[GRASS-SVN] r57135 - grass/trunk/scripts/v.krige
svn_grass at osgeo.org
Mon Jul 15 03:41:38 PDT 2013
Author: aghisla
Date: 2013-07-15 03:41:38 -0700 (Mon, 15 Jul 2013)
New Revision: 57135
grass/trunk/scripts/v.krige/v.krige.html
Documentation updated with meaningful parameters for CLI run.
Modified: grass/trunk/scripts/v.krige/v.krige.html
--- grass/trunk/scripts/v.krige/v.krige.html 2013-07-15 09:53:58 UTC (rev 57134)
+++ grass/trunk/scripts/v.krige/v.krige.html 2013-07-15 10:41:38 UTC (rev 57135)
@@ -86,7 +86,7 @@
elevation raster, as if it came from a point survey.
<div class="code"><pre>
- g.region rast=elevation.10m -p
+ g.region rast=elevation.10m -res=150 -p
v.random output=rand2k_elev n=2000
v.db.addtable map=rand2k_elev column="elevation double precision"
v.what.rast vect=rand2k_elev rast=elevation.10m column=elevation
@@ -128,9 +128,9 @@
v.krige input=rand2k_elev_filt column=elevation output=rand2k_elev_kriging \
output_var=rand2k_elev_kriging_var
- v.krige input=rand2k_elev_filt column=elevation output=rand2k_elev_kriging \
- output_var=rand2k_elev_kriging_var model=Lin sill=2500 nugget=0 range=1000 \
- --overwrite
+ v.krige input=rand2k_elev_filt column=elevation \
+ output=rand2k_elev_filt_kriging output_var=rand2k_elev_filt_kriging_var\
+ model=Mat sill=2500 nugget=0 range=1000
</pre></div>
Or run wxGUI, to interactively fit the variogram and explore options:
