[GRASS-SVN] r54539 - grass/trunk/raster/r.drain
svn_grass at osgeo.org
Sat Jan 5 12:25:28 PST 2013
Author: martinl
Date: 2013-01-05 12:25:27 -0800 (Sat, 05 Jan 2013)
New Revision: 54539
grass/trunk/raster/r.drain/filldir.c
grass/trunk/raster/r.drain/main.c
grass/trunk/raster/r.drain/r.drain.html
r.drain: sync with r.walk, r.cost
voutput renamed to vector_output
coordinate renamed to start_coordinates
vector_points renamed to start_points
Modified: grass/trunk/raster/r.drain/filldir.c
--- grass/trunk/raster/r.drain/filldir.c 2013-01-05 20:05:36 UTC (rev 54538)
+++ grass/trunk/raster/r.drain/filldir.c 2013-01-05 20:25:27 UTC (rev 54539)
@@ -112,11 +112,13 @@
lseek(fe, 0, SEEK_SET);
lseek(fd, 0, SEEK_SET);
advance_band3(fe, bnd);
- for (i = 0; i < nl; i += 1) {
+ for (i = 0; i < nl; i++) {
+ G_percent(i, nl, 5);
build_one_row(i, nl, bnd->ns, bnd, dir, m[i]);
write(fd, dir, bufsz);
+ G_percent(1, 1, 1);
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c 2013-01-05 20:05:36 UTC (rev 54538)
+++ grass/trunk/raster/r.drain/main.c 2013-01-05 20:25:27 UTC (rev 54539)
@@ -78,9 +78,9 @@
struct Option *opt1, *opt2, *coordopt, *vpointopt, *opt3, *opt4;
struct Flag *flag1, *flag2, *flag3, *flag4;
struct GModule *module;
- int in_type, dir_data_type;
+ int in_type;
void *in_buf;
- void *dir_buf;
+ void *dir_buf;
CELL *out_buf;
struct band3 bnd, bndC;
struct metrics *m = NULL;
@@ -112,36 +112,29 @@
opt1 = G_define_standard_option(G_OPT_R_ELEV);
opt1->key = "input";
- opt3 = G_define_option();
+ opt3 = G_define_standard_option(G_OPT_R_INPUT);
opt3->key = "indir";
- opt3->type = TYPE_STRING;
- opt3->gisprompt = "old,cell,raster";
opt3->description =
- _("Name of movement direction map associated with the cost surface");
+ _("Name of input movement direction map associated with the cost surface");
opt3->required = NO;
opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
- opt4 = G_define_option();
- opt4->key = "voutput";
- opt4->type = TYPE_STRING;
- opt4->gisprompt = "new,vector,vector";
+ opt4 = G_define_standard_option(G_OPT_V_OUTPUT);
+ opt4->key = "vector_output";
opt4->required = NO;
opt4->description =
- _("Output drain vector map (recommended for cost surface made using knight's move)");
+ _("Name for output drain vector map (recommended for cost surface made using knight's move)");
- coordopt = G_define_option();
- coordopt->key = "coordinate";
- coordopt->type = TYPE_STRING;
- coordopt->required = NO;
- coordopt->multiple = YES;
- coordopt->key_desc = "x,y";
- coordopt->description = _("Map coordinates of starting point(s) (E,N)");
+ coordopt = G_define_standard_option(G_OPT_M_COORDS);
+ coordopt->key = "start_coordinates";
+ coordopt->description = _("Coordinates of starting point(s) (E,N)");
coordopt->guisection = _("Start");
vpointopt = G_define_standard_option(G_OPT_V_INPUTS);
- vpointopt->key = "vector_points";
+ vpointopt->key = "start_points";
vpointopt->required = NO;
- vpointopt->description = _("Name of vector map(s) containing starting point(s)");
+ vpointopt->label = _("Name of starting vector points map(s)");
vpointopt->guisection = _("Start");
flag1 = G_define_flag();
@@ -170,36 +163,29 @@
if (flag4->answer) {
costmode = 1;
- G_message(_
- ("Directional drain selected... checking for direction raster"));
+ G_verbose_message(_("Directional drain selected... checking for direction raster"));
else {
- G_message(_("Surface/Hydrology drain selected"));
+ G_verbose_message(_("Surface/Hydrology drain selected"));
if (costmode == 1) {
if (!opt3->answer) {
- G_fatal_error(_
- ("Direction raster not specified, if direction flag is on, a direction raster must be given"));
+ G_fatal_error(_("Direction raster not specified, if direction flag is on, "
+ "a direction raster must be given"));
strcpy(dir_name, opt3->answer);
- dir_data_type = Rast_map_type(dir_name, "");
if (costmode == 0) {
if (opt3->answer) {
- G_fatal_error(_
- ("Direction map <%s> should not be specified for Surface/Hydrology drains"),
+ G_fatal_error(_("Direction map <%s> should not be specified for Surface/Hydrology drains"),
opt3->answer);
if (opt4->answer) {
- G_message(_("Outputting a vector path"));
- if (G_legal_filename(opt4->answer) < 0)
- G_fatal_error(_("<%s> is an illegal file name"), opt4->answer);
- /*G_ask_vector_new("",vect); */
if (0 > Vect_open_new(&vout, opt4->answer, 0)) {
- G_fatal_error(_("Unable to create vector map <%s>"),
+ G_fatal_error(_("Unable to create vector map <%s>"),
opt4->answer);
Vect_hist_command(&vout);
@@ -390,7 +376,7 @@
/* only necessary for non-dir drain */
- G_verbose_message(_("Calculating flow directions..."));
+ G_message(_("Calculating flow directions..."));
/* fill one-cell pits and take a first stab at flow directions */
filldir(fe, fd, nrows, &bnd, m);
@@ -459,8 +445,7 @@
/* build the output map */
- G_message(_("Writing raster map <%s>..."),
- new_map_name);
+ G_message(_("Writing output raster map..."));
for (i = 0; i < nrows; i++) {
G_percent(i, nrows, 2);
Rast_set_c_null_value(out_buf, ncols);
@@ -585,7 +570,6 @@
unlink(tempfile3);
G_free(dir_buf);
- G_done_msg(" ");
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.drain/r.drain.html
--- grass/trunk/raster/r.drain/r.drain.html 2013-01-05 20:05:36 UTC (rev 54538)
+++ grass/trunk/raster/r.drain/r.drain.html 2013-01-05 20:25:27 UTC (rev 54539)
@@ -9,14 +9,14 @@
<em><a href="r.slope.aspect.html">r.slope.aspect</a></em> or
<em><a href="r.watershed.html">r.watershed</a></em>.
-The <b>output</b> result (also a raster map layer) will show one or more
-least-cost paths between each user-provided location(s) and the minima
-(low category values) in the <b>input</b> map. If the -d flag is used the
-output least-cost paths will be found using the direction layer.
-By default, the <b>output</b> will be an integer CELL map with <tt>1</tt>
+The <b>output</b> raster map will show one or more least-cost paths
+between each user-provided location(s) and the minima (low category
+values) in the raster <b>input</b> map. If the -d flag is used the output
+least-cost paths will be found using the direction raster map. By
+default, the <b>output</b> will be an integer CELL map with <tt>1</tt>
along the least cost path, and null cells elsewhere.
-<p>With the <b>-c</b> (<em>copy</em>) flag, the input map cell values are
+<p>With the <b>-c</b> (<em>copy</em>) flag, the input raster map cell values are
copied verbatim along the path. With the <b>-a</b> (<em>accumulate</em>)
flag, the accumulated cell value from the starting point up to the current
cell is written on output. With either the <b>-c</b> or the <b>-a</b> flags, the
@@ -26,34 +26,39 @@
starting point to the final point.
The <b>-c</b>, <b>-a</b>, and <b>-n</b> flags are mutually incompatible.
-<p>For an elevation surface, the path is calculated by choosing the steeper
-"slope" between adjacent cells. The slope calculation accurately acounts
-for the variable scale in lat-lon projections. For a cost surface, the path
-is calculated by following the movement direction surface back to the start
-point given in <em>r.walk</em> or <em>r.cost</em>. The path search stops
+<p>For an elevation surface, the path is calculated by choosing the
+steeper "slope" between adjacent cells. The slope calculation
+accurately acounts for the variable scale in lat-lon projections. For
+a cost surface, the path is calculated by following the movement
+direction surface back to the start point given
+in <em><a href="r.walk.html">r.walk</a></em> or
+<em><a href="r.cost.html">r.cost</a></em>. The path search stops
as soon as a region border or a neighboring NULL cell is encountered,
because in these cases the direction can not be determined (the path
could continue outside the current region).
-<p>The <b>coordinate</b> parameter consists of map E and N grid coordinates of
+<p>The <b>start_coordinates</b> parameter consists of map E and N grid coordinates of
a starting point. Each x,y pair is the easting and northing (respectively) of
a starting point from which a least-cost corridor will be developed.
-The <b>vector_points</b> parameter can take multiple vector maps containing
+The <b>start_points</b> parameter can take multiple vector maps containing
additional starting points.
Up to 1024 starting points can be input from a combination of the
-<b>coordinate</b> and <b>vector_points</b> parameters.
+<b>start_coordinates</b> and <b>start_points</b> parameters.
<h2>NOTES</h2>
-If no direction input map is given, <em>r.drain</em> currently finds
-only the lowest point (the cell having the smallest category value) in
-the input file that can be reached through directly adjacent cells
-that are less than or equal in value to the cell reached immediately
-prior to it; therefore, it will not necessarily reach the lowest point
-in the input file. It currently finds <em>pits</em> in the data, rather
-than the lowest point in the entire input map. The <em>r.fill.dir</em>,
-<em>r.terraflow</em>, and <em>r.basins.fill</em> modules can be used to
-fill in subbasins prior to processing with <em>r.drain</em>.
+If no direction input map is given, <em>r.drain</em> currently finds
+only the lowest point (the cell having the smallest category value) in
+the input file that can be reached through directly adjacent cells
+that are less than or equal in value to the cell reached immediately
+prior to it; therefore, it will not necessarily reach the lowest point
+in the input file. It currently finds <em>pits</em> in the data,
+rather than the lowest point in the entire input
+map. The <em><a href="r.fill.dir.html">r.fill.dir</a></em>,
+<em><a href="r.terraflow.html">r.terraflow</a></em>,
+and <em><a href="r.basins.fill.html">r.basins.fill</a></em> modules
+can be used to fill in subbasins prior to processing
+with <em>r.drain</em>.
<p>
<em>r.drain</em> will not give sane results at the region boundary. On outer rows
@@ -194,19 +199,22 @@
<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.cost.html">r.cost</a></em>,
-<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
-<em><a href="r.basins.fill.html">r.basins.fill</a></em>,
-<em><a href="r.terraflow.html">r.terraflow</a></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.walk.html">r.walk</a></em>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.cost.html">r.cost</a>,
+<a href="r.fill.dir.html">r.fill.dir</a>,
+<a href="r.basins.fill.html">r.basins.fill</a>,
+<a href="r.terraflow.html">r.terraflow</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.walk.html">r.walk</a>
+</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
-Completely rewritten by Roger S. Miller, 2001
-<p>July 2004 at WebValley 2004, error checking and vector points added by
+Completely rewritten by Roger S. Miller, 2001<br>
+July 2004 at WebValley 2004, error checking and vector points added by
Matteo Franchi (Liceo Leonardo Da Vinci, Trento) and
Roberto Flor (ITC-irst, Trento, Italy)
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
