[GRASS-SVN] r54538 - in grass/trunk/raster: r.cost r.walk
svn_grass at osgeo.org
Sat Jan 5 12:05:37 PST 2013
Author: martinl
Date: 2013-01-05 12:05:36 -0800 (Sat, 05 Jan 2013)
New Revision: 54538
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.walk/main.c
r.walk/r.cost: remove unused variables
rename coordinate to coordinates (see G_OPT_M_COORDS)
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2013-01-05 19:31:23 UTC (rev 54537)
+++ grass/trunk/raster/r.cost/main.c 2013-01-05 20:05:36 UTC (rev 54538)
@@ -97,7 +97,6 @@
double min_cost, old_min_cost;
FCELL cur_dir;
double zero = 0.0;
- int at_percent = 0;
int col, row, nrows, ncols;
int maxcost;
int nseg;
@@ -118,7 +117,7 @@
struct Flag *flag2, *flag3, *flag4, *flag5;
struct Option *opt1, *opt2, *opt3, *opt4, *opt5, *opt6, *opt7, *opt8;
struct Option *opt9, *opt10, *opt11, *opt12;
- struct cost *pres_cell, *new_cell;
+ struct cost *pres_cell;
struct start_pt *pres_start_pt = NULL;
struct start_pt *pres_stop_pt = NULL;
struct cc {
@@ -183,14 +182,14 @@
opt9->guisection = _("Start");
opt3 = G_define_standard_option(G_OPT_M_COORDS);
- opt3->key = "start_coordinate";
+ opt3->key = "start_coordinates";
opt3->multiple = YES;
opt3->description =
_("Coordinates of starting point(s) (E,N)");
opt3->guisection = _("Start");
opt4 = G_define_standard_option(G_OPT_M_COORDS);
- opt4->key = "stop_coordinate";
+ opt4->key = "stop_coordinates";
opt4->multiple = YES;
opt4->description =
_("Coordinates of stopping point(s) (E,N)");
@@ -674,15 +673,13 @@
cellval = Rast_get_d_value(ptr2, data_type2);
if (start_with_raster_vals == 1) {
- new_cell = insert(cellval, row, col);
costs.cost_out = cellval;
costs.nearest = cellval;
segment_put(&cost_seg, &costs, row, col);
else {
value = &zero;
- new_cell = insert(zero, row, col);
- costs.cost_out = *value;
+ costs.cost_out = *value;
@@ -712,7 +709,6 @@
if (top_start_pt->row < 0 || top_start_pt->row >= nrows
|| top_start_pt->col < 0 || top_start_pt->col >= ncols)
G_fatal_error(_("Specified starting location outside database window"));
- new_cell = insert(zero, top_start_pt->row, top_start_pt->col);
segment_get(&cost_seg, &costs, top_start_pt->row,
top_start_pt->col);
@@ -734,7 +730,6 @@
G_message(_("Finding cost path..."));
n_processed = 0;
- at_percent = 0;
pres_cell = get_lowest();
while (pres_cell != NULL) {
@@ -983,7 +978,6 @@
costs.cost_out = min_cost;
costs.nearest = nearest;
- new_cell = insert(min_cost, row, col);
if (dir == TRUE) {
segment_put(&dir_seg, &cur_dir, row, col);
@@ -993,7 +987,6 @@
if (dir == TRUE) {
@@ -1203,7 +1196,7 @@
process_answers(char **answers, struct start_pt **points,
struct start_pt **top_start_pt)
- int col, row, n;
+ int col, row;
double east, north;
struct start_pt *new_start_pt;
int got_one = 0;
@@ -1214,7 +1207,7 @@
if (!answers)
return (0);
- for (n = 0; *answers != NULL; answers += 2) {
+ for (; *answers != NULL; answers += 2) {
if (!G_scan_easting(*answers, &east, G_projection()))
G_fatal_error(_("Illegal x coordinate <%s>"), *answers);
if (!G_scan_northing(*(answers + 1), &north, G_projection()))
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2013-01-05 19:31:23 UTC (rev 54537)
+++ grass/trunk/raster/r.walk/main.c 2013-01-05 20:05:36 UTC (rev 54538)
@@ -154,7 +154,7 @@
struct Option *opt9, *opt10, *opt11, *opt12, *opt13, *opt14, *opt15;
struct cc {
@@ -224,14 +224,14 @@
opt3->description =
opt4->description =
@@ -870,13 +870,11 @@
else {
value = &zero;
@@ -907,7 +905,6 @@
top_start_pt->col);
@@ -1375,14 +1372,12 @@
if (Rast_is_d_null_value(&old_min_cost)) {
if (dir == 1)
else if (old_min_cost > min_cost) {
if (dir == 1)
@@ -1532,7 +1527,7 @@
- int col, row, n;
+ int col, row;
double east, north;
@@ -1543,7 +1538,7 @@
if (!answers)
return (0);
