[GRASS-SVN] r57136 - grass/trunk/gui/wxpython/scripts
svn_grass at osgeo.org
Mon Jul 15 03:42:46 PDT 2013
Author: aghisla
Date: 2013-07-15 03:42:46 -0700 (Mon, 15 Jul 2013)
New Revision: 57136
grass/trunk/gui/wxpython/scripts/vkrige.py
Fixed variable names in gui script.
Modified: grass/trunk/gui/wxpython/scripts/vkrige.py
--- grass/trunk/gui/wxpython/scripts/vkrige.py 2013-07-15 10:41:38 UTC (rev 57135)
+++ grass/trunk/gui/wxpython/scripts/vkrige.py 2013-07-15 10:42:46 UTC (rev 57136)
@@ -464,10 +464,10 @@
# import data or pick them up
if self.controller.InputData is None:
- self.controller.InputData = controller.ImportMap(map = map,
+ self.controller.InputData = self.controller.ImportMap(map = map,
column = column)
# fit the variogram or pick it up
- Formula = controller.ComposeFormula(column = column,
+ Formula = self.controller.ComposeFormula(column = column,
isblock = self.KrigingRadioBox.GetStringSelection() == "Block kriging",
inputdata = self.controller.InputData)
if hasattr(self, 'VariogramCheckBox') and self.VariogramCheckBox.IsChecked():
@@ -483,7 +483,7 @@
if getattr(self, each+'ChextBox').IsChecked(): #@FIXME will be removed when chextboxes will be frozen
setattr(self, each.lower(), getattr(self, each+"Ctrl").GetValue())
- self.controller.Variogram = controller.FitVariogram(Formula,
+ self.controller.Variogram = self.controller.FitVariogram(Formula,
self.controller.InputData,
model = self.model,
sill = self.sill,
