[GRASS-SVN] r54671 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Wed Jan 16 05:30:24 PST 2013
Author: mic
Date: 2013-01-16 05:30:24 -0800 (Wed, 16 Jan 2013)
New Revision: 54671
grass-addons/grass7/raster/r.agent/libagent/grassland.py
grass-addons/grass7/raster/r.agent/libagent/playground.py
grass-addons/grass7/raster/r.agent/tests/test_grassland.py
grass-addons/grass7/raster/r.agent/tests/test_playground.py
add tests and move methods to upper class
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-16 13:15:56 UTC (rev 54670)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-16 13:30:24 UTC (rev 54671)
@@ -47,25 +47,6 @@
self.setgrasslayer(layername, False, force)
- def getlayer(self, layername):
- Return a layer from the collection by its name
- @param string name of the layer
- @return list the requested map layer
- retval = False
- if self.layers.has_key(layername):
- retval = self.layers[layername]
- return retval
- def removelayer(self, layername):
- Remove (forget about) the layer named from the layer collection
- self.layers.pop(layername)
def writelayer(self, layername, force=False):
if self.layers.has_key(layername) and \
self.grassmapnames.has_key(layername):
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-16 13:15:56 UTC (rev 54670)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-16 13:30:24 UTC (rev 54671)
@@ -47,14 +47,32 @@
"May not overwrite existing layer.")
self.layers[layername] = layer
- def createlayer(self, layername, grassmap=False):
+ def createlayer(self, layername, force=False):
+ Create a new layer and add it to the layer collection
+ @param string name of the layer
+ @param boolean whether to overwrite an existing layer
pass
- return []
+ Return a layer from the collection by its name
+ @return list the requested map layer
+ retval = False
+ if self.layers.has_key(layername):
+ retval = self.layers[layername]
+ return retval
- pass
+ Remove (forget about) the layer named from the layer collection
+ self.layers.pop(layername)
def writelayer(self, layername):
pass
Modified: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-01-16 13:15:56 UTC (rev 54670)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-01-16 13:30:24 UTC (rev 54671)
@@ -18,8 +18,22 @@
self.assertIsNotNone(self.pg.getbound("e"))
# def test_setlayer(self):
- # Enought if tested from Playground and e.g. setgrasslayer below..
+# Enought if tested from Playground and e.g. setgrasslayer below..
+ def test_createlayer(self):
+ #TODO
+ self.pg.createlayer("foo")
+ def test_getlayer(self):
+ self.pg.layers["foo"] = [0]
+ self.assertIs(self.pg.layers["foo"], self.pg.getlayer("foo"))
+ def test_removelayer(self):
+ self.assertTrue(self.pg.layers.has_key("foo"))
+ self.pg.removelayer("foo")
+ self.assertFalse(self.pg.layers.has_key("foo"))
# def tearDown(self):
Modified: grass-addons/grass7/raster/r.agent/tests/test_playground.py
--- grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-01-16 13:15:56 UTC (rev 54670)
+++ grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-01-16 13:30:24 UTC (rev 54671)
@@ -28,5 +28,19 @@
self.pg.setlayer(key, layer, True)
self.assertIs(self.pg.layers[key], layer)
+ #TODO
