[GRASS-SVN] r57174 - in grass/trunk/scripts: . db.univar
svn_grass at osgeo.org
Tue Jul 16 07:32:03 PDT 2013
Author: mmetz
Date: 2013-07-16 07:32:03 -0700 (Tue, 16 Jul 2013)
New Revision: 57174
Added:
grass/trunk/scripts/db.univar/
grass/trunk/scripts/db.univar/db.univar.html
grass/trunk/scripts/db.univar/db.univar.py
Removed:
grass/trunk/scripts/db.univar/v.db.univar.html
grass/trunk/scripts/db.univar/v.db.univar.py
grass/trunk/scripts/db.univar/Makefile
v.db.univar -> db.univar
Modified: grass/trunk/scripts/db.univar/Makefile
--- grass/trunk/scripts/v.db.univar/Makefile 2013-07-15 09:34:49 UTC (rev 57131)
+++ grass/trunk/scripts/db.univar/Makefile 2013-07-16 14:32:03 UTC (rev 57174)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM=v.db.univar
+PGM=db.univar
include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/scripts/db.univar/db.univar.html (from rev 57131, grass/trunk/scripts/v.db.univar/v.db.univar.html)
--- grass/trunk/scripts/db.univar/db.univar.html (rev 0)
+++ grass/trunk/scripts/db.univar/db.univar.html 2013-07-16 14:32:03 UTC (rev 57174)
@@ -0,0 +1,41 @@
+<h2>DESCRIPTION</h2>
+<em>v.db.univar</em> calculates basic univariate statistics for numeric
+attributes in a data table. It will calculate minimum, maximum, range, mean,
+standard deviation, variance, coefficient of variation, quartiles, median, and
+90th percentile.
+It uses <em>db.select</em> to create list values for statistical calculations.
+<em>NOTES</em>
+If the database and driver are not specified, the default values set in
+<em>db.connect</em> will be used.
+<h2>EXAMPLE</h2>
+In this example, random points are sampled from the elevation map
+(North Carolina sample dataset) and univariate statistics performed:
+<div class="code"><pre>
+g.region rast=elevation -p
+v.random output=samples n=100
+v.db.addtable samples column="heights double precision"
+v.what.rast samples raster=elevation colum=heights
+v.db.select samples
+v.db.univar samples colum=heights
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.univar.html">r.univar</a>,
+<a href="v.univar.html">v.univar,</a>,
+<a href="db.select.html">db.select</a>,
+<a href="d.vect.thematic.html">d.vect.thematic</a>
+</em>
+<h2>AUTHOR</h2>
+ Michael Barton, Arizona State University
+<p>and authors of <em>r.univar.sh</em>
+<p><i>Last changed: $Date$</i>
Copied: grass/trunk/scripts/db.univar/db.univar.py (from rev 57131, grass/trunk/scripts/v.db.univar/v.db.univar.py)
--- grass/trunk/scripts/db.univar/db.univar.py (rev 0)
+++ grass/trunk/scripts/db.univar/db.univar.py 2013-07-16 14:32:03 UTC (rev 57174)
@@ -0,0 +1,259 @@
+#!/usr/bin/env python
+# MODULE: db.univar (formerly called v.univar.sh)
+# AUTHOR(S): Michael Barton, Arizona State University
+# Converted to Python by Glynn Clements
+# Sync'ed to r.univar by Markus Metz
+# PURPOSE: Calculates univariate statistics from a GRASS vector map attribute column.
+# Based on r.univar.sh by Markus Neteler
+# COPYRIGHT: (C) 2005, 2007, 2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calculates univariate statistics on selected table column.
+#% keywords: database
+#% keywords: statistics
+#% keywords: attribute table
+#%end
+#%option G_OPT_DB_TABLE
+#% key: table
+#% required: yes
+#%end
+#%option G_OPT_DB_COLUMN
+#% description: Name of attribute column on which to calculate statistics (must be numeric)
+#% required: yes
+#%end
+#%option G_OPT_DB_DATABASE
+#%end
+#%option G_OPT_DB_DRIVER
+#% options: dbf,odbc,ogr,sqlite,pg
+#%end
+#%option G_OPT_DB_WHERE
+#%end
+#%option
+#% key: percentile
+#% type: double
+#% description: Percentile to calculate (requires extended statistics flag)
+#% required : no
+#% answer: 90
+#% options: 0-100
+#% multiple: yes
+#%end
+#%flag
+#% key: e
+#% description: Extended statistics (quartiles and 90th percentile)
+#%end
+#%flag
+#% key: g
+#% description: Print stats in shell script style
+#%end
+import sys
+import os
+import atexit
+import math
+from grass.script import core as grass
+def cleanup():
+ for ext in ['', '.sort']:
+ grass.try_remove(tmp + ext)
+def sortfile(infile, outfile):
+ inf = file(infile, 'r')
+ outf = file(outfile, 'w')
+ if grass.find_program('sort'):
+ grass.run_command('sort', flags = 'n', stdin = inf, stdout = outf)
+ else:
+ # FIXME: we need a large-file sorting function
+ grass.warning(_("'sort' not found: sorting in memory"))
+ lines = inf.readlines()
+ for i in range(len(lines)):
+ lines[i] = float(lines[i].rstrip('\r\n'))
+ lines.sort()
+ for line in lines:
+ outf.write(str(line) + '\n')
+ inf.close()
+ outf.close()
+def main():
+ global tmp
+ tmp = grass.tempfile()
+ extend = flags['e']
+ shellstyle = flags['g']
+ table = options['table']
+ column = options['column']
+ database = options['database']
+ driver = options['driver']
+ where = options['where']
+ perc = options['percentile']
+ if perc and len(perc) > 0:
+ extend = True
+ perc = [float(p) for p in perc.split(',')]
+ if not shellstyle:
+ grass.message(_("Calculation for column <%s> of table <%s>...") % (column, table))
+ grass.message(_("Reading column values..."))
+ sql = "SELECT %s FROM %s" % (column, table)
+ if where:
+ sql += " WHERE " + where
+ if not database:
+ database = None
+ if not driver:
+ driver = None
+ tmpf = file(tmp, 'w')
+ grass.run_command('db.select', flags = 'c', table = table,
+ database = database, driver = driver, sql = sql,
+ stdout = tmpf)
+ tmpf.close()
+ # check if result is empty
+ tmpf = file(tmp)
+ if tmpf.read(1) == '':
+ grass.fatal(_("Table <%s> contains no data.") % table)
+ tmpf.close()
+ # calculate statistics
+ grass.message(_("Calculating statistics..."))
+ N = 0
+ sum = 0.0
+ sum2 = 0.0
+ sum3 = 0.0
+ minv = 1e300
+ maxv = -1e300
+ tmpf = file(tmp)
+ for line in tmpf:
+ if len(line.rstrip('\r\n')) == 0:
+ continue
+ x = float(line.rstrip('\r\n'))
+ N += 1
+ sum += x
+ sum2 += x * x
+ sum3 += abs(x)
+ maxv = max(maxv, x)
+ minv = min(minv, x)
+ tmpf.close()
+ if N <= 0:
+ grass.fatal(_("No non-null values found"))
+ print ""
+ print "Number of values: %d" % N
+ print "Minimum: %g" % minv
+ print "Maximum: %g" % maxv
+ print "Range: %g" % (maxv - minv)
+ print "-----"
+ print "Mean: %g" % (sum/N)
+ print "Arithmetic mean of absolute values: %g" % (sum3/N)
+ print "Variance: %g" % ((sum2 - sum*sum/N)/N)
+ print "Standard deviation: %g" % (math.sqrt((sum2 - sum*sum/N)/N))
+ print "Coefficient of variation: %g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
+ print "Sum: %g" % sum
+ print "-----"
+ else:
+ print "n=%d" % N
+ print "min=%.15g" % minv
+ print "max=%.15g" % maxv
+ print "range=%.15g" % (maxv - minv)
+ print "mean=%.15g" % (sum/N)
+ print "mean_abs=%.15g" % (sum3/N)
+ print "variance=%.15g" % ((sum2 - sum*sum/N)/N)
+ print "stddev=%.15g" % (math.sqrt((sum2 - sum*sum/N)/N))
+ print "coeff_var=%.15g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
+ print "sum=%.15g" % sum
+ if not extend:
+ return
+ # preparations:
+ sortfile(tmp, tmp + ".sort")
+ number = N
+ odd = N % 2
+ eostr = ['even','odd'][odd]
+ q25pos = round(N * 0.25)
+ if q25pos == 0:
+ q25pos = 1
+ q50apos = round(N * 0.50)
+ if q50apos == 0:
+ q50apos = 1
+ q50bpos = q50apos + (1 - odd)
+ q75pos = round(N * 0.75)
+ if q75pos == 0:
+ q75pos = 1
+ ppos = {}
+ pval = {}
+ for i in range(len(perc)):
+ ppos[i] = round(N * perc[i] / 100)
+ if ppos[i] == 0:
+ ppos[i] = 1
+ pval[i] = 0
+ inf = file(tmp + ".sort")
+ l = 1
+ for line in inf:
+ if l == q25pos:
+ q25 = float(line.rstrip('\r\n'))
+ if l == q50apos:
+ q50a = float(line.rstrip('\r\n'))
+ if l == q50bpos:
+ q50b = float(line.rstrip('\r\n'))
+ if l == q75pos:
+ q75 = float(line.rstrip('\r\n'))
+ for i in range(len(ppos)):
+ if l == ppos[i]:
+ pval[i] = float(line.rstrip('\r\n'))
+ l += 1
+ q50 = (q50a + q50b) / 2
+ print "1st Quartile: %g" % q25
+ print "Median (%s N): %g" % (eostr, q50)
+ print "3rd Quartile: %g" % q75
+ if perc[i] == int(perc[i]): # integer
+ if int(perc[i]) % 10 == 1 and int(perc[i]) != 11:
+ print "%dst Percentile: %g" % (int(perc[i]), pval[i])
+ elif int(perc[i]) % 10 == 2 and int(perc[i]) != 12:
+ print "%dnd Percentile: %g" % (int(perc[i]), pval[i])
+ elif int(perc[i]) % 10 == 3 and int(perc[i]) != 13:
+ print "%drd Percentile: %g" % (int(perc[i]), pval[i])
+ else:
+ print "%dth Percentile: %g" % (int(perc[i]), pval[i])
+ else:
+ print "%.15g Percentile: %g" % (perc[i], pval[i])
+ else:
+ print "first_quartile=%g" % q25
+ print "median=%g" % q50
+ print "third_quartile=%g" % q75
+ percstr = "%.15g" % perc[i]
+ percstr = percstr.replace('.','_')
+ print "percentile_%s=%g" % (percstr, pval[i])
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Deleted: grass/trunk/scripts/db.univar/v.db.univar.html
--- grass/trunk/scripts/v.db.univar/v.db.univar.html 2013-07-15 09:34:49 UTC (rev 57131)
+++ grass/trunk/scripts/db.univar/v.db.univar.html 2013-07-16 14:32:03 UTC (rev 57174)
@@ -1,41 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.db.univar</em> calculates basic univariate statistics for numeric
-attributes in a data table. It will calculate minimum, maximum, range, mean,
-standard deviation, variance, coefficient of variation, quartiles, median, and
-90th percentile.
-It uses <em>db.select</em> to create list values for statistical calculations.
-<em>NOTES</em>
-If the database and driver are not specified, the default values set in
-<em>db.connect</em> will be used.
-<h2>EXAMPLE</h2>
-In this example, random points are sampled from the elevation map
-(North Carolina sample dataset) and univariate statistics performed:
-<div class="code"><pre>
-g.region rast=elevation -p
-v.random output=samples n=100
-v.db.addtable samples column="heights double precision"
-v.what.rast samples raster=elevation colum=heights
-v.db.select samples
-v.db.univar samples colum=heights
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.univar.html">r.univar</a>,
-<a href="v.univar.html">v.univar,</a>,
-<a href="db.select.html">db.select</a>,
-<a href="d.vect.thematic.html">d.vect.thematic</a>
-</em>
-<h2>AUTHOR</h2>
- Michael Barton, Arizona State University
-<p>and authors of <em>r.univar.sh</em>
-<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/scripts/db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py 2013-07-15 09:34:49 UTC (rev 57131)
+++ grass/trunk/scripts/db.univar/v.db.univar.py 2013-07-16 14:32:03 UTC (rev 57174)
@@ -1,259 +0,0 @@
-#!/usr/bin/env python
-# MODULE: v.db.univar (formerly called v.univar.sh)
-# AUTHOR(S): Michael Barton, Arizona State University
-# Converted to Python by Glynn Clements
-# Sync'ed to r.univar by Markus Metz
-# PURPOSE: Calculates univariate statistics from a GRASS vector map attribute column.
-# Based on r.univar.sh by Markus Neteler
-# COPYRIGHT: (C) 2005, 2007, 2008 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-# TODO: this module should be named db.univar.
-# v.db.univar should have as input options vector and layer instead of table
-#%module
-#% description: Calculates univariate statistics on selected table column for a GRASS vector map.
-#% keywords: vector
-#% keywords: statistics
-#% keywords: attribute table
-#%end
-#%flag
-#% key: e
-#% description: Extended statistics (quartiles and 90th percentile)
-#%end
-#%flag
-#% key: g
-#% description: Print stats in shell script style
-#%end
-#%option G_OPT_DB_TABLE
-#% key: table
-#% required: yes
-#%end
-#%option G_OPT_DB_COLUMN
-#% description: Name of attribute column on which to calculate statistics (must be numeric)
-#% required: yes
-#%end
-#%option G_OPT_DB_DATABASE
-#%end
-#%option G_OPT_DB_DRIVER
-#% options: dbf,odbc,ogr,sqlite,pg
-#%end
-#%option G_OPT_DB_WHERE
-#%end
-#%option
-#% key: percentile
-#% type: double
-#% description: Percentile to calculate (requires extended statistics flag)
-#% required : no
-#% answer: 90
-#% options: 0-100
-#% multiple: yes
-#%end
-import sys
-import os
-import atexit
-import math
-from grass.script import core as grass
-def cleanup():
- for ext in ['', '.sort']:
- grass.try_remove(tmp + ext)
-def sortfile(infile, outfile):
- inf = file(infile, 'r')
- outf = file(outfile, 'w')
- if grass.find_program('sort'):
- grass.run_command('sort', flags = 'n', stdin = inf, stdout = outf)
- else:
- # FIXME: we need a large-file sorting function
- grass.warning(_("'sort' not found: sorting in memory"))
- lines = inf.readlines()
- for i in range(len(lines)):
- lines[i] = float(lines[i].rstrip('\r\n'))
- lines.sort()
- for line in lines:
- outf.write(str(line) + '\n')
- inf.close()
- outf.close()
-def main():
- global tmp
- tmp = grass.tempfile()
- extend = flags['e']
- shellstyle = flags['g']
- table = options['table']
- column = options['column']
- database = options['database']
- driver = options['driver']
- where = options['where']
- perc = options['percentile']
- perc = [float(p) for p in perc.split(',')]
- if not shellstyle:
- grass.message(_("Calculation for column <%s> of table <%s>...") % (column, table))
- grass.message(_("Reading column values..."))
- sql = "SELECT %s FROM %s" % (column, table)
- if where:
- sql += " WHERE " + where
- if not database:
- database = None
- if not driver:
- driver = None
- tmpf = file(tmp, 'w')
- grass.run_command('db.select', flags = 'c', table = table,
- database = database, driver = driver, sql = sql,
- stdout = tmpf)
- tmpf.close()
- # check if result is empty
- tmpf = file(tmp)
- if tmpf.read(1) == '':
- grass.fatal(_("Table <%s> contains no data.") % table)
- tmpf.close()
- # calculate statistics
- grass.message(_("Calculating statistics..."))
- N = 0
- sum = 0.0
- sum2 = 0.0
- sum3 = 0.0
- minv = 1e300
- maxv = -1e300
- tmpf = file(tmp)
- for line in tmpf:
- if len(line.rstrip('\r\n')) == 0:
- continue
- x = float(line.rstrip('\r\n'))
- N += 1
- sum += x
- sum2 += x * x
- sum3 += abs(x)
- maxv = max(maxv, x)
- minv = min(minv, x)
- tmpf.close()
- if N <= 0:
- grass.fatal(_("No non-null values found"))
- print ""
- print "Number of values: %d" % N
- print "Minimum: %g" % minv
- print "Maximum: %g" % maxv
- print "Range: %g" % (maxv - minv)
- print "-----"
- print "Mean: %g" % (sum/N)
- print "Arithmetic mean of absolute values: %g" % (sum3/N)
- print "Variance: %g" % ((sum2 - sum*sum/N)/N)
- print "Standard deviation: %g" % (math.sqrt((sum2 - sum*sum/N)/N))
- print "Coefficient of variation: %g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
- print "Sum: %g" % sum
- print "-----"
- else:
- print "n=%d" % N
- print "min=%.15g" % minv
- print "max=%.15g" % maxv
- print "range=%.15g" % (maxv - minv)
- print "mean=%.15g" % (sum/N)
- print "mean_abs=%.15g" % (sum3/N)
- print "variance=%.15g" % ((sum2 - sum*sum/N)/N)
- print "stddev=%.15g" % (math.sqrt((sum2 - sum*sum/N)/N))
- print "coeff_var=%.15g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
- print "sum=%.15g" % sum
- if not extend:
- return
- # preparations:
- sortfile(tmp, tmp + ".sort")
- number = N
- odd = N % 2
- eostr = ['even','odd'][odd]
- q25pos = round(N * 0.25)
- if q25pos == 0:
- q25pos = 1
- q50apos = round(N * 0.50)
- if q50apos == 0:
- q50apos = 1
- q50bpos = q50apos + (1 - odd)
- q75pos = round(N * 0.75)
- if q75pos == 0:
- q75pos = 1
- ppos = {}
- pval = {}
- for i in range(len(perc)):
- ppos[i] = round(N * perc[i] / 100)
- if ppos[i] == 0:
- ppos[i] = 1
- pval[i] = 0
- inf = file(tmp + ".sort")
- l = 1
- for line in inf:
- if l == q25pos:
- q25 = float(line.rstrip('\r\n'))
- if l == q50apos:
- q50a = float(line.rstrip('\r\n'))
- if l == q50bpos:
- q50b = float(line.rstrip('\r\n'))
- if l == q75pos:
- q75 = float(line.rstrip('\r\n'))
- for i in range(len(ppos)):
- if l == ppos[i]:
- pval[i] = float(line.rstrip('\r\n'))
- l += 1
- q50 = (q50a + q50b) / 2
- print "1st Quartile: %g" % q25
- print "Median (%s N): %g" % (eostr, q50)
- print "3rd Quartile: %g" % q75
- if perc[i] == int(perc[i]): # integer
- if int(perc[i]) % 10 == 1 and int(perc[i]) != 11:
- print "%dst Percentile: %g" % (int(perc[i]), pval[i])
- elif int(perc[i]) % 10 == 2 and int(perc[i]) != 12:
- print "%dnd Percentile: %g" % (int(perc[i]), pval[i])
- elif int(perc[i]) % 10 == 3 and int(perc[i]) != 13:
- print "%drd Percentile: %g" % (int(perc[i]), pval[i])
- else:
- print "%dth Percentile: %g" % (int(perc[i]), pval[i])
- else:
- print "%.15g Percentile: %g" % (perc[i], pval[i])
- else:
- print "first_quartile=%g" % q25
- print "median=%g" % q50
- print "third_quartile=%g" % q75
- percstr = "%.15g" % perc[i]
- percstr = percstr.replace('.','_')
- print "percentile_%s=%g" % (percstr, pval[i])
-if __name__ == "__main__":
- options, flags = grass.parser()
- atexit.register(cleanup)
- main()
