[GRASS-SVN] r54642 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Jan 15 05:11:18 PST 2013
Author: zarch
Date: 2013-01-15 05:11:17 -0800 (Tue, 15 Jan 2013)
New Revision: 54642
grass/trunk/lib/python/pygrass/vector/__init__.py
Modify the write and rewrite method of the Vector class
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2013-01-15 13:11:06 UTC (rev 54641)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2013-01-15 13:11:17 UTC (rev 54642)
@@ -134,7 +134,7 @@
raise GrassError("Vect_rewind raise an error.")
@must_be_open
- def write(self, geo_obj, attrs=None, line=0, layer=None):
+ def write(self, geo_obj, attrs=None):
"""Write geometry features and attributes
Open a new vector map ::
@@ -187,15 +187,15 @@
- if layer:
- table = self.dblinks.by_layer(layer).table()
- else:
- table = self.table
- layer = self.layer
- line = line if line else table.num_rows() + 1
- attr = [line, ]
- attr.extend(attrs)
- libvect.Vect_cat_set(geo_obj.c_cats, layer, line)
+ self.n_lines += 1
+ if self.table is not None and attrs:
+ attr = [self.n_lines, ]
+ attr.extend(attrs)
+ cur = self.table.conn.cursor()
+ cur.execute(self.table.columns.insert_str, attr)
+ cur.close()
+ libvect.Vect_cat_set(geo_obj.c_cats, self.layer, self.n_lines)
result = libvect.Vect_write_line(self.c_mapinfo, geo_obj.gtype,
geo_obj.c_points, geo_obj.c_cats)
if result == -1:
@@ -207,12 +207,9 @@
# return offset into file where the feature starts (on level 1)
geo_obj.offset = result
- cur = table.conn.cursor()
- cur.execute(table.columns.insert_str, attr)
- table.conn.commit()
- cur.close()
# VECTOR WITH TOPOLOGY
@@ -414,7 +411,7 @@
if feature_id < 0: # Handle negative indices
feature_id += self.__len__() + 1
- if feature_id >= (self.__len__() + 1):
+ if feature_id > (self.__len__()):
raise IndexError('Index out of range')
if feature_id > 0:
c_points = ctypes.pointer(libvect.line_pnts())
@@ -444,11 +441,22 @@
return output
@must_be_open
- def rewrite(self, geo_obj):
+ def rewrite(self, line, geo_obj, attrs=None, **kargs):
+ """Rewrite a geometry features
+ attr = [line, ]
+ self.table.update(key=line, values=attr)
+ libvect.Vect_cat_set(geo_obj.c_cats, self.layer, line)
result = libvect.Vect_rewrite_line(self.c_mapinfo,
- geo_obj.id, geo_obj.gtype,
+ line, geo_obj.gtype,
geo_obj.c_points,
geo_obj.c_cats)
+ if result == -1:
+ raise GrassError("Not able to write the vector feature.")
