[GRASS-SVN] r54624 - grass/trunk/display/d.legend
svn_grass at osgeo.org
Mon Jan 14 02:37:51 PST 2013
Author: martinl
Date: 2013-01-14 02:37:50 -0800 (Mon, 14 Jan 2013)
New Revision: 54624
grass/trunk/display/d.legend/main.c
d.legend: more guisections
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c 2013-01-14 09:41:34 UTC (rev 54623)
+++ grass/trunk/display/d.legend/main.c 2013-01-14 10:37:50 UTC (rev 54624)
@@ -93,6 +93,7 @@
opt_color = G_define_standard_option(G_OPT_C_FG);
opt_color->label = _("Text color");
+ opt_color->guisection = _("Font settings");
opt_lines = G_define_option();
opt_lines->key = "lines";
@@ -118,7 +119,7 @@
opt_labelnum->answer = "5";
opt_labelnum->options = "2-100";
opt_labelnum->description = _("Number of text labels for smooth gradient legend");
- opt_labelnum->guisection = _("Advanced");
+ opt_labelnum->guisection = _("Gradient");
opt_at = G_define_option();
opt_at->key = "at";
@@ -133,13 +134,12 @@
opt_use = G_define_option();
opt_use->key = "use";
- opt_use->key_desc = "catnum";
opt_use->type = TYPE_DOUBLE; /* string as it is fed through the parser? */
opt_use->required = NO;
opt_use->description =
_("List of discrete category numbers/values for legend");
opt_use->multiple = YES;
- opt_use->guisection = _("Advanced");
+ opt_use->guisection = _("Subset");
opt_range = G_define_option();
opt_range->key = "range";
@@ -148,14 +148,14 @@
opt_range->required = NO;
opt_range->description =
_("Use a subset of the map range for the legend (min,max)");
- opt_range->guisection = _("Advanced");
+ opt_range->guisection = _("Subset");
opt_font = G_define_option();
opt_font->key = "font";
opt_font->type = TYPE_STRING;
opt_font->required = NO;
opt_font->description = _("Font name");
- opt_font->guisection = _("Advanced");
+ opt_font->guisection = _("Font settings");
/* HB: this option should become redundant as soon as the bug in trunk's D_text_size() is fixed. */
opt_fontscale = G_define_option();
@@ -165,7 +165,7 @@
opt_fontscale->answer = "5";
opt_fontscale->options = "0-100";
opt_fontscale->description = _("Font scaling factor for floating point legends");
- opt_fontscale->guisection = _("Advanced");
+ opt_fontscale->guisection = _("Font settings");
opt_path = G_define_option();
opt_path->key = "path";
@@ -173,7 +173,7 @@
opt_path->required = NO;
opt_path->description = _("Path to font file");
opt_path->gisprompt = "old_file,file,font";
- opt_path->guisection = _("Advanced");
+ opt_path->guisection = _("Font settings");
opt_charset = G_define_option();
opt_charset->key = "charset";
@@ -181,7 +181,7 @@
opt_charset->required = NO;
opt_charset->description =
_("Text encoding (only applicable to TrueType fonts)");
- opt_charset->guisection = _("Advanced");
+ opt_charset->guisection = _("Font settings");
hidestr = G_define_flag();
hidestr->key = 'v';
@@ -201,7 +201,7 @@
smooth = G_define_flag();
smooth->key = 's';
smooth->description = _("Draw smooth gradient");
- smooth->guisection = _("Advanced");
+ smooth->guisection = _("Gradient");
flipit = G_define_flag();
flipit->key = 'f';
@@ -211,6 +211,7 @@
size = G_define_flag();
size->key = 's';
size->description = _("Font size is height in pixels");
+ size->guisection = _("Font settings");
/* Check command line */
if (G_parser(argc, argv))
