[GRASS-SVN] r57175 - grass/trunk/scripts/v.db.univar
Tue Jul 16 07:32:43 PDT 2013
Author: mmetz
Date: 2013-07-16 07:32:43 -0700 (Tue, 16 Jul 2013)
New Revision: 57175
   grass/trunk/scripts/v.db.univar/v.db.univar.py
v.db.univar works now with vector maps
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py	2013-07-16 14:32:03 UTC (rev 57174)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py	2013-07-16 14:32:43 UTC (rev 57175)
@@ -16,36 +16,21 @@
-# TODO: this module should be named db.univar.
-# v.db.univar should have as input options vector and layer instead of table
 #%module
 #% description: Calculates univariate statistics on selected table column for a GRASS vector map.
 #% keywords: vector
 #% keywords: statistics
 #% keywords: attribute table
 #%end
-#%flag
-#% key: e
-#% description: Extended statistics (quartiles and 90th percentile)
-#%end
-#%flag
-#% key: g
-#% description: Print stats in shell script style
-#%end
-#%option G_OPT_DB_TABLE
-#% key: table
+#%option G_OPT_V_MAP
 #% required: yes
 #%end
+#%option G_OPT_V_FIELD
+#%end
 #%option G_OPT_DB_COLUMN
 #% description: Name of attribute column on which to calculate statistics (must be numeric)
 #% required: yes
 #%end
-#%option G_OPT_DB_DATABASE
-#%end
-#%option G_OPT_DB_DRIVER
-#% options: dbf,odbc,ogr,sqlite,pg
-#%end
 #%option G_OPT_DB_WHERE
 #%end
 #%option
@@ -57,203 +42,52 @@
 #% options: 0-100
 #% multiple: yes
 #%end
+#%flag
+#% key: e
+#% description: Extended statistics (quartiles and 90th percentile)
+#%end
+#%flag
+#% key: g
+#% description: Print stats in shell script style
+#%end
 import sys
 import os
-import atexit
-import math
-from grass.script import core as grass
+import grass.script as grass
-def cleanup():
-    for ext in ['', '.sort']:
-        grass.try_remove(tmp + ext)
-def sortfile(infile, outfile):
-    inf = file(infile, 'r')
-    outf = file(outfile, 'w')
-    if grass.find_program('sort'):
-        grass.run_command('sort', flags = 'n', stdin = inf, stdout = outf)
-    else:
-        # FIXME: we need a large-file sorting function
-        grass.warning(_("'sort' not found: sorting in memory"))
-        lines = inf.readlines()
-        for i in range(len(lines)):
-            lines[i] = float(lines[i].rstrip('\r\n'))
-        lines.sort()
-        for line in lines:
-            outf.write(str(line) + '\n')
-    inf.close()
-    outf.close()
 def main():
     global tmp
     tmp = grass.tempfile()
-    extend = flags['e']
-    shellstyle = flags['g']
-    table = options['table']
+    vector = options['map']
+    layer = options['layer']
     column = options['column']
-    database = options['database']
-    driver = options['driver']
     where = options['where']
     perc = options['percentile']
+    extend = flags['e']
+    shellstyle = flags['g']
-    perc = [float(p) for p in perc.split(',')]
+    fi = grass.vector_db(vector, stderr = nuldev)[int(layer)]
+    table = fi['table']
+    database = fi['database']
+    driver = fi['driver']
+    passflags = None
+    if flags['e']:
+	passflags = 'e'
+    if flags['g']:
+	if not passflags:
+	    passflags = 'g'
+	else:
+	    passflags = passflags + 'g'
+    grass.run_command('db.univar', table = table, column = column,
+                      database = database, driver = driver,
+		      perc = perc, where = where, flags = passflags)
-    if not shellstyle:
-        grass.message(_("Calculation for column <%s> of table <%s>...") % (column, table))
-        grass.message(_("Reading column values..."))
-    sql = "SELECT %s FROM %s" % (column, table)
-    if where:
-        sql += " WHERE " + where
-    if not database:
-        database = None
-    if not driver:
-        driver = None
-    tmpf = file(tmp, 'w')
-    grass.run_command('db.select', flags = 'c', table = table,
-        database = database, driver = driver, sql = sql,
-        stdout = tmpf)
-    tmpf.close()
-    # check if result is empty
-    tmpf = file(tmp)
-    if tmpf.read(1) == '':
-        grass.fatal(_("Table <%s> contains no data.") % table)
-        tmpf.close()
-    # calculate statistics
-        grass.message(_("Calculating statistics..."))
-    N = 0
-    sum = 0.0
-    sum2 = 0.0
-    sum3 = 0.0
-    minv = 1e300
-    maxv = -1e300
-    tmpf = file(tmp)
-    for line in tmpf:
-	if len(line.rstrip('\r\n')) == 0:
-	    continue
-        x = float(line.rstrip('\r\n'))
-        N += 1
-        sum += x
-        sum2 += x * x
-        sum3 += abs(x)
-        maxv = max(maxv, x)
-        minv = min(minv, x)
-    tmpf.close()
-    if N <= 0:
-        grass.fatal(_("No non-null values found"))
-        print ""
-        print "Number of values: %d" % N
-        print "Minimum: %g" % minv
-        print "Maximum: %g" % maxv
-        print "Range: %g" % (maxv - minv)
-        print "-----"
-        print "Mean: %g" % (sum/N)
-        print "Arithmetic mean of absolute values: %g" % (sum3/N)
-        print "Variance: %g" % ((sum2 - sum*sum/N)/N)
-        print "Standard deviation: %g" % (math.sqrt((sum2 - sum*sum/N)/N))
-        print "Coefficient of variation: %g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
-        print "Sum: %g" % sum
-        print "-----"
-    else:
-        print "n=%d" % N
-        print "min=%.15g" % minv
-        print "max=%.15g" % maxv
-        print "range=%.15g" % (maxv - minv)
-        print "mean=%.15g" % (sum/N)
-        print "mean_abs=%.15g" % (sum3/N)
-        print "variance=%.15g" % ((sum2 - sum*sum/N)/N)
-        print "stddev=%.15g" % (math.sqrt((sum2 - sum*sum/N)/N))
-        print "coeff_var=%.15g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
-        print "sum=%.15g" % sum
-    if not extend:
-        return
-    # preparations:
-    sortfile(tmp, tmp + ".sort")
-    number = N
-    odd = N % 2
-    eostr = ['even','odd'][odd]
-    q25pos = round(N * 0.25)
-    if q25pos == 0:
-	q25pos = 1
-    q50apos = round(N * 0.50)
-    if q50apos == 0:
-	q50apos = 1
-    q50bpos = q50apos + (1 - odd)
-    q75pos = round(N * 0.75)
-    if q75pos == 0:
-	q75pos = 1
-    ppos = {}
-    pval = {}
-    for i in range(len(perc)):
-        ppos[i] = round(N * perc[i] / 100)
-	if ppos[i] == 0:
-	    ppos[i] = 1
-        pval[i] = 0
-    inf = file(tmp + ".sort")
-    l = 1
-    for line in inf:
-        if l == q25pos:
-            q25 = float(line.rstrip('\r\n'))
-        if l == q50apos:
-            q50a = float(line.rstrip('\r\n'))
-        if l == q50bpos:
-            q50b = float(line.rstrip('\r\n'))
-        if l == q75pos:
-            q75 = float(line.rstrip('\r\n'))
-        for i in range(len(ppos)):
-            if l == ppos[i]:
-                pval[i] = float(line.rstrip('\r\n'))
-        l += 1
-    q50 = (q50a + q50b) / 2
-        print "1st Quartile: %g" % q25
-        print "Median (%s N): %g" % (eostr, q50)
-        print "3rd Quartile: %g" % q75
-            if perc[i] == int(perc[i]): # integer
-                if int(perc[i]) % 10 == 1 and int(perc[i]) != 11:
-                    print "%dst Percentile: %g" % (int(perc[i]), pval[i])
-                elif int(perc[i]) % 10 == 2 and int(perc[i]) != 12:
-                    print "%dnd Percentile: %g" % (int(perc[i]), pval[i])
-                elif int(perc[i]) % 10 == 3 and int(perc[i]) != 13:
-                    print "%drd Percentile: %g" % (int(perc[i]), pval[i])
-                else:
-                    print "%dth Percentile: %g" % (int(perc[i]), pval[i])
-            else:
-                print "%.15g Percentile: %g" % (perc[i], pval[i])
-    else:
-        print "first_quartile=%g" % q25
-        print "median=%g" % q50
-        print "third_quartile=%g" % q75
-            percstr = "%.15g" % perc[i]
-            percstr = percstr.replace('.','_')
-            print "percentile_%s=%g" % (percstr, pval[i])
 if __name__ == "__main__":
     options, flags = grass.parser()
-    atexit.register(cleanup)
+    nuldev = file(os.devnull, 'w')
     main()
