[GRASS-SVN] r54668 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Wed Jan 16 05:09:41 PST 2013
Author: mic
Date: 2013-01-16 05:09:40 -0800 (Wed, 16 Jan 2013)
New Revision: 54668
grass-addons/grass7/raster/r.agent/libagent/grassland.py
grass-addons/grass7/raster/r.agent/libagent/playground.py
grass-addons/grass7/raster/r.agent/tests/test_grassland.py
grass-addons/grass7/raster/r.agent/tests/test_playground.py
add tests and move methods to upper class
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-16 11:08:17 UTC (rev 54667)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-16 13:09:40 UTC (rev 54668)
@@ -15,6 +15,7 @@
class GrassLand(playground.Playground):
"""A GrassLand is a Playground and the interface to GRASS."""
def __init__(self):
"""Create a Playground with all the relevant info by GRASS"""
self.layers = dict()
@@ -23,25 +24,7 @@
if self.region['ewres'] != self.region['nsres']:
raise error.DataError("r.agent::libagent.playground.Playground()",
"Only square raster cells make sense.")
- def getbound(self, bound):
- Return the requested bound, takes: 'n', 's', 'w', or 'e'
- @param string bound
- @return float the outermost coordinate
- if bound == "n" or bound == "s" or bound == "w" or bound == "e":
- return self.region[bound]
- def setlayer(self, layername, layer, force=False):
- Put an existing map layer to the layer collection
- @param string name of the layer
- @param list a map layer
- @param boolean optional, whether to overwrite values if key exists
- if not force and self.layers.has_key(layername):
- raise error.Error("r.agent::libagent.playground.Playground()",
- "May not overwrite existing layer.")
- self.layers[layername] = layer
def setgrasslayer(self, layername, grassmapname, force=False):
Put an existing map from GRASS to the layer collection
@@ -55,6 +38,7 @@
layer.read(grassmapname)
self.grassmapnames[layername] = grassmapname
self.setlayer(layername, layer, force)
def createlayer(self, layername, force=False):
Create a new layer and add it to the layer collection
@@ -62,6 +46,7 @@
@param string name of a GRASS map layer or False if layer is only local
self.setgrasslayer(layername, False, force)
def getlayer(self, layername):
Return a layer from the collection by its name
@@ -72,6 +57,7 @@
if self.layers.has_key(layername):
retval = self.layers[layername]
return retval
def removelayer(self, layername):
Remove (forget about) the layer named from the layer collection
@@ -79,12 +65,14 @@
self.layers.pop(layername)
def writelayer(self, layername, force=False):
if self.layers.has_key(layername) and \
self.grassmapnames.has_key(layername):
grassmapname = self.grassmapnames[layername]
layer = self.layers[layername]
layer.write(grassmapname, overwrite=force)
def writelayerasnew(self, layername, grassmapname):
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-16 11:08:17 UTC (rev 54667)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-16 13:09:40 UTC (rev 54668)
@@ -9,28 +9,53 @@
for details.
+import error
class Playground(object):
"""A Playground is a major component of a World, defining
and organizing space."""
def __init__(self):
self.region = dict(n=0,s=0,w=0,e=0)
def getregion(self):
Return the region information
@return dict region
return self.region
- pass
+ Return the requested bound, takes: 'n', 's', 'w', or 'e'
+ @param string bound
+ @return float the outermost coordinate
+ if bound == "n" or bound == "s" or bound == "w" or bound == "e":
+ return self.region[bound]
- pass
+ Put an existing map layer to the layer collection
+ @param string name of the layer
+ @param list a map layer
+ @param boolean optional, whether to overwrite values if key exists
+ if not force and self.layers.has_key(layername):
+ raise error.Error("r.agent::libagent.playground.Playground()",
+ "May not overwrite existing layer.")
+ self.layers[layername] = layer
def createlayer(self, layername, grassmap=False):
pass
return []
pass
def writelayer(self, layername):
pass
Modified: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-01-16 11:08:17 UTC (rev 54667)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-01-16 13:09:40 UTC (rev 54668)
@@ -9,8 +9,17 @@
self.pg = grassland.GrassLand()
def test_getregion(self):
- self.pg.getregion()
+ self.assertIsNotNone(self.pg.getregion())
+ def test_getbound(self):
+ self.assertIsNotNone(self.pg.getbound("n"))
+ self.assertIsNotNone(self.pg.getbound("s"))
+ self.assertIsNotNone(self.pg.getbound("w"))
+ self.assertIsNotNone(self.pg.getbound("e"))
+# def test_setlayer(self):
+ # Enought if tested from Playground and e.g. setgrasslayer below..
# def tearDown(self):
Modified: grass-addons/grass7/raster/r.agent/tests/test_playground.py
--- grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-01-16 11:08:17 UTC (rev 54667)
+++ grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-01-16 13:09:40 UTC (rev 54668)
@@ -9,8 +9,24 @@
self.pg = playground.Playground()
+ def test_setlayer(self):
+ layer = [0]
+ key = "foo"
+ self.pg.setlayer(key, layer)
+ self.assertIs(self.pg.layers[key], layer)
+ self.assertRaises(Exception, self.pg.setlayer, (key, layer))
+ layer = [0]
+ self.assertIsNot(self.pg.layers[key], layer)
+ self.pg.setlayer(key, layer, True)
