[GRASS-SVN] r56994 - grass/branches/develbranch_6/scripts/g.extension
svn_grass at osgeo.org
Wed Jul 3 02:24:05 PDT 2013
Author: hamish
Date: 2013-07-03 02:24:05 -0700 (Wed, 03 Jul 2013)
New Revision: 56994
grass/branches/develbranch_6/scripts/g.extension/g.extension
buxfix: system-wide and sudo installs weren't working since default prefix answer was always set; don't need to be root to install to , just have the correct permissions; remove useless curly brackets.
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension 2013-07-03 09:03:36 UTC (rev 56993)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension 2013-07-03 09:24:05 UTC (rev 56994)
@@ -207,7 +207,16 @@
fi
-if [ "$PREFIX" = '$GRASS_ADDON_PATH' ] ; then
+if [ "$PREFIX" = '$GISBASE' ] || [ $GIS_FLAG_S -eq 1 ] || [ $GIS_FLAG_U -eq 1 ] ; then
+ SYSADMIN=1
+ PREFIX="$GISBASE"
+ # just to make later tests happy
+ if [ $GIS_FLAG_S -eq 0 ] && [ $GIS_FLAG_U -eq 1 ] ; then
+ GIS_FLAG_S=1
+ fi
+elif [ "$PREFIX" = '$GRASS_ADDON_PATH' ] ; then
if [ -z "$GRASS_ADDON_PATH" ] ; then
g.message -w message="GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/"
ADDON_PATH_EMPTY=true
@@ -220,14 +229,6 @@
GRASS_ADDON_PATH1=`echo "$GRASS_ADDON_PATH" | cut -f1 -d:`
fi
PREFIX="$GRASS_ADDON_PATH1"
-elif [ "$PREFIX" = '$GISBASE' ] || [ $GIS_FLAG_S -eq 1 ] || [ $GIS_FLAG_U -eq 1 ] ; then
- SYSADMIN=1
- PREFIX="$GISBASE"
- # just to make later tests happy
- if [ $GIS_FLAG_S -eq 0 ] && [ $GIS_FLAG_U -eq 1 ] ; then
- GIS_FLAG_S=1
- fi
fi
@@ -243,8 +244,8 @@
MYINST_DIR="$PREFIX"
fi
-if [ ! -w "$PREFIX" -a $SYSADMIN -ne 1 ] ; then
- g.message -e "'$PREFIX' is not writable (are you logged in as the system administator?)"
+if [ ! -w "$PREFIX" -a "$SYSADMIN" -ne 1 ] ; then
+ g.message -e "'$PREFIX' is not writable (do you have suitable file-system permissions?)"
exit 1
fi
@@ -265,8 +266,8 @@
if [ "$GIS_OPT_OPERATION" = "remove" ] ; then
g.message message="Removing <$MODULE>..."
- if test -f "${MYINST_DIR}/bin/${MODULE}" ; then
- rm -f "${MYINST_DIR}/bin/${MODULE}"
+ if test -f "$MYINST_DIR/bin/$MODULE" ; then
+ rm -f "$MYINST_DIR/bin/$MODULE"
fi
if test -f "$MYINST_DIR/scripts/$MODULE" ; then
rm -f "$MYINST_DIR/scripts/$MODULE"
@@ -274,12 +275,12 @@
if test -e "$MYINST_DIR/$MODULE" ; then
rm -f "$MYINST_DIR/$MODULE"
fi
- if test -f "${MYINST_DIR}/docs/html/${MODULE}.html" ; then
- rm -f "${MYINST_DIR}/docs/html/${MODULE}.html"
+ if test -f "$MYINST_DIR/docs/html/$MODULE.html" ; then
+ rm -f "$MYINST_DIR/docs/html/$MODULE.html"
#also html/$MODULE*.jpg, html/$MODULE*.png
fi
- if test -f "${MYINST_DIR}/man/man1/${MODULE}.1" ; then
- rm -f "${MYINST_DIR}/man/man1/${MODULE}.1"
+ if test -f "$MYINST_DIR/man/man1/$MODULE.1" ; then
+ rm -f "$MYINST_DIR/man/man1/$MODULE.1"
fi
if test -f "$MYINST_DIR/docs/man/man1/$MODULE.1" ; then
rm -f "$MYINST_DIR/docs/man/man1/$MODULE.1"
@@ -293,7 +294,7 @@
cd "$TMPDIR"
g.message message="Fetching <$MODULE> from GRASS-Addons SVN (be patient)..."
-svn co "${SVNURL_ADDONS}/${MODULECLASS}/${MODULE}"
+svn co "$SVNURL_ADDONS/$MODULECLASS/$MODULE"
if [ $? -ne 0 ] ; then
g.message -e message="GRASS Add-on $MODULE not found in repository or no network connection or another problem"
@@ -332,8 +333,8 @@
export INST_NOW
make MODULE_TOPDIR="$GISBASE" \
- ARCH_INC="'-I$GISBASE/include' '-I${MYINST_DIR}/include' '-I$TMPDIR/$DIST_DIR/include'" \
- ARCH_LIBPATH="'-L$GISBASE/lib' '-L${MYINST_DIR}/lib' '-L$TMPDIR/$DIST_DIR/lib'" \
+ ARCH_INC="'-I$GISBASE/include' '-I$MYINST_DIR/include' '-I$TMPDIR/$DIST_DIR/include'" \
+ ARCH_LIBPATH="'-L$GISBASE/lib' '-L$MYINST_DIR/lib' '-L$TMPDIR/$DIST_DIR/lib'" \
ARCH_LIBDIR="$GISBASE/lib" \
ARCH_DISTDIR="$TMPDIR/$DIST_DIR" \
ARCH_BINDIR="$TMPDIR/$DIST_DIR/bin"
@@ -367,12 +368,14 @@
if [ $SYSADMIN -eq 1 ] ; then
if test -f "$MYINST_DIR/$PROGTYPE/$MODULE" ; then
- if [ $GIS_FLAG_U -eq 1 ] ; then
+ if [ "$GIS_FLAG_U" -eq 1 ] ; then
g.message "You may need to enter your password to remove an earlier copy of $MODULE:"
sudo rm -f "$MYINST_DIR/$PROGTYPE/$MODULE"
else
- g.message "You need to enter the root password to remove an earlier copy of $MODULE:"
- su -c "rm -f \"$MYINST_DIR/$PROGTYPE/$MODULE\""
+ rm -f "$MYINST_DIR/$PROGTYPE/$MODULE"
+ if [ $? -ne 0 ] ; then
+ g.message -w "Removal failed. Do you have suitable file-system permissions?"
+ fi
fi
fi
@@ -382,9 +385,10 @@
INST_DIR="$MYINST_DIR" install
else
- g.message "You need to enter the root password to install $MODULE:"
- su -c "make MODULE_TOPDIR=\"$GISBASE\" ARCH_DISTDIR=\"$TMPDIR/$DIST_DIR\" INST_DIR=\"$MYINST_DIR\" install"
+ make MODULE_TOPDIR="$GISBASE" \
+ ARCH_DISTDIR="$TMPDIR/$DIST_DIR" \
+ INST_DIR="$MYINST_DIR" \
+ install
fi
else
@@ -392,6 +396,7 @@
fi
+ # ? ETC="$MYINST_DIR/etc"
@@ -403,6 +408,7 @@
exit 1
fi
+ # clean up python installs, since PythonScript.make doesn't exist yet
if [ -e "$MYINST_DIR/$PROGTYPE/$MODULE.py" ] ; then
# drop the .py from python scripts
mv "$MYINST_DIR/$PROGTYPE/$MODULE.py" "$MYINST_DIR/$PROGTYPE/$MODULE"
