[GRASS-SVN] r54701 - in grass-addons/grass7/raster: . r.hants
svn_grass at osgeo.org
Fri Jan 18 04:43:42 PST 2013
Author: mmetz
Date: 2013-01-18 04:43:41 -0800 (Fri, 18 Jan 2013)
New Revision: 54701
Added:
grass-addons/grass7/raster/r.hants/
grass-addons/grass7/raster/r.hants/main.c
r.hants preparation
Modified: grass-addons/grass7/raster/r.hants/main.c
--- grass/trunk/raster/r.series/main.c 2013-01-14 20:34:35 UTC (rev 54629)
+++ grass-addons/grass7/raster/r.hants/main.c 2013-01-18 12:43:41 UTC (rev 54701)
@@ -16,6 +16,8 @@
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
+#include <limits.h>
+#include <math.h>
#include <grass/gis.h>
#include <grass/raster.h>
@@ -25,42 +27,164 @@
struct menu
stat_func *method; /* routine to compute new value */
+ stat_func_w *method_w; /* routine to compute new value (weighted) */
int is_int; /* result is an integer */
char *name; /* method name */
char *text; /* menu display - full description */
} menu[] = {
- {c_ave, 0, "average", "average value"},
- {c_count, 1, "count", "count of non-NULL cells"},
- {c_median, 0, "median", "median value"},
- {c_mode, 0, "mode", "most frequently occuring value"},
- {c_min, 0, "minimum", "lowest value"},
- {c_minx, 1, "min_raster", "raster with lowest value"},
- {c_max, 0, "maximum", "highest value"},
- {c_maxx, 1, "max_raster", "raster with highest value"},
- {c_stddev, 0, "stddev", "standard deviation"},
- {c_range, 0, "range", "range of values"},
- {c_sum, 0, "sum", "sum of values"},
- {c_var, 0, "variance", "statistical variance"},
- {c_divr, 1, "diversity", "number of different values"},
- {c_reg_m, 0, "slope", "linear regression slope"},
- {c_reg_c, 0, "offset", "linear regression offset"},
- {c_reg_r2, 0, "detcoeff", "linear regression coefficient of determination"},
- {c_reg_t, 0, "tvalue", "linear regression t-value"},
- {c_quart1, 0, "quart1", "first quartile"},
- {c_quart3, 0, "quart3", "third quartile"},
- {c_perc90, 0, "perc90", "ninetieth percentile"},
- {c_quant, 0, "quantile", "arbitrary quantile"},
- {c_skew, 0, "skewness", "skewness"},
- {c_kurt, 0, "kurtosis", "kurtosis"},
- {NULL, 0, NULL, NULL}
+ {c_ave, w_ave, 0, "average", "average value"},
+ {c_count, NULL, 1, "count", "count of non-NULL cells"},
+ {c_median, w_median, 0, "median", "median value"},
+ {c_mode, w_mode, 0, "mode", "most frequently occuring value"},
+ {c_min, NULL, 0, "minimum", "lowest value"},
+ {c_minx, NULL, 1, "min_raster", "raster with lowest value"},
+ {c_max, NULL, 0, "maximum", "highest value"},
+ {c_maxx, NULL, 1, "max_raster", "raster with highest value"},
+ {c_stddev, w_stddev, 0, "stddev", "standard deviation"},
+ {c_range, NULL, 0, "range", "range of values"},
+ {c_sum, w_sum, 0, "sum", "sum of values"},
+ {c_var, w_var, 0, "variance", "statistical variance"},
+ {c_divr, NULL, 1, "diversity", "number of different values"},
+ {c_reg_m, NULL, 0, "slope", "linear regression slope"},
+ {c_reg_c, NULL, 0, "offset", "linear regression offset"},
+ {c_reg_r2, NULL, 0, "detcoeff", "linear regression coefficient of determination"},
+ {c_reg_t, NULL, 0, "tvalue", "linear regression t-value"},
+ {c_quart1, w_quart1, 0, "quart1", "first quartile"},
+ {c_quart3, w_quart3, 0, "quart3", "third quartile"},
+ {c_perc90, w_perc90, 0, "perc90", "ninetieth percentile"},
+ {c_quant, w_quant, 0, "quantile", "arbitrary quantile"},
+ {c_skew, w_skew, 0, "skewness", "skewness"},
+ {c_kurt, w_kurt, 0, "kurtosis", "kurtosis"},
+ {NULL, NULL, 0, NULL, NULL}
+static double f_box(double x)
+ return (x > 1) ? 0
+ : 1;
+static double f_bartlett(double x)
+ : 1 - x;
+static double f_hermite(double x)
+ : (2 * x - 3) * x * x + 1;
+static double f_gauss(double x)
+ return exp(-2 * x * x) * sqrt(2 / M_PI);
+static double f_normal(double x)
+ return f_gauss(x / 2) / 2;
+static double f_sinc(double x)
+ return (x == 0) ? 1 : sin(M_PI * x) / (M_PI * x);
+static double lanczos(double x, int a)
+ return (x > a) ? 0
+ : f_sinc(x) * f_sinc(x / a);
+static double f_lanczos1(double x)
+ return lanczos(x, 1);
+static double f_lanczos2(double x)
+ return lanczos(x, 2);
+static double f_lanczos3(double x)
+ return lanczos(x, 3);
+static double f_hann(double x)
+ return cos(M_PI * x) / 2 + 0.5;
+static double f_hamming(double x)
+ return 0.46 * cos(M_PI * x) + 0.54;
+static double f_blackman(double x)
+ return cos(M_PI * x) / 2 + 0.08 * cos(2 * M_PI * x) + 0.42;
+struct window_type {
+ const char *name;
+ double (*func)(double);
+ int radius;
+} w_menu[] = {
+ {"box", f_box, 1},
+ {"bartlett", f_bartlett, 1},
+ {"gauss", f_gauss, 4},
+ {"normal", f_normal, 8},
+ {"hermite", f_hermite, 1},
+ {"sinc", f_sinc, 0},
+ {"lanczos1", f_lanczos1, 1},
+ {"lanczos2", f_lanczos2, 2},
+ {"lanczos3", f_lanczos3, 3},
+ {"hann", f_hann, 0},
+ {"hamming", f_hamming, 0},
+ {"blackman", f_blackman, 0},
+ {NULL},
+static char *build_window_list(void)
+ char *buf = G_malloc(1024);
+ char *p = buf;
+ int i;
+ for (i = 0; w_menu[i].name; i++) {
+ const char *q;
+ if (i)
+ *p++ = ',';
+ for (q = w_menu[i].name; *q; p++, q++)
+ *p = *q;
+ *p = '\0';
+ return buf;
+static int find_window(const char *name)
+ int i;
+ if (strcmp(w_menu[i].name, name) == 0)
+ return i;
+ G_fatal_error(_("Unknown window <%s>"), name);
+ return -1;
struct input
const char *name;
int fd;
DCELL *buf;
- DCELL weight;
struct output
@@ -69,6 +193,7 @@
int fd;
DCELL *buf;
stat_func *method_fn;
+ stat_func_w *method_fn_w;
double quantile;
@@ -109,20 +234,21 @@
struct GModule *module;
struct
- struct Option *input, *file, *output, *method, *weights, *quantile, *range;
+ struct Option *input, *file, *output, *method, *quantile, *range, *weight;
} parm;
struct
- struct Flag *nulls, *lazy;
+ struct Flag *nulls, *lazy, *outlier;
} flag;
int i;
int num_inputs;
- int num_weights;
struct input *inputs = NULL;
int num_outputs;
struct output *outputs = NULL;
struct History history;
DCELL *values = NULL, *values_tmp = NULL;
+ DCELL (*values_w)[2], (*values_tmp_w)[2]; /* list of neighborhood values and weights */
+ double *weights;
int nrows, ncols;
int row, col;
double lo, hi;
@@ -143,7 +269,7 @@
parm.file = G_define_standard_option(G_OPT_F_INPUT);
parm.file->key = "file";
- parm.file->description = _("Input file with one raster map name and optional one weight per line, field separator between name and weight is |");
+ parm.file->description = _("Input file with raster map names, one per line");
parm.file->required = NO;
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -157,6 +283,14 @@
parm.method->description = _("Aggregate operation");
parm.method->multiple = YES;
+ parm.weight = G_define_option();
+ parm.weight->key = "window";
+ parm.weight->type = TYPE_STRING;
+ parm.weight->required = NO;
+ parm.weight->multiple = NO;
+ parm.weight->description = _("weighing window");
+ parm.weight->options = build_window_list();
parm.quantile = G_define_option();
parm.quantile->key = "quantile";
parm.quantile->type = TYPE_DOUBLE;
@@ -165,13 +299,6 @@
parm.quantile->options = "0.0-1.0";
parm.quantile->multiple = YES;
- parm.weights = G_define_option();
- parm.weights->key = "weights";
- parm.weights->type = TYPE_DOUBLE;
- parm.weights->required = NO;
- parm.weights->description = _("Weighting factor for each input map, default value is 1.0 for each input map");
- parm.weights->multiple = YES;
parm.range = G_define_option();
parm.range->key = "range";
parm.range->type = TYPE_DOUBLE;
@@ -186,6 +313,10 @@
flag.lazy->key = 'z';
flag.lazy->description = _("Don't keep files open");
+ flag.outlier = G_define_flag();
+ flag.outlier->key = 'o';
+ flag.outlier->description = _("Remove outliers");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -193,7 +324,7 @@
lo = atof(parm.range->answers[0]);
hi = atof(parm.range->answers[1]);
if (parm.input->answer && parm.file->answer)
G_fatal_error(_("input= and file= are mutually exclusive"));
@@ -214,28 +345,15 @@
max_inputs = 0;
for (;;) {
- char buf[GNAME_MAX + 50]; /* Name and weight*/
- char tok_buf[GNAME_MAX + 50];
+ char buf[GNAME_MAX];
char *name;
- int ntokens;
- char **tokens;
struct input *p;
- double weight = 1.0;
if (!G_getl2(buf, sizeof(buf), in))
break;
- strcpy(tok_buf, buf);
- tokens = G_tokenize(tok_buf, "|");
- ntokens = G_number_of_tokens(tokens);
+ name = G_chop(buf);
- if(ntokens > 1) {
- name = G_chop(tokens[0]);
- weight = atof(G_chop(tokens[1]));
- } else {
- name = G_chop(buf);
/* Ignore empty lines */
if (!*name)
continue;
@@ -247,8 +365,7 @@
p = &inputs[num_inputs++];
p->name = G_store(name);
- p->weight = weight;
- G_verbose_message(_("Reading raster map <%s> using weight %f..."), p->name, p->weight);
+ G_verbose_message(_("Reading raster map <%s>..."), p->name);
p->buf = Rast_allocate_d_buf();
if (!flag.lazy->answer)
p->fd = Rast_open_old(p->name, "");
@@ -256,7 +373,7 @@
if (num_inputs < 1)
G_fatal_error(_("No raster map name found in input file"));
fclose(in);
else {
@@ -267,37 +384,43 @@
if (num_inputs < 1)
G_fatal_error(_("Raster map not found"));
- /* count weights */
- if(parm.weights->answers) {
- for (i = 0; parm.weights->answers[i]; i++)
- num_weights = i;
- } else {
- num_weights = 0;
- if (num_weights && num_weights != num_inputs)
- G_fatal_error(_("input= and weights= must have the same number of values"));
inputs = G_malloc(num_inputs * sizeof(struct input));
for (i = 0; i < num_inputs; i++) {
struct input *p = &inputs[i];
p->name = parm.input->answers[i];
- if(num_weights)
- p->weight = (DCELL)atof(parm.weights->answers[i]);
- else
- p->weight = 1.0;
+ /* set the weights */
+ if (parm.weight->answer) {
+ int method = find_window(parm.weight->answer);
+ double (*func)(double) = w_menu[method].func;
+ double radius = (num_inputs - 1) / 2.0;
+ values_w = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
+ values_tmp_w = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
+ weights = (DCELL *) G_malloc(num_inputs * sizeof(DCELL));
+ for (i = 0; i < num_inputs; i++) {
+ double x = fabs((i - radius) / radius);
+ if (w_menu[method].radius > 1)
+ x *= w_menu[method].radius;
+ weights[i] = (*func)(x);
+ else {
+ values_w = NULL;
+ values_tmp_w = NULL;
+ weights = NULL;
/* process the output maps */
for (i = 0; parm.output->answers[i]; i++)
@@ -317,7 +440,23 @@
int method = find_method(method_name);
out->name = output_name;
- out->method_fn = menu[method].method;
+ if (weights) {
+ if (menu[method].method_w) {
+ out->method_fn = NULL;
+ out->method_fn_w = menu[method].method_w;
+ else {
+ G_warning(_("Method %s not compatible with weighing window, using unweighed version instead"),
+ method_name);
+ out->method_fn = menu[method].method;
+ out->method_fn_w = NULL;
+ else {
out->quantile = (parm.quantile->answer && parm.quantile->answers[i])
? atof(parm.quantile->answers[i])
: 0;
@@ -353,7 +492,7 @@
for (col = 0; col < ncols; col++) {
- int null = 0;
+ int null = 0, non_null = 0;
DCELL v = inputs[i].buf[col];
@@ -364,17 +503,59 @@
Rast_set_d_null_value(&v, 1);
null = 1;
- values[i] = v * inputs[i].weight;
+ else
+ non_null++;
+ if (weights) {
+ values_w[i][0] = v;
+ values_w[i][1] = weights[i];
+ values[i] = v;
+ if (flag.outlier->answer && non_null > 5) {
+ /* remove outlier */
+ /* lower bound = 1st_Quartile - 1.5 * (3rd_Quartile - 1st_Quartile) */
+ double quart1, quart3, lower_bound;
+ memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
+ c_quart1(&quart1, values_tmp, num_inputs, NULL);
+ c_quart3(&quart3, values_tmp, num_inputs, NULL);
+ if (quart1 < quart3)
+ lower_bound = quart1 - 0.5 * (quart3 - quart1);
+ else
+ lower_bound = -1e100;
+ DCELL v = values[i];
+ if (v <= lower_bound) {
+ Rast_set_d_null_value(&v, 1);
+ null = 1;
+ /* non_null--; */
+ values[i] = v;
+ if (weights)
for (i = 0; i < num_outputs; i++) {
struct output *out = &outputs[i];
- if (null && flag.nulls->answer)
+ if (non_null < 2 || (null && flag.nulls->answer))
Rast_set_d_null_value(&out->buf[col], 1);
else {
- memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
- (*out->method_fn)(&out->buf[col], values_tmp, num_inputs, &out->quantile);
+ if (out->method_fn_w) {
+ memcpy(values_tmp_w, values_w, num_inputs * 2 * sizeof(DCELL));
+ (*out->method_fn_w)(&out->buf[col], values_tmp_w, num_inputs, &out->quantile);
+ else {
+ (*out->method_fn)(&out->buf[col], values_tmp, num_inputs, &out->quantile);
