/main.c:95
+#: ../general/g.proj/main.c:101
+#: ../general/g.proj/main.c:112
+#: ../general/g.proj/main.c:117
+#: ../general/g.mapset/main.c:87
+#: ../general/g.mlist/main.c:140
+#: ../general/g.mlist/main.c:145
+#: ../general/g.mlist/main.c:150
+#: ../general/g.mlist/main.c:155
+#: ../general/g.region/main.c:91
+#: ../general/g.region/main.c:97
+#: ../general/g.region/main.c:102
+#: ../general/g.region/main.c:108
+#: ../general/g.region/main.c:114
+#: ../general/g.region/main.c:120
+#: ../general/g.region/main.c:126
+#: ../general/g.region/main.c:134
+#: ../general/g.region/main.c:139
+#: ../general/g.region/main.c:145
+#: ../general/g.region/main.c:150
+#: ../general/g.mapsets/main.c:98
+#: ../general/g.mapsets/main.c:103
+#: ../vector/v.db.connect/main.c:81
+#: ../vector/v.db.connect/main.c:86
+#: ../vector/v.db.connect/main.c:94
+#: ../vector/v.db.connect/main.c:110
+#: ../vector/v.to.db/parse.c:104
+#: ../vector/v.to.db/parse.c:109
+#: ../vector/v.to.db/parse.c:115
+#: ../vector/v.info/main.c:75
+#: ../vector/v.info/main.c:81
+#: ../vector/v.info/main.c:86
+#: ../vector/v.info/main.c:91
+#: ../vector/v.info/main.c:96
#: ../db/base/connect.c:52
#: ../locale/scriptstrings/g.extension_to_translate.c:9
msgid "Print"
@@ -2665,11 +3108,10 @@
#: ../raster/r.external/main.c:598
#, fuzzy
msgid "input= and source= are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
-#: ../raster/r.external/main.c:601 ../raster/r.in.gdal/main.c:222
+#: ../raster/r.external/main.c:601
+#: ../raster/r.in.gdal/main.c:222
#, fuzzy
msgid "Name for output raster map not specified"
msgstr ""
@@ -2683,7 +3125,8 @@
msgid "Unable to set window"
msgstr "Impossible de paramétrer la taille"
-#: ../raster/r.external/main.c:630 ../raster/r.in.gdal/main.c:446
+#: ../raster/r.external/main.c:630
+#: ../raster/r.in.gdal/main.c:446
#, fuzzy
msgid "Proceeding with import..."
@@ -2694,7 +3137,8 @@
msgstr "Le vecteur '%s' existe déjà."
# c-format
-#: ../raster/r.external/main.c:645 ../raster/r.in.gdal/main.c:472
+#: ../raster/r.external/main.c:645
+#: ../raster/r.in.gdal/main.c:472
#, fuzzy, c-format
msgid "Selected band (%d) does not exist"
@@ -2704,8 +3148,10 @@
msgid "Imagery group <%s> created"
-#: ../raster/r.bilinear/main.c:42 ../raster/r.resamp.stats/main.c:259
-#: ../raster/r.resamp.rst/main.c:156 ../raster/r.resample/main.c:54
+#: ../raster/r.bilinear/main.c:42
+#: ../raster/r.resamp.stats/main.c:259
+#: ../raster/r.resamp.rst/main.c:156
+#: ../raster/r.resample/main.c:54
#: ../raster/r.resamp.interp/main.c:72
#, fuzzy
msgid "raster, resample"
@@ -2715,31 +3161,35 @@
msgid "Bilinear interpolation utility for raster map layers."
msgstr "Outil d'interpolation bilinéaire pour couches raster."
-#: ../raster/r.bilinear/main.c:54 ../raster/r.bilinear/main.c:61
+#: ../raster/r.bilinear/main.c:54
+#: ../raster/r.bilinear/main.c:61
#, fuzzy
-msgid ""
-"Specific input value to be assigned to the north and/or south poles for "
-"longitude-latitude grids"
-msgstr ""
-"valeurs spécifiques qui seront assignées aux pôles nord et/ou sud pour des "
-"grilles données en latitude-longitude"
+msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
+msgstr "valeurs spécifiques qui seront assignées aux pôles nord et/ou sud pour des grilles données en latitude-longitude"
#: ../raster/r.bilinear/main.c:67
#, fuzzy
msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-msgstr ""
-"Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez "
-"l'instruction de mise en page cartographique \"scale\" à la place."
+msgstr "Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez l'instruction de mise en page cartographique \"scale\" à la place."
-#: ../raster/r.mode/main.c:50 ../raster/r.cross/main.c:75
-#: ../raster/r.statistics/main.c:42 ../raster/r.kappa/main.c:67
-#: ../raster/r.quantile/main.c:254 ../raster/r.support.stats/main.c:39
-#: ../raster/r.univar2/r.univar_main.c:97 ../raster/r.report/main.c:64
-#: ../raster/r.stats/main.c:103 ../raster/r.regression.line/main.c:42
-#: ../raster/r.sum/main.c:46 ../raster/r.median/main.c:46
-#: ../raster/r.surf.area/main.c:86 ../raster/r.neighbors/main.c:108
-#: ../raster/r.coin/main.c:66 ../raster/r.texture/main.c:74
-#: ../raster/r.covar/main.c:53 ../raster/r.surf.gauss/main.c:46
+#: ../raster/r.mode/main.c:50
+#: ../raster/r.cross/main.c:75
+#: ../raster/r.statistics/main.c:42
+#: ../raster/r.kappa/main.c:67
+#: ../raster/r.quantile/main.c:254
+#: ../raster/r.support.stats/main.c:39
+#: ../raster/r.univar2/r.univar_main.c:97
+#: ../raster/r.report/main.c:64
+#: ../raster/r.stats/main.c:103
+#: ../raster/r.regression.line/main.c:42
+#: ../raster/r.sum/main.c:46
+#: ../raster/r.median/main.c:46
+#: ../raster/r.surf.area/main.c:86
+#: ../raster/r.neighbors/main.c:108
+#: ../raster/r.coin/main.c:66
+#: ../raster/r.texture/main.c:74
+#: ../raster/r.covar/main.c:53
+#: ../raster/r.surf.gauss/main.c:46
#: ../raster/r.average/main.c:51
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
#, fuzzy
@@ -2747,12 +3197,8 @@
#: ../raster/r.mode/main.c:52
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Trouve la mode des valeurs d'une couche de couverture pour les zones "
-"définies par les catégories d'une couche de base."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trouve la mode des valeurs d'une couche de couverture pour les zones définies par les catégories d'une couche de base."
#: ../raster/r.mode/main.c:58
msgid "Base map to be reclassified"
@@ -2781,8 +3227,7 @@
#: ../raster/r.mode/main.c:97
#, fuzzy, c-format
msgid "%s: base map and output map must be different"
-msgstr ""
-"Les coordonnées des germes et la couche de sortie= doivent être fixées!"
+msgstr "Les coordonnées des germes et la couche de sortie= doivent être fixées!"
#: ../raster/r.mode/main.c:101
#, fuzzy, c-format
@@ -2801,14 +3246,11 @@
#: ../raster/r.profile/main.c:55
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Sort les valeurs de la couche raster à partir de ligne(s) définies par "
-"l'utilisateur"
+msgstr "Sort les valeurs de la couche raster à partir de ligne(s) définies par l'utilisateur"
#: ../raster/r.profile/main.c:66
msgid "Name of file for output (use output=- for stdout)"
-msgstr ""
-"Nom du fichier en sortie (utilisez output=- pour le flux de sortie stdout)"
+msgstr "Nom du fichier en sortie (utilisez output=- pour le flux de sortie stdout)"
#: ../raster/r.profile/main.c:74
#, fuzzy
@@ -2817,9 +3259,7 @@
#: ../raster/r.profile/main.c:81
msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-"Résolution utilisée pour le profil (par défaut = la résolution de la région "
-"courante)"
+msgstr "Résolution utilisée pour le profil (par défaut = la résolution de la région courante)"
#: ../raster/r.profile/main.c:88
msgid "Character to represent no data cell"
@@ -2827,14 +3267,12 @@
#: ../raster/r.profile/main.c:92
msgid "Interactively select End-Points"
-msgstr ""
-"Sélectionner de façon interactive les points de début et de fin du profil"
+msgstr "Sélectionner de façon interactive les points de début et de fin du profil"
-#: ../raster/r.profile/main.c:97 ../raster/r.transect/main.c:97
+#: ../raster/r.profile/main.c:97
+#: ../raster/r.transect/main.c:97
msgid "Output easting and northing in first two columns of four column output"
-msgstr ""
-"Sortie X et Y dans les deux premières colonnes d'un tableau de sortie à "
-"quatre colonnes"
+msgstr "Sortie X et Y dans les deux premières colonnes d'un tableau de sortie à quatre colonnes"
#: ../raster/r.profile/main.c:102
msgid "Output RRR:GGG:BBB color values for each profile point"
@@ -2851,12 +3289,18 @@
msgstr "Résolution"
# c-format
-#: ../raster/r.profile/main.c:157 ../raster/r.recode/main.c:93
-#: ../raster/r.out.arc/main.c:134 ../raster/r.out.ascii/main.c:172
-#: ../raster/r.cats/main.c:177 ../raster/r.out.ppm3/main.c:149
-#: ../display/d.nviz/main.c:204 ../general/g.transform/main.c:281
-#: ../general/g.pnmcomp/main.c:241 ../general/g.pnmcomp/main.c:258
-#: ../vector/v.out.ascii/out.c:169 ../vector/v.out.vtk/main.c:176
+#: ../raster/r.profile/main.c:157
+#: ../raster/r.recode/main.c:93
+#: ../raster/r.out.arc/main.c:134
+#: ../raster/r.out.ascii/main.c:172
+#: ../raster/r.cats/main.c:177
+#: ../raster/r.out.ppm3/main.c:149
+#: ../display/d.nviz/main.c:204
+#: ../general/g.transform/main.c:281
+#: ../general/g.pnmcomp/main.c:241
+#: ../general/g.pnmcomp/main.c:258
+#: ../vector/v.out.ascii/out.c:169
+#: ../vector/v.out.vtk/main.c:176
#, fuzzy, c-format
msgid "Unable to open file <%s>"
msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
@@ -2889,16 +3333,14 @@
#: ../raster/r.profile/main.c:209
#, fuzzy, c-format
msgid "Use mouse to select Start Point\n"
-msgstr ""
-"Utiliser la souris pour dimensionner et positionner le cartouche de légende"
+msgstr "Utiliser la souris pour dimensionner et positionner le cartouche de légende"
#: ../raster/r.profile/main.c:214
#, fuzzy, c-format
msgid ""
"\n"
"Use mouse to draw profile line\n"
-msgstr ""
#: ../raster/r.profile/main.c:215
#, fuzzy, c-format
@@ -2936,112 +3378,117 @@
msgid "Endpoint coordinates are outside of current region settings"
msgstr "%d points en dehors de la région courante"
-#: ../raster/r.profile/input.c:29 ../raster/r.profile/input.c:46
+#: ../raster/r.profile/input.c:29
+#: ../raster/r.profile/input.c:46
#: ../raster/r.profile/input.c:59
#, fuzzy
msgid "One coordinate pair per line, please"
msgstr "Un couple de coordonnées par ligne, svp."
-#: ../raster/r.sun2/main.c:227 ../raster/r.sun/main.c:173
+#: ../raster/r.sun2/main.c:227
+#: ../raster/r.sun/main.c:173
#, fuzzy
msgid "raster, sun energy"
-#: ../raster/r.sun2/main.c:228 ../raster/r.sun/main.c:174
+#: ../raster/r.sun2/main.c:228
+#: ../raster/r.sun/main.c:174
msgid "Solar irradiance and irradiation model."
msgstr ""
-#: ../raster/r.sun2/main.c:230 ../raster/r.sun/main.c:176
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-"Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi "
-"pour un jour donné, une latitude; des propriétés de surface et des "
-"conditions atmosphériques. Les paramètres solaires (par exemple, le lever du "
-"soleil, le coucher du soleil, la déclinaison, les radiations extra-"
-"terrestres, la durée du jour) sont sauvegardées dans un fichier texte local. "
-"Sinon, une heure locale peut être indiquée pour calculer des angles "
-"d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres "
-"portées par la topographie peuvent être pris en compte de façon optionnelle."
+#: ../raster/r.sun2/main.c:230
+#: ../raster/r.sun/main.c:176
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi pour un jour donné, une latitude; des propriétés de surface et des conditions atmosphériques. Les paramètres solaires (par exemple, le lever du soleil, le coucher du soleil, la déclinaison, les radiations extra-terrestres, la durée du jour) sont sauvegardées dans un fichier texte local. Sinon, une heure locale peut être indiquée pour calculer des angles d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres portées par la topographie peuvent être pris en compte de façon optionnelle."
-#: ../raster/r.sun2/main.c:244 ../raster/r.sun/main.c:206
+#: ../raster/r.sun2/main.c:244
+#: ../raster/r.sun/main.c:206
#: ../raster/r.horizon/main.c:225
msgid "Name of the input elevation raster map [meters]"
msgstr "Nom de la couche raster d'altitude (mètres)"
-#: ../raster/r.sun2/main.c:245 ../raster/r.sun2/main.c:254
-#: ../raster/r.sun2/main.c:263 ../raster/r.sun2/main.c:272
-#: ../raster/r.sun2/main.c:280 ../raster/r.sun2/main.c:289
-#: ../raster/r.sun2/main.c:299 ../raster/r.sun2/main.c:309
-#: ../raster/r.sun2/main.c:319 ../raster/r.sun2/main.c:329
-#: ../raster/r.sun2/main.c:338 ../raster/r.sun2/main.c:347
-#: ../raster/r.sun2/main.c:356 ../raster/r.sun2/main.c:364
-#: ../raster/r.sun2/main.c:372 ../raster/r.watershed/front/main.c:62
-#: ../raster/r.watershed/front/main.c:68 ../raster/r.watershed/front/main.c:74
-#: ../raster/r.watershed/front/main.c:83 ../raster/r.watershed/front/main.c:90
+#: ../raster/r.sun2/main.c:245
+#: ../raster/r.sun2/main.c:254
+#: ../raster/r.sun2/main.c:263
+#: ../raster/r.sun2/main.c:272
+#: ../raster/r.sun2/main.c:280
+#: ../raster/r.sun2/main.c:289
+#: ../raster/r.sun2/main.c:299
+#: ../raster/r.sun2/main.c:309
+#: ../raster/r.sun2/main.c:319
+#: ../raster/r.sun2/main.c:329
+#: ../raster/r.sun2/main.c:338
+#: ../raster/r.sun2/main.c:347
+#: ../raster/r.sun2/main.c:356
+#: ../raster/r.sun2/main.c:364
+#: ../raster/r.sun2/main.c:372
+#: ../raster/r.watershed/front/main.c:62
+#: ../raster/r.watershed/front/main.c:68
+#: ../raster/r.watershed/front/main.c:74
+#: ../raster/r.watershed/front/main.c:83
+#: ../raster/r.watershed/front/main.c:90
#: ../raster/r.watershed/front/main.c:151
-#: ../raster/r.watershed/front/main.c:159 ../raster/r.sun/main.c:207
-#: ../raster/r.sun/main.c:216 ../raster/r.sun/main.c:226
-#: ../raster/r.sun/main.c:235 ../raster/r.sun/main.c:243
-#: ../raster/r.sun/main.c:255 ../raster/r.sun/main.c:263
-#: ../raster/r.sun/main.c:275 ../raster/r.sun/main.c:282
-#: ../raster/r.sun/main.c:294 ../raster/r.sun/main.c:303
-#: ../raster/r.horizon/main.c:226 ../raster/r.horizon/main.c:235
-#: ../raster/r.horizon/main.c:243 ../raster/r.horizon/main.c:251
-#: ../raster/r.horizon/main.c:259 ../raster/r.horizon/main.c:267
-#: ../raster/r.horizon/main.c:275 ../raster/r.horizon/main.c:283
+#: ../raster/r.watershed/front/main.c:159
+#: ../raster/r.sun/main.c:207
+#: ../raster/r.sun/main.c:216
+#: ../raster/r.sun/main.c:226
+#: ../raster/r.sun/main.c:235
+#: ../raster/r.sun/main.c:243
+#: ../raster/r.sun/main.c:255
+#: ../raster/r.sun/main.c:263
+#: ../raster/r.sun/main.c:275
+#: ../raster/r.sun/main.c:282
+#: ../raster/r.sun/main.c:294
+#: ../raster/r.sun/main.c:303
+#: ../raster/r.horizon/main.c:226
+#: ../raster/r.horizon/main.c:235
+#: ../raster/r.horizon/main.c:243
+#: ../raster/r.horizon/main.c:251
+#: ../raster/r.horizon/main.c:259
+#: ../raster/r.horizon/main.c:267
+#: ../raster/r.horizon/main.c:275
+#: ../raster/r.horizon/main.c:283
#: ../raster/r.horizon/main.c:291
msgid "Input_options"
msgstr ""
-#: ../raster/r.sun2/main.c:253 ../raster/r.sun/main.c:215
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-"Nom de la couche d'aspect source (aspect du terrain ou azimut du panneau "
-"solaire) [degrés décimaux]"
+#: ../raster/r.sun2/main.c:253
+#: ../raster/r.sun/main.c:215
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr "Nom de la couche d'aspect source (aspect du terrain ou azimut du panneau solaire) [degrés décimaux]"
#: ../raster/r.sun2/main.c:262
#, fuzzy
msgid "A single value of the orientation (aspect), 270 is south"
msgstr "Valeur unique de latitude [degrés décimaux]"
-#: ../raster/r.sun2/main.c:271 ../raster/r.sun/main.c:225
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-"Nom de la couche raster source de pente (pente du terrain ou inclinaison du "
-"panneau solaire) [degrés décimaux]"
+#: ../raster/r.sun2/main.c:271
+#: ../raster/r.sun/main.c:225
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr "Nom de la couche raster source de pente (pente du terrain ou inclinaison du panneau solaire) [degrés décimaux]"
#: ../raster/r.sun2/main.c:279
#, fuzzy
msgid "A single value of inclination (slope)"
-#: ../raster/r.sun2/main.c:288 ../raster/r.sun/main.c:234
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-"Nom de la couche raster source pour le coefficient atmosphérique d'opacité "
-"de Linke"
+#: ../raster/r.sun2/main.c:288
+#: ../raster/r.sun/main.c:234
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr "Nom de la couche raster source pour le coefficient atmosphérique d'opacité de Linke"
-#: ../raster/r.sun2/main.c:298 ../raster/r.sun/main.c:245
+#: ../raster/r.sun2/main.c:298
+#: ../raster/r.sun/main.c:245
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
msgstr "Valeur unique du coefficient atmosphérique d'opacité de Linke [-]"
-#: ../raster/r.sun2/main.c:308 ../raster/r.sun/main.c:254
+#: ../raster/r.sun2/main.c:308
+#: ../raster/r.sun/main.c:254
msgid "Name of the ground albedo coefficient input raster map [-]"
msgstr "Nom de la couche raster source pour le coefficient d'albedo"
-#: ../raster/r.sun2/main.c:318 ../raster/r.sun/main.c:265
+#: ../raster/r.sun2/main.c:318
+#: ../raster/r.sun/main.c:265
msgid "A single value of the ground albedo coefficient [-]"
msgstr "Valeur unique pour le coefficient d'albedo terrestre [-]"
@@ -3070,17 +3517,22 @@
msgid "The horizon information input map prefix"
msgstr "Les informations de projection ne seront pas mises à jour."
-#: ../raster/r.sun2/main.c:371 ../raster/r.horizon/main.c:242
+#: ../raster/r.sun2/main.c:371
+#: ../raster/r.horizon/main.c:242
msgid "Angle step size for multidirectional horizon [degrees]"
msgstr "Pas angulaire pour l'horizon multidirectionnel [degrés]"
-#: ../raster/r.sun2/main.c:380 ../raster/r.sun/main.c:311
+#: ../raster/r.sun2/main.c:380
+#: ../raster/r.sun/main.c:311
msgid "Output incidence angle raster map (mode 1 only)"
msgstr "Couche raster en sortie pour l'angle d'incidence (mode 1 uniquement)"
-#: ../raster/r.sun2/main.c:381 ../raster/r.sun2/main.c:390
-#: ../raster/r.sun2/main.c:399 ../raster/r.sun2/main.c:408
-#: ../raster/r.sun2/main.c:417 ../raster/r.sun2/main.c:426
+#: ../raster/r.sun2/main.c:381
+#: ../raster/r.sun2/main.c:390
+#: ../raster/r.sun2/main.c:399
+#: ../raster/r.sun2/main.c:408
+#: ../raster/r.sun2/main.c:417
+#: ../raster/r.sun2/main.c:426
#: ../raster/r.watershed/front/main.c:97
#: ../raster/r.watershed/front/main.c:103
#: ../raster/r.watershed/front/main.c:110
@@ -3088,83 +3540,79 @@
#: ../raster/r.watershed/front/main.c:123
#: ../raster/r.watershed/front/main.c:130
#: ../raster/r.watershed/front/main.c:137
-#: ../raster/r.watershed/front/main.c:143 ../raster/r.sun/main.c:312
-#: ../raster/r.sun/main.c:321 ../raster/r.sun/main.c:330
-#: ../raster/r.sun/main.c:339 ../raster/r.sun/main.c:348
-#: ../raster/r.resamp.rst/main.c:183 ../raster/r.resamp.rst/main.c:191
-#: ../raster/r.resamp.rst/main.c:199 ../raster/r.resamp.rst/main.c:207
-#: ../raster/r.resamp.rst/main.c:215 ../raster/r.resamp.rst/main.c:223
-#: ../raster/r.resamp.rst/main.c:287 ../raster/r.horizon/main.c:300
-#: ../raster/r.horizon/main.c:310 ../raster/r.horizon/main.c:318
-#: ../vector/v.vol.rst/main.c:362 ../vector/v.vol.rst/main.c:379
-#: ../vector/v.vol.rst/main.c:389 ../vector/v.vol.rst/main.c:398
-#: ../vector/v.vol.rst/main.c:407 ../vector/v.vol.rst/main.c:416
+#: ../raster/r.watershed/front/main.c:143
+#: ../raster/r.sun/main.c:312
+#: ../raster/r.sun/main.c:321
+#: ../raster/r.sun/main.c:330
+#: ../raster/r.sun/main.c:339
+#: ../raster/r.sun/main.c:348
+#: ../raster/r.resamp.rst/main.c:183
+#: ../raster/r.resamp.rst/main.c:191
+#: ../raster/r.resamp.rst/main.c:199
+#: ../raster/r.resamp.rst/main.c:207
+#: ../raster/r.resamp.rst/main.c:215
+#: ../raster/r.resamp.rst/main.c:223
+#: ../raster/r.resamp.rst/main.c:287
+#: ../raster/r.horizon/main.c:300
+#: ../raster/r.horizon/main.c:310
+#: ../raster/r.horizon/main.c:318
+#: ../vector/v.vol.rst/main.c:362
+#: ../vector/v.vol.rst/main.c:379
+#: ../vector/v.vol.rst/main.c:389
+#: ../vector/v.vol.rst/main.c:398
+#: ../vector/v.vol.rst/main.c:407
+#: ../vector/v.vol.rst/main.c:416
#: ../vector/v.vol.rst/main.c:425
msgid "Output_options"
msgstr ""
-#: ../raster/r.sun2/main.c:389 ../raster/r.sun/main.c:320
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Fichier raster en sortie pour le rayonnement solaire [W.m-2] (mode 1) ou "
-"l'irradiation [Wh.m-2.day-1] (mode 2)"
+#: ../raster/r.sun2/main.c:389
+#: ../raster/r.sun/main.c:320
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Fichier raster en sortie pour le rayonnement solaire [W.m-2] (mode 1) ou l'irradiation [Wh.m-2.day-1] (mode 2)"
-#: ../raster/r.sun2/main.c:398 ../raster/r.sun/main.c:329
+#: ../raster/r.sun2/main.c:398
+#: ../raster/r.sun/main.c:329
msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr ""
-"Couche raster en sortie pour la durée d'ensoleillement [h] (mode 2 "
-"uniquement)"
+msgstr "Couche raster en sortie pour la durée d'ensoleillement [h] (mode 2 uniquement)"
-#: ../raster/r.sun2/main.c:407 ../raster/r.sun/main.c:338
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Couche raster en sortie pour le rayonnement diffus [W.m-2] (mode 1) ou "
-"l'irradiation diffuse [Wh.m-2.day-1] (mode 2)"
+#: ../raster/r.sun2/main.c:407
+#: ../raster/r.sun/main.c:338
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Couche raster en sortie pour le rayonnement diffus [W.m-2] (mode 1) ou l'irradiation diffuse [Wh.m-2.day-1] (mode 2)"
-#: ../raster/r.sun2/main.c:416 ../raster/r.sun/main.c:347
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Couche raster en sortie pour le rayonnement réfléchi [W.m-2] (mode 1) ou "
-"l'irradiation réfléchie [Wh.m-2.day-1] (mode 2)"
+#: ../raster/r.sun2/main.c:416
+#: ../raster/r.sun/main.c:347
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Couche raster en sortie pour le rayonnement réfléchi [W.m-2] (mode 1) ou l'irradiation réfléchie [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun2/main.c:425
#, fuzzy
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
-#: ../raster/r.sun2/main.c:432 ../raster/r.sun/main.c:354
+#: ../raster/r.sun2/main.c:432
+#: ../raster/r.sun/main.c:354
msgid "No. of day of the year (1-365)"
msgstr "Numéro du jour dans l'année (1-365)"
-#: ../raster/r.sun2/main.c:441 ../raster/r.sun/main.c:362
+#: ../raster/r.sun2/main.c:441
+#: ../raster/r.sun/main.c:362
msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-"Pas temporel pour calculer le rayonnement total sur une journée [heures "
-"décimales]"
+msgstr "Pas temporel pour calculer le rayonnement total sur une journée [heures décimales]"
-#: ../raster/r.sun2/main.c:448 ../raster/r.sun/main.c:369
+#: ../raster/r.sun2/main.c:448
+#: ../raster/r.sun/main.c:369
msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-"Valeur de la déclinaison (écrase la valeur calculée de façon interne) "
-"[radians]"
+msgstr "Valeur de la déclinaison (écrase la valeur calculée de façon interne) [radians]"
-#: ../raster/r.sun2/main.c:456 ../raster/r.sun/main.c:377
+#: ../raster/r.sun2/main.c:456
+#: ../raster/r.sun/main.c:377
msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-"Temps (solaire) local (à indiquer pour le mode 1 seulement) [heures "
-"décimales]"
+msgstr "Temps (solaire) local (à indiquer pour le mode 1 seulement) [heures décimales]"
-#: ../raster/r.sun2/main.c:479 ../raster/r.horizon/main.c:317
+#: ../raster/r.sun2/main.c:479
+#: ../raster/r.horizon/main.c:317
msgid "Sampling distance step coefficient (0.5-1.5)"
msgstr "Pas du coefficient d'échantillonnage (0.5-1.5)"
@@ -3176,18 +3624,22 @@
msgid "Civil time zone value, if none, the time will be local solar time"
msgstr ""
-#: ../raster/r.sun2/main.c:502 ../vector/v.buffer2/main.c:218
+#: ../raster/r.sun2/main.c:502
+#: ../vector/v.buffer2/main.c:218
#: ../vector/v.generalize/main.c:209
msgid "This does nothing. It is retained for backwards compatibility"
msgstr "Ceci ne fait rien. C'est maintenu pour la rétrocompatibilité "
-#: ../raster/r.sun2/main.c:503 ../vector/v.buffer2/main.c:216
-#: ../vector/v.buffer2/main.c:228 ../vector/v.build.polylines/main.c:134
+#: ../raster/r.sun2/main.c:503
+#: ../vector/v.buffer2/main.c:216
+#: ../vector/v.buffer2/main.c:228
+#: ../vector/v.build.polylines/main.c:134
#: ../vector/v.generalize/main.c:210
msgid "Unused"
msgstr "Inutilisé"
-#: ../raster/r.sun2/main.c:509 ../raster/r.sun/main.c:382
+#: ../raster/r.sun2/main.c:509
+#: ../raster/r.sun/main.c:382
msgid "Incorporate the shadowing effect of terrain"
msgstr "Intègre les effets d'ombres portées du relief"
@@ -3209,7 +3661,8 @@
msgid "Invalid civil time zone value"
msgstr "Valeur invalide de scalex"
-#: ../raster/r.sun2/main.c:592 ../raster/r.sun/main.c:408
+#: ../raster/r.sun2/main.c:592
+#: ../raster/r.sun/main.c:408
msgid "insol_time and incidout are incompatible options"
msgstr "insol_time et incidout ne sont pas compatibles"
@@ -3235,11 +3688,8 @@
msgstr "%s = %s -- doit être supérieur à zéro"
#: ../raster/r.sun2/main.c:610
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-"Si vous utilisez l'option horizon vous devez aussi fournir le paramètre "
-"'horizonstep'"
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr "Si vous utilisez l'option horizon vous devez aussi fournir le paramètre 'horizonstep'"
#: ../raster/r.sun2/main.c:616
#, fuzzy
@@ -3248,18 +3698,16 @@
#: ../raster/r.sun2/main.c:618
#, fuzzy
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
-msgstr ""
-"Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure "
-"locale donnée"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgstr "Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure locale donnée"
-#: ../raster/r.sun2/main.c:623 ../raster/r.sun/main.c:422
+#: ../raster/r.sun2/main.c:623
+#: ../raster/r.sun/main.c:422
msgid "incidout requires time parameter to be set"
msgstr "incidout demande de fixer le paramètre d'heure"
-#: ../raster/r.sun2/main.c:625 ../raster/r.sun/main.c:423
+#: ../raster/r.sun2/main.c:625
+#: ../raster/r.sun/main.c:423
msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr "Mode 2 : irradiation journalière cumulée pour un jour donné de l'année"
@@ -3268,44 +3716,47 @@
msgstr ""
#: ../raster/r.sun2/main.c:683
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-"Si vous souhaitez économiser de la mémoire et utiliser les ombres, vous "
-"devez utiliser des horizons pré-calculés."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr "Si vous souhaitez économiser de la mémoire et utiliser les ombres, vous devez utiliser des horizons pré-calculés."
-#: ../raster/r.sun2/main.c:728 ../display/d.where/main.c:93
-#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
+#: ../raster/r.sun2/main.c:728
+#: ../display/d.where/main.c:93
+#: ../general/g.region/printwindow.c:247
+#: ../general/g.region/printwindow.c:503
#: ../general/g.region/printwindow.c:622
msgid "Can't get projection info of current location"
-msgstr ""
-"Impossible d'obtenir les informations de projection pour le Secteur "
-"(location) courant"
+msgstr "Impossible d'obtenir les informations de projection pour le Secteur (location) courant"
-#: ../raster/r.sun2/main.c:732 ../raster/r.sun/main.c:475
-#: ../raster/r.horizon/main.c:482 ../display/d.where/main.c:96
-#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
+#: ../raster/r.sun2/main.c:732
+#: ../raster/r.sun/main.c:475
+#: ../raster/r.horizon/main.c:482
+#: ../display/d.where/main.c:96
+#: ../general/g.region/printwindow.c:250
+#: ../general/g.region/printwindow.c:506
#: ../general/g.region/printwindow.c:625
msgid "Can't get projection units of current location"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
-#: ../raster/r.sun2/main.c:736 ../raster/r.sun/main.c:479
-#: ../raster/r.horizon/main.c:486 ../ps/ps.map/do_geogrid.c:272
-#: ../display/d.where/main.c:99 ../display/d.grid/plot.c:294
-#: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
+#: ../raster/r.sun2/main.c:736
+#: ../raster/r.sun/main.c:479
+#: ../raster/r.horizon/main.c:486
+#: ../ps/ps.map/do_geogrid.c:272
+#: ../display/d.where/main.c:99
+#: ../display/d.grid/plot.c:294
+#: ../general/g.region/printwindow.c:253
+#: ../general/g.region/printwindow.c:509
#: ../general/g.region/printwindow.c:628
msgid "Can't get projection key values of current location"
-msgstr ""
-"Impossible d'obtenir les valeurs clefs de projection pour le Secteur "
+msgstr "Impossible d'obtenir les valeurs clefs de projection pour le Secteur (location) courant"
-#: ../raster/r.sun2/main.c:746 ../raster/r.sun/main.c:489
-#: ../raster/r.horizon/main.c:496 ../ps/ps.map/do_geogrid.c:278
-#: ../display/d.where/main.c:106 ../display/d.where/main.c:132
-#: ../display/d.grid/plot.c:301 ../display/d.grid/plot.c:328
+#: ../raster/r.sun2/main.c:746
+#: ../raster/r.sun/main.c:489
+#: ../raster/r.horizon/main.c:496
+#: ../ps/ps.map/do_geogrid.c:278
+#: ../display/d.where/main.c:106
+#: ../display/d.where/main.c:132
+#: ../display/d.grid/plot.c:301
+#: ../display/d.grid/plot.c:328
msgid "Unable to set up lat/long projection parameters"
msgstr "Impossible de fixer les paramètres de projection longitude/latitude"
@@ -3360,8 +3811,7 @@
msgid "SECTION 1b (of %1d): Determining Offmap Flow."
msgstr ""
"\n"
-"SECTION 1b (de %1d): Détermination du courant hors carte. Achevé "
-"(pourcentage): "
+"SECTION 1b (de %1d): Détermination du courant hors carte. Achevé (pourcentage): "
#: ../raster/r.watershed/ram/sg_factor.c:13
#: ../raster/r.watershed/seg/sg_factor.c:12
@@ -3382,7 +3832,8 @@
msgid "heapsize too large"
msgstr "heapsize trop élevée"
-#: ../raster/r.watershed/ram/do_cum.c:16 ../raster/r.watershed/seg/do_cum.c:17
+#: ../raster/r.watershed/ram/do_cum.c:16
+#: ../raster/r.watershed/seg/do_cum.c:17
#, fuzzy
msgid "SECTION 3: Accumulating Surface Flow with SFD."
msgstr ""
@@ -3409,59 +3860,45 @@
msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
msgstr ""
-#: ../raster/r.watershed/ram/main.c:79 ../raster/r.watershed/ram/main.c:95
-#: ../raster/r.watershed/seg/main.c:84 ../raster/r.watershed/seg/main.c:95
+#: ../raster/r.watershed/ram/main.c:79
+#: ../raster/r.watershed/ram/main.c:95
+#: ../raster/r.watershed/seg/main.c:84
+#: ../raster/r.watershed/seg/main.c:95
#, fuzzy, c-format
msgid "SECTION %d: Closing Maps."
msgstr ""
"\n"
"SECTION %d: Fermeture des couches."
-#: ../raster/r.watershed/ram/main.c:93 ../raster/r.watershed/seg/main.c:93
+#: ../raster/r.watershed/ram/main.c:93
+#: ../raster/r.watershed/seg/main.c:93
#, fuzzy, c-format
msgid "SECTION %d: Watershed determination."
msgstr ""
"\n"
"SECTION %d: Détermination du bassin versant."
-#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
+#: ../raster/r.watershed/ram/usage.c:9
+#: ../raster/r.watershed/seg/usage.c:9
#, c-format
msgid ""
"USAGE for basin delineation:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
"\n"
"USAGE for ARMSED FILE creation:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-"ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
"\n"
"USAGE for slope length determination:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-"[de=depression_map] [ac=accumulation_map] [di=display_map] "
-"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
msgstr ""
"USAGE pour la délimitation du bassin versant:\n"
-"%s -4 el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] "
-"[dr=couche_direction_drainage] [de=couche_depression] "
-"[ac=couche_accumulation] [di=couche_affichage] ba=couche_bassin_versant "
-"[se=couche_segment_cours_d_eau]\n"
+"%s -4 el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] ba=couche_bassin_versant [se=couche_segment_cours_d_eau]\n"
"\n"
"USAGE pour la création du fichier ARMSED:\n"
-"%s [-4] el=couche_altitude t=seuil_depression_marecageuse "
-"[ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] "
-"[ac=couche_accumulation] [di=couche_affichage] [ba=couche_bassin_versant] "
-"[se=couche_segment_cours_d_eau] ha=couche_demi_bassin ar=nom_fichier_ARMSED\n"
+"%s [-4] el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] [ba=couche_bassin_versant] [se=couche_segment_cours_d_eau] ha=couche_demi_bassin ar=nom_fichier_ARMSED\n"
"\n"
"USAGE pour la détermination de longueur de pentes:\n"
-"[ac=couche_accumulation] [di=couche_affichage] [ms=longueur_max_pente] "
-"[ob=couche_obstacles] [S=couche_escarpement_pente] LS=couche_longueur_pentes "
-"[r=couche_erosion_ruissellement] [sd=depot_pente valeur ou couche]"
+"%s [-4] el=couche_altitude t=seuil_depression_marecageuse [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] [ms=longueur_max_pente] [ob=couche_obstacles] [S=couche_escarpement_pente] LS=couche_longueur_pentes [r=couche_erosion_ruissellement] [sd=depot_pente valeur ou couche]"
#: ../raster/r.watershed/ram/close_maps.c:30
#: ../raster/r.watershed/ram/close_maps.c:165
@@ -3506,11 +3943,8 @@
"SECTION 1 démarrage: initialisation des variables. %d du total des sections."
#: ../raster/r.watershed/seg/init_vars.c:150
-msgid ""
-"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-msgstr ""
-"La mémoire maximale allouée était inférieure à 3 MB, fixée par défaut à 300 "
-"MB."
+msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+msgstr "La mémoire maximale allouée était inférieure à 3 MB, fixée par défaut à 300 MB."
#: ../raster/r.watershed/seg/close_maps.c:52
#, fuzzy
@@ -3542,13 +3976,11 @@
#: ../raster/r.watershed/shed/com_line.c:30
msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-"En mode express, l'ordinateur bouclera l'exécution environ 10 fois plus vite"
+msgstr "En mode express, l'ordinateur bouclera l'exécution environ 10 fois plus vite"
#: ../raster/r.watershed/shed/com_line.c:31
msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-"qu'en mode lent, mais il ne permettra pas l'exécution d'autres programmes"
+msgstr "qu'en mode lent, mais il ne permettra pas l'exécution d'autres programmes"
#: ../raster/r.watershed/shed/com_line.c:32
msgid "at the same time. The fast mode also places all of the data into"
@@ -3556,26 +3988,19 @@
#: ../raster/r.watershed/shed/com_line.c:33
msgid "RAM, which limits the size of window that can be run. The slow"
-msgstr ""
-"RAM, ce qui limite la taille de la fenêtre que l'on peut utiliser. Le mode "
-"lent"
+msgstr "RAM, ce qui limite la taille de la fenêtre que l'on peut utiliser. Le mode lent"
#: ../raster/r.watershed/shed/com_line.c:34
msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-"utilise l'espace disque sur la même partition du disque dur que celle où "
-"GRASS est"
+msgstr "utilise l'espace disque sur la même partition du disque dur que celle où GRASS est"
#: ../raster/r.watershed/shed/com_line.c:35
msgid "stored. Thus, if the program does not work in the slow mode, you will"
-msgstr ""
-"installé. Par conséquent, si le programme ne fonctionne pas bien en mode "
-"lent, vous devrez"
+msgstr "installé. Par conséquent, si le programme ne fonctionne pas bien en mode lent, vous devrez"
#: ../raster/r.watershed/shed/com_line.c:36
msgid "need to remove unnecessary files from that partition. The slow mode"
-msgstr ""
-"enlever tous les fichiers superflus stockés sur cette partition. Le mode lent"
+msgstr "enlever tous les fichiers superflus stockés sur cette partition. Le mode lent"
#: ../raster/r.watershed/shed/com_line.c:37
#, c-format
@@ -3607,41 +4032,28 @@
"Une des options de %s est une cartes de dépressions. Une"
#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
-msgstr ""
-"carte de dépressions indique tous les endroits dans la fenêtre courante où"
+msgid "depression map indicates all the locations in the current map window where"
+msgstr "carte de dépressions indique tous les endroits dans la fenêtre courante où"
#: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
-msgstr ""
-"l'eau s'accumule et n'est pas draînée sur un des bords de la carte. Les lacs "
-"sans"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
+msgstr "l'eau s'accumule et n'est pas draînée sur un des bords de la carte. Les lacs sans"
#: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'. If you wish to"
-msgstr ""
-"cours d'eau de sortie ni drainage souterrain sont des exemples de "
-"'dépressions'. Si vous souhaitez"
+msgid "outlet streams and sinkholes are examples of `depressions'. If you wish to"
+msgstr "cours d'eau de sortie ni drainage souterrain sont des exemples de 'dépressions'. Si vous souhaitez"
#: ../raster/r.watershed/shed/com_line.c:86
msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-"construire une carte de dépressions, préparez une carte où les valeurs non "
-"nulles indiquent les"
+msgstr "construire une carte de dépressions, préparez une carte où les valeurs non nulles indiquent les"
#: ../raster/r.watershed/shed/com_line.c:87
msgid "locations where depressions occur.\n"
msgstr "emplacement des dépressions réelles.\n"
#: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-"Tapez juste <entrée> pour la question suivante s'il n'y a pas de carte de "
-"dépressions."
+msgid "Hit <return> by itself for the next question if there is no depression map."
+msgstr "Tapez juste <entrée> pour la question suivante s'il n'y a pas de carte de dépressions."
#: ../raster/r.watershed/shed/com_line.c:99
#, c-format
@@ -3653,81 +4065,50 @@
"Le programme %s divisera la couche de relief en une série de"
#: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins. The number of watershed basins is indirectly determined"
-msgstr ""
-"bassins versants. Le nombre de bassins versants est déterminé de façon "
-"indirecte"
+msgid "watershed basins. The number of watershed basins is indirectly determined"
+msgstr "bassins versants. Le nombre de bassins versants est déterminé de façon indirecte"
#: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value. The basin threshold is the area necessary "
-"for"
-msgstr ""
-"par la valeur de `seuil de bassin'. Le seuil de bassin correspond à la "
-"valeur nécessaire pour"
+msgid "by the `basin threshold' value. The basin threshold is the area necessary for"
+msgstr "par la valeur de `seuil de bassin'. Le seuil de bassin correspond à la valeur nécessaire pour"
#: ../raster/r.watershed/shed/com_line.c:103
#, c-format
msgid "%s to define a unique watershed basin. This area only applies to"
-msgstr ""
-"que %s définisse un unique bassin versant. Cette zone s'applique uniquement "
-"aux"
+msgstr "que %s définisse un unique bassin versant. Cette zone s'applique uniquement aux"
#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'. An exterior drainage basin does not have any"
-msgstr ""
-"'bassins de drainage exogènes'. Un bassin de drainage exogène ne possède "
-"aucun autre"
+msgid "`exterior drainage basins'. An exterior drainage basin does not have any"
+msgstr "'bassins de drainage exogènes'. Un bassin de drainage exogène ne possède aucun autre"
#: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it. Interior drainage basin size is determined"
-msgstr ""
-"bassin de drainage interconnecté avec lui. La taille d'un bassin de drainage "
-"intérieur est déterminée"
+msgid "drainage basins flowing into it. Interior drainage basin size is determined"
+msgstr "bassin de drainage interconnecté avec lui. La taille d'un bassin de drainage intérieur est déterminée"
#: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-"par le courant de surface dans les tronçons de cours d'eau entre les "
-"confluences."
+msgid "by the surface flow going into stream segments between stream interceptions."
+msgstr "par le courant de surface dans les tronçons de cours d'eau entre les confluences."
#: ../raster/r.watershed/shed/com_line.c:108
#, c-format
msgid "Thus interior drainage basins can be of any size. The %s program"
-msgstr ""
-"Par conséquent, les bassins de drainage peuvent être de taille quelconque. "
-"Le programme %s"
+msgstr "Par conséquent, les bassins de drainage peuvent être de taille quelconque. Le programme %s"
#: ../raster/r.watershed/shed/com_line.c:110
msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-"permet aussi à l'utilisateur de mette en relation la taille du bassin au "
-"courant terrestre potentiel"
+msgstr "permet aussi à l'utilisateur de mette en relation la taille du bassin au courant terrestre potentiel"
#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-"(i.e., les zones avec de faibles capacités d'infiltration auront besoin de "
-"zones plus petites pour"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr "(i.e., les zones avec de faibles capacités d'infiltration auront besoin de zones plus petites pour"
#: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
-msgstr ""
-"développer des cours d'eau que les zones voisines possédant des taux élevés "
-"d'infiltration)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
+msgstr "développer des cours d'eau que les zones voisines possédant des taux élevés d'infiltration)."
#: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
-msgstr ""
-"L'utilisateur peut créer une couche avec des valeurs de courant "
-"potentielles, et"
+msgid "The user can create a map layer with potential overland flow values, and"
+msgstr "L'utilisateur peut créer une couche avec des valeurs de courant potentielles, et"
#: ../raster/r.watershed/shed/com_line.c:114
#, c-format
@@ -3757,8 +4138,7 @@
"How large an area (or how many overland flow units) must a drainage basin"
msgstr ""
"\n"
-"De quelle dimension (ou de combien d'unités de débit) doit être un bassin de "
-"drainage"
+"De quelle dimension (ou de combien d'unités de débit) doit être un bassin de drainage"
#: ../raster/r.watershed/shed/com_line.c:132
#, c-format
@@ -3847,8 +4227,7 @@
msgstr "une représentation de la couche d'accumulation). %s peut aussi"
#: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
msgstr "générer différentes variables dans le Revised Universal Soil Loss"
#: ../raster/r.watershed/shed/com_line.c:297
@@ -3866,22 +4245,15 @@
#: ../raster/r.watershed/shed/com_line.c:349
#, c-format
msgid "disturbed land. %s reflects this with an optional map layer or value"
-msgstr ""
-"un terrain accidenté. %s tient compte de cela grâce à une couche optionnelle "
-"ou une valeur"
+msgstr "un terrain accidenté. %s tient compte de cela grâce à une couche optionnelle ou une valeur"
#: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
-msgstr ""
-"dans laquelle la valeur indique le pourcentage de terrain accidenté à "
-"l'intérieur de cette cellule."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+msgstr "dans laquelle la valeur indique le pourcentage de terrain accidenté à l'intérieur de cette cellule."
#: ../raster/r.watershed/shed/com_line.c:352
msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr ""
-"Tapez <entrée> si vous ne disposez pas d'une couche montrant la topographie"
+msgstr "Tapez <entrée> si vous ne disposez pas d'une couche montrant la topographie"
#: ../raster/r.watershed/shed/com_line.c:364
msgid ""
@@ -3889,8 +4261,7 @@
"Type the value indicating the percent of disturbed land. This value will"
msgstr ""
"\n"
-"Tapez la valeur indiquant le pourcentage de terrain accidenté. Cette valeur "
-"va"
+"Tapez la valeur indiquant le pourcentage de terrain accidenté. Cette valeur va"
#: ../raster/r.watershed/shed/com_line.c:365
msgid "be used for every cell in the current region."
@@ -3911,32 +4282,25 @@
"Overland surface flow only occurs for a set distance before swales form."
msgstr ""
"\n"
-"Le courant de surface ne parcourt qu'une distance définie avant que ne se "
-"forment des dépressions marécageuses."
+"Le courant de surface ne parcourt qu'une distance définie avant que ne se forment des dépressions marécageuses."
#: ../raster/r.watershed/shed/com_line.c:380
#, c-format
msgid "Because of digital terrain model limitations, %s cannot pick up"
-msgstr ""
-"A cause d'insuffisances du Modèle Numérique de Terrain, %s ne peut distinguer"
+msgstr "A cause d'insuffisances du Modèle Numérique de Terrain, %s ne peut distinguer"
#: ../raster/r.watershed/shed/com_line.c:382
#, c-format
msgid "these swales. %s allows for an input (warning: kludge factor)"
-msgstr ""
-"ces dépressions marécageuses. %s permet d'ajouter une entrée (attention : "
-"facteur kludge)"
+msgstr "ces dépressions marécageuses. %s permet d'ajouter une entrée (attention : facteur kludge)"
#: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long. Normally,"
+msgid "that prevents the surface flow distance from getting too long. Normally,"
msgstr "qui empêche le parcours du courant d'être trop long. Normalement,"
#: ../raster/r.watershed/shed/com_line.c:385
msgid "maximum slope length is around 600 feet (about 183 meters)."
-msgstr ""
-"la longueur maximale de la pente est d'environ 600 pieds (soit à peu près "
-"183 mètres)."
+msgstr "la longueur maximale de la pente est d'environ 600 pieds (soit à peu près 183 mètres)."
#: ../raster/r.watershed/shed/com_line.c:400
msgid ""
@@ -3944,26 +4308,19 @@
"Roads, ditches, changes in ground cover, and other factors will stop"
msgstr ""
"\n"
-"Les routes, fossés, changements dans la couverture végétale, et d'autres "
-"facteurs vont interrompre"
+"Les routes, fossés, changements dans la couverture végétale, et d'autres facteurs vont interrompre"
#: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length. You may input a raster map indicating the locations of these"
-msgstr ""
-"la pente. Vous pouvez inclure une couche raster contenant les emplacements "
-"de ces"
+msgid "slope length. You may input a raster map indicating the locations of these"
+msgstr "la pente. Vous pouvez inclure une couche raster contenant les emplacements de ces"
#: ../raster/r.watershed/shed/com_line.c:402
msgid "blocking factors.\n"
msgstr "différents facteurs d'interruption.\n"
#: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-"Tapez juste <entrée> à la question suivante s'il n'y a pas de couche "
-"contenant des éléments d'interruption de pente."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
+msgstr "Tapez juste <entrée> à la question suivante s'il n'y a pas de couche contenant des éléments d'interruption de pente."
#: ../raster/r.watershed/shed/basin_maps.c:12
msgid ""
@@ -3977,20 +4334,16 @@
#: ../raster/r.watershed/shed/basin_maps.c:13
msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
-msgstr ""
-"dans le modèle d'érosion sols/hydrologie. Poursuivez le chargement de "
-"couches raster"
+msgstr "dans le modèle d'érosion sols/hydrologie. Poursuivez le chargement de couches raster"
#: ../raster/r.watershed/shed/basin_maps.c:14
msgid "layers, one at a time, until all desired map layers are in."
-msgstr ""
-"une par une, jusqu'à ce que toutes les couches nécessaires soient chargées."
+msgstr "une par une, jusqu'à ce que toutes les couches nécessaires soient chargées."
#: ../raster/r.watershed/shed/basin_maps.c:15
#, c-format
msgid "You can have %s include a list of categories in each."
-msgstr ""
-"%s peut vous fournir une liste des catégories de chacune d'entre elles."
+msgstr "%s peut vous fournir une liste des catégories de chacune d'entre elles."
#: ../raster/r.watershed/shed/basin_maps.c:17
#, c-format
@@ -4012,15 +4365,11 @@
#: ../raster/r.watershed/shed/basin_maps.c:38
msgid "basins. There are two possible methods of tabulating the information:"
-msgstr ""
-"bassins versants. Il existe deux méthodes possibles de mise en table de "
-"l'information :"
+msgstr "bassins versants. Il existe deux méthodes possibles de mise en table de l'information :"
#: ../raster/r.watershed/shed/basin_maps.c:39
msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-"1) en incluant seulement les données appartenant au bassin lui-même, ou 2) "
-"en utilisant"
+msgstr "1) en incluant seulement les données appartenant au bassin lui-même, ou 2) en utilisant"
#: ../raster/r.watershed/shed/basin_maps.c:40
msgid "data from the basin, and all basins upstream of it."
@@ -4079,9 +4428,7 @@
#: ../raster/r.watershed/shed/intro.c:10
#, c-format
msgid "%s also allows the user to prepare a report of map layers for each"
-msgstr ""
-"%s permet aussi à l'utilisateur de préparer un rapport sous forme de couches "
-"de données pour chaque"
+msgstr "%s permet aussi à l'utilisateur de préparer un rapport sous forme de couches de données pour chaque"
#: ../raster/r.watershed/shed/intro.c:12
#, c-format
@@ -4096,8 +4443,7 @@
#: ../raster/r.watershed/shed/intro.c:16
#, c-format
msgid "%s program. %s will then ask for map layers that will be"
-msgstr ""
-"programme %s. %s demandera alors les couches de données qui seront affectées"
+msgstr "programme %s. %s demandera alors les couches de données qui seront affectées"
#: ../raster/r.watershed/shed/intro.c:18
#, c-format
@@ -4119,10 +4465,10 @@
#: ../raster/r.watershed/shed/main.c:41
msgid "Slow version of water analysis program starting now"
-msgstr ""
-"Début de l'exécution du programme d'analyse hydrologique en version lente"
+msgstr "Début de l'exécution du programme d'analyse hydrologique en version lente"
-#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
+#: ../raster/r.watershed/shed/main.c:46
+#: ../raster/r.watershed/shed/main.c:55
#, c-format
msgid "<<%s>> command line failed"
msgstr "Echec de la ligne de commande <<%s>>"
@@ -4131,11 +4477,16 @@
msgid "unable to open output file"
msgstr "Impossible d'ouvrir le fichier de sortie"
-#: ../raster/r.watershed/front/main.c:56 ../raster/r.drain/main.c:94
-#: ../raster/r.topmodel/main.c:55 ../raster/r.gwflow/main.c:189
-#: ../raster/r.topidx/main.c:37 ../raster/r.fill.dir/main.c:84
-#: ../raster/r.water.outlet/main.c:47 ../raster/r.carve/main.c:77
-#: ../raster/r.basins.fill/main.c:53 ../raster/r.lake/main.c:150
+#: ../raster/r.watershed/front/main.c:56
+#: ../raster/r.drain/main.c:94
+#: ../raster/r.topmodel/main.c:55
+#: ../raster/r.gwflow/main.c:189
+#: ../raster/r.topidx/main.c:37
+#: ../raster/r.fill.dir/main.c:84
+#: ../raster/r.water.outlet/main.c:47
+#: ../raster/r.carve/main.c:77
+#: ../raster/r.basins.fill/main.c:53
+#: ../raster/r.lake/main.c:150
#: ../raster/r.flow/calc.c:411
#, fuzzy
msgid "raster, hydrology"
@@ -4159,9 +4510,7 @@
#: ../raster/r.watershed/front/main.c:79
msgid "Input map or value: percent of disturbed land, for USLE"
-msgstr ""
-"couche ou valeur d'entrée : pourcentage de terrain impacté par le "
-"glissement, pour USLE"
+msgstr "couche ou valeur d'entrée : pourcentage de terrain impacté par le glissement, pour USLE"
#: ../raster/r.watershed/front/main.c:88
msgid "Input map: terrain blocking overland surface flow, for USLE"
@@ -4169,8 +4518,7 @@
#: ../raster/r.watershed/front/main.c:95
msgid "Output map: number of cells that drain through each cell"
-msgstr ""
-"Couche de sortie : nombre de cellules qui s'écoulent dans d'autres cellules"
+msgstr "Couche de sortie : nombre de cellules qui s'écoulent dans d'autres cellules"
#: ../raster/r.watershed/front/main.c:101
msgid "Output map: drainage direction"
@@ -4194,9 +4542,7 @@
#: ../raster/r.watershed/front/main.c:135
msgid "Output map: slope length and steepness (LS) factor for USLE"
-msgstr ""
-"Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) "
-"pour USLE"
+msgstr "Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) pour USLE"
#: ../raster/r.watershed/front/main.c:141
msgid "Output map: slope steepness (S) factor for USLE"
@@ -4208,8 +4554,7 @@
#: ../raster/r.watershed/front/main.c:156
msgid "Input value: maximum length of surface flow, for USLE"
-msgstr ""
-"Valeur d'entrée : longueur maximum d'un écoulement de surface, pour USLE"
+msgstr "Valeur d'entrée : longueur maximum d'un écoulement de surface, pour USLE"
#: ../raster/r.watershed/front/main.c:166
#, fuzzy
@@ -4241,24 +4586,16 @@
msgstr "Activer l'option de mémoire étendue : le calcul est lent"
#: ../raster/r.watershed/front/main.c:193
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
-"Seulement nécessaire si les besoins de mémoire excèdent la RAM disponible ; "
-"voir le manuel pour calculer les besoins mémoire"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr "Seulement nécessaire si les besoins de mémoire excèdent la RAM disponible ; voir le manuel pour calculer les besoins mémoire"
#: ../raster/r.watershed/front/main.c:198
msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-"Utiliser une accumulation d'écoulement positive même pour les sous-"
-"estimations manifestes"
+msgstr "Utiliser une accumulation d'écoulement positive même pour les sous-estimations manifestes"
#: ../raster/r.watershed/front/main.c:200
msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-"Voir le manuel pour une description détaillée de la sortie d'accumulation "
-"d'écoulement"
+msgstr "Voir le manuel pour une description détaillée de la sortie d'accumulation d'écoulement"
#: ../raster/r.watershed/front/main.c:217
#, fuzzy
@@ -4276,8 +4613,7 @@
msgstr ""
"\n"
"Désolé, si aucune des options suivantes n'est fixée:\n"
-"\tbasin (bassin), stream (courant), half.basin (demi-bassin), slope (pente), "
-"ou 1s\n"
+"\tbasin (bassin), stream (courant), half.basin (demi-bassin), slope (pente), ou 1s\n"
"\tvous DEVEZ fournir une valeur pour le seuil du bassin (basin.threshold)."
#: ../raster/r.watershed/front/main.c:388
@@ -4311,15 +4647,18 @@
msgstr "Nom de fichier de sortie pour l'aspect"
# c-format
-#: ../raster/r.colors.out/main.c:91 ../raster/r.colors/main.c:390
+#: ../raster/r.colors.out/main.c:91
+#: ../raster/r.colors/main.c:390
#: ../raster/r.grow.distance/main.c:364
#, fuzzy, c-format
msgid "Unable to read color table for raster map <%s>"
msgstr "Impossible de créer la couche raster <%s>"
# c-format
-#: ../raster/r.colors.out/main.c:101 ../raster/r.out.png/r.out.png.c:233
-#: ../raster/r.out.pov/main.c:186 ../raster/r.out.mat/main.c:115
+#: ../raster/r.colors.out/main.c:101
+#: ../raster/r.out.png/r.out.png.c:233
+#: ../raster/r.out.pov/main.c:186
+#: ../raster/r.out.mat/main.c:115
#, c-format
msgid "Unable to open output file <%s>"
msgstr "impossible d'ouvrir le fichier en sortie <%s>"
@@ -4334,9 +4673,12 @@
msgid "Map coordinates of starting point(s) (E,N)"
msgstr "Les coordonnées XY du/des foyer(s) initial(aux)"
-#: ../raster/r.drain/main.c:110 ../raster/r.drain/main.c:116
-#: ../raster/r.cost/main.c:141 ../raster/r.cost/main.c:153
-#: ../raster/r.cost/main.c:162 ../raster/r.cost/main.c:212
+#: ../raster/r.drain/main.c:110
+#: ../raster/r.drain/main.c:116
+#: ../raster/r.cost/main.c:141
+#: ../raster/r.cost/main.c:153
+#: ../raster/r.cost/main.c:162
+#: ../raster/r.cost/main.c:212
msgid "Start"
msgstr "Démarrer"
@@ -4371,21 +4713,21 @@
msgid "Starting point %d is outside the current region"
msgstr "Le point de départ %d est en dehors de la région courante"
-#: ../raster/r.drain/main.c:187 ../raster/r.drain/main.c:228
+#: ../raster/r.drain/main.c:187
+#: ../raster/r.drain/main.c:228
#, fuzzy
msgid "Too many start points"
msgstr "Trop de points de départ."
-#: ../raster/r.drain/main.c:208 ../raster/r.cost/main.c:514
+#: ../raster/r.drain/main.c:208
+#: ../raster/r.cost/main.c:514
msgid "Failed to guess site file format"
msgstr "Echec pour définir le format du fichier de sites"
#: ../raster/r.drain/main.c:234
#, fuzzy, c-format
msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
-"La couche vectorielle de départ %s ne contient aucun point dans la région "
-"courante"
+msgstr "La couche vectorielle de départ %s ne contient aucun point dans la région courante"
#: ../raster/r.drain/main.c:240
msgid "No start/stop point(s) specified"
@@ -4397,17 +4739,22 @@
msgstr "Calcul des moyennes de classes..."
# c-format
-#: ../raster/r.drain/main.c:362 ../raster/r.drain/main.c:415
-#: ../raster/r.cost/main.c:925 ../raster/r.random.surface/save.c:100
-#: ../raster/r.composite/main.c:199 ../raster/r.random.cells/indep.c:137
+#: ../raster/r.drain/main.c:362
+#: ../raster/r.drain/main.c:415
+#: ../raster/r.cost/main.c:925
+#: ../raster/r.random.surface/save.c:100
+#: ../raster/r.composite/main.c:199
+#: ../raster/r.random.cells/indep.c:137
#: ../imagery/i.smap/shapiro/write_img.c:12
#, fuzzy, c-format
msgid "Writing raster map <%s>..."
msgstr "Couche raster %i créée \n"
# c-format
-#: ../raster/r.param.scale/open_files.c:26 ../raster/r.topidx/file_io.c:17
-#: ../raster/r.mfilter/perform.c:38 ../raster/r.mfilter.fp/perform.c:38
+#: ../raster/r.param.scale/open_files.c:26
+#: ../raster/r.topidx/file_io.c:17
+#: ../raster/r.mfilter/perform.c:38
+#: ../raster/r.mfilter.fp/perform.c:38
#: ../imagery/i.cca/main.c:185
#, fuzzy, c-format
msgid "Cannot open raster map <%s>"
@@ -4419,9 +4766,12 @@
# c-format
#: ../raster/r.param.scale/open_files.c:32
-#: ../raster/r.param.scale/open_files.c:36 ../raster/r.topidx/file_io.c:96
-#: ../raster/r.mfilter/perform.c:84 ../raster/r.mfilter.fp/perform.c:84
-#: ../raster/r.reclass/reclass.c:235 ../imagery/i.cca/main.c:191
+#: ../raster/r.param.scale/open_files.c:36
+#: ../raster/r.topidx/file_io.c:96
+#: ../raster/r.mfilter/perform.c:84
+#: ../raster/r.mfilter.fp/perform.c:84
+#: ../raster/r.reclass/reclass.c:235
+#: ../imagery/i.cca/main.c:191
#, fuzzy, c-format
msgid "Cannot create raster map <%s>"
msgstr "Impossible de créer la couche raster %s"
@@ -4448,14 +4798,8 @@
#: ../raster/r.param.scale/interface.c:56
#, fuzzy
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"Extrait les paramètres de terrain d'un Modèle Numérique d'Elévation (MNE). "
-"Utilise une approche multi-échelle en prenant des paramètres quadratiques "
-"sur une fenêtre de dimensions quelconques (par la méthode des moindres "
-"carrés)"
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "Extrait les paramètres de terrain d'un Modèle Numérique d'Elévation (MNE). Utilise une approche multi-échelle en prenant des paramètres quadratiques sur une fenêtre de dimensions quelconques (par la méthode des moindres carrés)"
#: ../raster/r.param.scale/interface.c:74
msgid "Output raster layer containing morphometric parameter"
@@ -4482,14 +4826,14 @@
msgid "Exponent for distance weighting (0.0-4.0)"
msgstr "Exponentielle pour la pondération des distances (0.0-4.0)"
-#: ../raster/r.param.scale/interface.c:114 ../raster/r.out.pov/main.c:157
+#: ../raster/r.param.scale/interface.c:114
+#: ../raster/r.out.pov/main.c:157
msgid "Vertical scaling factor"
msgstr "Facteur d'échelle vertical"
#: ../raster/r.param.scale/interface.c:120
msgid "Constrain model through central window cell"
-msgstr ""
-"Contrainte du modèle pour la cellule centrale de la fenêtre de traitement"
+msgstr "Contrainte du modèle pour la cellule centrale de la fenêtre de traitement"
#: ../raster/r.param.scale/interface.c:163
#, fuzzy
@@ -4507,14 +4851,15 @@
#: ../raster/r.in.gridatb/main.c:43
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-"Importer des fichiers GRIDATB.FOR (TOPMODEL) dans des couches raster GRASS"
+msgstr "Importer des fichiers GRIDATB.FOR (TOPMODEL) dans des couches raster GRASS"
-#: ../raster/r.in.gridatb/main.c:47 ../raster/r.out.gridatb/main.c:57
+#: ../raster/r.in.gridatb/main.c:47
+#: ../raster/r.out.gridatb/main.c:57
msgid "GRIDATB i/o map file"
msgstr "couche GRIDATB à importer"
-#: ../raster/r.in.gridatb/main.c:53 ../imagery/i.ifft/ifftmain.c:83
+#: ../raster/r.in.gridatb/main.c:53
+#: ../imagery/i.ifft/ifftmain.c:83
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:9
@@ -4539,11 +4884,13 @@
msgid "Setting window header failed"
msgstr "couche vecteur des points de départ"
-#: ../raster/r.in.gridatb/file_io.c:36 ../raster/r.out.gridatb/file_io.c:41
+#: ../raster/r.in.gridatb/file_io.c:36
+#: ../raster/r.out.gridatb/file_io.c:41
msgid "Rows changed"
msgstr "Les lignes ont changé"
-#: ../raster/r.in.gridatb/file_io.c:39 ../raster/r.out.gridatb/file_io.c:44
+#: ../raster/r.in.gridatb/file_io.c:39
+#: ../raster/r.out.gridatb/file_io.c:44
msgid "Cols changed"
msgstr "Les colonnes ont changé"
@@ -4593,15 +4940,12 @@
#: ../raster/r.support/modhead/modhead.c:86
#, c-format
msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-msgstr ""
-"[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête! "
-"Exécutez r.support sur [%s]."
+msgstr "[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête! Exécutez r.support sur [%s]."
#: ../raster/r.support/modhead/modhead.c:90
#, c-format
msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-msgstr ""
-"[%s] est une reclassification de [%s in %s] - impossible d'éditer l'en-tête!"
+msgstr "[%s] est une reclassification de [%s in %s] - impossible d'éditer l'en-tête!"
# c-format
#: ../raster/r.support/modhead/modhead.c:96
@@ -4678,12 +5022,8 @@
#: ../raster/r.support/modhead/modhead.c:271
#, c-format
-msgid ""
-"Header indicates %d row%s in the raster map, but the actual file format "
-"indicates %d row%s"
-msgstr ""
-"L'en-tête indique %d ligne%s dans le fichier de cellule, mais le format de "
-"fichier actuel indique %d ligne%s"
+msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
+msgstr "L'en-tête indique %d ligne%s dans le fichier de cellule, mais le format de fichier actuel indique %d ligne%s"
# c-format
#: ../raster/r.support/modhead/modhead.c:303
@@ -4720,9 +5060,7 @@
#: ../raster/r.support/modhead/ask_format.c:51
#, fuzzy, c-format
msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-msgstr ""
-"Lignes * colonnes * bits par cellule doivent être identique à la taille de "
-"fichier (%ld)"
+msgstr "Lignes * colonnes * bits par cellule doivent être identique à la taille de fichier (%ld)"
#: ../raster/r.support/modhead/ask_format.c:55
msgid "If you need help figuring them out, just hit ESC"
@@ -4795,17 +5133,17 @@
" Mise à jour du nombre de catégorie pour [%s]\n"
"\n"
-#: ../raster/r.support/front/front.c:54 ../raster/r.region/main.c:54
-#: ../raster/r.describe/main.c:59 ../raster/r.info/main.c:69
+#: ../raster/r.support/front/front.c:54
+#: ../raster/r.region/main.c:54
+#: ../raster/r.describe/main.c:59
+#: ../raster/r.info/main.c:69
#, fuzzy
msgid "raster, metadata"
msgstr "Importation vecteur complète"
#: ../raster/r.support/front/front.c:55
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Permet la création et/ou la modification des fichiers de gestion des couches "
-"rasters"
+msgstr "Permet la création et/ou la modification des fichiers de gestion des couches rasters"
#: ../raster/r.support/front/front.c:65
#, fuzzy
@@ -4814,8 +5152,7 @@
#: ../raster/r.support/front/front.c:73
msgid "Text to append to the next line of the map's metadata file"
-msgstr ""
-"Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
+msgstr "Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
#: ../raster/r.support/front/front.c:79
#, fuzzy
@@ -4841,12 +5178,14 @@
msgid "Text to use for data description or keyword(s)"
msgstr "Texte à utiliser pour la description des données ou mot(s)-clé"
-#: ../raster/r.support/front/front.c:114 ../raster/r.cats/main.c:78
+#: ../raster/r.support/front/front.c:114
+#: ../raster/r.cats/main.c:78
#, fuzzy
msgid "Raster map from which to copy category table"
msgstr "couche raster source pour la table de couleurs"
-#: ../raster/r.support/front/front.c:125 ../raster/r.cats/main.c:136
+#: ../raster/r.support/front/front.c:125
+#: ../raster/r.cats/main.c:136
#, fuzzy, c-format
msgid "Raster map <%s> not found in current mapset"
msgstr "couche vecteur <%s> introuvable"
@@ -4856,10 +5195,14 @@
msgid "Not enough room in history file"
msgstr "Pas assez de place dans le fichier historique"
-#: ../raster/r.support/front/front.c:230 ../raster/r.statistics/main.c:91
-#: ../raster/r.report/parse.c:264 ../raster/r.cats/main.c:155
-#: ../raster/r.cats/main.c:213 ../raster/r.mapcalc/map.c:92
-#: ../raster/r.mapcalc/map3.c:186 ../display/d.title/main.c:112
+#: ../raster/r.support/front/front.c:230
+#: ../raster/r.statistics/main.c:91
+#: ../raster/r.report/parse.c:264
+#: ../raster/r.cats/main.c:155
+#: ../raster/r.cats/main.c:213
+#: ../raster/r.mapcalc/map.c:92
+#: ../raster/r.mapcalc/map3.c:186
+#: ../display/d.title/main.c:112
#, fuzzy, c-format
msgid "Unable to read category file of raster map <%s@%s>"
msgstr "Editer le fichier de catégorie de [%s]?"
@@ -4912,24 +5255,21 @@
" it are treated by GRASS application programs as no data."
msgstr ""
"\n"
-"le fichier null de [%s] semble indiquer que certaines cellules ne "
-"contiennent\n"
-" pas de données. Si le fichier null de [%s] n'existe pas, les cellules de "
-"valeur zéro\n"
+"le fichier null de [%s] semble indiquer que certaines cellules ne contiennent\n"
+" pas de données. Si le fichier null de [%s] n'existe pas, les cellules de valeur zéro\n"
" sont traitées par les programmes GRASS comme sans données."
#: ../raster/r.support/front/front.c:308
#, c-format
msgid ""
"\n"
-"Do you want to create/reset the null file for [%s] so that null cell values "
-"are considered valid data? "
+"Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
msgstr ""
"\n"
-"Voulez-vous créer/réinitialiser le fichir null de [%s] pour que les cellules "
-"de valeur null soient considérées comme des données valides? "
+"Voulez-vous créer/réinitialiser le fichir null de [%s] pour que les cellules de valeur null soient considérées comme des données valides? "
-#: ../raster/r.support/front/front.c:317 ../raster/r.support/front/front.c:354
+#: ../raster/r.support/front/front.c:317
+#: ../raster/r.support/front/front.c:354
#, c-format
msgid "[%s] is a reclass of another map. Exiting."
msgstr "[%s] est la reclassification d'une autre couche. Sortie."
@@ -4961,7 +5301,8 @@
msgid "Removing null file for [%s]...\n"
msgstr "Suppression du fichier null pour [%s]...\n"
-#: ../raster/r.support/front/front.c:367 ../display/d.what.vect/main.c:172
+#: ../raster/r.support/front/front.c:367
+#: ../display/d.what.vect/main.c:172
msgid "Done."
msgstr "Terminé."
@@ -5016,8 +5357,7 @@
#: ../raster/r.topmodel/main.c:129
msgid "(i) Rainfall and potential evapotranspiration data file"
-msgstr ""
-"(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
+msgstr "(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
#: ../raster/r.topmodel/main.c:135
msgid "(o) Output file"
@@ -5033,9 +5373,7 @@
#: ../raster/r.topmodel/main.c:155
msgid "(i) OPTIONAL Output for given topographic index class"
-msgstr ""
-"(i)\tOPTIONNEL sortie pour une classe de valeurs topographiques indexées "
-"données"
+msgstr "(i)\tOPTIONNEL sortie pour une classe de valeurs topographiques indexées données"
#: ../raster/r.topmodel/main.c:163
msgid "Input data given for (o/i)"
@@ -5047,12 +5385,8 @@
msgstr "%s : ÉTAPE 1..."
#: ../raster/r.cross/main.c:77
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Crée le produit cartésien des valeurs de catégorie de plusieurs couches "
-"raster."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Crée le produit cartésien des valeurs de catégorie de plusieurs couches raster."
#: ../raster/r.cross/main.c:86
#, c-format
@@ -5063,36 +5397,51 @@
msgid "Non-zero data only"
msgstr "Données non nulles uniquement"
-#: ../raster/r.cross/main.c:100 ../raster/r.distance/parse.c:64
-#: ../raster/r.buffer/main.c:101 ../raster/r.contour/main.c:135
-#: ../raster/r.series/main.c:170 ../raster/r.clump/main.c:68
-#: ../raster/r.colors/main.c:249 ../raster/r.out.png/r.out.png.c:136
-#: ../raster/r.compress/main.c:82 ../raster/r.carve/main.c:116
-#: ../raster/r.describe/main.c:107 ../raster/r.out.ppm/main.c:69
-#: ../raster/r.out.ppm3/main.c:90 ../raster/r.neighbors/main.c:171
-#: ../raster/r.covar/main.c:67 ../imagery/i.smap/shapiro/parse.c:43
+#: ../raster/r.cross/main.c:100
+#: ../raster/r.distance/parse.c:64
+#: ../raster/r.buffer/main.c:101
+#: ../raster/r.contour/main.c:135
+#: ../raster/r.series/main.c:170
+#: ../raster/r.clump/main.c:68
+#: ../raster/r.colors/main.c:249
+#: ../raster/r.out.png/r.out.png.c:136
+#: ../raster/r.compress/main.c:82
+#: ../raster/r.carve/main.c:116
+#: ../raster/r.describe/main.c:107
+#: ../raster/r.out.ppm/main.c:69
+#: ../raster/r.out.ppm3/main.c:90
+#: ../raster/r.neighbors/main.c:171
+#: ../raster/r.covar/main.c:67
+#: ../imagery/i.smap/shapiro/parse.c:43
#: ../imagery/i.maxlik/main.c:95
msgid "Run quietly"
msgstr "Mode silencieux"
-#: ../raster/r.cross/main.c:107 ../raster/r.distance/parse.c:72
-#: ../raster/r.patch/main.c:87 ../raster/r.rescale.eq/main.c:107
-#: ../raster/r.buffer/main.c:110 ../raster/r.series/main.c:188
-#: ../raster/r.random.surface/init.c:109 ../raster/r.rescale/main.c:103
-#: ../raster/r.clump/main.c:77 ../raster/r.colors/main.c:258
-#: ../raster/r.out.png/r.out.png.c:159 ../raster/r.compress/main.c:90
-#: ../raster/r.carve/main.c:126 ../raster/r.describe/main.c:115
-#: ../raster/r.resample/main.c:90 ../raster/r.slope.aspect/main.c:301
-#: ../raster/r.to.vect/main.c:100 ../raster/r.out.ppm3/main.c:102
-#: ../raster/r.neighbors/main.c:292 ../raster/r.texture/main.c:221
-#: ../raster/r.covar/main.c:75 ../vector/v.mkgrid/main.c:141
+#: ../raster/r.cross/main.c:107
+#: ../raster/r.distance/parse.c:72
+#: ../raster/r.patch/main.c:87
+#: ../raster/r.rescale.eq/main.c:107
+#: ../raster/r.buffer/main.c:110
+#: ../raster/r.series/main.c:188
+#: ../raster/r.random.surface/init.c:109
+#: ../raster/r.rescale/main.c:103
+#: ../raster/r.clump/main.c:77
+#: ../raster/r.colors/main.c:258
+#: ../raster/r.out.png/r.out.png.c:159
+#: ../raster/r.compress/main.c:90
+#: ../raster/r.carve/main.c:126
+#: ../raster/r.describe/main.c:115
+#: ../raster/r.resample/main.c:90
+#: ../raster/r.slope.aspect/main.c:301
+#: ../raster/r.to.vect/main.c:100
+#: ../raster/r.out.ppm3/main.c:102
+#: ../raster/r.neighbors/main.c:292
+#: ../raster/r.texture/main.c:221
+#: ../raster/r.covar/main.c:75
+#: ../vector/v.mkgrid/main.c:141
#: ../vector/v.qcount/main.c:117
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Le drapeau '-q' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--"
-"quiet' à la place."
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
+msgstr "Le drapeau '-q' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--quiet' à la place."
#: ../raster/r.cross/main.c:122
#, fuzzy, c-format
@@ -5108,7 +5457,8 @@
msgid "%s: STEP 2 ..."
msgstr "%s : ÉTAPE 2..."
-#: ../raster/r.cross/main.c:194 ../raster/r.basins.fill/main.c:155
+#: ../raster/r.cross/main.c:194
+#: ../raster/r.basins.fill/main.c:155
#: ../raster/r.resample/main.c:152
#, fuzzy, c-format
msgid "Creating support files for <%s>..."
@@ -5136,16 +5486,18 @@
#: ../raster/r.distance/main.c:40
msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-"Trouve les points les plus proches entre objets dans deux couches raster"
+msgstr "Trouve les points les plus proches entre objets dans deux couches raster"
#: ../raster/r.distance/parse.c:41
msgid "Maps for computing inter-class distances"
msgstr "couches pour le calcul des distances inter-classe"
-#: ../raster/r.distance/parse.c:50 ../raster/r.stats/main.c:119
-#: ../raster/r.cats/main.c:72 ../vector/v.db.select/main.c:64
-#: ../db/base/select.c:214 ../locale/scriptstrings/r.tileset_to_translate.c:13
+#: ../raster/r.distance/parse.c:50
+#: ../raster/r.stats/main.c:119
+#: ../raster/r.cats/main.c:72
+#: ../vector/v.db.select/main.c:64
+#: ../db/base/select.c:214
+#: ../locale/scriptstrings/r.tileset_to_translate.c:13
msgid "Output field separator"
msgstr "Séparateur de champ en sortie"
@@ -5178,16 +5530,23 @@
msgid "Reading file"
msgstr "\rLecture du fichier '%s'"
-#: ../raster/r.out.mpeg/main.c:282 ../raster/r.out.mpeg/main.c:312
+#: ../raster/r.out.mpeg/main.c:282
+#: ../raster/r.out.mpeg/main.c:312
msgid "mpeg_encode ERROR"
msgstr "ERREUR mpeg_encode"
-#: ../raster/r.out.mpeg/main.c:384 ../raster/r.out.vtk/main.c:148
-#: ../raster/r.out.arc/main.c:60 ../raster/r.out.pov/main.c:121
-#: ../raster/r.out.tiff/r.out.tiff.c:99 ../raster/r.out.mat/main.c:64
-#: ../raster/r.out.bin/main.c:279 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.out.gdal/main.c:128 ../raster/r.out.gridatb/main.c:44
+#: ../raster/r.out.mpeg/main.c:384
+#: ../raster/r.out.vtk/main.c:148
+#: ../raster/r.out.arc/main.c:60
+#: ../raster/r.out.pov/main.c:121
+#: ../raster/r.out.tiff/r.out.tiff.c:99
+#: ../raster/r.out.mat/main.c:64
+#: ../raster/r.out.bin/main.c:279
+#: ../raster/r.out.ppm/main.c:54
+#: ../raster/r.out.ascii/main.c:59
+#: ../raster/r.out.ppm3/main.c:57
+#: ../raster/r.out.gdal/main.c:128
+#: ../raster/r.out.gridatb/main.c:44
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
msgid "raster, export"
@@ -5219,11 +5578,13 @@
"Convertir à la volée, en économisant l'espace disque\n"
"\t(nécessite r.out.ppm avec l'option stdout)"
-#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
+#: ../raster/r.out.mpeg/write.c:81
+#: ../raster/r.out.mpeg/write.c:178
msgid "Size mismatch error!"
msgstr "Erreur de correspondance de taille!"
-#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
+#: ../raster/r.out.mpeg/write.c:139
+#: ../raster/r.out.mpeg/write.c:181
msgid "Unable to open output file"
@@ -5231,21 +5592,18 @@
msgid "Unable to create temporary files."
msgstr "Impossible d'écrire les fichiers temporaires"
-#: ../raster/r.patch/main.c:53 ../raster/r.grow2/main.c:128
-#: ../raster/r.circle/dist.c:51 ../raster/r.digit/main.c:45
+#: ../raster/r.patch/main.c:53
+#: ../raster/r.grow2/main.c:128
+#: ../raster/r.circle/dist.c:51
+#: ../raster/r.digit/main.c:45
#: ../raster/r.grow.distance/main.c:148
#, fuzzy
msgid "raster, geometry"
#: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Crée une couche raster composite en utilisant des valeurs de catégories "
-"connues pour une (ou davantage) de couches raster afin de renseigner les "
-"zones de \"données nulles\" dans une autre couche raster"
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Crée une couche raster composite en utilisant des valeurs de catégories connues pour une (ou davantage) de couches raster afin de renseigner les zones de \"données nulles\" dans une autre couche raster"
#: ../raster/r.patch/main.c:62
msgid "Name of raster maps to be patched together"
@@ -5257,8 +5615,7 @@
#: ../raster/r.patch/main.c:77
msgid "Use zero (0) for transparency instead of NULL"
-msgstr ""
-"Utiliser la valeur zéro (0) pour la transparence à la place de la valeur NULL"
+msgstr "Utiliser la valeur zéro (0) pour la transparence à la place de la valeur NULL"
#: ../raster/r.patch/main.c:102
#, fuzzy
@@ -5271,7 +5628,8 @@
msgid "One or more input raster maps not found"
msgstr "%s - couche raster non trouvée"
-#: ../raster/r.patch/main.c:152 ../raster/r.series/main.c:261
+#: ../raster/r.patch/main.c:152
+#: ../raster/r.series/main.c:261
#: ../raster/r.slope.aspect/main.c:568
#, fuzzy
msgid "Percent complete..."
@@ -5291,9 +5649,7 @@
#: ../raster/r.quant/main.c:43
#, fuzzy
msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Cette routine produit un fichier de quantification pour une couche raster en "
-"virgule flottante."
+msgstr "Cette routine produit un fichier de quantification pour une couche raster en virgule flottante."
#: ../raster/r.quant/main.c:51
msgid "Base map to take quant rules from"
@@ -5408,21 +5764,16 @@
msgid "%s higher above pointer wrong"
msgstr "Hauteur de la caméra au-dessus du sol"
-#: ../raster/r.cost/main.c:124 ../raster/r.walk/main.c:174
+#: ../raster/r.cost/main.c:124
+#: ../raster/r.walk/main.c:174
#, fuzzy
msgid "raster, cost surface, cumulative costs"
msgstr "Couche relief raster à traiter"
#: ../raster/r.cost/main.c:126
#, fuzzy
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Produit une couche raster montrant le coût cumulé d'un déplacement entre "
-"différentes positions géographiques à partir d'une couche raster où la "
-"valeur de catégorie des cellules représente le coût."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Produit une couche raster montrant le coût cumulé d'un déplacement entre différentes positions géographiques à partir d'une couche raster où la valeur de catégorie des cellules représente le coût."
#: ../raster/r.cost/main.c:133
msgid "Name of raster map containing grid cell cost information"
@@ -5438,7 +5789,8 @@
msgid "Name of stop vector points map"
msgstr "Nom de la couche vecteur 2D source"
-#: ../raster/r.cost/main.c:147 ../raster/r.cost/main.c:171
+#: ../raster/r.cost/main.c:147
+#: ../raster/r.cost/main.c:171
#, fuzzy
msgid "Stop"
msgstr "Pente"
@@ -5467,59 +5819,65 @@
msgid "Optional maximum cumulative cost"
msgstr "Coût maximum cumulé (optionnel)"
-#: ../raster/r.cost/main.c:189 ../raster/r.walk/main.c:249
+#: ../raster/r.cost/main.c:189
+#: ../raster/r.walk/main.c:249
msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Coût assigné aux cellules vides. Par défaut, les cellules vides sont ignorées"
+msgstr "Coût assigné aux cellules vides. Par défaut, les cellules vides sont ignorées"
-#: ../raster/r.cost/main.c:198 ../raster/r.walk/main.c:257
+#: ../raster/r.cost/main.c:198
+#: ../raster/r.walk/main.c:257
#: ../raster/r.in.xyz/main.c:235
msgid "Percent of map to keep in memory"
msgstr "Pourcentage de la couche à garder en mémoire"
-#: ../raster/r.cost/main.c:203 ../raster/r.walk/main.c:299
+#: ../raster/r.cost/main.c:203
+#: ../raster/r.walk/main.c:299
msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr ""
-"Utiliser le \"mouvement du cavalier (aux échecs)\"; plus lent, mais plus "
-"précis"
+msgstr "Utiliser le \"mouvement du cavalier (aux échecs)\"; plus lent, mais plus précis"
#: ../raster/r.cost/main.c:207
#, fuzzy
msgid "Keep null values in output raster map"
msgstr "Garder les valeurs nulles dans la couche de sortie"
-#: ../raster/r.cost/main.c:211 ../raster/r.walk/main.c:307
+#: ../raster/r.cost/main.c:211
+#: ../raster/r.walk/main.c:307
msgid "Start with values in raster map"
msgstr "Démarrer avec les valeurs de la couche raster"
-#: ../raster/r.cost/main.c:217 ../raster/wildfire/r.ros/main.c:301
-#: ../raster/wildfire/r.spreadpath/main.c:110 ../display/d.vect/main.c:314
+#: ../raster/r.cost/main.c:217
+#: ../raster/wildfire/r.ros/main.c:301
+#: ../raster/wildfire/r.spreadpath/main.c:110
+#: ../display/d.vect/main.c:314
msgid "Run verbosely"
msgstr "Détails de l'exécution"
-#: ../raster/r.cost/main.c:238 ../raster/r.walk/main.c:322
-#: ../raster/wildfire/r.spread/main.c:338 ../raster/r.water.outlet/main.c:85
+#: ../raster/r.cost/main.c:238
+#: ../raster/r.walk/main.c:322
+#: ../raster/wildfire/r.spread/main.c:338
+#: ../raster/r.water.outlet/main.c:85
#, fuzzy
msgid "Unable to read current window parameters"
msgstr "Impossible de lire les paramètres de la fenêtre courante"
#: ../raster/r.cost/main.c:272
msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-"Vous devez précisément exactement des points de départ, un raster de départ "
-"ou des coordonnées"
+msgstr "Vous devez précisément exactement des points de départ, un raster de départ ou des coordonnées"
-#: ../raster/r.cost/main.c:277 ../raster/r.cost/main.c:547
+#: ../raster/r.cost/main.c:277
+#: ../raster/r.cost/main.c:547
#: ../raster/r.cost/main.c:653
msgid "No start points"
msgstr "Pas de points de départ"
-#: ../raster/r.cost/main.c:284 ../raster/r.walk/main.c:351
+#: ../raster/r.cost/main.c:284
+#: ../raster/r.walk/main.c:351
#, c-format
msgid "Inappropriate maximum cost: %d"
msgstr "Coût maximum inexact : %d"
-#: ../raster/r.cost/main.c:288 ../raster/r.walk/main.c:355
+#: ../raster/r.cost/main.c:288
+#: ../raster/r.walk/main.c:355
#, c-format
msgid "Inappropriate percent memory: %d"
msgstr "Pourcentage mémoire inexacte : %d"
@@ -5527,29 +5885,31 @@
#: ../raster/r.cost/main.c:306
#, fuzzy
msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Attention : coût négatif assigné aux cellules vides. Les cellules vides sont "
-"ignorées"
+msgstr "Attention : coût négatif assigné aux cellules vides. Les cellules vides sont ignorées"
-#: ../raster/r.cost/main.c:372 ../raster/r.walk/main.c:654
+#: ../raster/r.cost/main.c:372
+#: ../raster/r.walk/main.c:654
#, fuzzy
msgid "Creating some temporary files..."
msgstr "Création de fichiers temporaires..."
-#: ../raster/r.cost/main.c:393 ../raster/r.cost/main.c:620
-#: ../raster/r.series/main.c:214 ../raster/r.colors/stats.c:41
-#: ../raster/r.colors/stats.c:107 ../raster/r.grow.distance/main.c:259
-#: ../raster/r.surf.idw2/read_cell.c:38 ../raster/r.surf.idw/main.c:685
+#: ../raster/r.cost/main.c:393
+#: ../raster/r.cost/main.c:620
+#: ../raster/r.series/main.c:214
+#: ../raster/r.colors/stats.c:41
+#: ../raster/r.colors/stats.c:107
+#: ../raster/r.grow.distance/main.c:259
+#: ../raster/r.surf.idw2/read_cell.c:38
+#: ../raster/r.surf.idw/main.c:685
#, fuzzy, c-format
msgid "Reading raster map <%s>..."
msgstr "Lecteur du fichier raster..."
-#: ../raster/r.cost/main.c:419 ../raster/r.cost/main.c:437
+#: ../raster/r.cost/main.c:419
+#: ../raster/r.cost/main.c:437
#: ../raster/r.cost/main.c:456
#, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
msgstr ""
#: ../raster/r.cost/main.c:475
@@ -5562,16 +5922,17 @@
msgid "Failed to guess site file format\n"
-#: ../raster/r.cost/main.c:618 ../raster/r.texture/h_measure.c:770
+#: ../raster/r.cost/main.c:618
+#: ../raster/r.texture/h_measure.c:770
#: ../imagery/i.smap/bouman/interp.c:69
msgid "Unable to allocate memory"
msgstr "Impossible d'allouer de la mémoire"
-#: ../raster/r.cost/main.c:668 ../raster/r.walk/main.c:914
+#: ../raster/r.cost/main.c:668
+#: ../raster/r.walk/main.c:914
#, fuzzy
msgid "Specified starting location outside database window"
-msgstr ""
-"Secteur de départ spécifié en dehors de la fenêtre de la base de donnée"
+msgstr "Secteur de départ spécifié en dehors de la fenêtre de la base de donnée"
#: ../raster/r.cost/main.c:684
#, fuzzy
@@ -5583,7 +5944,8 @@
msgid "No data"
msgstr "Pas de table."
-#: ../raster/r.cost/main.c:913 ../raster/r.walk/main.c:1382
+#: ../raster/r.cost/main.c:913
+#: ../raster/r.walk/main.c:1382
msgid "Error, ct == pres_cell"
msgstr "Erreur, ct == pres_cell"
@@ -5592,33 +5954,34 @@
msgid "Peak cost value: %f."
msgstr "Valeur de coût maximum :%f"
-#: ../raster/r.cost/main.c:1076 ../raster/r.walk/main.c:1564
+#: ../raster/r.cost/main.c:1076
+#: ../raster/r.walk/main.c:1564
#, c-format
msgid "Illegal x coordinate <%s>"
msgstr "Coordonnée x illégale <%s>"
-#: ../raster/r.cost/main.c:1078 ../raster/r.walk/main.c:1566
+#: ../raster/r.cost/main.c:1078
+#: ../raster/r.walk/main.c:1566
#, c-format
msgid "Illegal y coordinate <%s>"
msgstr "Coordonnée y illégale <%s>"
-#: ../raster/r.cost/main.c:1082 ../raster/r.walk/main.c:1570
+#: ../raster/r.cost/main.c:1082
+#: ../raster/r.walk/main.c:1570
#, c-format
msgid "Warning, ignoring point outside window: %.4f,%.4f"
-msgstr ""
-"Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
+msgstr "Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
#: ../raster/r.grow2/main.c:130
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Produit une couche raster où les aires contiguës ont été agrandies d'une "
-"cellule."
+msgstr "Produit une couche raster où les aires contiguës ont été agrandies d'une cellule."
#: ../raster/r.grow2/main.c:141
msgid "Radius of buffer in raster cells"
msgstr "Rayon du buffer(zone-tampon) exprimé en nombre de cellules raster"
-#: ../raster/r.grow2/main.c:148 ../raster/r.grow.distance/main.c:168
+#: ../raster/r.grow2/main.c:148
+#: ../raster/r.grow.distance/main.c:168
msgid "Metric"
msgstr "Métrique"
@@ -5631,12 +5994,14 @@
msgstr "Valeurs à écrire pour les cellules \"développées\""
# c-format
-#: ../raster/r.grow2/main.c:199 ../raster/r.grow.distance/main.c:205
+#: ../raster/r.grow2/main.c:199
+#: ../raster/r.grow.distance/main.c:205
#, c-format
msgid "Unknown metric: [%s]."
msgstr "Métrique inconnue : [%s]"
-#: ../raster/r.grow2/main.c:212 ../raster/r.average/main.c:82
+#: ../raster/r.grow2/main.c:212
+#: ../raster/r.average/main.c:82
#, fuzzy, c-format
msgid "Error reading category file for <%s>"
msgstr "Erreur de lecture du fichier cats de <%s>"
@@ -5685,10 +6050,14 @@
msgid "write_vtk_structured_coordinates: Writing Coordinates"
msgstr "writeVTKStructuredCoordinates: Ecriture de coordonnées"
-#: ../raster/r.out.vtk/writeascii.c:184 ../raster/r.out.vtk/writeascii.c:245
-#: ../raster/r.out.vtk/writeascii.c:357 ../raster/r.out.vtk/writeascii.c:404
-#: ../raster/r.out.vtk/writeascii.c:408 ../raster/r.out.vtk/writeascii.c:412
-#: ../raster/r.out.vtk/writeascii.c:471 ../raster/r.out.vtk/writeascii.c:475
+#: ../raster/r.out.vtk/writeascii.c:184
+#: ../raster/r.out.vtk/writeascii.c:245
+#: ../raster/r.out.vtk/writeascii.c:357
+#: ../raster/r.out.vtk/writeascii.c:404
+#: ../raster/r.out.vtk/writeascii.c:408
+#: ../raster/r.out.vtk/writeascii.c:412
+#: ../raster/r.out.vtk/writeascii.c:471
+#: ../raster/r.out.vtk/writeascii.c:475
#: ../raster/r.out.vtk/writeascii.c:479
#, c-format
msgid "Unable to read row %i\n"
@@ -5711,9 +6080,7 @@
#: ../raster/r.out.vtk/writeascii.c:429
msgid "Wrong map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Valeurs de couches erronnées! Les valeurs doivent être comprises entre 0 et "
-"255!\n"
+msgstr "Valeurs de couches erronnées! Les valeurs doivent être comprises entre 0 et 255!\n"
#: ../raster/r.out.vtk/writeascii.c:459
#, fuzzy
@@ -5734,26 +6101,18 @@
msgstr "Altitude (si aucune couche d'altitude n'est fournie)"
#: ../raster/r.out.vtk/parameters.c:66
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-"Crée des données points VTK à la place des données cellules VTK (si aucune "
-"couche d'altitude n'est donnée)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr "Crée des données points VTK à la place des données cellules VTK (si aucune couche d'altitude n'est donnée)"
#: ../raster/r.out.vtk/parameters.c:76
#, fuzzy
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-"3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,"
-"greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr "3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,greenmap,bluemap]"
#: ../raster/r.out.vtk/parameters.c:86
#, fuzzy
msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
#: ../raster/r.out.vtk/parameters.c:111
msgid "Use structured grid for elevation (not recommended)"
@@ -5761,21 +6120,15 @@
#: ../raster/r.out.vtk/parameters.c:117
msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr ""
-"Utiliser une triangulation-polydonnées pour la création de la grille "
-"d'altitude"
+msgstr "Utiliser une triangulation-polydonnées pour la création de la grille d'altitude"
#: ../raster/r.out.vtk/parameters.c:123
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
-"Utiliser des arcs-polydonnées pour la création d'une grille d'altitude (afin "
-"d'utiliser vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr "Utiliser des arcs-polydonnées pour la création d'une grille d'altitude (afin d'utiliser vtkDelauny2D)"
#: ../raster/r.out.vtk/parameters.c:129
msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr ""
-"Facteur d'échelle à l'origine (si aucune couche d'altitude n'est donnée)"
+msgstr "Facteur d'échelle à l'origine (si aucune couche d'altitude n'est donnée)"
#: ../raster/r.out.vtk/main.c:79
#, fuzzy, c-format
@@ -5801,8 +6154,10 @@
msgstr "Convertit une couche raster au format VTK-Ascii"
# c-format
-#: ../raster/r.out.vtk/main.c:215 ../raster/r.out.vtk/main.c:280
-#: ../raster/r.out.vtk/main.c:307 ../raster/r.out.vtk/main.c:353
+#: ../raster/r.out.vtk/main.c:215
+#: ../raster/r.out.vtk/main.c:280
+#: ../raster/r.out.vtk/main.c:307
+#: ../raster/r.out.vtk/main.c:353
#, c-format
msgid "Open Raster file %s"
msgstr "Ouvrir le fichier raster %s"
@@ -5813,9 +6168,7 @@
#: ../raster/r.out.vtk/main.c:334
msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-"Couches RGB erronées. Les couches doivent être de même type! La sortie RGB "
-"n'est pas créée!"
+msgstr "Couches RGB erronées. Les couches doivent être de même type! La sortie RGB n'est pas créée!"
#: ../raster/r.out.vtk/main.c:371
msgid "Writing VTK Vector Data\n"
@@ -5823,11 +6176,8 @@
#: ../raster/r.out.vtk/main.c:381
#, fuzzy
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-"n'est pas créée!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
#: ../raster/r.out.vtk/main.c:393
msgid "Error closing VTK-ASCII file"
@@ -5858,7 +6208,8 @@
msgid "\"-\" to read from stdin"
msgstr "Impossible de lire la ligne %i\n"
-#: ../raster/r.recode/main.c:60 ../raster/r.clump/main.c:63
+#: ../raster/r.recode/main.c:60
+#: ../raster/r.clump/main.c:63
#, fuzzy
msgid "Title for output raster map"
msgstr "Titre de la couche raster de sortie"
@@ -5873,7 +6224,8 @@
msgid "Force output to 'double' raster map type (DCELL)"
msgstr "Forcer la création d'une couche de type double (DCELL)"
-#: ../raster/r.recode/main.c:87 ../raster/r.reclass/main.c:85
+#: ../raster/r.recode/main.c:87
+#: ../raster/r.reclass/main.c:85
#, fuzzy
msgid "Input map can NOT be the same as output map"
msgstr "Les cellules null en entrée seront conservées dans la couche en sortie"
@@ -5884,20 +6236,24 @@
msgid "No rules specified. Raster map <%s> not created."
msgstr "fichier de cellules coefdh <%s> non trouvé"
-#: ../raster/r.recode/main.c:102 ../raster/r.reclass/main.c:144
+#: ../raster/r.recode/main.c:102
+#: ../raster/r.reclass/main.c:144
#, fuzzy
msgid "No rules specified"
msgstr "Aucune couche de données spécifiée"
-#: ../raster/r.recode/main.c:112 ../raster/r.circle/dist.c:155
-#: ../raster/r.composite/main.c:273 ../raster/r.in.gdal/main.c:972
+#: ../raster/r.recode/main.c:112
+#: ../raster/r.circle/dist.c:155
+#: ../raster/r.composite/main.c:273
+#: ../raster/r.in.gdal/main.c:972
#: ../raster/r.surf.fractal/main.c:39
#, fuzzy, c-format
msgid "Raster map <%s> created."
msgstr "couche raster <%s> non trouvée"
# c-format
-#: ../raster/r.recode/read_rules.c:19 ../raster/r.contour/main.c:165
+#: ../raster/r.recode/read_rules.c:19
+#: ../raster/r.contour/main.c:165
#: ../raster/r.stats/main.c:315
#, fuzzy, c-format
msgid "Unable to read fp range of raster map <%s>"
@@ -5964,14 +6320,17 @@
msgid "'%s' is not a valid rule"
msgstr "<%s> n'est pas un nom valide pour une couche GRASS"
-#: ../raster/r.statistics/o_sum.c:35 ../raster/r.statistics/o_average.c:33
+#: ../raster/r.statistics/o_sum.c:35
+#: ../raster/r.statistics/o_average.c:33
#: ../raster/r.statistics/o_distrib.c:31
#, fuzzy, c-format
msgid "%s: running %s command"
msgstr "%s: ERREUR d'exécution de la commande %s"
-#: ../raster/r.statistics/o_sum.c:43 ../raster/r.statistics/o_average.c:41
-#: ../raster/r.statistics/o_distrib.c:39 ../raster/r.average/main.c:102
+#: ../raster/r.statistics/o_sum.c:43
+#: ../raster/r.statistics/o_average.c:41
+#: ../raster/r.statistics/o_distrib.c:39
+#: ../raster/r.average/main.c:102
#, fuzzy, c-format
msgid "%s: unable to open temporary file"
msgstr "Impossible d'ouvrir le fichier temporaire"
@@ -6001,20 +6360,20 @@
msgid "Resultant raster map (not used with 'distribution')"
msgstr "Couche raster résultat (non disponible avec 'distribution')"
-#: ../raster/r.statistics/main.c:73 ../raster/r.average/main.c:66
+#: ../raster/r.statistics/main.c:73
+#: ../raster/r.average/main.c:66
msgid "Cover values extracted from the category labels of the cover map"
-msgstr ""
-"Valeurs de la couche de couverture extraites des étiquettes de catégorie de "
-"la couche de couverture"
+msgstr "Valeurs de la couche de couverture extraites des étiquettes de catégorie de la couche de couverture"
-#: ../raster/r.statistics/main.c:82 ../raster/r.statistics/main.c:88
+#: ../raster/r.statistics/main.c:82
+#: ../raster/r.statistics/main.c:88
msgid "This module currently only works for integer (CELL) maps"
-msgstr ""
-"Pour le moment ce module ne fonctionne qu'avec des cartes de valeurs(CELL) "
-"entières"
+msgstr "Pour le moment ce module ne fonctionne qu'avec des cartes de valeurs(CELL) entières"
-#: ../raster/r.statistics/main.c:100 ../raster/r.proj.seg/main.c:238
-#: ../raster/r.neighbors/main.c:226 ../raster/r.proj/main.c:210
+#: ../raster/r.statistics/main.c:100
+#: ../raster/r.proj.seg/main.c:238
+#: ../raster/r.neighbors/main.c:226
+#: ../raster/r.proj/main.c:210
#: ../imagery/i.rectify/main.c:156
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:149
#, c-format
@@ -6035,48 +6394,50 @@
msgid "An output raster map needs to be defined with method '%s'"
msgstr "Une carte raster de sortie doit être définie avec la méthode '%s'"
-#: ../raster/r.statistics/read_stats.c:20 ../raster/r.median/read_stats.c:14
+#: ../raster/r.statistics/read_stats.c:20
+#: ../raster/r.median/read_stats.c:14
#, fuzzy
msgid "Reading r.stats output"
msgstr "Problème de lecture de r.stats en sortie"
-#: ../raster/r.statistics/o_var.c:100 ../raster/r.statistics/o_sdev.c:100
+#: ../raster/r.statistics/o_var.c:100
+#: ../raster/r.statistics/o_sdev.c:100
msgid "o_var: No data in array"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:52 ../raster/r.rescale/main.c:50
+#: ../raster/r.rescale.eq/main.c:52
+#: ../raster/r.rescale/main.c:50
#, fuzzy
msgid "raster, rescale"
msgstr "couche raster à échantillonner"
#: ../raster/r.rescale.eq/main.c:54
#, fuzzy
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Rééchelonne l'histogramme (ajusté sur l'étendue des valeurs de catégories) "
-"de la couche de données raster"
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Rééchelonne l'histogramme (ajusté sur l'étendue des valeurs de catégories) de la couche de données raster"
-#: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:61
+#: ../raster/r.rescale.eq/main.c:64
+#: ../raster/r.rescale/main.c:61
msgid "The name of the raster map to be rescaled"
msgstr "Nom de la couche raster dont on veut rééchelonner les valeurs"
-#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:69
+#: ../raster/r.rescale.eq/main.c:72
+#: ../raster/r.rescale/main.c:69
msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-"Intervalle de données à rééchelonner en entrée (par défaut : l'ensemble de "
-"la couche en entrée)"
+msgstr "Intervalle de données à rééchelonner en entrée (par défaut : l'ensemble de la couche en entrée)"
-#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:76
+#: ../raster/r.rescale.eq/main.c:79
+#: ../raster/r.rescale/main.c:76
msgid "The resulting raster map name"
msgstr "Nom de la couche raster résultat"
-#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:83
+#: ../raster/r.rescale.eq/main.c:86
+#: ../raster/r.rescale/main.c:83
msgid "The output data range"
msgstr "Intervalle de données en sortie"
-#: ../raster/r.rescale.eq/main.c:93 ../raster/r.rescale/main.c:90
+#: ../raster/r.rescale.eq/main.c:93
+#: ../raster/r.rescale/main.c:90
msgid "Title for new raster map"
msgstr "Nom de la nouvelle couche raster"
@@ -6086,7 +6447,8 @@
msgstr ""
# c-format
-#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:25
+#: ../raster/r.rescale.eq/get_stats.c:19
+#: ../raster/r.rescale/get_range.c:25
#, c-format
msgid "Reading %s ..."
msgstr "Lecture du fichier %s..."
@@ -6133,8 +6495,10 @@
msgid "Specified observer coordinate is outside current region bounds."
msgstr "Points germes en dehors de la région courante"
-#: ../raster/r.los/main.c:177 ../raster/r.los/main.c:182
-#: ../raster/r.resamp.rst/main.c:405 ../raster/r.resamp.rst/main.c:428
+#: ../raster/r.los/main.c:177
+#: ../raster/r.los/main.c:182
+#: ../raster/r.resamp.rst/main.c:405
+#: ../raster/r.resamp.rst/main.c:428
#, c-format
msgid "[%s]: Cannot read map header"
msgstr "[%s]: impossible de lire l'en-tête de couche"
@@ -6144,11 +6508,8 @@
msgstr ""
#: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-"Problème pour obtenir les paramètres de l'ellipsoïde courant, utilisation "
-"d'une sphère (6370997.0)"
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "Problème pour obtenir les paramètres de l'ellipsoïde courant, utilisation d'une sphère (6370997.0)"
#: ../raster/r.los/main.c:250
#, fuzzy, c-format
@@ -6156,10 +6517,14 @@
msgstr "Distance maximale depuis le point d'observation (en mètres)"
# c-format
-#: ../raster/r.los/main.c:380 ../raster/r.buffer/write_map.c:78
-#: ../raster/r.proj.seg/main.c:513 ../raster/r.null/null.c:348
-#: ../raster/r.proj/main.c:445 ../raster/r.texture/main.c:356
-#: ../raster/r.texture/main.c:360 ../raster/r.texture/main.c:367
+#: ../raster/r.los/main.c:380
+#: ../raster/r.buffer/write_map.c:78
+#: ../raster/r.proj.seg/main.c:513
+#: ../raster/r.null/null.c:348
+#: ../raster/r.proj/main.c:445
+#: ../raster/r.texture/main.c:356
+#: ../raster/r.texture/main.c:360
+#: ../raster/r.texture/main.c:367
#: ../imagery/i.landsat.acca/algorithm.c:362
#: ../imagery/i.landsat.acca/tools.c:291
#, fuzzy, c-format
@@ -6173,22 +6538,21 @@
#: ../raster/r.his/main.c:65
#, fuzzy
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Générer des couches raster de couche rouge, verte et bleue en combinant des "
-"couches raster de teinte, intensité et saturation."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Générer des couches raster de couche rouge, verte et bleue en combinant des couches raster de teinte, intensité et saturation."
-#: ../raster/r.his/main.c:74 ../display/d.his/main.c:76
+#: ../raster/r.his/main.c:74
+#: ../display/d.his/main.c:76
msgid "Name of layer to be used for HUE"
msgstr "Nom de la couche utilisée pour la teinte"
-#: ../raster/r.his/main.c:81 ../display/d.his/main.c:83
+#: ../raster/r.his/main.c:81
+#: ../display/d.his/main.c:83
msgid "Name of layer to be used for INTENSITY"
msgstr "nom de la couche utilisée pour l'intensité"
-#: ../raster/r.his/main.c:88 ../display/d.his/main.c:90
+#: ../raster/r.his/main.c:88
+#: ../display/d.his/main.c:90
msgid "Name of layer to be used for SATURATION"
msgstr "Nom de la couche utilisée pour la saturation"
@@ -6204,16 +6568,23 @@
msgid "Name of output layer to be used for BLUE"
msgstr "Nom de la couche bleue créée"
-#: ../raster/r.his/main.c:113 ../display/d.his/main.c:101
+#: ../raster/r.his/main.c:113
+#: ../display/d.his/main.c:101
msgid "Respect NULL values while drawing"
msgstr "Respecter les valeurs NULL lors du dessin"
-#: ../raster/r.his/main.c:142 ../raster/r.his/main.c:161
-#: ../raster/r.his/main.c:186 ../raster/r.out.ppm3/main.c:131
-#: ../display/d.histogram/main.c:165 ../display/d.rast.edit/cell.c:51
-#: ../display/d.rast.num/number.c:278 ../display/d.his/main.c:152
-#: ../display/d.his/main.c:171 ../display/d.his/main.c:196
-#: ../display/d.rast/display.c:21 ../display/d.rgb/main.c:105
+#: ../raster/r.his/main.c:142
+#: ../raster/r.his/main.c:161
+#: ../raster/r.his/main.c:186
+#: ../raster/r.out.ppm3/main.c:131
+#: ../display/d.histogram/main.c:165
+#: ../display/d.rast.edit/cell.c:51
+#: ../display/d.rast.num/number.c:278
+#: ../display/d.his/main.c:152
+#: ../display/d.his/main.c:171
+#: ../display/d.his/main.c:196
+#: ../display/d.rast/display.c:21
+#: ../display/d.rgb/main.c:105
#: ../display/d.legend/main.c:259
#, fuzzy, c-format
msgid "Color file for <%s> not available"
@@ -6242,12 +6613,8 @@
msgstr "couche raster source"
#: ../raster/r.buffer/main.c:71
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Créer une couche raster montrant des zones tampons entourant les cellules "
-"qui contiennent des valeurs de catégorie non NULL"
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Créer une couche raster montrant des zones tampons entourant les cellules qui contiennent des valeurs de catégorie non NULL"
#: ../raster/r.buffer/main.c:83
msgid "Distance zone(s)"
@@ -6259,9 +6626,7 @@
#: ../raster/r.buffer/main.c:96
msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr ""
-"Ignore les cellules contenant la valeur zéro (0) au lieu des cellules "
-"contenant NULL"
+msgstr "Ignore les cellules contenant la valeur zéro (0) au lieu des cellules contenant NULL"
#: ../raster/r.buffer/main.c:149
#, fuzzy
@@ -6299,7 +6664,8 @@
msgid "Aggregation method"
msgstr "Opération d'agrégation"
-#: ../raster/r.resamp.stats/main.c:277 ../raster/r.series/main.c:180
+#: ../raster/r.resamp.stats/main.c:277
+#: ../raster/r.series/main.c:180
msgid "Propagate NULLs"
msgstr "Propager les valeurs NULL"
@@ -6307,17 +6673,20 @@
msgid "Weight according to area (slower)"
msgstr ""
-#: ../raster/r.resamp.stats/main.c:290 ../raster/r.series/main.c:101
+#: ../raster/r.resamp.stats/main.c:290
+#: ../raster/r.series/main.c:101
#, c-format
msgid "Unknown method <%s>"
msgstr "Méthode inconnue <%s>"
-#: ../raster/r.resamp.stats/main.c:374 ../raster/r.resamp.interp/main.c:320
+#: ../raster/r.resamp.stats/main.c:374
+#: ../raster/r.resamp.interp/main.c:320
#, c-format
msgid "Unable to read color table for %s"
msgstr "Impossible de lire la table de couleur %s"
-#: ../raster/r.resamp.stats/main.c:378 ../raster/r.resamp.interp/main.c:323
+#: ../raster/r.resamp.stats/main.c:378
+#: ../raster/r.resamp.interp/main.c:323
#, fuzzy, c-format
msgid "Unable to write color table for %s"
@@ -6325,9 +6694,7 @@
#: ../raster/r.circle/dist.c:53
#, fuzzy
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Crée une couche raster contenant des cercles concentriques autour d'un point "
-"donné"
+msgstr "Crée une couche raster contenant des cercles concentriques autour d'un point donné"
#: ../raster/r.circle/dist.c:63
msgid "The coordinate of the center (east,north)"
@@ -6359,17 +6726,8 @@
msgstr ""
#: ../raster/r.walk/main.c:176
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Produit une couche raster montrant le coût cumulé anisotropique d'un "
-"déplacement entre différentes positions géographiques à partir d'une couche "
-"raster d'altitude où la valeur de catégorie des cellules représente "
-"l'altitude combinée avec une couche raster dont la valeur correspond au coût "
-"de rugosité."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Produit une couche raster montrant le coût cumulé anisotropique d'un déplacement entre différentes positions géographiques à partir d'une couche raster d'altitude où la valeur de catégorie des cellules représente l'altitude combinée avec une couche raster dont la valeur correspond au coût de rugosité."
#: ../raster/r.walk/main.c:188
msgid "Name of elevation input raster map"
@@ -6379,7 +6737,8 @@
msgid "Name of input raster map containing friction costs"
msgstr "Nom de la couche en entrée contenant les coûts de rugosité"
-#: ../raster/r.walk/main.c:203 ../raster/r.water.outlet/main.c:62
+#: ../raster/r.walk/main.c:203
+#: ../raster/r.water.outlet/main.c:62
msgid "Name of raster map to contain results"
msgstr "Nom de la couche raster qui contiendra les résultats"
@@ -6413,14 +6772,11 @@
#: ../raster/r.walk/main.c:285
msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-"Coefficients lambda pour combiner l'énergie de marche et le coût de rugosité"
+msgstr "Coefficients lambda pour combiner l'énergie de marche et le coût de rugosité"
#: ../raster/r.walk/main.c:294
msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"Facteur de pente qui détermine le coût d'énergie du déplacement en fonction "
-"d'un pas de hauteur"
+msgstr "Facteur de pente qui détermine le coût d'énergie du déplacement en fonction d'un pas de hauteur"
#: ../raster/r.walk/main.c:303
msgid "Keep null values in output map"
@@ -6436,7 +6792,8 @@
msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
msgstr "Les coûts de marche sont a=%lf b=%lf c=%lf d=%lf"
-#: ../raster/r.walk/main.c:369 ../raster/r.walk/main.c:377
+#: ../raster/r.walk/main.c:369
+#: ../raster/r.walk/main.c:377
#: ../raster/r.walk/main.c:384
#, c-format
msgid "Missing required value: %d"
@@ -6479,12 +6836,11 @@
#: ../raster/r.walk/main.c:495
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"ignorées"
# c-format
-#: ../raster/r.walk/main.c:556 ../raster/r.walk/main.c:558
+#: ../raster/r.walk/main.c:556
+#: ../raster/r.walk/main.c:558
#, fuzzy, c-format
msgid "Unable to read %s"
msgstr "impossible de créer %s"
@@ -6506,7 +6862,8 @@
msgstr "DTM_Source map est : type de cellule double flottant"
# c-format
-#: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:599
+#: ../raster/r.walk/main.c:584
+#: ../raster/r.walk/main.c:599
#: ../raster/r.walk/main.c:636
#, c-format
msgid " %d rows, %d cols"
@@ -6547,8 +6904,10 @@
msgstr "NS résolution %s (%lf)"
# c-format
-#: ../raster/r.walk/main.c:682 ../raster/r.walk/main.c:744
-#: ../raster/wildfire/r.spread/main.c:514 ../raster/r.sum/main.c:74
+#: ../raster/r.walk/main.c:682
+#: ../raster/r.walk/main.c:744
+#: ../raster/wildfire/r.spread/main.c:514
+#: ../raster/r.sum/main.c:74
#, fuzzy, c-format
msgid "Reading %s..."
@@ -6565,14 +6924,12 @@
#: ../raster/r.walk/main.c:849
#, fuzzy, c-format
msgid "Raster output map <%s> not found (no start_points given)"
-msgstr ""
-"Couche raster en sortie %s - introuvable (aucun point de départ spécifié)"
+msgstr "Couche raster en sortie %s - introuvable (aucun point de départ spécifié)"
#: ../raster/r.walk/main.c:864
#, c-format
msgid "Memory allocation error on reading start points from raster map %s"
-msgstr ""
-"Erreur d'allocation mémoire à la lecture des points de la couche raster %s"
+msgstr "Erreur d'allocation mémoire à la lecture des points de la couche raster %s"
# c-format
#: ../raster/r.walk/main.c:867
@@ -6596,8 +6953,7 @@
#: ../raster/r.walk/main.c:1400
msgid "Will copy input map null values into output map"
-msgstr ""
-"Copier les cellules null de la couche en entrée dans la couche de sortie"
+msgstr "Copier les cellules null de la couche en entrée dans la couche de sortie"
#: ../raster/r.walk/main.c:1407
msgid ""
@@ -6628,16 +6984,15 @@
msgid "Peak cost value: %f"
-#: ../raster/r.what/main.c:91 ../raster/r.what.color/main.c:88
+#: ../raster/r.what/main.c:91
+#: ../raster/r.what.color/main.c:88
#, fuzzy
msgid "raster, querying"
msgstr "Nombre de points d'interpolation"
#: ../raster/r.what/main.c:93
msgid "Queries raster map layers on their category values and category labels."
-msgstr ""
-"Requète les couches raster sur les valeurs des catégories et les étiquettes "
-"des catégories"
+msgstr "Requète les couches raster sur les valeurs des catégories et les étiquettes des catégories"
#: ../raster/r.what/main.c:101
msgid "Name of existing raster map(s) to query"
@@ -6647,18 +7002,27 @@
msgid "Size of point cache"
msgstr "Taille du cache du pointeur"
-#: ../raster/r.what/main.c:110 ../raster/r.what/main.c:148
-#: ../display/d.legend/main.c:108 ../display/d.legend/main.c:117
-#: ../display/d.legend/main.c:125 ../display/d.legend/main.c:146
-#: ../display/d.legend/main.c:155 ../display/d.legend/main.c:165
-#: ../display/d.legend/main.c:170 ../display/d.legend/main.c:175
-#: ../display/d.legend/main.c:180 ../display/d.legend/main.c:185
-#: ../vector/v.buffer/main.c:279 ../vector/v.buffer/main.c:287
-#: ../vector/v.buffer/main.c:294 ../vector/v.buffer/main.c:304
+#: ../raster/r.what/main.c:110
+#: ../raster/r.what/main.c:148
+#: ../display/d.legend/main.c:108
+#: ../display/d.legend/main.c:117
+#: ../display/d.legend/main.c:125
+#: ../display/d.legend/main.c:146
+#: ../display/d.legend/main.c:155
+#: ../display/d.legend/main.c:165
+#: ../display/d.legend/main.c:170
+#: ../display/d.legend/main.c:175
+#: ../display/d.legend/main.c:180
+#: ../display/d.legend/main.c:185
+#: ../vector/v.buffer/main.c:279
+#: ../vector/v.buffer/main.c:287
+#: ../vector/v.buffer/main.c:294
+#: ../vector/v.buffer/main.c:304
msgid "Advanced"
msgstr ""
-#: ../raster/r.what/main.c:127 ../vector/v.what/main.c:69
+#: ../raster/r.what/main.c:127
+#: ../vector/v.what/main.c:69
msgid "Coordinates for query"
msgstr "Coordonnées pour la requête"
@@ -6678,8 +7042,7 @@
#: ../raster/r.what/main.c:143
msgid "Output integer category values, not cell values"
-msgstr ""
-"Produire des valeurs de catégorie entières au lieu de valeurs de cellule"
+msgstr "Produire des valeurs de catégorie entières au lieu de valeurs de cellule"
#: ../raster/r.what/main.c:147
msgid "Turn on cache reporting"
@@ -6698,8 +7061,7 @@
#: ../raster/r.contour/main.c:92
#, fuzzy
msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
+msgstr "Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
#: ../raster/r.contour/main.c:104
msgid "List of contour levels"
@@ -6726,9 +7088,7 @@
msgstr "Supprimer les messages d'erreur de croisement simple"
#: ../raster/r.contour/main.c:147
-msgid ""
-"The '-q' and '-n' flag is superseded and will be removed in future. Please "
-"use '--quiet' instead."
+msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
msgstr ""
#: ../raster/r.contour/main.c:152
@@ -6736,48 +7096,69 @@
msgstr ""
# c-format
-#: ../raster/r.contour/main.c:196 ../vector/v.net.centrality/main.c:240
-#: ../vector/v.overlay/main.c:464 ../vector/v.in.ogr/main.c:788
-#: ../vector/v.net.distance/main.c:208 ../vector/v.in.dwg/main.c:219
-#: ../vector/v.distance/main.c:835 ../vector/v.net.flow/main.c:168
-#: ../vector/v.surf.rst/main.c:613 ../vector/v.net.timetable/main.c:103
-#: ../vector/v.convert/att.c:80 ../vector/v.net.allpairs/main.c:153
-#: ../vector/v.net.components/main.c:147 ../vector/v.to.points/main.c:295
+#: ../raster/r.contour/main.c:196
+#: ../vector/v.net.centrality/main.c:240
+#: ../vector/v.overlay/main.c:464
+#: ../vector/v.in.ogr/main.c:788
+#: ../vector/v.net.distance/main.c:208
+#: ../vector/v.in.dwg/main.c:219
+#: ../vector/v.distance/main.c:835
+#: ../vector/v.net.flow/main.c:168
+#: ../vector/v.surf.rst/main.c:613
+#: ../vector/v.net.timetable/main.c:103
+#: ../vector/v.convert/att.c:80
+#: ../vector/v.net.allpairs/main.c:153
+#: ../vector/v.net.components/main.c:147
+#: ../vector/v.to.points/main.c:295
#: ../vector/v.net.path/path.c:109
#, fuzzy, c-format
msgid "Unable to create table: '%s'"
msgstr "Impossible de créer le fichier de cellules pour [%s]"
# c-format
-#: ../raster/r.contour/main.c:201 ../vector/v.in.ogr/main.c:793
-#: ../vector/v.in.dwg/main.c:223 ../vector/v.in.ascii/in.c:505
-#: ../vector/v.reclass/main.c:297 ../vector/v.convert/att.c:85
-#: ../vector/v.in.sites/main.c:174 ../vector/v.in.dxf/write_vect.c:225
+#: ../raster/r.contour/main.c:201
+#: ../vector/v.in.ogr/main.c:793
+#: ../vector/v.in.dwg/main.c:223
+#: ../vector/v.in.ascii/in.c:505
+#: ../vector/v.reclass/main.c:297
+#: ../vector/v.convert/att.c:85
+#: ../vector/v.in.sites/main.c:174
+#: ../vector/v.in.dxf/write_vect.c:225
#: ../vector/v.to.points/main.c:300
#, fuzzy, c-format
msgid "Unable to create index for table <%s>, key <%s>"
msgstr "impossible de créer la sortie <%s>"
-#: ../raster/r.contour/main.c:206 ../raster/r.to.vect/main.c:204
-#: ../vector/v.random/main.c:204 ../vector/v.overlay/main.c:474
-#: ../vector/v.in.ogr/main.c:799 ../vector/v.in.dwg/main.c:228
-#: ../vector/v.in.ascii/in.c:395 ../vector/v.sample/main.c:223
-#: ../vector/v.distance/main.c:840 ../vector/v.mkgrid/main.c:263
-#: ../vector/v.reclass/main.c:302 ../vector/v.convert/att.c:90
-#: ../vector/v.in.sites/main.c:179 ../vector/v.in.dxf/write_vect.c:223
+#: ../raster/r.contour/main.c:206
+#: ../raster/r.to.vect/main.c:204
+#: ../vector/v.random/main.c:204
+#: ../vector/v.overlay/main.c:474
+#: ../vector/v.in.ogr/main.c:799
+#: ../vector/v.in.dwg/main.c:228
+#: ../vector/v.in.ascii/in.c:395
+#: ../vector/v.sample/main.c:223
+#: ../vector/v.distance/main.c:840
+#: ../vector/v.mkgrid/main.c:263
+#: ../vector/v.reclass/main.c:302
+#: ../vector/v.convert/att.c:90
+#: ../vector/v.in.sites/main.c:179
+#: ../vector/v.in.dxf/write_vect.c:223
#: ../vector/v.to.points/main.c:306
#, fuzzy, c-format
msgid "Unable to grant privileges on table <%s>"
msgstr "Impossible d'accorder des privilèges sur la table : %s"
-#: ../raster/r.contour/main.c:224 ../vector/v.overlay/area_area.c:238
-#: ../vector/v.overlay/line_area.c:217 ../vector/v.convert/att.c:110
+#: ../raster/r.contour/main.c:224
+#: ../vector/v.overlay/area_area.c:238
+#: ../vector/v.overlay/line_area.c:217
+#: ../vector/v.convert/att.c:110
#: ../vector/v.to.points/main.c:63
#, fuzzy, c-format
msgid "Unable to insert new record: '%s'"
msgstr "Impossible d'insérer une nouvelle ligne : %s"
-#: ../raster/r.contour/main.c:244 ../vector/v.generalize/displacement.c:79
+#: ../raster/r.contour/main.c:244
+#: ../vector/v.generalize/displacement.c:79
#, fuzzy
msgid "Reading data..."
msgstr "Rotation des données ... "
@@ -6792,7 +7173,8 @@
msgid "Range of data: empty"
-#: ../raster/r.contour/main.c:299 ../raster/r.contour/main.c:303
+#: ../raster/r.contour/main.c:299
+#: ../raster/r.contour/main.c:303
#, fuzzy
msgid "This step value is not allowed"
msgstr "** Les valeurs négatives ne sont pas autorisées!"
@@ -6834,12 +7216,8 @@
#: ../raster/r.series/main.c:135
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Calcule chaque valeur de cellule en sortie comme une fonction des valeurs "
-"des cellules correspondantes dans les couches d'entrée."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Calcule chaque valeur de cellule en sortie comme une fonction des valeurs des cellules correspondantes dans les couches d'entrée."
#: ../raster/r.series/main.c:149
msgid "Aggregate operation"
@@ -6858,12 +7236,14 @@
msgid "Ignore values outside this range"
msgstr "Ignorer les valeurs en dehors de cet intervalle"
-#: ../raster/r.series/main.c:202 ../imagery/i.group/main.c:102
+#: ../raster/r.series/main.c:202
+#: ../imagery/i.group/main.c:102
#, fuzzy
msgid "No input raster map(s) specified"
msgstr "Aucune couche spécifiée en entrée."
-#: ../raster/r.series/main.c:217 ../raster/r.neighbors/main.c:216
+#: ../raster/r.series/main.c:217
+#: ../raster/r.neighbors/main.c:216
#: ../ps/ps.map/outl_io.c:72
#, fuzzy, c-format
msgid "Unable to open raster map <%s> in mapset <%s>"
@@ -6933,7 +7313,8 @@
msgid "Seed (%d) larger than maximum (%d)"
msgstr ""
-#: ../raster/r.random.surface/init.c:208 ../raster/r.random.surface/init.c:217
+#: ../raster/r.random.surface/init.c:208
+#: ../raster/r.random.surface/init.c:217
#, c-format
msgid " seed is set to %d"
msgstr ""
@@ -6970,13 +7351,15 @@
msgid "Must have a weight value for each filter"
msgstr ""
-#: ../raster/r.random.surface/init.c:425 ../raster/r.random.cells/init.c:156
+#: ../raster/r.random.surface/init.c:425
+#: ../raster/r.random.cells/init.c:156
#: ../imagery/i.topo.corr/main.c:52
#, fuzzy, c-format
msgid "<%s> is an illegal name"
msgstr "[%s] n'est pas un nom légal"
-#: ../raster/r.random.surface/save.c:219 ../imagery/i.pca/support.c:27
+#: ../raster/r.random.surface/save.c:219
+#: ../imagery/i.pca/support.c:27
#, fuzzy, c-format
msgid "Unable to write color table for raster map <%s>"
@@ -6988,10 +7371,10 @@
#: ../raster/r.random.surface/main.c:45
msgid "Generates random surface(s) with spatial dependence."
-msgstr ""
-"Générer des valeurs de surface aléatoire ayant une interdépendance spatiale"
+msgstr "Générer des valeurs de surface aléatoire ayant une interdépendance spatiale"
-#: ../raster/r.random.surface/main.c:57 ../raster/r.random.cells/init.c:115
+#: ../raster/r.random.surface/main.c:57
+#: ../raster/r.random.cells/init.c:115
#, fuzzy, c-format
msgid "Generating raster map <%s>..."
@@ -7002,9 +7385,7 @@
#: ../raster/r.in.xyz/main.c:161
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
msgstr ""
#: ../raster/r.in.xyz/main.c:165
@@ -7017,17 +7398,21 @@
msgid "Statistic to use for raster values"
msgstr "Statistique de couches raster."
-#: ../raster/r.in.xyz/main.c:177 ../raster/r.in.xyz/main.c:243
+#: ../raster/r.in.xyz/main.c:177
+#: ../raster/r.in.xyz/main.c:243
#: ../raster/r.in.xyz/main.c:252
msgid "Statistic"
msgstr "Statistique"
-#: ../raster/r.in.xyz/main.c:185 ../raster/r.in.arc/main.c:80
+#: ../raster/r.in.xyz/main.c:185
+#: ../raster/r.in.arc/main.c:80
msgid "Storage type for resultant raster map"
msgstr "Type de stockage pour la couche raster créée"
-#: ../raster/r.in.xyz/main.c:188 ../raster/r.in.xyz/main.c:197
-#: ../raster/r.in.xyz/main.c:205 ../raster/r.in.xyz/main.c:213
+#: ../raster/r.in.xyz/main.c:188
+#: ../raster/r.in.xyz/main.c:197
+#: ../raster/r.in.xyz/main.c:205
+#: ../raster/r.in.xyz/main.c:213
#: ../raster/simwe/r.sim.sediment/main.c:119
#: ../raster/simwe/r.sim.sediment/main.c:124
#: ../raster/simwe/r.sim.sediment/main.c:129
@@ -7046,8 +7431,10 @@
#: ../raster/simwe/r.sim.water/main.c:168
#: ../raster/simwe/r.sim.water/main.c:174
#: ../raster/simwe/r.sim.water/main.c:182
-#: ../raster/simwe/r.sim.water/main.c:189 ../vector/v.edit/args.c:103
-#: ../vector/v.edit/args.c:212 ../vector/v.out.ogr/main.c:108
+#: ../raster/simwe/r.sim.water/main.c:189
+#: ../vector/v.edit/args.c:103
+#: ../vector/v.edit/args.c:212
+#: ../vector/v.out.ogr/main.c:108
#: ../vector/v.out.ogr/main.c:128
#, fuzzy
msgid "Input"
@@ -7056,9 +7443,7 @@
#: ../raster/r.in.xyz/main.c:196
#, fuzzy
msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode points"
#: ../raster/r.in.xyz/main.c:204
msgid "Column number of y coordinates in input file"
@@ -7083,9 +7468,7 @@
msgstr "Format de sortie pour la pente"
#: ../raster/r.in.xyz/main.c:251
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
msgstr ""
#: ../raster/r.in.xyz/main.c:256
@@ -7121,21 +7504,21 @@
msgstr ""
# c-format
-#: ../raster/r.in.xyz/main.c:470 ../raster/r.in.arc/main.c:124
-#: ../raster/r.in.mat/main.c:144 ../display/d.linegraph/linegraph.c:193
+#: ../raster/r.in.xyz/main.c:470
+#: ../raster/r.in.arc/main.c:124
+#: ../raster/r.in.mat/main.c:144
+#: ../display/d.linegraph/linegraph.c:193
#: ../display/d.linegraph/linegraph.c:204
-#: ../vector/v.lrs/v.lrs.segment/main.c:131 ../vector/v.segment/main.c:92
+#: ../vector/v.lrs/v.lrs.segment/main.c:131
+#: ../vector/v.segment/main.c:92
#: ../vector/v.net.path/path.c:49
#, fuzzy, c-format
msgid "Unable to open input file <%s>"
msgstr "impossible d'ouvrir le fichier en entrée <%s>"
#: ../raster/r.in.xyz/main.c:477
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-"Si l'entrée ne provient pas d'un fichier, il n'est possible de réaliser "
-"qu'une seule passe."
+msgid "If input is not from a file it is only possible to perform a single pass."
+msgstr "Si l'entrée ne provient pas d'un fichier, il n'est possible de réaliser qu'une seule passe."
#: ../raster/r.in.xyz/main.c:483
msgid "zrange will not be taken into account during scan"
@@ -7146,38 +7529,43 @@
msgid "Reading data ..."
-#: ../raster/r.in.xyz/main.c:528 ../raster/r.in.poly/poly2rast.c:56
+#: ../raster/r.in.xyz/main.c:528
+#: ../raster/r.in.poly/poly2rast.c:56
#, fuzzy, c-format
msgid "Pass #%d (of %d) ..."
msgstr "classe %d (%d)\n"
-#: ../raster/r.in.xyz/main.c:599 ../raster/r.in.xyz/main.c:607
-#: ../raster/r.in.xyz/main.c:1103 ../raster/r.in.xyz/main.c:1111
+#: ../raster/r.in.xyz/main.c:599
+#: ../raster/r.in.xyz/main.c:607
+#: ../raster/r.in.xyz/main.c:1103
+#: ../raster/r.in.xyz/main.c:1111
#, c-format
msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
"[%s]"
msgstr ""
-"Pas assez de colonnes de données. Séparateur ou nombre de colonne "
-"incorrect ? trouvé les caractères suivants dans la ligne %lu:\n"
+"Pas assez de colonnes de données. Séparateur ou nombre de colonne incorrect ? trouvé les caractères suivants dans la ligne %lu:\n"
"[%s]"
-#: ../raster/r.in.xyz/main.c:603 ../raster/r.in.xyz/main.c:1107
+#: ../raster/r.in.xyz/main.c:603
+#: ../raster/r.in.xyz/main.c:1107
msgid "Line ignored as requested"
msgstr ""
-#: ../raster/r.in.xyz/main.c:622 ../raster/r.in.xyz/main.c:1141
+#: ../raster/r.in.xyz/main.c:622
+#: ../raster/r.in.xyz/main.c:1141
#, c-format
msgid "Bad y-coordinate line %lu column %d. <%s>"
msgstr ""
-#: ../raster/r.in.xyz/main.c:629 ../raster/r.in.xyz/main.c:1126
+#: ../raster/r.in.xyz/main.c:629
+#: ../raster/r.in.xyz/main.c:1126
#, c-format
msgid "Bad x-coordinate line %lu column %d. <%s>"
msgstr ""
-#: ../raster/r.in.xyz/main.c:636 ../raster/r.in.xyz/main.c:1156
+#: ../raster/r.in.xyz/main.c:636
+#: ../raster/r.in.xyz/main.c:1156
#, c-format
msgid "Bad z-coordinate line %lu column %d. <%s>"
msgstr ""
@@ -7216,12 +7604,11 @@
#: ../raster/r.composite/main.c:74
#, fuzzy
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Combiner des couches rouges, vertes et bleues en une seule couche composite."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Combiner des couches rouges, vertes et bleues en une seule couche composite."
-#: ../raster/r.composite/main.c:88 ../raster/r.out.ppm3/main.c:65
+#: ../raster/r.composite/main.c:88
+#: ../raster/r.out.ppm3/main.c:65
#, c-format
msgid "Name of raster map to be used for <%s>"
msgstr "Nom de la couche raster à utiliser pour <%s>"
@@ -7230,7 +7617,8 @@
msgid "Number of levels to be used for each component"
msgstr "Nombre de niveaux utilisés pour chaque composant"
-#: ../raster/r.composite/main.c:101 ../raster/r.composite/main.c:119
+#: ../raster/r.composite/main.c:101
+#: ../raster/r.composite/main.c:119
msgid "Levels"
msgstr "Niveaux"
@@ -7248,7 +7636,8 @@
msgstr "Utiliser la couleur la plus proche"
# c-format
-#: ../raster/r.composite/main.c:167 ../raster/r.lake/main.c:407
+#: ../raster/r.composite/main.c:167
+#: ../raster/r.lake/main.c:407
#, fuzzy, c-format
msgid "Unable to read color file of raster map <%s>"
msgstr "Impossible de créer la couche raster <%s>"
@@ -7270,18 +7659,12 @@
msgstr "Valeur raster"
#: ../raster/r.volume/main.c:59
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Calcul le volume de données \"flaques\" et produit (en option) une couche "
-"vectorielle point GRASS contenant les centroïdes de ces 'flaques'"
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Calcul le volume de données \"flaques\" et produit (en option) une couche vectorielle point GRASS contenant les centroïdes de ces 'flaques'"
#: ../raster/r.volume/main.c:69
msgid "Existing raster map representing data that will be summed within clumps"
-msgstr ""
-"Couche de données raster existante représentant les données à additionner à "
-"l'intérieur des 'flaques'"
+msgstr "Couche de données raster existante représentant les données à additionner à l'intérieur des 'flaques'"
#: ../raster/r.volume/main.c:77
msgid "Existing raster map, preferably the output of r.clump"
@@ -7289,8 +7672,7 @@
#: ../raster/r.volume/main.c:84
msgid "Vector points map to contain clump centroids"
-msgstr ""
-"Couche vectoriel de points qui doit contenir les centroïdes de 'flaques'"
+msgstr "Couche vectoriel de points qui doit contenir les centroïdes de 'flaques'"
#: ../raster/r.volume/main.c:88
msgid "Generate unformatted report"
@@ -7408,12 +7790,11 @@
msgstr ""
#: ../raster/r.gwflow/main.c:191
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
msgstr ""
-#: ../raster/r.gwflow/main.c:201 ../raster/r.topidx/main.c:53
+#: ../raster/r.gwflow/main.c:201
+#: ../raster/r.topidx/main.c:53
#, fuzzy, c-format
msgid "Lat/Long location is not supported by %s. Please reproject map first."
msgstr "Type de colonne non géré"
@@ -7445,9 +7826,7 @@
#: ../raster/r.topidx/main.c:39
#, fuzzy
msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Crée une couche d'indice topographique ln(a/tan(beta)) à partir d'une couche "
-"d'altitude."
+msgstr "Crée une couche d'indice topographique ln(a/tan(beta)) à partir d'une couche d'altitude."
#: ../raster/r.topidx/main.c:42
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
@@ -7461,10 +7840,14 @@
msgstr "couche d'indice topographique ln(a/tan(beta))"
# c-format
-#: ../raster/r.topidx/file_io.c:21 ../raster/r.out.tiff/r.out.tiff.c:169
-#: ../raster/r.null/null.c:163 ../raster/r.bitpattern/main.c:114
-#: ../raster/r.texture/main.c:240 ../imagery/i.landsat.toar/main.c:333
-#: ../imagery/i.landsat.toar/main.c:468 ../imagery/i.rectify/main.c:294
+#: ../raster/r.topidx/file_io.c:21
+#: ../raster/r.out.tiff/r.out.tiff.c:169
+#: ../raster/r.null/null.c:163
+#: ../raster/r.bitpattern/main.c:114
+#: ../raster/r.texture/main.c:240
+#: ../imagery/i.landsat.toar/main.c:333
+#: ../imagery/i.landsat.toar/main.c:468
+#: ../imagery/i.rectify/main.c:294
#: ../imagery/i.rectify/main.c:300
#, fuzzy, c-format
msgid "Unable to read header of raster map <%s>"
@@ -7472,10 +7855,7 @@
#: ../raster/r.topidx/file_io.c:37
#, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or "
-"coarser than, the input map's resolution."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
msgstr ""
#: ../raster/r.topidx/file_io.c:44
@@ -7490,60 +7870,74 @@
#: ../raster/r.in.arc/main.c:61
#, fuzzy
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Convertir un fichier raster ESRI ARC/INFO ASCII GRID en une couche raster."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Convertir un fichier raster ESRI ARC/INFO ASCII GRID en une couche raster."
#: ../raster/r.in.arc/main.c:69
#, fuzzy
msgid "ARC/INFO ASCII raster file (GRID) to be imported"
msgstr "Fichier ARC/INFO ASCII (GRID) à importer"
-#: ../raster/r.in.arc/main.c:94 ../raster/r.in.ascii/main.c:92
+#: ../raster/r.in.arc/main.c:94
+#: ../raster/r.in.ascii/main.c:92
#, fuzzy
msgid "Multiplier for ASCII data"
msgstr "Multiplicateur pour les données ASCII"
-#: ../raster/r.in.arc/main.c:114 ../raster/r.resamp.rst/main.c:616
-#: ../raster/r.resamp.rst/main.c:628 ../raster/r.resamp.rst/main.c:641
-#: ../raster/r.resamp.rst/main.c:655 ../raster/r.resamp.rst/main.c:668
-#: ../raster/r.resamp.rst/main.c:681 ../raster/r.in.ascii/main.c:128
-#: ../raster/r.in.ascii/main.c:155 ../display/d.text/main.c:193
-#: ../display/d.text.new/main.c:417 ../display/d.title/main.c:119
-#: ../general/g.setproj/get_stp.c:162 ../general/g.setproj/get_stp.c:165
-#: ../general/g.setproj/get_stp.c:282 ../general/g.setproj/get_stp.c:286
-#: ../vector/v.in.ascii/in.c:248 ../vector/v.surf.rst/main.c:646
-#: ../vector/v.surf.rst/main.c:655 ../vector/v.surf.rst/main.c:664
-#: ../vector/v.surf.rst/main.c:674 ../vector/v.surf.rst/main.c:683
+#: ../raster/r.in.arc/main.c:114
+#: ../raster/r.resamp.rst/main.c:616
+#: ../raster/r.resamp.rst/main.c:628
+#: ../raster/r.resamp.rst/main.c:641
+#: ../raster/r.resamp.rst/main.c:655
+#: ../raster/r.resamp.rst/main.c:668
+#: ../raster/r.resamp.rst/main.c:681
+#: ../raster/r.in.ascii/main.c:128
+#: ../raster/r.in.ascii/main.c:155
+#: ../display/d.text/main.c:193
+#: ../display/d.text.new/main.c:417
+#: ../display/d.title/main.c:119
+#: ../general/g.setproj/get_stp.c:162
+#: ../general/g.setproj/get_stp.c:165
+#: ../general/g.setproj/get_stp.c:282
+#: ../general/g.setproj/get_stp.c:286
+#: ../vector/v.in.ascii/in.c:248
+#: ../vector/v.surf.rst/main.c:646
+#: ../vector/v.surf.rst/main.c:655
+#: ../vector/v.surf.rst/main.c:664
+#: ../vector/v.surf.rst/main.c:674
+#: ../vector/v.surf.rst/main.c:683
#: ../vector/v.surf.rst/main.c:692
#, fuzzy, c-format
msgid "Unable to open temporary file <%s>"
-#: ../raster/r.in.arc/main.c:127 ../raster/r.in.ascii/main.c:185
+#: ../raster/r.in.arc/main.c:127
+#: ../raster/r.in.ascii/main.c:185
msgid "Can't get cell header"
msgstr "Impossible de l'en-tête de cellule"
-#: ../raster/r.in.arc/main.c:132 ../raster/r.out.tiff/r.out.tiff.c:173
+#: ../raster/r.in.arc/main.c:132
+#: ../raster/r.out.tiff/r.out.tiff.c:173
#: ../raster/r.in.ascii/main.c:190
msgid "Can't set window"
msgstr "Impossible de paramétrer la fenêtre"
-#: ../raster/r.in.arc/main.c:135 ../raster/r.horizon/main.c:623
+#: ../raster/r.in.arc/main.c:135
+#: ../raster/r.horizon/main.c:623
#: ../raster/r.in.ascii/main.c:193
#, c-format
msgid "OOPS: rows changed from %d to %d"
msgstr "OOPS : lignes changées de %d vers %d"
-#: ../raster/r.in.arc/main.c:138 ../raster/r.horizon/main.c:627
+#: ../raster/r.in.arc/main.c:138
+#: ../raster/r.horizon/main.c:627
#: ../raster/r.in.ascii/main.c:196
#, c-format
msgid "OOPS: cols changed from %d to %d"
msgstr "OOPS : colonnes changées de %d vers %d"
-#: ../raster/r.in.arc/main.c:161 ../raster/r.in.ascii/main.c:212
+#: ../raster/r.in.arc/main.c:161
+#: ../raster/r.in.ascii/main.c:212
#, c-format
msgid "Data conversion failed at row %d, col %d"
msgstr "Echec de la conversion de données à la ligne %d, colonne %d"
@@ -7558,7 +7952,8 @@
msgid "Illegal line in header"
msgstr "Nom du fichier de sortie illégal"
-#: ../raster/r.in.arc/gethead.c:160 ../raster/r.in.ascii/gethead.c:251
+#: ../raster/r.in.arc/gethead.c:160
+#: ../raster/r.in.ascii/gethead.c:251
#, c-format
msgid "Duplicate \"%s\" field in header"
msgstr ""
@@ -7568,7 +7963,8 @@
msgid "Illegal \"%s\" value in header: \"%s\""
msgstr ""
-#: ../raster/r.in.arc/gethead.c:173 ../raster/r.in.ascii/gethead.c:264
+#: ../raster/r.in.arc/gethead.c:173
+#: ../raster/r.in.ascii/gethead.c:264
#, c-format
msgid "\"%s\" field missing from header"
msgstr ""
@@ -7580,12 +7976,8 @@
#: ../raster/r.fill.dir/main.c:86
#, fuzzy
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtrer et générer une couche d'altitude sans dépressions et une couche de "
-"direction d'écoulement depuis une couche d'altitude donnée"
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtrer et générer une couche d'altitude sans dépressions et une couche de direction d'écoulement depuis une couche d'altitude donnée"
#: ../raster/r.fill.dir/main.c:91
msgid "Name of existing raster map containing elevation surface"
@@ -7605,9 +7997,7 @@
#: ../raster/r.fill.dir/main.c:119
msgid "Output aspect direction format (agnps, answers, or grass)"
-msgstr ""
-"Format de la direction de la couche d'aspect en sortie (agnps, answers, ou "
-"grass)"
+msgstr "Format de la direction de la couche d'aspect en sortie (agnps, answers, ou grass)"
#: ../raster/r.fill.dir/main.c:127
#, fuzzy
@@ -7646,29 +8036,35 @@
msgid "Upward pass %d"
msgstr ""
-#: ../raster/r.mfilter/getrow.c:12 ../raster/r.mfilter.fp/getrow.c:12
+#: ../raster/r.mfilter/getrow.c:12
+#: ../raster/r.mfilter.fp/getrow.c:12
#, fuzzy, c-format
msgid "Cannot read raster row %d"
msgstr "Impossible de lire la ligne raster."
-#: ../raster/r.mfilter/getrow.c:23 ../raster/r.mfilter.fp/getrow.c:23
+#: ../raster/r.mfilter/getrow.c:23
+#: ../raster/r.mfilter.fp/getrow.c:23
#, fuzzy
msgid "Error reading temporary file"
msgstr "Erreur lors de la lecture du fichier dbmscap\n"
-#: ../raster/r.mfilter/perform.c:43 ../raster/r.mfilter/perform.c:54
-#: ../raster/r.mfilter.fp/perform.c:43 ../raster/r.mfilter.fp/perform.c:54
+#: ../raster/r.mfilter/perform.c:43
+#: ../raster/r.mfilter/perform.c:54
+#: ../raster/r.mfilter.fp/perform.c:43
+#: ../raster/r.mfilter.fp/perform.c:54
#, fuzzy
msgid "Unable to create temporary file"
msgstr "Impossible d'écrire les fichiers temporaires"
# c-format
-#: ../raster/r.mfilter/perform.c:87 ../raster/r.mfilter.fp/perform.c:87
+#: ../raster/r.mfilter/perform.c:87
+#: ../raster/r.mfilter.fp/perform.c:87
#, fuzzy, c-format
msgid "Writing raster map <%s>"
msgstr "Couche raster %i créée \n"
-#: ../raster/r.mfilter/main.c:51 ../raster/r.mfilter.fp/main.c:58
+#: ../raster/r.mfilter/main.c:51
+#: ../raster/r.mfilter.fp/main.c:58
#: ../raster/r.bitpattern/main.c:62
#, fuzzy
msgid "raster, map algebra"
@@ -7684,16 +8080,19 @@
msgid "Path to filter file"
msgstr "Chemin du fichier VTK en sortie"
-#: ../raster/r.mfilter/main.c:71 ../raster/r.mfilter.fp/main.c:78
+#: ../raster/r.mfilter/main.c:71
+#: ../raster/r.mfilter.fp/main.c:78
msgid "Number of times to repeat the filter"
msgstr "Nombre de fois que sera répété le filtre"
-#: ../raster/r.mfilter/main.c:72 ../raster/r.mfilter/main.c:96
+#: ../raster/r.mfilter/main.c:72
+#: ../raster/r.mfilter/main.c:96
#, fuzzy
msgid "Filter"
msgstr "Type de donnée vectorielle"
-#: ../raster/r.mfilter/main.c:78 ../raster/r.mfilter.fp/main.c:84
+#: ../raster/r.mfilter/main.c:78
+#: ../raster/r.mfilter.fp/main.c:84
msgid "Output raster map title"
msgstr "Titre du fichier raster de sortie"
@@ -7701,73 +8100,88 @@
msgid "Apply filter only to zero data values"
msgstr "Appliquer le filtre uniquement aux valeurs de données zéro"
-#: ../raster/r.mfilter/main.c:104 ../raster/r.mfilter.fp/main.c:109
-#: ../raster/r.kappa/main.c:133 ../raster/r.out.ppm/main.c:81
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead"
+#: ../raster/r.mfilter/main.c:104
+#: ../raster/r.mfilter.fp/main.c:109
+#: ../raster/r.kappa/main.c:133
+#: ../raster/r.out.ppm/main.c:81
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
msgstr ""
-#: ../raster/r.mfilter/main.c:133 ../raster/r.mfilter.fp/main.c:138
+#: ../raster/r.mfilter/main.c:133
+#: ../raster/r.mfilter.fp/main.c:138
#, fuzzy
msgid "Raster map too small for the size of the filter"
msgstr "couche raster où remplacer les valeurs null"
# c-format
-#: ../raster/r.mfilter/getfilt.c:26 ../raster/r.mfilter.fp/getfilt.c:27
+#: ../raster/r.mfilter/getfilt.c:26
+#: ../raster/r.mfilter.fp/getfilt.c:27
#, fuzzy, c-format
msgid "Cannot open filter file '%s'"
msgstr "Impossible d'ouvrir le fichier [%s]"
-#: ../raster/r.mfilter/getfilt.c:46 ../raster/r.mfilter.fp/getfilt.c:47
+#: ../raster/r.mfilter/getfilt.c:46
+#: ../raster/r.mfilter.fp/getfilt.c:47
#, fuzzy
msgid "Illegal filter matrix size specified"
msgstr "2 couches doivent être spécifiées"
-#: ../raster/r.mfilter/getfilt.c:49 ../raster/r.mfilter.fp/getfilt.c:50
+#: ../raster/r.mfilter/getfilt.c:49
+#: ../raster/r.mfilter.fp/getfilt.c:50
#, fuzzy
msgid "Even filter matrix size specified"
-#: ../raster/r.mfilter/getfilt.c:71 ../raster/r.mfilter.fp/getfilt.c:72
+#: ../raster/r.mfilter/getfilt.c:71
+#: ../raster/r.mfilter.fp/getfilt.c:72
#, fuzzy
msgid "Illegal filter matrix"
msgstr "nom de fichier illégal [%s]"
-#: ../raster/r.mfilter/getfilt.c:79 ../raster/r.mfilter/getfilt.c:105
-#: ../raster/r.mfilter/getfilt.c:122 ../raster/r.mfilter.fp/getfilt.c:80
-#: ../raster/r.mfilter.fp/getfilt.c:107 ../raster/r.mfilter.fp/getfilt.c:124
+#: ../raster/r.mfilter/getfilt.c:79
+#: ../raster/r.mfilter/getfilt.c:105
+#: ../raster/r.mfilter/getfilt.c:122
+#: ../raster/r.mfilter.fp/getfilt.c:80
+#: ../raster/r.mfilter.fp/getfilt.c:107
+#: ../raster/r.mfilter.fp/getfilt.c:124
#, fuzzy
msgid "Filter file format error"
msgstr "Fichier source"
-#: ../raster/r.mfilter/getfilt.c:82 ../raster/r.mfilter.fp/getfilt.c:83
+#: ../raster/r.mfilter/getfilt.c:82
+#: ../raster/r.mfilter.fp/getfilt.c:83
msgid "Duplicate filter divisor specified"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:99 ../raster/r.mfilter.fp/getfilt.c:101
+#: ../raster/r.mfilter/getfilt.c:99
+#: ../raster/r.mfilter.fp/getfilt.c:101
msgid "Illegal divisor matrix"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:108 ../raster/r.mfilter.fp/getfilt.c:110
+#: ../raster/r.mfilter/getfilt.c:108
+#: ../raster/r.mfilter.fp/getfilt.c:110
msgid "Duplicate filter type specified"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:115 ../raster/r.mfilter.fp/getfilt.c:117
+#: ../raster/r.mfilter/getfilt.c:115
+#: ../raster/r.mfilter.fp/getfilt.c:117
#, fuzzy
msgid "Illegal filter type specified"
-#: ../raster/r.mfilter/getfilt.c:125 ../raster/r.mfilter.fp/getfilt.c:127
+#: ../raster/r.mfilter/getfilt.c:125
+#: ../raster/r.mfilter.fp/getfilt.c:127
msgid "Duplicate filter start specified"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:133 ../raster/r.mfilter.fp/getfilt.c:135
+#: ../raster/r.mfilter/getfilt.c:133
+#: ../raster/r.mfilter.fp/getfilt.c:135
#, c-format
msgid "Filter start %s ignored, using UL"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:155 ../raster/r.mfilter.fp/getfilt.c:157
+#: ../raster/r.mfilter/getfilt.c:155
+#: ../raster/r.mfilter.fp/getfilt.c:157
#, fuzzy
msgid "Illegal filter file format"
msgstr "Echec pour définir le format du fichier de sites"
@@ -7837,19 +8251,16 @@
msgid "Failed writing raster map row %d"
-#: ../raster/r.clump/main.c:49 ../raster/r.reclass/main.c:49
+#: ../raster/r.clump/main.c:49
+#: ../raster/r.reclass/main.c:49
#, fuzzy
msgid "raster, statistics, reclass"
msgstr "Statistiques de transition de classe."
#: ../raster/r.clump/main.c:51
#, fuzzy
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Reclasser les données dans une couche raster en regroupant les cellules qui "
-"forment des zones physiques discrètes."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Reclasser les données dans une couche raster en regroupant les cellules qui forment des zones physiques discrètes."
#: ../raster/r.clump/main.c:120
#, fuzzy, c-format
@@ -7872,20 +8283,34 @@
msgid "Type of color table"
msgstr "Type de la table de couleur"
-#: ../raster/r.colors/main.c:193 ../raster/r.colors/main.c:207
-#: ../raster/r.colors/main.c:225 ../raster/r.colors/main.c:230
-#: ../raster/r.colors/main.c:235 ../raster/r.colors/main.c:240
-#: ../display/d.vect/main.c:123 ../display/d.vect/main.c:133
-#: ../display/d.vect/main.c:140 ../display/d.vect/main.c:151
-#: ../display/d.vect/main.c:319 ../display/d.vect/main.c:325
-#: ../display/d.vect/main.c:345 ../display/d.rast.num/number.c:101
-#: ../display/d.rast.num/number.c:111 ../display/d.rast.num/number.c:125
-#: ../vector/v.label/main.c:153 ../vector/v.label/main.c:177
-#: ../vector/v.label/main.c:190 ../vector/v.label/main.c:196
-#: ../vector/v.label/main.c:206 ../vector/v.label.sa/main.c:149
-#: ../vector/v.label.sa/main.c:159 ../vector/v.label.sa/main.c:166
-#: ../vector/v.label.sa/main.c:176 ../vector/v.label.sa/main.c:186
-#: ../vector/v.label.sa/main.c:196 ../vector/v.label.sa/main.c:203
+#: ../raster/r.colors/main.c:193
+#: ../raster/r.colors/main.c:207
+#: ../raster/r.colors/main.c:225
+#: ../raster/r.colors/main.c:230
+#: ../raster/r.colors/main.c:235
+#: ../raster/r.colors/main.c:240
+#: ../display/d.vect/main.c:123
+#: ../display/d.vect/main.c:133
+#: ../display/d.vect/main.c:140
+#: ../display/d.vect/main.c:151
+#: ../display/d.vect/main.c:319
+#: ../display/d.vect/main.c:325
+#: ../display/d.vect/main.c:345
+#: ../display/d.rast.num/number.c:101
+#: ../display/d.rast.num/number.c:111
+#: ../display/d.rast.num/number.c:125
+#: ../vector/v.label/main.c:153
+#: ../vector/v.label/main.c:177
+#: ../vector/v.label/main.c:190
+#: ../vector/v.label/main.c:196
+#: ../vector/v.label/main.c:206
+#: ../vector/v.label.sa/main.c:149
+#: ../vector/v.label.sa/main.c:159
+#: ../vector/v.label.sa/main.c:166
+#: ../vector/v.label.sa/main.c:176
+#: ../vector/v.label.sa/main.c:186
+#: ../vector/v.label.sa/main.c:196
+#: ../vector/v.label.sa/main.c:203
#: ../locale/scriptstrings/v.colors_to_translate.c:7
#: ../locale/scriptstrings/v.colors_to_translate.c:10
#: ../locale/scriptstrings/v.colors_to_translate.c:12
@@ -7911,8 +8336,7 @@
#: ../raster/r.colors/main.c:216
msgid "Only write new color table if one doesn't already exist"
-msgstr ""
-"N'écrire une nouvelle table de couleur que s'il n'en existe pas déjà une"
+msgstr "N'écrire une nouvelle table de couleur que s'il n'en existe pas déjà une"
#: ../raster/r.colors/main.c:220
#, fuzzy
@@ -7949,16 +8373,11 @@
#: ../raster/r.colors/main.c:281
#, fuzzy
-msgid ""
-"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
-"specified!"
-msgstr ""
-"L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
+msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+msgstr "L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
#: ../raster/r.colors/main.c:284
-msgid ""
-"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
-"options"
+msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
msgstr ""
#: ../raster/r.colors/main.c:291
@@ -7968,9 +8387,7 @@
#: ../raster/r.colors/main.c:302
#, fuzzy
msgid "-g and -a flags are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
# c-format
#: ../raster/r.colors/main.c:312
@@ -7991,23 +8408,17 @@
#: ../raster/r.colors/main.c:344
#, fuzzy
msgid "Color table 'random' is not supported for floating point raster map"
-msgstr ""
-"Impossible de construire une table de couleurs aléatoire pour les couches en "
-"valeurs flottantes"
+msgstr "Impossible de construire une table de couleurs aléatoire pour les couches en valeurs flottantes"
#: ../raster/r.colors/main.c:349
#, fuzzy
msgid "Color table 'grey.eq' is not supported for floating point raster map"
-msgstr ""
-"Impossible de construire une table en valeurs de gris pour les couches en "
+msgstr "Impossible de construire une table en valeurs de gris pour les couches en valeurs flottantes"
#: ../raster/r.colors/main.c:356
#, fuzzy
msgid "Color table 'grey.log' is not supported for floating point raster map"
-msgstr ""
#: ../raster/r.colors/main.c:369
#, fuzzy, c-format
@@ -8028,16 +8439,15 @@
#: ../raster/r.colors/rules.c:42
#, c-format
msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr ""
-"Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez "
-"besoin.\n"
+msgstr "Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez besoin.\n"
#: ../raster/r.colors/rules.c:51
#, fuzzy, c-format
msgid "fp: Data range is %s to %s\n"
msgstr "fp: L'intervalle va de %.25f à %.25f\n"
-#: ../raster/r.colors/rules.c:55 ../raster/r.reclass/main.c:113
+#: ../raster/r.colors/rules.c:55
+#: ../raster/r.reclass/main.c:113
#, c-format
msgid "Data range is %ld to %ld\n"
msgstr "L'intervalle va de %ld à %ld\n"
@@ -8049,7 +8459,8 @@
" (rules %f to %f but data %f to %f)"
msgstr "Vos règles de couleurs n'englobent pas la totalité des données!"
-#: ../raster/r.colors/rules.c:106 ../raster/r.reclass/parse.c:40
+#: ../raster/r.colors/rules.c:106
+#: ../raster/r.reclass/parse.c:40
#, c-format
msgid "Enter a rule in one of these formats:\n"
msgstr "Entrez une règle dans l'un des formats suivants:\n"
@@ -8098,7 +8509,8 @@
msgid "Unable to use logarithmic scaling if range includes zero"
msgstr ""
-#: ../raster/r.to.rast3/main.c:58 ../raster/r.to.rast3elev/main.c:183
+#: ../raster/r.to.rast3/main.c:58
+#: ../raster/r.to.rast3elev/main.c:183
msgid "Could not close the map"
msgstr "Impossible de fermer la couche : couche d'entrée introuvable"
@@ -8129,14 +8541,11 @@
msgid "No output map"
msgstr "Aucune couche créée en sortie"
-#: ../raster/r.to.rast3/main.c:222 ../raster/r.to.rast3elev/main.c:462
+#: ../raster/r.to.rast3/main.c:222
+#: ../raster/r.to.rast3elev/main.c:462
#, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
-msgstr ""
-"Les réglages de région 2D et 3D sont différents. Utilisation des réglages de "
-"carte 3D pour ajuster la région 2D."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de carte 3D pour ajuster la région 2D."
#: ../raster/r.to.rast3/main.c:260
#, fuzzy
@@ -8146,30 +8555,30 @@
#: ../raster/r.to.rast3/main.c:268
#, c-format
msgid "Open raster map %s - one time for each depth (%d/%d)"
-msgstr ""
-"Ouvrir la couche raster %s - une couche pour chaque niveau de profondeur (%d/"
-"%d)"
+msgstr "Ouvrir la couche raster %s - une couche pour chaque niveau de profondeur (%d/%d)"
#: ../raster/r.to.rast3/main.c:281
msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-"Les couches en entrée doivent être composées du même type de données : soit "
-"CELL, FCELL ou DCELL!"
+msgstr "Les couches en entrée doivent être composées du même type de données : soit CELL, FCELL ou DCELL!"
-#: ../raster/r.to.rast3/main.c:285 ../raster/r.to.rast3elev/main.c:498
+#: ../raster/r.to.rast3/main.c:285
+#: ../raster/r.to.rast3elev/main.c:498
#, fuzzy
msgid "Creating 3D raster map"
msgstr "Création de la couche raster 3D\n"
-#: ../raster/r.to.rast3/main.c:309 ../raster/r.to.rast3elev/main.c:483
+#: ../raster/r.to.rast3/main.c:309
+#: ../raster/r.to.rast3elev/main.c:483
msgid "Error opening 3d raster map"
msgstr "Erreur à l'ouverture du fichier raster 3D"
-#: ../raster/r.to.rast3/main.c:341 ../raster/r.to.rast3elev/main.c:546
+#: ../raster/r.to.rast3/main.c:341
+#: ../raster/r.to.rast3elev/main.c:546
msgid "Error closing 3d raster map"
msgstr "Erreur de fermeture du fichier raster 3D"
-#: ../raster/r.to.rast3/main.c:378 ../raster/r.to.rast3elev/main.c:171
+#: ../raster/r.to.rast3/main.c:378
+#: ../raster/r.to.rast3elev/main.c:171
#, fuzzy
msgid "Unable to close input map"
msgstr "Impossible de fermer la couche source"
@@ -8195,20 +8604,13 @@
msgstr "time et insol_time ne sont pas compatibles"
#: ../raster/r.sun/main.c:417
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
-"time"
-msgstr ""
-"Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure "
-"locale donnée"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
+msgstr "Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure locale donnée"
-#: ../raster/r.sun/main.c:472 ../raster/r.horizon/main.c:479
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
-msgstr ""
-"Impossible de récupérer les infos de projection du Secteur courant : "
-"veuillez régler la latitude grâce à 'lat' ou à l'option 'latin'!"
+#: ../raster/r.sun/main.c:472
+#: ../raster/r.horizon/main.c:479
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "Impossible de récupérer les infos de projection du Secteur courant : veuillez régler la latitude grâce à 'lat' ou à l'option 'latin'!"
# c-format
#: ../raster/r.sun/main.c:527
@@ -8259,9 +8661,12 @@
# c-format
-#: ../raster/r.sun/main.c:734 ../raster/r.sun/main.c:741
-#: ../raster/r.sun/main.c:748 ../raster/r.sun/main.c:755
-#: ../raster/r.sun/main.c:762 ../raster/r.horizon/main.c:618
+#: ../raster/r.sun/main.c:734
+#: ../raster/r.sun/main.c:741
+#: ../raster/r.sun/main.c:748
+#: ../raster/r.sun/main.c:755
+#: ../raster/r.sun/main.c:762
+#: ../raster/r.horizon/main.c:618
#, c-format
msgid "Unable to create raster map %s"
msgstr "Impossible de créer la couche raster %s"
@@ -8276,51 +8681,62 @@
msgid "cols changed from %d to %d"
msgstr "colonnes changées de %d vers %d"
-#: ../raster/r.sun/main.c:1345 ../raster/r.horizon/main.c:815
-#: ../raster/r.horizon/main.c:833 ../ps/ps.map/do_geogrid.c:87
-#: ../ps/ps.map/do_geogrid.c:92 ../ps/ps.map/do_geogrid.c:116
-#: ../ps/ps.map/do_geogrid.c:121 ../ps/ps.map/do_geogrid.c:191
-#: ../ps/ps.map/do_geogrid.c:230 ../ps/ps.map/do_geogrid.c:306
-#: ../ps/ps.map/do_geogrid.c:322 ../ps/ps.map/do_geogrid.c:339
-#: ../ps/ps.map/do_geogrid.c:356 ../ps/ps.map/do_geogrid.c:412
-#: ../ps/ps.map/do_geogrid.c:418 ../ps/ps.map/do_geogrid.c:422
-#: ../ps/ps.map/do_geogrid.c:430 ../ps/ps.map/do_geogrid.c:434
-#: ../display/d.grid/plot.c:193 ../display/d.grid/plot.c:199
-#: ../display/d.grid/plot.c:244 ../display/d.grid/plot.c:250
-#: ../display/d.grid/plot.c:379 ../display/d.grid/plot.c:395
-#: ../display/d.grid/plot.c:412 ../display/d.grid/plot.c:429
+#: ../raster/r.sun/main.c:1345
+#: ../raster/r.horizon/main.c:815
+#: ../raster/r.horizon/main.c:833
+#: ../ps/ps.map/do_geogrid.c:87
+#: ../ps/ps.map/do_geogrid.c:92
+#: ../ps/ps.map/do_geogrid.c:116
+#: ../ps/ps.map/do_geogrid.c:121
+#: ../ps/ps.map/do_geogrid.c:191
+#: ../ps/ps.map/do_geogrid.c:230
+#: ../ps/ps.map/do_geogrid.c:306
+#: ../ps/ps.map/do_geogrid.c:322
+#: ../ps/ps.map/do_geogrid.c:339
+#: ../ps/ps.map/do_geogrid.c:356
+#: ../ps/ps.map/do_geogrid.c:412
+#: ../ps/ps.map/do_geogrid.c:418
+#: ../ps/ps.map/do_geogrid.c:422
+#: ../ps/ps.map/do_geogrid.c:430
+#: ../ps/ps.map/do_geogrid.c:434
+#: ../display/d.grid/plot.c:193
+#: ../display/d.grid/plot.c:199
+#: ../display/d.grid/plot.c:244
+#: ../display/d.grid/plot.c:250
+#: ../display/d.grid/plot.c:379
+#: ../display/d.grid/plot.c:395
+#: ../display/d.grid/plot.c:412
+#: ../display/d.grid/plot.c:429
msgid "Error in pj_do_proj"
msgstr "Erreur dans pj_do_proj"
-#: ../raster/r.le/r.le.patch/main.c:47 ../raster/r.le/r.le.trace/main.c:57
-#: ../raster/r.le/r.le.setup/main.c:61 ../raster/r.le/r.le.pixel/main.c:45
-#: ../raster/r.li/r.li.shape/main.c:33 ../raster/r.li/r.li.cwed/cwed.c:45
-#: ../raster/r.li/r.li.patchnum/main.c:35 ../raster/r.li/r.li.mps/mps.c:40
+#: ../raster/r.le/r.le.patch/main.c:47
+#: ../raster/r.le/r.le.trace/main.c:57
+#: ../raster/r.le/r.le.setup/main.c:61
+#: ../raster/r.le/r.le.pixel/main.c:45
+#: ../raster/r.li/r.li.shape/main.c:33
+#: ../raster/r.li/r.li.cwed/cwed.c:45
+#: ../raster/r.li/r.li.patchnum/main.c:35
+#: ../raster/r.li/r.li.mps/mps.c:40
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
#: ../raster/r.li/r.li.padrange/padrange.c:38
-#: ../raster/r.li/r.li.padsd/padsd.c:36 ../raster/r.li/r.li.mpa/mpa.c:38
+#: ../raster/r.li/r.li.padsd/padsd.c:36
+#: ../raster/r.li/r.li.mpa/mpa.c:38
#: ../raster/r.li/r.li.padcv/padcv.c:38
#: ../raster/r.li/r.li.patchdensity/main.c:34
msgid "raster, landscape structure analysis, patch index"
msgstr ""
#: ../raster/r.le/r.le.patch/main.c:49
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
msgstr ""
#: ../raster/r.le/r.le.trace/main.c:59
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
msgstr ""
#: ../raster/r.le/r.le.setup/main.c:63
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
msgstr ""
#: ../raster/r.le/r.le.setup/main.c:67
@@ -8338,9 +8754,7 @@
msgstr "Impossible de lire la couche vecteur"
#: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
msgstr ""
#: ../raster/r.digit/get_label.c:31
@@ -8358,19 +8772,13 @@
msgstr "C'est bon?"
#: ../raster/r.digit/main.c:47
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Outil interactif pour dessiner et sauvegarder des objets vecteurs à l'écran "
-"en utilisant un périphérique de pointage (souris) et de sauvegarder une "
-"couche vectorielle."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Outil interactif pour dessiner et sauvegarder des objets vecteurs à l'écran en utilisant un périphérique de pointage (souris) et de sauvegarder une couche vectorielle."
-#: ../raster/r.digit/main.c:56 ../vector/v.digit/main.c:117
+#: ../raster/r.digit/main.c:56
+#: ../vector/v.digit/main.c:117
msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
-"Commandes d'affichage à utiliser pour l'arrière-plan de numérisation "
-"(séparée par ';')"
+msgstr "Commandes d'affichage à utiliser pour l'arrière-plan de numérisation (séparée par ';')"
#: ../raster/r.digit/main.c:79
msgid "No graphics device selected!"
@@ -8414,7 +8822,8 @@
msgid "Quit without creating a map?? "
msgstr "Voulez-vous vraiment quitter sans créer de couche??"
-#: ../raster/r.surf.contour/main.c:52 ../raster/r.surf.idw2/main.c:60
+#: ../raster/r.surf.contour/main.c:52
+#: ../raster/r.surf.idw2/main.c:60
#: ../raster/r.surf.idw/main.c:69
#, fuzzy
msgid "raster, interpolation"
@@ -8434,19 +8843,14 @@
#: ../raster/r.surf.contour/main.c:72
msgid "Unused; retained for compatibility purposes, will be removed in future"
-msgstr ""
-"Inutile; conservé pour des questions de compatibilité, sera supprimé dans le "
-"futur"
+msgstr "Inutile; conservé pour des questions de compatibilité, sera supprimé dans le futur"
#: ../raster/r.surf.contour/main.c:77
-msgid ""
-"Invoke slow, but memory frugal operation (generally not needed, will be "
-"removed in future)"
-msgstr ""
-"Lance une opération lente, mais économe en mémoire (généralement ce n'est "
-"pas nécessaire, sera supprimé dans le futur)"
+msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
+msgstr "Lance une opération lente, mais économe en mémoire (généralement ce n'est pas nécessaire, sera supprimé dans le futur)"
-#: ../raster/r.in.bin/main.c:49 ../raster/r.in.bin/main.c:58
+#: ../raster/r.in.bin/main.c:49
+#: ../raster/r.in.bin/main.c:58
#: ../raster/r.in.bin/main.c:510
#, fuzzy
msgid "Error reading data"
@@ -8465,27 +8869,40 @@
#: ../raster/r.in.bin/main.c:246
#, fuzzy
msgid "Import as double-precision floating-point data (default: integer)"
-msgstr ""
-"Importer comme virgule flottante en double précision (par défaut : entier)"
+msgstr "Importer comme virgule flottante en double précision (par défaut : entier)"
#: ../raster/r.in.bin/main.c:250
msgid "Signed data (two's complement)"
msgstr ""
-#: ../raster/r.in.bin/main.c:251 ../raster/r.in.bin/main.c:256
-#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:346
-#: ../raster/r.resamp.rst/main.c:231 ../raster/r.resamp.rst/main.c:239
-#: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:255
-#: ../raster/r.resamp.rst/main.c:263 ../raster/r.slope.aspect/main.c:181
-#: ../raster/r.slope.aspect/main.c:191 ../raster/r.slope.aspect/main.c:249
-#: ../raster/r.slope.aspect/main.c:258 ../raster/r.slope.aspect/main.c:269
-#: ../imagery/i.landsat.toar/main.c:148 ../imagery/i.landsat.toar/main.c:156
-#: ../imagery/i.landsat.toar/main.c:165 ../imagery/i.landsat.toar/main.c:173
-#: ../imagery/i.cluster/main.c:105 ../imagery/i.cluster/main.c:121
-#: ../imagery/i.cluster/main.c:129 ../imagery/i.cluster/main.c:138
-#: ../imagery/i.cluster/main.c:146 ../imagery/i.cluster/main.c:154
-#: ../general/g.mapset/main.c:58 ../general/g.mapset/main.c:66
-#: ../general/g.mapset/main.c:76 ../vector/v.db.connect/main.c:60
+#: ../raster/r.in.bin/main.c:251
+#: ../raster/r.in.bin/main.c:256
+#: ../raster/r.in.bin/main.c:285
+#: ../raster/r.in.bin/main.c:346
+#: ../raster/r.resamp.rst/main.c:231
+#: ../raster/r.resamp.rst/main.c:239
+#: ../raster/r.resamp.rst/main.c:247
+#: ../raster/r.resamp.rst/main.c:255
+#: ../raster/r.resamp.rst/main.c:263
+#: ../raster/r.slope.aspect/main.c:181
+#: ../raster/r.slope.aspect/main.c:191
+#: ../raster/r.slope.aspect/main.c:249
+#: ../raster/r.slope.aspect/main.c:258
+#: ../raster/r.slope.aspect/main.c:269
+#: ../imagery/i.landsat.toar/main.c:148
+#: ../imagery/i.landsat.toar/main.c:156
+#: ../imagery/i.landsat.toar/main.c:165
+#: ../imagery/i.landsat.toar/main.c:173
+#: ../imagery/i.cluster/main.c:105
+#: ../imagery/i.cluster/main.c:121
+#: ../imagery/i.cluster/main.c:129
+#: ../imagery/i.cluster/main.c:138
+#: ../imagery/i.cluster/main.c:146
+#: ../imagery/i.cluster/main.c:154
+#: ../general/g.mapset/main.c:58
+#: ../general/g.mapset/main.c:66
+#: ../general/g.mapset/main.c:76
+#: ../vector/v.db.connect/main.c:60
#: ../vector/v.db.connect/main.c:65
#: ../vector/lidar/v.lidar.edgedetection/main.c:99
#: ../vector/lidar/v.lidar.edgedetection/main.c:108
@@ -8499,14 +8916,23 @@
#: ../vector/lidar/v.surf.bspline/main.c:138
#: ../vector/lidar/v.surf.bspline/main.c:146
#: ../vector/lidar/v.surf.bspline/main.c:153
-#: ../vector/lidar/v.surf.bspline/main.c:160 ../vector/v.vol.rst/main.c:261
-#: ../vector/v.vol.rst/main.c:269 ../vector/v.vol.rst/main.c:277
-#: ../vector/v.vol.rst/main.c:310 ../vector/v.vol.rst/main.c:319
-#: ../vector/v.vol.rst/main.c:328 ../vector/v.vol.rst/main.c:337
-#: ../vector/v.vol.rst/main.c:346 ../vector/v.vol.rst/main.c:354
-#: ../vector/v.surf.idw/main.c:115 ../vector/v.surf.idw/main.c:123
-#: ../vector/v.surf.idw/main.c:131 ../db/base/connect.c:62
-#: ../db/base/connect.c:66 ../db/base/connect.c:77 ../db/base/connect.c:87
+#: ../vector/lidar/v.surf.bspline/main.c:160
+#: ../vector/v.vol.rst/main.c:261
+#: ../vector/v.vol.rst/main.c:269
+#: ../vector/v.vol.rst/main.c:277
+#: ../vector/v.vol.rst/main.c:310
+#: ../vector/v.vol.rst/main.c:319
+#: ../vector/v.vol.rst/main.c:328
+#: ../vector/v.vol.rst/main.c:337
+#: ../vector/v.vol.rst/main.c:346
+#: ../vector/v.vol.rst/main.c:354
+#: ../vector/v.surf.idw/main.c:115
+#: ../vector/v.surf.idw/main.c:123
+#: ../vector/v.surf.idw/main.c:131
+#: ../db/base/connect.c:62
+#: ../db/base/connect.c:66
+#: ../db/base/connect.c:77
+#: ../db/base/connect.c:87
msgid "Settings"
msgstr "Réglages"
@@ -8518,14 +8944,22 @@
msgid "Get region info from GMT style header"
msgstr "Extraire l'information de région d'un en-tête au format GMT"
-#: ../raster/r.in.bin/main.c:261 ../raster/r.in.bin/main.c:301
-#: ../raster/r.in.bin/main.c:309 ../raster/r.in.bin/main.c:317
-#: ../raster/r.in.bin/main.c:325 ../raster/r.in.bin/main.c:332
-#: ../raster/r.in.bin/main.c:339 ../general/g.region/main.c:157
-#: ../general/g.region/main.c:217 ../general/g.region/main.c:227
-#: ../general/g.region/main.c:237 ../general/g.region/main.c:247
-#: ../general/g.region/main.c:256 ../general/g.region/main.c:265
-#: ../general/g.region/main.c:343 ../general/g.region/main.c:354
+#: ../raster/r.in.bin/main.c:261
+#: ../raster/r.in.bin/main.c:301
+#: ../raster/r.in.bin/main.c:309
+#: ../raster/r.in.bin/main.c:317
+#: ../raster/r.in.bin/main.c:325
+#: ../raster/r.in.bin/main.c:332
+#: ../raster/r.in.bin/main.c:339
+#: ../general/g.region/main.c:157
+#: ../general/g.region/main.c:217
+#: ../general/g.region/main.c:227
+#: ../general/g.region/main.c:237
+#: ../general/g.region/main.c:247
+#: ../general/g.region/main.c:256
+#: ../general/g.region/main.c:265
+#: ../general/g.region/main.c:343
+#: ../general/g.region/main.c:354
msgid "Bounds"
msgstr "Limites"
@@ -8534,12 +8968,14 @@
msgid "Binary raster file to be imported"
msgstr "Fichier raster à importer"
-#: ../raster/r.in.bin/main.c:284 ../raster/r.out.bin/main.c:310
+#: ../raster/r.in.bin/main.c:284
+#: ../raster/r.out.bin/main.c:310
#, fuzzy
msgid "Number of bytes per cell"
msgstr "\t\tNombre de bits par cellule"
-#: ../raster/r.in.bin/main.c:292 ../raster/r.out.bin/main.c:317
+#: ../raster/r.in.bin/main.c:292
+#: ../raster/r.out.bin/main.c:317
#, fuzzy
msgid "Output byte order"
msgstr "Sortie du fichier TIFF world"
@@ -8575,16 +9011,12 @@
#: ../raster/r.in.bin/main.c:366
#, fuzzy
msgid "order= and -b are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.in.bin/main.c:381
#, fuzzy
msgid "-f and -d are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.in.bin/main.c:385
#, c-format
@@ -8619,7 +9051,8 @@
# c-format
-#: ../raster/r.in.bin/main.c:433 ../display/d.grid/main.c:181
+#: ../raster/r.in.bin/main.c:433
+#: ../display/d.grid/main.c:181
#, c-format
msgid "Illegal north coordinate <%s>"
msgstr "Coordonnée Nord <%s> illégale"
@@ -8630,7 +9063,8 @@
msgid "Illegal south coordinate <%s>"
-#: ../raster/r.in.bin/main.c:437 ../display/d.grid/main.c:175
+#: ../raster/r.in.bin/main.c:437
+#: ../display/d.grid/main.c:175
#, c-format
msgid "Illegal east coordinate <%s>"
msgstr "Coordonnées Est <%s> illégale"
@@ -8648,9 +9082,7 @@
#: ../raster/r.in.bin/main.c:464
#, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
msgstr ""
#: ../raster/r.in.bin/main.c:487
@@ -8673,12 +9105,8 @@
msgstr "impossible d'ouvrir le fichier 3dview <%s> dans <%s>"
#: ../raster/r.kappa/main.c:69
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Calculer la matrice d'erreur et le paramètre kappa pour estimer la précision "
-"de la classification obtenue."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Calculer la matrice d'erreur et le paramètre kappa pour estimer la précision de la classification obtenue."
#: ../raster/r.kappa/main.c:75
#, fuzzy
@@ -8713,12 +9141,14 @@
msgid "No header in the report"
msgstr "Par d'en-tête dans le rapport"
-#: ../raster/r.kappa/main.c:121 ../imagery/i.cca/main.c:117
+#: ../raster/r.kappa/main.c:121
+#: ../imagery/i.cca/main.c:117
#, fuzzy, c-format
msgid "Illegal output file name <%s>"
-#: ../raster/r.kappa/stats.c:13 ../raster/r.report/stats.c:99
+#: ../raster/r.kappa/stats.c:13
+#: ../raster/r.report/stats.c:99
msgid "Problem reading r.stats output"
msgstr "Problème de lecture de r.stats en sortie"
@@ -8765,10 +9195,14 @@
msgid "Output world file"
-#: ../raster/r.out.png/r.out.png.c:196 ../display/d.paint.labels/color.c:66
-#: ../display/d.text/main.c:147 ../display/d.text.freetype/main.c:842
-#: ../display/d.rast/display.c:32 ../display/d.graph/do_graph.c:112
-#: ../display/d.graph/do_graph.c:393 ../display/d.graph/do_graph.c:408
+#: ../raster/r.out.png/r.out.png.c:196
+#: ../display/d.paint.labels/color.c:66
+#: ../display/d.text/main.c:147
+#: ../display/d.text.freetype/main.c:842
+#: ../display/d.rast/display.c:32
+#: ../display/d.graph/do_graph.c:112
+#: ../display/d.graph/do_graph.c:393
+#: ../display/d.graph/do_graph.c:408
#: ../display/d.graph/main.c:103
#, c-format
msgid "[%s]: No such color"
@@ -8780,18 +9214,24 @@
msgid "Converting <%s>..."
msgstr "Écriture [%s]..."
-#: ../raster/r.out.png/r.out.png.c:300 ../raster/r.univar2/r.univar_main.c:183
+#: ../raster/r.out.png/r.out.png.c:300
+#: ../raster/r.univar2/r.univar_main.c:183
#, fuzzy, c-format
msgid "Raster <%s> type mismatch"
msgstr "ERREUR: <%s> existe déjà\n"
# c-format
-#: ../raster/r.out.png/r.out.png.c:321 ../raster/r.surf.idw/main.c:690
-#: ../raster/r.proj/readcell.c:27 ../raster/r.mapcalc/map.c:234
-#: ../imagery/i.smap/bouman/read_block.c:16 ../imagery/i.maxlik/main.c:117
-#: ../imagery/i.gensig/covariance.c:34 ../imagery/i.gensig/read_train.c:10
+#: ../raster/r.out.png/r.out.png.c:321
+#: ../raster/r.surf.idw/main.c:690
+#: ../raster/r.proj/readcell.c:27
+#: ../raster/r.mapcalc/map.c:234
+#: ../imagery/i.smap/bouman/read_block.c:16
+#: ../imagery/i.maxlik/main.c:117
+#: ../imagery/i.gensig/covariance.c:34
+#: ../imagery/i.gensig/read_train.c:10
#: ../imagery/i.gensigset/read_data.c:27
-#: ../imagery/i.gensigset/read_train.c:10 ../imagery/i.cluster/main.c:290
+#: ../imagery/i.gensigset/read_train.c:10
+#: ../imagery/i.cluster/main.c:290
#, fuzzy, c-format
msgid "Unable to read raster map row %d"
@@ -8801,11 +9241,13 @@
msgid "Writing world file"
msgstr "Écriture du fichier TIFF World..."
-#: ../raster/r.out.png/r.out.png.c:455 ../raster/r.out.tiff/r.out.tiff.c:417
+#: ../raster/r.out.png/r.out.png.c:455
+#: ../raster/r.out.tiff/r.out.tiff.c:417
msgid "Got null file name"
msgstr "Reçu un nom de fichier null"
-#: ../raster/r.out.png/r.out.png.c:457 ../raster/r.out.tiff/r.out.tiff.c:419
+#: ../raster/r.out.png/r.out.png.c:457
+#: ../raster/r.out.tiff/r.out.tiff.c:419
msgid "Got null region struct"
msgstr "Reçu une structure de région null"
@@ -8816,14 +9258,8 @@
#: ../raster/r.resamp.rst/main.c:158
#, fuzzy
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Ré-interpole et fait une analyse topographique depuis une couche raster vers "
-"une nouvelle couche raster (probablement avec une résolution différente) en "
-"utilisant des splines régularisées avec tension et lissage."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Ré-interpole et fait une analyse topographique depuis une couche raster vers une nouvelle couche raster (probablement avec une résolution différente) en utilisant des splines régularisées avec tension et lissage."
#: ../raster/r.resamp.rst/main.c:169
msgid "Desired east-west resolution"
@@ -8881,12 +9317,14 @@
msgid "Anisotropy angle (in degrees)"
msgstr "Angle d'anisotropie (en degrés)"
-#: ../raster/r.resamp.rst/main.c:270 ../raster/r.resamp.rst/main.c:277
+#: ../raster/r.resamp.rst/main.c:270
+#: ../raster/r.resamp.rst/main.c:277
#, fuzzy
msgid "Anisotropy"
msgstr "Entropie"
-#: ../raster/r.resamp.rst/main.c:276 ../vector/v.surf.rst/main.c:382
+#: ../raster/r.resamp.rst/main.c:276
+#: ../vector/v.surf.rst/main.c:382
msgid "Anisotropy scaling factor"
msgstr "Facteur d'échelle d'anisotropie"
@@ -8894,12 +9332,13 @@
msgid "Use dnorm independent tension"
msgstr "Utiliser une tension indépendante dnorm"
-#: ../raster/r.resamp.rst/main.c:286 ../vector/v.surf.rst/main.c:209
+#: ../raster/r.resamp.rst/main.c:286
+#: ../vector/v.surf.rst/main.c:209
msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-"Affiche les dérivées partielles à la place des paramètres topographiques"
+msgstr "Affiche les dérivées partielles à la place des paramètres topographiques"
-#: ../raster/r.resamp.rst/main.c:293 ../general/g.setproj/main.c:107
+#: ../raster/r.resamp.rst/main.c:293
+#: ../general/g.setproj/main.c:107
msgid "Retrieving and setting region failed"
msgstr "La récupération et la configuration de la région a échoué"
@@ -8933,31 +9372,35 @@
#: ../raster/r.resamp.rst/main.c:343
msgid "When using anisotropy both theta and scalex must be specified"
-msgstr ""
-"Quand vous utilisez l'anisotropie, les paramètres theta et scalex doivent "
-"être spécifiés"
+msgstr "Quand vous utilisez l'anisotropie, les paramètres theta et scalex doivent être spécifiés"
-#: ../raster/r.resamp.rst/main.c:366 ../vector/v.surf.rst/main.c:520
+#: ../raster/r.resamp.rst/main.c:366
+#: ../vector/v.surf.rst/main.c:520
msgid "Not enough memory for az"
msgstr "Mémoire insuffisante pour az"
-#: ../raster/r.resamp.rst/main.c:371 ../vector/v.surf.rst/main.c:525
+#: ../raster/r.resamp.rst/main.c:371
+#: ../vector/v.surf.rst/main.c:525
msgid "Not enough memory for adx"
msgstr "Mémoire insuffisante pour adx"
-#: ../raster/r.resamp.rst/main.c:375 ../vector/v.surf.rst/main.c:529
+#: ../raster/r.resamp.rst/main.c:375
+#: ../vector/v.surf.rst/main.c:529
msgid "Not enough memory for ady"
msgstr "Mémoire insuffisante pour ady"
-#: ../raster/r.resamp.rst/main.c:380 ../vector/v.surf.rst/main.c:534
+#: ../raster/r.resamp.rst/main.c:380
+#: ../vector/v.surf.rst/main.c:534
msgid "Not enough memory for adxx"
msgstr "Mémoire insuffisante pour adxx"
-#: ../raster/r.resamp.rst/main.c:384 ../vector/v.surf.rst/main.c:538
+#: ../raster/r.resamp.rst/main.c:384
+#: ../vector/v.surf.rst/main.c:538
msgid "Not enough memory for adyy"
msgstr "Mémoire insuffisante pour adyy"
-#: ../raster/r.resamp.rst/main.c:388 ../vector/v.surf.rst/main.c:542
+#: ../raster/r.resamp.rst/main.c:388
+#: ../vector/v.surf.rst/main.c:542
msgid "Not enough memory for adxy"
msgstr "Mémoire insuffisante pour adxy"
@@ -8972,9 +9415,7 @@
#: ../raster/r.resamp.rst/main.c:431
msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-"Résolution de la couche en entrée ne correspond pas à la résolution de la "
-"région courante!"
+msgstr "Résolution de la couche en entrée ne correspond pas à la résolution de la région courante!"
#: ../raster/r.resamp.rst/main.c:451
msgid "Processing all selected output files will require"
@@ -9006,8 +9447,10 @@
msgid "Cannot set region to back to the initial region !!!"
msgstr "Impossible de reconfigurer la région sur la région initiale !!!"
-#: ../raster/r.resamp.rst/main.c:527 ../raster/r.resample/main.c:137
-#: ../vector/v.surf.rst/main.c:622 ../vector/v.surf.rst/main.c:773
+#: ../raster/r.resamp.rst/main.c:527
+#: ../raster/r.resample/main.c:137
+#: ../vector/v.surf.rst/main.c:622
+#: ../vector/v.surf.rst/main.c:773
msgid "Percent complete: "
msgstr "Pourcentage complet :"
@@ -9021,16 +9464,23 @@
msgid "dnorm in mainc after grid before out2= %f"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:607 ../vector/v.surf.rst/main.c:638
+#: ../raster/r.resamp.rst/main.c:607
+#: ../vector/v.surf.rst/main.c:638
msgid "Not enough memory for zero_array_cell"
msgstr "Mémoire insuffisante pour zero_array_cell"
-#: ../raster/r.resamp.rst/main.c:622 ../raster/r.resamp.rst/main.c:635
-#: ../raster/r.resamp.rst/main.c:648 ../raster/r.resamp.rst/main.c:662
-#: ../raster/r.resamp.rst/main.c:675 ../raster/r.resamp.rst/main.c:688
-#: ../vector/v.surf.rst/main.c:650 ../vector/v.surf.rst/main.c:659
-#: ../vector/v.surf.rst/main.c:668 ../vector/v.surf.rst/main.c:678
-#: ../vector/v.surf.rst/main.c:687 ../vector/v.surf.rst/main.c:696
+#: ../raster/r.resamp.rst/main.c:622
+#: ../raster/r.resamp.rst/main.c:635
+#: ../raster/r.resamp.rst/main.c:648
+#: ../raster/r.resamp.rst/main.c:662
+#: ../raster/r.resamp.rst/main.c:675
+#: ../raster/r.resamp.rst/main.c:688
+#: ../vector/v.surf.rst/main.c:650
+#: ../vector/v.surf.rst/main.c:659
+#: ../vector/v.surf.rst/main.c:668
+#: ../vector/v.surf.rst/main.c:678
+#: ../vector/v.surf.rst/main.c:687
+#: ../vector/v.surf.rst/main.c:696
msgid "Not enough disk space -- cannot write files"
msgstr "Espace disque insuffisant -- impossible d'écrire les fichiers"
@@ -9091,7 +9541,8 @@
msgid "Compresses and decompresses raster maps."
msgstr "Compresser et décompresser des fichiers raster."
-#: ../raster/r.compress/main.c:73 ../display/d.what.rast/main.c:81
+#: ../raster/r.compress/main.c:73
+#: ../display/d.what.rast/main.c:81
msgid "Name of existing raster map(s)"
msgstr "Nom des couches raster existantes"
@@ -9157,13 +9608,15 @@
"%sCOMPRESS [%s]"
msgstr ""
-#: ../raster/r.proj.seg/readcell.c:57 ../imagery/i.rectify/readcell.c:55
+#: ../raster/r.proj.seg/readcell.c:57
+#: ../imagery/i.rectify/readcell.c:55
#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:62
#, fuzzy
msgid "Unable to open temporary file"
msgstr "Impossible d'ouvrir le fichier temporaire"
-#: ../raster/r.proj.seg/readcell.c:63 ../raster/r.proj/readcell.c:22
+#: ../raster/r.proj.seg/readcell.c:63
+#: ../raster/r.proj/readcell.c:22
#: ../imagery/i.rectify/readcell.c:61
#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:70
msgid "Allocating memory and reading input map..."
@@ -9174,100 +9627,125 @@
msgid "Error reading input"
msgstr "Erreur de lecture de la couche Teinte"
-#: ../raster/r.proj.seg/readcell.c:90 ../raster/r.proj.seg/readcell.c:129
-#: ../imagery/i.rectify/readcell.c:87 ../imagery/i.rectify/readcell.c:126
+#: ../raster/r.proj.seg/readcell.c:90
+#: ../raster/r.proj.seg/readcell.c:129
+#: ../imagery/i.rectify/readcell.c:87
+#: ../imagery/i.rectify/readcell.c:126
#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:98
#, fuzzy
msgid "Error writing segment file"
-#: ../raster/r.proj.seg/readcell.c:117 ../imagery/i.rectify/readcell.c:114
+#: ../raster/r.proj.seg/readcell.c:117
+#: ../imagery/i.rectify/readcell.c:114
#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:128
msgid "Internal error: cache miss on fully-cached map"
msgstr ""
-#: ../raster/r.proj.seg/readcell.c:126 ../imagery/i.rectify/readcell.c:123
+#: ../raster/r.proj.seg/readcell.c:126
+#: ../imagery/i.rectify/readcell.c:123
#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:137
#, fuzzy
msgid "Error seeking on segment file"
msgstr "Erreur de fermeture du fichier VTK-ASCII"
-#: ../raster/r.proj.seg/main.c:139 ../raster/r.proj/main.c:130
+#: ../raster/r.proj.seg/main.c:139
+#: ../raster/r.proj/main.c:130
#, fuzzy
msgid "raster, projection, transformation"
msgstr "Erreur de lecture des cellules de données"
-#: ../raster/r.proj.seg/main.c:141 ../raster/r.proj/main.c:132
+#: ../raster/r.proj.seg/main.c:141
+#: ../raster/r.proj/main.c:132
#, fuzzy
msgid "Re-projects a raster map from one location to the current location."
-msgstr ""
-"Re-projeter une couche raster depuis un Secteur (location) vers le Secteur "
-"courant."
+msgstr "Re-projeter une couche raster depuis un Secteur (location) vers le Secteur courant."
-#: ../raster/r.proj.seg/main.c:144 ../raster/r.proj/main.c:135
+#: ../raster/r.proj.seg/main.c:144
+#: ../raster/r.proj/main.c:135
#, fuzzy
msgid "Name of input raster map to re-project"
msgstr "Nom de la couche raster source"
-#: ../raster/r.proj.seg/main.c:146 ../raster/r.proj.seg/main.c:163
-#: ../raster/r.proj.seg/main.c:172 ../raster/r.proj/main.c:137
-#: ../raster/r.proj/main.c:154 ../raster/r.proj/main.c:163
-#: ../vector/v.proj/main.c:70 ../vector/v.proj/main.c:87
-#: ../vector/v.proj/main.c:96 ../vector/v.net.flow/main.c:87
-#: ../vector/v.net.flow/main.c:92 ../vector/v.net.flow/main.c:98
+#: ../raster/r.proj.seg/main.c:146
+#: ../raster/r.proj.seg/main.c:163
+#: ../raster/r.proj.seg/main.c:172
+#: ../raster/r.proj/main.c:137
+#: ../raster/r.proj/main.c:154
+#: ../raster/r.proj/main.c:163
+#: ../vector/v.proj/main.c:70
+#: ../vector/v.proj/main.c:87
+#: ../vector/v.proj/main.c:96
+#: ../vector/v.net.flow/main.c:87
+#: ../vector/v.net.flow/main.c:92
+#: ../vector/v.net.flow/main.c:98
#, fuzzy
msgid "Source"
msgstr "Variance de la somme"
-#: ../raster/r.proj.seg/main.c:152 ../raster/r.proj/main.c:143
+#: ../raster/r.proj.seg/main.c:152
+#: ../raster/r.proj/main.c:143
#, fuzzy
msgid "Location containing input raster map"
msgstr "Secteur (location) de la couche source"
-#: ../raster/r.proj.seg/main.c:160 ../raster/r.proj/main.c:151
+#: ../raster/r.proj.seg/main.c:160
+#: ../raster/r.proj/main.c:151
#, fuzzy
msgid "Mapset containing input raster map"
msgstr "Nom de la couche vecteur 2D source"
-#: ../raster/r.proj.seg/main.c:169 ../raster/r.proj/main.c:160
+#: ../raster/r.proj.seg/main.c:169
+#: ../raster/r.proj/main.c:160
#: ../vector/v.proj/main.c:93
msgid "Path to GRASS database of input location"
msgstr "Chemin vers la base de données GRASS du Secteur source"
-#: ../raster/r.proj.seg/main.c:176 ../raster/r.proj/main.c:167
+#: ../raster/r.proj.seg/main.c:176
+#: ../raster/r.proj/main.c:167
#, fuzzy
msgid "Name for output raster map (default: input)"
-#: ../raster/r.proj.seg/main.c:177 ../raster/r.proj.seg/main.c:188
-#: ../raster/r.proj.seg/main.c:201 ../raster/r.proj.seg/main.c:215
-#: ../raster/r.proj.seg/main.c:221 ../raster/r.proj/main.c:168
-#: ../raster/r.proj/main.c:179 ../raster/r.proj/main.c:186
-#: ../vector/v.proj/main.c:101 ../vector/v.proj/main.c:113
+#: ../raster/r.proj.seg/main.c:177
+#: ../raster/r.proj.seg/main.c:188
+#: ../raster/r.proj.seg/main.c:201
+#: ../raster/r.proj.seg/main.c:215
+#: ../raster/r.proj.seg/main.c:221
+#: ../raster/r.proj/main.c:168
+#: ../raster/r.proj/main.c:179
+#: ../raster/r.proj/main.c:186
+#: ../vector/v.proj/main.c:101
+#: ../vector/v.proj/main.c:113
#, fuzzy
msgid "Target"
msgstr "Entité surfacique\n"
-#: ../raster/r.proj.seg/main.c:187 ../raster/r.proj/main.c:178
+#: ../raster/r.proj.seg/main.c:187
+#: ../raster/r.proj/main.c:178
#: ../imagery/i.rectify/main.c:136
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:124
msgid "Interpolation method to use"
msgstr "Méthode d'interpolation à utiliser"
-#: ../raster/r.proj.seg/main.c:194 ../raster/r.in.gdal/main.c:106
+#: ../raster/r.proj.seg/main.c:194
+#: ../raster/r.in.gdal/main.c:106
#, fuzzy
msgid "Cache size (MiB)"
msgstr "Taille de l'étiquette (pixels)"
-#: ../raster/r.proj.seg/main.c:200 ../raster/r.proj/main.c:185
+#: ../raster/r.proj.seg/main.c:200
+#: ../raster/r.proj/main.c:185
msgid "Resolution of output map"
msgstr "Résolution de la nouvelle couche"
-#: ../raster/r.proj.seg/main.c:205 ../raster/r.proj/main.c:190
+#: ../raster/r.proj.seg/main.c:205
+#: ../raster/r.proj/main.c:190
msgid "List raster maps in input location and exit"
msgstr "Lister les couches raster de l'emplacement source et quitter"
-#: ../raster/r.proj.seg/main.c:209 ../raster/r.proj/main.c:194
+#: ../raster/r.proj.seg/main.c:209
+#: ../raster/r.proj/main.c:194
msgid "Do not perform region cropping optimization"
msgstr "Ne pas optimiser par recadrage de la région"
@@ -9278,18 +9756,18 @@
#: ../raster/r.proj.seg/main.c:220
#, fuzzy
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-"Affiche les paramètres de la région courante (à la façon d'un script shell)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr "Affiche les paramètres de la région courante (à la façon d'un script shell)"
-#: ../raster/r.proj.seg/main.c:245 ../raster/r.proj/main.c:217
+#: ../raster/r.proj.seg/main.c:245
+#: ../raster/r.proj/main.c:217
#: ../vector/v.proj/main.c:132
#, fuzzy, c-format
msgid "option <%s>: <%s> exists."
msgstr "région <%s> non trouvée"
-#: ../raster/r.proj.seg/main.c:251 ../raster/r.proj/main.c:222
+#: ../raster/r.proj.seg/main.c:251
+#: ../raster/r.proj/main.c:222
#: ../vector/v.proj/main.c:149
msgid "Input and output locations can not be the same"
msgstr ""
@@ -9299,87 +9777,93 @@
msgid "Input and output locations are the same"
msgstr "couche d'entrée : emplacement des dépressions réelles"
-#: ../raster/r.proj.seg/main.c:263 ../raster/r.proj/main.c:228
+#: ../raster/r.proj.seg/main.c:263
+#: ../raster/r.proj/main.c:228
#, fuzzy
msgid "Unable to get projection info of output raster map"
-msgstr ""
-"Impossible d'obtenir les informations de projection pour le Secteur "
-"(location) courant"
+msgstr "Impossible d'obtenir les informations de projection pour le Secteur (location) courant"
-#: ../raster/r.proj.seg/main.c:266 ../raster/r.proj/main.c:231
+#: ../raster/r.proj.seg/main.c:266
+#: ../raster/r.proj/main.c:231
#, fuzzy
msgid "Unable to get projection units of output raster map"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
-#: ../raster/r.proj.seg/main.c:269 ../raster/r.proj/main.c:234
+#: ../raster/r.proj.seg/main.c:269
+#: ../raster/r.proj/main.c:234
#, fuzzy
msgid "Unable to get projection key values of output raster map"
-msgstr ""
-"Impossible d'obtenir les valeurs clefs de projection pour le Secteur "
+msgstr "Impossible d'obtenir les valeurs clefs de projection pour le Secteur (location) courant"
-#: ../raster/r.proj.seg/main.c:278 ../raster/r.proj/main.c:243
+#: ../raster/r.proj.seg/main.c:278
+#: ../raster/r.proj/main.c:243
#, fuzzy, c-format
msgid "Mapset <%s> in input location <%s> - %s"
msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
-#: ../raster/r.proj.seg/main.c:280 ../raster/r.proj/main.c:245
-#: ../raster/r.in.gdal/main.c:680 ../imagery/i.rectify/target.c:33
+#: ../raster/r.proj.seg/main.c:280
+#: ../raster/r.proj/main.c:245
+#: ../raster/r.in.gdal/main.c:680
+#: ../imagery/i.rectify/target.c:33
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:32
msgid "permission denied"
msgstr "permission refusée"
# c-format
-#: ../raster/r.proj.seg/main.c:281 ../raster/r.proj/main.c:246
-#: ../raster/r.in.gdal/main.c:681 ../imagery/i.rectify/target.c:33
+#: ../raster/r.proj.seg/main.c:281
+#: ../raster/r.proj/main.c:246
+#: ../raster/r.in.gdal/main.c:681
#, fuzzy
msgid "not found"
msgstr "%s non trouvé"
-#: ../raster/r.proj.seg/main.c:287 ../raster/r.proj/main.c:252
+#: ../raster/r.proj.seg/main.c:287
+#: ../raster/r.proj/main.c:252
#: ../vector/v.proj/main.c:169
#, fuzzy, c-format
msgid "Checking location <%s> mapset <%s>"
msgstr "couche raster en entrée"
-#: ../raster/r.proj.seg/main.c:299 ../raster/r.proj/main.c:264
-#: ../raster/r.in.gdal/main.c:219 ../raster/r.out.gdal/main.c:230
-#: ../vector/v.in.ogr/main.c:274 ../vector/v.in.ogr/main.c:327
-#: ../vector/v.proj/main.c:181 ../vector/v.select/main.c:90
+#: ../raster/r.proj.seg/main.c:299
+#: ../raster/r.proj/main.c:264
+#: ../raster/r.in.gdal/main.c:219
+#: ../raster/r.out.gdal/main.c:230
+#: ../vector/v.in.ogr/main.c:274
+#: ../vector/v.in.ogr/main.c:327
+#: ../vector/v.proj/main.c:181
+#: ../vector/v.select/main.c:90
#, fuzzy, c-format
msgid "Required parameter <%s> not set"
msgstr "incidout demande de fixer le paramètre d'heure"
-#: ../raster/r.proj.seg/main.c:302 ../raster/r.proj/main.c:267
+#: ../raster/r.proj.seg/main.c:302
+#: ../raster/r.proj/main.c:267
#, fuzzy, c-format
msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
msgstr "Le fichier vecteur [%s] n'est pas disponible"
-#: ../raster/r.proj.seg/main.c:310 ../raster/r.proj/main.c:275
+#: ../raster/r.proj.seg/main.c:310
+#: ../raster/r.proj/main.c:275
#, fuzzy
msgid "Unable to get projection info of input map"
-msgstr ""
-#: ../raster/r.proj.seg/main.c:313 ../raster/r.proj/main.c:278
+#: ../raster/r.proj.seg/main.c:313
+#: ../raster/r.proj/main.c:278
#, fuzzy
msgid "Unable to get projection units of input map"
-msgstr ""
-"courant"
-#: ../raster/r.proj.seg/main.c:316 ../raster/r.proj/main.c:281
+#: ../raster/r.proj.seg/main.c:316
+#: ../raster/r.proj/main.c:281
#, fuzzy
msgid "Unable to get projection key values of input map"
-msgstr ""
-#: ../raster/r.proj.seg/main.c:330 ../raster/r.proj/main.c:296
+#: ../raster/r.proj.seg/main.c:330
+#: ../raster/r.proj/main.c:296
msgid "Unable to work with unprojected data (xy location)"
msgstr "Impossible de travailler sur des données non projetées (secteur xy)"
@@ -9388,82 +9872,109 @@
msgid "Input map <%s@%s> in location <%s>:"
-#: ../raster/r.proj.seg/main.c:353 ../raster/r.proj.seg/main.c:355
+#: ../raster/r.proj.seg/main.c:353
+#: ../raster/r.proj.seg/main.c:355
#: ../raster/r.sunmask/g_solposition.c:127
-#: ../general/g.region/printwindow.c:281 ../general/g.region/printwindow.c:289
-#: ../general/g.region/printwindow.c:297 ../general/g.region/printwindow.c:305
-#: ../general/g.region/printwindow.c:534 ../general/g.region/printwindow.c:542
-#: ../general/g.region/printwindow.c:550 ../general/g.region/printwindow.c:558
-#: ../general/g.region/printwindow.c:676 ../general/g.region/printwindow.c:684
-#: ../general/g.region/printwindow.c:692 ../general/g.region/printwindow.c:700
+#: ../general/g.region/printwindow.c:281
+#: ../general/g.region/printwindow.c:289
+#: ../general/g.region/printwindow.c:297
+#: ../general/g.region/printwindow.c:305
+#: ../general/g.region/printwindow.c:534
+#: ../general/g.region/printwindow.c:542
+#: ../general/g.region/printwindow.c:550
+#: ../general/g.region/printwindow.c:558
+#: ../general/g.region/printwindow.c:676
+#: ../general/g.region/printwindow.c:684
+#: ../general/g.region/printwindow.c:692
+#: ../general/g.region/printwindow.c:700
msgid "Error in pj_do_proj (projection of input coordinate pair)"
msgstr "Erreur dans pj_do_proj (projection du couple de coordonnées en entrée)"
-#: ../raster/r.proj.seg/main.c:438 ../raster/r.proj/main.c:370
+#: ../raster/r.proj.seg/main.c:438
+#: ../raster/r.proj/main.c:370
#, fuzzy
msgid "Input:"
msgstr "couche source"
-#: ../raster/r.proj.seg/main.c:439 ../raster/r.proj.seg/main.c:450
-#: ../raster/r.proj/main.c:371 ../raster/r.proj/main.c:382
+#: ../raster/r.proj.seg/main.c:439
+#: ../raster/r.proj.seg/main.c:450
+#: ../raster/r.proj/main.c:371
+#: ../raster/r.proj/main.c:382
#, fuzzy, c-format
msgid "Cols: %d (%d)"
msgstr "classe %d (%d)\n"
# c-format
-#: ../raster/r.proj.seg/main.c:440 ../raster/r.proj.seg/main.c:451
-#: ../raster/r.proj/main.c:372 ../raster/r.proj/main.c:383
+#: ../raster/r.proj.seg/main.c:440
+#: ../raster/r.proj.seg/main.c:451
+#: ../raster/r.proj/main.c:372
+#: ../raster/r.proj/main.c:383
#, fuzzy, c-format
msgid "Rows: %d (%d)"
msgstr "lignes: %d"
-#: ../raster/r.proj.seg/main.c:441 ../raster/r.proj.seg/main.c:452
-#: ../raster/r.proj/main.c:373 ../raster/r.proj/main.c:384
+#: ../raster/r.proj.seg/main.c:441
+#: ../raster/r.proj.seg/main.c:452
+#: ../raster/r.proj/main.c:373
+#: ../raster/r.proj/main.c:384
#, fuzzy, c-format
msgid "North: %f (%f)"
msgstr "Noeud %d: %f %f\n"
-#: ../raster/r.proj.seg/main.c:442 ../raster/r.proj.seg/main.c:453
-#: ../raster/r.proj/main.c:374 ../raster/r.proj/main.c:385
+#: ../raster/r.proj.seg/main.c:442
+#: ../raster/r.proj.seg/main.c:453
+#: ../raster/r.proj/main.c:374
+#: ../raster/r.proj/main.c:385
#, c-format
msgid "South: %f (%f)"
msgstr "Sud : %f (%f)"
-#: ../raster/r.proj.seg/main.c:443 ../raster/r.proj.seg/main.c:454
-#: ../raster/r.proj/main.c:375 ../raster/r.proj/main.c:386
+#: ../raster/r.proj.seg/main.c:443
+#: ../raster/r.proj.seg/main.c:454
+#: ../raster/r.proj/main.c:375
+#: ../raster/r.proj/main.c:386
#, fuzzy, c-format
msgid "West: %f (%f)"
-#: ../raster/r.proj.seg/main.c:444 ../raster/r.proj.seg/main.c:455
-#: ../raster/r.proj/main.c:376 ../raster/r.proj/main.c:387
+#: ../raster/r.proj.seg/main.c:444
+#: ../raster/r.proj.seg/main.c:455
+#: ../raster/r.proj/main.c:376
+#: ../raster/r.proj/main.c:387
#, fuzzy, c-format
msgid "East: %f (%f)"
-#: ../raster/r.proj.seg/main.c:445 ../raster/r.proj.seg/main.c:456
-#: ../raster/r.proj/main.c:377 ../raster/r.proj/main.c:388
+#: ../raster/r.proj.seg/main.c:445
+#: ../raster/r.proj.seg/main.c:456
+#: ../raster/r.proj/main.c:377
+#: ../raster/r.proj/main.c:388
#, c-format
msgid "EW-res: %f"
msgstr "EO-res : %f"
-#: ../raster/r.proj.seg/main.c:446 ../raster/r.proj.seg/main.c:457
-#: ../raster/r.proj/main.c:378 ../raster/r.proj/main.c:389
+#: ../raster/r.proj.seg/main.c:446
+#: ../raster/r.proj.seg/main.c:457
+#: ../raster/r.proj/main.c:378
+#: ../raster/r.proj/main.c:389
#, c-format
msgid "NS-res: %f"
msgstr "NS-res : %f"
-#: ../raster/r.proj.seg/main.c:449 ../raster/r.proj/main.c:381
+#: ../raster/r.proj.seg/main.c:449
+#: ../raster/r.proj/main.c:381
#, fuzzy
msgid "Output:"
msgstr "couche de sortie"
-#: ../raster/r.proj.seg/main.c:485 ../raster/r.proj/main.c:417
+#: ../raster/r.proj.seg/main.c:485
+#: ../raster/r.proj/main.c:417
#, fuzzy
msgid "Projecting..."
msgstr "Traçage ... "
-#: ../raster/r.proj.seg/bordwalk.c:182 ../raster/r.proj/bordwalk.c:182
+#: ../raster/r.proj.seg/bordwalk.c:182
+#: ../raster/r.proj/bordwalk.c:182
#, fuzzy
msgid "Input raster map is outside current region"
msgstr "Il n'y aucune couche raster dans la fenêtre active"
@@ -9530,11 +10041,16 @@
msgid "Cannot read raster row [%d] from cover raster map <%s>"
msgstr "Impossible d'écrire la couche raster lac <%s>!"
-#: ../raster/r.random/random.c:194 ../vector/v.net.centrality/main.c:69
-#: ../vector/v.net.distance/main.c:256 ../vector/v.digit/attr.c:157
-#: ../vector/v.net.flow/main.c:244 ../vector/v.net.timetable/main.c:134
-#: ../vector/v.net.timetable/main.c:156 ../vector/v.net.allpairs/main.c:241
-#: ../vector/v.net.components/main.c:38 ../vector/v.net.path/path.c:309
+#: ../raster/r.random/random.c:194
+#: ../vector/v.net.centrality/main.c:69
+#: ../vector/v.net.distance/main.c:256
+#: ../vector/v.digit/attr.c:157
+#: ../vector/v.net.flow/main.c:244
+#: ../vector/v.net.timetable/main.c:134
+#: ../vector/v.net.timetable/main.c:156
+#: ../vector/v.net.allpairs/main.c:241
+#: ../vector/v.net.components/main.c:38
+#: ../vector/v.net.path/path.c:309
#, fuzzy, c-format
msgid "Cannot insert new record: %s"
msgstr "Impossible d'insérer un nouvel enregistrement : %s"
@@ -9563,22 +10079,21 @@
msgid "Programmer error in get_stats/switch"
msgstr ""
-#: ../raster/r.random/main.c:51 ../raster/r.surf.random/main.c:44
+#: ../raster/r.random/main.c:51
+#: ../raster/r.surf.random/main.c:44
#, fuzzy
msgid "raster, random"
msgstr "couche raster à échantillonner"
#: ../raster/r.random/main.c:53
#, fuzzy
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Crée une couche raster et une couche vectorielle contenant des points placés "
-"au hasard."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Crée une couche raster et une couche vectorielle contenant des points placés au hasard."
-#: ../raster/r.random/main.c:57 ../raster/r.water.outlet/main.c:55
-#: ../raster/r.out.bin/main.c:289 ../imagery/i.zc/main.c:69
+#: ../raster/r.random/main.c:57
+#: ../raster/r.water.outlet/main.c:55
+#: ../raster/r.out.bin/main.c:289
+#: ../imagery/i.zc/main.c:69
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:5
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
@@ -9587,7 +10102,8 @@
msgid "Name of input raster map"
-#: ../raster/r.random/main.c:62 ../raster/r.median/main.c:58
+#: ../raster/r.random/main.c:62
+#: ../raster/r.median/main.c:58
#, fuzzy
msgid "Name of cover raster map"
msgstr "Nom de la couche raster"
@@ -9609,17 +10125,25 @@
msgid "Generate vector points as 3D points"
msgstr "Générer des points vectoriels comme points 3D"
-#: ../raster/r.random/main.c:94 ../vector/v.in.ascii/in.c:161
+#: ../raster/r.random/main.c:94
+#: ../vector/v.in.ascii/in.c:161
msgid "Do not build topology in points mode"
msgstr "Ne construit pas de topologie en mode points"
-#: ../raster/r.random/main.c:95 ../vector/v.out.ascii/out.c:67
-#: ../vector/v.out.ascii/out.c:77 ../vector/v.out.ascii/out.c:84
-#: ../vector/v.out.ascii/out.c:97 ../vector/v.in.ascii/in.c:84
-#: ../vector/v.in.ascii/in.c:91 ../vector/v.in.ascii/in.c:103
-#: ../vector/v.in.ascii/in.c:113 ../vector/v.in.ascii/in.c:123
-#: ../vector/v.in.ascii/in.c:133 ../vector/v.in.ascii/in.c:157
-#: ../vector/v.in.ascii/in.c:162 ../vector/v.in.ascii/in.c:168
+#: ../raster/r.random/main.c:95
+#: ../vector/v.out.ascii/out.c:67
+#: ../vector/v.out.ascii/out.c:77
+#: ../vector/v.out.ascii/out.c:84
+#: ../vector/v.out.ascii/out.c:97
+#: ../vector/v.in.ascii/in.c:84
+#: ../vector/v.in.ascii/in.c:91
+#: ../vector/v.in.ascii/in.c:103
+#: ../vector/v.in.ascii/in.c:113
+#: ../vector/v.in.ascii/in.c:123
+#: ../vector/v.in.ascii/in.c:133
+#: ../vector/v.in.ascii/in.c:157
+#: ../vector/v.in.ascii/in.c:162
+#: ../vector/v.in.ascii/in.c:168
#: ../vector/v.transform/main.c:116
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
@@ -9660,7 +10184,8 @@
msgid "There are no valid locations in the current region"
msgstr "Points germes en dehors de la région courante"
-#: ../raster/wildfire/r.spread/main.c:101 ../raster/wildfire/r.ros/main.c:212
+#: ../raster/wildfire/r.spread/main.c:101
+#: ../raster/wildfire/r.ros/main.c:212
#: ../raster/wildfire/r.spreadpath/main.c:72
#, fuzzy
msgid "raster, fire"
@@ -9668,21 +10193,11 @@
#: ../raster/wildfire/r.spread/main.c:103
#, fuzzy
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"Simule une propagation elliptique anisotropique sur une fenêtre graphique et "
-"génère une couche raster pour le temps cumulé de propagation, à partir de "
-"couches rasters contenant des taux de propagation (ROS), les directions ROS, "
-"et l'origine du foyer. En option, produit des couches raster contenant des "
-"coordonnées UTM pour retracer le parcours de propagation du feu"
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "Simule une propagation elliptique anisotropique sur une fenêtre graphique et génère une couche raster pour le temps cumulé de propagation, à partir de couches rasters contenant des taux de propagation (ROS), les directions ROS, et l'origine du foyer. En option, produit des couches raster contenant des coordonnées UTM pour retracer le parcours de propagation du feu"
#: ../raster/wildfire/r.spread/main.c:108
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
msgstr ""
#: ../raster/wildfire/r.spread/main.c:116
@@ -9698,8 +10213,7 @@
#: ../raster/wildfire/r.spread/main.c:118
msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr ""
-"Nom de la couche raster de taux de propagation MAXimal (ROS) (en cm/min)"
+msgstr "Nom de la couche raster de taux de propagation MAXimal (ROS) (en cm/min)"
#: ../raster/wildfire/r.spread/main.c:127
msgid "Name of raster map containing DIRections of max ROS (degree)"
@@ -9714,37 +10228,24 @@
msgstr "Nom de la couche raster des foyers de départ de feu"
#: ../raster/wildfire/r.spread/main.c:153
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster de DISTance maximale d'ESSAIMAGE (en m) (nécessite "
-"w/ -s)"
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr "Nom de la couche raster de DISTance maximale d'ESSAIMAGE (en m) (nécessite w/ -s)"
#: ../raster/wildfire/r.spread/main.c:161
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster de VITESSE du Vent au sol (en pieds/min) (nécessite "
-"w/ -s)"
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgstr "Nom de la couche raster de VITESSE du Vent au sol (en pieds/min) (nécessite w/ -s)"
#: ../raster/wildfire/r.spread/main.c:169
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible de la cellule "
-"recevant un brandon de départ de foyer secondaire (%) (nécessite w/ -s) "
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible de la cellule recevant un brandon de départ de foyer secondaire (%) (nécessite w/ -s) "
#: ../raster/wildfire/r.spread/main.c:177
msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-msgstr ""
-"TAILLE de la fenêtre d'échantillonnage de base pour atteindre une précision "
-"suffisante (3)"
+msgstr "TAILLE de la fenêtre d'échantillonnage de base pour atteindre une précision suffisante (3)"
#: ../raster/wildfire/r.spread/main.c:184
msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-"Echantillonnage de DENSité pour des CALCULS supplémentaires (0.0 - 1.0 (0.5))"
+msgstr "Echantillonnage de DENSité pour des CALCULS supplémentaires (0.0 - 1.0 (0.5))"
#: ../raster/wildfire/r.spread/main.c:191
msgid "INITial TIME for current simulation (0) (min)"
@@ -9767,8 +10268,7 @@
#: ../raster/wildfire/r.spread/main.c:214
msgid "Name of raster map to contain OUTPUT spread time (min)"
-msgstr ""
-"Nom de la couche raster en SORTIE pour le temps de propagation (en min)"
+msgstr "Nom de la couche raster en SORTIE pour le temps de propagation (en min)"
#: ../raster/wildfire/r.spread/main.c:222
#, fuzzy
@@ -9790,15 +10290,15 @@
#: ../raster/wildfire/r.spread/main.c:243
msgid "For wildfires: consider SPOTTING effect"
-msgstr ""
-"Pour les feux de forêts : prendre en compte l'ESSAIMAGE du foyer initial en "
-"foyers secondaires"
+msgstr "Pour les feux de forêts : prendre en compte l'ESSAIMAGE du foyer initial en foyers secondaires"
# c-format
#: ../raster/wildfire/r.spread/main.c:384
#: ../raster/wildfire/r.spread/main.c:393
-#: ../raster/wildfire/r.spread/main.c:403 ../raster/wildfire/r.ros/main.c:424
-#: ../raster/wildfire/r.ros/main.c:428 ../raster/wildfire/r.ros/main.c:432
+#: ../raster/wildfire/r.spread/main.c:403
+#: ../raster/wildfire/r.ros/main.c:424
+#: ../raster/wildfire/r.ros/main.c:428
+#: ../raster/wildfire/r.ros/main.c:432
#: ../raster/wildfire/r.ros/main.c:439
#, fuzzy, c-format
msgid "Raster map <%s> already exists in mapset <%s>, select another name"
@@ -9811,16 +10311,8 @@
msgstr "Lecture du fichier %s..."
#: ../raster/wildfire/r.ros/main.c:214
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"Génère trois ou quatre couches raster montrant 1) la base (orthogonale) de "
-"la 'vitesse de propagation du feu' (ROS), 2)le ROS maximum (progression du "
-"feu), 3) la direction du ROS maximum et en option 4) la distance maximale "
-"prévue pour l'essaimage du foyer initial (c.f. escarbilles/brandons)"
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "Génère trois ou quatre couches raster montrant 1) la base (orthogonale) de la 'vitesse de propagation du feu' (ROS), 2)le ROS maximum (progression du feu), 3) la direction du ROS maximum et en option 4) la distance maximale prévue pour l'essaimage du foyer initial (c.f. escarbilles/brandons)"
#: ../raster/wildfire/r.ros/main.c:224
msgid "Name of raster map containing fuel MODELs"
@@ -9828,18 +10320,15 @@
#: ../raster/wildfire/r.ros/main.c:231
msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 1 heure (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 1 heure (%)"
#: ../raster/wildfire/r.ros/main.c:238
msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 10 heures (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 10 heures (%)"
#: ../raster/wildfire/r.ros/main.c:245
msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 100 heures (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 100 heures (%)"
#: ../raster/wildfire/r.ros/main.c:253
msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
@@ -9859,9 +10348,7 @@
#: ../raster/wildfire/r.ros/main.c:281
msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr ""
-"Nom de la couche raster d'ASPECT (en degrés, dans le sens anti-horaire en "
-"partant de l'E)"
+msgstr "Nom de la couche raster d'ASPECT (en degrés, dans le sens anti-horaire en partant de l'E)"
#: ../raster/wildfire/r.ros/main.c:288
msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
@@ -9869,8 +10356,7 @@
#: ../raster/wildfire/r.ros/main.c:296
msgid "Name of raster map to contain results (several new layers)"
-msgstr ""
-"Nom de la couche raster des résultats en sortie (plusieurs nouvelles couches)"
+msgstr "Nom de la couche raster des résultats en sortie (plusieurs nouvelles couches)"
#: ../raster/wildfire/r.ros/main.c:305
msgid "Also produce maximum SPOTTING distance"
@@ -9882,25 +10368,17 @@
msgstr "Pourcentage effectué..."
#: ../raster/wildfire/r.spreadpath/main.c:74
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Trace de façon récursive le plus court chemin vers les cellules pour lequel "
-"le coût cumulé est déterminé"
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Trace de façon récursive le plus court chemin vers les cellules pour lequel le coût cumulé est déterminé"
#: ../raster/wildfire/r.spreadpath/main.c:83
msgid "Name of raster map containing back-path easting information"
-msgstr ""
-"Nom de la couche raster pour les informations X de plus court chemin pour la "
-"propagation du foyer"
+msgstr "Nom de la couche raster pour les informations X de plus court chemin pour la propagation du foyer"
#: ../raster/wildfire/r.spreadpath/main.c:91
#, fuzzy
msgid "Name of raster map containing back-path northing information"
-msgstr ""
-"Nom de la couche raster pour les informations Y de plus court chemin pour la "
+msgstr "Nom de la couche raster pour les informations Y de plus court chemin pour la propagation du foyer"
#: ../raster/wildfire/r.spreadpath/main.c:99
msgid "The map E and N grid coordinates of starting points"
@@ -9915,15 +10393,18 @@
msgstr ""
#: ../raster/r.univar2/r.univar_main.c:42
-#: ../raster/r.univar2/r3.univar_main.c:43 ../raster/r.stats/main.c:114
-#: ../vector/v.db.select/main.c:84 ../db/base/select.c:233
+#: ../raster/r.univar2/r3.univar_main.c:43
+#: ../raster/r.stats/main.c:114
+#: ../vector/v.db.select/main.c:84
+#: ../db/base/select.c:233
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
#, fuzzy
msgid "Name for output file (if omitted or \"-\" output to stdout)"
msgstr "Nom de la couche binaire à créer (utiliser output=- pour stdout)"
#: ../raster/r.univar2/r.univar_main.c:52
-#: ../raster/r.univar2/r3.univar_main.c:53 ../vector/v.univar/main.c:124
+#: ../raster/r.univar2/r3.univar_main.c:53
+#: ../vector/v.univar/main.c:124
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
#, fuzzy
msgid "Percentile to calculate (requires extended statistics flag)"
@@ -9935,13 +10416,15 @@
msgstr ""
#: ../raster/r.univar2/r.univar_main.c:60
-#: ../raster/r.univar2/r3.univar_main.c:61 ../vector/v.univar/main.c:128
+#: ../raster/r.univar2/r3.univar_main.c:61
+#: ../vector/v.univar/main.c:128
#: ../vector/v.what/main.c:89
msgid "Print the stats in shell script style"
msgstr "Produit les statistiques à la façon d'un script shell"
#: ../raster/r.univar2/r.univar_main.c:64
-#: ../raster/r.univar2/r3.univar_main.c:65 ../vector/v.univar/main.c:132
+#: ../raster/r.univar2/r3.univar_main.c:65
+#: ../vector/v.univar/main.c:132
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
#, fuzzy
msgid "Calculate extended statistics"
@@ -9953,16 +10436,15 @@
msgstr ""
#: ../raster/r.univar2/r.univar_main.c:99
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-"Calcule des statistiques univariées à partir des cellules non vides d'une "
-"couche raster."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr "Calcule des statistiques univariées à partir des cellules non vides d'une couche raster."
# c-format
#: ../raster/r.univar2/r.univar_main.c:110
-#: ../raster/r.univar2/r3.univar_main.c:123 ../raster/r.stats/main.c:208
-#: ../raster/r.regression.line/main.c:75 ../vector/v.db.select/main.c:111
+#: ../raster/r.univar2/r3.univar_main.c:123
+#: ../raster/r.stats/main.c:208
+#: ../raster/r.regression.line/main.c:75
+#: ../vector/v.db.select/main.c:111
#: ../db/base/select.c:130
#, fuzzy, c-format
msgid "Unable to open file <%s> for writing"
@@ -9981,12 +10463,8 @@
#: ../raster/r.univar2/r3.univar_main.c:102
#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"couche raster."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
#: ../raster/r.univar2/r3.univar_main.c:163
#, fuzzy
@@ -9996,9 +10474,7 @@
#: ../raster/r.grow.distance/main.c:150
#, fuzzy
msgid "Generates a raster map layer of distance to features in input layer."
-msgstr ""
-"Produit une couche raster où les aires contiguës ont été agrandies d'une "
-"cellule."
+msgstr "Produit une couche raster où les aires contiguës ont été agrandies d'une cellule."
#: ../raster/r.grow.distance/main.c:157
#, fuzzy
@@ -10059,26 +10535,26 @@
msgid "Raster map(s) to report on"
msgstr "couche(s) raster à analyser"
-#: ../raster/r.report/parse.c:44 ../vector/v.to.db/parse.c:85
+#: ../raster/r.report/parse.c:44
+#: ../vector/v.to.db/parse.c:85
msgid "Units"
msgstr "Unités"
#: ../raster/r.report/parse.c:46
#, fuzzy
-msgid ""
-"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
-"cover"
-msgstr ""
-"mi(les), me(tres), k(ilomètres), a(cres), h(ectares), c(ellules_nombre), p"
-"(ourcentage_couverture)"
+msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
+msgstr "mi(les), me(tres), k(ilomètres), a(cres), h(ectares), c(ellules_nombre), p(ourcentage_couverture)"
#: ../raster/r.report/parse.c:56
msgid "Character representing no data cell value"
msgstr "Caractère représentant les valeurs manquantes pour une cellule"
-#: ../raster/r.report/parse.c:57 ../raster/r.report/parse.c:66
-#: ../raster/r.report/parse.c:75 ../raster/r.report/parse.c:100
-#: ../raster/r.report/parse.c:105 ../raster/r.report/parse.c:110
+#: ../raster/r.report/parse.c:57
+#: ../raster/r.report/parse.c:66
+#: ../raster/r.report/parse.c:75
+#: ../raster/r.report/parse.c:100
+#: ../raster/r.report/parse.c:105
+#: ../raster/r.report/parse.c:110
#, fuzzy
msgid "Formatting"
msgstr "Abandon."
@@ -10097,11 +10573,10 @@
msgid "Name of an output file to hold the report"
msgstr "Nom du fichier où stocker le résultat"
-#: ../raster/r.report/parse.c:91 ../raster/r.stats/main.c:136
+#: ../raster/r.report/parse.c:91
+#: ../raster/r.stats/main.c:136
msgid "Number of fp subranges to collect stats from"
-msgstr ""
-"Nombres de chiffres après la virgule à prendre en compte pour constituer les "
-"statistiques"
+msgstr "Nombres de chiffres après la virgule à prendre en compte pour constituer les statistiques"
#: ../raster/r.report/parse.c:99
msgid "Suppress page headers"
@@ -10123,17 +10598,15 @@
msgid "Filter out cells where all maps have no data"
msgstr "Filtrer les cellules où toutes les couches n'ont pas de données"
-#: ../raster/r.report/parse.c:122 ../raster/r.stats/main.c:196
+#: ../raster/r.report/parse.c:122
+#: ../raster/r.stats/main.c:196
msgid "Report for cats fp ranges (fp maps only)"
-msgstr ""
-"Examen des catégories en nombres à virgule flottante (couches en virgule "
-"flottante uniquement)"
+msgstr "Examen des catégories en nombres à virgule flottante (couches en virgule flottante uniquement)"
-#: ../raster/r.report/parse.c:127 ../raster/r.stats/main.c:200
+#: ../raster/r.report/parse.c:127
+#: ../raster/r.stats/main.c:200
msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-"Lire une couche en virgule flottante comme une couche de valeurs entières "
-"(en utilisant les règles de quantification de la couche)"
+msgstr "Lire une couche en virgule flottante comme une couche de valeurs entières (en utilisant les règles de quantification de la couche)"
#: ../raster/r.report/parse.c:170
#, fuzzy
@@ -10175,7 +10648,8 @@
msgid "Converts a raster map layer into a height-field file for POVRAY."
msgstr "Conertit une couche raster en fichier pour POVRAY"
-#: ../raster/r.out.pov/main.c:131 ../raster/r.out.ascii/main.c:70
+#: ../raster/r.out.pov/main.c:131
+#: ../raster/r.out.ascii/main.c:70
msgid "Name of an existing raster map"
msgstr "Nom d'une couche raster GRASS existante"
@@ -10199,8 +10673,7 @@
#: ../raster/r.out.pov/main.c:193
#, c-format
msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-"La couche raster est trop grande! Elle dépasse %d colonnes ou %d lignes"
+msgstr "La couche raster est trop grande! Elle dépasse %d colonnes ou %d lignes"
#: ../raster/r.out.pov/main.c:214
msgid "Negative elevation values in input"
@@ -10235,8 +10708,7 @@
msgid ""
"Warning, ignoring point outside window: \n"
" %.4f,%.4f\n"
-msgstr ""
-"Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
+msgstr "Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
#: ../raster/r.water.outlet/main.c:121
#, fuzzy
@@ -10253,14 +10725,17 @@
msgid "Unable to close new basin map layer"
msgstr "Impossible d'ouvrir la nouvelle couche L."
-#: ../raster/r.carve/raster.c:12 ../raster/r.out.tiff/r.out.tiff.c:283
-#: ../raster/r.texture/main.c:261 ../imagery/i.zc/main.c:167
+#: ../raster/r.carve/raster.c:12
+#: ../raster/r.out.tiff/r.out.tiff.c:283
+#: ../raster/r.texture/main.c:261
+#: ../imagery/i.zc/main.c:167
#, fuzzy
msgid "Reading raster map..."
msgstr "Lecteur du fichier raster..."
# c-format
-#: ../raster/r.carve/raster.c:32 ../raster/r.in.poly/poly2rast.c:78
+#: ../raster/r.carve/raster.c:32
+#: ../raster/r.in.poly/poly2rast.c:78
#: ../vector/v.to.rast/vect2rast.c:182
#, fuzzy
msgid "Writing raster map..."
@@ -10274,26 +10749,17 @@
msgstr "Traitement des lignes..."
#: ../raster/r.carve/enforce_ds.c:173
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-"Le vecteur sort et ré-entre dans la région - ce cas particulier n'est pas "
-"encore implémenté."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr "Le vecteur sort et ré-entre dans la région - ce cas particulier n'est pas encore implémenté."
#: ../raster/r.carve/lobf.c:74
msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-"Tentative de division par zéro... pas de solution unique pour le modèle... "
-"on passe..."
+msgstr "Tentative de division par zéro... pas de solution unique pour le modèle... on passe..."
#: ../raster/r.carve/main.c:78
#, fuzzy
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Prends les données vectorielles de cours d'eau, les transforme en raster, et "
-"soustrait la profondeur du modèle de terrain en sortie"
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Prends les données vectorielles de cours d'eau, les transforme en raster, et soustrait la profondeur du modèle de terrain en sortie"
#: ../raster/r.carve/main.c:83
msgid "Name of input raster elevation map"
@@ -10337,12 +10803,8 @@
msgstr "Projection lat/long non gérée pour le moment."
#: ../raster/r.out.tiff/r.out.tiff.c:101
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
-"Exporte une couche Raster GRASS en un fichier TIFF 8/24 bits à la résolution "
-"de la région actuelle."
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+msgstr "Exporte une couche Raster GRASS en un fichier TIFF 8/24 bits à la résolution de la région actuelle."
#: ../raster/r.out.tiff/r.out.tiff.c:111
#, fuzzy
@@ -10365,7 +10827,8 @@
msgid "Output Tiled TIFF"
msgstr "Fichier de sortie Tiled TIFF"
-#: ../raster/r.out.tiff/r.out.tiff.c:136 ../raster/r.out.mat/main.c:81
+#: ../raster/r.out.tiff/r.out.tiff.c:136
+#: ../raster/r.out.mat/main.c:81
#: ../raster/r.in.mat/main.c:115
#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
@@ -10375,20 +10838,12 @@
#: ../raster/r.out.tiff/r.out.tiff.c:177
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
-"be rounded to integer!"
-msgstr ""
-"La couche <%s> du jeu de données <%s> est une couche en point flottant. Les "
-"valeurs décimales seront arrondies à l'entier!"
+msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
+msgstr "La couche <%s> du jeu de données <%s> est une couche en point flottant. Les valeurs décimales seront arrondies à l'entier!"
#: ../raster/r.out.tiff/r.out.tiff.c:183
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
-msgstr ""
-"La table de couleur pour la palette doit compter moins de 256 couleurs pour "
-"l'intervalle disponible de données"
+msgid "Color map for palette must have less than 256 colors for the available range of data"
+msgstr "La table de couleur pour la palette doit compter moins de 256 couleurs pour l'intervalle disponible de données"
# c-format
#: ../raster/r.out.tiff/r.out.tiff.c:198
@@ -10421,7 +10876,8 @@
msgid "Name of raster map for which to edit null file"
msgstr "couche raster où remplacer les valeurs null"
-#: ../raster/r.null/null.c:71 ../raster/r.null/null.c:79
+#: ../raster/r.null/null.c:71
+#: ../raster/r.null/null.c:79
#: ../general/g.proj/main.c:190
msgid "Modify"
msgstr "Modifier"
@@ -10430,7 +10886,8 @@
msgid "Only do the work if the map is floating-point"
msgstr "NE faire le travail que si la carte est en virgule flottante"
-#: ../raster/r.null/null.c:84 ../raster/r.null/null.c:89
+#: ../raster/r.null/null.c:84
+#: ../raster/r.null/null.c:89
#: ../raster/r.null/null.c:95
msgid "Check"
msgstr "Vérifier"
@@ -10461,9 +10918,7 @@
#: ../raster/r.null/null.c:123
#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
msgstr ""
#: ../raster/r.null/null.c:129
@@ -10509,7 +10964,8 @@
msgid "Error writing null row %d"
msgstr "Erreur d'écriture de la ligne null [%d]"
-#: ../raster/r.null/null.c:187 ../raster/r.null/null.c:200
+#: ../raster/r.null/null.c:187
+#: ../raster/r.null/null.c:200
#, fuzzy, c-format
msgid "Raster map <%s> modified."
msgstr "couche raster <%s> non trouvée"
@@ -10551,7 +11007,8 @@
msgid "Number of passes through the dataset"
msgstr "Nombre de passes sur les données"
-#: ../raster/r.basins.fill/main.c:99 ../raster/r.in.gdal/main.c:233
+#: ../raster/r.basins.fill/main.c:99
+#: ../raster/r.in.gdal/main.c:233
#, fuzzy, c-format
msgid "Raster map <%s> already exists"
@@ -10570,20 +11027,19 @@
msgid "Surface generation program."
msgstr "Programme de génération de relief."
-#: ../raster/r.surf.idw2/main.c:72 ../raster/r.surf.idw/main.c:81
+#: ../raster/r.surf.idw2/main.c:72
+#: ../raster/r.surf.idw/main.c:81
#: ../vector/v.surf.idw/main.c:113
msgid "Number of interpolation points"
msgstr "Nombre de points d'interpolation"
#: ../raster/r.surf.idw2/main.c:80
#, fuzzy
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Les bases de données en latitude/longitude ne sont pas supportées par r."
-"flow. Veuillez à utiliser 'r.watershed' pour calculer la crue."
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Les bases de données en latitude/longitude ne sont pas supportées par r.flow. Veuillez à utiliser 'r.watershed' pour calculer la crue."
-#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:141
+#: ../raster/r.surf.idw2/main.c:87
+#: ../vector/v.surf.idw/main.c:141
#, c-format
msgid "%s=%s - illegal number of interpolation points"
msgstr "%s=%s - nombre illégal de points d'interpolation"
@@ -10607,7 +11063,8 @@
msgid "Generates area statistics for raster map layers."
msgstr "Génère des statistiques zonales pour des couches rasters"
-#: ../raster/r.stats/main.c:127 ../raster/r.describe/main.c:72
+#: ../raster/r.stats/main.c:127
+#: ../raster/r.describe/main.c:72
msgid "String representing no data cell value"
msgstr "Chaîne de caractère pour les cellules sans valeur"
@@ -10629,8 +11086,7 @@
#: ../raster/r.stats/main.c:162
msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
-"Affiche des pourcentages APPROCHÉS (le total peut être différent de 100%)"
+msgstr "Affiche des pourcentages APPROCHÉS (le total peut être différent de 100%)"
#: ../raster/r.stats/main.c:167
msgid "Print category labels"
@@ -10646,18 +11102,16 @@
#: ../raster/r.stats/main.c:182
msgid "Print raw indexes of fp ranges (fp maps only)"
-msgstr ""
-"Affiche les index brutes de valeurs en nombres à virgule flottante (couches "
-"en nombre à virgule flottante uniquement)"
+msgstr "Affiche les index brutes de valeurs en nombres à virgule flottante (couches en nombre à virgule flottante uniquement)"
-#: ../raster/r.stats/main.c:187 ../raster/r.describe/main.c:94
+#: ../raster/r.stats/main.c:187
+#: ../raster/r.describe/main.c:94
msgid "Suppress reporting of any NULLs"
msgstr "Supprime l'affichage de toute valeur NULL"
#: ../raster/r.stats/main.c:192
msgid "Suppress reporting of NULLs when all values are NULL"
-msgstr ""
-"Supprime l'affichage des valeurs NULL lorsque toutes les valeurs sont NULL"
+msgstr "Supprime l'affichage des valeurs NULL lorsque toutes les valeurs sont NULL"
#: ../raster/r.stats/main.c:214
#, fuzzy, c-format
@@ -10672,30 +11126,18 @@
#: ../raster/r.stats/main.c:284
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"%s: -i signifie lire %s comme entier! le drapeau -C et/ou l'option nsteps "
-"vont être ignorés."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "%s: -i signifie lire %s comme entier! le drapeau -C et/ou l'option nsteps vont être ignorés."
#: ../raster/r.stats/main.c:301
#, fuzzy, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-"%s: cats de %s sont soit manquantes ou n'ont pas d'étiquette explicite. "
-"Utilisation de nsteps=%d"
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "%s: cats de %s sont soit manquantes ou n'ont pas d'étiquette explicite. Utilisation de nsteps=%d"
#: ../raster/r.stats/main.c:308
#, fuzzy, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
-msgstr ""
-"%s: le drapeau -C a été spécifié, utilisation cats fp (valeurs flottantes) "
-"intervalle de %s, l'option nsteps est ignorée"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr "%s: le drapeau -C a été spécifié, utilisation cats fp (valeurs flottantes) intervalle de %s, l'option nsteps est ignorée"
# c-format
#: ../raster/r.stats/main.c:342
@@ -10717,7 +11159,8 @@
msgid "Set from current region"
msgstr "Définir à partir de la région actuelle"
-#: ../raster/r.region/main.c:70 ../general/g.region/main.c:80
+#: ../raster/r.region/main.c:70
+#: ../general/g.region/main.c:80
msgid "Set from default region"
msgstr "Définir à partir de la région par défaut"
@@ -10729,31 +11172,38 @@
msgid "Set region from named region"
msgstr "Définir la région actuelle à partir de la région spécifiée"
-#: ../raster/r.region/main.c:96 ../general/g.region/main.c:180
+#: ../raster/r.region/main.c:96
+#: ../general/g.region/main.c:180
msgid "Set region to match this raster map"
msgstr "Ajuster l'emprise de la région sur cette couche raster"
-#: ../raster/r.region/main.c:102 ../general/g.region/main.c:196
+#: ../raster/r.region/main.c:102
+#: ../general/g.region/main.c:196
msgid "Set region to match this vector map"
msgstr "Ajuster l'emprise de la région sur cette couche vectorielle"
-#: ../raster/r.region/main.c:110 ../general/g.region/main.c:205
+#: ../raster/r.region/main.c:110
+#: ../general/g.region/main.c:205
msgid "Set region to match this 3dview file"
msgstr "Ajuster l'emprise de la région sur cette couche 3dview"
-#: ../raster/r.region/main.c:120 ../general/g.region/main.c:215
+#: ../raster/r.region/main.c:120
+#: ../general/g.region/main.c:215
msgid "Value for the northern edge"
msgstr "Valeur de la limite nord"
-#: ../raster/r.region/main.c:130 ../general/g.region/main.c:225
+#: ../raster/r.region/main.c:130
+#: ../general/g.region/main.c:225
msgid "Value for the southern edge"
msgstr "Valeur de la limite sud"
-#: ../raster/r.region/main.c:140 ../general/g.region/main.c:235
+#: ../raster/r.region/main.c:140
+#: ../general/g.region/main.c:235
msgid "Value for the eastern edge"
msgstr "Valeur de la limite est"
-#: ../raster/r.region/main.c:150 ../general/g.region/main.c:245
+#: ../raster/r.region/main.c:150
+#: ../general/g.region/main.c:245
msgid "Value for the western edge"
msgstr "Valeur de la limite ouest"
@@ -10762,39 +11212,48 @@
msgstr "Couche raster sur laquelle ajuster la région"
# c-format
-#: ../raster/r.region/main.c:168 ../raster/r.region/main.c:227
-#: ../raster/r.region/main.c:350 ../display/d.title/main.c:108
-#: ../general/g.region/main.c:481 ../general/g.region/main.c:832
+#: ../raster/r.region/main.c:168
+#: ../raster/r.region/main.c:227
+#: ../raster/r.region/main.c:350
+#: ../display/d.title/main.c:108
+#: ../general/g.region/main.c:481
+#: ../general/g.region/main.c:832
#, fuzzy, c-format
msgid "Unable to read header of raster map <%s@%s>"
-#: ../raster/r.region/main.c:182 ../general/g.region/main.c:422
+#: ../raster/r.region/main.c:182
+#: ../general/g.region/main.c:422
#, fuzzy, c-format
msgid "Region <%s> not found"
-#: ../raster/r.region/main.c:184 ../general/g.region/main.c:424
+#: ../raster/r.region/main.c:184
+#: ../general/g.region/main.c:424
#, fuzzy, c-format
msgid "Unable to read region <%s> in <%s>"
msgstr "impossible de lire la région <%s> dans <%s>"
-#: ../raster/r.region/main.c:195 ../general/g.region/main.c:436
+#: ../raster/r.region/main.c:195
+#: ../general/g.region/main.c:436
#, c-format
msgid "3dview file <%s> not found"
msgstr "fichier 3dview <%s> non trouvé"
-#: ../raster/r.region/main.c:201 ../general/g.region/main.c:441
+#: ../raster/r.region/main.c:201
+#: ../general/g.region/main.c:441
#, fuzzy, c-format
msgid "Unable to open 3dview file <%s> in <%s>"
msgstr "impossible d'ouvrir le fichier 3dview <%s> dans <%s>"
-#: ../raster/r.region/main.c:206 ../general/g.region/main.c:447
+#: ../raster/r.region/main.c:206
+#: ../general/g.region/main.c:447
#, fuzzy, c-format
msgid "Unable to read 3dview file <%s> in <%s>"
msgstr "impossible de lire le fichier 3dview <%s> dans <%s>"
-#: ../raster/r.region/main.c:209 ../general/g.region/main.c:450
+#: ../raster/r.region/main.c:209
+#: ../general/g.region/main.c:450
#, fuzzy, c-format
msgid "Old 3dview file. Region <%s> not found in <%s>"
msgstr "Ancien fichier 3dview. Aucune région trouvée dans <%s> in <%s>"
@@ -10805,7 +11264,8 @@
msgid "Unable to open vector map <%s> in <%s>"
msgstr "Impossible d'ouvrir la couche vecteur [%s]"
-#: ../raster/r.region/main.c:360 ../general/g.region/adjust.c:11
+#: ../raster/r.region/main.c:360
+#: ../general/g.region/adjust.c:11
#, fuzzy, c-format
msgid "Invalid region: %s"
msgstr "région incorrecte : %s"
@@ -10817,9 +11277,7 @@
#: ../raster/r.describe/main.c:61
msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Affiche une liste succinte des valeurs de catégorie trouvées dans une couche "
-"raster."
+msgstr "Affiche une liste succinte des valeurs de catégorie trouvées dans une couche raster."
#: ../raster/r.describe/main.c:80
#, fuzzy
@@ -10855,8 +11313,7 @@
#: ../raster/r.out.mat/main.c:65
msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr ""
-"Exporte une couche raster GRASS vers un fichier binaire au format MAT-File"
+msgstr "Exporte une couche raster GRASS vers un fichier binaire au format MAT-File"
#: ../raster/r.out.mat/main.c:76
msgid "Name for the output binary MAT-File"
@@ -10873,43 +11330,51 @@
msgid "Using the Current Region settings:"
msgstr "Afficher l'emprise de la région courante"
-#: ../raster/r.out.mat/main.c:198 ../raster/r.in.mat/main.c:415
+#: ../raster/r.out.mat/main.c:198
+#: ../raster/r.in.mat/main.c:415
#, fuzzy, c-format
msgid "northern edge=%f"
-#: ../raster/r.out.mat/main.c:199 ../raster/r.in.mat/main.c:416
+#: ../raster/r.out.mat/main.c:199
+#: ../raster/r.in.mat/main.c:416
#, fuzzy, c-format
msgid "southern edge=%f"
-#: ../raster/r.out.mat/main.c:200 ../raster/r.in.mat/main.c:417
+#: ../raster/r.out.mat/main.c:200
+#: ../raster/r.in.mat/main.c:417
#, c-format
msgid "eastern edge=%f"
msgstr "bordure orientale=%f"
-#: ../raster/r.out.mat/main.c:201 ../raster/r.in.mat/main.c:418
+#: ../raster/r.out.mat/main.c:201
+#: ../raster/r.in.mat/main.c:418
#, c-format
msgid "western edge=%f"
msgstr "bordure occidentale=%f"
-#: ../raster/r.out.mat/main.c:202 ../raster/r.in.mat/main.c:419
+#: ../raster/r.out.mat/main.c:202
+#: ../raster/r.in.mat/main.c:419
#, c-format
msgid "nsres=%f"
msgstr "nsres=%f"
-#: ../raster/r.out.mat/main.c:203 ../raster/r.in.mat/main.c:420
+#: ../raster/r.out.mat/main.c:203
+#: ../raster/r.in.mat/main.c:420
#, c-format
msgid "ewres=%f"
msgstr "ewres=%f"
# c-format
-#: ../raster/r.out.mat/main.c:204 ../raster/r.in.mat/main.c:421
+#: ../raster/r.out.mat/main.c:204
+#: ../raster/r.in.mat/main.c:421
#, fuzzy, c-format
msgid "rows=%d"
msgstr "lignes: %d"
-#: ../raster/r.out.mat/main.c:205 ../raster/r.in.mat/main.c:422
+#: ../raster/r.out.mat/main.c:205
+#: ../raster/r.in.mat/main.c:422
#, fuzzy, c-format
msgid "cols=%d"
msgstr "colonnes: %d"
@@ -10948,71 +11413,54 @@
msgstr "%d points écrits dans la couche vecteur"
#: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
-msgstr ""
-"Impossible de calculer la position du soleil sur des secteur non projetés. "
-"Spécifier directement la position du soleil."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgstr "Impossible de calculer la position du soleil sur des secteur non projetés. Spécifier directement la position du soleil."
#: ../raster/r.sunmask/g_solposition.c:88
#, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
-msgstr ""
-"Le point spécifié %f, %f est en dehors de la région courante, est-ce "
-"intentionnel ? Quoi qu'il en soit il sera utilisé."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgstr "Le point spécifié %f, %f est en dehors de la région courante, est-ce intentionnel ? Quoi qu'il en soit il sera utilisé."
#: ../raster/r.sunmask/g_solposition.c:98
#, fuzzy
msgid "Unable to get projection info of current location"
-msgstr ""
#: ../raster/r.sunmask/g_solposition.c:101
#, fuzzy
msgid "Unable to get projection units of current location"
-msgstr ""
-"courant"
#: ../raster/r.sunmask/g_solposition.c:104
#, fuzzy
msgid "Unable to get projection key values of current location"
-msgstr ""
-#: ../raster/r.sunmask/main.c:115 ../raster/r.horizon/main.c:177
+#: ../raster/r.sunmask/main.c:115
+#: ../raster/r.horizon/main.c:177
#, fuzzy
msgid "raster, sun position"
msgstr "Projection source"
#: ../raster/r.sunmask/main.c:116
#, fuzzy
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
msgstr "Calcule un <simple> index sur un fichier raster"
#: ../raster/r.sunmask/main.c:117
#, fuzzy
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-"Calculer des zones d'ombre portée à partir de la position du soleil et d'un "
-"MNT. A : la position exacte du soleil est donnée. B : date/heure pour "
-"calculer la position du soleil grâce à r.sunmask."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr "Calculer des zones d'ombre portée à partir de la position du soleil et d'un MNT. A : la position exacte du soleil est donnée. B : date/heure pour calculer la position du soleil grâce à r.sunmask."
#: ../raster/r.sunmask/main.c:131
#, fuzzy
msgid "Altitude of the sun above horizon, degrees (A)"
msgstr "A : altitude du soleil au dessus de l'horizon, en degrés"
-#: ../raster/r.sunmask/main.c:132 ../raster/r.sunmask/main.c:141
-#: ../raster/r.sunmask/main.c:208 ../raster/r.sunmask/main.c:218
+#: ../raster/r.sunmask/main.c:132
+#: ../raster/r.sunmask/main.c:141
+#: ../raster/r.sunmask/main.c:208
+#: ../raster/r.sunmask/main.c:218
#, fuzzy
msgid "Position"
@@ -11026,9 +11474,12 @@
msgid "Year (B)"
msgstr "Année (B)"
-#: ../raster/r.sunmask/main.c:149 ../raster/r.sunmask/main.c:157
-#: ../raster/r.sunmask/main.c:165 ../raster/r.sunmask/main.c:173
-#: ../raster/r.sunmask/main.c:181 ../raster/r.sunmask/main.c:189
+#: ../raster/r.sunmask/main.c:149
+#: ../raster/r.sunmask/main.c:157
+#: ../raster/r.sunmask/main.c:165
+#: ../raster/r.sunmask/main.c:173
+#: ../raster/r.sunmask/main.c:181
+#: ../raster/r.sunmask/main.c:189
#: ../raster/r.sunmask/main.c:198
msgid "Time"
msgstr ""
@@ -11069,7 +11520,8 @@
msgid "Easting coordinate (point of interest)"
msgstr "Coordonnée X d'un point sur le plan."
-#: ../raster/r.sunmask/main.c:207 ../raster/r.sunmask/main.c:217
+#: ../raster/r.sunmask/main.c:207
+#: ../raster/r.sunmask/main.c:217
msgid "Default: map center"
msgstr "Défaut : centre de la carte"
@@ -11118,28 +11570,18 @@
#: ../raster/r.sunmask/main.c:282
#, fuzzy
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
-msgstr ""
-"Ni la position du soleil, ni les coordonnées E/N, ni la date/heure/fuseau "
-"n'ont été entièrement définies."
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+msgstr "Ni la position du soleil, ni les coordonnées E/N, ni la date/heure/fuseau n'ont été entièrement définies."
#: ../raster/r.sunmask/main.c:286
#, fuzzy, c-format
msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr ""
-"Calcul de la position du soleil en cours... (utilisation de solpos (V. %s) "
-"de NREL)\n"
+msgstr "Calcul de la position du soleil en cours... (utilisation de solpos (V. %s) de NREL)\n"
#: ../raster/r.sunmask/main.c:291
#, fuzzy
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
-msgstr ""
-"Utilisation de données d'azimut et d'altitude du soleil (ignore d'autres "
-"données éventuelles)\n"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
+msgstr "Utilisation de données d'azimut et d'altitude du soleil (ignore d'autres données éventuelles)\n"
#: ../raster/r.sunmask/main.c:397
#, fuzzy
@@ -11149,23 +11591,22 @@
#: ../raster/r.sunmask/main.c:411
#, fuzzy, c-format
msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
-msgstr ""
-"L'heure (%02i:%02i:%02i) est avant le lever du soleil (%02d:%02d:%02d) !\n"
+msgstr "L'heure (%02i:%02i:%02i) est avant le lever du soleil (%02d:%02d:%02d) !\n"
#: ../raster/r.sunmask/main.c:415
#, fuzzy, c-format
msgid "Time (%02i:%02i:%02i) is before sunrise"
msgstr "L'heure (%02i:%02i:%02i) est avant le lever du soleil !\n"
-#: ../raster/r.sunmask/main.c:418 ../raster/r.sunmask/main.c:428
+#: ../raster/r.sunmask/main.c:418
+#: ../raster/r.sunmask/main.c:428
msgid "Nothing to calculate. Please verify settings."
msgstr "Rien à calculer. Veuillez vérifier les paramètres."
#: ../raster/r.sunmask/main.c:422
#, fuzzy, c-format
msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
-msgstr ""
-"L'heure (%02i:%02i:%02i) est après le coucher du soleil (%02d:%02d:%02d) !\n"
+msgstr "L'heure (%02i:%02i:%02i) est après le coucher du soleil (%02d:%02d:%02d) !\n"
#: ../raster/r.sunmask/main.c:426
#, fuzzy, c-format
@@ -11297,14 +11738,11 @@
msgstr "Couche pour le coefficient y"
#: ../raster/r.regression.line/main.c:59
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"fichier ASCII où stocker les coefficients de régression (sortie à l'écran si "
-"aucun fichier n'est spécifié)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr "fichier ASCII où stocker les coefficients de régression (sortie à l'écran si aucun fichier n'est spécifié)."
-#: ../raster/r.regression.line/main.c:63 ../general/g.region/main.c:149
+#: ../raster/r.regression.line/main.c:63
+#: ../general/g.region/main.c:149
#: ../locale/scriptstrings/i.oif_to_translate.c:9
#, fuzzy
msgid "Print in shell script style"
@@ -11314,9 +11752,12 @@
msgid "Slower but accurate (applies to FP maps only"
msgstr ""
-#: ../raster/r.out.bin/main.c:53 ../raster/r.out.bin/main.c:62
-#: ../raster/r.out.bin/main.c:461 ../raster/r.mapcalc/map3.c:124
-#: ../raster/r.mapcalc/map3.c:138 ../raster/r.mapcalc/map3.c:152
+#: ../raster/r.out.bin/main.c:53
+#: ../raster/r.out.bin/main.c:62
+#: ../raster/r.out.bin/main.c:461
+#: ../raster/r.mapcalc/map3.c:124
+#: ../raster/r.mapcalc/map3.c:138
+#: ../raster/r.mapcalc/map3.c:152
#, fuzzy
msgid "Error writing data"
msgstr "Erreur de lecture des cellules de données"
@@ -11328,7 +11769,8 @@
msgstr "Ouvrir le fichier raster %s"
# c-format
-#: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
+#: ../raster/r.out.bin/main.c:144
+#: ../raster/r.out.bin/main.c:228
#: ../raster/r.out.bin/main.c:407
#, fuzzy, c-format
msgid "Unable to create file <%s>"
@@ -11383,16 +11825,12 @@
#: ../raster/r.out.bin/main.c:366
#, fuzzy
msgid "order= and -s are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
#: ../raster/r.out.bin/main.c:375
#, fuzzy
msgid "-i and -f are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.out.bin/main.c:394
msgid "Floating-point output requires bytes=4 or bytes=8"
@@ -11467,12 +11905,8 @@
#: ../raster/r.surf.random/main.c:46
#, fuzzy
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Produit una couche raster de données aléatoires uniformément réparties dans "
-"un rang donné par l'utilisateur."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "Produit una couche raster de données aléatoires uniformément réparties dans un rang donné par l'utilisateur."
#: ../raster/r.surf.random/main.c:53
msgid "Minimum random value"
@@ -11576,7 +12010,8 @@
msgid "Invalid 'map_data' array"
msgstr "Tableau invalide 'couche_données'"
-#: ../raster/r.in.mat/main.c:330 ../raster/r.in.mat/main.c:468
+#: ../raster/r.in.mat/main.c:330
+#: ../raster/r.in.mat/main.c:468
#: ../raster/r.in.mat/main.c:550
msgid "Please contact the GRASS development team"
msgstr "Veuillez contacter l'équipe de développement GRASS"
@@ -11635,17 +12070,20 @@
msgid "Calculates shape index on a raster map"
-#: ../raster/r.li/r.li.shape/main.c:41 ../raster/r.li/r.li.cwed/cwed.c:53
+#: ../raster/r.li/r.li.shape/main.c:41
+#: ../raster/r.li/r.li.cwed/cwed.c:53
#: ../raster/r.li/r.li.patchnum/main.c:43
#: ../raster/r.li/r.li.simpson/simpson.c:47
#: ../raster/r.li/r.li.dominance/dominance.c:46
-#: ../raster/r.li/r.li.pielou/pielou.c:67 ../raster/r.li/r.li.mps/mps.c:47
+#: ../raster/r.li/r.li.pielou/pielou.c:67
+#: ../raster/r.li/r.li.mps/mps.c:47
#: ../raster/r.li/r.li.shannon/shannon.c:46
#: ../raster/r.li/r.li.richness/richness.c:47
#: ../raster/r.li/r.li.renyi/renyi.c:54
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:46
#: ../raster/r.li/r.li.padrange/padrange.c:44
-#: ../raster/r.li/r.li.padsd/padsd.c:42 ../raster/r.li/r.li.mpa/mpa.c:45
+#: ../raster/r.li/r.li.padsd/padsd.c:42
+#: ../raster/r.li/r.li.mpa/mpa.c:45
#: ../raster/r.li/r.li.padcv/padcv.c:44
#: ../raster/r.li/r.li.patchdensity/main.c:42
#, fuzzy
@@ -11659,11 +12097,8 @@
#: ../raster/r.li/r.li.patchnum/main.c:34
#, fuzzy
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Calcule un index de densité de patch sur un fichier raster, en utilisant un "
-"algorithme de voisinage quatre"
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Calcule un index de densité de patch sur un fichier raster, en utilisant un algorithme de voisinage quatre"
#: ../raster/r.li/r.li.simpson/simpson.c:37
#, fuzzy
@@ -11691,12 +12126,8 @@
#: ../raster/r.li/r.li.mps/mps.c:39
#, fuzzy
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.li/r.li.shannon/shannon.c:36
#, fuzzy
@@ -11718,11 +12149,8 @@
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:37
#, fuzzy
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.li/r.li.padrange/padrange.c:37
#, fuzzy
@@ -11832,9 +12260,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:492
#, c-format
msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-msgstr ""
-"Le fichier de configuration peut seulement être utilisé avec les fichiers "
-"raster \t\t\t%s"
+msgstr "Le fichier de configuration peut seulement être utilisé avec les fichiers raster \t\t\t%s"
#: ../raster/r.li/r.li.daemon/daemon.c:499
msgid "Illegal configuration file (sample area)"
@@ -11967,20 +12393,13 @@
#: ../raster/r.li/r.li.patchdensity/main.c:33
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.out.ppm/main.c:56
#, fuzzy
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
#: ../raster/r.out.ppm/main.c:64
#, fuzzy
@@ -11992,7 +12411,8 @@
msgstr "Sortir du niveau de gris plutôt que de la couleur"
# c-format
-#: ../raster/r.out.ppm/main.c:110 ../raster/r.out.ppm3/main.c:109
+#: ../raster/r.out.ppm/main.c:110
+#: ../raster/r.out.ppm3/main.c:109
#, fuzzy, c-format
msgid "rows = %d, cols = %d"
msgstr "%d lignes, %d colonnes"
@@ -12040,8 +12460,7 @@
#: ../raster/r.random.cells/main.c:37
msgid "Generates random cell values with spatial dependence."
-msgstr ""
-"Générer des valeurs de cellules aléatoires ayant une interdépendance spatiale"
+msgstr "Générer des valeurs de cellules aléatoires ayant une interdépendance spatiale"
#: ../raster/r.timestamp/main.c:35
#, fuzzy
@@ -12051,15 +12470,11 @@
#: ../raster/r.timestamp/main.c:36
#, fuzzy
msgid "Modifies a timestamp for a raster map."
-msgstr ""
-"Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une "
-"couche raster"
+msgstr "Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une couche raster"
#: ../raster/r.timestamp/main.c:37
msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
-"couche raster"
#: ../raster/r.timestamp/main.c:46
#, fuzzy
@@ -12085,12 +12500,8 @@
msgstr "Nom de la couche ASCII à créer (utiliser out=- pour stdout)"
#: ../raster/r.out.ascii/main.c:92
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
-msgstr ""
-"Nombre de valeurs à produire avant de passer à la ligne (seulement pour les "
-"formats SURFER ou MODFLOW)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
+msgstr "Nombre de valeurs à produire avant de passer à la ligne (seulement pour les formats SURFER ou MODFLOW)"
#: ../raster/r.out.ascii/main.c:100
msgid "String to represent null cell (GRASS grid only)"
@@ -12145,12 +12556,8 @@
#: ../raster/r.cats/main.c:53
#, fuzzy
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Afficher les étiquettes et valeurs de catégorie associées avec les couches "
-"raster demandées."
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Afficher les étiquettes et valeurs de catégorie associées avec les couches raster demandées."
#: ../raster/r.cats/main.c:66
#, fuzzy
@@ -12187,7 +12594,8 @@
msgid "Category table for <%s> set from <%s>"
msgstr "Table de couleur de [%s] mise à jour à %s"
-#: ../raster/r.cats/main.c:197 ../raster/r.cats/main.c:243
+#: ../raster/r.cats/main.c:197
+#: ../raster/r.cats/main.c:243
#, fuzzy, c-format
msgid "Cannot create category file for <%s>"
msgstr "Editer le fichier de catégorie de [%s]?"
@@ -12199,9 +12607,7 @@
#: ../raster/r.cats/main.c:268
msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"La couche est en valeurs flottantes! La liste des cats est ignorée, la liste "
-"des vals est utilisée à la place"
+msgstr "La couche est en valeurs flottantes! La liste des cats est ignorée, la liste des vals est utilisée à la place"
#: ../raster/r.cats/main.c:285
msgid "vals argument is required for floating point map!"
@@ -12231,21 +12637,13 @@
#: ../raster/r.slope.aspect/main.c:156
#, fuzzy
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Produit des couches raster de pente, aspect, courbures et dérivées "
-"partielles à partir d'une couche raster de valeurs réelles d'altitude. "
-"L'aspect est calculé dans le sens contraire des aiguilles d'une montre à "
-"partir de l'est."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Produit des couches raster de pente, aspect, courbures et dérivées partielles à partir d'une couche raster de valeurs réelles d'altitude. L'aspect est calculé dans le sens contraire des aiguilles d'une montre à partir de l'est."
#: ../raster/r.slope.aspect/main.c:158
#, fuzzy
msgid "Aspect is calculated counterclockwise from east."
-msgstr ""
-"Angle de rotation (en degrés, sens inverse des aiguilles d'une montre en "
-"partant de l'Est)"
+msgstr "Angle de rotation (en degrés, sens inverse des aiguilles d'une montre en partant de l'Est)"
#: ../raster/r.slope.aspect/main.c:165
#, fuzzy
@@ -12256,16 +12654,26 @@
"#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
"Nom de la couche raster de sortie"
-#: ../raster/r.slope.aspect/main.c:166 ../raster/r.slope.aspect/main.c:172
-#: ../raster/r.slope.aspect/main.c:198 ../raster/r.slope.aspect/main.c:205
-#: ../raster/r.slope.aspect/main.c:212 ../raster/r.slope.aspect/main.c:219
-#: ../raster/r.slope.aspect/main.c:226 ../raster/r.slope.aspect/main.c:233
-#: ../raster/r.slope.aspect/main.c:240 ../vector/v.surf.rst/main.c:210
-#: ../vector/v.surf.rst/main.c:228 ../vector/v.surf.rst/main.c:234
-#: ../vector/v.surf.rst/main.c:240 ../vector/v.surf.rst/main.c:246
-#: ../vector/v.surf.rst/main.c:252 ../vector/v.surf.rst/main.c:258
-#: ../vector/v.surf.rst/main.c:266 ../vector/v.surf.rst/main.c:273
-#: ../vector/v.surf.rst/main.c:280 ../vector/v.surf.rst/main.c:287
+#: ../raster/r.slope.aspect/main.c:166
+#: ../raster/r.slope.aspect/main.c:172
+#: ../raster/r.slope.aspect/main.c:198
+#: ../raster/r.slope.aspect/main.c:205
+#: ../raster/r.slope.aspect/main.c:212
+#: ../raster/r.slope.aspect/main.c:219
+#: ../raster/r.slope.aspect/main.c:226
+#: ../raster/r.slope.aspect/main.c:233
+#: ../raster/r.slope.aspect/main.c:240
+#: ../vector/v.surf.rst/main.c:210
+#: ../vector/v.surf.rst/main.c:228
+#: ../vector/v.surf.rst/main.c:234
+#: ../vector/v.surf.rst/main.c:240
+#: ../vector/v.surf.rst/main.c:246
+#: ../vector/v.surf.rst/main.c:252
+#: ../vector/v.surf.rst/main.c:258
+#: ../vector/v.surf.rst/main.c:266
+#: ../vector/v.surf.rst/main.c:273
+#: ../vector/v.surf.rst/main.c:280
+#: ../vector/v.surf.rst/main.c:287
#, fuzzy
msgid "Outputs"
@@ -12299,19 +12707,13 @@
#: ../raster/r.slope.aspect/main.c:211
#, fuzzy
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-"Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx "
-"(gradient E-W)"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx (gradient E-W)"
#: ../raster/r.slope.aspect/main.c:218
#, fuzzy
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-"Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy "
-"(gradient N-S)"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy (gradient N-S)"
#: ../raster/r.slope.aspect/main.c:225
#, fuzzy
@@ -12334,9 +12736,7 @@
#: ../raster/r.slope.aspect/main.c:254
msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr ""
-"Valeur de pente minimale (en pourcentage) pour laquelle l'aspect doit être "
-"calculé"
+msgstr "Valeur de pente minimale (en pourcentage) pour laquelle l'aspect doit être calculé"
#: ../raster/r.slope.aspect/main.c:268
msgid "Do not align the current region to the elevation layer"
@@ -12354,12 +12754,8 @@
#: ../raster/r.slope.aspect/main.c:350
#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-"Vous devez spécifier au moins un des paramètres : <%s>, <%s>, <%s>, <%s>, <"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "Vous devez spécifier au moins un des paramètres : <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
# c-format
#: ../raster/r.slope.aspect/main.c:380
@@ -12500,8 +12896,10 @@
msgid "extend_lines: q back pointer not NULL!"
msgstr ""
-#: ../raster/r.to.vect/util.c:156 ../raster/r.to.vect/areas_io.c:371
-#: ../vector/v.random/main.c:300 ../vector/v.in.ogr/main.c:924
+#: ../raster/r.to.vect/util.c:156
+#: ../raster/r.to.vect/areas_io.c:371
+#: ../vector/v.random/main.c:300
+#: ../vector/v.in.ogr/main.c:924
#, c-format
msgid "Cannot insert new row: %s"
msgstr "Impossible d'insérer une nouvelle ligne : %s"
@@ -12515,7 +12913,8 @@
msgid "Converts a raster map into a vector map layer."
msgstr "Convertit une couche raster en couche vectorielle"
-#: ../raster/r.to.vect/main.c:65 ../vector/v.to.db/parse.c:36
+#: ../raster/r.to.vect/main.c:65
+#: ../vector/v.to.db/parse.c:36
#: ../vector/v.net.bridge/main.c:63
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
msgid "Feature type"
@@ -12528,16 +12927,20 @@
#: ../raster/r.to.vect/main.c:74
msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"Utiliser les valeurs raster comme catégories à la place d'une séquence "
-"unique (uniquement pour les CELL)"
+msgstr "Utiliser les valeurs raster comme catégories à la place d'une séquence unique (uniquement pour les CELL)"
-#: ../raster/r.to.vect/main.c:75 ../raster/r.to.vect/main.c:82
-#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
-#: ../vector/v.in.ogr/main.c:239 ../vector/v.digit/line.c:86
-#: ../vector/v.digit/attr.c:539 ../vector/v.digit/attr.c:575
-#: ../vector/v.transform/main.c:185 ../vector/v.transform/main.c:196
-#: ../vector/v.to.rast/main.c:72 ../vector/v.to.rast/main.c:78
+#: ../raster/r.to.vect/main.c:75
+#: ../raster/r.to.vect/main.c:82
+#: ../vector/v.in.ogr/main.c:193
+#: ../vector/v.in.ogr/main.c:216
+#: ../vector/v.in.ogr/main.c:239
+#: ../vector/v.digit/line.c:86
+#: ../vector/v.digit/attr.c:539
+#: ../vector/v.digit/attr.c:575
+#: ../vector/v.transform/main.c:185
+#: ../vector/v.transform/main.c:196
+#: ../vector/v.to.rast/main.c:72
+#: ../vector/v.to.rast/main.c:78
#: ../vector/v.to.rast/main.c:84
#, fuzzy
msgid "Attributes"
@@ -12545,18 +12948,12 @@
#: ../raster/r.to.vect/main.c:80
#, fuzzy
-msgid ""
-"Write raster values as z coordinate. Table is not created. Currently "
-"supported only for points."
-msgstr ""
-"Ecrit les valeurs rasters comme des coordonnées z. La table n'est pas créée. "
-"Pour le moment n'existe que pour les points."
+msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
+msgstr "Ecrit les valeurs rasters comme des coordonnées z. La table n'est pas créée. Pour le moment n'existe que pour les points."
#: ../raster/r.to.vect/main.c:87
msgid "Do not build vector topology (use with care for massive point export)"
-msgstr ""
-"Ne pas construire la topologie de vecteur (à utiliser avec précaution pour "
-"l'export massif de points)"
+msgstr "Ne pas construire la topologie de vecteur (à utiliser avec précaution pour l'export massif de points)"
#: ../raster/r.to.vect/main.c:92
msgid "Quiet - Do not show progress"
@@ -12568,21 +12965,23 @@
msgstr "Lister les formats gérés en sor"
#: ../raster/r.to.vect/main.c:124
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
msgstr ""
# c-format
-#: ../raster/r.to.vect/main.c:195 ../vector/v.random/main.c:193
-#: ../vector/v.lrs/v.lrs.create/main.c:326 ../vector/v.in.ascii/in.c:386
-#: ../vector/v.mkgrid/main.c:255 ../vector/v.in.sites/main.c:170
+#: ../raster/r.to.vect/main.c:195
+#: ../vector/v.random/main.c:193
+#: ../vector/v.lrs/v.lrs.create/main.c:326
+#: ../vector/v.in.ascii/in.c:386
+#: ../vector/v.mkgrid/main.c:255
+#: ../vector/v.in.sites/main.c:170
#: ../vector/v.in.dxf/write_vect.c:218
#, fuzzy, c-format
msgid "Unable to create table: %s"
msgstr "Impossible de créer le fichier de cellules pour [%s]"
-#: ../raster/r.to.vect/main.c:199 ../vector/v.overlay/main.c:469
+#: ../raster/r.to.vect/main.c:199
+#: ../vector/v.overlay/main.c:469
#: ../vector/v.mkgrid/main.c:259
#, fuzzy
msgid "Unable to create index"
@@ -12613,12 +13012,8 @@
msgstr "Écriture %s..."
#: ../raster/r.out.ppm3/main.c:59
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
-"Convertit trois couches raster R,G,B en un fichier image au format PPM, avec "
-"la résolution de la région actuelle."
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Convertit trois couches raster R,G,B en un fichier image au format PPM, avec la résolution de la région actuelle."
#: ../raster/r.out.ppm3/main.c:85
msgid "Name for new PPM file. (use out=- for stdout)"
@@ -12647,11 +13042,8 @@
#: ../raster/r.transect/main.c:56
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Donne en sortie les valeurs de la couche raster situées le long du transect "
-"défini"
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Donne en sortie les valeurs de la couche raster situées le long du transect défini"
#: ../raster/r.transect/main.c:60
msgid "Raster map to be queried"
@@ -12693,12 +13085,8 @@
msgstr "Impossible de lire %s"
#: ../raster/r.median/main.c:48
-msgid ""
-"Finds the median of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Trouve la médiane des valeurs d'une couche de couverture dans les zones "
-"définies par les catégories d'une couche de base."
+msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trouve la médiane des valeurs d'une couche de couverture dans les zones définies par les catégories d'une couche de base."
#: ../raster/r.median/main.c:54
#, fuzzy
@@ -12714,8 +13102,7 @@
#: ../raster/r.median/main.c:79
#, fuzzy, c-format
msgid "Base map and output map <%s> must be different"
-msgstr ""
-"Les coordonnées des germes et la couche de sortie= doivent être fixées!"
+msgstr "Les coordonnées des germes et la couche de sortie= doivent être fixées!"
#: ../raster/r.median/main.c:82
#, fuzzy, c-format
@@ -12735,20 +13122,15 @@
msgstr "Échelle verticale"
#: ../raster/r.neighbors/main.c:110
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Calcule pour chaque cellule une fonction des valeurs des cellules "
-"adjacentes, et sauvegarde les nouvelles valeurs de cellule dans une couche "
-"raster de sortie."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Calcule pour chaque cellule une fonction des valeurs des cellules adjacentes, et sauvegarde les nouvelles valeurs de cellule dans une couche raster de sortie."
#: ../raster/r.neighbors/main.c:133
msgid "Neighborhood operation"
msgstr "Opération sur le voisinage"
-#: ../raster/r.neighbors/main.c:134 ../raster/r.neighbors/main.c:142
+#: ../raster/r.neighbors/main.c:134
+#: ../raster/r.neighbors/main.c:142
#: ../raster/r.neighbors/main.c:176
#, fuzzy
msgid "Neighborhood"
@@ -12792,16 +13174,12 @@
#: ../raster/r.neighbors/main.c:189
#, fuzzy
msgid "weight= and -c are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.neighbors/main.c:201
#, fuzzy
msgid "weight= and gauss= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.neighbors/main.c:255
#, c-format
@@ -12831,7 +13209,8 @@
msgstr "Méthode d'interpolation à utiliser"
# c-format
-#: ../raster/r.resamp.interp/main.c:97 ../imagery/i.topo.corr/main.c:197
+#: ../raster/r.resamp.interp/main.c:97
+#: ../imagery/i.topo.corr/main.c:197
#, fuzzy, c-format
msgid "Invalid method: %s"
msgstr "Police invalide : %s"
@@ -12849,7 +13228,8 @@
msgid "Print raster map type only"
msgstr "Écrire uniquement le type de couche"
-#: ../raster/r.info/main.c:90 ../vector/v.info/main.c:85
+#: ../raster/r.info/main.c:90
+#: ../vector/v.info/main.c:85
#, fuzzy
msgid "Print map region only"
msgstr "Afficher seulement la région de la couche raster"
@@ -12868,23 +13248,23 @@
msgid "Print raster map vertical datum only"
-#: ../raster/r.info/main.c:106 ../vector/v.info/main.c:90
+#: ../raster/r.info/main.c:106
+#: ../vector/v.info/main.c:90
#, fuzzy
msgid "Print map title only"
#: ../raster/r.info/main.c:111
msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Afficher l'étiquette date&heure de la couche raster (sous la forme jour.mois."
-"année heure:minute:secondes)"
+msgstr "Afficher l'étiquette date&heure de la couche raster (sous la forme jour.mois.année heure:minute:secondes)"
#: ../raster/r.info/main.c:142
#, fuzzy
msgid "Unable to read range file"
msgstr "Impossible de lire le fichier couleur"
-#: ../raster/r.reclass/reclass.c:49 ../raster/r.reclass/reclass.c:109
+#: ../raster/r.reclass/reclass.c:49
+#: ../raster/r.reclass/reclass.c:109
#, fuzzy
msgid "Too many categories"
msgstr "Trop de points de départ."
@@ -12908,12 +13288,8 @@
#: ../raster/r.reclass/main.c:51
#, fuzzy
-msgid ""
-"Creates a new map layer whose category values are based upon a "
-"reclassification of the categories in an existing raster map layer."
-msgstr ""
-"Crée une nouvelle couche dont les catégories sont basées sur la "
-"reclassification des catégories d'une couche raster existante."
+msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+msgstr "Crée une nouvelle couche dont les catégories sont basées sur la reclassification des catégories d'une couche raster existante."
#: ../raster/r.reclass/main.c:56
msgid "Raster map to be reclassified"
@@ -12937,9 +13313,7 @@
#: ../raster/r.reclass/main.c:105
#, fuzzy, c-format
msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-"Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez "
-"besoin.\n"
+msgstr "Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez besoin.\n"
#: ../raster/r.reclass/main.c:107
#, fuzzy, c-format
@@ -12983,7 +13357,8 @@
msgid "Can't have null on the left-hand side of the rule"
msgstr ""
-#: ../raster/r.reclass/parse.c:87 ../raster/r.reclass/parse.c:99
+#: ../raster/r.reclass/parse.c:87
+#: ../raster/r.reclass/parse.c:99
msgid "Can't have null on the right-hand side of the rule"
msgstr ""
@@ -12994,9 +13369,7 @@
#: ../raster/r.coin/main.c:68
#, fuzzy
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
msgstr "Rééchelonne l'étendue des valeurs de catégories pour une couche raster"
#: ../raster/r.coin/main.c:76
@@ -13015,9 +13388,7 @@
msgstr "Unités de distance"
#: ../raster/r.coin/main.c:91
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
msgstr ""
#: ../raster/r.coin/main.c:98
@@ -13055,8 +13426,7 @@
msgstr ""
#: ../raster/r.coin/inter.c:35
-msgid ""
-"This utility will allow you to compare the coincidence of two map layers\n"
+msgid "This utility will allow you to compare the coincidence of two map layers\n"
msgstr ""
#: ../raster/r.coin/inter.c:52
@@ -13126,8 +13496,7 @@
#: ../raster/r.coin/inter.c:117
#, c-format
-msgid ""
-"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
msgstr ""
#: ../raster/r.coin/inter.c:126
@@ -13139,8 +13508,7 @@
#: ../raster/r.coin/inter.c:142
#, c-format
-msgid ""
-"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
msgstr ""
#: ../raster/r.coin/print_coin.c:44
@@ -13150,22 +13518,13 @@
#: ../raster/r.texture/h_measure.c:84
#, fuzzy
-msgid ""
-"Negative or no data pixel found. This module is not yet able to process no "
-"data holes in a map, please fill with r.fillnulls or other algorithms"
-msgstr ""
-"Valeur négative ou pixel sans données trouvé. Ce module n'est pour l'instant "
-"pas capable de traiter les trous de données dans une couche, veuillez "
-"compléter la couche avec r.fillbulls ou d'autres algorithmes."
+msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
+msgstr "Valeur négative ou pixel sans données trouvé. Ce module n'est pour l'instant pas capable de traiter les trous de données dans une couche, veuillez compléter la couche avec r.fillbulls ou d'autres algorithmes."
#: ../raster/r.texture/h_measure.c:88
#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-"Trop de catégories (trouvées: %i, max: %i). Essaye de rééchelonner ou de "
-"refaire la classification de la couche"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+msgstr "Trop de catégories (trouvées: %i, max: %i). Essaye de rééchelonner ou de refaire la classification de la couche"
#: ../raster/r.texture/h_measure.c:937
#, c-format
@@ -13195,13 +13554,20 @@
msgid "Angular Second Moment"
msgstr "Second temps angulaire"
-#: ../raster/r.texture/main.c:123 ../raster/r.texture/main.c:128
-#: ../raster/r.texture/main.c:133 ../raster/r.texture/main.c:138
-#: ../raster/r.texture/main.c:143 ../raster/r.texture/main.c:148
-#: ../raster/r.texture/main.c:153 ../raster/r.texture/main.c:158
-#: ../raster/r.texture/main.c:163 ../raster/r.texture/main.c:168
-#: ../raster/r.texture/main.c:173 ../raster/r.texture/main.c:178
-#: ../raster/r.texture/main.c:183 ../raster/r.texture/main.c:188
+#: ../raster/r.texture/main.c:123
+#: ../raster/r.texture/main.c:128
+#: ../raster/r.texture/main.c:133
+#: ../raster/r.texture/main.c:138
+#: ../raster/r.texture/main.c:143
+#: ../raster/r.texture/main.c:148
+#: ../raster/r.texture/main.c:153
+#: ../raster/r.texture/main.c:158
+#: ../raster/r.texture/main.c:163
+#: ../raster/r.texture/main.c:168
+#: ../raster/r.texture/main.c:173
+#: ../raster/r.texture/main.c:178
+#: ../raster/r.texture/main.c:183
+#: ../raster/r.texture/main.c:188
#, fuzzy
msgid "Features"
msgstr "Type de donnée vectorielle"
@@ -13283,11 +13649,10 @@
#: ../raster/r.in.gdal/main.c:113
msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Nom du Secteur (location) où lire la projection pour la transformation des "
-"points de calage"
+msgstr "Nom du Secteur (location) où lire la projection pour la transformation des points de calage"
-#: ../raster/r.in.gdal/main.c:128 ../vector/v.in.ogr/main.c:183
+#: ../raster/r.in.gdal/main.c:128
+#: ../vector/v.in.ogr/main.c:183
msgid "Name for new location to create"
msgstr "Nom du nouveau Secteur (location) à créer"
@@ -13299,9 +13664,7 @@
#: ../raster/r.in.gdal/main.c:155
#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
msgid "Keep band numbers instead of using band color names"
-msgstr ""
-"Conserver les numéros de bande plutôt que d'utiliser les noms de couleur des "
-"bandes"
+msgstr "Conserver les numéros de bande plutôt que d'utiliser les noms de couleur des bandes"
#: ../raster/r.in.gdal/main.c:176
msgid "You have to specify a target location different from output location"
@@ -13322,35 +13685,24 @@
msgstr "Le vecteur '%s' existe déjà."
#: ../raster/r.in.gdal/main.c:250
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
msgstr ""
#: ../raster/r.in.gdal/main.c:266
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
msgstr ""
#: ../raster/r.in.gdal/main.c:308
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
msgstr ""
#: ../raster/r.in.gdal/main.c:328
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Impossible de convertir la projection de la couche en entrée au format "
-"GRASS ; impossible de créer le nouveau Secteur"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "Impossible de convertir la projection de la couche en entrée au format GRASS ; impossible de créer le nouveau Secteur"
# c-format
-#: ../raster/r.in.gdal/main.c:334 ../general/g.proj/create.c:15
+#: ../raster/r.in.gdal/main.c:334
+#: ../general/g.proj/create.c:15
#, fuzzy, c-format
msgid "Location <%s> created"
msgstr "Secteur %s créé!"
@@ -13359,8 +13711,7 @@
#, fuzzy
msgid ""
"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
"Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
@@ -13397,32 +13748,25 @@
#: ../raster/r.in.gdal/main.c:655
#, fuzzy
msgid "Unable to translate projection key values of input GCPs"
-msgstr ""
-"Impossible d'obtenir les valeurs clefs de projection pour le Secteur "
-"(location) courant"
+msgstr "Impossible d'obtenir les valeurs clefs de projection pour le Secteur (location) courant"
#: ../raster/r.in.gdal/main.c:671
#, fuzzy
msgid "Unable to get projection info of target location"
-msgstr ""
-"Impossible d'obtenir les informations de projection pour le Secteur "
+msgstr "Impossible d'obtenir les informations de projection pour le Secteur (location) courant"
#: ../raster/r.in.gdal/main.c:673
#, fuzzy
msgid "Unable to get projection units of target location"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
#: ../raster/r.in.gdal/main.c:675
#, fuzzy
msgid "Unable to get projection key values of target location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:678 ../imagery/i.rectify/target.c:32
+#: ../raster/r.in.gdal/main.c:678
+#: ../imagery/i.rectify/target.c:32
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:31
#, fuzzy, c-format
msgid "Mapset <%s> in target location <%s> - "
@@ -13443,14 +13787,7 @@
msgstr ""
#: ../raster/r.horizon/main.c:181
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
msgstr ""
#: ../raster/r.horizon/main.c:234
@@ -13458,33 +13795,23 @@
msgstr ""
#: ../raster/r.horizon/main.c:250
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
msgstr ""
#: ../raster/r.horizon/main.c:258
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:266
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:274
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:282
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:290
@@ -13560,9 +13887,7 @@
#: ../raster/simwe/r.sim.sediment/main.c:113
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
msgstr ""
#: ../raster/simwe/r.sim.sediment/main.c:118
@@ -13670,13 +13995,20 @@
#: ../raster/simwe/r.sim.water/main.c:268
#: ../raster/simwe/r.sim.water/main.c:277
#: ../raster/simwe/r.sim.water/main.c:285
-#: ../raster/simwe/r.sim.water/main.c:294 ../vector/v.surf.rst/main.c:199
-#: ../vector/v.surf.rst/main.c:204 ../vector/v.surf.rst/main.c:293
-#: ../vector/v.surf.rst/main.c:301 ../vector/v.surf.rst/main.c:309
-#: ../vector/v.surf.rst/main.c:316 ../vector/v.surf.rst/main.c:324
-#: ../vector/v.surf.rst/main.c:332 ../vector/v.surf.rst/main.c:341
-#: ../vector/v.surf.rst/main.c:350 ../vector/v.surf.rst/main.c:359
-#: ../vector/v.surf.rst/main.c:368 ../vector/v.surf.rst/main.c:376
+#: ../raster/simwe/r.sim.water/main.c:294
+#: ../vector/v.surf.rst/main.c:199
+#: ../vector/v.surf.rst/main.c:204
+#: ../vector/v.surf.rst/main.c:293
+#: ../vector/v.surf.rst/main.c:301
+#: ../vector/v.surf.rst/main.c:309
+#: ../vector/v.surf.rst/main.c:316
+#: ../vector/v.surf.rst/main.c:324
+#: ../vector/v.surf.rst/main.c:332
+#: ../vector/v.surf.rst/main.c:341
+#: ../vector/v.surf.rst/main.c:350
+#: ../vector/v.surf.rst/main.c:359
+#: ../vector/v.surf.rst/main.c:368
+#: ../vector/v.surf.rst/main.c:376
#: ../vector/v.surf.rst/main.c:383
#, fuzzy
msgid "Parameters"
@@ -13721,7 +14053,8 @@
msgstr "Vous ne fabriquez aucun fichier raster ou vecteur en sortie"
#: ../raster/simwe/r.sim.sediment/main.c:358
-#: ../raster/simwe/r.sim.water/main.c:480 ../vector/v.surf.rst/main.c:717
+#: ../raster/simwe/r.sim.water/main.c:480
+#: ../vector/v.surf.rst/main.c:717
#: ../vector/v.surf.rst/main.c:769
msgid "Input failed"
msgstr "Echec de la saisie en entrée"
@@ -13791,9 +14124,7 @@
msgstr ""
#: ../raster/simwe/r.sim.water/main.c:276
-msgid ""
-"Threshold water depth [m] (diffusion increases after this water depth is "
-"reached)"
+msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
msgstr ""
#: ../raster/simwe/r.sim.water/main.c:284
@@ -13827,9 +14158,7 @@
#: ../raster/simwe/simlib/input.c:409
#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
msgstr ""
#: ../raster/simwe/simlib/input.c:541
@@ -13898,9 +14227,7 @@
#: ../raster/r.thin/main.c:57
#, fuzzy
msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
-"'Amincit' les cellules de valeur non-nulles qui semblent appartenir à des "
-"entités linéaires dans une couche raster"
+msgstr "'Amincit' les cellules de valeur non-nulles qui semblent appartenir à des entités linéaires dans une couche raster"
#: ../raster/r.thin/main.c:69
msgid "Maximal number of iterations"
@@ -13917,7 +14244,8 @@
msgid "%s: Unable to create temporary file <%s> -- errno = %d"
msgstr "Impossible d'écrire les fichiers temporaires"
-#: ../raster/r.thin/io.c:124 ../raster/r.thin/io.c:136
+#: ../raster/r.thin/io.c:124
+#: ../raster/r.thin/io.c:136
#: ../raster/r.thin/io.c:147
#, fuzzy, c-format
msgid "%s: Error writing temporary file"
@@ -13971,11 +14299,8 @@
msgstr ""
#: ../raster/r.covar/main.c:55
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
-msgstr ""
-"Produit une matrice de covariance/correlation pour la couche raster choisie."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Produit une matrice de covariance/correlation pour la couche raster choisie."
#: ../raster/r.covar/main.c:62
msgid "Print correlation matrix"
@@ -13986,7 +14311,8 @@
msgid "%s: complete ... "
msgstr "Pourcentage effectué..."
-#: ../raster/r.covar/main.c:129 ../imagery/i.pca/main.c:146
+#: ../raster/r.covar/main.c:129
+#: ../imagery/i.pca/main.c:146
msgid "No non-null values"
msgstr "Pas de valeurs non-null"
@@ -13994,38 +14320,26 @@
#: ../raster/r.out.gdal/export_band.c:373
#, fuzzy
msgid "Unable to allocate buffer for reading raster map"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
#: ../raster/r.out.gdal/export_band.c:186
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:191
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %f will "
+msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:201
#, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:208
#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
msgstr ""
# c-format
@@ -14047,9 +14361,12 @@
#: ../raster/r.out.gdal/export_band.c:536
#: ../raster/r.out.gdal/export_band.c:548
#: ../raster/r.out.gdal/export_band.c:561
-#: ../raster/r.out.gdal/export_band.c:575 ../raster/r.out.gdal/main.c:631
-#: ../raster/r.out.gdal/main.c:643 ../raster/r.out.gdal/main.c:656
-#: ../raster/r.out.gdal/main.c:669 ../raster/r.out.gdal/main.c:681
+#: ../raster/r.out.gdal/export_band.c:575
+#: ../raster/r.out.gdal/main.c:631
+#: ../raster/r.out.gdal/main.c:643
+#: ../raster/r.out.gdal/main.c:656
+#: ../raster/r.out.gdal/main.c:669
+#: ../raster/r.out.gdal/main.c:681
#: ../raster/r.out.gdal/main.c:694
msgid "Selected GDAL datatype does not cover data range."
msgstr ""
@@ -14057,8 +14374,10 @@
#: ../raster/r.out.gdal/export_band.c:499
#: ../raster/r.out.gdal/export_band.c:511
#: ../raster/r.out.gdal/export_band.c:524
-#: ../raster/r.out.gdal/export_band.c:537 ../raster/r.out.gdal/main.c:632
-#: ../raster/r.out.gdal/main.c:644 ../raster/r.out.gdal/main.c:657
+#: ../raster/r.out.gdal/export_band.c:537
+#: ../raster/r.out.gdal/main.c:632
+#: ../raster/r.out.gdal/main.c:644
+#: ../raster/r.out.gdal/main.c:657
#: ../raster/r.out.gdal/main.c:670
#, c-format
msgid "GDAL datatype: %s, range: %d - %d"
@@ -14075,13 +14394,15 @@
msgid "Raster map <%s> range: %g - %g"
msgstr "couche raster <%s> non trouvée"
-#: ../raster/r.out.gdal/export_band.c:549 ../raster/r.out.gdal/main.c:682
+#: ../raster/r.out.gdal/export_band.c:549
+#: ../raster/r.out.gdal/main.c:682
#, c-format
msgid "GDAL datatype: %s, range: %u - %u"
msgstr ""
#: ../raster/r.out.gdal/export_band.c:562
-#: ../raster/r.out.gdal/export_band.c:576 ../raster/r.out.gdal/main.c:695
+#: ../raster/r.out.gdal/export_band.c:576
+#: ../raster/r.out.gdal/main.c:695
#, c-format
msgid "GDAL datatype: %s, range: %g - %g"
msgstr ""
@@ -14147,9 +14468,7 @@
#: ../raster/r.out.gdal/main.c:190
#, fuzzy
msgid "Creation option(s) to pass to the output format driver"
-msgstr ""
-"option de création du pilote de format de sortie. De multiples options "
-"peuvent être disponibles"
+msgstr "option de création du pilote de format de sortie. De multiples options peuvent être disponibles"
#: ../raster/r.out.gdal/main.c:192
#: ../locale/scriptstrings/d.out.file_to_translate.c:21
@@ -14161,9 +14480,7 @@
msgstr ""
#: ../raster/r.out.gdal/main.c:201
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
msgstr ""
#: ../raster/r.out.gdal/main.c:210
@@ -14189,17 +14506,13 @@
#: ../raster/r.out.gdal/main.c:267
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../raster/r.out.gdal/main.c:272
#, fuzzy
msgid "Unable to get in-memory raster driver"
-msgstr ""
-"mémoire)"
#: ../raster/r.out.gdal/main.c:276
#, c-format
@@ -14223,26 +14536,21 @@
#: ../raster/r.out.gdal/main.c:435
#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
msgstr ""
#: ../raster/r.out.gdal/main.c:446
#, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
msgstr ""
#: ../raster/r.out.gdal/main.c:454
#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
msgstr ""
-#: ../raster/r.out.gdal/main.c:482 ../raster/r.out.gdal/main.c:511
+#: ../raster/r.out.gdal/main.c:482
+#: ../raster/r.out.gdal/main.c:511
#: ../raster/r.out.gdal/main.c:515
#, fuzzy
msgid "Raster export aborted."
@@ -14314,8 +14622,10 @@
msgid "Unable to create raster map <%s> using driver <%s>"
msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
-#: ../raster/r.out.gdal/main.c:635 ../raster/r.out.gdal/main.c:647
-#: ../raster/r.out.gdal/main.c:660 ../raster/r.out.gdal/main.c:673
+#: ../raster/r.out.gdal/main.c:635
+#: ../raster/r.out.gdal/main.c:647
+#: ../raster/r.out.gdal/main.c:660
+#: ../raster/r.out.gdal/main.c:673
#: ../raster/r.out.gdal/main.c:685
#, fuzzy, c-format
msgid "Range to be exported: %f - %f"
@@ -14326,33 +14636,31 @@
msgid "Range to be exported: %g - %g"
msgstr "Fichier raster à importer"
-#: ../raster/r.out.gdal/main.c:722 ../raster/r.out.gdal/main.c:735
-#: ../raster/r.out.gdal/main.c:749 ../raster/r.out.gdal/main.c:762
+#: ../raster/r.out.gdal/main.c:722
+#: ../raster/r.out.gdal/main.c:735
+#: ../raster/r.out.gdal/main.c:749
+#: ../raster/r.out.gdal/main.c:762
#: ../raster/r.out.gdal/main.c:777
#, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %f gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
msgstr ""
-#: ../raster/r.out.gdal/main.c:725 ../raster/r.out.gdal/main.c:752
+#: ../raster/r.out.gdal/main.c:725
+#: ../raster/r.out.gdal/main.c:752
#: ../raster/r.out.gdal/main.c:780
#, c-format
msgid "GDAL datatype: %s, valid range: %d - %d"
msgstr ""
-#: ../raster/r.out.gdal/main.c:738 ../raster/r.out.gdal/main.c:765
+#: ../raster/r.out.gdal/main.c:738
+#: ../raster/r.out.gdal/main.c:765
#, c-format
msgid "GDAL datatype: %s, valid range: %u - %u"
msgstr ""
#: ../raster/r.out.gdal/main.c:791
#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
msgstr ""
#: ../raster/r.out.gdal/main.c:794
@@ -14400,8 +14708,7 @@
#: ../raster/r.lake/main.c:195
msgid "Use negative depth values for lake raster map"
-msgstr ""
-"Utiliser des valeurs de profondeur négatives pour la couche raster du lac"
+msgstr "Utiliser des valeurs de profondeur négatives pour la couche raster du lac"
#: ../raster/r.lake/main.c:200
msgid "Overwrite seed map with result (lake) map"
@@ -14418,8 +14725,7 @@
#: ../raster/r.lake/main.c:212
msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
#: ../raster/r.lake/main.c:215
#, fuzzy
@@ -14442,9 +14748,7 @@
msgstr "get_img : mémoire insuffisante."
#: ../raster/r.lake/main.c:303
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
msgstr ""
#: ../raster/r.lake/main.c:386
@@ -14467,14 +14771,8 @@
msgstr ""
#: ../raster/r.surf.gauss/main.c:48
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
-msgstr ""
-"Module GRASS pour produire une couche raster de données gaussiennes dont la "
-"moyenne et l'écart-type peuvent être donnés par l'utilisateur. Utilise un "
-"générateur de nombres aléatoires gaussiens."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+msgstr "Module GRASS pour produire une couche raster de données gaussiennes dont la moyenne et l'écart-type peuvent être donnés par l'utilisateur. Utilise un générateur de nombres aléatoires gaussiens."
#: ../raster/r.surf.gauss/main.c:55
#, fuzzy
@@ -14512,16 +14810,15 @@
#: ../raster/r.in.poly/main.c:31
#, fuzzy
msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr ""
-"Créer des couches raster à partir de fichiers de données polygones/lignes "
-"dans le répertoire courant."
+msgstr "Créer des couches raster à partir de fichiers de données polygones/lignes dans le répertoire courant."
#: ../raster/r.in.poly/main.c:35
#, fuzzy
msgid "Name of input file; or \"-\" to read from stdin"
msgstr "Fichier ascii contenant les signatures spectrales"
-#: ../raster/r.in.poly/main.c:50 ../vector/v.to.rast/main.c:100
+#: ../raster/r.in.poly/main.c:50
+#: ../vector/v.to.rast/main.c:100
msgid "Number of rows to hold in memory"
msgstr "Nombre de lignes à garder en mémoire"
@@ -14548,11 +14845,8 @@
#: ../raster/r.in.ascii/main.c:74
#, fuzzy
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgid "ASCII raster file to be imported. If not given reads from standard input"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../raster/r.in.ascii/main.c:100
msgid "String representing NULL value data cell"
@@ -14724,9 +15018,7 @@
#: ../raster/r.surf.fractal/process.c:53
#, fuzzy
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr ""
-"mémoire)"
#: ../raster/r.surf.fractal/spec_syn.c:61
msgid "Preliminary surface calculations..."
@@ -14760,12 +15052,8 @@
msgstr "Dimension fractale de la surface (2 < D < 3)"
#: ../raster/r.average/main.c:53
-msgid ""
-"Finds the average of values in a cover map within areas assigned the same "
-msgstr ""
-"Trouve la moyenne des valeurs d'une couche de couverture à partir des zones "
-"ayant la même catégorie dans une couche de base spécifiée par l'utilisateur."
+msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trouve la moyenne des valeurs d'une couche de couverture à partir des zones ayant la même catégorie dans une couche de base spécifiée par l'utilisateur."
#: ../raster/r.average/main.c:93
#, c-format
@@ -14820,7 +15108,8 @@
msgid "Could not get raster row from elev map"
msgstr "Ligne du fichier raster introuvable\n"
-#: ../raster/r.to.rast3elev/main.c:326 ../raster/r.to.rast3elev/main.c:360
+#: ../raster/r.to.rast3elev/main.c:326
+#: ../raster/r.to.rast3elev/main.c:360
#, fuzzy
msgid "Error writing 3D raster double data"
@@ -14832,9 +15121,7 @@
#: ../raster/r.to.rast3elev/main.c:402
#, fuzzy
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir "
-"d'une couche de relief 2D"
+msgstr "Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir d'une couche de relief 2D"
#: ../raster/r.to.rast3elev/main.c:433
#, fuzzy
@@ -14847,21 +15134,27 @@
msgstr "Le fichier de catégorie de <%s> n'est pas valide"
# c-format
-#: ../raster/r.mapcalc/map.c:83 ../raster/r.mapcalc/map3.c:177
+#: ../raster/r.mapcalc/map.c:83
+#: ../raster/r.mapcalc/map3.c:177
#, fuzzy, c-format
msgid "Unable to read color file for raster map <%s@%s>"
msgstr "Impossible de créer la couche raster <%s>"
# c-format
-#: ../raster/r.mapcalc/map.c:96 ../raster/r.mapcalc/map3.c:190
+#: ../raster/r.mapcalc/map.c:96
+#: ../raster/r.mapcalc/map3.c:190
#, fuzzy, c-format
msgid "Unable to create btree for raster map <%s@%s>"
-#: ../raster/r.mapcalc/map.c:141 ../raster/r.mapcalc/map.c:353
-#: ../raster/r.mapcalc/map.c:394 ../raster/r.mapcalc/map.c:484
-#: ../raster/r.mapcalc/map3.c:235 ../raster/r.mapcalc/map3.c:417
-#: ../raster/r.mapcalc/map3.c:461 ../raster/r.mapcalc/map3.c:552
+#: ../raster/r.mapcalc/map.c:141
+#: ../raster/r.mapcalc/map.c:353
+#: ../raster/r.mapcalc/map.c:394
+#: ../raster/r.mapcalc/map.c:484
+#: ../raster/r.mapcalc/map3.c:235
+#: ../raster/r.mapcalc/map3.c:417
+#: ../raster/r.mapcalc/map3.c:461
+#: ../raster/r.mapcalc/map3.c:552
#: ../raster/r.mapcalc/expression.c:356
#, fuzzy, c-format
msgid "Invalid map modifier: '%c'"
@@ -14872,8 +15165,10 @@
msgid "Rowio_setup failed"
msgstr "Echec de la fermeture."
-#: ../raster/r.mapcalc/map.c:280 ../raster/r.mapcalc/evaluate.c:91
-#: ../raster/r.mapcalc/evaluate.c:206 ../raster/r.mapcalc/map3.c:348
+#: ../raster/r.mapcalc/map.c:280
+#: ../raster/r.mapcalc/evaluate.c:91
+#: ../raster/r.mapcalc/evaluate.c:206
+#: ../raster/r.mapcalc/map3.c:348
#, fuzzy, c-format
msgid "Unknown type: %d"
msgstr "Type inconnu: %c"
@@ -14884,13 +15179,15 @@
# c-format
-#: ../raster/r.mapcalc/map.c:309 ../raster/r.mapcalc/map3.c:367
+#: ../raster/r.mapcalc/map.c:309
+#: ../raster/r.mapcalc/map3.c:367
#, fuzzy, c-format
msgid "Unable to close raster map <%s@%s>"
msgstr "Impossible d'ouvrir la couche raster <%s>"
# c-format
-#: ../raster/r.mapcalc/map.c:442 ../imagery/i.topo.corr/main.c:38
+#: ../raster/r.mapcalc/map.c:442
+#: ../imagery/i.topo.corr/main.c:38
#, fuzzy, c-format
msgid "Unable to open raster map <%s@%s>"
@@ -15071,13 +15368,8 @@
#: ../raster/r.flow/calc.c:413
#, fuzzy
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)."
-msgstr ""
-"Constructon de courbes de terrain (lignes du courant), longueur des "
-"courants, et densité de lignes de courants (zones amont) à partir d'un "
-"modèle numérique de terrain (MNT) raster"
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+msgstr "Constructon de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (zones amont) à partir d'un modèle numérique de terrain (MNT) raster"
#: ../raster/r.flow/calc.c:451
#, fuzzy
@@ -15116,9 +15408,7 @@
#: ../raster/r.flow/calc.c:507
msgid "Compute upslope flowlines instead of default downhill flowlines"
-msgstr ""
-"Calculer les courants ascendants plutôt que les courants descendants par "
-"défaut"
+msgstr "Calculer les courants ascendants plutôt que les courants descendants par défaut"
#: ../raster/r.flow/calc.c:511
msgid "3-D lengths instead of 2-D"
@@ -15130,17 +15420,12 @@
#: ../raster/r.flow/calc.c:533
msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-"Vous devez sélectionner une couche de sortie ou plus (flout, lgout, dsout)"
+msgstr "Vous devez sélectionner une couche de sortie ou plus (flout, lgout, dsout)"
#: ../raster/r.flow/calc.c:549
#, fuzzy
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
-"Les bases de données en latitude/longitude ne sont pas supportées par r."
-"flow. Veuillez à utiliser 'r.watershed' pour calculer la crue."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
+msgstr "Les bases de données en latitude/longitude ne sont pas supportées par r.flow. Veuillez à utiliser 'r.watershed' pour calculer la crue."
# c-format
#: ../raster/r.flow/io.c:68
@@ -15156,9 +15441,7 @@
#: ../raster/r.flow/io.c:89
#, fuzzy
msgid "Elevation file's resolution differs from current region resolution"
-msgstr ""
-"Résolution de la couche en entrée ne correspond pas à la résolution de la "
-"région courante!"
+msgstr "Résolution de la couche en entrée ne correspond pas à la résolution de la région courante!"
# c-format
#: ../raster/r.flow/io.c:101
@@ -15169,9 +15452,7 @@
#: ../raster/r.flow/io.c:104
#, fuzzy
msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-"région courante!"
#: ../raster/r.flow/io.c:118
msgid "Reading input files: barrier"
@@ -15214,7 +15495,8 @@
msgid "Unable to write segment file for %s"
msgstr "Impossible d'écrire le fichier temporaire"
-#: ../imagery/i.points/main.c:96 ../imagery/i.vpoints/main.c:94
+#: ../imagery/i.points/main.c:96
+#: ../imagery/i.vpoints/main.c:94
#, fuzzy
msgid "imagery, geometry"
msgstr "Couche vecteur à supprimer"
@@ -15223,59 +15505,88 @@
msgid "Mark ground control points on image to be rectified."
msgstr "Placer des points de contrôle sur une image pour la recaler."
-#: ../imagery/i.points/main.c:105 ../imagery/i.vpoints/main.c:104
+#: ../imagery/i.points/main.c:105
+#: ../imagery/i.vpoints/main.c:104
#, fuzzy
msgid "Name of imagery group to be registered"
msgstr "Nom du groupe d'images"
-#: ../imagery/i.points/main.c:123 ../imagery/i.class/main.c:90
+#: ../imagery/i.points/main.c:123
+#: ../imagery/i.class/main.c:90
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:97
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:81
-#: ../display/d.paint.labels/main.c:90 ../display/d.histogram/main.c:181
-#: ../display/d.vect/main.c:377 ../display/d.rhumbline/main.c:108
-#: ../display/d.where/main.c:144 ../display/d.what.vect/main.c:160
-#: ../display/d.text/main.c:132 ../display/d.linegraph/linegraph.c:251
-#: ../display/d.profile/main.c:134 ../display/d.ask/main.c:61
-#: ../display/d.what.rast/main.c:116 ../display/d.info/main.c:74
-#: ../display/d.vect.chart/main.c:257 ../display/d.barscale/main.c:134
-#: ../display/d.erase/main.c:58 ../display/d.zoom/main.c:158
-#: ../display/d.zoom/main.c:293 ../display/d.zoom/redraw.c:39
-#: ../display/d.rast.num/number.c:132 ../display/d.text.freetype/main.c:310
-#: ../display/d.grid/main.c:186 ../display/d.frame/frame.c:129
-#: ../display/d.frame/frame.c:183 ../display/d.frame/frame.c:223
-#: ../display/d.frame/list.c:23 ../display/d.frame/select.c:36
-#: ../display/d.text.new/main.c:295 ../display/d.his/main.c:117
-#: ../display/d.geodesic/main.c:105 ../display/d.colortable/main.c:138
-#: ../display/d.rast/main.c:114 ../display/d.thematic.area/main.c:397
-#: ../display/d.font.freetype/main.c:103 ../display/d.graph/main.c:96
-#: ../display/d.rgb/main.c:83 ../display/d.path/main.c:159
-#: ../display/d.rast.arrow/arrow.c:245 ../display/d.extract/main.c:79
-#: ../display/d.legend/main.c:274 ../display/d.menu/main.c:108
-#: ../display/d.measure/main.c:87 ../display/d.nviz/main.c:250
-#: ../display/d.extend/main.c:41 ../display/d.font/main.c:86
+#: ../display/d.paint.labels/main.c:90
+#: ../display/d.histogram/main.c:181
+#: ../display/d.vect/main.c:377
+#: ../display/d.rhumbline/main.c:108
+#: ../display/d.where/main.c:144
+#: ../display/d.what.vect/main.c:160
+#: ../display/d.text/main.c:132
+#: ../display/d.linegraph/linegraph.c:251
+#: ../display/d.profile/main.c:134
+#: ../display/d.ask/main.c:61
+#: ../display/d.what.rast/main.c:116
+#: ../display/d.info/main.c:74
+#: ../display/d.vect.chart/main.c:257
+#: ../display/d.barscale/main.c:134
+#: ../display/d.erase/main.c:58
+#: ../display/d.zoom/main.c:158
+#: ../display/d.zoom/main.c:293
+#: ../display/d.zoom/redraw.c:39
+#: ../display/d.rast.num/number.c:132
+#: ../display/d.text.freetype/main.c:310
+#: ../display/d.grid/main.c:186
+#: ../display/d.frame/frame.c:129
+#: ../display/d.frame/frame.c:183
+#: ../display/d.frame/frame.c:223
+#: ../display/d.frame/list.c:23
+#: ../display/d.frame/select.c:36
+#: ../display/d.text.new/main.c:295
+#: ../display/d.his/main.c:117
+#: ../display/d.geodesic/main.c:105
+#: ../display/d.colortable/main.c:138
+#: ../display/d.rast/main.c:114
+#: ../display/d.thematic.area/main.c:397
+#: ../display/d.font.freetype/main.c:103
+#: ../display/d.graph/main.c:96
+#: ../display/d.rgb/main.c:83
+#: ../display/d.path/main.c:159
+#: ../display/d.rast.arrow/arrow.c:245
+#: ../display/d.extract/main.c:79
+#: ../display/d.legend/main.c:274
+#: ../display/d.menu/main.c:108
+#: ../display/d.measure/main.c:87
+#: ../display/d.nviz/main.c:250
+#: ../display/d.extend/main.c:41
+#: ../display/d.font/main.c:86
#: ../vector/v.label/main.c:234
msgid "No graphics device selected"
msgstr "Aucune sortie graphique n'est sélectionnée"
-#: ../imagery/i.points/main.c:130 ../imagery/i.vpoints/main.c:127
+#: ../imagery/i.points/main.c:130
+#: ../imagery/i.vpoints/main.c:127
#, c-format
msgid "[%s] Only local groups may be used"
msgstr ""
-#: ../imagery/i.points/main.c:139 ../imagery/i.points/main.c:143
-#: ../imagery/i.vpoints/main.c:136 ../imagery/i.vpoints/main.c:140
+#: ../imagery/i.points/main.c:139
+#: ../imagery/i.points/main.c:143
+#: ../imagery/i.vpoints/main.c:136
+#: ../imagery/i.vpoints/main.c:140
#, fuzzy, c-format
msgid "Group [%s] contains no maps, run i.group"
msgstr "Groupe [%s] ne contient pas de fichier"
-#: ../imagery/i.points/main.c:248 ../imagery/i.vpoints/main.c:254
+#: ../imagery/i.points/main.c:248
+#: ../imagery/i.vpoints/main.c:254
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:302
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:195
#, c-format
msgid "ERROR: %s"
msgstr ""
-#: ../imagery/i.points/main.c:250 ../imagery/i.vpoints/main.c:256
+#: ../imagery/i.points/main.c:250
+#: ../imagery/i.vpoints/main.c:256
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:304
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:197
#, c-format
@@ -15334,7 +15645,8 @@
msgid "Initializing data..."
msgstr "Initialisation des données...\n"
-#: ../imagery/i.zc/main.c:170 ../imagery/i.fft/fftmain.c:170
+#: ../imagery/i.zc/main.c:170
+#: ../imagery/i.fft/fftmain.c:170
msgid "Error while reading input raster map."
msgstr "Erreur de lecture de la couche raster en entrée"
@@ -15348,12 +15660,12 @@
msgstr "Transformée réussie."
#: ../imagery/i.smap/shapiro/read_sig.c:13
-#: ../imagery/i.smap/shapiro/openfiles.c:15 ../imagery/i.gensig/openfiles.c:16
+#: ../imagery/i.smap/shapiro/openfiles.c:15
+#: ../imagery/i.gensig/openfiles.c:16
#: ../imagery/i.gensigset/openfiles.c:15
#, fuzzy, c-format
msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr ""
-"Impossible de lire le fichier REF du sous-groupe [%s] dans le groupe [%s]"
+msgstr "Impossible de lire le fichier REF du sous-groupe [%s] dans le groupe [%s]"
#: ../imagery/i.smap/shapiro/read_sig.c:17
#: ../imagery/i.smap/shapiro/openfiles.c:19
@@ -15362,7 +15674,8 @@
msgstr "Le sous-groupe [%s] du groupe [%s] ne contient pas de fichier."
# c-format
-#: ../imagery/i.smap/shapiro/read_sig.c:23 ../imagery/i.maxlik/open.c:54
+#: ../imagery/i.smap/shapiro/read_sig.c:23
+#: ../imagery/i.maxlik/open.c:54
#: ../imagery/i.cluster/open_files.c:70
#, fuzzy, c-format
msgid "Unable to read signature file <%s>"
@@ -15378,20 +15691,18 @@
msgid "Signature file <%s> is empty"
msgstr "Fichier signature [%s] invalide"
-#: ../imagery/i.smap/shapiro/main.c:38 ../imagery/i.gensigset/main.c:40
+#: ../imagery/i.smap/shapiro/main.c:38
+#: ../imagery/i.gensigset/main.c:40
#, fuzzy
msgid "imagery, classification, supervised, SMAP"
msgstr "Nom de fichier du résultat de la classification"
#: ../imagery/i.smap/shapiro/main.c:40
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Effectue une classification contextuelle de l'image en utilisant une "
-"estimation séquentielle maximum a posteriori (SMAP)."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Effectue une classification contextuelle de l'image en utilisant une estimation séquentielle maximum a posteriori (SMAP)."
-#: ../imagery/i.smap/shapiro/parse.c:21 ../imagery/i.maxlik/main.c:79
+#: ../imagery/i.smap/shapiro/parse.c:21
+#: ../imagery/i.maxlik/main.c:79
#, fuzzy
msgid "Name of file containing signatures"
msgstr "Fichier contenant les requêtes SQL"
@@ -15407,13 +15718,13 @@
#: ../imagery/i.smap/shapiro/parse.c:39
msgid "Use maximum likelihood estimation (instead of smap)"
-msgstr ""
-"Utiliser l'estimation plus grande ressemblance 'maximum likelihood' (à la "
-"place de l'estimation SMAP)"
+msgstr "Utiliser l'estimation plus grande ressemblance 'maximum likelihood' (à la place de l'estimation SMAP)"
# c-format
-#: ../imagery/i.smap/shapiro/parse.c:58 ../imagery/i.maxlik/open.c:16
-#: ../imagery/i.gensig/parse.c:39 ../imagery/i.gensigset/parse.c:45
+#: ../imagery/i.smap/shapiro/parse.c:58
+#: ../imagery/i.maxlik/open.c:16
+#: ../imagery/i.gensig/parse.c:39
+#: ../imagery/i.gensigset/parse.c:45
#: ../imagery/i.cluster/open_files.c:17
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:177
#, fuzzy, c-format
@@ -15423,7 +15734,8 @@
"groupe <%s> non trouvé"
# c-format
-#: ../imagery/i.smap/shapiro/parse.c:61 ../imagery/i.gensig/parse.c:42
+#: ../imagery/i.smap/shapiro/parse.c:61
+#: ../imagery/i.gensig/parse.c:42
#: ../imagery/i.gensigset/parse.c:48
#, fuzzy, c-format
msgid "Subgroup <%s> not found"
@@ -15462,9 +15774,7 @@
#: ../imagery/i.landsat.acca/main.c:74
#, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
msgstr ""
#: ../imagery/i.landsat.acca/main.c:106
@@ -15476,7 +15786,8 @@
msgid "imagery, landsat, acca"
msgstr "Nom de fichier de signatures à utiliser pour la classification"
-#: ../imagery/i.landsat.acca/main.c:111 ../imagery/i.landsat.toar/main.c:70
+#: ../imagery/i.landsat.acca/main.c:111
+#: ../imagery/i.landsat.toar/main.c:70
#, fuzzy
msgid "Base name of input raster bands"
msgstr ""
@@ -15485,7 +15796,8 @@
-#: ../imagery/i.landsat.acca/main.c:112 ../imagery/i.landsat.toar/main.c:71
+#: ../imagery/i.landsat.acca/main.c:112
+#: ../imagery/i.landsat.toar/main.c:71
msgid "Example: 'B.' for B.1, B.2, ..."
msgstr ""
@@ -15502,8 +15814,10 @@
msgid "Number of classes in the cloud temperature histogram"
msgstr "Nombre de classes pour l'intervalle thématique (entier)"
-#: ../imagery/i.landsat.acca/main.c:139 ../imagery/i.landsat.acca/main.c:154
-#: ../imagery/i.landsat.acca/main.c:160 ../imagery/i.landsat.acca/main.c:165
+#: ../imagery/i.landsat.acca/main.c:139
+#: ../imagery/i.landsat.acca/main.c:154
+#: ../imagery/i.landsat.acca/main.c:160
+#: ../imagery/i.landsat.acca/main.c:165
#, fuzzy
msgid "Cloud settings"
msgstr "Afficher également les paramètres 3D"
@@ -15525,8 +15839,7 @@
msgstr ""
#: ../imagery/i.landsat.acca/main.c:159
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
msgstr ""
#: ../imagery/i.landsat.acca/main.c:164
@@ -15669,21 +15982,13 @@
#: ../imagery/i.maxlik/main.c:67
#, fuzzy
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
-msgstr ""
-"Fonction d'imagerie qui fait une classification des réflectances spectrales "
-"des cellules de données images à partir des informations de signatures "
-"spectrales générées soit par i.cluster, i.class, ou i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
+msgstr "Fonction d'imagerie qui fait une classification des réflectances spectrales des cellules de données images à partir des informations de signatures spectrales générées soit par i.cluster, i.class, ou i.gensig."
#: ../imagery/i.maxlik/main.c:80
#, fuzzy
msgid "Generated by either i.cluster, i.class, or i.gensig"
-msgstr ""
#: ../imagery/i.maxlik/main.c:85
#, fuzzy
@@ -15696,25 +16001,22 @@
msgstr "couche raster où écrire les résultats rejetés du seuillage"
# c-format
-#: ../imagery/i.maxlik/open.c:19 ../imagery/i.cluster/open_files.c:21
+#: ../imagery/i.maxlik/open.c:19
+#: ../imagery/i.cluster/open_files.c:21
#, fuzzy, c-format
msgid "Subgroup <%s> in group <%s> not found"
msgstr "sous-groupe <%s> non trouvé"
#: ../imagery/i.maxlik/open.c:26
#, fuzzy, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
msgstr ""
"Le sous-groupe [%s] du groupe [%s] ne contient aucun fichier.\n"
"Le sous-groupe doit contenir au moins 2 fichiers."
#: ../imagery/i.maxlik/open.c:29
#, fuzzy, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
msgstr ""
"Le sous-groupe [%s] du groupe [%s] ne contient qu'un fichier.\n"
@@ -15725,7 +16027,8 @@
msgid "Unable to open signature file <%s>"
msgstr "impossible d'ouvrir le fichier en entrée <%s>"
-#: ../imagery/i.maxlik/open.c:58 ../imagery/i.cluster/open_files.c:74
+#: ../imagery/i.maxlik/open.c:58
+#: ../imagery/i.cluster/open_files.c:74
#, fuzzy, c-format
msgid "<%s> has too many signatures (limit is 255)"
msgstr "** <%s> a trop de signatures (le plafond est 255)"
@@ -15748,28 +16051,20 @@
#: ../imagery/i.landsat.toar/landsat_met.c:87
#, c-format
-msgid ""
-"Product creation date not in metadata file <%s>, input this data in the "
-"command line parameters"
+msgid "Product creation date not in metadata file <%s>, input this data in the command line parameters"
msgstr ""
#: ../imagery/i.landsat.toar/landsat_met.c:95
#, c-format
-msgid ""
-"Unable to read solar elevation from metadata file in metadata file <%s>, "
-"input this data in the command line parameters"
+msgid "Unable to read solar elevation from metadata file in metadata file <%s>, input this data in the command line parameters"
msgstr ""
#: ../imagery/i.landsat.toar/main.c:64
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
msgstr ""
#: ../imagery/i.landsat.toar/main.c:65
-msgid ""
-"imagery, landsat, top-of-atmosphere reflectance, dos-type simple atmospheric "
-"correction"
+msgid "imagery, landsat, top-of-atmosphere reflectance, dos-type simple atmospheric correction"
msgstr ""
#: ../imagery/i.landsat.toar/main.c:77
@@ -15789,19 +16084,20 @@
msgid "Spacecraft sensor"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:92 ../imagery/i.landsat.toar/main.c:122
-#: ../imagery/i.landsat.toar/main.c:130 ../imagery/i.landsat.toar/main.c:139
+#: ../imagery/i.landsat.toar/main.c:92
+#: ../imagery/i.landsat.toar/main.c:122
+#: ../imagery/i.landsat.toar/main.c:130
+#: ../imagery/i.landsat.toar/main.c:139
#: ../imagery/i.landsat.toar/main.c:147
msgid "Required only if 'metfile' not given"
msgstr ""
#: ../imagery/i.landsat.toar/main.c:95
-msgid ""
-"mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;mss4;Landsat-4 MSS;"
-"mss5;Landsat-5 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
+msgid "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;mss4;Landsat-4 MSS;mss5;Landsat-5 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:111 ../imagery/i.landsat.toar/main.c:112
+#: ../imagery/i.landsat.toar/main.c:111
+#: ../imagery/i.landsat.toar/main.c:112
#, fuzzy
msgid "Atmospheric correction method"
@@ -15839,7 +16135,8 @@
msgid "Output at-sensor radiance for all bands"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:200 ../imagery/i.landsat.toar/main.c:212
+#: ../imagery/i.landsat.toar/main.c:200
+#: ../imagery/i.landsat.toar/main.c:212
#, fuzzy, c-format
msgid "Illegal date format: [%s] (yyyy-mm-dd)"
msgstr "valeur illégale pour null"
@@ -15892,7 +16189,8 @@
msgid "reflectance"
msgstr "Résolution"
-#: ../imagery/i.class/signature.c:50 ../imagery/i.class/signature.c:55
+#: ../imagery/i.class/signature.c:50
+#: ../imagery/i.class/signature.c:55
msgid "Unable to allocate space for signature statistics."
msgstr "Impossible d'allouer de l'espace pour les statistiques de signature"
@@ -15903,8 +16201,7 @@
#: ../imagery/i.class/signature.c:113
#, c-format
msgid "prepare_signature: scan line %d has odd number of points."
-msgstr ""
-"prepare_signature : la ligne de scan %d a un nombre de points aberrant."
+msgstr "prepare_signature : la ligne de scan %d a un nombre de points aberrant."
#: ../imagery/i.class/signature.c:123
msgid "signature: perimeter points out of order."
@@ -15924,8 +16221,7 @@
#: ../imagery/i.class/signature.c:278
msgid "Unable to allocate the cell buffer in display_signature()."
-msgstr ""
-"Impossible d'allouer la mémoire tampon des cellules dans display_signature()."
+msgstr "Impossible d'allouer la mémoire tampon des cellules dans display_signature()."
#: ../imagery/i.class/signature.c:310
msgid "Did not find input cell map MASK."
@@ -15938,8 +16234,7 @@
#: ../imagery/i.class/add_point.c:22
#, c-format
msgid "Can't mark another point. Only %d points allowed. Sorry."
-msgstr ""
-"Impossible d'ajouter un autre point. Seulement %d points permis. Désolé."
+msgstr "Impossible d'ajouter un autre point. Seulement %d points permis. Désolé."
#: ../imagery/i.class/draw_reg.c:89
#, c-format
@@ -15993,28 +16288,22 @@
#: ../imagery/i.class/main.c:55
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
msgstr ""
#: ../imagery/i.class/main.c:58
#, fuzzy
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
-msgstr ""
-"Une fonction de traitement d'images qui génère des signatures spectrales "
-"pour une image en permettant à l'utilisateur de sélectionner des zones "
-"d'intérêt. Le fichier de signatures en sortie peut être utilisé en entrée de "
-"i.maxlik ou comme fichier germe pour i.cluster."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
+msgstr "Une fonction de traitement d'images qui génère des signatures spectrales pour une image en permettant à l'utilisateur de sélectionner des zones d'intérêt. Le fichier de signatures en sortie peut être utilisé en entrée de i.maxlik ou comme fichier germe pour i.cluster."
-#: ../imagery/i.class/main.c:62 ../display/d.rast/main.c:57
+#: ../imagery/i.class/main.c:62
+#: ../display/d.rast/main.c:57
#, fuzzy
msgid "Name of raster map to be displayed"
msgstr "Nom de la couche raster d'aspect à afficher"
-#: ../imagery/i.class/main.c:72 ../imagery/i.cca/main.c:93
+#: ../imagery/i.class/main.c:72
+#: ../imagery/i.cca/main.c:93
#, fuzzy
msgid "Name of input imagery subgroup"
msgstr "Nom du sous-groupe d'images"
@@ -16036,7 +16325,8 @@
"\n"
"Attention, un masque est actif."
-#: ../imagery/i.class/main.c:103 ../imagery/i.group/main.c:110
+#: ../imagery/i.class/main.c:103
+#: ../imagery/i.group/main.c:110
#: ../imagery/i.target/main.c:79
#, fuzzy
msgid "Group must exist in the current mapset"
@@ -16054,7 +16344,8 @@
msgid "Subgroup [%s] does not have any files"
msgstr "Le sous-groupe [%s] ne contient aucun fichier"
-#: ../imagery/i.class/main.c:223 ../imagery/i.class/main.c:227
+#: ../imagery/i.class/main.c:223
+#: ../imagery/i.class/main.c:227
#, fuzzy
msgid "The subgroup must have at least 2 files to run"
msgstr "Le sous-groupe doit avoir au moins 2 fichiers pour pouvoir exécuter %s"
@@ -16067,8 +16358,7 @@
#: ../imagery/i.class/main.c:232
#, fuzzy
msgid "Unable to read cell header for first band file"
-msgstr ""
-"Impossible de lire l'en-tête de cellule pour le fichier de première bande"
+msgstr "Impossible de lire l'en-tête de cellule pour le fichier de première bande"
#: ../imagery/i.class/main.c:237
msgid ""
@@ -16125,8 +16415,7 @@
#: ../imagery/i.class/complete_reg.c:12
msgid "Too few points for region. Must have at least 3 points."
-msgstr ""
-"Trop peu de points pour cette région. Vous devez entrer au moins 3 points."
+msgstr "Trop peu de points pour cette région. Vous devez entrer au moins 3 points."
#: ../imagery/i.class/complete_reg.c:14
msgid "Area already completed."
@@ -16136,7 +16425,8 @@
msgid "Can not erase an undefined region."
msgstr "Impossible d'effacer une région non définie"
-#: ../imagery/i.group/main.c:52 ../imagery/i.target/main.c:45
+#: ../imagery/i.group/main.c:52
+#: ../imagery/i.target/main.c:45
msgid "imagery, map management"
msgstr ""
@@ -16173,7 +16463,8 @@
msgid "List files from specified (sub)group (shell script style)"
msgstr "Liste les fichiers du (sous)-groupe spécifié"
-#: ../imagery/i.group/main.c:120 ../imagery/i.group/main.c:141
+#: ../imagery/i.group/main.c:120
+#: ../imagery/i.group/main.c:141
#, fuzzy
msgid "Specified group does not exist in current mapset"
msgstr "Le groupe spécifié n'existe pas... Sortie."
@@ -16193,7 +16484,8 @@
msgid "Group <%s> does not yet exist. Creating..."
msgstr "Le groupe [%s] - n'existe pas encore. Création..."
-#: ../imagery/i.group/main.c:168 ../imagery/i.group/main.c:177
+#: ../imagery/i.group/main.c:168
+#: ../imagery/i.group/main.c:177
#, fuzzy, c-format
msgid "Adding raster maps to group <%s>..."
msgstr "Lecteur du fichier raster..."
@@ -16233,7 +16525,8 @@
msgid "Removing raster map <%s> from group"
msgstr "fichier de cellules elevin <%s> non trouvé"
-#: ../imagery/i.group/main.c:315 ../imagery/i.group/main.c:374
+#: ../imagery/i.group/main.c:315
+#: ../imagery/i.group/main.c:374
#, fuzzy
msgid "No raster map removed"
msgstr "Couche raster 3D à supprimer"
@@ -16277,69 +16570,76 @@
msgid "Generates statistics for i.maxlik from raster map."
msgstr "Génère des statistiques pour i.maxlik à partir d'une couche raster"
-#: ../imagery/i.gensig/get_train.c:28 ../imagery/i.gensigset/get_train.c:32
+#: ../imagery/i.gensig/get_train.c:28
+#: ../imagery/i.gensigset/get_train.c:32
#, fuzzy
msgid "Finding training classes..."
msgstr "Recherche des classes d'apprentissage..."
-#: ../imagery/i.gensig/get_train.c:53 ../imagery/i.gensigset/get_train.c:57
+#: ../imagery/i.gensig/get_train.c:53
+#: ../imagery/i.gensigset/get_train.c:57
#, fuzzy, c-format
msgid "Training class %d only has one cell - this class will be ignored"
-msgstr ""
-"La classe d'apprentissage [%d] n'a qu'une cellule - cette classe sera "
-"ignorée."
+msgstr "La classe d'apprentissage [%d] n'a qu'une cellule - cette classe sera ignorée."
-#: ../imagery/i.gensig/get_train.c:58 ../imagery/i.gensigset/get_train.c:62
+#: ../imagery/i.gensig/get_train.c:58
+#: ../imagery/i.gensigset/get_train.c:62
#, fuzzy
msgid "Training map has no classes"
msgstr "La couche d'apprentissage n'a pas de classes."
-#: ../imagery/i.gensig/get_train.c:73 ../imagery/i.gensigset/get_train.c:78
+#: ../imagery/i.gensig/get_train.c:73
+#: ../imagery/i.gensigset/get_train.c:78
#, fuzzy
msgid "1 class found"
msgstr "1 classe."
-#: ../imagery/i.gensig/get_train.c:75 ../imagery/i.gensigset/get_train.c:80
+#: ../imagery/i.gensig/get_train.c:75
+#: ../imagery/i.gensigset/get_train.c:80
#, fuzzy, c-format
msgid "%d classes found"
msgstr "%s : pas de données points trouvées"
-#: ../imagery/i.gensig/parse.c:14 ../imagery/i.gensigset/parse.c:13
+#: ../imagery/i.gensig/parse.c:14
+#: ../imagery/i.gensigset/parse.c:13
#, fuzzy
msgid "Ground truth training map"
msgstr "Couche d'apprentissage de vérité terrain"
-#: ../imagery/i.gensig/parse.c:22 ../imagery/i.gensigset/parse.c:21
+#: ../imagery/i.gensig/parse.c:22
+#: ../imagery/i.gensigset/parse.c:21
#: ../imagery/i.cluster/main.c:97
#, fuzzy
msgid "Name for output file containing result signatures"
msgstr "Nom pour un fichier de sortie contenant la matrice d'erreur et kappa"
# c-format
-#: ../imagery/i.gensig/write_sig.c:15 ../imagery/i.gensigset/write_sig.c:13
+#: ../imagery/i.gensig/write_sig.c:15
+#: ../imagery/i.gensigset/write_sig.c:13
#, fuzzy, c-format
msgid "Unable to create signature file <%s>"
msgstr "Impossible de créer le fichier de cellules pour [%s]"
-#: ../imagery/i.gensig/write_sig.c:18 ../imagery/i.gensigset/write_sig.c:16
+#: ../imagery/i.gensig/write_sig.c:18
+#: ../imagery/i.gensigset/write_sig.c:16
#, fuzzy
msgid "Writing signatures..."
msgstr "Écriture du fichier signature [%s]..."
-#: ../imagery/i.gensig/openfiles.c:20 ../imagery/i.gensigset/openfiles.c:19
+#: ../imagery/i.gensig/openfiles.c:20
+#: ../imagery/i.gensigset/openfiles.c:19
#, fuzzy, c-format
msgid "Subgroup <%s> in group <%s> contains no raster maps."
-#: ../imagery/i.his.rgb/h2rmain.c:45 ../imagery/i.rgb.his/r2hmain.c:45
+#: ../imagery/i.his.rgb/h2rmain.c:45
+#: ../imagery/i.rgb.his/r2hmain.c:45
#, fuzzy
msgid "imagery, color transformation, RGB, HIS"
msgstr "Affiche l'information topologique (déboguage)"
#: ../imagery/i.his.rgb/h2rmain.c:47
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
msgstr ""
#: ../imagery/i.his.rgb/h2rmain.c:53
@@ -16385,19 +16685,24 @@
"Nom de la couche raster de sortie"
# c-format
-#: ../imagery/i.his.rgb/h2rmain.c:95 ../imagery/i.rgb.his/r2hmain.c:93
+#: ../imagery/i.his.rgb/h2rmain.c:95
+#: ../imagery/i.rgb.his/r2hmain.c:93
#, fuzzy, c-format
msgid "Unable to read raster map row %ld"
-#: ../imagery/i.his.rgb/h2rmain.c:104 ../imagery/i.rgb.his/r2hmain.c:102
+#: ../imagery/i.his.rgb/h2rmain.c:104
+#: ../imagery/i.rgb.his/r2hmain.c:102
#, fuzzy, c-format
msgid "Failed writing raster map row %ld"
-#: ../imagery/i.his.rgb/openfiles.c:23 ../imagery/i.his.rgb/openfiles.c:25
-#: ../imagery/i.his.rgb/openfiles.c:27 ../imagery/i.rgb.his/openfiles.c:37
-#: ../imagery/i.rgb.his/openfiles.c:39 ../imagery/i.rgb.his/openfiles.c:41
+#: ../imagery/i.his.rgb/openfiles.c:23
+#: ../imagery/i.his.rgb/openfiles.c:25
+#: ../imagery/i.his.rgb/openfiles.c:27
+#: ../imagery/i.rgb.his/openfiles.c:37
+#: ../imagery/i.rgb.his/openfiles.c:39
+#: ../imagery/i.rgb.his/openfiles.c:41
#, fuzzy
msgid "Unable to allocate the input row buffer"
msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
@@ -16434,12 +16739,8 @@
#: ../imagery/i.rectify/main.c:92
#, fuzzy
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Recale une image en calculer la transformation de coordonnées pour chaque "
-"pixel de l'image basée sur des points d'amer"
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Recale une image en calculer la transformation de coordonnées pour chaque pixel de l'image basée sur des points d'amer"
#: ../imagery/i.rectify/main.c:106
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:100
@@ -16465,11 +16766,8 @@
#: ../imagery/i.rectify/main.c:141
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:134
#, fuzzy
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
-msgstr ""
-"Utiliser les paramètres de la région courante dans le Secteur en sortie (déf."
-"= calculer la plus petite surface)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
+msgstr "Utiliser les paramètres de la région courante dans le Secteur en sortie (déf.= calculer la plus petite surface)"
#: ../imagery/i.rectify/main.c:145
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:138
@@ -16560,7 +16858,8 @@
msgstr "FFT terminée..."
#: ../imagery/i.rectify/report.c:10
-#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:10 ../db/base/select.c:93
+#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:10
+#: ../db/base/select.c:93
#, fuzzy
msgid "failed"
@@ -16637,8 +16936,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:13
#, fuzzy, c-format
msgid "Target information for group <%s> missing"
-msgstr ""
-"Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
+msgstr "Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
#: ../imagery/i.rectify/target.c:20
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:19
@@ -16664,10 +16962,10 @@
#: ../imagery/i.target/main.c:67
msgid "Set current location and mapset as target for of imagery group"
-msgstr ""
-"Règle le Secteur courant et le jeu de donnée comme cible du groupe d'images"
+msgstr "Règle le Secteur courant et le jeu de donnée comme cible du groupe d'images"
-#: ../imagery/i.target/main.c:89 ../imagery/i.target/main.c:106
+#: ../imagery/i.target/main.c:89
+#: ../imagery/i.target/main.c:106
#: ../imagery/i.target/main.c:115
#, fuzzy, c-format
msgid "Group <%s> targeted for location [%s], mapset [%s]"
@@ -16685,20 +16983,18 @@
" OR\n"
" manually enter the variables"
msgstr ""
-"Vous devez utiliser le drapeau pour utiliser le jeu de données et le Secteur "
-"courants(-c)\n"
+"Vous devez utiliser le drapeau pour utiliser le jeu de données et le Secteur courants(-c)\n"
" OU\n"
" entrer les variables à la main."
-#: ../imagery/i.vpoints/plot.c:61 ../imagery/i.vpoints/plot.c:143
+#: ../imagery/i.vpoints/plot.c:61
+#: ../imagery/i.vpoints/plot.c:143
#: ../display/d.graph/do_graph.c:415
msgid "Cannot read symbol, cannot display points"
msgstr "Impossible de lire le symbole, impossible d'afficher les points"
#: ../imagery/i.vpoints/main.c:96
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
msgstr ""
#: ../imagery/i.topo.corr/correction.c:100
@@ -16775,7 +17071,8 @@
msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
msgstr "fichier de cellules albedo <%s> non trouvé"
-#: ../imagery/i.ifft/ifftmain.c:68 ../imagery/i.fft/fftmain.c:74
+#: ../imagery/i.ifft/ifftmain.c:68
+#: ../imagery/i.fft/fftmain.c:74
#, fuzzy
msgid "imagery, FFT"
msgstr "groupes d'images"
@@ -16797,21 +17094,16 @@
#: ../imagery/i.ifft/ifftmain.c:101
#, fuzzy
-msgid ""
-"Unable to open real-image in the 'cell_misc' directory. Raster map probably "
-"wasn't created by i.fft"
+msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
msgstr ""
"Impossible d'ouvrir l'image (partie réelle) dans le répertoire cell_misc.\n"
"La couche en entrée n'a pas été créée par i.fft"
#: ../imagery/i.ifft/ifftmain.c:111
#, fuzzy
-msgid ""
-"Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
-"probably wasn't created by i.fft"
+msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
msgstr ""
-"Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire "
-"cell_misc.\n"
+"Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire cell_misc.\n"
#: ../imagery/i.ifft/ifftmain.c:134
@@ -16819,7 +17111,8 @@
msgid "Power 2 values: %d rows %d columns"
msgstr "2 valeurs : [%d] lignes [%d] colonnes."
-#: ../imagery/i.ifft/ifftmain.c:144 ../imagery/i.gensigset/read_data.c:19
+#: ../imagery/i.ifft/ifftmain.c:144
+#: ../imagery/i.gensigset/read_data.c:19
#: ../imagery/i.cluster/main.c:285
#, fuzzy
msgid "Reading raster maps..."
@@ -16830,7 +17123,8 @@
msgid "Masking raster maps..."
msgstr "Masquer les couches rasters..."
-#: ../imagery/i.ifft/ifftmain.c:172 ../imagery/i.fft/fftmain.c:201
+#: ../imagery/i.ifft/ifftmain.c:172
+#: ../imagery/i.fft/fftmain.c:201
msgid "Rotating data..."
msgstr "Rotation des données ... "
@@ -16868,9 +17162,7 @@
#: ../imagery/i.fft/fftmain.c:115
msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-"MASK raster trouvé, penser à le supprimer (voir la page du manuel). "
-"Poursuite..."
+msgstr "MASK raster trouvé, penser à le supprimer (voir la page du manuel). Poursuite..."
#: ../imagery/i.fft/fftmain.c:129
#, fuzzy
@@ -16894,15 +17186,14 @@
#: ../imagery/i.fft/fftmain.c:231
#, fuzzy
msgid "Writing viewable versions of transformed data..."
-msgstr ""
-"Ecriture des versions visualisables des données transformées dans les "
-"fichiers..."
+msgstr "Ecriture des versions visualisables des données transformées dans les fichiers..."
#: ../imagery/i.fft/fftmain.c:274
msgid " "
msgstr ""
-#: ../imagery/i.fft/save_fft.c:17 ../imagery/i.fft/save_fft.c:22
+#: ../imagery/i.fft/save_fft.c:17
+#: ../imagery/i.fft/save_fft.c:22
#, fuzzy
msgid "Unable to open file in the 'cell_misc' directory"
msgstr "Impossible d'ouvrir le fichier dans le répertoire cell_misc"
@@ -16937,10 +17228,7 @@
msgstr "Nom de la couche source"
#: ../imagery/i.modis.qc/main.c:110
-msgid ""
-"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
-"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
-"LST 1Km 8-days (Day/Night);"
+msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
msgstr ""
#: ../imagery/i.modis.qc/main.c:122
@@ -16949,27 +17237,7 @@
msgstr "Nom de la couche raster plane à créer."
#: ../imagery/i.modis.qc/main.c:123
-msgid ""
-"adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
-"cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
-"diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
-"modland_qa_bits;mod09: MODIS Land General Quality Assessment;"
-"mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
-"data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;"
-"mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average "
-"LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality "
-"Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;"
-"mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;"
-"lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: "
-"StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA "
-"Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;"
-"cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09A1s: "
-"StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA "
-"Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow "
-"Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;"
-"mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA "
-"Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
-"Mask;"
+msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09
A1s: StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
msgstr ""
#: ../imagery/i.modis.qc/main.c:157
@@ -16977,10 +17245,7 @@
msgstr ""
#: ../imagery/i.modis.qc/main.c:158
-msgid ""
-"1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;"
-"mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;"
-"mod09A1 Band 7: SWIR 3;"
+msgid "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
msgstr ""
#: ../imagery/i.modis.qc/main.c:181
@@ -17080,8 +17345,7 @@
#: ../imagery/i.cca/main.c:86
msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
-"Programme de traitement d'image en analyse en composante canonique (cca)"
+msgstr "Programme de traitement d'image en analyse en composante canonique (cca)"
#: ../imagery/i.cca/main.c:99
#, fuzzy
@@ -17126,8 +17390,7 @@
#: ../imagery/i.cca/main.c:140
msgid "Need at least two signatures in signature file."
-msgstr ""
-"Il faut au moins deux signatures dans le fichier de signatures spectrales."
+msgstr "Il faut au moins deux signatures dans le fichier de signatures spectrales."
#: ../imagery/i.cca/main.c:145
#, c-format
@@ -17141,9 +17404,7 @@
#: ../imagery/i.cca/main.c:207
#, fuzzy, c-format
msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-msgstr ""
-"La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle "
-"0-255.\n"
+msgstr "La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle 0-255.\n"
#: ../imagery/i.cca/transform.c:18
msgid "Unable to allocate cell buffers."
@@ -17299,21 +17560,13 @@
#: ../imagery/i.cluster/main.c:82
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
msgstr ""
#: ../imagery/i.cluster/main.c:85
#, fuzzy
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-"Fonction de traitement d'image qui génère des signatures spectrales pour les "
-"types de couverture du sol dans une image en utilisant un algorithme à "
-"cluster. Le fichier de signature résultat est utilisé en entrée pour i."
-"maxlik, pour générer une classification d'image non-supervisée."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr "Fonction de traitement d'image qui génère des signatures spectrales pour les types de couverture du sol dans une image en utilisant un algorithme à cluster. Le fichier de signature résultat est utilisé en entrée pour i.maxlik, pour générer une classification d'image non-supervisée."
#: ../imagery/i.cluster/main.c:104
msgid "Initial number of classes"
@@ -17326,9 +17579,7 @@
#: ../imagery/i.cluster/main.c:120
msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr ""
-"Intervalle d'échantillonnage (par ligne et colonne); par défaut: ~10,000 "
-"pixels"
+msgstr "Intervalle d'échantillonnage (par ligne et colonne); par défaut: ~10,000 pixels"
#: ../imagery/i.cluster/main.c:127
msgid "Maximum number of iterations"
@@ -17523,8 +17774,7 @@
#: ../imagery/i.cluster/main.c:297
#, fuzzy
msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr ""
-"Mémoire insuffisante. Rééxécuter en choisissant un échantillon plus petit."
+msgstr "Mémoire insuffisante. Rééxécuter en choisissant un échantillon plus petit."
#: ../imagery/i.cluster/main.c:303
#, c-format
@@ -17533,19 +17783,13 @@
#: ../imagery/i.cluster/main.c:306
#, fuzzy
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-"Points échantillonnées insuffisants. Rééxécuter en choisissant un plus large "
-"échantillon."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr "Points échantillonnées insuffisants. Rééxécuter en choisissant un plus large échantillon."
#: ../imagery/i.cluster/main.c:310
#, fuzzy
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-"Echantillon insuffisant de points de données non-nuls. Vérifiez votre région "
-"courante (et le masque appliqué)"
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr "Echantillon insuffisant de points de données non-nuls. Vérifiez votre région courante (et le masque appliqué)"
#: ../imagery/i.cluster/main.c:323
#, c-format
@@ -17564,9 +17808,7 @@
#: ../imagery/i.cluster/main.c:335
#, fuzzy, c-format
msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr ""
-"Impossible d'écrire le fichier de signature <%s> pour le groupe <%s>, sous-"
-"groupe <%s>"
+msgstr "Impossible d'écrire le fichier de signature <%s> pour le groupe <%s>, sous-groupe <%s>"
#: ../imagery/i.cluster/main.c:340
#, c-format
@@ -17649,8 +17891,7 @@
#: ../imagery/i.pca/main.c:67
#, fuzzy
msgid "Principal components analysis (PCA) for image processing."
-msgstr ""
#: ../imagery/i.pca/main.c:72
#, fuzzy
@@ -17717,9 +17958,7 @@
msgstr "Calcul des moyennes de classes..."
#: ../imagery/i.rgb.his/r2hmain.c:47
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
msgstr ""
#: ../imagery/i.rgb.his/r2hmain.c:53
@@ -17795,9 +18034,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:88
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
msgstr ""
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:129
@@ -17913,8 +18150,7 @@
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:91
#, fuzzy, c-format
msgid "Target information for group [%s] missing\n"
-msgstr ""
# c-format
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:98
@@ -18096,9 +18332,7 @@
msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
#: ../imagery/i.ortho.photo/i.photo.init/main.c:46
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
msgstr ""
#: ../imagery/i.ortho.photo/i.photo.init/main.c:64
@@ -18110,8 +18344,7 @@
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:54
#, fuzzy
msgid "Creates control points on an image to be ortho-rectified."
-msgstr ""
-"Placer des points de contrôle sur une image pour le recalage de l'orthophoto."
+msgstr "Placer des points de contrôle sur une image pour le recalage de l'orthophoto."
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:66
#, fuzzy
@@ -18120,10 +18353,8 @@
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:72
#, fuzzy
-msgid ""
-"Name of a map from target mapset which will be initially drawn on screen"
-msgstr ""
-"Nom de la couche de données du jeu de données cible à afficher à l'écran."
+msgid "Name of a map from target mapset which will be initially drawn on screen"
+msgstr "Nom de la couche de données du jeu de données cible à afficher à l'écran."
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:114
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:98
@@ -18180,8 +18411,7 @@
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:57
#, fuzzy
-msgid ""
-"Interactively select and modify the imagery group camera reference file."
+msgid "Interactively select and modify the imagery group camera reference file."
msgstr "Sélectionner de façon interactive l'itinéraire"
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:68
@@ -18199,7 +18429,8 @@
msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-#: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_colortable.c:61
+#: ../ps/ps.map/r_info.c:48
+#: ../ps/ps.map/r_colortable.c:61
#: ../ps/ps.map/r_vlegend.c:49
#, fuzzy
msgid "illegal where request"
@@ -18219,7 +18450,8 @@
msgid "illegal bgcolor request"
msgstr ""
-#: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
+#: ../ps/ps.map/r_info.c:93
+#: ../ps/ps.map/r_vlegend.c:86
#, fuzzy
msgid "illegal border color request"
msgstr "Couleur de bord d'étiquette"
@@ -18228,25 +18460,32 @@
msgid "illegal mapinfo sub-request"
msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:71 ../ps/ps.map/ps_vareas.c:163
+#: ../ps/ps.map/ps_vpoints.c:71
+#: ../ps/ps.map/ps_vareas.c:163
#: ../ps/ps.map/ps_vlines.c:55
#, fuzzy
msgid "Cannot load data from table"
msgstr "Impossible de sélectionner des données dans la table"
-#: ../ps/ps.map/ps_vpoints.c:87 ../ps/ps.map/do_plt.c:147
+#: ../ps/ps.map/ps_vpoints.c:87
+#: ../ps/ps.map/do_plt.c:147
msgid "Cannot read symbol, using default icon"
msgstr "Impossible de lire le symbole, utilisation de l'icone par défaut"
-#: ../ps/ps.map/ps_vpoints.c:127 ../ps/ps.map/ps_vareas.c:66
-#: ../ps/ps.map/ps_vareas.c:77 ../ps/ps.map/ps_vlines.c:83
+#: ../ps/ps.map/ps_vpoints.c:127
+#: ../ps/ps.map/ps_vareas.c:66
+#: ../ps/ps.map/ps_vareas.c:77
+#: ../ps/ps.map/ps_vlines.c:83
msgid "Read error in vector map"
msgstr "Erreur de lecture sur le fichier vecteur en sortie"
# c-format
-#: ../ps/ps.map/ps_vpoints.c:164 ../ps/ps.map/ps_vpoints.c:175
-#: ../ps/ps.map/ps_vpoints.c:199 ../ps/ps.map/ps_vpoints.c:240
-#: ../ps/ps.map/ps_vpoints.c:250 ../ps/ps.map/ps_vareas.c:101
+#: ../ps/ps.map/ps_vpoints.c:164
+#: ../ps/ps.map/ps_vpoints.c:175
+#: ../ps/ps.map/ps_vpoints.c:199
+#: ../ps/ps.map/ps_vpoints.c:240
+#: ../ps/ps.map/ps_vpoints.c:250
+#: ../ps/ps.map/ps_vareas.c:101
#: ../ps/ps.map/ps_vlines.c:118
#, fuzzy, c-format
msgid "No record for category [%d]"
@@ -18257,24 +18496,25 @@
msgid "Attribute is of invalid size [%.3f] for category [%d]"
msgstr "L'attribut est de taille invalide (%.3f) pour la catégorie %d"
-#: ../ps/ps.map/ps_vpoints.c:205 ../ps/ps.map/ps_vareas.c:107
+#: ../ps/ps.map/ps_vpoints.c:205
+#: ../ps/ps.map/ps_vareas.c:107
#: ../ps/ps.map/ps_vlines.c:124
#, fuzzy, c-format
msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), entité surfacique %d "
-"avec la catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d"
-#: ../ps/ps.map/catval.c:49 ../ps/ps.map/catval.c:111
-#: ../ps/ps.map/catval.c:177 ../vector/v.label/main.c:278
-#: ../vector/v.buffer/main.c:383 ../vector/v.class/main.c:105
-#: ../vector/v.vol.rst/user1.c:93 ../vector/v.to.rast3/main.c:82
+#: ../ps/ps.map/catval.c:49
+#: ../ps/ps.map/catval.c:111
+#: ../ps/ps.map/catval.c:177
+#: ../vector/v.label/main.c:278
+#: ../vector/v.buffer/main.c:383
+#: ../vector/v.class/main.c:105
+#: ../vector/v.vol.rst/user1.c:93
+#: ../vector/v.to.rast3/main.c:82
#: ../vector/v.label.sa/labels.c:80
#, fuzzy
msgid "Unable to get layer info for vector map"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
# c-format
#: ../ps/ps.map/catval.c:64
@@ -18282,11 +18522,16 @@
msgid "Column type not supported (must be string)"
msgstr "Type de colonne (%s) non géré"
-#: ../ps/ps.map/catval.c:67 ../ps/ps.map/catval.c:132
-#: ../ps/ps.map/catval.c:199 ../vector/v.univar/main.c:331
-#: ../vector/v.sample/main.c:185 ../vector/v.buffer/main.c:397
-#: ../vector/lidar/v.surf.bspline/main.c:348 ../vector/v.normal/main.c:154
-#: ../vector/v.class/main.c:126 ../vector/v.to.rast3/main.c:96
+#: ../ps/ps.map/catval.c:67
+#: ../ps/ps.map/catval.c:132
+#: ../ps/ps.map/catval.c:199
+#: ../vector/v.univar/main.c:331
+#: ../vector/v.sample/main.c:185
+#: ../vector/v.buffer/main.c:397
+#: ../vector/lidar/v.surf.bspline/main.c:348
+#: ../vector/v.normal/main.c:154
+#: ../vector/v.class/main.c:126
+#: ../vector/v.to.rast3/main.c:96
#: ../vector/v.surf.idw/read_sites.c:52
#, fuzzy
msgid "Unable to select data from table"
@@ -18325,9 +18570,7 @@
#: ../ps/ps.map/r_vpoints.c:244
#, c-format
-msgid ""
-"The mapping instruction <%s> will be renamed to <%s> in future versions of "
-"GRASS. Please use <%s> instead."
+msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
msgstr ""
#: ../ps/ps.map/ps_outline.c:41
@@ -18381,7 +18624,8 @@
msgid "No raster selected for colortable!"
msgstr "%d enregistrements sélectionnés dans le tableau"
-#: ../ps/ps.map/ps_fclrtbl.c:46 ../ps/ps.map/ps_clrtbl.c:35
+#: ../ps/ps.map/ps_fclrtbl.c:46
+#: ../ps/ps.map/ps_clrtbl.c:35
#, fuzzy, c-format
msgid "Creating color table for <%s in %s>..."
msgstr "Création des fichiers support pour %s..."
@@ -18394,27 +18638,24 @@
#: ../ps/ps.map/ps_fclrtbl.c:64
#, fuzzy
msgid "A floating point colortable must contain a range of values"
-msgstr ""
-"Une table de couleurs en valeurs flottante doit contenir un ensemble de "
-"valeurs"
+msgstr "Une table de couleurs en valeurs flottante doit contenir un ensemble de valeurs"
-#: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
+#: ../ps/ps.map/ps_fclrtbl.c:69
+#: ../ps/ps.map/ps_clrtbl.c:44
msgid "Unable to read colors for colorbar"
msgstr "Impossible de lire les couleurs de la légende couleur"
-#: ../ps/ps.map/ps_fclrtbl.c:92 ../ps/ps.map/ps_fclrtbl.c:97
+#: ../ps/ps.map/ps_fclrtbl.c:92
+#: ../ps/ps.map/ps_fclrtbl.c:97
#: ../ps/ps.map/ps_clrtbl.c:69
msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Emplacement vertical (y) de la légende couleur en dehors des limites de la "
-"page. Ajustement automatique."
+msgstr "Emplacement vertical (y) de la légende couleur en dehors des limites de la page. Ajustement automatique."
-#: ../ps/ps.map/ps_fclrtbl.c:103 ../ps/ps.map/ps_fclrtbl.c:108
+#: ../ps/ps.map/ps_fclrtbl.c:103
+#: ../ps/ps.map/ps_fclrtbl.c:108
#: ../ps/ps.map/ps_clrtbl.c:75
msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Emplacement horizontal (x) de la légende couleur en dehors des limites de la "
+msgstr "Emplacement horizontal (x) de la légende couleur en dehors des limites de la page. Ajustement automatique."
# c-format
#: ../ps/ps.map/r_plt.c:158
@@ -18441,8 +18682,7 @@
#: ../ps/ps.map/do_labels.c:43
#, c-format
msgid "Can't open label file <%s> in mapset <%s>"
-msgstr ""
-"impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
+msgstr "impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
# c-format
#: ../ps/ps.map/do_labels.c:47
@@ -18463,9 +18703,7 @@
#: ../ps/ps.map/do_labels.c:161
msgid "Text labels: 'fontsize' given so ignoring 'size'"
-msgstr ""
-"Etiquettes texte : 'fontsize' (taille de police) spécifiée, on ignore donc "
-"le paramètre 'size'"
+msgstr "Etiquettes texte : 'fontsize' (taille de police) spécifiée, on ignore donc le paramètre 'size'"
#: ../ps/ps.map/main.c:100
msgid "postscript, map, printing"
@@ -18483,27 +18721,19 @@
#: ../ps/ps.map/main.c:110
#, fuzzy
msgid "List paper formats ( name width height left right top bottom(margin) )"
-msgstr ""
-"Afficher le format papier (nom largeur hauteur gauche droite haut bas "
-"(marges) )"
+msgstr "Afficher le format papier (nom largeur hauteur gauche droite haut bas (marges) )"
#: ../ps/ps.map/main.c:115
msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr ""
-"Créer un EPS (Encapsulated PostScript) à la place du fichier PostScript"
+msgstr "Créer un EPS (Encapsulated PostScript) à la place du fichier PostScript"
#: ../ps/ps.map/main.c:120
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
msgstr ""
#: ../ps/ps.map/main.c:126
-msgid ""
-"File containing mapping instructions (or use input=- to enter from keyboard)"
-msgstr ""
-"Fichier contenant les instructions de mise en page cartographique (ou "
-"utilisez input=- pour les saisir à partir du clavier)"
+msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
+msgstr "Fichier contenant les instructions de mise en page cartographique (ou utilisez input=- pour les saisir à partir du clavier)"
#: ../ps/ps.map/main.c:134
msgid "PostScript output file"
@@ -18511,9 +18741,7 @@
#: ../ps/ps.map/main.c:142
msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-msgstr ""
-"Echelle de la carte en sortie, par exemple 1:25000 (par défaut, ajusté à la "
-"page)"
+msgstr "Echelle de la carte en sortie, par exemple 1:25000 (par défaut, ajusté à la page)"
#: ../ps/ps.map/main.c:148
msgid "Number of copies to print"
@@ -18521,13 +18749,8 @@
#: ../ps/ps.map/main.c:241
#, fuzzy, c-format
-msgid ""
-"Using <%s> from the command line is depreciated. Please use the <%s> mapping "
-"instruction instead. The parameter <%s> will be removed in future versions "
-"of GRASS."
-msgstr ""
-"Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez "
-"l'instruction de mise en page cartographique \"scale\" à la place."
+msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
+msgstr "Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez l'instruction de mise en page cartographique \"scale\" à la place."
#: ../ps/ps.map/main.c:267
#, fuzzy, c-format
@@ -18545,10 +18768,7 @@
msgstr "Des données existent au-delà de l'instruction finale 'end'!"
#: ../ps/ps.map/main.c:324
-msgid ""
-"GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping "
-"instruction. This mapping instruction is superseded and will be removed in "
-"future versions of GRASS. Please use --verbose instead."
+msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
msgstr ""
#: ../ps/ps.map/main.c:331
@@ -18593,7 +18813,8 @@
msgid "Bounding box in eps file <%s> was not found"
msgstr "fichier 3dview <%s> non trouvé"
-#: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:168
+#: ../ps/ps.map/ps_clrtbl.c:39
+#: ../display/d.histogram/main.c:168
#: ../display/d.legend/main.c:269
#, fuzzy, c-format
msgid "Category file for <%s> not available"
@@ -18601,15 +18822,8 @@
#: ../ps/ps.map/ps_clrtbl.c:54
#, fuzzy
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
-msgstr ""
-"Votre fichier cats/ est invalide. Un fichier cats/ avec catégories et "
-"étiquettes est requis pour la table de couleurs en utilisant les rasters "
-"CELL. Aucune table de couleurs ne seraassignée au fichier postscript en "
-"sortie."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
+msgstr "Votre fichier cats/ est invalide. Un fichier cats/ avec catégories et étiquettes est requis pour la table de couleurs en utilisant les rasters CELL. Aucune table de couleurs ne seraassignée au fichier postscript en sortie."
#: ../ps/ps.map/do_plt.c:41
#, fuzzy
@@ -18627,11 +18841,8 @@
msgstr "Afficher l'index"
#: ../display/d.paint.labels/main.c:48
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
-msgstr ""
-"Affiche des étiquettes de texte (créées avec v.label) dans le moniteur actif"
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
+msgstr "Affiche des étiquettes de texte (créées avec v.label) dans le moniteur actif"
#: ../display/d.paint.labels/main.c:54
msgid "Ignore rotation setting and draw horizontally"
@@ -18643,13 +18854,11 @@
#: ../display/d.paint.labels/main.c:68
msgid "Minimum region size (diagonal) when labels are displayed"
-msgstr ""
-"Taille minimum de la région (diagonale) quand les étiquettes sont affichées"
+msgstr "Taille minimum de la région (diagonale) quand les étiquettes sont affichées"
#: ../display/d.paint.labels/main.c:75
msgid "Maximum region size (diagonal) when labels are displayed"
-msgstr ""
-"Taille maximum de la région (diagonale) quand les étiquettes sont affichées"
+msgstr "Taille maximum de la région (diagonale) quand les étiquettes sont affichées"
# c-format
#: ../display/d.paint.labels/main.c:87
@@ -18657,63 +18866,85 @@
msgid "Label file <%s> not found"
msgstr "Fichier raster <%s> non trouvé"
-#: ../display/d.paint.labels/main.c:102 ../display/d.vect/main.c:387
+#: ../display/d.paint.labels/main.c:102
+#: ../display/d.vect/main.c:387
msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-"La taille de la région est plus petite que minreg, rien n'a été affiché."
+msgstr "La taille de la région est plus petite que minreg, rien n'a été affiché."
-#: ../display/d.paint.labels/main.c:111 ../display/d.vect/main.c:396
+#: ../display/d.paint.labels/main.c:111
+#: ../display/d.vect/main.c:396
msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-"La taille de la région est plus grande que maxreg, rien n'a été affiché."
+msgstr "La taille de la région est plus grande que maxreg, rien n'a été affiché."
# c-format
-#: ../display/d.paint.labels/main.c:121 ../vector/v.lrs/v.lrs.label/main.c:299
+#: ../display/d.paint.labels/main.c:121
+#: ../vector/v.lrs/v.lrs.label/main.c:299
#, fuzzy, c-format
msgid "Unable to open label file <%s>"
msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#: ../display/d.paint.labels/main.c:124 ../display/d.text/main.c:152
-#: ../display/d.info/main.c:103 ../display/d.info/main.c:129
-#: ../display/d.barscale/main.c:137 ../display/d.rast.num/number.c:166
-#: ../display/d.text.freetype/main.c:316 ../display/d.text.new/main.c:309
-#: ../display/d.graph/main.c:119 ../display/d.rast.arrow/arrow.c:248
+#: ../display/d.paint.labels/main.c:124
+#: ../display/d.text/main.c:152
+#: ../display/d.info/main.c:103
+#: ../display/d.info/main.c:129
+#: ../display/d.barscale/main.c:137
+#: ../display/d.rast.num/number.c:166
+#: ../display/d.text.freetype/main.c:316
+#: ../display/d.text.new/main.c:309
+#: ../display/d.graph/main.c:119
+#: ../display/d.rast.arrow/arrow.c:248
#: ../display/d.legend/main.c:277
msgid "No current window"
msgstr "Pas de fenêtre active"
-#: ../display/d.paint.labels/main.c:127 ../display/d.text/main.c:155
-#: ../display/d.info/main.c:105 ../display/d.info/main.c:131
-#: ../display/d.barscale/main.c:140 ../display/d.rast.num/number.c:169
-#: ../display/d.text.freetype/main.c:318 ../display/d.text.new/main.c:312
-#: ../display/d.graph/main.c:122 ../display/d.rast.arrow/arrow.c:251
+#: ../display/d.paint.labels/main.c:127
+#: ../display/d.text/main.c:155
+#: ../display/d.info/main.c:105
+#: ../display/d.info/main.c:131
+#: ../display/d.barscale/main.c:140
+#: ../display/d.rast.num/number.c:169
+#: ../display/d.text.freetype/main.c:318
+#: ../display/d.text.new/main.c:312
+#: ../display/d.graph/main.c:122
+#: ../display/d.rast.arrow/arrow.c:251
#: ../display/d.legend/main.c:280
msgid "Current window not available"
msgstr "Fenêtre courante non disponible"
-#: ../display/d.paint.labels/main.c:130 ../display/d.rast.edit/cell.c:35
-#: ../display/d.info/main.c:111 ../display/d.info/main.c:136
-#: ../display/d.barscale/main.c:156 ../display/d.rast.num/number.c:176
+#: ../display/d.paint.labels/main.c:130
+#: ../display/d.rast.edit/cell.c:35
+#: ../display/d.info/main.c:111
+#: ../display/d.info/main.c:136
+#: ../display/d.barscale/main.c:156
+#: ../display/d.rast.num/number.c:176
#: ../display/d.rast.arrow/arrow.c:257
msgid "Setting map window"
msgstr "Paramétrage de la fenêtre d'affichage de la couche"
-#: ../display/d.paint.labels/main.c:133 ../display/d.rast.edit/cell.c:38
-#: ../display/d.barscale/main.c:159 ../display/d.rast.num/number.c:179
+#: ../display/d.paint.labels/main.c:133
+#: ../display/d.rast.edit/cell.c:38
+#: ../display/d.barscale/main.c:159
+#: ../display/d.rast.num/number.c:179
#: ../display/d.rast.arrow/arrow.c:260
msgid "Current window not settable"
msgstr "Impossible de configurer la fenêtre actuelle"
-#: ../display/d.paint.labels/main.c:137 ../display/d.info/main.c:113
-#: ../display/d.info/main.c:138 ../display/d.barscale/main.c:163
-#: ../display/d.rast.num/number.c:184 ../display/d.graph/main.c:125
+#: ../display/d.paint.labels/main.c:137
+#: ../display/d.info/main.c:113
+#: ../display/d.info/main.c:138
+#: ../display/d.barscale/main.c:163
+#: ../display/d.rast.num/number.c:184
+#: ../display/d.graph/main.c:125
#: ../display/d.rast.arrow/arrow.c:264
msgid "Getting screen window"
msgstr "Récupération de la fenêtre"
-#: ../display/d.paint.labels/main.c:139 ../display/d.what.rast/main.c:137
-#: ../display/d.info/main.c:115 ../display/d.info/main.c:140
-#: ../display/d.barscale/main.c:165 ../display/d.rast.num/number.c:186
+#: ../display/d.paint.labels/main.c:139
+#: ../display/d.what.rast/main.c:137
+#: ../display/d.info/main.c:115
+#: ../display/d.info/main.c:140
+#: ../display/d.barscale/main.c:165
+#: ../display/d.rast.num/number.c:186
#: ../display/d.rast.arrow/arrow.c:266
msgid "Error in calculating conversions"
msgstr "Erreur dans le calcul de conversion"
@@ -18724,12 +18955,8 @@
msgstr "Statistiques de transition de classe."
#: ../display/d.histogram/main.c:73
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-"Affiche un histogramme sous forme de diagramme en barre ou d'un diagramme "
-"camembert pour un fichier raster spécifié par l'utilisateur."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+msgstr "Affiche un histogramme sous forme de diagramme en barre ou d'un diagramme camembert pour un fichier raster spécifié par l'utilisateur."
#: ../display/d.histogram/main.c:77
msgid "Raster map for which histogram will be displayed"
@@ -18737,8 +18964,7 @@
#: ../display/d.histogram/main.c:81
msgid "Indicate if a pie or bar chart is desired"
-msgstr ""
-"Indique si l'on a besoin d'un diagramme en barre ou d'un diagramme camembert"
+msgstr "Indique si l'on a besoin d'un diagramme en barre ou d'un diagramme camembert"
#: ../display/d.histogram/main.c:90
#, fuzzy
@@ -18751,9 +18977,7 @@
#: ../display/d.histogram/main.c:108
msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr ""
-"Nombre d'étapes pour la division des intervalles de données (couches en "
-"points flottants seulement)"
+msgstr "Nombre d'étapes pour la division des intervalles de données (couches en points flottants seulement)"
#: ../display/d.histogram/main.c:115
msgid "Display information for null cells"
@@ -18765,9 +18989,7 @@
#: ../display/d.histogram/main.c:124
msgid "Report for ranges defined in cats file (fp maps only)"
-msgstr ""
-"Examen des catégories en nombres à virgule flottante (couches en virgule "
-"flottante uniquement)"
+msgstr "Examen des catégories en nombres à virgule flottante (couches en virgule flottante uniquement)"
#: ../display/d.histogram/main.c:149
#, c-format
@@ -18778,13 +19000,14 @@
msgid "When -C flag is set, the nsteps argument is ignored"
msgstr "Quand le drapeau -C est fixé, l'argument nsteps est ignoré"
-#: ../display/d.histogram/main.c:171 ../display/d.legend/main.c:517
+#: ../display/d.histogram/main.c:171
+#: ../display/d.legend/main.c:517
#, fuzzy, c-format
msgid "Range information for <%s> not available"
-msgstr ""
-#: ../display/d.vect/dir.c:31 ../display/d.vect/attr.c:53
+#: ../display/d.vect/dir.c:31
+#: ../display/d.vect/attr.c:53
#: ../display/d.vect/label.c:28
#, fuzzy
msgid "Can't read vector map"
@@ -18796,7 +19019,8 @@
# c-format
-#: ../display/d.vect/attr.c:110 ../display/d.vect.chart/plot.c:85
+#: ../display/d.vect/attr.c:110
+#: ../display/d.vect.chart/plot.c:85
#: ../vector/v.in.db/main.c:163
#, fuzzy, c-format
msgid "Unable to open select cursor: '%s'"
@@ -18808,7 +19032,8 @@
msgid "No attribute found for cat %d: %s"
msgstr "Aucun enregistrement pour la ligne (cat = %d)"
-#: ../display/d.vect/topo.c:39 ../display/d.thematic.area/plot1.c:294
+#: ../display/d.vect/topo.c:39
+#: ../display/d.thematic.area/plot1.c:294
#, c-format
msgid ""
"\n"
@@ -18817,7 +19042,8 @@
"\n"
"ERREUR: fichier vecteur - lecture impossible\n"
-#: ../display/d.vect/main.c:78 ../display/d.what.vect/main.c:54
+#: ../display/d.vect/main.c:78
+#: ../display/d.what.vect/main.c:54
#: ../display/d.extract/main.c:50
#, fuzzy
msgid "display, vector"
@@ -18826,49 +19052,70 @@
#: ../display/d.vect/main.c:79
#, fuzzy
msgid "Displays user-specified vector map in the active graphics frame."
-msgstr ""
-"Afficher trois couches rasters spécifiées par l'utilisateur comme calques "
-"rouge, vert, bleu superposés dans le moniteur actif."
+msgstr "Afficher trois couches rasters spécifiées par l'utilisateur comme calques rouge, vert, bleu superposés dans le moniteur actif."
#: ../display/d.vect/main.c:91
msgid "Display"
msgstr "Afficher"
#: ../display/d.vect/main.c:92
-msgid ""
-"shape;Display geometry of features;cat;Display category numbers of features;"
-"topo;Display topology information (nodes, edges);dir;Display direction of "
-"linear features;attr;Display selected attribute based on 'attrcol';zcoor;"
-"Display z-coordinate of features (only for 3D vector maps)"
+msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
msgstr ""
-#: ../display/d.vect/main.c:103 ../display/d.vect/main.c:109
-#: ../display/d.vect/main.c:112 ../display/d.vect/main.c:115
-#: ../display/d.vect/main.c:333 ../display/d.rast/main.c:66
-#: ../display/d.rast/main.c:75 ../display/d.rast/main.c:94
-#: ../display/d.thematic.area/main.c:131 ../display/d.thematic.area/main.c:134
-#: ../vector/v.net.centrality/main.c:107 ../vector/v.net.centrality/main.c:109
-#: ../vector/v.in.ogr/main.c:132 ../vector/v.in.ogr/main.c:146
-#: ../vector/v.in.ogr/main.c:168 ../vector/v.buffer2/main.c:160
-#: ../vector/v.buffer2/main.c:163 ../vector/v.out.ascii/out.c:80
-#: ../vector/v.out.ascii/out.c:87 ../vector/v.edit/args.c:42
-#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
-#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
-#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
-#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
-#: ../vector/v.edit/args.c:202 ../vector/v.extract/main.c:107
-#: ../vector/v.extract/main.c:117 ../vector/v.extract/main.c:123
-#: ../vector/v.extract/main.c:127 ../vector/v.extract/main.c:130
-#: ../vector/v.extract/main.c:138 ../vector/v.extract/main.c:148
-#: ../vector/v.category/main.c:92 ../vector/v.category/main.c:97
-#: ../vector/v.category/main.c:101 ../vector/v.surf.rst/main.c:193
-#: ../vector/v.surf.rst/main.c:219 ../vector/v.surf.rst/main.c:222
-#: ../vector/v.reclass/main.c:76 ../vector/v.reclass/main.c:79
-#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
-#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
-#: ../vector/v.select/args.c:89 ../vector/v.net.allpairs/main.c:67
-#: ../vector/v.net.allpairs/main.c:69 ../vector/v.net.allpairs/main.c:71
-#: ../vector/v.to.rast/main.c:45 ../vector/v.to.rast/main.c:50
+#: ../display/d.vect/main.c:103
+#: ../display/d.vect/main.c:109
+#: ../display/d.vect/main.c:112
+#: ../display/d.vect/main.c:115
+#: ../display/d.vect/main.c:333
+#: ../display/d.rast/main.c:66
+#: ../display/d.rast/main.c:75
+#: ../display/d.rast/main.c:94
+#: ../display/d.thematic.area/main.c:131
+#: ../display/d.thematic.area/main.c:134
+#: ../vector/v.net.centrality/main.c:107
+#: ../vector/v.net.centrality/main.c:109
+#: ../vector/v.in.ogr/main.c:132
+#: ../vector/v.in.ogr/main.c:146
+#: ../vector/v.in.ogr/main.c:168
+#: ../vector/v.buffer2/main.c:160
+#: ../vector/v.buffer2/main.c:163
+#: ../vector/v.out.ascii/out.c:80
+#: ../vector/v.out.ascii/out.c:87
+#: ../vector/v.edit/args.c:42
+#: ../vector/v.edit/args.c:47
+#: ../vector/v.edit/args.c:125
+#: ../vector/v.edit/args.c:129
+#: ../vector/v.edit/args.c:138
+#: ../vector/v.edit/args.c:147
+#: ../vector/v.edit/args.c:156
+#: ../vector/v.edit/args.c:159
+#: ../vector/v.edit/args.c:173
+#: ../vector/v.edit/args.c:202
+#: ../vector/v.extract/main.c:107
+#: ../vector/v.extract/main.c:117
+#: ../vector/v.extract/main.c:123
+#: ../vector/v.extract/main.c:127
+#: ../vector/v.extract/main.c:130
+#: ../vector/v.extract/main.c:138
+#: ../vector/v.extract/main.c:148
+#: ../vector/v.category/main.c:92
+#: ../vector/v.category/main.c:97
+#: ../vector/v.category/main.c:101
+#: ../vector/v.surf.rst/main.c:193
+#: ../vector/v.surf.rst/main.c:219
+#: ../vector/v.surf.rst/main.c:222
+#: ../vector/v.reclass/main.c:76
+#: ../vector/v.reclass/main.c:79
+#: ../vector/v.select/args.c:16
+#: ../vector/v.select/args.c:21
+#: ../vector/v.select/args.c:30
+#: ../vector/v.select/args.c:35
+#: ../vector/v.select/args.c:89
+#: ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69
+#: ../vector/v.net.allpairs/main.c:71
+#: ../vector/v.to.rast/main.c:45
+#: ../vector/v.to.rast/main.c:50
#, fuzzy
msgid "Selection"
msgstr "Résolution"
@@ -18883,13 +19130,13 @@
msgid "Feature color"
msgstr "Couleur de ligne"
-#: ../display/d.vect/main.c:126 ../display/d.vect/main.c:136
-#: ../display/d.vect/main.c:239 ../display/d.vect/main.c:249
+#: ../display/d.vect/main.c:126
+#: ../display/d.vect/main.c:136
+#: ../display/d.vect/main.c:239
+#: ../display/d.vect/main.c:249
#, fuzzy
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
-"Couleur de fond, soit une couleur GRASS standard, soit un triplet R:G:B, "
-"soit aucune \"none\""
+msgstr "Couleur de fond, soit une couleur GRASS standard, soit un triplet R:G:B, soit aucune \"none\""
#: ../display/d.vect/main.c:132
msgid "Area fill color"
@@ -18897,18 +19144,15 @@
#: ../display/d.vect/main.c:141
msgid "Name of color definition column (for use with -a flag)"
-msgstr ""
-"Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -"
-"a)"
+msgstr "Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -a)"
#: ../display/d.vect/main.c:149
#, fuzzy
msgid "Type of color table (for use with -z flag)"
-msgstr ""
-"a)"
-#: ../display/d.vect/main.c:158 ../display/d.vect/main.c:163
+#: ../display/d.vect/main.c:158
+#: ../display/d.vect/main.c:163
#: ../display/d.vect/main.c:171
msgid "Lines"
msgstr ""
@@ -18919,16 +19163,16 @@
#: ../display/d.vect/main.c:165
msgid "Name of column for line widths (these values will be scaled by wscale)"
-msgstr ""
-"Nom de la colonne pour l'épaisseur de la ligne (ces valeurs seront mise à "
-"l'échelle par wscale)"
+msgstr "Nom de la colonne pour l'épaisseur de la ligne (ces valeurs seront mise à l'échelle par wscale)"
#: ../display/d.vect/main.c:172
msgid "Scale factor for wcolumn"
msgstr "Facteur d'échelle pour wcolumn"
-#: ../display/d.vect/main.c:180 ../display/d.vect/main.c:190
-#: ../display/d.vect/main.c:197 ../display/d.vect/main.c:203
+#: ../display/d.vect/main.c:180
+#: ../display/d.vect/main.c:190
+#: ../display/d.vect/main.c:197
+#: ../display/d.vect/main.c:203
msgid "Symbols"
msgstr ""
@@ -18958,10 +19202,14 @@
msgid "Measured in degrees CCW from east"
msgstr ""
-#: ../display/d.vect/main.c:212 ../display/d.vect/main.c:219
-#: ../display/d.vect/main.c:227 ../display/d.vect/main.c:235
-#: ../display/d.vect/main.c:245 ../display/d.vect/main.c:255
-#: ../display/d.vect/main.c:261 ../display/d.vect/main.c:267
+#: ../display/d.vect/main.c:212
+#: ../display/d.vect/main.c:219
+#: ../display/d.vect/main.c:227
+#: ../display/d.vect/main.c:235
+#: ../display/d.vect/main.c:245
+#: ../display/d.vect/main.c:255
+#: ../display/d.vect/main.c:261
+#: ../display/d.vect/main.c:267
#: ../display/d.vect/main.c:275
msgid "Labels"
msgstr ""
@@ -18995,8 +19243,10 @@
msgid "Label size (pixels)"
msgstr "Taille de l'étiquette (pixels)"
-#: ../display/d.vect/main.c:262 ../display/d.text.freetype/main.c:168
-#: ../display/d.text.new/main.c:221 ../vector/v.label/main.c:123
+#: ../display/d.vect/main.c:262
+#: ../display/d.text.freetype/main.c:168
+#: ../display/d.text.new/main.c:221
+#: ../vector/v.label/main.c:123
msgid "Font name"
msgstr "nom de la police"
@@ -19009,44 +19259,29 @@
msgstr "Justification verticale des étiquettes"
#: ../display/d.vect/main.c:285
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
-msgstr ""
-"Taille minimum de la région (hauteur et largeur moyenne) quand la couche est "
-"affichée"
+msgid "Minimum region size (average from height and width) when map is displayed"
+msgstr "Taille minimum de la région (hauteur et largeur moyenne) quand la couche est affichée"
#: ../display/d.vect/main.c:293
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
-msgstr ""
-"Taille maximum de la région (hauteur et largeur moyenne) quand la couche est "
-"affichée"
+msgid "Maximum region size (average from height and width) when map is displayed"
+msgstr "Taille maximum de la région (hauteur et largeur moyenne) quand la couche est affichée"
-#: ../display/d.vect/main.c:303 ../display/d.thematic.area/main.c:158
+#: ../display/d.vect/main.c:303
+#: ../display/d.thematic.area/main.c:158
msgid "Rendering method for filled polygons"
msgstr ""
#: ../display/d.vect/main.c:305
-msgid ""
-"g;use the libgis render functions (features: clipping);r;use the raster "
-"graphics library functions (features: polylines);d;use the display library "
-"basic functions (features: polylines);c;use the display library clipping "
-"functions (features: clipping);l;use the display library culling functions "
-"(features: culling, polylines)"
+msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
msgstr ""
#: ../display/d.vect/main.c:321
msgid "Get colors from map table column (of form RRR:GGG:BBB)"
-msgstr ""
-"Prendre les couleurs dans la table de la couche (sous forme RRR:GGG:BBB)"
+msgstr "Prendre les couleurs dans la table de la couche (sous forme RRR:GGG:BBB)"
#: ../display/d.vect/main.c:327
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
-msgstr ""
-"Couleurs aléatoires en fonction du code de catégorie (ou du code de la "
-"couche si 'layer=-1' "
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+msgstr "Couleurs aléatoires en fonction du code de catégorie (ou du code de la couche si 'layer=-1' "
#: ../display/d.vect/main.c:334
#, fuzzy
@@ -19054,25 +19289,20 @@
msgstr "Utilisez les valeurs de l'option 'cats' comme ID ligne"
#: ../display/d.vect/main.c:339
-msgid ""
-"Don't add to list of vectors and commands in monitor (it won't be drawn if "
-"the monitor is refreshed)"
-msgstr ""
-"Ne pas ajouter la liste des vecteurs dans le moniteur (cela ne sera pas "
-"afficher sile moniteur est rafraîchi"
+msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
+msgstr "Ne pas ajouter la liste des vecteurs dans le moniteur (cela ne sera pas afficher sile moniteur est rafraîchi"
#: ../display/d.vect/main.c:344
msgid "Colorize polygons according to z height"
msgstr ""
#: ../display/d.vect/main.c:411
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
msgstr ""
# c-format
-#: ../display/d.vect/main.c:427 ../display/d.thematic.area/main.c:318
+#: ../display/d.vect/main.c:427
+#: ../display/d.thematic.area/main.c:318
#, c-format
msgid "Unknown color: [%s]"
msgstr "Couleur inconnue : [%s]"
@@ -19083,21 +19313,29 @@
msgid "Unknown color: '%s'"
-#: ../display/d.vect/main.c:463 ../vector/v.univar/main.c:205
-#: ../vector/v.extract/main.c:274 ../vector/v.surf.rst/main.c:450
+#: ../display/d.vect/main.c:463
+#: ../vector/v.univar/main.c:205
+#: ../vector/v.extract/main.c:274
+#: ../vector/v.surf.rst/main.c:450
msgid "'layer' must be > 0 for 'where'."
msgstr "'layer' doit être > 0 pour 'where'."
-#: ../display/d.vect/main.c:466 ../display/d.what.vect/what.c:446
-#: ../display/d.thematic.area/main.c:227 ../vector/v.db.connect/main.c:175
+#: ../display/d.vect/main.c:466
+#: ../display/d.what.vect/what.c:446
+#: ../display/d.thematic.area/main.c:227
+#: ../vector/v.db.connect/main.c:175
#, c-format
msgid "Database connection not defined"
msgstr "La connexion à la base de données n'a pas été définie"
# c-format
-#: ../display/d.vect/main.c:475 ../display/d.thematic.area/main.c:236
-#: ../vector/v.convert/att.c:73 ../db/base/tables.c:51 ../db/base/execute.c:68
-#: ../db/base/describe.c:57 ../db/base/select.c:73
+#: ../display/d.vect/main.c:475
+#: ../display/d.thematic.area/main.c:236
+#: ../vector/v.convert/att.c:73
+#: ../db/base/tables.c:51
+#: ../db/base/execute.c:68
+#: ../db/base/describe.c:57
+#: ../db/base/select.c:73
#, fuzzy, c-format
msgid "Unable to open database <%s>"
msgstr "Impossible d'ouvrir la couche raster <%s>"
@@ -19111,24 +19349,22 @@
msgid "%d errors in cat option"
msgstr "%d erreurs dans l'option cat"
-#: ../display/d.vect/main.c:583 ../display/d.thematic.area/main.c:402
+#: ../display/d.vect/main.c:583
+#: ../display/d.thematic.area/main.c:402
#, fuzzy
msgid "Plotting ..."
msgstr "Traçage ... "
-#: ../display/d.vect/main.c:591 ../display/d.thematic.area/main.c:409
+#: ../display/d.vect/main.c:591
+#: ../display/d.thematic.area/main.c:409
#, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-"Les limites de la couche sont en-dehors de la région courante, rien n'a été "
-"affiché.\n"
+msgid "The bounding box of the map is outside the current region, nothing drawn."
+msgstr "Les limites de la couche sont en-dehors de la région courante, rien n'a été affiché.\n"
#: ../display/d.vect/main.c:625
#, fuzzy
msgid "Unable to display areas, topology not available"
-msgstr ""
-"Impossible d'afficher les entités surfaciques, topologie non disponible"
+msgstr "Impossible d'afficher les entités surfaciques, topologie non disponible"
#: ../display/d.vect/main.c:630
#, fuzzy
@@ -19144,20 +19380,18 @@
msgid "Color definition column not specified."
msgstr "La colonne de définition de couleur n'est pas spécifiée."
-#: ../display/d.vect/area.c:83 ../display/d.vect/plot1.c:233
+#: ../display/d.vect/area.c:83
+#: ../display/d.vect/plot1.c:233
#, fuzzy, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
-"BBB' where RGB values range 0-255. You can use '%s' module to define color "
-"rules. Unable to colorize features."
-msgstr ""
-"La colonne de définition de couleur (%s) n'est pas une chaîne de caractère."
-"La colonne doit être de la forme RRR:GGG:BBB ou les valeurs RGB sont "
-"comprises dans l'intervalle 0-255."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
+msgstr "La colonne de définition de couleur (%s) n'est pas une chaîne de caractère.La colonne doit être de la forme RRR:GGG:BBB ou les valeurs RGB sont comprises dans l'intervalle 0-255."
-#: ../display/d.vect/area.c:93 ../display/d.vect/area.c:136
-#: ../display/d.vect/plot1.c:243 ../display/d.vect/plot1.c:284
-#: ../display/d.vect/plot1.c:327 ../display/d.vect/plot1.c:370
+#: ../display/d.vect/area.c:93
+#: ../display/d.vect/area.c:136
+#: ../display/d.vect/plot1.c:243
+#: ../display/d.vect/plot1.c:284
+#: ../display/d.vect/plot1.c:327
+#: ../display/d.vect/plot1.c:370
#: ../display/d.thematic.area/main.c:255
#: ../display/d.thematic.area/plot1.c:225
#: ../display/d.thematic.area/plot1.c:253
@@ -19165,41 +19399,37 @@
msgid "Cannot select data (%s) from table"
msgstr "Impossible de sélectionner des données (%s) dans la table"
-#: ../display/d.vect/area.c:113 ../display/d.vect/plot1.c:261
+#: ../display/d.vect/area.c:113
+#: ../display/d.vect/plot1.c:261
#: ../display/d.thematic.area/plot1.c:238
msgid "Line width column not specified."
msgstr "La colonne de la largeur de ligne n'est pas spécifiée."
-#: ../display/d.vect/area.c:128 ../display/d.thematic.area/plot1.c:249
+#: ../display/d.vect/area.c:128
+#: ../display/d.thematic.area/plot1.c:249
#, c-format
msgid "Line width column (%s) not a number."
msgstr "la colonne de largeur de ligne (%s) n'est pas de type nombre"
#: ../display/d.vect/area.c:302
#, c-format
-msgid ""
-"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-msgstr ""
-"avec la catégorie %d: code couleur [%s]"
+msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d: code couleur [%s]"
#: ../display/d.vect/area.c:308
#, c-format
msgid "Error in color definition column (%s), area %d with cat %d"
-msgstr ""
-#: ../display/d.vect/area.c:369 ../display/d.vect/plot1.c:587
+#: ../display/d.vect/area.c:369
+#: ../display/d.vect/plot1.c:587
#: ../display/d.thematic.area/plot1.c:444
#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), élément %d avec la "
-"catégorie %d: largeur de ligne [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d: largeur de ligne [%d]"
-#: ../display/d.vect/plot1.c:222 ../display/d.thematic.area/plot1.c:210
+#: ../display/d.vect/plot1.c:222
+#: ../display/d.thematic.area/plot1.c:210
#, fuzzy
msgid "Color definition column not specified"
@@ -19229,82 +19459,69 @@
msgid "Symbol rotation column (%s) is not numeric."
msgstr "Nom de la colonne (le type doit être numérique)"
-#: ../display/d.vect/plot1.c:388 ../display/d.vect/plot1.c:689
+#: ../display/d.vect/plot1.c:388
+#: ../display/d.vect/plot1.c:689
#, fuzzy
msgid "Unable to read symbol, unable to display points"
# c-format
-#: ../display/d.vect/plot1.c:419 ../vector/v.label/main.c:297
-#: ../vector/v.info/main.c:388 ../vector/v.to.3d/trans3.c:82
-#: ../vector/v.to.3d/trans2.c:81 ../vector/v.label.sa/labels.c:146
+#: ../display/d.vect/plot1.c:419
+#: ../vector/v.label/main.c:297
+#: ../vector/v.info/main.c:388
+#: ../vector/v.to.3d/trans3.c:82
+#: ../vector/v.to.3d/trans2.c:81
+#: ../vector/v.label.sa/labels.c:146
#, fuzzy
msgid "Unable to read vector map"
msgstr "Impossible de créer la couche raster <%s>"
#: ../display/d.vect/plot1.c:511
#, fuzzy, c-format
-msgid ""
-"Error in color definition column '%s', feature id %d with cat %d: "
-"colorstring '%s'"
-msgstr ""
+msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
#: ../display/d.vect/plot1.c:519
#, fuzzy, c-format
msgid "Error in color definition column '%s', feature id %d with cat %d"
-msgstr ""
#: ../display/d.vect/plot1.c:641
#, fuzzy, c-format
-msgid ""
-"Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-msgstr ""
+msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
#: ../display/d.vect/plot1.c:729
#, fuzzy, c-format
msgid "Error in color definition column '%s': %d features affected"
-msgstr ""
-#: ../display/d.mapgraph/main.c:48 ../display/d.text/main.c:66
-#: ../display/d.linegraph/linegraph.c:113 ../display/d.vect.chart/main.c:63
-#: ../display/d.barscale/main.c:56 ../display/d.text.freetype/main.c:138
-#: ../display/d.grid/main.c:51 ../display/d.text.new/main.c:142
-#: ../display/d.thematic.area/main.c:78 ../display/d.graph/main.c:54
-#: ../display/d.legend/main.c:86 ../display/d.title/main.c:45
+#: ../display/d.mapgraph/main.c:48
+#: ../display/d.text/main.c:66
+#: ../display/d.linegraph/linegraph.c:113
+#: ../display/d.vect.chart/main.c:63
+#: ../display/d.barscale/main.c:56
+#: ../display/d.text.freetype/main.c:138
+#: ../display/d.grid/main.c:51
+#: ../display/d.text.new/main.c:142
+#: ../display/d.thematic.area/main.c:78
+#: ../display/d.graph/main.c:54
+#: ../display/d.legend/main.c:86
+#: ../display/d.title/main.c:45
msgid "display, cartography"
msgstr "affichage, cartoraphie"
#: ../display/d.mapgraph/main.c:50
-msgid ""
-"Generates and displays simple graphics on map layers drawn in the active "
-"graphics monitor display frame."
-msgstr ""
-"Génére et affiche des graphiques sur les couches de données affichées dans "
-"le moniteur actif."
+msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
+msgstr "Génére et affiche des graphiques sur les couches de données affichées dans le moniteur actif."
#: ../display/d.mapgraph/main.c:57
-msgid ""
-"Unix file containg graphing instructions, if not given reads from standard "
-"input"
-msgstr ""
-"Le fichier Unix contient les instruction de dessin, s'il n'y en a pas partir "
-"des instructions de la ligne de commande"
+msgid "Unix file containg graphing instructions, if not given reads from standard input"
+msgstr "Le fichier Unix contient les instruction de dessin, s'il n'y en a pas partir des instructions de la ligne de commande"
#: ../display/d.mapgraph/main.c:67
-msgid ""
-"Color to draw with, either a standard GRASS color or R:G:B triplet "
-"(separated by colons)"
-msgstr ""
-"Couleur de traçage, soit une couleur GRASS standard soit un triplet R:G:B "
-"(séparé par le signe :)"
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "Couleur de traçage, soit une couleur GRASS standard soit un triplet R:G:B (séparé par le signe :)"
#: ../display/drivers/XDRIVER/Get_w_pointer.c:21
#: ../display/drivers/XDRIVER/Get_w_line.c:35
@@ -19348,52 +19565,60 @@
msgid "using default visual which is %s"
msgstr "utilisation du visuel %s par défaut\n"
-#: ../display/d.rhumbline/main.c:45 ../display/d.geodesic/main.c:45
+#: ../display/d.rhumbline/main.c:45
+#: ../display/d.geodesic/main.c:45
#, fuzzy
msgid "display, distance"
#: ../display/d.rhumbline/main.c:47
#, fuzzy
-msgid ""
-"Displays the rhumbline joining two user-specified points, in the active "
-"frame on the user's graphics monitor."
-msgstr ""
-"Superpose une grille dont le pas est spécifié par l'utilisateur dans le "
-"moniteuractif."
+msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
+msgstr "Superpose une grille dont le pas est spécifié par l'utilisateur dans le moniteuractif."
-#: ../display/d.rhumbline/main.c:55 ../display/d.geodesic/main.c:56
+#: ../display/d.rhumbline/main.c:55
+#: ../display/d.geodesic/main.c:56
#: ../display/d.path/main.c:66
#, fuzzy
msgid "Starting and ending coordinates"
msgstr "Utiliser les coordonnées du centre de la couche\n"
-#: ../display/d.rhumbline/main.c:61 ../display/d.geodesic/main.c:62
+#: ../display/d.rhumbline/main.c:61
+#: ../display/d.geodesic/main.c:62
msgid "Line color"
-#: ../display/d.rhumbline/main.c:70 ../display/d.barscale/main.c:88
-#: ../display/d.grid/main.c:86 ../vector/v.label/main.c:152
-#: ../vector/v.lrs/v.lrs.label/main.c:193 ../vector/v.label.sa/main.c:144
+#: ../display/d.rhumbline/main.c:70
+#: ../display/d.barscale/main.c:88
+#: ../display/d.grid/main.c:86
+#: ../vector/v.label/main.c:152
+#: ../vector/v.lrs/v.lrs.label/main.c:193
+#: ../vector/v.label.sa/main.c:144
msgid "Text color"
msgstr "Couleur du texte"
# c-format
-#: ../display/d.rhumbline/main.c:79 ../display/d.geodesic/main.c:78
+#: ../display/d.rhumbline/main.c:79
+#: ../display/d.geodesic/main.c:78
#, fuzzy, c-format
msgid "Location is not %s"
msgstr "Secteur : %s\n"
-#: ../display/d.rhumbline/main.c:85 ../display/d.geodesic/main.c:83
+#: ../display/d.rhumbline/main.c:85
+#: ../display/d.geodesic/main.c:83
#: ../display/d.path/main.c:143
#, fuzzy
msgid "No coordinates given"
msgstr "Coordonnées de la carte"
-#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:93
-#: ../display/d.rhumbline/main.c:98 ../display/d.rhumbline/main.c:102
-#: ../display/d.geodesic/main.c:87 ../display/d.geodesic/main.c:91
-#: ../display/d.geodesic/main.c:95 ../display/d.geodesic/main.c:99
+#: ../display/d.rhumbline/main.c:89
+#: ../display/d.rhumbline/main.c:93
+#: ../display/d.rhumbline/main.c:98
+#: ../display/d.rhumbline/main.c:102
+#: ../display/d.geodesic/main.c:87
+#: ../display/d.geodesic/main.c:91
+#: ../display/d.geodesic/main.c:95
+#: ../display/d.geodesic/main.c:99
#, fuzzy, c-format
msgid "%s - illegal longitude"
msgstr "%s - nom illégal"
@@ -19404,12 +19629,8 @@
#: ../display/d.where/main.c:44
-msgid ""
-"Identifies the geographic coordinates associated with point locations in the "
-"active frame on the graphics monitor."
-msgstr ""
-"Identifie les coordonnées géographiques associées à l'emplacement d'un point "
-"dans le moniteur actif."
+msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
+msgstr "Identifie les coordonnées géographiques associées à l'emplacement d'un point dans le moniteur actif."
#: ../display/d.where/main.c:49
msgid "One mouse click only"
@@ -19424,12 +19645,8 @@
msgstr "Sortie latitude/longitude référencée sur l'ellipsoïde courant"
#: ../display/d.where/main.c:63
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
-"Sortie de latitude/longitude référencée sur l'ellipsoïde WGS84 en utilisant "
-"les paramètres de transformation de datum du Secteur courant (si disponible)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgstr "Sortie de latitude/longitude référencée sur l'ellipsoïde WGS84 en utilisant les paramètres de transformation de datum du Secteur courant (si disponible)"
#: ../display/d.where/main.c:69
msgid "Output frame coordinates of current display monitor (percentage)"
@@ -19451,8 +19668,10 @@
"Sortie WGS84 impossible car ce Secteur ne contient pas \n"
"de paramètres de transformation du datum. Essayez de lancer g.setproj."
-#: ../display/d.what.vect/what.c:179 ../display/d.what.vect/what.c:181
-#: ../vector/v.what/what.c:112 ../vector/v.what/what.c:114
+#: ../display/d.what.vect/what.c:179
+#: ../display/d.what.vect/what.c:181
+#: ../vector/v.what/what.c:112
+#: ../vector/v.what/what.c:114
#, c-format
msgid "Nothing Found.\n"
msgstr "Rien n'a été trouvé.\n"
@@ -19462,7 +19681,8 @@
msgid "Line: %d Type: %s Left: %d Right: %d "
msgstr "Ligne: %d Type: %s Gauche: %d Droite: %d "
-#: ../display/d.what.vect/what.c:241 ../vector/v.what/what.c:169
+#: ../display/d.what.vect/what.c:241
+#: ../vector/v.what/what.c:169
#: ../vector/v.what/what.c:224
#, c-format
msgid "Length: %f\n"
@@ -19483,12 +19703,14 @@
msgid "length %f\n"
msgstr "longueur %f\n"
-#: ../display/d.what.vect/what.c:295 ../vector/v.what/what.c:238
+#: ../display/d.what.vect/what.c:295
+#: ../vector/v.what/what.c:238
#, c-format
msgid "Point height: %f\n"
msgstr "Hauteur du point: %f\n"
-#: ../display/d.what.vect/what.c:313 ../vector/v.what/what.c:255
+#: ../display/d.what.vect/what.c:313
+#: ../vector/v.what/what.c:255
#, c-format
msgid "Line height: %f\n"
msgstr "Hauteur de la ligne: %f\n"
@@ -19523,12 +19745,14 @@
msgid "Island: %d In area: %d\n"
msgstr "Île: %d Dans zone: %d\n"
-#: ../display/d.what.vect/what.c:393 ../display/d.what.vect/what.c:401
+#: ../display/d.what.vect/what.c:393
+#: ../display/d.what.vect/what.c:401
#, c-format
msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
msgstr "Taille - Mètres carrés: %.3f\t\tHectares: %.3f\n"
-#: ../display/d.what.vect/what.c:397 ../display/d.what.vect/what.c:405
+#: ../display/d.what.vect/what.c:397
+#: ../display/d.what.vect/what.c:405
#, c-format
msgid " Acres: %.3f\t\tSq Miles: %.4f\n"
msgstr " Acres: %.3f\t\tSq Miles: %.4f\n"
@@ -19592,14 +19816,11 @@
msgstr "attention: %s - fichier de vecteur introuvable\n"
#: ../display/d.what.vect/main.c:56
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
-msgstr ""
-"Permet à l'utilisateur de requêter de façon interactive la couche vectoriel "
-"sur des lieux choisis dans la région géographique courante."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
+msgstr "Permet à l'utilisateur de requêter de façon interactive la couche vectoriel sur des lieux choisis dans la région géographique courante."
-#: ../display/d.what.vect/main.c:74 ../display/d.what.rast/main.c:94
+#: ../display/d.what.vect/main.c:74
+#: ../display/d.what.rast/main.c:94
msgid "Identify just one location"
msgstr "Choisissez un seul Secteur"
@@ -19607,7 +19828,8 @@
msgid "Name of existing vector map"
msgstr "Nom de la couche vectorielle existante"
-#: ../display/d.what.vect/main.c:89 ../display/d.what.rast/main.c:98
+#: ../display/d.what.vect/main.c:89
+#: ../display/d.what.rast/main.c:98
msgid "Terse output. For parsing by programs"
msgstr "Sortie 'terse'. Pour le parsing par des programmes externes"
@@ -19615,7 +19837,8 @@
msgid "Print information as plain text to terminal window"
msgstr "Affiche l'information en texte simple dans la fenêtre de la console"
-#: ../display/d.what.vect/main.c:98 ../vector/v.what/main.c:81
+#: ../display/d.what.vect/main.c:98
+#: ../vector/v.what/main.c:81
msgid "Print topological information (debugging)"
msgstr "Affiche l'information topologique (déboguage)"
@@ -19632,51 +19855,53 @@
msgid "%s: You must build topology on vector map"
msgstr "%s: vous devez construire la topologie du fichier vectorielle"
-#: ../display/d.what.vect/main.c:154 ../vector/v.select/main.c:143
+#: ../display/d.what.vect/main.c:154
+#: ../vector/v.select/main.c:143
#: ../vector/v.what/main.c:162
#, fuzzy
msgid "Building spatial index..."
msgstr "Construction de l'index spatial ..."
-#: ../display/d.text/main.c:68 ../display/d.text.new/main.c:144
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+#: ../display/d.text/main.c:68
+#: ../display/d.text.new/main.c:144
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
msgstr "Trace du texte dans le moniteur actif en utilisant la police courante"
-#: ../display/d.text/main.c:77 ../display/d.text.new/main.c:159
+#: ../display/d.text/main.c:77
+#: ../display/d.text.new/main.c:159
msgid "Height of letters in percentage of available frame height"
msgstr "Hauteur des lettres en pourcentage de la hauteur du cadre graphique"
-#: ../display/d.text/main.c:85 ../display/d.text.freetype/main.c:192
+#: ../display/d.text/main.c:85
+#: ../display/d.text.freetype/main.c:192
#: ../display/d.text.new/main.c:167
msgid "Text color, either a standard GRASS color or R:G:B triplet"
msgstr "Couleur du texte, une couleur GRASS standard ou triplet R:G:B"
-#: ../display/d.text/main.c:94 ../display/d.text.new/main.c:184
+#: ../display/d.text/main.c:94
+#: ../display/d.text.new/main.c:184
msgid "The screen line number on which text will begin to be drawn"
msgstr "Numéro de ligne de l'écran sur laquelle on va tracer le début du texte"
-#: ../display/d.text/main.c:103 ../display/d.text.new/main.c:192
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
-msgstr ""
-"Position de l'écran à partir de laquelle on va commencer à tracer le texte "
-"(en pourcentage, [0,0] est en bas à gauche)"
+#: ../display/d.text/main.c:103
+#: ../display/d.text.new/main.c:192
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+msgstr "Position de l'écran à partir de laquelle on va commencer à tracer le texte (en pourcentage, [0,0] est en bas à gauche)"
-#: ../display/d.text/main.c:110 ../display/d.text.freetype/main.c:217
+#: ../display/d.text/main.c:110
+#: ../display/d.text.freetype/main.c:217
#: ../display/d.text.new/main.c:208
msgid "Rotation angle in degrees (counter-clockwise)"
-msgstr ""
-"Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
+msgstr "Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
-#: ../display/d.text/main.c:114 ../display/d.text.freetype/main.c:236
+#: ../display/d.text/main.c:114
+#: ../display/d.text.freetype/main.c:236
#: ../display/d.text.new/main.c:251
msgid "Use bold text"
msgstr "Utiliser des caractères gras"
-#: ../display/d.text/main.c:122 ../display/d.text.new/main.c:275
+#: ../display/d.text/main.c:122
+#: ../display/d.text.new/main.c:275
msgid "Please choose only one placement method"
msgstr "Veuillez choisir une et une seule méthode de positionnement"
@@ -19685,7 +19910,8 @@
msgid "value [%.0f,%.0f] out of range [0-100]"
msgstr "valeur [%.0f,%.0f] hors de l'intervalle [0-100]"
-#: ../display/d.save/main.c:79 ../display/d.info/main.c:34
+#: ../display/d.save/main.c:79
+#: ../display/d.info/main.c:34
#, fuzzy
msgid "display, metadata"
@@ -19693,23 +19919,18 @@
#: ../display/d.save/main.c:81
#, fuzzy
msgid "Creates a list of commands for recreating screen graphics."
-msgstr ""
-"Créer une liste de commande pour recréer les effets graphiques à l'écran"
+msgstr "Créer une liste de commande pour recréer les effets graphiques à l'écran"
#: ../display/d.save/main.c:86
msgid "Name of frame(s) to save"
msgstr "Nom du/des cadre(s) graphique(s) à sauvegarder"
#: ../display/d.save/main.c:126
-msgid ""
-"List of object numbers to remove which are displayed after \"#\". -1 for the "
-"last object."
+msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
msgstr ""
#: ../display/d.save/main.c:134
-msgid ""
-"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
-"done first, if any."
+msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
msgstr ""
#: ../display/d.save/main.c:143
@@ -19728,7 +19949,8 @@
msgid "No monitor selected"
msgstr "Pas de moniteur sélectionné"
-#: ../display/d.save/main.c:481 ../display/d.save/main.c:516
+#: ../display/d.save/main.c:481
+#: ../display/d.save/main.c:516
#, c-format
msgid "Unknown item type in pad: %s"
msgstr "Type d'objet inconnu: %s"
@@ -19738,13 +19960,17 @@
msgid "Can't clear current graphics window"
msgstr "Impossible de créer la fenêtre graphique courante"
-#: ../display/d.rast.edit/cell.c:86 ../display/d.rast/display.c:75
+#: ../display/d.rast.edit/cell.c:86
+#: ../display/d.rast/display.c:75
msgid "Cannot use current window"
msgstr "Impossible de créer la fenêtre courante"
-#: ../display/d.rast.edit/main.c:59 ../display/d.what.rast/main.c:52
-#: ../display/d.rast.num/number.c:84 ../display/d.colortable/main.c:60
-#: ../display/d.colors/main.c:50 ../display/d.rast/main.c:51
+#: ../display/d.rast.edit/main.c:59
+#: ../display/d.what.rast/main.c:52
+#: ../display/d.rast.num/number.c:84
+#: ../display/d.colortable/main.c:60
+#: ../display/d.colors/main.c:50
+#: ../display/d.rast/main.c:51
#: ../display/d.rast.arrow/arrow.c:110
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
#, fuzzy
@@ -19759,12 +19985,8 @@
#: ../display/d.linegraph/linegraph.c:115
#, fuzzy
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
-msgstr ""
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
#: ../display/d.linegraph/linegraph.c:119
#, fuzzy
@@ -19883,10 +20105,10 @@
"\n"
"\n"
"Use mouse to choose action"
-msgstr ""
-"Utiliser la souris pour dimensionner et positionner le cartouche de légende"
+msgstr "Utiliser la souris pour dimensionner et positionner le cartouche de légende"
-#: ../display/d.profile/main.c:199 ../display/d.profile/main.c:393
+#: ../display/d.profile/main.c:199
+#: ../display/d.profile/main.c:393
msgid "Use 'd.frame -e' to remove left over frames"
msgstr ""
@@ -19930,9 +20152,7 @@
msgstr "Faire pivoter le cartouche de légende"
#: ../display/d.ask/main.c:38
-msgid ""
-"Prompts the user to select a GRASS data base file from among files displayed "
-"in a menu on the graphics monitor."
+msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
msgstr ""
#: ../display/d.ask/main.c:46
@@ -19959,14 +20179,8 @@
msgstr "Vous cliquez en dehors de la couche"
#: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
-msgstr ""
-"Permet à l'utilisateur de requêter de façon interactive les contenus de "
-"catégories de multiples couches rasters sur des lieux choisis par "
-"l'utilisateur dans la région géographique courante."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
+msgstr "Permet à l'utilisateur de requêter de façon interactive les contenus de catégories de multiples couches rasters sur des lieux choisis par l'utilisateur dans la région géographique courante."
#: ../display/d.what.rast/main.c:89
msgid "Field separator (terse mode only)"
@@ -19974,15 +20188,15 @@
#: ../display/d.what.rast/main.c:103
msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
-"Affiche la colonne/ligne pour la couche entière en fonction de la résolution "
-"de la région"
+msgstr "Affiche la colonne/ligne pour la couche entière en fonction de la résolution de la région"
-#: ../display/d.what.rast/main.c:119 ../display/d.his/main.c:120
+#: ../display/d.what.rast/main.c:119
+#: ../display/d.his/main.c:120
msgid "No current graphics window"
msgstr "Pas de fenêtre graphique active"
-#: ../display/d.what.rast/main.c:122 ../display/d.his/main.c:123
+#: ../display/d.what.rast/main.c:122
+#: ../display/d.his/main.c:123
msgid "Current graphics window not available"
msgstr "Fenêtre graphique courante non disponible"
@@ -20032,18 +20246,19 @@
#: ../display/d.vect.chart/main.c:65
#, fuzzy
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr ""
-"Afficher des diagrammes de données vectorielles GRASS dans le moniteur actif"
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
+msgstr "Afficher des diagrammes de données vectorielles GRASS dans le moniteur actif"
#: ../display/d.vect.chart/main.c:82
msgid "Chart type"
msgstr "Type de diagramme"
-#: ../display/d.vect.chart/main.c:83 ../display/d.vect.chart/main.c:97
-#: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
-#: ../display/d.vect.chart/main.c:120 ../display/d.vect.chart/main.c:129
+#: ../display/d.vect.chart/main.c:83
+#: ../display/d.vect.chart/main.c:97
+#: ../display/d.vect.chart/main.c:105
+#: ../display/d.vect.chart/main.c:112
+#: ../display/d.vect.chart/main.c:120
+#: ../display/d.vect.chart/main.c:129
#: ../display/d.vect.chart/main.c:135
#, fuzzy
msgid "Chart properties"
@@ -20059,9 +20274,7 @@
#: ../display/d.vect.chart/main.c:104
msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-"Taille du diagramme (diamètre pour le diagramme camembert, largeur totale "
-"pour le diagramme en barres)"
+msgstr "Taille du diagramme (diamètre pour le diagramme camembert, largeur totale pour le diagramme en barres)"
#: ../display/d.vect.chart/main.c:111
msgid "Scale for size (to get size in pixels)"
@@ -20083,7 +20296,8 @@
msgid "Maximum value used for bar plot reference"
msgstr "Valeur maximale utilisée pour le diagramme en barres"
-#: ../display/d.vect.chart/main.c:148 ../display/d.thematic.area/main.c:174
+#: ../display/d.vect.chart/main.c:148
+#: ../display/d.thematic.area/main.c:174
msgid "Create legend information and send to stdout"
msgstr ""
@@ -20094,8 +20308,7 @@
#: ../display/d.barscale/main.c:61
msgid "Use mouse to interactively place scale"
-msgstr ""
-"Utilisez la souris pour positionner l'échelle graphique de façon interactive"
+msgstr "Utilisez la souris pour positionner l'échelle graphique de façon interactive"
#: ../display/d.barscale/main.c:65
msgid "Use feet/miles instead of meters"
@@ -20103,9 +20316,7 @@
#: ../display/d.barscale/main.c:69
msgid "Draw a line scale instead of a bar scale"
-msgstr ""
-"Afficher une échelle graphique sous forme de ligne, plutôt que sous forme de "
-"barre"
+msgstr "Afficher une échelle graphique sous forme de ligne, plutôt que sous forme de barre"
#: ../display/d.barscale/main.c:73
msgid "Write text on top of the scale, not to the right"
@@ -20120,14 +20331,11 @@
msgstr "Affiche seulement une échelle graphique"
#: ../display/d.barscale/main.c:98
-msgid ""
-"The screen coordinates for top-left corner of label ([0,0] is top-left of "
-"frame)"
-msgstr ""
-"Les coordonnées écran pour le coin supérieur gauche de l'étiquette ([0,0] "
-"est le coin supérieurgauche du cadre graphique)"
+msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
+msgstr "Les coordonnées écran pour le coin supérieur gauche de l'étiquette ([0,0] est le coin supérieurgauche du cadre graphique)"
-#: ../display/d.barscale/main.c:106 ../display/d.grid/main.c:95
+#: ../display/d.barscale/main.c:106
+#: ../display/d.grid/main.c:95
msgid "Font size for gridline coordinate labels"
msgstr ""
@@ -20140,9 +20348,12 @@
msgid "Choose either -n or -s flag"
msgstr "Choisissez soit le drapeau -n soit le drapeau -s"
-#: ../display/d.erase/main.c:32 ../display/d.colorlist/main.c:35
-#: ../display/d.frame/frame.c:60 ../display/d.font.freetype/main.c:59
-#: ../display/d.extend/main.c:31 ../display/d.font/main.c:46
+#: ../display/d.erase/main.c:32
+#: ../display/d.colorlist/main.c:35
+#: ../display/d.frame/frame.c:60
+#: ../display/d.font.freetype/main.c:59
+#: ../display/d.extend/main.c:31
+#: ../display/d.font/main.c:46
#: ../locale/scriptstrings/d.resize_to_translate.c:2
#: ../locale/scriptstrings/d.monsize_to_translate.c:2
#: ../locale/scriptstrings/d.mvmon_to_translate.c:2
@@ -20153,31 +20364,30 @@
#: ../display/d.erase/main.c:34
msgid "Erase the contents of the active display frame with user defined color"
-msgstr ""
-"Efface le contenu du moniteur actif avec la couleur choisie par l'utilisateur"
+msgstr "Efface le contenu du moniteur actif avec la couleur choisie par l'utilisateur"
#: ../display/d.erase/main.c:42
-msgid ""
-"Color to erase with, either a standard GRASS color or R:G:B triplet "
-msgstr ""
-"Couleur pour effacer, soit une couleur GRASS standard soit un triplet R:G:B"
+msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "Couleur pour effacer, soit une couleur GRASS standard soit un triplet R:G:B(séparé par le signe :)"
-#: ../display/d.erase/main.c:47 ../display/d.frame/frame.c:74
+#: ../display/d.erase/main.c:47
+#: ../display/d.frame/frame.c:74
msgid "Remove all frames and erase the screen"
msgstr "Supprimer tous les cadres graphiques et effacer l'écran"
-#: ../display/d.erase/main.c:52 ../display/d.rgb/main.c:65
+#: ../display/d.erase/main.c:52
+#: ../display/d.rgb/main.c:65
msgid "Don't add to list of commands in monitor"
msgstr "Ne pas ajouter à la liste des commandes dans le moniteur"
-#: ../display/d.erase/main.c:62 ../display/d.colortable/main.c:140
+#: ../display/d.erase/main.c:62
+#: ../display/d.colortable/main.c:140
#: ../display/d.measure/main.c:90
msgid "No current frame"
msgstr "Pas de cadre graphique actif"
-#: ../display/d.erase/main.c:64 ../display/d.colortable/main.c:142
+#: ../display/d.erase/main.c:64
+#: ../display/d.colortable/main.c:142
#: ../display/d.measure/main.c:93
msgid "Current frame not available"
msgstr "Cadre graphique courant non disponible"
@@ -20188,14 +20398,11 @@
#: ../display/d.zoom/main.c:59
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
-msgstr ""
-"Permet à l'utilisateur de changer les réglages de la région géographique "
-"courante de manière interactive, à l'aide de la souris."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
+msgstr "Permet à l'utilisateur de changer les réglages de la région géographique courante de manière interactive, à l'aide de la souris."
-#: ../display/d.zoom/main.c:90 ../display/d.legend/main.c:92
+#: ../display/d.zoom/main.c:90
+#: ../display/d.legend/main.c:92
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
msgid "Name of raster map"
msgstr "Nom de la couche raster"
@@ -20223,9 +20430,7 @@
#: ../display/d.zoom/main.c:130
msgid "Just redraw given maps using default colors"
-msgstr ""
-"Redessiner simplement les couches concernées en utilisant les couleurs par "
-"défaut"
+msgstr "Redessiner simplement les couches concernées en utilisant les couleurs par défaut"
#: ../display/d.zoom/main.c:134
msgid "Return to previous zoom"
@@ -20265,7 +20470,8 @@
msgid "Zooming complete."
msgstr "Zoom achevé."
-#: ../display/d.zoom/zoom.c:15 ../display/d.zoom/pan.c:17
+#: ../display/d.zoom/zoom.c:15
+#: ../display/d.zoom/pan.c:17
#, c-format
msgid ""
"\n"
@@ -20303,8 +20509,7 @@
#: ../display/d.zoom/zoom.c:42
#, c-format
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Note: lancer 'd.erase' pour la nouvelle région pour modifier l'affichage.\n"
+msgstr "Note: lancer 'd.erase' pour la nouvelle région pour modifier l'affichage.\n"
#: ../display/d.zoom/pan.c:18
#, fuzzy, c-format
@@ -20317,12 +20522,8 @@
msgstr " Droite: quitter\n"
#: ../display/d.rast.num/number.c:86
-msgid ""
-"Overlays cell category values on a raster map layer displayed to the "
-msgstr ""
-"Superpose les valeurs de catégorie des cellules sur la couche raster "
-"affichée dans lemoniteur."
+msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+msgstr "Superpose les valeurs de catégorie des cellules sur la couche raster affichée dans lemoniteur."
#: ../display/d.rast.num/number.c:100
msgid "Color for drawing grid, or \"none\""
@@ -20334,8 +20535,7 @@
#: ../display/d.rast.num/number.c:124
msgid "Get text color from cell color value"
-msgstr ""
-"Choisir la couleur du texte en fonction de la valeur de couleur de la cellule"
+msgstr "Choisir la couleur du texte en fonction de la valeur de couleur de la cellule"
#: ../display/d.rast.num/number.c:138
msgid "No raster map exists in current window"
@@ -20345,35 +20545,28 @@
#, fuzzy, c-format
msgid ""
"Current region size: %d rows X %d cols\n"
-"Your current region setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
msgstr ""
"\n"
-"Votre fenêtre courante semble trop grande. Les cellules affichées dans votre "
-"moniteur graphique risque d'être trop petites pour que le code de catégorie "
-"soit visible."
+"Votre fenêtre courante semble trop grande. Les cellules affichées dans votre moniteur graphique risque d'être trop petites pour que le code de catégorie soit visible."
#: ../display/d.rast.num/number.c:216
msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
msgstr ""
#: ../display/d.text.freetype/main.c:140
-msgid ""
-"Draws text in the graphics monitor's active display frame using TrueType "
-"fonts."
-msgstr ""
-"Affiche du texte dans le moniteur actif en utilisant des polices TrueType"
+msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
+msgstr "Affiche du texte dans le moniteur actif en utilisant des polices TrueType"
-#: ../display/d.text.freetype/main.c:146 ../display/d.text.new/main.c:150
+#: ../display/d.text.freetype/main.c:146
+#: ../display/d.text.new/main.c:150
msgid "Text to display"
msgstr "Texte à afficher"
#: ../display/d.text.freetype/main.c:154
#, fuzzy
msgid "Screen position (percentage, [0,0] is bottom left)"
-msgstr ""
-"Les coordonnées sont en pourcentage du cadre graphique ([0,0] est en bas à "
-"gauche)"
+msgstr "Les coordonnées sont en pourcentage du cadre graphique ([0,0] est en bas à gauche)"
#: ../display/d.text.freetype/main.c:176
msgid "Path to TrueType font (including file name)"
@@ -20381,34 +20574,37 @@
#: ../display/d.text.freetype/main.c:201
msgid "Height of letters (in percent of available frame height)"
-msgstr ""
-"Hauteur des caractères (en pourcentage de la hauteur disponible du cadre "
-"graphique)"
+msgstr "Hauteur des caractères (en pourcentage de la hauteur disponible du cadre graphique)"
-#: ../display/d.text.freetype/main.c:209 ../display/d.text.new/main.c:200
+#: ../display/d.text.freetype/main.c:209
+#: ../display/d.text.new/main.c:200
msgid "Text alignment"
msgstr "Alignement du texte"
-#: ../display/d.text.freetype/main.c:224 ../display/d.text.new/main.c:215
+#: ../display/d.text.freetype/main.c:224
+#: ../display/d.text.new/main.c:215
msgid "Line spacing"
msgstr "Espacement des lignes"
-#: ../display/d.text.freetype/main.c:228 ../display/d.text.new/main.c:243
+#: ../display/d.text.freetype/main.c:228
+#: ../display/d.text.new/main.c:243
#, fuzzy
msgid "Screen position in pixels ([0,0] is top left)"
msgstr "Les coordonnées sont en pixels ([0,0] est en haut à gauche)"
-#: ../display/d.text.freetype/main.c:232 ../display/d.text.new/main.c:247
+#: ../display/d.text.freetype/main.c:232
+#: ../display/d.text.new/main.c:247
#, fuzzy
msgid "Screen position in geographic coordinates"
msgstr "Coordonnées du point germe"
-#: ../display/d.text.freetype/main.c:240 ../display/d.text.new/main.c:255
+#: ../display/d.text.freetype/main.c:240
+#: ../display/d.text.new/main.c:255
msgid "Use radians instead of degrees for rotation"
-msgstr ""
-"Utilisez des radians à la place de degrés pour définir l'angle de rotation"
+msgstr "Utilisez des radians à la place de degrés pour définir l'angle de rotation"
-#: ../display/d.text.freetype/main.c:244 ../display/d.text.new/main.c:259
+#: ../display/d.text.freetype/main.c:244
+#: ../display/d.text.new/main.c:259
msgid "Font size is height in pixels"
msgstr "La taille de la police est la hauteur en pixels"
@@ -20424,35 +20620,42 @@
msgid "Choose only one coordinate system for placement"
msgstr "Choisissez un seul système de coordonnées pour déterminer le placement"
-#: ../display/d.text.freetype/main.c:265 ../display/d.text.freetype/main.c:268
+#: ../display/d.text.freetype/main.c:265
+#: ../display/d.text.freetype/main.c:268
#: ../display/d.text.freetype/main.c:606
msgid "No font selected"
msgstr "Pas de police sélectionnée"
# c-format
-#: ../display/d.text.freetype/main.c:277 ../display/d.text.freetype/main.c:440
+#: ../display/d.text.freetype/main.c:277
+#: ../display/d.text.freetype/main.c:440
#, c-format
msgid "Invalid font: %s"
msgstr "Police invalide : %s"
-#: ../display/d.text.freetype/main.c:327 ../vector/v.label.sa/labels.c:92
+#: ../display/d.text.freetype/main.c:327
+#: ../vector/v.label.sa/labels.c:92
msgid "Unable to initialise FreeType"
msgstr "Impossible de réinitialiser FreeType"
-#: ../display/d.text.freetype/main.c:331 ../display/d.text.freetype/main.c:458
+#: ../display/d.text.freetype/main.c:331
+#: ../display/d.text.freetype/main.c:458
msgid "Unable to create face"
msgstr "Impossible de créer le texte"
-#: ../display/d.text.freetype/main.c:334 ../display/d.text.freetype/main.c:461
+#: ../display/d.text.freetype/main.c:334
+#: ../display/d.text.freetype/main.c:461
#: ../display/d.text.freetype/main.c:478
msgid "Unable to set size"
msgstr "Impossible de paramétrer la taille"
-#: ../display/d.text.freetype/main.c:349 ../display/d.text.freetype/main.c:568
+#: ../display/d.text.freetype/main.c:349
+#: ../display/d.text.freetype/main.c:568
msgid "Unable to create text conversion context"
msgstr "Impossible de créer le contexte de conversion du texte"
-#: ../display/d.text.freetype/main.c:351 ../display/d.text.freetype/main.c:570
+#: ../display/d.text.freetype/main.c:351
+#: ../display/d.text.freetype/main.c:570
msgid "Text conversion error"
msgstr "Erreur de conversion du texte"
@@ -20472,9 +20675,7 @@
#: ../display/d.text.freetype/main.c:645
#, c-format
msgid "%s: Unable to read FreeType definition file; use the default"
-msgstr ""
-"%s : impossible de lire le fichier de définition FreeType; on utilise les "
-"paramètres par défaut"
+msgstr "%s : impossible de lire le fichier de définition FreeType; on utilise les paramètres par défaut"
#: ../display/d.text.freetype/main.c:651
#, c-format
@@ -20516,12 +20717,8 @@
msgstr "Erreur dans pj_do_proj6"
#: ../display/d.grid/main.c:53
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
-msgstr ""
-"moniteuractif."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
#: ../display/d.grid/main.c:61
msgid "Size of grid to be drawn"
@@ -20540,7 +20737,8 @@
msgid "Grid color"
msgstr "Couleur de la bordure"
-#: ../display/d.grid/main.c:76 ../display/d.grid/main.c:81
+#: ../display/d.grid/main.c:76
+#: ../display/d.grid/main.c:81
#: ../display/d.grid/main.c:87
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
@@ -20552,8 +20750,10 @@
msgid "Color"
msgstr ""
-#: ../display/d.grid/main.c:80 ../vector/v.label/main.c:194
-#: ../vector/v.lrs/v.lrs.label/main.c:237 ../vector/v.label.sa/main.c:190
+#: ../display/d.grid/main.c:80
+#: ../vector/v.label/main.c:194
+#: ../vector/v.lrs/v.lrs.label/main.c:237
+#: ../vector/v.label.sa/main.c:190
msgid "Border color"
@@ -20569,22 +20769,19 @@
#: ../display/d.grid/main.c:109
#, fuzzy
msgid "Draw '+' marks instead of grid lines"
-msgstr ""
-"barre"
#: ../display/d.grid/main.c:113
#, fuzzy
msgid "Draw fiducial marks instead of grid lines"
-msgstr ""
-"barre"
#: ../display/d.grid/main.c:117
msgid "Disable grid drawing"
msgstr "Traçage de la grille désactivé"
-#: ../display/d.grid/main.c:118 ../display/d.grid/main.c:123
+#: ../display/d.grid/main.c:118
+#: ../display/d.grid/main.c:123
#: ../display/d.grid/main.c:128
#, fuzzy
msgid "Disable"
@@ -20729,8 +20926,7 @@
#: ../display/d.text.new/main.c:239
#, fuzzy
msgid "Use mouse to interactively place text"
-msgstr ""
#: ../display/d.text.new/main.c:263
#, fuzzy
@@ -20777,12 +20973,8 @@
#: ../display/d.his/main.c:67
#, fuzzy
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
-msgstr ""
-"Générer des couches raster de couche rouge, verte et bleue en combinant des "
-"couches raster de teinte, intensité et saturation."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
+msgstr "Générer des couches raster de couche rouge, verte et bleue en combinant des couches raster de teinte, intensité et saturation."
#: ../display/d.his/main.c:95
msgid "Percent to brighten intensity channel"
@@ -20804,9 +20996,7 @@
msgstr "Erreur de lecture de la couche Saturation"
#: ../display/d.geodesic/main.c:47
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
msgstr ""
#: ../display/d.geodesic/main.c:70
@@ -20814,12 +21004,14 @@
msgid "Text color or \"none\""
-#: ../display/d.mon/pgms/start.c:68 ../display/d.mon/pgms/select.c:18
+#: ../display/d.mon/pgms/start.c:68
+#: ../display/d.mon/pgms/select.c:18
#, c-format
msgid "Usage: %s monitor_name"
msgstr ""
-#: ../display/d.mon/pgms/stop.c:33 ../display/d.mon/pgms/release.c:41
+#: ../display/d.mon/pgms/stop.c:33
+#: ../display/d.mon/pgms/release.c:41
#, c-format
msgid "%s: -%c unrecognized option"
msgstr ""
@@ -20839,7 +21031,8 @@
msgid "Error - Monitor '%s' was not running"
msgstr ""
-#: ../display/d.mon/pgms/stop.c:76 ../display/d.mon/pgms/select.c:27
+#: ../display/d.mon/pgms/stop.c:76
+#: ../display/d.mon/pgms/select.c:27
#: ../display/d.mon/pgms/release.c:74
#, fuzzy, c-format
msgid "No such monitor as <%s>"
@@ -20876,8 +21069,7 @@
#: ../display/d.mon/cmd/main.c:51
msgid "To establish and control use of a graphics display monitor."
-msgstr ""
-"Pour gérer et contrôler l'utilisation des moniteurs graphiques d'affichage"
+msgstr "Pour gérer et contrôler l'utilisation des moniteurs graphiques d'affichage"
#: ../display/d.mon/cmd/main.c:57
msgid "Name of graphics monitor to start"
@@ -20946,16 +21138,12 @@
#: ../display/d.colortable/main.c:111
#, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [lines] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:125
#, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [cols] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:134
@@ -20976,9 +21164,7 @@
#: ../display/d.rast/main.c:52
#, fuzzy
msgid "Displays user-specified raster map in the active graphics frame."
-msgstr ""
#: ../display/d.rast/main.c:65
msgid "List of categories to be displayed (INT maps)"
@@ -20992,11 +21178,13 @@
msgid "Background color (for null)"
msgstr "Couleur de fond (pour null)"
-#: ../display/d.rast/main.c:84 ../display/d.rast/main.c:89
+#: ../display/d.rast/main.c:84
+#: ../display/d.rast/main.c:89
msgid "Null cells"
msgstr ""
-#: ../display/d.rast/main.c:88 ../display/d.rgb/main.c:61
+#: ../display/d.rast/main.c:88
+#: ../display/d.rgb/main.c:61
msgid "Overlay (non-null values only)"
msgstr "Superposer (seulement sur les valeurs non-null)"
@@ -21010,9 +21198,7 @@
#: ../display/d.rast/main.c:119
msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
-"Catlist ignorée : la couche est en valeurs flottantes (veuillez utiliser "
-"'val=')"
+msgstr "Catlist ignorée : la couche est en valeurs flottantes (veuillez utiliser 'val=')"
#: ../display/d.rast/main.c:125
msgid "Ignoring vallist: map is integer (please use 'cat=')"
@@ -21020,9 +21206,7 @@
#: ../display/d.thematic.area/main.c:80
#, fuzzy
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
#: ../display/d.thematic.area/main.c:90
@@ -21033,18 +21217,19 @@
msgid "Class breaks, without minimum and maximum"
msgstr ""
-#: ../display/d.thematic.area/main.c:105 ../vector/v.class/main.c:68
+#: ../display/d.thematic.area/main.c:105
+#: ../vector/v.class/main.c:68
#, fuzzy
msgid "Algorithm to use for classification"
msgstr "Nom de fichier de signatures à utiliser pour la classification"
-#: ../display/d.thematic.area/main.c:106 ../vector/v.class/main.c:69
-msgid ""
-"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
-"(normal distribution);"
+#: ../display/d.thematic.area/main.c:106
+#: ../vector/v.class/main.c:69
+msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
msgstr ""
-#: ../display/d.thematic.area/main.c:117 ../vector/v.class/main.c:80
+#: ../display/d.thematic.area/main.c:117
+#: ../vector/v.class/main.c:80
#, fuzzy
msgid "Number of classes to define"
msgstr "Nombre de copies à imprimer"
@@ -21057,7 +21242,8 @@
msgid "Layer number. If -1, all layers are displayed."
msgstr "Code de couche. Si fixé à -1, toutes les couches sont affichées."
-#: ../display/d.thematic.area/main.c:140 ../display/d.thematic.area/main.c:148
+#: ../display/d.thematic.area/main.c:140
+#: ../display/d.thematic.area/main.c:148
#, fuzzy
msgid "Boundaries"
msgstr "Limites"
@@ -21073,10 +21259,7 @@
#: ../display/d.thematic.area/main.c:160
-msgid ""
-"d;use the display library basic functions (features: polylines);c;use the "
-"display library clipping functions (features: clipping);l;use the display "
-"library culling functions (features: culling, polylines)"
+msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
msgstr ""
#: ../display/d.thematic.area/main.c:168
@@ -21084,9 +21267,7 @@
msgstr ""
#: ../display/d.thematic.area/main.c:179
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info , include extended statistical info from classification algorithm"
msgstr ""
#: ../display/d.thematic.area/main.c:183
@@ -21116,9 +21297,7 @@
msgstr "La clef primaire doit être un entier"
#: ../display/d.thematic.area/main.c:329
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
msgstr ""
#: ../display/d.thematic.area/main.c:366
@@ -21149,12 +21328,14 @@
msgid "Classification of %s into %i classes\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:462 ../vector/v.class/main.c:195
+#: ../display/d.thematic.area/main.c:462
+#: ../vector/v.class/main.c:195
#, c-format
msgid "Using algorithm: *** %s ***\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:464 ../vector/v.class/main.c:196
+#: ../display/d.thematic.area/main.c:464
+#: ../vector/v.class/main.c:196
#, fuzzy, c-format
msgid "Mean: %f\tStandard deviation = %f\n"
msgstr "Écart-type"
@@ -21164,51 +21345,39 @@
msgid "Last chi2 = %f\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:471 ../vector/v.class/main.c:203
+#: ../display/d.thematic.area/main.c:471
+#: ../vector/v.class/main.c:203
#, c-format
msgid "Stdev multiplied by %.4f to define step\n"
msgstr ""
#: ../display/d.thematic.area/plot1.c:220
#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
-msgstr ""
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
#: ../display/d.thematic.area/plot1.c:369
#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
-msgstr ""
-"catégorie %d: code couleur [%s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d: code couleur [%s]"
#: ../display/d.thematic.area/plot1.c:376
#, c-format
msgid "Error in color definition column (%s), element %d with cat %d"
-msgstr ""
-"catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d"
-#: ../display/d.font.freetype/main.c:61 ../display/d.font/main.c:48
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"Sélectionnez la police à utiliser pour afficher le texte sur le moniteur "
-"graphique."
+#: ../display/d.font.freetype/main.c:61
+#: ../display/d.font/main.c:48
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "Sélectionnez la police à utiliser pour afficher le texte sur le moniteur graphique."
#: ../display/d.font.freetype/main.c:68
#, fuzzy
msgid "Font name or pathname of TTF file"
msgstr "Nom du nouveau fichier TIFF"
-#: ../display/d.font.freetype/main.c:75 ../display/d.font/main.c:71
+#: ../display/d.font.freetype/main.c:75
+#: ../display/d.font/main.c:71
msgid "Character encoding"
msgstr "Encodage du caractère"
@@ -21220,7 +21389,8 @@
"Paramétrage du nettoyage de FreeType\n"
# c-format
-#: ../display/d.graph/do_graph.c:54 ../display/d.graph/do_graph.c:83
+#: ../display/d.graph/do_graph.c:54
+#: ../display/d.graph/do_graph.c:83
#, c-format
msgid "Problem parsing coordinates [%s]"
msgstr "Problème d'interprétation des coordonnées [%s]"
@@ -21229,33 +21399,27 @@
msgid "Unable to read color"
msgstr "Impossible de lire cette couleur"
-#: ../display/d.graph/do_graph.c:136 ../display/d.graph/do_graph.c:213
-#: ../display/d.graph/do_graph.c:234 ../display/d.graph/do_graph.c:292
-#: ../display/d.graph/do_graph.c:363 ../display/d.graph/graphics.c:60
+#: ../display/d.graph/do_graph.c:136
+#: ../display/d.graph/do_graph.c:213
+#: ../display/d.graph/do_graph.c:234
+#: ../display/d.graph/do_graph.c:292
+#: ../display/d.graph/do_graph.c:363
+#: ../display/d.graph/graphics.c:60
#, c-format
msgid "Problem parsing command [%s]"
msgstr "Problem pour interpréter la commande [%s]"
#: ../display/d.graph/main.c:56
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
-msgstr ""
-"Programme pour générer et afficher de simples graphiques dans le moniteur "
-"actif."
+msgid "Program for generating and displaying simple graphics on the display monitor."
+msgstr "Programme pour générer et afficher de simples graphiques dans le moniteur actif."
#: ../display/d.graph/main.c:63
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
-msgstr ""
-"Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les "
-"prendre à partirde la ligne de commande"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
+msgstr "Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les prendre à partirde la ligne de commande"
#: ../display/d.graph/main.c:71
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Couleur pour le traçage, soit une couleur GRASS standard, soit un triplet R:"
-"G:B"
+msgstr "Couleur pour le traçage, soit une couleur GRASS standard, soit un triplet R:G:B"
#: ../display/d.graph/main.c:78
msgid "Coordinates are given in map units"
@@ -21274,12 +21438,8 @@
#: ../display/d.rgb/main.c:56
#, fuzzy
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
-"Afficher trois couches rasters spécifiées par l'utilisateur comme calques "
-"rouge, vert, bleu superposés dans le moniteur actif."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
+msgstr "Afficher trois couches rasters spécifiées par l'utilisateur comme calques rouge, vert, bleu superposés dans le moniteur actif."
#: ../display/d.rgb/main.c:70
#, fuzzy, c-format
@@ -21299,71 +21459,93 @@
msgid "Finds shortest path for selected starting and ending node."
msgstr ""
-#: ../display/d.path/main.c:59 ../vector/v.net.iso/main.c:85
-#: ../vector/v.net.steiner/main.c:359 ../vector/v.net.alloc/main.c:75
-#: ../vector/v.net.salesman/main.c:110 ../vector/v.net.path/main.c:50
+#: ../display/d.path/main.c:59
+#: ../vector/v.net.iso/main.c:85
+#: ../vector/v.net.steiner/main.c:359
+#: ../vector/v.net.alloc/main.c:75
+#: ../vector/v.net.salesman/main.c:110
+#: ../vector/v.net.path/main.c:50
#, fuzzy
msgid "Arc type"
-#: ../display/d.path/main.c:71 ../vector/v.net.iso/main.c:89
-#: ../vector/v.net.steiner/main.c:364 ../vector/v.net/main.c:82
-#: ../vector/v.net.alloc/main.c:80 ../vector/v.net.salesman/main.c:114
+#: ../display/d.path/main.c:71
+#: ../vector/v.net.iso/main.c:89
+#: ../vector/v.net.steiner/main.c:364
+#: ../vector/v.net/main.c:82
+#: ../vector/v.net.alloc/main.c:80
+#: ../vector/v.net.salesman/main.c:114
#: ../vector/v.net.path/main.c:55
#, fuzzy
msgid "Arc layer"
msgstr "Requêter la couche"
-#: ../display/d.path/main.c:76 ../vector/v.net.iso/main.c:94
-#: ../vector/v.net/main.c:88 ../vector/v.net.alloc/main.c:85
+#: ../display/d.path/main.c:76
+#: ../vector/v.net.iso/main.c:94
+#: ../vector/v.net/main.c:88
+#: ../vector/v.net.alloc/main.c:85
#: ../vector/v.net.path/main.c:60
#, fuzzy
msgid "Node layer"
-#: ../display/d.path/main.c:82 ../vector/v.net.distance/main.c:113
+#: ../display/d.path/main.c:82
+#: ../vector/v.net.distance/main.c:113
#: ../vector/v.net.path/main.c:73
msgid "Arc forward/both direction(s) cost column"
msgstr ""
-#: ../display/d.path/main.c:88 ../vector/v.net.distance/main.c:118
+#: ../display/d.path/main.c:88
+#: ../vector/v.net.distance/main.c:118
#: ../vector/v.net.path/main.c:79
msgid "Arc backward direction cost column"
msgstr ""
-#: ../display/d.path/main.c:94 ../vector/v.net.path/main.c:85
+#: ../display/d.path/main.c:94
+#: ../vector/v.net.path/main.c:85
#, fuzzy
msgid "Node cost column"
msgstr "Nombre de colonnes"
-#: ../display/d.path/main.c:100 ../display/d.extract/main.c:65
+#: ../display/d.path/main.c:100
+#: ../display/d.extract/main.c:65
#, fuzzy
msgid "Original line color"
msgstr "Couleur de mise en valeur"
# c-format
-#: ../display/d.path/main.c:102 ../display/d.path/main.c:110
-#: ../display/d.path/main.c:118 ../display/d.path/main.c:128
+#: ../display/d.path/main.c:102
+#: ../display/d.path/main.c:110
+#: ../display/d.path/main.c:118
+#: ../display/d.path/main.c:128
#, fuzzy
msgid "Rendering"
msgstr "Lecture du fichier %s..."
-#: ../display/d.path/main.c:108 ../display/d.extract/main.c:71
+#: ../display/d.path/main.c:108
+#: ../display/d.extract/main.c:71
#, fuzzy
msgid "Highlight color"
msgstr "Couleur de mise en valeur du texte"
-#: ../display/d.path/main.c:116 ../general/g.pnmcomp/main.c:334
-#: ../vector/v.label/main.c:188 ../vector/v.lrs/v.lrs.label/main.c:228
+#: ../display/d.path/main.c:116
+#: ../general/g.pnmcomp/main.c:334
+#: ../vector/v.label/main.c:188
+#: ../vector/v.lrs/v.lrs.label/main.c:228
#: ../vector/v.label.sa/main.c:170
msgid "Background color"
msgstr "Couleur de fond"
-#: ../display/d.path/main.c:123 ../vector/v.net.iso/main.c:127
-#: ../vector/v.net.centrality/main.c:167 ../vector/v.net.steiner/main.c:394
-#: ../vector/v.net.distance/main.c:123 ../vector/v.net.alloc/main.c:117
-#: ../vector/v.net.spanningtree/main.c:64 ../vector/v.net.allpairs/main.c:89
-#: ../vector/v.net.salesman/main.c:136 ../vector/v.net.path/main.c:102
+#: ../display/d.path/main.c:123
+#: ../vector/v.net.iso/main.c:127
+#: ../vector/v.net.centrality/main.c:167
+#: ../vector/v.net.steiner/main.c:394
+#: ../vector/v.net.distance/main.c:123
+#: ../vector/v.net.alloc/main.c:117
+#: ../vector/v.net.spanningtree/main.c:64
+#: ../vector/v.net.allpairs/main.c:89
+#: ../vector/v.net.salesman/main.c:136
+#: ../vector/v.net.path/main.c:102
#, fuzzy
msgid "Use geodesic calculation for longitude-latitude locations"
msgstr "%s ne fonctionne pas avec un Secteur latitude-longitude"
@@ -21372,19 +21554,24 @@
msgid "Render bold lines"
msgstr ""
-#: ../display/d.path/main.c:146 ../display/d.path/main.c:150
+#: ../display/d.path/main.c:146
+#: ../display/d.path/main.c:150
#, fuzzy, c-format
msgid "%s - illegal x value"
msgstr "%s=%s - nom illégal"
-#: ../display/d.path/main.c:148 ../display/d.path/main.c:152
+#: ../display/d.path/main.c:148
+#: ../display/d.path/main.c:152
#, fuzzy, c-format
msgid "%s - illegal y value"
-#: ../display/d.path/main.c:185 ../vector/v.net.centrality/main.c:201
-#: ../vector/v.net.distance/main.c:153 ../vector/v.net.spanningtree/main.c:93
-#: ../vector/v.net.allpairs/main.c:122 ../vector/v.net.path/main.c:120
+#: ../display/d.path/main.c:185
+#: ../vector/v.net.centrality/main.c:201
+#: ../vector/v.net.distance/main.c:153
+#: ../vector/v.net.spanningtree/main.c:93
+#: ../vector/v.net.allpairs/main.c:122
+#: ../vector/v.net.path/main.c:120
msgid "The current projection is not longitude-latitude"
msgstr ""
@@ -21415,23 +21602,27 @@
"\n"
-#: ../display/d.path/select.c:65 ../display/d.path/select.c:242
+#: ../display/d.path/select.c:65
+#: ../display/d.path/select.c:242
#: ../display/d.path/select.c:259
#, c-format
msgid "Node %d: %f %f\n"
msgstr "Noeud %d: %f %f\n"
-#: ../display/d.path/select.c:149 ../display/d.path/select.c:280
+#: ../display/d.path/select.c:149
+#: ../display/d.path/select.c:280
#, c-format
msgid "Destination unreachable\n"
msgstr "Destination impossible à atteindre\n"
-#: ../display/d.path/select.c:153 ../display/d.path/select.c:283
+#: ../display/d.path/select.c:153
+#: ../display/d.path/select.c:283
#, c-format
msgid "Costs on the network = %f\n"
msgstr "Coûts pour le réseau = %f\n"
-#: ../display/d.path/select.c:154 ../display/d.path/select.c:284
+#: ../display/d.path/select.c:154
+#: ../display/d.path/select.c:284
#, fuzzy, c-format
msgid ""
" Distance to the network = %f, distance from the network = %f\n"
@@ -21439,12 +21630,8 @@
msgstr " Distance jusqu'au réseau = %f, distance depuis le réseau = %f\n"
#: ../display/d.rast.arrow/arrow.c:112
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
-"Tracer des flèches représentant la direction d'aspect des cellules pour une "
-"couche rastercontenant des données d'aspect."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+msgstr "Tracer des flèches représentant la direction d'aspect des cellules pour une couche rastercontenant des données d'aspect."
#: ../display/d.rast.arrow/arrow.c:121
msgid "Name of raster aspect map to be displayed"
@@ -21477,8 +21664,7 @@
#: ../display/d.rast.arrow/arrow.c:177
msgid "Raster map containing values used for arrow length"
-msgstr ""
-"Couche raster contenant les valeurs utilisées pour la longueur des flèches"
+msgstr "Couche raster contenant les valeurs utilisées pour la longueur des flèches"
#: ../display/d.rast.arrow/arrow.c:184
msgid "Scale factor for arrows (magnitude map)"
@@ -21518,21 +21704,15 @@
#: ../display/d.extract/extract.c:45
msgid " - L: draw box with left mouse button to select"
-msgstr ""
-" - L : dessiner la boîte avec le bouton gauche de la souris pour la "
-"sélectionner"
+msgstr " - L : dessiner la boîte avec le bouton gauche de la souris pour la sélectionner"
#: ../display/d.extract/extract.c:46
msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-" - M : dessiner la boîte avec le bouton du milieu de la souris pour la "
-"supprimer de l'affichage"
+msgstr " - M : dessiner la boîte avec le bouton du milieu de la souris pour la supprimer de l'affichage"
#: ../display/d.extract/extract.c:47
msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-" - R : quitter et enregistrer les couches vectorielles sélectionnées dans "
-"une nouvelle zone d'affichage\n"
+msgstr " - R : quitter et enregistrer les couches vectorielles sélectionnées dans une nouvelle zone d'affichage\n"
#: ../display/d.extract/extract.c:49
#, fuzzy
@@ -21541,9 +21721,7 @@
#: ../display/d.extract/main.c:52
msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-"Sélectionne et extraits des couches vectorielles avec la souris dans une "
-"nouvelle couche vectorielle."
+msgstr "Sélectionne et extraits des couches vectorielles avec la souris dans une nouvelle couche vectorielle."
#: ../display/d.extract/main.c:117
#, fuzzy
@@ -21556,9 +21734,7 @@
msgstr "Impossible de lire les informations de liaison à la base de données"
#: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
msgstr "Affiche la légende de la couche raster du moniteur actif."
#: ../display/d.legend/main.c:99
@@ -21567,15 +21743,11 @@
#: ../display/d.legend/main.c:107
msgid "Number of text lines (useful for truncating long legends)"
-msgstr ""
-"Nombre de lignes de texte (pratique pour tronquer les longs textes de "
-"légende)"
+msgstr "Nombre de lignes de texte (pratique pour tronquer les longs textes de légende)"
#: ../display/d.legend/main.c:116
msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
-msgstr ""
-"Facteur de discrétisation (thinning) (thin=10 donne les catégories "
-"0,10,20...)"
+msgstr "Facteur de discrétisation (thinning) (thin=10 donne les catégories 0,10,20...)"
#: ../display/d.legend/main.c:124
msgid "Number of text labels for smooth gradient legend"
@@ -21591,14 +21763,11 @@
#: ../display/d.legend/main.c:154
msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
-"Utiliser un sous-ensemble de l'intervalle des valeurs de la carte pour la "
-"légende (min, max)"
+msgstr "Utiliser un sous-ensemble de l'intervalle des valeurs de la carte pour la légende (min, max)"
#: ../display/d.legend/main.c:160
msgid "Use mouse to size & place legend"
-msgstr ""
#: ../display/d.legend/main.c:164
msgid "Do not show category labels"
@@ -21622,70 +21791,61 @@
msgid "Flip legend"
-#: ../display/d.legend/main.c:205 ../display/d.menu/main.c:113
-#: ../display/d.menu/main.c:119 ../display/d.menu/main.c:125
+#: ../display/d.legend/main.c:205
+#: ../display/d.menu/main.c:113
+#: ../display/d.menu/main.c:119
+#: ../display/d.menu/main.c:125
#, c-format
msgid "Don't know the color %s"
msgstr "Couleur %s inconnue"
#: ../display/d.legend/main.c:340
msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-"Le cartouche de légende dépasse du cadre. Il est possible que le texte ne "
-"s'affiche pas correctement"
+msgstr "Le cartouche de légende dépasse du cadre. Il est possible que le texte ne s'affiche pas correctement"
#: ../display/d.legend/main.c:344
#, fuzzy
msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
-"Disposition horizontale de la légende car la largeur du cartouche dépasse la "
-"hauteur.\n"
+msgstr "Disposition horizontale de la légende car la largeur du cartouche dépasse la hauteur.\n"
#: ../display/d.legend/main.c:355
#, fuzzy, c-format
msgid "Range information for <%s> not available (run r.support)"
-msgstr ""
-"Information sur l'intervalle de [%s] non disponible (exécutez r.support)"
+msgstr "Information sur l'intervalle de [%s] non disponible (exécutez r.support)"
#: ../display/d.legend/main.c:360
#, fuzzy
msgid "Input map contains no data"
msgstr "Le tableau ne contient pas de données"
-#: ../display/d.legend/main.c:373 ../display/d.legend/main.c:531
+#: ../display/d.legend/main.c:373
+#: ../display/d.legend/main.c:531
msgid "Color range exceeds lower limit of actual data"
-msgstr ""
-"Les valeurs de couleurs excède la limite plancher des données actuelles"
+msgstr "Les valeurs de couleurs excède la limite plancher des données actuelles"
-#: ../display/d.legend/main.c:379 ../display/d.legend/main.c:535
+#: ../display/d.legend/main.c:379
+#: ../display/d.legend/main.c:535
msgid "Color range exceeds upper limit of actual data"
-msgstr ""
-"Les valeurs de couleurs dépassent la limite plafond des données actuelles"
+msgstr "Les valeurs de couleurs dépassent la limite plafond des données actuelles"
#: ../display/d.legend/main.c:436
#, fuzzy, c-format
msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr ""
-"utilisation=%s hors de l'intervalle [%d,%d]. (étendre à l'intervalle= ?)"
+msgstr "utilisation=%s hors de l'intervalle [%d,%d]. (étendre à l'intervalle= ?)"
#: ../display/d.legend/main.c:477
msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
-"Rien à dessiner! (pas de catégories liées aux étiquettes? valeurs hors "
-"intervalles?"
+msgstr "Rien à dessiner! (pas de catégories liées aux étiquettes? valeurs hors intervalles?"
#: ../display/d.legend/main.c:487
#, fuzzy
msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-"Utilisation forcée d'une légende simplifiée : trop de catégories pour la "
-"taille courante de la fenêtre.\n"
+msgstr "Utilisation forcée d'une légende simplifiée : trop de catégories pour la taille courante de la fenêtre.\n"
#: ../display/d.legend/main.c:542
#, fuzzy, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
-msgstr ""
-"utilisation=%s hors de l'intervalle [%.3f, %.3f]. (étendre à l'intervalle= ?)"
+msgstr "utilisation=%s hors de l'intervalle [%.3f, %.3f]. (étendre à l'intervalle= ?)"
#: ../display/d.legend/main.c:901
msgid "Nothing to draw! (no categories with labels?)"
@@ -21698,8 +21858,7 @@
#: ../display/d.menu/main.c:68
#, fuzzy
-msgid ""
-"Creates and displays a menu within the active frame on the graphics monitor."
+msgid "Creates and displays a menu within the active frame on the graphics monitor."
#: ../display/d.menu/main.c:77
@@ -21730,12 +21889,8 @@
msgstr "Afficher l'index"
#: ../display/d.measure/main.c:51
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
-msgstr ""
-"Mesure les longueurs et les surfaces des objets dessinés par l'utilisateur "
-"dans le cadre actif du moniteur graphique."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
+msgstr "Mesure les longueurs et les surfaces des objets dessinés par l'utilisateur dans le cadre actif du moniteur graphique."
#: ../display/d.measure/main.c:57
msgid "Line color 1"
@@ -21845,12 +22000,8 @@
msgstr ""
#: ../display/d.nviz/main.c:538
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-"Ce point est ignoré, il est en dehors de la région. Peut-être que la "
-"distance focale de la caméra le place au-delà du bord?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr "Ce point est ignoré, il est en dehors de la région. Peut-être que la distance focale de la caméra le place au-delà du bord?"
#: ../display/d.extend/main.c:52
#, fuzzy
@@ -21858,8 +22009,7 @@
msgstr "Nom de la couche raster d'aspect à afficher"
#: ../display/d.title/main.c:47
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
msgstr ""
#: ../display/d.title/main.c:58
@@ -21926,16 +22076,21 @@
#: ../display/d.font/main.c:126
#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
msgstr ""
-#: ../general/g.filename/main.c:39 ../general/g.access/main.c:37
-#: ../general/g.tempfile/main.c:36 ../general/g.findfile/main.c:35
-#: ../general/g.mremove/main.c:58 ../general/g.mlist/main.c:65
-#: ../general/manage/cmd/remove.c:99 ../general/manage/cmd/rename.c:40
-#: ../general/manage/cmd/list.c:41 ../general/manage/cmd/copy.c:39
-#: ../general/g.ask/main.c:40 ../general/g.findetc/main.c:28
+#: ../general/g.filename/main.c:39
+#: ../general/g.access/main.c:37
+#: ../general/g.tempfile/main.c:36
+#: ../general/g.findfile/main.c:35
+#: ../general/g.mremove/main.c:58
+#: ../general/g.mlist/main.c:65
+#: ../general/manage/cmd/remove.c:99
+#: ../general/manage/cmd/rename.c:40
+#: ../general/manage/cmd/list.c:41
+#: ../general/manage/cmd/copy.c:39
+#: ../general/g.ask/main.c:40
+#: ../general/g.findetc/main.c:28
msgid "general, map management"
msgstr ""
@@ -21943,7 +22098,8 @@
msgid "Prints GRASS data base file names."
msgstr "Affiche les noms de fichiers de base de données"
-#: ../general/g.filename/main.c:48 ../general/g.findfile/main.c:48
+#: ../general/g.filename/main.c:48
+#: ../general/g.findfile/main.c:48
msgid "Name of an element"
msgstr "Nom d'un élément"
@@ -21955,7 +22111,8 @@
msgid "Name of a mapset (default: current)"
msgstr "Nom du jeu de données (par défaut : le jeu de données courant)"
-#: ../general/g.gui/main.c:36 ../general/g.pnmcomp/main.c:281
+#: ../general/g.gui/main.c:36
+#: ../general/g.pnmcomp/main.c:281
#, fuzzy
msgid "general, gui"
msgstr "Projection source"
@@ -21974,10 +22131,7 @@
msgstr ""
#: ../general/g.gui/main.c:45
-msgid ""
-"wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
-"(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command "
-"line interface only"
+msgid "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
msgstr ""
#: ../general/g.gui/main.c:54
@@ -22049,9 +22203,7 @@
#: ../general/g.transform/main.c:322
#, fuzzy
msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-"Recale une image en calculer la transformation de coordonnées pour chaque "
-"pixel de l'image basée sur des points d'amer"
+msgstr "Recale une image en calculer la transformation de coordonnées pour chaque pixel de l'image basée sur des points d'amer"
#: ../general/g.transform/main.c:331
#, fuzzy
@@ -22059,14 +22211,11 @@
msgstr "Ordre du polynome de recalage (1-3)"
#: ../general/g.transform/main.c:339
-msgid ""
-"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-"forward coordinates difference (destination);rxy;reverse coordinates "
-"difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
msgstr ""
-#: ../general/g.transform/main.c:349 ../vector/v.out.ascii/out.c:63
+#: ../general/g.transform/main.c:349
+#: ../vector/v.out.ascii/out.c:63
msgid "Output format"
msgstr "Format de sortie"
@@ -22130,7 +22279,8 @@
msgid "Unable to determine mapset permissions"
msgstr "Impossible de déterminer le type de cellule raster"
-#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+#: ../general/g.access/exp_perms.c:11
+#: ../general/g.access/exp_perms.c:29
msgid "have"
msgstr ""
@@ -22191,9 +22341,7 @@
#: ../general/g.findfile/main.c:79
#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
msgstr ""
# c-format
@@ -22236,18 +22384,11 @@
#: ../general/g.proj/create.c:36
#, fuzzy, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
-msgstr ""
-"Vous devez sélectionner le jeu de données PERMANENT avant de mettre à jour "
-"la projectiondu Secteur courant. (Le jeu de données courant est %s)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
+msgstr "Vous devez sélectionner le jeu de données PERMANENT avant de mettre à jour la projectiondu Secteur courant. (Le jeu de données courant est %s)"
#: ../general/g.proj/create.c:63
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
msgstr ""
#: ../general/g.proj/create.c:67
@@ -22258,16 +22399,15 @@
"Information de projection mise à jour!\n"
"\n"
-#: ../general/g.proj/main.c:63 ../general/g.setproj/main.c:78
+#: ../general/g.proj/main.c:63
+#: ../general/g.setproj/main.c:78
#, fuzzy
msgid "general, projection"
#: ../general/g.proj/main.c:66
#, fuzzy
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
msgstr "Affiche et manipule les fichiers d'information de projection GRASS"
#: ../general/g.proj/main.c:69
@@ -22291,19 +22431,15 @@
#: ../general/g.proj/main.c:91
msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Vérifier l'information de datum et afficher les paramètres de transformation"
+msgstr "Vérifier l'information de datum et afficher les paramètres de transformation"
#: ../general/g.proj/main.c:97
msgid "Print projection information in PROJ.4 format"
msgstr "Afficher l'information de projection au format PROJ.4"
#: ../general/g.proj/main.c:103
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-"Afficher une sortie 'à plat' sans sauts de ligne (s'applique à la sortie WKT "
-"et PROJ.4)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr "Afficher une sortie 'à plat' sans sauts de ligne (s'applique à la sortie WKT et PROJ.4)"
#: ../general/g.proj/main.c:113
msgid "Print projection information in WKT format"
@@ -22313,8 +22449,10 @@
msgid "Use ESRI-style format (applies to WKT output only)"
msgstr "Utilisez le format style-ESRI (s'applique à la sortie WKT seulement)"
-#: ../general/g.proj/main.c:126 ../general/g.proj/main.c:135
-#: ../general/g.proj/main.c:145 ../general/g.proj/main.c:155
+#: ../general/g.proj/main.c:126
+#: ../general/g.proj/main.c:135
+#: ../general/g.proj/main.c:145
+#: ../general/g.proj/main.c:155
#, fuzzy
msgid "Specification"
msgstr "** mauvaise indication de couleur **\n"
@@ -22327,16 +22465,13 @@
#: ../general/g.proj/main.c:136
#, fuzzy
msgid "Name of ASCII file containing a WKT projection description"
-msgstr ""
-"Fichier ASCII contenant une description de projection WKT en une ligne (- "
-"pour stdin)"
+msgstr "Fichier ASCII contenant une description de projection WKT en une ligne (- pour stdin)"
-#: ../general/g.proj/main.c:138 ../general/g.proj/main.c:147
+#: ../general/g.proj/main.c:138
+#: ../general/g.proj/main.c:147
#, fuzzy
msgid "'-' for standard input"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../general/g.proj/main.c:146
#, fuzzy
@@ -22348,7 +22483,8 @@
msgid "EPSG projection code"
msgstr "Méthode de reprojection à utiliser"
-#: ../general/g.proj/main.c:164 ../general/g.proj/main.c:177
+#: ../general/g.proj/main.c:164
+#: ../general/g.proj/main.c:177
#: ../general/g.proj/main.c:183
msgid "Datum"
msgstr ""
@@ -22364,27 +22500,23 @@
#: ../general/g.proj/main.c:178
#, fuzzy
msgid "Index number of datum transform parameters"
-msgstr ""
#: ../general/g.proj/main.c:179
msgid "\"0\" for unspecified or \"-1\" to list and exit"
msgstr ""
#: ../general/g.proj/main.c:185
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
msgstr ""
#: ../general/g.proj/main.c:191
#, fuzzy
msgid "Create new projection files (modifies current location)"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
-#: ../general/g.proj/main.c:199 ../general/g.mapset/main.c:82
+#: ../general/g.proj/main.c:199
+#: ../general/g.mapset/main.c:82
#: ../locale/scriptstrings/r.mask_to_translate.c:4
#: ../locale/scriptstrings/r.mask_to_translate.c:6
#: ../locale/scriptstrings/r.mask_to_translate.c:8
@@ -22444,7 +22576,8 @@
msgid "Trying to open with OGR..."
msgstr "Essai d'ouverture à l'aide d'OGR..."
-#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
+#: ../general/g.proj/input.c:226
+#: ../general/g.proj/input.c:245
msgid "...succeeded."
msgstr "...réussi."
@@ -22455,24 +22588,20 @@
#: ../general/g.proj/input.c:254
#, fuzzy, c-format
msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr ""
-"Impossible de lire le fichier géoréférencé %s à l'aide de GDAL ni d'OGR"
+msgstr "Impossible de lire le fichier géoréférencé %s à l'aide de GDAL ni d'OGR"
#: ../general/g.proj/input.c:259
#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"La lecture du fichier %s a fonctionné, mais elle ne contenait pas "
-"d'information de projection. 'XY (sans projection)' va être utilisé"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "La lecture du fichier %s a fonctionné, mais elle ne contenait pas d'information de projection. 'XY (sans projection)' va être utilisé"
#: ../general/g.proj/output.c:182
#, c-format
msgid "%s: Unable to convert to WKT"
msgstr "%s : impossible de convertir en WKT"
-#: ../general/g.mremove/read_list.c:144 ../general/g.mlist/read_list.c:144
+#: ../general/g.mremove/read_list.c:144
+#: ../general/g.mlist/read_list.c:144
#, c-format
msgid ""
"Format error: <%s>\n"
@@ -22486,7 +22615,8 @@
msgid "Removing %s <%s>"
-#: ../general/g.mremove/do_remove.c:42 ../general/g.mremove/do_remove.c:84
+#: ../general/g.mremove/do_remove.c:42
+#: ../general/g.mremove/do_remove.c:84
#, fuzzy
msgid "couldn't be removed"
msgstr "Icone à supprimer"
@@ -22496,12 +22626,14 @@
msgid "%s: couldn't be removed"
msgstr "%s fichier(s) à supprimer"
-#: ../general/g.mremove/do_remove.c:67 ../general/g.mremove/do_remove.c:89
+#: ../general/g.mremove/do_remove.c:67
+#: ../general/g.mremove/do_remove.c:89
#, c-format
msgid "%s: missing"
msgstr ""
-#: ../general/g.mremove/do_remove.c:71 ../general/g.mremove/do_remove.c:93
+#: ../general/g.mremove/do_remove.c:71
+#: ../general/g.mremove/do_remove.c:93
#, fuzzy, c-format
msgid "%s: removed"
msgstr "%-5d centroïdes lus\n"
@@ -22512,35 +22644,39 @@
msgid "<%s> nothing removed"
msgstr "<%s> non trouvé\n"
-#: ../general/g.mremove/check_reclass.c:14 ../general/manage/cmd/remove.c:38
+#: ../general/g.mremove/check_reclass.c:14
+#: ../general/manage/cmd/remove.c:38
#, c-format
msgid "[%s@%s] is a base map for [%s]. Remove forced."
msgstr ""
-#: ../general/g.mremove/check_reclass.c:18 ../general/manage/cmd/remove.c:41
+#: ../general/g.mremove/check_reclass.c:18
+#: ../general/manage/cmd/remove.c:41
#, c-format
msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
msgstr ""
#: ../general/g.mremove/check_reclass.c:41
-#: ../general/g.mremove/check_reclass.c:55 ../general/manage/cmd/remove.c:63
+#: ../general/g.mremove/check_reclass.c:55
+#: ../general/manage/cmd/remove.c:63
#: ../general/manage/cmd/remove.c:76
#, c-format
msgid "Removing information about reclassed map from [%s@%s] failed"
msgstr ""
-#: ../general/g.mremove/main.c:60 ../general/manage/cmd/remove.c:101
+#: ../general/g.mremove/main.c:60
+#: ../general/manage/cmd/remove.c:101
msgid "Removes data base element files from the user's current mapset."
-msgstr ""
-"Supprimer les fichiers éléments de base de données du jeu de données courant "
-"de l'utilisateur"
+msgstr "Supprimer les fichiers éléments de base de données du jeu de données courant de l'utilisateur"
-#: ../general/g.mremove/main.c:66 ../general/g.mlist/main.c:128
+#: ../general/g.mremove/main.c:66
+#: ../general/g.mlist/main.c:128
#, fuzzy
msgid "Use basic regular expressions instead of wildcards"
msgstr "utiliser une expression régulière à la place d'une wildcard"
-#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:134
+#: ../general/g.mremove/main.c:71
+#: ../general/g.mlist/main.c:134
#, fuzzy
msgid "Use extended regular expressions instead of wildcards"
@@ -22556,24 +22692,25 @@
msgid "Remove base maps"
msgstr "couche raster de couverture"
-#: ../general/g.mremove/main.c:96 ../general/manage/cmd/remove.c:120
+#: ../general/g.mremove/main.c:96
+#: ../general/manage/cmd/remove.c:120
#, c-format
msgid "%s file(s) to be removed"
-#: ../general/g.mremove/main.c:104 ../general/g.mlist/main.c:163
+#: ../general/g.mremove/main.c:104
+#: ../general/g.mlist/main.c:163
#, fuzzy
msgid "-r and -e are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
#: ../general/g.mremove/main.c:107
msgid "The following files would be deleted:"
msgstr ""
# c-format
-#: ../general/g.mremove/main.c:130 ../general/g.mlist/main.c:172
+#: ../general/g.mremove/main.c:130
+#: ../general/g.mlist/main.c:172
#: ../general/g.mlist/main.c:183
#, fuzzy, c-format
msgid "Unable to compile regular expression %s"
@@ -22583,7 +22720,8 @@
msgid "You must use the force flag to actually remove them. Exiting."
msgstr ""
-#: ../general/g.mapset/main.c:48 ../general/g.gisenv/main.c:38
+#: ../general/g.mapset/main.c:48
+#: ../general/g.gisenv/main.c:38
#: ../general/g.region/main.c:72
#, fuzzy
msgid "general, settings"
@@ -22595,8 +22733,7 @@
msgstr "Sauvegarder cadre graphique actif"
#: ../general/g.mapset/main.c:50
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
msgstr ""
#: ../general/g.mapset/main.c:57
@@ -22609,8 +22746,7 @@
msgstr ""
#: ../general/g.mapset/main.c:75
-msgid ""
-"GIS data directory (full path to the directory where the new location is)"
+msgid "GIS data directory (full path to the directory where the new location is)"
msgstr ""
#: ../general/g.mapset/main.c:80
@@ -22640,8 +22776,7 @@
#: ../general/g.mapset/main.c:156
#, fuzzy
msgid "The mapset does not exist. Use -c flag to create it."
-msgstr ""
-"La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
+msgstr "La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
#: ../general/g.mapset/main.c:165
#, fuzzy
@@ -22650,9 +22785,7 @@
#: ../general/g.mapset/main.c:179
#, c-format
-msgid ""
-"%s is currently running GRASS in selected mapset or lock file cannot be "
-"checked"
+msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
msgstr ""
# c-format
@@ -22691,22 +22824,18 @@
#: ../general/g.mlist/main.c:67
#, fuzzy
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Lister les fichiers de base de données GRASS disponibles du type spécifié "
-"par l'utilisateur vers la sortie standard."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur vers la sortie standard."
#: ../general/g.mlist/main.c:97
#, fuzzy
msgid "Map name search pattern (default: all)"
-msgstr ""
-"motif à recherche dans le nom de couche, doit être entre simples guillemets "
-"(par défaut: tous)"
+msgstr "motif à recherche dans le nom de couche, doit être entre simples guillemets (par défaut: tous)"
-#: ../general/g.mlist/main.c:98 ../general/g.mlist/main.c:106
-#: ../general/g.mlist/main.c:129 ../general/g.mlist/main.c:135
+#: ../general/g.mlist/main.c:98
+#: ../general/g.mlist/main.c:106
+#: ../general/g.mlist/main.c:129
+#: ../general/g.mlist/main.c:135
#, fuzzy
msgid "Pattern"
msgstr "Valeur raster"
@@ -22714,15 +22843,14 @@
#: ../general/g.mlist/main.c:105
#, fuzzy
msgid "Map name exclusion pattern (default: none)"
-msgstr ""
#: ../general/g.mlist/main.c:115
msgid "One-character output separator, newline, comma, space, or tab"
msgstr ""
-#: ../general/g.mlist/main.c:123 ../general/manage/cmd/list.c:72
+#: ../general/g.mlist/main.c:123
+#: ../general/manage/cmd/list.c:72
#, fuzzy
msgid "Mapset to list (default: current search path)"
msgstr "jeu de données à lister (par défaut : chemin de recherche courant)"
@@ -22741,7 +22869,8 @@
msgid "Pretty printing in human readable format"
msgstr "Supprimer l'affichage des informations d'en-tête"
-#: ../general/g.mlist/main.c:154 ../general/manage/cmd/list.c:76
+#: ../general/g.mlist/main.c:154
+#: ../general/manage/cmd/list.c:76
#, fuzzy
msgid "Verbose listing (also list map titles)"
msgstr "Sortie détaillée (lister aussi les titres de couches)"
@@ -22777,9 +22906,7 @@
#: ../general/g.gisenv/main.c:40
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Affiche et modifie les réglages actuels de l'utilisateur pour les variables "
-"GRASS"
+msgstr "Affiche et modifie les réglages actuels de l'utilisateur pour les variables GRASS"
#: ../general/g.gisenv/main.c:45
msgid "GRASS variable to get"
@@ -22804,9 +22931,7 @@
#: ../general/g.gisenv/main.c:76
#, fuzzy
msgid "-s and -n are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../general/manage/cmd/remove.c:106
#, fuzzy
@@ -22815,9 +22940,7 @@
#: ../general/manage/cmd/rename.c:42
msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"Renommer les fichiers éléments de la base de données dans le jeu de données "
-"courant de l'utilisateur"
+msgstr "Renommer les fichiers éléments de la base de données dans le jeu de données courant de l'utilisateur"
#: ../general/manage/cmd/rename.c:57
#, c-format
@@ -22838,9 +22961,7 @@
#: ../general/manage/cmd/rename.c:89
#, fuzzy, c-format
msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr ""
-"%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les "
-"renommer\n"
+msgstr "%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les renommer\n"
# c-format
#: ../general/manage/cmd/rename.c:99
@@ -22851,19 +22972,11 @@
#: ../general/manage/cmd/list.c:43
#, fuzzy
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
#: ../general/manage/cmd/copy.c:41
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
-msgstr ""
-"Copier les fichiers de données disponibles dans le chemin de recherche et le "
-"Secteur vers le répertoire approprié sous le jeu de données courant de "
-"l'utilisateur."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
+msgstr "Copier les fichiers de données disponibles dans le chemin de recherche et le Secteur vers le répertoire approprié sous le jeu de données courant de l'utilisateur."
#: ../general/manage/cmd/copy.c:58
#, c-format
@@ -22879,9 +22992,7 @@
#: ../general/manage/cmd/copy.c:79
#, fuzzy, c-format
msgid "%s=%s,%s: files are the same, no copy required"
-msgstr ""
-"copier\n"
+msgstr "%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les copier\n"
#: ../general/manage/cmd/copy.c:84
#, fuzzy, c-format
@@ -22891,12 +23002,14 @@
#: ../general/g.region/main.c:74
#, fuzzy
msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
-"Définition de l'emprise de la région géographique pour une couche raster."
+msgstr "Définition de l'emprise de la région géographique pour une couche raster."
-#: ../general/g.region/main.c:81 ../general/g.region/main.c:86
-#: ../general/g.region/main.c:174 ../general/g.region/main.c:181
-#: ../general/g.region/main.c:190 ../general/g.region/main.c:197
+#: ../general/g.region/main.c:81
+#: ../general/g.region/main.c:86
+#: ../general/g.region/main.c:174
+#: ../general/g.region/main.c:181
+#: ../general/g.region/main.c:190
+#: ../general/g.region/main.c:197
#: ../general/g.region/main.c:207
msgid "Existing"
msgstr "Existant"
@@ -22913,9 +23026,7 @@
#: ../general/g.region/main.c:95
#, fuzzy
msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Afficher la région courante en latitude/longitude à partir de l'ellipsoïde/"
-"datum courants"
+msgstr "Afficher la région courante en latitude/longitude à partir de l'ellipsoïde/datum courants"
#: ../general/g.region/main.c:101
msgid "Print the current region extent"
@@ -22944,9 +23055,7 @@
msgstr ""
#: ../general/g.region/main.c:132
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
msgstr ""
#: ../general/g.region/main.c:138
@@ -22956,26 +23065,23 @@
#: ../general/g.region/main.c:144
#, fuzzy
msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr ""
-"Affiche la boîte englobante maximale en latitude/longitude en WGS84 "
-"(seulement en mode -g)"
+msgstr "Affiche la boîte englobante maximale en latitude/longitude en WGS84 (seulement en mode -g)"
#: ../general/g.region/main.c:155
#, fuzzy
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Ajuster la région à la résolution (par défaut, alignement sur les limites de "
-"l'emprise,fonctionne seulement pour la résolution 2D)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Ajuster la région à la résolution (par défaut, alignement sur les limites de l'emprise,fonctionne seulement pour la résolution 2D)"
#: ../general/g.region/main.c:161
msgid "Do not update the current region"
msgstr "Ne pas modifier la région courante"
-#: ../general/g.region/main.c:162 ../general/g.region/main.c:365
-#: ../vector/v.label/main.c:91 ../vector/v.label/main.c:96
-#: ../vector/v.label/main.c:171 ../vector/v.label/main.c:184
+#: ../general/g.region/main.c:162
+#: ../general/g.region/main.c:365
+#: ../vector/v.label/main.c:91
+#: ../vector/v.label/main.c:96
+#: ../vector/v.label/main.c:171
+#: ../vector/v.label/main.c:184
msgid "Effects"
msgstr "Effets"
@@ -22985,9 +23091,7 @@
#: ../general/g.region/main.c:188
msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-"Ajuster l'emprise de la région sur cette couche raster 3D (pour les valeurs "
-"2D et 3D)"
+msgstr "Ajuster l'emprise de la région sur cette couche raster 3D (pour les valeurs 2D et 3D)"
#: ../general/g.region/main.c:255
msgid "Value for the top edge"
@@ -23002,9 +23106,12 @@
msgid "Number of rows in the new region"
msgstr "Nombre de lignes à garder en mémoire"
-#: ../general/g.region/main.c:274 ../general/g.region/main.c:283
-#: ../general/g.region/main.c:293 ../general/g.region/main.c:303
-#: ../general/g.region/main.c:313 ../general/g.region/main.c:323
+#: ../general/g.region/main.c:274
+#: ../general/g.region/main.c:283
+#: ../general/g.region/main.c:293
+#: ../general/g.region/main.c:303
+#: ../general/g.region/main.c:313
+#: ../general/g.region/main.c:323
#: ../general/g.region/main.c:332
msgid "Resolution"
msgstr "Résolution"
@@ -23110,7 +23217,8 @@
msgid "Could not read from <%s>"
msgstr "Impossible de lire <%s>"
-#: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:516
+#: ../general/g.region/printwindow.c:263
+#: ../general/g.region/printwindow.c:516
#: ../general/g.region/printwindow.c:647
#, fuzzy
msgid "Unable to update lat/long projection parameters"
@@ -23121,19 +23229,12 @@
msgstr ""
#: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
msgstr ""
#: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"Impossible de projeter les données en WGS84 étant donné que ce Secteur ne "
-"possède pas deparamètres de transformation de datume. Essayez de lancer g."
-"setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "Impossible de projeter les données en WGS84 étant donné que ce Secteur ne possède pas deparamètres de transformation de datume. Essayez de lancer g.setproj."
#: ../general/g.region/printwindow.c:783
msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -23209,8 +23310,7 @@
#: ../general/g.setproj/main.c:216
#, fuzzy
msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
#: ../general/g.setproj/main.c:224
#, fuzzy
@@ -23241,7 +23341,8 @@
msgid "Do you want to change the radius?"
msgstr "Souhaitez-vous poursuivre?"
-#: ../general/g.setproj/main.c:313 ../general/g.setproj/main.c:319
+#: ../general/g.setproj/main.c:313
+#: ../general/g.setproj/main.c:319
#, fuzzy
msgid "Enter radius for the sphere in meters"
msgstr "Rayon minimal pour le cercle/l'anneau (en mètres)"
@@ -23267,10 +23368,7 @@
msgstr "Les informations de projection ne seront pas mises à jour."
#: ../general/g.setproj/main.c:455
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
msgstr ""
#: ../general/g.setproj/main.c:460
@@ -23378,8 +23476,10 @@
msgstr "Erreur de lecture de la ligne de données"
# c-format
-#: ../general/g.pnmcomp/main.c:68 ../general/g.pnmcomp/main.c:73
-#: ../general/g.pnmcomp/main.c:82 ../general/g.pnmcomp/main.c:133
+#: ../general/g.pnmcomp/main.c:68
+#: ../general/g.pnmcomp/main.c:73
+#: ../general/g.pnmcomp/main.c:82
+#: ../general/g.pnmcomp/main.c:133
#: ../general/g.pnmcomp/main.c:146
#, fuzzy
msgid "Invalid PPM file"
@@ -23404,7 +23504,8 @@
msgstr "Nombre invalide d'étapes: %s"
# c-format
-#: ../general/g.pnmcomp/main.c:124 ../general/g.pnmcomp/main.c:141
+#: ../general/g.pnmcomp/main.c:124
+#: ../general/g.pnmcomp/main.c:141
#, fuzzy
msgid "Invalid PGM file"
msgstr "Etiquette date&heure invalide"
@@ -23458,16 +23559,17 @@
msgstr "Afficher également les paramètres 3D"
#: ../general/g.message/main.c:35
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
msgstr ""
#: ../general/g.message/main.c:37
msgid "This module should be used in scripts for messages served to user."
msgstr ""
-#: ../general/g.message/main.c:41 ../general/g.message/main.c:46
-#: ../general/g.message/main.c:51 ../general/g.message/main.c:56
+#: ../general/g.message/main.c:41
+#: ../general/g.message/main.c:46
+#: ../general/g.message/main.c:51
+#: ../general/g.message/main.c:56
#, fuzzy
msgid "Type"
msgstr "Type inconnu"
@@ -23489,7 +23591,8 @@
msgid "Print message as progress info"
msgstr ""
-#: ../general/g.message/main.c:61 ../general/g.message/main.c:66
+#: ../general/g.message/main.c:61
+#: ../general/g.message/main.c:66
#: ../general/g.message/main.c:80
msgid "Level"
msgstr ""
@@ -23548,20 +23651,16 @@
#: ../general/g.mapsets/main.c:61
#, fuzzy
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-"l'utilisateur."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
#: ../general/g.mapsets/main.c:69
#, fuzzy
msgid "Name(s) of existing mapset(s)"
msgstr "Nom des couches raster existantes"
-#: ../general/g.mapsets/main.c:70 ../general/g.mapsets/main.c:79
+#: ../general/g.mapsets/main.c:70
+#: ../general/g.mapsets/main.c:79
#: ../general/g.mapsets/main.c:88
msgid "Search path"
msgstr ""
@@ -23601,7 +23700,8 @@
msgid "Show mapset selection dialog"
msgstr ""
-#: ../general/g.mapsets/main.c:132 ../general/g.mapsets/main.c:161
+#: ../general/g.mapsets/main.c:132
+#: ../general/g.mapsets/main.c:161
#, fuzzy, c-format
msgid "Mapset <%s> not found"
msgstr "raster <%s> non trouvé"
@@ -23630,9 +23730,12 @@
msgid "** no mapsets **\n"
msgstr ""
-#: ../vector/v.random/main.c:84 ../vector/v.univar/main.c:93
-#: ../vector/v.kcv/main.c:76 ../vector/v.qcount/main.c:69
-#: ../vector/lidar/v.outlier/main.c:73 ../vector/v.normal/main.c:79
+#: ../vector/v.random/main.c:84
+#: ../vector/v.univar/main.c:93
+#: ../vector/v.kcv/main.c:76
+#: ../vector/v.qcount/main.c:69
+#: ../vector/lidar/v.outlier/main.c:73
+#: ../vector/v.normal/main.c:79
#: ../vector/v.class/main.c:45
#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
@@ -23654,8 +23757,10 @@
msgid "Minimum z height (needs -z flag or column name)"
msgstr "Hauteur z minimum (requiert le drapeau -z)"
-#: ../vector/v.random/main.c:102 ../vector/v.random/main.c:111
-#: ../vector/v.random/main.c:123 ../vector/v.random/main.c:128
+#: ../vector/v.random/main.c:102
+#: ../vector/v.random/main.c:111
+#: ../vector/v.random/main.c:123
+#: ../vector/v.random/main.c:128
#, fuzzy
msgid "3D output"
msgstr "Crée une sortie 3D"
@@ -23670,12 +23775,11 @@
msgstr ""
#: ../vector/v.random/main.c:121
-msgid ""
-"If type is not given then DOUBLE PRECISION is used. Writes Z data to column "
-"instead of 3D vector."
+msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
msgstr ""
-#: ../vector/v.random/main.c:127 ../vector/v.in.ogr/main.c:211
+#: ../vector/v.random/main.c:127
+#: ../vector/v.in.ogr/main.c:211
msgid "Create 3D output"
@@ -23684,7 +23788,8 @@
msgid "Use drand48() function instead of rand()"
msgstr "Utilise la fonction drand48() (par défaut=rand() )"
-#: ../vector/v.random/main.c:136 ../vector/v.edit/args.c:216
+#: ../vector/v.random/main.c:136
+#: ../vector/v.edit/args.c:216
#: ../vector/v.in.dxf/main.c:74
#, fuzzy
msgid "Do not build topology"
@@ -23710,9 +23815,7 @@
msgstr ""
#: ../vector/v.random/main.c:234
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
msgstr ""
# c-format
@@ -23731,29 +23834,27 @@
msgstr "Importation vecteur complète"
#: ../vector/v.net.iso/main.c:75
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
msgstr ""
-#: ../vector/v.net.iso/main.c:99 ../vector/v.net.alloc/main.c:92
+#: ../vector/v.net.iso/main.c:99
+#: ../vector/v.net.alloc/main.c:92
msgid "Arc forward/both direction(s) cost column (number)"
msgstr ""
-#: ../vector/v.net.iso/main.c:103 ../vector/v.net.alloc/main.c:98
+#: ../vector/v.net.iso/main.c:103
+#: ../vector/v.net.alloc/main.c:98
msgid "Arc backward direction cost column (number)"
msgstr ""
-#: ../vector/v.net.iso/main.c:107 ../vector/v.net.alloc/main.c:104
+#: ../vector/v.net.iso/main.c:107
+#: ../vector/v.net.alloc/main.c:104
#, fuzzy
msgid "Node cost column (number)"
#: ../vector/v.net.iso/main.c:113
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
msgstr ""
#: ../vector/v.net.iso/main.c:122
@@ -23789,7 +23890,8 @@
msgid "Number of centres: %d (nlayer %d)"
msgstr "Nombre de points en entrée : %d."
-#: ../vector/v.net.iso/main.c:227 ../vector/v.net.alloc/main.c:189
+#: ../vector/v.net.iso/main.c:227
+#: ../vector/v.net.alloc/main.c:189
msgid "Not enough centres for selected nlayer. Nothing will be allocated."
msgstr ""
@@ -23798,7 +23900,8 @@
msgid "Calculating costs from centre %d..."
msgstr "Calcul des moyennes de classes..."
-#: ../vector/v.net.iso/main.c:508 ../vector/v.net.alloc/main.c:340
+#: ../vector/v.net.iso/main.c:508
+#: ../vector/v.net.alloc/main.c:340
#: ../vector/v.net.alloc/main.c:351
#, fuzzy
msgid "Cannot get line segment, segment out of line"
@@ -23810,22 +23913,24 @@
#: ../vector/v.net.centrality/main.c:97
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
msgstr ""
-#: ../vector/v.net.centrality/main.c:115 ../vector/v.net.allpairs/main.c:77
+#: ../vector/v.net.centrality/main.c:115
+#: ../vector/v.net.allpairs/main.c:77
msgid "Name of arc forward/both direction(s) cost column"
msgstr ""
-#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:122
-#: ../vector/v.net.allpairs/main.c:78 ../vector/v.net.allpairs/main.c:84
+#: ../vector/v.net.centrality/main.c:116
+#: ../vector/v.net.centrality/main.c:122
+#: ../vector/v.net.allpairs/main.c:78
+#: ../vector/v.net.allpairs/main.c:84
#, fuzzy
msgid "Cost"
msgstr "Contraste"
-#: ../vector/v.net.centrality/main.c:121 ../vector/v.net.allpairs/main.c:83
+#: ../vector/v.net.centrality/main.c:121
+#: ../vector/v.net.allpairs/main.c:83
msgid "Name of arc backward direction cost column"
msgstr ""
@@ -23834,8 +23939,10 @@
msgid "Name of degree centrality column"
-#: ../vector/v.net.centrality/main.c:128 ../vector/v.net.centrality/main.c:134
-#: ../vector/v.net.centrality/main.c:140 ../vector/v.net.centrality/main.c:146
+#: ../vector/v.net.centrality/main.c:128
+#: ../vector/v.net.centrality/main.c:134
+#: ../vector/v.net.centrality/main.c:140
+#: ../vector/v.net.centrality/main.c:146
#, fuzzy
msgid "Columns"
msgstr "colonne(s)"
@@ -23864,22 +23971,30 @@
msgid "Cummulative error tolerance for eigenvector centrality"
msgstr ""
-#: ../vector/v.net.centrality/main.c:171 ../vector/v.net.components/main.c:91
+#: ../vector/v.net.centrality/main.c:171
+#: ../vector/v.net.components/main.c:91
#, fuzzy
msgid "Add points on nodes"
msgstr "%d points chargés\n"
-#: ../vector/v.net.centrality/main.c:244 ../vector/v.net.distance/main.c:212
-#: ../vector/v.digit/c_face.c:282 ../vector/v.db.connect/main.c:331
-#: ../vector/v.sample/main.c:219 ../vector/v.net.flow/main.c:172
-#: ../vector/v.net.timetable/main.c:107 ../vector/v.net.components/main.c:151
+#: ../vector/v.net.centrality/main.c:244
+#: ../vector/v.net.distance/main.c:212
+#: ../vector/v.digit/c_face.c:282
+#: ../vector/v.db.connect/main.c:331
+#: ../vector/v.sample/main.c:219
+#: ../vector/v.net.flow/main.c:172
+#: ../vector/v.net.timetable/main.c:107
+#: ../vector/v.net.components/main.c:151
#: ../vector/v.net.path/path.c:113
msgid "Cannot create index"
msgstr "Impossible de créer l'index"
-#: ../vector/v.net.centrality/main.c:248 ../vector/v.net.distance/main.c:216
-#: ../vector/v.net.flow/main.c:176 ../vector/v.net.timetable/main.c:112
-#: ../vector/v.net.allpairs/main.c:161 ../vector/v.net.components/main.c:155
+#: ../vector/v.net.centrality/main.c:248
+#: ../vector/v.net.distance/main.c:216
+#: ../vector/v.net.flow/main.c:176
+#: ../vector/v.net.timetable/main.c:112
+#: ../vector/v.net.allpairs/main.c:161
+#: ../vector/v.net.components/main.c:155
#: ../vector/v.net.path/path.c:117
#, fuzzy, c-format
msgid "Cannot grant privileges on table <%s>"
@@ -23899,16 +24014,22 @@
msgid "Computing eigenvector centrality measure"
-#: ../vector/v.net.centrality/main.c:311 ../vector/v.net.allpairs/main.c:219
+#: ../vector/v.net.centrality/main.c:311
+#: ../vector/v.net.allpairs/main.c:219
#, fuzzy
msgid "Writing data into the table..."
msgstr "Écriture des données dans le fichier..."
-#: ../vector/v.type/main.c:47 ../vector/v.overlay/main.c:55
-#: ../vector/v.parallel/main.c:39 ../vector/v.parallel2/main.c:45
-#: ../vector/v.mkgrid/main.c:63 ../vector/v.in.region/main.c:38
-#: ../vector/v.patch/main.c:68 ../vector/v.split/main.c:42
-#: ../vector/v.to.points/main.c:173 ../vector/v.segment/main.c:52
+#: ../vector/v.type/main.c:47
+#: ../vector/v.overlay/main.c:55
+#: ../vector/v.parallel/main.c:39
+#: ../vector/v.parallel2/main.c:45
+#: ../vector/v.mkgrid/main.c:63
+#: ../vector/v.in.region/main.c:38
+#: ../vector/v.patch/main.c:68
+#: ../vector/v.split/main.c:42
+#: ../vector/v.to.points/main.c:173
+#: ../vector/v.segment/main.c:52
#: ../vector/v.hull/main.c:273
#, fuzzy
msgid "vector, geometry"
@@ -23944,7 +24065,8 @@
msgid "Nothing to do"
msgstr "Rien n'a été trouvé.\n"
-#: ../vector/v.type/main.c:141 ../vector/v.type/main.c:174
+#: ../vector/v.type/main.c:141
+#: ../vector/v.type/main.c:174
#, fuzzy
msgid "Incompatible types"
msgstr "Type de colonne inconnu"
@@ -23960,15 +24082,20 @@
# c-format
-#: ../vector/v.type/main.c:234 ../vector/v.net/main.c:197
-#: ../vector/v.proj/main.c:296 ../vector/v.kcv/main.c:161
-#: ../vector/v.build.polylines/main.c:233 ../vector/v.category/main.c:527
-#: ../vector/v.transform/main.c:361 ../vector/v.clean/main.c:281
+#: ../vector/v.type/main.c:234
+#: ../vector/v.net/main.c:197
+#: ../vector/v.proj/main.c:296
+#: ../vector/v.kcv/main.c:161
+#: ../vector/v.build.polylines/main.c:233
+#: ../vector/v.category/main.c:527
+#: ../vector/v.transform/main.c:361
+#: ../vector/v.clean/main.c:281
#, fuzzy
msgid "Failed to copy attribute table to output map"
msgstr "impossible de créer la couche en sortie <%s>"
-#: ../vector/v.voronoi/vo_main.c:120 ../vector/v.voronoi/dt_main.c:46
+#: ../vector/v.voronoi/vo_main.c:120
+#: ../vector/v.voronoi/dt_main.c:46
#: ../vector/v.delaunay2/main.c:86
#, fuzzy
msgid "vector, geometry, triangulation"
@@ -23976,19 +24103,17 @@
#: ../vector/v.voronoi/vo_main.c:121
#, fuzzy
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Crée une couche raster et une couche vectorielle contenant des points placés "
-"au hasard."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Crée une couche raster et une couche vectorielle contenant des points placés au hasard."
#: ../vector/v.voronoi/vo_main.c:136
msgid "Output tessellation as a graph (lines), not areas"
msgstr ""
-#: ../vector/v.voronoi/vo_main.c:140 ../vector/v.overlay/main.c:120
-#: ../vector/v.in.ogr/main.c:215 ../vector/v.select/args.c:80
+#: ../vector/v.voronoi/vo_main.c:140
+#: ../vector/v.overlay/main.c:120
+#: ../vector/v.in.ogr/main.c:215
+#: ../vector/v.select/args.c:80
#: ../vector/v.to.points/main.c:213
msgid "Do not create attribute table"
msgstr "Ne pas créer de table attributaire"
@@ -24010,13 +24135,16 @@
msgid "Writing sites to output..."
msgstr "Écriture %s..."
-#: ../vector/v.voronoi/vo_main.c:339 ../vector/v.digit/attr.c:536
-#: ../vector/v.extract/main.c:461 ../vector/v.generalize/misc.c:159
+#: ../vector/v.voronoi/vo_main.c:339
+#: ../vector/v.digit/attr.c:536
+#: ../vector/v.extract/main.c:461
+#: ../vector/v.generalize/misc.c:159
#, c-format
msgid "Layer %d"
msgstr "couche %d"
-#: ../vector/v.voronoi/vo_main.c:344 ../vector/v.extract/main.c:466
+#: ../vector/v.voronoi/vo_main.c:344
+#: ../vector/v.extract/main.c:466
#, fuzzy
msgid "No table"
msgstr "Pas de table."
@@ -24034,27 +24162,29 @@
msgid "Removing incorrect boundaries from output"
msgstr "Suppression des fichiers du groupe"
-#: ../vector/v.voronoi/dt_main.c:47 ../vector/v.delaunay2/main.c:87
+#: ../vector/v.voronoi/dt_main.c:47
+#: ../vector/v.delaunay2/main.c:87
#, fuzzy
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"au hasard."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
-#: ../vector/v.voronoi/dt_main.c:55 ../vector/v.delaunay2/main.c:95
+#: ../vector/v.voronoi/dt_main.c:55
+#: ../vector/v.delaunay2/main.c:95
#, fuzzy
msgid "Use only points in current region"
msgstr "Utiliser la région courante"
-#: ../vector/v.voronoi/dt_main.c:60 ../vector/v.delaunay2/main.c:100
+#: ../vector/v.voronoi/dt_main.c:60
+#: ../vector/v.delaunay2/main.c:100
msgid "Output triangulation as a graph (lines), not areas"
msgstr ""
-#: ../vector/v.voronoi/dt_main.c:142 ../vector/v.overlay/area_area.c:68
-#: ../vector/v.in.ogr/main.c:1051 ../vector/v.buffer2/main.c:594
-#: ../vector/v.buffer2/main.c:686 ../vector/v.buffer/main.c:663
+#: ../vector/v.voronoi/dt_main.c:142
+#: ../vector/v.overlay/area_area.c:68
+#: ../vector/v.in.ogr/main.c:1051
+#: ../vector/v.buffer2/main.c:594
+#: ../vector/v.buffer2/main.c:686
+#: ../vector/v.buffer/main.c:663
#: ../vector/v.buffer/main.c:750
msgid "Cannot calculate area centroid"
msgstr "Impossible de calculer le centroïde de la surface"
@@ -24079,16 +24209,15 @@
msgstr ""
#: ../vector/v.net.steiner/main.c:349
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
msgstr ""
#: ../vector/v.net.steiner/main.c:369
msgid "Node layer (used for terminals)"
msgstr ""
-#: ../vector/v.net.steiner/main.c:375 ../vector/v.net.salesman/main.c:125
+#: ../vector/v.net.steiner/main.c:375
+#: ../vector/v.net.salesman/main.c:125
msgid "Arcs' cost column (for both directions)"
msgstr ""
@@ -24117,8 +24246,7 @@
#: ../vector/v.net.steiner/main.c:527
#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
msgstr ""
#: ../vector/v.net.steiner/main.c:532
@@ -24140,13 +24268,16 @@
msgid "No Steiner point found -> leaving cycle"
msgstr ""
-#: ../vector/v.overlay/area_area.c:39 ../vector/v.overlay/line_area.c:69
+#: ../vector/v.overlay/area_area.c:39
+#: ../vector/v.overlay/line_area.c:69
#, fuzzy
msgid "Breaking lines..."
msgstr "Traitement des lignes..."
-#: ../vector/v.overlay/area_area.c:43 ../vector/v.buffer2/main.c:549
-#: ../vector/v.buffer2/main.c:556 ../vector/v.buffer/main.c:625
+#: ../vector/v.overlay/area_area.c:43
+#: ../vector/v.buffer2/main.c:549
+#: ../vector/v.buffer2/main.c:556
+#: ../vector/v.buffer/main.c:625
#, fuzzy
msgid "Removing duplicates..."
msgstr "Suppression des centroïdes en doublons..."
@@ -24157,7 +24288,8 @@
msgid "Cleaning boundaries at nodes..."
-#: ../vector/v.overlay/area_area.c:55 ../vector/v.buffer2/main.c:574
+#: ../vector/v.overlay/area_area.c:55
+#: ../vector/v.buffer2/main.c:574
#: ../vector/v.buffer/main.c:637
#, fuzzy
msgid "Attaching islands..."
@@ -24169,8 +24301,10 @@
msgid "Querying vector map <%s>..."
-#: ../vector/v.overlay/area_area.c:103 ../vector/v.overlay/area_area.c:183
-#: ../vector/v.overlay/area_area.c:211 ../vector/v.overlay/line_area.c:161
+#: ../vector/v.overlay/area_area.c:103
+#: ../vector/v.overlay/area_area.c:183
+#: ../vector/v.overlay/area_area.c:211
+#: ../vector/v.overlay/line_area.c:161
#: ../vector/v.overlay/line_area.c:189
#, fuzzy
msgid "Attribute not found"
@@ -24181,7 +24315,8 @@
msgid "Writing centroids..."
msgstr "Écrire les sommets de lignes."
-#: ../vector/v.overlay/area_area.c:264 ../vector/v.buffer/main.c:760
+#: ../vector/v.overlay/area_area.c:264
+#: ../vector/v.buffer/main.c:760
#, fuzzy
msgid "Attaching centroids..."
msgstr "Rattachement des catégories...\n"
@@ -24191,34 +24326,40 @@
msgid "Overlays two vector maps."
msgstr "Nom de la couche vecteur"
-#: ../vector/v.overlay/main.c:59 ../vector/v.select/args.c:10
+#: ../vector/v.overlay/main.c:59
+#: ../vector/v.select/args.c:10
#, fuzzy
msgid "Name of input vector map (A)"
msgstr "Nom de la couche vecteur 2D source"
# c-format
-#: ../vector/v.overlay/main.c:63 ../vector/v.select/args.c:14
+#: ../vector/v.overlay/main.c:63
+#: ../vector/v.select/args.c:14
#, fuzzy
msgid "Feature type (vector map A)"
msgstr "Impossible de créer la couche vecteur %s"
-#: ../vector/v.overlay/main.c:69 ../vector/v.select/args.c:19
+#: ../vector/v.overlay/main.c:69
+#: ../vector/v.select/args.c:19
#, fuzzy
msgid "Layer number (vector map A)"
msgstr "Nom du nouveau fichier vecteur binaire"
-#: ../vector/v.overlay/main.c:73 ../vector/v.select/args.c:24
+#: ../vector/v.overlay/main.c:73
+#: ../vector/v.select/args.c:24
#, fuzzy
msgid "Name of input vector map (B)"
# c-format
-#: ../vector/v.overlay/main.c:77 ../vector/v.select/args.c:28
+#: ../vector/v.overlay/main.c:77
+#: ../vector/v.select/args.c:28
#, fuzzy
msgid "Feature type (vector map B)"
-#: ../vector/v.overlay/main.c:83 ../vector/v.select/args.c:33
+#: ../vector/v.overlay/main.c:83
+#: ../vector/v.select/args.c:33
#, fuzzy
msgid "Layer number (vector map B)"
@@ -24231,23 +24372,13 @@
#: ../vector/v.overlay/main.c:98
#, fuzzy
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
msgstr ""
-"Opérateur qui définit la relation requise entre objets. Un objet est écrit "
-"dansla couche de sortie si le résultat de l'opération 'ainput opérateur "
-"binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de "
-"la couche est définie.\n"
+"Opérateur qui définit la relation requise entre objets. Un objet est écrit dansla couche de sortie si le résultat de l'opération 'ainput opérateur binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de la couche est définie.\n"
"\t recouvrement : les objets se recouvrent totalement ou partiellement"
#: ../vector/v.overlay/main.c:103
-msgid ""
-"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-"(only for atype=area);not;features from ainput not overlayed by features "
-"from binput;xor;features from either ainput or binput but not those from "
-"ainput overlayed by binput (only for atype=area)"
+msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
msgstr ""
#: ../vector/v.overlay/main.c:114
@@ -24271,16 +24402,15 @@
#: ../vector/v.overlay/main.c:235
#, fuzzy, c-format
msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr ""
-"%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. "
-"Vérifiez le paramètre 'type'"
+msgstr "%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.overlay/main.c:269
#, fuzzy
msgid "Collecting input attributes..."
-#: ../vector/v.overlay/main.c:304 ../vector/v.label/main.c:323
+#: ../vector/v.overlay/main.c:304
+#: ../vector/v.label/main.c:323
#: ../vector/v.label.sa/labels.c:174
#, fuzzy
msgid "Unable to select attributes"
@@ -24291,8 +24421,10 @@
msgid "Unknown column type '%s'"
-#: ../vector/v.overlay/main.c:365 ../vector/v.lrs/v.lrs.label/main.c:347
-#: ../vector/v.out.svg/main.c:370 ../vector/v.out.ogr/main.c:1066
+#: ../vector/v.overlay/main.c:365
+#: ../vector/v.lrs/v.lrs.label/main.c:347
+#: ../vector/v.out.svg/main.c:370
+#: ../vector/v.out.ogr/main.c:1066
#: ../vector/v.out.vtk/writeVTK.c:580
#, fuzzy
msgid "Unable to fetch data from table"
@@ -24308,7 +24440,8 @@
msgid "Building partial topology..."
msgstr "Construction de l'index spatial ..."
-#: ../vector/v.overlay/main.c:494 ../vector/v.buffer/main.c:223
+#: ../vector/v.overlay/main.c:494
+#: ../vector/v.buffer/main.c:223
#, fuzzy
msgid "Rebuilding topology..."
msgstr "Lecteur du fichier raster..."
@@ -24324,14 +24457,8 @@
#: ../vector/v.kernel/main.c:108
#, fuzzy
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
-msgstr ""
-"Génère une couche de densité raster à partir de données vecteurs points en "
-"utilisantun noyau Gaussien isotropique mobile 2D et génère de façon "
-"optionnelle une carte vectorielle de densitésur le réseau vectoriel avec un "
-"noyau 1D"
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+msgstr "Génère une couche de densité raster à partir de données vecteurs points en utilisantun noyau Gaussien isotropique mobile 2D et génère de façon optionnelle une carte vectorielle de densitésur le réseau vectoriel avec un noyau 1D"
#: ../vector/v.kernel/main.c:112
msgid "Input vector with training points"
@@ -24377,9 +24504,7 @@
msgstr "Méthode inconnue <%s>"
#: ../vector/v.kernel/main.c:168
-msgid ""
-"none;No method applied at nodes with more than 2 arcs;split;Equal split "
-"(Okabe 2009) applied at nodes;"
+msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
msgstr ""
#: ../vector/v.kernel/main.c:175
@@ -24388,23 +24513,15 @@
#: ../vector/v.kernel/main.c:183
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Tente de calculer un écart-type optimal avec 'stddeviation' comme maximum "
-"'expérimental'"
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Tente de calculer un écart-type optimal avec 'stddeviation' comme maximum 'expérimental'"
#: ../vector/v.kernel/main.c:188
msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Calculer seulement l'écart-type optimal et quitte (aucune couche n'est "
-"écrite)"
+msgstr "Calculer seulement l'écart-type optimal et quitte (aucune couche n'est écrite)"
#: ../vector/v.kernel/main.c:193
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
msgstr ""
#: ../vector/v.kernel/main.c:198
@@ -24427,15 +24544,11 @@
#: ../vector/v.kernel/main.c:249
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
msgstr ""
#: ../vector/v.kernel/main.c:253
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
msgstr ""
#: ../vector/v.kernel/main.c:290
@@ -24451,12 +24564,8 @@
#: ../vector/v.kernel/main.c:345
#, fuzzy, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"Choix automatique du paramètre de lissage (écart-type), maximumvaleur "
-"possible de l'écart type si elle était fixée à %f"
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "Choix automatique du paramètre de lissage (écart-type), maximumvaleur possible de l'écart type si elle était fixée à %f"
# c-format
#: ../vector/v.kernel/main.c:352
@@ -24477,12 +24586,8 @@
#: ../vector/v.kernel/main.c:370
#, fuzzy, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"distances entre tous les points en-dessous de %e (4 * écart-type), "
-"impossiblede calculer la valeur optimale."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "distances entre tous les points en-dessous de %e (4 * écart-type), impossiblede calculer la valeur optimale."
#: ../vector/v.kernel/main.c:381
#, c-format
@@ -24499,7 +24604,8 @@
"Ecrire le fichier vecteur en sortie en utilisant le paramètre de lissage=%f."
# c-format
-#: ../vector/v.kernel/main.c:410 ../vector/v.kernel/main.c:517
+#: ../vector/v.kernel/main.c:410
+#: ../vector/v.kernel/main.c:517
#, c-format
msgid ""
"\n"
@@ -24533,8 +24639,10 @@
msgid "Dimension > 2 supported only by gaussian function"
msgstr ""
-#: ../vector/v.in.ogr/main.c:103 ../vector/v.in.dwg/main.c:65
-#: ../vector/v.in.ascii/in.c:48 ../vector/v.in.dxf/main.c:60
+#: ../vector/v.in.ogr/main.c:103
+#: ../vector/v.in.dwg/main.c:65
+#: ../vector/v.in.ascii/in.c:48
+#: ../vector/v.in.dxf/main.c:60
#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
@@ -24567,9 +24675,7 @@
#: ../vector/v.in.ogr/main.c:128
#, fuzzy
msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-"Couche vectorielle cible, si elle n'est pas indiquée, les couches "
-"disponibles seront seulement affichées"
+msgstr "Couche vectorielle cible, si elle n'est pas indiquée, les couches disponibles seront seulement affichées"
#: ../vector/v.in.ogr/main.c:130
#, fuzzy
@@ -24587,7 +24693,8 @@
msgid "Import subregion only"
msgstr "Afficher seulement la région de la couche raster"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+#: ../vector/v.in.ogr/main.c:141
+#: ../vector/v.in.ogr/main.c:225
#, fuzzy
msgid "Subregion"
msgstr "Région\n"
@@ -24595,25 +24702,21 @@
#: ../vector/v.in.ogr/main.c:143
#, fuzzy
msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
-msgstr ""
-"Importer la sous-région seulement (xmin,ymin,xmax,ymax - habituellement O,S,"
-"E,N)"
+msgstr "Importer la sous-région seulement (xmin,ymin,xmax,ymax - habituellement O,S,E,N)"
#: ../vector/v.in.ogr/main.c:154
msgid "Minimum size of area to be imported (square units)"
msgstr ""
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+#: ../vector/v.in.ogr/main.c:155
+#: ../vector/v.in.ogr/main.c:176
msgid "Min-area & snap"
msgstr ""
#: ../vector/v.in.ogr/main.c:156
#, fuzzy
msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-"Taille minimale des entités surfaciques à importer (en unités au carré). Les "
-"entités plus petites et les îles sont ignorées. Elle doit être supérieure à "
-"snap^2"
+msgstr "Taille minimale des entités surfaciques à importer (en unités au carré). Les entités plus petites et les îles sont ignorées. Elle doit être supérieure à snap^2"
#: ../vector/v.in.ogr/main.c:162
#, fuzzy
@@ -24622,9 +24725,7 @@
#: ../vector/v.in.ogr/main.c:164
#, fuzzy
-msgid ""
-"point;import area centroids as points;line;import area boundaries as lines;"
-"boundary;import lines as area boundaries;centroid;import points as centroids"
+msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
msgstr ""
"Option de modification du type en entrée par défaut:\n"
"\t point -> importe les centroïdes d'entités surfaciques comme points\n"
@@ -24642,12 +24743,8 @@
msgstr ""
#: ../vector/v.in.ogr/main.c:191
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
-msgstr ""
-"Liste de noms de colonnes à utiliser à la place des noms originaux, le "
-"premier correspondà la colonne de catégorie"
+msgid "List of column names to be used instead of original names, first is used for category column"
+msgstr "Liste de noms de colonnes à utiliser à la place des noms originaux, le premier correspondà la colonne de catégorie"
#: ../vector/v.in.ogr/main.c:198
msgid "List available layers in data source and exit"
@@ -24691,12 +24788,14 @@
msgid "Vector map <%s> already exists and will be overwritten"
msgstr "Le vecteur '%s' existe déjà."
-#: ../vector/v.in.ogr/main.c:339 ../vector/v.edit/main.c:94
+#: ../vector/v.in.ogr/main.c:339
+#: ../vector/v.edit/main.c:94
#, fuzzy, c-format
msgid "Vector map <%s> already exists"
msgstr "ERREUR: <%s> existe déjà\n"
-#: ../vector/v.in.ogr/main.c:364 ../vector/v.external/main.c:128
+#: ../vector/v.in.ogr/main.c:364
+#: ../vector/v.external/main.c:128
#, fuzzy, c-format
msgid "Layer <%s> not available"
msgstr "La couche '%s' n'est pas disponible"
@@ -24712,20 +24811,12 @@
#: ../vector/v.in.ogr/main.c:485
#, fuzzy
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location"
-msgstr ""
-"Impossible de convertir la projection de la couche en entrée au format "
-"GRASS ; impossible de créer le nouveau Secteur"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location"
+msgstr "Impossible de convertir la projection de la couche en entrée au format GRASS ; impossible de créer le nouveau Secteur"
#: ../vector/v.in.ogr/main.c:497
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-"Impossible de convertir l'information de projection de la couche de données "
-"au format GRASS pour vérification"
+msgid "Unable to convert input map projection information to GRASS format for checking"
+msgstr "Impossible de convertir l'information de projection de la couche de données au format GRASS pour vérification"
# c-format
#: ../vector/v.in.ogr/main.c:527
@@ -24744,12 +24835,8 @@
#: ../vector/v.in.ogr/main.c:590
#, fuzzy
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
-"des données en entrée.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr "Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' des données en entrée.\n"
# c-format
#: ../vector/v.in.ogr/main.c:613
@@ -24770,25 +24857,17 @@
#: ../vector/v.in.ogr/main.c:727
#, fuzzy, c-format
msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-"Ecriture de la colonne <%s> de longueur fixée à 40 caractères (possible "
-"troncature des données)"
+msgstr "Ecriture de la colonne <%s> de longueur fixée à 40 caractères (possible troncature des données)"
#: ../vector/v.in.ogr/main.c:750
#, fuzzy, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-"Largeur de la colonne '%s' fixée à 255 (non spécifiée par OGR), des chaînes "
-"risquent d'être tronquées"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr "Largeur de la colonne '%s' fixée à 255 (non spécifiée par OGR), des chaînes risquent d'être tronquées"
#: ../vector/v.in.ogr/main.c:762
#, fuzzy, c-format
msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
# c-format
#: ../vector/v.in.ogr/main.c:766
@@ -24836,7 +24915,8 @@
msgid "Break polygons:"
msgstr "Exporter les lignes en tant que polygones"
-#: ../vector/v.in.ogr/main.c:988 ../vector/v.in.ogr/main.c:1002
+#: ../vector/v.in.ogr/main.c:988
+#: ../vector/v.in.ogr/main.c:1002
#, fuzzy
msgid "Remove duplicates:"
@@ -24882,15 +24962,8 @@
#: ../vector/v.in.ogr/main.c:1138
#, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
-msgstr ""
-"les entités surfaciques %d comprennent des objets se recouvrant, étant donné "
-"que les polygones se recouvrent dans les couches en entrée. De telles "
-"entités sont liées à plus d'un tuple de la table attributaire. Le nombre "
-"d'objets de ces entités est stocké comme une catégorie de la couche %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr "les entités surfaciques %d comprennent des objets se recouvrant, étant donné que les polygones se recouvrent dans les couches en entrée. De telles entités sont liées à plus d'un tuple de la table attributaire. Le nombre d'objets de ces entités est stocké comme une catégorie de la couche %d"
#: ../vector/v.in.ogr/main.c:1148
#, fuzzy, c-format
@@ -24940,13 +25013,8 @@
#: ../vector/v.in.ogr/main.c:1214
#, fuzzy
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, use -z flag to "
-"import 3D vector"
-msgstr ""
-"Les données en entrée contiennent des objets 3D. Les objets vecteurs créés "
-"sont uniquement 2D utilisez le drapeau -z pour importer des objets "
-"vectoriels 3D"
+msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
+msgstr "Les données en entrée contiennent des objets 3D. Les objets vecteurs créés sont uniquement 2D utilisez le drapeau -z pour importer des objets vectoriels 3D"
# c-format
#: ../vector/v.in.ogr/geom.c:195
@@ -24954,8 +25022,10 @@
msgid "Cannot read part of geometry"
msgstr "Impossible d'écrire dans : %s"
-#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:247
-#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:321
+#: ../vector/v.in.ogr/geom.c:234
+#: ../vector/v.in.ogr/geom.c:247
+#: ../vector/v.in.ogr/geom.c:275
+#: ../vector/v.in.ogr/geom.c:321
msgid "Skipping empty geometry feature"
msgstr ""
@@ -25019,12 +25089,7 @@
msgstr "région <%s> non trouvée"
#: ../vector/v.net/main.c:71
-msgid ""
-"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
-"connect still unconnected points to vector network by inserting new line(s);"
-"report;print to standard output {line_category start_point_category "
-"end_point_category};nreport;print to standard output {point_category "
-"line_category[,line_category...]}"
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
msgstr ""
#: ../vector/v.net/main.c:97
@@ -25034,8 +25099,7 @@
#: ../vector/v.net/main.c:101
#, fuzzy
msgid "Assign unique categories to new points"
-msgstr ""
-"Assignation de catégories uniques aux nouveaux points (opération=noeuds)"
+msgstr "Assignation de catégories uniques aux nouveaux points (opération=noeuds)"
#: ../vector/v.net/main.c:102
#, fuzzy
@@ -25100,9 +25164,7 @@
#: ../vector/v.proj/main.c:64
#, fuzzy
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Re-projeter une couche raster depuis un Secteur (location) vers le Secteur "
-"courant."
+msgstr "Re-projeter une couche raster depuis un Secteur (location) vers le Secteur courant."
#: ../vector/v.proj/main.c:76
#, fuzzy
@@ -25164,7 +25226,8 @@
msgid "Error in pj_do_transform"
msgstr "Erreur dans pj_do_proj"
-#: ../vector/v.label/main.c:61 ../vector/v.label.sa/main.c:54
+#: ../vector/v.label/main.c:61
+#: ../vector/v.label.sa/main.c:54
msgid "vector, paint labels"
msgstr ""
@@ -25173,7 +25236,8 @@
msgid "Creates paint labels for a vector map from attached attributes."
msgstr "Créer des icones pour le fichier vecteur GRASS et les attributs liés"
-#: ../vector/v.label/main.c:68 ../vector/v.label.sa/main.c:107
+#: ../vector/v.label/main.c:68
+#: ../vector/v.label.sa/main.c:107
msgid "Name for new paint-label file"
msgstr "Nom du nouveau fichier d'icones"
@@ -25181,7 +25245,8 @@
msgid "If not given the name of the input map is used"
msgstr ""
-#: ../vector/v.label/main.c:79 ../vector/v.label.sa/main.c:103
+#: ../vector/v.label/main.c:79
+#: ../vector/v.label.sa/main.c:103
msgid "Name of attribute column to be used for labels"
msgstr "Nom du champ attributaire à utiliser pour les étiquettes"
@@ -25197,8 +25262,10 @@
msgid "Offset label in x-direction"
msgstr "Décaler l'étiquette dans la direction x"
-#: ../vector/v.label/main.c:103 ../vector/v.label/main.c:110
-#: ../vector/v.label/main.c:119 ../vector/v.label/main.c:163
+#: ../vector/v.label/main.c:103
+#: ../vector/v.label/main.c:110
+#: ../vector/v.label/main.c:119
+#: ../vector/v.label/main.c:163
msgid "Placement"
msgstr ""
@@ -25206,28 +25273,32 @@
msgid "Offset label in y-direction"
msgstr "Décaler l'étiquette dans la direction y"
-#: ../vector/v.label/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:173
+#: ../vector/v.label/main.c:114
+#: ../vector/v.lrs/v.lrs.label/main.c:173
msgid "Reference position"
msgstr "Position de référence"
-#: ../vector/v.label/main.c:126 ../vector/v.label/main.c:133
-#: ../vector/v.label/main.c:141 ../vector/v.label/main.c:149
-#: ../vector/v.lrs/v.lrs.label/main.c:180 ../vector/v.label.sa/main.c:118
-#: ../vector/v.label.sa/main.c:119 ../vector/v.label.sa/main.c:126
+#: ../vector/v.label/main.c:126
+#: ../vector/v.label/main.c:133
+#: ../vector/v.label/main.c:141
+#: ../vector/v.label/main.c:149
+#: ../vector/v.lrs/v.lrs.label/main.c:180
+#: ../vector/v.label.sa/main.c:118
+#: ../vector/v.label.sa/main.c:119
+#: ../vector/v.label.sa/main.c:126
#, fuzzy
msgid "Font"
msgstr "nom de la police"
-#: ../vector/v.label/main.c:130 ../vector/v.lrs/v.lrs.label/main.c:186
+#: ../vector/v.label/main.c:130
+#: ../vector/v.lrs/v.lrs.label/main.c:186
#: ../vector/v.label.sa/main.c:123
msgid "Label size (in map-units)"
msgstr "Taille de l'étiquette (en unités de la carte)"
#: ../vector/v.label/main.c:138
msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Espacement entre caractères pour les étiquettes courbes (en unités de la "
-"carte)"
+msgstr "Espacement entre caractères pour les étiquettes courbes (en unités de la carte)"
#: ../vector/v.label/main.c:145
msgid "Label size (in points)"
@@ -25236,45 +25307,49 @@
#: ../vector/v.label/main.c:157
#, fuzzy
msgid "Rotation angle (degrees counter-clockwise)"
-msgstr ""
-"Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
+msgstr "Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
#: ../vector/v.label/main.c:167
#, fuzzy
msgid "Border width"
msgstr "Epaisseur de ligne"
-#: ../vector/v.label/main.c:175 ../vector/v.lrs/v.lrs.label/main.c:210
+#: ../vector/v.label/main.c:175
+#: ../vector/v.lrs/v.lrs.label/main.c:210
#: ../vector/v.label.sa/main.c:153
msgid "Highlight color for text"
msgstr "Couleur de mise en valeur du texte"
-#: ../vector/v.label/main.c:181 ../vector/v.label.sa/main.c:163
+#: ../vector/v.label/main.c:181
+#: ../vector/v.label.sa/main.c:163
msgid "Width of highlight coloring"
msgstr "Largeur de la couleur de mise en valeur"
-#: ../vector/v.label/main.c:201 ../vector/v.label.sa/main.c:181
+#: ../vector/v.label/main.c:201
+#: ../vector/v.label.sa/main.c:181
msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr ""
-"Vecteurs opaques (pertinent seulement si la couleur de fond est sélectionnée)"
+msgstr "Vecteurs opaques (pertinent seulement si la couleur de fond est sélectionnée)"
#: ../vector/v.label/main.c:252
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"les options de taille et d'espace sont très mal assorties, le résultat "
-"risque d'être mauvais"
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "les options de taille et d'espace sont très mal assorties, le résultat risque d'être mauvais"
#: ../vector/v.label/main.c:260
msgid "Too many parameters for <reference>"
msgstr "Trop de paramètres pour cette opération"
-#: ../vector/v.label/main.c:329 ../vector/v.buffer2/main.c:417
-#: ../vector/v.buffer2/main.c:489 ../vector/v.sample/main.c:252
-#: ../vector/v.sample/main.c:260 ../vector/v.buffer/main.c:454
-#: ../vector/v.buffer/main.c:466 ../vector/v.buffer/main.c:531
-#: ../vector/v.buffer/main.c:543 ../vector/v.what.rast/main.c:318
-#: ../vector/v.vol.rst/user1.c:170 ../vector/v.label.sa/labels.c:178
+#: ../vector/v.label/main.c:329
+#: ../vector/v.buffer2/main.c:417
+#: ../vector/v.buffer2/main.c:489
+#: ../vector/v.sample/main.c:252
+#: ../vector/v.sample/main.c:260
+#: ../vector/v.buffer/main.c:454
+#: ../vector/v.buffer/main.c:466
+#: ../vector/v.buffer/main.c:531
+#: ../vector/v.buffer/main.c:543
+#: ../vector/v.what.rast/main.c:318
+#: ../vector/v.vol.rst/user1.c:170
+#: ../vector/v.label.sa/labels.c:178
#, fuzzy, c-format
msgid "No record for category %d in table <%s>"
msgstr "Pas d'enregistrement pour la catégorie '%d' dans la table"
@@ -25289,22 +25364,23 @@
msgid "vector, buffer"
msgstr "Couche vecteur à supprimer"
-#: ../vector/v.buffer2/main.c:152 ../vector/v.buffer/main.c:256
+#: ../vector/v.buffer2/main.c:152
+#: ../vector/v.buffer/main.c:256
#, fuzzy
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"crée une zone-tampon autour d'objet d'un type donné (les entités surfaciques "
-"doivent contenir un centroïde)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "crée une zone-tampon autour d'objet d'un type donné (les entités surfaciques doivent contenir un centroïde)."
#: ../vector/v.buffer2/main.c:170
#, fuzzy
msgid "Buffer distance along major axis in map units"
msgstr "Distance de zone-tampon en unités carte."
-#: ../vector/v.buffer2/main.c:171 ../vector/v.buffer2/main.c:179
-#: ../vector/v.buffer2/main.c:187 ../vector/v.buffer2/main.c:193
-#: ../vector/v.buffer2/main.c:201 ../vector/v.buffer2/main.c:210
+#: ../vector/v.buffer2/main.c:171
+#: ../vector/v.buffer2/main.c:179
+#: ../vector/v.buffer2/main.c:187
+#: ../vector/v.buffer2/main.c:193
+#: ../vector/v.buffer2/main.c:201
+#: ../vector/v.buffer2/main.c:210
#, fuzzy
msgid "Distance"
msgstr "Zone(s) de distance"
@@ -25314,7 +25390,8 @@
msgid "Buffer distance along minor axis in map units"
-#: ../vector/v.buffer2/main.c:186 ../vector/v.parallel2/main.c:74
+#: ../vector/v.buffer2/main.c:186
+#: ../vector/v.parallel2/main.c:74
msgid "Angle of major axis in degrees"
msgstr ""
@@ -25323,25 +25400,22 @@
msgid "Name of column to use for buffer distances"
msgstr "Colonne attributaire à utiliser pour la distance de zone-tampons"
-#: ../vector/v.buffer2/main.c:200 ../vector/v.buffer/main.c:286
+#: ../vector/v.buffer2/main.c:200
+#: ../vector/v.buffer/main.c:286
msgid "Scaling factor for attribute column values"
msgstr "Facteur d'échelle pour les valeurs de colonnes attributaires"
-#: ../vector/v.buffer2/main.c:209 ../vector/v.buffer/main.c:296
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
-msgstr ""
-"Distance maximale entre l'arc de cercle théorique et les segments de "
-"polygones comme multiples du buffer"
+#: ../vector/v.buffer2/main.c:209
+#: ../vector/v.buffer/main.c:296
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
+msgstr "Distance maximale entre l'arc de cercle théorique et les segments de polygones comme multiples du buffer"
#: ../vector/v.buffer2/main.c:225
-msgid ""
-"This is an alias to the distance option. It is retained for backwards "
-"compatibility"
+msgid "This is an alias to the distance option. It is retained for backwards compatibility"
msgstr ""
-#: ../vector/v.buffer2/main.c:227 ../vector/v.buffer/main.c:271
+#: ../vector/v.buffer2/main.c:227
+#: ../vector/v.buffer/main.c:271
msgid "Buffer distance in map units"
@@ -25357,11 +25431,9 @@
msgid "Select a buffer distance/minordistance/angle or column, but not both."
msgstr ""
-#: ../vector/v.buffer2/main.c:251 ../vector/v.buffer/main.c:319
-msgid ""
-"The bufcol option may contain bugs during the cleaning step. If you "
-"encounter problems, use the debug option or clean manually with v.clean "
-"tool=break; v.category step=0; v.extract -d type=area"
+#: ../vector/v.buffer2/main.c:251
+#: ../vector/v.buffer/main.c:319
+msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
msgstr ""
#: ../vector/v.buffer2/main.c:262
@@ -25370,16 +25442,13 @@
msgstr "L'option échelle requiert une couche de magnitude"
#: ../vector/v.buffer2/main.c:265
-msgid ""
-"The buffer option has been replaced by the distance option and will be "
-"removed in future."
+msgid "The buffer option has been replaced by the distance option and will be removed in future."
msgstr ""
#: ../vector/v.buffer2/main.c:268
#, fuzzy
msgid "Use the distance option instead of the buffer option."
-msgstr ""
-"Utilisez des radians à la place de degrés pour définir l'angle de rotation"
+msgstr "Utilisez des radians à la place de degrés pour définir l'angle de rotation"
#: ../vector/v.buffer2/main.c:272
#, fuzzy
@@ -25401,19 +25470,21 @@
msgid "Unable to select data from table <%s>"
msgstr "Impossible de sélectionner des données dans la table"
-#: ../vector/v.buffer2/main.c:350 ../vector/v.univar/main.c:328
-#: ../vector/v.sample/main.c:266 ../vector/v.buffer/main.c:402
+#: ../vector/v.buffer2/main.c:350
+#: ../vector/v.univar/main.c:328
+#: ../vector/v.sample/main.c:266
+#: ../vector/v.buffer/main.c:402
#: ../vector/lidar/v.surf.bspline/main.c:345
-#: ../vector/lidar/v.surf.bspline/crosscorr.c:138 ../vector/v.class/main.c:123
-#: ../vector/v.what.rast/main.c:163 ../vector/v.to.rast3/main.c:100
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:138
+#: ../vector/v.class/main.c:123
+#: ../vector/v.what.rast/main.c:163
+#: ../vector/v.to.rast3/main.c:100
#: ../vector/v.surf.idw/read_sites.c:49
msgid "Column type not supported"
msgstr "Type de colonne non géré"
#: ../vector/v.buffer2/main.c:380
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
msgstr ""
#: ../vector/v.buffer2/main.c:394
@@ -25421,14 +25492,18 @@
msgid "Buffering lines..."
-#: ../vector/v.buffer2/main.c:423 ../vector/v.buffer2/main.c:495
-#: ../vector/v.buffer/main.c:473 ../vector/v.buffer/main.c:550
+#: ../vector/v.buffer2/main.c:423
+#: ../vector/v.buffer2/main.c:495
+#: ../vector/v.buffer/main.c:473
+#: ../vector/v.buffer/main.c:550
#, fuzzy, c-format
msgid "Attribute is of invalid size (%.3f) for category %d"
msgstr "L'attribut est de taille invalide (%.3f) pour la catégorie %d"
-#: ../vector/v.buffer2/main.c:437 ../vector/v.buffer2/main.c:509
-#: ../vector/v.buffer/main.c:335 ../vector/v.buffer/main.c:485
+#: ../vector/v.buffer2/main.c:437
+#: ../vector/v.buffer2/main.c:509
+#: ../vector/v.buffer/main.c:335
+#: ../vector/v.buffer/main.c:485
#: ../vector/v.buffer/main.c:562
#, c-format
msgid "The tolerance in map units: %g"
@@ -25445,12 +25520,14 @@
msgid "Writing buffers..."
msgstr "Écriture des attributs..."
-#: ../vector/v.buffer2/main.c:540 ../vector/v.buffer/main.c:607
+#: ../vector/v.buffer2/main.c:540
+#: ../vector/v.buffer/main.c:607
#, fuzzy
msgid "Building parts of topology..."
-#: ../vector/v.buffer2/main.c:543 ../vector/v.buffer/main.c:619
+#: ../vector/v.buffer2/main.c:543
+#: ../vector/v.buffer/main.c:619
#, fuzzy
msgid "Snapping boundaries..."
msgstr "Rotation des données ... "
@@ -25461,7 +25538,8 @@
# c-format
-#: ../vector/v.buffer2/main.c:553 ../vector/v.buffer/main.c:622
+#: ../vector/v.buffer2/main.c:553
+#: ../vector/v.buffer/main.c:622
#, fuzzy
msgid "Breaking boundaries..."
@@ -25472,32 +25550,32 @@
msgid "Cleaning boundaries at nodes"
-#: ../vector/v.buffer2/main.c:580 ../vector/v.buffer2/main.c:673
-#: ../vector/v.buffer/main.c:644 ../vector/v.buffer/main.c:734
+#: ../vector/v.buffer2/main.c:580
+#: ../vector/v.buffer2/main.c:673
+#: ../vector/v.buffer/main.c:644
+#: ../vector/v.buffer/main.c:734
#, fuzzy
msgid "Calculating centroids for areas..."
# c-format
-#: ../vector/v.buffer2/main.c:611 ../vector/v.buffer/main.c:686
+#: ../vector/v.buffer2/main.c:611
+#: ../vector/v.buffer/main.c:686
#, fuzzy
msgid "Generating list of boundaries to be deleted..."
# c-format
-#: ../vector/v.buffer2/main.c:644 ../vector/v.buffer/main.c:718
+#: ../vector/v.buffer2/main.c:644
+#: ../vector/v.buffer/main.c:718
#, fuzzy
msgid "Deleting boundaries..."
#: ../vector/v.univar/main.c:95
#, fuzzy
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
-msgstr ""
-"Calcule des statistiques univariées pour un attribut. La variance et l'écart-"
-"type sont calculés uniquement pour les points si cela est spécifié."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+msgstr "Calcule des statistiques univariées pour un attribut. La variance et l'écart-type sont calculés uniquement pour les points si cela est spécifié."
#: ../vector/v.univar/main.c:111
msgid "Column name"
@@ -25511,9 +25589,7 @@
#: ../vector/v.univar/main.c:144
#, fuzzy, c-format
msgid "The '-%c' flag is currently broken, please use v.distance instead."
-msgstr ""
-"Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--"
-"verbose' à la place."
+msgstr "Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--verbose' à la place."
#: ../vector/v.univar/main.c:149
#, fuzzy, c-format
@@ -25523,12 +25599,8 @@
msgstr "incidout demande de fixer le paramètre d'heure"
#: ../vector/v.univar/main.c:175
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-"Type de vecteur spécifié incompatible, seuls le nombre d'objet, le minimum, "
-"le maximum et l'intervalle de valeur peuvent être calculés"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr "Type de vecteur spécifié incompatible, seuls le nombre d'objet, le minimum, le maximum et l'intervalle de valeur peuvent être calculés"
#: ../vector/v.univar/main.c:180
#, fuzzy
@@ -25543,30 +25615,27 @@
#: ../vector/v.univar/main.c:311
#, fuzzy, c-format
msgid " Database connection not defined for layer <%s>"
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>"
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>"
#: ../vector/v.univar/main.c:605
#, fuzzy
msgid "Cannot sort the key/value array"
msgstr "Impossible d'insérer dans la table: %s"
-#: ../vector/v.net.distance/main.c:60 ../vector/v.net.timetable/main.c:254
-#: ../vector/v.net.allpairs/main.c:58 ../vector/v.net.path/main.c:41
+#: ../vector/v.net.distance/main.c:60
+#: ../vector/v.net.timetable/main.c:254
+#: ../vector/v.net.allpairs/main.c:58
+#: ../vector/v.net.path/main.c:41
#, fuzzy
msgid "vector, network, shortest path"
#: ../vector/v.net.distance/main.c:61
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
msgstr ""
#: ../vector/v.net.distance/main.c:64
-msgid ""
-"Finds the shortest paths from a feature 'to' to every feature 'from' and "
-"various information about this realtion are uploaded to the attribute table."
+msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
msgstr ""
#: ../vector/v.net.distance/main.c:73
@@ -25574,9 +25643,12 @@
msgid "From layer number or name"
msgstr "Code de couche"
-#: ../vector/v.net.distance/main.c:74 ../vector/v.net.distance/main.c:79
-#: ../vector/v.net.distance/main.c:85 ../vector/v.distance/main.c:121
-#: ../vector/v.distance/main.c:133 ../vector/v.distance/main.c:145
+#: ../vector/v.net.distance/main.c:74
+#: ../vector/v.net.distance/main.c:79
+#: ../vector/v.net.distance/main.c:85
+#: ../vector/v.distance/main.c:121
+#: ../vector/v.distance/main.c:133
+#: ../vector/v.distance/main.c:145
#, fuzzy
msgid "From"
msgstr "Type de donnée vectorielle"
@@ -25596,10 +25668,14 @@
msgid "To layer number or name"
-#: ../vector/v.net.distance/main.c:90 ../vector/v.net.distance/main.c:95
-#: ../vector/v.net.distance/main.c:101 ../vector/v.net.distance/main.c:108
-#: ../vector/v.distance/main.c:126 ../vector/v.distance/main.c:140
-#: ../vector/v.distance/main.c:150 ../vector/v.distance/main.c:209
+#: ../vector/v.net.distance/main.c:90
+#: ../vector/v.net.distance/main.c:95
+#: ../vector/v.net.distance/main.c:101
+#: ../vector/v.net.distance/main.c:108
+#: ../vector/v.distance/main.c:126
+#: ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:150
+#: ../vector/v.distance/main.c:209
msgid "To"
msgstr ""
@@ -25627,15 +25703,14 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:72
#, fuzzy
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
msgstr "Créer des points le long des lignes en entrée."
#: ../vector/v.lrs/v.lrs.segment/main.c:76
#: ../vector/v.lrs/v.lrs.where/main.c:65
#: ../vector/v.lrs/v.lrs.create/main.c:126
-#: ../vector/v.lrs/v.lrs.label/main.c:107 ../vector/v.to.points/main.c:178
+#: ../vector/v.lrs/v.lrs.label/main.c:107
+#: ../vector/v.to.points/main.c:178
#, fuzzy
msgid "Input vector map containing lines"
msgstr "Couche en entrée contenant les lignes"
@@ -25648,7 +25723,8 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:85
#: ../vector/v.lrs/v.lrs.where/main.c:74
#: ../vector/v.lrs/v.lrs.create/main.c:145
-#: ../vector/v.lrs/v.lrs.label/main.c:116 ../vector/v.segment/main.c:66
+#: ../vector/v.lrs/v.lrs.label/main.c:116
+#: ../vector/v.segment/main.c:66
#, fuzzy
msgid "Line layer"
msgstr "Couleur de ligne"
@@ -25676,12 +25752,11 @@
msgid "Name of the reference system table"
msgstr "Nom du nouveau fichier raster"
-#: ../vector/v.lrs/v.lrs.segment/main.c:112 ../vector/v.segment/main.c:71
+#: ../vector/v.lrs/v.lrs.segment/main.c:112
+#: ../vector/v.segment/main.c:71
#, fuzzy
msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr ""
-"Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les "
-"prendre à partirde la ligne de commande"
+msgstr "Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les prendre à partirde la ligne de commande"
#: ../vector/v.lrs/v.lrs.segment/main.c:151
#: ../vector/v.lrs/v.lrs.where/main.c:145
@@ -25780,7 +25855,8 @@
"%s"
msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:331 ../vector/v.segment/main.c:222
+#: ../vector/v.lrs/v.lrs.segment/main.c:331
+#: ../vector/v.segment/main.c:222
#, fuzzy, c-format
msgid "Incorrect segment type: %s"
msgstr "Impossible de créer le segment de fichier %s"
@@ -25807,9 +25883,7 @@
msgstr "%d points écrits vers la couche cible\n"
#: ../vector/v.lrs/v.lrs.where/main.c:60
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
msgstr ""
#: ../vector/v.lrs/v.lrs.where/main.c:69
@@ -25883,8 +25957,7 @@
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:180
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:189
@@ -25919,9 +25992,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:280
#, fuzzy
msgid "Cannot get layer info for points"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
# c-format
#: ../vector/v.lrs/v.lrs.create/main.c:315
@@ -26084,8 +26155,7 @@
#: ../vector/v.lrs/v.lrs.label/main.c:247
#, fuzzy
msgid "Only relevant if background color is selected"
-msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:338
#, fuzzy, c-format
@@ -26117,9 +26187,12 @@
# c-format
-#: ../vector/v.out.ascii/b2a.c:237 ../vector/v.distance/main.c:377
-#: ../vector/v.distance/main.c:419 ../vector/v.reclass/main.c:138
-#: ../vector/v.to.3d/trans3.c:62 ../vector/v.to.3d/trans2.c:60
+#: ../vector/v.out.ascii/b2a.c:237
+#: ../vector/v.distance/main.c:377
+#: ../vector/v.distance/main.c:419
+#: ../vector/v.reclass/main.c:138
+#: ../vector/v.to.3d/trans3.c:62
+#: ../vector/v.to.3d/trans2.c:60
#, fuzzy, c-format
msgid "Column <%s> not found in table <%s>"
msgstr "Colonne <%s> non trouvée"
@@ -26130,23 +26203,23 @@
msgid "Column <%s>: unsupported data type"
-#: ../vector/v.out.ascii/out.c:45 ../vector/v.out.svg/main.c:73
-#: ../vector/v.out.ogr/main.c:96 ../vector/v.out.pov/main.c:43
-#: ../vector/v.out.dxf/main.c:48 ../vector/v.out.vtk/main.c:46
+#: ../vector/v.out.ascii/out.c:45
+#: ../vector/v.out.svg/main.c:73
+#: ../vector/v.out.ogr/main.c:96
+#: ../vector/v.out.pov/main.c:43
+#: ../vector/v.out.dxf/main.c:48
+#: ../vector/v.out.vtk/main.c:46
msgid "vector, export"
msgstr ""
#: ../vector/v.out.ascii/out.c:47
#, fuzzy
msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-msgstr ""
-"Convertit une couche vecteur binaire GRASS en couche vecteur ASCII GRASS"
+msgstr "Convertit une couche vecteur binaire GRASS en couche vecteur ASCII GRASS"
#: ../vector/v.out.ascii/out.c:54
msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-msgstr ""
-"Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si '-"
-"o' est défini"
+msgstr "Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si '-o' est défini"
#: ../vector/v.out.ascii/out.c:66
#, fuzzy
@@ -26180,16 +26253,15 @@
msgid "'output' must be given for old version"
msgstr "la sortie 'output' doit être spécifiée pour l'ancienne version"
-#: ../vector/v.out.ascii/out.c:140 ../vector/v.out.vtk/main.c:186
+#: ../vector/v.out.ascii/out.c:140
+#: ../vector/v.out.vtk/main.c:186
#, fuzzy
msgid "Failed to interpret 'dp' parameter as an integer"
msgstr "Echec pour interpréter dp comme valeur entière (integer)"
#: ../vector/v.out.ascii/out.c:147
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
#: ../vector/v.out.ascii/out.c:185
@@ -26259,20 +26331,20 @@
#: ../vector/v.support/main.c:110
#, fuzzy
msgid "Text to append to the comment line of the map's metadata file"
-msgstr ""
-"Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
+msgstr "Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
msgstr ""
#: ../vector/v.support/main.c:122
msgid "Replace comment instead of appending it"
msgstr ""
-#: ../vector/v.support/main.c:129 ../vector/v.build/main.c:84
-#: ../vector/v.edit/main.c:120 ../vector/v.neighbors/main.c:77
+#: ../vector/v.support/main.c:129
+#: ../vector/v.build/main.c:84
+#: ../vector/v.edit/main.c:120
+#: ../vector/v.neighbors/main.c:77
#, fuzzy, c-format
msgid "Vector map <%s> not found in the current mapset"
msgstr "couche vecteur <%s> introuvable"
@@ -26283,7 +26355,8 @@
msgid "Unable to open history file for vector map <%s>"
msgstr "Impossible d'ouvrir le curseur sélectionné : '%s'"
-#: ../vector/v.build/main.c:34 ../vector/v.clean/main.c:43
+#: ../vector/v.build/main.c:34
+#: ../vector/v.clean/main.c:43
#, fuzzy
msgid "vector, topology"
msgstr "Boîte à outil pour nettoyer la topologie vectorielle"
@@ -26303,9 +26376,7 @@
msgstr ""
#: ../vector/v.build/main.c:55
-msgid ""
-"build;build topology;dump;write topology to stdout;sdump;write spatial index "
-"to stdout;cdump;write category index to stdout"
+msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
msgstr ""
#: ../vector/v.edit/args.c:38
@@ -26318,34 +26389,18 @@
msgstr ""
#: ../vector/v.edit/args.c:55
-msgid ""
-"create;Create new (empty) vector map;add;Add new features to existing vector "
-"map;delete;Delete selected features from vector map;move;Move selected "
-"features in vector map;vertexmove;Move vertex of selected vector lines;"
-"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
-"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
-"vector lines;select;Select lines and print their ID's;catadd;Set new "
-"categories to selected vector features for defined layer;catdel;Delete "
-"categories from selected vector features for defined layer;copy;Copy "
-"selected features;snap;Snap vector features in given threshold;flip;Flip "
-"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
-"labeling (automated assignment of z coordinate to vector lines);chtype;"
-"Change feature type (point<->centroid, line<->boundary)"
+msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
msgstr ""
#: ../vector/v.edit/args.c:100
#, fuzzy
msgid "ASCII file to be converted to binary vector map"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../vector/v.edit/args.c:102
#, fuzzy
msgid "If not given (or \"-\") reads from standard input"
-msgstr ""
#: ../vector/v.edit/args.c:112
msgid "Difference in x,y direction for moving feature or vertex"
@@ -26384,9 +26439,7 @@
msgstr ""
#: ../vector/v.edit/args.c:170
-msgid ""
-"length;Select only lines or boundaries shorter/longer than threshold "
-"distance;dangle;Select dangles shorter/longer than threshold distance"
+msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
msgstr ""
#: ../vector/v.edit/args.c:178
@@ -26395,15 +26448,11 @@
#: ../vector/v.edit/args.c:185
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
msgstr ""
#: ../vector/v.edit/args.c:187
-msgid ""
-"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
-"vertex"
+msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
msgstr ""
#: ../vector/v.edit/args.c:195
@@ -26414,7 +26463,8 @@
msgid "Pair: value,step (e.g. 1100,10)"
msgstr ""
-#: ../vector/v.edit/args.c:201 ../vector/v.extract/main.c:106
+#: ../vector/v.edit/args.c:201
+#: ../vector/v.extract/main.c:106
#: ../vector/v.select/args.c:88
#, fuzzy
msgid "Reverse selection"
@@ -26448,14 +26498,17 @@
msgid "At least one option from %s must be specified"
msgstr "2 couches doivent être spécifiées"
-#: ../vector/v.edit/args.c:309 ../vector/v.edit/args.c:318
-#: ../vector/v.edit/args.c:325 ../vector/v.edit/args.c:332
+#: ../vector/v.edit/args.c:309
+#: ../vector/v.edit/args.c:318
+#: ../vector/v.edit/args.c:325
+#: ../vector/v.edit/args.c:332
#: ../vector/v.edit/args.c:336
#, c-format
msgid "Tool %s requires option %s"
msgstr ""
-#: ../vector/v.edit/snap.c:111 ../vector/v.edit/a2b.c:328
+#: ../vector/v.edit/snap.c:111
+#: ../vector/v.edit/a2b.c:328
#, fuzzy, c-format
msgid "Unable to rewrite line %d"
msgstr "Impossible de créer le texte"
@@ -26466,9 +26519,7 @@
#: ../vector/v.edit/main.c:57
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
msgstr ""
#: ../vector/v.edit/main.c:66
@@ -26477,7 +26528,8 @@
msgstr "Ne pas afficher les codes de catégories"
# c-format
-#: ../vector/v.edit/main.c:78 ../vector/v.in.ascii/in.c:204
+#: ../vector/v.edit/main.c:78
+#: ../vector/v.in.ascii/in.c:204
#, fuzzy, c-format
msgid "Unable to open ASCII file <%s>"
msgstr "impossible d'ouvrir le fichier en entrée <%s>"
@@ -26486,16 +26538,15 @@
msgid "Creating new DB connection based on default mapset settings..."
msgstr ""
-#: ../vector/v.edit/main.c:131 ../vector/v.kcv/main.c:137
+#: ../vector/v.edit/main.c:131
+#: ../vector/v.kcv/main.c:137
#, fuzzy, c-format
msgid "Unable to open vector map <%s> at topological level %d"
#: ../vector/v.edit/main.c:154
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
#: ../vector/v.edit/main.c:169
@@ -26514,9 +26565,7 @@
#: ../vector/v.edit/main.c:229
#, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
msgstr ""
# c-format
@@ -26525,8 +26574,10 @@
msgid "%d features added"
msgstr "%d points écrits dans la couche vecteur"
-#: ../vector/v.edit/main.c:269 ../vector/v.edit/main.c:290
-#: ../vector/v.edit/main.c:298 ../vector/v.edit/main.c:323
+#: ../vector/v.edit/main.c:269
+#: ../vector/v.edit/main.c:290
+#: ../vector/v.edit/main.c:298
+#: ../vector/v.edit/main.c:323
#: ../vector/v.edit/main.c:360
#, fuzzy, c-format
msgid "Threshold value for snapping is %.2f"
@@ -26584,16 +26635,15 @@
# c-format
-#: ../vector/v.edit/main.c:338 ../vector/v.edit/main.c:342
+#: ../vector/v.edit/main.c:338
+#: ../vector/v.edit/main.c:342
#, fuzzy, c-format
msgid "%d features modified"
#: ../vector/v.edit/main.c:347
#, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
msgstr ""
# c-format
@@ -26650,13 +26700,15 @@
msgid "Layer must be > 0 for 'where'"
msgstr "'layer' doit être > 0 pour 'where'."
-#: ../vector/v.edit/a2b.c:85 ../vector/v.edit/a2b.c:123
+#: ../vector/v.edit/a2b.c:85
+#: ../vector/v.edit/a2b.c:123
#: ../vector/v.edit/a2b.c:147
#, fuzzy, c-format
msgid "Error reading ASCII file: '%s'"
msgstr "Erreur de lecture du fichier cats de <%s>"
-#: ../vector/v.edit/a2b.c:136 ../vector/v.in.ascii/a2b.c:103
+#: ../vector/v.edit/a2b.c:136
+#: ../vector/v.in.ascii/a2b.c:103
#, fuzzy
msgid "End of ASCII file reached before end of coordinates"
msgstr "Fichier ASCII conservant les coordonnées de transformation"
@@ -26692,16 +26744,18 @@
msgid "Name of DWG or DXF file"
msgstr "Nom du fichier d'étiquettes"
-#: ../vector/v.in.dwg/main.c:79 ../vector/v.in.dxf/main.c:107
+#: ../vector/v.in.dwg/main.c:79
+#: ../vector/v.in.dxf/main.c:107
msgid "List of layers to import"
msgstr "Fichier de couches à importer"
-#: ../vector/v.in.dwg/main.c:84 ../vector/v.in.dxf/main.c:88
+#: ../vector/v.in.dwg/main.c:84
+#: ../vector/v.in.dxf/main.c:88
msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
-"Inverser la sélection de couches (ne pas importer les couches dans la liste)"
+msgstr "Inverser la sélection de couches (ne pas importer les couches dans la liste)"
-#: ../vector/v.in.dwg/main.c:88 ../vector/v.in.ascii/in.c:141
+#: ../vector/v.in.dwg/main.c:88
+#: ../vector/v.in.ascii/in.c:141
#, fuzzy
msgid "Create 3D vector map"
@@ -26710,7 +26764,8 @@
msgid "Write circles as points (centre)"
msgstr ""
-#: ../vector/v.in.dwg/main.c:96 ../vector/v.in.dxf/main.c:82
+#: ../vector/v.in.dwg/main.c:96
+#: ../vector/v.in.dxf/main.c:82
#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
msgid "List available layers and exit"
msgstr "Lister les couches disponibles et quitter"
@@ -26786,7 +26841,8 @@
msgid "Bad arguments to pointfunc %s"
msgstr ""
-#: ../vector/v.mapcalc/vector.c:304 ../vector/v.mapcalc/number.c:216
+#: ../vector/v.mapcalc/vector.c:304
+#: ../vector/v.mapcalc/number.c:216
#, c-format
msgid "No function defined to perform ``point %c point''"
msgstr ""
@@ -26820,12 +26876,14 @@
msgstr "La connexion à la base de données n'a pas été définie\n"
# c-format
-#: ../vector/v.digit/form.c:108 ../vector/v.digit/generate.c:77
+#: ../vector/v.digit/form.c:108
+#: ../vector/v.digit/generate.c:77
#, fuzzy
msgid "Cannot open driver"
msgstr "Impossible d'utiliser le pilote %s"
-#: ../vector/v.digit/form.c:120 ../vector/v.digit/generate.c:89
+#: ../vector/v.digit/form.c:120
+#: ../vector/v.digit/generate.c:89
#, fuzzy
msgid "Cannot open database"
msgstr "Impossible d'ouvrir la base de données %s"
@@ -26874,26 +26932,41 @@
msgid "Digitize new %s:"
msgstr ""
-#: ../vector/v.digit/line.c:140 ../vector/v.digit/line.c:224
+#: ../vector/v.digit/line.c:140
+#: ../vector/v.digit/line.c:224
#: ../vector/v.digit/line.c:253
#, fuzzy
msgid "New point"
msgstr "Afficher"
-#: ../vector/v.digit/line.c:481 ../vector/v.digit/line.c:564
-#: ../vector/v.digit/line.c:566 ../vector/v.digit/line.c:620
-#: ../vector/v.digit/line.c:671 ../vector/v.digit/line.c:705
-#: ../vector/v.digit/vertex.c:36 ../vector/v.digit/vertex.c:56
-#: ../vector/v.digit/vertex.c:131 ../vector/v.digit/vertex.c:152
-#: ../vector/v.digit/vertex.c:200 ../vector/v.digit/vertex.c:220
-#: ../vector/v.digit/vertex.c:304 ../vector/v.digit/vertex.c:325
-#: ../vector/v.digit/vertex.c:373 ../vector/v.digit/vertex.c:471
-#: ../vector/v.digit/vertex.c:516 ../vector/v.digit/vertex.c:570
-#: ../vector/v.digit/vertex.c:633 ../vector/v.digit/vertex.c:669
-#: ../vector/v.digit/attr.c:192 ../vector/v.digit/attr.c:302
-#: ../vector/v.digit/attr.c:398 ../vector/v.digit/attr.c:403
-#: ../vector/v.digit/attr.c:407 ../vector/v.digit/attr.c:463
+#: ../vector/v.digit/line.c:481
+#: ../vector/v.digit/line.c:564
+#: ../vector/v.digit/line.c:566
+#: ../vector/v.digit/line.c:620
+#: ../vector/v.digit/line.c:671
+#: ../vector/v.digit/line.c:705
+#: ../vector/v.digit/vertex.c:36
+#: ../vector/v.digit/vertex.c:56
+#: ../vector/v.digit/vertex.c:131
+#: ../vector/v.digit/vertex.c:152
+#: ../vector/v.digit/vertex.c:200
+#: ../vector/v.digit/vertex.c:220
+#: ../vector/v.digit/vertex.c:304
+#: ../vector/v.digit/vertex.c:325
+#: ../vector/v.digit/vertex.c:373
+#: ../vector/v.digit/vertex.c:471
+#: ../vector/v.digit/vertex.c:516
+#: ../vector/v.digit/vertex.c:570
+#: ../vector/v.digit/vertex.c:633
+#: ../vector/v.digit/vertex.c:669
+#: ../vector/v.digit/attr.c:192
+#: ../vector/v.digit/attr.c:302
+#: ../vector/v.digit/attr.c:398
+#: ../vector/v.digit/attr.c:403
+#: ../vector/v.digit/attr.c:407
+#: ../vector/v.digit/attr.c:463
#, fuzzy
msgid "Quit tool"
msgstr "Silencieux"
@@ -26912,19 +26985,22 @@
msgid "Undo last point"
msgstr "Pas de points de départ"
-#: ../vector/v.digit/line.c:253 ../vector/v.digit/line.c:337
+#: ../vector/v.digit/line.c:253
+#: ../vector/v.digit/line.c:337
#: ../vector/v.digit/line.c:386
#, fuzzy
msgid "Close line"
msgstr "Echec de la fermeture."
-#: ../vector/v.digit/line.c:337 ../vector/v.digit/line.c:386
+#: ../vector/v.digit/line.c:386
#: ../vector/v.digit/line.c:407
#, fuzzy
msgid "New Point"
msgstr "Afficher"
#, fuzzy
msgid "Undo Last Point"
@@ -26938,25 +27014,36 @@
msgid "Delete point, line, boundary, or centroid:"
msgstr ""
-#: ../vector/v.digit/line.c:481 ../vector/v.digit/line.c:566
-#: ../vector/v.digit/line.c:620 ../vector/v.digit/line.c:705
-#: ../vector/v.digit/vertex.c:152 ../vector/v.digit/vertex.c:373
-#: ../vector/v.digit/vertex.c:669 ../vector/v.digit/attr.c:403
#, fuzzy
msgid "Select"
msgstr "Résolution"
-#: ../vector/v.digit/line.c:566 ../vector/v.digit/line.c:671
-#: ../vector/v.digit/vertex.c:130 ../vector/v.digit/vertex.c:303
-#: ../vector/v.digit/vertex.c:471 ../vector/v.digit/vertex.c:633
+#: ../vector/v.digit/vertex.c:130
+#: ../vector/v.digit/vertex.c:303
#, fuzzy
msgid "Unselect"
msgstr "Pas de moniteur sélectionné"
-#: ../vector/v.digit/line.c:564 ../vector/v.digit/vertex.c:130
msgid "Confirm and select next"
msgstr ""
@@ -26965,7 +27052,8 @@
msgid "Move point, line, boundary, or centroid:"
msgstr ""
-#: ../vector/v.digit/line.c:671 ../vector/v.digit/vertex.c:633
#, fuzzy
msgid "New location"
msgstr "Secteur (location) de la base de données"
@@ -26979,7 +27067,8 @@
msgid "Remove vertex:"
#, fuzzy
msgid "Select vertex"
@@ -27000,12 +27089,14 @@
# c-format
-#: ../vector/v.digit/c_face.c:183 ../vector/v.digit/c_face.c:241
+#: ../vector/v.digit/c_face.c:183
+#: ../vector/v.digit/c_face.c:241
#, c-format
msgid "Cannot open driver %s"
-#: ../vector/v.digit/c_face.c:189 ../vector/v.digit/c_face.c:251
+#: ../vector/v.digit/c_face.c:189
+#: ../vector/v.digit/c_face.c:251
#, c-format
msgid "Cannot open database %s"
@@ -27016,13 +27107,15 @@
msgid "Cannot open driver "
-#: ../vector/v.digit/c_face.c:252 ../vector/v.digit/attr.c:137
+#: ../vector/v.digit/c_face.c:252
+#: ../vector/v.digit/attr.c:137
#: ../vector/v.digit/attr.c:650
#, c-format
msgid "Cannot open database %s by driver %s"
msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
-#: ../vector/v.digit/c_face.c:269 ../vector/v.vol.rst/main.c:596
+#: ../vector/v.digit/c_face.c:269
+#: ../vector/v.vol.rst/main.c:596
#, c-format
msgid "Cannot create table: %s"
msgstr "Impossible de créer la table : %s"
@@ -27037,7 +27130,8 @@
msgid "Cannot create index:\n"
msgstr "Impossible de créer l'index"
-#: ../vector/v.digit/c_face.c:294 ../vector/v.db.connect/main.c:336
+#: ../vector/v.digit/c_face.c:294
+#: ../vector/v.db.connect/main.c:336
#, c-format
msgid "Cannot grant privileges on table %s"
msgstr "Impossible d'accorder des privilèges sur la table : %s"
@@ -27048,9 +27142,7 @@
#: ../vector/v.digit/c_face.c:312
-msgid ""
-"Cannot add database link to vector, link for given field probably already "
-"exists."
+msgid "Cannot add database link to vector, link for given field probably already exists."
msgstr ""
#: ../vector/v.digit/attr.c:94
@@ -27063,7 +27155,8 @@
msgid "Database table for this layer is not defined"
msgstr "La connexion à la base de données n'a pas été définie"
-#: ../vector/v.digit/attr.c:145 ../vector/v.digit/attr.c:659
+#: ../vector/v.digit/attr.c:145
+#: ../vector/v.digit/attr.c:659
#, fuzzy, c-format
msgid "Cannot select record from table %s"
@@ -27073,22 +27166,26 @@
msgid "Display categories:"
msgstr "%-5d catégories de la ligne lues\n"
-#: ../vector/v.digit/attr.c:192 ../vector/v.digit/attr.c:463
#, fuzzy
msgid "Select line"
msgstr "Résolution"
-#: ../vector/v.digit/attr.c:301 ../vector/v.digit/attr.c:406
+#: ../vector/v.digit/attr.c:301
+#: ../vector/v.digit/attr.c:406
#, fuzzy
msgid "Copy attributes:"
msgstr "Ne pas créer de table attributaire"
-#: ../vector/v.digit/attr.c:302 ../vector/v.digit/attr.c:407
#, fuzzy
msgid "Select source object"
msgstr "Projection source"
-#: ../vector/v.digit/attr.c:396 ../vector/v.digit/attr.c:402
+#: ../vector/v.digit/attr.c:396
+#: ../vector/v.digit/attr.c:402
#, fuzzy
msgid "Select the target object"
msgstr "Fixe la couleur du texte de la légende"
@@ -27145,9 +27242,7 @@
#: ../vector/v.digit/attr.c:668
#, c-format
-msgid ""
-"There are no more features with category %d (layer %d) in the map, but there "
-"is record in the table. Delete this record?"
+msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
msgstr ""
#: ../vector/v.digit/attr.c:680
@@ -27172,8 +27267,7 @@
#: ../vector/v.digit/generate.c:110
#, fuzzy, c-format
-msgid ""
-"Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
#: ../vector/v.digit/generate.c:121
@@ -27210,10 +27304,8 @@
#: ../vector/v.digit/main.c:157
#, fuzzy, c-format
-msgid ""
-"Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-msgstr ""
-"La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
+msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+msgstr "La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
#: ../vector/v.digit/centre.c:56
#, fuzzy
@@ -27225,7 +27317,8 @@
msgstr ""
# c-format
-#: ../vector/v.digit/var.c:80 ../vector/v.digit/var.c:101
+#: ../vector/v.digit/var.c:80
+#: ../vector/v.digit/var.c:101
#: ../vector/v.digit/var.c:122
#, fuzzy, c-format
msgid "Cannot set variable code = %d"
@@ -27247,7 +27340,8 @@
msgid "Cannot get name of variable %d"
msgstr "Impossible d'obtenir la liste des tables: \n"
-#: ../vector/v.digit/var.c:199 ../vector/v.digit/var.c:215
+#: ../vector/v.digit/var.c:199
+#: ../vector/v.digit/var.c:215
#: ../vector/v.digit/var.c:231
#, fuzzy, c-format
msgid "Cannot get value of variable code = %d"
@@ -27257,13 +27351,16 @@
msgid "Zoom by window"
msgstr ""
-#: ../vector/v.digit/zoom.c:27 ../vector/v.digit/zoom.c:44
+#: ../vector/v.digit/zoom.c:27
+#: ../vector/v.digit/zoom.c:44
#: ../vector/v.digit/zoom.c:75
msgid "1. corner"
msgstr ""
-#: ../vector/v.digit/zoom.c:75 ../vector/v.digit/zoom.c:158
+#: ../vector/v.digit/zoom.c:75
+#: ../vector/v.digit/zoom.c:158
#, fuzzy
msgid "Quit"
msgstr "Silencieux"
@@ -27299,15 +27396,11 @@
msgstr ""
#: ../vector/v.net.alloc/main.c:65
-msgid ""
-"Centre node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation"
+msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
msgstr ""
#: ../vector/v.net.alloc/main.c:110
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
+msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
msgstr ""
#: ../vector/v.net.alloc/main.c:186
@@ -27340,16 +27433,15 @@
#: ../vector/v.kcv/main.c:174
#, fuzzy, c-format
msgid "Unable to get layer info for vector map <%s>"
-msgstr ""
-"vectorielle"
#: ../vector/v.kcv/main.c:198
#, fuzzy, c-format
msgid "Cannot alter table: %s"
-#: ../vector/v.kcv/main.c:270 ../vector/v.sample/main.c:289
+#: ../vector/v.kcv/main.c:270
+#: ../vector/v.sample/main.c:289
#, fuzzy, c-format
msgid "Unable to insert row: %s"
msgstr "Impossible d'insérer une nouvelle ligne : %s"
@@ -27360,9 +27452,7 @@
msgstr "Importation vecteur complète"
#: ../vector/v.extract/main.c:93
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
msgstr ""
#: ../vector/v.extract/main.c:98
@@ -27381,11 +27471,8 @@
#: ../vector/v.extract/main.c:122
#, fuzzy
-msgid ""
-"Layer number (if -1, all features in all layers of given type are extracted)"
-msgstr ""
-"Code de couche. Si fixé à -1, tous les objets de toutes les couches du type "
-"donné sont extraites."
+msgid "Layer number (if -1, all features in all layers of given type are extracted)"
+msgstr "Code de couche. Si fixé à -1, tous les objets de toutes les couches du type donné sont extraites."
#: ../vector/v.extract/main.c:136
#, fuzzy
@@ -27395,9 +27482,7 @@
#: ../vector/v.extract/main.c:137
#, fuzzy
msgid "If '-' given reads from standard input"
-msgstr ""
#: ../vector/v.extract/main.c:145
msgid "Number of random categories matching vector objects to extract"
@@ -27410,21 +27495,18 @@
#: ../vector/v.extract/main.c:156
#, fuzzy
msgid "Enter -1 to keep original categories or the desired NEW category value"
-msgstr ""
-"Saisir -1 pour conserver la catégorie originale ou la valeur de la NOUVELLE "
-"catégorie souhaitée. Si la nouvelle est >= 0, la table n'est pas copiée."
+msgstr "Saisir -1 pour conserver la catégorie originale ou la valeur de la NOUVELLE catégorie souhaitée. Si la nouvelle est >= 0, la table n'est pas copiée."
#: ../vector/v.extract/main.c:157
msgid "If new >= 0, table is not copied"
msgstr ""
#: ../vector/v.extract/main.c:175
-msgid ""
-"List, file, where and random options are exclusive. Please specify only one "
-"of them"
+msgid "List, file, where and random options are exclusive. Please specify only one of them"
msgstr ""
-#: ../vector/v.extract/main.c:204 ../vector/v.drape/main.c:220
+#: ../vector/v.extract/main.c:204
+#: ../vector/v.drape/main.c:220
msgid "Layer 0 not supported"
msgstr "Couche 0 non gérée"
@@ -27461,9 +27543,7 @@
msgstr "%d catégories chargées depuis la table"
#: ../vector/v.extract/main.c:313
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
msgstr ""
#: ../vector/v.extract/main.c:319
@@ -27473,16 +27553,12 @@
#: ../vector/v.extract/main.c:323
#, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
msgstr ""
#: ../vector/v.extract/main.c:346
#, c-format
-msgid ""
-"Random category count is larger or equal to uniq \"%s\" feature category "
-"count %d"
+msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
msgstr ""
# c-format
@@ -27491,13 +27567,15 @@
msgid "Extracting features..."
msgstr "Écriture %s..."
-#: ../vector/v.extract/main.c:428 ../vector/v.select/main.c:480
+#: ../vector/v.extract/main.c:428
+#: ../vector/v.select/main.c:480
#: ../vector/v.generalize/misc.c:127
#, fuzzy
msgid "Writing attributes..."
-#: ../vector/v.extract/main.c:481 ../vector/v.in.db/main.c:225
+#: ../vector/v.extract/main.c:481
+#: ../vector/v.in.db/main.c:225
#, fuzzy
msgid "Unable to copy table"
msgstr "Impossible d'ouvrir le fichier de sortie"
@@ -27507,8 +27585,10 @@
msgid "Removing duplicate centroids..."
msgstr "Suppression des centroïdes en doublons..."
-#: ../vector/v.db.connect/main.c:50 ../vector/v.distance/main.c:114
-#: ../vector/v.to.db/main.c:33 ../vector/v.db.select/main.c:53
+#: ../vector/v.db.connect/main.c:50
+#: ../vector/v.distance/main.c:114
+#: ../vector/v.to.db/main.c:33
+#: ../vector/v.db.select/main.c:53
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
#: ../locale/scriptstrings/v.db.join_to_translate.c:2
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
@@ -27525,16 +27605,15 @@
#: ../vector/v.db.connect/main.c:52
#, fuzzy
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Affiche/configure la connexion à la base de données de la couche vecteur "
-"vers une table attributaire"
+msgstr "Affiche/configure la connexion à la base de données de la couche vecteur vers une table attributaire"
#: ../vector/v.db.connect/main.c:72
#, fuzzy
msgid "Key column name"
msgstr "Nom de la colonne y"
-#: ../vector/v.db.connect/main.c:73 ../vector/v.in.db/main.c:87
+#: ../vector/v.db.connect/main.c:73
+#: ../vector/v.in.db/main.c:87
#, fuzzy
msgid "Must refer to an integer column"
msgstr "Nom de la clef primaire (doit faire référence à une colonne d'entier)"
@@ -27564,9 +27643,7 @@
#: ../vector/v.db.connect/main.c:108
msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Affiche les types/noms des colonnes de la table pour une couche spécifiée et "
-"quitte"
+msgstr "Affiche les types/noms des colonnes de la table pour une couche spécifiée et quitte"
#: ../vector/v.db.connect/main.c:115
msgid "Overwrite connection parameter for certain layer"
@@ -27581,12 +27658,11 @@
msgid "Unable to modify vector map stored in other mapset"
msgstr "Afficher des couches vecteur plutôt que des couches raster"
-#: ../vector/v.db.connect/main.c:161 ../vector/v.info/main.c:199
+#: ../vector/v.db.connect/main.c:161
+#: ../vector/v.info/main.c:199
#, c-format
msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"La connexion à la base de données pour la couche <%s> n'a pas été définie "
-"dans le fichier Base de données"
+msgstr "La connexion à la base de données pour la couche <%s> n'a pas été définie dans le fichier Base de données"
#: ../vector/v.db.connect/main.c:170
#, fuzzy, c-format
@@ -27595,8 +27671,7 @@
#: ../vector/v.db.connect/main.c:198
#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
#: ../vector/v.db.connect/main.c:261
@@ -27604,43 +27679,39 @@
msgid "Use -o to overwrite existing link for layer <%d>"
msgstr "Utilisez -o pour écraser le lien existant pour la couche <%d>"
-#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
+#: ../vector/v.db.connect/main.c:269
+#: ../vector/v.db.connect/main.c:309
#, c-format
msgid "Table <%s> does not exist in database <%s>"
msgstr "La table <%s> n'existe pas dans la base de données <%s>"
# c-format
-#: ../vector/v.db.connect/main.c:284 ../vector/v.transform/trans_digit.c:106
+#: ../vector/v.db.connect/main.c:284
+#: ../vector/v.transform/trans_digit.c:106
#: ../vector/v.in.db/main.c:138
#, fuzzy, c-format
msgid "Missing column <%s> in table <%s>"
-#: ../vector/v.db.connect/main.c:290 ../vector/v.in.db/main.c:141
+#: ../vector/v.db.connect/main.c:290
+#: ../vector/v.in.db/main.c:141
#, fuzzy
msgid "Data type of key column must be integer"
msgstr "La clef primaire doit être un entier"
-#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
+#: ../vector/v.db.connect/main.c:297
+#: ../vector/v.db.connect/main.c:315
#, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"La table <%s> fait à présent partie de la couche vectorielle <%s> et risque "
-"d'être effacée ou écrasée par les modules GRASS"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "La table <%s> fait à présent partie de la couche vectorielle <%s> et risque d'être effacée ou écrasée par les modules GRASS"
#: ../vector/v.db.connect/main.c:339
msgid "Select privileges were granted on the table"
msgstr "Des droits de sélection ont été accordés sur cette table"
#: ../vector/v.db.connect/main.c:346
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Pour définir une nouvelle connexion vous devez spécifier ces paramètres : "
-"pilote, base de données, table [, clef [, couche]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Pour définir une nouvelle connexion vous devez spécifier ces paramètres : pilote, base de données, table [, clef [, couche]]"
#: ../vector/v.delaunay2/main.c:141
#, fuzzy
@@ -27661,7 +27732,8 @@
msgid "Calculate area centroids..."
msgstr "Impossible de calculer le centroïde de l'entité surfacique"
-#: ../vector/v.delaunay2/main.c:172 ../vector/v.category/main.c:261
+#: ../vector/v.delaunay2/main.c:172
+#: ../vector/v.category/main.c:261
#, fuzzy
msgid "Unable to calculate area centroid"
msgstr "Impossible de calculer le centroïde de la surface"
@@ -27671,9 +27743,12 @@
msgid "Unable to calculate area centroid z coordinate"
-#: ../vector/v.delaunay2/memory.c:64 ../vector/v.delaunay2/memory.c:70
-#: ../vector/v.delaunay2/memory.c:74 ../vector/v.delaunay2/memory.c:84
-#: ../vector/v.delaunay2/memory.c:92 ../vector/v.delaunay2/memory.c:104
+#: ../vector/v.delaunay2/memory.c:64
+#: ../vector/v.delaunay2/memory.c:70
+#: ../vector/v.delaunay2/memory.c:74
+#: ../vector/v.delaunay2/memory.c:84
+#: ../vector/v.delaunay2/memory.c:92
+#: ../vector/v.delaunay2/memory.c:104
#: ../vector/v.delaunay2/memory.c:108
#, fuzzy
msgid "Not enough memory."
@@ -27686,16 +27761,12 @@
#: ../vector/v.in.ascii/in.c:50
#, fuzzy
msgid "Creates a vector map from ASCII points file or ASCII vector file."
-msgstr ""
-"Convertit une couche vecteur binaire GRASS en la combinant avec d'autres "
-"couches vectorielles binaires."
+msgstr "Convertit une couche vecteur binaire GRASS en la combinant avec d'autres couches vectorielles binaires."
#: ../vector/v.in.ascii/in.c:56
#, fuzzy
msgid "ASCII file to be imported, if not given reads from standard input"
-msgstr ""
#: ../vector/v.in.ascii/in.c:67
msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
@@ -27706,7 +27777,8 @@
msgid "Input file format"
msgstr "Fichier source"
-#: ../vector/v.in.ascii/in.c:71 ../vector/v.in.ascii/in.c:74
+#: ../vector/v.in.ascii/in.c:71
+#: ../vector/v.in.ascii/in.c:74
#: ../vector/v.in.ascii/in.c:152
#, fuzzy
msgid "Input format"
@@ -27715,9 +27787,7 @@
#: ../vector/v.in.ascii/in.c:83
#, fuzzy
msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-"Nombre de lignes d'en-tête à sauter au début du fichier source (écrit dans "
-"l'historique de la carte)"
+msgstr "Nombre de lignes d'en-tête à sauter au début du fichier source (écrit dans l'historique de la carte)"
#: ../vector/v.in.ascii/in.c:92
msgid "Column definition in SQL style (points mode)"
@@ -27725,54 +27795,40 @@
#: ../vector/v.in.ascii/in.c:93
#, fuzzy
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
msgstr ""
"Définition des colonnes en mode points en SQL, par exemple:\n"
"'x double précision, y double précision, cat int, name varchar(10)'"
-#: ../vector/v.in.ascii/in.c:105 ../vector/v.in.ascii/in.c:115
+#: ../vector/v.in.ascii/in.c:105
+#: ../vector/v.in.ascii/in.c:115
msgid "First column is 1"
msgstr ""
#: ../vector/v.in.ascii/in.c:114
#, fuzzy
msgid "Number of column used as y coordinate (points mode)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées y (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées y (la première colonne est 1) en mode points"
#: ../vector/v.in.ascii/in.c:124
#, fuzzy
msgid "Number of column used as z coordinate (points mode)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode points"
#: ../vector/v.in.ascii/in.c:125
#, fuzzy
msgid "First column is 1. If 0, z coordinate is not used"
-msgstr ""
-"en mode pointsSi la valeur est 0, les coordonnées z ne sont pas utilisées."
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode pointsSi la valeur est 0, les coordonnées z ne sont pas utilisées."
#: ../vector/v.in.ascii/in.c:135
#, fuzzy
msgid "Number of column used as category (points mode)"
-msgstr ""
-"en mode points"
#: ../vector/v.in.ascii/in.c:137
#, fuzzy
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
-msgstr ""
-"Nombre de colonne utilisé comme catégorie (la première colonne est 1) en "
-"mode pointsSi la valeur est 0, une catégorie unique est assignée à chaque "
-"ligne et écrit dans la nouvelle colonne 'cat'."
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "Nombre de colonne utilisé comme catégorie (la première colonne est 1) en mode pointsSi la valeur est 0, une catégorie unique est assignée à chaque ligne et écrit dans la nouvelle colonne 'cat'."
#: ../vector/v.in.ascii/in.c:146
#, fuzzy
@@ -27847,16 +27903,14 @@
#: ../vector/v.in.ascii/in.c:271
#, fuzzy
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
msgstr ""
"numéro de colonne z > numéro de dernière colonne\n"
"(séparateur de champ erroné?)"
#: ../vector/v.in.ascii/in.c:276
#, fuzzy
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
msgstr ""
"numéro de colonne cat > numéro de dernière colonne\n"
@@ -27883,24 +27937,18 @@
#: ../vector/v.in.ascii/in.c:417
#, fuzzy, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr ""
-"Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)"
-"de la source."
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr "Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)de la source."
#: ../vector/v.in.ascii/in.c:445
#, fuzzy, c-format
msgid "Column number %d <%s> defined as double has only integer values"
-msgstr ""
-"La colonne %d définie comme double ne contient que des valeurs entières"
+msgstr "La colonne %d définie comme double ne contient que des valeurs entières"
#: ../vector/v.in.ascii/in.c:450
#, fuzzy, c-format
msgid "Column number %d <%s> defined as string has only integer values"
-msgstr ""
-"La colonne %d définie comme chaîne de caractères ne contient que des valeurs "
-"entières"
+msgstr "La colonne %d définie comme chaîne de caractères ne contient que des valeurs entières"
#: ../vector/v.in.ascii/in.c:458
#, fuzzy, c-format
@@ -27925,9 +27973,7 @@
#: ../vector/v.in.ascii/in.c:483
#, fuzzy, c-format
msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-"La longeur de la colonne %d (%d) est inférieure à la longueur de la plus "
-"grande valeur (%d)"
+msgstr "La longeur de la colonne %d (%d) est inférieure à la longueur de la plus grande valeur (%d)"
#: ../vector/v.in.ascii/in.c:523
#, fuzzy
@@ -27935,9 +27981,7 @@
#: ../vector/v.in.ascii/in.c:530
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
msgstr ""
# c-format
@@ -28018,8 +28062,10 @@
msgid "Importing points..."
msgstr "Importation des objets de la couche %d..."
-#: ../vector/v.in.ascii/points.c:405 ../vector/v.mkgrid/main.c:309
-#: ../vector/v.in.sites/main.c:240 ../vector/v.in.dxf/write_vect.c:58
+#: ../vector/v.in.ascii/points.c:405
+#: ../vector/v.mkgrid/main.c:309
+#: ../vector/v.in.sites/main.c:240
+#: ../vector/v.in.dxf/write_vect.c:58
#, fuzzy, c-format
msgid "Unable to insert new record: %s"
@@ -28040,9 +28086,7 @@
#: ../vector/v.sample/main.c:98
msgid "Vector map attribute column to use for comparison"
-msgstr ""
-"Nom du champ attributaire de la couche vectorielle à utiliser pour la "
-"comparaison"
+msgstr "Nom du champ attributaire de la couche vectorielle à utiliser pour la comparaison"
#: ../vector/v.sample/main.c:101
msgid "Vector map to store differences"
@@ -28053,12 +28097,8 @@
msgstr "couche raster à échantillonner"
#: ../vector/v.sample/main.c:113
-msgid ""
-"Option scaling factor for values read from raster map. Sampled values will "
-"be multiplied by this factor"
-msgstr ""
-"Option de facteur d'échelle pour les valeurs lues dans la couche raster. Les "
-"valeurs échantillonnées seront multipliées par ce facteur"
+msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
+msgstr "Option de facteur d'échelle pour les valeurs lues dans la couche raster. Les valeurs échantillonnées seront multipliées par ce facteur"
#: ../vector/v.sample/main.c:119
#, fuzzy
@@ -28068,15 +28108,12 @@
#: ../vector/v.sample/main.c:124
#, fuzzy
msgid "Cubic convolution interpolation (default is nearest neighbor)"
-msgstr ""
-"Outil d'interpolation par convolution cubique [par défaut plus proche voisin]"
+msgstr "Outil d'interpolation par convolution cubique [par défaut plus proche voisin]"
#: ../vector/v.sample/main.c:142
#, fuzzy
msgid "Flags -b & -c are mutually exclusive. Choose only one."
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
# c-format
#: ../vector/v.sample/main.c:181
@@ -28084,14 +28121,16 @@
msgid "Column type <%s> not supported (must be integer or double precision)"
msgstr "Type de colonne (%s) non géré"
-#: ../vector/v.sample/main.c:187 ../vector/v.normal/main.c:155
+#: ../vector/v.sample/main.c:187
+#: ../vector/v.normal/main.c:155
#: ../vector/v.surf.idw/read_sites.c:54
#, c-format
msgid "%d records selected from table"
msgstr "%d enregistrements sélectionnés dans le tableau"
# c-format
-#: ../vector/v.sample/main.c:216 ../vector/v.patch/main.c:285
+#: ../vector/v.sample/main.c:216
+#: ../vector/v.patch/main.c:285
#, fuzzy, c-format
msgid "Unable to create table <%s>"
msgstr "impossible de créer la sortie <%s>"
@@ -28102,9 +28141,7 @@
msgstr "Vérification des points vecteurs..."
#: ../vector/v.distance/main.c:116
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
msgstr ""
#: ../vector/v.distance/main.c:120
@@ -28157,19 +28194,11 @@
msgstr ""
#: ../vector/v.distance/main.c:181
-msgid ""
-"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
-"to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate "
-"of the nearest point on the 'to' feature;to_along;distance to the nearest "
-"point on the 'to' feature along that linear feature;to_angle;angle along the "
-"nearest linear feature in the 'to' map, measured CCW from the +x axis, in "
-"radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature "
-"given by to_column option"
+msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
msgstr ""
#: ../vector/v.distance/main.c:202
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
msgstr ""
#: ../vector/v.distance/main.c:203
@@ -28198,9 +28227,7 @@
msgstr ""
#: ../vector/v.distance/main.c:228
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
msgstr ""
#: ../vector/v.distance/main.c:280
@@ -28306,32 +28333,35 @@
msgstr "%d catégories de la couche vecteur manquantes dans la table"
# c-format
-#: ../vector/v.distance/main.c:1151 ../vector/v.what.rast/main.c:377
+#: ../vector/v.distance/main.c:1151
+#: ../vector/v.what.rast/main.c:377
#, c-format
msgid "%d records updated"
msgstr "%d enregistrements mis à jour"
# c-format
-#: ../vector/v.distance/main.c:1153 ../vector/v.what.rast/main.c:378
+#: ../vector/v.distance/main.c:1153
+#: ../vector/v.what.rast/main.c:378
#, c-format
msgid "%d update errors"
msgstr "%d erreurs de mise à jour"
# c-format
-#: ../vector/v.to.db/query.c:23 ../vector/v.to.db/lines.c:75
+#: ../vector/v.to.db/query.c:23
+#: ../vector/v.to.db/lines.c:75
#: ../vector/v.to.rast/do_lines.c:35
#, fuzzy
msgid "Reading features..."
msgstr "Lecture du fichier %s..."
# c-format
-#: ../vector/v.to.db/query.c:83 ../vector/v.to.db/main.c:48
-#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
+#: ../vector/v.to.db/query.c:83
+#: ../vector/v.to.db/main.c:48
+#: ../vector/v.to.db/update.c:28
+#: ../vector/v.to.db/update.c:32
#, fuzzy, c-format
msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>. "
-"Utilisez d'abord v.db.connect."
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>. Utilisez d'abord v.db.connect."
# c-format
#: ../vector/v.to.db/query.c:93
@@ -28341,9 +28371,7 @@
#: ../vector/v.to.db/query.c:108
#, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
msgstr ""
#: ../vector/v.to.db/query.c:145
@@ -28377,7 +28405,8 @@
msgstr "Le vecteur '%s' existe déjà."
# c-format
-#: ../vector/v.to.db/update.c:221 ../vector/v.to.3d/trans3.c:129
+#: ../vector/v.to.db/update.c:221
+#: ../vector/v.to.3d/trans3.c:129
#, fuzzy, c-format
msgid "Record (cat %d) does not exist (not updated)"
msgstr "La couche raster [%s] n'existe pas"
@@ -28385,9 +28414,7 @@
#: ../vector/v.to.db/parse.c:38
#, fuzzy
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Type d'éléments (pour les coord point/centroïde valide, pour la longueur "
-"ligne/contour valide)"
+msgstr "Type d'éléments (pour les coord point/centroïde valide, pour la longueur ligne/contour valide)"
#: ../vector/v.to.db/parse.c:42
#, fuzzy
@@ -28399,7 +28426,8 @@
msgid "Query layer number (read from)"
-#: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:99
+#: ../vector/v.to.db/parse.c:47
+#: ../vector/v.to.db/parse.c:99
#: ../db/base/execute.c:118
#, fuzzy
msgid "Query"
@@ -28411,8 +28439,7 @@
#: ../vector/v.to.db/parse.c:87
#, fuzzy
-msgid ""
-"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
msgstr "mi(les), f(pieds), me(tres), k(ilomètres), a(cres), h(ectares)"
#: ../vector/v.to.db/parse.c:93
@@ -28423,9 +28450,7 @@
#: ../vector/v.to.db/parse.c:94
#, fuzzy
msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
-msgstr ""
-"Lancer une requête sur la colonne par l'option 'query'. Par exemple, 'cat', "
-"'count(*)', 'sum(val)'"
+msgstr "Lancer une requête sur la colonne par l'option 'query'. Par exemple, 'cat', 'count(*)', 'sum(val)'"
#: ../vector/v.to.db/parse.c:103
#, fuzzy
@@ -28439,8 +28464,7 @@
#: ../vector/v.to.db/parse.c:114
msgid "In print mode prints totals for options: length,area,count"
-msgstr ""
-"En mode affichage, affiche les totaux des options : longueur, aire, comptage"
+msgstr "En mode affichage, affiche les totaux des options : longueur, aire, comptage"
#: ../vector/v.to.db/parse.c:153
msgid "This option requires one column"
@@ -28516,7 +28540,8 @@
msgstr "%d catégories chargées depuis la couche vecteur"
# c-format
-#: ../vector/v.to.db/areas.c:28 ../vector/v.to.rast/do_areas.c:33
+#: ../vector/v.to.db/areas.c:28
+#: ../vector/v.to.rast/do_areas.c:33
#, fuzzy
msgid "Reading areas..."
@@ -28541,9 +28566,7 @@
msgstr ""
#: ../vector/v.parallel2/main.c:85
-msgid ""
-"left;Parallel line is on the left;right;Parallel line is on the right;both;"
-"Parallel lines on both sides"
+msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
msgstr ""
#: ../vector/v.parallel2/main.c:95
@@ -28602,8 +28625,7 @@
#: ../vector/v.mkgrid/main.c:111
#, fuzzy
msgid "Angle of rotation (in degrees counter-clockwise)"
-msgstr ""
-"Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
+msgstr "Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
# c-format
#: ../vector/v.mkgrid/main.c:119
@@ -28641,7 +28663,8 @@
msgstr "Coordonnées invalides : %s %s"
# c-format
-#: ../vector/v.mkgrid/main.c:203 ../vector/v.mkgrid/main.c:206
+#: ../vector/v.mkgrid/main.c:203
+#: ../vector/v.mkgrid/main.c:206
#, fuzzy
msgid "Invalid distance"
msgstr "Etiquette date&heure invalide"
@@ -28679,10 +28702,7 @@
msgstr "Nom de colonne de catégorie"
#: ../vector/v.build.polylines/main.c:123
-msgid ""
-"no;Do not assign any category number to polyline;first;Assign category "
-"number of first line to polyline;multi;Assign multiple category numbers to "
-"polyline"
+msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
msgstr ""
# c-format
@@ -28749,12 +28769,7 @@
msgstr "Icone à supprimer"
#: ../vector/v.category/main.c:84
-msgid ""
-"add;add a new category;del;delete all categories of given layer;chlayer;"
-"change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the "
-"value specified by cat option to the current category value;report;print "
-"report (statistics), in shell style: layer type count min max;print;print "
-"category values, more cats in the same layer are separated by '/'"
+msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
msgstr ""
#: ../vector/v.category/main.c:100
@@ -28775,14 +28790,11 @@
msgstr ""
#: ../vector/v.category/main.c:135
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
msgstr ""
#: ../vector/v.category/main.c:153
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
msgstr ""
#: ../vector/v.category/main.c:162
@@ -28803,7 +28815,8 @@
msgid "Output vector wasn't entered"
msgstr "La couche de vecteur en sortie n'a pas été saisie."
-#: ../vector/v.category/main.c:229 ../vector/v.select/main.c:149
+#: ../vector/v.category/main.c:229
+#: ../vector/v.select/main.c:149
#, fuzzy
msgid "Processing features..."
msgstr "Traitement des entités surfaciques ainput..."
@@ -28911,7 +28924,8 @@
msgid "Sink layer number or name"
-#: ../vector/v.net.flow/main.c:103 ../vector/v.net.flow/main.c:108
+#: ../vector/v.net.flow/main.c:103
+#: ../vector/v.net.flow/main.c:108
#: ../vector/v.net.flow/main.c:114
msgid "Sink"
msgstr ""
@@ -28926,7 +28940,8 @@
msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
msgstr "Conditions WHERE de la requête SQL sans le mot clef 'where'"
-#: ../vector/v.net.flow/main.c:186 ../vector/v.net.flow/main.c:191
+#: ../vector/v.net.flow/main.c:186
+#: ../vector/v.net.flow/main.c:191
#: ../vector/v.net.connectivity/main.c:130
#: ../vector/v.net.connectivity/main.c:135
#, fuzzy, c-format
@@ -28982,40 +28997,33 @@
msgid "Lines buffers... "
msgstr "Recherche des classes d'apprentissage..."
-#: ../vector/v.buffer/main.c:492 ../vector/v.buffer/main.c:569
+#: ../vector/v.buffer/main.c:492
+#: ../vector/v.buffer/main.c:569
#, c-format
msgid "The tolerance was reset to %g (map units). [category %d]"
-msgstr ""
-"La tolérance a été réinitialisée à %g (en unités cartes). [catégorie %d]"
+msgstr "La tolérance a été réinitialisée à %g (en unités cartes). [catégorie %d]"
#: ../vector/v.buffer/main.c:509
#, fuzzy
msgid "Areas buffers... "
msgstr "couche raster source"
-#: ../vector/v.surf.rst/main.c:164 ../vector/lidar/v.surf.bspline/main.c:83
-#: ../vector/v.vol.rst/main.c:202 ../vector/v.surf.idw/main.c:84
+#: ../vector/v.surf.rst/main.c:164
+#: ../vector/lidar/v.surf.bspline/main.c:83
+#: ../vector/v.vol.rst/main.c:202
+#: ../vector/v.surf.idw/main.c:84
#, fuzzy
msgid "vector, interpolation"
msgstr "Nombre de points d'interpolation"
#: ../vector/v.surf.rst/main.c:166
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Ré-interpole de façon approchée et fait une analyse topographique depuis une "
-"couche vecteur de points ou d'isolignes vers une nouvelle couche raster (en "
-"valeurs flottantes) en utilisant des splines régularisées avec tension et "
-"lissage."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Ré-interpole de façon approchée et fait une analyse topographique depuis une couche vecteur de points ou d'isolignes vers une nouvelle couche raster (en valeurs flottantes) en utilisant des splines régularisées avec tension et lissage."
#: ../vector/v.surf.rst/main.c:192
#, fuzzy
msgid "Use z-coordinates (3D vector only)"
-msgstr ""
-"Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D "
-"seulement)"
+msgstr "Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
#: ../vector/v.surf.rst/main.c:198
msgid "Perform cross-validation procedure without raster approximation"
@@ -29025,7 +29033,8 @@
msgid "Use scale dependent tension"
msgstr "Utiliser une tension dépendante de l'échelle"
-#: ../vector/v.surf.rst/main.c:216 ../vector/lidar/v.surf.bspline/main.c:150
+#: ../vector/v.surf.rst/main.c:216
+#: ../vector/lidar/v.surf.bspline/main.c:150
msgid "If set to 0, z coordinates are used. (3D vector only)"
msgstr "Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
@@ -29053,14 +29062,14 @@
msgid "Output mean curvature raster map"
msgstr "Nom du fichier raster en sortie pour la courbure moyenne du profil"
-#: ../vector/v.surf.rst/main.c:265 ../vector/v.vol.rst/main.c:286
+#: ../vector/v.surf.rst/main.c:265
+#: ../vector/v.vol.rst/main.c:286
msgid "Output deviations vector point file"
msgstr "Fichier en sortie de déviations de vecteurs points"
#: ../vector/v.surf.rst/main.c:272
msgid "Output cross-validation errors vector point file"
-msgstr ""
-"Fichier en sortie de validation croisée des erreurs sur vecteurs points"
+msgstr "Fichier en sortie de validation croisée des erreurs sur vecteurs points"
#: ../vector/v.surf.rst/main.c:279
msgid "Output vector map showing quadtree segmentation"
@@ -29070,23 +29079,22 @@
msgid "Output vector map showing overlapping windows"
msgstr "Fichier vecteur en sortie montrant le recouvrement des fenêtres"
-#: ../vector/v.surf.rst/main.c:292 ../vector/v.vol.rst/main.c:302
+#: ../vector/v.surf.rst/main.c:292
+#: ../vector/v.vol.rst/main.c:302
msgid "Name of the raster map used as mask"
msgstr "Nom de la couche raster utilisée comme masque (MASK)"
#: ../vector/v.surf.rst/main.c:300
-msgid ""
-"Name of the attribute column with values to be used for approximation (if "
-"layer>0)"
-msgstr ""
-"Nom de la colonne attributaire où prendre les valeurs à utiliser pour "
-"calculer les valeurs approchées(si couche>0)"
+msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
+msgstr "Nom de la colonne attributaire où prendre les valeurs à utiliser pour calculer les valeurs approchées(si couche>0)"
-#: ../vector/v.surf.rst/main.c:308 ../vector/v.vol.rst/main.c:260
+#: ../vector/v.surf.rst/main.c:308
+#: ../vector/v.vol.rst/main.c:260
msgid "Tension parameter"
msgstr "Paramètre de tension"
-#: ../vector/v.surf.rst/main.c:315 ../vector/v.vol.rst/main.c:268
+#: ../vector/v.surf.rst/main.c:315
+#: ../vector/v.vol.rst/main.c:268
msgid "Smoothing parameter"
msgstr "Paramètre de lissage"
@@ -29094,26 +29102,24 @@
msgid "Name of the attribute column with smoothing parameters"
msgstr "Nom de la colonne attributaire contenant les paramètres de lissage"
-#: ../vector/v.surf.rst/main.c:331 ../vector/v.vol.rst/main.c:309
+#: ../vector/v.surf.rst/main.c:331
+#: ../vector/v.vol.rst/main.c:309
msgid "Maximum number of points in a segment"
msgstr "Nombre maximum de points dans un segment"
-#: ../vector/v.surf.rst/main.c:340 ../vector/v.vol.rst/main.c:318
+#: ../vector/v.surf.rst/main.c:340
+#: ../vector/v.vol.rst/main.c:318
msgid "Minimum number of points for approximation in a segment (>segmax)"
msgstr "Nombre de points minimal pour la construction d'un segment (>segmax)"
-#: ../vector/v.surf.rst/main.c:349 ../vector/v.vol.rst/main.c:336
+#: ../vector/v.surf.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:336
msgid "Minimum distance between points (to remove almost identical points)"
-msgstr ""
-"Distance minimum entre les points en unités carte (pour supprimer les points "
-"quasi-identiques)"
+msgstr "Distance minimum entre les points en unités carte (pour supprimer les points quasi-identiques)"
#: ../vector/v.surf.rst/main.c:358
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
-"Distance maximum entre les points des courbes de niveau en unités carte "
-"(pour insérer des points supplémentaires)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
+msgstr "Distance maximum entre les points des courbes de niveau en unités carte (pour insérer des points supplémentaires)"
#: ../vector/v.surf.rst/main.c:367
msgid "Conversion factor for values used for approximation"
@@ -29121,12 +29127,12 @@
#: ../vector/v.surf.rst/main.c:375
msgid "Anisotropy angle (in degrees counterclockwise from East)"
-msgstr ""
-"Angle d'anisotropie (en degrés, sens inverse des aiguilles d'une montre en "
-"partant de l'Est)"
+msgstr "Angle d'anisotropie (en degrés, sens inverse des aiguilles d'une montre en partant de l'Est)"
-#: ../vector/v.surf.rst/main.c:408 ../vector/v.surf.rst/main.c:413
-#: ../vector/v.surf.rst/main.c:418 ../vector/v.surf.rst/main.c:423
+#: ../vector/v.surf.rst/main.c:408
+#: ../vector/v.surf.rst/main.c:413
+#: ../vector/v.surf.rst/main.c:418
+#: ../vector/v.surf.rst/main.c:423
#, fuzzy, c-format
msgid "Output vector map name <%s> is not valid map name"
@@ -29137,20 +29143,12 @@
msgstr "Vous ne fabriquez aucun fichier raster ou vecteur en sortie"
#: ../vector/v.surf.rst/main.c:456
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-"Vous devez spécifier les deux options de validation croisée (drapeau -c et "
-"sortie vecteur cvdev)"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr "Vous devez spécifier les deux options de validation croisée (drapeau -c et sortie vecteur cvdev)"
#: ../vector/v.surf.rst/main.c:459
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
-msgstr ""
-"La validation croisée ne peut être calculée simultanément avec la sortie "
-"raster ou la sortie du fichier devi"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr "La validation croisée ne peut être calculée simultanément avec la sortie raster ou la sortie du fichier devi"
#: ../vector/v.surf.rst/main.c:462
msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
@@ -29166,15 +29164,11 @@
#: ../vector/v.surf.rst/main.c:492
msgid "Both smatt and smooth options specified - using constant"
-msgstr ""
-"Les options smatt et smooth sont toutes deux spécifiées - utilisation de "
-"constante"
+msgstr "Les options smatt et smooth sont toutes deux spécifiées - utilisation de constante"
#: ../vector/v.surf.rst/main.c:502
msgid "The computation will last too long - lower npmin is suggested"
-msgstr ""
-"Le calcul risque de durer trop longtemps - nous vous suggérons de choisir "
-"une npmin plus basse"
+msgstr "Le calcul risque de durer trop longtemps - nous vous suggérons de choisir une npmin plus basse"
#: ../vector/v.surf.rst/main.c:549
msgid "Cannot create quaddata"
@@ -29205,9 +29199,7 @@
#: ../vector/v.surf.rst/main.c:796
msgid "Cannot write raster maps -- try to increase resolution"
-msgstr ""
-"Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la "
-"résolution"
+msgstr "Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la résolution"
#: ../vector/v.transform/get_coor.c:36
#, fuzzy
@@ -29253,9 +29245,7 @@
#: ../vector/v.transform/main.c:75
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
msgstr ""
#: ../vector/v.transform/main.c:82
@@ -29266,10 +29256,14 @@
msgid "Shift all z values to bottom=0"
msgstr "Réhausser toutes les valeurs z à bottom=0"
-#: ../vector/v.transform/main.c:87 ../vector/v.transform/main.c:99
-#: ../vector/v.transform/main.c:125 ../vector/v.transform/main.c:134
-#: ../vector/v.transform/main.c:143 ../vector/v.transform/main.c:152
-#: ../vector/v.transform/main.c:161 ../vector/v.transform/main.c:170
+#: ../vector/v.transform/main.c:87
+#: ../vector/v.transform/main.c:99
+#: ../vector/v.transform/main.c:125
+#: ../vector/v.transform/main.c:134
+#: ../vector/v.transform/main.c:143
+#: ../vector/v.transform/main.c:152
+#: ../vector/v.transform/main.c:161
+#: ../vector/v.transform/main.c:170
#: ../vector/v.transform/main.c:180
msgid "Custom"
msgstr ""
@@ -29281,12 +29275,8 @@
#: ../vector/v.transform/main.c:97
#, fuzzy
-msgid ""
-"Instead of points use transformation parameters (xshift, yshift, zshift, "
-"xscale, yscale, zscale, zrot)"
-msgstr ""
-"A la place des points, utilisez les options de transformation (xshift, "
-"yshift, zshift, xscale, yscale, zscale, zrot)"
+msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
+msgstr "A la place des points, utilisez les options de transformation (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
#: ../vector/v.transform/main.c:111
#, fuzzy
@@ -29295,12 +29285,8 @@
#: ../vector/v.transform/main.c:112
#, fuzzy
-msgid ""
-"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
-"yscale, zscale, zrot) are used instead"
-msgstr ""
+msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
#: ../vector/v.transform/main.c:123
msgid "Shifting value for x coordinates"
@@ -29310,7 +29296,8 @@
msgid "Shifting value for y coordinates"
msgstr "Réhausser les valeurs de coordonnées y"
-#: ../vector/v.transform/main.c:141 ../vector/v.extrude/main.c:85
+#: ../vector/v.transform/main.c:141
+#: ../vector/v.extrude/main.c:85
msgid "Shifting value for z coordinates"
msgstr "Réhausser les valeurs de coordonnées z"
@@ -29328,9 +29315,7 @@
#: ../vector/v.transform/main.c:178
msgid "Rotation around z axis in degrees counterclockwise"
-msgstr ""
-"Angle de rotation autour de l'axe z en degrés (dans le sens inverse des "
-"aiguilles d'une montre)"
+msgstr "Angle de rotation autour de l'axe z en degrés (dans le sens inverse des aiguilles d'une montre)"
#: ../vector/v.transform/main.c:184
#, fuzzy
@@ -29348,19 +29333,13 @@
#: ../vector/v.transform/main.c:211
#, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Transformation "
-"parameters are used automatically when no pointsfile is given."
+msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
msgstr ""
#: ../vector/v.transform/main.c:217
#, fuzzy, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être "
-"écrasé!\n"
+msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+msgstr "Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être écrasé!\n"
#: ../vector/v.transform/main.c:226
#, c-format
@@ -29373,9 +29352,7 @@
msgstr ""
#: ../vector/v.transform/main.c:236
-msgid ""
-"Name of table and name for output vector map must be different. Otherwise "
-"the table is overwritten."
+msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
msgstr ""
#: ../vector/v.transform/main.c:253
@@ -29422,16 +29399,13 @@
#: ../vector/v.transform/trans_digit.c:117
#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
msgstr ""
#: ../vector/v.transform/trans_digit.c:128
#, fuzzy
msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-"Vérifier l'information de datum et afficher les paramètres de transformation"
+msgstr "Vérifier l'information de datum et afficher les paramètres de transformation"
#: ../vector/lidar/v.outlier/main.c:74
#, fuzzy
@@ -29449,9 +29423,7 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:86
#: ../vector/lidar/v.lidar.correction/main.c:81
#: ../vector/lidar/v.surf.bspline/main.c:96
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
msgstr ""
#: ../vector/lidar/v.outlier/main.c:92
@@ -29500,7 +29472,8 @@
msgid "Unable to read name of driver"
msgstr "Impossible de lire la ligne %i\n"
-#: ../vector/lidar/v.outlier/main.c:171 ../vector/lidar/v.outlier/main.c:237
+#: ../vector/lidar/v.outlier/main.c:171
+#: ../vector/lidar/v.outlier/main.c:237
#: ../vector/lidar/v.lidar.edgedetection/main.c:193
#: ../vector/lidar/v.lidar.edgedetection/main.c:205
#: ../vector/lidar/v.lidar.edgedetection/main.c:255
@@ -29702,9 +29675,7 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:396
#, fuzzy
msgid "Allocating memory for bilinear interpolation"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
#: ../vector/lidar/v.lidar.edgedetection/main.c:429
#, fuzzy
@@ -29733,9 +29704,7 @@
msgstr ""
#: ../vector/lidar/v.lidar.correction/main.c:75
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
msgstr ""
#: ../vector/lidar/v.lidar.correction/main.c:85
@@ -29800,21 +29769,27 @@
msgid "Correction and creation of terrain vector"
msgstr ""
-#: ../vector/lidar/lidarlib/zones.c:414 ../vector/lidar/lidarlib/zones.c:451
+#: ../vector/lidar/lidarlib/zones.c:414
+#: ../vector/lidar/lidarlib/zones.c:451
#, c-format
msgid "<%s> created in database."
msgstr ""
-#: ../vector/lidar/lidarlib/zones.c:418 ../vector/lidar/lidarlib/zones.c:455
+#: ../vector/lidar/lidarlib/zones.c:418
+#: ../vector/lidar/lidarlib/zones.c:455
#, fuzzy, c-format
msgid "<%s> has not been created in database."
# c-format
-#: ../vector/lidar/lidarlib/raster.c:80 ../vector/lidar/lidarlib/raster.c:95
-#: ../vector/lidar/lidarlib/raster.c:108 ../vector/lidar/lidarlib/raster.c:125
-#: ../vector/lidar/lidarlib/raster.c:140 ../vector/lidar/lidarlib/raster.c:153
-#: ../vector/lidar/lidarlib/raster.c:168 ../vector/lidar/lidarlib/raster.c:181
+#: ../vector/lidar/lidarlib/raster.c:80
+#: ../vector/lidar/lidarlib/raster.c:95
+#: ../vector/lidar/lidarlib/raster.c:108
+#: ../vector/lidar/lidarlib/raster.c:125
+#: ../vector/lidar/lidarlib/raster.c:140
+#: ../vector/lidar/lidarlib/raster.c:153
+#: ../vector/lidar/lidarlib/raster.c:168
+#: ../vector/lidar/lidarlib/raster.c:181
#, fuzzy, c-format
msgid "Unable to access table <%s>"
@@ -29828,9 +29803,7 @@
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:90
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:104
@@ -29857,9 +29830,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:159
msgid "Attribute table column with values to interpolate (if layer>0)"
-msgstr ""
-"Colonne de la table attributaire avec les valeurs à interpoler (si la "
-"couche>0)"
+msgstr "Colonne de la table attributaire avec les valeurs à interpoler (si la couche>0)"
#: ../vector/lidar/v.surf.bspline/main.c:172
msgid "Choose either vector or raster output, not both"
@@ -29877,9 +29848,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:231
#, fuzzy
msgid "Layer but not column with z values given"
-msgstr ""
-"couche>0)"
#: ../vector/lidar/v.surf.bspline/main.c:254
msgid "Cross validation didn't finish correctly"
@@ -29897,9 +29866,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:285
#, c-format
-msgid ""
-"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
-"a raster output or other driver."
+msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:307
@@ -29929,9 +29896,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:392
#, fuzzy
-msgid ""
-"Cannot allocate memory for auxiliar matrix.Consider changing region "
-"resolution"
+msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
msgstr "Impossible d'allouer de la mémoire"
#: ../vector/lidar/v.surf.bspline/main.c:590
@@ -29961,9 +29926,7 @@
msgstr "%d points en dehors de la région courante"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:93
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
msgstr ""
#: ../vector/lidar/v.surf.bspline/crosscorr.c:124
@@ -29978,8 +29941,7 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:156
#, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
msgstr ""
#: ../vector/lidar/v.surf.bspline/crosscorr.c:174
@@ -30005,15 +29967,12 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:318
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
msgstr ""
#: ../vector/lidar/v.surf.bspline/crosscorr.c:320
#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
msgstr ""
#: ../vector/lidar/v.surf.bspline/crosscorr.c:328
@@ -30039,9 +29998,7 @@
msgstr ""
#: ../vector/lidar/v.lidar.growing/main.c:81
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
msgstr ""
#: ../vector/lidar/v.lidar.growing/main.c:86
@@ -30099,9 +30056,7 @@
#: ../vector/v.reclass/main.c:66
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
msgstr ""
#: ../vector/v.reclass/main.c:83
@@ -30125,8 +30080,10 @@
msgid "Either 'rules' or 'col' must be specified"
msgstr "2 couches doivent être spécifiées"
-#: ../vector/v.reclass/main.c:224 ../vector/v.to.rast/support.c:145
-#: ../vector/v.to.rast/support.c:306 ../vector/v.to.rast/support.c:456
+#: ../vector/v.reclass/main.c:224
+#: ../vector/v.to.rast/support.c:145
+#: ../vector/v.to.rast/support.c:306
+#: ../vector/v.to.rast/support.c:456
#: ../vector/v.to.rast/vect2rast.c:73
#, fuzzy, c-format
msgid "No records selected from table <%s>"
@@ -30137,7 +30094,8 @@
msgid "Key column type is not integer"
-#: ../vector/v.reclass/main.c:247 ../vector/v.db.select/main.c:197
+#: ../vector/v.reclass/main.c:247
+#: ../vector/v.db.select/main.c:197
#, fuzzy, c-format
msgid "Unable to fetch data from table <%s>"
msgstr "Impossible de sélectionner des données dans la table"
@@ -30255,13 +30213,15 @@
msgstr "Impossible de fermer la couche : couche d'entrée introuvable"
# c-format
-#: ../vector/v.net.timetable/main.c:421 ../vector/v.net.timetable/main.c:452
+#: ../vector/v.net.timetable/main.c:421
+#: ../vector/v.net.timetable/main.c:452
#: ../vector/v.net.timetable/main.c:460
#, fuzzy, c-format
msgid "No stop with category: %d"
msgstr "%d points sans catégorie"
-#: ../vector/v.net.timetable/main.c:444 ../vector/v.net.path/path.c:149
+#: ../vector/v.net.timetable/main.c:444
+#: ../vector/v.net.path/path.c:149
#, fuzzy, c-format
msgid "Wrong input format: %s"
msgstr "Fausse entrée pour le multiplicateur: %s"
@@ -30326,7 +30286,8 @@
msgid "No areas found, skipping type=poly"
-#: ../vector/v.out.svg/main.c:215 ../vector/v.extrude/main.c:204
+#: ../vector/v.out.svg/main.c:215
+#: ../vector/v.extrude/main.c:204
#, c-format
msgid "Skipping area %d without centroid"
msgstr ""
@@ -30372,16 +30333,12 @@
#: ../vector/v.external/main.c:60
#, fuzzy
msgid "Creates a new vector as a read-only link to OGR layer."
-msgstr ""
#: ../vector/v.external/main.c:75
#, fuzzy
msgid "Output vector. If not given, available layers are printed only."
-msgstr ""
-"Couche vectorielle cible, si elle n'est pas indiquée, les couches "
-"disponibles seront seulement affichées"
+msgstr "Couche vectorielle cible, si elle n'est pas indiquée, les couches disponibles seront seulement affichées"
#: ../vector/v.external/main.c:83
msgid ""
@@ -30389,8 +30346,7 @@
"\t\tESRI Shapefile: shapefile name\n"
"\t\tMapInfo File: mapinfo file name"
msgstr ""
-"nom de la couche OGR. Si elle n'est pas indiquée, les couches disponibles "
-"seront seulement affichées. Exemples:\n"
+"nom de la couche OGR. Si elle n'est pas indiquée, les couches disponibles seront seulement affichées. Exemples:\n"
"\t\tShapefile ESRI : nom du shapefile\n"
"\t\tFichier MapInfo : nom du fichier mapinfo"
@@ -30422,9 +30378,7 @@
#: ../vector/v.out.ogr/main.c:106
#, fuzzy
-msgid ""
-"Feature type(s). Combinations not supported by all output formats. Default: "
-"first type found in input."
+msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
msgstr "Type d'objet. Le mélange de types n'est pas géré par tous les format."
#: ../vector/v.out.ogr/main.c:114
@@ -30452,8 +30406,10 @@
-#: ../vector/v.out.ogr/main.c:125 ../vector/v.out.ogr/main.c:138
-#: ../vector/v.out.ogr/main.c:148 ../vector/v.out.ogr/main.c:158
+#: ../vector/v.out.ogr/main.c:125
+#: ../vector/v.out.ogr/main.c:138
+#: ../vector/v.out.ogr/main.c:148
+#: ../vector/v.out.ogr/main.c:158
#, fuzzy
msgid "Creation"
msgstr "Corrélation"
@@ -30474,35 +30430,25 @@
#: ../vector/v.out.ogr/main.c:162
#, fuzzy
msgid "Open an existing datasource for update"
-msgstr ""
-"Nettoyer les données existantes qui se trouvent dans le répertoire de "
-"téléchargement"
+msgstr "Nettoyer les données existantes qui se trouvent dans le répertoire de téléchargement"
#: ../vector/v.out.ogr/main.c:167
msgid "Skip export of GRASS category ID ('cat') attribute"
msgstr ""
#: ../vector/v.out.ogr/main.c:171
-msgid ""
-"Export features with category (labeled) only. Otherwise all features are "
-"exported"
-msgstr ""
-"Exporter seulement les objets dotés de catégorie (étiquette). Sinon tous les "
-"objets sontexportés"
+msgid "Export features with category (labeled) only. Otherwise all features are exported"
+msgstr "Exporter seulement les objets dotés de catégorie (étiquette). Sinon tous les objets sontexportés"
#: ../vector/v.out.ogr/main.c:176
#, fuzzy
msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Utiliser le format de fichier .prj de style ESRI (ne s'applique qu'aux "
-"sorties sous forme de SHAPE)"
+msgstr "Utiliser le format de fichier .prj de style ESRI (ne s'applique qu'aux sorties sous forme de SHAPE)"
#: ../vector/v.out.ogr/main.c:181
#, fuzzy
msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
#: ../vector/v.out.ogr/main.c:186
msgid "Export lines as polygons"
@@ -30529,143 +30475,88 @@
msgstr "Le mélange de types n'est pas géré par tous les formats."
#: ../vector/v.out.ogr/main.c:326
-msgid ""
-"The map contains islands. To preserve them in the output map, use the -c flag"
+msgid "The map contains islands. To preserve them in the output map, use the -c flag"
msgstr ""
#: ../vector/v.out.ogr/main.c:331
#, fuzzy, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Point(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Point(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:336
#, fuzzy, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Ligne(s) trouvée(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Ligne(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:342
#, fuzzy, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Contours(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Contours(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:348
#, fuzzy, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Centroïde(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Centroïde(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:353
#, fuzzy, c-format
-msgid ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. "
-"Vérifiez le paramètre 'type'"
+msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:357
#, fuzzy, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:363
#, fuzzy, c-format
-msgid ""
-"%d kernel(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"paramètre 'type'"
+msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:368
#, fuzzy, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"paramètre 'type'"
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:374
#, fuzzy
-msgid ""
-"No points found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"paramètre 'type'"
+msgid "No points found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:383
#, fuzzy
-msgid ""
-"No lines found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"paramètre 'type'"
+msgid "No lines found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:393
#, fuzzy
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this geometry "
-"type."
-msgstr ""
-"paramètre 'type'"
+msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:402
#, fuzzy
-msgid ""
-"No areas found, but requested to be exported. Will skip this geometry type."
-msgstr ""
+msgid "No areas found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:412
#, fuzzy
-msgid ""
-"No centroids found, but requested to be exported. Will skip this geometry "
-"type."
-msgstr ""
-"paramètre 'type'"
+msgid "No centroids found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:421
#, fuzzy
-msgid ""
-"No faces found, but requested to be exported. Will skip this geometry type."
-msgstr ""
+msgid "No faces found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:430
#, fuzzy
-msgid ""
-"No kernels found, but requested to be exported. Will skip this geometry type."
-msgstr ""
+msgid "No kernels found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:439
#, fuzzy
-msgid ""
-"No volumes found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"paramètre 'type'"
+msgid "No volumes found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:450
#, fuzzy
@@ -30700,16 +30591,12 @@
#: ../vector/v.out.ogr/main.c:583
#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
msgstr ""
#: ../vector/v.out.ogr/main.c:590
#, c-format
-msgid ""
-"'lco') to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
msgstr ""
#: ../vector/v.out.ogr/main.c:603
@@ -30719,9 +30606,7 @@
#: ../vector/v.out.ogr/main.c:613
msgid "No attribute table found -> using only category numbers as attributes"
-msgstr ""
-"Aucune table attributaire trouvée -> on utilise les identifiants de "
-"catégories comme attributs"
+msgstr "Aucune table attributaire trouvée -> on utilise les identifiants de catégories comme attributs"
#: ../vector/v.out.ogr/main.c:617
msgid "Exporting 'cat' anyway, as it is the only attribute table field"
@@ -30787,7 +30672,8 @@
msgstr "%d points écrits dans la couche vecteur"
# c-format
-#: ../vector/v.out.ogr/main.c:1061 ../vector/v.out.vtk/writeVTK.c:576
+#: ../vector/v.out.ogr/main.c:1061
+#: ../vector/v.out.vtk/writeVTK.c:576
#, c-format
msgid "Cannot select attributes for cat = %d"
msgstr "Impossible de sélectionner les attributs pour cat = %d"
@@ -30801,20 +30687,15 @@
#: ../vector/v.patch/main.c:69
#, fuzzy
msgid "Create a new vector map layer by combining other vector map layers."
-msgstr ""
#: ../vector/v.patch/main.c:80
#, fuzzy
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
msgstr "Nom de la couche en sortie où les erreurs seront écrites"
#: ../vector/v.patch/main.c:84
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
msgstr ""
#: ../vector/v.patch/main.c:89
@@ -30825,9 +30706,7 @@
#: ../vector/v.patch/main.c:91
#, fuzzy
msgid "Only the table of layer 1 is currently supported"
-msgstr ""
-"Copie égalment la table attributaire. Seule la table de la couche 1 est "
-"prise en compte pour le moment"
+msgstr "Copie égalment la table attributaire. Seule la table de la couche 1 est prise en compte pour le moment"
#: ../vector/v.patch/main.c:189
msgid "Missing table"
@@ -30877,9 +30756,7 @@
#: ../vector/v.patch/main.c:322
#, fuzzy, c-format
msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-"Erreur de lecture du fichier '%s'. Certaines données ne seront pas "
-"correctes\n"
+msgstr "Erreur de lecture du fichier '%s'. Certaines données ne seront pas correctes\n"
#: ../vector/v.patch/main.c:364
#, fuzzy, c-format
@@ -30889,16 +30766,12 @@
#: ../vector/v.patch/main.c:370
#, fuzzy
msgid "Intersections at borders will have to be snapped"
-msgstr ""
-"Les intersections aux limites doivent faire l'objet d'une opération de "
-"capture."
+msgstr "Les intersections aux limites doivent faire l'objet d'une opération de capture."
#: ../vector/v.patch/main.c:371
#, fuzzy
msgid "Lines common between files will have to be edited"
-msgstr ""
-"Les lignes communes aux deux fichiers devront faire l'objet d'une session "
-"d'édition."
+msgstr "Les lignes communes aux deux fichiers devront faire l'objet d'une session d'édition."
#: ../vector/v.patch/main.c:372
#, fuzzy
@@ -30958,15 +30831,9 @@
#: ../vector/v.select/args.c:47
#, fuzzy
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
msgstr ""
-"Opérateur qui définit la relation requise entre objets. Un objet est écrit "
-"dansla couche de sortie si le résultat de l'opération 'ainput opérateur "
-"binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de "
-"la couche est définie.\n"
+"Opérateur qui définit la relation requise entre objets. Un objet est écrit dansla couche de sortie si le résultat de l'opération 'ainput opérateur binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de la couche est définie.\n"
"\t recouvrement : les objets se recouvrent totalement ou partiellement"
#: ../vector/v.select/args.c:53
@@ -30974,15 +30841,7 @@
msgstr ""
#: ../vector/v.select/args.c:58
-msgid ""
-"overlap;features partially or completely overlap;equals;features are "
-"spatially equals (using GEOS);disjoint;features do not spatially intersect "
-"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
-"features spatially touches (using GEOS);crosses;features spatially crosses "
-"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
-"contains;feature B is completely inside feature A (using GEOS);overlaps;"
-"features spatially overlap (using GEOS);relate;feature A is spatially "
-"related to feature B (using GEOS, requires 'relate' option);"
+msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
msgstr ""
#: ../vector/v.select/args.c:75
@@ -31002,8 +30861,7 @@
#: ../vector/v.select/main.c:54
#, fuzzy
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
msgstr "Sélectionne les objets de ainput à partir des objets de binput"
#: ../vector/v.select/main.c:87
@@ -31019,9 +30877,7 @@
#: ../vector/v.select/main.c:172
#, fuzzy, c-format
msgid "Unable to read line id %d from vector map <%s>"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
#: ../vector/v.select/main.c:278
#, fuzzy
@@ -31064,8 +30920,7 @@
#: ../vector/v.convert/att.c:36
#, fuzzy
msgid "No category labels (dig_cats) found, no table created"
-msgstr ""
-"Aucune étiquette de catégorie (dig_cats) trouvée, aucune table créée.\n"
+msgstr "Aucune étiquette de catégorie (dig_cats) trouvée, aucune table créée.\n"
# c-format
#: ../vector/v.convert/att.c:41
@@ -31074,7 +30929,8 @@
msgstr "impossible d'ouvrir le fichier dig_att <%s>\n"
# c-format
-#: ../vector/v.convert/att.c:67 ../vector/v.info/main.c:212
+#: ../vector/v.convert/att.c:67
+#: ../vector/v.info/main.c:212
#, fuzzy, c-format
msgid "Unable to open driver <%s>"
msgstr "Impossible d'ouvrir la couche raster <%s>"
@@ -31143,13 +30999,8 @@
#: ../vector/v.convert/read.c:99
#, fuzzy
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
-msgstr ""
-"ATTENTION: Le format de fichier d'entrée n'est pas supporté. Nous allons "
-"essayer de le convertir quand même mais la conversion peut échouer. Veuillez "
-"lire le manuel pour plus d'informations."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
+msgstr "ATTENTION: Le format de fichier d'entrée n'est pas supporté. Nous allons essayer de le convertir quand même mais la conversion peut échouer. Veuillez lire le manuel pour plus d'informations."
#: ../vector/v.convert/read.c:185
#, fuzzy, c-format
@@ -31289,9 +31140,7 @@
#: ../vector/v.in.sites/main.c:59
#, fuzzy
msgid "Converts a GRASS site_lists file into a vector map."
-msgstr ""
-"Convertit le fichier GRASS ascii ou le fichier points en couche vectorielle "
-"binaire"
+msgstr "Convertit le fichier GRASS ascii ou le fichier points en couche vectorielle binaire"
#: ../vector/v.in.sites/main.c:83
#, fuzzy, c-format
@@ -31345,7 +31194,8 @@
msgid "Duplicate area centroids: %d"
-#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.info/main.c:265
+#: ../vector/v.clean/test/topocheck.c:42
+#: ../vector/v.info/main.c:265
#: ../locale/scriptstrings/v.build.all_to_translate.c:2
msgid "vector"
msgstr ""
@@ -31376,31 +31226,12 @@
msgstr ""
#: ../vector/v.clean/main.c:66
-msgid ""
-"break;break lines at each intersection;rmdupl;remove duplicate geometry "
-"features (pay attention to categories!);rmdangle;remove dangles, threshold "
-"ignored if < 0;chdangle;change the type of boundary dangle to line, "
-"threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges "
-"connecting area and island or 2 islands;chbridge;change the type of bridges "
-"connecting area and island or 2 islands from boundary to line;snap;snap "
-"lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' "
-"option ignored);bpol;break (topologically clean) polygons (imported from non "
-"topological format, like ShapeFile). Boundaries are broken on each point "
-"shared between 2 and more polygons where angles of segments are different;"
-"prune;remove vertices in threshold from lines and boundaries, boundary is "
-"pruned only if topology is not damaged (new intersection, changed "
-"attachement of centroid), first and last segment of the boundary is never "
-"changed;rmarea;remove small areas, the longest boundary with adjacent area "
-"is removed;rmline;remove all lines or boundaries of zero length, threshold "
-"is ignored;rmsa;remove small angles between lines at nodes"
+msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove small a
reas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
msgstr ""
#: ../vector/v.clean/main.c:94
-msgid ""
-"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-msgstr ""
-"Seuillage en unités de la carte, une valeur pour chaque outil (par défaut : "
-"0.0[,0.0,...])"
+msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+msgstr "Seuillage en unités de la carte, une valeur pour chaque outil (par défaut : 0.0[,0.0,...])"
#: ../vector/v.clean/main.c:100
#, fuzzy
@@ -31491,7 +31322,8 @@
msgid "Copying vector lines..."
-#: ../vector/v.clean/main.c:295 ../vector/v.clean/main.c:305
+#: ../vector/v.clean/main.c:295
+#: ../vector/v.clean/main.c:305
#, fuzzy
msgid "Rebuilding parts of topology..."
msgstr "Construction de l'index spatial ..."
@@ -31590,9 +31422,7 @@
#: ../vector/v.perturb/main.c:75
msgid "Random location perturbations of GRASS vector points"
-msgstr ""
-"Génère des perturbations aléatoires sur la position de points vectoriels "
-"GRASS"
+msgstr "Génère des perturbations aléatoires sur la position de points vectoriels GRASS"
#: ../vector/v.perturb/main.c:78
msgid "Vector points to be spatially perturbed"
@@ -31603,14 +31433,8 @@
msgstr "Distribution de la perturbation"
#: ../vector/v.perturb/main.c:96
-msgid ""
-"Parameter(s) of distribution. If the distribution is uniform, only one "
-"parameter, the maximum, is needed. For a normal distribution, two "
-"parameters, the mean and standard deviation, are required."
-msgstr ""
-"Paramètre(s) de distribution. Si la distribution est uniforme, seul un "
-"paramètre, le maximum, est nécessaire. Pour une distribution normale, deux "
-"paramètres, la moyenne et l'écart-type, sont nécessaires."
+msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr "Paramètre(s) de distribution. Si la distribution est uniforme, seul un paramètre, le maximum, est nécessaire. Pour une distribution normale, deux paramètres, la moyenne et l'écart-type, sont nécessaires."
#: ../vector/v.perturb/main.c:106
msgid "Minimum deviation in map units"
@@ -31620,19 +31444,18 @@
msgid "Seed for random number generation"
msgstr "Germe pour une génération aléatoire de nimbre"
-#: ../vector/v.perturb/main.c:137 ../vector/v.perturb/main.c:144
+#: ../vector/v.perturb/main.c:137
+#: ../vector/v.perturb/main.c:144
msgid "Error scanning arguments"
msgstr "Arguments de l'erreur de scanning"
#: ../vector/v.perturb/main.c:140
msgid "Maximum of uniform distribution must be >= zero"
-msgstr ""
-"Le maximum d'une distribution uniforme doit être supérieure ou égale à zéro"
+msgstr "Le maximum d'une distribution uniforme doit être supérieure ou égale à zéro"
#: ../vector/v.perturb/main.c:147
msgid "Standard deviation of normal distribution must be >= zero"
-msgstr ""
-"L'écart-type d'une distribution normale doit être supérieur ou égal à zéro"
+msgstr "L'écart-type d'une distribution normale doit être supérieur ou égal à zéro"
#: ../vector/v.perturb/main.c:232
msgid "Cannot get db link info"
@@ -31656,10 +31479,7 @@
msgstr ""
#: ../vector/v.class/main.c:166
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
msgstr ""
#: ../vector/v.class/main.c:193
@@ -31710,9 +31530,7 @@
#: ../vector/v.info/main.c:65
#, fuzzy
msgid "Outputs basic information about a user-specified vector map."
-msgstr ""
-"Afficher des informations générales à propos d'une couche vecteur spécifiée "
-"par l'utilisateur."
+msgstr "Afficher des informations générales à propos d'une couche vecteur spécifiée par l'utilisateur."
#: ../vector/v.info/main.c:74
msgid "Print vector history instead of info"
@@ -31720,9 +31538,7 @@
#: ../vector/v.info/main.c:80
msgid "Print types/names of table columns for specified layer instead of info"
-msgstr ""
-"Afficher les types/noms des colonnes de la table pour une couche spécifiée à "
-"la place des informations"
+msgstr "Afficher les types/noms des colonnes de la table pour une couche spécifiée à la place des informations"
#: ../vector/v.info/main.c:95
#, fuzzy
@@ -31876,7 +31692,8 @@
msgid "Fixed height for 3D vector features"
msgstr "Hauteur fixée pour les objets vecteurs 3D"
-#: ../vector/v.to.3d/args.c:31 ../vector/v.to.3d/args.c:34
+#: ../vector/v.to.3d/args.c:31
+#: ../vector/v.to.3d/args.c:34
#: ../vector/v.to.3d/args.c:41
#, fuzzy
msgid "Height"
@@ -31891,7 +31708,8 @@
msgid "Can be used for reverse transformation, to store height of points"
msgstr ""
-#: ../vector/v.to.3d/trans3.c:67 ../vector/v.to.3d/trans2.c:65
+#: ../vector/v.to.3d/trans3.c:67
+#: ../vector/v.to.3d/trans2.c:65
#, fuzzy
msgid "Column must be numeric"
msgstr "Nom de la colonne (le type doit être numérique)"
@@ -31917,9 +31735,7 @@
#: ../vector/v.to.3d/trans2.c:113
#, fuzzy, c-format
msgid "Unable to get height for feature category %d"
-msgstr ""
-"vectorielle"
#: ../vector/v.to.3d/main.c:37
#, fuzzy
@@ -31957,13 +31773,15 @@
msgid "Vector map <%s> is 3D"
msgstr "Couche vecteur %s introuvable"
-#: ../vector/v.to.3d/main.c:97 ../vector/v.to.3d/main.c:127
+#: ../vector/v.to.3d/main.c:97
+#: ../vector/v.to.3d/main.c:127
#: ../vector/v.in.db/main.c:212
#, fuzzy
msgid "Copying attributes..."
msgstr "Écriture des attributs..."
-#: ../vector/v.to.3d/main.c:99 ../vector/v.to.3d/main.c:129
+#: ../vector/v.to.3d/main.c:99
+#: ../vector/v.to.3d/main.c:129
#, fuzzy
msgid "Unable to copy attributes"
@@ -31988,41 +31806,47 @@
msgid "Prints vector map attributes."
msgstr "Affiche les attributs des vecteurs"
-#: ../vector/v.db.select/main.c:65 ../vector/v.db.select/main.c:71
-#: ../vector/v.db.select/main.c:78 ../vector/v.db.select/main.c:94
-#: ../vector/v.db.select/main.c:99 ../db/base/select.c:215
-#: ../db/base/select.c:221 ../db/base/select.c:228 ../db/base/select.c:238
+#: ../vector/v.db.select/main.c:65
+#: ../vector/v.db.select/main.c:71
+#: ../vector/v.db.select/main.c:78
+#: ../vector/v.db.select/main.c:94
+#: ../vector/v.db.select/main.c:99
+#: ../db/base/select.c:215
+#: ../db/base/select.c:221
+#: ../db/base/select.c:228
+#: ../db/base/select.c:238
#: ../db/base/select.c:247
#, fuzzy
msgid "Format"
msgstr "format OGR"
-#: ../vector/v.db.select/main.c:69 ../db/base/select.c:219
+#: ../vector/v.db.select/main.c:69
+#: ../db/base/select.c:219
msgid "Output vertical record separator"
msgstr "Caractère de séparation vertical d'enregistrement en sortie"
-#: ../vector/v.db.select/main.c:77 ../db/base/select.c:227
+#: ../vector/v.db.select/main.c:77
+#: ../db/base/select.c:227
msgid "Null value indicator"
msgstr "Indicateur de valeur vide ('null')"
#: ../vector/v.db.select/main.c:89
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
msgstr ""
-#: ../vector/v.db.select/main.c:93 ../db/base/select.c:237
+#: ../vector/v.db.select/main.c:93
+#: ../db/base/select.c:237
msgid "Do not include column names in output"
msgstr "Ne pas inclure de nom de colonnes en sortie"
-#: ../vector/v.db.select/main.c:98 ../db/base/select.c:246
+#: ../vector/v.db.select/main.c:98
+#: ../db/base/select.c:246
msgid "Vertical output (instead of horizontal)"
msgstr "Sortie verticale (à la place d'horizontale)"
#: ../vector/v.db.select/main.c:141
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
# c-format
@@ -32042,10 +31866,14 @@
msgid "Unable to get bounding box of line %d"
msgstr "Ne pas afficher les codes de catégories"
-#: ../vector/v.in.dxf/add_text.c:35 ../vector/v.in.dxf/add_point.c:27
-#: ../vector/v.in.dxf/add_polyline.c:90 ../vector/v.in.dxf/add_arc.c:36
-#: ../vector/v.in.dxf/add_3dface.c:29 ../vector/v.in.dxf/add_lwpolyline.c:33
-#: ../vector/v.in.dxf/add_line.c:28 ../vector/v.in.dxf/add_circle.c:32
+#: ../vector/v.in.dxf/add_text.c:35
+#: ../vector/v.in.dxf/add_point.c:27
+#: ../vector/v.in.dxf/add_polyline.c:90
+#: ../vector/v.in.dxf/add_arc.c:36
+#: ../vector/v.in.dxf/add_3dface.c:29
+#: ../vector/v.in.dxf/add_lwpolyline.c:33
+#: ../vector/v.in.dxf/add_line.c:28
+#: ../vector/v.in.dxf/add_circle.c:32
#, c-format
msgid "Layer %d: %s\n"
msgstr "couche %d: %s\n"
@@ -32060,9 +31888,7 @@
#: ../vector/v.in.dxf/main.c:62
msgid "Converts files in DXF format to GRASS vector map format."
-msgstr ""
-"Convertir les fichiers au formats DXF vers le format de fichier vectoriel "
-"GRASS"
+msgstr "Convertir les fichiers au formats DXF vers le format de fichier vectoriel GRASS"
#: ../vector/v.in.dxf/main.c:66
msgid "Ignore the map extent of DXF file"
@@ -32076,8 +31902,10 @@
msgid "Import polyface meshes as 3D wire frame"
msgstr "Importer les treillis (meshes) polyfaces comme structure 3D"
-#: ../vector/v.in.dxf/main.c:83 ../vector/v.in.dxf/main.c:89
-#: ../vector/v.in.dxf/main.c:94 ../vector/v.in.dxf/main.c:108
+#: ../vector/v.in.dxf/main.c:83
+#: ../vector/v.in.dxf/main.c:89
+#: ../vector/v.in.dxf/main.c:94
+#: ../vector/v.in.dxf/main.c:108
#, fuzzy
msgid "DXF layers"
msgstr "Requêter la couche"
@@ -32138,9 +31966,7 @@
#: ../vector/v.in.dxf/write_vect.c:230
#, fuzzy, c-format
msgid "Unable to add database link for vector map <%s>"
-msgstr ""
-"vectorielle"
#: ../vector/v.what.rast/main.c:81
#, fuzzy
@@ -32150,14 +31976,11 @@
#: ../vector/v.what.rast/main.c:83
#, fuzzy
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Charge les valeurs raster dans la table aux positions des points vecteurs"
+msgstr "Charge les valeurs raster dans la table aux positions des points vecteurs"
#: ../vector/v.what.rast/main.c:88
msgid "Name of input vector points map for which to edit attribute table"
-msgstr ""
-"Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la "
-"table attributaire"
+msgstr "Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la table attributaire"
#: ../vector/v.what.rast/main.c:92
msgid "Name of existing raster map to be queried"
@@ -32168,8 +31991,10 @@
msgstr "Nom de la colonne (qui sera mise à jour par les valeurs rasters)"
# c-format
-#: ../vector/v.what.rast/main.c:160 ../vector/v.to.rast/support.c:317
-#: ../vector/v.to.rast/support.c:469 ../vector/v.to.rast/vect2rast.c:64
+#: ../vector/v.what.rast/main.c:160
+#: ../vector/v.to.rast/support.c:317
+#: ../vector/v.to.rast/support.c:469
+#: ../vector/v.to.rast/vect2rast.c:64
#, c-format
msgid "Column <%s> not found"
msgstr "Colonne <%s> non trouvée"
@@ -32180,9 +32005,7 @@
#: ../vector/v.what.rast/main.c:169
msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Le type de raster est flottant et le type de colonne est entier, des données "
-"vont être perdues!!"
+msgstr "Le type de raster est flottant et le type de colonne est entier, des données vont être perdues!!"
# c-format
#: ../vector/v.what.rast/main.c:249
@@ -32235,9 +32058,7 @@
msgstr ""
#: ../vector/v.net.salesman/main.c:101
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
msgstr ""
#: ../vector/v.net.salesman/main.c:119
@@ -32300,7 +32121,8 @@
msgid "Use either -n or -v flag, not both"
msgstr "Choisissez soit le drapeau -n soit le drapeau -s"
-#: ../vector/v.to.points/main.c:273 ../vector/v.generalize/misc.c:177
+#: ../vector/v.to.points/main.c:273
+#: ../vector/v.generalize/misc.c:177
#, fuzzy, c-format
msgid "Unable to copy table <%s>"
msgstr "Impossible d'ouvrir le fichier de sortie"
@@ -32319,8 +32141,7 @@
#: ../vector/v.extrude/main.c:71
#, fuzzy
msgid "Extrudes flat vector object to 3D with defined height."
-msgstr ""
-"Mettre en relief des objets vecteurs plats en fonction d'une hauteur définie"
+msgstr "Mettre en relief des objets vecteurs plats en fonction d'une hauteur définie"
#: ../vector/v.extrude/main.c:75
msgid "Trace elevation"
@@ -32396,13 +32217,15 @@
msgid "Name for output vector map where segments will be written"
msgstr "Couche en sortie où les points seront écrits"
-#: ../vector/v.segment/main.c:137 ../vector/v.segment/main.c:177
+#: ../vector/v.segment/main.c:137
+#: ../vector/v.segment/main.c:177
#, fuzzy, c-format
msgid "Unable to read input: %s"
# c-format
-#: ../vector/v.segment/main.c:147 ../vector/v.segment/main.c:186
+#: ../vector/v.segment/main.c:147
+#: ../vector/v.segment/main.c:186
#, fuzzy, c-format
msgid "Unable to find line of cat %d"
msgstr "couche vectorielle d'entrée introuvable [%s]"
@@ -32541,7 +32364,8 @@
msgid "Island: %d In area: %d\n"
msgstr "Île: %d Dans entité surfacique: %d\n"
-#: ../vector/v.what/what.c:346 ../vector/v.what/what.c:353
+#: ../vector/v.what/what.c:346
+#: ../vector/v.what/what.c:353
#, fuzzy, c-format
msgid ""
"Sq Meters: %.3f\n"
@@ -32550,7 +32374,8 @@
"Mètres carrés: %.3f \n"
"Hectares: %.3f\n"
-#: ../vector/v.what/what.c:348 ../vector/v.what/what.c:356
+#: ../vector/v.what/what.c:348
+#: ../vector/v.what/what.c:356
#, fuzzy, c-format
msgid ""
"Acres: %.3f\n"
@@ -32595,9 +32420,7 @@
#: ../vector/v.what/main.c:70
#, fuzzy
msgid "If not given reads from standard input"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../vector/v.what/main.c:77
msgid "Query threshold distance"
@@ -32638,7 +32461,8 @@
msgid "Unable to calculate the output vectors"
msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
-#: ../vector/v.generalize/misc.c:208 ../vector/v.generalize/misc.c:221
+#: ../vector/v.generalize/misc.c:208
+#: ../vector/v.generalize/misc.c:221
#, fuzzy, c-format
msgid "'%s' must be > 0 for '%s'"
msgstr "'layer' doit être >0 pour 'cats'."
@@ -32673,9 +32497,7 @@
msgstr "Suppression des centroïdes en doublons..."
#: ../vector/v.generalize/main.c:77
-msgid ""
-"vector, generalization, simplification, smoothing, displacement, network "
-"generalization"
+msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
msgstr ""
#: ../vector/v.generalize/main.c:78
@@ -32684,16 +32506,7 @@
#: ../vector/v.generalize/main.c:95
-msgid ""
-"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
-"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
-"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
-"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
-"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
-"smoothing;network;Network generalization;displacement;Displacement of lines "
-"close to each other;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
msgstr ""
#: ../vector/v.generalize/main.c:109
@@ -32791,8 +32604,7 @@
#: ../vector/v.generalize/main.c:495
#, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
msgstr ""
#: ../vector/v.generalize/main.c:498
@@ -32814,9 +32626,7 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:204
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
msgstr ""
#: ../vector/v.vol.rst/main.c:237
@@ -32835,7 +32645,8 @@
msgid "Name of the column with smoothing parameters"
msgstr "Nom de la colonne contenant les paramètres de lissage"
-#: ../vector/v.vol.rst/main.c:287 ../vector/v.vol.rst/main.c:295
+#: ../vector/v.vol.rst/main.c:287
+#: ../vector/v.vol.rst/main.c:295
msgid "Analysis"
msgstr ""
@@ -32850,8 +32661,7 @@
#: ../vector/v.vol.rst/main.c:345
msgid "Conversion factor for w-values used for interpolation"
-msgstr ""
-"Facteur de conversion pour les valeurs w utilisées dans l'interpolation"
+msgstr "Facteur de conversion pour les valeurs w utilisées dans l'interpolation"
#: ../vector/v.vol.rst/main.c:353
msgid "Conversion factor for z-values"
@@ -32891,8 +32701,7 @@
#: ../vector/v.vol.rst/main.c:430
msgid "Perform a cross-validation procedure without volume interpolation"
-msgstr ""
-"Effectue une procédure de validation croisée sans interpolation de volume"
+msgstr "Effectue une procédure de validation croisée sans interpolation de volume"
#: ../vector/v.vol.rst/main.c:467
msgid "Smoothing must be a positive value"
@@ -32900,8 +32709,7 @@
#: ../vector/v.vol.rst/main.c:473
msgid "Both crossvalidation options (-c, cvdev) must be specified"
-msgstr ""
-"Vous devez spécifier les deux options de validation croisée (-c, cvdev)"
+msgstr "Vous devez spécifier les deux options de validation croisée (-c, cvdev)"
#: ../vector/v.vol.rst/main.c:475
msgid "Both crossvalidation and deviations file specified"
@@ -32928,8 +32736,7 @@
# c-format
#: ../vector/v.vol.rst/user1.c:126
#, fuzzy
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
msgstr "Type de colonne (%s) non géré"
#: ../vector/v.to.rast3/main.c:45
@@ -32937,12 +32744,8 @@
msgstr ""
#: ../vector/v.to.rast3/main.c:46
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
-msgstr ""
-"Convertit une couche vecteur GRASS binaire (points seulement) en couche "
-"raster 3D GRASS"
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+msgstr "Convertit une couche vecteur GRASS binaire (points seulement) en couche raster 3D GRASS"
#: ../vector/v.to.rast3/main.c:59
msgid "Column name (type must be numeric)"
@@ -32954,7 +32757,8 @@
msgid "Unable to create output map"
msgstr "impossible de créer la couche en sortie <%s>"
-#: ../vector/v.to.rast3/main.c:150 ../vector/v.to.rast/do_lines.c:51
+#: ../vector/v.to.rast3/main.c:150
+#: ../vector/v.to.rast/do_lines.c:51
#: ../vector/v.to.rast/do_lines.c:59
#, c-format
msgid "No record for line (cat = %d)"
@@ -33003,8 +32807,7 @@
#: ../vector/v.label.sa/labels.c:223
#, c-format
-msgid ""
-"Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
msgstr ""
# c-format
@@ -33031,17 +32834,13 @@
msgstr "Taille de la bordure (seulement pour la sortie ps.map)"
#: ../vector/v.label.sa/main.c:207
-msgid ""
-"Numeric column to give precedence in case of overlapping labels. The label "
-"with a smaller weight is hidden."
+msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
msgstr ""
#: ../vector/v.label.sa/font.c:55
#, fuzzy, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s : impossible de lire le fichier de définition FreeType; on utilise les "
-"paramètres par défaut"
+msgstr "%s : impossible de lire le fichier de définition FreeType; on utilise les paramètres par défaut"
#: ../vector/v.label.sa/font.c:61
#, fuzzy, c-format
@@ -33055,18 +32854,17 @@
#: ../vector/v.in.db/main.c:54
#, fuzzy
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Créer de nouveaux objets vecteurs (points) à partir de la table de la base "
-"de données contenant les coordonnées."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Créer de nouveaux objets vecteurs (points) à partir de la table de la base de données contenant les coordonnées."
#: ../vector/v.in.db/main.c:58
msgid "Input table name"
msgstr "Nom de la table source"
-#: ../vector/v.in.db/main.c:63 ../vector/v.in.db/main.c:67
-#: ../db/base/execute.c:123 ../db/base/execute.c:128
+#: ../vector/v.in.db/main.c:63
+#: ../vector/v.in.db/main.c:67
+#: ../db/base/execute.c:123
+#: ../db/base/execute.c:128
#, fuzzy
msgid "Connection"
@@ -33093,8 +32891,7 @@
#: ../vector/v.in.db/main.c:130
#, fuzzy, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
msgstr "La table vectorielle cible <'%s'> existe déjà."
#: ../vector/v.in.db/main.c:173
@@ -33117,21 +32914,16 @@
#: ../vector/v.surf.idw/main.c:86
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Interpolation de surface à partir de données vecteur point par Pondération "
-"de laDistance Inverse au Carré"
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Interpolation de surface à partir de données vecteur point par pondération de la distance inverse au carré (IDSW)."
#: ../vector/v.surf.idw/main.c:95
#, fuzzy
msgid "If set to 0, z coordinates are used (3D vector only)"
-msgstr ""
-"Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D "
-"seulement)"
+msgstr "Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
-#: ../vector/v.surf.idw/main.c:98 ../vector/v.surf.idw/main.c:106
+#: ../vector/v.surf.idw/main.c:98
+#: ../vector/v.surf.idw/main.c:106
#, fuzzy
msgid "Values"
msgstr "Valeur de la chaîne de bit"
@@ -33139,17 +32931,14 @@
#: ../vector/v.surf.idw/main.c:104
#, fuzzy
msgid "Attribute table column with values to interpolate"
-msgstr ""
-"couche>0)"
#: ../vector/v.surf.idw/main.c:105
msgid "Required if layer > 0"
msgstr ""
#: ../vector/v.surf.idw/main.c:122
-msgid ""
-"Power parameter; greater values assign greater influence to closer points"
+msgid "Power parameter; greater values assign greater influence to closer points"
msgstr ""
#: ../vector/v.surf.idw/main.c:127
@@ -33159,12 +32948,8 @@
#: ../vector/v.surf.idw/main.c:128
#, fuzzy
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-"Ne pas indexer les points par cellule raster (plus lent, mais utilise moins "
-"de mémoireet inclue les points extérieurs à la région dans l'interpolation)"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr "Ne pas indexer les points par cellule raster (plus lent, mais utilise moins de mémoireet inclue les points extérieurs à la région dans l'interpolation)"
#: ../vector/v.surf.idw/main.c:147
msgid "No attribute column specified"
@@ -33211,9 +32996,7 @@
#: ../vector/v.hull/main.c:286
#, fuzzy
msgid "Use all vector points (do not limit to current region)"
-msgstr ""
-"La couche vectorielle de départ %s ne contient aucun point dans la région "
-"courante"
+msgstr "La couche vectorielle de départ %s ne contient aucun point dans la région courante"
#: ../vector/v.hull/main.c:291
msgid "Create a 'flat' 2D hull even if the input is 3D points"
@@ -33259,9 +33042,7 @@
#: ../vector/v.out.dxf/write_dxf.c:23
#, fuzzy, c-format
msgid "The file '%s' already exists and will be overwritten."
-msgstr ""
-"écrasé!\n"
#: ../vector/v.out.dxf/write_dxf.c:27
#, fuzzy, c-format
@@ -33276,9 +33057,7 @@
#: ../vector/v.drape/main.c:168
#, fuzzy
msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Convertit une couche vecteur 2D en couche vecteur 3D en rééchantillonnant le "
-"raster d'altitude.Par défaut, en rééchantillonnant au plus proche voisin"
+msgstr "Convertit une couche vecteur 2D en couche vecteur 3D en rééchantillonnant le raster d'altitude.Par défaut, en rééchantillonnant au plus proche voisin"
#: ../vector/v.drape/main.c:180
#, fuzzy
@@ -33314,13 +33093,13 @@
"\n"
"Aucune couche DXF trouvée!\n"
-#: ../vector/v.drape/main.c:407 ../vector/v.drape/main.c:417
+#: ../vector/v.drape/main.c:407
+#: ../vector/v.drape/main.c:417
msgid "Due to error attribute data to new map are not transferred"
msgstr ""
#: ../vector/v.drape/main.c:425
-msgid ""
-"No features drapped. Check Your computational region and input raster map."
+msgid "No features drapped. Check Your computational region and input raster map."
msgstr ""
# c-format
@@ -33330,7 +33109,8 @@
# c-format
-#: ../vector/v.net.path/path.c:168 ../vector/v.net.path/path.c:186
+#: ../vector/v.net.path/path.c:168
+#: ../vector/v.net.path/path.c:186
#, fuzzy, c-format
msgid "No point with category [%d]"
@@ -33368,11 +33148,8 @@
#: ../vector/v.net.path/main.c:65
#, fuzzy
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
-"Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les "
-"prendre à partirde la ligne de commande"
+msgid "Name of file containing start and end points. If not given, read from stdin"
+msgstr "Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les prendre à partirde la ligne de commande"
#: ../vector/v.net.path/main.c:92
#, fuzzy
@@ -33380,10 +33157,7 @@
msgstr "Distance maximale du point au réseau"
#: ../vector/v.net.path/main.c:93
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
msgstr ""
#: ../vector/v.net.path/main.c:106
@@ -33452,13 +33226,15 @@
msgid "%s is empty"
msgstr "L'intervalle va de %ld à %ld\n"
-#: ../vector/v.to.rast/support.c:141 ../vector/v.to.rast/support.c:302
+#: ../vector/v.to.rast/support.c:141
+#: ../vector/v.to.rast/support.c:302
#: ../vector/v.to.rast/support.c:452
#, fuzzy, c-format
msgid "Unknown column <%s> in table <%s>"
msgstr "Type de colonne inconnu"
-#: ../vector/v.to.rast/support.c:162 ../vector/v.to.rast/support.c:328
+#: ../vector/v.to.rast/support.c:162
+#: ../vector/v.to.rast/support.c:328
#, fuzzy
msgid "No records selected"
msgstr "Pas de police sélectionnée"
@@ -33466,9 +33242,7 @@
#: ../vector/v.to.rast/support.c:175
#, fuzzy, c-format
msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), entité surfacique %d "
-"avec la catégorie %d: code couleur [%s]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d: code couleur [%s]"
#: ../vector/v.to.rast/support.c:178
msgid "Color set to [200:200:200]"
@@ -33477,15 +33251,14 @@
#: ../vector/v.to.rast/support.c:183
#, fuzzy, c-format
msgid "Error in color definition column (%s), with cat %d"
-msgstr ""
-"avec la catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d"
#: ../vector/v.to.rast/support.c:275
msgid "Label column was not specified, no labels will be written"
msgstr ""
-#: ../vector/v.to.rast/support.c:351 ../vector/v.to.rast/support.c:498
+#: ../vector/v.to.rast/support.c:351
+#: ../vector/v.to.rast/support.c:498
#, fuzzy, c-format
msgid "Column type (%s) not supported"
msgstr "Type de colonne non géré"
@@ -33495,7 +33268,8 @@
msgid "Cannot allocate memory for row buffer"
-#: ../vector/v.to.rast/support.c:579 ../vector/v.to.rast/vect2rast.c:119
+#: ../vector/v.to.rast/support.c:579
+#: ../vector/v.to.rast/vect2rast.c:119
#, fuzzy, c-format
msgid "Unknown use type: %d"
msgstr "Type inconnu: %c"
@@ -33592,10 +33366,7 @@
#: ../vector/v.to.rast/main.c:62
#, fuzzy
-msgid ""
-"attr;read values from attribute table;cat;use category values;val;use value "
-"specified by value option;z;use z coordinate (points or contours only);dir;"
-"output as flow direction (lines only)"
+msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
msgstr ""
"Valeurs raster en entrée :\n"
"\t\tattr - valeur de la table attributaire en lecture\n"
@@ -33612,9 +33383,7 @@
#: ../vector/v.to.rast/main.c:77
#, fuzzy
msgid "Name of color definition column (with RRR:GGG:BBB entries)"
-msgstr ""
-"Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -"
-"a)"
+msgstr "Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -a)"
#: ../vector/v.to.rast/main.c:83
#, fuzzy
@@ -33632,9 +33401,7 @@
#: ../vector/v.to.rast/main.c:118
msgid "Column parameter cannot be combined with use of category values option"
-msgstr ""
-"Le paramètre de colonne ne peut pas être combiner avec l'option de valeurs "
-"de catégories"
+msgstr "Le paramètre de colonne ne peut pas être combiner avec l'option de valeurs de catégories"
#: ../vector/v.to.rast/main.c:123
msgid "Column parameter cannot be combined with use of value option"
@@ -33642,16 +33409,15 @@
#: ../vector/v.to.rast/main.c:128
msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr ""
-"Le paramètre de colonne ne peut être combiné avec l'utilisation de "
-"coordonnées z"
+msgstr "Le paramètre de colonne ne peut être combiné avec l'utilisation de coordonnées z"
#: ../vector/v.to.rast/main.c:134
#, fuzzy, c-format
msgid "Unknown option '%s'"
msgstr "Type inconnu"
-#: ../vector/v.to.rast/do_lines.c:65 ../vector/v.to.rast/do_areas.c:63
+#: ../vector/v.to.rast/do_lines.c:65
+#: ../vector/v.to.rast/do_areas.c:63
#, fuzzy
msgid "Unable to use column specified"
msgstr "Aucune colonne attributaire spécifiée"
@@ -33661,7 +33427,8 @@
msgid "%d lines with varying height were not written to raster"
msgstr ""
-#: ../vector/v.to.rast/do_areas.c:49 ../vector/v.to.rast/do_areas.c:57
+#: ../vector/v.to.rast/do_areas.c:49
+#: ../vector/v.to.rast/do_areas.c:57
#, fuzzy, c-format
msgid "No record for area (cat = %d)"
msgstr "Aucun enregistrement pour la ligne (cat = %d)"
@@ -33684,8 +33451,7 @@
#: ../vector/v.out.vtk/writeVTK.c:188
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr ""
#: ../vector/v.out.vtk/writeVTK.c:623
@@ -33703,8 +33469,10 @@
msgid "No numerical attributes found. Skipping export"
-#: ../vector/v.out.vtk/writeVTK.c:717 ../vector/v.out.vtk/writeVTK.c:744
-#: ../vector/v.out.vtk/writeVTK.c:771 ../vector/v.out.vtk/writeVTK.c:797
+#: ../vector/v.out.vtk/writeVTK.c:717
+#: ../vector/v.out.vtk/writeVTK.c:744
+#: ../vector/v.out.vtk/writeVTK.c:771
+#: ../vector/v.out.vtk/writeVTK.c:797
#, fuzzy, c-format
msgid "Error reading value of attribute '%s'"
msgstr "Erreur de lecture du fichier cats de <%s>"
@@ -33773,7 +33541,8 @@
msgid "Lat-long projection"
-#: ../db/drivers/ogr/fetch.c:132 ../db/drivers/ogr/describe.c:165
+#: ../db/drivers/ogr/fetch.c:132
+#: ../db/drivers/ogr/describe.c:165
msgid "Unknown type"
@@ -33784,12 +33553,8 @@
#: ../db/drivers/ogr/describe.c:157
#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"colonne '%s', de type 'string': largeur inconnue -> enregistrée comme varchar"
-"(250) des données peuvent être tronquées"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "colonne '%s', de type 'string': largeur inconnue -> enregistrée comme varchar(250) des données peuvent être tronquées"
#: ../db/drivers/mysql/cursor.c:46
msgid "Cannot allocate cursor."
@@ -33859,17 +33624,15 @@
msgid "Wrong port number in MySQL database definition: "
msgstr "Erreur de définition du numéro de port de la base de données MySQL:"
-#: ../db/drivers/mysql/parse.c:71 ../db/drivers/postgres/parse.c:55
+#: ../db/drivers/mysql/parse.c:71
+#: ../db/drivers/postgres/parse.c:55
msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-"'utilisateur'('user') n'est pas géré dans la définition des bases de "
-"données, utiliser db.login"
+msgstr "'utilisateur'('user') n'est pas géré dans la définition des bases de données, utiliser db.login"
-#: ../db/drivers/mysql/parse.c:75 ../db/drivers/postgres/parse.c:59
+#: ../db/drivers/mysql/parse.c:75
+#: ../db/drivers/postgres/parse.c:59
msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'mot de passe'('password') n'est pas géré dans la définition des bases de "
+msgstr "'mot de passe'('password') n'est pas géré dans la définition des bases de données, utiliser db.login"
#: ../db/drivers/mysql/parse.c:79
msgid "Unknown option in database definition for "
@@ -33882,12 +33645,8 @@
#: ../db/drivers/mysql/describe.c:126
#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"colonne '%s' : type BIGINT (entier large) enregistré comme entier (4 octets) "
-"des données peuvent avoir été endommagées"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonne '%s' : type BIGINT (entier large) enregistré comme entier (4 octets) des données peuvent avoir été endommagées"
#: ../db/drivers/mysql/select.c:43
msgid "Cannot select data: \n"
@@ -33913,30 +33672,18 @@
#: ../db/drivers/postgres/describe.c:116
#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"colonne '%s' : type int8 (entier large) enregistré comme entier (4 octets) "
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonne '%s' : type int8 (entier large) enregistré comme entier (4 octets) des données peuvent avoir été endommagées"
#: ../db/drivers/postgres/describe.c:120
#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"colonne '%s' : type character varying enregistré comme varchar(250) des "
-"données peuvent être tronquées"
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "colonne '%s' : type character varying enregistré comme varchar(250) des données peuvent être tronquées"
#: ../db/drivers/postgres/describe.c:126
#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"colonne '%s' : type bool (booléen) enregistré comme char(1) avec '0' (faux) "
-"ou '1' (vrai)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "colonne '%s' : type bool (booléen) enregistré comme char(1) avec '0' (faux) ou '1' (vrai)"
# c-format
#: ../db/drivers/sqlite/db.c:85
@@ -33960,7 +33707,9 @@
msgid "SQLite driver: column '%s', SQLite type %d is not supported"
msgstr "Pilote SQLite : colonne '%s', type de donnée SQLite %d non géré"
-#: ../db/base/droptable.c:78 ../db/base/createdb.c:71 ../db/base/dropdb.c:71
+#: ../db/base/droptable.c:78
+#: ../db/base/createdb.c:71
+#: ../db/base/dropdb.c:71
#: ../db/base/databases.c:90
#, fuzzy
msgid "database, SQL"
@@ -33986,7 +33735,9 @@
msgid "System tables instead of user tables"
msgstr "tables du système au lieu de tables utilisateurs"
-#: ../db/base/tables.c:95 ../db/base/columns.c:92 ../db/base/drivers.c:73
+#: ../db/base/tables.c:95
+#: ../db/base/columns.c:92
+#: ../db/base/drivers.c:73
#: ../db/base/describe.c:125
#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
@@ -34010,8 +33761,7 @@
#: ../db/base/connect.c:47
#, fuzzy
msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
-"Affiche/configure la connexion à la base de données du jeu de données courant"
+msgstr "Affiche/configure la connexion à la base de données du jeu de données courant"
#: ../db/base/connect.c:51
#, fuzzy
@@ -34030,18 +33780,13 @@
#: ../db/base/connect.c:75
#, fuzzy
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
-"Schéma de la base de données. Ne pas utiliser cette option si le pilote ou "
-"le serveur ne gèrent pas les schémas de BD."
+msgid "Do not use this option if schemas are not supported by driver/database server"
+msgstr "Schéma de la base de données. Ne pas utiliser cette option si le pilote ou le serveur ne gèrent pas les schémas de BD."
#: ../db/base/connect.c:85
#, fuzzy
msgid "Default group of database users to which select privilege is granted"
-msgstr ""
-"Groupe d'utilisateurs par défaut de la base de données qui ont le privilège "
-"SELECT."
+msgstr "Groupe d'utilisateurs par défaut de la base de données qui ont le privilège SELECT."
#: ../db/base/connect.c:121
#, fuzzy
@@ -34094,12 +33839,15 @@
msgid "Lists all database drivers."
msgstr "Liste tous les pilotes de base de données"
-#: ../db/base/execute.c:78 ../db/base/execute.c:86
+#: ../db/base/execute.c:78
+#: ../db/base/execute.c:86
#, fuzzy, c-format
msgid "Error while executing: '%s'"
msgstr "Erreur lors de l'exécution : \"%s\""
-#: ../db/base/execute.c:112 ../db/base/copy.c:37 ../db/base/select.c:255
+#: ../db/base/execute.c:112
+#: ../db/base/copy.c:37
+#: ../db/base/select.c:255
#, fuzzy
msgid "database, attribute table, SQL"
msgstr "Ne pas créer de table attributaire"
@@ -34117,9 +33865,7 @@
#: ../db/base/execute.c:119
#, fuzzy
msgid "If not given or '-' read from standard input"
-msgstr ""
#: ../db/base/execute.c:134
msgid "Ignore SQL errors and continue"
@@ -34128,8 +33874,7 @@
#: ../db/base/describe.c:104
#, fuzzy
msgid "Print column names only instead of full column descriptions"
-msgstr ""
-"afficher uniquement le nom des colonnes, au lieu de la description complète"
+msgstr "afficher uniquement le nom des colonnes, au lieu de la description complète"
#: ../db/base/describe.c:109
#, fuzzy
@@ -34148,13 +33893,8 @@
#: ../db/base/copy.c:40
#, fuzzy
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Copier une table. Vous pouvez soit utiliser 'from_table' (avec une clause "
-"'where' optionnelle)ou l'option 'select', mais pas simultanément "
-"'from_table' et 'select'."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Copier une table. Vous pouvez soit utiliser 'from_table' (avec une clause 'where' optionnelle)ou l'option 'select', mais pas simultanément 'from_table' et 'select'."
#: ../db/base/copy.c:46
msgid "Input driver name"
@@ -34184,8 +33924,7 @@
#, fuzzy
msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
msgstr ""
-"Clause \"select\" complète (seulement si from_table et where n'ont pas été "
-"utilisés), ex:\n"
+"Clause \"select\" complète (seulement si from_table et where n'ont pas été utilisés), ex:\n"
"\t\tSELECT dedek FROM starobince WHERE obec = 'Frimburg'"
#: ../db/base/copy.c:88
@@ -34222,9 +33961,7 @@
#: ../db/base/databases.c:92
msgid "List all databases for a given driver and location."
-msgstr ""
-"Lister toutes les bases de données pour un pilote et un Secteur (location) "
-"donnés."
+msgstr "Lister toutes les bases de données pour un pilote et un Secteur (location) donnés."
#: ../db/base/select.c:93
#, fuzzy, c-format
@@ -34243,9 +33980,7 @@
#: ../db/base/select.c:207
#, fuzzy
msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-msgstr ""
-"Clause SQL 'select', par exemple: 'select * from rybniky where kapri = "
-"'hodne''"
+msgstr "Clause SQL 'select', par exemple: 'select * from rybniky where kapri = 'hodne''"
#: ../db/base/select.c:211
#, fuzzy
@@ -34272,8 +34007,7 @@
#: ../db/db.login/main.c:44
msgid "Sets user/password for driver/database."
-msgstr ""
-"Définir utilisateurs/mot de passe pour le pilote de la base de données."
+msgstr "Définir utilisateurs/mot de passe pour le pilote de la base de données."
#: ../db/db.login/main.c:60
#, fuzzy
@@ -34334,12 +34068,8 @@
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
#, fuzzy
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importer les fichiers pays US-NGA GEOnet Names Server (GNS) dans une couche "
-"de points vectoriels GRASS"
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importer les fichiers pays US-NGA GEOnet Names Server (GNS) dans une couche de points vectoriels GRASS"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
@@ -34389,12 +34119,8 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"Calcule des statistiques univariées à partir d'une couche raster GRASS basée "
-"sur des objets vecteurs"
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+msgstr "Calcule des statistiques univariées à partir d'une couche raster GRASS basée sur des objets vecteurs"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
#, fuzzy
@@ -34412,9 +34138,7 @@
msgstr "Nom de la couche vecteur"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use"
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
msgstr ""
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
@@ -34429,9 +34153,7 @@
#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
msgid "Export display monitor to a GpsDrive compatible backdrop image"
-msgstr ""
-"Exporter le moniteur d'affichage vers une image compatible avec un récepteur "
-"GPS"
+msgstr "Exporter le moniteur d'affichage vers une image compatible avec un récepteur GPS"
#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
#, fuzzy
@@ -34450,9 +34172,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:1
#, fuzzy
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mèle les composantes de couleurs de deux couches rasters en fonction d'un "
-"ratio donné"
+msgstr "Mèle les composantes de couleurs de deux couches rasters en fonction d'un ratio donné"
#: ../locale/scriptstrings/r.blend_to_translate.c:2
msgid "raster"
@@ -34470,8 +34190,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:5
#, fuzzy
msgid "Base name for red, green and blue output maps containing the blend"
-msgstr ""
-"Nom de base pour les couches de sortie rouge, vert, bleu contenant le mélange"
+msgstr "Nom de base pour les couches de sortie rouge, vert, bleu contenant le mélange"
#: ../locale/scriptstrings/r.blend_to_translate.c:6
msgid "Percentage weight of first map for color blending"
@@ -34509,9 +34228,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
#, fuzzy
msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Colonne attributaire à utiliser pour l'affichage thématique (doit être "
-"numérique)"
+msgstr "Colonne attributaire à utiliser pour l'affichage thématique (doit être numérique)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
msgid "Type of thematic display"
@@ -34524,16 +34241,12 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
#, fuzzy
msgid "Break points for custom breaks option"
-msgstr ""
-"Points de rupture pour l'option de rupture personnalisée. Valeurs séparées "
-"par des espaces (0 10 20 30 ...)"
+msgstr "Points de rupture pour l'option de rupture personnalisée. Valeurs séparées par des espaces (0 10 20 30 ...)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
#, fuzzy
msgid "Separate values by spaces (0 10 20 30 ...)"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
msgid "Vector point icon for point data"
@@ -34547,13 +34260,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
#, fuzzy
msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-"Taille maximale de l'icone/largeur de ligne pour les points gradués/lignes)"
+msgstr "Taille maximale de l'icone/largeur de ligne pour les points gradués/lignes)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
msgid "Number of classes for interval theme (integer)"
@@ -34567,9 +34278,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
#, fuzzy
msgid "Select 'single_color' for graduated point/line display"
-msgstr ""
-"Schéma de couleur pour la cartographie en couleurs graduelles (choisissez "
-"'couleur simple' pour l'affichage point gradué/ligne)"
+msgstr "Schéma de couleur pour la cartographie en couleurs graduelles (choisissez 'couleur simple' pour l'affichage point gradué/ligne)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
#, fuzzy
@@ -34579,10 +34288,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
#, fuzzy
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
-"Couleur pour les lignes graduées ou les contours de points/entités "
-"surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de "
-"couleur pour couleur simple."
+msgstr "Couleur pour les lignes graduées ou les contours de points/entités surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de couleur pour couleur simple."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
#, fuzzy
@@ -34592,32 +34298,23 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
#, fuzzy
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
#, fuzzy
msgid "Beginning color for custom color gradient"
-msgstr ""
-"Couleur de départ pour le gardient de couleur personnalisé. Doit être "
-"exprimé sous forme de triplet R:G:B."
+msgstr "Couleur de départ pour le gardient de couleur personnalisé. Doit être exprimé sous forme de triplet R:G:B."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
#, fuzzy
msgid "Must be expressed as R:G:B triplet"
-msgstr ""
-"Couleur de fin pour le gradient de couleur personnalisé. Doit être exprimé "
-"sous forme de triplet R:G:B."
+msgstr "Couleur de fin pour le gradient de couleur personnalisé. Doit être exprimé sous forme de triplet R:G:B."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
#, fuzzy
msgid "Ending color for custom color gradient"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
@@ -34633,9 +34330,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-"Sauvegarder les commandes de cartographie thématique dans le fichier de "
-"groupe dans le Gestionnaire SIG"
+msgstr "Sauvegarder les commandes de cartographie thématique dans le fichier de groupe dans le Gestionnaire SIG"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
@@ -34647,22 +34342,16 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
#, fuzzy
msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-"Racine du nom du fichier d'instruction psmat dans le répertoire courant (si "
-"non indiqué, aucun fichier d'instruction psmap ne sera créé)"
+msgstr "Racine du nom du fichier d'instruction psmat dans le répertoire courant (si non indiqué, aucun fichier d'instruction psmap ne sera créé)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
#, fuzzy
msgid "If not set, no psmap instruction files will be created)"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-"Nom du fichier de groupe où les commandes de cartographie thématique seront "
-"sauvegardées"
+msgstr "Nom du fichier de groupe où les commandes de cartographie thématique seront sauvegardées"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
#, fuzzy
@@ -34671,15 +34360,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
msgid "Only draw fills (no outlines) for areas and points"
-msgstr ""
-"Ne dessiner que le remplissage (sans contours) pour les entités surfaciques "
-"et les points"
+msgstr "Ne dessiner que le remplissage (sans contours) pour les entités surfaciques et les points"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
msgid "Update color values to GRASSRGB column in attribute table"
-msgstr ""
-"Mettre à jour les valeurs de couleurs de la colonne GRASSRGB dans la table "
-"attributaire"
+msgstr "Mettre à jour les valeurs de couleurs de la colonne GRASSRGB dans la table attributaire"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:60
msgid "Output legend for GIS Manager (for scripting use only)"
@@ -34697,9 +34382,7 @@
#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
#, fuzzy
msgid "Table from which to drop attribute column"
-msgstr ""
-"Nom de la couche de points vecteurs en entrée pour laquelle éditer la table "
-"attributaire"
+msgstr "Nom de la couche de points vecteurs en entrée pour laquelle éditer la table attributaire"
#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
#, fuzzy
@@ -34708,8 +34391,7 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Crée une couche de relief estompé à partir d'une couche d'altitude (MNT)."
+msgstr "Crée une couche de relief estompé à partir d'une couche d'altitude (MNT)."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
#: ../locale/scriptstrings/r.plane_to_translate.c:2
@@ -34735,15 +34417,12 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"Facteur d'échelle pour convertir les unités horizontales en unités d'altitude"
+msgstr "Facteur d'échelle pour convertir les unités horizontales en unités d'altitude"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
#, fuzzy
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-"Fixer le facteur d'échelle (s'applique au Secteur en lat./long. seulement)"
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgstr "Fixer le facteur d'échelle (s'applique au Secteur en lat./long. seulement)"
#: ../locale/scriptstrings/d.redraw_to_translate.c:1
#, fuzzy
@@ -34786,12 +34465,8 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
#, fuzzy
-msgid ""
-"The database must be in form printed by v.db.connect -g, i.e. with "
-"substituted variables"
-msgstr ""
-"Nom de l'ancienne base de données, la base de données doit être sous à la "
-"forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
+msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
+msgstr "Nom de l'ancienne base de données, la base de données doit être sous à la forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
msgid "Name of new database"
@@ -34807,9 +34482,7 @@
#: ../locale/scriptstrings/d.out.png_to_translate.c:1
msgid "Saves active display monitor to PNG file in home directory"
-msgstr ""
-"Sauvegarder l'affichage du moniteur actif en fichier PNG dans le répertoire "
-"home"
+msgstr "Sauvegarder l'affichage du moniteur actif en fichier PNG dans le répertoire home"
#: ../locale/scriptstrings/d.out.png_to_translate.c:2
#: ../locale/scriptstrings/d.out.file_to_translate.c:2
@@ -34863,9 +34536,7 @@
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
#, fuzzy
msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"importer aussi la couche de qualité (couche du statut SM) et couche filtre "
-"NDVI"
+msgstr "importer aussi la couche de qualité (couche du statut SM) et couche filtre NDVI"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
@@ -34873,9 +34544,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"Trace un diagramme polaire angulaire pour l'aspect (exposition) ou les "
-"directions du courant"
+msgstr "Trace un diagramme polaire angulaire pour l'aspect (exposition) ou les directions du courant"
#: ../locale/scriptstrings/d.polar_to_translate.c:2
#: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -34903,16 +34572,12 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
#, fuzzy
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"nom de la table attributaire existante (par défaut : nom de la couche "
-"vecteur)"
+msgstr "nom de la table attributaire existante (par défaut : nom de la couche vecteur)"
#: ../locale/scriptstrings/v.db.join_to_translate.c:3
#, fuzzy
msgid "Vector map to which to join other table"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.join_to_translate.c:4
#, fuzzy
@@ -34978,11 +34643,8 @@
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
#, fuzzy
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr ""
-"option de création du pilote de format de sortie. De multiples options "
-"peuvent être disponibles"
+msgid "Creation option to the output format driver. Multiple options may be listed"
+msgstr "option de création du pilote de format de sortie. De multiples options peuvent être disponibles"
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
#, fuzzy
@@ -34992,12 +34654,8 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"Calcule des statistiques univariées sur la colonne sélectionnée dans une "
-"table de couche vecteur."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr "Calcule des statistiques univariées sur la colonne sélectionnée dans une table de couche vecteur."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
@@ -35014,9 +34672,7 @@
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
#, fuzzy
msgid "Column on which to calculate statistics (must be numeric)"
-msgstr ""
-"Nom de la colonne sur laquelle calculée les statistiques (le type doit être "
-"numérique)"
+msgstr "Nom de la colonne sur laquelle calculée les statistiques (le type doit être numérique)"
# c-format
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
@@ -35076,9 +34732,7 @@
#: ../locale/scriptstrings/d.slide.show_to_translate.c:4
#, fuzzy
msgid "Map prefix. Specify character(s) to view selected maps only"
-msgstr ""
-"préfixe de couche. Spécifier les caractère(s) pour voir les couches "
-"sélectionnées seulement"
+msgstr "préfixe de couche. Spécifier les caractère(s) pour voir les couches sélectionnées seulement"
#: ../locale/scriptstrings/d.slide.show_to_translate.c:5
#, fuzzy
@@ -35093,9 +34747,7 @@
#: ../locale/scriptstrings/d.slide.show_to_translate.c:7
#, fuzzy
msgid "Mapsets to use. Specify multiple mapsets comma separated"
-msgstr ""
-"Jeux de données à utiliser. Spécifier de multiples jeux de données en les "
-"séparant par des virgules"
+msgstr "Jeux de données à utiliser. Spécifier de multiples jeux de données en les séparant par des virgules"
#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
#, fuzzy
@@ -35109,9 +34761,7 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
#, fuzzy
msgid "Create a 3D line from 3 column data"
-msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
#, fuzzy
@@ -35153,12 +34803,8 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
#, fuzzy
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reclasser une couche raster plus grande ou plus petite que la taille "
-"spécifiée par l'utilisateur (en hectares)"
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reclasser une couche raster plus grande ou plus petite que la taille spécifiée par l'utilisateur (en hectares)"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
#, fuzzy
@@ -35168,23 +34814,17 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
#, fuzzy
msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr ""
-"option valeur 'plus petite que' <= pour la taille limite de surface "
-"[hectares]"
+msgstr "option valeur 'plus petite que' <= pour la taille limite de surface [hectares]"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
#, fuzzy
msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr ""
-"option valeur 'plus grande que' >= pour la taille limite de surface "
-"[hectares]"
+msgstr "option valeur 'plus grande que' >= pour la taille limite de surface [hectares]"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
#, fuzzy
msgid "Calculate new raster map from a r.mapcalc expression."
-msgstr ""
-"r.mapcalculator - calcule une nouvelle couche raster à partir d'une "
-"expression r.mapcalc"
+msgstr "r.mapcalculator - calcule une nouvelle couche raster à partir d'une expression r.mapcalc"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:2
#, fuzzy
@@ -35240,9 +34880,7 @@
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
#, fuzzy
msgid "Imports attribute tables in various formats."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
#, fuzzy
@@ -35310,8 +34948,7 @@
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
msgid "Preserve relative colors, adjust brightness only"
-msgstr ""
-"Préserver les nuances de couleurs relatives, ajuster seulement la luminosité"
+msgstr "Préserver les nuances de couleurs relatives, ajuster seulement la luminosité"
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
msgid "Reset to standard color range"
@@ -35319,11 +34956,8 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:1
#, fuzzy
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"afficher la réponse spectrale à des emplacements précisés par l'utilisateur "
-"dans un groupe ou dans des images"
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "afficher la réponse spectrale à des emplacements précisés par l'utilisateur dans un groupe ou dans des images"
#: ../locale/scriptstrings/i.spectral_to_translate.c:2
msgid "imagery, raster, multispectral"
@@ -35358,18 +34992,13 @@
msgstr "Etiquette avec coordonnées à la place d'un nombre"
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Créer une couche plane raster en fonction de l'angle (inclinaison), de "
-"l'aspect/exposition (azimut), et un point"
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Créer une couche plane raster en fonction de l'angle (inclinaison), de l'aspect/exposition (azimut), et un point"
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#, fuzzy
@@ -35418,9 +35047,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
#, fuzzy
msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
#, fuzzy
@@ -35432,9 +35059,7 @@
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur "
-"stdout)"
+msgstr "Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur stdout)"
#: ../locale/scriptstrings/d.monsize_to_translate.c:1
msgid "Selects/starts specified monitor at specified size"
@@ -35455,9 +35080,7 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
#, fuzzy
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
#, fuzzy
@@ -35466,12 +35089,8 @@
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
#, fuzzy
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Charger des Waypoints, Routes et Tracks à partir d'un récepteur GPS Garmin "
-"dans une couche vecteur."
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Charger des Waypoints, Routes et Tracks à partir d'un récepteur GPS Garmin dans une couche vecteur."
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
@@ -35511,8 +35130,7 @@
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
#, fuzzy
msgid "Do not attempt projection transform from WGS84"
-msgstr ""
-"Ne pas essayer de faire une transformation de projection à partir de WGS84"
+msgstr "Ne pas essayer de faire une transformation de projection à partir de WGS84"
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
#, fuzzy
@@ -35521,12 +35139,8 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
#, fuzzy
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"r.in.aster - georéférencement, recalage, et import d'images Terra-ASTER et "
-"de MNT en utilisant gdalwarp"
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+msgstr "r.in.aster - georéférencement, recalage, et import d'images Terra-ASTER et de MNT en utilisant gdalwarp"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
#, fuzzy
@@ -35535,17 +35149,12 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
-"Type de traitement d'image ASTER (niveau 1A, niveau 1B, ou MNT relatif)"
+msgstr "Type de traitement d'image ASTER (niveau 1A, niveau 1B, ou MNT relatif)"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
#, fuzzy
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
-msgstr ""
-"canal L1A ou L1B à traduire (1, 2,3n,3b,4-14). Il n'est possible de traduire "
-"qu'un seul canal"
+msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
+msgstr "canal L1A ou L1B à traduire (1, 2,3n,3b,4-14). Il n'est possible de traduire qu'un seul canal"
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
#, fuzzy
@@ -35577,8 +35186,7 @@
#: ../locale/scriptstrings/d.out.file_to_translate.c:1
#, fuzzy
msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr ""
-"Sauvegarder le moniteur actif en fichier graphique dans le répertoire home"
+msgstr "Sauvegarder le moniteur actif en fichier graphique dans le répertoire home"
#: ../locale/scriptstrings/d.out.file_to_translate.c:3
#, fuzzy
@@ -35624,9 +35232,7 @@
#: ../locale/scriptstrings/d.out.file_to_translate.c:14
#, fuzzy
msgid "(10=smallest/worst, 100=largest/best)"
-msgstr ""
-"Taille/qualité pour les fichiers JPEG (10=plus petit/très dégradée, 100=plus "
-"grande/moins dégradée)"
+msgstr "Taille/qualité pour les fichiers JPEG (10=plus petit/très dégradée, 100=plus grande/moins dégradée)"
#: ../locale/scriptstrings/d.out.file_to_translate.c:16
#, fuzzy
@@ -35659,8 +35265,7 @@
msgstr ""
#: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
msgstr ""
#: ../locale/scriptstrings/d.out.file_to_translate.c:26
@@ -35720,19 +35325,13 @@
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
#, fuzzy
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"ajouter une ou plusieurs colonnes à la table attributaire connectée à une "
-"couche vecteur donnée"
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "ajouter une ou plusieurs colonnes à la table attributaire connectée à une couche vecteur donnée"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
#, fuzzy
msgid "Name of vector map for which to edit attribute table"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
#, fuzzy
@@ -35742,9 +35341,7 @@
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-msgid ""
-"number determines which table to use."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
msgstr ""
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:6
@@ -35753,27 +35350,18 @@
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:7
#, fuzzy
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
-msgstr ""
-"nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de "
-"données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgstr "nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
#, fuzzy
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"permet d'affecter une nouvelle valeur à la colonne de la table attributaire "
-"connectée à la table"
+msgid "Allows to update a column in the attribute table connected to a vector map."
+msgstr "permet d'affecter une nouvelle valeur à la colonne de la table attributaire connectée à la table"
#: ../locale/scriptstrings/v.db.update_to_translate.c:3
#, fuzzy
msgid "Vector map to edit the attribute table for"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.update_to_translate.c:4
msgid "Layer to which the table to be changed is connected"
@@ -35786,12 +35374,8 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
#, fuzzy
-msgid ""
-"Value to update the column with (varchar values have to be in single quotes, "
-"e.g. 'grass')"
-msgstr ""
-"nouvelle valeur à affecter à la colonne (les valeurs varchar doivent être "
-"entre simples guillemets, par exemple : 'grass')"
+msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
+msgstr "nouvelle valeur à affecter à la colonne (les valeurs varchar doivent être entre simples guillemets, par exemple : 'grass')"
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
#, fuzzy
@@ -35800,17 +35384,13 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
#, fuzzy
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
+msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
msgstr "Conditions WHERE de la requête SQL sans le mot clef 'where'"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
#, fuzzy
msgid "Exports attribute tables into various formats."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
#, fuzzy
@@ -35828,8 +35408,7 @@
msgstr "format OGR"
#: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
+msgid "Set color rules for features in a vector using a numeric attribute column."
msgstr ""
#: ../locale/scriptstrings/v.colors_to_translate.c:2
@@ -35869,11 +35448,8 @@
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
#, fuzzy
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"convertit toutes les anciennes couches vectorielles GRASS (versions "
-"antérieures à 5.7) du jeu de données courant au format récent"
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr "convertit toutes les anciennes couches vectorielles GRASS (versions antérieures à 5.7) du jeu de données courant au format récent"
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
#, fuzzy
@@ -35888,9 +35464,7 @@
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
#, fuzzy
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Remplir les zones sans données des couches rasters en utilisant "
-"l'interpolation par splines v.surf.rst"
+msgstr "Remplir les zones sans données des couches rasters en utilisant l'interpolation par splines v.surf.rst"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
#, fuzzy
@@ -35905,9 +35479,7 @@
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
#, fuzzy
msgid "Name for output raster map with nulls filled by interpolation"
-msgstr ""
-"Couche raster de sortie où remplacer les nulls par interpolation des valeurs "
-"voisines"
+msgstr "Couche raster de sortie où remplacer les nulls par interpolation des valeurs voisines"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
msgid "Spline tension parameter"
@@ -35964,12 +35536,8 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"crée et ajoute une nouvelle table attributaire à une couche donnée vecteur "
-"existante"
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "crée et ajoute une nouvelle table attributaire à une couche donnée vecteur existante"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
msgid "Vector map for which to add new attribute table"
@@ -35977,8 +35545,7 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-"Nom de la nouvelle table attributaire (par défaut: nouvelle couche vecteur)"
+msgstr "Nom de la nouvelle table attributaire (par défaut: nouvelle couche vecteur)"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
msgid "Layer where to add new attribute table"
@@ -35986,27 +35553,18 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
#, fuzzy
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-msgstr ""
+msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
#, fuzzy
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
+msgid "Renames a column in the attribute table connected to a given vector map."
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
#, fuzzy
msgid "Vector map for which to rename attribute column"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
#, fuzzy
@@ -36020,9 +35578,7 @@
#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:1
#, fuzzy
msgid "Calculates new grid3D volume from r3.mapcalc expression."
-msgstr ""
#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
#, fuzzy
@@ -36080,8 +35636,7 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
#, fuzzy
msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Charge les valeurs vecteurs dans la table aux positions des points vecteurs"
+msgstr "Charge les valeurs vecteurs dans la table aux positions des points vecteurs"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
#, fuzzy
@@ -36119,9 +35674,7 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Tester le pilote de base de données, la base de données doit exister et "
-"connectée par db.connect"
+msgstr "Tester le pilote de base de données, la base de données doit exister et connectée par db.connect"
#: ../locale/scriptstrings/db.test_to_translate.c:3
msgid "Test name"
@@ -36129,12 +35682,8 @@
#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
#, fuzzy
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
msgid "run non-interactively"
@@ -36174,8 +35723,7 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:1
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Convertit les coordonnées d'une projection à une autre (interface de cs2cs)."
+msgstr "Convertit les coordonnées d'une projection à une autre (interface de cs2cs)."
#: ../locale/scriptstrings/m.proj_to_translate.c:2
#, fuzzy
@@ -36217,38 +35765,28 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:13
msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"Utiliser LL WGS84 en entrée et le secteur courant comme projection en sortie"
+msgstr "Utiliser LL WGS84 en entrée et le secteur courant comme projection en sortie"
#: ../locale/scriptstrings/m.proj_to_translate.c:15
msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-"Utiliser le secteur courant en entrée et LL WGS84 comme projection en sortie"
+msgstr "Utiliser le secteur courant en entrée et LL WGS84 comme projection en sortie"
#: ../locale/scriptstrings/m.proj_to_translate.c:17
#, fuzzy
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
-msgstr ""
-"Sortie long/lat en degrés décimaux et les autres projections avec beaucoup "
-"de décimales"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgstr "Sortie long/lat en degrés décimaux et les autres projections avec beaucoup de décimales"
#: ../locale/scriptstrings/m.proj_to_translate.c:19
-msgid ""
-"Script style output in CSV format respecting the field separator settings"
+msgid "Script style output in CSV format respecting the field separator settings"
msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:21
msgid "Verbose mode (print projection parameters and filenames to stderr)"
-msgstr ""
-"Mode détaillé (affiche les paramètres de projection et les noms de fichiers "
-"vers stderr)"
+msgstr "Mode détaillé (affiche les paramètres de projection et les noms de fichiers vers stderr)"
#: ../locale/scriptstrings/i.oif_to_translate.c:1
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Calcule la table Facteur-Index-Optimum pour les canaux 1-5, & 7 de LANDSAT TM"
+msgstr "Calcule la table Facteur-Index-Optimum pour les canaux 1-5, & 7 de LANDSAT TM"
#: ../locale/scriptstrings/i.oif_to_translate.c:2
#, fuzzy
@@ -36281,18 +35819,13 @@
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
#, fuzzy
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
+msgid "Drops a column from the attribute table connected to a given vector map."
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
#, fuzzy
msgid "Vector map for which to drop attribute column"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
#, fuzzy
@@ -36307,9 +35840,7 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
msgid "Force removal (required for actual deletion of table)"
@@ -36323,9 +35854,7 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
msgid "Layer from which to drop linked attribute table"
@@ -36347,12 +35876,8 @@
#, fuzzy
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Télécharger des Waypoints, Routes, et Tracks depuis un récepteur GPS ou un "
-"fichier GPS ASCII dans une couche vectorielle."
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Télécharger des Waypoints, Routes, et Tracks depuis un récepteur GPS ou un fichier GPS ASCII dans une couche vectorielle."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
#, fuzzy
@@ -36382,20 +35907,15 @@
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
#, fuzzy
msgid "Format of GPS input data (use gpsbabel supported formats)"
-msgstr ""
-"Format de données GPS en entrée (utiliser les formats gérés par gpsbabel)"
+msgstr "Format de données GPS en entrée (utiliser les formats gérés par gpsbabel)"
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
#, fuzzy
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-"projection des données en entrées (utiliser les options de PROJ.4), si rien "
-"n'est indiqué Lat/Lon WGS84 sera utilisée"
+msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+msgstr "projection des données en entrées (utiliser les options de PROJ.4), si rien n'est indiqué Lat/Lon WGS84 sera utilisée"
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
msgstr ""
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
@@ -36451,8 +35971,7 @@
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
#, fuzzy
msgid "Prints a graph of the correlation between data layers (in pairs)."
-msgstr ""
-"Affiche un graphe de corrélation entre les couches de données (par paires)"
+msgstr "Affiche un graphe de corrélation entre les couches de données (par paires)"
#: ../locale/scriptstrings/d.correlate_to_translate.c:3
#: ../locale/scriptstrings/d.correlate_to_translate.c:4
@@ -36463,9 +35982,7 @@
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
-"Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de "
-"couleurs; créer une couche *.mosaic"
+msgstr "Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de couleurs; créer une couche *.mosaic"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
#, fuzzy
@@ -36491,9 +36008,7 @@
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
#, fuzzy
msgid "calculates univariate statistics from a GRASS raster map"
-msgstr ""
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
msgid "extended statistics (quartiles and percentile)"
@@ -36505,12 +36020,8 @@
msgstr "Centile à calculer (requiert le drapeau -e)"
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Produit des tuiles de la projection source pour l'utilisation dans la région "
-"et la projection cible."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Produit des tuiles de la projection source pour l'utilisation dans la région et la projection cible."
#: ../locale/scriptstrings/r.tileset_to_translate.c:2
#, fuzzy
@@ -36526,11 +36037,8 @@
msgstr "Produit une requête vers un serveur cartographique en sortie"
#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Nom de la région à utiliser à la place de la région courante pour l'emprise "
-"et la résolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
+msgstr "Nom de la région à utiliser à la place de la région courante pour l'emprise et la résolution"
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
#, fuzzy
@@ -36590,8 +36098,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
msgid "Skip to downloading (to resume downloads faster)"
-msgstr ""
-"Passer directement au téléchargement (pour finir le téléchargement plus vite)"
+msgstr "Passer directement au téléchargement (pour finir le téléchargement plus vite)"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
@@ -36609,9 +36116,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
#, fuzzy
msgid "Clean existing data out of download directory"
-msgstr ""
-"Nettoyer les données existantes qui se trouvent dans le répertoire de "
-"téléchargement"
+msgstr "Nettoyer les données existantes qui se trouvent dans le répertoire de téléchargement"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
@@ -36672,9 +36177,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
#, fuzzy
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"Région désignée pour laquelle demander les données. La région courante est "
-"utilisée si rien d'autre n'est précisée."
+msgstr "Région désignée pour laquelle demander les données. La région courante est utilisée si rien d'autre n'est précisée."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
msgid "Folder to save downloaded data to"
@@ -36752,12 +36255,8 @@
msgstr "préfixe de couche raster TC en sortie"
#: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
-msgstr ""
-"Divise l'affichage actif en deux cadres & affiche des couches/exécute des "
-"commandes dans chaque cadre."
+msgid "Divides active display into two frames & displays maps/executes commands in each frame."
+msgstr "Divise l'affichage actif en deux cadres & affiche des couches/exécute des commandes dans chaque cadre."
#: ../locale/scriptstrings/d.split_to_translate.c:3
msgid "Enter raster map to display in 1st frame"
@@ -36780,11 +36279,8 @@
msgstr "Comment partager l'affichage"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"Transformée de Brovey pour fusionner les canaux multispectraux et "
-"panchromatique à haute résolution"
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr "Transformée de Brovey pour fusionner les canaux multispectraux et panchromatique à haute résolution"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
#, fuzzy
@@ -36842,9 +36338,7 @@
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -36890,12 +36384,8 @@
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
#, fuzzy
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Aucune table attributaire trouvée -> on utilise les identifiants de "
-"catégories comme attributs"
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Aucune table attributaire trouvée -> on utilise les identifiants de catégories comme attributs"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
#, fuzzy
@@ -36931,4502 +36421,3 @@
msgid "Percent to brighten"
msgstr "Pourcentage de convergence"
-#, fuzzy
-#~ msgid "Create/Edit"
-#~ msgstr "Corrélation"
-#~ msgid ""
-#~ "Create new projection files (modifies current location unless 'location' "
-#~ "option specified)"
-#~ msgstr ""
-#~ "Créer de nouveaux fichiers de projection (modifie le Secteur courant à "
-#~ "moins quel'option 'location' soit utilisée"
-# c-format
-#~ msgid "Location %s created!"
-#~ msgstr "Secteur %s créé!"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING! A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ATTENTION! Un fichier de projection existe déjà pour ce Secteur\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr ""
-#~ "Voulez-vous vraiment écraser les informations de projection courante "
-#~ msgid "Error writing PROJ_INFO"
-#~ msgstr "Erreur d'écriture de PROJ_INFO"
-#~ msgid "Error writing PROJ_UNITS"
-#~ msgstr "Erreur d'écriture de PROJ_UNITS"
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Les informations de projection ne seront pas mises à jour."
-#, fuzzy
-#~ msgid "Use G3D mask (if exists) with output map"
-#~ msgstr "Utilisez le masque raster 3D (s'il existe) sur la couche en entrée"
-#~ msgid "Use G3D mask (if exists) with input map"
-#, fuzzy
-#~ msgid "Results into a table:"
-#~ msgstr "Nom de la couche en sortie"
-#~ msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
-#~ msgstr "Nombre d'attributs incohérent (<%s/%s> %d: <%s> %d"
-#~ msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
-#~ msgstr "Nombre d'attributs incohérent (<%s> %d: <%s> %d"
-#~ msgid "Title, in quotes"
-#~ msgstr "Titre, entre guillemets"
-#, fuzzy
-#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
-#, fuzzy
-#~ msgid "Computing means for band %d..."
-#~ msgstr "La copie de table a échoué"
-#, fuzzy
-#~ msgid "Computing row %d (of %d) of covariance matrix..."
-#~ msgstr "Calcul de la matrice de covariance de classe"
-#, fuzzy
-#~ msgid "Unable to allocate memory for row buffer"
-#, fuzzy
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "Impossible d'allouer de la mémoire"
-#, fuzzy
-#~ msgid "Transforming <%s>..."
-#~ msgstr "Rotation des données ... "
-#~ msgid "Current window size:"
-#~ msgstr "Taille de la fenêtre courante:"
-# c-format
-#~ msgid "rows: %d"
-#~ msgstr "lignes: %d"
-#~ msgid "columns: %d"
-#~ msgstr "colonnes: %d"
-#~ msgid "Aborting."
-#~ msgstr "Abandon."
-# c-format
-#, fuzzy
-#~ msgid "Cannot open driver\n"
-#~ msgstr "Impossible d'utiliser le pilote %s"
-#, fuzzy
-#~ msgid "Cannot open database\n"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
-#~ msgid "Requested 3d raster map not found"
-#~ msgstr "Le fichier raster 3D <%s> n'a pas été trouvé"
-#, fuzzy
-#~ msgid "Error closing new ASCII file"
-#~ msgstr "Erreur de fermeture du fichier VTK-ASCII"
-#, fuzzy
-#~ msgid "Error closing new 3d raster map"
-#~ msgstr "Erreur de fermeture du fichier raster 3D"
-#, fuzzy
-#~ msgid "Error closing ascii file"
-#~ msgid "Could not close G3D map"
-#~ msgstr "Impossible de fermer la couche G3D"
-#~ msgid "Use g3d mask (if exists) with input map"
-#~ msgid "Could not write raster row"
-#~ msgstr "Impossible d'écrire la ligne du raster : %s"
-#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "Impossible de fermer la couche G3D <%s>"
-#, fuzzy
-#~ msgid "Unable to close the 3d raster map"
-#~ msgstr "Impossible de fermer la couche source"
-#, fuzzy
-#~ msgid "Requested 3d raster map <%s> not found"
-#~ msgstr ""
-#~ "#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
-#~ "La couche g3d <%s> demandé n'a pas été trouvé\n"
-#~ "Le fichier g3d <%s> demandé n'a pas été trouvé"
-#~ msgid "Requested g3d RGB map <%s> not found"
-#~ msgstr "Le fichier raster g3d RGB <%s> n'a pas été trouvé"
-#~ msgid "Please provide three g3d RGB maps"
-#~ msgstr "Veuillez indiquer trois couches g3d RGB"
-#~ msgid "Requested g3d vector map <%s> not found"
-#~ msgstr "Couche vecteur g3d <%s> introuvable"
-# c-format
-#, fuzzy
-#~ msgid "Open rgb 3d raster map %s"
-#~ msgstr "Ouvrir le fichier raster 3D %s"
-#, fuzzy
-#~ msgid "Error closing g3d rgb map."
-#, fuzzy
-#~ msgid "Error closing g3d vector map."
-#~ msgstr "Erreur de fermeture du fichier vecteur 3D"
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "Convertit une couche raster 3D au format VTK-ASCII"
-#, fuzzy
-#~ msgid "unable to close input 3d raster map"
-#~ msgid "Use g3d mask (if exists) with input maps"
-#~ msgstr ""
-#~ "Utiliser le masque raster 3D (s'il existe) sur les couches de données en "
-#~ "entrée"
-#~ msgid "Could not get top raster row \n"
-#~ msgstr "Ligne de début de fichier raster introuvable\n"
-#~ msgid "Could not get bottom raster row \n"
-#~ msgstr "Ligne de fin de fichier raster introuvable\n"
-#, fuzzy
-#~ msgid ""
-#~ "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-#~ "ascii file"
-#~ msgstr ""
-#~ "writeVTKData : écriture des données de cellules %s de dimensions ligne %i "
-#~ "colonnes %i et profondeur %i au format vtk-ascii"
-#, fuzzy
-#~ msgid "write_vtk_rgb_data: writing rgb data"
-#~ msgstr "writeVTKData: Ecriture de données VTK"
-#, fuzzy
-#~ msgid "Use G3D mask (if exists)"
-#, fuzzy
-#~ msgid "Error opening g3d map <%s>"
-#~ msgstr ""
-#~ "Erreur à l'ouverture de la couche g3d <%s>\n"
-#~ "Erreur à l'ouverture du fichier raster 3D <%s>"
-#, fuzzy
-#~ msgid "Write the result to g3d map <%s>"
-#~ msgstr "Titre de la nouvelle couche raster"
-#, fuzzy
-#~ msgid "Error closing g3d file"
-#, fuzzy
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgid "modifyNull: error opening map"
-#~ msgstr ""
-#~ "modifyNull (modification des valeurs nulles) : erreur d'ouverture de la "
-#~ "couche"
-#~ msgid "modifyNull: error closing map"
-#~ msgstr ""
-#~ "modifyNull (modification des valeurs nulles) : erreur dans la fermeture "
-#~ "de la couche"
-#~ msgid "makeMask: error opening map."
-#~ msgstr "makeMask (définition d'un masque) : erreur d'ouverture de la couche"
-#~ msgid "makeMask: error opening g3d mask file"
-#~ msgstr ""
-#~ "makeMask (définition d'un masque) : erreur d'ouverture du fichier de "
-#~ "masque raster 3D"
-#~ msgid "makeMask: error closing g3d mask file"
-#~ msgstr ""
-#~ "makeMask (définition d'un masque) : erreur de fermeture du fichier de "
-#~ msgid "makeMask: error closing map"
-#~ msgstr ""
-#~ "makeMask (définition d'un masque) : erreur de fermeture de la couche"
-#~ msgid "Error: couldn't create %s"
-#~ msgstr "Erreur : impossible de créer %s"
-#~ msgid "Error while writing grid. Disk full?"
-#~ msgstr ""
-#~ "Erreur au cours de l'écriture de la grille 3D. Espace mémoire insuffisant?"
-#, fuzzy
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "Nom de la couche vecteur de latitudes (degrés décimaux)"
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "Nom de la couche raster existante"
-#, fuzzy
-#~ msgid "Print mapset names"
-#~ msgstr "Afficher le nom du jeu de données"
-#, fuzzy
-#~ msgid "Remove lines and areas smaller than threshold"
-#~ msgstr "Supprimer tous les cadres graphiques et effacer l'écran"
-#, fuzzy
-#~ msgid "Unable to calculate centroid for area %d"
-#, fuzzy
-#~ msgid "Target information for group <%s> missing.\n"
-#~ msgstr ""
-#~ "Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
-#, fuzzy
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "région <%s> non trouvée"
-#, fuzzy
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr ""
-#~ "impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <"
-#~ "%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create file <%s> in mapset <%s>"
-#~ msgstr ""
-#~ "%s>"
-#, fuzzy
-#~ msgid "input"
-#~ msgstr "couche source"
-#, fuzzy
-#~ msgid "input,cell,raster"
-#~ msgstr "couche raster source"
-#, fuzzy
-#~ msgid "output"
-#~ msgstr "couche de sortie"
-#, fuzzy
-#~ msgid "output,cell,raster"
-#~ msgstr "couche raster en sortie"
-#, fuzzy
-#~ msgid "basemap"
-#~ msgstr "couche raster de couverture"
-#, fuzzy
-#~ msgid "method"
-#~ msgstr "Méthode inconnue <%s>"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgstr "La couche raster [%s] existe dans le groupe."
-#, fuzzy
-#~ msgid "into <%s@%s> (location <%s>) ... %s"
-#~ msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
-#, fuzzy
-#~ msgid "Error while writing to temp file"
-#~ msgstr "Erreur à la lecture du fichier de signatures."
-#, fuzzy
-#~ msgid "Error writing row %d"
-#~ msgstr "Erreur d'écriture de la ligne null [%d]"
-#, fuzzy
-#~ msgid "raster, vector, visualization"
-#~ msgstr "Nombre de points d'interpolation"
-#, fuzzy
-#~ msgid "Selects data from table."
-#~ msgstr "Sélectionner les données depuis une base de données."
-#, fuzzy
-#~ msgid "imagery"
-#~ msgstr "groupes d'images"
-#, fuzzy
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr ""
-#~ "La colonne %d définie comme entier ne contient que des valeurs doubles"
-#~ msgid "Reading map"
-#~ msgstr "Lecture de la couche"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr ""
-#~ "Les données sont signées (le bit le plus haut marque le signe négatif)"
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "Nombre de bits par pixel (1,2,4)"
-#, fuzzy
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "Limite Sud de la région géographique (extrémité)"
-#, fuzzy
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "Attention : nom de sous-groupe illégal <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr " Nombre maximum d'itérations: %d\n"
-# c-format
-#, fuzzy
-#~ msgid "Using rows=%d cols=%d\n"
-#~ msgstr "%d lignes, %d colonnes"
-#, fuzzy
-#~ msgid "Conversion failed at row %d"
-#~ msgstr "Echec de la conversion de données à la ligne %d, colonne %d"
-# c-format
-#, fuzzy
-#~ msgid "<%s> created"
-#~ msgid "Raster map to be displayed"
-#~ msgstr "couche raster à afficher"
-#, fuzzy
-#~ msgid "Poorly placed psuedo control points. "
-#~ msgstr "Pas de points de départ"
-#, fuzzy
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "Impossible de trouver les informations sur la couche vectorielle"
-#, fuzzy
-#~ msgid "No active psuedo control points"
-#, fuzzy
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "Impossible d'écrire le fichier temporaire"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open map %s"
-#~ msgstr "impossible d'ouvrir <%s>"
-#, fuzzy
-#~ msgid "Unable to write row %d"
-#, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "Sortie. Ne pas changer les paramètres actuels"
-#, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
-#, fuzzy
-#~ msgid "vector, projection"
-#~ msgstr "Projection source"
-#, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "Aucune couche créée en sortie"
-#, fuzzy
-#~ msgid "Location of input raster map"
-#~ msgstr "Secteur (location) de la couche source"
-#, fuzzy
-#~ msgid "Mapset of input raster map"
-#~ msgstr "Nom de la couche raster source"
-#, fuzzy
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "couche raster en entrée"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "Nom de la couche raster d'altitude"
-#~ msgid "Output raster map having shadows"
-#~ msgstr "couche à créer contenant les ombres"
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B : année (1950..2050)"
-#~ msgid "B: month (0..12)"
-#~ msgstr "B : mois (0..12)"
-#~ msgid "B: day (0..31)"
-#~ msgstr "B : jour (0..31)"
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B : heure (0..24)"
-#, fuzzy
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "coordonnée Est (point d'intérêt, défaut : centre de la couche)"
-#, fuzzy
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "coordonnée Nord (point d'intérêt, défaut : centre de la couche)"
-#~ msgid "Zero is a real elevation"
-#~ msgstr "Zéro est une vraie altitude"
-#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr ""
-#~ " %d.%02d.%02d, numéro de jour %d, heure : %02i:%02i:%02i (heure "
-#~ "décimale : %f)\n"
-#~ msgid " long: %f, lat: %f, timezone: %f\n"
-#~ msgstr " long : %f, lat : %f, fuseau horaire : %f\n"
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ " sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr ""
-#~ " Position du soleil : azimut: %f,\n"
-#~ " angle du soleil au dessus de l'horizon.(réfraction corrigée) : %f\n"
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Lever du soleil (sans réfraction) : %02d:%02d:%02d\n"
-#~ msgid " Sunset time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Coucher du soleil (sans réfraction) : %02d:%02d:%02d\n"
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "Pas de calcul de couche demandé. Terminé.\n"
-#, fuzzy
-#~ msgid "Can't open range file for %s"
-#~ msgstr "impossible d'ouvrir le fichier pour %s"
-#, fuzzy
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "impossible de lire les lignes de la couche d'altitude"
-#~ msgid "Raster map to be recoded"
-#~ msgstr "Couche raster à recoder"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "Génère une couche raster montrant les sous-bassins versants."
-#~ msgid "Coded stream network file name"
-#~ msgstr "Nom du fichier réseau codant les cours d'eau"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "Nom de fichier du réseau d'arêtes amincies"
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "Nom de la couche de délimitation des bassins versants"
-# c-format
-#, fuzzy
-#~ msgid "Starting map [%s]"
-#, fuzzy
-#~ msgid "Percent done:"
-#~ msgstr "Pourcentage complet :"
-#, fuzzy
-#~ msgid ""
-#~ "Displays and overlays raster map layers in the active display frame on "
-#~ "the graphics monitor."
-#~ msgstr "Affiche et superpose les couches rasters dans le moniteur actif"
-#, fuzzy
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#~ msgstr "mi(les), f(pieds), me(tres), k(ilomètres), a(cres), h(ectares)"
-#~ msgid ""
-#~ "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr ""
-#~ "Nombre de colonnes utilisées comme coordonnées x (la première colonne est "
-#~ "1) en mode points"
-#, fuzzy
-#~ msgid "Duplicate area centroids"
-#~ msgstr "Impossible de calculer le centroïde de la surface"
-#, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "Nom du fichier vecteur de sortie"
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Produit des couches raster de pente, aspect, courbures et dérivées "
-#~ "partielles à partir d'une couche raster de valeurs réelles d'altitude. "
-#~ "L'aspect est calculé dans le sens contraire des aiguilles d'une montre à "
-#~ "partir de l'est."
-#~ msgid "Output slope filename"
-#~ msgstr "Fichier sortie pour la pente"
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Nom de fichier de sortie pour la courbure du profil"
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Nom de fichier de sortie pour la courbure tangentielle"
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr ""
-#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx "
-#~ "(gradient E-W)"
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr ""
-#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy "
-#~ "(gradient N-S)"
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr ""
-#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxx"
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr ""
-#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dyy"
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr ""
-#~ "Nom de fichier de sortie pour la dérivée partielle d'ordre deux en dxy"
-# c-format
-#~ msgid "wrong type: %s"
-#~ msgstr "Type erroné: %s"
-# c-format
-#, fuzzy
-#~ msgid "Creating support files..."
-#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "ASPECT [%s] TERMINE"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "PENTE [%s] TERMINEE"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "COURBE DE PROFIL [%s] TERMINEE"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "COURBE TANGENTIELLE [%s] TERMINEE"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "PENTE E-W [%s] TERMINEE"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "PENTE N-S [%s] TERMINEE"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "DXX [%s] TERMINEE"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "DYY [%s] TERMINEE"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "DXY [%s] TERMINEE"
-#~ msgid "unable to open MASK"
-#~ msgstr "impossible d'ouvrir le MASK"
-#, fuzzy
-#~ msgid "Unable to open MASK"
-#, fuzzy
-#~ msgid "Name of input vector points map"
-#~ msgstr "Nom de la couche vecteur 2D source"
-#, fuzzy
-#~ msgid "Name of output vector area map"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vectorielle de centroïdes"
-#, fuzzy
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "La table <%s> n'existe pas dans la base de données <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
-#, fuzzy
-#~ msgid "M.Q. solution"
-#~ msgstr "Résolution"
-#~ msgid "3-d data in dxf file. Polyline_flag: %d"
-#~ msgstr "Données 3-D dans le fichier dxf. Polyline_flag: %d"
-#, fuzzy
-#~ msgid ""
-#~ "Computes direct (beam), diffuse and reflected solar irradiation raster "
-#~ "maps for given day, latitude, surface and atmospheric conditions. Solar "
-#~ "parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-#~ "irradiance, daylight length) are saved in a local text file. "
-#~ "Alternatively, a local time can be specified to compute solar incidence "
-#~ "angle and/or irradiance raster maps. The shadowing effect of the "
-#~ "topography is optionally incorporated."
-#~ msgstr ""
-#~ "Calcule des couches de rayonnement solaire direct (beam), diffus et "
-#~ "réfléchi pour un jour donné, une latitude; des propriétés de surface et "
-#~ "des conditions atmosphériques. Les paramètres solaires (par exemple, le "
-#~ "lever du soleil, le coucher du soleil, la déclinaison, les radiations "
-#~ "extra-terrestres, la durée du jour) sont sauvegardées dans un fichier "
-#~ "texte local. Sinon, une heure locale peut être indiquée pour calculer des "
-#~ "angles d'incidence ou d'irradiance du rayonnement solaire. Les effets "
-#~ "d'ombres portées par la topographie peuvent être pris en compte de façon "
-#~ "optionnelle."
-#, fuzzy
-#~ msgid "incidout requres time parameter to be set"
-#~ msgstr "incidout demande de fixer le paramètre d'heure"
-#, fuzzy
-#~ msgid "Mode 2: integrated daily irradiation"
-#~ msgstr ""
-#~ "Mode 2 : irradiation journalière cumulée pour un jour donné de l'année"
-#, fuzzy
-#~ msgid "Eigen values:"
-#~ msgstr "Valeur de la chaîne de bit"
-#~ msgid "Please choose only one print style"
-#~ msgstr "Veuillez choisir une et un seul style d'affichage"
-#, fuzzy
-#~ msgid "Spline type of interpolation"
-#~ msgstr "La valeur en sortie est l'erreur d'interpolation"
-#, fuzzy
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Couche raster en sortie (par défaut : tuile en entrée)"
-#, fuzzy
-#~ msgid "%d boundaries converted to lines"
-#~ msgstr "%-5d centroïdes écrits dans le fichier de sortie.\n"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Elevation raster map <%s> does not cover the entire area of the input "
-#~ "vector map <%s>. "
-#~ msgstr "Couche vectorielle <%s> en entrée introuvable"
-#~ msgid "Species <%s> not known. I'll use parameters for spruce instead"
-#~ msgstr ""
-#~ "L'essence <%s> est inconnue. J'utilise les paramètres pour les sapins à "
-#~ "la place"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Trace la grille géographique"
-#~ msgid ""
-#~ "\n"
-#~ "SECTION 2: A * Search. Percent complete: "
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION 2: A * Recherche. Achevé (pourcentage): "
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION 2: A * Search. Percent complete:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION 2: A * Recherche. Achevé (pourcentage):"
-#~ msgid " segments in row:\t%d"
-#~ msgstr "\tsegments en ligne:\t%d"
-#~ msgid "segments in columns:\t%d"
-#~ msgstr "segments en colonnes:\t%d"
-#~ msgid " total segments:\t%d"
-#~ msgstr "\ttotal des segments:\t%d"
-#~ msgid " open segments:\t%d"
-#~ msgstr "\touvrir des segments:\t%d"
-#~ msgid ""
-#~ "GRASS module to create a fractal surface of a given fractal dimension. "
-#~ "Uses spectral synthesis method. Can create intermediate layers showing "
-#~ "the build up of different spectral coefficients (see Saupe, pp.106-107 "
-#~ "for an example of this). Use this module to generate naturally looking "
-#~ "synthetical elevation models (DEM)."
-#~ msgstr ""
-#~ "Module GRASS pour créer une surface fractale de dimension fractale "
-#~ "donnée. Utilise la méthode de synthèse spectrale. Peut créer des couches "
-#~ "intermédiaires pour montrer la construction des différents coefficients "
-#~ "spectraux (voir Saupe, pp.106-107 pour un example). Utiliser ce module "
-#~ "pour générer des modèles numériques de terrain artificiels mais à "
-#~ "l'aspect naturel."
-#~ msgid ""
-#~ "Save graphic legend output in tlegend.txt file for d.graph display in GIS "
-#~ "Manager"
-#~ msgstr ""
-#~ "Sauvegarder la sortie graphique de légende dans un fichier tlegend.txt "
-#~ "pour l'affichage de d.graph dans le Gestionnaire SIG"
-#~ msgid "force removal (use only if you know what you are doing)"
-#~ msgstr "Forcer la suppression (à n'utiliser que si vous êtes sûr de vous)"
-#~ msgid "Print all, inclusive range"
-#~ msgstr "Afficher toutes les valeurs sur l'intervalle, bornes incluses"
-#~ msgid "Resolution of raster and raster3d maps should be equal!"
-#~ msgstr ""
-#~ "Attention, la résolution des couches rasters et rasters 3D doit être "
-#~ "identique!"
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "Connexion à la base de données via DBMI."
-#~ msgid "Invoke fast, but memory intensive operation"
-#~ msgstr "Utiliser une méthode rapide, mais gourmande en mémoire"
-#~ msgid ""
-#~ "Output direction type AGNPS, ANSWERS or GRASS aspect\n"
-#~ " default: GRASS"
-#~ msgstr ""
-#~ "Type de direction en sortie : AGNPS, ANSWERS ou GRASS\n"
-#~ " défaut: GRASS"
-#~ msgid "Aspect"
-#~ msgstr "Aspect"
-#~ msgid "Mean curvature"
-#~ msgstr "Courbure moyenne"
-# c-format
-#, fuzzy
-#~ msgid "ERROR: Problem opening output file."
-#~ msgstr "impossible d'ouvrir le fichier en sortie <%s>"
-#~ msgid "Output drain raster map"
-#~ msgstr "couche raster de sortie"
-#, fuzzy
-#~ msgid "Creates explicitly the NULL-value bitmap file."
-#~ msgstr "Créer de façon explicite le fichier bitmap 3D de valeur-NULL"
-#, fuzzy
-#~ msgid ""
-#~ "Creation option to the output format driver. Multiple options may be "
-#~ "listed."
-#~ msgstr ""
-#~ "option de création du pilote de format de sortie. De multiples options "
-#~ "peuvent être disponibles"
-#, fuzzy
-#~ msgid "Name of the sampling locations vector points map"
-#, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "Nom du fichier de sortie"
-#, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "raster <%s> non trouvé"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open file [%s]"
-#, fuzzy
-#~ msgid "Failed to guess file format"
-#~ msgstr "Echec pour définir le format du fichier de sites"
-#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
-#~ msgstr "Lecteur du fichier raster..."
-#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
-#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "Vous ne fabriquez aucun fichier raster ou vecteur en sortie"
-#, fuzzy
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "%s=%s - nom illégal"
-#, fuzzy
-#~ msgid "Unable to read current region parameters"
-#~ msgstr "Impossible de lire les paramètres de la fenêtre courante"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier de cellules pour [%s]\n"
-#~ "Impossible d'ouvrir la couche raster [%s]"
-# c-format
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "Impossible d'ouvrir la base de données <%s> avec le pilote <%s>"
-#~ msgid "No map specified"
-#~ msgstr "Aucune couche de données spécifiée"
-#, fuzzy
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "Impossible d'écrire les fichiers temporaires"
-# c-format
-#, fuzzy
-#~ msgid "%s - color table not found"
-#~ msgstr "%s - couche non trouvée"
-#~ msgid "Can't make random color table for floating point map"
-#~ msgstr ""
-#~ "Impossible de construire une table de couleurs aléatoire pour les couches "
-#~ "en valeurs flottantes"
-#~ msgid "Can't make grey.eq color table for floating point map"
-#~ msgstr ""
-#~ "Impossible de construire une table en valeurs de gris pour les couches en "
-#~ "valeurs flottantes"
-#~ msgid "Can't make logarithmic color table for floating point map"
-#~ msgstr ""
-#~ "Impossible de construire une table de couleurs logarithmique pour les "
-#~ "couches en valeurs flottantes"
-#~ msgid "%s - unknown color request"
-#~ msgstr "%s - couleur demandée inconnue"
-# c-format
-#, fuzzy
-#~ msgid "Can't find %d,%d:%f"
-#~ msgid "Starting points raster map"
-#~ msgstr "couche vecteur des points de départ"
-#~ msgid "Source map is: Integer cell type"
-#~ msgstr "La couche en entrée : cellules de type entier"
-#~ msgid "Source map is: Floating point (float) cell type"
-#~ msgstr "La couche en entrée : cellules de type flottant"
-#~ msgid "Source map is: Floating point (double) cell type"
-#~ msgstr "La couche en entrée : cellules de type double flottant"
-# c-format
-#, fuzzy
-#~ msgid "Reading %s"
-#~ msgstr "Lecture du fichier %s..."
-#~ msgid "can't open raster map [%s] needed for input coordinates"
-#~ msgstr ""
-#~ "Impossible d'ouvrir le fichier raster [%s] nécessaire pour obtenir les "
-#~ "coordonnées en entrée"
-# c-format
-#, fuzzy
-#~ msgid "Writing %s"
-#~ msgstr "Écriture %s..."
-#~ msgid "Error getting input null cells"
-#~ msgstr "Erreur de récupération des cellules null en entrée"
-# c-format
-#, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#~ msgstr "<%s> impossible d'ouvrir le fichier raster"
-#, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#~ msgstr "Impossible d'ouvrir le fichier de signature en sortie"
-#, fuzzy
-#~ msgid "SECTION %d beginning: Closing Maps."
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION %d démarrage: Fermeture des couches."
-#, fuzzy
-#~ msgid "SECTION %d beginning: Watershed determination."
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION %d démarrage: détermination du bassin versant."
-#~ msgid "problem w/ astar algorithm"
-#~ msgstr "problème avec l'algorithme astar"
-#~ msgid "Could not read range file"
-#~ msgstr "Impossible de lire le fichier d'intervalle"
-#, fuzzy
-#~ msgid "Reading data: "
-# c-format
-#, fuzzy
-#~ msgid "Unable to read f_range for map %s"
-#~ msgstr "%s: impossible de lire l'intervalle pour [%s]"
-#, fuzzy
-#~ msgid "Integer data range of %s is empty"
-#~ msgstr "L'intervalle va de %ld à %ld\n"
-#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "Nom de la couche raster qui sera utilisée pour <%s>"
-#, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "%-5d points lus en mémoire\n"
-#, fuzzy
-#~ msgid "%d centroids converted to points"
-#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "%s fichier(s) à supprimer"
-# c-format
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
-#~ msgstr "%d points en dehors de la région courante"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot read field info"
-#~ msgstr "Impossible de lire les informations du champ"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
-#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "Type de colonne non géré"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Impossible de sélectionner des données dans la table"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d records selected from table"
-#~ msgstr "%d enregistrements sélectionnés dans le tableau"
-#, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Aucun enregistrement pour la ligne (cat = %d)"
-#, fuzzy
-#~ msgid "From type"
-#~ msgstr "Type de donnée vectorielle"
-#, fuzzy
-#~ msgid "From layer"
-#~ msgstr "Requêter la couche"
-#, fuzzy
-#~ msgid "To layer"
-#, fuzzy
-#~ msgid "vector, attribute table"
-#~ msgstr "Affiche les attributs des vecteurs"
-#, fuzzy
-#~ msgid "The column must be type integer or string"
-#~ msgstr "La clef primaire doit être un entier"
-#~ msgid "Cannot fetch data"
-#~ msgstr "Impossible de rapatrier les données"
-#, fuzzy
-#~ msgid "Calculating costs from centres..."
-#~ msgstr "Calcul des moyennes de classes..."
-#, fuzzy
-#~ msgid "Feature id(s)"
-#~ msgid "Input vector was not found."
-#~ msgstr "Le vecteur en entrée n'a pas été trouvé."
-#~ msgid "Cannot open dig_cats file."
-#~ msgstr "Impossible d'ouvrir le fichier dig_cats."
-#~ msgid "Cannot insert into table: %s"
-#~ msgstr "Impossible d'insérer dans la table: %s"
-#, fuzzy
-#~ msgid "Arc layer (network)"
-#, fuzzy
-#~ msgid "Node layer (points)"
-#~ msgstr "Nom de la couche utilisée pour la teinte"
-#, fuzzy
-#~ msgid "Reading data from the map..."
-#~ msgstr "Lecture de la couche raster."
-#, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
-#~ msgstr "Lancer une requête sur la couche grâce à l'option 'query'"
-# c-format
-#, fuzzy
-#~ msgid "%d categories read from map"
-#~ msgstr "%d catégories chargées depuis la table"
-# c-format
-#, fuzzy
-#~ msgid "%d update/insert errors"
-#~ msgstr "%d erreurs de mise à jour"
-#~ msgid ""
-#~ "Operator defines required relation between features. A feature is written "
-#~ "to output if the result of operation 'ainput operator binput' is true. An "
-#~ "input feature is considered to be true, if category of given layer is "
-#~ "defined.\n"
-#~ "\t overlap: features partially or completely overlap"
-#~ msgstr ""
-#~ "Opérateur qui définit la relation requise entre objets. Un objet est "
-#~ "écrit dansla couche de sortie si le résultat de l'opération 'ainput "
-#~ "opérateur binput' est vrai. Un objeten entrée est considéré vrai, si la "
-#~ "catégorie de la couche est définie.\n"
-#~ "\t recouvrement : les objets se recouvrent totalement ou partiellement"
-#~ msgid "Processing ainput lines ..."
-#~ msgstr "Traitement des lignes ainput..."
-#~ msgid "Processing ainput areas ..."
-#~ msgstr "Traitement des entités surfaciques ainput..."
-#~ msgid "Writing attributes ..."
-#~ msgstr "Écriture des attributs..."
-# c-format
-#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
-#~ msgstr "Fichier raster inverse en sortie après ifft"
-#~ msgid "%s: %s - Unable to find the real-image map."
-#~ msgstr "%s: %s - impossible de trouver l'image (partie réelle)"
-#~ msgid "%s: %s - Unable to find the imaginary-image."
-#~ msgstr "%s: %s - impossible de trouver l'image (partie imaginaire)"
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "2 valeurs : [%d] lignes [%d] colonnes."
-#~ msgid "Reading the raster maps..."
-#~ msgstr "Lecture des couches raster..."
-#~ msgid "Rotating data arrays..."
-#~ msgstr "Rotation des vecteurs de données..."
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "FFT inverse terminée..."
-#~ msgid "Unable to open output file."
-#~ msgstr "Impossible d'ouvrir le fichier de sortie"
-#~ msgid "Transform successful."
-#~ msgstr "Transformée réussie."
-#, fuzzy
-#~ msgid "Hue map name"
-#~ msgstr "%s - nom illégal"
-#, fuzzy
-#~ msgid "Intensity map name"
-#, fuzzy
-#~ msgid "Saturation map name"
-#, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "Couche en sortie où les points seront écrits"
-#, fuzzy
-#~ msgid "Output map representing the green"
-#, fuzzy
-#~ msgid "Output map representing the blue"
-#~ msgstr "Format de sortie pour la pente"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "Impossible d'accéder à la ligne %d de la couche raster %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot write row to raster map"
-#~ msgstr "Impossible de créer la couche raster %s"
-#, fuzzy
-#~ msgid "Red input raster map"
-#, fuzzy
-#~ msgid "Green input raster map"
-#, fuzzy
-#~ msgid "Blue input raster map"
-#, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "Fichier raster en sortie pour la densité des courants"
-#~ msgid "Class transition statistics."
-#~ msgstr "Statistiques de transition de classe."
-#~ msgid "Transition probabilities: %f %f %f; %f"
-#~ msgstr "Probabilités de transition : %f %f %f; %f"
-#~ msgid "get_img: out of memory."
-#~ msgstr "get_img : mémoire insuffisante."
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#~ msgstr "Le sous-groupe [%s] du groupe [%s] ne contient pas de fichier."
-#~ msgid "Writing [%s] ..."
-#~ msgstr "Écriture [%s]..."
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "Fichier de signatures image"
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Sous-groupe [%s] non trouvé"
-#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "Fichier signature [%s] manquant ou impossible à lire."
-#, fuzzy
-#~ msgid "Calculating eigenvalues and eigenvectors..."
-#~ msgstr "Calcul de la moyenne de classe..."
-# c-format
-#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
-#~ msgid "Calculating class mean ..."
-#~ msgid "Calculating class covariance matrix..."
-#, fuzzy
-#~ msgid "Imagery group"
-#, fuzzy
-#~ msgid "Subgroup containing image files"
-#~ msgstr "sous-groupe contenant les fichiers image"
-#, fuzzy
-#~ msgid "Resultant signature file"
-#~ msgstr "fichier signature résultat"
-#~ msgid "1 class."
-#~ msgstr "1 classe."
-#~ msgid "%d classes."
-#~ msgstr "%d classes."
-#~ msgid ""
-#~ "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
-#~ msgstr ""
-#~ "Impossible de créer le fichier signature [%s] du sous-groupe [%s] dans le "
-#~ "groupe [%s]."
-#, fuzzy
-#~ msgid "Input raster map being fft"
-#~ msgstr "Fichier raster en entrée pour la FFT"
-#, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "%s : %s - nom de fichier illégal pour la partie réelle\n"
-#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "%s : %s - nom de fichier illégale pour la partie imaginaire\n"
-#~ msgid "Initializing data...\n"
-#~ msgstr "Initialisation des données...\n"
-#~ msgid "Reading the raster map..."
-#~ msgid "FFT completed..."
-#~ msgstr "FFT terminée..."
-# c-format
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ "groupe <%s> non trouvé"
-# c-format
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "sous-groupe <%s> non trouvé"
-#~ msgid "Subgroup [%s] doesn't have any files"
-#~ msgstr "Le sous-groupe [%s] ne contient aucun fichier"
-#~ msgid "The subgroup must have at least 2 files to run %s"
-#~ msgstr ""
-#~ "Le sous-groupe doit avoir au moins 2 fichiers pour pouvoir exécuter %s"
-#~ msgid "Unable to proceed"
-#~ msgstr "impossible de poursuivre"
-# c-format
-#, fuzzy
-#~ msgid "Can't open seed signature file <%s>"
-#~ msgstr "impossible d'ouvrir le fichier signature germe <%s>"
-#, fuzzy
-#~ msgid "Can't read signature file <%s>"
-#~ msgstr "Impossible de lire le fichier de signature [%s]."
-#~ msgid "Group of imagery files to be clustered"
-#~ msgstr "Groupe de fichier images à clusteriser"
-#~ msgid "Subgroup name in the above group"
-#~ msgstr "Nom du sous-groupe dans le groupe ci-dessus"
-#, fuzzy
-#~ msgid "File containing initial signatures"
-#~ msgstr "Fichier contenant les signatures initiales"
-#, fuzzy
-#~ msgid "Output file to contain final report"
-#~ msgstr "Nom du fichier en sortie contenant le rapport final"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- valeur illégale de min_size"
-#~ msgid "Can't creat reportfile: "
-#~ msgstr "Impossible de créer le fichier de rapport: "
-#~ msgid "Reading image ... "
-#~ msgstr "Lecture de l'image..."
-# c-format
-#, fuzzy
-#~ msgid "Unable to read head of %s"
-#~ msgstr "Impossible de lire les informations de l'en-tête de fichier [%s]"
-# c-format
-#~ msgid "group=[%s] - not found."
-#~ msgstr "groupe=[%s] non trouvé"
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#~ msgstr "sous-groupe=[%s] (du groupe [%s]) - non trouvé."
-#~ msgid "Can't read signature file [%s]."
-#~ msgid "[%s] has more than 255 signatures."
-#~ msgstr "[%s] a plus de 255 signatures."
-#~ msgid "Unable to create reject layer [%s]."
-#~ msgstr "Impossible de créer la couche de rejet [%s]."
-#~ msgid "Imagery group to be classified"
-#~ msgstr "Groupe d'images sur lequel lancer une classification"
-#~ msgid "Subgroup containing image files to be classified"
-#~ msgstr "Sous-groupe contenant les fichiers images pour la classification"
-#~ msgid "Signatures to use for classification"
-#~ msgstr "Nom de fichier de signatures à utiliser pour la classification"
-#~ msgid "Raster map to hold classification results"
-#~ msgstr ""
-#~ "Nom de fichier raster devant contenir les résultat de la classification"
-#, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#~ msgstr "Impossible de sélectionner des données dans la table attributaire"
-#~ msgid ""
-#~ "Background color, either a standard GRASS color, R:G:B triplet, or \"none"
-#~ msgstr ""
-#~ "Couleur de fond, soit une couleur GRASS standard, soit un triplet R:G:B, "
-#~ "soit aucune \"none\""
-#~ msgid "Vector map to display thematically"
-#~ msgstr "couche vecteur à afficher (thématique)"
-#, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "Type de couche vecteur"
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Couche à utiliser pour l'affichage thématique"
-#~ msgid ""
-#~ "Icon size for point data (minimum icon size/line width for graduated "
-#~ "points/lines)"
-#~ msgstr ""
-#~ "Taille de l'icone pour des données ponctuelles (taille minimale de "
-#~ "l'icone/largeur de ligne pour les points gradués/lignes)"
-#, fuzzy
-#~ msgid ""
-#~ "Color for graduated points map (grass named color or R:G:B triplet). Set "
-#~ "color scheme to single color."
-#~ msgstr ""
-#~ "Couleur pour les lignes graduées ou les contours de points/entités "
-#~ "surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de "
-#~ "couleur pour couleur simple."
-#~ msgid ""
-#~ "Color for graduated lines or point/area outlines (grass named color or R:"
-#~ "G:B triplet). Set color scheme to single color."
-#~ msgstr ""
-#~ msgid "Apply regular expressions and wildcards to g.list"
-#~ msgstr "Appliquer des expressions régulières et des wildcards à g.list"
-#, fuzzy
-#~ msgid "Data type"
-#~ msgstr "Type de données"
-#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "jeu de données à lister (par défaut : chemin de recherche courant)"
-#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Caractère de séparation en sortie (par défaut : nouvelle ligne)"
-#~ msgid "Apply regular expressions and wildcards to g.remove"
-#~ msgstr "Appliquer des expressions régulières et des wildcards à g.remove"
-#, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "Couche raster 3D à supprimer"
-#~ msgid "3d raster to remove"
-#, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "Icone à supprimer"
-#, fuzzy
-#~ msgid "Region to remove"
-#~ msgstr "Région à supprimer"
-#, fuzzy
-#~ msgid "Label to remove"
-#~ msgstr "Etiquette à supprimer"
-#~ msgid "3dview to remove"
-#~ msgstr "3dview à supprimer"
-#, fuzzy
-#~ msgid "Group to remove"
-#~ msgstr "groupe à supprimer"
-#~ msgid "sensor: LANDSAT"
-#~ msgstr "Capteur: LANDSAT"
-#~ msgid "sensor: QuickBird"
-#~ msgstr "Capteur: QuickBird"
-#~ msgid "sensor: SPOT"
-#~ msgstr "Capteur: SPOT"
-#, fuzzy
-#~ msgid "raster input maps"
-#~ msgid "reclass raster output map"
-#~ msgstr "Reclasser la couche raster en sortie"
-#~ msgid "Output field seperator"
-#~ msgstr "Séparateur de champ en sortie"
-#~ msgid "Run verbosly"
-#~ msgstr "Détails de l'exécution"
-#, fuzzy
-#~ msgid "Do not print polyline info"
-#~ msgstr "Ne construit pas de topologie en mode points"
-#, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Couleur de mise en valeur du texte"
-#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "Mémoire insuffisante pour allouer la structure de données."
-# c-format
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "impossible de lire le fichier signature <%s> **"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condition optionnelle (sans le mot-clef WHERE), ex: \n"
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr ""
-#~ "Conserver les numéros de bande plutôt que d'utiliser les noms de couleur "
-#~ "des bandes"
-#~ msgid ""
-#~ "Name and type of the new column(s) (types depend on database backend, but "
-#~ "all support VARCHAR(), INT, DOUBLE and DATE)"
-#~ msgstr ""
-#~ "Nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base "
-#~ "de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE et DATE)"
-#~ msgid "Memory allocation error"
-#~ msgstr "Erreur d'allocation mémoire"
-#~ msgid "Saving new map"
-#~ msgstr "Sauvegarde de la nouvelle couche"
-#~ msgid "Output raster map with lake"
-#~ msgstr "couche raster en sortie contenant le lac"
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "couche raster terrain <%s> non trouvée!"
-# c-format
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "Impossible d'ouvrir la couche raster terrain <%s@%s>!"
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "couche de germes <%s> non trouvée!"
-# c-format
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "Impossible d'ouvrir la couche de germes <%s@%s>!"
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgid "Loading maps: "
-#~ msgstr "Chargement des couches"
-#, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr "Erreur de lecture de la couche raster en entrée"
-# c-format
-#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-#~ msgstr "Erreur de lecture du fichier raster [%s]"
-# c-format
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s@%s>!"
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr ""
-#~ "Commence le remplissage du lac au niveau de %8.4f en %d passages. \n"
-#~ "pourcentage achevé:"
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Erreur d'écriture du fichier couleur pour <%s@%s>!"
-#~ msgid "All done."
-#~ msgstr "Complètement terminé."
-#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "Nom du fichier vecteur contenant les données en entrée"
-#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "Allocation métrique"
-#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Nom de la couche raster d'altitude (mètres)"
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nom du fichier raster source"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "Calcule un <simple> index sur un fichier raster"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Couche raster en entrée"
-#~ msgid "Output file name"
-# c-format
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr ""
-#~ "%s: impossible de lire l'intervalle en nombre à virgule flottante pour "
-#~ "[%s]"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgid "Error reading '%s' map"
-#~ msgstr "Erreur de lecture de la couche '%s'"
-#~ msgid "G_put_raster_row failed (file system full?)"
-#~ msgstr "Echec de G_put_raster_row (système de fichier surchargé?)"
-#, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "Unités de distance"
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Impossible d'exécuter: %s"
-#, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "Impossible d'ouvrir la table <%s>"
-#~ msgid "DXF input file"
-#~ msgstr "Fichier DXF source"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier [%s]"
-#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "%s: impossible d'ouvrir le nouveau fichier vectoriel"
-#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr ""
-#~ "\n"
-#~ "Conversion de %s en couche vectorielle: "
-#~ msgid "Create 3D file"
-#~ msgstr "Crée fichier 3D"
-#~ msgid "imagery group"
-#~ msgid "imagery subgroup"
-#~ msgstr "sous-groupe d'images"
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nom de(s) (la) couche(s) raster(s) en entrée"
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr "Extension du fichier de sortie (Fichiers en entrée + extension)"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- nom du fichier de signature résultat illégal"
-#, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Fichier(s) raster pour la Vue%d"
-#, fuzzy
-#~ msgid "Raster file(s) for Color"
-#~ msgid "Raster map to zoom into"
-#~ msgstr "Couche raster sur laquelle zoomer"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr ""
-#~ "Sauvegarder la région courante dans le fichier de définition de la région"
-#, fuzzy
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "L'option Geo-Grid n'est pas disponible en projection XY"
-#, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s>"
-#, fuzzy
-#~ msgid "No such monitor as '%s'"
-#~ msgstr "[%s] ne correspond pas à une couleur connue"
-#, fuzzy
-#~ msgid "Error - No such monitor as '%s'"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr ""
-#~ "\a\n"
-#~ "** Les fichiers rasters dans le sous-groupe [%s] n'existent pas :"
-#~ msgid " %s"
-#~ msgstr "\t\t%s"
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "Ajouter les fichiers au groupe [%s]"
-#~ msgid "Adding files to subgroup [%s]"
-#~ msgstr "Ajouter les fichiers au sous-groupe [%s]"
-#~ msgid "Skipping [%s]..."
-#~ msgstr "Saut de [%s]..."
-#~ msgid "Writing group REF"
-#~ msgstr "Ecriture du groupe REF"
-#~ msgid "Writing subgroup REF"
-#~ msgstr "Ecriture du sous-groupe REF"
-#~ msgid "Found file <%s@%s> in group."
-#~ msgstr "Fichier <%s@%s> trouvé dans le groupe"
-#~ msgid "Found file <%s@%s> in subgroup."
-#~ msgstr "Fichier <%s@%s> trouvé dans le sous-groupe"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgid "Multiplier"
-#~ msgstr "Multiplicateur"
-#~ msgid ""
-#~ "Projection of input dataset and current location appear to match.\n"
-#~ "Proceeding with import...\n"
-#~ msgstr ""
-#~ "La projection des données en entrée et le Secteur (location) courant "
-#~ "semblent correspondre.\n"
-#~ "Poursuite de la procédure d'importation...\n"
-#~ msgid "Name of the resultant map"
-#~ msgid "%s: percent complete: "
-#~ msgstr "%s : pourcentage effectué :"
-# c-format
-#~ msgid "Raster map not found."
-#~ msgstr "couche raster non trouvée"
-# c-format
-#~ msgid "%s: can't read range for [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Raster file [%s] not found"
-#~ msgstr "Fichier raster <%s> non trouvé"
-# c-format
-#, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#~ msgstr "impossible de créer %s"
-#, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
-#, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#~ msgstr "Impossible de créer la table : %s"
-# c-format
-#, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Impossible de lire <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
-#, fuzzy
-#~ msgid "Unable to write line %d"
-# c-format
-#, fuzzy
-#~ msgid "Unable to delete line %d"
-#~ msgstr "Impossible d'effacer le fichier %s\n"
-#, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Type inconnu"
-#, fuzzy
-#~ msgid ""
-#~ "If 'list', 'file' and 'where' options are not specified, all features of "
-#~ "given type and layer are extracted. Categories are not changed in that "
-#~ "case."
-#~ msgstr ""
-#~ "Sélectionne les objets vectoriels d'une couche vectorielle existante et "
-#~ "crée une nouvelle couche contenant seulement les objets sélectionnés. Si "
-#~ "les options 'list', 'file' et 'where' ne sont pas spécifiées, tous les "
-#~ "objets d'un type et d'une couche données sont extraits,dans ce cas, les "
-#~ "catégories sont inchangées."
-#, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "Pas de connexion de la couche à la base de données"
-#, fuzzy
-#~ msgid "Load categories from the database (table = %s, db = %s)."
-#~ msgstr ""
-#~ "Charger les catégories à partir de la base de données (table = %s, db = "
-#~ "%s).\n"
-# c-format
-#, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "%d catégories chargées depuis la base de données\n"
-#~ msgid "Done"
-#~ msgstr "Terminé"
-# c-format
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "Impossible d'ouvrir la source de données OGR %s"
-#~ msgid "Cannot create layer"
-#~ msgstr "Impossible de créer la couche"
-#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Le fichier vecteur [%s] n'est pas disponible"
-#, fuzzy
-#~ msgid ""
-#~ "Load values from vector to database. For uploaded/printed category values "
-#~ "'-1' is used for 'no category' and 'null'/'-' if category cannot be found "
-#~ "or multiple categories were found."
-#~ msgstr ""
-#~ "Charge les valeurs de vecteurs dans la base de données. Parmi les valeurs "
-#~ "de catégories chargées/affichées '-1est utilisé pour 'pas de catégorie' "
-#~ "et 'null'/'-' si la catégorie n'a pas été trouvée ouque de multiples "
-#~ "catégories ont été trouvées."
-#, fuzzy
-#~ msgid "Column(s)"
-#~ msgstr "colonne(s)"
-#, fuzzy
-#~ msgid "Column type [%d] not supported"
-# c-format
-#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr "Impossible de trouver l'en-tête de fichier %s"
-#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "Editer le fichier de catégorie de [%s]?"
-#~ msgid "Print;Shell Script"
-#~ msgstr "Afficher;Shell Script"
-#~ msgid "Creating support files for [%s]."
-#~ msgstr "Créer des fichiers supports pour [%s]."
-# c-format
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr "%s : fichier de cellules <%s> non trouvé"
-#~ msgid "%s: <%s> raster map exists already"
-#~ msgstr "%s : <%s> le fichier raster existe déjà"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-# c-format
-#~ msgid "%s - map not found"
-# c-format
-#~ msgid "%s not found"
-#~ msgstr "%s non trouvé"
-#~ msgid "Could not access %s layer"
-#~ msgstr "Impossible d'accéder à la couche %s"
-# c-format
-#~ msgid "Vector map %s - not found"
-#~ msgstr "Couche vecteur %s introuvable"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "couche raster contenant les données d'altitude"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "couche raster où écrire les résultats"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Altitude du point d'observation"
-# c-format
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "%s: fichier de cellules <%s> non trouvé"
-# c-format
-#~ msgid "Cell file [%s] not found\n"
-#~ msgstr "Fichier de cellules [%s] non trouvé\n"
-# c-format
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "fichier de cellules 3dview <%s> non trouvé\n"
-# c-format
-#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
-# c-format
-#, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgid "raster map <%s> not found"
-#~ msgstr "couche raster <%s> non trouvée"
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "impossible de trouver les en-tête pour <%s> dans <%s>"
-#~ msgid "region <%s> not found"
-#~ msgid "can't read region <%s> in <%s>"
-#~ msgstr "impossible de lire la région <%s> dans <%s>"
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgstr "impossible d'ouvrir le fichier 3dview <%s> dans <%s>"
-#~ msgid "can't read 3dview file <%s> in <%s>"
-#~ msgstr "impossible de lire le fichier 3dview <%s> dans <%s>"
-#~ msgid "can't open vector map <%s> in <%s>"
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
-#~ msgid "invalid region: %s"
-#~ msgstr "région incorrecte : %s"
-#, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Creating support files"
-#~ msgid "can't open %s"
-#~ msgstr "Impossible d'ouvrir %s"
-#~ msgid "%s file [%s] not found!"
-#~ msgstr "%s fichier [%s] non trouvé!"
-# c-format
-#, fuzzy
-#~ msgid "%s: %s - map not found"
-#~ msgstr "%s: %s - non trouvé"
-#, fuzzy
-#~ msgid "%s: unable to open %s"
-# c-format
-#~ msgid "%s - not found"
-# c-format
-#~ msgid "Cannot read %s"
-#~ msgstr "Impossible de lire %s"
-# c-format
-#~ msgid "Reading %s ... "
-#~ msgstr "Lecture de %s..."
-#~ msgid "map layer [%s] not legal for GRASS"
-#~ msgstr "la couche [%s] n'est pas légal pour GRASS"
-# c-format
-#~ msgid "[%s] map not found."
-#~ msgstr "[%s] couche non trouvée"
-# c-format
-#~ msgid "[%s] map not found"
-# c-format
-#~ msgid "elevation file [%s] not found"
-#~ msgstr "fichier d'altitude [%s] non trouvé"
-#~ msgid "min computed aspect %.4f max computed aspect %.4f"
-#~ msgstr "aspect minimum calculé %.4f aspect maximum calculé %.4f"
-#~ msgid "min computed slope %.4f max computed slope %.4f"
-#~ msgstr "pente minimum calculée %.4f pente maximum calculée %.4f"
-# c-format
-#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Impossible de décrire la table %s"
-#, fuzzy
-#~ msgid "Cannot insert values: %s"
-#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s donne un nombre illégal de sites [%d]"
-#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "Pas de paramètres définis pour la connexion à la base de données. Faites-"
-#~ "le avec db.connect"
-# c-format
-#~ msgid "Could not find input %s"
-#~ msgstr "Impossible de trouver l'entrée %s"
-#~ msgid "Could not open input"
-#~ msgstr "Impossible d'ouvrir l'entrée %s"
-#~ msgid "Could not open output"
-#~ msgstr "Impossible d'ouvrir la sortie"
-# c-format
-#~ msgid "Could not find input map <%s>"
-#~ msgstr "couche d'entrée introuvable <%s>"
-#~ msgid "Unkown item type in pad: %s"
-#~ msgstr "Type d'objet inconnu: %s"
-#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "impossible de trouver les en-tête de raster 3D <%s> dans <%s>"
-# c-format
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s ligne %s: %s"
-# c-format
-#, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "impossible d'écrire la région <%s>"
-# c-format
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** valeur entrée invalide **"
-#~ msgid "No graphics device selected."
-#~ msgstr "Aucune sortie graphique n'est sélectionnée"
-#~ msgid "Unable to read raster row."
-#~ msgstr "Impossible de lire la ligne raster."
-#~ msgid "Training map [%s] not found."
-#~ msgstr "couche d'apprentissage raster [%s] non trouvée"
-# c-format
-#~ msgid "%s map not found"
-#~ msgstr "%s couche non trouvée"
-# c-format
-#~ msgid "cannot read head of %s"
-#, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "nom de fichier illégal [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "Condition for update (everything after the 'where' sql statement; ex: "
-#~ "cat=1 or col1/col2>1)"
-#~ msgstr ""
-#~ "conditionnelle pour la mise à jour (tout ce qui se trouve après la clause "
-#~ "'where'; ex : cat=1 ou col1/col2>1)"
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr ""
-#~ "Impossible de récupérer les informations de la couche pour cette couche "
-#~ "vectorielle"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr ""
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr ""
-#~ "valeurs de couverture extraites des étiquettes de catégorie de la couche "
-#~ "de couverture"
-# c-format
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "%s : %s - couche raster non trouvée"
-#~ msgid "%s: %s - illegal name"
-#~ msgstr "%s: %s - nom illégal"
-#~ msgid "%s: ERROR reading category file for %s"
-#~ msgstr "%s: ERREUR de lecture du fichier de catégorie pour %s"
-# c-format
-#~ msgid "%s: %s - not found"
-#~ msgid "%s: %s - illegal units"
-#~ msgstr "%s: %s - unités illégales"
-# c-format
-#, fuzzy
-#~ msgid "%s: %s - can't open"
-#, fuzzy
-#~ msgid "Reading input map (%s) ... "
-#, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#~ msgstr "%s: ERREUR d'exécution de la commande %s"
-#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#~ msgstr "%s: %s dans %s - impossible de lire le fichier de catégorie"
-# c-format
-#, fuzzy
-#~ msgid "Writing output map (%s) ... "
-#~ msgstr "Ecriture de la couche raster en sortie %s..."
-#, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
-#, fuzzy
-#~ msgid "%s - ERROR writing %s"
-#~ msgid "Reading raster map... "
-# c-format
-#, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr ""
-#~ "\n"
-#~ "Écriture du nouveau fichier raster..."
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Liste de catégories. Exemple : 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
-#~ msgstr "Caractère de séparation en sortie (par défaut : tabulation)"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-# c-format
-#~ msgid "Cannot create raster map %s"
-# c-format
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "Impossible de créer la couche vecteur %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
-#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Nombre de lignes à garder en mémoire"
-#, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Écrire uniquement le type de couche"
-#, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Type inconnu: %c"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open raster map [%s]"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "Impossible d'ouvrir la couche raster"
-#, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#~ msgstr ""
-#~ "Impossible de calculer le centroïde de la surface (problème d'allocation "
-#~ "mémoire)"
-#, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "Impossible de lire la couche raster"
-#, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "Impossible de créer l'arborescence"
-#, fuzzy
-#~ msgid "Couldn't set geo transform."
-#, fuzzy
-#~ msgid "Couldn't set projection."
-# c-format
-#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
-#~ msgstr "Impossible d'ouvrir le fichier raster [%s]!"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
-# c-format
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier %s"
-#, fuzzy
-#~ msgid "Reading raster map"
-#~ msgid "Cannot open output map."
-#~ msgstr "Impossible d'ouvrir la couche de sortie"
-#, fuzzy
-#~ msgid "Illegal file name. Please try another."
-#~ msgstr "Nom du fichier de sortie illégal"
-#, fuzzy
-#~ msgid "%s: can't open %s"
-#, fuzzy
-#~ msgid "Reading raster map <%s> ..."
-#, fuzzy
-#~ msgid "memory allocation failure"
-#~ msgid "Can't find data map."
-#~ msgstr "Impossible de trouver la couche de données."
-#~ msgid "Can't find clump map."
-#~ msgstr "Impossible de trouver la couche de 'flaques'"
-#, fuzzy
-#~ msgid "Output terrain only vector map name"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#, fuzzy
-#~ msgid "Rebuilding topology ..."
-# c-format
-#~ msgid "No record for cat = %d"
-#, fuzzy
-#~ msgid "Removing duplicates ..."
-#~ msgstr "Suppression des centroïdes en doublons..."
-#, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "Rattachement des catégories...\n"
-#, fuzzy
-#~ msgid "Attaching centroids ..."
-#, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgstr "couche vecteur <%s> introuvable"
-#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Le nombre minimum de couches spécifiées en entrée est de deux."
-#~ msgid "Attribute column(s)"
-#~ msgstr "Colonne(s) attributaire(s)"
-#, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "Impossible de lire les informations de liaison à la base de données"
-# c-format
-#~ msgid "cell file [%s] not found"
-#~ msgstr "fichier de cellules 3dview <%s> non trouvé"
-# c-format
-#~ msgid "can't open raster map [%s]"
-#~ msgstr "impossible d'ouvrir le fichier de cellule [%s]"
-#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Impossible de créer l'index"
-#, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Existant"
-#, fuzzy
-#~ msgid "For tool 'add', see also 'thresh' parameter"
-#~ msgstr "Ne pas copier la table (voir aussi le paramètre 'new')"
-# c-format
-#, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgid "No layer database connection."
-# c-format
-#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%-5d lignes mortes sautées\n"
-# c-format
-#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
-#~ msgid "Print vector map region only"
-#~ msgstr "Afficher seulement la région de la couche vecteur"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
-#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr ""
-#~ "vectorielle"
-#~ msgid "Cannot select attribute."
-#, fuzzy
-#~ msgid "Creating vector grid..."
-#~ msgstr "Écriture du nouveau fichier cats..."
-# c-format
-#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "Fichier vecteur introuvable : %s"
-# c-format
-#, fuzzy
-#~ msgid "Could not find input map <%s>."
-# c-format
-#, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "%d points écrits dans la couche vecteur"
-#, fuzzy
-#~ msgid "Parameter <%s> not set"
-#, fuzzy
-#~ msgid "Input map containing lines"
-#~ msgstr "Couche en entrée contenant les lignes"
-#, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgid "Cannot get layer information for vector map"
-# c-format
-#~ msgid "<%s> cellfile not found"
-#~ msgstr "fichier de cellules <%s> non trouvé"
-# c-format
-#, fuzzy
-#~ msgid "Not able to open vector map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vecteur [%s]"
-#~ msgid "No table."
-#~ msgstr "Pas de table."
-#~ msgid "Can't read raster"
-#~ msgid "driver name"
-#~ msgstr "nom du pilote (driver)"
-#~ msgid "database name"
-#~ msgstr "nom de la base de donnée"
-#~ msgid "Driver name"
-#~ msgstr "Nom du pilote (driver)"
-#~ msgid "Cannot list databases."
-#~ msgstr "Impossible de lister les bases de données."
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nom de table, tout sélectionner dans cette table"
-#~ msgid "output field separator"
-#~ msgstr "caractère de séparation de champs en sortie"
-#~ msgid "output vertical record separator"
-#~ msgstr "caractère de séparation vertical d'enregistrements en sortie"
-#~ msgid "null value indicator"
-#~ msgstr "indicateur de valeur vide ('null')"
-#~ msgid "do not include column names in output"
-#~ msgstr "ne pas inclure de nom de colonnes en sortie"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "sortie verticale (à la place d'horizontale)"
-# c-format
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "Impossible de trouver le jeu de données (mapset) de %s"
-# c-format
-#~ msgid "Cannot open File %s"
-# c-format
-#~ msgid "Not able to open file for [%s]"
-#~ msgid "Label file [%s] not available"
-#~ msgstr "Fichier d'étiquette [%s] non disponible"
-# c-format
-#~ msgid "Can't open label file [%s]"
-#~ msgstr "impossible d'ouvrir le fichier d'étiquettes pour %s"
-#, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
-#, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
-#~ msgid "Unable to open raster map [%s] in [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
-# c-format
-#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#~ msgstr "Impossible de créer la couche raster [%s]"
-# c-format
-#~ msgid "Unable to create output <%s>"
-#~ msgstr "impossible de créer la sortie <%s>"
-# c-format
-#~ msgid "Input file [%s] not found."
-#~ msgstr "Le fichier en entrée [%s] n'a pas été trouvé."
-# c-format
-#~ msgid "Unable to open output file <%s>."
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "Multiplicateur pour les données ASCII"
-# c-format
-#, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Could not open input file [%s]"
-# c-format
-#, fuzzy
-#~ msgid "unable to create raster"
-#~ msgstr "impossible de créer raster\n"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
-#~ msgstr "Impossible de créer la couche raster <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open file for <%s>"
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "Nom du relief aléatoire à produire"
-# c-format
-#, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-# c-format
-#, fuzzy
-#~ msgid "%s: Unable to open output raster map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr "Pas de connexion définie pour le pilote <%s>. Exécutez db.connect"
-#~ msgid "Table name"
-#~ msgstr "Nom de la table"
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat: layer[/layer name] table key database driver"
-#~ msgstr ""
-#~ "Affiche les paramètres de connexion courants et quitte (style script "
-#~ "shell)\n"
-#~ "\tformat: couche[/nom de la couche] Table Clef primaire Base de données "
-#~ "PilotePilote"
-#~ msgid "x column name"
-#~ msgstr "Nom de la colonne x"
-#~ msgid "z column name"
-#~ msgstr "Nom de la colonne z"
-#, fuzzy
-#~ msgid "Cannot drop table: %s"
-#, fuzzy
-#~ msgid "Cannot open labels <%s>"
-#, fuzzy
-#~ msgid "Cannot fetch data from table"
-# c-format
-#~ msgid "Cannot open file [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "OGR output datasource name. For example:\n"
-#~ "\t\tESRI Shapefile: filename or directory for storage\n"
-#~ "\t\tMapInfo File: filename or directory for storage"
-#~ msgstr ""
-#~ "nom de la source de données OGR. Exemples\n"
-#~ "\t\t Shapefile ESRI : répertoire contenant des shapefiles\n"
-#~ "\t\tFichier MapInfo : répertoire contenant des fichiers mapinfo"
-# c-format
-#, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-# c-format
-#, fuzzy
-#~ msgid "Querying input '%s' ... "
-#, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "Vérification des points vecteurs..."
-#, fuzzy
-#~ msgid "Cannot create table <%s>"
-# c-format
-#~ msgid "no record for cat = %d"
-#~ msgstr "Aucun enregistrement pour cat = %d"
-#~ msgid "cannot insert row: %s"
-#~ msgstr "Impossible d'insérer une nouvelle ligne : %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "couche vectorielle d'entrée introuvable [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
-# c-format
-#, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
-#~ msgstr ""
-#~ "La connexion à la base de données n'a pas été définie pour la couche <"
-#~ "%d>. Utilisez d'abord v.db.connect."
-#, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr ""
-#~ "Transforme une couche vectorielle d'un système de coordonnées vers un "
-#~ "autre système de coordonnées."
-#, fuzzy
-#~ msgid ""
-#~ "ASCII file holding transform coordinates (if not given transformation "
-#~ "options [xshift, yshift, zshift, xscale, yscale, zscale, zrot] will be "
-#~ "used instead)"
-#~ msgstr ""
-#~ "A la place des points, utilisez les options de transformation (xshift, "
-#~ "yshift, zshift, xscale, yscale, zscale, zrot)"
-#, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "Les coordonnées XY du/des foyer(s) initial(aux)"
-#, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "Impossible de lancer le pilote '%s'."
-# c-format
-#~ msgid "Cannot start driver <%s>."
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "[%s] n'est pas un nom légal"
-# c-format
-#~ msgid "Could not open <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgid "Not able to find cellfile [%s]"
-# c-format
-#~ msgid "Raster map [%s] not available"
-#~ msgstr "La couche raster [%s] n'est pas disponible"
-# c-format
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "Fichier(s) raster [%s] non disponible"
-# c-format
-#~ msgid "Raster map [%s] not found"
-#~ msgstr "Couche raster [%s] non trouvée"
-# c-format
-#~ msgid "Unable to open raster map [%s]"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s]"
-#~ msgid "Vector file [%s] not available"
-#, fuzzy
-#~ msgid "<%s> illegal name"
-#~ msgstr "%s: <%s> nom illégal"
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Mémoire insuffisante!\n"
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "%s: %s - impossible d'ouvrir la couche raster en entrée\n"
-#~ msgid "Insufficent memory for allocation of data sturcture"
-#~ msgstr "Mémoire insuffisante pour l'allocation de la structure de données"
-#~ msgid "%s: %s - illegal name for output raster map."
-#~ msgstr "%s: %s - nom illégal de la couche raster en sortie"
-#~ msgid "Insufficent memory for allocation of data structure."
-#, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "Exporte un raster GRASS en différents formats (requiert GDAL)"
-#~ msgid "Couldn't find raster map %s"
-#~ msgstr "Fichier raster introuvable : %s"
-# c-format
-#~ msgid "%s: <%s> not found"
-#~ msgstr "%s: <%s> non trouvé"
-#~ msgid "%s: <%s> illegal name"
-# c-format
-#~ msgid "%s: Cannot open <%s>"
-#~ msgstr "%s: Impossible d'ouvrir <%s>"
-#~ msgid "CREATING SUPPORT FILES ..."
-#~ msgstr "CREATION DE FICHIERS DE SUPPORT..."
-#~ msgid "Error reading map %s"
-#~ msgstr "Erreur de lecture de la couche %s"
-#~ msgid "<%s> is not a valid GRASS map name"
-#~ msgstr "<%s> n'est pas un nom valide pour une couche GRASS"
-# c-format
-#~ msgid "Cannot find %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
-#~ msgid "could not read range file"
-#~ msgid "OUT OF MEMORY !!!\n"
-#~ msgstr "MEMOIRE INSUFFISANTE !!!\n"
-# c-format
-#~ msgid "Unable to create raster map [%s]."
-#, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#~ msgstr "Ouvrir le fichier raster 3D %s"
-#, fuzzy
-#~ msgid "Closing raster map"
-#~ msgstr "couche raster de couverture"
-# c-format
-#, fuzzy
-#~ msgid "Swap temp files"
-#~ msgstr "Impossible d'ouvrir le fichier temporaire %s"
-# c-format
-#, fuzzy
-#~ msgid "Writing [%s]"
-#, fuzzy
-#~ msgid "%s: illegal map name"
-#, fuzzy
-#~ msgid "%s: <%s> illegal file name"
-# c-format
-#, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr ""
-#~ "impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <"
-#~ "%s>"
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the CURRENTLY DEFINED REGION."
-#~ msgstr ""
-#~ "Convertit une couche Raster GRASS en un fichier d'image PPM où la "
-#~ "résolution est celle de la région actuelle."
-#~ msgid "Mapset of input map"
-#~ msgstr "Jeu de données (mapset) de la couche source"
-#, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#~ msgstr "couche raster en entrée"
-#, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#~ msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
-#, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "Couche résultat en sortie"
-#, fuzzy
-#~ msgid "<%s> is illegal file name"
-#, fuzzy
-#~ msgid "[%s] is an illegal file name"
-#, fuzzy
-#~ msgid "no rules specified"
-# c-format
-#~ msgid "Can't open temp file [%s]"
-#~ msgstr "impossible d'ouvrir le fichier temporaire %s"
-#~ msgid "Names of existing raster maps"
-#~ msgstr "Noms de fichiers raster existants"
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir la couche en entrée <%s> dans le jeu de données <%s>"
-#, fuzzy
-#~ msgid "%s - illegal name "
-#, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
-# c-format
-#, fuzzy
-#~ msgid "%s in %s -can't open raster map"
-#~ msgstr "%s - impossible d'ouvrir le fichier raster"
-# c-format
-#, fuzzy
-#~ msgid "%s - can't create raster map"
-#~ msgstr "%s - impossible d'ouvrir le fichier raster cellhd"
-#~ msgid "%s=%s - illegal name"
-# c-format
-#~ msgid "%s: can't create %s"
-#~ msgstr "%s : Impossible de créer %s"
-#~ msgid "Normalized"
-#~ msgstr "Normalisé"
-# c-format
-#, fuzzy
-#~ msgid "Cell file [%s] not found"
-#~ msgid "Can't read current window parameters"
-#~ msgid "Error getting input null cells at row %d from %s"
-#~ msgstr ""
-#~ "Erreur de récupération des cellules nulles en entrée à la ligne %d de %s"
-#~ msgid "[%s] file name not legal"
-#~ msgid "[%s] file name not legal\n"
-#~ msgstr "[%s] n'est pas un nom légal\n"
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "Le fichier raster G3D <%s> demandé n'a pas été trouvé"
-#, fuzzy
-#~ msgid "Could not open output map"
-#~ msgstr "Impossible d'ouvrir la couche en sortie\n"
-#~ msgid "unable to close output map"
-#~ msgstr "Impossible de fermer la couche de sortie"
-#, fuzzy
-#~ msgid "Could not close the 3d raster map"
-#~ msgstr "Impossible de fermer la nouvelle couche g3d"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create output map [%s]"
-#~ msgstr "Impossible de créer la couche cible : [%s]"
-#, fuzzy
-#~ msgid "Database's name couldn't be read"
-#~ msgstr "La connexion à la base de données n'a pas été définie"
-#, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
-#~ msgid "Vector file [%s] not available in search list"
-#~ msgstr ""
-#~ "Le fichier vecteur [%s] n'est pas disponible dans la liste de recherche"
-#~ msgid "Cannot open database <%s>"
-#~ msgstr "Impossible d'ouvrir la base de données <%s>"
-#~ msgid "Cannot open table <%s>"
-#~ msgid ""
-#~ "OGR layer name. If not given, all available layers are imported. "
-#~ "Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "nom de la couche OGR. Si elle n'est pas spécifiée, toutes les couches "
-#~ "disponibles sont importées. Exemples:\n"
-#~ "\t\tShapefile ESRI : nom du shapefile\n"
-#~ "\t\tFichier MapInfo : nom du fichier mapinfo"
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "Le vecteur '%s' existe déjà."
-# c-format
-#~ msgid "Could not find input map '%s'."
-#~ msgstr "couche d'entrée '%s' introuvable "
-# c-format
-#~ msgid "Could not find network input map '%s'."
-#~ msgstr "couche réseau d'entrée '%s' introuvable "
-# c-format
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Erreur d'ouverture de la couche raster [%s]."
-#, fuzzy
-#~ msgid "Topology is not available"
-#~ msgstr "La couche '%s' n'est pas disponible"
-# c-format
-#~ msgid "Cannot describe table %s"
-#, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "\tFichier du collage (patch) %s"
-# c-format
-#, fuzzy
-#~ msgid "[%d] files patched"
-#, fuzzy
-#~ msgid "Column type not supported"
-#~ msgid "Could not open vector map <%s>"
-#, fuzzy
-#~ msgid "Name of output raster map"
-#~ msgstr ""
-#~ "#-#-#-#-# grassmods_fr.po (grassmods_fr) #-#-#-#-#\n"
-#~ "Nom de la couche raster cible\n"
-#~ "Nom de la couche raster de sortie"
-#~ msgid "Done "
-#~ msgstr "Terminé\t\t"
-# c-format
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Pass [%d] of [%d]:"
-#~ msgstr "classe %d (%d)\n"
-#~ msgid "Illegal output name: '%s'"
-#~ msgstr "Nom en sortie illégale : '%s'"
-#~ msgid "Can't create output map"
-#~ msgstr "Impossible de créer la couche en sortie"
-#~ msgid "Could not close new 3d raster map"
-#~ msgid "%s: cellfile [%s] not found."
-#~ msgstr "%s: fichier de cellules [%s] non trouvé"
-#~ msgid "Unable to open cellfile [%s]."
-#~ msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#~ msgid "Error reading wildcard."
-#~ msgstr "Erreur de lecture de la wildcard"
-#~ msgid ""
-#~ "Sets the grid color, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Fixe la couleur de la grille, soit une couleur GRASS standard, soit un "
-#~ "triplet R:G:B(séparé par le signe :)"
-#~ msgid ""
-#~ "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr ""
-#~ "Fixe la couleur de la bordure, soit une couleur GRASS standard soit un "
-#~ "triplet R:G:B"
-#~ msgid "Border not yet implemented for LatLong locations: border not drawn."
-#~ msgstr ""
-#~ "La bordure n'est pas encore implémentée dans les Secteurs latitude/"
-#~ "longitude : la bordure n'est pas tracée"
-#~ msgid "Unable to open the temporary file."
-#~ msgstr "Impossible d'ouvrir le fichier temporaire"
-#~ msgid "Unable to open raster map [%s]."
-# c-format
-#~ msgid "Unable to find raster [%s]."
-#~ msgstr "Fichier raster introuvable [%s]"
-#~ msgid "use regular expression instead of wildcard"
-#~ msgstr "utiliser une expression régulière à la place d'une wildcard"
-#~ msgid "name for new raster map"
-#~ msgstr "Nom de la nouvelle couche raster"
-#~ msgid "Output GRASS image file"
-#~ msgstr "Fichier d'image GRASS en sortie"
-#, fuzzy
-#~ msgid "name for new vector map"
-#~ msgstr "Nom du nouveau fichier vecteur binaire"
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr ""
-#~ "Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur "
-#~ "stdout)"
-#~ msgid "Input vector map"
-#~ msgstr "couche vecteur en entrée"
-#~ msgid "%s: ERROR can't open tempfile"
-#~ msgstr "%s: ERREUR impossible d'ouvrir le fichier temporaire"
-# c-format
-#, fuzzy
-#~ msgid "unable to find raster map [%s]"
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"color\" specified - ignoring color"
-#~ msgstr ""
-#~ "L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"rules\" specified - ignoring rules"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"raster\" specified - ignoring raster"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Both options \"color\" AND \"raster\" specified - ignoring raster"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Both options \"color\" AND \"rules\" specified - ignoring rules"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Both options \"raster\" AND \"rules\" specified - ignoring raster"
-#~ msgstr ""
-#~ msgid "<%s> raster map not found"
-#~ msgstr "<%s> fichier raster introuvable"
-# c-format
-#~ msgid "<%s> unable to open raster map"
-# c-format
-#~ msgid "Cannot find vector map [%s]"
-# c-format
-#~ msgid "%s - can't open raster map"
-# c-format
-#~ msgid "Can't get row %d from raster map %s"
-# c-format
-#~ msgid "%s - raster map not found"
-#~ msgstr "%s - couche raster non trouvée"
-#~ msgid "string representing no data cell value"
-#~ msgstr "chaîne représentant les cellules sans données"
-#~ msgid "File name of classification result"
-#~ msgstr "Nom de fichier du résultat de la classification"
-#~ msgid "File name of reference classes"
-#~ msgstr "Nom de fichier des classes de référence"
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "rapport étendu, 132 colonnes (80 par défaut)"
-#~ msgid "quiet"
-#~ msgstr "silencieux"
-#, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#~ msgstr "%s -- Nom du fichier de sortie illégal"
-# c-format
-#~ msgid "%s: <%s> reference map not found"
-#~ msgstr "%s: couche de référence <%s> introuvable"
-#~ msgid "Base raster map"
-#~ msgstr "couche raster de base"
-#~ msgid "Resultant raster map"
-#~ msgstr "couche raster résultante"
-# c-format
-#, fuzzy
-#~ msgid "%s: raster map not found"
-#~ msgid ""
-#~ "Raster map that represents the elevation, used for the 3D information"
-#~ msgstr ""
-#~ "La couche raster qui représente l'altitude, utilisée pour l'information 3D"
-#, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#~ msgstr "Erreur d'ouverture du fichier d'affichage [%s]"
-# c-format
-#, fuzzy
-#~ msgid "Problem opening output file [%s]"
-#, fuzzy
-#~ msgid "can't write category file for <%s>"
-#, fuzzy
-#~ msgid "%s: can't open tempfile"
-# c-format
-#, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgid "Elevation map"
-#~ msgstr "couche d'altitude"
-#~ msgid "Topographic index ln(a/tanB) map"
-#~ msgstr "couche d'indice topographique ln(a/tan(beta))"
-#~ msgid "Output verbosely"
-# c-format
-#~ msgid "Can't open raster map %s"
-#~ msgstr "Impossible d'ouvrir le fichier raster %s"
-#~ msgid "CREATING SUPPORT FILES"
-#~ msgstr "CREATION DE FICHIERS DE SUPPORT"
-#~ msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-#~ msgstr "ALTITUDE pour le jeu de données [%s] dans [%s]"
-# c-format
-#, fuzzy
-#~ msgid "It could not be find input map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "It could not be found input map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgid "Category ranges: e.g. 1,3-8,13"
-#~ msgstr "Intervalle de catégories. Exemple : 1,3-8,13"
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "Écriture des attributs...\n"
-# c-format
-#, fuzzy
-#~ msgid "Could not open ascii file <%s>"
-#, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#~ msgid "List available formats and exit"
-#~ msgstr "Lister les formats disponibles et quitter"
-#, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#, fuzzy
-#~ msgid "SVG output file"
-# c-format
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "Impossible de trouver la couche vecteur %s"
-# c-format
-#~ msgid "Could not find vector map %s"
-# c-format
-#, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "Coordonnées de la carte"
-#~ msgid "Unable to allocate memory."
-#~ msgstr "Impossible d'allouer la mémoire."
-#~ msgid "Input file"
-#~ msgstr "Fichier source"
-#~ msgid "Raster output file"
-#~ msgstr "couche raster de sortie"
-#, fuzzy
-#~ msgid "Pass #%d (of %d) ... "
-# c-format
-#, fuzzy
-#~ msgid "Writing raster map ... "
-#~ msgstr "Couche raster %i créée \n"
-#~ msgid "Keep existing color table"
-#~ msgstr "Garder la table de couleurs existante"
-#~ msgid "List rules"
-#~ msgstr "Lister les règles"
-#, fuzzy
-#~ msgid "Name of the output walkers site file"
-#~ msgid "Verbose mode."
-#~ msgstr "Détails de l'exécution."
-# c-format
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d lignes, %d colonnes"
-#, fuzzy
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule entier.\n"
-#~ "Ecriture..."
-#, fuzzy
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule flottant.\n"
-#~ "Ecriture..."
-#, fuzzy
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule double.\n"
-#~ "Ecriture..."
-#, fuzzy
-#~ msgid "%s in %s - can't read header file"
-# c-format
-#, fuzzy
-#~ msgid "%s - unable to create raster map"
-#, fuzzy
-#~ msgid "%s - unable to create category file"
-#~ msgstr "Impossible d'écrire les fichiers temporaires"
-#~ msgid "verbose mode"
-#, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr ""
-#~ "Nom de la couche de points vecteurs en entrée pour laquelle éditer la "
-#~ "table attributaire"
-#, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr ""
-#~ "Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour "
-#~ "la table attributaire"
-#, fuzzy
-#~ msgid "Path to the input file"
-#~ msgstr "couche raster source"
-#, fuzzy
-#~ msgid "Path to an output file"
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "Nom de la couche raster existante à afficher"
-#~ msgid "driver name:"
-#~ msgstr "nom du pilote :"
-#~ msgid "Database name:"
-#~ msgstr "Nom de la base de donnée :"
-#, fuzzy
-#~ msgid ""
-#~ "ASCII file to be converted to binary vector map, if not given (or \"-\") "
-#~ "reads from standard input"
-#~ msgstr ""
-#~ "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est "
-#~ "indiqué prendreles paramètres saisis en ligne de commande"
-# c-format
-#~ msgid "could not find input map <%s>"
-# c-format
-#~ msgid "unable to open raster map [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier de cellules [%s]"
-#~ msgid "cannot get layer info for vector map"
-#~ msgstr ""
-#~ "vectorielle"
-#~ msgid "cannot open database %s by driver %s"
-#~ msgid "column type not supported"
-#~ msgid "cannot select data from table"
-#~ msgid "cannot create table: %s"
-#~ msgstr "Impossible de créer la table: %s"
-#~ msgid "cannot create index"
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "Impossible d'accorder des privilèges sur la table: %s"
-#~ msgid "Cannot find vector map"
-#~ msgstr "Impossible de trouver la couche vecteur"
-#~ msgid "Cannot find raster map"
-#~ msgstr "Impossible de trouver la couche raster"
-#~ msgid "Cannot open raster map"
-#~ msgid "Unknown keyword [%s] in vector head."
-#~ msgstr "Mot-clef inconnu [%s] dans l'en-tête de vecteur"
-#~ msgid "#%s"
-#~ msgstr "#%s"
-#, fuzzy
-#~ msgid "Error while reading cell map."
-#, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Erreur de suppression de l'ancienne couche MASK."
-#, fuzzy
-#~ msgid "Error in opening output file <%s>"
-#~ msgstr "impossible d'ouvrir le fichier en sortie <%s>"
-#, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
-#, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgid "Unable to open cell man <%s> for input.\n"
-#~ msgstr "impossible d'ouvrir le fichier de cellule <%s> en entrée.\n"
-#~ msgid "Unable to open cell map <%s> for output.\n"
-#~ msgstr "Impossible d'ouvrir la couche de cellule <%s> en sortie.\n"
-#, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "Impossible de lire la table de couleur %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot find map %s"
-# c-format
-#, fuzzy
-#~ msgid "Cannot open map %s"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Nom du fichier de règles prédéfinies"
-#, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr ""
-#~ "** attention: la(es) valeur(s) R:V:B est(sont) en dehors des limites "
-#~ "[0..255]: %d:%d:%d **\n"
-#, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr ""
-#~ "** attention: la(es) valeur(s) R V B est(sont) en dehors des limites "
-#~ "[0..255]: %d %d %d **\n"
-#, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** attention: aucune valeur **\n"
-#, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:ligne %d:%s\n"
-#, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - couleur inconnue\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "Les couleurs valides sont:\n"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find base map <%s>"
-# c-format
-#, fuzzy
-#~ msgid "Unable to find cover map <%s>"
-#, fuzzy
-#~ msgid "%s: reading category file for %s"
-# c-format
-#, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-# c-format
-#, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-#, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
-# c-format
-#, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
-# c-format
-#, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
-# c-format
-#~ msgid "Unable to find [%s]."
-#~ msgstr "impossible de trouver [%s]"
-#, fuzzy
-#~ msgid "Unable to read cats table for %s"
-# c-format
-#, fuzzy
-#~ msgid "Could not open raster <%s>"
-#~ msgstr "Impossible d'ouvrir la couche %s"
-#~ msgid "%s - too many patch files. only %d allowed"
-#~ msgstr "%s - trop de fichiers patch. Seul(s) %d autorisé(s)"
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr ""
-#~ "Coordonnées de l'écran pour le placement de la légende (exprimées en "
-#~ "pourcentage)"
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "Nom de police (non géré en mode interactif, voir aussi le drapeau -l) ou "
-#~ "chemin vers une police TrueType (nom de fichier inclus)"
-# c-format
-#, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#~ msgstr "fichier de cellules slopein <%s> non trouvé"
-#, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
-# c-format
-#, fuzzy
-#~ msgid "No record for category for [%d]"
-#~ msgstr "Aucun enregistrement pour la ligne (cat = %d)"
-#, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
-#~ msgstr "Erreur de lecture du fichier cats de <%s>"
-#, fuzzy
-#~ msgid "Error reading categories: <%s>"
-#, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr ""
-#~ "couche: %d\n"
-#~ "catégorie: %d\n"
-#, fuzzy
-#~ msgid "No lines found"
-#~ msgstr ""
-#~ "\n"
-#~ "Aucune couche DXF trouvée!\n"
-#, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr "Sélectionner le type: ligne ou surface"
-# c-format
-#, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "Couche d'entrée vecteur introuvable %s"
-#, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#~ msgstr "Nom du fichier vecteur de sortie"
-#~ msgid "Do not create attribute table."
-#~ msgstr "Ne pas créer de table attributaire."
-#~ msgid "Could not find input %s\n"
-#~ msgstr "Entrée introuvable %s\n"
-#, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
-#, fuzzy
-#~ msgid ""
-#~ "List vector maps in input location and exit (a dummy value must be given "
-#~ "for input)"
-#~ msgstr "Lister les couches raster de l'emplacement source et quitter"
-#~ msgid ""
-#~ "Allows the user to interactively query a vector map layer at user-"
-#~ "selected locations within the current geographic region"
-#~ msgstr ""
-#~ "Permet à l'utilisateur de requêter de façon interactive une couche "
-#~ "vectorielle sur des positions choisies par l'utilisateur dans la région "
-#~ "géographique courante"
-#, fuzzy
-#~ msgid "| Tool | Threshold |"
-#~ msgstr " couche courante Nouvelle couche\n"
-#, fuzzy
-#~ msgid "| Break | "
-#~ msgstr ""
-#~ " VÉRIFICATION DES RÉSIDUS DE LA COUCHE\n"
-#~ "\n"
-#, fuzzy
-#~ msgid "| Prune | "
-#~ msgstr ""
-#~ "\n"
-#~ msgid "Patch complete. %d files patched."
-#~ msgstr "Collage achevé. Les fichiers %d sont collés."
-# c-format
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "%s : couche vecteur <%s> introuvable"
-# c-format
-#, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#, fuzzy
-#~ msgid "Raster <%s> could not be open."
-#~ msgstr "raster <%s> non trouvé"
-#, fuzzy
-#~ msgid "CrossCorrelation()"
-#~ msgstr "Corrélation"
-#, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "Méthode d'interpolation à utiliser"
-#, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "Paramétrage de la fenêtre graphique"
-#, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#~ msgstr "Nombre de points d'interpolation"
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-# c-format
-#, fuzzy
-#~ msgid "%s: Dropping <s>"
-#, fuzzy
-#~ msgid "Interpolation was a success!"
-# c-format
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "%d points en dehors de la région courante"
-#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
-#~ msgstr "Impossible de sélectionner des données dans la table"
-#~ msgid "Subgroup [%s] doesn't have any files."
-#~ msgstr "Le sous-groupe [%s] ne comprend aucun fichier"
-#~ msgid "Subgroup [%s] only has 1 file."
-#~ msgstr "Le sous-groupe [%s] ne comprend qu'un seul fichier"
-#~ msgid "%s -- illegal output file name"
-#, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
-#~ msgstr ""
-#~ "\n"
-#~ "Désolé, vous devez choisir une couche en sortie."
-# c-format
-#, fuzzy
-#~ msgid "Writing "
-#~ msgstr "Écriture %s..."
-#~ msgid "%s: %s in %s - can't read category file"
-#, fuzzy
-#~ msgid "Calculation time"
-#~ msgstr "Calcul des moyennes de classes..."
-#, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "Nombre maximum d'itération"
-#~ msgid "Finished.\n"
-#~ msgstr "Terminé.\n"
-# c-format
-#~ msgid "Existing raster map name"
-#~ msgstr "Le nom du fichier raster existe déjà"
-# c-format
-#~ msgid "%s - can't read raster cellhd"
-#~ msgid "error reading cell data"
-#~ msgstr "Erreur de lecture des cellules de données"
-#~ msgid "History line too long: truncating to %d characters"
-#~ msgstr "Ligne d'historique trop longue : tronquée à %d caractères"
-#, fuzzy
-#~ msgid "Done!"
-#, fuzzy
-#~ msgid "No line found."
-#~ msgstr "Rien n'a été trouvé.\n"
-#, fuzzy
-#~ msgid "Nothing Found."
-#, fuzzy
-#~ msgid "Do not build topology."
-#, fuzzy
-#~ msgid "No features found"
-#~ msgstr ""
-#~ "\n"
-# c-format
-#~ msgid "Could not open ascii file [%s]"
-#~ msgid "vector map to be created"
-#~ msgstr "Fichier vecteur à créer"
-#~ msgid "%s: Cannot open dxf file"
-#~ msgstr "%s: impossible d'ouvrir le fichier dxf"
-#, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr ""
-#~ "\n"
-#~ msgid "Finished"
-#~ msgid "Name of output 3d raster map"
-#~ msgstr "Nom du fichier grille G3D en sortie"
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Où %s est un des:\n"
-#~ msgid "%s: - no such database %s\n"
-#~ msgstr "%s: - cette base de données n'existe pas %s\n"
-#~ msgid "must be even number of names"
-#~ msgstr "Les noms doivent être en nombre pair"
-# c-format
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "ERREUR: <%s> non trouvé\n"
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "ERREUR: <%s> - nom illégal\n"
-# c-format
-#~ msgid "Cannot open toolbox: %s"
-#~ msgstr "Impossible d'ouvrir la boîte à outils %s"
-# c-format
-#~ msgid "Cannot open toolbox."
-#~ msgstr "Impossible d'ouvrir la boîte à outils."
-#~ msgid "Could not find input map <%s>\n"
-#~ msgstr "couche d'entrée introuvable <%s>\n"
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "'%s' a terminé la transformation des vecteurs.\n"
-#~ msgid ""
-#~ " CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ msgid " Current Map New Map\n"
-#~ msgid ""
-#~ " POINT X coord Y coord | X coord Y coord | "
-#~ "residuals\n"
-#~ msgstr ""
-#~ " POINT coord X coordY | coord X coord Y | résidus\n"
-#~ msgid " Residual mean average : %f\n"
-#~ msgstr " Moyenne résiduelle : %f\n"
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "Couche(s) vectorielles -- source pour la composite"
-#~ msgid "Append files to existing file"
-#~ msgstr "Modifie les fichier par rapport à un fichier existant"
-#, fuzzy
-#~ msgid "Adding new features to vector file ..."
-# c-format
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "Couche vecteur '%s' introuvable"
-#~ msgid "Input aspect file"
-#~ msgstr "Fichier d'aspect en entrée"
-#~ msgid "Input barrier file"
-#~ msgstr "Fichier source d'obstacles"
-#~ msgid "Quiet operation"
-#~ msgstr "Mode silencieux"
-#~ msgid "Display Reference Information"
-#~ msgstr "Afficher la position de référence"
-#~ msgid ""
-#~ "Aspect file's resolution differs from current "
-#~ "region resolution"
-#~ msgstr ""
-#~ "Résolution de la couche en entrée ne correspond pas à la résolution de la "
-#~ "région courante!"
-#, fuzzy
-#~ msgid ""
-#~ "Calculates Simpson's diversity index on a raster map.\n"
-#~ "Return -1 if all the cells in the area are null"
-#~ msgstr ""
-#~ "Calcule un index de densité de patch sur un fichier raster, en utilisant "
-#~ "un algorithme de voisinage quatre"
-#, fuzzy
-#~ msgid ""
-#~ "Calculates Shannon's diversity index on a raster map\n"
-#~ msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Calculates dominance's diversity index on a raster map\n"
-#~ msgstr ""
-# c-format
-#~ msgid "%s\n"
-#~ msgstr "%s\n"
-#, fuzzy
-#~ msgid ""
-#~ "Calculates dominance's diversity index on a raster map.\n"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "Résolution"
-#, fuzzy
-#~ msgid "input layer name"
-#~ msgstr "Nom de la couche source"
-#, fuzzy
-#~ msgid "output layer name"
-#~ msgstr "Nom de la couche de sortie"
-#~ msgid "Hit RETURN -->"
-#~ msgstr "Tapez ENTREE -->"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist."
-#~ msgstr ""
-#~ "\a\n"
-#~ "** Les fichiers suivants du sous-groupe [%s] n'existent pas."
-#~ msgid "The subgroup must have at least 2 files to run %s."
-#~ msgstr ""
-#~ "Le sous-groupe doit comprendre au moins 2 fichiers pour exécuter %s."
-#~ msgid ""
-#~ "\n"
-#~ "If you continue the mask will be removed."
-#~ msgstr ""
-#~ "\n"
-#~ "Si vous continuez, le masque sera supprimé."
-#~ msgid "Did not find input cell map."
-#~ msgstr "couche de cellules en entrée introuvable."
-#~ msgid "Imagery files subgroup"
-#~ msgstr "Sous-groupe de fichiers image"
-#~ msgid "Warning: illegal group name <%s>."
-#~ msgstr "Attention : nom de groupe illégal <%s>"
-#~ msgid "Warning: illegal output file name <%s>."
-#~ msgstr "Attention : nom de fichier de sortie illégal <%s>"
-#~ msgid "An output cell map name is required."
-#~ msgstr "Un nom de couche de cellule en sortie est requis."
-#~ msgid "The output cell map name can not be longer than 12 characters."
-#~ msgstr ""
-#~ "Le nom de la couche de cellule en sortie ne peut dépasser 12 caractères."
-#~ msgid "L: from M: to R: quit\n"
-#~ msgstr "L: depuis M: vers R: quitter\n"
-#~ msgid "Category <%d>: Area fill color and background color are the same!"
-#~ msgstr ""
-#~ "Catégories <%d>: la couleur de remplissage et la couleur de fond sont "
-#~ "identiques!"
-#~ msgid "Category <%d>: Line color and background color are the same!"
-#~ msgstr ""
-#~ "Catégorie <%d>: la couleur de ligne et la couleur de fond sont identiques!"
-#~ msgid "Line color and background color are the same!"
-#~ msgstr "La couleur des lignes et du fond est identique!"
-#~ msgid "Area fill color and background color are the same!"
-#~ msgstr ""
-#~ "La couleur de remplissage des entités surfaciques et la couleur de fond "
-#~ "sont identiques!"
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "Date&heure, date&heure1/date&heure2, ou aucune"
-# c-format
-#, fuzzy
-#~ msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
-#~ msgstr ""
-#~ "G3dToRaster (Raster 3D en raster) : écrire %i couches rasters de "
-#~ "dimensions lignes %i colonnes"
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Terminé\n"
-#~ msgid "Writing VTK VoxelData\n"
-#~ msgstr "Ecriture des données Voxel VTK\n"
-# c-format
-#, fuzzy
-#~ msgid "Open vector 3d raster map %s"
-# c-format
-#~ msgid "Open 3d raster map %s"
-#~ msgid ""
-#~ "OGR datasource name.\n"
-#~ "\t\tESRI Shapefile: directory containing shapefiles\n"
-#~ "\t\tMapInfo File: directory containing mapinfo files"
-#~ msgstr ""
-#~ "nom de la source de données OGR. \n"
-#~ msgid "Vector import complete"
-#~ msgstr "Importation vecteur complète"
-#, fuzzy
-#~ msgid "Required parameter <points> not set"
-#~ msgstr "signature : points hors du périmètre"
-#, fuzzy
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "Vous devez entrer au moins %d points."
-#, fuzzy
-#~ msgid "ERROR: An area needs at least 3 points"
-#, fuzzy
-#~ msgid "Unknown GIS formats"
-#~ msgstr "Format d'étiquette date&heure inconnu: "
-#, fuzzy
-#~ msgid "file type (ignored)"
-#~ msgstr "type de fichier"
-# c-format
-#, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "Impossible de créer le fichier de cellules pour [%s]"
-#, fuzzy
-#~ msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
-#~ msgstr ""
-#~ "RasterToG3D(Raster vers Raster 3D) : créer %i couches rasters de "
-#~ msgid "Writing g3d slice %i\n"
-#~ msgstr "Ecriture de la tranche raster %i à partir du raster 3D \n"
-#~ msgid "error opening 3d raster map"
-#~ msgstr "Échec à l'ouverture du fichier raster 3D"
-#~ msgid "Done\n"
-#~ msgstr "Terminé\n"
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr ""
-#~ "Lire les couches en nombres à virgule flottante comme étant en nombres "
-#~ "entiers (utilise les règles de quantification de la couche)"
-#~ msgid "Name for the resulting raster map"
-#, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "Ouvrir le fichier raster %s dans le jeu de données (mapset) %s\n"
-#, fuzzy
-#~ msgid ""
-#~ "elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i "
-#~ "and count %i."
-#~ msgstr ""
-# c-format
-#, fuzzy
-#~ msgid "Open 3d raster map %s\n"
-#, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#~ msgstr "Nom de la couche d'altitude résultante"
-# c-format
-#~ msgid "Could not open map %s\n"
-#~ msgstr "Impossible d'ouvrir la couche %s\n"
-#, fuzzy
-#~ msgid "Either -i flag and/or profile parameter must be used."
-#~ msgstr "Il faut utiliser soit le drapeau -i et/ou le paramètre itinéraire"
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "Fichier binaire à importer"
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "Sortie des dérivées partielles "
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La taille de la région est plus petite que minreg, rien n'a été affiché.\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La taille de la région est plus grande que maxreg, rien n'a été affiché.\n"
-#~ msgid "Do not rebuild and store the topology at the end"
-#~ msgstr "Ne pas reconstruire et stocker la topologie à la fin"
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr ""
-#~ "Construit des arbres 3D à partir du fichier source de vecteurs points"
-#~ msgid "Diameter of the tree crown in map units"
-#~ msgstr "Diamètre du feuillage de l'arbre en unités carte"
-#~ msgid "Height of tree trunk in meters"
-#~ msgstr "Hauteur du tronc d'arbre (en mètres)"
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "Nom de la colonne contenant la largeur du feuillage de l'arbre"
-#~ msgid "Representation of spruce in percent"
-#~ msgstr "Représentation des sapins en pourcentage"
-#~ msgid "Representation of fir in percent"
-#~ msgstr "Représentation des pins pignons en pourcentage"
-#~ msgid "Representation of pine in percent"
-#~ msgstr "Représentation des pins en pourcentage"
-#~ msgid "Representation of larch in percent"
-#~ msgstr "Représentation des mélèzes en pourcentage"
-#~ msgid "Representation of beech in percent"
-#~ msgstr "Représentation des hêtres en pourcentage"
-#~ msgid "Representation of oak in percent"
-#~ msgstr "Représentation des chênes en pourcentage"
-#~ msgid "Representation of douglas in percent"
-#~ msgstr "Représentation des pins douglas en pourcentage"
-#~ msgid "Representation of maple in percent"
-#~ msgstr "Représentation des érables en pourcentage"
-#~ msgid "Representation of alder in percent"
-#~ msgstr "Représentation des vernes/aulnes en pourcentage"
-#~ msgid "Vertical variability of tree heights [% of height]"
-#~ msgstr "Variabilité verticale des hauteurs d'arbres [% de hauteur]"
-#~ msgid "Horizontal variability of tree position in map units"
-#~ msgstr "Variabilité horizontale de la position des arbres en unités cartes"
-#~ msgid "Crown length [% of tree height]"
-#~ msgstr "Epaisseur du feuillage [en % de la hauteur de l'arbre]"
-#~ msgid "Total species representation is > 100"
-#~ msgstr "Le total de représentation des essences est > 100"
-#~ msgid "Total species representation is < 100"
-#~ msgstr "Le total de représentation des essences est < 100"
-# c-format
-#, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
-#~ msgstr ""
-#~ "Impossible de sélectionner des attributs pour l'entité surfacique #%d"
-#, fuzzy
-#~ msgid "Display active frame dimensions"
-#~ msgstr "Afficher le rectangle écran"
-#, fuzzy
-#~ msgid "Right: "
-#~ msgstr " Droite: quitter\n"
-#, fuzzy
-#~ msgid "%s Quit\n"
-#~ msgstr "Silencieux"
-#, fuzzy
-#~ msgid "output 3d raster map which will be filled with the 2D raster slices"
-#~ msgstr "Couche(s) raster 3D à convertir en tranches raster 2D"
-#, fuzzy
-#~ msgid "Quiet mode"
-#, fuzzy
-#~ msgid "Raster map(s) to be converted to VTK-ASCII data format"
-#~ msgstr "Couche(s) G3D à convertir au format de données VTK-ASCII"
-#, fuzzy
-#~ msgid ""
-#~ "3 raster maps (r,g,b) which are used to create rgb values [redmap,"
-#~ "greenmap,bluemap]"
-#~ msgstr ""
-#~ "3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB "
-#~ "[redmap,greenmap,bluemap]"
-# c-format
-#, fuzzy
-#~ msgid "Running: %s"
-#~ msgstr "Lecture du fichier %s..."
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION %d: Closing Maps."
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION %d: Fermeture des couches."
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "SECTION 3: Accumulating Surface Flow. Percent complete: "
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION 3: Accumulation du courant de surface. Achevé (pourcentage):"
-#, fuzzy
-#~ msgid "CREATING SUPPORT FILES FOR %s"
-#, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
-#~ msgstr "Aucune couche de données spécifiée"
-#, fuzzy
-#~ msgid "Width of stream (in meters)"
-#~ msgstr "Profondeur additionnelle du cours d'eau"
-#, fuzzy
-#~ msgid "done."
-#~ msgstr "Terminé."
-#, fuzzy
-#~ msgid "Query column name"
-#~ msgstr "Nom de la colonne y"
-#, fuzzy
-#~ msgid ""
-#~ "convert all old GRASS < V5.7 sites maps to vector maps in current mapset"
-#~ msgstr ""
-#~ "convertit toutes les anciennes couches vectorielles GRASS (versions "
-#~ "antérieures à 5.7) du jeu de données courant au format récent"
-#, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
-#~ msgstr ""
-#~ "stdout)"
-#, fuzzy
-#~ msgid "any,grid3,3d raster"
-#, fuzzy
-#~ msgid "Name for G3d raster map"
-#~ msgstr "Nom de la couche raster"
-#, fuzzy
-#~ msgid "No output maps"
-#~ msgstr "Aucune couche créée en sortie"
-#, fuzzy
-#~ msgid "Error opening 3d raster map <%s>. No Vector Data will be created."
-#~ msgstr ""
-#~ "Erreur à l'ouverture de la couche g3d <%s>\n"
-#~ "Erreur à l'ouverture du fichier raster 3D <%s>"
-#, fuzzy
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr ""
-#~ "Valeurs de couches erronnées! Les valeurs doivent être comprises entre 0 "
-#~ "et 255!\n"
-#, fuzzy
-#~ msgid "The resolution of raster and raster3d maps should be equal!"
-#~ msgstr "Nom de la couche raster dont on veut rééchelonner les valeurs"
-#, fuzzy
-#~ msgid ""
-#~ "Feature type. Possible combinations of more types: point,centroid or line,"
-#~ "boundary."
-#~ msgstr ""
-#~ "Type d'objet. Le mélange de types n'est pas géré par tous les format."
-#, fuzzy
-#~ msgid "Line width of highlight color (only for ps.map output)"
-#~ msgstr "Taille de la bordure (seulement pour la sortie ps.map)"
-#, fuzzy
-#~ msgid "unknown interpolation method"
-#, fuzzy
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "Les coordonnées XY de la grille des foyers initiaux"
-#, fuzzy
-#~ msgid "Name of existing raster map."
-#~ msgstr ""
-#~ "Nom du fichier raster existant\n"
-#~ "Nom de la couche raster existante"
-#, fuzzy
-#~ msgid "Name of input map"
-#, fuzzy
-#~ msgid "Name of output map"
-#, fuzzy
-#~ msgid "Name of existing input raster map"
-#~ msgstr ""
-#, fuzzy
-#~ msgid "Wrong RGB maps. RGB output not added!"
-#~ msgstr ""
-#~ "Couches RGB erronées. Les couches doivent être de même type! La sortie "
-#~ "RGB n'est pas créée!"
-#, fuzzy
-#~ msgid "cover raster map"
-#, fuzzy
-#~ msgid "resultant raster map"
-#, fuzzy
-#~ msgid "(i) Rectangular elevation map"
-#~ msgstr "(i) couche d'altitudes"
-#, fuzzy
-#~ msgid "Name of the resulting map"
-#~ msgstr "Nom de la couche en sortie"
-#, fuzzy
-#~ msgid "Fill areas with random colors according to category number"
-#~ msgstr "Nom de la colonne contenant l'attribut w à interpoler"
-#, fuzzy
-#~ msgid "Done.\n"
-#, fuzzy
-#~ msgid "Zooming finished.\n"
-#, fuzzy
-#~ msgid ""
-#~ "column '%s' : type text is stored as varchar(250) some data may be lost"
-#~ msgstr ""
-#~ "colonne '%s' : type character varying enregistré comme varchar(250) des "
-#~ "données peuvent être tronquées"
-#, fuzzy
-#~ msgid "Profile curvature"
-#~ msgstr "Nom de fichier de sortie pour la courbure du profil"
-#, fuzzy
-#~ msgid "Tangential curvature"
-#~ msgstr "Nom de fichier de sortie pour la courbure tangentielle"
-# c-format
-#~ msgid "creating support files for %s"
-#~ msgstr "impossible d'ouvrir le fichier pour %s"
-#, fuzzy
-#~ msgid "Unable to connect line id %d to line %d"
-#~ msgstr "Ne pas afficher les codes de catégories"
-#~ msgid "Extend location extents based on new dataset"
-#~ msgstr "Étendre le Secteur actuel en fonction des données importés"
Modified: grass/branches/releasebranch_6_4/locale/po/grasstcl_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grasstcl_fr.po 2013-01-05 09:25:09 UTC (rev 54530)
+++ grass/branches/releasebranch_6_4/locale/po/grasstcl_fr.po 2013-01-05 12:25:29 UTC (rev 54531)
@@ -10,7 +10,7 @@
"Project-Id-Version: grasstcl_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-11-05 10:54+0100\n"
-"PO-Revision-Date: 2012-08-31 00:45+0100\n"
+"PO-Revision-Date: 2012-12-24 17:49+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: français <grass-translations at lists.osgeo.org>\n"
"Language: \n"
@@ -27,11 +27,10 @@
#: ../lib/init/file_option.tcl:72
msgid "Define location using projection information in georeferenced file"
-msgstr ""
-"Définir le secteur à partir des informations de projection d'un fichier "
-"géoréférencé"
+msgstr "Définir le secteur à partir des informations de projection d'un fichier géoréférencé"
-#: ../lib/init/file_option.tcl:92 ../lib/init/epsg_option.tcl:120
+#: ../lib/init/file_option.tcl:92
+#: ../lib/init/epsg_option.tcl:120
msgid "Name of new location"
msgstr "Nom du nouveau secteur"
@@ -45,12 +44,12 @@
#: ../lib/init/file_option.tcl:102
msgid "Path to georeferenced file (format must be readable by GDAL/OGR)"
-msgstr ""
-"Chemin vers le fichier géoréférencé (le format doit être lisible par GDAL/"
-"OGR)"
+msgstr "Chemin vers le fichier géoréférencé (le format doit être lisible par GDAL/OGR)"
-#: ../lib/init/file_option.tcl:105 ../lib/init/gis_set.tcl:267
-#: ../lib/init/epsg_option.tcl:133 ../lib/init/epsg_option.tcl:146
+#: ../lib/init/file_option.tcl:105
+#: ../lib/init/gis_set.tcl:267
+#: ../lib/init/epsg_option.tcl:133
+#: ../lib/init/epsg_option.tcl:146
msgid "Browse..."
msgstr "Parcourir..."
@@ -58,20 +57,28 @@
msgid "Browse to locate georeferenced file"
msgstr "Naviguer pour localiser le fichier géoréférencé"
-#: ../lib/init/file_option.tcl:111 ../lib/init/epsg_option.tcl:162
+#: ../lib/init/file_option.tcl:111
+#: ../lib/init/epsg_option.tcl:162
msgid "Define location"
msgstr "Définir le secteur"
-#: ../lib/init/file_option.tcl:114 ../lib/init/file_option.tcl:266
-#: ../lib/init/epsg_option.tcl:165 ../lib/init/epsg_option.tcl:312
-#: ../lib/gtcltk/select.tcl:210 ../gui/tcltk/gis.m/gm.tcl:468
-#: ../gui/tcltk/gis.m/gm.tcl:543 ../gui/tcltk/gis.m/dnviz.tcl:230
-#: ../gui/tcltk/gis.m/georect.tcl:703 ../gui/tcltk/gis.m/rules.tcl:172
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:921 ../gui/tcltk/gis.m/animate.tcl:538
+#: ../lib/init/file_option.tcl:114
+#: ../lib/init/file_option.tcl:266
+#: ../lib/init/epsg_option.tcl:165
+#: ../lib/init/epsg_option.tcl:312
+#: ../lib/gtcltk/select.tcl:210
+#: ../gui/tcltk/gis.m/gm.tcl:468
+#: ../gui/tcltk/gis.m/gm.tcl:543
+#: ../gui/tcltk/gis.m/dnviz.tcl:230
+#: ../gui/tcltk/gis.m/georect.tcl:703
+#: ../gui/tcltk/gis.m/rules.tcl:172
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:921
+#: ../gui/tcltk/gis.m/animate.tcl:538
msgid "Cancel"
msgstr "Annuler"
-#: ../lib/init/file_option.tcl:131 ../lib/init/file_option.tcl:134
+#: ../lib/init/file_option.tcl:131
+#: ../lib/init/file_option.tcl:134
msgid "Choose georeferenced file"
msgstr "Choisir le fichier géoréférencé"
@@ -83,13 +90,17 @@
"ATTENTION : merci de fournir\n"
"un fichier géoréférencé valide"
-#: ../lib/init/file_option.tcl:185 ../lib/init/file_option.tcl:212
-#: ../lib/init/epsg_option.tcl:234 ../lib/init/epsg_option.tcl:261
+#: ../lib/init/file_option.tcl:185
+#: ../lib/init/file_option.tcl:212
+#: ../lib/init/epsg_option.tcl:234
+#: ../lib/init/epsg_option.tcl:261
msgid "Error creating location!"
msgstr "Erreur lors de la création du secteur!"
-#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
-#: ../lib/init/epsg_option.tcl:235 ../lib/init/epsg_option.tcl:262
+#: ../lib/init/file_option.tcl:186
+#: ../lib/init/file_option.tcl:213
+#: ../lib/init/epsg_option.tcl:235
+#: ../lib/init/epsg_option.tcl:262
#, tcl-format
msgid ""
"g.proj returned the following message:\n"
@@ -98,13 +109,17 @@
"g.proj retourne le message d'erreur :\n"
"%s"
-#: ../lib/init/file_option.tcl:193 ../lib/init/file_option.tcl:217
-#: ../lib/init/epsg_option.tcl:242 ../lib/init/epsg_option.tcl:266
+#: ../lib/init/file_option.tcl:193
+#: ../lib/init/file_option.tcl:217
+#: ../lib/init/epsg_option.tcl:242
+#: ../lib/init/epsg_option.tcl:266
msgid "Informational output from g.proj"
msgstr "sortie informelle de g.proj"
-#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
-#: ../lib/init/epsg_option.tcl:243 ../lib/init/epsg_option.tcl:267
+#: ../lib/init/file_option.tcl:194
+#: ../lib/init/file_option.tcl:218
+#: ../lib/init/epsg_option.tcl:243
+#: ../lib/init/epsg_option.tcl:267
#, tcl-format
msgid ""
"g.proj returned the following informational message:\n"
@@ -113,23 +128,22 @@
"g.proj retourne le message informel suivant :\n"
"%s"
-#: ../lib/init/file_option.tcl:240 ../lib/init/epsg_option.tcl:286
+#: ../lib/init/file_option.tcl:240
+#: ../lib/init/epsg_option.tcl:286
msgid "Select datum transformation parameters:"
msgstr "Sélectionnez les paramètres de transformation de référence :"
-#: ../lib/init/file_option.tcl:244 ../lib/init/epsg_option.tcl:290
-msgid ""
-"Continue without specifying parameters - if used when creating a location, "
-"other GRASS modules will use the \"default\" (likely non-optimum) parameters "
-"for this datum if necessary in the future."
-msgstr ""
-"Continuer sans préciser les paramètres - lors de l'utilisation par d'autres "
-"modules de GRASS, la référence \"default\" sera utilisée par défaut "
-"(probablement non optimale) à l'avenir."
+#: ../lib/init/file_option.tcl:244
+#: ../lib/init/epsg_option.tcl:290
+msgid "Continue without specifying parameters - if used when creating a location, other GRASS modules will use the \"default\" (likely non-optimum) parameters for this datum if necessary in the future."
+msgstr "Continuer sans préciser les paramètres - lors de l'utilisation par d'autres modules de GRASS, la référence \"default\" sera utilisée par défaut (probablement non optimale) à l'avenir."
-#: ../lib/init/file_option.tcl:263 ../lib/init/epsg_option.tcl:309
-#: ../vector/v.digit/settings.tcl:174 ../gui/tcltk/gis.m/gm.tcl:465
-#: ../gui/tcltk/gis.m/dnviz.tcl:228 ../gui/tcltk/gis.m/rules.tcl:170
+#: ../lib/init/file_option.tcl:263
+#: ../lib/init/epsg_option.tcl:309
+#: ../vector/v.digit/settings.tcl:174
+#: ../gui/tcltk/gis.m/gm.tcl:465
+#: ../gui/tcltk/gis.m/dnviz.tcl:228
+#: ../gui/tcltk/gis.m/rules.tcl:170
#: ../gui/tcltk/gis.m/animate.tcl:536
msgid "OK"
msgstr "OK"
@@ -147,20 +161,20 @@
"Attention : impossible de sauvegarder les données dans le fichier <%s>.\n"
"Message d'erreur : %s"
-#: ../lib/init/gis_set.tcl:131 ../lib/init/gis_set.tcl:403
-#: ../lib/init/gis_set.tcl:509 ../lib/init/gis_set.tcl:641
-#: ../lib/init/gis_set.tcl:662 ../lib/init/gis_set.tcl:680
+#: ../lib/init/gis_set.tcl:131
+#: ../lib/init/gis_set.tcl:403
+#: ../lib/init/gis_set.tcl:509
+#: ../lib/init/gis_set.tcl:641
+#: ../lib/init/gis_set.tcl:662
+#: ../lib/init/gis_set.tcl:680
#: ../lib/init/gis_set.tcl:708
msgid "WARNING: invalid location"
msgstr "ATTENTION : secteur non valide"
#: ../lib/init/gis_set.tcl:132
#, tcl-format
-msgid ""
-"Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
-msgstr ""
-"Attention : le secteur <%s> de la géodatabase <%s> n'est pas un répertoire "
-"ou n'existe pas."
+msgid "Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
+msgstr "Attention : le secteur <%s> de la géodatabase <%s> n'est pas un répertoire ou n'existe pas."
#: ../lib/init/gis_set.tcl:183
#, tcl-format
@@ -247,8 +261,7 @@
"Warning: Unable to create directory for new mapset. \n"
"Error message: %s"
msgstr ""
-"Attention : Impossible de créer le répertoire pour le nouveau jeu de "
-"cartes.\n"
+"Attention : Impossible de créer le répertoire pour le nouveau jeu de cartes.\n"
#: ../lib/init/gis_set.tcl:437
@@ -280,7 +293,8 @@
"Attention : le secteur <%s> n'est pas valide.\n"
" Réessayer avec un secteur valide."
-#: ../lib/init/gis_set.tcl:515 ../lib/init/gis_set.tcl:686
+#: ../lib/init/gis_set.tcl:515
+#: ../lib/init/gis_set.tcl:686
msgid "WARNING: invalid mapset"
msgstr "ATTENTION : jeu de cartes non valide"
@@ -289,41 +303,76 @@
msgid "Warning: <%s> is not a valid mapset"
msgstr "Attention : <%s> n'est pas un jeu de cartes valide"
-#: ../lib/init/gis_set.tcl:531 ../lib/gis/gui.tcl:509
-#: ../gui/tcltk/gis.m/vector.tcl:368 ../gui/tcltk/gis.m/vector.tcl:372
-#: ../gui/tcltk/gis.m/gridline.tcl:166 ../gui/tcltk/gis.m/gridline.tcl:218
-#: ../gui/tcltk/gis.m/gridline.tcl:249 ../gui/tcltk/gis.m/frames.tcl:118
-#: ../gui/tcltk/gis.m/frames.tcl:122 ../gui/tcltk/gis.m/rgbhis.tcl:156
-#: ../gui/tcltk/gis.m/rgbhis.tcl:165 ../gui/tcltk/gis.m/profile.tcl:131
-#: ../gui/tcltk/gis.m/profile.tcl:135 ../gui/tcltk/gis.m/rastnums.tcl:165
-#: ../gui/tcltk/gis.m/rastnums.tcl:168 ../gui/tcltk/gis.m/rastarrows.tcl:169
-#: ../gui/tcltk/gis.m/rastarrows.tcl:172 ../gui/tcltk/gis.m/histogram.tcl:163
-#: ../gui/tcltk/gis.m/histogram.tcl:166 ../gui/tcltk/gis.m/chart.tcl:210
-#: ../gui/tcltk/gis.m/chart.tcl:214 ../gui/tcltk/gis.m/dnviz.tcl:208
-#: ../gui/tcltk/gis.m/dnviz.tcl:212 ../gui/tcltk/gis.m/labels.tcl:136
-#: ../gui/tcltk/gis.m/labels.tcl:140 ../gui/tcltk/gis.m/georect.tcl:708
-#: ../gui/tcltk/gis.m/georect.tcl:712 ../gui/tcltk/gis.m/georect.tcl:1142
-#: ../gui/tcltk/gis.m/georect.tcl:1146 ../gui/tcltk/gis.m/runandoutput.tcl:47
-#: ../gui/tcltk/gis.m/barscale.tcl:180 ../gui/tcltk/gis.m/barscale.tcl:184
-#: ../gui/tcltk/gis.m/dtext.tcl:179 ../gui/tcltk/gis.m/dtext.tcl:183
-#: ../gui/tcltk/gis.m/rules.tcl:139 ../gui/tcltk/gis.m/rules.tcl:143
-#: ../gui/tcltk/gis.m/raster.tcl:209 ../gui/tcltk/gis.m/raster.tcl:213
-#: ../gui/tcltk/gis.m/animate.tcl:408 ../gui/tcltk/gis.m/animate.tcl:412
-#: ../gui/tcltk/gis.m/animate.tcl:481 ../gui/tcltk/gis.m/animate.tcl:484
-#: ../gui/tcltk/gis.m/thematic.tcl:269 ../gui/tcltk/gis.m/thematic.tcl:273
-#: ../gui/tcltk/gis.m/legend.tcl:219 ../gui/tcltk/gis.m/legend.tcl:222
-#: ../gui/tcltk/d.m/vector.tcl:202 ../gui/tcltk/d.m/vector.tcl:206
-#: ../gui/tcltk/d.m/gridline.tcl:81 ../gui/tcltk/d.m/gridline.tcl:120
-#: ../gui/tcltk/d.m/gridline.tcl:150 ../gui/tcltk/d.m/frames.tcl:66
-#: ../gui/tcltk/d.m/frames.tcl:70 ../gui/tcltk/d.m/rgbhis.tcl:130
-#: ../gui/tcltk/d.m/rgbhis.tcl:137 ../gui/tcltk/d.m/chart.tcl:96
-#: ../gui/tcltk/d.m/chart.tcl:100 ../gui/tcltk/d.m/labels.tcl:70
-#: ../gui/tcltk/d.m/labels.tcl:74 ../gui/tcltk/d.m/barscale.tcl:74
-#: ../gui/tcltk/d.m/barscale.tcl:78 ../gui/tcltk/d.m/dtext.tcl:75
-#: ../gui/tcltk/d.m/dtext.tcl:79 ../gui/tcltk/d.m/fttext.tcl:83
-#: ../gui/tcltk/d.m/fttext.tcl:87 ../gui/tcltk/d.m/raster.tcl:90
-#: ../gui/tcltk/d.m/raster.tcl:94 ../gui/tcltk/d.m/thematic.tcl:121
-#: ../gui/tcltk/d.m/thematic.tcl:125 ../gui/tcltk/d.m/legend.tcl:86
+#: ../lib/init/gis_set.tcl:531
+#: ../lib/gis/gui.tcl:509
+#: ../gui/tcltk/gis.m/vector.tcl:368
+#: ../gui/tcltk/gis.m/vector.tcl:372
+#: ../gui/tcltk/gis.m/gridline.tcl:166
+#: ../gui/tcltk/gis.m/gridline.tcl:218
+#: ../gui/tcltk/gis.m/gridline.tcl:249
+#: ../gui/tcltk/gis.m/frames.tcl:118
+#: ../gui/tcltk/gis.m/frames.tcl:122
+#: ../gui/tcltk/gis.m/rgbhis.tcl:156
+#: ../gui/tcltk/gis.m/rgbhis.tcl:165
+#: ../gui/tcltk/gis.m/profile.tcl:131
+#: ../gui/tcltk/gis.m/profile.tcl:135
+#: ../gui/tcltk/gis.m/rastnums.tcl:165
+#: ../gui/tcltk/gis.m/rastnums.tcl:168
+#: ../gui/tcltk/gis.m/rastarrows.tcl:169
+#: ../gui/tcltk/gis.m/rastarrows.tcl:172
+#: ../gui/tcltk/gis.m/histogram.tcl:163
+#: ../gui/tcltk/gis.m/histogram.tcl:166
+#: ../gui/tcltk/gis.m/chart.tcl:210
+#: ../gui/tcltk/gis.m/chart.tcl:214
+#: ../gui/tcltk/gis.m/dnviz.tcl:208
+#: ../gui/tcltk/gis.m/dnviz.tcl:212
+#: ../gui/tcltk/gis.m/labels.tcl:136
+#: ../gui/tcltk/gis.m/labels.tcl:140
+#: ../gui/tcltk/gis.m/georect.tcl:708
+#: ../gui/tcltk/gis.m/georect.tcl:712
+#: ../gui/tcltk/gis.m/georect.tcl:1142
+#: ../gui/tcltk/gis.m/georect.tcl:1146
+#: ../gui/tcltk/gis.m/runandoutput.tcl:47
+#: ../gui/tcltk/gis.m/barscale.tcl:180
+#: ../gui/tcltk/gis.m/barscale.tcl:184
+#: ../gui/tcltk/gis.m/dtext.tcl:179
+#: ../gui/tcltk/gis.m/dtext.tcl:183
+#: ../gui/tcltk/gis.m/rules.tcl:139
+#: ../gui/tcltk/gis.m/rules.tcl:143
+#: ../gui/tcltk/gis.m/raster.tcl:209
+#: ../gui/tcltk/gis.m/raster.tcl:213
+#: ../gui/tcltk/gis.m/animate.tcl:408
+#: ../gui/tcltk/gis.m/animate.tcl:412
+#: ../gui/tcltk/gis.m/animate.tcl:481
+#: ../gui/tcltk/gis.m/animate.tcl:484
+#: ../gui/tcltk/gis.m/thematic.tcl:269
+#: ../gui/tcltk/gis.m/thematic.tcl:273
+#: ../gui/tcltk/gis.m/legend.tcl:219
+#: ../gui/tcltk/gis.m/legend.tcl:222
+#: ../gui/tcltk/d.m/vector.tcl:202
+#: ../gui/tcltk/d.m/vector.tcl:206
+#: ../gui/tcltk/d.m/gridline.tcl:81
+#: ../gui/tcltk/d.m/gridline.tcl:120
+#: ../gui/tcltk/d.m/gridline.tcl:150
+#: ../gui/tcltk/d.m/frames.tcl:66
+#: ../gui/tcltk/d.m/frames.tcl:70
+#: ../gui/tcltk/d.m/rgbhis.tcl:130
+#: ../gui/tcltk/d.m/rgbhis.tcl:137
+#: ../gui/tcltk/d.m/chart.tcl:96
+#: ../gui/tcltk/d.m/chart.tcl:100
+#: ../gui/tcltk/d.m/labels.tcl:70
+#: ../gui/tcltk/d.m/labels.tcl:74
+#: ../gui/tcltk/d.m/barscale.tcl:74
+#: ../gui/tcltk/d.m/barscale.tcl:78
+#: ../gui/tcltk/d.m/dtext.tcl:75
+#: ../gui/tcltk/d.m/dtext.tcl:79
+#: ../gui/tcltk/d.m/fttext.tcl:83
+#: ../gui/tcltk/d.m/fttext.tcl:87
+#: ../gui/tcltk/d.m/raster.tcl:90
+#: ../gui/tcltk/d.m/raster.tcl:94
+#: ../gui/tcltk/d.m/thematic.tcl:121
+#: ../gui/tcltk/d.m/thematic.tcl:125
+#: ../gui/tcltk/d.m/legend.tcl:86
#: ../gui/tcltk/d.m/legend.tcl:90
msgid "Help"
msgstr "Aide"
@@ -341,14 +390,8 @@
msgstr "Démarrage de GRASS pour la première fois"
#: ../lib/init/gis_set.tcl:584
-msgid ""
-"GRASS needs a directory in which to store its data. Create one now if you "
-"have not already done so. A popular choice is \"grassdata\", located in "
-"your home directory."
-msgstr ""
-"GRASS nécessite un dossier dans lequel stocker ses données. En créer un "
-"maintenant si vous ne l'avez pas encore fait. Un choix fréquent est "
-"\"grassdata\", situé dans votre dossier personnel."
+msgid "GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory."
+msgstr "GRASS nécessite un dossier dans lequel stocker ses données. En créer un maintenant si vous ne l'avez pas encore fait. Un choix fréquent est \"grassdata\", situé dans votre dossier personnel."
#: ../lib/init/gis_set.tcl:589
msgid "Select GIS data directory"
@@ -360,12 +403,12 @@
#: ../lib/init/gis_set.tcl:595
msgid "WARNING: Invalid database. Finding first valid directory in parent tree"
-msgstr ""
-"ATTENTION : base de données non valide. Recherche d'un répertoire valide "
-"dans l'arborescence supérieure"
+msgstr "ATTENTION : base de données non valide. Recherche d'un répertoire valide dans l'arborescence supérieure"
-#: ../lib/init/gis_set.tcl:642 ../lib/init/gis_set.tcl:663
-#: ../lib/init/gis_set.tcl:681 ../lib/init/gis_set.tcl:709
+#: ../lib/init/gis_set.tcl:642
+#: ../lib/init/gis_set.tcl:663
+#: ../lib/init/gis_set.tcl:681
+#: ../lib/init/gis_set.tcl:709
#, tcl-format
msgid ""
"Warning: selected location <%%s> is not valid. \n"
@@ -399,25 +442,17 @@
"It's a fatal error. GRASS will not start till issue with GISRC file is fixed."
msgstr ""
"Quelque chose s'est mal passé lors du traitement du fichier GISRC \"%s\".\n"
-"ceci est une erreur fatale. GRASS ne peut pas démarrertant que le problème "
-"ne sera pas résolu."
+"ceci est une erreur fatale. GRASS ne peut pas démarrertant que le problème ne sera pas résolu."
#: ../lib/init/gis_set.tcl:938
msgid ""
"\n"
"\n"
-"On MS-Windows systems failure might be caused by non-latin letter in GISRC "
-"file path. Check that Your username doesn't contain non-latin letters. Due "
-"to non-latin letter encoding handling in MS-Windows, it's not possible to "
-"run GRASS if username contains non-latin letters."
+"On MS-Windows systems failure might be caused by non-latin letter in GISRC file path. Check that Your username doesn't contain non-latin letters. Due to non-latin letter encoding handling in MS-Windows, it's not possible to run GRASS if username contains non-latin letters."
msgstr ""
"\n"
"\n"
-"Sur les systèmes MS-Windows des erreurs peuvent être causées par des lettre "
-"non-latine dans le chemin du fichier GISRC. Vérifiez que votre nom "
-"d'utilisateur ne contien pas de lettres non-latines. La gestion de "
-"l'encodage des lettres non-latines de MS-Windows ne permet pas de lancer "
-"GRASS si le nom d'utilisateur en contient."
+"Sur les systèmes MS-Windows des erreurs peuvent être causées par des lettre non-latine dans le chemin du fichier GISRC. Vérifiez que votre nom d'utilisateur ne contien pas de lettres non-latines. La gestion de l'encodage des lettres non-latines de MS-Windows ne permet pas de lancer GRASS si le nom d'utilisateur en contient."
#: ../lib/init/gis_set.tcl:942
msgid "ERROR: unable to read GISRC"
@@ -431,14 +466,11 @@
msgid ""
"Warning: Unable to get environmental variable GRASS_PROJSHARE. \n"
"This is a GRASS installation error. \n"
-"Set environmental variable GRASS_PROJSHARE to point to directory with Proj4 "
-"EPSG file. "
+"Set environmental variable GRASS_PROJSHARE to point to directory with Proj4 EPSG file. "
msgstr ""
-"Attention : impossible d'accéder à la variable d'environnement "
-"GRASS_PROJSHARE.\n"
+"Attention : impossible d'accéder à la variable d'environnement GRASS_PROJSHARE.\n"
"Il s'agit d'une erreur d'installation de GRASS.\n"
-"Fixer la variable d'environnement GRASS_PROJSHARE pour qu'elle pointe vers "
-"le répertoire contenant le fichier EPSG Proj4."
+"Fixer la variable d'environnement GRASS_PROJSHARE pour qu'elle pointe vers le répertoire contenant le fichier EPSG Proj4."
#: ../lib/init/epsg_option.tcl:101
msgid "Define location using EPSG projection codes"
@@ -448,7 +480,8 @@
msgid "Enter name for location to be created"
msgstr "Entrer le nom du secteur à créer"
-#: ../lib/init/epsg_option.tcl:127 ../lib/init/epsg_option.tcl:130
+#: ../lib/init/epsg_option.tcl:127
+#: ../lib/init/epsg_option.tcl:130
msgid "Path to the EPSG-codes file"
msgstr "Chemin vers le fichier de codes EPSG"
@@ -496,15 +529,14 @@
#: ../lib/init/epsg_option.tcl:342
msgid "You can select EPSG code (in <braces>) and copy it for later use."
-msgstr ""
-"Vous pouvez sélectionner un code EPSG (entre <chevrons>) et le copier pour "
-"un usage ultérieur."
+msgstr "Vous pouvez sélectionner un code EPSG (entre <chevrons>) et le copier pour un usage ultérieur."
#: ../lib/init/epsg_option.tcl:379
msgid "GUESS THAT IS NOT THE EPSG FILE"
msgstr "ÇA N'EST SANS DOUTE PAS LE FICHIER EPSG"
-#: ../lib/init/epsg_option.tcl:385 ../lib/init/epsg_option.tcl:414
+#: ../lib/init/epsg_option.tcl:385
+#: ../lib/init/epsg_option.tcl:414
#: ../lib/init/epsg_option.tcl:433
msgid "Search"
msgstr "Rechercher"
@@ -513,10 +545,14 @@
msgid "Grab code"
msgstr "Capter le code"
-#: ../lib/init/epsg_option.tcl:392 ../lib/init/epsg_option.tcl:436
-#: ../lib/gis/gui.tcl:511 ../gui/tcltk/gis.m/mapprint.tcl:372
-#: ../gui/tcltk/gis.m/gmmenu.tcl:90 ../gui/tcltk/gis.m/runandoutput.tcl:48
-#: ../gui/tcltk/d.m/menu.tcl:176 ../gui/tcltk/d.m/print.tcl:281
+#: ../lib/init/epsg_option.tcl:392
+#: ../lib/init/epsg_option.tcl:436
+#: ../lib/gis/gui.tcl:511
+#: ../gui/tcltk/gis.m/mapprint.tcl:372
+#: ../gui/tcltk/gis.m/gmmenu.tcl:90
+#: ../gui/tcltk/gis.m/runandoutput.tcl:48
+#: ../gui/tcltk/d.m/menu.tcl:176
+#: ../gui/tcltk/d.m/print.tcl:281
msgid "Close"
msgstr "Fermer"
@@ -544,14 +580,19 @@
msgid "Ok"
msgstr "Ok"
-#: ../lib/gis/gui.tcl:11 ../lib/gis/gui.tcl:15 ../lib/gis/gui.tcl:19
-#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/grassabout.tcl:94
-#: ../gui/tcltk/gis.m/gmlib.tcl:141 ../gui/tcltk/gis.m/runandoutput.tcl:277
+#: ../lib/gis/gui.tcl:11
+#: ../lib/gis/gui.tcl:15
+#: ../lib/gis/gui.tcl:19
+#: ../lib/gis/gui.tcl:310
+#: ../gui/tcltk/gis.m/grassabout.tcl:94
+#: ../gui/tcltk/gis.m/gmlib.tcl:141
+#: ../gui/tcltk/gis.m/runandoutput.tcl:277
#: ../gui/tcltk/gis.m/runandoutput.tcl:283
msgid "Error"
msgstr "Erreur"
-#: ../lib/gis/gui.tcl:229 ../gui/tcltk/gis.m/gmlib.tcl:119
+#: ../lib/gis/gui.tcl:229
+#: ../gui/tcltk/gis.m/gmlib.tcl:119
msgid "Save File"
msgstr "Sauvegarder le fichier"
@@ -559,7 +600,8 @@
msgid "Load File"
msgstr "Charger le fichier"
-#: ../lib/gis/gui.tcl:295 ../lib/gis/gui.tcl:485
+#: ../lib/gis/gui.tcl:295
+#: ../lib/gis/gui.tcl:485
msgid "Output"
msgstr "Sortie"
@@ -571,11 +613,13 @@
msgid "Required"
msgstr "Requis"
-#: ../lib/gis/gui.tcl:469 ../gui/tcltk/gis.m/gmmenu.tcl:171
+#: ../lib/gis/gui.tcl:469
+#: ../gui/tcltk/gis.m/gmmenu.tcl:171
msgid "Copy"
msgstr "Copier"
-#: ../lib/gis/gui.tcl:508 ../gui/tcltk/gis.m/runandoutput.tcl:44
+#: ../lib/gis/gui.tcl:508
+#: ../gui/tcltk/gis.m/runandoutput.tcl:44
#: ../gui/tcltk/gis.m/runandoutput.tcl:118
msgid "Run"
msgstr "Exécuter"
@@ -596,7 +640,8 @@
msgid "multiple"
msgstr "multiple"
-#: ../vector/v.digit/cats.tcl:20 ../gui/tcltk/gis.m/gmmenu.tcl:178
+#: ../vector/v.digit/cats.tcl:20
+#: ../gui/tcltk/gis.m/gmmenu.tcl:178
msgid "Delete"
msgstr "Effacer"
@@ -648,7 +693,8 @@
msgid "Symbology"
msgstr "Symbologie"
-#: ../vector/v.digit/settings.tcl:187 ../vector/v.digit/settings.tcl:340
+#: ../vector/v.digit/settings.tcl:187
+#: ../vector/v.digit/settings.tcl:340
msgid "Background"
msgstr "Fond"
@@ -808,7 +854,8 @@
msgid "Zoom out"
msgstr "Zoom arrière"
-#: ../vector/v.digit/toolbox.tcl:212 ../gui/tcltk/gis.m/georecttool.tcl:130
+#: ../vector/v.digit/toolbox.tcl:212
+#: ../gui/tcltk/gis.m/georecttool.tcl:130
#: ../gui/tcltk/gis.m/maptool.tcl:151
msgid "Pan"
msgstr "Se déplacer dans la zone d'affichage"
@@ -845,30 +892,51 @@
msgid "mouse button actions (left, middle, right)"
msgstr "Actions des boutons de la souris (gauche, milieu, droit)"
-#: ../gui/tcltk/gis.m/vector.tcl:196 ../gui/tcltk/gis.m/vector.tcl:876
-#: ../gui/tcltk/gis.m/gridline.tcl:103 ../gui/tcltk/gis.m/gridline.tcl:416
-#: ../gui/tcltk/gis.m/frames.tcl:78 ../gui/tcltk/gis.m/frames.tcl:275
-#: ../gui/tcltk/gis.m/rgbhis.tcl:83 ../gui/tcltk/gis.m/rgbhis.tcl:362
-#: ../gui/tcltk/gis.m/mapprint.tcl:197 ../gui/tcltk/gis.m/mapprint.tcl:204
-#: ../gui/tcltk/gis.m/rastnums.tcl:81 ../gui/tcltk/gis.m/rastnums.tcl:375
-#: ../gui/tcltk/gis.m/rastarrows.tcl:88 ../gui/tcltk/gis.m/rastarrows.tcl:372
-#: ../gui/tcltk/gis.m/histogram.tcl:85 ../gui/tcltk/gis.m/histogram.tcl:370
-#: ../gui/tcltk/gis.m/chart.tcl:91 ../gui/tcltk/gis.m/chart.tcl:468
-#: ../gui/tcltk/gis.m/labels.tcl:78 ../gui/tcltk/gis.m/labels.tcl:279
-#: ../gui/tcltk/gis.m/georect.tcl:409 ../gui/tcltk/gis.m/barscale.tcl:91
-#: ../gui/tcltk/gis.m/barscale.tcl:401 ../gui/tcltk/gis.m/dtext.tcl:94
-#: ../gui/tcltk/gis.m/dtext.tcl:407 ../gui/tcltk/gis.m/rules.tcl:207
-#: ../gui/tcltk/gis.m/cmd.tcl:75 ../gui/tcltk/gis.m/cmd.tcl:206
-#: ../gui/tcltk/gis.m/raster.tcl:87 ../gui/tcltk/gis.m/raster.tcl:480
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:228 ../gui/tcltk/gis.m/mapcanvas.tcl:238
-#: ../gui/tcltk/gis.m/animate.tcl:91 ../gui/tcltk/gis.m/thematic.tcl:111
-#: ../gui/tcltk/gis.m/thematic.tcl:640 ../gui/tcltk/gis.m/thematic.tcl:713
-#: ../gui/tcltk/gis.m/legend.tcl:95 ../gui/tcltk/gis.m/legend.tcl:505
+#: ../gui/tcltk/gis.m/vector.tcl:196
+#: ../gui/tcltk/gis.m/vector.tcl:876
+#: ../gui/tcltk/gis.m/gridline.tcl:103
+#: ../gui/tcltk/gis.m/gridline.tcl:416
+#: ../gui/tcltk/gis.m/frames.tcl:78
+#: ../gui/tcltk/gis.m/frames.tcl:275
+#: ../gui/tcltk/gis.m/rgbhis.tcl:83
+#: ../gui/tcltk/gis.m/rgbhis.tcl:362
+#: ../gui/tcltk/gis.m/mapprint.tcl:197
+#: ../gui/tcltk/gis.m/mapprint.tcl:204
+#: ../gui/tcltk/gis.m/rastnums.tcl:81
+#: ../gui/tcltk/gis.m/rastnums.tcl:375
+#: ../gui/tcltk/gis.m/rastarrows.tcl:88
+#: ../gui/tcltk/gis.m/rastarrows.tcl:372
+#: ../gui/tcltk/gis.m/histogram.tcl:85
+#: ../gui/tcltk/gis.m/histogram.tcl:370
+#: ../gui/tcltk/gis.m/chart.tcl:91
+#: ../gui/tcltk/gis.m/chart.tcl:468
+#: ../gui/tcltk/gis.m/labels.tcl:78
+#: ../gui/tcltk/gis.m/labels.tcl:279
+#: ../gui/tcltk/gis.m/georect.tcl:409
+#: ../gui/tcltk/gis.m/barscale.tcl:91
+#: ../gui/tcltk/gis.m/barscale.tcl:401
+#: ../gui/tcltk/gis.m/dtext.tcl:94
+#: ../gui/tcltk/gis.m/dtext.tcl:407
+#: ../gui/tcltk/gis.m/rules.tcl:207
+#: ../gui/tcltk/gis.m/cmd.tcl:75
+#: ../gui/tcltk/gis.m/cmd.tcl:206
+#: ../gui/tcltk/gis.m/raster.tcl:87
+#: ../gui/tcltk/gis.m/raster.tcl:480
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:228
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:238
+#: ../gui/tcltk/gis.m/animate.tcl:91
+#: ../gui/tcltk/gis.m/thematic.tcl:111
+#: ../gui/tcltk/gis.m/thematic.tcl:640
+#: ../gui/tcltk/gis.m/thematic.tcl:713
+#: ../gui/tcltk/gis.m/legend.tcl:95
+#: ../gui/tcltk/gis.m/legend.tcl:505
msgid "Error creating tempfile"
msgstr "Erreur lors de la création temporaire"
-#: ../gui/tcltk/gis.m/vector.tcl:222 ../gui/tcltk/gis.m/thematic.tcl:133
-#: ../gui/tcltk/d.m/menu.tcl:94 ../gui/tcltk/d.m/menu.tcl:134
+#: ../gui/tcltk/gis.m/vector.tcl:222
+#: ../gui/tcltk/gis.m/thematic.tcl:133
+#: ../gui/tcltk/d.m/menu.tcl:94
+#: ../gui/tcltk/d.m/menu.tcl:134
msgid "Vector map"
msgstr "Couche vectorielle"
@@ -876,22 +944,30 @@
msgid "Vector output map"
msgstr "Couche vectorielle de sortie"
-#: ../gui/tcltk/gis.m/vector.tcl:247 ../gui/tcltk/gis.m/vector.tcl:269
-#: ../gui/tcltk/gis.m/vector.tcl:302 ../gui/tcltk/gis.m/chart.tcl:130
-#: ../gui/tcltk/gis.m/chart.tcl:151 ../gui/tcltk/gis.m/raster.tcl:145
-#: ../gui/tcltk/gis.m/raster.tcl:161 ../gui/tcltk/gis.m/thematic.tcl:173
+#: ../gui/tcltk/gis.m/vector.tcl:247
+#: ../gui/tcltk/gis.m/vector.tcl:269
+#: ../gui/tcltk/gis.m/vector.tcl:302
+#: ../gui/tcltk/gis.m/chart.tcl:130
+#: ../gui/tcltk/gis.m/chart.tcl:151
+#: ../gui/tcltk/gis.m/raster.tcl:145
+#: ../gui/tcltk/gis.m/raster.tcl:161
+#: ../gui/tcltk/gis.m/thematic.tcl:173
#: ../gui/tcltk/gis.m/thematic.tcl:194
msgid "This action requires map name to be set"
msgstr "Cette action nécessite de nommer la carte"
-#: ../gui/tcltk/gis.m/vector.tcl:253 ../gui/tcltk/gis.m/vector.tcl:275
-#: ../gui/tcltk/gis.m/vector.tcl:308 ../gui/tcltk/gis.m/chart.tcl:136
-#: ../gui/tcltk/gis.m/chart.tcl:157 ../gui/tcltk/gis.m/thematic.tcl:179
+#: ../gui/tcltk/gis.m/vector.tcl:253
+#: ../gui/tcltk/gis.m/vector.tcl:275
+#: ../gui/tcltk/gis.m/vector.tcl:308
+#: ../gui/tcltk/gis.m/chart.tcl:136
+#: ../gui/tcltk/gis.m/chart.tcl:157
+#: ../gui/tcltk/gis.m/thematic.tcl:179
#: ../gui/tcltk/gis.m/thematic.tcl:200
msgid "You must provide valid vector layer number"
msgstr "Vous devez indiquer un numéro de couche valide"
-#: ../gui/tcltk/gis.m/vector.tcl:319 ../gui/tcltk/gis.m/thematic.tcl:222
+#: ../gui/tcltk/gis.m/vector.tcl:319
+#: ../gui/tcltk/gis.m/thematic.tcl:222
msgid "Vector point symbol"
msgstr "Symbole de point vectoriel"
@@ -899,13 +975,20 @@
msgid "Display vector maps"
msgstr "Afficher les couches vectorielles"
-#: ../gui/tcltk/gis.m/vector.tcl:344 ../gui/tcltk/gis.m/gridline.tcl:151
-#: ../gui/tcltk/gis.m/rgbhis.tcl:143 ../gui/tcltk/gis.m/rastnums.tcl:148
-#: ../gui/tcltk/gis.m/rastarrows.tcl:152 ../gui/tcltk/gis.m/histogram.tcl:146
-#: ../gui/tcltk/gis.m/chart.tcl:192 ../gui/tcltk/gis.m/labels.tcl:118
-#: ../gui/tcltk/gis.m/barscale.tcl:160 ../gui/tcltk/gis.m/dtext.tcl:168
-#: ../gui/tcltk/gis.m/cmd.tcl:105 ../gui/tcltk/gis.m/raster.tcl:185
-#: ../gui/tcltk/gis.m/thematic.tcl:251 ../gui/tcltk/gis.m/legend.tcl:200
+#: ../gui/tcltk/gis.m/vector.tcl:344
+#: ../gui/tcltk/gis.m/gridline.tcl:151
+#: ../gui/tcltk/gis.m/rgbhis.tcl:143
+#: ../gui/tcltk/gis.m/rastnums.tcl:148
+#: ../gui/tcltk/gis.m/rastarrows.tcl:152
+#: ../gui/tcltk/gis.m/histogram.tcl:146
+#: ../gui/tcltk/gis.m/chart.tcl:192
+#: ../gui/tcltk/gis.m/labels.tcl:118
+#: ../gui/tcltk/gis.m/barscale.tcl:160
+#: ../gui/tcltk/gis.m/dtext.tcl:168
+#: ../gui/tcltk/gis.m/cmd.tcl:105
+#: ../gui/tcltk/gis.m/raster.tcl:185
+#: ../gui/tcltk/gis.m/thematic.tcl:251
+#: ../gui/tcltk/gis.m/legend.tcl:200
msgid "Opaque "
msgstr "Opaque "
@@ -913,7 +996,8 @@
msgid "Transparent"
msgstr "Transparent"
-#: ../gui/tcltk/gis.m/vector.tcl:354 ../gui/tcltk/gis.m/thematic.tcl:261
+#: ../gui/tcltk/gis.m/vector.tcl:354
+#: ../gui/tcltk/gis.m/thematic.tcl:261
#: ../gui/tcltk/d.m/thematic.tcl:116
msgid "Vector map:"
msgstr "Couche vectorielle : "
@@ -922,7 +1006,8 @@
msgid "vector map to display"
msgstr "couche vectorielle à afficher"
-#: ../gui/tcltk/gis.m/vector.tcl:362 ../gui/tcltk/gis.m/vector.tcl:366
+#: ../gui/tcltk/gis.m/vector.tcl:362
+#: ../gui/tcltk/gis.m/vector.tcl:366
msgid "Vector Info"
msgstr "Informations sur les vecteurs"
@@ -994,11 +1079,13 @@
msgid "Attribute column for rotation"
msgstr "Colonne attributaire pour la rotation"
-#: ../gui/tcltk/gis.m/vector.tcl:433 ../gui/tcltk/d.m/vector.tcl:259
+#: ../gui/tcltk/gis.m/vector.tcl:433
+#: ../gui/tcltk/d.m/vector.tcl:259
msgid "Draw lines:"
msgstr "Tracer les lignes :"
-#: ../gui/tcltk/gis.m/vector.tcl:436 ../gui/tcltk/gis.m/vector.tcl:452
+#: ../gui/tcltk/gis.m/vector.tcl:436
+#: ../gui/tcltk/gis.m/vector.tcl:452
msgid "Color"
msgstr "Couleur des lignes "
@@ -1014,7 +1101,8 @@
msgid "(pixels) "
msgstr "(pixels)"
-#: ../gui/tcltk/gis.m/vector.tcl:449 ../gui/tcltk/d.m/vector.tcl:275
+#: ../gui/tcltk/gis.m/vector.tcl:449
+#: ../gui/tcltk/d.m/vector.tcl:275
msgid "Fill areas:"
msgstr "Remplir les surfaces :"
@@ -1022,15 +1110,18 @@
msgid "Random colors "
msgstr "Couleurs aléatoires"
-#: ../gui/tcltk/gis.m/vector.tcl:458 ../gui/tcltk/d.m/vector.tcl:284
+#: ../gui/tcltk/gis.m/vector.tcl:458
+#: ../gui/tcltk/d.m/vector.tcl:284
msgid "GRASSRGB column colors"
msgstr "Couleurs GRASSRGB"
-#: ../gui/tcltk/gis.m/vector.tcl:465 ../gui/tcltk/d.m/vector.tcl:291
+#: ../gui/tcltk/gis.m/vector.tcl:465
+#: ../gui/tcltk/d.m/vector.tcl:291
msgid "Label vectors:"
msgstr "Afficher les étiquettes :"
-#: ../gui/tcltk/gis.m/vector.tcl:466 ../gui/tcltk/d.m/vector.tcl:292
+#: ../gui/tcltk/gis.m/vector.tcl:466
+#: ../gui/tcltk/d.m/vector.tcl:292
msgid "label"
msgstr " "
@@ -1042,7 +1133,8 @@
msgid " Text size"
msgstr " Taille du texte"
-#: ../gui/tcltk/gis.m/vector.tcl:473 ../gui/tcltk/d.m/vector.tcl:299
+#: ../gui/tcltk/gis.m/vector.tcl:473
+#: ../gui/tcltk/d.m/vector.tcl:299
msgid "text size"
msgstr "taille de texte"
@@ -1050,19 +1142,24 @@
msgid "Label part to align with vector point "
msgstr "Partie de l'étiquette a aligner sur le point"
-#: ../gui/tcltk/gis.m/vector.tcl:483 ../gui/tcltk/gis.m/maplabels.tcl:221
+#: ../gui/tcltk/gis.m/vector.tcl:483
+#: ../gui/tcltk/gis.m/maplabels.tcl:221
#: ../gui/tcltk/gis.m/maptext.tcl:175
msgid "left"
msgstr "gauche"
-#: ../gui/tcltk/gis.m/vector.tcl:483 ../gui/tcltk/gis.m/vector.tcl:488
-#: ../gui/tcltk/gis.m/maplabels.tcl:200 ../gui/tcltk/gis.m/maplabels.tcl:221
-#: ../gui/tcltk/gis.m/dtext.tcl:213 ../gui/tcltk/gis.m/maptext.tcl:166
+#: ../gui/tcltk/gis.m/vector.tcl:488
+#: ../gui/tcltk/gis.m/maplabels.tcl:200
+#: ../gui/tcltk/gis.m/dtext.tcl:213
+#: ../gui/tcltk/gis.m/maptext.tcl:166
msgid "center"
msgstr "centre"
msgid "right"
msgstr "droite"
@@ -1091,7 +1188,8 @@
msgid "Query vectors for display: "
msgstr "Couches vectorielles de requête pour l'affichage :"
-#: ../gui/tcltk/gis.m/vector.tcl:505 ../gui/tcltk/d.m/vector.tcl:327
+#: ../gui/tcltk/gis.m/vector.tcl:505
+#: ../gui/tcltk/d.m/vector.tcl:327
msgid "layer for query"
msgstr "numéro de la couche "
@@ -1107,15 +1205,21 @@
msgid " Show attribute columns"
msgstr " Afficher les colonnes attributaires"
-#: ../gui/tcltk/gis.m/vector.tcl:533 ../gui/tcltk/gis.m/chart.tcl:239
-#: ../gui/tcltk/gis.m/thematic.tcl:299 ../gui/tcltk/d.m/vector.tcl:349
-#: ../gui/tcltk/d.m/chart.tcl:121 ../gui/tcltk/d.m/thematic.tcl:151
+#: ../gui/tcltk/gis.m/vector.tcl:533
+#: ../gui/tcltk/gis.m/chart.tcl:239
+#: ../gui/tcltk/gis.m/thematic.tcl:299
+#: ../gui/tcltk/d.m/vector.tcl:349
+#: ../gui/tcltk/d.m/chart.tcl:121
+#: ../gui/tcltk/d.m/thematic.tcl:151
msgid "columns"
msgstr "champs"
-#: ../gui/tcltk/gis.m/vector.tcl:537 ../gui/tcltk/gis.m/chart.tcl:243
-#: ../gui/tcltk/gis.m/thematic.tcl:303 ../gui/tcltk/d.m/vector.tcl:353
-#: ../gui/tcltk/d.m/chart.tcl:125 ../gui/tcltk/d.m/thematic.tcl:155
+#: ../gui/tcltk/gis.m/vector.tcl:537
+#: ../gui/tcltk/gis.m/chart.tcl:243
+#: ../gui/tcltk/gis.m/thematic.tcl:303
+#: ../gui/tcltk/d.m/vector.tcl:353
+#: ../gui/tcltk/d.m/chart.tcl:125
+#: ../gui/tcltk/d.m/thematic.tcl:155
msgid "Show columns"
msgstr "Montrer les champs"
@@ -1123,14 +1227,18 @@
msgid " Show attribute data"
msgstr " Afficher les données attributaires"
-#: ../gui/tcltk/gis.m/vector.tcl:539 ../gui/tcltk/gis.m/chart.tcl:245
-#: ../gui/tcltk/gis.m/thematic.tcl:305 ../gui/tcltk/d.m/vector.tcl:355
+#: ../gui/tcltk/gis.m/vector.tcl:539
+#: ../gui/tcltk/gis.m/chart.tcl:245
+#: ../gui/tcltk/gis.m/thematic.tcl:305
+#: ../gui/tcltk/d.m/vector.tcl:355
#: ../gui/tcltk/d.m/thematic.tcl:157
msgid "data"
msgstr "données"
-#: ../gui/tcltk/gis.m/vector.tcl:543 ../gui/tcltk/gis.m/chart.tcl:249
-#: ../gui/tcltk/gis.m/thematic.tcl:309 ../gui/tcltk/d.m/vector.tcl:359
+#: ../gui/tcltk/gis.m/vector.tcl:543
+#: ../gui/tcltk/gis.m/chart.tcl:249
+#: ../gui/tcltk/gis.m/thematic.tcl:309
+#: ../gui/tcltk/d.m/vector.tcl:359
#: ../gui/tcltk/d.m/thematic.tcl:161
msgid "Show data"
msgstr "Montrer les données"
@@ -1151,7 +1259,8 @@
msgid "Select existing vector for saving queried objects"
msgstr "Sélectionner la couche vectorielle pour enregistrer la requête"
-#: ../gui/tcltk/gis.m/vector.tcl:571 ../gui/tcltk/d.m/vector.tcl:376
+#: ../gui/tcltk/gis.m/vector.tcl:571
+#: ../gui/tcltk/d.m/vector.tcl:376
msgid "Display when avg. region dimension is"
msgstr "Afficher lorsque les dimensions moyennes de la région sont"
@@ -1160,14 +1269,11 @@
msgstr "ou <"
#: ../gui/tcltk/gis.m/gm.tcl:75
-msgid ""
-"GISDBASE or LOCATION_NAME or MAPSET is empty. This is a fatal error. gis.m "
-"can not work without proper settings."
-msgstr ""
-"GISDBASE ou LOCATION_NAME ou MAPSET est vide. Ceci est une erreur fatale. "
-"gis.m ne peut pas fonctionner sans des paramètres corrects."
+msgid "GISDBASE or LOCATION_NAME or MAPSET is empty. This is a fatal error. gis.m can not work without proper settings."
+msgstr "GISDBASE ou LOCATION_NAME ou MAPSET est vide. Ceci est une erreur fatale. gis.m ne peut pas fonctionner sans des paramètres corrects."
-#: ../gui/tcltk/gis.m/gm.tcl:219 ../gui/tcltk/d.m/d.m.tcl:314
+#: ../gui/tcltk/gis.m/gm.tcl:219
+#: ../gui/tcltk/d.m/d.m.tcl:314
msgid "Loading GIS Manager"
msgstr "Chargement du Gestionnaire SIG"
@@ -1175,7 +1281,8 @@
msgid "Creating MainFrame..."
msgstr "Créer MainFrame..."
-#: ../gui/tcltk/gis.m/gm.tcl:266 ../gui/tcltk/d.m/d.m.tcl:404
+#: ../gui/tcltk/gis.m/gm.tcl:266
+#: ../gui/tcltk/d.m/d.m.tcl:404
msgid "Done"
msgstr "Fait"
@@ -1215,15 +1322,13 @@
"\n"
"This action will close all sessions gis.m instances.\n"
"\n"
-"If You have running some GRASS module from comandline, GRASS will terminate "
-"after it finishes to run."
+"If You have running some GRASS module from comandline, GRASS will terminate after it finishes to run."
msgstr ""
"Voulez-vous vraiment quitter la session GRASS ?\n"
"\n"
"Cette action va fermer les sessions de toutes les instances gis.m.\n"
"\n"
-"Si vous avez lancé des modules GRASS depuis la ligne de commande, GRASS se "
-"terminera une fois les exécutions terminées."
+"Si vous avez lancé des modules GRASS depuis la ligne de commande, GRASS se terminera une fois les exécutions terminées."
msgid "Terminate current GRASS session"
@@ -1250,12 +1355,18 @@
msgid "Display grid lines, and geodesic lines or rhumblines"
msgstr "Affichage des lignes de la grille, et des lignes géodésiques"
-#: ../gui/tcltk/gis.m/gridline.tcl:155 ../gui/tcltk/gis.m/rgbhis.tcl:147
-#: ../gui/tcltk/gis.m/rastnums.tcl:152 ../gui/tcltk/gis.m/rastarrows.tcl:156
-#: ../gui/tcltk/gis.m/histogram.tcl:150 ../gui/tcltk/gis.m/chart.tcl:196
-#: ../gui/tcltk/gis.m/labels.tcl:122 ../gui/tcltk/gis.m/barscale.tcl:164
-#: ../gui/tcltk/gis.m/dtext.tcl:172 ../gui/tcltk/gis.m/cmd.tcl:109
-#: ../gui/tcltk/gis.m/raster.tcl:189 ../gui/tcltk/gis.m/thematic.tcl:255
+#: ../gui/tcltk/gis.m/gridline.tcl:155
+#: ../gui/tcltk/gis.m/rgbhis.tcl:147
+#: ../gui/tcltk/gis.m/rastnums.tcl:152
+#: ../gui/tcltk/gis.m/rastarrows.tcl:156
+#: ../gui/tcltk/gis.m/histogram.tcl:150
+#: ../gui/tcltk/gis.m/chart.tcl:196
+#: ../gui/tcltk/gis.m/labels.tcl:122
+#: ../gui/tcltk/gis.m/barscale.tcl:164
+#: ../gui/tcltk/gis.m/dtext.tcl:172
+#: ../gui/tcltk/gis.m/cmd.tcl:109
+#: ../gui/tcltk/gis.m/raster.tcl:189
+#: ../gui/tcltk/gis.m/thematic.tcl:255
#: ../gui/tcltk/gis.m/legend.tcl:204
msgid " Transparent"
msgstr " Transparent"
@@ -1264,7 +1375,8 @@
msgid "Grid options: "
msgstr "Options de grille :"
-#: ../gui/tcltk/gis.m/gridline.tcl:162 ../gui/tcltk/d.m/gridline.tcl:77
+#: ../gui/tcltk/gis.m/gridline.tcl:162
+#: ../gui/tcltk/d.m/gridline.tcl:77
msgid "draw grid"
msgstr "tracer la grille"
@@ -1276,7 +1388,8 @@
msgid "grid color "
msgstr "Couleur de la grille"
-#: ../gui/tcltk/gis.m/gridline.tcl:170 ../gui/tcltk/d.m/gridline.tcl:85
+#: ../gui/tcltk/gis.m/gridline.tcl:170
+#: ../gui/tcltk/d.m/gridline.tcl:85
msgid "Help for grids"
msgstr "Aide pour les grilles"
@@ -1296,9 +1409,12 @@
msgid "text color "
msgstr "Couleur du texte"
-#: ../gui/tcltk/gis.m/gridline.tcl:191 ../gui/tcltk/gis.m/rastnums.tcl:184
-#: ../gui/tcltk/gis.m/histogram.tcl:179 ../gui/tcltk/gis.m/barscale.tcl:204
-#: ../gui/tcltk/gis.m/dtext.tcl:232 ../gui/tcltk/gis.m/maptext.tcl:186
+#: ../gui/tcltk/gis.m/gridline.tcl:191
+#: ../gui/tcltk/gis.m/rastnums.tcl:184
+#: ../gui/tcltk/gis.m/histogram.tcl:179
+#: ../gui/tcltk/gis.m/barscale.tcl:204
+#: ../gui/tcltk/gis.m/dtext.tcl:232
+#: ../gui/tcltk/gis.m/maptext.tcl:186
#: ../gui/tcltk/gis.m/legend.tcl:265
msgid "select font for text"
msgstr "sélectionner la police pour le texte"
@@ -1327,159 +1443,258 @@
msgid "Geodesic and rhumblines for latlong locations only"
msgstr "Géodésiques et rhumblines pour latitude et longitude seulement"
-#: ../gui/tcltk/gis.m/gridline.tcl:217 ../gui/tcltk/d.m/gridline.tcl:119
+#: ../gui/tcltk/gis.m/gridline.tcl:217
+#: ../gui/tcltk/d.m/gridline.tcl:119
msgid "draw geodesic line"
msgstr "dessiner les lignes géodésiques"
-#: ../gui/tcltk/gis.m/gridline.tcl:222 ../gui/tcltk/d.m/gridline.tcl:124
+#: ../gui/tcltk/gis.m/gridline.tcl:222
+#: ../gui/tcltk/d.m/gridline.tcl:124
msgid "Help for geodesic lines"
msgstr "Aide pour les lignes géodésiques"
-#: ../gui/tcltk/gis.m/gridline.tcl:223 ../gui/tcltk/gis.m/gridline.tcl:254
+#: ../gui/tcltk/gis.m/gridline.tcl:223
+#: ../gui/tcltk/gis.m/gridline.tcl:254
msgid " line color"
msgstr "Couleur de ligne"
-#: ../gui/tcltk/gis.m/gridline.tcl:227 ../gui/tcltk/gis.m/gridline.tcl:233
-#: ../gui/tcltk/gis.m/gridline.tcl:258 ../gui/tcltk/gis.m/rastnums.tcl:179
-#: ../gui/tcltk/gis.m/rastnums.tcl:196 ../gui/tcltk/gis.m/rastarrows.tcl:201
-#: ../gui/tcltk/gis.m/rastarrows.tcl:208 ../gui/tcltk/gis.m/rastarrows.tcl:220
-#: ../gui/tcltk/gis.m/rastarrows.tcl:227 ../gui/tcltk/gis.m/chart.tcl:292
-#: ../gui/tcltk/gis.m/raster.tcl:273 ../gui/tcltk/gis.m/legend.tcl:262
+#: ../gui/tcltk/gis.m/gridline.tcl:227
+#: ../gui/tcltk/gis.m/gridline.tcl:233
+#: ../gui/tcltk/gis.m/gridline.tcl:258
+#: ../gui/tcltk/gis.m/rastnums.tcl:179
+#: ../gui/tcltk/gis.m/rastnums.tcl:196
+#: ../gui/tcltk/gis.m/rastarrows.tcl:201
+#: ../gui/tcltk/gis.m/rastarrows.tcl:208
+#: ../gui/tcltk/gis.m/rastarrows.tcl:220
+#: ../gui/tcltk/gis.m/rastarrows.tcl:227
+#: ../gui/tcltk/gis.m/chart.tcl:292
+#: ../gui/tcltk/gis.m/raster.tcl:273
+#: ../gui/tcltk/gis.m/legend.tcl:262
msgid "white"
msgstr "blanc"
msgid "grey"
msgstr "gris"
msgid "gray"
msgstr "gris"
msgid "black"
msgstr "noir"
msgid "brown"
msgstr "marron"
msgid "red"
msgstr "rouge"
msgid "orange"
msgstr "orange"
msgid "yellow"
msgstr "jaune"
msgid "green"
msgstr "vert"
msgid "aqua"
msgstr "bleu-vert"
msgid "cyan"
msgstr "cyan"
msgid "indigo"
msgstr "indigo"
msgid "blue"
msgstr "bleu"
msgid "purple"
msgstr "pourpre"
msgid "violet"
msgstr "violet"
msgid "magenta"
msgstr "magenta"
@@ -1487,29 +1702,32 @@
msgid " text color"
-#: ../gui/tcltk/gis.m/gridline.tcl:240 ../gui/tcltk/gis.m/gridline.tcl:265
+#: ../gui/tcltk/gis.m/gridline.tcl:240
+#: ../gui/tcltk/gis.m/gridline.tcl:265
msgid " line endpoints (x1,y1,x2,y2)"
msgstr " ligne des points limites (x1, y1, x2, y2)"
-#: ../gui/tcltk/gis.m/gridline.tcl:248 ../gui/tcltk/d.m/gridline.tcl:149
+#: ../gui/tcltk/gis.m/gridline.tcl:248
+#: ../gui/tcltk/d.m/gridline.tcl:149
msgid "draw rhumbline"
msgstr "tracer l'orthodromie"
-#: ../gui/tcltk/gis.m/gridline.tcl:253 ../gui/tcltk/d.m/gridline.tcl:154
+#: ../gui/tcltk/gis.m/gridline.tcl:253
+#: ../gui/tcltk/d.m/gridline.tcl:154
msgid "Help for rhumblines"
msgstr "Aide pour l'orthodromie"
#: ../gui/tcltk/gis.m/frames.tcl:105
msgid "Divide map display into frames for displaying multiple maps"
-msgstr ""
-"Diviser l'affichage de la carte dans des cadres pour l'affichage de "
-"multiples cartes"
+msgstr "Diviser l'affichage de la carte dans des cadres pour l'affichage de multiples cartes"
-#: ../gui/tcltk/gis.m/frames.tcl:112 ../gui/tcltk/d.m/frames.tcl:60
+#: ../gui/tcltk/gis.m/frames.tcl:112
+#: ../gui/tcltk/d.m/frames.tcl:60
msgid "create and select frame"
msgstr "créer et sélectionner un cadre"
-#: ../gui/tcltk/gis.m/frames.tcl:114 ../gui/tcltk/d.m/frames.tcl:62
+#: ../gui/tcltk/gis.m/frames.tcl:114
+#: ../gui/tcltk/d.m/frames.tcl:62
msgid "select frame"
msgstr "sélectionner un cadre"
@@ -1524,9 +1742,7 @@
#: ../gui/tcltk/gis.m/frames.tcl:135
#, tcl-format
msgid "Set frame borders at 0-100% from lower left corner of display "
-msgstr ""
-"Définir les bordures du cadre à 0-100% à partir du coin inférieur gauche de "
-"l'écran"
+msgstr "Définir les bordures du cadre à 0-100% à partir du coin inférieur gauche de l'écran"
#: ../gui/tcltk/gis.m/frames.tcl:141
msgid " set borders (bottom,top,left,right): "
@@ -1550,25 +1766,26 @@
msgstr "Couche matricielle pour le canal bleu ou la saturation"
#: ../gui/tcltk/gis.m/rgbhis.tcl:136
-msgid ""
-"Display 3 raster maps as Red/Green/Blue or Hue/Intensity/Saturation channels"
-msgstr ""
-"Afficher 3 couches matricielles comme canaux Rouge/Vert/Bleu ou Teinte/"
-"Valeur/Saturation"
+msgid "Display 3 raster maps as Red/Green/Blue or Hue/Intensity/Saturation channels"
+msgstr "Afficher 3 couches matricielles comme canaux Rouge/Vert/Bleu ou Teinte/Valeur/Saturation"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:155 ../gui/tcltk/d.m/rgbhis.tcl:128
+#: ../gui/tcltk/gis.m/rgbhis.tcl:155
+#: ../gui/tcltk/d.m/rgbhis.tcl:128
msgid "display maps as RGB"
msgstr "afficher les couches en RVB"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:160 ../gui/tcltk/d.m/rgbhis.tcl:134
+#: ../gui/tcltk/gis.m/rgbhis.tcl:160
+#: ../gui/tcltk/d.m/rgbhis.tcl:134
msgid "Help for RGB"
msgstr "Aide sur RVB"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:164 ../gui/tcltk/d.m/rgbhis.tcl:135
+#: ../gui/tcltk/gis.m/rgbhis.tcl:164
+#: ../gui/tcltk/d.m/rgbhis.tcl:135
msgid "display maps as HIS"
msgstr "afficher les couches en TVS "
-#: ../gui/tcltk/gis.m/rgbhis.tcl:169 ../gui/tcltk/d.m/rgbhis.tcl:141
+#: ../gui/tcltk/gis.m/rgbhis.tcl:169
+#: ../gui/tcltk/d.m/rgbhis.tcl:141
msgid "Help for HIS"
msgstr "Aide sur TVS"
@@ -1604,55 +1821,58 @@
msgid "Adjusts the HIS intensity channel brightness"
msgstr "Ajuste la luminosité du canal valeur TVS"
-#: ../gui/tcltk/gis.m/rgbhis.tcl:220 ../gui/tcltk/gis.m/raster.tcl:263
-#: ../gui/tcltk/d.m/rgbhis.tcl:147 ../gui/tcltk/d.m/raster.tcl:143
+#: ../gui/tcltk/gis.m/rgbhis.tcl:220
+#: ../gui/tcltk/gis.m/raster.tcl:263
+#: ../gui/tcltk/d.m/rgbhis.tcl:147
+#: ../gui/tcltk/d.m/raster.tcl:143
msgid "overlay maps from other layers (transparent null value cells)"
-msgstr ""
-"Superposer le drapage sur les autres couches (cellules nulles transparentes)"
+msgstr "Superposer le drapage sur les autres couches (cellules nulles transparentes)"
#: ../gui/tcltk/gis.m/maplabels.tcl:127
msgid "Label file"
msgstr "Nom du fichier d'étiquettes"
-#: ../gui/tcltk/gis.m/maplabels.tcl:140 ../gui/tcltk/gis.m/maptext.tcl:83
-#: ../gui/tcltk/gis.m/thematic.tcl:145 ../gui/tcltk/gis.m/thematic.tcl:152
+#: ../gui/tcltk/gis.m/maplabels.tcl:140
+#: ../gui/tcltk/gis.m/maptext.tcl:83
+#: ../gui/tcltk/gis.m/thematic.tcl:145
+#: ../gui/tcltk/gis.m/thematic.tcl:152
#: ../gui/tcltk/gis.m/thematic.tcl:158
msgid "This is font sample text."
msgstr "Ceci est un texte d'échntillonnage de police"
msgid "Select label font"
msgstr "Sélectionner la police des étiquettes"
#: ../gui/tcltk/gis.m/maplabels.tcl:163
msgid "Create postscript labels for vector objects from v.labels file"
-msgstr ""
-"Créer un fichier postscript des étiquettes pour les objets vectoriels à "
-"partir d'un fichier et v.labels"
+msgstr "Créer un fichier postscript des étiquettes pour les objets vectoriels à partir d'un fichier et v.labels"
#: ../gui/tcltk/gis.m/maplabels.tcl:170
msgid " (for postscript eps, pdf, and print output only)"
msgstr " (pour le Postscript eps, PDF et sortie d'impression seulement)"
-#: ../gui/tcltk/gis.m/maplabels.tcl:177 ../gui/tcltk/gis.m/labels.tcl:128
+#: ../gui/tcltk/gis.m/maplabels.tcl:177
+#: ../gui/tcltk/gis.m/labels.tcl:128
msgid "Labels file:"
msgstr "Fichier d'étiquettes :"
-#: ../gui/tcltk/gis.m/maplabels.tcl:180 ../gui/tcltk/gis.m/labels.tcl:131
+#: ../gui/tcltk/gis.m/maplabels.tcl:180
+#: ../gui/tcltk/gis.m/labels.tcl:131
msgid "labels file to display"
msgstr "étiquettes de fichier à afficher"
#: ../gui/tcltk/gis.m/maplabels.tcl:189
msgid "Override offset, alignment, and color settings in v.labels file: "
-msgstr ""
-"Ignorer la compensation, l'alignement et les paramètres de couleur dans le "
-"fichier v.labels :"
+msgstr "Ignorer la compensation, l'alignement et les paramètres de couleur dans le fichier v.labels :"
#: ../gui/tcltk/gis.m/maplabels.tcl:196
msgid "Align label with vector object: "
msgstr "Aligner les étiquettes avec l'objet vecteur :"
-#: ../gui/tcltk/gis.m/maplabels.tcl:200 ../gui/tcltk/gis.m/dtext.tcl:213
msgid "lower left"
msgstr "inférieur gauche"
@@ -1661,22 +1881,26 @@
msgid "lower center"
msgstr "inférieur centre"
msgid "lower right"
msgstr "inférieur droit"
msgid "center left"
msgstr "centre gauche"
msgid "center right"
msgstr "centre droit"
msgid "upper left"
msgstr "supérieur gauche"
@@ -1685,7 +1909,8 @@
msgid "upper center"
msgstr "supérieur centre"
msgid "upper right"
msgstr "supérieur droit"
@@ -1758,16 +1983,20 @@
msgid "size:"
msgstr "taille :"
-#: ../gui/tcltk/gis.m/maplabels.tcl:274 ../gui/tcltk/gis.m/dtext.tcl:234
-#: ../gui/tcltk/gis.m/maptext.tcl:190 ../gui/tcltk/d.m/fttext.tcl:149
+#: ../gui/tcltk/gis.m/maplabels.tcl:274
+#: ../gui/tcltk/gis.m/dtext.tcl:234
+#: ../gui/tcltk/gis.m/maptext.tcl:190
+#: ../gui/tcltk/d.m/fttext.tcl:149
msgid " color"
msgstr " couleur"
-#: ../gui/tcltk/gis.m/maplabels.tcl:281 ../gui/tcltk/gis.m/labels.tcl:164
+#: ../gui/tcltk/gis.m/maplabels.tcl:281
+#: ../gui/tcltk/gis.m/labels.tcl:164
msgid "Launch v.label to create labels file"
msgstr "Lancer v.label pour créer un fichier des étiquettes"
-#: ../gui/tcltk/gis.m/maplabels.tcl:282 ../gui/tcltk/gis.m/labels.tcl:165
+#: ../gui/tcltk/gis.m/maplabels.tcl:282
+#: ../gui/tcltk/gis.m/labels.tcl:165
msgid "v.label"
msgstr "v.label"
@@ -1827,7 +2056,8 @@
msgid "Custom paper size"
msgstr "Format personnalisé"
-#: ../gui/tcltk/gis.m/mapprint.tcl:282 ../gui/tcltk/d.m/print.tcl:181
+#: ../gui/tcltk/gis.m/mapprint.tcl:282
+#: ../gui/tcltk/d.m/print.tcl:181
msgid "width:"
msgstr "largeur :"
@@ -1867,9 +2097,12 @@
msgid "Save to PDF file* "
msgstr "Sauvegarder dans un fichier PDF* "
-#: ../gui/tcltk/gis.m/mapprint.tcl:345 ../gui/tcltk/gis.m/mapprint.tcl:357
-#: ../gui/tcltk/d.m/print.tcl:212 ../gui/tcltk/d.m/print.tcl:223
-#: ../gui/tcltk/d.m/print.tcl:234 ../gui/tcltk/d.m/print.tcl:261
+#: ../gui/tcltk/gis.m/mapprint.tcl:345
+#: ../gui/tcltk/gis.m/mapprint.tcl:357
+#: ../gui/tcltk/d.m/print.tcl:212
+#: ../gui/tcltk/d.m/print.tcl:223
+#: ../gui/tcltk/d.m/print.tcl:234
+#: ../gui/tcltk/d.m/print.tcl:261
msgid "Browse"
msgstr "Parcourir"
@@ -1881,7 +2114,8 @@
msgid "*requires ghostscript to be installed and in path"
msgstr "*requiert que Ghostscript soit installé et figure dans le path"
-#: ../gui/tcltk/gis.m/mapprint.tcl:371 ../gui/tcltk/d.m/print.tcl:279
+#: ../gui/tcltk/gis.m/mapprint.tcl:371
+#: ../gui/tcltk/d.m/print.tcl:279
msgid "Print"
msgstr "Imprimer"
@@ -1921,7 +2155,8 @@
msgid "r.univar error"
msgstr "r.univar erreur"
-#: ../gui/tcltk/gis.m/profile.tcl:412 ../gui/tcltk/gis.m/mapcanvas.tcl:493
+#: ../gui/tcltk/gis.m/profile.tcl:412
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:493
msgid "g.proj or projection error"
msgstr "g.proj ou erreur de projection"
@@ -1950,8 +2185,7 @@
"Elevation range for selected raster is zero.\n"
"No profile can be created."
msgstr ""
-"L'échelle des altitudes pour la couche matricielle sélectionnée est égal à "
-"zéro.\n"
+"L'échelle des altitudes pour la couche matricielle sélectionnée est égal à zéro.\n"
"Le profil ne peut être créé."
#: ../gui/tcltk/gis.m/profile.tcl:452
@@ -1962,12 +2196,15 @@
msgid "Error reading region values"
msgstr "Erreur de lecture de la région"
-#: ../gui/tcltk/gis.m/profile.tcl:563 ../gui/tcltk/gis.m/profile.tcl:648
+#: ../gui/tcltk/gis.m/profile.tcl:563
+#: ../gui/tcltk/gis.m/profile.tcl:648
msgid "r.profile error"
msgstr "r.profile erreur"
-#: ../gui/tcltk/gis.m/rastnums.tcl:105 ../gui/tcltk/gis.m/raster.tcl:115
-#: ../gui/tcltk/d.m/menu.tcl:77 ../gui/tcltk/d.m/menu.tcl:113
+#: ../gui/tcltk/gis.m/rastnums.tcl:105
+#: ../gui/tcltk/gis.m/raster.tcl:115
+#: ../gui/tcltk/d.m/menu.tcl:77
+#: ../gui/tcltk/d.m/menu.tcl:113
msgid "Raster map"
msgstr "Couche matricielle"
@@ -1978,8 +2215,7 @@
#: ../gui/tcltk/gis.m/rastnums.tcl:136
msgid "Display cell values from raster map or image"
-msgstr ""
-"Afficher les valeurs des cellules matricielles de la couche ou de l'image"
+msgstr "Afficher les valeurs des cellules matricielles de la couche ou de l'image"
#: ../gui/tcltk/gis.m/rastnums.tcl:142
msgid " (resolution must be 100x100 or less)"
@@ -2003,8 +2239,7 @@
#: ../gui/tcltk/gis.m/rastnums.tcl:198
msgid "use raster colors for cell values"
-msgstr ""
-"utiliser les couleurs de la couche matricielle pour les valeurs de cellules"
+msgstr "utiliser les couleurs de la couche matricielle pour les valeurs de cellules"
#: ../gui/tcltk/gis.m/rastnums.tcl:280
msgid ""
@@ -2021,19 +2256,17 @@
#: ../gui/tcltk/gis.m/rastnums.tcl:286
msgid ""
"Cell values can only be displayed for \n"
-"regions of < 10,000 cells. Map in explore mode may contain more than 10,000 "
-"cells.\n"
+"regions of < 10,000 cells. Map in explore mode may contain more than 10,000 cells.\n"
"\n"
" It's suggested to constrain map to region geometry to display cell values."
msgstr ""
"Les valeurs de cellules ne peuvent être affichées que pour \n"
-"des régions < 10 000 cellules. Une carte en mode exploration peut contenir "
-"plus de 10 000 cellules.\n"
+"des régions < 10 000 cellules. Une carte en mode exploration peut contenir plus de 10 000 cellules.\n"
"\n"
-"Il est conseillé de contraindre la carte à la géométrie de la région pour "
-"afficher les valeurs des cellules."
+"Il est conseillé de contraindre la carte à la géométrie de la région pour afficher les valeurs des cellules."
-#: ../gui/tcltk/gis.m/rastnums.tcl:288 ../gui/tcltk/gis.m/maptool.tcl:327
+#: ../gui/tcltk/gis.m/rastnums.tcl:288
+#: ../gui/tcltk/gis.m/maptool.tcl:327
msgid "Constrain map to region geometry"
msgstr "Contraindre la zone d'affichage à la géométrie de la région"
@@ -2045,11 +2278,13 @@
msgid "Start new map display monitor"
msgstr "Afficher une nouvelle zone d'affichage"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:42 ../gui/tcltk/d.m/tool2.tcl:22
+#: ../gui/tcltk/gis.m/gmtool1.tcl:42
+#: ../gui/tcltk/d.m/tool2.tcl:22
msgid "Add raster layer"
msgstr "Ajouter une couche matricielle"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:49 ../gui/tcltk/d.m/tool2.tcl:28
+#: ../gui/tcltk/gis.m/gmtool1.tcl:49
+#: ../gui/tcltk/d.m/tool2.tcl:28
msgid "Add RGB or HIS layer"
msgstr "Ajouter une couche RGB ou HIS"
@@ -2069,43 +2304,45 @@
msgid "Add raster legend layer"
msgstr "Ajouter une couche matricielle de légende"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:92 ../gui/tcltk/d.m/tool2.tcl:48
+#: ../gui/tcltk/gis.m/gmtool1.tcl:92
+#: ../gui/tcltk/d.m/tool2.tcl:48
msgid "Add vector layer"
msgstr "Ajouter une couche vectorielle"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:99 ../gui/tcltk/d.m/tool2.tcl:62
+#: ../gui/tcltk/gis.m/gmtool1.tcl:99
+#: ../gui/tcltk/d.m/tool2.tcl:62
msgid "Add thematic map layer"
msgstr "Ajouter une couche thématique"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:108 ../gui/tcltk/d.m/tool2.tcl:54
+#: ../gui/tcltk/gis.m/gmtool1.tcl:108
+#: ../gui/tcltk/d.m/tool2.tcl:54
msgid "Add thematic charts layer"
msgstr "Ajouter une couche graphique"
#: ../gui/tcltk/gis.m/gmtool1.tcl:121
msgid "Add raster labels layer (using v.labels file)"
-msgstr ""
-"Ajouter une couche matricielle d'étiquettes (en utilisant un fichier et v."
-"labels)"
+msgstr "Ajouter une couche matricielle d'étiquettes (en utilisant un fichier et v.labels)"
-#: ../gui/tcltk/gis.m/gmtool1.tcl:128 ../gui/tcltk/d.m/tool2.tcl:88
+#: ../gui/tcltk/gis.m/gmtool1.tcl:128
+#: ../gui/tcltk/d.m/tool2.tcl:88
msgid "Add text layer"
msgstr "Ajouter une couche de texte"
#: ../gui/tcltk/gis.m/gmtool1.tcl:135
msgid "Add postscript labels layer (using v.labels file)"
-msgstr ""
-"Ajouter une couche d'étiquettes postscript (en utilisant un fichier et v."
-"labels)"
+msgstr "Ajouter une couche d'étiquettes postscript (en utilisant un fichier et v.labels)"
#: ../gui/tcltk/gis.m/gmtool1.tcl:142
msgid "Add postscript text layer"
msgstr "Ajouter une couche textuelle postscript"
-#: ../gui/tcltk/gis.m/georecttool.tcl:40 ../gui/tcltk/gis.m/maptool.tcl:41
+#: ../gui/tcltk/gis.m/georecttool.tcl:40
+#: ../gui/tcltk/gis.m/maptool.tcl:41
msgid "Display active layers"
msgstr "Afficher les couches actives"
-#: ../gui/tcltk/gis.m/georecttool.tcl:47 ../gui/tcltk/gis.m/maptool.tcl:68
+#: ../gui/tcltk/gis.m/georecttool.tcl:47
+#: ../gui/tcltk/gis.m/maptool.tcl:68
#: ../gui/tcltk/d.m/tool1.tcl:40
msgid "Erase to white"
msgstr "Effacer tout"
@@ -2114,15 +2351,18 @@
msgid "Set ground control points"
msgstr "Fixer les points d'amer"
-#: ../gui/tcltk/gis.m/georecttool.tcl:92 ../gui/tcltk/gis.m/maptool.tcl:113
+#: ../gui/tcltk/gis.m/georecttool.tcl:92
+#: ../gui/tcltk/gis.m/maptool.tcl:113
msgid "Zoom In"
msgstr "Zoom avant"
-#: ../gui/tcltk/gis.m/georecttool.tcl:111 ../gui/tcltk/gis.m/maptool.tcl:132
+#: ../gui/tcltk/gis.m/georecttool.tcl:111
+#: ../gui/tcltk/gis.m/maptool.tcl:132
msgid "Zoom Out"
-#: ../gui/tcltk/gis.m/georecttool.tcl:144 ../gui/tcltk/gis.m/maptool.tcl:165
+#: ../gui/tcltk/gis.m/georecttool.tcl:144
+#: ../gui/tcltk/gis.m/maptool.tcl:165
#: ../gui/tcltk/d.m/tool1.tcl:87
msgid "Return to previous zoom"
msgstr "Revenir au zoom précédent"
@@ -2131,7 +2371,8 @@
msgid "Zoom to map"
msgstr "Zomme sur la carte"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:85 ../gui/tcltk/d.m/menu.tcl:75
+#: ../gui/tcltk/gis.m/gmmenu.tcl:85
+#: ../gui/tcltk/d.m/menu.tcl:75
msgid "&File"
msgstr "&Fichier"
@@ -2139,16 +2380,19 @@
msgid "Workspace"
msgstr "&Espace de travail"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:87 ../gui/tcltk/d.m/menu.tcl:173
+#: ../gui/tcltk/gis.m/gmmenu.tcl:87
+#: ../gui/tcltk/d.m/menu.tcl:173
msgid "Open..."
msgstr "Ouvrir..."
-#: ../gui/tcltk/gis.m/gmmenu.tcl:88 ../gui/tcltk/gis.m/mapcanvas.tcl:925
+#: ../gui/tcltk/gis.m/gmmenu.tcl:88
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:925
#: ../gui/tcltk/d.m/menu.tcl:174
msgid "Save"
msgstr "Sauvegarder"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:89 ../gui/tcltk/d.m/menu.tcl:175
+#: ../gui/tcltk/gis.m/gmmenu.tcl:89
+#: ../gui/tcltk/d.m/menu.tcl:175
msgid "Save as..."
msgstr "Enregistrer sous..."
@@ -2156,8 +2400,10 @@
msgid "Import raster map"
msgstr "Importer une couche &matricielle"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:94 ../gui/tcltk/gis.m/gmmenu.tcl:133
-#: ../gui/tcltk/d.m/menu.tcl:78 ../gui/tcltk/d.m/menu.tcl:114
+#: ../gui/tcltk/gis.m/gmmenu.tcl:94
+#: ../gui/tcltk/gis.m/gmmenu.tcl:133
+#: ../gui/tcltk/d.m/menu.tcl:78
+#: ../gui/tcltk/d.m/menu.tcl:114
msgid "Multiple formats using GDAL"
msgstr "Formats multiples avec GDAL"
@@ -2169,7 +2415,8 @@
msgid "Aggregate ASCII xyz"
msgstr "ASCII x,y,z"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:98 ../gui/tcltk/gis.m/gmmenu.tcl:135
+#: ../gui/tcltk/gis.m/gmmenu.tcl:98
+#: ../gui/tcltk/gis.m/gmmenu.tcl:135
msgid "ASCII grid"
msgstr "Grille ASCII"
@@ -2177,7 +2424,8 @@
msgid "ASCII polygons and lines"
msgstr "Polygones et lignes ASCII"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:101 ../gui/tcltk/gis.m/gmmenu.tcl:142
+#: ../gui/tcltk/gis.m/gmmenu.tcl:101
+#: ../gui/tcltk/gis.m/gmmenu.tcl:142
msgid "Binary"
msgstr "Fichier binaire"
@@ -2185,11 +2433,13 @@
msgid "ESRI grid"
msgstr "Grille ESRI"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:103 ../gui/tcltk/gis.m/gmmenu.tcl:139
+#: ../gui/tcltk/gis.m/gmmenu.tcl:103
+#: ../gui/tcltk/gis.m/gmmenu.tcl:139
msgid "GRIDATB.FOR"
msgstr "Fichier GRIDATB.FOR"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:104 ../gui/tcltk/gis.m/gmmenu.tcl:140
+#: ../gui/tcltk/gis.m/gmmenu.tcl:104
+#: ../gui/tcltk/gis.m/gmmenu.tcl:140
msgid "MAT-File (v.4)"
msgstr "MAT-File (v.4)"
@@ -2205,7 +2455,8 @@
msgid "Terra ASTER"
msgstr "Terra ASTER HDF"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:109 ../gui/tcltk/d.m/menu.tcl:92
+#: ../gui/tcltk/gis.m/gmmenu.tcl:109
+#: ../gui/tcltk/d.m/menu.tcl:92
msgid "Web Mapping Server"
msgstr "Web Mapping Server (WMS)"
@@ -2213,11 +2464,13 @@
msgid "Import vector map"
msgstr "Importer une couche &vectorielle"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:112 ../gui/tcltk/gis.m/gmmenu.tcl:154
+#: ../gui/tcltk/gis.m/gmmenu.tcl:112
+#: ../gui/tcltk/gis.m/gmmenu.tcl:154
msgid "Multiple formats using OGR"
msgstr "Formats multiples avec OGR"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:114 ../gui/tcltk/gis.m/gmmenu.tcl:156
+#: ../gui/tcltk/gis.m/gmmenu.tcl:114
+#: ../gui/tcltk/gis.m/gmmenu.tcl:156
msgid "ASCII points or GRASS ASCII vector"
msgstr "Fichier de points ASCII ou fichier vectoriel GRASS ASCII"
@@ -2229,7 +2482,8 @@
msgid "Old GRASS vector"
msgstr "Ancien format vectoriel GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:118 ../gui/tcltk/gis.m/gmmenu.tcl:157
+#: ../gui/tcltk/gis.m/gmmenu.tcl:118
+#: ../gui/tcltk/gis.m/gmmenu.tcl:157
msgid "DXF"
msgstr "DXF"
@@ -2261,11 +2515,13 @@
msgid "Import grid 3D volume"
msgstr "Importer un volume grid&3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:127 ../gui/tcltk/gis.m/gmmenu.tcl:164
+#: ../gui/tcltk/gis.m/gmmenu.tcl:127
+#: ../gui/tcltk/gis.m/gmmenu.tcl:164
msgid "ASCII 3D"
msgstr "ASCII 3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:128 ../gui/tcltk/gis.m/gmmenu.tcl:165
+#: ../gui/tcltk/gis.m/gmmenu.tcl:128
+#: ../gui/tcltk/gis.m/gmmenu.tcl:165
msgid "Vis5D"
msgstr "Vis5D"
@@ -2301,7 +2557,8 @@
msgid "PPM from RGB"
msgstr "PPM depuis RVB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:148 ../gui/tcltk/gis.m/gmmenu.tcl:159
+#: ../gui/tcltk/gis.m/gmmenu.tcl:148
+#: ../gui/tcltk/gis.m/gmmenu.tcl:159
msgid "POV-Ray"
msgstr "POV-Ray"
@@ -2313,7 +2570,8 @@
msgid "VRML"
msgstr "VRML"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:151 ../gui/tcltk/gis.m/gmmenu.tcl:161
+#: ../gui/tcltk/gis.m/gmmenu.tcl:151
+#: ../gui/tcltk/gis.m/gmmenu.tcl:161
#: ../gui/tcltk/gis.m/gmmenu.tcl:166
msgid "VTK"
msgstr "VTK"
@@ -2322,11 +2580,13 @@
msgid "Export vector map"
msgstr "Exporter une couche ve&ctorielle"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:158 ../gui/tcltk/d.m/menu.tcl:139
+#: ../gui/tcltk/gis.m/gmmenu.tcl:158
+#: ../gui/tcltk/d.m/menu.tcl:139
msgid "Multiple GPS formats using GPSBabel"
msgstr "Formats GPS multiples avec GPSBabel"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:160 ../gui/tcltk/d.m/menu.tcl:141
+#: ../gui/tcltk/gis.m/gmmenu.tcl:160
+#: ../gui/tcltk/d.m/menu.tcl:141
msgid "SVG"
msgstr "SVG"
@@ -2338,7 +2598,8 @@
msgid "Export data table"
msgstr "Exporter une table de données"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:170 ../gui/tcltk/d.m/menu.tcl:151
+#: ../gui/tcltk/gis.m/gmmenu.tcl:170
+#: ../gui/tcltk/d.m/menu.tcl:151
msgid "Manage maps and volumes"
msgstr "&Gérer couches et volumes"
@@ -2358,7 +2619,8 @@
msgid "Delete filtered"
msgstr "Suppression filtrée"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:181 ../gui/tcltk/d.m/menu.tcl:159
+#: ../gui/tcltk/gis.m/gmmenu.tcl:181
+#: ../gui/tcltk/d.m/menu.tcl:159
msgid "Map type conversions"
msgstr "&Conversions couches et volume"
@@ -2374,7 +2636,8 @@
msgid "Raster 2.5D to volume"
msgstr "Matricielle 2.5D vers volume"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:186 ../gui/tcltk/d.m/menu.tcl:163
+#: ../gui/tcltk/gis.m/gmmenu.tcl:186
+#: ../gui/tcltk/d.m/menu.tcl:163
msgid "Vector to raster"
msgstr "Vectorielle vers matricielle"
@@ -2426,23 +2689,28 @@
msgid "&Quit GIS Manager"
msgstr "&Quitter le gestionnaire des couches"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:208 ../gui/tcltk/d.m/menu.tcl:188
+#: ../gui/tcltk/gis.m/gmmenu.tcl:208
+#: ../gui/tcltk/d.m/menu.tcl:188
msgid "&Config"
msgstr "&Config"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:209 ../gui/tcltk/d.m/menu.tcl:189
+#: ../gui/tcltk/gis.m/gmmenu.tcl:209
+#: ../gui/tcltk/d.m/menu.tcl:189
msgid "Region"
msgstr "&Région"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:210 ../gui/tcltk/d.m/menu.tcl:190
+#: ../gui/tcltk/gis.m/gmmenu.tcl:210
+#: ../gui/tcltk/d.m/menu.tcl:190
msgid "Display region settings"
msgstr "Afficher les réglages de la région"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:211 ../gui/tcltk/d.m/menu.tcl:191
+#: ../gui/tcltk/gis.m/gmmenu.tcl:211
+#: ../gui/tcltk/d.m/menu.tcl:191
msgid "Change region settings"
msgstr "Changer les réglages de la région"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:213 ../gui/tcltk/d.m/menu.tcl:194
+#: ../gui/tcltk/gis.m/gmmenu.tcl:213
+#: ../gui/tcltk/d.m/menu.tcl:194
msgid "GRASS working environment"
msgstr "&Environnement GRASS"
@@ -2466,15 +2734,18 @@
msgid "Change settings"
msgstr "Modifier les réglages"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:219 ../gui/tcltk/d.m/menu.tcl:200
+#: ../gui/tcltk/gis.m/gmmenu.tcl:219
+#: ../gui/tcltk/d.m/menu.tcl:200
msgid "Change default GUI"
msgstr "Changer l'interface par défaut"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:220 ../gui/tcltk/d.m/menu.tcl:201
+#: ../gui/tcltk/gis.m/gmmenu.tcl:220
+#: ../gui/tcltk/d.m/menu.tcl:201
msgid "Show current GRASS version"
msgstr "Afficher la version courante de GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:222 ../gui/tcltk/gis.m/gmmenu.tcl:223
+#: ../gui/tcltk/gis.m/gmmenu.tcl:222
+#: ../gui/tcltk/gis.m/gmmenu.tcl:223
#: ../gui/tcltk/d.m/menu.tcl:203
msgid "Manage projections"
msgstr "&Gérer les projections"
@@ -2491,16 +2762,20 @@
msgid "Display font"
msgstr "&Police d'affichage"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:230 ../gui/tcltk/d.m/menu.tcl:221
+#: ../gui/tcltk/gis.m/gmmenu.tcl:230
+#: ../gui/tcltk/d.m/menu.tcl:221
msgid "&Raster"
msgstr "&Matrice"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:231 ../gui/tcltk/gis.m/gmmenu.tcl:438
-#: ../gui/tcltk/d.m/menu.tcl:222 ../gui/tcltk/d.m/menu.tcl:381
+#: ../gui/tcltk/gis.m/gmmenu.tcl:231
+#: ../gui/tcltk/gis.m/gmmenu.tcl:438
+#: ../gui/tcltk/d.m/menu.tcl:222
+#: ../gui/tcltk/d.m/menu.tcl:381
msgid "Develop map"
msgstr "&Développer une couche"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:232 ../gui/tcltk/d.m/menu.tcl:223
+#: ../gui/tcltk/gis.m/gmmenu.tcl:232
+#: ../gui/tcltk/d.m/menu.tcl:223
msgid "Digitize raster"
msgstr "Digitaliser une couche matricielle"
@@ -2524,7 +2799,8 @@
msgid "Timestamps"
msgstr "Timbres horaires (timestamps)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:245 ../gui/tcltk/d.m/menu.tcl:234
+#: ../gui/tcltk/gis.m/gmmenu.tcl:245
+#: ../gui/tcltk/d.m/menu.tcl:234
msgid "Resample using aggregate statistics"
msgstr "Rééchantillonner par agrégats statistiques"
@@ -2556,7 +2832,8 @@
msgid "Tiling"
msgstr "Mosaïquer"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:256 ../gui/tcltk/d.m/menu.tcl:243
+#: ../gui/tcltk/gis.m/gmmenu.tcl:256
+#: ../gui/tcltk/d.m/menu.tcl:243
msgid "Manage map colors"
msgstr "&Gérer les couleurs de la couche"
@@ -2580,7 +2857,8 @@
msgid "Create RGB"
msgstr "Créer RVB"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:263 ../gui/tcltk/gis.m/gmmenu.tcl:561
+#: ../gui/tcltk/gis.m/gmmenu.tcl:263
+#: ../gui/tcltk/gis.m/gmmenu.tcl:561
msgid "HIS to RGB"
msgstr "TVS vers RVB"
@@ -2588,7 +2866,8 @@
msgid "Query raster color"
msgstr "Interroger une carte 'raster'"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:268 ../gui/tcltk/d.m/menu.tcl:253
+#: ../gui/tcltk/gis.m/gmmenu.tcl:268
+#: ../gui/tcltk/d.m/menu.tcl:253
#: ../gui/tcltk/d.m/menu.tcl:409
msgid "Query by coordinate(s)"
msgstr "&Interroger la couche"
@@ -2605,11 +2884,13 @@
msgid "MASK"
msgstr "&Masque de couche"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:273 ../gui/tcltk/d.m/menu.tcl:258
+#: ../gui/tcltk/gis.m/gmmenu.tcl:273
+#: ../gui/tcltk/d.m/menu.tcl:258
msgid "Map calculator"
msgstr "&Calculateur de couche"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:274 ../gui/tcltk/d.m/menu.tcl:259
+#: ../gui/tcltk/gis.m/gmmenu.tcl:274
+#: ../gui/tcltk/d.m/menu.tcl:259
#: ../gui/tcltk/d.m/menu.tcl:419
msgid "Neighborhood analysis"
msgstr "&Analyse de voisinage"
@@ -2622,12 +2903,15 @@
msgid "Neighborhood points"
msgstr "Points voisins"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:278 ../gui/tcltk/gis.m/gmmenu.tcl:504
-#: ../gui/tcltk/d.m/menu.tcl:263 ../gui/tcltk/d.m/menu.tcl:433
+#: ../gui/tcltk/gis.m/gmmenu.tcl:278
+#: ../gui/tcltk/gis.m/gmmenu.tcl:504
+#: ../gui/tcltk/d.m/menu.tcl:263
+#: ../gui/tcltk/d.m/menu.tcl:433
msgid "Overlay maps"
msgstr "&Superposer des couches"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:279 ../gui/tcltk/d.m/menu.tcl:264
+#: ../gui/tcltk/gis.m/gmmenu.tcl:279
+#: ../gui/tcltk/d.m/menu.tcl:264
msgid "Cross product"
msgstr "Produit en croix"
@@ -2635,7 +2919,8 @@
msgid "Map series"
msgstr "Série de cartes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:281 ../gui/tcltk/d.m/menu.tcl:266
+#: ../gui/tcltk/gis.m/gmmenu.tcl:281
+#: ../gui/tcltk/d.m/menu.tcl:266
msgid "Patch maps"
msgstr "Assembler des cartes"
@@ -2643,7 +2928,8 @@
msgid "Statistical overlay"
msgstr "Recouvrement statistique"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:285 ../gui/tcltk/d.m/menu.tcl:270
+#: ../gui/tcltk/gis.m/gmmenu.tcl:285
+#: ../gui/tcltk/d.m/menu.tcl:270
msgid "Solar radiance and shadows"
msgstr "&Rayonnement solaire et ombrage"
@@ -2655,7 +2941,8 @@
msgid "Shadows map"
msgstr "Carte des ombres"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:289 ../gui/tcltk/d.m/menu.tcl:274
+#: ../gui/tcltk/gis.m/gmmenu.tcl:289
+#: ../gui/tcltk/d.m/menu.tcl:274
msgid "Terrain analysis"
msgstr "A&nalyse de terrain"
@@ -2663,11 +2950,13 @@
msgid "Cumulative movement costs"
msgstr "Coûts de déplacement cumulés"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:291 ../gui/tcltk/d.m/menu.tcl:276
+#: ../gui/tcltk/gis.m/gmmenu.tcl:291
+#: ../gui/tcltk/d.m/menu.tcl:276
msgid "Cost surface"
msgstr "Surface de coût"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:292 ../gui/tcltk/d.m/menu.tcl:277
+#: ../gui/tcltk/gis.m/gmmenu.tcl:292
+#: ../gui/tcltk/d.m/menu.tcl:277
msgid "Least cost route or flow"
msgstr "Plus court chemin ou flux"
@@ -2675,15 +2964,18 @@
msgid "Shaded relief"
msgstr "Ombrage"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:296 ../gui/tcltk/d.m/menu.tcl:280
+#: ../gui/tcltk/gis.m/gmmenu.tcl:296
+#: ../gui/tcltk/d.m/menu.tcl:280
msgid "Slope and aspect"
msgstr "Pente et exposition"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:297 ../gui/tcltk/d.m/menu.tcl:281
+#: ../gui/tcltk/gis.m/gmmenu.tcl:297
+#: ../gui/tcltk/d.m/menu.tcl:281
msgid "Terrain parameters"
msgstr "Paramètres de terrain"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:298 ../gui/tcltk/d.m/menu.tcl:282
+#: ../gui/tcltk/gis.m/gmmenu.tcl:298
+#: ../gui/tcltk/d.m/menu.tcl:282
msgid "Textural features"
msgstr "Objets de texture"
@@ -2691,7 +2983,8 @@
msgid "Visibility"
msgstr "Visibilité"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:301 ../gui/tcltk/d.m/menu.tcl:284
+#: ../gui/tcltk/gis.m/gmmenu.tcl:301
+#: ../gui/tcltk/d.m/menu.tcl:284
msgid "Distance to features"
msgstr "Distance de l'objet"
@@ -2699,7 +2992,8 @@
msgid "Horizon"
msgstr "Horizon"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:305 ../gui/tcltk/d.m/menu.tcl:286
+#: ../gui/tcltk/gis.m/gmmenu.tcl:305
+#: ../gui/tcltk/d.m/menu.tcl:286
msgid "Transform features"
msgstr "&Transformer des objets"
@@ -2715,7 +3009,8 @@
msgid "Thin"
msgstr "Affiner"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:311 ../gui/tcltk/d.m/menu.tcl:292
+#: ../gui/tcltk/gis.m/gmmenu.tcl:311
+#: ../gui/tcltk/d.m/menu.tcl:292
msgid "Hydrologic modeling"
msgstr "&Modélisation hydrologique"
@@ -2739,11 +3034,13 @@
msgid "Flow lines"
msgstr "Lignes de flux"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:319 ../gui/tcltk/gis.m/gmmenu.tcl:612
+#: ../gui/tcltk/gis.m/gmmenu.tcl:319
+#: ../gui/tcltk/gis.m/gmmenu.tcl:612
msgid "Groundwater flow model"
msgstr "&Modèle de flux des eaux souterraines"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:321 ../gui/tcltk/d.m/menu.tcl:298
+#: ../gui/tcltk/gis.m/gmmenu.tcl:321
+#: ../gui/tcltk/d.m/menu.tcl:298
msgid "SIMWE overland flow modeling"
msgstr "Modélisation SIM&WE de l'écoulement de surface"
@@ -2751,27 +3048,33 @@
msgid "SIMWE sediment flux modeling"
msgstr "Modélisation SIMWE des flu&x de sédiments"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:324 ../gui/tcltk/d.m/menu.tcl:300
+#: ../gui/tcltk/gis.m/gmmenu.tcl:324
+#: ../gui/tcltk/d.m/menu.tcl:300
msgid "Topographic index map"
msgstr "Index des cartes topographiques"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:325 ../gui/tcltk/d.m/menu.tcl:301
+#: ../gui/tcltk/gis.m/gmmenu.tcl:325
+#: ../gui/tcltk/d.m/menu.tcl:301
msgid "TOPMODEL simulation"
msgstr "Simulation TOPMODEL"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:327 ../gui/tcltk/d.m/menu.tcl:302
+#: ../gui/tcltk/gis.m/gmmenu.tcl:327
+#: ../gui/tcltk/d.m/menu.tcl:302
msgid "Watershed subbasins"
msgstr "Sous-bassins versants"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:328 ../gui/tcltk/d.m/menu.tcl:303
+#: ../gui/tcltk/gis.m/gmmenu.tcl:328
+#: ../gui/tcltk/d.m/menu.tcl:303
msgid "Watershed analysis"
msgstr "Analyse de bassin versant"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:329 ../gui/tcltk/d.m/menu.tcl:304
+#: ../gui/tcltk/gis.m/gmmenu.tcl:329
+#: ../gui/tcltk/d.m/menu.tcl:304
msgid "Watershed basin creation"
msgstr "Création de bassin versant"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:331 ../gui/tcltk/d.m/menu.tcl:306
+#: ../gui/tcltk/gis.m/gmmenu.tcl:331
+#: ../gui/tcltk/d.m/menu.tcl:306
msgid "Landscape structure modeling"
msgstr "Modélisation de la structure du pa&ysage"
@@ -2795,7 +3098,8 @@
msgid "Landscape patch analysis"
msgstr "Correcti&f d'analyse de paysage"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:347 ../gui/tcltk/d.m/menu.tcl:307
+#: ../gui/tcltk/gis.m/gmmenu.tcl:347
+#: ../gui/tcltk/d.m/menu.tcl:307
msgid "Set up sampling and analysis framework"
msgstr "Mettre en place l'échantillonnage et l'analyse"
@@ -2851,7 +3155,8 @@
msgid "Shape index"
msgstr "Indice de forme"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:366 ../gui/tcltk/d.m/menu.tcl:313
+#: ../gui/tcltk/gis.m/gmmenu.tcl:366
+#: ../gui/tcltk/d.m/menu.tcl:313
msgid "Wildfire modeling"
msgstr "Modélisation des feu&x naturels"
@@ -2867,7 +3172,8 @@
msgid "Anisotropic spread simulation"
msgstr "Simulation de diffusion anisotrope"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:372 ../gui/tcltk/d.m/menu.tcl:319
+#: ../gui/tcltk/gis.m/gmmenu.tcl:372
+#: ../gui/tcltk/d.m/menu.tcl:319
msgid "Change category values and labels"
msgstr "Changement des &valeurs de catégories et des étiquettes"
@@ -2883,7 +3189,8 @@
msgid "Reclassify interactively"
msgstr "Reclasser de façon interactive"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:377 ../gui/tcltk/gis.m/gmmenu.tcl:512
+#: ../gui/tcltk/gis.m/gmmenu.tcl:377
+#: ../gui/tcltk/gis.m/gmmenu.tcl:512
msgid "Reclassify using rules file"
msgstr "Reclasser en utilisant un fichier de règles"
@@ -2907,7 +3214,8 @@
msgid "Concentric circles"
msgstr "Cercles concentri&ques"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:387 ../gui/tcltk/d.m/menu.tcl:336
+#: ../gui/tcltk/gis.m/gmmenu.tcl:387
+#: ../gui/tcltk/d.m/menu.tcl:336
msgid "Generate random cells"
msgstr "Générer des ce&llules aléatoires"
@@ -2919,7 +3227,8 @@
msgid "Random cells and vector points"
msgstr "Cellules aléatoires et points vectoriels"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:391 ../gui/tcltk/d.m/menu.tcl:339
+#: ../gui/tcltk/gis.m/gmmenu.tcl:391
+#: ../gui/tcltk/d.m/menu.tcl:339
msgid "Generate surfaces"
msgstr "Gé&nération de surfaces"
@@ -2951,7 +3260,8 @@
msgid "Contour lines"
msgstr "Courbes de ni&veau"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:403 ../gui/tcltk/d.m/menu.tcl:348
+#: ../gui/tcltk/gis.m/gmmenu.tcl:403
+#: ../gui/tcltk/d.m/menu.tcl:348
msgid "Interpolate surfaces"
msgstr "Int&erpolation de surfaces"
@@ -2983,13 +3293,17 @@
msgid "Fill NULL cells"
msgstr "Remplir les cellules NULL"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:416 ../gui/tcltk/gis.m/gmmenu.tcl:539
-#: ../gui/tcltk/gis.m/gmmenu.tcl:598 ../gui/tcltk/d.m/menu.tcl:359
-#: ../gui/tcltk/d.m/menu.tcl:465 ../gui/tcltk/d.m/menu.tcl:521
+#: ../gui/tcltk/gis.m/gmmenu.tcl:416
+#: ../gui/tcltk/gis.m/gmmenu.tcl:539
+#: ../gui/tcltk/gis.m/gmmenu.tcl:598
+#: ../gui/tcltk/d.m/menu.tcl:359
+#: ../gui/tcltk/d.m/menu.tcl:465
+#: ../gui/tcltk/d.m/menu.tcl:521
msgid "Reports and statistics"
msgstr "Rapp&orts et statistiques"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:417 ../gui/tcltk/d.m/menu.tcl:360
+#: ../gui/tcltk/gis.m/gmmenu.tcl:417
+#: ../gui/tcltk/d.m/menu.tcl:360
#: ../gui/tcltk/d.m/menu.tcl:522
msgid "Report basic file information"
msgstr "Renvoyer l'information de base du fichier"
@@ -2998,7 +3312,8 @@
msgid "Manage category information"
msgstr "Gérer les informations de catégories"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:420 ../gui/tcltk/gis.m/gmmenu.tcl:616
+#: ../gui/tcltk/gis.m/gmmenu.tcl:420
+#: ../gui/tcltk/gis.m/gmmenu.tcl:616
#: ../gui/tcltk/d.m/menu.tcl:363
msgid "General statistics"
msgstr "Statistiques générales"
@@ -3015,7 +3330,8 @@
msgid "Sum cell category values"
msgstr "Somme des valeurs de catégories de cellules"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:424 ../gui/tcltk/d.m/menu.tcl:366
+#: ../gui/tcltk/gis.m/gmmenu.tcl:424
+#: ../gui/tcltk/d.m/menu.tcl:366
msgid "Sum area by map and category"
msgstr "Somme des aires par zone géographique et par catégorie"
@@ -3023,12 +3339,15 @@
msgid "Statistics for clumped cells (works with r.clump)"
msgstr "Statistiques de grumeaux de cellules (fonctionne avec r.clump)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:426 ../gui/tcltk/d.m/menu.tcl:368
+#: ../gui/tcltk/gis.m/gmmenu.tcl:426
+#: ../gui/tcltk/d.m/menu.tcl:368
msgid "Total surface area corrected for topography"
msgstr "Surface totale corrigée pour la topographie"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:427 ../gui/tcltk/gis.m/gmmenu.tcl:617
-#: ../gui/tcltk/gis.m/gmmenu.tcl:655 ../gui/tcltk/d.m/menu.tcl:369
+#: ../gui/tcltk/gis.m/gmmenu.tcl:427
+#: ../gui/tcltk/gis.m/gmmenu.tcl:617
+#: ../gui/tcltk/gis.m/gmmenu.tcl:655
+#: ../gui/tcltk/d.m/menu.tcl:369
#: ../gui/tcltk/d.m/menu.tcl:469
msgid "Univariate statistics"
msgstr "Statistiques univariées"
@@ -3041,7 +3360,8 @@
msgid "Sample transects (bearing/distance)"
msgstr "Exemple de transects (parcours/distance)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:432 ../gui/tcltk/d.m/menu.tcl:375
+#: ../gui/tcltk/gis.m/gmmenu.tcl:432
+#: ../gui/tcltk/d.m/menu.tcl:375
msgid "Covariance/correlation"
msgstr "Covariance/corrélation"
@@ -3053,11 +3373,13 @@
msgid "Mutual category occurences"
msgstr "Occurrence des catégories mutuelles"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:437 ../gui/tcltk/d.m/menu.tcl:380
+#: ../gui/tcltk/gis.m/gmmenu.tcl:437
+#: ../gui/tcltk/d.m/menu.tcl:380
msgid "&Vector"
msgstr "&Vecteur"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:439 ../gui/tcltk/d.m/menu.tcl:382
+#: ../gui/tcltk/gis.m/gmmenu.tcl:439
+#: ../gui/tcltk/d.m/menu.tcl:382
msgid "Digitize"
msgstr "Numériser"
@@ -3065,7 +3387,8 @@
msgid "Edit features"
msgstr "Editer les caractéristiques"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:442 ../gui/tcltk/d.m/menu.tcl:384
+#: ../gui/tcltk/gis.m/gmmenu.tcl:442
+#: ../gui/tcltk/d.m/menu.tcl:384
msgid "Create/rebuild topology"
msgstr "Créer/reconstruire la topologie"
@@ -3197,15 +3520,18 @@
msgid "Nearest features"
msgstr "Caractéristi&ques les plus proches"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:490 ../gui/tcltk/d.m/menu.tcl:424
+#: ../gui/tcltk/gis.m/gmmenu.tcl:490
+#: ../gui/tcltk/d.m/menu.tcl:424
msgid "Network analysis"
msgstr "Anal&yse de réseau"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:491 ../gui/tcltk/d.m/menu.tcl:425
+#: ../gui/tcltk/gis.m/gmmenu.tcl:491
+#: ../gui/tcltk/d.m/menu.tcl:425
msgid "Allocate subnets"
msgstr "Allouer des sous-réseaux"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:492 ../gui/tcltk/d.m/menu.tcl:426
+#: ../gui/tcltk/gis.m/gmmenu.tcl:492
+#: ../gui/tcltk/d.m/menu.tcl:426
msgid "Network maintenance"
msgstr "Maintenance du réseaux"
@@ -3213,7 +3539,8 @@
msgid "Visibility network"
msgstr "Réseau visible"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:494 ../gui/tcltk/d.m/menu.tcl:427
+#: ../gui/tcltk/gis.m/gmmenu.tcl:494
+#: ../gui/tcltk/d.m/menu.tcl:427
msgid "Shortest route"
msgstr "Plus court chemin"
@@ -3225,11 +3552,13 @@
msgid "Split net"
msgstr "Diviser"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:501 ../gui/tcltk/d.m/menu.tcl:430
+#: ../gui/tcltk/gis.m/gmmenu.tcl:501
+#: ../gui/tcltk/d.m/menu.tcl:430
msgid "Steiner tree"
msgstr "Arbre de Steiner"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:502 ../gui/tcltk/d.m/menu.tcl:431
+#: ../gui/tcltk/gis.m/gmmenu.tcl:502
+#: ../gui/tcltk/d.m/menu.tcl:431
msgid "Traveling salesman analysis"
msgstr "Analyse de type voyageur de commerce"
@@ -3241,7 +3570,8 @@
msgid "Patch (combine)"
msgstr "Assembler de multiples couches (combinaison)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:509 ../gui/tcltk/d.m/menu.tcl:440
+#: ../gui/tcltk/gis.m/gmmenu.tcl:509
+#: ../gui/tcltk/d.m/menu.tcl:440
msgid "Change attributes"
msgstr "Chan&ger les attributs"
@@ -3257,7 +3587,8 @@
msgid "Generate area for current region"
msgstr "Générer une surface pour la région couran&te"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:516 ../gui/tcltk/d.m/menu.tcl:451
+#: ../gui/tcltk/gis.m/gmmenu.tcl:516
+#: ../gui/tcltk/d.m/menu.tcl:451
msgid "Generate areas from points"
msgstr "Générer l'aire à &partir des points"
@@ -3277,7 +3608,8 @@
msgid "Generate grid"
msgstr "Générer une gr&ille"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:522 ../gui/tcltk/d.m/menu.tcl:446
+#: ../gui/tcltk/gis.m/gmmenu.tcl:522
+#: ../gui/tcltk/d.m/menu.tcl:446
msgid "Generate points"
msgstr "Générer &des points"
@@ -3289,7 +3621,8 @@
msgid "Generate points along lines"
msgstr "Générer des points le long des lignes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:525 ../gui/tcltk/d.m/menu.tcl:448
+#: ../gui/tcltk/gis.m/gmmenu.tcl:525
+#: ../gui/tcltk/d.m/menu.tcl:448
msgid "Generate random points"
msgstr "Générer des points aléatoires"
@@ -3317,15 +3650,18 @@
msgid "Update point attributes from raster"
msgstr "Mise à jour des attrib&uts de points depuis la couche matricielle"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:535 ../gui/tcltk/d.m/menu.tcl:458
+#: ../gui/tcltk/gis.m/gmmenu.tcl:535
+#: ../gui/tcltk/d.m/menu.tcl:458
msgid "Sample raster map at point locations"
msgstr "Échantillonner une couche matricielle aux emplacements des points"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:536 ../gui/tcltk/d.m/menu.tcl:459
+#: ../gui/tcltk/gis.m/gmmenu.tcl:536
+#: ../gui/tcltk/d.m/menu.tcl:459
msgid "Sample raster neighborhood around points"
msgstr "Échantillonner le voisinage de la couche matricielle autour des points"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:540 ../gui/tcltk/gis.m/gmmenu.tcl:615
+#: ../gui/tcltk/gis.m/gmmenu.tcl:540
+#: ../gui/tcltk/gis.m/gmmenu.tcl:615
#: ../gui/tcltk/d.m/menu.tcl:466
msgid "Basic information"
msgstr "Information de base"
@@ -3354,11 +3690,13 @@
msgid "Test normality"
msgstr "Test de normalité"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:552 ../gui/tcltk/d.m/menu.tcl:476
+#: ../gui/tcltk/gis.m/gmmenu.tcl:552
+#: ../gui/tcltk/d.m/menu.tcl:476
msgid "&Imagery"
msgstr "&Image"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:553 ../gui/tcltk/d.m/menu.tcl:477
+#: ../gui/tcltk/gis.m/gmmenu.tcl:553
+#: ../gui/tcltk/d.m/menu.tcl:477
msgid "Develop images and groups"
msgstr "&Développer images et groupes"
@@ -3374,7 +3712,8 @@
msgid "Mosaic images"
msgstr "Images en mosaïque"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:559 ../gui/tcltk/d.m/menu.tcl:483
+#: ../gui/tcltk/gis.m/gmmenu.tcl:559
+#: ../gui/tcltk/d.m/menu.tcl:483
msgid "Manage image colors"
msgstr "&Gérer les couleurs d'image"
@@ -3386,7 +3725,8 @@
msgid "RGB to HIS"
msgstr "RVB vers TVS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:564 ../gui/tcltk/d.m/menu.tcl:494
+#: ../gui/tcltk/gis.m/gmmenu.tcl:564
+#: ../gui/tcltk/d.m/menu.tcl:494
msgid "Ortho photo rectification"
msgstr "&Recalage type orthophoto"
@@ -3394,23 +3734,28 @@
msgid "Brovey sharpening"
msgstr "Transformée de &Brovey"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:571 ../gui/tcltk/d.m/menu.tcl:498
+#: ../gui/tcltk/gis.m/gmmenu.tcl:571
+#: ../gui/tcltk/d.m/menu.tcl:498
msgid "Classify image"
msgstr "&Classification d'image"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:572 ../gui/tcltk/d.m/menu.tcl:499
+#: ../gui/tcltk/gis.m/gmmenu.tcl:572
+#: ../gui/tcltk/d.m/menu.tcl:499
msgid "Clustering input for unsupervised classification"
msgstr "Regroupement pour classification non supervisée"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:574 ../gui/tcltk/d.m/menu.tcl:501
+#: ../gui/tcltk/gis.m/gmmenu.tcl:574
+#: ../gui/tcltk/d.m/menu.tcl:501
msgid "Maximum likelihood classification (MLC)"
msgstr "Classification par maximum de vraisemblance (MLC)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:575 ../gui/tcltk/d.m/menu.tcl:502
+#: ../gui/tcltk/gis.m/gmmenu.tcl:575
+#: ../gui/tcltk/d.m/menu.tcl:502
msgid "Sequential maximum a posteriory classification (SMAP)"
msgstr "Classification séquentielle de maximum à posteriori (SMAP)"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:577 ../gui/tcltk/d.m/menu.tcl:504
+#: ../gui/tcltk/gis.m/gmmenu.tcl:577
+#: ../gui/tcltk/d.m/menu.tcl:504
msgid "Interactive input for supervised classification"
msgstr "Entrée interactive pour classification supervisée"
@@ -3422,7 +3767,8 @@
msgid "Input for supervised SMAP"
msgstr "Entrée pour classifiaction supervisée par SMAP"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:585 ../gui/tcltk/d.m/menu.tcl:508
+#: ../gui/tcltk/gis.m/gmmenu.tcl:585
+#: ../gui/tcltk/d.m/menu.tcl:508
msgid "Filter image"
msgstr "&Filtrage d'image"
@@ -3434,15 +3780,18 @@
msgid "Matrix/convolving filter"
msgstr "Matrice/filtre de convolution"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:589 ../gui/tcltk/d.m/menu.tcl:512
+#: ../gui/tcltk/gis.m/gmmenu.tcl:589
+#: ../gui/tcltk/d.m/menu.tcl:512
msgid "Spectral response"
msgstr "Réponse &spectrale"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:590 ../gui/tcltk/d.m/menu.tcl:513
+#: ../gui/tcltk/gis.m/gmmenu.tcl:590
+#: ../gui/tcltk/d.m/menu.tcl:513
msgid "Tassled cap vegetation index"
msgstr "&Indice de végétation de Tessel"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:591 ../gui/tcltk/d.m/menu.tcl:514
+#: ../gui/tcltk/gis.m/gmmenu.tcl:591
+#: ../gui/tcltk/d.m/menu.tcl:514
msgid "Transform image"
msgstr "&Transformation d'image"
@@ -3478,15 +3827,18 @@
msgid "&Volumes"
msgstr "&Volumes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:605 ../gui/tcltk/d.m/menu.tcl:531
+#: ../gui/tcltk/gis.m/gmmenu.tcl:605
+#: ../gui/tcltk/d.m/menu.tcl:531
msgid "Develop grid3D volumes"
msgstr "&Développer des volumes grid3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:606 ../gui/tcltk/d.m/menu.tcl:532
+#: ../gui/tcltk/gis.m/gmmenu.tcl:606
+#: ../gui/tcltk/d.m/menu.tcl:532
msgid "Manage nulls for grid3D volume"
msgstr "Gérer les creux de volume pour grid3D"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:607 ../gui/tcltk/d.m/menu.tcl:533
+#: ../gui/tcltk/gis.m/gmmenu.tcl:607
+#: ../gui/tcltk/d.m/menu.tcl:533
msgid "Manage timestamp for grid3D volume"
msgstr "Timestamp pour gérer le volume grid3D"
@@ -3506,48 +3858,59 @@
msgid "Interpolate volume from vector points"
msgstr "&Interpoler un volume à partir de vecteur points"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:614 ../gui/tcltk/gis.m/gmmenu.tcl:654
+#: ../gui/tcltk/gis.m/gmmenu.tcl:614
+#: ../gui/tcltk/gis.m/gmmenu.tcl:654
#: ../gui/tcltk/d.m/menu.tcl:539
msgid "Report and Statistics"
msgstr "Rapp&ort et statistiques"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:620 ../gui/tcltk/d.m/menu.tcl:543
+#: ../gui/tcltk/gis.m/gmmenu.tcl:620
+#: ../gui/tcltk/d.m/menu.tcl:543
msgid "&Databases"
msgstr "Base de &Données"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:621 ../gui/tcltk/d.m/menu.tcl:553
+#: ../gui/tcltk/gis.m/gmmenu.tcl:621
+#: ../gui/tcltk/d.m/menu.tcl:553
msgid "Database information"
msgstr "&Information sur la base de données"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:622 ../gui/tcltk/d.m/menu.tcl:554
+#: ../gui/tcltk/gis.m/gmmenu.tcl:622
+#: ../gui/tcltk/d.m/menu.tcl:554
msgid "Describe table"
msgstr "Décrire une table"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:623 ../gui/tcltk/d.m/menu.tcl:555
+#: ../gui/tcltk/gis.m/gmmenu.tcl:623
+#: ../gui/tcltk/d.m/menu.tcl:555
msgid "List columns"
msgstr "Lister les champs"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:624 ../gui/tcltk/d.m/menu.tcl:556
+#: ../gui/tcltk/gis.m/gmmenu.tcl:624
+#: ../gui/tcltk/d.m/menu.tcl:556
msgid "List drivers"
msgstr "Lister les pilotes"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:625 ../gui/tcltk/d.m/menu.tcl:557
+#: ../gui/tcltk/gis.m/gmmenu.tcl:625
+#: ../gui/tcltk/d.m/menu.tcl:557
msgid "List tables"
msgstr "Lister les tables"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:628 ../gui/tcltk/d.m/menu.tcl:544
+#: ../gui/tcltk/gis.m/gmmenu.tcl:628
+#: ../gui/tcltk/d.m/menu.tcl:544
msgid "Manage database"
msgstr "Gérer les bases de données"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:629 ../gui/tcltk/d.m/menu.tcl:545
+#: ../gui/tcltk/gis.m/gmmenu.tcl:629
+#: ../gui/tcltk/d.m/menu.tcl:545
msgid "Connect to database"
msgstr "Se connecter à la base de données"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:630 ../gui/tcltk/d.m/menu.tcl:546
+#: ../gui/tcltk/gis.m/gmmenu.tcl:630
+#: ../gui/tcltk/d.m/menu.tcl:546
msgid "Login to database"
msgstr "S'identifier sur la base de données"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:632 ../gui/tcltk/d.m/menu.tcl:548
+#: ../gui/tcltk/gis.m/gmmenu.tcl:632
+#: ../gui/tcltk/d.m/menu.tcl:548
msgid "Copy table"
msgstr "Copier la table"
@@ -3575,12 +3938,15 @@
msgid "Rename a column"
msgstr "Renommer un champ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:641 ../gui/tcltk/d.m/menu.tcl:551
+#: ../gui/tcltk/gis.m/gmmenu.tcl:641
+#: ../gui/tcltk/d.m/menu.tcl:551
msgid "Test database"
msgstr "Tester la base de données"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:644 ../gui/tcltk/gis.m/mapcanvas.tcl:2195
-#: ../gui/tcltk/gis.m/maptool.tcl:229 ../gui/tcltk/d.m/menu.tcl:560
+#: ../gui/tcltk/gis.m/gmmenu.tcl:644
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:2195
+#: ../gui/tcltk/gis.m/maptool.tcl:229
+#: ../gui/tcltk/d.m/menu.tcl:560
msgid "Query"
msgstr "Interroger les éléments de la zone d'affichage"
@@ -3596,7 +3962,8 @@
msgid "SQL statement"
msgstr "Clause SQL"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:649 ../gui/tcltk/d.m/menu.tcl:402
+#: ../gui/tcltk/gis.m/gmmenu.tcl:649
+#: ../gui/tcltk/d.m/menu.tcl:402
msgid "Vector<->database connections"
msgstr "&Couche vectorielle <-> base de données"
@@ -3608,39 +3975,48 @@
msgid "Set vector - database connection"
msgstr "Fixer la connexion couche vectorielle à la base de données"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:658 ../gui/tcltk/d.m/menu.tcl:565
+#: ../gui/tcltk/gis.m/gmmenu.tcl:658
+#: ../gui/tcltk/d.m/menu.tcl:565
msgid "&Help"
msgstr "&Aide"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:659 ../gui/tcltk/d.m/menu.tcl:566
+#: ../gui/tcltk/gis.m/gmmenu.tcl:659
+#: ../gui/tcltk/d.m/menu.tcl:566
msgid "GRASS help"
msgstr "&Aide GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:660 ../gui/tcltk/d.m/menu.tcl:567
+#: ../gui/tcltk/gis.m/gmmenu.tcl:660
+#: ../gui/tcltk/d.m/menu.tcl:567
msgid "GIS Manager &help"
msgstr "Aide Gestionnaire S&IG"
msgid "GIS Manager help"
msgstr "Aide Gestionnaire SIG"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:661 ../gui/tcltk/d.m/menu.tcl:568
+#: ../gui/tcltk/gis.m/gmmenu.tcl:661
+#: ../gui/tcltk/d.m/menu.tcl:568
msgid "About &GRASS"
msgstr "À propos de &GRASS"
msgid "About GRASS"
msgstr "À propos de GRASS"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:662 ../gui/tcltk/d.m/menu.tcl:569
+#: ../gui/tcltk/gis.m/gmmenu.tcl:662
+#: ../gui/tcltk/d.m/menu.tcl:569
msgid "About &System"
msgstr "À propos du &Système"
msgid "About System"
msgstr "À propos du système"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:670 ../gui/tcltk/d.m/menu.tcl:577
+#: ../gui/tcltk/gis.m/gmmenu.tcl:670
+#: ../gui/tcltk/d.m/menu.tcl:577
msgid "&Xtns"
msgstr "&Xtns"
@@ -3648,7 +4024,8 @@
msgid "Aspect map"
msgstr "Aspect de la carte"
-#: ../gui/tcltk/gis.m/rastarrows.tcl:114 ../gui/tcltk/gis.m/rastarrows.tcl:126
+#: ../gui/tcltk/gis.m/rastarrows.tcl:114
+#: ../gui/tcltk/gis.m/rastarrows.tcl:126
#, tcl-format
msgid "arrows for %s"
msgstr "flèches pour %s"
@@ -3659,15 +4036,11 @@
#: ../gui/tcltk/gis.m/rastarrows.tcl:139
msgid "Display arrows whose orientations are based on raster aspect map"
-msgstr ""
-"Affichage des flèches dont les orientations sont fondées sur les aspects de "
-"la couche matricielle"
+msgstr "Affichage des flèches dont les orientations sont fondées sur les aspects de la couche matricielle"
#: ../gui/tcltk/gis.m/rastarrows.tcl:145
msgid " (optionally, arrow lengths are based on slope or intensity map)"
-msgstr ""
-" (option, longueur de flèche calculée sur la pente ou l'intensité de la "
-"carte)"
+msgstr " (option, longueur de flèche calculée sur la pente ou l'intensité de la carte)"
#: ../gui/tcltk/gis.m/rastarrows.tcl:162
msgid "Aspect map: "
@@ -3728,8 +4101,7 @@
#: ../gui/tcltk/gis.m/histogram.tcl:139
msgid "Draw histogram of values from raster map or image"
-msgstr ""
-"Dessiner l'histogramme des valeurs de la couche matricielle ou de l'image"
+msgstr "Dessiner l'histogramme des valeurs de la couche matricielle ou de l'image"
#: ../gui/tcltk/gis.m/histogram.tcl:156
msgid "Raster to histogram: "
@@ -3739,11 +4111,13 @@
msgid "Graph style"
msgstr "Style du graphique"
-#: ../gui/tcltk/gis.m/histogram.tcl:175 ../gui/tcltk/gis.m/chart.tcl:280
+#: ../gui/tcltk/gis.m/histogram.tcl:175
+#: ../gui/tcltk/gis.m/chart.tcl:280
msgid "bar"
msgstr "histogramme"
msgid "pie"
msgstr "camembert"
@@ -3759,7 +4133,8 @@
msgid " background"
msgstr " arrière-plan"
-#: ../gui/tcltk/gis.m/histogram.tcl:191 ../gui/tcltk/gis.m/barscale.tcl:214
+#: ../gui/tcltk/gis.m/histogram.tcl:191
+#: ../gui/tcltk/gis.m/barscale.tcl:214
msgid "transparent background"
msgstr "fond transparent"
@@ -3775,11 +4150,13 @@
msgid "r.info error"
msgstr "Erreur avec r.info"
-#: ../gui/tcltk/gis.m/gmlib.tcl:85 ../gui/tcltk/gis.m/gmlib.tcl:114
+#: ../gui/tcltk/gis.m/gmlib.tcl:85
+#: ../gui/tcltk/gis.m/gmlib.tcl:114
msgid "Map Resource File"
msgstr "Extensions de fichier"
-#: ../gui/tcltk/gis.m/gmlib.tcl:86 ../gui/tcltk/gis.m/gmlib.tcl:116
+#: ../gui/tcltk/gis.m/gmlib.tcl:86
+#: ../gui/tcltk/gis.m/gmlib.tcl:116
msgid "All Files"
msgstr "Tous les fichiers"
@@ -3801,13 +4178,11 @@
msgstr "graphique pour %s"
#: ../gui/tcltk/gis.m/chart.tcl:185
-msgid ""
-"Display pie and bar charts of attribute values at vector object locations"
-msgstr ""
-"Affichage de graphiques sur les valeurs des attributs de la couche "
-"vectorielle"
+msgid "Display pie and bar charts of attribute values at vector object locations"
+msgstr "Affichage de graphiques sur les valeurs des attributs de la couche vectorielle"
-#: ../gui/tcltk/gis.m/chart.tcl:202 ../gui/tcltk/d.m/chart.tcl:91
+#: ../gui/tcltk/gis.m/chart.tcl:202
+#: ../gui/tcltk/d.m/chart.tcl:91
msgid "Vector map to chart:"
msgstr "Couche vectorielle pour laquelle produire un diagramme :"
@@ -3815,31 +4190,38 @@
msgid "vector map to chart"
msgstr "Couche vectorielle pour laquelle produire un diagramme"
-#: ../gui/tcltk/gis.m/chart.tcl:220 ../gui/tcltk/d.m/chart.tcl:106
+#: ../gui/tcltk/gis.m/chart.tcl:220
+#: ../gui/tcltk/d.m/chart.tcl:106
msgid "Vector type:"
msgstr "Type de vecteur :"
-#: ../gui/tcltk/gis.m/chart.tcl:221 ../gui/tcltk/d.m/vector.tcl:227
+#: ../gui/tcltk/gis.m/chart.tcl:221
+#: ../gui/tcltk/d.m/vector.tcl:227
#: ../gui/tcltk/d.m/chart.tcl:107
msgid "points"
msgstr "points"
-#: ../gui/tcltk/gis.m/chart.tcl:222 ../gui/tcltk/gis.m/legend.tcl:308
-#: ../gui/tcltk/d.m/vector.tcl:229 ../gui/tcltk/d.m/chart.tcl:108
+#: ../gui/tcltk/gis.m/chart.tcl:222
+#: ../gui/tcltk/gis.m/legend.tcl:308
+#: ../gui/tcltk/d.m/vector.tcl:229
+#: ../gui/tcltk/d.m/chart.tcl:108
msgid "lines"
msgstr "lignes"
-#: ../gui/tcltk/gis.m/chart.tcl:223 ../gui/tcltk/d.m/vector.tcl:231
+#: ../gui/tcltk/gis.m/chart.tcl:223
+#: ../gui/tcltk/d.m/vector.tcl:231
#: ../gui/tcltk/d.m/chart.tcl:109
msgid "boundaries"
msgstr "contours"
-#: ../gui/tcltk/gis.m/chart.tcl:224 ../gui/tcltk/d.m/vector.tcl:233
+#: ../gui/tcltk/gis.m/chart.tcl:224
+#: ../gui/tcltk/d.m/vector.tcl:233
#: ../gui/tcltk/d.m/chart.tcl:110
msgid "centroids"
msgstr "centroïdes"
-#: ../gui/tcltk/gis.m/chart.tcl:225 ../gui/tcltk/d.m/vector.tcl:235
+#: ../gui/tcltk/gis.m/chart.tcl:225
+#: ../gui/tcltk/d.m/vector.tcl:235
#: ../gui/tcltk/d.m/chart.tcl:111
msgid "areas"
msgstr "domaines"
@@ -3872,14 +4254,14 @@
msgid " scale factor"
msgstr " Facteur d'échelle"
-#: ../gui/tcltk/gis.m/chart.tcl:278 ../gui/tcltk/d.m/chart.tcl:158
+#: ../gui/tcltk/gis.m/chart.tcl:278
+#: ../gui/tcltk/d.m/chart.tcl:158
msgid "Chart type:"
msgstr "Type de diagramme :"
#: ../gui/tcltk/gis.m/chart.tcl:281
msgid "\tfixed chart size (if size column not used)"
-msgstr ""
-"\tFixe la taille du graphique (si la taille des colonnes n'est pas utilisée)"
+msgstr "\tFixe la taille du graphique (si la taille des colonnes n'est pas utilisée)"
#: ../gui/tcltk/gis.m/chart.tcl:288
msgid "\tchart outline color:"
@@ -3889,7 +4271,8 @@
msgid "none"
msgstr "Aucun"
-#: ../gui/tcltk/gis.m/dnviz.tcl:49 ../gui/tcltk/gis.m/rules.tcl:35
+#: ../gui/tcltk/gis.m/dnviz.tcl:49
+#: ../gui/tcltk/gis.m/rules.tcl:35
msgid "Select input map"
msgstr "Sélectionner la carte d'entrée"
@@ -3981,7 +4364,8 @@
msgid "Output keyframe file"
msgstr "Fichier de sortie"
-#: ../gui/tcltk/gis.m/dnviz.tcl:219 ../gui/tcltk/gis.m/rules.tcl:147
+#: ../gui/tcltk/gis.m/dnviz.tcl:219
+#: ../gui/tcltk/gis.m/rules.tcl:147
msgid "Overwrite existing file"
msgstr "Écraser les fichiers existants"
@@ -3993,16 +4377,19 @@
msgid "Clear all path coordinates"
msgstr "Effacer toutes les coordonnées du chemin"
-#: ../gui/tcltk/gis.m/dnviz.tcl:232 ../gui/tcltk/gis.m/rules.tcl:174
+#: ../gui/tcltk/gis.m/dnviz.tcl:232
+#: ../gui/tcltk/gis.m/rules.tcl:174
#: ../gui/tcltk/gis.m/animate.tcl:540
msgid "Apply"
msgstr "Appliquer"
-#: ../gui/tcltk/gis.m/dnviz.tcl:359 ../gui/tcltk/gis.m/rules.tcl:194
+#: ../gui/tcltk/gis.m/dnviz.tcl:359
+#: ../gui/tcltk/gis.m/rules.tcl:194
msgid "You must select an input map"
msgstr "Vous devez sélectionner une image en entrée"
-#: ../gui/tcltk/gis.m/dnviz.tcl:360 ../gui/tcltk/gis.m/rules.tcl:194
+#: ../gui/tcltk/gis.m/dnviz.tcl:360
msgid "No input map selected"
msgstr "Pas d'image en entrée sélectionnée"
@@ -4028,10 +4415,10 @@
#: ../gui/tcltk/gis.m/labels.tcl:111
msgid "Display labels for vector objects (created with v.label)"
-msgstr ""
-"Affichage des étiquettes pour les objets vectoriels (créés avec v.label)"
+msgstr "Affichage des étiquettes pour les objets vectoriels (créés avec v.label)"
-#: ../gui/tcltk/gis.m/labels.tcl:146 ../gui/tcltk/d.m/labels.tcl:80
+#: ../gui/tcltk/gis.m/labels.tcl:146
+#: ../gui/tcltk/d.m/labels.tcl:80
msgid "Display constraints:"
msgstr "Afficher les contraintes :"
@@ -4043,30 +4430,23 @@
msgid "max"
msgstr "max"
-#: ../gui/tcltk/gis.m/labels.tcl:151 ../gui/tcltk/d.m/labels.tcl:85
+#: ../gui/tcltk/gis.m/labels.tcl:151
+#: ../gui/tcltk/d.m/labels.tcl:85
msgid "region size"
msgstr "Taille de la région"
-#: ../gui/tcltk/gis.m/labels.tcl:157 ../gui/tcltk/d.m/labels.tcl:91
+#: ../gui/tcltk/gis.m/labels.tcl:157
+#: ../gui/tcltk/d.m/labels.tcl:91
msgid " ignore rotation setting and draw horizontally"
msgstr " ignorer la rotation et dessiner à l'horizontale"
#: ../gui/tcltk/gis.m/georect.tcl:285
-msgid ""
-"There is no raster group file (REF). You must select the 'create/edit group' "
-"option to create a group file."
-msgstr ""
-"Il n'existe pas de groupe de fichier matriciel (REF). Vous devez "
-"sélectionner l'option 'créer / modifier groupe ' pour créer un fichier de "
-"groupe."
+msgid "There is no raster group file (REF). You must select the 'create/edit group' option to create a group file."
+msgstr "Il n'existe pas de groupe de fichier matriciel (REF). Vous devez sélectionner l'option 'créer / modifier groupe ' pour créer un fichier de groupe."
#: ../gui/tcltk/gis.m/georect.tcl:307
-msgid ""
-"There is no vector group file (VREF). You must select the 'create/edit "
-"group' option to create a group file."
-msgstr ""
-"Il n'existe pas de vecteur fichier de groupe (VREF). Vous devez sélectionner "
-"l'option 'créer/modifier groupe' pour créer un fichier de groupe."
+msgid "There is no vector group file (VREF). You must select the 'create/edit group' option to create a group file."
+msgstr "Il n'existe pas de vecteur fichier de groupe (VREF). Vous devez sélectionner l'option 'créer/modifier groupe' pour créer un fichier de groupe."
#: ../gui/tcltk/gis.m/georect.tcl:388
msgid "Select mapset of raster to georectify"
@@ -4106,9 +4486,7 @@
#: ../gui/tcltk/gis.m/georect.tcl:627
msgid "Set up environment for georectifying rasters or vectors"
-msgstr ""
-"Mettre en place l'environnement pour géoréférencer les couches matricielles "
-"ou vectorielles"
+msgstr "Mettre en place l'environnement pour géoréférencer les couches matricielles ou vectorielles"
#: ../gui/tcltk/gis.m/georect.tcl:636
msgid "Georeference raster"
@@ -4132,8 +4510,7 @@
#: ../gui/tcltk/gis.m/georect.tcl:661
msgid "Create/edit group (rasters or vectors to georectify)"
-msgstr ""
-"Créer/éditer un groupe (couches matricielles ou vectorielles à géoréférencer)"
+msgstr "Créer/éditer un groupe (couches matricielles ou vectorielles à géoréférencer)"
#: ../gui/tcltk/gis.m/georect.tcl:669
msgid "3. Select group"
@@ -4148,12 +4525,8 @@
msgstr "4. Sélectionner une carte"
#: ../gui/tcltk/gis.m/georect.tcl:683
-msgid ""
-"Select non-georectified raster or vector to display for marking ground "
-"control points"
-msgstr ""
-"Sélectionner une couche matricielle non géoréférencée ou une couche "
-"vectorielle à afficher pour marquer les points d'amer"
+msgid "Select non-georectified raster or vector to display for marking ground control points"
+msgstr "Sélectionner une couche matricielle non géoréférencée ou une couche vectorielle à afficher pour marquer les points d'amer"
#: ../gui/tcltk/gis.m/georect.tcl:693
msgid "5. Start georectifying"
@@ -4181,9 +4554,7 @@
#: ../gui/tcltk/gis.m/georect.tcl:1014
msgid "affine transformation (rasters & vectors). Requires 3+ GCPs."
-msgstr ""
-"transformation affine (couches matricielles et vectorielles). Requiert au "
-"moins 3 points d'amer."
+msgstr "transformation affine (couches matricielles et vectorielles). Requiert au moins 3 points d'amer."
#: ../gui/tcltk/gis.m/georect.tcl:1019
msgid "2nd order"
@@ -4191,9 +4562,7 @@
#: ../gui/tcltk/gis.m/georect.tcl:1020
msgid "polynomial transformation (rasters only). Requires 6+ GCPs."
-msgstr ""
-"Transformation polynomiale (couches matricielles seulement). Requiert au "
-"moins 6 points d'amer."
+msgstr "Transformation polynomiale (couches matricielles seulement). Requiert au moins 6 points d'amer."
#: ../gui/tcltk/gis.m/georect.tcl:1024
msgid "3rd order"
@@ -4201,9 +4570,7 @@
#: ../gui/tcltk/gis.m/georect.tcl:1025
msgid "polynomial transformation (rasters only). Requires 10+ GCPs."
-msgstr ""
-"moins 10 points d'amer."
+msgstr "Transformation polynomiale (couches matricielles seulement). Requiert au moins 10 points d'amer."
#: ../gui/tcltk/gis.m/georect.tcl:1028
msgid "Clip map/image to target region"
@@ -4258,30 +4625,16 @@
msgstr "Quitter le géorectifieur"
#: ../gui/tcltk/gis.m/georect.tcl:1323
-msgid ""
-"There is no POINTS file of ground control points for group. You must create "
-"ground control points before georectifying map."
-msgstr ""
-"Il n'existe pas de fichier POINTS de contrôle au sol pour le groupe. Vous "
-"devez créer des points de contrôle au sol avant de géoréférencer la carte."
+msgid "There is no POINTS file of ground control points for group. You must create ground control points before georectifying map."
+msgstr "Il n'existe pas de fichier POINTS de contrôle au sol pour le groupe. Vous devez créer des points de contrôle au sol avant de géoréférencer la carte."
#: ../gui/tcltk/gis.m/georect.tcl:1353
-msgid ""
-"Insufficient ground control points for georectification method. You need at "
-"least 3 points for 1st order, 6 points for 2nd order and 10 points for 3rd "
-"order."
-msgstr ""
-"Insuffisance des points de contrôle au sol pour la méthode de "
-"géoréférencement. Vous devez disposer d'au moins 3 points pour le 1er ordre, "
-"6 points pour le 2ème ordre et 10 points pour le 3ème."
+msgid "Insufficient ground control points for georectification method. You need at least 3 points for 1st order, 6 points for 2nd order and 10 points for 3rd order."
+msgstr "Insuffisance des points de contrôle au sol pour la méthode de géoréférencement. Vous devez disposer d'au moins 3 points pour le 1er ordre, 6 points pour le 2ème ordre et 10 points pour le 3ème."
#: ../gui/tcltk/gis.m/georect.tcl:1384
-msgid ""
-"No valid ground control points in GCP file. You must create valid ground "
-"control points before georectifying map."
-msgstr ""
-"Aucun point de contrôle dans le fichier GCP. Vous devez créer des points de "
-"contrôle valides avant de géoréférencer la carte."
+msgid "No valid ground control points in GCP file. You must create valid ground control points before georectifying map."
+msgstr "Aucun point de contrôle dans le fichier GCP. Vous devez créer des points de contrôle valides avant de géoréférencer la carte."
#: ../gui/tcltk/gis.m/georect.tcl:1587
msgid "Error setting region"
@@ -4291,15 +4644,18 @@
msgid "Please wait..."
msgstr "Patientez..."
-#: ../gui/tcltk/gis.m/georect.tcl:2029 ../gui/tcltk/gis.m/mapcanvas.tcl:1503
+#: ../gui/tcltk/gis.m/georect.tcl:2029
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1503
msgid "Drag or click mouse to zoom"
msgstr "Glisser ou cliquez pour zoommer"
-#: ../gui/tcltk/gis.m/georect.tcl:2031 ../gui/tcltk/gis.m/mapcanvas.tcl:1505
+#: ../gui/tcltk/gis.m/georect.tcl:2031
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1505
msgid "Drag or click mouse to unzoom"
msgstr "Faites glisser la souris ou cliquez pour dézoomer"
-#: ../gui/tcltk/gis.m/georect.tcl:2229 ../gui/tcltk/gis.m/mapcanvas.tcl:1808
+#: ../gui/tcltk/gis.m/georect.tcl:2229
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1808
msgid "Drag with mouse to pan"
msgstr "Glisser avec la souris pour se déplacer"
@@ -4312,8 +4668,10 @@
msgid "You must open a display before adding map layers"
msgstr "Vous devez ouvrir un affichage avant d'ajouter des couches"
-#: ../gui/tcltk/gis.m/gmtree.tcl:483 ../gui/tcltk/gis.m/gmtree.tcl:631
-#: ../gui/tcltk/gis.m/gmtree.tcl:1152 ../gui/tcltk/gis.m/gmtree.tcl:1158
+#: ../gui/tcltk/gis.m/gmtree.tcl:483
+#: ../gui/tcltk/gis.m/gmtree.tcl:631
+#: ../gui/tcltk/gis.m/gmtree.tcl:1152
+#: ../gui/tcltk/gis.m/gmtree.tcl:1158
msgid "No layer selected"
msgstr "Pas de couche sélectionnée"
@@ -4335,8 +4693,7 @@
#: ../gui/tcltk/gis.m/gmtree.tcl:1185
msgid "You can digitize raster or vector maps only"
-msgstr ""
-"Vous ne pouvez digitaliser que des couches matricielles ou vectorielles"
+msgstr "Vous ne pouvez digitaliser que des couches matricielles ou vectorielles"
#: ../gui/tcltk/gis.m/runandoutput.tcl:121
msgid "Run (background)"
@@ -4364,60 +4721,66 @@
#: ../gui/tcltk/gis.m/runandoutput.tcl:262
msgid "Functions that require X Windows are not available in Windows"
-msgstr ""
-"Les fonctions qui nécessitent X Windows ne sont pas disponibles sous Windows"
+msgstr "Les fonctions qui nécessitent X Windows ne sont pas disponibles sous Windows"
#: ../gui/tcltk/gis.m/runandoutput.tcl:284
msgid "This module requires X11 support, but no xmons were found"
-msgstr ""
-"Ce module nécessite le support de X11, mais aucun moniteur X n'a été trouvé"
+msgstr "Ce module nécessite le support de X11, mais aucun moniteur X n'a été trouvé"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:26 ../gui/tcltk/d.m/tool2.tcl:100
+#: ../gui/tcltk/gis.m/gmtool2.tcl:26
+#: ../gui/tcltk/d.m/tool2.tcl:100
msgid "Scalebar and north arrow"
msgstr "Échelle et Nord"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:32 ../gui/tcltk/d.m/tool2.tcl:105
+#: ../gui/tcltk/gis.m/gmtool2.tcl:32
+#: ../gui/tcltk/d.m/tool2.tcl:105
msgid "Overlay grids and lines"
msgstr "Superposer grilles et lignes"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:39 ../gui/tcltk/d.m/tool2.tcl:116
+#: ../gui/tcltk/gis.m/gmtool2.tcl:39
+#: ../gui/tcltk/d.m/tool2.tcl:116
msgid "Add command layer"
msgstr "Ajouter une commande de couche"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:59 ../gui/tcltk/d.m/tool2.tcl:130
+#: ../gui/tcltk/gis.m/gmtool2.tcl:59
+#: ../gui/tcltk/d.m/tool2.tcl:130
msgid "Add group"
msgstr "Ajouter groupe"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:65 ../gui/tcltk/d.m/tool2.tcl:135
+#: ../gui/tcltk/gis.m/gmtool2.tcl:65
+#: ../gui/tcltk/d.m/tool2.tcl:135
msgid "Duplicate Layer"
msgstr "Copier la couche"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:70 ../gui/tcltk/d.m/tool2.tcl:139
+#: ../gui/tcltk/gis.m/gmtool2.tcl:70
+#: ../gui/tcltk/d.m/tool2.tcl:139
msgid "Delete layer"
msgstr "Effacer la couche"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:84 ../gui/tcltk/d.m/tool1.tcl:121
+#: ../gui/tcltk/gis.m/gmtool2.tcl:84
+#: ../gui/tcltk/d.m/tool1.tcl:121
msgid "Create new workspace file (erase current workspace settings first)"
-msgstr ""
-"Créer un nouveau fichier espace de travail (effacer d'abord les réglages "
-"courants)"
+msgstr "Créer un nouveau fichier espace de travail (effacer d'abord les réglages courants)"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:90 ../gui/tcltk/d.m/tool1.tcl:124
+#: ../gui/tcltk/gis.m/gmtool2.tcl:90
+#: ../gui/tcltk/d.m/tool1.tcl:124
msgid "Open existing workspace file"
msgstr "Ouvrir un fichier espace de travail existant"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:96 ../gui/tcltk/d.m/tool1.tcl:127
+#: ../gui/tcltk/gis.m/gmtool2.tcl:96
+#: ../gui/tcltk/d.m/tool1.tcl:127
msgid "Save workspace file"
msgstr "Sauvegarder le fichier espace de travail"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:111 ../gui/tcltk/d.m/tool1.tcl:66
+#: ../gui/tcltk/gis.m/gmtool2.tcl:111
+#: ../gui/tcltk/d.m/tool1.tcl:66
msgid "Animate raster map series"
msgstr "Animer la série de couches matricielles"
-#: ../gui/tcltk/gis.m/gmtool2.tcl:127 ../gui/tcltk/d.m/tool2.tcl:153
+#: ../gui/tcltk/gis.m/gmtool2.tcl:127
+#: ../gui/tcltk/d.m/tool2.tcl:153
msgid "Digitize map (select or create new map first)"
-msgstr ""
-"Numériser la carte (ou sélectionnez Créer une nouvelle carte en premier)"
+msgstr "Numériser la carte (ou sélectionnez Créer une nouvelle carte en premier)"
#: ../gui/tcltk/gis.m/barscale.tcl:153
msgid "Display scale and north arrow"
@@ -4430,9 +4793,7 @@
#: ../gui/tcltk/gis.m/barscale.tcl:176
msgid "\t enter x,y of scale/arrow upper left corner"
-msgstr ""
-"\t coordonnées x,y pour l'emplacement de l'échelle et du Nord à partir du "
-"coin supérieur gauche"
+msgstr "\t coordonnées x,y pour l'emplacement de l'échelle et du Nord à partir du coin supérieur gauche"
#: ../gui/tcltk/gis.m/barscale.tcl:179
msgid " "
@@ -4442,11 +4803,12 @@
msgid "\t "
msgstr "\t "
-#: ../gui/tcltk/gis.m/barscale.tcl:191 ../gui/tcltk/gis.m/dtext.tcl:201
-#: ../gui/tcltk/gis.m/maptext.tcl:154 ../gui/tcltk/gis.m/legend.tcl:238
+#: ../gui/tcltk/gis.m/barscale.tcl:191
+#: ../gui/tcltk/gis.m/dtext.tcl:201
+#: ../gui/tcltk/gis.m/maptext.tcl:154
+#: ../gui/tcltk/gis.m/legend.tcl:238
msgid "place with mouse"
-msgstr ""
-"positionner à l'aide de la souris l'emplacement de l'échelle et du Nord"
+msgstr "positionner à l'aide de la souris l'emplacement de l'échelle et du Nord"
#: ../gui/tcltk/gis.m/barscale.tcl:199
msgid "Scale appearance: text color"
@@ -4464,11 +4826,13 @@
msgid "display N. arrow only"
msgstr "Afficher seulement le Nord"
-#: ../gui/tcltk/gis.m/barscale.tcl:224 ../gui/tcltk/d.m/barscale.tcl:94
+#: ../gui/tcltk/gis.m/barscale.tcl:224
+#: ../gui/tcltk/d.m/barscale.tcl:94
msgid "display scale only"
msgstr "Afficher seulement l'échelle"
-#: ../gui/tcltk/gis.m/barscale.tcl:232 ../gui/tcltk/d.m/barscale.tcl:103
+#: ../gui/tcltk/gis.m/barscale.tcl:232
+#: ../gui/tcltk/d.m/barscale.tcl:103
msgid "text on top of scale, instead of to right"
msgstr "texte au-dessus de l'échelle, plutôt qu'à droite"
@@ -4476,7 +4840,8 @@
msgid "line scale instead of bar"
msgstr "Afficher une échelle graphique sous forme de ligne"
-#: ../gui/tcltk/gis.m/barscale.tcl:242 ../gui/tcltk/d.m/barscale.tcl:110
+#: ../gui/tcltk/gis.m/barscale.tcl:242
+#: ../gui/tcltk/d.m/barscale.tcl:110
msgid "use feet/miles instead of meters"
msgstr "utiliser des pieds/miles au lieu des mètres"
@@ -4504,35 +4869,43 @@
msgid "Text to display: "
msgstr "Texte à afficher :"
-#: ../gui/tcltk/gis.m/dtext.tcl:190 ../gui/tcltk/gis.m/maptext.tcl:143
+#: ../gui/tcltk/gis.m/dtext.tcl:190
+#: ../gui/tcltk/gis.m/maptext.tcl:143
msgid "Text placement: x,y coordinates (from upper left) "
msgstr "Emplacement du texte : coordonnées x,y (du haut à gauche)"
-#: ../gui/tcltk/gis.m/dtext.tcl:196 ../gui/tcltk/gis.m/maptext.tcl:150
+#: ../gui/tcltk/gis.m/dtext.tcl:196
+#: ../gui/tcltk/gis.m/maptext.tcl:150
msgid " coordinate type for text placement "
msgstr " système de coordonnées pour déterminer le placement"
-#: ../gui/tcltk/gis.m/dtext.tcl:199 ../gui/tcltk/gis.m/maptext.tcl:153
+#: ../gui/tcltk/gis.m/dtext.tcl:199
+#: ../gui/tcltk/gis.m/maptext.tcl:153
msgid "pixels"
msgstr "pixels"
msgid "percent"
msgstr "pourcentage"
msgid "geographic"
msgstr "coordonnées géographiques"
-#: ../gui/tcltk/gis.m/dtext.tcl:209 ../gui/tcltk/gis.m/maptext.tcl:162
+#: ../gui/tcltk/gis.m/dtext.tcl:209
+#: ../gui/tcltk/gis.m/maptext.tcl:162
msgid " align text with coordinate point "
msgstr " aligner le texte avec les coordonnées du point"
-#: ../gui/tcltk/gis.m/dtext.tcl:213 ../gui/tcltk/gis.m/maptext.tcl:166
+#: ../gui/tcltk/gis.m/dtext.tcl:213
+#: ../gui/tcltk/gis.m/maptext.tcl:166
msgid "bottom center"
msgstr "en bas au milieu"
msgid "top center"
msgstr "en haut au milieu"
@@ -4544,7 +4917,8 @@
msgid "Text options: font "
msgstr "Options du texte : police"
-#: ../gui/tcltk/gis.m/dtext.tcl:236 ../gui/tcltk/d.m/dtext.tcl:106
+#: ../gui/tcltk/gis.m/dtext.tcl:236
+#: ../gui/tcltk/d.m/dtext.tcl:106
#: ../gui/tcltk/d.m/fttext.tcl:151
msgid "bold text"
msgstr "texte en gras"
@@ -4574,12 +4948,8 @@
msgstr "Erreur lors de la création du fichier de règles"
#: ../gui/tcltk/gis.m/maptext.tcl:129
-msgid ""
-"Create postscript text object (for postscript eps, pdf, and print output "
-"only)"
-msgstr ""
-"Créer un objet texte postscript (pour le Postscript eps, PDF et sorite "
-"d'impression seulement)"
+msgid "Create postscript text object (for postscript eps, pdf, and print output only)"
+msgstr "Créer un objet texte postscript (pour le Postscript eps, PDF et sorite d'impression seulement)"
#: ../gui/tcltk/gis.m/maptext.tcl:136
msgid "Text to display:"
@@ -4593,11 +4963,13 @@
msgid " line width"
msgstr " épaisseur de ligne"
-#: ../gui/tcltk/gis.m/maptext.tcl:183 ../gui/tcltk/d.m/fttext.tcl:144
+#: ../gui/tcltk/gis.m/maptext.tcl:183
+#: ../gui/tcltk/d.m/fttext.tcl:144
msgid "Font:"
msgstr "Police :"
-#: ../gui/tcltk/gis.m/cmd.tcl:115 ../gui/tcltk/d.m/cmd.tcl:52
+#: ../gui/tcltk/gis.m/cmd.tcl:115
+#: ../gui/tcltk/d.m/cmd.tcl:52
msgid "Command:"
msgstr "Commande :"
@@ -4617,7 +4989,8 @@
msgid "base raster map to display"
msgstr "couche matricielle à afficher"
-#: ../gui/tcltk/gis.m/raster.tcl:203 ../gui/tcltk/gis.m/raster.tcl:207
+#: ../gui/tcltk/gis.m/raster.tcl:203
+#: ../gui/tcltk/gis.m/raster.tcl:207
msgid "base map info"
msgstr "information sur la couche de base"
@@ -4627,14 +5000,11 @@
#: ../gui/tcltk/gis.m/raster.tcl:226
msgid "\tOptional color draping. Use base map for shading,"
-msgstr ""
-"\tCouche de drapage facultative. Utilisez la couche matricielle pour comme "
-"couche de drapage,"
+msgstr "\tCouche de drapage facultative. Utilisez la couche matricielle pour comme couche de drapage,"
#: ../gui/tcltk/gis.m/raster.tcl:231
msgid "\tdrape map for color in color relief map or data fusion"
-msgstr ""
-"\tmettre la couche servant pour l'ombrage dans le champ couche matricielle."
+msgstr "\tmettre la couche servant pour l'ombrage dans le champ couche matricielle."
#: ../gui/tcltk/gis.m/raster.tcl:236
msgid "\tdrape map: "
@@ -4644,7 +5014,8 @@
msgid "raster map to drape over base map"
msgstr "couche matricielle pour draper la couche de base"
-#: ../gui/tcltk/gis.m/raster.tcl:244 ../gui/tcltk/gis.m/raster.tcl:248
+#: ../gui/tcltk/gis.m/raster.tcl:244
+#: ../gui/tcltk/gis.m/raster.tcl:248
msgid "drape map info"
msgstr "informations sur la couche de drapage"
@@ -4658,8 +5029,7 @@
#: ../gui/tcltk/gis.m/raster.tcl:270
msgid " Set background color (colored null value cells)"
-msgstr ""
-" Définir la couleur d'arrière-plan (couleur des cellules de valeur nulle) :"
+msgstr " Définir la couleur d'arrière-plan (couleur des cellules de valeur nulle) :"
#: ../gui/tcltk/gis.m/mapcanvas.tcl:584
msgid "Maximum zoom-in reached"
@@ -4673,11 +5043,13 @@
msgid "please wait..."
msgstr "veuillez patienter..."
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:826 ../gui/tcltk/gis.m/mapcanvas.tcl:2149
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:826
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:2149
msgid "You have to select map layer first"
msgstr "Vous devez sélectionner la couche de la carte en premier"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:827 ../gui/tcltk/gis.m/mapcanvas.tcl:2150
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:827
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:2150
msgid "No map layer selected"
@@ -4714,7 +5086,8 @@
msgid "Error setting region (Problem with g.region?)"
msgstr "Erreur de définition de la région (problème avec g.region ?)"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1440 ../gui/tcltk/gis.m/mapcanvas.tcl:1445
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1440
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1445
msgid "Error reading current resolution with g.region"
msgstr "Erreur de lecture de la résolution actuelle par g.region"
@@ -4808,9 +5181,7 @@
#: ../gui/tcltk/gis.m/animate.tcl:479
msgid "Select maps to animate in one or more frames (1 frame required)"
-msgstr ""
-"Sélectionnez des cartes pour animer dans un ou plusieurs cadres (1 cadre "
-"requis)"
+msgstr "Sélectionnez des cartes pour animer dans un ou plusieurs cadres (1 cadre requis)"
#: ../gui/tcltk/gis.m/animate.tcl:492
msgid "Maps for frame 1 (required): "
@@ -4845,16 +5216,15 @@
msgid "thematic map for %s"
msgstr "carte thématique pour %s"
-#: ../gui/tcltk/gis.m/thematic.tcl:145 ../gui/tcltk/gis.m/thematic.tcl:152
+#: ../gui/tcltk/gis.m/thematic.tcl:145
+#: ../gui/tcltk/gis.m/thematic.tcl:152
#: ../gui/tcltk/gis.m/thematic.tcl:158
msgid "Select font"
msgstr "Sélectionner une police"
#: ../gui/tcltk/gis.m/thematic.tcl:238
msgid "Display vector maps thematically by graduate colors (all types)"
-msgstr ""
-"Affiche des couches vectorielles par thèmes via des couleurs graduelles "
-"(tous types)"
+msgstr "Affiche des couches vectorielles par thèmes via des couleurs graduelles (tous types)"
#: ../gui/tcltk/gis.m/thematic.tcl:244
msgid " or by graduated sizes (points and lines)"
@@ -4864,7 +5234,8 @@
msgid "vector for thematic mapping"
msgstr "couche vectorielle de la carte thématique"
-#: ../gui/tcltk/gis.m/thematic.tcl:279 ../gui/tcltk/d.m/thematic.tcl:131
+#: ../gui/tcltk/gis.m/thematic.tcl:279
+#: ../gui/tcltk/d.m/thematic.tcl:131
msgid " vector type"
msgstr "type de vecteur"
@@ -4894,10 +5265,10 @@
#: ../gui/tcltk/gis.m/thematic.tcl:291
msgid " NUMERIC attribute column to use for thematic map"
-msgstr ""
-" attribut de la colonne NUMERIQUE à utiliser pour la carte thématique"
+msgstr " attribut de la colonne NUMERIQUE à utiliser pour la carte thématique"
-#: ../gui/tcltk/gis.m/thematic.tcl:298 ../gui/tcltk/d.m/vector.tcl:348
+#: ../gui/tcltk/gis.m/thematic.tcl:298
+#: ../gui/tcltk/d.m/vector.tcl:348
#: ../gui/tcltk/d.m/thematic.tcl:150
msgid " show attribute columns"
msgstr "montrer les champs attributaires"
@@ -4906,7 +5277,8 @@
msgid " show data"
msgstr " montrer les données"
-#: ../gui/tcltk/gis.m/thematic.tcl:315 ../gui/tcltk/d.m/thematic.tcl:168
+#: ../gui/tcltk/gis.m/thematic.tcl:315
+#: ../gui/tcltk/d.m/thematic.tcl:168
msgid "Thematic map: type"
msgstr "Carte thématique : type"
@@ -4922,7 +5294,8 @@
msgid "graduated lines"
msgstr "lignes graduées"
-#: ../gui/tcltk/gis.m/thematic.tcl:320 ../gui/tcltk/d.m/thematic.tcl:171
+#: ../gui/tcltk/gis.m/thematic.tcl:320
+#: ../gui/tcltk/d.m/thematic.tcl:171
msgid " map by"
msgstr "carte par"
@@ -4958,16 +5331,19 @@
msgid "Graduated points & lines: "
msgstr "Points et lignes gradués :"
-#: ../gui/tcltk/gis.m/thematic.tcl:353 ../gui/tcltk/d.m/vector.tcl:245
+#: ../gui/tcltk/gis.m/thematic.tcl:353
+#: ../gui/tcltk/d.m/vector.tcl:245
#: ../gui/tcltk/d.m/thematic.tcl:205
msgid "icon"
msgstr "icône"
-#: ../gui/tcltk/gis.m/thematic.tcl:357 ../gui/tcltk/d.m/thematic.tcl:210
+#: ../gui/tcltk/gis.m/thematic.tcl:357
+#: ../gui/tcltk/d.m/thematic.tcl:210
msgid "point color"
msgstr "couleur de point"
-#: ../gui/tcltk/gis.m/thematic.tcl:359 ../gui/tcltk/d.m/thematic.tcl:212
+#: ../gui/tcltk/gis.m/thematic.tcl:359
+#: ../gui/tcltk/d.m/thematic.tcl:212
msgid "line color"
msgstr "couleur de ligne"
@@ -5039,14 +5415,15 @@
msgid " end color"
msgstr " profondeur de couleur"
-#: ../gui/tcltk/gis.m/thematic.tcl:391 ../gui/tcltk/d.m/thematic.tcl:243
+#: ../gui/tcltk/gis.m/thematic.tcl:391
+#: ../gui/tcltk/d.m/thematic.tcl:243
msgid "draw border"
msgstr "tracer la bordure"
-#: ../gui/tcltk/gis.m/thematic.tcl:398 ../gui/tcltk/d.m/thematic.tcl:250
+#: ../gui/tcltk/gis.m/thematic.tcl:398
+#: ../gui/tcltk/d.m/thematic.tcl:250
msgid "save thematic colors to GRASSRGB column of vector file"
-msgstr ""
-"mettre thématiques couleurs à GRASSRGB colonne pour le fichier vectoriel"
+msgstr "mettre thématiques couleurs à GRASSRGB colonne pour le fichier vectoriel"
#: ../gui/tcltk/gis.m/thematic.tcl:405
msgid "Legend: title font "
@@ -5056,7 +5433,8 @@
msgid "title font for legend"
msgstr "Titre de police pour la légende"
-#: ../gui/tcltk/gis.m/thematic.tcl:412 ../gui/tcltk/gis.m/thematic.tcl:438
+#: ../gui/tcltk/gis.m/thematic.tcl:412
+#: ../gui/tcltk/gis.m/thematic.tcl:438
msgid " font color"
msgstr " couleur de la police"
@@ -5076,7 +5454,8 @@
msgid "label font for legend"
msgstr "Etiquette de police pour la légende"
-#: ../gui/tcltk/gis.m/thematic.tcl:446 ../gui/tcltk/d.m/thematic.tcl:260
+#: ../gui/tcltk/gis.m/thematic.tcl:446
+#: ../gui/tcltk/d.m/thematic.tcl:260
msgid "use math notation in legend"
msgstr "utiliser la notation mathématiques dans la légende"
@@ -5116,9 +5495,7 @@
#: ../gui/tcltk/gis.m/legend.tcl:193
msgid "Display legend for raster map using cat values and labels"
-msgstr ""
-"Afficher les légendes de la couche matricielle en utilisant les valeurs de "
-"catégories et les étiquettes"
+msgstr "Afficher les légendes de la couche matricielle en utilisant les valeurs de catégories et les étiquettes"
#: ../gui/tcltk/gis.m/legend.tcl:210
msgid "Raster map: "
@@ -5296,7 +5673,8 @@
msgid "Could not create BMP"
msgstr "Impossible de créer le BMP"
-#: ../gui/tcltk/gis.m/maptool.tcl:409 ../gui/tcltk/gis.m/maptool.tcl:414
+#: ../gui/tcltk/gis.m/maptool.tcl:409
+#: ../gui/tcltk/gis.m/maptool.tcl:414
msgid "Could not create JPG"
msgstr "Impossible de créer le JPG"
@@ -5340,7 +5718,8 @@
msgid "faces"
msgstr "faces"
-#: ../gui/tcltk/d.m/vector.tcl:262 ../gui/tcltk/d.m/vector.tcl:278
+#: ../gui/tcltk/d.m/vector.tcl:262
+#: ../gui/tcltk/d.m/vector.tcl:278
#: ../gui/tcltk/d.m/vector.tcl:294
msgid "color"
msgstr "couleur"
@@ -5385,7 +5764,8 @@
msgid " SQL where statement"
msgstr "\tclause SQL where"
-#: ../gui/tcltk/d.m/vector.tcl:354 ../gui/tcltk/d.m/thematic.tcl:156
+#: ../gui/tcltk/d.m/vector.tcl:354
+#: ../gui/tcltk/d.m/thematic.tcl:156
msgid " show data"
@@ -5493,11 +5873,13 @@
msgid "ESRI Arc/Info ASCII grid"
msgstr "Grille ASCII ESRI Arc/Info"
-#: ../gui/tcltk/d.m/menu.tcl:86 ../gui/tcltk/d.m/menu.tcl:120
+#: ../gui/tcltk/d.m/menu.tcl:86
+#: ../gui/tcltk/d.m/menu.tcl:120
msgid "GRIDATB.FOR map file (TOPMODEL)"
msgstr "fichier GRIDATB.FOR (TOPMODEL)"
-#: ../gui/tcltk/d.m/menu.tcl:87 ../gui/tcltk/d.m/menu.tcl:121
+#: ../gui/tcltk/d.m/menu.tcl:87
+#: ../gui/tcltk/d.m/menu.tcl:121
msgid "MAT-File (v.4) array (Matlab or Octave)"
msgstr "Tableau MAT-File (v.4) (Matlab ou Octave)"
@@ -5549,15 +5931,18 @@
msgid "Matlab and MapGen files"
msgstr "Fichiers Matlab et MapGen"
-#: ../gui/tcltk/d.m/menu.tcl:107 ../gui/tcltk/d.m/menu.tcl:144
+#: ../gui/tcltk/d.m/menu.tcl:107
+#: ../gui/tcltk/d.m/menu.tcl:144
msgid "Grid 3D"
msgstr "Grille 3D"
-#: ../gui/tcltk/d.m/menu.tcl:108 ../gui/tcltk/d.m/menu.tcl:145
+#: ../gui/tcltk/d.m/menu.tcl:108
+#: ../gui/tcltk/d.m/menu.tcl:145
msgid "ASCII 3D file"
msgstr "Fichier ASCII 3D"
-#: ../gui/tcltk/d.m/menu.tcl:109 ../gui/tcltk/d.m/menu.tcl:146
+#: ../gui/tcltk/d.m/menu.tcl:109
+#: ../gui/tcltk/d.m/menu.tcl:146
msgid "Vis5D file"
msgstr "Fichier Vis5D"
@@ -5609,7 +5994,8 @@
msgid "VRML file"
msgstr "Fichier VRML"
-#: ../gui/tcltk/d.m/menu.tcl:132 ../gui/tcltk/d.m/menu.tcl:142
+#: ../gui/tcltk/d.m/menu.tcl:132
+#: ../gui/tcltk/d.m/menu.tcl:142
#: ../gui/tcltk/d.m/menu.tcl:147
msgid "VTK ASCII file"
msgstr "Fichier ASCII VTK"
@@ -5624,8 +6010,7 @@
#: ../gui/tcltk/d.m/menu.tcl:138
msgid "ASCII vector or point file/old GRASS ASCII vector file"
-msgstr ""
-"Vecteur ASCII ou fichier de points / ancien fichier vecteur ASCII GRASS"
+msgstr "Vecteur ASCII ou fichier de points / ancien fichier vecteur ASCII GRASS"
#: ../gui/tcltk/d.m/menu.tcl:140
msgid "POV-Ray format"
@@ -5721,9 +6106,7 @@
#: ../gui/tcltk/d.m/menu.tcl:180
msgid "XWD (Save display, selected with mouse, to map.xwd in home directory )"
-msgstr ""
-"XWD (sauvegarder l'affichage, sélectionné avec la souris, dans un fichier "
-"map.xwd du répertoire personnel)"
+msgstr "XWD (sauvegarder l'affichage, sélectionné avec la souris, dans un fichier map.xwd du répertoire personnel)"
#: ../gui/tcltk/d.m/menu.tcl:181
msgid "Save displays to multiple graphic file formats"
@@ -5759,8 +6142,7 @@
#: ../gui/tcltk/d.m/menu.tcl:196
msgid "Change current working session to new mapset, location, or GISDBASE"
-msgstr ""
-"Changer de jeu de données, secteur, ou GISDBASE pour la session en cours"
+msgstr "Changer de jeu de données, secteur, ou GISDBASE pour la session en cours"
#: ../gui/tcltk/d.m/menu.tcl:197
msgid "Modify access by other users to current mapset"
@@ -5780,8 +6162,7 @@
#: ../gui/tcltk/d.m/menu.tcl:205
msgid "Show projection information and create projection files"
-msgstr ""
-"Montrer les informations de projection et créer des fichiers de projection"
+msgstr "Montrer les informations de projection et créer des fichiers de projection"
#: ../gui/tcltk/d.m/menu.tcl:207
msgid "Convert coordinates from one projection to another"
@@ -5892,12 +6273,8 @@
msgstr "Créer une image couleurs à partir de fichiers RVB"
#: ../gui/tcltk/d.m/menu.tcl:250
-msgid ""
-"Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) "
-"maps"
-msgstr ""
-"Créer 3 couches RVB (rouge, vert, bleu) à partir de 3 couches TVS (teinte, "
-"valeur, saturation)"
+msgid "Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) maps"
+msgstr "Créer 3 couches RVB (rouge, vert, bleu) à partir de 3 couches TVS (teinte, valeur, saturation)"
#: ../gui/tcltk/d.m/menu.tcl:255
msgid "Create raster buffers"
@@ -5909,9 +6286,7 @@
#: ../gui/tcltk/d.m/menu.tcl:257
msgid "Locate closest points between areas in 2 raster maps"
-msgstr ""
-"Repérer les points les plus proches entre les zones dans 2 couches "
-"matricielles"
+msgstr "Repérer les points les plus proches entre les zones dans 2 couches matricielles"
#: ../gui/tcltk/d.m/menu.tcl:260
msgid "Moving window analysis of raster cells"
@@ -5927,8 +6302,7 @@
#: ../gui/tcltk/d.m/menu.tcl:268
msgid "Statistical calculations for cover map over base map"
-msgstr ""
-"Calculs statistiques pour la couche de couverture sur la couche de base"
+msgstr "Calculs statistiques pour la couche de couverture sur la couche de base"
#: ../gui/tcltk/d.m/menu.tcl:271
msgid "Solar irradiance and daily irradiation"
@@ -5968,9 +6342,7 @@
#: ../gui/tcltk/d.m/menu.tcl:293
msgid "Carve stream channels into elevation map using vector streams map"
-msgstr ""
-"Creuser des chenaux dans une couche matricielle d'élévation via une couche "
-"vectorielle de flux"
+msgstr "Creuser des chenaux dans une couche matricielle d'élévation via une couche vectorielle de flux"
#: ../gui/tcltk/d.m/menu.tcl:294
msgid "Depressionless elevation map and flowline map"
@@ -6018,9 +6390,7 @@
#: ../gui/tcltk/d.m/menu.tcl:320
msgid "Edit category values of individual cells for displayed raster map"
-msgstr ""
-"Modifier la catégorie des valeurs des cellules individuelles pour afficher "
+msgstr "Modifier la catégorie des valeurs des cellules individuelles pour afficher la couche matricielle"
#: ../gui/tcltk/d.m/menu.tcl:323
msgid "Reclassify categories for areas of specified sizes"
@@ -6036,14 +6406,11 @@
#: ../gui/tcltk/d.m/menu.tcl:327
msgid "Recode categories using rules (create new map)"
-msgstr ""
-"Recoder les catégories en se servant des règles (créer une nouvelle carte)"
+msgstr "Recoder les catégories en se servant des règles (créer une nouvelle carte)"
#: ../gui/tcltk/d.m/menu.tcl:328
msgid "Recode categories using rules file (create new map)"
-msgstr ""
-"Recoder les catégories en utilisant le fichier de règles (créer une nouvelle "
-"carte)"
+msgstr "Recoder les catégories en utilisant le fichier de règles (créer une nouvelle carte)"
#: ../gui/tcltk/d.m/menu.tcl:330
msgid "Rescale categories (create new map)"
@@ -6051,9 +6418,7 @@
#: ../gui/tcltk/d.m/menu.tcl:331
msgid "Rescale categories with equalized histogram (create new map)"
-msgstr ""
-"Re-échantillonner les catégories avec un histogramme de classes égales "
-"(créer une nouvelle carte)"
+msgstr "Re-échantillonner les catégories avec un histogramme de classes égales (créer une nouvelle carte)"
#: ../gui/tcltk/d.m/menu.tcl:334
msgid "Generate concentric circles around points"
@@ -6065,9 +6430,7 @@
#: ../gui/tcltk/d.m/menu.tcl:337
msgid "Generate random cells and vector points from raster map"
-msgstr ""
-"Générer des cellules aléatoires et une couche vectorielle de points à partir "
-"de la couche matricielle"
+msgstr "Générer des cellules aléatoires et une couche vectorielle de points à partir de la couche matricielle"
#: ../gui/tcltk/d.m/menu.tcl:340
msgid "Generate density surface using moving Gausian kernal"
@@ -6103,9 +6466,7 @@
#: ../gui/tcltk/d.m/menu.tcl:350
msgid "Inverse distance weighted interpolation from raster points"
-msgstr ""
-"Interpolation de points d'une couche matricielle par distance inverse "
-"pondérée (IDW)"
+msgstr "Interpolation de points d'une couche matricielle par distance inverse pondérée (IDW)"
#: ../gui/tcltk/d.m/menu.tcl:351
msgid "Interpolation from raster contours"
@@ -6117,9 +6478,7 @@
#: ../gui/tcltk/d.m/menu.tcl:354
msgid "Regularized spline tension interpolation from vector points or contours"
-msgstr ""
-"Interpolation de points ou courbes de niveau vectoriels par splines régulées "
-"(RST)"
+msgstr "Interpolation de points ou courbes de niveau vectoriels par splines régulées (RST)"
#: ../gui/tcltk/d.m/menu.tcl:356
msgid "Fill NULL cells by interpolation using regularized spline tension"
@@ -6139,8 +6498,7 @@
#: ../gui/tcltk/d.m/menu.tcl:367
msgid "Summary statistics for clumped cells (works with r.clump)"
-msgstr ""
-"Statistiques résumées pour les grumeaux de cellules (fonctionne avec r.clump)"
+msgstr "Statistiques résumées pour les grumeaux de cellules (fonctionne avec r.clump)"
#: ../gui/tcltk/d.m/menu.tcl:370
msgid "Univariate statistics (script version)"
@@ -6152,8 +6510,7 @@
#: ../gui/tcltk/d.m/menu.tcl:373
msgid "Sample values along transects (use azimuth, distance)"
-msgstr ""
-"Echantillonner des valeurs le long du transect (utiliser azimut distance"
+msgstr "Echantillonner des valeurs le long du transect (utiliser azimut distance"
#: ../gui/tcltk/d.m/menu.tcl:376
msgid "Linear regression between 2 maps"
@@ -6193,9 +6550,7 @@
#: ../gui/tcltk/d.m/menu.tcl:394
msgid "Convert 2D vector to 3D by sampling raster"
-msgstr ""
-"Convertir la couche vectorielle 2D en 3D par échantillonnage de couche "
-"matricielle"
+msgstr "Convertir la couche vectorielle 2D en 3D par échantillonnage de couche matricielle"
#: ../gui/tcltk/d.m/menu.tcl:395
msgid "Extrude 2D vector into 3D vector"
@@ -6203,8 +6558,7 @@
#: ../gui/tcltk/d.m/menu.tcl:397
msgid "Create text label file for vector features"
-msgstr ""
-"Créer un fichier d'étiquette texte pour les caractéristiques vectorielles"
+msgstr "Créer un fichier d'étiquette texte pour les caractéristiques vectorielles"
#: ../gui/tcltk/d.m/menu.tcl:398
msgid "Assign colors from a numeric attribute column"
@@ -6248,35 +6602,23 @@
#: ../gui/tcltk/d.m/menu.tcl:415
msgid "Create stationing from imput lines, and linear reference system"
-msgstr ""
-"Créer des stations pour les lignes entrées, et un système de référence "
-"linéaire"
+msgstr "Créer des stations pour les lignes entrées, et un système de référence linéaire"
#: ../gui/tcltk/d.m/menu.tcl:416
-msgid ""
-"Create points/segments from input lines, linear reference system and "
-"positions read from stdin"
-msgstr ""
-"Créer des points/segments des lignes entrées, un système de référence "
-"linéaire et les positions lues de stdin"
+msgid "Create points/segments from input lines, linear reference system and positions read from stdin"
+msgstr "Créer des points/segments des lignes entrées, un système de référence linéaire et les positions lues de stdin"
#: ../gui/tcltk/d.m/menu.tcl:417
-msgid ""
-"Find line id and real km+offset for given points in vector map using linear "
-"reference system"
-msgstr ""
-"Trouvez la ligne id et le km réel pour les points donnés de la carte "
-"vectorielle en utilisant un système de référence linéaire"
+msgid "Find line id and real km+offset for given points in vector map using linear reference system"
+msgstr "Trouvez la ligne id et le km réel pour les points donnés de la carte vectorielle en utilisant un système de référence linéaire"
#: ../gui/tcltk/d.m/menu.tcl:420
msgid "Locate nearest features to points or centroids"
-msgstr ""
-"Repérer les caractéristiques les plus proches des points ou des centroïdes"
+msgstr "Repérer les caractéristiques les plus proches des points ou des centroïdes"
#: ../gui/tcltk/d.m/menu.tcl:421
msgid "Generate Thiessen polygons around points (Voronoi diagram)"
-msgstr ""
-"Générer des polygones de Thiessen autour des points (diagramme de Voronoï)"
+msgstr "Générer des polygones de Thiessen autour des points (diagramme de Voronoï)"
#: ../gui/tcltk/d.m/menu.tcl:422
msgid "Connect points to create Delaunay triangles"
@@ -6336,9 +6678,7 @@
#: ../gui/tcltk/d.m/menu.tcl:454
msgid "Generate Voronoi diagram/Thiessen polygons for point set"
-msgstr ""
-"Générer le diagramme de Voronoï/les polygones de Thiessen pour le jeu de "
-"points"
+msgstr "Générer le diagramme de Voronoï/les polygones de Thiessen pour le jeu de points"
#: ../gui/tcltk/d.m/menu.tcl:456
msgid "Sample raster maps"
@@ -6346,26 +6686,19 @@
#: ../gui/tcltk/d.m/menu.tcl:457
msgid "Calculate statistics for raster map overlain by vector map"
-msgstr ""
-"Calculer des statistiques pour la couche matricielle en-dessous de la couche "
-"vectorielle"
+msgstr "Calculer des statistiques pour la couche matricielle en-dessous de la couche vectorielle"
#: ../gui/tcltk/d.m/menu.tcl:461
msgid "Partition points into test/training sets for k-fold cross validatation"
-msgstr ""
-"Partition des points en test/jeux de données pour une validation croisée k-"
-"fois"
+msgstr "Partition des points en test/jeux de données pour une validation croisée k-fois"
#: ../gui/tcltk/d.m/menu.tcl:462
msgid "Transfer attribute data from queried vector map to points"
-msgstr ""
-"Transfert les données attributaires de la carte vectorielle à des points"
+msgstr "Transfert les données attributaires de la carte vectorielle à des points"
#: ../gui/tcltk/d.m/menu.tcl:467
msgid "Load vector attributes to database or create reports"
-msgstr ""
-"Charge les données attributaires de la carte vectorielle de la base de "
-"données ou crée des rapports"
+msgstr "Charge les données attributaires de la carte vectorielle de la base de données ou crée des rapports"
#: ../gui/tcltk/d.m/menu.tcl:468
msgid "Report areas for vector attribute categories"
@@ -6377,9 +6710,7 @@
#: ../gui/tcltk/d.m/menu.tcl:472
msgid "Calculate stats for raster map underlying vector objects"
-msgstr ""
-"Calculer des statistiques pour la couche matricielle croisant des objets "
-"vectoriels"
+msgstr "Calculer des statistiques pour la couche matricielle croisant des objets vectoriels"
#: ../gui/tcltk/d.m/menu.tcl:473
msgid "Indices of point counts in quadrats"
@@ -6398,25 +6729,16 @@
msgstr "Mosaïque jusqu'à 4 images adjacentes"
#: ../gui/tcltk/d.m/menu.tcl:484
-msgid ""
-"Color balance and enhance color tables of multiband imagery for rgb display"
-msgstr ""
-"Balance des couleurs et renforcement des tables de couleurs de l'imagerie "
-"multi-bandes pour l'affichage rgb"
+msgid "Color balance and enhance color tables of multiband imagery for rgb display"
+msgstr "Balance des couleurs et renforcement des tables de couleurs de l'imagerie multi-bandes pour l'affichage rgb"
#: ../gui/tcltk/d.m/menu.tcl:485
-msgid ""
-"Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
-msgstr ""
-"Transforme des images couleur HIS (Teinte/Intensité/Saturation) en RVB "
-"(Rouge/Vert/Bleu)"
+msgid "Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
+msgstr "Transforme des images couleur HIS (Teinte/Intensité/Saturation) en RVB (Rouge/Vert/Bleu)"
#: ../gui/tcltk/d.m/menu.tcl:486
-msgid ""
-"Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
-msgstr ""
-"Transforme une image en couleur RGB (rouge, vert, bleu) en couleur HIS "
-"(teinte, intensité, saturation)"
+msgid "Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
+msgstr "Transforme une image en couleur RGB (rouge, vert, bleu) en couleur HIS (teinte, intensité, saturation)"
#: ../gui/tcltk/d.m/menu.tcl:488
msgid "Rectify and georeference image group"
@@ -6424,15 +6746,11 @@
#: ../gui/tcltk/d.m/menu.tcl:489
msgid "Set ground control points (GCP's) from raster map or keyboard entry"
-msgstr ""
-"Définir des points de contrôle au sol (GCP) d'une couche matricielle ou "
-"entré au clavier"
+msgstr "Définir des points de contrôle au sol (GCP) d'une couche matricielle ou entré au clavier"
#: ../gui/tcltk/d.m/menu.tcl:491
msgid "Set ground control points (GCP's) from vector map or keyboard entry"
-msgstr ""
-"Définir des points de contrôle au sol (GCP) d'une carte vectorielle ou entré "
-"au clavier"
+msgstr "Définir des points de contrôle au sol (GCP) d'une carte vectorielle ou entré au clavier"
#: ../gui/tcltk/d.m/menu.tcl:493
msgid "Affine and Polynomial rectification (rubber sheet)"
@@ -6480,9 +6798,7 @@
#: ../gui/tcltk/d.m/menu.tcl:525
msgid "Bit pattern comparison for ID of low quality pixels"
-msgstr ""
-"Opérateur de comparaison par bits pour l'identification des pixels de basse "
-"qualité"
+msgstr "Opérateur de comparaison par bits pour l'identification des pixels de basse qualité"
#: ../gui/tcltk/d.m/menu.tcl:526
msgid "Kappa classification accuracy assessment"
@@ -6510,8 +6826,7 @@
#: ../gui/tcltk/d.m/menu.tcl:538
msgid "Interpolate volume from vector points using splines"
-msgstr ""
-"Interpole un volume à partir d'un vecteur de points en utilisant des splines"
+msgstr "Interpole un volume à partir d'un vecteur de points en utilisant des splines"
#: ../gui/tcltk/d.m/menu.tcl:540
msgid "Display information about grid3D volume"
@@ -6661,7 +6976,8 @@
msgid "Labels name:"
msgstr "Nom des étiquettes :"
-#: ../gui/tcltk/d.m/barscale.tcl:67 ../gui/tcltk/d.m/legend.tcl:106
+#: ../gui/tcltk/d.m/barscale.tcl:67
+#: ../gui/tcltk/d.m/legend.tcl:106
msgid "Text color: "
msgstr "Couleur du texte : "
@@ -6685,10 +7001,10 @@
msgid "line scale instead of bar scale "
msgstr "échelle linéaire plutôt que barrette"
-#: ../gui/tcltk/d.m/barscale.tcl:118 ../gui/tcltk/d.m/legend.tcl:185
+#: ../gui/tcltk/d.m/barscale.tcl:118
+#: ../gui/tcltk/d.m/legend.tcl:185
msgid "place with mouse (cannot save placement with group)"
-msgstr ""
-"placer avec la souris (impossible de sauvegarder la position dans le groupe)"
+msgstr "placer avec la souris (impossible de sauvegarder la position dans le groupe)"
#: ../gui/tcltk/d.m/dtext.tcl:101
msgid "Text options: color"
@@ -6740,8 +7056,7 @@
#: ../gui/tcltk/d.m/fttext.tcl:102
msgid " (leave blank to place with mouse; position will not save)"
-msgstr ""
-" (laisser en blanc avec la souris ; la position ne sera pas sauvée)"
+msgstr " (laisser en blanc avec la souris ; la position ne sera pas sauvée)"
#: ../gui/tcltk/d.m/fttext.tcl:108
msgid " coordinate type"
@@ -6753,12 +7068,8 @@
#: ../gui/tcltk/d.m/fttext.tcl:120
#, tcl-format
-msgid ""
-" (for coordinates, % is from bottom left of display, pixels from top "
-"left)"
-msgstr ""
-" (pour les coordonnées, en % depuis en bas à gauche de l'écran, en "
-"pixels depuis en haut à gauche)"
+msgid " (for coordinates, % is from bottom left of display, pixels from top left)"
+msgstr " (pour les coordonnées, en % depuis en bas à gauche de l'écran, en pixels depuis en haut à gauche)"
#: ../gui/tcltk/d.m/fttext.tcl:126
msgid " text rotation (degrees counterclockwise)"
@@ -6780,7 +7091,8 @@
msgid "show legend in selected display monitor"
msgstr "montrer la légende dans le moniteur sélectionné"
-#: ../gui/tcltk/d.m/raster.tcl:111 ../gui/tcltk/d.m/raster.tcl:136
+#: ../gui/tcltk/d.m/raster.tcl:111
+#: ../gui/tcltk/d.m/raster.tcl:136
msgid " thin legend by "
msgstr " légende par"
@@ -6836,81 +7148,3 @@
msgid "flip legend"
msgstr "retourner la légende"
-#~ msgid "Test"
-#~ msgstr "Tester"
-#~ msgid "Run (in Xterm)"
-#~ msgstr "Exécuter (dans un terminal X)"
-#~ msgid "Zoom to..."
-#~ msgstr "Zoom sur..."
-#~ msgid "Export display to graphics file"
-#~ msgstr "Exporter la zone d'affichage dans un fichier graphique"
-#~ msgid "Create/rebuild topology: "
-#~ msgstr "Créer/reconstruire la topologie"
-#~ msgid "Generalization"
-#~ msgstr "Généralisation"
-#~ msgid "WARNING: Error creating new location"
-#~ msgstr "ATTENTION : erreur lors de la création du nouveau secteur"
-#~ msgid ""
-#~ "Error creating new location from georeferenced file. g.proj returned "
-#~ "following message:\n"
-#~ "\n"
-#~ "%s"
-#~ msgstr ""
-#~ "Erreur lors de la création du nouveau secteur à partir d'un fichier "
-#~ "géoréférencé. g.proj a renvoyé le message suivant :\n"
-#~ "\n"
-#~ "%s"
-#~ msgid "cumulative length = %s\n"
-#~ msgstr "longueur cumulée = %s\n"
-#~ msgid "text color"
-#~ msgstr "couleur de texte"
-#~ msgid " text size"
-#~ msgstr " taille de texte"
-#~ msgid " justification"
-#~ msgstr " justification"
-#~ msgid "Can't open %s - bad file format"
-#~ msgstr "Impossible d'ouvrir %s - mauvais format de fichier"
-#~ msgid ""
-#~ "WARNING: Please supply a\n"
-#~ "valid EPSG code (integer)"
-#~ msgstr ""
-#~ "ATTENTION : merci de fournir un\n"
-#~ "code EPSG valide (nombre entier)"
-#~ msgid ""
-#~ "Error creating new location from EPSG code. g.proj returned following "
-#~ "message:\n"
-#~ "\n"
-#~ "%s"
-#~ msgstr ""
-#~ "Erreur lors de la création du secteur à partir d'un code EPSG. g.proj a "
-#~ "renvoyé le message suivant :\n"
-#~ "\n"
-#~ "%s"
-#, fuzzy
-#~ msgid "Datum transform number: "
-#~ msgstr "Numéro de datum :"
-#, fuzzy
-#~ msgid "Enter number of datum transform selected"
-#~ msgstr "Entrer le numéro du datum sélectionné"
-#~ msgid "Display: rows=%d columns=%d resolution=%g %s"
-#~ msgstr "Afficher : lignes=%d colonnes=%d résolution=%g %s"
-#~ msgid " --segment length = %s\n"
-#~ msgstr " --longueur du segment = %s\n"
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po 2013-01-05 09:25:09 UTC (rev 54530)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po 2013-01-05 12:25:29 UTC (rev 54531)
@@ -10,7 +10,7 @@
"Project-Id-Version: grasswxpy_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-11-05 10:54+0100\n"
-"PO-Revision-Date: 2012-12-01 19:00+0100\n"
+"PO-Revision-Date: 2013-01-03 22:25+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: français <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
@@ -20,7 +20,8 @@
"X-Poedit-Language: French\n"
"X-Poedit-Country: FRANCE\n"
-#: ../gui/wxpython/nviz/tools.py:83 ../gui/wxpython/nviz/preferences.py:55
+#: ../gui/wxpython/nviz/tools.py:83
+#: ../gui/wxpython/nviz/preferences.py:55
#: ../gui/wxpython/nviz/preferences.py:60
msgid "View"
msgstr "Vue"
@@ -39,7 +40,8 @@
msgid "Analysis"
msgstr "Analyses"
-#: ../gui/wxpython/nviz/tools.py:98 ../gui/wxpython/nviz/tools.py:378
+#: ../gui/wxpython/nviz/tools.py:98
+#: ../gui/wxpython/nviz/tools.py:378
msgid "Animation"
msgstr "Animation"
@@ -49,31 +51,36 @@
#: ../gui/wxpython/nviz/tools.py:239
msgid "Adjusts the distance and angular perspective of the image viewpoint"
-msgstr ""
+msgstr "Ajuster la distance et l'angle de perspective de l'image au point de vue"
-#: ../gui/wxpython/nviz/tools.py:244 ../gui/wxpython/nviz/preferences.py:68
+#: ../gui/wxpython/nviz/tools.py:244
+#: ../gui/wxpython/nviz/preferences.py:68
msgid "Perspective:"
msgstr "Perspective :"
#: ../gui/wxpython/nviz/tools.py:252
msgid "Tilts the plane of the surface from the horizontal"
-msgstr ""
+msgstr "Penche la surface par rapport à l'horizontale"
-#: ../gui/wxpython/nviz/tools.py:256 ../gui/wxpython/nviz/tools.py:1020
+#: ../gui/wxpython/nviz/tools.py:256
+#: ../gui/wxpython/nviz/tools.py:1020
msgid "Tilt:"
msgstr "Inclinaison :"
#: ../gui/wxpython/nviz/tools.py:263
msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
-msgstr ""
+msgstr "Ajuster la hauteur de vue (l'angle de vue s'ajuste automatiquement pour garder le même centre de la vue)"
#: ../gui/wxpython/nviz/tools.py:268
msgid "Adjusts the relative height of features above the plane of the surface"
msgstr "Ajuster la hauteur relative des objets au dessus de la surface"
-#: ../gui/wxpython/nviz/tools.py:276 ../gui/wxpython/nviz/tools.py:1036
-#: ../gui/wxpython/nviz/tools.py:1674 ../gui/wxpython/gui_core/dialogs.py:2189
-#: ../gui/wxpython/psmap/dialogs.py:2734 ../gui/wxpython/psmap/dialogs.py:2872
+#: ../gui/wxpython/nviz/tools.py:276
+#: ../gui/wxpython/nviz/tools.py:1036
+#: ../gui/wxpython/nviz/tools.py:1674
+#: ../gui/wxpython/gui_core/dialogs.py:2189
+#: ../gui/wxpython/psmap/dialogs.py:2734
+#: ../gui/wxpython/psmap/dialogs.py:2872
#: ../gui/wxpython/psmap/dialogs.py:3477
#: ../gui/wxpython/gmodeler/preferences.py:176
#: ../gui/wxpython/gmodeler/preferences.py:295
@@ -81,7 +88,8 @@
msgid "Height:"
msgstr "Hauteur :"
-#: ../gui/wxpython/nviz/tools.py:282 ../gui/wxpython/nviz/preferences.py:149
+#: ../gui/wxpython/nviz/tools.py:282
+#: ../gui/wxpython/nviz/preferences.py:149
msgid "Z-exag:"
msgstr "Exagération verticale :"
@@ -121,18 +129,20 @@
msgid "Reset to default view"
msgstr "Revenir à la vue par défaut"
-#: ../gui/wxpython/nviz/tools.py:340 ../gui/wxpython/nviz/preferences.py:171
+#: ../gui/wxpython/nviz/tools.py:340
+#: ../gui/wxpython/nviz/preferences.py:171
msgid "Image Appearance"
msgstr "Apparence de l'image"
-#: ../gui/wxpython/nviz/tools.py:348 ../gui/wxpython/nviz/preferences.py:178
+#: ../gui/wxpython/nviz/tools.py:348
+#: ../gui/wxpython/nviz/preferences.py:178
#: ../gui/wxpython/gui_core/preferences.py:676
msgid "Background color:"
msgstr "Couleur d'arrière-plan :"
#: ../gui/wxpython/nviz/tools.py:385
msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr "Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est recommandé d'utiliser le mode avion (barre d'outils d'affichage) pour obtenir un déplacement fluide."
+msgstr "Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est recommandé d'utiliser le mode survol (barre d'outils d'affichage) pour obtenir un déplacement fluide."
#: ../gui/wxpython/nviz/tools.py:396
msgid "Record"
@@ -156,17 +166,18 @@
#: ../gui/wxpython/nviz/tools.py:418
msgid "Frame rate (FPS):"
-msgstr ""
+msgstr "Taux de rafraichissement (FPS) :"
#: ../gui/wxpython/nviz/tools.py:424
msgid "Frames are recorded with given frequency (FPS). "
-msgstr ""
+msgstr "Les images sont enregistrées à la fréquence donnée (FPS)."
#: ../gui/wxpython/nviz/tools.py:467
msgid "Save image sequence"
msgstr "Enregistrer la séquence d'image"
-#: ../gui/wxpython/nviz/tools.py:474 ../gui/wxpython/psmap/dialogs.py:4119
+#: ../gui/wxpython/nviz/tools.py:474
+#: ../gui/wxpython/psmap/dialogs.py:4119
msgid "Choose a directory:"
msgstr "Choisir un répertoire :"
@@ -174,7 +185,8 @@
msgid "Choose a directory for images"
msgstr "Choisir un répertoire pour les images"
-#: ../gui/wxpython/nviz/tools.py:476 ../gui/wxpython/gui_core/gselect.py:877
+#: ../gui/wxpython/nviz/tools.py:476
+#: ../gui/wxpython/gui_core/gselect.py:877
#: ../gui/wxpython/gui_core/gselect.py:1175
#: ../gui/wxpython/gui_core/gselect.py:1184
#: ../gui/wxpython/gui_core/gselect.py:1193
@@ -182,7 +194,8 @@
#: ../gui/wxpython/gui_core/gselect.py:1696
#: ../gui/wxpython/gui_core/forms.py:1290
#: ../gui/wxpython/gui_core/dialogs.py:1810
-#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
+#: ../gui/wxpython/psmap/dialogs.py:1971
+#: ../gui/wxpython/psmap/dialogs.py:2160
#: ../gui/wxpython/psmap/dialogs.py:4121
#: ../gui/wxpython/location_wizard/wizard.py:100
#: ../gui/wxpython/location_wizard/wizard.py:1109
@@ -203,16 +216,19 @@
msgid "File format:"
msgstr "Format de fichier :"
-#: ../gui/wxpython/nviz/tools.py:542 ../gui/wxpython/nviz/tools.py:1766
+#: ../gui/wxpython/nviz/tools.py:542
+#: ../gui/wxpython/nviz/tools.py:1766
#: ../gui/wxpython/nviz/preferences.py:360
msgid "Surface"
msgstr "Surface"
-#: ../gui/wxpython/nviz/tools.py:548 ../gui/wxpython/nviz/tools.py:1079
+#: ../gui/wxpython/nviz/tools.py:548
+#: ../gui/wxpython/nviz/tools.py:1079
msgid "Constant surface"
msgstr "Surface constante"
-#: ../gui/wxpython/nviz/tools.py:553 ../gui/wxpython/nviz/preferences.py:462
+#: ../gui/wxpython/nviz/tools.py:553
+#: ../gui/wxpython/nviz/preferences.py:462
msgid "Vector"
msgstr "Vecteur"
@@ -220,7 +236,8 @@
msgid "Volume"
msgstr "volume"
-#: ../gui/wxpython/nviz/tools.py:594 ../gui/wxpython/nviz/preferences.py:252
+#: ../gui/wxpython/nviz/tools.py:594
+#: ../gui/wxpython/nviz/preferences.py:252
msgid "Lighting"
msgstr "Éclairage"
@@ -232,48 +249,58 @@
msgid "Decorations"
msgstr "Décorations"
-#: ../gui/wxpython/nviz/tools.py:626 ../gui/wxpython/nviz/tools.py:937
+#: ../gui/wxpython/nviz/tools.py:626
+#: ../gui/wxpython/nviz/tools.py:937
msgid "Cutting planes"
msgstr "Plans de coupe"
-#: ../gui/wxpython/nviz/tools.py:648 ../gui/wxpython/nviz/mapwindow.py:1611
+#: ../gui/wxpython/nviz/tools.py:648
+#: ../gui/wxpython/nviz/mapwindow.py:1611
#: ../gui/wxpython/psmap/dialogs.py:1143
msgid "Raster map"
msgstr "Carte raster"
-#: ../gui/wxpython/nviz/tools.py:671 ../gui/wxpython/nviz/tools.py:1467
+#: ../gui/wxpython/nviz/tools.py:671
+#: ../gui/wxpython/nviz/tools.py:1467
#: ../gui/wxpython/nviz/preferences.py:367
msgid "Draw"
msgstr "Dessiner"
-#: ../gui/wxpython/nviz/tools.py:678 ../gui/wxpython/nviz/tools.py:1474
+#: ../gui/wxpython/nviz/tools.py:678
+#: ../gui/wxpython/nviz/tools.py:1474
#: ../gui/wxpython/nviz/preferences.py:373
msgid "Mode:"
msgstr "Mode :"
-#: ../gui/wxpython/nviz/tools.py:681 ../gui/wxpython/nviz/preferences.py:376
+#: ../gui/wxpython/nviz/tools.py:681
+#: ../gui/wxpython/nviz/preferences.py:376
msgid "coarse"
msgstr "grossier"
-#: ../gui/wxpython/nviz/tools.py:682 ../gui/wxpython/nviz/preferences.py:377
+#: ../gui/wxpython/nviz/tools.py:682
+#: ../gui/wxpython/nviz/preferences.py:377
msgid "fine"
msgstr "fin"
-#: ../gui/wxpython/nviz/tools.py:683 ../gui/wxpython/nviz/preferences.py:378
+#: ../gui/wxpython/nviz/tools.py:683
+#: ../gui/wxpython/nviz/preferences.py:378
msgid "both"
msgstr "les deux"
-#: ../gui/wxpython/nviz/tools.py:692 ../gui/wxpython/nviz/tools.py:953
+#: ../gui/wxpython/nviz/tools.py:692
+#: ../gui/wxpython/nviz/tools.py:953
#: ../gui/wxpython/nviz/tools.py:1488
msgid "Shading:"
msgstr "Ombrage :"
-#: ../gui/wxpython/nviz/tools.py:695 ../gui/wxpython/nviz/tools.py:1254
+#: ../gui/wxpython/nviz/tools.py:695
+#: ../gui/wxpython/nviz/tools.py:1254
#: ../gui/wxpython/nviz/tools.py:1491
msgid "flat"
msgstr "plat"
-#: ../gui/wxpython/nviz/tools.py:696 ../gui/wxpython/nviz/tools.py:1492
+#: ../gui/wxpython/nviz/tools.py:696
+#: ../gui/wxpython/nviz/tools.py:1492
msgid "gouraud"
msgstr "gouraud"
@@ -285,25 +312,30 @@
msgid "Use draw settings for all loaded surfaces"
msgstr "Utiliser les paramètres de rendu pour toutes les surfaces chargées"
-#: ../gui/wxpython/nviz/tools.py:713 ../gui/wxpython/nviz/preferences.py:405
+#: ../gui/wxpython/nviz/tools.py:713
+#: ../gui/wxpython/nviz/preferences.py:405
msgid "Coarse mode:"
msgstr "Mode grossier :"
-#: ../gui/wxpython/nviz/tools.py:716 ../gui/wxpython/nviz/tools.py:756
+#: ../gui/wxpython/nviz/tools.py:716
+#: ../gui/wxpython/nviz/tools.py:756
#: ../gui/wxpython/nviz/preferences.py:392
#: ../gui/wxpython/nviz/preferences.py:409
msgid "resolution:"
msgstr "résolution :"
-#: ../gui/wxpython/nviz/tools.py:729 ../gui/wxpython/nviz/preferences.py:421
+#: ../gui/wxpython/nviz/tools.py:729
+#: ../gui/wxpython/nviz/preferences.py:421
msgid "style:"
msgstr "style :"
-#: ../gui/wxpython/nviz/tools.py:732 ../gui/wxpython/nviz/preferences.py:424
+#: ../gui/wxpython/nviz/tools.py:732
+#: ../gui/wxpython/nviz/preferences.py:424
msgid "wire"
msgstr "treillis"
-#: ../gui/wxpython/nviz/tools.py:733 ../gui/wxpython/nviz/preferences.py:425
+#: ../gui/wxpython/nviz/tools.py:733
+#: ../gui/wxpython/nviz/preferences.py:425
msgid "surface"
msgstr "surface"
@@ -311,7 +343,8 @@
msgid "Change wire color"
msgstr "Couleur du treillis"
-#: ../gui/wxpython/nviz/tools.py:752 ../gui/wxpython/nviz/preferences.py:388
+#: ../gui/wxpython/nviz/tools.py:752
+#: ../gui/wxpython/nviz/preferences.py:388
msgid "Fine mode:"
msgstr "Mode fin :"
@@ -319,44 +352,58 @@
msgid "Surface attributes"
msgstr "Attributs pour les surfaces"
-#: ../gui/wxpython/nviz/tools.py:785 ../gui/wxpython/nviz/tools.py:2270
-#: ../gui/wxpython/psmap/dialogs.py:4593 ../gui/wxpython/psmap/dialogs.py:4848
+#: ../gui/wxpython/nviz/tools.py:785
+#: ../gui/wxpython/nviz/tools.py:2270
+#: ../gui/wxpython/psmap/dialogs.py:4593
+#: ../gui/wxpython/psmap/dialogs.py:4848
#: ../gui/wxpython/wxplot/dialogs.py:595
#: ../gui/wxpython/gmodeler/preferences.py:88
#: ../gui/wxpython/gmodeler/preferences.py:326
msgid "Color"
msgstr "Couleur"
-#: ../gui/wxpython/nviz/tools.py:786 ../gui/wxpython/nviz/tools.py:2271
-#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/psmap/dialogs.py:1726
+#: ../gui/wxpython/nviz/tools.py:786
+#: ../gui/wxpython/nviz/tools.py:2271
+#: ../gui/wxpython/menustrings.py:312
+#: ../gui/wxpython/psmap/dialogs.py:1726
msgid "Mask"
msgstr "Masque"
-#: ../gui/wxpython/nviz/tools.py:787 ../gui/wxpython/nviz/tools.py:2272
+#: ../gui/wxpython/nviz/tools.py:787
+#: ../gui/wxpython/nviz/tools.py:2272
msgid "Transparency"
msgstr "Transparence"
-#: ../gui/wxpython/nviz/tools.py:788 ../gui/wxpython/nviz/tools.py:2273
+#: ../gui/wxpython/nviz/tools.py:788
+#: ../gui/wxpython/nviz/tools.py:2273
msgid "Shininess"
msgstr "Luminosité"
-#: ../gui/wxpython/nviz/tools.py:794 ../gui/wxpython/nviz/tools.py:2284
+#: ../gui/wxpython/nviz/tools.py:794
+#: ../gui/wxpython/nviz/tools.py:2284
msgid "map"
msgstr "carte"
-#: ../gui/wxpython/nviz/tools.py:797 ../gui/wxpython/nviz/tools.py:2289
+#: ../gui/wxpython/nviz/tools.py:797
+#: ../gui/wxpython/nviz/tools.py:2289
msgid "unset"
msgstr "non défini"
-#: ../gui/wxpython/nviz/tools.py:802 ../gui/wxpython/nviz/tools.py:2294
+#: ../gui/wxpython/nviz/tools.py:802
+#: ../gui/wxpython/nviz/tools.py:2294
msgid "constant"
msgstr "constante"
-#: ../gui/wxpython/nviz/tools.py:853 ../gui/wxpython/nviz/tools.py:1583
-#: ../gui/wxpython/psmap/dialogs.py:2704 ../gui/wxpython/psmap/dialogs.py:3246
-#: ../gui/wxpython/psmap/dialogs.py:3441 ../gui/wxpython/psmap/dialogs.py:3815
-#: ../gui/wxpython/psmap/dialogs.py:3819 ../gui/wxpython/psmap/dialogs.py:4221
-#: ../gui/wxpython/psmap/dialogs.py:4226 ../gui/wxpython/psmap/dialogs.py:4675
+#: ../gui/wxpython/nviz/tools.py:853
+#: ../gui/wxpython/nviz/tools.py:1583
+#: ../gui/wxpython/psmap/dialogs.py:2704
+#: ../gui/wxpython/psmap/dialogs.py:3246
+#: ../gui/wxpython/psmap/dialogs.py:3441
+#: ../gui/wxpython/psmap/dialogs.py:3815
+#: ../gui/wxpython/psmap/dialogs.py:3819
+#: ../gui/wxpython/psmap/dialogs.py:4221
+#: ../gui/wxpython/psmap/dialogs.py:4226
+#: ../gui/wxpython/psmap/dialogs.py:4675
#: ../gui/wxpython/psmap/dialogs.py:4680
msgid "Position"
msgstr "Position"
@@ -365,12 +412,15 @@
msgid "Changes the x, y, and z position of the current surface"
msgstr "Modifier les positions x, y et z de la surface actuelle"
-#: ../gui/wxpython/nviz/tools.py:869 ../gui/wxpython/nviz/tools.py:1055
-#: ../gui/wxpython/nviz/tools.py:1598 ../gui/wxpython/nviz/tools.py:2454
+#: ../gui/wxpython/nviz/tools.py:869
+#: ../gui/wxpython/nviz/tools.py:1055
+#: ../gui/wxpython/nviz/tools.py:1598
+#: ../gui/wxpython/nviz/tools.py:2454
msgid "Reset"
msgstr "Remise à zéro"
-#: ../gui/wxpython/nviz/tools.py:870 ../gui/wxpython/nviz/tools.py:1599
+#: ../gui/wxpython/nviz/tools.py:870
+#: ../gui/wxpython/nviz/tools.py:1599
msgid "Reset to default position"
msgstr "Revenir à la position par défaut"
@@ -392,7 +442,7 @@
#: ../gui/wxpython/nviz/tools.py:958
msgid "blend"
-msgstr ""
+msgstr "hachures"
#: ../gui/wxpython/nviz/tools.py:959
msgid "shaded"
@@ -414,7 +464,8 @@
msgid "Sets the Y coordinate of the current cutting plane"
msgstr "Définir la coordonnée Y du plan de coupe"
-#: ../gui/wxpython/nviz/tools.py:1004 ../gui/wxpython/gui_core/dialogs.py:756
+#: ../gui/wxpython/nviz/tools.py:1004
+#: ../gui/wxpython/gui_core/dialogs.py:756
msgid "Rotation:"
msgstr "Rotation :"
@@ -430,13 +481,16 @@
msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
msgstr "Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si l'inclinaison n'est pas à 0)"
-#: ../gui/wxpython/nviz/tools.py:1090 ../gui/wxpython/menustrings.py:4
+#: ../gui/wxpython/nviz/tools.py:1090
+#: ../gui/wxpython/menustrings.py:4
#: ../gui/wxpython/menustrings.py:858
msgid "New"
msgstr "Nouveau"
-#: ../gui/wxpython/nviz/tools.py:1094 ../gui/wxpython/nviz/tools.py:1883
-#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/psmap/dialogs.py:1316
+#: ../gui/wxpython/nviz/tools.py:1094
+#: ../gui/wxpython/nviz/tools.py:1883
+#: ../gui/wxpython/menustrings.py:163
+#: ../gui/wxpython/psmap/dialogs.py:1316
msgid "Delete"
msgstr "Supprimer"
@@ -448,21 +502,26 @@
msgid "Value:"
msgstr "Valeur :"
-#: ../gui/wxpython/nviz/tools.py:1131 ../gui/wxpython/nviz/tools.py:2443
+#: ../gui/wxpython/nviz/tools.py:1131
+#: ../gui/wxpython/nviz/tools.py:2443
msgid "Transparency:"
msgstr "Transparence :"
-#: ../gui/wxpython/nviz/tools.py:1143 ../gui/wxpython/nviz/tools.py:1696
-#: ../gui/wxpython/nviz/tools.py:1817 ../gui/wxpython/nviz/preferences.py:333
+#: ../gui/wxpython/nviz/tools.py:1143
+#: ../gui/wxpython/nviz/tools.py:1696
+#: ../gui/wxpython/nviz/tools.py:1817
+#: ../gui/wxpython/nviz/preferences.py:333
#: ../gui/wxpython/nviz/preferences.py:490
#: ../gui/wxpython/nviz/preferences.py:544
#: ../gui/wxpython/gui_core/preferences.py:960
-#: ../gui/wxpython/psmap/dialogs.py:1776 ../gui/wxpython/psmap/dialogs.py:1879
+#: ../gui/wxpython/psmap/dialogs.py:1776
+#: ../gui/wxpython/psmap/dialogs.py:1879
#: ../gui/wxpython/gcp/manager.py:2437
msgid "Color:"
msgstr "Couleur :"
-#: ../gui/wxpython/nviz/tools.py:1173 ../gui/wxpython/psmap/dialogs.py:2618
+#: ../gui/wxpython/nviz/tools.py:1173
+#: ../gui/wxpython/psmap/dialogs.py:2618
msgid "Vector map"
msgstr "Carte vectorielle"
@@ -470,7 +529,8 @@
msgid "Show vector lines"
msgstr "Montrer les lignes vectorielles"
-#: ../gui/wxpython/nviz/tools.py:1207 ../gui/wxpython/nviz/preferences.py:468
+#: ../gui/wxpython/nviz/tools.py:1207
+#: ../gui/wxpython/nviz/preferences.py:468
msgid "Vector lines"
msgstr "Lignes vectorielles"
@@ -482,7 +542,8 @@
msgid "width:"
msgstr "largeur :"
-#: ../gui/wxpython/nviz/tools.py:1233 ../gui/wxpython/nviz/tools.py:1339
+#: ../gui/wxpython/nviz/tools.py:1233
+#: ../gui/wxpython/nviz/tools.py:1339
msgid "color:"
msgstr "couleur :"
@@ -495,7 +556,8 @@
msgid "on surface(s):"
msgstr "sur la surface :"
-#: ../gui/wxpython/nviz/tools.py:1263 ../gui/wxpython/nviz/tools.py:1390
+#: ../gui/wxpython/nviz/tools.py:1263
+#: ../gui/wxpython/nviz/tools.py:1390
msgid "Height above surface:"
msgstr "Hauteur au-dessus de la surface :"
@@ -503,7 +565,8 @@
msgid "Show vector points"
msgstr "Afficher les points vectoriels"
-#: ../gui/wxpython/nviz/tools.py:1307 ../gui/wxpython/nviz/preferences.py:508
+#: ../gui/wxpython/nviz/tools.py:1307
+#: ../gui/wxpython/nviz/preferences.py:508
msgid "Vector points"
msgstr "Points vectoriels"
@@ -511,11 +574,13 @@
msgid "Icon:"
msgstr "Icône :"
-#: ../gui/wxpython/nviz/tools.py:1321 ../gui/wxpython/psmap/dialogs.py:2000
+#: ../gui/wxpython/nviz/tools.py:1321
+#: ../gui/wxpython/psmap/dialogs.py:2000
msgid "size:"
msgstr "taille :"
-#: ../gui/wxpython/nviz/tools.py:1371 ../gui/wxpython/psmap/dialogs.py:1958
+#: ../gui/wxpython/nviz/tools.py:1371
+#: ../gui/wxpython/psmap/dialogs.py:1958
msgid "symbol:"
msgstr "symbole :"
@@ -539,7 +604,8 @@
msgid "Resolution:"
msgstr "Résolution :"
-#: ../gui/wxpython/nviz/tools.py:1523 ../gui/wxpython/nviz/tools.py:3508
+#: ../gui/wxpython/nviz/tools.py:1523
+#: ../gui/wxpython/nviz/tools.py:3508
msgid "List of isosurfaces"
msgstr "Liste des iso-surfaces"
@@ -559,7 +625,8 @@
msgid "Light color and intensity"
msgstr "Couleur et intensité de la lumière"
-#: ../gui/wxpython/nviz/tools.py:1706 ../gui/wxpython/nviz/preferences.py:306
+#: ../gui/wxpython/nviz/tools.py:1706
+#: ../gui/wxpython/nviz/preferences.py:306
msgid "Brightness:"
msgstr "Luminosité :"
@@ -567,7 +634,8 @@
msgid "Adjusts the brightness of the light"
msgstr "Ajuster la luminosité de la lumière"
-#: ../gui/wxpython/nviz/tools.py:1717 ../gui/wxpython/nviz/preferences.py:320
+#: ../gui/wxpython/nviz/tools.py:1717
+#: ../gui/wxpython/nviz/preferences.py:320
msgid "Ambient:"
msgstr "Ambiante :"
@@ -595,7 +663,8 @@
msgid "S && E"
msgstr "S && E"
-#: ../gui/wxpython/nviz/tools.py:1799 ../gui/wxpython/gui_core/gselect.py:1101
+#: ../gui/wxpython/nviz/tools.py:1799
+#: ../gui/wxpython/gui_core/gselect.py:1101
#: ../gui/wxpython/gui_core/toolbars.py:77
msgid "Settings"
msgstr "Paramètres"
@@ -604,7 +673,8 @@
msgid "Elevation of fringe from bottom:"
msgstr "Altitude de la frange depuis le fond :"
-#: ../gui/wxpython/nviz/tools.py:1853 ../gui/wxpython/psmap/toolbars.py:85
+#: ../gui/wxpython/nviz/tools.py:1853
+#: ../gui/wxpython/psmap/toolbars.py:85
#: ../gui/wxpython/psmap/dialogs.py:4490
#: ../gui/wxpython/mapdisp/toolbars.py:35
msgid "North Arrow"
@@ -622,7 +692,8 @@
msgid "Place arrow"
msgstr "Positionner la flèche"
-#: ../gui/wxpython/nviz/tools.py:1895 ../gui/wxpython/psmap/toolbars.py:81
+#: ../gui/wxpython/nviz/tools.py:1895
+#: ../gui/wxpython/psmap/toolbars.py:81
msgid "Scale bar"
msgstr "Barre d'échelle"
@@ -659,8 +730,10 @@
msgid "Directory %s does not exist."
msgstr "Le répertoire %s n'existe pas."
-#: ../gui/wxpython/nviz/tools.py:2146 ../gui/wxpython/nviz/tools.py:2191
-#: ../gui/wxpython/nviz/tools.py:4286 ../gui/wxpython/nviz/mapwindow.py:2110
+#: ../gui/wxpython/nviz/tools.py:2146
+#: ../gui/wxpython/nviz/tools.py:2191
+#: ../gui/wxpython/nviz/tools.py:4286
+#: ../gui/wxpython/nviz/mapwindow.py:2110
#: ../gui/wxpython/nviz/mapwindow.py:2128
msgid "constant#"
msgstr "constante#"
@@ -670,8 +743,9 @@
msgstr "Attributs de l'iso-surface"
#: ../gui/wxpython/nviz/tools.py:2263
+#, fuzzy
msgid "toggle normal direction"
-msgstr ""
+msgstr "Bascule de la direction normale"
#: ../gui/wxpython/nviz/tools.py:2269
msgid "Isosurface value"
@@ -717,8 +791,10 @@
msgid "SW"
msgstr "SO"
-#: ../gui/wxpython/nviz/tools.py:3003 ../gui/wxpython/nviz/tools.py:3695
-#: ../gui/wxpython/nviz/tools.py:3697 ../gui/wxpython/nviz/tools.py:4614
+#: ../gui/wxpython/nviz/tools.py:3003
+#: ../gui/wxpython/nviz/tools.py:3695
+#: ../gui/wxpython/nviz/tools.py:3697
+#: ../gui/wxpython/nviz/tools.py:4614
msgid "Level"
msgstr "Niveau"
@@ -726,8 +802,10 @@
msgid "List of slices"
msgstr "Liste des tranches"
-#: ../gui/wxpython/nviz/tools.py:3704 ../gui/wxpython/nviz/tools.py:3706
-#: ../gui/wxpython/nviz/tools.py:3983 ../gui/wxpython/nviz/tools.py:4627
+#: ../gui/wxpython/nviz/tools.py:3704
+#: ../gui/wxpython/nviz/tools.py:3706
+#: ../gui/wxpython/nviz/tools.py:3983
+#: ../gui/wxpython/nviz/tools.py:4627
msgid "Slice parallel to"
msgstr "Tranches parallèles à"
@@ -735,7 +813,8 @@
msgid "None"
msgstr "Aucun"
-#: ../gui/wxpython/nviz/tools.py:4294 ../gui/wxpython/menustrings.py:462
+#: ../gui/wxpython/nviz/tools.py:4294
+#: ../gui/wxpython/menustrings.py:462
msgid "Plane"
msgstr "Plan"
@@ -757,37 +836,44 @@
msgstr "intervalle:"
# Easting et Northing sont ici traduits resp. Abscisse et Ordonnée, désignant plutôt des valeurs numériques que des directions cardinales.
-#: ../gui/wxpython/nviz/tools.py:4715 ../gui/wxpython/nviz/tools.py:4726
+#: ../gui/wxpython/nviz/tools.py:4715
+#: ../gui/wxpython/nviz/tools.py:4726
msgid "North edge:"
msgstr "Limite nord :"
-#: ../gui/wxpython/nviz/tools.py:4716 ../gui/wxpython/nviz/tools.py:4727
+#: ../gui/wxpython/nviz/tools.py:4716
+#: ../gui/wxpython/nviz/tools.py:4727
msgid "South edge:"
msgstr "Limite sud :"
-#: ../gui/wxpython/nviz/tools.py:4717 ../gui/wxpython/nviz/tools.py:4724
+#: ../gui/wxpython/nviz/tools.py:4717
+#: ../gui/wxpython/nviz/tools.py:4724
#: ../gui/wxpython/nviz/tools.py:4733
msgid "West edge:"
msgstr "Limite ouest :"
-#: ../gui/wxpython/nviz/tools.py:4718 ../gui/wxpython/nviz/tools.py:4725
+#: ../gui/wxpython/nviz/tools.py:4718
+#: ../gui/wxpython/nviz/tools.py:4725
#: ../gui/wxpython/nviz/tools.py:4734
msgid "East edge:"
msgstr "Limite est :"
-#: ../gui/wxpython/nviz/tools.py:4720 ../gui/wxpython/nviz/tools.py:4731
+#: ../gui/wxpython/nviz/tools.py:4720
+#: ../gui/wxpython/nviz/tools.py:4731
#: ../gui/wxpython/nviz/tools.py:4739
msgid "Northing (Y):"
msgstr "Ordonnée (Y) :"
-#: ../gui/wxpython/nviz/tools.py:4721 ../gui/wxpython/nviz/tools.py:4730
+#: ../gui/wxpython/nviz/tools.py:4721
+#: ../gui/wxpython/nviz/tools.py:4730
#: ../gui/wxpython/nviz/tools.py:4740
msgid "Height (Z):"
msgstr "Hauteur (Z) :"
-#: ../gui/wxpython/nviz/tools.py:4722 ../gui/wxpython/nviz/tools.py:4729
+#: ../gui/wxpython/nviz/tools.py:4722
+#: ../gui/wxpython/nviz/tools.py:4729
#: ../gui/wxpython/nviz/tools.py:4738
msgid "Easting (X):"
msgstr "Abscisse (X) :"
@@ -802,7 +888,7 @@
#: ../gui/wxpython/nviz/tools.py:4840
msgid "Adjusts the distance and direction of the image viewpoint"
-msgstr ""
+msgstr "Ajuster la distance et la direction au point de vue"
#: ../gui/wxpython/nviz/tools.py:4872
msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
@@ -842,12 +928,12 @@
#: ../gui/wxpython/nviz/preferences.py:204
msgid "Fly-through"
-msgstr ""
+msgstr "Survol"
#: ../gui/wxpython/nviz/preferences.py:208
#: ../gui/wxpython/mapdisp/toolbars.py:56
msgid "Fly-through mode"
-msgstr ""
+msgstr "Mode survol"
#: ../gui/wxpython/nviz/preferences.py:215
msgid "Move exag:"
@@ -891,7 +977,8 @@
msgid "3D view settings saved to file <%s>."
msgstr "Paramètres de vue 3D enregistrés dans le fichier %s."
-#: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/wxplot/profile.py:31
+#: ../gui/wxpython/nviz/wxnviz.py:32
+#: ../gui/wxpython/wxplot/profile.py:31
msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
msgstr "Ce module requiert le module NumPy, qui n'a pas pu êter importé. Il n'est probablement pas installé (n'est pas compris dans la distribution standard Python). Voir le site Numeric Python (http://numpy.scipy.org) pour télécharger les binaires ou le code source."
@@ -900,7 +987,8 @@
msgid "3D view mode: %s\n"
msgstr "Mode vue 3D : %s\n"
-#: ../gui/wxpython/nviz/wxnviz.py:321 ../gui/wxpython/nviz/wxnviz.py:332
+#: ../gui/wxpython/nviz/wxnviz.py:321
+#: ../gui/wxpython/nviz/wxnviz.py:332
#: ../gui/wxpython/modules/histogram.py:343
#, python-format
msgid "Raster map <%s> not found"
@@ -911,7 +999,8 @@
msgid "Vector map <%s> not found"
msgstr "Carte vectorielle <%s> non trouvée"
-#: ../gui/wxpython/nviz/wxnviz.py:474 ../gui/wxpython/nviz/wxnviz.py:486
+#: ../gui/wxpython/nviz/wxnviz.py:474
+#: ../gui/wxpython/nviz/wxnviz.py:486
#, python-format
msgid "3d raster map <%s> not found"
msgstr "carte raster 3d <%s> non trouvée"
@@ -1073,7 +1162,8 @@
msgid "3D view Toolbar"
msgstr "Barre d'outils de vue 3D"
-#: ../gui/wxpython/lmgr/frame.py:228 ../gui/wxpython/lmgr/frame.py:1158
+#: ../gui/wxpython/lmgr/frame.py:228
+#: ../gui/wxpython/lmgr/frame.py:1158
msgid "Rename Map Display"
msgstr "Renommer la fenêtre de carte"
@@ -1081,7 +1171,8 @@
msgid "Map layers"
msgstr "Couches"
-#: ../gui/wxpython/lmgr/frame.py:260 ../gui/wxpython/lmgr/frame.py:456
+#: ../gui/wxpython/lmgr/frame.py:260
+#: ../gui/wxpython/lmgr/frame.py:456
msgid "Command console"
msgstr "Console de commande"
@@ -1095,7 +1186,8 @@
msgid "Python shell"
msgstr "Shell Python"
-#: ../gui/wxpython/lmgr/frame.py:303 ../gui/wxpython/mapdisp/toolbars.py:84
+#: ../gui/wxpython/lmgr/frame.py:303
+#: ../gui/wxpython/mapdisp/toolbars.py:84
msgid "3D view"
msgstr "Vue 3D"
@@ -1114,7 +1206,8 @@
msgid "Switch to new location?"
msgstr "Changer pour le nouveau secteur ?"
-#: ../gui/wxpython/lmgr/frame.py:354 ../gui/wxpython/lmgr/frame.py:678
+#: ../gui/wxpython/lmgr/frame.py:354
+#: ../gui/wxpython/lmgr/frame.py:678
#, python-format
msgid ""
"Current location is <%(loc)s>.\n"
@@ -1123,11 +1216,13 @@
"Le secteur courant est <%(loc)s>.\n"
"Le jeu de cartes courant est <%(mapset)s>."
-#: ../gui/wxpython/lmgr/frame.py:360 ../gui/wxpython/gis_set.py:427
+#: ../gui/wxpython/lmgr/frame.py:360
+#: ../gui/wxpython/gis_set.py:427
msgid "Do you want to set the default region extents and resolution now?"
msgstr "Voulez-vous définir les limites et la résolution la région par défaut maintenant ?"
-#: ../gui/wxpython/lmgr/frame.py:362 ../gui/wxpython/gis_set.py:429
+#: ../gui/wxpython/lmgr/frame.py:362
+#: ../gui/wxpython/gis_set.py:429
#, python-format
msgid "Location <%s> created"
msgstr "Secteur <%s> créé"
@@ -1136,16 +1231,19 @@
msgid "Choose model to run"
msgstr "Choisir un modèle à exécuter"
-#: ../gui/wxpython/lmgr/frame.py:413 ../gui/wxpython/gmodeler/frame.py:367
+#: ../gui/wxpython/lmgr/frame.py:413
+#: ../gui/wxpython/gmodeler/frame.py:367
#: ../gui/wxpython/gmodeler/frame.py:411
msgid "GRASS Model File (*.gxm)|*.gxm"
msgstr "Ficher modèle GRASS (*.gxm)|*.gxm"
-#: ../gui/wxpython/lmgr/frame.py:470 ../gui/wxpython/lmgr/frame.py:1785
+#: ../gui/wxpython/lmgr/frame.py:470
+#: ../gui/wxpython/lmgr/frame.py:1785
msgid "Do you want to save changes in the workspace?"
msgstr "Voulez-vous enregistrer les modfications de l'espace de travail ?"
-#: ../gui/wxpython/lmgr/frame.py:472 ../gui/wxpython/lmgr/frame.py:1787
+#: ../gui/wxpython/lmgr/frame.py:472
+#: ../gui/wxpython/lmgr/frame.py:1787
msgid "Do you want to store current settings to workspace file?"
msgstr "Voulez-vous enregistrer les paramètres actuels dans un fichier ?"
@@ -1154,7 +1252,8 @@
msgid "Close Map Display %s"
msgstr "Fermer la fenêtre de carte %s"
-#: ../gui/wxpython/lmgr/frame.py:581 ../gui/wxpython/lmgr/frame.py:1402
+#: ../gui/wxpython/lmgr/frame.py:581
+#: ../gui/wxpython/lmgr/frame.py:1402
msgid "Selected map layer is not vector."
msgstr "La couche sélectionnée n'est pas un vecteur."
@@ -1206,28 +1305,34 @@
msgid "No location/mapset provided. Operation canceled."
msgstr "Aucun secteur/jeux de carte sélectionné. Opération annulée."
-#: ../gui/wxpython/lmgr/frame.py:685 ../gui/wxpython/gis_set.py:780
+#: ../gui/wxpython/lmgr/frame.py:685
+#: ../gui/wxpython/gis_set.py:780
msgid "Enter name for new mapset:"
msgstr "Entrer le nom du nouveau jeu de cartes :"
-#: ../gui/wxpython/lmgr/frame.py:686 ../gui/wxpython/gis_set.py:781
+#: ../gui/wxpython/lmgr/frame.py:686
+#: ../gui/wxpython/gis_set.py:781
#: ../gui/wxpython/menustrings.py:227
msgid "Create new mapset"
msgstr "Créer un nouveau jeu de cartes"
-#: ../gui/wxpython/lmgr/frame.py:692 ../gui/wxpython/lmgr/frame.py:713
+#: ../gui/wxpython/lmgr/frame.py:692
+#: ../gui/wxpython/lmgr/frame.py:713
msgid "No mapset provided. Operation canceled."
msgstr "Aucun jeux de carte sélectionné. Opération annulée."
-#: ../gui/wxpython/lmgr/frame.py:701 ../gui/wxpython/lmgr/frame.py:720
+#: ../gui/wxpython/lmgr/frame.py:701
+#: ../gui/wxpython/lmgr/frame.py:720
#, python-format
msgid "Current mapset is <%s>."
msgstr "Le jeux de cartes actuel est <%s>."
-#: ../gui/wxpython/lmgr/frame.py:752 ../gui/wxpython/lmgr/frame.py:757
+#: ../gui/wxpython/lmgr/frame.py:752
+#: ../gui/wxpython/lmgr/frame.py:757
#: ../gui/wxpython/gui_core/ghelp.py:485
#: ../gui/wxpython/gui_core/goutput.py:850
-#: ../gui/wxpython/gmodeler/model.py:927 ../gui/wxpython/gmodeler/model.py:994
+#: ../gui/wxpython/gmodeler/model.py:927
+#: ../gui/wxpython/gmodeler/model.py:994
msgid "unknown"
msgstr "Inconnu"
@@ -1243,7 +1348,8 @@
msgid "GRASS SVN Revision"
msgstr "Version SVN :"
-#: ../gui/wxpython/lmgr/frame.py:775 ../gui/wxpython/gui_core/ghelp.py:439
+#: ../gui/wxpython/lmgr/frame.py:775
+#: ../gui/wxpython/gui_core/ghelp.py:439
msgid "GIS Library Revision"
msgstr "Version de la bibliothèque SIG :"
@@ -1263,7 +1369,8 @@
msgid "Choose workspace file"
msgstr "Choisir un fichier d'environnement de travail"
-#: ../gui/wxpython/lmgr/frame.py:861 ../gui/wxpython/lmgr/frame.py:1052
+#: ../gui/wxpython/lmgr/frame.py:861
+#: ../gui/wxpython/lmgr/frame.py:1052
msgid "GRASS Workspace File (*.gxw)|*.gxw"
msgstr "Fichier d'espace de travail GRASS (*.gxw)|*.gxw"
@@ -1276,7 +1383,8 @@
"Lecture du fichier d'environnement <%s> impossible.\n"
"Fichier non valide, impossible d'analyser le document XML."
-#: ../gui/wxpython/lmgr/frame.py:900 ../gui/wxpython/lmgr/frame.py:1029
+#: ../gui/wxpython/lmgr/frame.py:900
+#: ../gui/wxpython/lmgr/frame.py:1029
msgid "Please wait, loading workspace..."
msgstr "Patientez, chargement de l'environnement de travail ..."
@@ -1292,12 +1400,14 @@
msgid "Choose file to save current workspace"
msgstr "Choisir le fichier où enregistrer l'environnement de travail courant"
-#: ../gui/wxpython/lmgr/frame.py:1066 ../gui/wxpython/lmgr/frame.py:1082
+#: ../gui/wxpython/lmgr/frame.py:1066
+#: ../gui/wxpython/lmgr/frame.py:1082
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
msgstr "Le fichier d'environnement <%s> existe déjà. Voulez-vous écraser ce fichier ?"
-#: ../gui/wxpython/lmgr/frame.py:1068 ../gui/wxpython/lmgr/frame.py:1085
+#: ../gui/wxpython/lmgr/frame.py:1068
+#: ../gui/wxpython/lmgr/frame.py:1085
#: ../gui/wxpython/menustrings.py:9
msgid "Save workspace"
msgstr "Enregistrer l'espace de travail"
@@ -1306,7 +1416,8 @@
msgid "Writing current settings to workspace file failed."
msgstr "Échec d'écriture des paramètres de l'espace de travail courant."
-#: ../gui/wxpython/lmgr/frame.py:1117 ../gui/wxpython/wxplot/profile.py:348
+#: ../gui/wxpython/lmgr/frame.py:1117
+#: ../gui/wxpython/wxplot/profile.py:348
#: ../gui/wxpython/gmodeler/frame.py:881
#, python-format
msgid "Unable to open file <%s> for writing."
@@ -1369,8 +1480,10 @@
msgid "No map layer selected. Operation canceled."
msgstr "Aucune ccouche sélectionnée. Opération annulée."
-#: ../gui/wxpython/lmgr/frame.py:1826 ../gui/wxpython/gis_set.py:523
-#: ../gui/wxpython/gis_set.py:558 ../gui/wxpython/gui_core/ghelp.py:274
+#: ../gui/wxpython/lmgr/frame.py:1826
+#: ../gui/wxpython/gis_set.py:523
+#: ../gui/wxpython/gis_set.py:558
+#: ../gui/wxpython/gui_core/ghelp.py:274
#: ../gui/wxpython/core/gcmd.py:143
msgid "Message"
msgstr "Message"
@@ -1481,7 +1594,8 @@
msgid "Georectifier"
msgstr "Géorectifier"
-#: ../gui/wxpython/lmgr/toolbars.py:142 ../gui/wxpython/menustrings.py:196
+#: ../gui/wxpython/lmgr/toolbars.py:142
+#: ../gui/wxpython/menustrings.py:196
msgid "Cartographic Composer"
msgstr "Composeur de cartes"
@@ -1522,12 +1636,14 @@
msgstr "Afficher le manuel de la vue 3D"
#: ../gui/wxpython/lmgr/layertree.py:50
-#: ../gui/wxpython/gui_core/dialogs.py:1681 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/gui_core/dialogs.py:1681
+#: ../gui/wxpython/menustrings.py:29
msgid "Import raster data"
msgstr "Importer une carte raster"
#: ../gui/wxpython/lmgr/layertree.py:52
-#: ../gui/wxpython/gui_core/dialogs.py:1679 ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/gui_core/dialogs.py:1679
+#: ../gui/wxpython/menustrings.py:150
msgid "Link external raster data"
msgstr "Lier une carte raster externe"
@@ -1536,12 +1652,14 @@
msgstr "Sélectionner le format de sortie raster"
#: ../gui/wxpython/lmgr/layertree.py:56
-#: ../gui/wxpython/gui_core/dialogs.py:1675 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/gui_core/dialogs.py:1675
+#: ../gui/wxpython/menustrings.py:56
msgid "Import vector data"
msgstr "Importer des données vectorielles"
#: ../gui/wxpython/lmgr/layertree.py:58
-#: ../gui/wxpython/gui_core/dialogs.py:1673 ../gui/wxpython/menustrings.py:152
+#: ../gui/wxpython/gui_core/dialogs.py:1673
+#: ../gui/wxpython/menustrings.py:152
msgid "Link external vector data"
msgstr "Lier des données vectorielles externes"
@@ -1596,7 +1714,7 @@
#: ../gui/wxpython/lmgr/layertree.py:84
msgid "Add rhumbline layer"
-msgstr "Ajouter une loxodromie"
+msgstr "Ajouter une couche loxodrome (ligne de direction constante)"
#: ../gui/wxpython/lmgr/layertree.py:86
msgid "Add labels"
@@ -1629,7 +1747,8 @@
msgid "Remove"
msgstr "Supprimer"
-#: ../gui/wxpython/lmgr/layertree.py:338 ../gui/wxpython/menustrings.py:161
+#: ../gui/wxpython/lmgr/layertree.py:338
+#: ../gui/wxpython/menustrings.py:161
msgid "Rename"
msgstr "Renommer"
@@ -1654,11 +1773,13 @@
msgid "Set computational region from selected map(s)"
msgstr "Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
-#: ../gui/wxpython/lmgr/layertree.py:374 ../gui/wxpython/lmgr/layertree.py:447
+#: ../gui/wxpython/lmgr/layertree.py:374
+#: ../gui/wxpython/lmgr/layertree.py:447
msgid "Export"
msgstr "Exporter"
-#: ../gui/wxpython/lmgr/layertree.py:381 ../gui/wxpython/lmgr/layertree.py:453
+#: ../gui/wxpython/lmgr/layertree.py:381
+#: ../gui/wxpython/lmgr/layertree.py:453
msgid "Set color table"
msgstr "Définir une table de couleur"
@@ -1682,7 +1803,8 @@
msgid "Rebuild topology"
msgstr "Reconstruire la topologie"
-#: ../gui/wxpython/lmgr/layertree.py:428 ../gui/wxpython/lmgr/layertree.py:461
+#: ../gui/wxpython/lmgr/layertree.py:428
+#: ../gui/wxpython/lmgr/layertree.py:461
#: ../gui/wxpython/gmodeler/preferences.py:428
msgid "Metadata"
msgstr "Métadonnée"
@@ -1695,11 +1817,13 @@
msgid "Set computational region from selected map(s) (ignore NULLs)"
msgstr "Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) (ignore les NULLs)"
-#: ../gui/wxpython/lmgr/layertree.py:455 ../gui/wxpython/menustrings.py:717
+#: ../gui/wxpython/lmgr/layertree.py:455
+#: ../gui/wxpython/menustrings.py:717
msgid "Histogram"
msgstr "Histogramme"
-#: ../gui/wxpython/lmgr/layertree.py:457 ../gui/wxpython/menustrings.py:506
+#: ../gui/wxpython/lmgr/layertree.py:457
+#: ../gui/wxpython/menustrings.py:506
msgid "Univariate raster statistics"
msgstr "Statistiques raster univariées"
@@ -1711,9 +1835,12 @@
msgid "Unable to create profile of raster map."
msgstr "Impossible de créer le profil de carte raster."
-#: ../gui/wxpython/lmgr/layertree.py:553 ../gui/wxpython/gis_set.py:208
-#: ../gui/wxpython/gis_set.py:535 ../gui/wxpython/gis_set.py:571
-#: ../gui/wxpython/gis_set.py:637 ../gui/wxpython/gui_core/preferences.py:211
+#: ../gui/wxpython/lmgr/layertree.py:553
+#: ../gui/wxpython/gis_set.py:208
+#: ../gui/wxpython/gis_set.py:535
+#: ../gui/wxpython/gis_set.py:571
+#: ../gui/wxpython/gis_set.py:637
+#: ../gui/wxpython/gui_core/preferences.py:211
#: ../gui/wxpython/gui_core/preferences.py:1240
#: ../gui/wxpython/gui_core/preferences.py:1269
#: ../gui/wxpython/gui_core/preferences.py:1278
@@ -1728,8 +1855,10 @@
#: ../gui/wxpython/location_wizard/dialogs.py:438
#: ../gui/wxpython/wxplot/profile.py:349
#: ../gui/wxpython/mapdisp/mapwindow.py:1643
-#: ../gui/wxpython/vdigit/dialogs.py:241 ../gui/wxpython/vdigit/dialogs.py:433
-#: ../gui/wxpython/gmodeler/frame.py:882 ../gui/wxpython/core/workspace.py:999
+#: ../gui/wxpython/vdigit/dialogs.py:241
+#: ../gui/wxpython/vdigit/dialogs.py:433
+#: ../gui/wxpython/gmodeler/frame.py:882
+#: ../gui/wxpython/core/workspace.py:999
#: ../gui/wxpython/core/gcmd.py:109
msgid "Error"
msgstr "Erreur"
@@ -1758,7 +1887,8 @@
#: ../gui/wxpython/lmgr/layertree.py:824
#: ../gui/wxpython/gui_core/dialogs.py:1243
-#: ../gui/wxpython/psmap/dialogs.py:695 ../gui/wxpython/gcp/manager.py:314
+#: ../gui/wxpython/psmap/dialogs.py:695
+#: ../gui/wxpython/gcp/manager.py:314
#: ../gui/wxpython/gmodeler/frame.py:1311
msgid "raster"
msgstr "raster"
@@ -1790,7 +1920,8 @@
#: ../gui/wxpython/lmgr/layertree.py:845
-#: ../gui/wxpython/psmap/dialogs.py:696 ../gui/wxpython/gcp/manager.py:314
+#: ../gui/wxpython/psmap/dialogs.py:696
#: ../gui/wxpython/gmodeler/frame.py:1312
msgid "vector"
msgstr "vecteur"
@@ -1813,7 +1944,7 @@
#: ../gui/wxpython/lmgr/layertree.py:860
msgid "rhumbline"
-msgstr ""
+msgstr "ligne loxodrome (direction constante)"
#: ../gui/wxpython/lmgr/layertree.py:863
msgid "vector labels"
@@ -1943,7 +2074,8 @@
msgid "Enter GRASS session"
msgstr "Démarrer une session GRASS"
-#: ../gui/wxpython/gis_set.py:209 ../gui/wxpython/gis_set.py:638
+#: ../gui/wxpython/gis_set.py:209
+#: ../gui/wxpython/gis_set.py:638
msgid "Unable to set GRASS database. Check your locale settings."
msgstr "Impossible de déterminer la base de données GRASS. Vérifiez vos paramètres de langue."
@@ -1960,7 +2092,7 @@
#: ../gui/wxpython/gis_set.py:378
#, python-format
msgid "Invalid line in GISRC file (%s):%s\n"
-msgstr ""
+msgstr "Ligne invalide dans le fichier GISRC (%s) : %s\n"
#: ../gui/wxpython/gis_set.py:407
#, python-format
@@ -2001,7 +2133,8 @@
"\n"
"Ce jeu de cartes ne peut être renommé."
-#: ../gui/wxpython/gis_set.py:512 ../gui/wxpython/gis_set.py:547
+#: ../gui/wxpython/gis_set.py:512
+#: ../gui/wxpython/gis_set.py:547
#, python-format
msgid ""
"Current name: %s\n"
@@ -2112,7 +2245,8 @@
msgid "Unable to delete location"
msgstr "Impossible d'effacer le secteur"
-#: ../gui/wxpython/gis_set.py:764 ../gui/wxpython/gui_core/gselect.py:876
+#: ../gui/wxpython/gis_set.py:764
+#: ../gui/wxpython/gui_core/gselect.py:876
msgid "Choose GIS Data Directory"
msgstr "Choisir le répertoire de données SIG"
@@ -2143,7 +2277,8 @@
"\n"
"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer de droits pour cette opération) et continuer ?"
-#: ../gui/wxpython/gis_set.py:823 ../gui/wxpython/gis_set.py:835
+#: ../gui/wxpython/gis_set.py:823
+#: ../gui/wxpython/gis_set.py:835
msgid "Lock file found"
msgstr "Ficher de verrouillage détecté"
@@ -2203,9 +2338,12 @@
msgid "Limit 100000 records."
msgstr "Limite 100000 enregistrement"
-#: ../gui/wxpython/dbmgr/manager.py:273 ../gui/wxpython/dbmgr/manager.py:827
-#: ../gui/wxpython/dbmgr/manager.py:1161 ../gui/wxpython/dbmgr/manager.py:1827
-#: ../gui/wxpython/dbmgr/manager.py:1849 ../gui/wxpython/dbmgr/manager.py:1993
+#: ../gui/wxpython/dbmgr/manager.py:273
+#: ../gui/wxpython/dbmgr/manager.py:827
+#: ../gui/wxpython/dbmgr/manager.py:1161
+#: ../gui/wxpython/dbmgr/manager.py:1827
+#: ../gui/wxpython/dbmgr/manager.py:1849
+#: ../gui/wxpython/dbmgr/manager.py:1993
#, python-format
msgid "Number of loaded records: %d"
msgstr "Nombre d’enregistrements chargés : %d"
@@ -2215,7 +2353,8 @@
msgstr "Valeur inconnue"
# Conserver le sigle GUI me semble plus clair pour l'utilisateur que sa traduction française (IGU) peu voire pas usitée.
-#: ../gui/wxpython/dbmgr/manager.py:303 ../gui/wxpython/dbmgr/vinfo.py:42
+#: ../gui/wxpython/dbmgr/manager.py:303
+#: ../gui/wxpython/dbmgr/vinfo.py:42
msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
msgstr "Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI ('Attributs')"
@@ -2244,7 +2383,7 @@
#: ../gui/wxpython/dbmgr/manager.py:404
msgid "Area size"
-msgstr "Aire"
+msgstr "Aire de la surface"
#: ../gui/wxpython/dbmgr/manager.py:405
msgid "Line length"
@@ -2278,7 +2417,8 @@
msgid "Line azimuth"
msgstr "Azimuth de la ligne"
-#: ../gui/wxpython/dbmgr/manager.py:571 ../gui/wxpython/dbmgr/manager.py:3106
+#: ../gui/wxpython/dbmgr/manager.py:571
+#: ../gui/wxpython/dbmgr/manager.py:3106
msgid "GRASS GIS Attribute Table Manager"
msgstr "Gestionnaire des tables d'attributs GRASS"
@@ -2311,13 +2451,16 @@
msgid "Attribute data - right-click to edit/manage records"
msgstr "Données attributaires - clic droit pour éditer/gérer les enregistrements"
-#: ../gui/wxpython/dbmgr/manager.py:703 ../gui/wxpython/dbmgr/manager.py:843
-#: ../gui/wxpython/dbmgr/manager.py:2317 ../gui/wxpython/dbmgr/manager.py:2447
+#: ../gui/wxpython/dbmgr/manager.py:703
+#: ../gui/wxpython/dbmgr/manager.py:843
+#: ../gui/wxpython/dbmgr/manager.py:2317
+#: ../gui/wxpython/dbmgr/manager.py:2447
#: ../gui/wxpython/dbmgr/manager.py:2701
msgid "Table"
msgstr "Table"
-#: ../gui/wxpython/dbmgr/manager.py:705 ../gui/wxpython/dbmgr/manager.py:845
+#: ../gui/wxpython/dbmgr/manager.py:705
+#: ../gui/wxpython/dbmgr/manager.py:845
#: ../gui/wxpython/dbmgr/manager.py:1015
msgid " (readonly)"
msgstr " (lecture seule)"
@@ -2330,7 +2473,8 @@
msgid "Apply SELECT statement and reload data records"
msgstr "Appliquer l'expression SELECT et recharger les enregistrements"
-#: ../gui/wxpython/dbmgr/manager.py:734 ../gui/wxpython/dbmgr/manager.py:2050
+#: ../gui/wxpython/dbmgr/manager.py:734
+#: ../gui/wxpython/dbmgr/manager.py:2050
#: ../gui/wxpython/dbmgr/sqlbuilder.py:454
msgid "SQL Builder"
msgstr "Constructeur SQL"
@@ -2343,13 +2487,15 @@
msgid "Advanced"
msgstr "Élaborée"
-#: ../gui/wxpython/dbmgr/manager.py:755 ../gui/wxpython/dbmgr/manager.py:761
+#: ../gui/wxpython/dbmgr/manager.py:755
+#: ../gui/wxpython/dbmgr/manager.py:761
#: ../gui/wxpython/dbmgr/sqlbuilder.py:108
#, python-format
msgid "Example: %s"
msgstr "Exemple : %s"
-#: ../gui/wxpython/dbmgr/manager.py:856 ../gui/wxpython/dbmgr/sqlbuilder.py:87
+#: ../gui/wxpython/dbmgr/manager.py:856
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:87
msgid "Database connection"
msgstr "Connexion base de données"
@@ -2363,7 +2509,8 @@
msgid "Add column"
msgstr "Ajouter une colonne"
-#: ../gui/wxpython/dbmgr/manager.py:887 ../gui/wxpython/dbmgr/manager.py:938
+#: ../gui/wxpython/dbmgr/manager.py:887
+#: ../gui/wxpython/dbmgr/manager.py:938
msgid "Column"
msgstr "Colonne"
@@ -2376,7 +2523,8 @@
msgid "Length"
msgstr "Longueur"
-#: ../gui/wxpython/dbmgr/manager.py:930 ../gui/wxpython/menustrings.py:838
+#: ../gui/wxpython/dbmgr/manager.py:930
+#: ../gui/wxpython/menustrings.py:838
msgid "Rename column"
msgstr "Renommer une colonne"
@@ -2397,11 +2545,13 @@
msgid "List of layers"
msgstr "Liste de couches"
-#: ../gui/wxpython/dbmgr/manager.py:1126 ../gui/wxpython/core/settings.py:702
+#: ../gui/wxpython/dbmgr/manager.py:1126
+#: ../gui/wxpython/core/settings.py:702
msgid "Edit selected record"
msgstr "Éditer les enregistrements sélectionnés"
-#: ../gui/wxpython/dbmgr/manager.py:1130 ../gui/wxpython/dbmgr/manager.py:1380
+#: ../gui/wxpython/dbmgr/manager.py:1130
+#: ../gui/wxpython/dbmgr/manager.py:1380
msgid "Insert new record"
msgstr "Insérer un nouvel enregistrement"
@@ -2433,7 +2583,8 @@
msgid "Highlight selected features and zoom"
msgstr "Surligner et zoomer sur les objets sélectionnés"
-#: ../gui/wxpython/dbmgr/manager.py:1146 ../gui/wxpython/dbmgr/manager.py:2092
+#: ../gui/wxpython/dbmgr/manager.py:1146
+#: ../gui/wxpython/dbmgr/manager.py:2092
msgid "Extract selected features"
msgstr "Extraire les objets sélectionnés"
@@ -2441,7 +2592,8 @@
msgid "Delete selected features"
msgstr "Supprimer les objets sélectionnés"
-#: ../gui/wxpython/dbmgr/manager.py:1155 ../gui/wxpython/dbmgr/manager.py:1679
+#: ../gui/wxpython/dbmgr/manager.py:1155
+#: ../gui/wxpython/dbmgr/manager.py:1679
#: ../gui/wxpython/vdigit/dialogs.py:278
#: ../gui/wxpython/gmodeler/dialogs.py:731
#: ../gui/wxpython/gmodeler/dialogs.py:906
@@ -2453,7 +2605,8 @@
msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
msgstr "Les enregistrements sélectionnés (%d) vont être définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
-#: ../gui/wxpython/dbmgr/manager.py:1190 ../gui/wxpython/dbmgr/manager.py:1236
+#: ../gui/wxpython/dbmgr/manager.py:1190
+#: ../gui/wxpython/dbmgr/manager.py:1236
#: ../gui/wxpython/gmodeler/dialogs.py:851
msgid "Delete records"
msgstr "Supprimer les enregistrements"
@@ -2473,7 +2626,8 @@
msgid "Category number (column %s) is missing."
msgstr "Le numéro de catégorie (colonne %s) est manquant."
-#: ../gui/wxpython/dbmgr/manager.py:1415 ../gui/wxpython/dbmgr/manager.py:1524
+#: ../gui/wxpython/dbmgr/manager.py:1415
+#: ../gui/wxpython/dbmgr/manager.py:1524
#, python-format
msgid "Value '%(value)s' needs to be entered as %(type)s."
msgstr "La valeur '%(value)s' demande à être entrée comme %(type)s."
@@ -2527,7 +2681,8 @@
msgid "Selected column '%s' will PERMANENTLY removed from table. Do you want to drop the column?"
msgstr "Les colonnes sélectionnées '%s' seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces colonnes ?"
-#: ../gui/wxpython/dbmgr/manager.py:1695 ../gui/wxpython/dbmgr/manager.py:1732
+#: ../gui/wxpython/dbmgr/manager.py:1695
+#: ../gui/wxpython/dbmgr/manager.py:1732
msgid "Drop column(s)"
msgstr "Supprimer la(les) colonne(s)"
@@ -2551,7 +2706,8 @@
msgid "Column <%(column)s> already exists in table <%(table)s>."
msgstr "La colonne <%(column)s> existe déjà dans la table <%(table)s>."
-#: ../gui/wxpython/dbmgr/manager.py:1955 ../gui/wxpython/dbmgr/manager.py:1978
+#: ../gui/wxpython/dbmgr/manager.py:1955
+#: ../gui/wxpython/dbmgr/manager.py:1978
#, python-format
msgid ""
"Loading attribute data failed.\n"
@@ -2583,7 +2739,8 @@
msgid "Nothing to delete."
msgstr "Rien à supprimer."
-#: ../gui/wxpython/dbmgr/manager.py:2208 ../gui/wxpython/dbmgr/manager.py:2623
+#: ../gui/wxpython/dbmgr/manager.py:2208
+#: ../gui/wxpython/dbmgr/manager.py:2623
#: ../gui/wxpython/dbmgr/manager.py:3043
#, python-format
msgid "Drop also linked attribute table (%s)"
@@ -2603,20 +2760,25 @@
msgid "Data length"
msgstr "Taille de la donnée"
-#: ../gui/wxpython/dbmgr/manager.py:2317 ../gui/wxpython/dbmgr/manager.py:2430
-#: ../gui/wxpython/dbmgr/manager.py:2681 ../gui/wxpython/dbmgr/dialogs.py:483
+#: ../gui/wxpython/dbmgr/manager.py:2430
+#: ../gui/wxpython/dbmgr/manager.py:2681
+#: ../gui/wxpython/dbmgr/dialogs.py:483
#: ../gui/wxpython/vdigit/preferences.py:362
#: ../gui/wxpython/vdigit/preferences.py:364
-#: ../gui/wxpython/vdigit/dialogs.py:111 ../gui/wxpython/vdigit/dialogs.py:555
+#: ../gui/wxpython/vdigit/dialogs.py:111
+#: ../gui/wxpython/vdigit/dialogs.py:555
msgid "Layer"
msgstr "Couche"
-#: ../gui/wxpython/dbmgr/manager.py:2317 ../gui/wxpython/dbmgr/manager.py:2436
+#: ../gui/wxpython/dbmgr/manager.py:2436
#: ../gui/wxpython/dbmgr/manager.py:2689
msgid "Driver"
msgstr "Pilote"
-#: ../gui/wxpython/dbmgr/manager.py:2317 ../gui/wxpython/dbmgr/manager.py:2441
+#: ../gui/wxpython/dbmgr/manager.py:2441
#: ../gui/wxpython/dbmgr/manager.py:2695
#: ../gui/wxpython/gui_core/gselect.py:1130
msgid "Database"
@@ -2638,7 +2800,8 @@
msgid "Layer description"
msgstr "Description de couche"
-#: ../gui/wxpython/dbmgr/manager.py:2452 ../gui/wxpython/dbmgr/manager.py:2490
+#: ../gui/wxpython/dbmgr/manager.py:2452
+#: ../gui/wxpython/dbmgr/manager.py:2490
#: ../gui/wxpython/dbmgr/manager.py:2707
msgid "Key column"
msgstr "Colonne clé"
@@ -2722,7 +2885,8 @@
msgid "SQL statement not verified"
msgstr "Expression SQL non vérifiée"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:99 ../gui/wxpython/menustrings.py:820
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:99
+#: ../gui/wxpython/menustrings.py:820
msgid "Query"
msgstr "Requête"
@@ -2820,7 +2984,8 @@
msgid "No attributes found"
msgstr "Aucun attribut trouvé"
-#: ../gui/wxpython/dbmgr/dialogs.py:112 ../gui/wxpython/menustrings.py:650
+#: ../gui/wxpython/dbmgr/dialogs.py:112
+#: ../gui/wxpython/menustrings.py:650
msgid "Update attributes"
msgstr "Mettre à jour les attributs"
@@ -2836,11 +3001,13 @@
msgid "&Reload"
msgstr "&Recharger"
-#: ../gui/wxpython/dbmgr/dialogs.py:121 ../gui/wxpython/dbmgr/dialogs.py:587
+#: ../gui/wxpython/dbmgr/dialogs.py:121
+#: ../gui/wxpython/dbmgr/dialogs.py:587
msgid "&Submit"
msgstr "&Soumettre"
-#: ../gui/wxpython/dbmgr/dialogs.py:139 ../gui/wxpython/vdigit/dialogs.py:166
+#: ../gui/wxpython/dbmgr/dialogs.py:139
+#: ../gui/wxpython/vdigit/dialogs.py:166
msgid "Feature id:"
msgstr "Id objet :"
@@ -2853,9 +3020,11 @@
msgid "Unknown"
msgstr "Inconnu"
-#: ../gui/wxpython/dbmgr/dialogs.py:484 ../gui/wxpython/dbmgr/dialogs.py:602
+#: ../gui/wxpython/dbmgr/dialogs.py:484
+#: ../gui/wxpython/dbmgr/dialogs.py:602
-#: ../gui/wxpython/vdigit/dialogs.py:118 ../gui/wxpython/vdigit/dialogs.py:556
+#: ../gui/wxpython/vdigit/dialogs.py:118
+#: ../gui/wxpython/vdigit/dialogs.py:556
msgid "Category"
msgstr "Catégorie"
@@ -2886,19 +3055,22 @@
msgstr "Revenir aux réglages par défaut et appliquer les modifications"
#: ../gui/wxpython/gui_core/preferences.py:87
-#: ../gui/wxpython/wxplot/dialogs.py:376 ../gui/wxpython/wxplot/dialogs.py:763
+#: ../gui/wxpython/wxplot/dialogs.py:376
+#: ../gui/wxpython/wxplot/dialogs.py:763
#: ../gui/wxpython/gcp/manager.py:2370
msgid "Apply changes for the current session"
msgstr "Appliquer les changements pour la session courante"
#: ../gui/wxpython/gui_core/preferences.py:89
-#: ../gui/wxpython/wxplot/dialogs.py:381 ../gui/wxpython/wxplot/dialogs.py:765
+#: ../gui/wxpython/wxplot/dialogs.py:381
+#: ../gui/wxpython/wxplot/dialogs.py:765
#: ../gui/wxpython/gcp/manager.py:2372
msgid "Apply and save changes to user settings file (default for next sessions)"
msgstr "Appliquer et enregistrer les changements dans le fichier de configuration personnel (valeurs par défaut pour la prochaine session)"
#: ../gui/wxpython/gui_core/preferences.py:92
-#: ../gui/wxpython/psmap/dialogs.py:354 ../gui/wxpython/wxplot/dialogs.py:383
+#: ../gui/wxpython/psmap/dialogs.py:354
+#: ../gui/wxpython/wxplot/dialogs.py:383
#: ../gui/wxpython/wxplot/dialogs.py:766
#: ../gui/wxpython/vdigit/preferences.py:58
#: ../gui/wxpython/gmodeler/preferences.py:452
@@ -2979,8 +3151,10 @@
#: ../gui/wxpython/gui_core/preferences.py:412
#: ../gui/wxpython/gui_core/preferences.py:587
#: ../gui/wxpython/gui_core/preferences.py:1390
-#: ../gui/wxpython/psmap/dialogs.py:2787 ../gui/wxpython/psmap/dialogs.py:3265
-#: ../gui/wxpython/psmap/dialogs.py:3721 ../gui/wxpython/wxplot/dialogs.py:310
+#: ../gui/wxpython/psmap/dialogs.py:2787
+#: ../gui/wxpython/psmap/dialogs.py:3265
+#: ../gui/wxpython/psmap/dialogs.py:3721
+#: ../gui/wxpython/wxplot/dialogs.py:310
msgid "Font settings"
msgstr "Réglages de police"
@@ -3083,7 +3257,8 @@
#: ../gui/wxpython/gui_core/preferences.py:809
#: ../gui/wxpython/gui_core/dialogs.py:1506
-#: ../gui/wxpython/modules/vclean.py:135 ../gui/wxpython/scripts/vkrige.py:139
+#: ../gui/wxpython/modules/vclean.py:135
+#: ../gui/wxpython/scripts/vkrige.py:139
#: ../gui/wxpython/gmodeler/preferences.py:442
msgid "Allow output files to overwrite existing files"
msgstr "Permettre au fichier de sortie d'écraser les fichiers existants"
@@ -3238,7 +3413,8 @@
msgstr "Encodage de caractère :"
#: ../gui/wxpython/gui_core/preferences.py:1439
-#: ../gui/wxpython/psmap/dialogs.py:291 ../gui/wxpython/psmap/dialogs.py:3555
+#: ../gui/wxpython/psmap/dialogs.py:291
+#: ../gui/wxpython/psmap/dialogs.py:3555
msgid "Font size:"
msgstr "Taille du texte :"
@@ -3488,8 +3664,10 @@
msgstr "Enregistrer l'affichage dans un fichier graphique"
#: ../gui/wxpython/gui_core/toolbars.py:60
-#: ../gui/wxpython/modules/histogram.py:451 ../gui/wxpython/wxplot/base.py:486
-#: ../gui/wxpython/gcp/mapdisplay.py:493 ../gui/wxpython/mapdisp/frame.py:604
+#: ../gui/wxpython/modules/histogram.py:451
+#: ../gui/wxpython/wxplot/base.py:486
+#: ../gui/wxpython/gcp/mapdisplay.py:493
+#: ../gui/wxpython/mapdisp/frame.py:604
msgid "Print display"
msgstr "Imprimer l'écran"
@@ -3521,15 +3699,18 @@
msgid "Create histogram with d.histogram"
msgstr "Créer un histogramme avec d.histogram"
-#: ../gui/wxpython/gui_core/ghelp.py:56 ../gui/wxpython/gui_core/ghelp.py:64
+#: ../gui/wxpython/gui_core/ghelp.py:56
+#: ../gui/wxpython/gui_core/ghelp.py:64
msgid "description"
msgstr "description"
-#: ../gui/wxpython/gui_core/ghelp.py:57 ../gui/wxpython/gui_core/ghelp.py:66
+#: ../gui/wxpython/gui_core/ghelp.py:57
+#: ../gui/wxpython/gui_core/ghelp.py:66
msgid "command"
msgstr "commande"
-#: ../gui/wxpython/gui_core/ghelp.py:58 ../gui/wxpython/gui_core/ghelp.py:65
+#: ../gui/wxpython/gui_core/ghelp.py:58
+#: ../gui/wxpython/gui_core/ghelp.py:65
msgid "keywords"
msgstr "mots-clé"
@@ -3537,7 +3718,8 @@
msgid "Find module(s)"
msgstr "Trouver le(s) module(s)"
-#: ../gui/wxpython/gui_core/ghelp.py:133 ../gui/wxpython/gui_core/ghelp.py:166
+#: ../gui/wxpython/gui_core/ghelp.py:133
+#: ../gui/wxpython/gui_core/ghelp.py:166
#, python-format
msgid "%d modules found"
msgstr "%d modules trouvés"
@@ -3546,9 +3728,11 @@
msgid "Menu tree (double-click to run command)"
msgstr "Arborescence de menu (double clic pour exécuter une commande)"
-#: ../gui/wxpython/gui_core/ghelp.py:210 ../gui/wxpython/gui_core/forms.py:455
+#: ../gui/wxpython/gui_core/ghelp.py:210
+#: ../gui/wxpython/gui_core/forms.py:455
#: ../gui/wxpython/modules/mcalc_builder.py:132
-#: ../gui/wxpython/modules/vclean.py:156 ../gui/wxpython/scripts/vkrige.py:152
+#: ../gui/wxpython/modules/vclean.py:156
+#: ../gui/wxpython/scripts/vkrige.py:152
#: ../gui/wxpython/gmodeler/frame.py:1481
#: ../gui/wxpython/gmodeler/model.py:2175
msgid "&Run"
@@ -3568,7 +3752,8 @@
msgid "%d modules match"
msgstr "%d modules correspondent"
-#: ../gui/wxpython/gui_core/ghelp.py:384 ../gui/wxpython/menustrings.py:853
+#: ../gui/wxpython/gui_core/ghelp.py:384
+#: ../gui/wxpython/menustrings.py:853
#: ../gui/wxpython/menustrings.py:854
msgid "About GRASS GIS"
msgstr "Au sujet du SIG GRASS"
@@ -3581,7 +3766,8 @@
msgid "SVN Revision"
msgstr "Version SVN"
-#: ../gui/wxpython/gui_core/ghelp.py:477 ../gui/wxpython/gui_core/ghelp.py:710
+#: ../gui/wxpython/gui_core/ghelp.py:477
+#: ../gui/wxpython/gui_core/ghelp.py:710
msgid "Language"
msgstr "Langue"
@@ -3613,23 +3799,28 @@
msgid "Translators"
msgstr "Traducteurs"
-#: ../gui/wxpython/gui_core/ghelp.py:537 ../gui/wxpython/gui_core/ghelp.py:561
-#: ../gui/wxpython/gui_core/ghelp.py:584 ../gui/wxpython/gui_core/ghelp.py:639
+#: ../gui/wxpython/gui_core/ghelp.py:537
+#: ../gui/wxpython/gui_core/ghelp.py:561
+#: ../gui/wxpython/gui_core/ghelp.py:584
+#: ../gui/wxpython/gui_core/ghelp.py:639
#: ../gui/wxpython/gui_core/ghelp.py:698
#, python-format
msgid "%s file missing"
msgstr "fichier %s manquant"
-#: ../gui/wxpython/gui_core/ghelp.py:626 ../gui/wxpython/gui_core/ghelp.py:685
+#: ../gui/wxpython/gui_core/ghelp.py:626
+#: ../gui/wxpython/gui_core/ghelp.py:685
#, python-format
msgid "Error when reading file '%s'."
msgstr "Erreur à la lecture du fichier '%s'."
-#: ../gui/wxpython/gui_core/ghelp.py:627 ../gui/wxpython/gui_core/ghelp.py:686
+#: ../gui/wxpython/gui_core/ghelp.py:627
+#: ../gui/wxpython/gui_core/ghelp.py:686
msgid "Lines:"
msgstr "Lignes :"
-#: ../gui/wxpython/gui_core/ghelp.py:644 ../gui/wxpython/gui_core/ghelp.py:646
+#: ../gui/wxpython/gui_core/ghelp.py:644
+#: ../gui/wxpython/gui_core/ghelp.py:646
#: ../gui/wxpython/gui_core/ghelp.py:706
#: ../gui/wxpython/gmodeler/frame.py:1299
#: ../gui/wxpython/gmodeler/frame.py:1342
@@ -3639,7 +3830,8 @@
msgid "Name"
msgstr "Nom"
#: ../gui/wxpython/gui_core/ghelp.py:708
msgid "E-mail"
msgstr "Courriel"
@@ -3677,7 +3869,8 @@
msgid "Run the command (Ctrl+R)"
msgstr "Exécuter la commande (Ctrl+R)"
-#: ../gui/wxpython/gui_core/forms.py:462 ../gui/wxpython/modules/vclean.py:159
+#: ../gui/wxpython/gui_core/forms.py:462
+#: ../gui/wxpython/modules/vclean.py:159
msgid "Copy the current command string to the clipboard (Ctrl+C)"
msgstr "Copier la commande courante dans le presse-papier [Ctrl+C)"
@@ -3703,15 +3896,18 @@
msgid "'%s' copied to clipboard"
msgstr "'%s' copié dans le presse-papier"
-#: ../gui/wxpython/gui_core/forms.py:745 ../gui/wxpython/gui_core/forms.py:758
+#: ../gui/wxpython/gui_core/forms.py:745
+#: ../gui/wxpython/gui_core/forms.py:758
msgid "Required"
msgstr "Requis"
-#: ../gui/wxpython/gui_core/forms.py:748 ../gui/wxpython/gui_core/forms.py:758
+#: ../gui/wxpython/gui_core/forms.py:748
msgid "Optional"
msgstr "Optionnel"
-#: ../gui/wxpython/gui_core/forms.py:784 ../gui/wxpython/scripts/vkrige.py:108
+#: ../gui/wxpython/gui_core/forms.py:784
+#: ../gui/wxpython/scripts/vkrige.py:108
#: ../gui/wxpython/gmodeler/frame.py:115
msgid "Command output"
msgstr "Messages de la commande"
@@ -3852,7 +4048,7 @@
"impossible de lancer la commande :\n"
"%(cmd)s\n"
"\n"
-"Option <%(opt)s> : la lecture depuis l'entrée standard n'ets pas supportée par wxGUI"
+"Option <%(opt)s> : la lecture depuis l'entrée standard n'est pas prise en charge par wxGUI"
#: ../gui/wxpython/gui_core/goutput.py:655
#: ../gui/wxpython/gui_core/goutput.py:801
@@ -3921,9 +4117,10 @@
#: ../gui/wxpython/gui_core/goutput.py:1346
#: ../gui/wxpython/gmodeler/frame.py:180
msgid "Python script contains local modifications"
-msgstr ""
+msgstr "Le script Python contient des modifications locales"
-#: ../gui/wxpython/gui_core/mapdisp.py:84 ../gui/wxpython/core/render.py:434
+#: ../gui/wxpython/gui_core/mapdisp.py:84
+#: ../gui/wxpython/core/render.py:434
#, python-format
msgid "GRASS module '%s' not found. Unable to start map display window."
msgstr "Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage des cartes."
@@ -3950,7 +4147,8 @@
msgstr "Choisir le jeu de cartes dans le secteur GRASS"
#: ../gui/wxpython/gui_core/dialogs.py:224
-#: ../gui/wxpython/gui_core/dialogs.py:337 ../gui/wxpython/menustrings.py:520
+#: ../gui/wxpython/gui_core/dialogs.py:337
+#: ../gui/wxpython/menustrings.py:520
msgid "Create new vector map"
msgstr "Créer un nouvelle carte vecteur"
@@ -4004,7 +4202,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:530
msgid "Click and drag on the map display to set legend size and position and then press OK"
-msgstr ""
+msgstr "Cliquer et déplacer dans la fenêtre de carte pour définir la taille et la position de la légende, puis appuyer sur OK."
#: ../gui/wxpython/gui_core/dialogs.py:541
#, python-format
@@ -4130,7 +4328,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:1200
#, python-format
msgid "Dynamic series (%s)"
-msgstr ""
+msgstr "Série dynamique (%s)"
#: ../gui/wxpython/gui_core/dialogs.py:1238
msgid "Map type:"
@@ -4251,8 +4449,10 @@
msgstr "Ajuster la transparence de la carte"
#: ../gui/wxpython/gui_core/dialogs.py:2038
-#: ../gui/wxpython/psmap/dialogs.py:4600 ../gui/wxpython/psmap/dialogs.py:4615
-#: ../gui/wxpython/psmap/dialogs.py:4854 ../gui/wxpython/psmap/dialogs.py:4875
+#: ../gui/wxpython/psmap/dialogs.py:4600
+#: ../gui/wxpython/psmap/dialogs.py:4615
+#: ../gui/wxpython/psmap/dialogs.py:4854
+#: ../gui/wxpython/psmap/dialogs.py:4875
msgid "transparent"
msgstr "transparent"
@@ -4284,7 +4484,8 @@
msgid "Symbol name:"
msgstr "Nom du symbole :"
-#: ../gui/wxpython/menustrings.py:2 ../gui/wxpython/menustrings.py:857
+#: ../gui/wxpython/menustrings.py:857
msgid "&File"
msgstr "&Fichier"
@@ -4296,7 +4497,8 @@
msgid "Create new workspace"
msgstr "Créer un nouvel espace de travail"
-#: ../gui/wxpython/menustrings.py:6 ../gui/wxpython/menustrings.py:860
+#: ../gui/wxpython/menustrings.py:860
msgid "Open"
msgstr "Ouvrir"
@@ -4304,12 +4506,14 @@
msgid "Load workspace from file"
msgstr "Charger un espace de travail depuis un fichier"
-#: ../gui/wxpython/menustrings.py:8 ../gui/wxpython/menustrings.py:862
+#: ../gui/wxpython/menustrings.py:862
#: ../gui/wxpython/modules/colorrules.py:406
msgid "Save"
msgstr "Enregistrer"
-#: ../gui/wxpython/menustrings.py:10 ../gui/wxpython/menustrings.py:864
+#: ../gui/wxpython/menustrings.py:10
+#: ../gui/wxpython/menustrings.py:864
msgid "Save as"
msgstr "Enregistrer sous"
@@ -4317,7 +4521,8 @@
msgid "Save workspace to file"
msgstr "Enregistrer l'espace de travail dans un fichier"
-#: ../gui/wxpython/menustrings.py:12 ../gui/wxpython/menustrings.py:866
+#: ../gui/wxpython/menustrings.py:12
+#: ../gui/wxpython/menustrings.py:866
msgid "Close"
msgstr "Fermer"
@@ -4369,11 +4574,13 @@
msgid "Open new map display window"
msgstr "Ouvrir une nouvelle fenêtre d'affichage de cartes"
-#: ../gui/wxpython/menustrings.py:25 ../gui/wxpython/menustrings.py:26
+#: ../gui/wxpython/menustrings.py:25
+#: ../gui/wxpython/menustrings.py:26
msgid "Close current map display window"
msgstr "Fermer la fenêtre d'affichage de carte actuelle"
-#: ../gui/wxpython/menustrings.py:27 ../gui/wxpython/menustrings.py:28
+#: ../gui/wxpython/menustrings.py:27
+#: ../gui/wxpython/menustrings.py:28
msgid "Close all open map display windows"
msgstr "Fermer tous les fenêtres d'affichage de cartes"
@@ -4621,7 +4828,8 @@
msgid "Export raster map"
msgstr "Exporter une carte raster"
-#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:125
+#: ../gui/wxpython/menustrings.py:92
+#: ../gui/wxpython/menustrings.py:125
msgid "Common export formats"
msgstr "Formats standards d'export"
@@ -4709,7 +4917,8 @@
msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
msgstr "Convertit 3 cartes raster (R,V,B) en fichier image PPM à la résolution de la RÉGION COURANTE."
-#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:133
+#: ../gui/wxpython/menustrings.py:114
+#: ../gui/wxpython/menustrings.py:133
msgid "POV-Ray export"
msgstr "Export POV-Ray"
@@ -4733,7 +4942,8 @@
msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
msgstr "Exporte une carte raster vers le langage Virtual Reality Modeling (VRML)"
-#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:137
+#: ../gui/wxpython/menustrings.py:120
+#: ../gui/wxpython/menustrings.py:137
#: ../gui/wxpython/menustrings.py:144
msgid "VTK export"
msgstr "Export VTK"
@@ -4878,7 +5088,8 @@
msgid "Renames data base element files in the user's current mapset."
msgstr "Renommer les fichiers éléments de la base de données dans le jeu de données courant de l'utilisateur"
-#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:166
+#: ../gui/wxpython/menustrings.py:164
+#: ../gui/wxpython/menustrings.py:166
msgid "Removes data base element files from the user's current mapset."
msgstr "Supprimer les fichiers éléments de base de données du jeu de données courant de l'utilisateur"
@@ -4886,72 +5097,90 @@
msgid "Delete filtered"
msgstr "Suppression filtrée"
-#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:299
-#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:777
+#: ../gui/wxpython/menustrings.py:167
+#: ../gui/wxpython/menustrings.py:299
+#: ../gui/wxpython/menustrings.py:578
+#: ../gui/wxpython/menustrings.py:777
msgid "Map type conversions"
msgstr "Conversions de type de carte"
-#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:300
+#: ../gui/wxpython/menustrings.py:168
+#: ../gui/wxpython/menustrings.py:300
msgid "Raster to vector"
msgstr "Raster vers vecteur"
-#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:301
+#: ../gui/wxpython/menustrings.py:169
+#: ../gui/wxpython/menustrings.py:301
msgid "Converts a raster map into a vector map layer."
msgstr "Convertit une carte raster en carte vecteur."
-#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:302
+#: ../gui/wxpython/menustrings.py:170
+#: ../gui/wxpython/menustrings.py:302
msgid "Raster series to volume"
msgstr "Raster vers volume"
-#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:303
+#: ../gui/wxpython/menustrings.py:171
+#: ../gui/wxpython/menustrings.py:303
msgid "Converts 2D raster map slices to one 3D raster volume map."
msgstr "Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
-#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:304
+#: ../gui/wxpython/menustrings.py:172
+#: ../gui/wxpython/menustrings.py:304
msgid "Raster 2.5D to volume"
msgstr "Raster 2.5D vers volume"
-#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:305
+#: ../gui/wxpython/menustrings.py:173
+#: ../gui/wxpython/menustrings.py:305
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
msgstr "Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
-#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:579
+#: ../gui/wxpython/menustrings.py:174
+#: ../gui/wxpython/menustrings.py:579
msgid "Vector to raster"
msgstr "Vecteur vers raster"
-#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:580
+#: ../gui/wxpython/menustrings.py:175
+#: ../gui/wxpython/menustrings.py:580
msgid "Converts (rasterize) a vector map into a raster map."
msgstr "Convertir une carte vecteur en carte raster."
-#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:581
+#: ../gui/wxpython/menustrings.py:176
+#: ../gui/wxpython/menustrings.py:581
msgid "Vector to volume"
msgstr "Vectorielle vers volume"
-#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:582
+#: ../gui/wxpython/menustrings.py:177
+#: ../gui/wxpython/menustrings.py:582
msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
msgstr "Convertir une carte vecteur binaire GRASS (uniquement des points) en carte raster 3D GRASS."
-#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:178
+#: ../gui/wxpython/menustrings.py:583
msgid "2D vector to 3D vector"
msgstr "vecteur 2D vers vecteur 3D"
-#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:584
+#: ../gui/wxpython/menustrings.py:179
+#: ../gui/wxpython/menustrings.py:584
msgid "Performs transformation of 2D vector features to 3D."
msgstr "Effectue la transformation de données vectorielles de 2D vers 3D."
-#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:180
+#: ../gui/wxpython/menustrings.py:585
msgid "Sites to vector"
msgstr "GRASS Sites vers vecteur"
-#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:586
+#: ../gui/wxpython/menustrings.py:181
+#: ../gui/wxpython/menustrings.py:586
msgid "Converts a GRASS site_lists file into a vector map."
msgstr "Convertir un fichier \"site_list\" GRASS en carte vecteur."
-#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:778
+#: ../gui/wxpython/menustrings.py:182
+#: ../gui/wxpython/menustrings.py:778
msgid "Volume to raster series"
msgstr "Volume vers série raster"
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:779
+#: ../gui/wxpython/menustrings.py:183
+#: ../gui/wxpython/menustrings.py:779
msgid "Converts 3D raster maps to 2D raster maps"
msgstr "Convertir des cartes raster 3D en cartes raster 2D"
@@ -4971,7 +5200,8 @@
msgid "Launch Graphical modeler"
msgstr "Lancer le modeleur graphique"
-#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:894
+#: ../gui/wxpython/menustrings.py:188
+#: ../gui/wxpython/menustrings.py:894
msgid "Run model"
msgstr "Exécuter un modèle"
@@ -5023,7 +5253,8 @@
msgid "Quit wxGUI session"
msgstr "Quitter la session wxGUI"
-#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:874
+#: ../gui/wxpython/menustrings.py:202
+#: ../gui/wxpython/menustrings.py:874
msgid "&Settings"
msgstr "Paramètres"
@@ -5035,7 +5266,8 @@
msgid "Display region"
msgstr "Afficher la région"
-#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:207
+#: ../gui/wxpython/menustrings.py:205
+#: ../gui/wxpython/menustrings.py:207
msgid "Manages the boundary definitions for the geographic region."
msgstr "Gère les définitions de contour pour la région géographique."
@@ -5091,7 +5323,8 @@
msgid "Show settings"
msgstr "Montrer les paramètres"
-#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:222
+#: ../gui/wxpython/menustrings.py:220
+#: ../gui/wxpython/menustrings.py:222
msgid "Outputs and modifies the user's current GRASS variable settings."
msgstr "Affiche et modifie les réglages de variables GRASS de l'utilisateur courant."
@@ -5193,7 +5426,8 @@
msgid "Removes installed GRASS AddOns extension."
msgstr "Désinstalle des extensions GRASS AddOns."
-#: ../gui/wxpython/menustrings.py:247 ../gui/wxpython/menustrings.py:875
+#: ../gui/wxpython/menustrings.py:247
+#: ../gui/wxpython/menustrings.py:875
msgid "Preferences"
msgstr "Préférences"
@@ -5251,11 +5485,11 @@
#: ../gui/wxpython/menustrings.py:261
msgid "Timestamp"
-msgstr "Horodatage"
+msgstr "Date et heure"
#: ../gui/wxpython/menustrings.py:262
msgid "Modifies a timestamp for a raster map."
-msgstr "Modifier la date d'une carte raster."
+msgstr "Modifier la date et heure d'une carte raster."
#: ../gui/wxpython/menustrings.py:263
msgid "Resample using aggregate statistics"
@@ -5290,7 +5524,8 @@
msgstr "Ré-interpole et en option calcule une analyse topographique d'une carte raster (éventuellement à une résolution différente) en utilisant les splines régulées avec tension et lissage."
# Pour désigner les support files, je propose la traduction fichiers de maintenance. Guère d'autre idée pour englober à la fois la dimension historique du fichier, méta-infos, lien vers un éventuel autre raster...
-#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:544
+#: ../gui/wxpython/menustrings.py:271
+#: ../gui/wxpython/menustrings.py:544
msgid "Support file maintenance"
msgstr "Administration du fichier de maintenance"
@@ -5323,11 +5558,13 @@
msgid "Produces tilings of the source projection for use in the destination region and projection."
msgstr "Produit une mosaïque de la projection source pour utilisation dans la région et projection de destination."
-#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:563
+#: ../gui/wxpython/menustrings.py:279
+#: ../gui/wxpython/menustrings.py:563
msgid "Manage colors"
msgstr "Gérer les couleurs"
-#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:564
+#: ../gui/wxpython/menustrings.py:280
+#: ../gui/wxpython/menustrings.py:564
msgid "Color tables"
msgstr "Tables de couleurs"
@@ -5343,7 +5580,8 @@
msgid "Set color rules based on stddev from a map's mean value."
msgstr "Définir les règles de couleurs depuis l'écart-type des valeurs moyennes d'une carte."
-#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:566
+#: ../gui/wxpython/menustrings.py:284
+#: ../gui/wxpython/menustrings.py:566
msgid "Color rules"
msgstr "Règle de couleurs"
@@ -5375,7 +5613,8 @@
msgid "Combines red, green and blue raster maps into a single composite raster map."
msgstr "Combine des cartes raster rouge, vert et bleu en une unique carte raster composite."
-#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:713
+#: ../gui/wxpython/menustrings.py:292
+#: ../gui/wxpython/menustrings.py:713
msgid "RGB to HIS"
msgstr "RVB vers TSV"
@@ -5493,7 +5732,7 @@
#: ../gui/wxpython/menustrings.py:329
msgid "Calculates category or object oriented statistics."
-msgstr ""
+msgstr "Calculer les catégories ou les statistiques orientées objet."
#: ../gui/wxpython/menustrings.py:330
msgid "Solar radiance and shadows"
@@ -5625,7 +5864,7 @@
#: ../gui/wxpython/menustrings.py:362
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr "Produit une couche raster où les aires contiguës ont été agrandies d'une cellule."
+msgstr "Produit une couche raster où les surfaces contiguës ont été agrandies d'une cellule."
#: ../gui/wxpython/menustrings.py:363
msgid "Thin"
@@ -5677,7 +5916,7 @@
#: ../gui/wxpython/menustrings.py:375
msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-msgstr "Constructin de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (zones amont) à partir d'un modèle numérique d'altitudes (MNA) raster."
+msgstr "Constructin de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (surfaces amont) à partir d'un modèle numérique d'altitudes (MNA) raster."
#: ../gui/wxpython/menustrings.py:376
msgid "Watershed analysis"
@@ -5703,29 +5942,33 @@
msgid "Watershed basin creation program."
msgstr "Création de bassin versant."
-#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:786
+#: ../gui/wxpython/menustrings.py:382
+#: ../gui/wxpython/menustrings.py:786
msgid "Groundwater modeling"
msgstr "Modélisation d'hydro-géologie"
#: ../gui/wxpython/menustrings.py:383
+#, fuzzy
msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
-msgstr ""
+msgstr "Calcul numérique pour les eaux souterraines transitoires, confinées et non confinées, en deux dimensions."
#: ../gui/wxpython/menustrings.py:384
msgid "SIMWE Overland flow modeling"
msgstr "Modélisation SIM&WE de l'écoulement de surface"
#: ../gui/wxpython/menustrings.py:385
+#, fuzzy
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
+msgstr "Simulation de crue avec la méthode SIMWE."
#: ../gui/wxpython/menustrings.py:386
msgid "SIMWE Sediment flux modeling"
msgstr "Modélisation SIMWE des flux de sédiments"
#: ../gui/wxpython/menustrings.py:387
+#, fuzzy
msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
-msgstr ""
+msgstr "Simulation de transport de sédiments et d'érosion/sédimentation avec la méthode SIMWE."
#: ../gui/wxpython/menustrings.py:388
msgid "Topographic index map"
@@ -5769,7 +6012,7 @@
#: ../gui/wxpython/menustrings.py:398
msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
+msgstr "Calculer les attributs, taille de patch, taille intérieure, forme, dimension fractale, et périmètre d'un jeux de patchs dans un paysage."
#: ../gui/wxpython/menustrings.py:399
msgid "Summary and display (requires XTerm)"
@@ -5777,7 +6020,7 @@
#: ../gui/wxpython/menustrings.py:400
msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
-msgstr ""
+msgstr "Affiche les limites de chaque patch de r.le et montre comment la limite ets tracée, affiche les attributs, taille, périmètre, indice de forme pour chaque patch et enregistre les données dans un fichier de sortie."
#: ../gui/wxpython/menustrings.py:401
msgid "Landscape patch analysis"
@@ -5797,7 +6040,7 @@
#: ../gui/wxpython/menustrings.py:405
msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgstr "Calcule l'index de densité de bords d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:406
msgid "Contrast weighted edge density"
@@ -5809,35 +6052,35 @@
#: ../gui/wxpython/menustrings.py:408
msgid "Patch area mean"
-msgstr ""
+msgstr "Surface moyenne des patch"
#: ../gui/wxpython/menustrings.py:409
msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgstr "Calculer l'index de taille moyenne de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:410
msgid "Patch area range"
-msgstr "Correctif de l'échelle"
+msgstr "Plage de surface de patch"
#: ../gui/wxpython/menustrings.py:411
msgid "Calculates range of patch area size on a raster map"
-msgstr ""
+msgstr "Calculer la plage des tailles de patch d'une carte raster."
#: ../gui/wxpython/menustrings.py:412
msgid "Patch area Std Dev"
-msgstr "Correctif de la variance"
+msgstr "Écart-type des tailles de patch"
#: ../gui/wxpython/menustrings.py:413
msgid "Calculates standard deviation of patch area a raster map"
-msgstr ""
+msgstr "Calculer l'écart-type des tailles de patch d'une carte raster."
#: ../gui/wxpython/menustrings.py:414
msgid "Patch area Coeff Var"
-msgstr "Correctif du coefficient de variation"
+msgstr "Coefficient de variation des tailles de patch"
#: ../gui/wxpython/menustrings.py:415
msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr ""
+msgstr "Calculer le coefficient de variation des taille de patch d'une carte raster."
#: ../gui/wxpython/menustrings.py:416
msgid "Patch density"
@@ -5845,7 +6088,7 @@
#: ../gui/wxpython/menustrings.py:417
msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgstr "Calculer l'index de densité de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:418
msgid "Patch number"
@@ -5853,15 +6096,16 @@
#: ../gui/wxpython/menustrings.py:419
msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
+msgstr "Calculer l'index du nombre de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:420
msgid "Dominance's diversity"
msgstr "Diversité de la Dominance"
-#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:427
+#: ../gui/wxpython/menustrings.py:421
+#: ../gui/wxpython/menustrings.py:427
msgid "Calculates dominance's diversity index on a raster map"
-msgstr ""
+msgstr "Calculer l'index de diversité de dominance d'une carte raster"
#: ../gui/wxpython/menustrings.py:422
msgid "Shannon's diversity"
@@ -5881,7 +6125,7 @@
#: ../gui/wxpython/menustrings.py:426
msgid "Richness"
-msgstr ""
+msgstr "Richesse"
#: ../gui/wxpython/menustrings.py:428
msgid "Shape index"
@@ -5929,7 +6173,7 @@
#: ../gui/wxpython/menustrings.py:439
msgid "Interactively edit cell values in a raster map."
-msgstr ""
+msgstr "Modification interactive des valeurs de cellules d'une carte raster."
#: ../gui/wxpython/menustrings.py:440
msgid "Reclassify by size"
@@ -5939,13 +6183,14 @@
msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:648
+#: ../gui/wxpython/menustrings.py:442
+#: ../gui/wxpython/menustrings.py:648
msgid "Reclassify"
msgstr "Reclasser"
#: ../gui/wxpython/menustrings.py:443
msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-msgstr ""
+msgstr "Créer une nouvelle carte dont les valeurs de catégories sont basées sur une reclassification des catégories d'une carte raster existante."
#: ../gui/wxpython/menustrings.py:444
msgid "Recode"
@@ -5961,7 +6206,7 @@
#: ../gui/wxpython/menustrings.py:447
msgid "Rescales the range of category values in a raster map layer."
-msgstr ""
+msgstr "Redéfinir l'échelle des valeurs de catégories d'une carte raster."
#: ../gui/wxpython/menustrings.py:448
msgid "Rescale with histogram"
@@ -5981,7 +6226,7 @@
#: ../gui/wxpython/menustrings.py:452
msgid "Generates random cell values with spatial dependence."
-msgstr ""
+msgstr "Génère des valeurs de cellules aléatoires avec une dépendance spatiale."
#: ../gui/wxpython/menustrings.py:453
msgid "Random cells and vector points"
@@ -5989,7 +6234,7 @@
#: ../gui/wxpython/menustrings.py:454
msgid "Creates a raster map layer and vector point map containing randomly located points."
-msgstr ""
+msgstr "Créer une carte raster ou une carte vectorielle de points contenant des points dispersés de manière aléatoire."
#: ../gui/wxpython/menustrings.py:455
msgid "Generate surfaces"
@@ -6001,7 +6246,7 @@
#: ../gui/wxpython/menustrings.py:457
msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
+msgstr "Créer une surface fractale à partir d'une dimension fractale donnée."
#: ../gui/wxpython/menustrings.py:458
msgid "Gaussian kernel density surface"
@@ -6017,7 +6262,7 @@
#: ../gui/wxpython/menustrings.py:461
msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
-msgstr ""
+msgstr "Produit une carte raster d'écarts gaussiens où la moyenne et l'écart-type peuvent être définis par l'utilisateur. Utilise un générateur de nombre aléatoire gaussien."
# Dip traduit ici pendage, en référence à la terminologie des géologues.
#: ../gui/wxpython/menustrings.py:463
@@ -6038,7 +6283,7 @@
#: ../gui/wxpython/menustrings.py:467
msgid "Generates random surface(s) with spatial dependence."
-msgstr ""
+msgstr "Génère une surface aléatoire avec une dépendance spatiale."
#: ../gui/wxpython/menustrings.py:468
msgid "Interpolate surfaces"
@@ -6050,7 +6295,7 @@
#: ../gui/wxpython/menustrings.py:470
msgid "Bilinear interpolation utility for raster map layers."
-msgstr ""
+msgstr "Utilitaire d'interpolation bilinéaire pour les cartes raster."
#: ../gui/wxpython/menustrings.py:471
msgid "Bilinear and bicubic from vector points"
@@ -6058,7 +6303,7 @@
#: ../gui/wxpython/menustrings.py:472
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
+msgstr "Interpolation spline bicubique ou bilinéaire avec régularisation de Tykhonov."
#: ../gui/wxpython/menustrings.py:473
msgid "IDW from raster points"
@@ -6070,7 +6315,7 @@
#: ../gui/wxpython/menustrings.py:475
msgid "IDW from raster points (alternate method for sparse points)"
-msgstr ""
+msgstr "IDW depuis des points raster (méthode alternative pour points clairsemés)"
#: ../gui/wxpython/menustrings.py:476
msgid "Surface generation program."
@@ -6082,7 +6327,7 @@
#: ../gui/wxpython/menustrings.py:478
msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
-msgstr ""
+msgstr "Interpolation de surface à partir de données vecteur point par pondération de la distance inverse au carré (IDSW)."
#: ../gui/wxpython/menustrings.py:479
msgid "Raster contours"
@@ -6090,7 +6335,7 @@
#: ../gui/wxpython/menustrings.py:480
msgid "Surface generation program from rasterized contours."
-msgstr ""
+msgstr "Programme de génération de surface depuis des contours rasterisés."
#: ../gui/wxpython/menustrings.py:481
msgid "Regularized spline tension"
@@ -6098,15 +6343,15 @@
#: ../gui/wxpython/menustrings.py:482
msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
-msgstr ""
+msgstr "Approximation spatiale et analyse topographique depuis des données points ou isolines au format vecteur vers un raster en nombre flottants, en utilisant des splines régulées avec tension."
#: ../gui/wxpython/menustrings.py:483
msgid "Ordinary or block kriging"
-msgstr ""
+msgstr "Krigeage ordinaire ou par bloc"
#: ../gui/wxpython/menustrings.py:484
msgid "Performs ordinary or block kriging."
-msgstr ""
+msgstr "Effectue un krigeage ordinaire ou par bloc."
#: ../gui/wxpython/menustrings.py:485
msgid "Fill NULL cells"
@@ -6114,15 +6359,16 @@
#: ../gui/wxpython/menustrings.py:486
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr "Remplir les zones de no-data de la carte raster par interpolation spline."
+msgstr "Remplir les zones sans données de la carte raster par interpolation spline."
-#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:764
+#: ../gui/wxpython/menustrings.py:487
+#: ../gui/wxpython/menustrings.py:764
msgid "Report and statistics"
msgstr "Compte-rendu et statistiques"
#: ../gui/wxpython/menustrings.py:488
msgid "Basic raster metadata"
-msgstr ""
+msgstr "Métadonnées raster basiques"
#: ../gui/wxpython/menustrings.py:489
msgid "Output basic information about a raster map layer."
@@ -6134,7 +6380,7 @@
#: ../gui/wxpython/menustrings.py:491
msgid "Manages category values and labels associated with user-specified raster map layers."
-msgstr ""
+msgstr "Gérer les valeurs de catégories et les étiquettes associées aux cartes raster spécifiées."
#: ../gui/wxpython/menustrings.py:492
msgid "General statistics"
@@ -6146,11 +6392,11 @@
#: ../gui/wxpython/menustrings.py:494
msgid "Quantiles for large data sets"
-msgstr ""
+msgstr "Quantiles pour les gros jeux de données."
#: ../gui/wxpython/menustrings.py:495
msgid "Compute quantiles using two passes."
-msgstr ""
+msgstr "Calculer les quantiles en deux passes."
#: ../gui/wxpython/menustrings.py:496
msgid "Range of category values"
@@ -6162,15 +6408,15 @@
#: ../gui/wxpython/menustrings.py:498
msgid "Sum category values"
-msgstr ""
+msgstr "Somme des valeurs de catégorie"
#: ../gui/wxpython/menustrings.py:499
msgid "Sums up the raster cell values."
-msgstr ""
+msgstr "Somme des valeurs de cellules"
#: ../gui/wxpython/menustrings.py:500
msgid "Sum area by raster map and category"
-msgstr ""
+msgstr "Somme des surfaces par carte raster et catégorie"
#: ../gui/wxpython/menustrings.py:501
msgid "Reports statistics for raster map layers."
@@ -6186,15 +6432,15 @@
#: ../gui/wxpython/menustrings.py:504
msgid "Total corrected area"
-msgstr ""
+msgstr "Surface totale corrigée"
#: ../gui/wxpython/menustrings.py:505
msgid "Surface area estimation for rasters."
-msgstr "Estimer les surfaces pour les matrices."
+msgstr "Estimation des surfaces pour les rasters."
#: ../gui/wxpython/menustrings.py:507
msgid "Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
+msgstr "Calculer les statistiques univariées pour les cellules non nulles de la carte raster."
#: ../gui/wxpython/menustrings.py:508
msgid "Sample transects"
@@ -6226,7 +6472,7 @@
#: ../gui/wxpython/menustrings.py:515
msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr ""
+msgstr "Calcule une régression linéaire depuis deux cartes raster : y = a + b*x."
#: ../gui/wxpython/menustrings.py:516
msgid "Mutual category occurrences"
@@ -6428,11 +6674,13 @@
msgid "Queries a vector map layer at given locations."
msgstr "Interroge une couche de carte vecteur à des emplacements donnés."
-#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:823
+#: ../gui/wxpython/menustrings.py:571
+#: ../gui/wxpython/menustrings.py:823
msgid "Query vector attribute data"
msgstr "Interroger la carte vecteur depuis la table d'attributs"
-#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:824
+#: ../gui/wxpython/menustrings.py:572
+#: ../gui/wxpython/menustrings.py:824
msgid "Prints vector map attributes."
msgstr "Afficher la table d'attributs de la carte vecteur."
@@ -6450,7 +6698,7 @@
#: ../gui/wxpython/menustrings.py:576
msgid "Spatial query"
-msgstr ""
+msgstr "Requête spatiale"
#: ../gui/wxpython/menustrings.py:577
msgid "Selects features from vector map (A) by features from other vector map (B)."
@@ -6502,15 +6750,15 @@
#: ../gui/wxpython/menustrings.py:598
msgid "Create Linear Reference System"
-msgstr ""
+msgstr "Créer un système de référence linéaire"
#: ../gui/wxpython/menustrings.py:599
msgid "Create stationing"
-msgstr "Créer stationnement"
+msgstr "Créer des placements"
#: ../gui/wxpython/menustrings.py:600
msgid "Create stationing from input lines, and linear reference system"
-msgstr ""
+msgstr "Créer des placement à partir de lignes, et d'un système de référence linéaire"
#: ../gui/wxpython/menustrings.py:601
msgid "Create points/segments"
@@ -6518,7 +6766,7 @@
#: ../gui/wxpython/menustrings.py:602
msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
-msgstr ""
+msgstr "Créer des points/segments à partir des lignes en entrée, un système de référence linéaire et des positions lues depuis l'entrée standard ou un fichier."
#: ../gui/wxpython/menustrings.py:603
msgid "Find line id and offset"
@@ -6534,7 +6782,7 @@
#: ../gui/wxpython/menustrings.py:606
msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
-msgstr ""
+msgstr "Trouve l'élément de la carte \"vers\" le plus proche des éléments de la carte \"depuis\"."
#: ../gui/wxpython/menustrings.py:607
msgid "Network analysis"
@@ -6546,7 +6794,7 @@
#: ../gui/wxpython/menustrings.py:609
msgid "Performs network maintenance."
-msgstr ""
+msgstr "Effectue la maintenance du réseau."
#: ../gui/wxpython/menustrings.py:610
msgid "Allocate subnets"
@@ -6582,15 +6830,15 @@
#: ../gui/wxpython/menustrings.py:618
msgid "Shortest path using timetables"
-msgstr ""
+msgstr "Chemin le plus court avec des tables horaires"
#: ../gui/wxpython/menustrings.py:619
msgid "Finds shortest path using timetables."
-msgstr ""
+msgstr "Trouve le chemin le plus court à l'aide de tables horaires."
#: ../gui/wxpython/menustrings.py:620
msgid "Shortest path for all pairs"
-msgstr ""
+msgstr "Chemin le plus court pour toutes les paires"
#: ../gui/wxpython/menustrings.py:621
msgid "Computes the shortest path between all pairs of nodes in the network."
@@ -6622,11 +6870,11 @@
#: ../gui/wxpython/menustrings.py:628
msgid "Vertex connectivity"
-msgstr ""
+msgstr "Connectivité des sommets"
#: ../gui/wxpython/menustrings.py:629
msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
+msgstr "Calcule la connectivité des sommets entre deux jeux de noeuds d'un réseau."
#: ../gui/wxpython/menustrings.py:630
msgid "Components"
@@ -6634,15 +6882,15 @@
#: ../gui/wxpython/menustrings.py:631
msgid "Computes strongly and weakly connected components in the network."
-msgstr ""
+msgstr "Calcule les composants fortement et faiblement connectés d'un réseau."
#: ../gui/wxpython/menustrings.py:632
msgid "Centrality"
-msgstr ""
+msgstr "Centralité"
#: ../gui/wxpython/menustrings.py:633
msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
-msgstr ""
+msgstr "Calcule les degré, centralité, intermédiarité, proximité et vecteur propre des mesures de centralité d'un réseau."
#: ../gui/wxpython/menustrings.py:634
msgid "Steiner tree"
@@ -6650,15 +6898,15 @@
#: ../gui/wxpython/menustrings.py:635
msgid "Create Steiner tree for the network and given terminals"
-msgstr ""
+msgstr "Créer l'arbre de Steiner pour le réseau et les points terminaux donnés"
#: ../gui/wxpython/menustrings.py:636
msgid "Minimum spanning tree"
-msgstr ""
+msgstr "Arbre couvrant de poids minimal"
#: ../gui/wxpython/menustrings.py:637
msgid "Computes minimum spanning tree for the network."
-msgstr ""
+msgstr "Calcul l'arbre couvrant de poids minimum pour le réseau."
#: ../gui/wxpython/menustrings.py:638
msgid "Traveling salesman analysis"
@@ -6666,9 +6914,10 @@
#: ../gui/wxpython/menustrings.py:639
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
+msgstr "Créer un cycle connectant les noeud donnés (problème du voyageur de commerce)."
-#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:641
+#: ../gui/wxpython/menustrings.py:640
+#: ../gui/wxpython/menustrings.py:641
msgid "Overlay vector maps"
msgstr "Superposer des cartes vectorielles"
@@ -6706,7 +6955,7 @@
#: ../gui/wxpython/menustrings.py:652
msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-msgstr ""
+msgstr "Calculer les statistiques univariées d'une carte raster, basé sur des polygones vectoriels et ajouter les statistiques dans des nouvelles colonnes attributaires."
#: ../gui/wxpython/menustrings.py:653
msgid "Update point attributes from areas"
@@ -6714,7 +6963,7 @@
#: ../gui/wxpython/menustrings.py:654
msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
+msgstr "Ajouter dans la table les valeurs de vecteur à la position des points du vecteur."
#: ../gui/wxpython/menustrings.py:655
msgid "Update database values from vector"
@@ -6730,7 +6979,7 @@
#: ../gui/wxpython/menustrings.py:658
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
+msgstr "Ajouter dans la table les valeurs de raster à la position des points du vecteur."
#: ../gui/wxpython/menustrings.py:659
msgid "Sample raster neighborhood around points"
@@ -6830,11 +7079,11 @@
#: ../gui/wxpython/menustrings.py:683
msgid "Test/training point sets"
-msgstr ""
+msgstr "Jeux de points de tests/d'entraînement"
#: ../gui/wxpython/menustrings.py:684
msgid "Randomly partition points into test/train sets."
-msgstr ""
+msgstr "Répartit aléatoirement les points dans des jeux de tests/entraînement."
#: ../gui/wxpython/menustrings.py:685
msgid "Reports and statistics"
@@ -6854,7 +7103,7 @@
#: ../gui/wxpython/menustrings.py:689
msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
+msgstr "Classifier les données attributaires, par exemple pour une cartographie thématique"
#: ../gui/wxpython/menustrings.py:690
msgid "Report topology by category"
@@ -6870,7 +7119,7 @@
#: ../gui/wxpython/menustrings.py:693
msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-msgstr ""
+msgstr "Calcule les statistiques univariées pour les attributs. La variance et l'écart-type sont calculés uniquement pour les points."
#: ../gui/wxpython/menustrings.py:694
msgid "Univariate statistics for attribute columns"
@@ -6878,7 +7127,7 @@
#: ../gui/wxpython/menustrings.py:695
msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
-msgstr ""
+msgstr "Calcule les statistiques univariées sur la colonne sélectionnée."
#: ../gui/wxpython/menustrings.py:696
msgid "Quadrat indices"
@@ -6886,7 +7135,7 @@
#: ../gui/wxpython/menustrings.py:697
msgid "Indices for quadrat counts of sites lists."
-msgstr ""
+msgstr "Indice de compte par quadrat."
#: ../gui/wxpython/menustrings.py:698
msgid "Test normality"
@@ -6894,7 +7143,7 @@
#: ../gui/wxpython/menustrings.py:699
msgid "Tests for normality for points."
-msgstr ""
+msgstr "Test de normalité pour les points."
#: ../gui/wxpython/menustrings.py:700
msgid "&Imagery"
@@ -6927,7 +7176,7 @@
#: ../gui/wxpython/menustrings.py:707
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
+msgstr "Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une carte *.mosaic"
#: ../gui/wxpython/menustrings.py:708
msgid "Manage image colors"
@@ -6939,7 +7188,7 @@
#: ../gui/wxpython/menustrings.py:710
msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr ""
+msgstr "Applique une balance automatique des couleurs pour les images LANDSAT."
#: ../gui/wxpython/menustrings.py:711
msgid "HIS to RGB"
@@ -6971,7 +7220,7 @@
#: ../gui/wxpython/menustrings.py:720
msgid "Displays spectral response at user specified locations in group or images."
-msgstr ""
+msgstr "Affiche la réponse spectrale d'une position données pour un groupe ou une image."
#: ../gui/wxpython/menustrings.py:721
msgid "Brovey sharpening"
@@ -6979,7 +7228,7 @@
#: ../gui/wxpython/menustrings.py:722
msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
+msgstr "Transformation de Brovey pour fusionner des canaux multispectraux et panchromatique haute résolution."
#: ../gui/wxpython/menustrings.py:723
msgid "Classify image"
@@ -6991,7 +7240,7 @@
#: ../gui/wxpython/menustrings.py:725
msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
-msgstr ""
+msgstr "Générer les signatures spectrales pour l'occupation des sols dans une image, à l'aide d'un algorithme de regroupement."
#: ../gui/wxpython/menustrings.py:726
msgid "Input for supervised MLC"
@@ -7007,15 +7256,15 @@
#: ../gui/wxpython/menustrings.py:729
msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
+msgstr "Classifier la réflectance spectrale des cellules dans une image."
#: ../gui/wxpython/menustrings.py:730
msgid "Interactive input for supervised classification (requires Xterm)"
-msgstr ""
+msgstr "Entrée interactive pour une classification supervisée (requiert Xterm)"
#: ../gui/wxpython/menustrings.py:731
msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
-msgstr ""
+msgstr "Générer les signatures spectrales d'une image en permettant à l'utilisateur de décrire les régions d'intérêt."
#: ../gui/wxpython/menustrings.py:732
msgid "Input for supervised SMAP"
@@ -7027,11 +7276,11 @@
#: ../gui/wxpython/menustrings.py:734
msgid "Sequential maximum a posteriori classification (SMAP)"
-msgstr ""
+msgstr "Classification par le maximum séquentiel à postériori (SMAP)"
#: ../gui/wxpython/menustrings.py:735
msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
-msgstr ""
+msgstr "Effectue une classification d'image contextuelle, en utilisant l'estimation du maximum séquentiel à postériori (SMAP)."
#: ../gui/wxpython/menustrings.py:736
msgid "Filter image"
@@ -7063,7 +7312,7 @@
#: ../gui/wxpython/menustrings.py:743
msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
+msgstr "Analyse d'image par composante canonique (cca)."
#: ../gui/wxpython/menustrings.py:744
msgid "Principal components"
@@ -7071,7 +7320,7 @@
#: ../gui/wxpython/menustrings.py:745
msgid "Principal components analysis (PCA) for image processing."
-msgstr ""
+msgstr "Analyse d'image par composante principale (pca)."
#: ../gui/wxpython/menustrings.py:746
msgid "Fast Fourier"
@@ -7079,7 +7328,7 @@
#: ../gui/wxpython/menustrings.py:747
msgid "Fast Fourier Transform (FFT) for image processing."
-msgstr ""
+msgstr "Analyse d'image par transformée de Fourier rapide (FFT)."
#: ../gui/wxpython/menustrings.py:748
msgid "Inverse Fast Fourier"
@@ -7087,7 +7336,7 @@
#: ../gui/wxpython/menustrings.py:749
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
-msgstr ""
+msgstr "Analyse d'image par inverse de transformée de Fourier rapide (IFFT)."
#: ../gui/wxpython/menustrings.py:750
msgid "Satellite images tools"
@@ -7095,19 +7344,19 @@
#: ../gui/wxpython/menustrings.py:751
msgid "Landsat DN to radiance/reflectance"
-msgstr ""
+msgstr "Valeur numérique Landsat vers radiance/réflectance."
#: ../gui/wxpython/menustrings.py:752
msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
-msgstr ""
+msgstr "Calculer la radiance ou la réflectance \"top-of-atmosphere\" et la température pour les images Landsat MSS/TM/ETM+."
#: ../gui/wxpython/menustrings.py:753
msgid "Landsat cloud cover assessment"
-msgstr ""
+msgstr "Évaluation de la couverture nuageuse Landsat."
#: ../gui/wxpython/menustrings.py:754
msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
+msgstr "Effecture une évaluation automatique de la couverture nuageuse (ACCA) pour Landsat TM/ETM+."
#: ../gui/wxpython/menustrings.py:755
msgid "Modis quality control"
@@ -7135,23 +7384,23 @@
#: ../gui/wxpython/menustrings.py:761
msgid "Satellite images products"
-msgstr ""
+msgstr "Produits d'imagerie satellitale"
#: ../gui/wxpython/menustrings.py:762
msgid "Tasseled cap vegetation index"
-msgstr ""
+msgstr "Index de végétation de Tessel"
#: ../gui/wxpython/menustrings.py:763
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr ""
+msgstr "Transformation de Tasseled cap (Kauth Thomas) pour les données LANDSAT-TM"
#: ../gui/wxpython/menustrings.py:765
msgid "Bit pattern comparison "
-msgstr ""
+msgstr "Comparaison bit à bit"
#: ../gui/wxpython/menustrings.py:766
msgid "Compares bit patterns with a raster map."
-msgstr ""
+msgstr "Comparaison bit à bit avec une carte raster."
#: ../gui/wxpython/menustrings.py:767
msgid "Kappa analysis"
@@ -7159,7 +7408,7 @@
#: ../gui/wxpython/menustrings.py:768
msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
-msgstr ""
+msgstr "Calcule la matrice de confusion et les paramètres kappa pour l'évaluation de l'exactitude des résultats de classification."
#: ../gui/wxpython/menustrings.py:769
msgid "OIF for LandSat TM"
@@ -7167,7 +7416,7 @@
#: ../gui/wxpython/menustrings.py:770
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
+msgstr "Calcule la table de facteur d'index optimal pour les bandes 1-5 et 7 de Landsat TM."
#: ../gui/wxpython/menustrings.py:771
msgid "V&olumes"
@@ -7179,19 +7428,19 @@
#: ../gui/wxpython/menustrings.py:773
msgid "Manage 3D NULL values"
-msgstr ""
+msgstr "Gérer les valeurs 3D NULL"
#: ../gui/wxpython/menustrings.py:774
msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr ""
+msgstr "Créer explicitement un fichier 3D de valeurs NULL."
#: ../gui/wxpython/menustrings.py:775
msgid "Manage timestamp"
-msgstr ""
+msgstr "Gérer les dates et heures"
#: ../gui/wxpython/menustrings.py:776
msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr ""
+msgstr "Afficher/ajouter/supprimer une date/heure d'une carte raster 3D"
#: ../gui/wxpython/menustrings.py:780
msgid "3D Mask"
@@ -7199,7 +7448,7 @@
#: ../gui/wxpython/menustrings.py:781
msgid "Establishes the current working 3D raster mask."
-msgstr ""
+msgstr "Définir le masque raster 3D courant."
#: ../gui/wxpython/menustrings.py:782
msgid "Volume calculator"
@@ -7211,23 +7460,24 @@
#: ../gui/wxpython/menustrings.py:784
msgid "Cross section"
-msgstr ""
+msgstr "Coupe transversale"
#: ../gui/wxpython/menustrings.py:785
+#, fuzzy
msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-msgstr ""
+msgstr "Créer une carte raster 2D de coupe transversale pour une carte raster 3D, basée sur une carte d'altitudes en 2D."
#: ../gui/wxpython/menustrings.py:787
msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
-msgstr ""
+msgstr "Calcul numérique des flux d'eaux souterraines transitoire et confinées, en trois dimensions."
#: ../gui/wxpython/menustrings.py:788
msgid "Interpolate volume from points"
-msgstr ""
+msgstr "Interpoler un volume depuis des points."
#: ../gui/wxpython/menustrings.py:789
msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
-msgstr ""
+msgstr "Interpoler des données points vers une carte raster 3D, en utilisant l'algorithme des splines régulées avec tension (RST)."
#: ../gui/wxpython/menustrings.py:790
msgid "Report and Statistics"
@@ -7235,11 +7485,11 @@
#: ../gui/wxpython/menustrings.py:791
msgid "Basic volume metadata"
-msgstr ""
+msgstr "Métadonnées basiques pour le volume"
#: ../gui/wxpython/menustrings.py:792
msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
+msgstr "Affiche les informations basiques pour une carte raster 3D donnée."
#: ../gui/wxpython/menustrings.py:793
msgid "Voxel statistics"
@@ -7255,7 +7505,7 @@
#: ../gui/wxpython/menustrings.py:796
msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
-msgstr ""
+msgstr "Calculer les statistiques univariées pour les valeurs 3D non-nulles d'une carte raster 3D."
#: ../gui/wxpython/menustrings.py:797
msgid "&Database"
@@ -7307,7 +7557,7 @@
#: ../gui/wxpython/menustrings.py:809
msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
+msgstr "Afficher/définir les connexions base de données pour le jeux de crate actuel puis quitter."
#: ../gui/wxpython/menustrings.py:810
msgid "Login"
@@ -7333,7 +7583,8 @@
msgid "Copy a table."
msgstr "Copier une table."
-#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:836
+#: ../gui/wxpython/menustrings.py:816
+#: ../gui/wxpython/menustrings.py:836
msgid "Drop column"
msgstr "Supprimer une colonne"
@@ -7423,17 +7674,18 @@
#: ../gui/wxpython/menustrings.py:843
msgid "Reconnects vectors to a new database."
-msgstr ""
+msgstr "Reconnecter les vecteurs à une nouvelle base de données."
#: ../gui/wxpython/menustrings.py:844
msgid "Set vector map - database connection"
-msgstr ""
+msgstr "Définir les connexions entre carte vecteur et base de données."
#: ../gui/wxpython/menustrings.py:845
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
+msgstr "Afficher/définir les connexions base de données pour la table d'attributs de la crate vecteur."
-#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:898
+#: ../gui/wxpython/menustrings.py:846
+#: ../gui/wxpython/menustrings.py:898
msgid "&Help"
msgstr "&Aide"
@@ -7441,7 +7693,8 @@
msgid "GRASS help"
msgstr "Aide GRASS"
-#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:850
+#: ../gui/wxpython/menustrings.py:848
+#: ../gui/wxpython/menustrings.py:850
msgid "Display the HTML man pages of GRASS"
msgstr "Afficher les pages de manuel de GRASS"
@@ -7452,7 +7705,7 @@
#: ../gui/wxpython/menustrings.py:851
msgid "About system"
-msgstr ""
+msgstr "À propos du système"
#: ../gui/wxpython/menustrings.py:852
msgid "Prints system information"
@@ -7466,7 +7719,8 @@
msgid "Load model from file"
msgstr "Charger le modèle depuis un fichier"
-#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/gmodeler/frame.py:393
+#: ../gui/wxpython/menustrings.py:863
+#: ../gui/wxpython/gmodeler/frame.py:393
msgid "Save model"
msgstr "Enregistrer le modèle"
@@ -7492,7 +7746,7 @@
#: ../gui/wxpython/menustrings.py:871
msgid "Export model to Python script"
-msgstr ""
+msgstr "Exporter le modèle dans un script Python"
#: ../gui/wxpython/menustrings.py:872
msgid "Quit modeler"
@@ -7500,7 +7754,7 @@
#: ../gui/wxpython/menustrings.py:873
msgid "Close modeler window"
-msgstr ""
+msgstr "Fermer la fenêtre du modeleur"
#: ../gui/wxpython/menustrings.py:876
#: ../gui/wxpython/gmodeler/preferences.py:28
@@ -7525,7 +7779,7 @@
#: ../gui/wxpython/menustrings.py:881
msgid "Add data item to model"
-msgstr ""
+msgstr "Ajouter un objet données au modèle"
#: ../gui/wxpython/menustrings.py:882
msgid "Define relation"
@@ -7533,7 +7787,7 @@
#: ../gui/wxpython/menustrings.py:883
msgid "Define relation between data and action items"
-msgstr ""
+msgstr "Définir la relation entre les objets données et action"
#: ../gui/wxpython/menustrings.py:884
msgid "Add loop / series"
@@ -7549,7 +7803,7 @@
#: ../gui/wxpython/menustrings.py:887
msgid "Adds condition (if/else) to model"
-msgstr ""
+msgstr "Ajouter une condition (if/else) au modèle"
#: ../gui/wxpython/menustrings.py:888
msgid "Remove item"
@@ -7557,16 +7811,16 @@
#: ../gui/wxpython/menustrings.py:889
msgid "Remove action/data from model"
-msgstr ""
+msgstr "Supprimer une action/donnée du modèle"
#: ../gui/wxpython/menustrings.py:890
#: ../gui/wxpython/gmodeler/preferences.py:421
msgid "Model properties"
-msgstr " Propriétés du modèle"
+msgstr "Propriétés du modèle"
#: ../gui/wxpython/menustrings.py:891
msgid "Model properties (name, purpose, etc.)"
-msgstr ""
+msgstr "Propriétés du modèle (name, objectif, etc.)"
#: ../gui/wxpython/menustrings.py:892
msgid "Delete intermediate data"
@@ -7574,19 +7828,19 @@
#: ../gui/wxpython/menustrings.py:893
msgid "Delete intermediate data defined in the model"
-msgstr ""
+msgstr "Supprimer les données intermédiaires définies dans le modèle"
#: ../gui/wxpython/menustrings.py:895
msgid "Run entire model"
-msgstr ""
+msgstr "Exécuter le modèle complet"
#: ../gui/wxpython/menustrings.py:896
msgid "Validate model"
-msgstr ""
+msgstr "Valider le modèle"
#: ../gui/wxpython/menustrings.py:897
msgid "Validate entire model"
-msgstr ""
+msgstr "Valider le modèle complet"
#: ../gui/wxpython/menustrings.py:899
msgid "Help"
@@ -7671,7 +7925,8 @@
msgid "Failed to read file %s."
msgstr "Impossible de lire le fichier %s."
-#: ../gui/wxpython/psmap/frame.py:548 ../gui/wxpython/psmap/frame.py:571
+#: ../gui/wxpython/psmap/frame.py:548
+#: ../gui/wxpython/psmap/frame.py:571
#: ../gui/wxpython/psmap/dialogs.py:1210
msgid "Please, create map frame first."
msgstr "Merci de créer d'abord le cadre de carte."
@@ -7693,7 +7948,8 @@
"C) 2011 par l'équipe de développement de GRASS\n"
"\n"
-#: ../gui/wxpython/psmap/frame.py:1021 ../gui/wxpython/gmodeler/frame.py:708
+#: ../gui/wxpython/psmap/frame.py:1021
+#: ../gui/wxpython/gmodeler/frame.py:708
msgid "This program is free software under the GNU General Public License(>=v2). Read the file COPYING that comes with GRASS for details."
msgstr "Ce programme est un logiciel libre placé sous la licence GNU General Public License (>=v2). Lisez le fichier COPYING fourni avec GRASS pour plus de détails."
@@ -7705,7 +7961,8 @@
msgid "inch"
msgstr "Pouce"
-#: ../gui/wxpython/psmap/utils.py:92 ../gui/wxpython/modules/vclean.py:194
+#: ../gui/wxpython/psmap/utils.py:92
+#: ../gui/wxpython/modules/vclean.py:194
msgid "point"
msgstr "point"
@@ -7733,7 +7990,8 @@
msgid "miles"
msgstr "mile"
-#: ../gui/wxpython/psmap/utils.py:99 ../gui/wxpython/psmap/utils.py:103
+#: ../gui/wxpython/psmap/utils.py:99
+#: ../gui/wxpython/psmap/utils.py:103
msgid "nautical miles"
msgstr "miles nautiques"
@@ -7874,8 +8132,10 @@
msgstr "Générer une sortie PDF"
#: ../gui/wxpython/psmap/toolbars.py:60
-#: ../gui/wxpython/modules/histogram.py:443 ../gui/wxpython/wxplot/base.py:484
-#: ../gui/wxpython/gcp/mapdisplay.py:485 ../gui/wxpython/mapdisp/frame.py:596
+#: ../gui/wxpython/modules/histogram.py:443
+#: ../gui/wxpython/wxplot/base.py:484
+#: ../gui/wxpython/gcp/mapdisplay.py:485
+#: ../gui/wxpython/mapdisp/frame.py:596
msgid "Page setup"
msgstr "Mise en page"
@@ -7891,7 +8151,8 @@
msgid "Zoom to full extent"
msgstr "Zoomer sur l'étendue complète"
-#: ../gui/wxpython/psmap/toolbars.py:66 ../gui/wxpython/psmap/dialogs.py:618
+#: ../gui/wxpython/psmap/toolbars.py:66
+#: ../gui/wxpython/psmap/dialogs.py:618
#: ../gui/wxpython/psmap/dialogs.py:673
msgid "Map frame"
msgstr "Fenêtre de cartes"
@@ -7912,7 +8173,8 @@
msgid "Quit Cartographic Composer"
msgstr "Quitter le Composeur cartographique"
-#: ../gui/wxpython/psmap/toolbars.py:75 ../gui/wxpython/psmap/dialogs.py:3705
+#: ../gui/wxpython/psmap/toolbars.py:75
+#: ../gui/wxpython/psmap/dialogs.py:3705
#: ../gui/wxpython/psmap/dialogs.py:3710
msgid "Text"
msgstr "Texte"
@@ -7921,12 +8183,14 @@
msgid "Map info"
msgstr "Informations sur la carte"
-#: ../gui/wxpython/psmap/toolbars.py:79 ../gui/wxpython/wxplot/dialogs.py:576
+#: ../gui/wxpython/psmap/toolbars.py:79
+#: ../gui/wxpython/wxplot/dialogs.py:576
#: ../gui/wxpython/wxplot/dialogs.py:618
msgid "Legend"
msgstr "Légende"
-#: ../gui/wxpython/psmap/toolbars.py:83 ../gui/wxpython/psmap/dialogs.py:4061
+#: ../gui/wxpython/psmap/toolbars.py:83
+#: ../gui/wxpython/psmap/dialogs.py:4061
#: ../gui/wxpython/psmap/dialogs.py:4109
msgid "Image"
msgstr "Image"
@@ -7935,7 +8199,8 @@
msgid "Add simple graphics"
msgstr "Ajouter un graphique simple"
-#: ../gui/wxpython/psmap/toolbars.py:89 ../gui/wxpython/psmap/dialogs.py:4522
+#: ../gui/wxpython/psmap/toolbars.py:89
+#: ../gui/wxpython/psmap/dialogs.py:4522
#: ../gui/wxpython/vdigit/preferences.py:516
msgid "Point"
msgstr "Point"
@@ -8001,7 +8266,8 @@
msgid "Close dialog and apply changes"
msgstr "Appliquer les changements et fermer la boite de dialogue"
-#: ../gui/wxpython/psmap/dialogs.py:358 ../gui/wxpython/vdigit/dialogs.py:142
+#: ../gui/wxpython/psmap/dialogs.py:358
+#: ../gui/wxpython/vdigit/dialogs.py:142
msgid "Apply changes"
msgstr "Appliquer les changements"
@@ -8017,7 +8283,8 @@
msgid "Orientation"
msgstr "Orientation"
-#: ../gui/wxpython/psmap/dialogs.py:383 ../gui/wxpython/psmap/dialogs.py:2084
+#: ../gui/wxpython/psmap/dialogs.py:383
+#: ../gui/wxpython/psmap/dialogs.py:2084
msgid "Width"
msgstr "Largeur"
@@ -8047,8 +8314,10 @@
msgid "Literal is not allowed!"
msgstr "Textuel non permis !"
-#: ../gui/wxpython/psmap/dialogs.py:439 ../gui/wxpython/psmap/dialogs.py:1034
-#: ../gui/wxpython/psmap/dialogs.py:1056 ../gui/wxpython/psmap/dialogs.py:1106
+#: ../gui/wxpython/psmap/dialogs.py:439
+#: ../gui/wxpython/psmap/dialogs.py:1034
+#: ../gui/wxpython/psmap/dialogs.py:1056
+#: ../gui/wxpython/psmap/dialogs.py:1106
#: ../gui/wxpython/psmap/dialogs.py:3637
msgid "Invalid input"
msgstr "Entrée non valide"
@@ -8069,7 +8338,8 @@
msgid "Landscape"
msgstr "Paysage"
-#: ../gui/wxpython/psmap/dialogs.py:506 ../gui/wxpython/psmap/dialogs.py:527
+#: ../gui/wxpython/psmap/dialogs.py:506
+#: ../gui/wxpython/psmap/dialogs.py:527
#: ../gui/wxpython/location_wizard/wizard.py:1678
msgid "custom"
msgstr "Personnalisé"
@@ -8102,11 +8372,13 @@
msgid "fixed scale and map center"
msgstr "échelle fixe et center de la carte"
-#: ../gui/wxpython/psmap/dialogs.py:691 ../gui/wxpython/psmap/dialogs.py:859
+#: ../gui/wxpython/psmap/dialogs.py:691
+#: ../gui/wxpython/psmap/dialogs.py:859
msgid "Map selection"
msgstr "Sélection de la carte"
-#: ../gui/wxpython/psmap/dialogs.py:699 ../gui/wxpython/psmap/dialogs.py:1283
+#: ../gui/wxpython/psmap/dialogs.py:699
+#: ../gui/wxpython/psmap/dialogs.py:1283
msgid "Map:"
msgstr "Carte :"
@@ -8130,7 +8402,8 @@
msgid "N:"
msgstr "N :"
-#: ../gui/wxpython/psmap/dialogs.py:728 ../gui/wxpython/psmap/dialogs.py:4166
+#: ../gui/wxpython/psmap/dialogs.py:728
+#: ../gui/wxpython/psmap/dialogs.py:4166
msgid "Scale:"
msgstr "Échelle"
@@ -8143,7 +8416,8 @@
msgid "Map max resolution (dpi):"
msgstr "Résolution max de carte (dpi)"
-#: ../gui/wxpython/psmap/dialogs.py:762 ../gui/wxpython/psmap/dialogs.py:2653
+#: ../gui/wxpython/psmap/dialogs.py:762
+#: ../gui/wxpython/psmap/dialogs.py:2653
msgid "Border"
msgstr "Bordure"
@@ -8195,7 +8469,8 @@
msgid "raster:"
msgstr "carte raster :"
-#: ../gui/wxpython/psmap/dialogs.py:1270 ../gui/wxpython/gmodeler/model.py:668
+#: ../gui/wxpython/psmap/dialogs.py:1270
+#: ../gui/wxpython/gmodeler/model.py:668
msgid "Vector maps"
msgstr "Carte vectorielle"
@@ -8203,11 +8478,13 @@
msgid "Add map"
msgstr "Ajouter une carte"
-#: ../gui/wxpython/psmap/dialogs.py:1287 ../gui/wxpython/psmap/dialogs.py:1651
+#: ../gui/wxpython/psmap/dialogs.py:1287
+#: ../gui/wxpython/psmap/dialogs.py:1651
msgid "points"
msgstr "points"
-#: ../gui/wxpython/psmap/dialogs.py:1287 ../gui/wxpython/psmap/dialogs.py:1653
+#: ../gui/wxpython/psmap/dialogs.py:1653
msgid "lines"
msgstr "lignes"
@@ -8231,11 +8508,13 @@
msgid "The topmost vector map overlaps the others"
msgstr "La carte la plus haute recouvre les autres"
-#: ../gui/wxpython/psmap/dialogs.py:1314 ../gui/wxpython/psmap/dialogs.py:2636
+#: ../gui/wxpython/psmap/dialogs.py:1314
+#: ../gui/wxpython/psmap/dialogs.py:2636
msgid "Up"
msgstr "Haut"
-#: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/psmap/dialogs.py:2637
+#: ../gui/wxpython/psmap/dialogs.py:1315
+#: ../gui/wxpython/psmap/dialogs.py:2637
msgid "Down"
msgstr "Bas"
@@ -8292,24 +8571,30 @@
msgid "Use current mask"
msgstr "Utiliser le masque courant"
-#: ../gui/wxpython/psmap/dialogs.py:1746 ../gui/wxpython/psmap/dialogs.py:1845
+#: ../gui/wxpython/psmap/dialogs.py:1746
+#: ../gui/wxpython/psmap/dialogs.py:1845
msgid "Colors"
msgstr "Couleurs"
-#: ../gui/wxpython/psmap/dialogs.py:1751 ../gui/wxpython/psmap/dialogs.py:1850
+#: ../gui/wxpython/psmap/dialogs.py:1751
+#: ../gui/wxpython/psmap/dialogs.py:1850
msgid "Outline"
msgstr "Contour"
-#: ../gui/wxpython/psmap/dialogs.py:1755 ../gui/wxpython/psmap/dialogs.py:1859
+#: ../gui/wxpython/psmap/dialogs.py:1755
+#: ../gui/wxpython/psmap/dialogs.py:1859
msgid "draw outline"
msgstr "dessiner le contour"
-#: ../gui/wxpython/psmap/dialogs.py:1758 ../gui/wxpython/psmap/dialogs.py:1863
-#: ../gui/wxpython/psmap/dialogs.py:3750 ../gui/wxpython/psmap/dialogs.py:3755
+#: ../gui/wxpython/psmap/dialogs.py:1758
+#: ../gui/wxpython/psmap/dialogs.py:1863
+#: ../gui/wxpython/psmap/dialogs.py:3750
+#: ../gui/wxpython/psmap/dialogs.py:3755
msgid "Width (pts):"
msgstr "Largeur (pts) :"
-#: ../gui/wxpython/psmap/dialogs.py:1795 ../gui/wxpython/psmap/dialogs.py:1899
+#: ../gui/wxpython/psmap/dialogs.py:1795
+#: ../gui/wxpython/psmap/dialogs.py:1899
#: ../gui/wxpython/wxplot/dialogs.py:610
msgid "Fill"
msgstr "Remplir"
@@ -8318,28 +8603,32 @@
msgid "fill color"
msgstr "remplir par la couleur"
-#: ../gui/wxpython/psmap/dialogs.py:1802 ../gui/wxpython/psmap/dialogs.py:1905
+#: ../gui/wxpython/psmap/dialogs.py:1802
+#: ../gui/wxpython/psmap/dialogs.py:1905
msgid "choose color:"
msgstr "choisir la couleur :"
-#: ../gui/wxpython/psmap/dialogs.py:1814 ../gui/wxpython/psmap/dialogs.py:1918
+#: ../gui/wxpython/psmap/dialogs.py:1814
+#: ../gui/wxpython/psmap/dialogs.py:1918
msgid "color from map table column:"
-msgstr ""
+msgstr "couleur depuis la colonne :"
#: ../gui/wxpython/psmap/dialogs.py:1861
msgid "No effect for fill color from table column"
-msgstr ""
+msgstr "Pas d'effet de remplissage de couleur depuis la colonne"
#: ../gui/wxpython/psmap/dialogs.py:1903
msgid "Color of lines:"
msgstr "Couleur des lignes :"
-#: ../gui/wxpython/psmap/dialogs.py:1948 ../gui/wxpython/psmap/dialogs.py:2079
+#: ../gui/wxpython/psmap/dialogs.py:1948
+#: ../gui/wxpython/psmap/dialogs.py:2079
#: ../gui/wxpython/psmap/dialogs.py:2148
msgid "Size and style"
msgstr "Taille et style"
-#: ../gui/wxpython/psmap/dialogs.py:1953 ../gui/wxpython/gcp/manager.py:2396
+#: ../gui/wxpython/psmap/dialogs.py:1953
+#: ../gui/wxpython/gcp/manager.py:2396
#: ../gui/wxpython/vdigit/preferences.py:80
msgid "Symbology"
msgstr "Symbologie"
@@ -8348,22 +8637,26 @@
msgid "eps file:"
msgstr "fichier eps :"
-#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
+#: ../gui/wxpython/psmap/dialogs.py:1971
+#: ../gui/wxpython/psmap/dialogs.py:2160
msgid "Type filename or click browse to choose file"
msgstr "Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
-#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
+#: ../gui/wxpython/psmap/dialogs.py:1972
+#: ../gui/wxpython/psmap/dialogs.py:2161
msgid "Choose a file"
msgstr "Choisir un fichier"
-#: ../gui/wxpython/psmap/dialogs.py:1995 ../gui/wxpython/psmap/dialogs.py:2706
-#: ../gui/wxpython/psmap/dialogs.py:3471 ../gui/wxpython/wxplot/dialogs.py:601
+#: ../gui/wxpython/psmap/dialogs.py:1995
+#: ../gui/wxpython/psmap/dialogs.py:2706
+#: ../gui/wxpython/psmap/dialogs.py:3471
+#: ../gui/wxpython/wxplot/dialogs.py:601
msgid "Size"
msgstr "Taille"
#: ../gui/wxpython/psmap/dialogs.py:2002
msgid "size from map table column:"
-msgstr ""
+msgstr "taille depuis la colonne :"
#: ../gui/wxpython/psmap/dialogs.py:2004
msgid "scale:"
@@ -8379,7 +8672,7 @@
#: ../gui/wxpython/psmap/dialogs.py:2043
msgid "counterclockwise in degrees:"
-msgstr ""
+msgstr "sens anti-horaire en degrés :"
#: ../gui/wxpython/psmap/dialogs.py:2045
msgid "from map table column:"
@@ -8387,13 +8680,14 @@
#: ../gui/wxpython/psmap/dialogs.py:2088
msgid "Set width (pts):"
-msgstr ""
+msgstr "Définir la largeur (pts) :"
#: ../gui/wxpython/psmap/dialogs.py:2097
msgid "multiply width by category value"
msgstr "modifier la largeur depuis une valeur de catégorie"
-#: ../gui/wxpython/psmap/dialogs.py:2114 ../gui/wxpython/psmap/dialogs.py:4893
+#: ../gui/wxpython/psmap/dialogs.py:2114
+#: ../gui/wxpython/psmap/dialogs.py:4893
#: ../gui/wxpython/wxplot/dialogs.py:567
msgid "Line style"
msgstr "Style de ligne"
@@ -8412,19 +8706,19 @@
#: ../gui/wxpython/psmap/dialogs.py:2158
msgid "use pattern:"
-msgstr ""
+msgstr "utiliser le motif :"
#: ../gui/wxpython/psmap/dialogs.py:2159
msgid "Choose pattern file:"
-msgstr "Choisir le fichier de modèle :"
+msgstr "Choisir un fichier de motif :"
#: ../gui/wxpython/psmap/dialogs.py:2163
msgid "pattern line width (pts):"
-msgstr ""
+msgstr "épaisseur de ligne du motif (pts) :"
#: ../gui/wxpython/psmap/dialogs.py:2165
msgid "pattern scale factor:"
-msgstr ""
+msgstr "facteur d'échelle du motif :"
#: ../gui/wxpython/psmap/dialogs.py:2481
msgid "Raster legend"
@@ -8446,22 +8740,23 @@
msgid "select raster"
msgstr "sélectionner la carte raster"
-#: ../gui/wxpython/psmap/dialogs.py:2504 ../gui/wxpython/psmap/dialogs.py:3190
+#: ../gui/wxpython/psmap/dialogs.py:2504
+#: ../gui/wxpython/psmap/dialogs.py:3190
#, python-format
msgid "%(rast)s: type %(type)s"
-msgstr ""
+msgstr "%(rast)s : type %(type)s"
#: ../gui/wxpython/psmap/dialogs.py:2523
msgid "Type of legend"
-msgstr ""
+msgstr "Type de légende"
#: ../gui/wxpython/psmap/dialogs.py:2527
msgid "discrete legend (categorical maps)"
-msgstr ""
+msgstr "légende discrète (carte avec catégories)"
#: ../gui/wxpython/psmap/dialogs.py:2529
msgid "continuous color gradient legend (floating point map)"
-msgstr ""
+msgstr "légende en gradient de couleurs continues (carte en nombre flottants)"
#: ../gui/wxpython/psmap/dialogs.py:2540
msgid "Advanced legend settings"
@@ -8469,11 +8764,11 @@
#: ../gui/wxpython/psmap/dialogs.py:2544
msgid "draw \"no data\" box"
-msgstr ""
+msgstr "afficher la boite \"pas de données\""
#: ../gui/wxpython/psmap/dialogs.py:2550
msgid "draw ticks across color table"
-msgstr ""
+msgstr "afficher l'échelle de la table de couleur"
#: ../gui/wxpython/psmap/dialogs.py:2561
#: ../gui/wxpython/modules/colorrules.py:834
@@ -8502,7 +8797,8 @@
msgid "Label"
msgstr "Étiquette"
-#: ../gui/wxpython/psmap/dialogs.py:2638 ../gui/wxpython/psmap/dialogs.py:2944
+#: ../gui/wxpython/psmap/dialogs.py:2638
+#: ../gui/wxpython/psmap/dialogs.py:2944
msgid "Edit label"
msgstr "Modifier les étiquettes"
@@ -8526,7 +8822,8 @@
"Largeur du symbole de couleur (pour les lignes)\n"
"en face du texte de la légende"
-#: ../gui/wxpython/psmap/dialogs.py:2756 ../gui/wxpython/psmap/dialogs.py:2861
+#: ../gui/wxpython/psmap/dialogs.py:2756
+#: ../gui/wxpython/psmap/dialogs.py:2861
msgid "Columns:"
msgstr "Colonnes :"
@@ -8596,7 +8893,8 @@
msgid "default"
msgstr "défaut"
-#: ../gui/wxpython/psmap/dialogs.py:3524 ../gui/wxpython/wxplot/dialogs.py:625
+#: ../gui/wxpython/psmap/dialogs.py:3524
+#: ../gui/wxpython/wxplot/dialogs.py:625
msgid "Style"
msgstr "Style"
@@ -8663,7 +8961,7 @@
#: ../gui/wxpython/psmap/dialogs.py:3875
msgid "rotate text (counterclockwise)"
-msgstr "pivoter le texte (sens inverse des aiguilles)"
+msgstr "pivoter le texte (sens anti-horaire)"
#: ../gui/wxpython/psmap/dialogs.py:3951
msgid "No text entered!"
@@ -8681,11 +8979,13 @@
msgid "Scale And Rotation"
msgstr "Échelle et rotation"
-#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4650
+#: ../gui/wxpython/psmap/dialogs.py:4192
+#: ../gui/wxpython/psmap/dialogs.py:4650
msgid "Rotation angle (deg):"
msgstr "Angle de rotation (deg) :"
-#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4659
+#: ../gui/wxpython/psmap/dialogs.py:4201
+#: ../gui/wxpython/psmap/dialogs.py:4659
msgid "Counterclockwise rotation in degrees"
msgstr "Rotation anti-horaire en degrés"
@@ -8717,7 +9017,7 @@
#: ../gui/wxpython/psmap/dialogs.py:4504
msgid "Compute convergence"
-msgstr ""
+msgstr "Calculer la convergence"
#: ../gui/wxpython/psmap/dialogs.py:4560
msgid "Symbol"
@@ -8735,11 +9035,13 @@
"Note : le symbol sélectionné n'est pas affiché\n"
"en mode brouillon (seulement en mode aperçu"
-#: ../gui/wxpython/psmap/dialogs.py:4598 ../gui/wxpython/psmap/dialogs.py:4852
+#: ../gui/wxpython/psmap/dialogs.py:4598
+#: ../gui/wxpython/psmap/dialogs.py:4852
msgid "Outline color:"
msgstr "Couleur de mise en valeur:"
-#: ../gui/wxpython/psmap/dialogs.py:4613 ../gui/wxpython/psmap/dialogs.py:4873
+#: ../gui/wxpython/psmap/dialogs.py:4613
+#: ../gui/wxpython/psmap/dialogs.py:4873
msgid "Fill color:"
msgstr "Remplir par la couleur"
@@ -8763,7 +9065,8 @@
msgid "Line settings"
msgstr "Paramètres de la ligne"
-#: ../gui/wxpython/psmap/dialogs.py:4896 ../gui/wxpython/gcp/manager.py:2528
+#: ../gui/wxpython/psmap/dialogs.py:4896
+#: ../gui/wxpython/gcp/manager.py:2528
msgid "Line width:"
msgstr "Épaisseur de ligne :"
@@ -8785,13 +9088,16 @@
msgstr "Sélectionner la police pour le texte d'histogramme"
#: ../gui/wxpython/modules/histogram.py:414
-#: ../gui/wxpython/gcp/mapdisplay.py:456 ../gui/wxpython/mapdisp/frame.py:567
+#: ../gui/wxpython/gcp/mapdisplay.py:456
+#: ../gui/wxpython/mapdisp/frame.py:567
#: ../gui/wxpython/gmodeler/frame.py:544
msgid "Choose a file name to save the image (no need to add extension)"
msgstr "Choisissez un nom de fichier pour enregistrer l'image (extension non nécessaire)"
-#: ../gui/wxpython/modules/histogram.py:447 ../gui/wxpython/wxplot/base.py:485
-#: ../gui/wxpython/gcp/mapdisplay.py:489 ../gui/wxpython/mapdisp/frame.py:600
+#: ../gui/wxpython/modules/histogram.py:447
+#: ../gui/wxpython/wxplot/base.py:485
+#: ../gui/wxpython/gcp/mapdisplay.py:489
+#: ../gui/wxpython/mapdisp/frame.py:600
msgid "Print preview"
msgstr "Aperçu avant impression"
@@ -8889,15 +9195,15 @@
#: ../gui/wxpython/modules/mcalc_builder.py:159
msgid "left shift"
-msgstr ""
+msgstr "décalage à gauche"
#: ../gui/wxpython/modules/mcalc_builder.py:161
msgid "right shift"
-msgstr ""
+msgstr "décalage à droite"
#: ../gui/wxpython/modules/mcalc_builder.py:163
msgid "right shift (unsigned)"
-msgstr ""
+msgstr "décalage à droite (non signé)"
#: ../gui/wxpython/modules/mcalc_builder.py:165
msgid "greater than"
@@ -8925,35 +9231,35 @@
#: ../gui/wxpython/modules/mcalc_builder.py:178
msgid "one's complement"
-msgstr ""
+msgstr "complément à 1"
#: ../gui/wxpython/modules/mcalc_builder.py:180
msgid "NOT"
-msgstr ""
+msgstr "NOT"
#: ../gui/wxpython/modules/mcalc_builder.py:182
msgid "bitwise AND"
-msgstr ""
+msgstr "AND bit à bit"
#: ../gui/wxpython/modules/mcalc_builder.py:184
msgid "bitwise OR"
-msgstr ""
+msgstr "OR bit à bit"
#: ../gui/wxpython/modules/mcalc_builder.py:186
msgid "logical AND"
-msgstr ""
+msgstr "AND logique"
#: ../gui/wxpython/modules/mcalc_builder.py:188
msgid "logical AND (ignores NULLs)"
-msgstr ""
+msgstr "AND logique (ignore les NULLs)"
#: ../gui/wxpython/modules/mcalc_builder.py:190
msgid "logical OR"
-msgstr ""
+msgstr "OR logique"
#: ../gui/wxpython/modules/mcalc_builder.py:192
msgid "logical OR (ignores NULLs)"
-msgstr ""
+msgstr "OR logique (ignore les NULLs)"
#: ../gui/wxpython/modules/mcalc_builder.py:194
msgid "conditional"
@@ -9070,7 +9376,7 @@
#: ../gui/wxpython/modules/colorrules.py:504
msgid "Show preview of map (current Map Display extent is used)."
-msgstr ""
+msgstr "Affiche un aperçu de la carte (l'étendue de la fenêtre de cartes actuelle sera utilisée)."
#: ../gui/wxpython/modules/colorrules.py:534
msgid "No valid color rules given."
@@ -9177,12 +9483,12 @@
#: ../gui/wxpython/modules/colorrules.py:1171
#, python-format
msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules cannot be edited."
-msgstr ""
+msgstr "La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <%(mapset)s>. Les règles de couleur ne peuvent pas être modifiées."
#: ../gui/wxpython/modules/colorrules.py:1176
#, python-format
msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
-msgstr ""
+msgstr "La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <%(mapset)s>. La table d'attributs ne peut pas être modifiée."
#: ../gui/wxpython/modules/colorrules.py:1318
#, python-format
@@ -9196,11 +9502,11 @@
#: ../gui/wxpython/modules/colorrules.py:1411
#, python-format
msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
-msgstr ""
+msgstr "Le nombre d'enregistrements est de %d, afficher tous les enregistrements serait très long et peut provoquer un gel de l'ordinateur. Voulez-vous continuer ?"
#: ../gui/wxpython/modules/colorrules.py:1415
msgid "Too many records"
-msgstr ""
+msgstr "Trop d'enregistrements"
#: ../gui/wxpython/modules/colorrules.py:1457
#, python-format
@@ -9306,7 +9612,8 @@
msgid "Extension"
msgstr "Extension"
-#: ../gui/wxpython/modules/vclean.py:31 ../gui/wxpython/modules/vclean.py:113
+#: ../gui/wxpython/modules/vclean.py:31
+#: ../gui/wxpython/modules/vclean.py:113
msgid "Set up vector cleaning tools"
msgstr "Configurer les outils de nettoyage vectoriel"
@@ -9420,30 +9727,30 @@
#: ../gui/wxpython/modules/vclean.py:382
msgid "Please select a cleaning tool to move up"
-msgstr ""
+msgstr "Merci de sélectionnerun outil de nettoyage à faire monter"
#: ../gui/wxpython/modules/vclean.py:405
#, python-format
msgid "%s. cleaning tool moved down"
-msgstr ""
+msgstr "%s. outil de nettoyage descendu"
#: ../gui/wxpython/modules/vclean.py:407
msgid "Last cleaning tool can not be moved down "
-msgstr ""
+msgstr "Le dernier outil de nettoyage ne peut pas être descendu"
#: ../gui/wxpython/modules/vclean.py:409
msgid "Please select a cleaning tool to move down"
-msgstr ""
+msgstr "Merci de sélectionner un outil de nettoyage à faire descendre"
#: ../gui/wxpython/modules/vclean.py:420
#, python-format
msgid "cleaning tool: '%s'"
-msgstr ""
+msgstr "outil de nettoyage : '%s'"
#: ../gui/wxpython/modules/vclean.py:428
#, python-format
msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
-msgstr ""
+msgstr "Seuil pour %(num)s. outil '%(tool)s' : %(thresh)s"
#: ../gui/wxpython/modules/vclean.py:456
msgid "Name of input vector map"
@@ -9455,7 +9762,7 @@
#: ../gui/wxpython/modules/vclean.py:458
msgid "Tools"
-msgstr ""
+msgstr "Outils"
#: ../gui/wxpython/modules/vclean.py:459
msgid "Threshold"
@@ -9503,7 +9810,7 @@
#: ../gui/wxpython/location_wizard/wizard.py:138
msgid "Optional location title, you can leave this field blank."
-msgstr ""
+msgstr "Titre de secteur optionnel, vous pouvez laisser ce champ vide."
#: ../gui/wxpython/location_wizard/wizard.py:169
msgid "Choose GRASS data directory:"
@@ -9862,22 +10169,23 @@
msgid "Select from list of datum transformations"
msgstr "Sélectionner parmi une liste de datums de transformation"
-#: ../gui/wxpython/scripts/p.cmd.py:53 ../gui/wxpython/scripts/p.vect.py:356
+#: ../gui/wxpython/scripts/p.cmd.py:53
+#: ../gui/wxpython/scripts/p.vect.py:356
#: ../gui/wxpython/scripts/p.rast.py:99
msgid "GRASS_PYCMDFILE - File not found. Run p.mon."
-msgstr ""
+msgstr "GRASS_PYCMDFILE - Fichier non trouvé. Exécuter p.mon"
#: ../gui/wxpython/scripts/vkrige.py:33
msgid "No GRASS-python library found."
-msgstr ""
+msgstr "Librairie GRASS-python non trouvée."
#: ../gui/wxpython/scripts/vkrige.py:65
msgid "Input Data"
-msgstr ""
+msgstr "Données en entrée"
#: ../gui/wxpython/scripts/vkrige.py:71
msgid "Point dataset:"
-msgstr ""
+msgstr "Jeux de points :"
#: ../gui/wxpython/scripts/vkrige.py:83
msgid "Numeric column:"
@@ -9948,7 +10256,8 @@
msgid "GRASS Profile Analysis Tool"
msgstr "Outil d'analyse de profil GRASS"
-#: ../gui/wxpython/wxplot/profile.py:64 ../gui/wxpython/wxplot/profile.py:153
+#: ../gui/wxpython/wxplot/profile.py:64
+#: ../gui/wxpython/wxplot/profile.py:153
msgid "Profile of"
msgstr "Profil de"
@@ -9967,7 +10276,7 @@
#: ../gui/wxpython/wxplot/profile.py:146
msgid "Not all points of profile lie inside computational region."
-msgstr ""
+msgstr "Les points du profilage ne sont pas tous dans la région de calcul."
#: ../gui/wxpython/wxplot/profile.py:214
msgid "Raster values"
@@ -9994,9 +10303,8 @@
msgstr "Statistiques du profile"
#: ../gui/wxpython/wxplot/base.py:35
-#, fuzzy
msgid "Draw/re-draw plot"
-msgstr "Trace/retrace le profil"
+msgstr "Trace/retrace le graphique"
#: ../gui/wxpython/wxplot/base.py:37
msgid "Draw transect in map display window to profile"
@@ -10019,15 +10327,16 @@
msgstr "Quitter l'outil"
#: ../gui/wxpython/wxplot/base.py:381
-#, fuzzy
msgid "Left Mouse Down at Point:"
-msgstr "Gauche : nouveau point"
+msgstr "Clic gauche sur le point :"
-#: ../gui/wxpython/wxplot/base.py:411 ../gui/wxpython/wxplot/dialogs.py:247
+#: ../gui/wxpython/wxplot/base.py:411
+#: ../gui/wxpython/wxplot/dialogs.py:247
msgid "Text settings"
msgstr "Réglages de texte"
-#: ../gui/wxpython/wxplot/base.py:415 ../gui/wxpython/wxplot/base.py:472
+#: ../gui/wxpython/wxplot/base.py:415
+#: ../gui/wxpython/wxplot/base.py:472
#: ../gui/wxpython/wxplot/dialogs.py:503
msgid "Plot settings"
msgstr "Paramètres d'affichage"
@@ -10100,14 +10409,15 @@
msgid "Weight:"
msgstr "Graisse :"
-#: ../gui/wxpython/wxplot/dialogs.py:378 ../gui/wxpython/wxplot/dialogs.py:764
+#: ../gui/wxpython/wxplot/dialogs.py:378
+#: ../gui/wxpython/wxplot/dialogs.py:764
msgid "Apply changes for the current session and close dialog"
msgstr "Appliquer les changements pour la session courante et fermer la boite de dialogue"
#: ../gui/wxpython/wxplot/dialogs.py:434
-#, fuzzy, python-format
+#, python-format
msgid "Plot text sizes saved to file '%s'."
-msgstr "Réglages sauvegardés dans le fichier '%s'."
+msgstr "Tailles de texte du graphique sauvegardées dans le fichier '%s'."
#: ../gui/wxpython/wxplot/dialogs.py:492
msgid "No map or image group selected to plot."
@@ -10115,13 +10425,14 @@
#: ../gui/wxpython/wxplot/dialogs.py:493
#: ../gui/wxpython/mapdisp/mapwindow.py:1675
-#: ../gui/wxpython/core/workspace.py:1015 ../gui/wxpython/core/gcmd.py:134
+#: ../gui/wxpython/core/workspace.py:1015
+#: ../gui/wxpython/core/gcmd.py:134
msgid "Warning"
msgstr "Attention"
#: ../gui/wxpython/wxplot/dialogs.py:523
msgid "Map/image plotted"
-msgstr ""
+msgstr "Carte/image tracée"
#: ../gui/wxpython/wxplot/dialogs.py:535
msgid "Settings for selected map"
@@ -10158,7 +10469,7 @@
#: ../gui/wxpython/wxplot/dialogs.py:662
msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
-msgstr ""
+msgstr "Échelle de l'axe automatique, min et max personnalisés, ou échelle correspondant aux données (min)"
#: ../gui/wxpython/wxplot/dialogs.py:667
msgid "Custom min"
@@ -10193,15 +10504,16 @@
msgstr "Afficher la légende"
#: ../gui/wxpython/wxplot/dialogs.py:857
+#, python-format
msgid "Plot settings saved to file '%s'."
-msgstr "Réglages de profil sauvegardés dans le fichier '%s'."
+msgstr "Paramètres de graphique sauvegardés dans le fichier '%s'."
#: ../gui/wxpython/gcp/manager.py:129
msgid "Setup for georectification"
msgstr "paramétrage de la géo-rectification"
-#: ../gui/wxpython/gcp/manager.py:162 ../gui/wxpython/gcp/manager.py:166
+#: ../gui/wxpython/gcp/manager.py:162
+#: ../gui/wxpython/gcp/manager.py:166
msgid "Georectifying setup canceled."
msgstr "Paramétrage de la géo-rectification annulée."
@@ -10249,7 +10561,8 @@
msgid "Add vector map to group..."
msgstr "Ajouter une carte vecteur au groupe ..."
-#: ../gui/wxpython/gcp/manager.py:462 ../gui/wxpython/gcp/manager.py:2618
+#: ../gui/wxpython/gcp/manager.py:462
+#: ../gui/wxpython/gcp/manager.py:2618
msgid "Extension for output maps:"
msgstr "Suffixe pour les cartes en sortie :"
@@ -10265,11 +10578,13 @@
msgid "Select maps to display for ground control point (GCP) creation"
msgstr "Sélectionner les cartes à afficher pour la création des points de contrôle"
-#: ../gui/wxpython/gcp/manager.py:602 ../gui/wxpython/gcp/manager.py:2560
+#: ../gui/wxpython/gcp/manager.py:602
+#: ../gui/wxpython/gcp/manager.py:2560
msgid "Select source map to display:"
msgstr "Sélectionner la carte source à afficher :"
-#: ../gui/wxpython/gcp/manager.py:613 ../gui/wxpython/gcp/manager.py:2565
+#: ../gui/wxpython/gcp/manager.py:613
+#: ../gui/wxpython/gcp/manager.py:2565
msgid "Select target map to display:"
msgstr "Sélectionner la carte cible à afficher :"
@@ -10297,7 +10612,7 @@
#: ../gui/wxpython/gcp/manager.py:1037
msgid "mapwin not defined for "
-msgstr ""
+msgstr "fenêtre de carte non définie pour "
#: ../gui/wxpython/gcp/manager.py:1107
msgid "source"
@@ -10335,11 +10650,11 @@
#: ../gui/wxpython/gcp/manager.py:1201
msgid "source mapwin not defined"
-msgstr ""
+msgstr "fenêtre source non définie"
#: ../gui/wxpython/gcp/manager.py:1206
msgid "target mapwin not defined"
-msgstr ""
+msgstr "fenêtre destination non définie"
#: ../gui/wxpython/gcp/manager.py:1234
msgid "Reading POINTS file failed"
@@ -10366,7 +10681,8 @@
msgid "Transforming <%s>..."
msgstr "Transformation de <%s>..."
-#: ../gui/wxpython/gcp/manager.py:1401 ../gui/wxpython/gcp/manager.py:1472
+#: ../gui/wxpython/gcp/manager.py:1401
+#: ../gui/wxpython/gcp/manager.py:1472
#, python-format
msgid "Georectification of vector map <%s> failed"
msgstr "Échec du géoréférencement de la carte vecteur <%s>"
@@ -10378,7 +10694,7 @@
#: ../gui/wxpython/gcp/manager.py:1453
msgid "For all vector maps georectified successfully,"
-msgstr ""
+msgstr "Pour toutes les cartes vectorielles correctement géorectifiées,"
#: ../gui/wxpython/gcp/manager.py:1454
msgid "you will need to copy any attribute tables"
@@ -10386,7 +10702,7 @@
#: ../gui/wxpython/gcp/manager.py:1455
msgid "and reconnect them to the georectified vectors"
-msgstr ""
+msgstr "et les reconnecter aux vecteurs géorectifiés"
#: ../gui/wxpython/gcp/manager.py:1478
msgid "GCP Manager settings"
@@ -10424,31 +10740,38 @@
msgid "Adjust target display to source display"
msgstr "Ajuster l'affichage cible à l'affichage source"
-#: ../gui/wxpython/gcp/manager.py:1924 ../gui/wxpython/gcp/manager.py:1941
+#: ../gui/wxpython/gcp/manager.py:1924
+#: ../gui/wxpython/gcp/manager.py:1941
msgid "use"
msgstr "utiliser"
-#: ../gui/wxpython/gcp/manager.py:1925 ../gui/wxpython/gcp/manager.py:1942
+#: ../gui/wxpython/gcp/manager.py:1925
+#: ../gui/wxpython/gcp/manager.py:1942
msgid "source E"
msgstr "E source"
-#: ../gui/wxpython/gcp/manager.py:1926 ../gui/wxpython/gcp/manager.py:1943
+#: ../gui/wxpython/gcp/manager.py:1926
+#: ../gui/wxpython/gcp/manager.py:1943
msgid "source N"
msgstr "N source"
-#: ../gui/wxpython/gcp/manager.py:1927 ../gui/wxpython/gcp/manager.py:1944
+#: ../gui/wxpython/gcp/manager.py:1927
+#: ../gui/wxpython/gcp/manager.py:1944
msgid "target E"
msgstr "E cible"
-#: ../gui/wxpython/gcp/manager.py:1928 ../gui/wxpython/gcp/manager.py:1945
+#: ../gui/wxpython/gcp/manager.py:1928
+#: ../gui/wxpython/gcp/manager.py:1945
msgid "target N"
msgstr "N cible"
-#: ../gui/wxpython/gcp/manager.py:1929 ../gui/wxpython/gcp/manager.py:1946
+#: ../gui/wxpython/gcp/manager.py:1929
+#: ../gui/wxpython/gcp/manager.py:1946
msgid "Forward error"
msgstr "Erreur suivante"
-#: ../gui/wxpython/gcp/manager.py:1930 ../gui/wxpython/gcp/manager.py:1947
+#: ../gui/wxpython/gcp/manager.py:1930
+#: ../gui/wxpython/gcp/manager.py:1947
msgid "Backward error"
msgstr "Erreur précédente"
@@ -10591,7 +10914,8 @@
msgid "Target Display"
msgstr "Affichage cible"
-#: ../gui/wxpython/gcp/mapdisplay.py:222 ../gui/wxpython/mapdisp/frame.py:376
+#: ../gui/wxpython/gcp/mapdisplay.py:222
+#: ../gui/wxpython/mapdisp/frame.py:376
msgid "Map Toolbar"
msgstr "Barre d'outils pour les cartes"
@@ -10603,19 +10927,23 @@
msgid "GCP Manager toolbar"
msgstr "Barre d'outils du gestionnaire de points de contrôle"
-#: ../gui/wxpython/gcp/mapdisplay.py:441 ../gui/wxpython/mapdisp/frame.py:552
+#: ../gui/wxpython/gcp/mapdisplay.py:441
+#: ../gui/wxpython/mapdisp/frame.py:552
msgid "Nothing to render (empty map). Operation canceled."
msgstr "Rien à afficher (carte vide). Opération annulée."
-#: ../gui/wxpython/gcp/mapdisplay.py:578 ../gui/wxpython/mapdisp/frame.py:1240
+#: ../gui/wxpython/gcp/mapdisplay.py:578
+#: ../gui/wxpython/mapdisp/frame.py:1240
msgid "Zoom to computational region (set with g.region)"
msgstr "Zoomer sur la région de calcul (définie avec g.region)"
-#: ../gui/wxpython/gcp/mapdisplay.py:582 ../gui/wxpython/mapdisp/frame.py:1244
+#: ../gui/wxpython/gcp/mapdisplay.py:582
+#: ../gui/wxpython/mapdisp/frame.py:1244
msgid "Zoom to default region"
msgstr "Zoom sur la région par défaut"
-#: ../gui/wxpython/gcp/mapdisplay.py:586 ../gui/wxpython/mapdisp/frame.py:1248
+#: ../gui/wxpython/gcp/mapdisplay.py:586
+#: ../gui/wxpython/mapdisp/frame.py:1248
msgid "Zoom to saved region"
msgstr "Zoom sur la région sauvegardée"
@@ -10623,7 +10951,8 @@
msgid "Set computational region from display"
msgstr "Définir la région calculée à partir de celle de l'écran"
-#: ../gui/wxpython/gcp/mapdisplay.py:594 ../gui/wxpython/mapdisp/frame.py:1256
+#: ../gui/wxpython/gcp/mapdisplay.py:594
+#: ../gui/wxpython/mapdisp/frame.py:1256
msgid "Save display geometry to named region"
msgstr "Enregistrer la géométrie de l'écran dans un nom de région"
@@ -10643,8 +10972,10 @@
"Souhaitez-vous démarrer le numériseur Tcl/Tk(v.digit) à la place ?\n"
"Détails: %s"
-#: ../gui/wxpython/mapdisp/frame.py:197 ../gui/wxpython/mapdisp/frame.py:208
-#: ../gui/wxpython/mapdisp/frame.py:260 ../gui/wxpython/mapdisp/frame.py:407
+#: ../gui/wxpython/mapdisp/frame.py:197
+#: ../gui/wxpython/mapdisp/frame.py:208
+#: ../gui/wxpython/mapdisp/frame.py:260
+#: ../gui/wxpython/mapdisp/frame.py:407
#: ../gui/wxpython/mapdisp/toolbars.py:78
msgid "2D view"
msgstr "Vue 2D"
@@ -10727,12 +11058,16 @@
"Geodesic distance is not yet supported by this tool.\n"
"Reason: %s"
msgstr ""
+"La distance géodésique n'est pas encore supportée par cet outil.\n"
+"Raison : %s"
-#: ../gui/wxpython/mapdisp/frame.py:983 ../gui/wxpython/mapdisp/frame.py:989
+#: ../gui/wxpython/mapdisp/frame.py:983
+#: ../gui/wxpython/mapdisp/frame.py:989
msgid "segment"
msgstr "segment"
-#: ../gui/wxpython/mapdisp/frame.py:984 ../gui/wxpython/mapdisp/frame.py:990
+#: ../gui/wxpython/mapdisp/frame.py:984
+#: ../gui/wxpython/mapdisp/frame.py:990
msgid "total distance"
msgstr "distance totale"
@@ -10742,7 +11077,7 @@
#: ../gui/wxpython/mapdisp/frame.py:985
msgid "deg"
-msgstr ""
+msgstr "deg"
#: ../gui/wxpython/mapdisp/frame.py:1090
msgid "Scale and North arrow"
@@ -10762,7 +11097,7 @@
#: ../gui/wxpython/mapdisp/frame.py:1127
msgid "legend object"
-msgstr ""
+msgstr "objet légende"
#: ../gui/wxpython/mapdisp/frame.py:1149
#: ../gui/wxpython/mapdisp/toolbars.py:46
@@ -10795,7 +11130,7 @@
#: ../gui/wxpython/mapdisp/toolbars.py:38
msgid "Measuring, profiling, histogramming, ..."
-msgstr ""
+msgstr "Mesures, profilage, histogrammes, ..."
#: ../gui/wxpython/mapdisp/toolbars.py:40
msgid "Measure distance"
@@ -10803,12 +11138,11 @@
#: ../gui/wxpython/mapdisp/toolbars.py:42
msgid "Profile surface map"
-msgstr ""
+msgstr "Profiler la carte de surface"
#: ../gui/wxpython/mapdisp/toolbars.py:44
-#, fuzzy
msgid "Create bivariate scatterplot of raster maps"
-msgstr "Créer un histogramme de carte raster"
+msgstr "Créer un nuage de points bivarié de la carte raster"
#: ../gui/wxpython/mapdisp/toolbars.py:48
msgid "Create histogram of raster map"
@@ -10816,15 +11150,15 @@
#: ../gui/wxpython/mapdisp/toolbars.py:53
msgid "Rotate 3D scene"
-msgstr ""
+msgstr "Faire pivoter la scène 3D"
#: ../gui/wxpython/mapdisp/toolbars.py:54
msgid "Drag with mouse to rotate 3D scene"
-msgstr "Déplacer avec la souris pour faire tourner la scène 3D"
+msgstr "Déplacer avec la souris pour faire pivoter la scène 3D"
#: ../gui/wxpython/mapdisp/toolbars.py:57
msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
-msgstr ""
+msgstr "Déplacer avec la souris, appuyer sur Ctrl pour les différents modes, ou Maj pour accélérer"
#: ../gui/wxpython/mapdisp/toolbars.py:59
msgid "Click mouse to zoom"
@@ -10871,7 +11205,7 @@
#: ../gui/wxpython/mapdisp/statusbar.py:385
msgid "Show comp. extent"
-msgstr ""
+msgstr "Afficher l'étendue"
#: ../gui/wxpython/mapdisp/statusbar.py:388
msgid "Show computational extent"
@@ -10903,7 +11237,7 @@
#: ../gui/wxpython/mapdisp/statusbar.py:497
msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
-msgstr ""
+msgstr "Étant donné que tous les moniteurs et les résolutions sont réglés différemment, ces valeurs ne sont pas des échelles réelles mais restent proches de la réalité."
#: ../gui/wxpython/mapdisp/statusbar.py:550
msgid "Go to"
@@ -10940,15 +11274,15 @@
#: ../gui/wxpython/mapdisp/statusbar.py:779
msgid "Coordinates"
-msgstr ""
+msgstr "Coordonnées"
#: ../gui/wxpython/mapdisp/statusbar.py:833
msgid "Extent"
-msgstr ""
+msgstr "Etendue"
#: ../gui/wxpython/mapdisp/statusbar.py:928
msgid "Comp. region"
-msgstr ""
+msgstr "Région de calcul"
#: ../gui/wxpython/mapdisp/statusbar.py:977
msgid "Go to GCP No."
@@ -11004,6 +11338,8 @@
"There was a problem printing.\n"
"Perhaps your current printer is not set correctly?"
msgstr ""
+"Problème lors de l'impression.\n"
+"Peut-être que votre imprimante n'est pas configurée correctement ?"
#: ../gui/wxpython/vdigit/wxdisplay.py:869
#, python-format
@@ -11321,7 +11657,8 @@
msgid "Digitize new point"
msgstr "Numériser un nouveau point"
-#: ../gui/wxpython/vdigit/toolbars.py:85 ../gui/wxpython/vdigit/toolbars.py:94
+#: ../gui/wxpython/vdigit/toolbars.py:85
+#: ../gui/wxpython/vdigit/toolbars.py:94
#: ../gui/wxpython/vdigit/toolbars.py:97
msgid "Left: new point"
@@ -11330,7 +11667,8 @@
msgid "Digitize new line"
msgstr "Numériser une nouvelle ligne"
-#: ../gui/wxpython/vdigit/toolbars.py:88 ../gui/wxpython/vdigit/toolbars.py:91
+#: ../gui/wxpython/vdigit/toolbars.py:88
+#: ../gui/wxpython/vdigit/toolbars.py:91
#: ../gui/wxpython/vdigit/toolbars.py:112
msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
msgstr "Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : fermer la ligne"
@@ -11525,7 +11863,7 @@
#: ../gui/wxpython/vdigit/mapwindow.py:502
msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
-msgstr ""
+msgstr "Pas d'action. Choisissez l'outil approprié depuis la barre d'outil de numérisation."
#: ../gui/wxpython/vdigit/mapwindow.py:992
msgid "Z bulk-labeling dialog"
@@ -11547,7 +11885,8 @@
msgid "Apply changes and close dialog"
msgstr "Appliquer les modifications et fermer la boîte de dialogue"
-#: ../gui/wxpython/vdigit/dialogs.py:236 ../gui/wxpython/vdigit/dialogs.py:455
+#: ../gui/wxpython/vdigit/dialogs.py:236
+#: ../gui/wxpython/vdigit/dialogs.py:455
#, python-format
msgid ""
"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
@@ -11627,7 +11966,7 @@
#: ../gui/wxpython/gmodeler/frame.py:182
#: ../gui/wxpython/gmodeler/frame.py:1628
msgid "Python script is up-to-date"
-msgstr ""
+msgstr "Le script Python est à jour"
#: ../gui/wxpython/gmodeler/frame.py:197
msgid "Redrawing model..."
@@ -11663,11 +12002,13 @@
msgid "%d maps deleted from current mapset"
msgstr "%d cartes supprimées du jeu de cartes courant"
-#: ../gui/wxpython/gmodeler/frame.py:335 ../gui/wxpython/gmodeler/frame.py:450
+#: ../gui/wxpython/gmodeler/frame.py:335
+#: ../gui/wxpython/gmodeler/frame.py:450
msgid "Current model is not empty. Do you want to store current settings to model file?"
msgstr "le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres courants dans un fichier ?"
-#: ../gui/wxpython/gmodeler/frame.py:338 ../gui/wxpython/gmodeler/frame.py:453
+#: ../gui/wxpython/gmodeler/frame.py:338
+#: ../gui/wxpython/gmodeler/frame.py:453
msgid "Create new model?"
msgstr "Créer un nouveau modèle ?"
@@ -11678,14 +12019,16 @@
#: ../gui/wxpython/gmodeler/frame.py:383
#, python-format
msgid "%(items)d items (%(actions)d actions) loaded into model"
-msgstr ""
+msgstr "%(items)d éléments (%(actions)d actions) chargés dans le modèle"
-#: ../gui/wxpython/gmodeler/frame.py:390 ../gui/wxpython/gmodeler/frame.py:427
+#: ../gui/wxpython/gmodeler/frame.py:390
+#: ../gui/wxpython/gmodeler/frame.py:427
#, python-format
msgid "Model file <%s> already exists. Do you want to overwrite this file?"
msgstr "Le fichier de modèle <%s> existe déjà. Voulez-vous écraser ce fichier ?"
-#: ../gui/wxpython/gmodeler/frame.py:400 ../gui/wxpython/gmodeler/frame.py:440
+#: ../gui/wxpython/gmodeler/frame.py:400
+#: ../gui/wxpython/gmodeler/frame.py:440
#, python-format
msgid "File <%s> saved"
msgstr "Fichier <%s> enregistré"
@@ -11702,7 +12045,8 @@
msgid "Model is empty. Nothing to validate."
msgstr "Le modèle est vide. Rien à valider."
-#: ../gui/wxpython/gmodeler/frame.py:502 ../gui/wxpython/gmodeler/model.py:511
+#: ../gui/wxpython/gmodeler/frame.py:502
+#: ../gui/wxpython/gmodeler/model.py:511
msgid "Validating model..."
msgstr "Validation du modèle ..."
@@ -11721,7 +12065,8 @@
msgid "Model is valid."
msgstr "Le modèle est valide."
-#: ../gui/wxpython/gmodeler/frame.py:572 ../gui/wxpython/gmodeler/frame.py:579
+#: ../gui/wxpython/gmodeler/frame.py:572
+#: ../gui/wxpython/gmodeler/frame.py:579
#, python-format
msgid "Model exported to <%s>"
msgstr "Modèle exporté vers <%s>"
@@ -11825,7 +12170,7 @@
#: ../gui/wxpython/gmodeler/frame.py:1444
msgid "In block"
-msgstr ""
+msgstr "Bloc"
#: ../gui/wxpython/gmodeler/frame.py:1445
msgid "Command / Condition"
@@ -11848,6 +12193,8 @@
"Refresh python script based on the model.\n"
"It will discards all local changes."
msgstr ""
+"Actualiser le script Python basé sur le modèle.\n"
+"Ceci écrasera toutes les modifications manuelles."
#: ../gui/wxpython/gmodeler/frame.py:1526
#, python-format
@@ -11873,11 +12220,11 @@
#: ../gui/wxpython/gmodeler/frame.py:1604
msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
-msgstr ""
+msgstr "Le script Python a été modifié manuellement. La mise à jour écrasera toutes les modifications. Voulez-vous vraiment continuer ?"
#: ../gui/wxpython/gmodeler/frame.py:1607
msgid "Update"
-msgstr ""
+msgstr "Mettre à jour"
#: ../gui/wxpython/gmodeler/model.py:58
msgid "model"
@@ -11887,7 +12234,8 @@
msgid "Script generated by wxGUI Graphical Modeler."
msgstr "Script généré par le Modeleur Graphique wxGUI."
-#: ../gui/wxpython/gmodeler/model.py:388 ../gui/wxpython/gmodeler/model.py:450
+#: ../gui/wxpython/gmodeler/model.py:388
+#: ../gui/wxpython/gmodeler/model.py:450
#, python-format
msgid "undefined variable '%s'"
msgstr "variable '%s' non définie"
@@ -12086,18 +12434,24 @@
"Relation doesn't start with data item.\n"
"Unable to add relation."
msgstr ""
+"La relation ne commence pas par des données.\n"
+"Impossible d'ajouter la relation."
#: ../gui/wxpython/gmodeler/dialogs.py:341
msgid ""
"Relation doesn't point to GRASS command.\n"
msgstr ""
+"La relation ne pointe pas vers une commande GRASS.\n"
#: ../gui/wxpython/gmodeler/dialogs.py:354
msgid ""
"No relevant option found.\n"
msgstr ""
+"Pas d'option pertinente trouvée.\n"
#: ../gui/wxpython/gmodeler/dialogs.py:385
msgid "Condition"
@@ -12113,15 +12467,15 @@
#: ../gui/wxpython/gmodeler/dialogs.py:419
msgid "Series"
-msgstr ""
+msgstr "Séries"
#: ../gui/wxpython/gmodeler/dialogs.py:420
msgid "Define map series as condition for the loop"
-msgstr ""
+msgstr "Définir une série de cartes comme condition pour la boucle"
#: ../gui/wxpython/gmodeler/dialogs.py:464
msgid "Define series of maps"
-msgstr ""
+msgstr "Définir une série de cartes"
#: ../gui/wxpython/gmodeler/dialogs.py:479
msgid "If-else properties"
@@ -12129,11 +12483,11 @@
#: ../gui/wxpython/gmodeler/dialogs.py:485
msgid "List of items in 'if' block"
-msgstr ""
+msgstr "Liste des éléments dans le bloc \"if\""
#: ../gui/wxpython/gmodeler/dialogs.py:490
msgid "List of items in 'else' block"
-msgstr ""
+msgstr "Liste des éléments dans le bloc \"else\""
#: ../gui/wxpython/gmodeler/dialogs.py:654
#, python-format
@@ -12155,7 +12509,7 @@
#: ../gui/wxpython/gmodeler/dialogs.py:905
msgid "Normalize"
-msgstr ""
+msgstr "Normaliser"
#: ../gui/wxpython/core/render.py:125
#, python-format
@@ -12191,7 +12545,8 @@
msgid "Unable to zoom to raster map <%s>."
msgstr "Impossible de zoomer sur la carte raster : %s"
-#: ../gui/wxpython/core/render.py:643 ../gui/wxpython/core/render.py:646
+#: ../gui/wxpython/core/render.py:643
+#: ../gui/wxpython/core/render.py:646
#: ../gui/wxpython/core/gcmd.py:387
msgid "Details:"
msgstr "Détails :"
@@ -12210,19 +12565,21 @@
msgid "ERROR: Rendering failed. Details: %s"
msgstr "ERREUR : le rendu a échoué. Détails : %s"
-#: ../gui/wxpython/core/render.py:980 ../gui/wxpython/core/render.py:1064
+#: ../gui/wxpython/core/render.py:980
+#: ../gui/wxpython/core/render.py:1064
#, python-format
msgid "Unable to render map layer <%s>."
msgstr "Impossible de générer l'aperçu de la carte <%s>."
-#: ../gui/wxpython/core/render.py:1173 ../gui/wxpython/core/render.py:1212
+#: ../gui/wxpython/core/render.py:1173
+#: ../gui/wxpython/core/render.py:1212
#, python-format
msgid "Unable to render overlay <%s>."
msgstr "Impossible de générer l'aperçu de la superposition <%s>."
#: ../gui/wxpython/core/settings.py:447
msgid "Segment break"
-msgstr ""
+msgstr "Fin de segement"
#: ../gui/wxpython/core/settings.py:514
msgid "animation"
@@ -12266,7 +12623,7 @@
#: ../gui/wxpython/core/settings.py:722
msgid "Zoom and recenter"
-msgstr ""
+msgstr "Zoom et recentre"
#: ../gui/wxpython/core/settings.py:723
msgid "Zoom to mouse cursor"
@@ -12278,11 +12635,11 @@
#: ../gui/wxpython/core/settings.py:725
msgid "Scroll forward to zoom in"
-msgstr ""
+msgstr "Molette avant pour zoomer"
#: ../gui/wxpython/core/settings.py:726
msgid "Scroll back to zoom in"
-msgstr ""
+msgstr "Molette arrière pour zoomer"
#: ../gui/wxpython/core/settings.py:759
msgid "box"
@@ -12298,15 +12655,15 @@
#: ../gui/wxpython/core/settings.py:762
msgid "diamond"
-msgstr ""
+msgstr "diamant"
#: ../gui/wxpython/core/settings.py:763
msgid "aster"
-msgstr ""
+msgstr "étoile"
#: ../gui/wxpython/core/settings.py:764
msgid "gyro"
-msgstr ""
+msgstr "roue"
#: ../gui/wxpython/core/settings.py:765
msgid "histogram"
@@ -12324,6 +12681,9 @@
"\t\tDetails: %(detail)s\n"
"\t\tLine: '%(line)s'\n"
msgstr ""
+"Erreur : la lecture des paramètres depuis le fichier <%(file)s> a échoué.\n"
+"\t\tDétails: %(detail)s\n"
+"\t\tLigne: '%(line)s'\n"
#: ../gui/wxpython/core/settings.py:845
msgid "Unable to create settings directory"
@@ -12336,15 +12696,19 @@
"\n"
"Details: %(detail)s"
msgstr ""
+"L'enregistrement des paramètres dans le fichier <%(file)s> a échoué.\n"
+"\n"
+"Détails : %(detail)s"
#: ../gui/wxpython/core/settings.py:980
msgid "Unable to set "
-msgstr ""
+msgstr "Impossible de définir "
-#: ../gui/wxpython/core/settings.py:1006 ../gui/wxpython/core/settings.py:1012
+#: ../gui/wxpython/core/settings.py:1006
+#: ../gui/wxpython/core/settings.py:1012
#, python-format
msgid "Unable to parse settings '%s'"
-msgstr ""
+msgstr "Impossible de lire la configuration '%s'"
#: ../gui/wxpython/core/menudata.py:84
msgid "Unknow tag"
@@ -12376,11 +12740,13 @@
"%s: line skipped - unable to parse '%s'\n"
"Reason: %s\n"
msgstr ""
+"%s : ligne sautée - impossible de lire '%s'\n"
+"Raison : %s\n"
#: ../gui/wxpython/core/utils.py:821
#, python-format
msgid "Duplicated key: %s\n"
-msgstr ""
+msgstr "Paramètre en double : %s\n"
#: ../gui/wxpython/core/utils.py:836
#, python-format
@@ -12413,7 +12779,7 @@
#: ../gui/wxpython/core/gcmd.py:81
#, python-format
msgid "ERROR: %s\n"
-msgstr ""
+msgstr "ERREUR : %s\n"
#: ../gui/wxpython/core/gcmd.py:122
msgid "Reason"
@@ -12423,7 +12789,8 @@
msgid "Execution failed:"
msgstr "L'exécution a échoué :"
-#: ../gui/wxpython/core/gcmd.py:389 ../gui/wxpython/core/gcmd.py:393
+#: ../gui/wxpython/core/gcmd.py:389
+#: ../gui/wxpython/core/gcmd.py:393
msgid "Error: "
msgstr "Erreur :"
@@ -12432,1086 +12799,3 @@
msgid "Unable to exectute command: '%s'"
msgstr "Impossible d'exécuter la commande : '%s'"
-#~ msgid "Python:"
-#~ msgstr "Python :"
-#~ msgid "wxPython:"
-#~ msgstr "wxPython :"
-#~ msgid "Language:"
-#~ msgstr "Langue :"
-#~ msgid "Adjusts the viewer's angle of view"
-#~ msgstr "Ajuster l'angle de vue"
-#~ msgid "Rotates the scene about the horizontal axis. An angle of 0 is flat. The scene rotates between -90 and 90 degrees."
-#~ msgstr "Effectue une rotation sur l'axe horitontal. Un angle de 0 est plat. L'angle de rotation doit être entre -90 et 90 degrés."
-#~ msgid "Adjusts the vertical exaggeration of the surface. As an example, if the easting and northing are in meters and the elevation in feet, a vertical exaggeration of .305 would produce a true (unexaggerated) surface. "
-#~ msgstr "Ajuster l'exagération verticale. Par exemple, si les abscisse et ordonnée sont en mètres et l'altitude en pieds, une exagération verticale de 0,305 produira une surface vraie (non exagérée)."
-#~ msgid "Adjusts the look direction (azimuth). Click and drag the puck to change the current eye position."
-#~ msgstr "Ajuster la direction de la vue (azimuth). Cliquez et déplacez le point pour changer l'angle de vue."
-#~ msgid "Profile line settings"
-#~ msgstr "Réglages de ligne du profil"
-#~ msgid "'%(cmd)s' failed. Details: %(det)s"
-#~ msgstr "Commande '%(cmd)s' échouée. Détails : %(det)s"
-#~ msgid "Profile of %s"
-#~ msgstr "Profil de %s"
-#~ msgid "Profile settings"
-#~ msgstr "Réglages du profil"
-#~ msgid "Select raster map 2 (optional):"
-#~ msgstr "Sélectionner la carte raster 2 (optionnel) :"
-#~ msgid "Select raster map 3 (optional):"
-#~ msgstr "Sélectionner la carte raster 3 (optionnel) :"
-#~ msgid ""
-#~ "No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
-#~ "\n"
-#~ "New attribute table can be created by Attribute Table Manager."
-#~ msgstr ""
-#~ "Aucune table attributaire liée à la carte vecteur <%(vector)s> trouvée. %(msg)s\n"
-#~ "\n"
-#~ "Une nouvelle table attributaire peut être créée par le gestionnaire de table attributaire."
-#~ msgid "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
-#~ msgstr "Le module r.mapcalc ne peut pas être utilisé dans le modèle. Utiliser r.mapcalculator à la place."
-#~ msgid "Change ID"
-#~ msgstr "Modifier l'ID"
-#~ msgid "&Add"
-#~ msgstr "&Ajouter"
-#~ msgid "Add selected map layers to current display"
-#~ msgstr "Ajouter la carte sélectionnée à l'affichage courant"
-#~ msgid "Filter:"
-#~ msgstr "Filtre :"
-#~ msgid ""
-#~ "No layers marked for import.\n"
-#~ "Operation canceled."
-#~ msgstr ""
-#~ "Aucune couche sélectionnée pour l'import.\n"
-#~ "Opération annulée."
-#~ msgid "Source"
-#~ msgstr "Source"
-#~ msgid "Directory:"
-#~ msgstr "Répertoire :"
-#~ msgid "Database:"
-#~ msgstr "Base de données :"
-#~ msgid "north"
-#~ msgstr "nord"
-#~ msgid "south"
-#~ msgstr "sud"
-#~ msgid "east"
-#~ msgstr "est"
-#~ msgid "west"
-#~ msgstr "ouest"
-#~ msgid "north-west"
-#~ msgstr "nord-ouest"
-#~ msgid "north-east"
-#~ msgstr "nord-est"
-#~ msgid "south-east"
-#~ msgstr "sud-est"
-#~ msgid "south-west"
-#~ msgstr "sud-ouest"
-#~ msgid "Topography"
-#~ msgstr "Topographie"
-#~ msgid "res."
-#~ msgstr "res."
-#~ msgid "Mask zeros:"
-#~ msgstr "Masquer les zéros :"
-#~ msgid "by elevation"
-#~ msgstr "par altitude"
-#~ msgid "width"
-#~ msgstr "largeur"
-#~ msgid "display"
-#~ msgstr "afficher"
-#~ msgid "size"
-#~ msgstr "taille"
-#~ msgid "slides"
-#~ msgstr "vues"
-#~ msgid "Topography level"
-#~ msgstr "Niveau topographique"
-#~ msgid "Follow source viewpoint"
-#~ msgstr "Suivre le point de vue de la source"
-#~ msgid "(value)"
-#~ msgstr "(valeur)"
-#~ msgid "(step)"
-#~ msgstr "(pas)"
-#~ msgid "(x)"
-#~ msgstr "(x) "
-#~ msgid "Show lines"
-#~ msgstr "Afficher les lignes"
-#~ msgid "Show points"
-#~ msgstr "Afficher les points"
-#~ msgid "Nviz settings saved to file <%s>."
-#~ msgstr "Paramètres NVIZ enregistrés dans <%s>."
-#~ msgid "Set map canvas for "
-#~ msgstr "Définir la trame de carte pour"
-#~ msgid " / Zoom to map"
-#~ msgstr "/ Zoomer sur la carte"
-#~ msgid "Cl&ear"
-#~ msgstr "N&ettoyer"
-#~ msgid "replace existing color table"
-#~ msgstr "Remplacer la table de couleur existante"
-#~ msgid "Please select attribute column and RGB color column first"
-#~ msgstr "Merci de sélectionner d'abord une colonne d'attribut et une colonne de couleur RVG"
-#~ msgid "Color table already exists. Check out 'replace existing color table' to overwrite it."
-#~ msgstr "La table de couleur existe déjà. Cochez la case « remplacer la table de couleur existante » pour la remplacer."
-#~ msgid "Function not implemented yet"
-#~ msgstr "Fonction pas encore implantée"
-#~ msgid "C&lear cmd"
-#~ msgstr "Effacer les commandes"
-#~ msgid "&Save output"
-#~ msgstr "Enregistrer les messages de sortie"
-#~ msgid "&Abort cmd"
-#~ msgstr "Annuler la commande"
-#~ msgid "3d raster"
-#~ msgstr "raster 3d"
-#~ msgid "Georectification Toolbar"
-#~ msgstr "Barre d'outils de géo-rectification"
-#~ msgid "No map layer selected for querying."
-#~ msgstr "Aucune carte vecteur sélectionnée pour interrogation."
-#~ msgid "Query surface (raster map)"
-#~ msgstr "Interroger une surface (carte raster)"
-#~ msgid "set up vector cleaning tools"
-#~ msgstr "Configurer les outils de nettoyage vectoriel"
-#~ msgid "Invalid GCP Number"
-#~ msgstr "Numéro de point d'amer non valide"
-#~ msgid ""
-#~ "Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-#~ "Layer and category number must be integer.\n"
-#~ "Layer number must be greater then zero."
-#~ msgstr ""
-#~ "Impossible d'ajouter la nouvelle couche/catégorie <%(layer)s/%(category)s>.\n"
-#~ "Les numéros de couche et de catégorie doivent être des nombres entiers.\n"
-#~ "Le numéro de couche doit être supérieur à zéro."
-#~ msgid "Attribute Table Manager"
-#~ msgstr "Gestionnaire de table attributaire"
-#~ msgid "Choose GIS Data Directory:"
-#~ msgstr "Choisir le répertoire contenant les données SIG : "
-#~ msgid "GRASS Quickstart"
-#~ msgstr "Démarrage rapide de GRASS"
-#~ msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
-#~ msgstr "L'utilitaire de sortie papier n'est pas disponible. Vous pouvez l'installer via %s"
-#~ msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
-#~ msgstr "Impossible d'aller dans le jeux de cartes <%(mapset)s> du secteur de travail <%(loc)s>."
-#~ msgid "Starting GRASS GUI..."
-#~ msgstr "Démarrage de l'interface graphique de GRASS"
-#~ msgid "Query with attributes"
-#~ msgstr "Interroger via les attributs"
-#~ msgid "Query with another vector map"
-#~ msgstr "Interroger à partir d'une autre carte vecteur"
-#~ msgid "Update point attributes from raster"
-#~ msgstr "Mise à jour des attributs ponctuels depuis une carte raster"
-#~ msgid "Ortho photo rectification (requires Xterm)"
-#~ msgstr "Orthorectification (requiert XTerm)"
-#~ msgid "Add action"
-#~ msgstr "Ajouter une action"
-#~ msgid "Show GUI settings"
-#~ msgstr "Afficher les réglages de l'interface graphique"
-#~ msgid "Profile options"
-#~ msgstr "Options de profil"
-#~ msgid "Quit Profile Analysis Tool"
-#~ msgstr "Quitter l'outil d'analyse de profil"
-#~ msgid "Set GCP"
-#~ msgstr "Ajuster les points de contrôles (PCS)"
-#~ msgid "Define GCP (Ground Control Points)"
-#~ msgstr "Définir les points de contrôle au sol (PCS)"
-#~ msgid "Recalculate RMS error"
-#~ msgstr "Recalculer l'erreur RMS"
-#~ msgid "Save GCPs to POINTS file"
-#~ msgstr "Enregistrer GCPs dans un fichier POINTS"
-#~ msgid "Add new GCP"
-#~ msgstr "Ajouter de nouveaux PCS"
-#~ msgid "Delete selected GCP"
-#~ msgstr "Supprimer les points de contrôles (PCS) sélectionnés"
-#~ msgid "Clear selected GCP"
-#~ msgstr "Nettoyer les points d'amer sélectionnés"
-#~ msgid "Reload GCPs from POINTS file"
-#~ msgstr "Recharger les points d'amer depuis un fichier POINTS"
-#~ msgid "Quit georectification"
-#~ msgstr "Quitter le module de géo-rectification"
-#~ msgid "Settings dialog for georectification tool"
-#~ msgstr "Paramètres pour l'outil de géo-rectification"
-#~ msgid "Switch to view control page"
-#~ msgstr "Passer à la page de contrôle de vue"
-#~ msgid "Change view settings"
-#~ msgstr "Modifier les paramètres d'affichage"
-#~ msgid "Switch to surface (raster) control page"
-#~ msgstr "Passer à la page de contrôle de surface (raster)"
-#~ msgid "Change surface (loaded raster maps) settings"
-#~ msgstr "Modifier les paramètres de surface (carte vecteur chargée)"
-#~ msgid "Switch to vector (2D/3D) control page"
-#~ msgstr "Passer à la page de contrôle de vecteur (2D/3D)"
-#~ msgid "Change 2D/3D vector settings"
-#~ msgstr "Modifier les paramètres de vecteur 2D/3D"
-#~ msgid "Switch to volume (3D raster) control page"
-#~ msgstr "Passer à la page de contrôle de volume (raster 3D)"
-#~ msgid "Change volume (loaded 3D raster maps) settings"
-#~ msgstr "Modifier les réglages de volumes (cartes 3D chargées)"
-#~ msgid "Switch to lighting control page"
-#~ msgstr "Passer à la page de contrôle d'éclairage"
-#~ msgid "Change lighting settings"
-#~ msgstr "Modifier les réglages d'éclairage"
-#~ msgid "Switch to fringe control page"
-#~ msgstr "Passer à la page de contrôle de frange"
-#~ msgid "Switch on/off fringes"
-#~ msgstr "Commuter les franges"
-#~ msgid "Quit 3D view mode"
-#~ msgstr "Quitter le mode vue 3D"
-#~ msgid "Create new model (Ctrl+N)"
-#~ msgstr "Créer un nouveau modèle (Ctrl+N)"
-#~ msgid "Load model from file (Ctrl+O)"
-#~ msgstr "Charger un modèle depuis un fichier (Ctrl+O)"
-#~ msgid "Save current model to file (Ctrl+S)"
-#~ msgstr "Enregistrer le modèle actuel dans un fichier (Ctrl+S)"
-#~ msgid "Show modeler settings"
-#~ msgstr "Afficher les réglages du modeleur"
-#~ msgid "Show model properties"
-#~ msgstr "Afficher les propriétés du modèle"
-#~ msgid "Manage model variables"
-#~ msgstr "Gérer les variables du modèle"
-#~ msgid "Redraw model canvas"
-#~ msgstr "Redessiner la trame du modèle"
-#~ msgid "Add raster map"
-#~ msgstr "Ajouter une carte raster"
-#~ msgid "Add vector map"
-#~ msgstr "Ajouter une carte vecteur"
-#~ msgid "Add text"
-#~ msgstr "Ajouter du texte"
-#~ msgid "Unable to render overlay <%s>"
-#~ msgstr "Impossible de générer l'aperçu de la superposition <%s>"
-#~ msgid "Upload or report topology"
-#~ msgstr "Envoyer ou charger la topologie"
-#~ msgid "GRASS GIS Hardcopy Map Output Utility (experimental prototype)"
-#~ msgstr "SIG GRASS - Utilitaire d'export de cartes (expérimental)"
-#, fuzzy
-#~ msgid "Close current"
-#~ msgstr "Fermer le fichier d'espace de travail courant"
-#~ msgid "Submit"
-#~ msgstr "Valider"
-#~ msgid "Vector digitizer"
-#~ msgstr "Numérisation de vecteur"
-#~ msgid "Vector querying"
-#~ msgstr "Interrogation de vecteur"
-#~ msgid "Query raster/vector map(s) (display mode)"
-#~ msgstr "Interroger une(des) carte(s) 'raster'/vectorielle(s) (mode affichage)"
-#~ msgid "Query vector map (edit mode)"
-#~ msgstr "Interroger une carte vecteur (mode édition)"
-#~ msgid "GRASS GIS Graphical Modeler"
-#~ msgstr "Gestionnaire graphique des modèles GRASS"
-#, fuzzy
-#~ msgid "Flag not found: %s"
-#~ msgstr "Drapeau non trouvé : %s"
-#~ msgid "Parameter '%(name)s' (%(desc)s) is missing."
-#~ msgstr "Le paramètre '%(name)s' (%(desc)s) est manquant."
-#~ msgid "<required>"
-#~ msgstr "<obligatoire>"
-#~ msgid "Unable to fetch interface description for command '%s'."
-#~ msgstr "Impossible de trouver la description de l'interface pour la commande '%s'."
-#~ msgid "Menu style:"
-#~ msgstr "Style de menu :"
-#~ msgid "Load map layers into layer tree"
-#~ msgstr "Charger des cartes dans l'arborescence des couches"
-#, fuzzy
-#~ msgid "Load map layers into workspace (Ctrl+L)"
-#~ msgstr "Charger des cartes dans l'espace de travail"
-#~ msgid "Load map layers"
-#~ msgstr "Charger des cartes"
-#~ msgid "General settings"
-#~ msgstr "Paramètres généraux"
-#, fuzzy
-#~ msgid "Show help page"
-#, fuzzy
-#~ msgid "Select maps to display"
-#~ msgstr "Démarrer un nouvel écran"
-#~ msgid "Delete GCP"
-#~ msgstr "Effacer des PCS"
-#~ msgid "RMS Error"
-#~ msgstr "Erreur RMS"
-#, fuzzy
-#~ msgid "Map toolbar"
-#~ msgstr "Barre d'outils pour les cartes"
-#, fuzzy
-#~ msgid "Generates stream channels."
-#~ msgstr "Creuser des chenaux d'écoulement"
-#, fuzzy
-#~ msgid "Creates watershed basins."
-#~ msgstr "Sous-bassins versants"
-#, fuzzy
-#~ msgid "Reclassify raster map based on category values."
-#~ msgstr "Reclassifier une carte 'raster' selon des règles"
-#~ msgid "Attribute management is available only for vector maps."
-#~ msgstr "La gestion des attributs est seulement disponible pour les cartes vectorielles"
-#~ msgid "Display zoom management"
-#~ msgstr "Gestion des zooms"
-#~ msgid "Add thematic layer"
-#~ msgstr "Ajouter une couche thématique"
-#~ msgid "Settings dialog for digitization tool"
-#~ msgstr "Paramètres pour l'outil de digitalisation "
-#~ msgid "Select color"
-#~ msgstr "Choisir une couleur"
-#~ msgid "Aggregate ASCII xyz import"
-#~ msgstr "Importer des données ASCII xyz"
-#, fuzzy
-#~ msgid "Multiple export formats using OGR"
-#~ msgstr "Importer de multiples donénes vectorielles en utilisant OGR"
-#~ msgid "Add attributes"
-#~ msgstr "Ajouter des attributs"
-#, fuzzy
-#~ msgid "Digitize new area"
-#~ msgstr "Digitaliser une nouvelle ligne"
-#~ msgid "Zoom to map"
-#~ msgstr "Zomme sur la carte"
-#, fuzzy
-#~ msgid "Zoom to displayed map"
-#~ msgstr "Zoomer sur la carte sélectionnée"
-#, fuzzy
-#~ msgid "Show Help"
-#~ msgid "Location wizard"
-#~ msgstr "Aide à la localisation"
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr "Importer un fichier 'raster' supporté par GDAL dans une carte 'raster' binaire"
-#, fuzzy
-#~ msgid "Bulk import of raster data"
-#~ msgstr "Importer une couche &matricielle"
-#, fuzzy
-#~ msgid "Converts multiple GDAL supported layers to GRASS raster maps."
-#~ msgstr "Convertir des couches GDAL sélectionnées en 'raster' GRASS au moyen de r.in.gdal"
-#, fuzzy
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#, fuzzy
-#~ msgid "Link multiple GDAL supported raster maps as pseudo GRASS raster map layers."
-#, fuzzy
-#~ msgid "Bulk import of vector data"
-#~ msgstr "Importer une couche &vectorielle"
-#, fuzzy
-#~ msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr"
-#~ msgstr "Convertit les couches OGR sélectionées en cartes vectorielles GRASS en utilisant v.in.ogr."
-#, fuzzy
-#~ msgid "Creates multiple new pseduo-vector maps as a read-only links using OGR."
-#~ msgstr "Crée un carte vectorielle depuis un fichier de points ASCII ou un fichier vecteur ASCII."
-#, fuzzy
-#~ msgid "Converts multiple DXF layers to GRASS vector maps."
-#, fuzzy
-#~ msgid "Georectify raster and vector maps"
-#~ msgstr "Interroge une (des) carte(s) 'raster' ou vectorielle(s)"
-#~ msgid "Reclassify interactively"
-#~ msgstr "Reclasser de façon interactive"
-#~ msgid "Reclassify using rules file"
-#~ msgstr "Reclasser en utilisant un fichier de règles"
-#~ msgid "Recode using rules file"
-#~ msgstr "Re-codage en utilisant un fichier de rôle"
-#, fuzzy
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "Importe des cartes vectorielles au format d'anciennes versions de GRASS."
-#, fuzzy
-#~ msgid "Set colors interactively by entering color rules"
-#~ msgstr "Créer une nouvelle table de couleur en utilisant des règles de coloriage"
-#~ msgid "Reclassify objects interactively"
-#~ msgstr "Classification interactive d'objets"
-#, fuzzy
-#~ msgid "Reclassify objects using rules file"
-#~ msgstr "Reclassifier une carte vectorielle en utilisant des requêts SQL"
-#, fuzzy
-#~ msgid "GRASS GIS Map Display: 1"
-#~ msgstr "SIG GRASS - Moniteur d'affichage des cartes"
-#~ msgid "Select image/map to display for ground control point (GCP) creation"
-#~ msgstr "Sélectionner une image ou une carte à afficher pour la création des points de contrôle au sol (PCS)"
-#~ msgid "Select display image/map:"
-#~ msgstr "Sélectionner l'image ou la carte à afficher :"
-#~ msgid "You must select a valid image/map in order to continue"
-#~ msgstr "Vous devez choisir une image ou une carte valide pour pouvoir continuer"
-#, fuzzy
-#~ msgid "Define/manage ground control points"
-#~ msgstr "Créer et gérer les points de contrôle au sol"
-#~ msgid "Ground Control Points"
-#~ msgstr "Points de Contrôle au Sol"
-#~ msgid "POINTS file <%s> saved"
-#~ msgstr "Fichier POINTS <%s> sauvé"
-#~ msgid "POINTS file saved"
-#~ msgstr "Fichier POINTS sauvé"
-#~ msgid "Georectifier settings"
-#~ msgstr "Paramètres de géo-rectification"
-#~ msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
-#~ msgstr "Erreur RMS pour les points sélectionnés avant : %(fwd)s arrière : %(bkw)s"
-#~ msgid "use| X coord"
-#~ msgstr "Utiliser| coord X"
-#~ msgid "Y coord"
-#~ msgstr "Coord Y"
-#~ msgid "E coord"
-#~ msgstr "Coord E"
-#~ msgid "N coord"
-#~ msgstr "Coord N"
-#~ msgid "Ground Control Point"
-#~ msgstr "Point de contrôle au sol"
-#~ msgid "Georectifier settings saved to file '%s'."
-#~ msgstr "Paramètres de géo-rectification sauvés dans le fichier '%s'."
-#~ msgid "Enter rules"
-#~ msgstr "Entrer les règles"
-#~ msgid "Create new color table using color rules"
-#~ msgid "Raster map:"
-#~ msgstr "Carte 'raster' :"
-#~ msgid "Enter color rules"
-#~ msgstr "Entrer les règles de coloriage"
-#~ msgid "Raster map to reclassify:"
-#~ msgstr "Carte 'raster' à reclassifier"
-#~ msgid "Reclassified raster map:"
-#~ msgstr "Carte 'raster' reclassifiée :"
-#~ msgid "Enter reclassification rules"
-#~ msgstr "Entrer les règles de reclassification"
-#~ msgid "Recode raster map using rules"
-#~ msgstr "Recoder une carte 'raster' en utilisant des règles"
-#~ msgid "Raster map to recode:"
-#~ msgstr "Carte 'raster' à recoder :"
-#~ msgid "Recoded raster map:"
-#~ msgstr "Carte 'raster' recodée :"
-#~ msgid "Enter recoding rules"
-#~ msgstr "Entrer les règles de recodification"
-#~ msgid "Reclassify vector map using SQL rules"
-#~ msgid "Vector map to reclassify:"
-#~ msgstr "Carte vectorielle à reclassifier :"
-#~ msgid "Reclassified vector map:"
-#~ msgstr "Carte vectorielle reclassifiée :"
-#~ msgid "overwrite existing file"
-#~ msgstr "écraser le fichier existant"
-#~ msgid "Map layers for each display"
-#~ msgstr "Couches pour chaque écran"
-#~ msgid "Unable to read workspace file"
-#~ msgstr "Incapable de lire le fichier d'environnement"
-#, fuzzy
-#~ msgid "GRASS GIS Raster Map Calculator (3D raster)"
-#~ msgstr "&Calculateur de couche"
-#~ msgid "Redraw GCP markers in map displays"
-#~ msgstr "Redessiner les points PCS sur la carte"
-#, fuzzy
-#~ msgid "Save workspace to open file"
-#~ msgstr "Sauver l'espace de travail courant"
-#, fuzzy
-#~ msgid "Close loaded workspace"
-#~ msgstr "Fermer l'espace de travail courant"
-#~ msgid "MAT-File (v.4) import"
-#~ msgstr "Imoorter un MAT-File (v.4)"
-#, fuzzy
-#~ msgid "MAT-File (v.4) export"
-#~ msgid "E&xit"
-#~ msgstr "&Quitter"
-#~ msgid "Set ground control points (GCPs)"
-#~ msgid "Map calculator"
-#~ msgid "Restore default settings"
-#~ msgstr "Restaurer les paramètres par défaut"
-#, fuzzy
-#~ msgid "DXF file:"
-#~ msgstr "Choisir le fichier DXF :"
-#~ msgid "Input DXF file"
-#~ msgstr "Fichier DXF en entrée"
-#~ msgid ""
-#~ "File <%(file)s>: Unable to get list of DXF layers.\n"
-#~ "\n"
-#~ "%(details)s"
-#~ msgstr ""
-#~ "Fichier <%(file)s> : Impossible de charger la liste des couches DXF.\n"
-#~ "\n"
-#~ "%(details)s"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to start vector digitizer.\n"
-#~ "The VDigit python extension was not found or loaded properly.\n"
-#~ "Switching back to 2D display mode.\n"
-#~ "\n"
-#~ "Details: %s"
-#~ msgstr ""
-#~ "Impossible de démarrer Nviz. L'extension Python pour Nviz n'a pas été trouvée ou chargée correctement. Retour au mode d'affichage 2D.\n"
-#~ "\n"
-#~ "Détails : %s"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to switch to 3D display mode.\n"
-#~ "The GLCanvas class has not been included with this build of wxPython!\n"
-#~ "\n"
-#~ "Details: %s"
-#~ msgstr ""
-#~ "Impossible de démarrer Nviz. La classe GLCanvas n'a pas été incluse dans cette compilation de wxPython! Retour au mode d'affichage 2D.\n"
-#~ "\n"
-#~ "Détails : %s"
-#~ msgid "Twist"
-#~ msgstr "Basculer :"
-#~ msgid "Z-exag"
-#~ msgstr "Exagération verticale :"
-#~ msgid "Multiple raster data import using GDAL"
-#~ msgstr "Importer de multiples données 'raster' en utilisant GDAL"
-#, fuzzy
-#~ msgid "Multiple link to GDAL"
-#~ msgstr "Importation multiple"
-#~ msgid "Import vector data using OGR"
-#~ msgstr "Importer des données vectorielles en utilisant OGR"
-#~ msgid "Multiple vector data import using OGR"
-#~ msgid "Link to OGR"
-#~ msgstr "Lien vers OGR"
-#, fuzzy
-#~ msgid "Multiple link to OGR"
-#~ msgid "Multiple DXF layers import"
-#~ msgstr "Importer de multiples couches DXF"
-#~ msgid "Import grid 3D volume"
-#~ msgstr "Importer un volume grid&3D"
-#, fuzzy
-#~ msgid "Multiple export formats using GDAL"
-#~ msgid "Export grid 3D volume"
-#~ msgstr "Exporter un volume gri&d3D"
-#~ msgid "Import GDAL layers"
-#~ msgstr "Importer des couches GDAL"
-#, fuzzy
-#~ msgid "Link GDAL layers"
-#~ msgid "Import OGR layers"
-#~ msgstr "Importer des couches OGR"
-#, fuzzy
-#~ msgid "Link OGR layers"
-#, fuzzy
-#~ msgid "Command %s could not be run"
-#~ msgstr "Commande '%s' pas encore implémentée"
-#~ msgid "Command '%s' not yet implemented."
-#, fuzzy
-#~ msgid "&Close"
-#~ msgstr "Code"
-#~ msgid " (those in bold typeface are required)"
-#~ msgstr "(ceux qui sont en caractères gras sont obligatoires)"
-#, fuzzy
-#~ msgid "It assumes a cartesian coordinate system"
-#~ msgstr "Choisir le système de coordonnées"
-#, fuzzy
-#~ msgid "Digitize raster map"
-#~ msgstr "Ajouter une carte 3D (raster)"
-#, fuzzy
-#~ msgid "Reclassify vector objects interactively by entering SQL rules"
-#, fuzzy
-#~ msgid "Ortho Photo rectification"
-#~ msgstr "Setup pour la géo-rectification"
-#~ msgid "Use coordinate system of selected georeferenced file"
-#~ msgstr "Utiliser le système de coordonnées du fichier géo-référencé sélectionné"
-#~ msgid "Use coordinate system of selected WKT or PRJ file"
-#~ msgstr "Utiliser le système de coordonnées du fichier WKT ou PRJ sélectionné"
-#~ msgid "Create custom PROJ.4 parameters string for coordinate system"
-#~ msgstr "Créer une chaîne de paramètres PROJ.4 particuliers pour le système de coordonnées"
-#~ msgid "Select ellipsoid"
-#~ msgstr "Choisir l'ellipsoïde"
-#~ msgid "Set zone for UTM projection:"
-#~ msgstr "Définir la zone pour la projection UTM"
-#~ msgid "Zone:"
-#~ msgstr "Zone :"
-#~ msgid "Hemisphere for zone:"
-#~ msgstr "Hémisphère pour la zone :"
-#~ msgid "Datum"
-#~ msgstr "Données"
-#~ msgid "Transformation parameters:"
-#~ msgstr "Paramètres de transformation :"
-#~ msgid "Browse EPSG Codes"
-#~ msgstr "Passer en revue les codes EPSG"
-#~ msgid "Datums:"
-#~ msgstr "Données : "
-#~ msgid ""
-#~ "Unable to start Nviz. The OpenGL package was not found. You can get it at http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.\n"
-#~ "\n"
-#~ "Details: %s"
-#~ msgstr ""
-#~ "Impossible de démarrer Nviz. Le package OpenGL n'a pas été trouvé. Vous pouvez le trouver sur http://PyOpenGL.sourceforge.net. Retour au mode d'affichage 2D.\n"
-#~ "\n"
-#~ "Détails : %s"
-#~ msgid "Add overlay"
-#~ msgstr "Ajouter une couche"
-#~ msgid "Add graphic overlays to map"
-#~ msgstr "Ajouter une couche graphique à la carte"
-#~ msgid "New workspace"
-#~ msgstr "Nouvel espace de travail"
-#~ msgid "Open existing workspace"
-#~ msgstr "Ouvrir un espace de travail existant"
-#~ msgid "Load map layers from GRC file to layer tree (not fully implemented)"
-#~ msgstr "Charger des cartes depuis un fichier GRC dans l'arborescence des couches (pas totalement implémenté)"
-#~ msgid "Save workspace as"
-#~ msgstr "Sauver l'espace de travail sous"
-#~ msgid "Save current workspace as file"
-#~ msgstr "Sauver l'espace de travail courant dans un fichier"
-#~ msgid "Close current workspace file"
-#~ msgid "All"
-#~ msgstr "Tout"
-#, fuzzy
-#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
-#~ msgstr "Importer des fichiers SRTM HGT dans GRASS"
-#, fuzzy
-#~ msgid "Exports a GRASS raster to a binary array."
-#~ msgstr "Convertit un fichier 'raster' ASCII en une carte 'raster' binaire"
-#, fuzzy
-#~ msgid "Converts a vector map to any of the supported OGR vector formats."
-#~ msgstr "Convertit des fichiers DXF en carte vectorielle GRASS."
-#, fuzzy
-#~ msgid "Creates a mask for limiting raster operation."
-#~ msgstr ""
-#~ "Créer un nouveau jeu de cartes\n"
-#~ "dans la localisation choisie"
-#, fuzzy
-#~ msgid "Watershed basin analysis program"
-#~ msgstr "Analyse de bassin versant"
-#~ msgid "Quit GRASS GIS"
-#~ msgstr "Quitter le SIG GRASS"
-#, fuzzy
-#~ msgid ""
-#~ "Reading workspace file <%(file)s> failed.\n"
-#~ "Invalid file, unable to parse XML document.\n"
-#~ "\n"
-#~ "%(err)s"
-#~ msgstr "Lecture du fichier d'environnement <%s> impossible. Fichier invalide, incapable de déchiffrer le document XML"
-#~ msgid "Import raster map"
-#~ msgstr "Importer une carte raster"
-#~ msgid "Import vector map"
-#~ msgstr "Importer une carte vecteur"
-#, fuzzy
-#~ msgid "3D Raster map"
-#~ msgstr "Carte raster 3D"
-#~ msgid "module"
-#~ msgstr "module"
-#~ msgid "Unable to get list of available mapsets."
-#~ msgstr "Impossible d'obtenir la liste des jeux de cartes existants."
-#~ msgid "Unable to get list of accessible mapsets."
-#~ msgstr "Impossible d'obtenir la liste des jeux de cartes accessibles."
-#~ msgid "Run"
-#~ msgstr "&Exécuter"
-#, fuzzy
-#~ msgid "Saved NVIZ Settings"
-#~ msgstr "Sauver les paramètres courants ?"
-#, fuzzy
-#~ msgid "Creates a lines vector map from an ASCII x,y points file."
-#~ msgstr "Crée des lignes vectorielles depuis un fichier de points ASCII x,y."
-#~ msgid "Create new workspace file (erase current workspace settings first)"
-#~ msgstr "Créer un nouvel espace de travail (efface d'abord les paramètres de l'espace en cours)"
-#~ msgid "Unable to open workspace file <%s> for writing."
-#~ msgstr "Impossible d'ouvrir le fichier d'environnement <%s> en écriture."
-#~ msgid "Create new workspace file"
-#~ msgstr "Créer un nouvel espace de travail"
-#~ msgid "Load map layers into workspace"
-#~ msgid "Open existing workspace file"
-#~ msgstr "Ouvrir un fichier espace de travail existant"
-#~ msgid "Save current workspace to file"
-#~ msgid "Downloads and imports data from WMS servers."
-#~ msgstr "Téklécharge et importe des données depuis un serveur WMS."
-#~ msgid "Close this window without executing the command"
-#~ msgstr "Fermer cette fenêtre sans exécuter la commande"
-#~ msgid "Show manual page of the command"
-#~ msgstr "Afficher la page de manuel pour la commande"
-#~ msgid "Run the command"
-#~ msgstr "Exécuter la commande"
-#~ msgid "Reading workspace file <%s> failed. Invalid file, unable to parse XML document."
-#~ msgid "Writing current settings to workspace file failed (%s)."
-#~ msgstr "Ecriture des paramètres courant dans le fichier d'environnement (%s) non réussie."
-#, fuzzy
-#~ msgid "Add various vector-based map layer"
-#~ msgstr "Ajouter une couche vectorielle"
-#~ msgid "Force re-rendering of all layers"
-#~ msgstr "Force la regénération de toutes les couches"
-#~ msgid "Add layer group"
-#~ msgstr "Ajouter un groupe"
-#~ msgid "Delete selected layer"
-#~ msgstr "Effacer la couche sélectionnée"
-#~ msgid "Add RGB layer"
-#~ msgstr "Ajouter une couche RVB"
-#~ msgid "Add HIS layer"
-#~ msgstr "Ajouter une couche TIS"
-#~ msgid "Reload GCPs from selected POINTS file"
-#~ msgstr "Recharger les PCS depuis un fichier Points"
-#~ msgid "Show Nviz settings dialog"
-#~ msgstr "Afficher la boîte de dialogue des paramètres NVIZ"
-#~ msgid "Matlab-ASCII or Mapgen import"
-#~ msgstr "Importer depuis Matlab-ASCII ou Mapgen"
-#, fuzzy
-#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-#~ msgstr "Importer dans GRASS des fichiers vectoriels Mapgen ou Matlab-ASCII."
-#, fuzzy
-#~ msgid "Raster"
-#~ msgstr "Carte raster"
-#~ msgid "Nviz toolbar"
-#~ msgstr "Barre d'outils NVIZ"
-#~ msgid "3D View Tools"
-#~ msgstr "Outils de vue 3D"
-#~ msgid "coarse:"
-#~ msgstr "grossier :"
-#~ msgid "fine:"
-#~ msgstr "fin :"
-#~ msgid "Icon size:"
-#~ msgstr "Taille de l'icône"
-#~ msgid "Layer properties"
-#~ msgstr " Propriétés de la couche"
-#~ msgid "%(primitives)d primitives (%(points)d points)"
-#~ msgstr "%(primitives)d primitives (%(points)d points)"
-#~ msgid "Parameter not found: %s"
-#~ msgstr "Paramètre non trouvé : %s"
-#~ msgid "Parameter %(name)s (%(desc)s) is missing.\n"
-#~ msgstr "Le paramètre %(name)s (%(desc)s) est manquant.\n"
-#~ msgid "Copy the current command string to the clipboard"
-#~ msgstr "Copier la chaîne de commande dans le presse-papier"
-#~ msgid "Create mapset"
-#~ msgstr "Créer un jeu de cartes"
-#~ msgid "Select file extension:"
-#~ msgstr "Choisir l'extension du fichier :"
-#, fuzzy
-#~ msgid "Add multiple raster or vector map layers (Ctrl+L)"
-#~ msgstr "Ajouter une couche 'raster'"
-#, fuzzy
-#~ msgid "Add raster map layer (Ctrl+R)"
-#, fuzzy
-#~ msgid "Add vector map layer (Ctrl+V)"
-#~ msgid "No vector map selected for querying."
-#~ msgstr "Aucune carte vecteur sélectionnée pour l'interrogation."
-#~ msgid "Unable to save settings."
-#~ msgstr "Impossible d'enregistrer les paramètres."
-#, fuzzy
-#~ msgid "GRASS GIS Hardcopy Map Output Utility"
-#~ msgstr "SIG GRASS - Utilitaire d'export de cartes"
-#~ msgid "&Abort command"
-#~ msgid "Name for GRASS map"
-#~ msgstr "Nom de la carte GRASS"
-#~ msgid "GRASS GIS Layer Manager (Experimental Prototype)"
-#~ msgstr "Gestionnaire de couches d'information GRASS GIS (prototype expérimental)"
-#, fuzzy
-#~ msgid "Copying attributes..."
-#~ msgstr "Afficher les attributs"
-#~ msgid "Vector map <%s> is 2D"
-#~ msgstr "La carte vecteur <%s> est en 2D"
-#~ msgid "properties"
-#~ msgstr "propriétés"
