[GRASS-SVN] r54672 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Wed Jan 16 06:13:17 PST 2013
Author: mic
Date: 2013-01-16 06:13:16 -0800 (Wed, 16 Jan 2013)
New Revision: 54672
grass-addons/grass7/raster/r.agent/libagent/grassland.py
grass-addons/grass7/raster/r.agent/libagent/playground.py
grass-addons/grass7/raster/r.agent/tests/test_grassland.py
grass-addons/grass7/raster/r.agent/tests/test_playground.py
add tests and move methods to upper class
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-16 13:30:24 UTC (rev 54671)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-16 14:13:16 UTC (rev 54672)
@@ -29,23 +29,26 @@
Put an existing map from GRASS to the layer collection
@param string name of the layer
- @param string name of a GRASS map layer
+ @param string name of an existing GRASS map layer
@param boolean optional, whether to overwrite values if key exists
layer = garray.array()
- if grassmapname:
- # fill the new grass array with the contents from the file
- layer.read(grassmapname)
- self.grassmapnames[layername] = grassmapname
+ # fill the new grass array with the contents from the file
+ layer.read(grassmapname)
+ self.grassmapnames[layername] = grassmapname
self.setlayer(layername, layer, force)
- def createlayer(self, layername, force=False):
+ def createlayer(self, layername, grassmapname=False, force=False):
Create a new layer and add it to the layer collection
@param string name of a GRASS map layer or False if layer is only local
+ @param boolean whether to overwrite an existing layer
- self.setgrasslayer(layername, False, force)
+ layer = garray.array()
+ if grassmapname:
+ self.setlayer(layername, layer)
def writelayer(self, layername, force=False):
if self.layers.has_key(layername) and \
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-16 13:30:24 UTC (rev 54671)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-16 14:13:16 UTC (rev 54672)
@@ -17,7 +17,8 @@
def __init__(self):
self.layers = dict()
- self.region = dict(n=0,s=0,w=0,e=0)
+#TODO
+ self.region = dict(n=0,s=0,w=0,e=0,rows=0,cols=0)
def getregion(self):
@@ -53,7 +54,11 @@
- pass
+ #TODO rows vs. cols
+ layer = []
+ for i in range(self.region["rows"]):
+ l.append( [[] for j in range(self.region["cols"])])
def getlayer(self, layername):
Modified: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-01-16 13:30:24 UTC (rev 54671)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py 2013-01-16 14:13:16 UTC (rev 54672)
@@ -21,8 +21,9 @@
# Enought if tested from Playground and e.g. setgrasslayer below..
def test_createlayer(self):
- #TODO
- self.pg.createlayer("foo")
+ self.pg.createlayer("foo", "foo")
+ self.assertTrue(self.pg.layers.has_key("foo"))
+ self.assertTrue(self.pg.grassmapnames.has_key("foo"))
def test_getlayer(self):
self.pg.layers["foo"] = [0]
Modified: grass-addons/grass7/raster/r.agent/tests/test_playground.py
--- grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-01-16 13:30:24 UTC (rev 54671)
+++ grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-01-16 14:13:16 UTC (rev 54672)
@@ -29,8 +29,9 @@
self.assertIs(self.pg.layers[key], layer)
- #TODO
+ #TODO rows / cols
