[GRASS-SVN] r54667 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Wed Jan 16 03:08:18 PST 2013
Author: mic
Date: 2013-01-16 03:08:17 -0800 (Wed, 16 Jan 2013)
New Revision: 54667
Added:
grass-addons/grass7/raster/r.agent/tests/test_grassland.py
grass-addons/grass7/raster/r.agent/tests/test_playground.py
grass-addons/grass7/raster/r.agent/libagent/grassland.py
grass-addons/grass7/raster/r.agent/libagent/playground.py
add tests and move method to upper class
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-16 11:04:14 UTC (rev 54666)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-16 11:08:17 UTC (rev 54667)
@@ -23,12 +23,6 @@
if self.region['ewres'] != self.region['nsres']:
raise error.DataError("r.agent::libagent.playground.Playground()",
"Only square raster cells make sense.")
- def getregion(self):
- Return the region information
- @return dict region
- return self.region
def getbound(self, bound):
Return the requested bound, takes: 'n', 's', 'w', or 'e'
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-16 11:04:14 UTC (rev 54666)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-16 11:08:17 UTC (rev 54667)
@@ -14,8 +14,13 @@
and organizing space."""
def __init__(self):
self.layers = dict()
+ self.region = dict(n=0,s=0,w=0,e=0)
- pass
+ Return the region information
+ @return dict region
+ return self.region
pass
def setlayer(self, layername, layer, force=False):
Added: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py (rev 0)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-01-16 11:08:17 UTC (rev 54667)
@@ -0,0 +1,16 @@
+import unittest2 as unittest
+#import unittest
+from libagent import playground, grassland
+class TestOurExceptions(unittest.TestCase):
+ def setUp(self):
+ self.pg = grassland.GrassLand()
+ def test_getregion(self):
+ self.pg.getregion()
+# def tearDown(self):
Added: grass-addons/grass7/raster/r.agent/tests/test_playground.py
--- grass-addons/grass7/raster/r.agent/tests/test_playground.py (rev 0)
+++ grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-01-16 11:08:17 UTC (rev 54667)
@@ -0,0 +1,16 @@
+#import unittest
+ def setUp(self):
+ self.pg = playground.Playground()
