[GRASS-SVN] r54702 - grass-addons/grass7/raster/r.hants
svn_grass at osgeo.org
Fri Jan 18 04:46:31 PST 2013
Author: mmetz
Date: 2013-01-18 04:46:30 -0800 (Fri, 18 Jan 2013)
New Revision: 54702
Added:
grass-addons/grass7/raster/r.hants/r.hants.html
Removed:
grass-addons/grass7/raster/r.hants/r.series.html
grass-addons/grass7/raster/r.hants/test_suite/
grass-addons/grass7/raster/r.hants/Makefile
grass-addons/grass7/raster/r.hants/main.c
r.hants: harmonic analysis of time series
Modified: grass-addons/grass7/raster/r.hants/Makefile
--- grass-addons/grass7/raster/r.hants/Makefile 2013-01-18 12:43:41 UTC (rev 54701)
+++ grass-addons/grass7/raster/r.hants/Makefile 2013-01-18 12:46:30 UTC (rev 54702)
@@ -1,9 +1,9 @@
MODULE_TOPDIR = ../..
-PGM = r.series
+PGM = r.hants
-LIBES = $(STATSLIB) $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(STATSDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(GMATHLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(GMATHDEP) $(RASTERDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass-addons/grass7/raster/r.hants/main.c
--- grass-addons/grass7/raster/r.hants/main.c 2013-01-18 12:43:41 UTC (rev 54701)
+++ grass-addons/grass7/raster/r.hants/main.c 2013-01-18 12:46:30 UTC (rev 54702)
@@ -1,12 +1,13 @@
- * MODULE: r.series
- * AUTHOR(S): Glynn Clements <glynn gclements.plus.com> (original contributor)
- * Hamish Bowman <hamish_b yahoo.com>, Jachym Cepicky <jachym les-ejk.cz>,
- * Martin Wegmann <wegmann biozentrum.uni-wuerzburg.de>
- * PURPOSE:
- * COPYRIGHT: (C) 2002-2008 by the GRASS Development Team
+ * MODULE: r.hants
+ * AUTHOR(S): Wout Verhoef, NLR, Remote Sensing Dept., June 1998
+ * Mohammad Abouali, converted to MATLAB, 2011
+ * Markus Metz, converted to C, 2013
+ * based on r.series
+ * PURPOSE: time series correction
+ * COPYRIGHT: (C) 2013 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -17,252 +18,140 @@
#include <stdlib.h>
#include <unistd.h>
#include <limits.h>
+#include <float.h>
#include <math.h>
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/glocale.h>
-#include <grass/stats.h>
+#include <grass/gmath.h>
-struct menu
- stat_func *method; /* routine to compute new value */
- stat_func_w *method_w; /* routine to compute new value (weighted) */
- int is_int; /* result is an integer */
- char *name; /* method name */
- char *text; /* menu display - full description */
-} menu[] = {
- {c_ave, w_ave, 0, "average", "average value"},
- {c_count, NULL, 1, "count", "count of non-NULL cells"},
- {c_median, w_median, 0, "median", "median value"},
- {c_mode, w_mode, 0, "mode", "most frequently occuring value"},
- {c_min, NULL, 0, "minimum", "lowest value"},
- {c_minx, NULL, 1, "min_raster", "raster with lowest value"},
- {c_max, NULL, 0, "maximum", "highest value"},
- {c_maxx, NULL, 1, "max_raster", "raster with highest value"},
- {c_stddev, w_stddev, 0, "stddev", "standard deviation"},
- {c_range, NULL, 0, "range", "range of values"},
- {c_sum, w_sum, 0, "sum", "sum of values"},
- {c_var, w_var, 0, "variance", "statistical variance"},
- {c_divr, NULL, 1, "diversity", "number of different values"},
- {c_reg_m, NULL, 0, "slope", "linear regression slope"},
- {c_reg_c, NULL, 0, "offset", "linear regression offset"},
- {c_reg_r2, NULL, 0, "detcoeff", "linear regression coefficient of determination"},
- {c_reg_t, NULL, 0, "tvalue", "linear regression t-value"},
- {c_quart1, w_quart1, 0, "quart1", "first quartile"},
- {c_quart3, w_quart3, 0, "quart3", "third quartile"},
- {c_perc90, w_perc90, 0, "perc90", "ninetieth percentile"},
- {c_quant, w_quant, 0, "quantile", "arbitrary quantile"},
- {c_skew, w_skew, 0, "skewness", "skewness"},
- {c_kurt, w_kurt, 0, "kurtosis", "kurtosis"},
- {NULL, NULL, 0, NULL, NULL}
-static double f_box(double x)
- return (x > 1) ? 0
- : 1;
-static double f_bartlett(double x)
+struct input
- : 1 - x;
+ const char *name;
+ int fd;
+ DCELL *buf;
-static double f_hermite(double x)
+struct output
- : (2 * x - 3) * x * x + 1;
-static double f_gauss(double x)
- return exp(-2 * x * x) * sqrt(2 / M_PI);
-static double f_normal(double x)
- return f_gauss(x / 2) / 2;
-static double f_sinc(double x)
- return (x == 0) ? 1 : sin(M_PI * x) / (M_PI * x);
-static double lanczos(double x, int a)
- return (x > a) ? 0
- : f_sinc(x) * f_sinc(x / a);
-static double f_lanczos1(double x)
- return lanczos(x, 1);
-static double f_lanczos2(double x)
- return lanczos(x, 2);
-static double f_lanczos3(double x)
- return lanczos(x, 3);
-static double f_hann(double x)
- return cos(M_PI * x) / 2 + 0.5;
-static double f_hamming(double x)
- return 0.46 * cos(M_PI * x) + 0.54;
-static double f_blackman(double x)
- return cos(M_PI * x) / 2 + 0.08 * cos(2 * M_PI * x) + 0.42;
-struct window_type {
const char *name;
- double (*func)(double);
- int radius;
-} w_menu[] = {
- {"box", f_box, 1},
- {"bartlett", f_bartlett, 1},
- {"gauss", f_gauss, 4},
- {"normal", f_normal, 8},
- {"hermite", f_hermite, 1},
- {"sinc", f_sinc, 0},
- {"lanczos1", f_lanczos1, 1},
- {"lanczos2", f_lanczos2, 2},
- {"lanczos3", f_lanczos3, 3},
- {"hann", f_hann, 0},
- {"hamming", f_hamming, 0},
- {"blackman", f_blackman, 0},
- {NULL},
+ int fd;
+ DCELL *buf;
-static char *build_window_list(void)
+static int solvemat(double **m, double a[], double B[], int n)
- char *buf = G_malloc(1024);
- char *p = buf;
- int i;
+ int i, j, i2, j2, imark;
+ double factor, temp;
+ double pivot; /* ACTUAL VALUE OF THE LARGEST PIVOT CANDIDATE */
- for (i = 0; w_menu[i].name; i++) {
- const char *q;
+ for (i = 0; i < n; i++) {
+ j = i;
- if (i)
- *p++ = ',';
- for (q = w_menu[i].name; *q; p++, q++)
- *p = *q;
- *p = '\0';
+ /* find row with largest magnitude value for pivot value */
- return buf;
+ pivot = m[i][j];
+ imark = i;
+ for (i2 = i + 1; i2 < n; i2++) {
+ temp = fabs(m[i2][j]);
+ if (temp > fabs(pivot)) {
+ pivot = m[i2][j];
+ imark = i2;
-static int find_window(const char *name)
- int i;
+ /* if the pivot is very small then the points are nearly co-linear */
+ /* co-linear points result in an undefined matrix, and nearly */
+ /* co-linear points results in a solution with rounding error */
- if (strcmp(w_menu[i].name, name) == 0)
- return i;
+ if (pivot == 0.0) {
+ G_warning(_("Matrix is unsolvable"));
+ return 0;
- G_fatal_error(_("Unknown window <%s>"), name);
+ /* if row with highest pivot is not the current row, switch them */
- return -1;
+ if (imark != i) {
+ for (j2 = 0; j2 < n; j2++) {
+ temp = m[imark][j2];
+ m[imark][j2] = m[i][j2];
+ m[i][j2] = temp;
-struct input
- const char *name;
- int fd;
- DCELL *buf;
+ temp = a[imark];
+ a[imark] = a[i];
+ a[i] = temp;
-struct output
- const char *name;
- int fd;
- DCELL *buf;
- stat_func *method_fn;
- stat_func_w *method_fn_w;
- double quantile;
+ /* compute zeros above and below the pivot, and compute
+ values for the rest of the row as well */
-static char *build_method_list(void)
- char *p = buf;
- int i;
+ for (i2 = 0; i2 < n; i2++) {
+ if (i2 != i) {
+ factor = m[i2][j] / pivot;
+ for (j2 = j; j2 < n; j2++)
+ m[i2][j2] -= factor * m[i][j2];
+ a[i2] -= factor * a[i];
- for (i = 0; menu[i].name; i++) {
- char *q;
+ /* SINCE ALL OTHER VALUES IN THE MATRIX ARE ZERO NOW, CALCULATE THE
+ COEFFICIENTS BY DIVIDING THE COLUMN VECTORS BY THE DIAGONAL VALUES. */
- if (i)
- *p++ = ',';
- for (q = menu[i].name; *q; p++, q++)
- *p = *q;
+ B[i] = a[i] / m[i][i];
- *p = '\0';
- return buf;
+ return 1;
-static int find_method(const char *method_name)
- int i;
- if (strcmp(menu[i].name, method_name) == 0)
- return i;
- G_fatal_error(_("Unknown method <%s>"), method_name);
- return -1;
int main(int argc, char *argv[])
struct GModule *module;
struct
- struct Option *input, *file, *output, *method, *quantile, *range, *weight;
+ struct Option *input, *file,
+ *nf, /* number of harmonics */
+ *fet, /* fit error tolerance */
+ *dod, /* degree of over-determination */
+ *range, /* low/high threshold */
+ *ts, /* time steps*/
+ *bl, /* length of base period */
+ *delta; /* threshold for high amplitudes */
} parm;
struct
- struct Flag *nulls, *lazy, *outlier;
+ struct Flag *lo, *hi, *lazy;
} flag;
- int i;
+ int i, j, k;
int num_inputs;
struct input *inputs = NULL;
int num_outputs;
struct output *outputs = NULL;
struct History history;
- DCELL *values = NULL, *values_tmp = NULL;
- DCELL (*values_w)[2], (*values_tmp_w)[2]; /* list of neighborhood values and weights */
- double *weights;
+ DCELL *values = NULL, *rc = NULL;
int nrows, ncols;
int row, col;
- double lo, hi;
+ double lo, hi, fet, *cs, *sn, *ts, delta;
+ int bl;
+ double **mat, **mat_t, **A, *za, *zr, maxerrlo, maxerrhi;
+ int dod, nf, nr, nout, noutmax;
+ int rejlo, rejhi, *useval, dumped;
G_gisinit(argv[0]);
module = G_define_module();
G_add_keyword(_("raster"));
- G_add_keyword(_("aggregation"));
G_add_keyword(_("series"));
+ G_add_keyword(_("filtering"));
module->description =
- _("Makes each output cell value a "
- "function of the values assigned to the corresponding cells "
- "in the input raster map layers.");
+ _("Approximates a periodic time series "
+ "and creates approximated output.");
parm.input = G_define_standard_option(G_OPT_R_INPUTS);
parm.input->required = NO;
@@ -272,58 +161,65 @@
parm.file->description = _("Input file with raster map names, one per line");
parm.file->required = NO;
- parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
- parm.output->multiple = YES;
+ parm.nf = G_define_option();
+ parm.nf->key = "nf";
+ parm.nf->type = TYPE_INTEGER;
+ parm.nf->required = YES;
+ parm.nf->description = _("Number of frequencies");
+ parm.nf->multiple = YES;
- parm.method = G_define_option();
- parm.method->key = "method";
- parm.method->type = TYPE_STRING;
- parm.method->required = YES;
- parm.method->options = build_method_list();
- parm.method->description = _("Aggregate operation");
- parm.method->multiple = YES;
+ parm.fet = G_define_option();
+ parm.fet->key = "fet";
+ parm.fet->type = TYPE_DOUBLE;
+ parm.fet->required = NO;
+ parm.fet->multiple = NO;
+ parm.fet->description = _("Fit error tolerance");
- parm.weight = G_define_option();
- parm.weight->key = "window";
- parm.weight->type = TYPE_STRING;
- parm.weight->required = NO;
- parm.weight->multiple = NO;
- parm.weight->description = _("weighing window");
- parm.weight->options = build_window_list();
+ parm.dod = G_define_option();
+ parm.dod->key = "dod";
+ parm.dod->type = TYPE_INTEGER;
+ parm.dod->required = NO;
+ parm.dod->answer = "0";
+ parm.dod->description = _("Degree of over-determination");
- parm.quantile = G_define_option();
- parm.quantile->key = "quantile";
- parm.quantile->type = TYPE_DOUBLE;
- parm.quantile->required = NO;
- parm.quantile->description = _("Quantile to calculate for method=quantile");
- parm.quantile->options = "0.0-1.0";
- parm.quantile->multiple = YES;
parm.range = G_define_option();
parm.range->key = "range";
parm.range->type = TYPE_DOUBLE;
parm.range->key_desc = "lo,hi";
parm.range->description = _("Ignore values outside this range");
- flag.nulls = G_define_flag();
- flag.nulls->key = 'n';
- flag.nulls->description = _("Propagate NULLs");
+ parm.ts = G_define_option();
+ parm.ts->key = "time_steps";
+ parm.ts->type = TYPE_DOUBLE;
+ parm.ts->multiple = YES;
+ parm.ts->description = _("Time steps of the input maps");
+ parm.bl = G_define_option();
+ parm.bl->key = "base_period";
+ parm.bl->type = TYPE_INTEGER;
+ parm.bl->description = _("Length of the base period");
+ parm.delta = G_define_option();
+ parm.delta->key = "base_period";
+ parm.delta->type = TYPE_DOUBLE;
+ parm.delta->answer = "0";
+ parm.delta->description = _("Threshold for high amplitudes");
+ flag.lo = G_define_flag();
+ flag.lo->key = 'l';
+ flag.lo->description = _("Reject low outliers");
+ flag.hi = G_define_flag();
+ flag.hi->key = 'h';
+ flag.hi->description = _("Reject high outliers");
flag.lazy = G_define_flag();
flag.lazy->key = 'z';
flag.lazy->description = _("Don't keep files open");
- flag.outlier = G_define_flag();
- flag.outlier->key = 'o';
- flag.outlier->description = _("Remove outliers");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (parm.range->answer) {
- lo = atof(parm.range->answers[0]);
- hi = atof(parm.range->answers[1]);
if (parm.input->answer && parm.file->answer)
G_fatal_error(_("input= and file= are mutually exclusive"));
@@ -331,7 +227,36 @@
if (!parm.input->answer && !parm.file->answer)
G_fatal_error(_("Please specify input= or file="));
+ nf = atoi(parm.nf->answer);
+ if (nf < 1)
+ G_fatal_error(_("The number of frequencies must be > 0"));
+ fet = DBL_MAX;
+ if (parm.fet->answer) {
+ fet = atof(parm.fet->answer);
+ if (fet < 0)
+ G_fatal_error(_("The fit error tolerance must be >= 0"));
+ dod = 0;
+ if (parm.dod->answer) {
+ dod = atoi(parm.dod->answer);
+ if (dod < 0)
+ G_fatal_error(_("The degree of over-determination must be >= 0"));
+ lo = -DBL_MAX;
+ hi = DBL_MAX;
+ if (parm.range->answer) {
+ lo = atof(parm.range->answers[0]);
+ hi = atof(parm.range->answers[1]);
+ delta = 0;
+ if (parm.delta->answer) {
+ delta = atof(parm.delta->answer);
+ rejlo = flag.lo->answer;
+ rejhi = flag.hi->answer;
/* process the input maps from the file */
if (parm.file->answer) {
FILE *in;
@@ -397,84 +322,105 @@
- /* set the weights */
- if (parm.weight->answer) {
- int method = find_window(parm.weight->answer);
- double (*func)(double) = w_menu[method].func;
- double radius = (num_inputs - 1) / 2.0;
+ /* length of base period */
+ if (parm.bl->answer)
+ bl = atoi(parm.bl->answer);
+ else
+ bl = num_inputs;
+ num_outputs = num_inputs;
+ outputs = G_calloc(num_outputs, sizeof(struct output));
+ for (i = 0; i < num_outputs; i++) {
+ struct output *out = &outputs[i];
+ char output_name[GNAME_MAX];
- values_w = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
- values_tmp_w = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
- weights = (DCELL *) G_malloc(num_inputs * sizeof(DCELL));
+ sprintf(output_name, "%s_hants", inputs[i].name);
- for (i = 0; i < num_inputs; i++) {
- double x = fabs((i - radius) / radius);
+ out->name = G_store(output_name);
+ out->buf = Rast_allocate_d_buf();
+ out->fd = Rast_open_new(output_name, DCELL_TYPE);
- if (w_menu[method].radius > 1)
- x *= w_menu[method].radius;
- weights[i] = (*func)(x);
+ /* initialise variables */
+ values = G_malloc(num_inputs * sizeof(DCELL));
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ cs = G_alloc_vector(bl);
+ sn = G_alloc_vector(bl);
+ ts = G_alloc_vector(num_inputs);
+ rc = G_malloc(num_inputs * sizeof(DCELL));
+ useval = G_malloc(num_inputs * sizeof(int));
+ if (parm.ts->answer) {
+ for (i = 0; parm.ts->answers[i]; i++);
+ if (i != num_inputs)
+ G_fatal_error(_("Number of time steps does not match number of input maps"));
+ ts[i] = atof(parm.ts->answers[i]);
else {
- values_w = NULL;
- values_tmp_w = NULL;
- weights = NULL;
+ for (i = 0; i < num_inputs; i++) {
+ ts[i] = i;
+ if (2 * nf + 1 < num_inputs)
+ nr = 2 * nf + 1;
+ else
+ nr = num_inputs;
- /* process the output maps */
- for (i = 0; parm.output->answers[i]; i++)
- num_outputs = i;
+ noutmax = num_inputs - nr - dod;
- for (i = 0; parm.method->answers[i]; i++)
- if (num_outputs != i)
- G_fatal_error(_("output= and method= must have the same number of values"));
+ /* are the dimensions correct ? */
+ mat = G_alloc_matrix(nr, num_inputs);
+ mat_t = G_alloc_matrix(num_inputs, nr);
+ A = G_alloc_matrix(nr, nr);
+ za = G_alloc_vector(nr);
+ zr = G_alloc_vector(nr);
+ rc = G_alloc_vector(num_inputs);
- outputs = G_calloc(num_outputs, sizeof(struct output));
+ for (i = 0; i < bl; i++) {
+ double ang = 2.0 * M_PI * i / bl;
- for (i = 0; i < num_outputs; i++) {
- struct output *out = &outputs[i];
- const char *output_name = parm.output->answers[i];
- const char *method_name = parm.method->answers[i];
- int method = find_method(method_name);
+ cs[i] = cos(ang);
+ sn[i] = sin(ang);
+ for (j = 0; j < num_inputs; j++) {
+ mat[0][j] = 1.;
+ mat_t[j][0] = 1.;
- out->name = output_name;
- if (weights) {
- if (menu[method].method_w) {
- out->method_fn = NULL;
- out->method_fn_w = menu[method].method_w;
- else {
- G_warning(_("Method %s not compatible with weighing window, using unweighed version instead"),
- method_name);
+ for (i = 0; i < nr / 2; i++) {
+ int i1 = 2 * i + 1;
+ int i2 = 2 * i + 2;
+ int idx = (int) ((i + 1) * (ts[j] - 1)) % bl;
+ if (idx >= bl)
+ G_fatal_error("cs/sn index out of range: %d, %d", idx, bl);
+ if (i2 >= nr)
+ G_fatal_error("mat index out of range: %d, %d", 2 * i + 2, nr);
- out->method_fn = menu[method].method;
- out->method_fn_w = NULL;
+ mat[i1][j] = cs[idx];
+ mat[i2][j] = sn[idx];
+ mat_t[j][i1] = mat[i1][j];
+ mat_t[j][i2] = mat[i2][j];
- else {
- out->quantile = (parm.quantile->answer && parm.quantile->answers[i])
- ? atof(parm.quantile->answers[i])
- : 0;
- out->buf = Rast_allocate_d_buf();
- out->fd = Rast_open_new(output_name,
- menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
- /* initialise variables */
- values = G_malloc(num_inputs * sizeof(DCELL));
- values_tmp = G_malloc(num_inputs * sizeof(DCELL));
- nrows = Rast_window_rows();
- ncols = Rast_window_cols();
/* process the data */
G_verbose_message(_("Percent complete..."));
+ dumped = 0;
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
@@ -497,67 +443,152 @@
DCELL v = inputs[i].buf[col];
- if (Rast_is_d_null_value(&v))
- null = 1;
+ useval[i] = 0;
+ if (Rast_is_d_null_value(&v)) {
+ null++;
else if (parm.range->answer && (v < lo || v > hi)) {
Rast_set_d_null_value(&v, 1);
- null = 1;
+ null++;
- else
+ else {
non_null++;
+ useval[i] = 1;
- if (weights) {
- values_w[i][0] = v;
- values_w[i][1] = weights[i];
values[i] = v;
+ nout = null;
- if (flag.outlier->answer && non_null > 5) {
- /* remove outlier */
- /* lower bound = 1st_Quartile - 1.5 * (3rd_Quartile - 1st_Quartile) */
- double quart1, quart3, lower_bound;
+ /* HANTS */
+ if (nout <= noutmax) {
+ int n = 0, done = 0;
- memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
- c_quart1(&quart1, values_tmp, num_inputs, NULL);
- c_quart3(&quart3, values_tmp, num_inputs, NULL);
+ while (!done) {
+ /* za = mat * y */
- if (quart1 < quart3)
- lower_bound = quart1 - 0.5 * (quart3 - quart1);
- else
- lower_bound = -1e100;
+ /* A = mat * diag(p) * mat' */
- DCELL v = values[i];
+ /* mat: nr, num_inputs
+ * diag(p): num_inputs, num_inputs
+ * mat_t: num_inputs, nr
+ * A temp: nr, num_inputs
+ * A: nr, nr */
- if (v <= lower_bound) {
- Rast_set_d_null_value(&v, 1);
- null = 1;
- /* non_null--; */
- values[i] = v;
- if (weights)
+ for (i = 0; i < nr; i++) {
+ za[i] = 0;
+ if (useval[j])
+ za[i] += mat[i][j] * values[j];
+ for (j = 0; j < nr; j++) {
+ A[i][j] = 0;
+ for (k = 0; k < num_inputs; k++) {
+ if (useval[k])
+ A[i][j] += mat[i][k] * mat_t[k][j];
+ if (i > 0 && i == j)
+ A[i][j] += delta;
+ /* zr = A \ za
+ * solve A * zr = za */
+ if (!solvemat(A, za, zr, nr)) {
+ fprintf(stdout, "za:\n");
+ fprintf(stdout, "%g\n", za[i]);
+ fprintf(stdout, "matrix A:\n");
+ fprintf(stdout, "%g ", M(A, i, j));
+ fprintf(stdout, "\n");
- if (non_null < 2 || (null && flag.nulls->answer))
- Rast_set_d_null_value(&out->buf[col], 1);
- else {
- if (out->method_fn_w) {
- memcpy(values_tmp_w, values_w, num_inputs * 2 * sizeof(DCELL));
- (*out->method_fn_w)(&out->buf[col], values_tmp_w, num_inputs, &out->quantile);
+ G_fatal_error(_("Unable to solve matrix!"));
+ done = -1;
+ Rast_set_d_null_value(rc, num_outputs);
+ break;
- else {
- (*out->method_fn)(&out->buf[col], values_tmp, num_inputs, &out->quantile);
+ /* rc = mat' * zr */
+ maxerrlo = maxerrhi = 0;
+ rc[i] = 0;
+ rc[i] += mat_t[i][j] * zr[j];
+ if (useval[i]) {
+ if (maxerrlo < rc[i] - values[i])
+ maxerrlo = rc[i] - values[i];
+ if (maxerrhi < values[i] - rc[i])
+ maxerrhi = values[i] - rc[i];
+ if (rejlo && maxerrlo < fet) {
+ done = 1;
+ if (rejhi && maxerrhi < fet) {
+ done = 1;
+ if (!done && (rejlo || rejhi)) {
+ /* filter outliers */
+ if (useval[i]) {
+ if (rejlo && rc[i] - values[i] > maxerrlo * 0.5) {
+ useval[i] = 0;
+ nout++;
+ if (rejhi && values[i] - rc[i] > maxerrhi * 0.5) {
+ useval[i] = 0;
+ nout++;
+ n++;
+ if (n >= num_inputs)
+ done = 1;
+ if (nout > noutmax)
+ done = 1;
+ out->buf[col] = rc[i];
+ if (non_null >= 20 && done == 1 && !dumped &&
+ row > nrows / 3 && col > ncols / 2 ) {
+#if 0
+ fprintf(stdout, "%g;%g\n", values[i], rc[i]);
+#endif
+ dumped = 1;
+ else {
+ Rast_set_d_null_value(&out->buf[col], 1);
Copied: grass-addons/grass7/raster/r.hants/r.hants.html (from rev 54701, grass-addons/grass7/raster/r.hants/r.series.html)
--- grass-addons/grass7/raster/r.hants/r.hants.html (rev 0)
+++ grass-addons/grass7/raster/r.hants/r.hants.html 2013-01-18 12:46:30 UTC (rev 54702)
@@ -0,0 +1,69 @@
+<h2>DESCRIPTION</h2>
+<em>r.hants</em> performs a harmonic analysis of time series in order to
+estimate missing values and identify outliers. For each input map, an
+output map with the suffix <em>_hants</em> is created.
+The option <b>nf</b>, number of frequencies, should be carefully chosen.
+Different numbers of frequencies should be tested first on a small test
+region before running the module on the full region. As a rule of thumb,
+the number of frequencies should be at least
+<em>estimated periodicity + 3</em>, e.g. for NDVI with an annual cycle
+(one peak per year), the number of frequencies should be at least 4 when
+analysing one year. If two peaks are assumed per year, the number of
+frequencies should be at least 5 when analysing one year.
+<h2>NOTES</h2>
+<p>
+If the <em>range=</em> option is given, any values which fall outside
+that range will be treated as if they were NULL.
+The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
+values outside of this range are treated as NULL (i.e., they will be
+ignored by most aggregates, or will cause the result to be NULL if -n is given).
+<p>
+The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
+<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
+negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
+<p>
+The number of raster maps to be processed is given by the limit of the
+operating system. For example, both the hard and soft limits are
+typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
+1500</tt> (UNIX-based operating systems) but not higher than the hard
+limit. If it is too low, you can as superuser add an entry in
+<div class="code"><pre>
+/etc/security/limits.conf
+# <domain> <type> <item> <value>
+your_username hard nofile 1500
+</pre></div>
+This would raise the hard limit to 1500 file. Be warned that more
+files open need more RAM.
+<p>Use the <em>file</em> option to analyze large amount of raster maps
+without hitting open files limit and the size limit of command line
+arguments. The computation is slower than the <em>input</em> option
+method. For every single row in the output map(s) all input maps are
+opened and closed. The amount of RAM will rise linear with the number of
+specified input maps. The input and file options are mutually exclusive.
+Input is a text file with a new line separated list of raster map names
+and optional weights. As separator between the map name and the weight
+the charachter | must be used.
+<h2>REFERENCES</h2>
+<p>
+Roerink, G. J., Menenti, M. and Verhoef, W., 2000. Reconstructing
+cloudfree NDVI composites using Fourier analysis of time series.
+International Journal of Remote Sensing, 21 (9), 1911-1917.
+DOI: <a href=http://dx.doi.org/10.1080/014311600209814>10.1080/014311600209814</a>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster/r.hants/r.series.html
--- grass-addons/grass7/raster/r.hants/r.series.html 2013-01-18 12:43:41 UTC (rev 54701)
+++ grass-addons/grass7/raster/r.hants/r.series.html 2013-01-18 12:46:30 UTC (rev 54702)
@@ -1,147 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.series</em> makes each output cell value a function of the values
-assigned to the corresponding cells in the input raster map layers.
-Following methods are available:
-<ul>
- <li>average: average value
- <li>count: count of non-NULL cells
- <li>median: median value
- <li>mode: most frequently occuring value
- <li>minimum: lowest value
- <li>maximum: highest value
- <li>range: range of values (max - min)
- <li>stddev: standard deviation
- <li>sum: sum of values
- <li>variance: statistical variance
- <li>diversity: number of different values
- <li>slope: linear regression slope
- <li>offset: linear regression offset
- <li>detcoeff: linear regression coefficient of determination
- <li>tvalue: linear regression t-value
- <li>min_raster: raster map number with the minimum time-series value
- <li>max_raster: raster map number with the maximum time-series value
- </ul>
-<h2>NOTES</h2>
-With <em>-n</em> flag, any cell for which any of the corresponding input cells are
-NULL is automatically set to NULL (NULL propagation). The aggregate function is not
-called, so all methods behave this way with respect to the <em>-n</em> flag.
-<p>Without <em>-n</em> flag, the complete list of inputs for each cell (including
-NULLs) is passed to the aggregate function. Individual aggregates can
-handle data as they choose. Mostly, they just compute the aggregate
-over the non-NULL values, producing a NULL result only if all inputs
-are NULL.
-<p>The <em>min_raster</em> and <em>max_raster</em> methods generate a map with the
-number of the raster map that holds the minimum/maximum value of the
-time-series. The numbering starts at <em>0</em> up to <em>n</em> for the
-first and the last raster listed in <em>input=</em>, respectively.
-<p>If the <em>range=</em> option is given, any values which fall outside
-that range will be treated as if they were NULL.
-The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
-values outside of this range are treated as NULL (i.e., they will be
-ignored by most aggregates, or will cause the result to be NULL if -n is given).
-The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
-<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
-negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
-<p>Linear regression (slope, offset, coefficient of determination, t-value) assumes equal time intervals.
-If the data have irregular time intervals, NULL raster maps can be inserted into time series
-to make time intervals equal (see example).
-<p>Number of raster maps to be processed is given by the limit of the
-operating system. For example, both the hard and soft limits are
-typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
-1500</tt> (UNIX-based operating systems) but not higher than the hard
-limit. If it is too low, you can as superuser add an entry in
-<div class="code"><pre>
-/etc/security/limits.conf
-# <domain> <type> <item> <value>
-your_username hard nofile 1500
-</pre></div>
-This would raise the hard limit to 1500 file. Be warned that more
-files open need more RAM.
-For each map a weighting factor can be specified using the <em>weights</em> option.
-Using weights can be meaningful when computing sum or average of maps with different
-temporal extent. The default weight is 1.0. The number of weights must be identical
-with the number of input maps and must have the same order. Weights can also be specified in the
-input file.
-<p>Use the <em>file</em> option to analyze large amount of raster maps without
-hitting open files limit and the size limit of command line arguments.
-The computation is slower than the <em>input</em> option method.
-For every sinlge row in the output map(s)
-all input maps are opened and closed. The amount of RAM will rise linear
-with the number of specified input maps. The input and file options are mutually exclusive.
-Input is a text file with a new line separated list of raster map names and optional weights.
-As separator between the map name and the weight the charachter | must be used.
-<h2>EXAMPLES</h2>
-Using <em>r.series</em> with wildcards:
-<br>
-r.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
- output=insitu_data.stddev method=stddev
-</pre></div>
-<p>Note the <em>g.mlist</em> script also supports regular expressions for
-selecting map names.
-<p>Using <em>r.series</em> with NULL raster maps:
-<br>
-r.mapcalc "dummy = null()"
-r.series in=map2001,map2002,dummy,dummy,map2005,map2006,dummy,map2008 \
- out=res_slope,res_offset,res_coeff meth=slope,offset,detcoeff
-</pre></div>
-<p>Example for multiple aggregates to be computed in one run (3 resulting aggregates
-from two input maps):
-r.series in=one,two out=result_avg,res_slope,result_count meth=sum,slope,count
-</pre></div>
-<p>Example to use the file option of r.series:
-cat > input.txt << EOF
-map1
-map2
-map3
-EOF
-r.series file=input.txt out=result_sum meth=sum
-</pre></div>
-<p>Example to use the file option of r.series including weights. The weight 0.75
-should be assigned to map2. As the other maps do not have weights we can leave it out:
-map1
-map2|0.75
-map3
-EOF
-</pre></div>
-<p>
-Example for counting the number of days above a certain temperature using
-daily average maps ('???' as DOY wildcard):
-r.series input=`g.mlist rast pat="temp_2003_???_avg" sep=,` \
- output=temp_2003_days_over_25deg range=25.0,100.0 method=count
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="g.mlist.html">g.mlist</a></em>,
-<em><a href="g.region.html">g.region</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements
-<p><i>Last changed: $Date$</i>
