[GRASS-SVN] r56991 - grass/trunk/scripts/r.in.wms
svn_grass at osgeo.org
Wed Jul 3 01:37:57 PDT 2013
Author: turek
Date: 2013-07-03 01:37:56 -0700 (Wed, 03 Jul 2013)
New Revision: 56991
grass/trunk/scripts/r.in.wms/r.in.wms.py
r.in.wms:porting back most of Hamish Bowman's changes of the module options from G6 r.in.wms2 (r56970)
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py 2013-07-03 08:04:33 UTC (rev 56990)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py 2013-07-03 08:37:56 UTC (rev 56991)
@@ -4,7 +4,7 @@
AUTHOR(S): Stepan Turek <stepan.turek AT seznam.cz>
-PURPOSE: Downloads and imports data from WMS server.
+PURPOSE: Downloads and imports data from WMS/WMTS/NASA OnEarth server.
COPYRIGHT: (C) 2012 Stepan Turek, and by the GRASS Development Team
@@ -13,160 +13,163 @@
#%module
-#% description: Downloads and imports data from WMS server.
+#% description: Downloads and imports data from WMS/WMTS/NASA OnEarth server.
#% keywords: raster
#% keywords: import
#% keywords: WMS
+#% keywords: WMTS
+#% keywords: OnEarth
#%end
#%option
#% key: url
#% type: string
-#% description: URL of WMS server
+#% description: Typically starts with "http://"
#% required: yes
#%end
+#%option G_OPT_R_OUTPUT
+#% description: Name for output raster map
+#%end
#%option
#% key: layers
#% type: string
-#% description: Layers to request from WMS server
+#% description: Layer(s) to request from the map server
#% multiple: yes
#% required: yes
#%end
-#%option G_OPT_R_OUTPUT
-#% description: Name for output raster map
+#%option
+#% key: styles
+#% type: string
+#% description: Layer style(s) to request from the map server
+#% multiple: yes
+#% guisection: Map style
#%end
#%option
+#% key: format
+#% type: string
+#% description: Image format requested from the server
+#% options: geotiff,tiff,jpeg,gif,png
+#% answer: geotiff
+#% guisection: Request
+#%end
+#%option
#% key: srs
#% type: integer
-#% description: EPSG number of source projection for request
+#% description: EPSG code of requested source projection
#% answer:4326
-#% guisection: Request properties
#%end
#%option
-#% key: region
-#% type: string
-#% description: Named region to request data for. Current region used if omitted
+#% key: driver
+#% type:string
+#% description: Driver used to communication with server
+#% descriptions: WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;
+#% options:WMS_GDAL, WMS_GRASS, WMTS_GRASS, OnEarth_GRASS
+#% answer:WMS_GRASS
+#% guisection: Connection
#%end
#%option
#% key: wms_version
#% type:string
-#% description: WMS standard
+#% description: WMS standard version
#% options: 1.1.1,1.3.0
#% answer: 1.1.1
#%end
#%option
-#% key: format
-#% type: string
-#% description: Image format requested from the server
-#% options: geotiff,tiff,jpeg,gif,png
-#% answer: geotiff
-#%end
-#%option
-#% key: method
-#% type: string
-#% description: Reprojection method to use
-#% options:nearest,linear,cubic,cubicspline
-#% answer:nearest
-#%end
-#%option
#% key: maxcols
#% type:integer
#% description: Maximum columns to request at a time
-#% answer:400
+#% answer:512
#%end
#%option
#% key: maxrows
#% type: integer
#% description: Maximum rows to request at a time
-#% answer: 300
+#% answer: 512
#%end
#%option
#% key: urlparams
#% type:string
-#% description: Additional query parameters for server
+#% description: Additional query parameters to pass to the server
#%end
#%option
#% key: username
#% type:string
#% description: Username for server connection
#%end
#%option
#% key: password
#% type:string
#% description: Password for server connection
#%end
#%option
-#% key: styles
+#% key: method
#% type: string
-#% description: Styles to request from map server
-#% multiple: yes
-#% guisection: Map style
+#% description: Interpolation method to use in reprojection
+#% options:nearest,linear,cubic,cubicspline
+#% answer:nearest
#%end
#%option
-#% key: bgcolor
+#% key: region
#% type: string
-#% description: Color of map background
+#% description: Request data for this named region instead of the current region bounds
#%end
-#%flag
-#% key: o
-#% description: Don't request transparent data
+#%option
+#% key: bgcolor
+#% type: string
+#% description: Background color
#%end
-#%flag
-#% key: c
-#% description: Get capabilities
-#% suppress_required: yes
-#%end
-#%option
-#% key: driver
-#% type:string
-#% description: Driver for communication with server
-#% descriptions: WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;
-#% options:WMS_GDAL, WMS_GRASS, WMTS_GRASS, OnEarth_GRASS
-#% answer:WMS_GRASS
-#%end
#%option G_OPT_F_INPUT
#% key: capfile
#% required: no
#% gisprompt: old,bin,file
-#% description: Capabilities file to load
+#% description: Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers
#%end
#%option G_OPT_F_OUTPUT
#% key: capfile_output
#% required: no
-#% description: File where capabilities will be saved (only with 'c' flag).
+#% description: File in which the server capabilities will be saved ('c' flag)
#%end
+#%flag
+#% key: c
+#% description: Get the server capabilities then exit
+#% suppress_required: yes
+#%end
+#%flag
+#% key: o
+#% description: Don't request transparent data
+#%end
import os
import sys
sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'r.in.wms'))
