[GRASS-SVN] r54533 - in grass/trunk/raster: r.cost r.walk
svn_grass at osgeo.org
Sat Jan 5 06:04:56 PST 2013
Author: martinl
Date: 2013-01-05 06:04:55 -0800 (Sat, 05 Jan 2013)
New Revision: 54533
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.walk/main.c
grass/trunk/raster/r.walk/r.walk.html
r.walk/r.cost: sync parameters
update manual pages
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2013-01-05 12:26:48 UTC (rev 54532)
+++ grass/trunk/raster/r.cost/main.c 2013-01-05 14:04:55 UTC (rev 54533)
@@ -146,7 +146,7 @@
opt2 = G_define_standard_option(G_OPT_R_INPUT);
opt2->description =
- _("Name of raster map containing grid cell cost information");
+ _("Name of input raster map containing grid cell cost information");
opt1 = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -154,15 +154,13 @@
opt12->key = "nearest";
opt12->required = NO;
opt12->description =
- _("Name of output raster map with nearest start point");
+ _("Name for output raster map with nearest start point");
- opt11 = G_define_option();
+ opt11 = G_define_standard_option(G_OPT_R_OUTPUT);
opt11->key = "outdir";
- opt11->type = TYPE_STRING;
opt11->required = NO;
- opt11->gisprompt = "new,cell,raster";
opt11->description =
- _("Name of output raster map to contain movement directions");
+ _("Name for output raster map to contain movement directions");
opt7 = G_define_standard_option(G_OPT_V_INPUT);
opt7->key = "start_points";
@@ -173,7 +171,7 @@
opt8 = G_define_standard_option(G_OPT_V_INPUT);
opt8->key = "stop_points";
opt8->required = NO;
- opt8->label = _("Name of stop vector points map");
+ opt8->label = _("Name of stopping vector points map");
opt8->guisection = _("Stop");
opt9 = G_define_standard_option(G_OPT_R_INPUT);
@@ -182,22 +180,18 @@
opt9->description = _("Name of starting raster points map");
opt9->guisection = _("Start");
- opt3 = G_define_option();
- opt3->key = "coordinate";
- opt3->type = TYPE_STRING;
- opt3->key_desc = "x,y";
+ opt3 = G_define_standard_option(G_OPT_M_COORDS);
+ opt3->key = "start_coordinate";
opt3->multiple = YES;
opt3->description =
- _("Map grid coordinates of a starting point (E,N)");
+ _("Coordinates of starting point(s) (E,N)");
opt3->guisection = _("Start");
- opt4 = G_define_option();
+ opt4 = G_define_standard_option(G_OPT_M_COORDS);
opt4->key = "stop_coordinate";
- opt4->type = TYPE_STRING;
- opt4->key_desc = "x,y";
opt4->multiple = YES;
opt4->description =
- _("Map grid coordinates of a stopping point (E,N)");
+ _("Coordinates of stopping point(s) (E,N)");
opt4->guisection = _("Stop");
opt5 = G_define_option();
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2013-01-05 12:26:48 UTC (rev 54532)
+++ grass/trunk/raster/r.cost/r.cost.html 2013-01-05 14:04:55 UTC (rev 54533)
@@ -25,17 +25,17 @@
<p><em>r.cost</em> can be run with three different methods of identifying the
starting point(s). One or more points (geographic coordinate pairs) can be
-provided as specified <b>coordinate</b>s on the command line, from a vector
+provided as specified <b>start_coordinate</b> on the command line, from a vector
points file, or from a raster map.
All non-NULL cells are considered to be starting points.
-Each <em>x,y</em> <b>coordinate</b> pair gives the geographic location of a
+Each <em>x,y</em> <b>start_coordinate</b> pair gives the geographic location of a
point from which the transportation cost should be figured. As many points as
desired can be entered by the user. These starting points can also be read
from a vector points file through the <b>start_points</b> option or from a
raster map through the <b>start_rast</b> option.
<p><em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
-or one of the stop points given with <b>stop_coordinates</b> is reached.
+or one of the stop points given with <b>stop_coordinate</b> is reached.
Alternatively, the stop points can be read from a vector points file with the
<b>stop_points</b> option. During execution, once the cumulative cost to all
stopping points has been determined, processing stops.
@@ -53,7 +53,7 @@
retained as null cells in the output map.
<p>As <em>r.cost</em> can run for a very long time, it can be useful to
-use the <b>-v</b> verbose flag to track progress.
+use the <b>--v</b> verbose flag to track progress.
<p>The Knight's move (<b>-k</b> flag) may be used to improve the accuracy of
the output. In the diagram below, the center location (<tt>O</tt>) represents a
@@ -226,7 +226,7 @@
<h2>Movement Direction</h2>
<p>The movement direction surface is created to record the sequence of
movements that created the cost accumulation surface. Without it
-<em>r.drain</em> would not correctly create a path from an end point
+<em><a href="r.drain.html">r.drain</a></em> would not correctly create a path from an end point
back to the start point. The direction of each cell points towards
the next cell. The directions are recorded as degrees CCW from East:
<div class="code"><pre>
@@ -238,31 +238,26 @@
</pre></div>
<p>
-Once <em>r.cost</em> computes the cumulative cost map, <em>r.drain</em>
+Once <em>r.cost</em> computes the cumulative cost map, <em><a href="r.drain.html">r.drain</a></em>
can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
and the movement direction raster map when running r.drain to ensure
the path is computed according to the proper movement directions.
<h2>SEE ALSO</h2>
-<em><a href="r.drain.html">r.drain</a></em>,
-<em><a href="r.walk.html">r.walk</a></em>,
-<em><a href="r.in.ascii.html">r.in.ascii</a></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.out.ascii.html">r.out.ascii</a></em>
+<em>
+<a href="r.drain.html">r.drain</a>,
+<a href="r.walk.html">r.walk</a>,
+<a href="r.in.ascii.html">r.in.ascii</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.out.ascii.html">r.out.ascii</a>
+</em>
<h2>AUTHOR</h2>
-Antony Awaida,<br>
-Intelligent Engineering<br>
-Systems Laboratory,<br>
-M.I.T.<br>
-<br>
-James Westervelt,<br>
-U.S.Army Construction Engineering Research Laboratory
+Antony Awaida, Intelligent Engineering Systems Laboratory, M.I.T.<br>
+James Westervelt, U.S.Army Construction Engineering Research Laboratory<br>
+Updated for Grass 5 by Pierre de Mouveaux (pmx at audiovu.com)
-<p>Updated for Grass 5<br>
-Pierre de Mouveaux (pmx at audiovu.com)
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2013-01-05 12:26:48 UTC (rev 54532)
+++ grass/trunk/raster/r.walk/main.c 2013-01-05 14:04:55 UTC (rev 54533)
@@ -179,75 +179,62 @@
G_add_keyword(_("raster"));
G_add_keyword(_("cost surface"));
G_add_keyword(_("cumulative costs"));
- module->description =
- _("Outputs a raster map layer showing the "
- "anisotropic cumulative cost of moving between different "
+ module->label =
+ _("Outputs a raster map showing the "
+ "anisotropic cumulative cost.");
+ module->description = _("Computes anisotropic cumulative cost of moving between different "
"geographic locations on an input elevation raster map "
- "layer whose cell category values represent elevation "
+ "whose cell category values represent elevation "
"combined with an input raster map layer whose cell "
"values represent friction cost.");
- opt12 = G_define_standard_option(G_OPT_R_INPUT);
- opt12->key = "elevation";
- opt12->required = YES;
- opt12->description = _("Name of elevation input raster map");
+ opt12 = G_define_standard_option(G_OPT_R_ELEV);
opt2->key = "friction";
- opt2->required = YES;
opt2->description =
_("Name of input raster map containing friction costs");
- opt1->required = YES;
- opt1->label = _("output map with walking costs");
- opt1->description = _("Name of output raster map to contain walking costs");
+ opt1->description = _("Name for output raster map to contain walking costs");
- opt7 = G_define_option();
+ opt7 = G_define_standard_option(G_OPT_V_INPUT);
- opt7->type = TYPE_STRING;
- opt7->gisprompt = "old,vector,vector";
opt7->required = NO;
- opt7->description = _("Starting points vector map");
+ opt7->label = _("Name of starting vector points map");
+ opt7->guisection = _("Start");
- opt8 = G_define_option();
+ opt8 = G_define_standard_option(G_OPT_V_INPUT);
- opt8->type = TYPE_STRING;
- opt8->gisprompt = "old,vector,vector";
- opt8->description = _("Stop points vector map");
+ opt8->guisection = _("Stop");
- opt9 = G_define_option();
+ opt9 = G_define_standard_option(G_OPT_R_INPUT);
opt9->key = "start_rast";
- opt9->type = TYPE_STRING;
opt9->required = NO;
- opt9->gisprompt = "old,cell,raster";
- opt9->description =
- _("Starting points raster map");
+ opt9->description = _("Name of starting raster points map");
+ opt9->guisection = _("Start");
opt3->description =
- _("The map E and N grid coordinates of a starting point (E,N)");
+ opt3->guisection = _("Start");
opt4->description =
- _("The map E and N grid coordinates of a stopping point (E,N)");
+ opt4->guisection = _("Stop");
opt5->key = "max_cost";
@@ -255,7 +242,7 @@
opt5->required = NO;
opt5->multiple = NO;
opt5->answer = "0";
- opt5->description = _("An optional maximum cumulative cost");
+ opt5->description = _("Maximum cumulative cost");
opt6 = G_define_option();
opt6->key = "null_cost";
Modified: grass/trunk/raster/r.walk/r.walk.html
--- grass/trunk/raster/r.walk/r.walk.html 2013-01-05 12:26:48 UTC (rev 54532)
+++ grass/trunk/raster/r.walk/r.walk.html 2013-01-05 14:04:55 UTC (rev 54533)
@@ -1,32 +1,42 @@
<h2>DESCRIPTION</h2>
-<em>r.walk</em> outputs 1) a raster map layer showing the lowest
+<em>r.walk</em> outputs 1) a raster map showing the lowest
cumulative cost of moving between each cell and the user-specified
-starting points and 2) a second raster map layer showing the movement
+starting points and 2) a second raster map showing the movement
direction to the next cell on the path back to the start point (see
<a href="#move">Movement Direction</a>). It uses an input elevation
-raster map layer whose cell category values represent elevation,
-combined with a second input raster map layer whose cell values
+raster map whose cell category values represent elevation,
+combined with a second input raster map whose cell values
represent friction costs.
-This function is similar to <em>r.cost</em>, but in addiction to a
-friction map, it considers an anisotropic travel time due to the
-different walking speed associated with downhill and uphill movements.
<p>
+This function is similar to <em><a href="r.cost.html">r.cost</a></em>,
+but in addiction to a friction map, it considers an anisotropic travel
+time due to the different walking speed associated with downhill and
+uphill movements.
+<h2>NOTES</h2>
+<p>
The formula from Aitken 1977/Langmuir 1984 (based on Naismith's rule
for walking times) has been used to estimate the cost parameters of
specific slope intervals:
-<p>T= [(a)*(Delta S)] + [(b)*(Delta H uphill)] + [(c)*(Delta H moderate downhill)] + [(d)*(Delta H steep downhill)]
-<p>where:<br>
-T is time of movement in seconds,<br>
-Delta S is the distance covered in meters,<br>
-Delta H is the altitude difference in meter.
-<p>
+<div class="code"><pre>
+T= [(a)*(Delta S)] + [(b)*(Delta H uphill)] + [(c)*(Delta H moderate downhill)] + [(d)*(Delta H steep downhill)]
+</pre></div>
-The a, b, c, d parameters take in account movement speed in the different
-conditions and are linked to:
+where:
+<ul>
+ <li><tt>T</tt> is time of movement in seconds,</li>
+ <li><tt>Delta S</tt> is the distance covered in meters,</li>
+ <li><tt>Delta H</tt> is the altitude difference in meter.</li>
+</ul>
+<p>
+The a, b, c, d <b>walk_coeff</b> parameters take in account
+movement speed in the different conditions and are linked to:
<ul>
<li>a: underfoot condition (a=1/walking_speed)</li>
<li>b: underfoot condition and cost associated to movement uphill</li>
@@ -36,16 +46,18 @@
It has been proved that moving downhill is favourable up to a specific
slope value threshold, after that it becomes unfavourable. The default
-slope value threshold (slope factor) is -0.2125, corresponding to
-tan(-12), calibrated on human behaviour (>5 and <12
-degrees: moderate downhill; >12 degrees: steep downhill). The
-default values for a, b, c, d are those proposed by Langmuir (0.72, 6.0,
-1.9998, -1.9998), based on man walking effort in standard
-conditions.<p>
-The lambda parameter of the linear equation combining movement and
-friction costs:<br>
+slope value threshold (<b>slope_factor</b>) is -0.2125, corresponding
+to tan(-12), calibrated on human behaviour (>5 and <12 degrees:
+moderate downhill; >12 degrees: steep downhill). The default values
+for a, b, c, d <b>walk_coeff</b> parameters are those proposed by
+Langmuir (0.72, 6.0, 1.9998, -1.9998), based on man walking effort in
+standard conditions.
-total cost = movement time cost + (lambda) * friction costs<br>
+<p>The <b>lambda</b> parameter of the linear equation
+combining movement and friction costs:<br>
+total cost = movement time cost + (lambda) * friction costs
+</pre></div>
must be set in the option section of <em>r.walk</em>.
<p>
For a more accurate result, the "knight's move" option can be used
@@ -70,7 +82,7 @@
@@ -84,21 +96,14 @@
<p>
Once <em>r.walk</em> computes the cumulative cost map as a linear
combination of friction cost (from friction map) and the altitude and
-distance covered (from the digital elevation model), <em>r.drain</em>
-can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
-and the movement direction raster map when running r.drain to ensure
-the path is computed according to the proper movement directions.
+distance covered (from the digital elevation
+model), <em><a href="r.drain.html">r.drain</a></em> can be used to
+find the minimum cost path. Make sure to use the <b>-d</b> flag and
+the movement direction raster map when
+running <em><a href="r.drain.html">r.drain</a></em> to ensure the path
+is computed according to the proper movement directions.
-<h2>SEE ALSO</h2>
-<em><a href="r.cost.html">r.cost</a></em>,
<h2>REFERENCES</h2>
<ul>
@@ -112,29 +117,34 @@
Sports Council/MLTB. Cordee, Leicester.
</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.cost.html">r.cost</a>,
+</em>
<h2>AUTHORS</h2>
-<b>Based on r.cost written by :</b>
-<p>Antony Awaida,<br>
-M.I.T.<br>
-<br>
+<b>Based on r.cost written by :</b><br>
+Antony Awaida, Intelligent Engineering, Systems Laboratory, M.I.T.<br>
+<p><b>Initial version of r.walk:</b><br>
+Steno Fontanari, 2002
-<p><b>Initial version of r.walk:</b>
-<p>Steno Fontanari, 2002
-<p><b>Current version of r.walk:</b>
-<p>Franceschetti Simone, Sorrentino Diego, Mussi Fabiano and Pasolli Mattia<br>
+<p><b>Current version of r.walk:</b><br>
+Franceschetti Simone, Sorrentino Diego, Mussi Fabiano and Pasolli Mattia<br>
Correction by: Fontanari Steno, Napolitano Maurizio and Flor Roberto<br>
In collaboration with: Franchi Matteo, Vaglia Beatrice, Bartucca Luisa, Fava Valentina and Tolotti Mathias, 2004
-<p><b>Updated for Grass 6.1</b>
-<p>Roberto Flor and Markus Neteler
+<p><b>Updated for Grass 6.1:</b><br>
+Roberto Flor and Markus Neteler
+<p>
