[GRASS-SVN] r57134 - in grass/trunk: gui/wxpython/scripts scripts scripts/v.krige
svn_grass at osgeo.org
Mon Jul 15 02:53:58 PDT 2013
Author: aghisla
Date: 2013-07-15 02:53:58 -0700 (Mon, 15 Jul 2013)
New Revision: 57134
grass/trunk/gui/wxpython/scripts/vkrige.py
grass/trunk/scripts/Makefile
grass/trunk/scripts/v.krige/v.krige.py
Removed global variables from GUI and core scripts.
Modified: grass/trunk/gui/wxpython/scripts/vkrige.py
--- grass/trunk/gui/wxpython/scripts/vkrige.py 2013-07-15 09:49:51 UTC (rev 57133)
+++ grass/trunk/gui/wxpython/scripts/vkrige.py 2013-07-15 09:53:58 UTC (rev 57134)
@@ -463,14 +463,13 @@
column = self.parent.InputDataColumn.GetValue()
# import data or pick them up
- if globals()["InputData"] is None:
- globals()["InputData"] = controller.ImportMap(map = map,
+ if self.controller.InputData is None:
+ self.controller.InputData = controller.ImportMap(map = map,
column = column)
# fit the variogram or pick it up
Formula = controller.ComposeFormula(column = column,
isblock = self.KrigingRadioBox.GetStringSelection() == "Block kriging",
- inputdata = globals()['InputData'])
- #if globals()["Variogram"] is None:
+ inputdata = self.controller.InputData)
if hasattr(self, 'VariogramCheckBox') and self.VariogramCheckBox.IsChecked():
self.model = ''
for each in ("Sill","Nugget","Range"):
@@ -484,8 +483,8 @@
if getattr(self, each+'ChextBox').IsChecked(): #@FIXME will be removed when chextboxes will be frozen
setattr(self, each.lower(), getattr(self, each+"Ctrl").GetValue())
- globals()["Variogram"] = controller.FitVariogram(Formula,
- InputData,
+ self.controller.Variogram = controller.FitVariogram(Formula,
+ self.controller.InputData,
model = self.model,
sill = self.sill,
nugget = self.nugget,
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile 2013-07-15 09:49:51 UTC (rev 57133)
+++ grass/trunk/scripts/Makefile 2013-07-15 09:53:58 UTC (rev 57134)
@@ -68,9 +68,9 @@
v.pack \
v.unpack \
v.what.vect \
- wxpyimgview
+ wxpyimgview \
-# v.krige \
+ v.krige \
# r.mapcalculator \
# r3.mapcalculator \
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py 2013-07-15 09:49:51 UTC (rev 57133)
+++ grass/trunk/scripts/v.krige/v.krige.py 2013-07-15 09:53:58 UTC (rev 57134)
@@ -124,18 +124,26 @@
# globals
-Command = None
-InputData = None
-Variogram = None
-VariogramFunction = None
-robjects = None
-rinterface = None
+#~ Command = None
+#~ InputData = None
+#~ Variogram = None
+#~ VariogramFunction = None
+#~ robjects = None
+#~ rinterface = None
#classes in alphabetical order. methods in logical order :)
# <2.5 class definition, without () - please test
class Controller:
""" Executes analysis. For the moment, only with gstat functions."""
+ # moved here the global variables
+ def __init__(self):
+ #~ self.Command = None
+ self.InputData = None
+ self.Variogram = None
+ #~ VariogramFunction = None
+ #~ robjects = None
+ #~ rinterface = None
def ImportMap(self, map, column):
""" Imports GRASS map as SpatialPointsDataFrame and adds x/y columns to attribute table.
@@ -252,20 +260,20 @@
"exponentially with resolution." % grass.region()['cells']))
logger.message(_("Importing data..."))
- globals()["InputData"] = self.ImportMap(input, column)
+ if self.InputData is None:
+ self.InputData = self.ImportMap(input, column)
# and from here over, InputData refers to the global variable
#print(robjects.r.slot(InputData, 'data').names)
logger.message(_("Data successfully imported."))
- GridPredicted = self.CreateGrid(InputData)
+ GridPredicted = self.CreateGrid(self.InputData)
logger.message(_("Fitting variogram..."))
isblock = block is not ''
- Formula = self.ComposeFormula(column, isblock, InputData)
- if globals()["Variogram"] is None:
- globals()["Variogram"] = self.FitVariogram(Formula,
- InputData,
+ Formula = self.ComposeFormula(column, isblock, self.InputData)
+ if self.Variogram is None:
+ self.Variogram = self.FitVariogram(Formula,
+ self.InputData,
model = model,
sill = sill,
nugget = nugget,
@@ -273,8 +281,8 @@
logger.message(_("Variogram fitting complete."))
logger.message(_("Kriging..."))
- KrigingResult = self.DoKriging(Formula, InputData,
- GridPredicted, Variogram['variogrammodel'], block) # using global ones
+ KrigingResult = self.DoKriging(Formula, self.InputData,
+ GridPredicted, self.Variogram['variogrammodel'], block) # using global ones
logger.message(_("Kriging complete."))
self.ExportMap(map = KrigingResult,
@@ -282,14 +290,14 @@
name = output,
overwrite = overwrite,
command = command,
- variograms = Variogram)
+ variograms = self.Variogram)
if output_var is not '':
column='var1.var',
name = output_var,
command = command,
def main(argv = None):
""" Main. Calls either GUI or CLI, depending on arguments provided. """
