[GRASS-SVN] r56993 - grass/trunk/gui/scripts
svn_grass at osgeo.org
Wed Jul 3 02:03:36 PDT 2013
Author: turek
Date: 2013-07-03 02:03:36 -0700 (Wed, 03 Jul 2013)
New Revision: 56993
grass/trunk/gui/scripts/d.wms.py
d.wms:porting back most of Hamish Bowman's changes of the G6 r.in.wms2 module options (r56970)
Modified: grass/trunk/gui/scripts/d.wms.py
--- grass/trunk/gui/scripts/d.wms.py 2013-07-03 08:52:56 UTC (rev 56992)
+++ grass/trunk/gui/scripts/d.wms.py 2013-07-03 09:03:36 UTC (rev 56993)
@@ -16,28 +16,22 @@
#%module
-#% description: Downloads and displays data from WMS server.
+#% description: Downloads and displays data from WMS/WMTS/NASA OnEarth server.
#% keywords: raster
#% keywords: import
-#% keywords: wms
+#% keywords: WMS
+#% keywords: WMTS
+#% keywords: OnEarth
#%end
#%option
#% key: url
#% type: string
-#% description: URL of WMS server
+#% description: Typically starts with "http://"
#% required: yes
#%end
#%option
-#% key: layers
-#% type: string
-#% description: Layers to request from WMS server
-#% multiple: yes
-#% required: yes
-#%end
-#%option
#% key: map
#% type: string
#% description: Name for output WMS layer in the layer tree
@@ -45,20 +39,19 @@
#%end
#%option
-#% key: srs
-#% type: integer
-#% description: EPSG number of source projection for request
-#% answer:4326
-#% guisection: Request properties
+#% key: layers
+#% type: string
+#% description: Layer(s) to request from the map server
+#% multiple: yes
+#% required: yes
#%end
#%option
-#% key: wms_version
+#% key: styles
#% type: string
-#% description: WMS standard
-#% options: 1.1.1,1.3.0
-#% answer: 1.1.1
+#% description: Layer style(s) to request from the map server
+#% multiple: yes
+#% guisection: Map style
#%end
#%option
@@ -67,91 +60,102 @@
#% description: Image format requested from the server
#% options: geotiff,tiff,jpeg,gif,png
#% answer: geotiff
+#% guisection: Request
#%end
#%option
-#% key: method
-#% type: string
-#% description: Reprojection method to use
-#% options:nearest,linear,cubic,cubicspline
-#% answer:nearest
+#% key: srs
+#% type: integer
+#% description: EPSG code of requested source projection
+#% answer:4326
#%end
#%option
+#% key: driver
+#% type:string
+#% description: Driver used to communication with server
+#% descriptions: WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;
+#% options:WMS_GDAL, WMS_GRASS, WMTS_GRASS, OnEarth_GRASS
+#% answer:WMS_GRASS
+#% guisection: Connection
+#%end
+#%option
+#% key: wms_version
+#% type:string
+#% description: WMS standard version
+#% options: 1.1.1,1.3.0
+#% answer: 1.1.1
+#%end
+#%option
#% key: maxcols
#% type:integer
#% description: Maximum columns to request at a time
-#% answer:400
+#% answer:512
#%end
#%option
#% key: maxrows
#% type: integer
#% description: Maximum rows to request at a time
-#% answer: 300
+#% answer: 512
#%end
#%option
#% key: urlparams
#% type:string
-#% description: Additional query parameters for server
+#% description: Additional query parameters to pass to the server
#%end
#%option
#% key: username
#% type:string
#% description: Username for server connection
#%end
#%option
#% key: password
#% type:string
#% description: Password for server connection
#%end
#%option
-#% key: styles
+#% key: method
#% type: string
-#% description: Styles to request from map server
-#% multiple: yes
-#% guisection: Map style
+#% description: Interpolation method to use in reprojection
+#% options:nearest,linear,cubic,cubicspline
+#% answer:nearest
#%end
#%option
#% key: bgcolor
#% type: string
-#% description: Color of map background
+#% description: Background color
#%end
+#%option G_OPT_F_INPUT
+#% key: capfile
+#% required: no
+#% gisprompt: old,bin,file
+#% description: Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers
+#%end
#%flag
#% key: o
#% description: Don't request transparent data
#%end
-#%option
-#% key: driver
-#% type:string
-#% description: Driver for communication with server
-#% descriptions: WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;
-#% options:WMS_GDAL, WMS_GRASS, WMTS_GRASS, OnEarth_GRASS
-#% answer:WMS_GRASS
-#%end
-#%option G_OPT_F_INPUT
-#% key: capfile
-#% required: no
-#% gisprompt: old,file,bin_input
-#% description: Capabilities file to load
import os
import sys
