[GRASS-SVN] r54625 - grass/trunk/mswindows
svn_grass at osgeo.org
Mon Jan 14 04:07:18 PST 2013
Author: martinl
Date: 2013-01-14 04:07:18 -0800 (Mon, 14 Jan 2013)
New Revision: 54625
Added:
grass/trunk/mswindows/FileAssociation.nsh
grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
wingrass/nsis: fix file association
Added: grass/trunk/mswindows/FileAssociation.nsh
--- grass/trunk/mswindows/FileAssociation.nsh (rev 0)
+++ grass/trunk/mswindows/FileAssociation.nsh 2013-01-14 12:07:18 UTC (rev 54625)
@@ -0,0 +1,190 @@
+_____________________________________________________________________________
+ File Association
+ Based on code taken from http://nsis.sourceforge.net/File_Association
+ Usage in script:
+ 1. !include "FileAssociation.nsh"
+ 2. [Section|Function]
+ ${FileAssociationFunction} "Param1" "Param2" "..." $var
+ [SectionEnd|FunctionEnd]
+ FileAssociationFunction=[RegisterExtension|UnRegisterExtension]
+ ${RegisterExtension} "[executable]" "[extension]" "[description]"
+"[executable]" ; executable which opens the file format
+"[extension]" ; extension, which represents the file format to open
+"[description]" ; description for the extension. This will be display in Windows Explorer.
+ ${UnRegisterExtension} "[extension]" "[description]"
+ Macros
+ Change log window verbosity (default: 3=no script)
+ Example:
+ !include "FileAssociation.nsh"
+ !insertmacro RegisterExtension
+ ${FileAssociation_VERBOSE} 4 # all verbosity
+ !insertmacro UnRegisterExtension
+ ${FileAssociation_VERBOSE} 3 # no script
+!ifndef FileAssociation_INCLUDED
+!define FileAssociation_INCLUDED
+!include Util.nsh
+!verbose push
+!verbose 3
+!ifndef _FileAssociation_VERBOSE
+ !define _FileAssociation_VERBOSE 3
+!endif
+!verbose ${_FileAssociation_VERBOSE}
+!define FileAssociation_VERBOSE `!insertmacro FileAssociation_VERBOSE`
+!verbose pop
+!macro FileAssociation_VERBOSE _VERBOSE
+ !verbose push
+ !verbose 3
+ !undef _FileAssociation_VERBOSE
+ !define _FileAssociation_VERBOSE ${_VERBOSE}
+ !verbose pop
+!macroend
+!macro RegisterExtensionCall _EXECUTABLE _EXTENSION _DESCRIPTION
+ !verbose push
+ !verbose ${_FileAssociation_VERBOSE}
+ Push `${_DESCRIPTION}`
+ Push `${_EXTENSION}`
+ Push `${_EXECUTABLE}`
+ ${CallArtificialFunction} RegisterExtension_
+ !verbose pop
+!macroend
+!macro UnRegisterExtensionCall _EXTENSION _DESCRIPTION
+ !verbose push
+ ${CallArtificialFunction} UnRegisterExtension_
+ !verbose pop
+!macroend
+!define RegisterExtension `!insertmacro RegisterExtensionCall`
+!define un.RegisterExtension `!insertmacro RegisterExtensionCall`
+!macroend
+!macro un.RegisterExtension
+!macroend
+!macro RegisterExtension_
+ !verbose push
+ Exch $R2 ;exe
+ Exch
+ Exch $R1 ;ext
+ Exch
+ Exch 2
+ Exch $R0 ;desc
+ Exch 2
+ Push $0
+ Push $1
+ ReadRegStr $1 HKCR $R1 "" ; read current file association
+ StrCmp "$1" "" NoBackup ; is it empty
+ StrCmp "$1" "$R0" NoBackup ; is it our own
+ WriteRegStr HKCR $R1 "backup_val" "$1" ; backup current value
+NoBackup:
+ WriteRegStr HKCR $R1 "" "$R0" ; set our file association
+ ReadRegStr $0 HKCR $R0 ""
+ StrCmp $0 "" 0 Skip
+ WriteRegStr HKCR "$R0" "" "$R0"
+ WriteRegStr HKCR "$R0\shell" "" "open"
+ WriteRegStr HKCR "$R0\DefaultIcon" "" "$R2,0"
+Skip:
+ WriteRegStr HKCR "$R0\shell\open\command" "" '"$R2" "%1"'
+ WriteRegStr HKCR "$R0\shell\edit" "" "Edit $R0"
+ WriteRegStr HKCR "$R0\shell\edit\command" "" '"$R2" "%1"'
+ Pop $1
+ Pop $0
+ Pop $R2
+ Pop $R1
+ Pop $R0
+ !verbose pop
+!macroend
+!define UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
+!define un.UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
+!macroend
+!macro un.UnRegisterExtension
+!macroend
+!macro UnRegisterExtension_
+ !verbose push
+ Exch $R1 ;desc
+ Exch
+ Exch $R0 ;ext
+ Exch
+ Push $0
+ Push $1
+ ReadRegStr $1 HKCR $R0 ""
+ StrCmp $1 $R1 0 NoOwn ; only do this if we own it
+ ReadRegStr $1 HKCR $R0 "backup_val"
+ StrCmp $1 "" 0 Restore ; if backup="" then delete the whole key
+ DeleteRegKey HKCR $R0
+ Goto NoOwn
+Restore:
+ WriteRegStr HKCR $R0 "" $1
+ DeleteRegValue HKCR $R0 "backup_val"
+ DeleteRegKey HKCR $R1 ;Delete key with association name settings
+NoOwn:
+ Pop $1
+ Pop $0
+ Pop $R1
+ Pop $R0
+ !verbose pop
+!macroend
+!endif # !FileAssociation_INCLUDED
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-01-14 10:37:50 UTC (rev 54624)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-01-14 12:07:18 UTC (rev 54625)
@@ -624,8 +624,9 @@
WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
;File Association
- ${registerExtension} "$INSTALL_DIR\extrabin\pythonw.exe" ".py" "Python File"
+ ${registerExtension} "$INSTALL_DIR\extrabin\python.exe" ".py" "Python File"
+ ${registerExtension} "$INSTALL_DIR\extrabin\python.exe" ".pyc" "Compiled Python File"
;Create the Desktop Shortcut
SetShellVarContext current
@@ -1007,7 +1008,8 @@
DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
;File Association
- ${unregisterExtension} ".py" "Python File"
+ ${unregisterExtension} ".py" "Python File"
+ ${unregisterExtension} ".pyc" "Compiled Python File"
SectionEnd
