[GRASS-SVN] r54623 - grass/trunk/display/d.legend
svn_grass at osgeo.org
Mon Jan 14 01:41:35 PST 2013
Author: hamish
Date: 2013-01-14 01:41:34 -0800 (Mon, 14 Jan 2013)
New Revision: 54623
grass/trunk/display/d.legend/main.c
add support for RGB text color, or 'none' (merge from devbr6)
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c 2013-01-14 08:53:54 UTC (rev 54622)
+++ grass/trunk/display/d.legend/main.c 2013-01-14 09:41:34 UTC (rev 54623)
@@ -48,7 +48,7 @@
int thin;
int i, j, k;
int lines, steps;
- int new_colr, fp;
+ int fp;
double t, b, l, r;
int hide_catnum, hide_catstr, hide_nodata, do_smooth;
char *cstr;
@@ -91,12 +91,8 @@
opt_input = G_define_standard_option(G_OPT_R_MAP);
opt_input->description = _("Name of raster map");
- opt_color = G_define_option();
- opt_color->key = "color";
- opt_color->type = TYPE_STRING;
- opt_color->answer = DEFAULT_FG_COLOR;
- opt_color->gisprompt = "old_color,color,color";
- opt_color->description = _("Sets the legend's text color");
+ opt_color = G_define_standard_option(G_OPT_C_FG);
+ opt_color->label = _("Text color");
opt_lines = G_define_option();
opt_lines->key = "lines";
@@ -161,6 +157,7 @@
opt_font->description = _("Font name");
opt_font->guisection = _("Advanced");
+ /* HB: this option should become redundant as soon as the bug in trunk's D_text_size() is fixed. */
opt_fontscale = G_define_option();
opt_fontscale->key = "fontscale";
opt_fontscale->type = TYPE_DOUBLE;
@@ -219,6 +216,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
map_name = opt_input->answer;
hide_catstr = hidestr->answer; /* note hide_catstr gets changed and re-read below */
@@ -231,13 +229,7 @@
fontscale = atof(opt_fontscale->answer);
fontscale = 1.0 / (100.0/fontscale);
- color = 0; /* if only to get rid of the compiler warning */
- if (opt_color->answer != NULL) {
- new_colr = D_translate_color(opt_color->answer);
- if (new_colr == 0)
- G_fatal_error(_("Don't know the color %s"), opt_color->answer);
- color = new_colr;
+ color = D_parse_color(opt_color->answer, TRUE);
if (opt_lines->answer != NULL)
sscanf(opt_lines->answer, "%d", &lines);
@@ -734,7 +726,8 @@
y1 + 4 + txsiz);
- D_text(buff);
+ if(color)
+ D_text(buff);
} /*for */
@@ -924,7 +917,9 @@
D_pos_abs((l + 3 + dots_per_line), (cur_dot_row) - 3);
- D_text(buff);
+ if(color)
+ D_text(buff);
if (0 == k)
@@ -946,7 +941,8 @@
D_use_color(white);
D_pos_abs((l + 3 + dots_per_line), (cur_dot_row));
- D_text(buff);
+ if(color)
+ D_text(buff);
