[GRASS-SVN] r54703 - grass-addons/grass7/raster/r.hants
svn_grass at osgeo.org
Fri Jan 18 11:49:01 PST 2013
Author: mmetz
Date: 2013-01-18 11:49:00 -0800 (Fri, 18 Jan 2013)
New Revision: 54703
grass-addons/grass7/raster/r.hants/main.c
r.hants code cleanup
Modified: grass-addons/grass7/raster/r.hants/main.c
--- grass-addons/grass7/raster/r.hants/main.c 2013-01-18 12:46:30 UTC (rev 54702)
+++ grass-addons/grass7/raster/r.hants/main.c 2013-01-18 19:49:00 UTC (rev 54703)
@@ -26,8 +26,8 @@
#include <grass/glocale.h>
#include <grass/gmath.h>
+/* TODO: add option for amplitude and phase output */
struct input
const char *name;
@@ -115,7 +115,7 @@
struct GModule *module;
struct
- struct Option *input, *file,
+ struct Option *input, *file, *suffix,
*nf, /* number of harmonics */
*fet, /* fit error tolerance */
*dod, /* degree of over-determination */
@@ -133,6 +133,7 @@
struct input *inputs = NULL;
int num_outputs;
struct output *outputs = NULL;
+ char *suffix;
struct History history;
DCELL *values = NULL, *rc = NULL;
int nrows, ncols;
@@ -161,6 +162,14 @@
parm.file->description = _("Input file with raster map names, one per line");
parm.file->required = NO;
+ parm.suffix = G_define_option();
+ parm.suffix->key = "suffix";
+ parm.suffix->type = TYPE_STRING;
+ parm.suffix->required = NO;
+ parm.suffix->answer = "_hants";
+ parm.suffix->label = _("Suffix for output maps");
+ parm.suffix->description = _("The suffix will be appended to input map names");
parm.nf = G_define_option();
parm.nf->key = "nf";
parm.nf->type = TYPE_INTEGER;
@@ -200,10 +209,11 @@
parm.bl->description = _("Length of the base period");
parm.delta = G_define_option();
- parm.delta->key = "base_period";
+ parm.delta->key = "delta";
parm.delta->type = TYPE_DOUBLE;
parm.delta->answer = "0";
- parm.delta->description = _("Threshold for high amplitudes");
+ parm.delta->label = _("Threshold for high amplitudes");
+ parm.delta->description = _("Delta should be between 0 and 1");
flag.lo = G_define_flag();
flag.lo->key = 'l';
@@ -252,10 +262,14 @@
delta = 0;
if (parm.delta->answer) {
delta = atof(parm.delta->answer);
+ if (delta < 0 || delta > 1)
+ G_fatal_error(_("The threshold for high amplitudes must be >= 0 and <= 1"));
rejlo = flag.lo->answer;
rejhi = flag.hi->answer;
+ if ((rejlo || rejhi) && !parm.fet->answer)
+ G_fatal_error(_("Fit error tolerance is required when outliers should be rejected"));
/* process the input maps from the file */
if (parm.file->answer) {
@@ -321,6 +335,8 @@
p->fd = Rast_open_old(p->name, "");
+ if (num_inputs < 3)
+ G_fatal_error(_("At least 3 input maps are required"));
/* length of base period */
if (parm.bl->answer)
@@ -331,12 +347,16 @@
num_outputs = num_inputs;
outputs = G_calloc(num_outputs, sizeof(struct output));
+ suffix = parm.suffix->answer;
+ if (!suffix)
+ suffix = "_hants";
for (i = 0; i < num_outputs; i++) {
struct output *out = &outputs[i];
char output_name[GNAME_MAX];
- sprintf(output_name, "%s_hants", inputs[i].name);
+ sprintf(output_name, "%s%s", inputs[i].name, suffix);
out->name = G_store(output_name);
out->buf = Rast_allocate_d_buf();
@@ -415,14 +435,13 @@
/* process the data */
- G_verbose_message(_("Percent complete..."));
+ G_message(_("Harmonic analysis of %d input maps..."), num_inputs);
dumped = 0;
for (row = 0; row < nrows; row++) {
- G_percent(row, nrows, 2);
+ G_percent(row, nrows, 4);
if (flag.lazy->answer) {
/* Open the files only on run time */
@@ -489,34 +508,19 @@
if (useval[k])
A[i][j] += mat[i][k] * mat_t[k][j];
- if (i > 0 && i == j)
- A[i][j] += delta;
+ if (i > 0)
+ A[i][i] += delta;
/* zr = A \ za
* solve A * zr = za */
if (!solvemat(A, za, zr, nr)) {
- fprintf(stdout, "za:\n");
- for (i = 0; i < nr; i++)
- fprintf(stdout, "%g\n", za[i]);
- fprintf(stdout, "matrix A:\n");
- for (i = 0; i < nr; i++) {
- for (j = 0; j < nr; j++) {
- fprintf(stdout, "%g ", M(A, i, j));
- fprintf(stdout, "\n");
- G_fatal_error(_("Unable to solve matrix!"));
done = -1;
Rast_set_d_null_value(rc, num_outputs);
break;
+ /* G_math_solver_gauss(A, zr, za, nr) is much slower */
/* rc = mat' * zr */
maxerrlo = maxerrhi = 0;
@@ -533,13 +537,13 @@
- if (rejlo && maxerrlo < fet) {
+ if (rejlo || rejhi) {
done = 1;
+ if (rejlo && maxerrlo > fet)
+ done = 0;
+ if (rejhi && maxerrhi > fet)
+ done = 0;
- if (rejhi && maxerrhi < fet) {
- done = 1;
if (!done && (rejlo || rejhi)) {
/* filter outliers */
@@ -571,6 +575,8 @@
out->buf[col] = rc[i];
+ /* DEBUG
+ * dump original and approximated values for one cell to stdout */
if (non_null >= 20 && done == 1 && !dumped &&
row > nrows / 3 && col > ncols / 2 ) {
#if 0
@@ -581,6 +587,20 @@
dumped = 1;
+#if 0
+ /* amplitude and phase */
+ amp[0] = zr[0];
+ phase[0] = 0;
+ for (i = 1; i < nr; i += 2) {
+ int ifr = (i + 1) / 2;
+ double angle = atan2(zr[i + 1], zr[i]) * 180 / M_PI;
+ if (angle < 0)
+ angle += 360;
+ phase[ifr] = angle;
+ amp[ifr] = sqrt(zr[i] * zr[i] + zr[i + 1] * zr[i + 1]);
+#endif
else {
