[GRASS-SVN] r54673 - in grass-addons/grass7/raster/r.agent:	libagent tests
    svn_grass at osgeo.org
    Wed Jan 16 07:59:35 PST 2013
Author: mic
Date: 2013-01-16 07:59:33 -0800 (Wed, 16 Jan 2013)
New Revision: 54673
   grass-addons/grass7/raster/r.agent/libagent/grassland.py
   grass-addons/grass7/raster/r.agent/libagent/playground.py
   grass-addons/grass7/raster/r.agent/tests/test_grassland.py
   grass-addons/grass7/raster/r.agent/tests/test_playground.py
add tests and move methods to upper class
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-01-16 14:13:16 UTC (rev 54672)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-01-16 15:59:33 UTC (rev 54673)
@@ -50,15 +50,27 @@
             self.grassmapnames[layername] = grassmapname
         self.setlayer(layername, layer)
-    def writelayer(self, layername, force=False):
+    def removelayer(self, layername):
+        Remove (forget about) the layer named from the layer collection
+        @param string name of the layer
+        if self.layers.has_key(layername):
+            self.layers.pop(layername)
+        if self.grassmapnames.has_key(layername):
+            self.grassmapnames.pop(layername)
+    def writelayer(self, layername, grassmapname=False, force=False):
+        Write out a given layer to a GRASS map file
+        @param string name of the layer to be exported
+        @param string optional name of the GRASS map file to be created
+        @param boolean whether an existing file may be overwritten
+        #TODO implement
         if self.layers.has_key(layername) and \
             grassmapname = self.grassmapnames[layername]
             layer = self.layers[layername]
             layer.write(grassmapname, overwrite=force)
-    def writelayerasnew(self, layername, grassmapname):
-        if self.layers.has_key(layername):
-            layer = self.layers[layername]
-            layer.write(grassmapname)
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py	2013-01-16 14:13:16 UTC (rev 54672)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py	2013-01-16 15:59:33 UTC (rev 54673)
@@ -48,13 +48,15 @@
                                     "May not overwrite existing layer.")
         self.layers[layername] = layer
-    def createlayer(self, layername, force=False):
+    def createlayer(self, layername, filename=False, force=False):
         Create a new layer and add it to the layer collection
+        @param string file name if it is to be created from an existing file
         @param boolean whether to overwrite an existing layer
         #TODO rows vs. cols
+        #TODO import from file
         layer = []
         for i in range(self.region["rows"]):
             l.append( [[] for j in range(self.region["cols"])])
@@ -79,6 +81,14 @@
-    def writelayer(self, layername):
+    def writelayer(self, layername, filename, force=False):
+        Write out a given layer to a certain file
+        @param string name of the file to be written to
+        #TODO export to file
+        #TODO overwrite policy: to increment or to fail?
         pass
Modified: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py	2013-01-16 14:13:16 UTC (rev 54672)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py	2013-01-16 15:59:33 UTC (rev 54673)
@@ -31,10 +31,15 @@
     def test_removelayer(self):
         self.pg.layers["foo"] = [0]
+        self.pg.grassmapnames["foo"] = "foo"
         self.assertTrue(self.pg.layers.has_key("foo"))
         self.pg.removelayer("foo")
         self.assertFalse(self.pg.layers.has_key("foo"))
+        self.assertFalse(self.pg.grassmapnames.has_key("foo"))
+    def test_writelayer(self):
+        pass
 #    def tearDown(self):
Modified: grass-addons/grass7/raster/r.agent/tests/test_playground.py
--- grass-addons/grass7/raster/r.agent/tests/test_playground.py	2013-01-16 14:13:16 UTC (rev 54672)
+++ grass-addons/grass7/raster/r.agent/tests/test_playground.py	2013-01-16 15:59:33 UTC (rev 54673)
@@ -43,5 +43,8 @@
+        pass
