[GRASS-SVN] r54537 - grass/trunk/raster/r.what
svn_grass at osgeo.org
Sat Jan 5 11:31:24 PST 2013
Author: martinl
Date: 2013-01-05 11:31:23 -0800 (Sat, 05 Jan 2013)
New Revision: 54537
grass/trunk/raster/r.what/Makefile
grass/trunk/raster/r.what/main.c
grass/trunk/raster/r.what/r.what.html
r.what: `points` option added (read coordinates from vector points map)
Modified: grass/trunk/raster/r.what/Makefile
--- grass/trunk/raster/r.what/Makefile 2013-01-05 18:20:05 UTC (rev 54536)
+++ grass/trunk/raster/r.what/Makefile 2013-01-05 19:31:23 UTC (rev 54537)
@@ -2,8 +2,10 @@
PGM = r.what
-LIBES = $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+LIBES = $(RASTERLIB) $(GISLIB) $(VECTORLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP) $(VECTORDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/raster/r.what/main.c
--- grass/trunk/raster/r.what/main.c 2013-01-05 18:20:05 UTC (rev 54536)
+++ grass/trunk/raster/r.what/main.c 2013-01-05 19:31:23 UTC (rev 54537)
@@ -6,8 +6,9 @@
* Markus Neteler <neteler itc.it>,Brad Douglas <rez touchofmadness.com>,
* Huidae Cho <grass4u gmail.com>, Glynn Clements <glynn gclements.plus.com>,
* Hamish Bowman <hamish_b yahoo.com>, Soeren Gebbert <soeren.gebbert gmx.de>
+ * Martin Landa <landa.martin gmail.com>
* PURPOSE:
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2006, 2012 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -20,8 +21,10 @@
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <grass/gis.h>
#include <grass/raster.h>
+#include <grass/vector.h>
#include <grass/glocale.h>
struct order
@@ -56,16 +59,18 @@
RASTER_MAP_TYPE out_type[NFILES];
CELL *cell[NFILES];
DCELL *dcell[NFILES];
+ struct Map_info Map;
+ struct line_pnts *Points;
/* int row, col; */
double drow, dcol;
int row_in_window, in_window;
double east, north;
- int line;
+ int line, ltype;
char buffer[1024];
char **ptr;
struct _opt {
- struct Option *input, *cache, *null, *coords, *fs;
+ struct Option *input, *cache, *null, *coords, *fs, *points;
} opt;
struct _flg {
struct Flag *label, *cache, *cat_int, *color, *header;
@@ -76,7 +81,6 @@
int point, point_cnt;
struct order *cache;
int cur_row;
- int projection;
int cache_hit = 0, cache_miss = 0;
int cache_hit_tot = 0, cache_miss_tot = 0;
int pass = 0;
@@ -101,7 +105,13 @@
opt.coords = G_define_standard_option(G_OPT_M_COORDS);
opt.coords->description = _("Coordinates for query");
- opt.coords->guisection = _("Required");
+ opt.coords->guisection = _("Query");
+ opt.points = G_define_standard_option(G_OPT_V_MAP);
+ opt.points->key = "points";
+ opt.points->label = _("Name of vector points map for query");
+ opt.points->required = NO;
+ opt.points->guisection = _("Query");
opt.null = G_define_option();
opt.null->key = "null";
@@ -151,29 +161,12 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
tty = isatty(0);
- projection = G_projection();
- /* see v.in.ascii for a better solution */
- if (opt.fs->answer != NULL) {
- if (strcmp(opt.fs->answer, "space") == 0)
- fs = ' ';
- else if (strcmp(opt.fs->answer, "tab") == 0 ||
- strcmp(opt.fs->answer, "\\t") == 0)
- fs = '\t';
- else if (strcmp(opt.fs->answer, "newline") == 0)
- fs = '\n';
- else if (strcmp(opt.fs->answer, "comma") == 0)
- fs = ',';
- else
- fs = opt.fs->answer[0];
+ fs = G_option_to_separator(opt.fs);
null_str = opt.null->answer;
if (tty)
Cache_size = 1;
else
@@ -184,19 +177,19 @@
cache = (struct order *)G_malloc(sizeof(struct order) * Cache_size);
- /*enable cache report */
+ /* enable cache report */
if (flg.cache->answer)
cache_report = TRUE;
+ /* open raster maps to query */
ptr = opt.input->answers;
nfiles = 0;
for (; *ptr != NULL; ptr++) {
char name[GNAME_MAX];
if (nfiles >= NFILES)
- G_fatal_error(_("can only do up to %d raster maps"),
- NFILES);
+ G_fatal_error(_("Can only do up to %d raster maps (%d given)"),
+ NFILES, nfiles);
strcpy(name, *ptr);
fd[nfiles] = Rast_open_old(name, "");
@@ -216,6 +209,7 @@
nfiles++;
+ /* allocate row buffers */
for (i = 0; i < nfiles; i++) {
if (flg.cat_int->answer)
out_type[i] = CELL_TYPE;
@@ -225,9 +219,16 @@
dcell[i] = Rast_allocate_d_buf();
+ /* open vector points map */
+ if (opt.points->answer) {
+ Vect_set_open_level(1); /* topology not required */
+ if (Vect_open_old(&Map, opt.points->answer, "") < 0)
+ G_fatal_error(_("Unable to open vector map <%s>"), opt.points->answer);
+ Points = Vect_new_line_struct();
G_get_window(&window);
+ /* print header row */
if(flg.header->answer) {
fprintf(stdout, "easting%cnorthing%csite_name", fs, fs);
@@ -248,7 +249,7 @@
line = 0;
- if (!opt.coords->answers && tty)
+ if (!opt.coords->answers && !opt.points->answers && tty)
fprintf(stderr, "enter points, \"end\" to quit\n");
j = 0;
@@ -260,57 +261,78 @@
cache_hit = cache_miss = 0;
- if (!opt.coords->answers && tty) {
+ if (!opt.coords->answers && !opt.points->answers && tty) {
fprintf(stderr, "\neast north [label] > ");
Cache_size = 1;
point_cnt = 0;
for (i = 0; i < Cache_size; i++) {
- if (!opt.coords->answers && fgets(buffer, 1000, stdin) == NULL)
+ fgets(buffer, 1000, stdin) == NULL)
done = TRUE;
else {
line++;
- if ((!opt.coords->answers &&
+ if ((!opt.coords->answers && !opt.points->answers &&
(strncmp(buffer, "end\n", 4) == 0 ||
strncmp(buffer, "exit\n", 5) == 0)) ||
- (opt.coords->answers && !opt.coords->answers[j]))
+ (opt.coords->answers && !opt.coords->answers[j])) {
done = TRUE;
else {
- *(cache[point_cnt].lab_buf) =
- *(cache[point_cnt].east_buf) =
- *(cache[point_cnt].north_buf) = 0;
- if (!opt.coords->answers)
- sscanf(buffer, "%s %s %[^\n]",
- cache[point_cnt].east_buf,
- cache[point_cnt].north_buf,
- cache[point_cnt].lab_buf);
- else {
- strcpy(cache[point_cnt].east_buf,
- opt.coords->answers[j++]);
- strcpy(cache[point_cnt].north_buf,
- if (*(cache[point_cnt].east_buf) == 0)
- continue; /* skip blank lines */
- if (*(cache[point_cnt].north_buf) == 0) {
- oops(line, buffer,
- "two coordinates (east north) required");
- continue;
- if (!G_scan_northing
- (cache[point_cnt].north_buf, &north, window.proj)
- || !G_scan_easting(cache[point_cnt].east_buf,
- &east, window.proj)) {
- oops(line, buffer, "invalid coordinate(s)");
- continue;
+ ltype = Vect_read_next_line(&Map, Points, NULL);
+ if (ltype == -1)
+ G_fatal_error(_("Unable to read vector map <%s>"), Vect_get_full_name(&Map));
+ else if (ltype == -2)
+ done = TRUE;
+ else if (!(ltype & GV_POINTS)) {
+ G_warning(_("Line %d is not point or centroid, skipped"), line);
+ continue;
+ else {
+ east = Points->x[0];
+ north = Points->y[0];
+ sprintf(cache[point_cnt].east_buf, "%f", east);
+ sprintf(cache[point_cnt].north_buf, "%f", north);
+ else {
+ *(cache[point_cnt].lab_buf) =
+ *(cache[point_cnt].east_buf) =
+ *(cache[point_cnt].north_buf) = 0;
+ if (!opt.coords->answers)
+ sscanf(buffer, "%s %s %[^\n]",
+ cache[point_cnt].east_buf,
+ cache[point_cnt].north_buf,
+ cache[point_cnt].lab_buf);
+ else {
+ strcpy(cache[point_cnt].east_buf,
+ opt.coords->answers[j++]);
+ strcpy(cache[point_cnt].north_buf,
+ if (*(cache[point_cnt].east_buf) == 0)
+ continue; /* skip blank lines */
+ if (*(cache[point_cnt].north_buf) == 0) {
+ oops(line, buffer,
+ "two coordinates (east north) required");
+ continue;
+ if (!G_scan_northing(cache[point_cnt].north_buf, &north, window.proj) ||
+ !G_scan_easting(cache[point_cnt].east_buf, &east, window.proj)) {
+ oops(line, buffer, "invalid coordinate(s)");
+ continue;
/* convert north, east to row and col */
drow = Rast_northing_to_row(north, &window);
dcol = Rast_easting_to_col(east, &window);
/* a special case.
* if north falls at southern edge, or east falls on eastern edge,
* the point will appear outside the window.
@@ -455,12 +477,18 @@
fprintf(stderr, "\n");
if (cache_report & !tty)
fprintf(stderr, "Total: Cache Hit: %6d Miss: %6d\n",
cache_hit_tot, cache_miss_tot);
+ /* close vector points map */
+ Vect_close(&Map);
+ Vect_destroy_line_struct(Points);
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.what/r.what.html
--- grass/trunk/raster/r.what/r.what.html 2013-01-05 18:20:05 UTC (rev 54536)
+++ grass/trunk/raster/r.what/r.what.html 2013-01-05 19:31:23 UTC (rev 54537)
@@ -6,9 +6,12 @@
eastings and northings); the user can also (optionally) associate a label
with each location.
-<p>The input coordinates can be entered directly on the command line, or
-redirected via <tt>stdin</tt> from an input text file, script, or piped from
-another program (like <em><a href="d.where.html">d.where</a></em>).
+<p>The input coordinates can be entered directly on the command line
+via <b>coordinates</b> paramater, or redirected via <tt>stdin</tt>
+from an input text file, script, or piped from another program
+(like <em><a href="v.out.ascii.html">v.out.ascii</a></em>). Coordinates
+can be given also as a vector points map (<b>points</b>).
<p>If none of the above input methods are used and the module is run from the
terminal prompt, the program will interactively query the user for point
locations and labels.
@@ -23,25 +26,28 @@
<h2>EXAMPLES</h2>
-<h3>Input from <tt>stdin</tt> on the command line</h3>
+<h3>Input coordinates given as an option</h3>
-Input coordinates may be given directly from <tt>stdin</tt>, for example:
-<br> (input data appears between the "<tt>EOF</tt>" markers)
+The module's <b>coordinates</b> parameter can be used to enter coordinate
+pairs directly. The maximum number of pairs will be limited by your system's
+maximum input line length (e.g. 4096 characters).
<div class="code"><pre>
-r.what map=soils,aspect << EOF
-635342.21 7654321.09 site 1
-653324.88 7563412.42 site 2
-EOF
+g.region rast=soils,aspect
+r.what map=soils,aspect coordinates=635342.21,7654321.09,653324.88,7563412.42
-635342.21|7654321.09|site 1|45|21
-653324.88|7563412.42|site 2|44|20
+635342.21|7654321.09|45|21
+653324.88|7563412.42|44|20
</pre></div>
+<h3>Input coordinates given as a vector points map</h3>
+Coordinates can be read from exising vector points map by
+specifing <b>points</b> option. Other features then points or
+centroids are ignored.
-echo "635342.21 7654321.09" | r.what map=soils,aspect
-635342.21|7654321.09|45|21
+r.what map=soils,aspect points=bugsites
</pre></div>
@@ -58,49 +64,42 @@
</pre></div>
+<h3>Input from standard input on the command line</h3>
-<h3>Input coordinates given as a module option</h3>
+Input coordinates may be given directly from standard input (<tt>stdin</tt>), for example
+(input data appears between the "<tt>EOF</tt>" markers):
-The module's <b>east_north</b> parameter can be used to enter coordinate
-pairs directly. The maximum number of pairs will be limited by your system's
-maximum input line length (e.g. 4096 characters).
-r.what map=soils,aspect coordinates=635342.21,7654321.09,653324.88,7563412.42
+r.what map=soils,aspect << EOF
+635342.21 7654321.09 site 1
+653324.88 7563412.42 site 2
+EOF
-653324.88|7563412.42|44|20
+635342.21|7654321.09|site 1|45|21
+653324.88|7563412.42|site 2|44|20
</pre></div>
-<h3>Input coordinates piped from another program</h3>
-The input coordinates may be "piped" from the <tt>stdout</tt> of another
-program.
-<!-- (d.where is still present in grass7, but not very useful in this context)
-For example:
-d.where | r.what map=soils,aspect
+echo "635342.21 7654321.09" | r.what map=soils,aspect
</pre></div>
-In the next example, vector point coordinates are piped from the
-<em>v.out.ascii</em> module. The standard UNIX program "<tt>tr</tt>" is
-used to convert the column separators in <em>v.out.ascii</em>'s output into
-spaces for <em>r.what</em>.
+<h3>Input coordinates piped from another program</h3>
+The input coordinates may be "piped" from the standard output
+(<tt>stdout</tt>) of another program. In the next example, vector
+point coordinates are piped from the
+<em><a href="v.out.ascii.html">v.out.ascii</a></em> module.
-v.out.ascii bugsites separator=' ' | r.what map=soils,aspect
+v.out.ascii bugsites separator=space | r.what map=soils,aspect
</pre></div>
<h3>Output containing raster map category labels</h3>
Here we use the <b>-f</b> label flag to enable the output of category labels
-associated with the raster cell(s), as well as values. (categorical maps only)
+associated with the raster cell(s), as well as values (categorical maps only).
r.what -f map=soils,aspect << EOF
@@ -112,18 +111,20 @@
653324.88|7563412.42|site 2|44|NdC|20|15 degrees NW
</pre></div>
<h2>NOTE</h2>
The maximum number of raster map layers that can be queried at one time is 400.
<!-- as given by raster/r.what/main.c "#define NFILES 400" -->
+<h2>TODO</h2>
+<ul>
+ <li>Add <b>file</b> option</li>
+</ul>
<h2>SEE ALSO</h2>
<em>
-<a href="d.where.html">d.where</a>,
<a href="r.category.html">r.category</a>,
<a href="r.report.html">r.report</a>,
<a href="r.stats.html">r.stats</a>,
@@ -134,10 +135,9 @@
<a href="v.what.vect.html">v.what.vect</a>
</em>
<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory
+Michael Shapiro, U.S. Army Construction Engineering Research Laboratory<br>
+Vector point input added by Martin Landa, Czech Technical University in Prague, Czech Republic
<p>
<i>Last changed: $Date$</i>
