[GRASS-SVN] r54641 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Jan 15 05:11:07 PST 2013
Author: zarch
Date: 2013-01-15 05:11:06 -0800 (Tue, 15 Jan 2013)
New Revision: 54641
grass/trunk/lib/python/pygrass/vector/abstract.py
Rewrite the open method of the vector classes
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2013-01-15 13:10:56 UTC (rev 54640)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2013-01-15 13:11:06 UTC (rev 54641)
@@ -223,7 +223,7 @@
def open(self, mode='r', layer='0', overwrite=None,
# parameters valid only if mode == 'w'
- tab_name='', tab_cols=[('cat', 'INTEGER PRIMARY KEY'), ],
+ tab_name='', tab_cols=None,
link_layer=1, link_name=None, link_key='cat',
link_db='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db',
link_driver='sqlite'):
@@ -247,43 +247,54 @@
# check if the mode is valid
if mode not in ('r', 'rw', 'w'):
raise ValueError("Mode not supported. Use one of: 'r', 'rw', 'w'.")
# check if the map exist
- if self.exist() and mode == 'r':
- openvect = libvect.Vect_open_old2(self.c_mapinfo, self.name,
- self.mapset, layer)
+ if self.exist() and mode in ('r', 'rw'):
+ # open in READ mode
+ if mode == 'r':
+ openvect = libvect.Vect_open_old2(self.c_mapinfo, self.name,
+ self.mapset, layer)
+ # open in READ and WRITE mode
+ elif mode == 'rw':
+ openvect = libvect.Vect_open_update2(self.c_mapinfo, self.name,
+ # instantiate class attributes
+ self.dblinks = DBlinks(self.c_mapinfo)
# If it is opened in write mode
if mode == 'w':
- #TODO: build topo if new
openvect = libvect.Vect_open_new(self.c_mapinfo, self.name,
libvect.WITHOUT_Z)
- # create a link
- link = Link(link_layer,
- link_name if link_name else self.name,
- tab_name if tab_name else self.name,
- link_key, link_db, link_driver)
- # add the new link
- self.dblinks.add(link)
- # get the table
- table = link.table()
- # create the new columns
- table.columns.create(tab_cols)
- self.n_lines = 0
- elif mode == 'rw':
- openvect = libvect.Vect_open_update2(self.c_mapinfo, self.name,
- # initialize the dblinks object
- self.dblinks = DBlinks(self.c_mapinfo)
+ if tab_cols:
+ # create a link
+ link = Link(link_layer,
+ link_name if link_name else self.name,
+ tab_name if tab_name else self.name,
+ link_key, link_db, link_driver)
+ # add the new link
+ self.dblinks.add(link)
+ # create the table
+ table = self.get_table()
+ table.columns.create(tab_cols)
+ table.conn.commit()
# check the C function result.
if openvect == -1:
str_err = "Not able to open the map, C function return %d."
raise OpenError(str_err % openvect)
- # istantiate the table
- self.layer = self.dblinks[0].layer
- self.table = self.get_table(layer=self.layer)
+ if len(self.dblinks) == 0:
+ self.layer = 1
+ self.table = None
+ self.n_lines = 0
+ else:
+ self.layer = self.dblinks[0].layer
+ self.table = self.get_table(layer=self.layer)
+ self.n_lines = self.table.n_rows()
self.writable = self.mapset == functions.getenv("MAPSET")
- if mode != 'w':
- self.n_lines = self.table.num_rows()
def get_table(self, layer=None, name=None,):
if layer is None and name is None and len(self.dblinks) == 0:
@@ -293,10 +304,11 @@
elif name is not None:
return self.dblinks.by_name(name).table()
else:
- return self.dblinks.by_layer(1).table()
+ return self.dblinks[0].table()
def close(self):
- self.table.conn.close()
+ if self.table is not None:
+ self.table.conn.close()
if self.is_open():
if libvect.Vect_close(self.c_mapinfo) != 0:
str_err = 'Error when trying to close the map with Vect_close'
