[GRASS-SVN] r56992 - grass/trunk/scripts/r.in.wms
svn_grass at osgeo.org
Wed Jul 3 01:52:56 PDT 2013
Author: turek
Date: 2013-07-03 01:52:56 -0700 (Wed, 03 Jul 2013)
New Revision: 56992
grass/trunk/scripts/r.in.wms/r.in.wms.py
grass/trunk/scripts/r.in.wms/wms_base.py
r.in.wms:porting back Hamish Bowman's changes from G6 r.in.wms2 (r56972, r56975 and r56986)
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py 2013-07-03 08:37:56 UTC (rev 56991)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py 2013-07-03 08:52:56 UTC (rev 56992)
@@ -179,7 +179,7 @@
def GetRegionParams(opt_region):
# set region
- if opt_region:
+ if opt_region:
reg_spl = opt_region.strip().split('@', 1)
reg_mapset = '.'
if len(reg_spl) > 1:
@@ -201,7 +201,6 @@
def main():
if 'GRASS' in options['driver']:
grass.debug("Using GRASS driver")
from wms_drv import WMSDrv
Modified: grass/trunk/scripts/r.in.wms/wms_base.py
--- grass/trunk/scripts/r.in.wms/wms_base.py 2013-07-03 08:37:56 UTC (rev 56991)
+++ grass/trunk/scripts/r.in.wms/wms_base.py 2013-07-03 08:52:56 UTC (rev 56992)
@@ -264,7 +264,7 @@
# print to output
cap_lines = cap.readlines()
for line in cap_lines:
- print line
+ print line.rstrip()
def _computeBbox(self):
"""!Get region extent for WMS query (bbox)
@@ -303,7 +303,8 @@
points = grass.read_command('m.proj', flags = 'd',
proj_output = self.proj_srs,
proj_input = self.proj_location,
- input = temp_region) # TODO: stdin
+ input = temp_region,
+ quiet = True) # TODO: stdin
grass.try_remove(temp_region)
if not points:
grass.fatal(_("Unable to determine region, %s failed") % 'm.proj')
@@ -523,6 +524,7 @@
output = self.opt_output ) != 0:
grass.fatal(_('%s failed') % 'r.composite')
+ grass.message(_('<%s> created.') % self.opt_output)
class WMSDriversInfo:
def __init__(self):
